	list      p=16F716            
	#include <p16F716.inc>     
	Errorlevel	-302
	__CONFIG   _CP_OFF & _WDT_OFF & _PWRTE_OFF & _HS_OSC  &_BODEN_OFF  ;&_VBOR_25
	cblock	0x20
			;	General	register's ,, Timer reg!
			x
			x1
			index
			tmr.period
			time.out
			slow,slow2
			loc
			servo.toogle
			tmr1l
			tmr1h
		wtf
		Transmission.enabled
			;	Switch register's
			switch
			Lamp
			;	Data register's
			dev		;	8 bit
			com		;	8 bit
			com2	;	8 bit
			extr		;	8 bit
			err		;	8 bit
			stop		;	2 bit
			com.out	
			extr.out
			com2.out
			coM
			flag	
			bit
			shift
	servo.carry
	bit2
			;	Save reg
			w_save
			status_save
			fsr_s	
			pclath_s
			intcon_s
			;  	Register's --LCD--		
			t1,t2,text.reg,turn,slide.reg,shift2
			lcd.shift,lcd.shift.dec,lcd.shift2,lcd.shift2.dec
			hun,hun1
			ten,ten1
			one,one1
			;	Analog reg
			ad.regh
			endc
			#define		pwm			CCPR1L
			#define		rs			PORTA,0
			#define		en			PORTA,1
			#define		dat			PORTB
			#define		in			PORTB,2
			#define		m.ena		PORTB,3
			#define		servo		PORTA,2
			#define		out			PORTB,1
			;	Transmission		Include File's				
			#include		Transmission.asm
			#include		Save.asm
			#include		Load.asm
			;		LCD	Include File's				
			#include		Ltctm.asm
			#include		slides3.asm
			#include		Character.def.asm
			#include		Lcd.Register.controll.asm
				Character.def		 ;#### Long.Macro
;			Reset vektor				
	org		0x00
	goto	Start
	org		0x04
					Save		 ;#### Short.Macro
;	  ###	Goto interrupt priority	###
;	btfsc	INTCON,T0IF
;	goto	Tmr0.interrupt
	btfsc	PIR1,TMR1IF
	goto	Tmr1.interrupt
;			Portb,0 interrupt			
Rb0.interrupt
	bcf		INTCON,INTF	
;			Start bit wait				
	btfsc	flag,0
	goto	Device.code		
;	Start bit maximum length			
	movlw	.162
	addwf	TMR0,w								
	skpnc										
	goto	Exit															
;	Start bit minimum length			
	movfw	TMR0
	sublw	.88	
	skpnc
	goto	Exit	
;			Start bit Ok!				
	bsf		flag,0
	goto	Load.Escape
					Transmission	 ;#### Short.Macro
Done
;		Succes.Protect					
;	movlw	.119
;	subwf	err,w
;	skpz
;	goto	Exit
;	movlw	.176
;	subwf	dev,w
;	skpz
;	goto	Exit
	movfw	com
	movwf	com.out
	movfw	com2
	movwf	com2.out
	movfw	extr
	movwf	extr.out
Exit
	clrf		flag
	clrf		dev
	clrf		bit
	clrf		com
	clrf		com2
	clrf		extr
	goto	Load.Escape
;		TMR1 interrupt!					
Tmr1.interrupt
	bcf		PIR1,TMR1IF
Load.Escape
					Load		 ;#### Short.Macro
;	#######	All Interrupt END #########	
;	Enter Bank1		Initializing		
Start	
	bsf			STATUS,5
	clrf			TRISB
	clrf			TRISA
	bsf			TRISB,0
	bsf			TRISA,3
;	bsf			TRISA,1		;	Servo.Analog ### !!!!!!!
	movlw		.0	
	movwf		ADCON1			
	movlw		0xff				
	movwf		PR2	
	bsf			PIE1,TMR1IE
		;	20Mhz Prescale 32 zero bit .110 Strat 50 - 195	
		;	20Mhz Prescale 64 zero bit .50 Strat 162 - 88	
		;	4Mhz Prescale 16 zero bit .40  Strat 170- 61	
		;	RF Module bit6 .. 1
		;	IR Module bit6 ...0
	movlw		b'01000101'
	movwf		OPTION_REG			
	bcf			STATUS,5				
;	###		Zero.bit over check		###	
	movlw		.50
	movwf		tmr.period
;	Megszakítás regiszetrek engedélyezése!
	bsf			INTCON,GIE
	bsf			INTCON,INTE
;	bsf			INTCON,T0IE
	bsf			INTCON,PEIE
	movlw	b'00000001'
	movwf	T1CON
;			pwm  in Engine driver		
 ;	clrf	 	TMR2 	
 ;	bsf 		T2CON,0 		
 ;	movlw 	b'00001100'	
;	movwf 	CCP1CON 	
 ;	bsf 		T2CON,2 
;	Segédregiszterek induláskor törlés	
	clrf	hun
	clrf	ten
	clrf	one
	clrf	hun1
	clrf	ten1
	clrf	one1
;#####################  	MAIN PROGRAM	################################
;Main
;	btfss	loc,0
;	goto	$-1
;Cycle
;	movfw	com.out
;	movwf	ad.regh
;	movlw	0
;	subwf	ad.regh,w
;	movlw	1
;	skpnz
;	movwf	ad.regh
;	bsf		servo
;	call		position
;	bcf		servo
;	call		t.20ms
;	decfsz	slow,f
;	goto	Cycle
;	movlw	.20
;	movwf	slow
;	bcf		loc,0
;	goto	Main
;position
;	decfsz	ad.regh,f
;	goto	_nop
;	movlw	.110
;	movwf	t1
;	movlw	.10
;	movwf	t2
;	decfsz	t2,f
;	goto	$-1
;	decfsz	t1,f
;	goto	$-5
;	return
;_nop
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	$+1
;	goto	position
;t.20ms
;	movlw	0xff
;	movwf	t1
;	movlw	.50
;	movwf	t2
;	decfsz	t2,f
;	goto	$-1
;	decfsz	t1,f
;	goto	$-5
;	return
;		### LCD Initailize	####		
	call		LCD.initialize
	movlw	1
	call		lcd.cmd
; 		###	INITIALIZING END ###		
				;		MAIN PROGRAM				
LCD
	movlw	.10
	subwf	extr.out,w
	skpnz
	bsf		out
	skpz
	bcf		out
	;	###	LCD LINE 1 ###############################
	movfw	extr.out
	movfw	com2.out
	movwf	lcd.shift
	movwf	lcd.shift.dec	
	;	###	LCD LINE 2 ###############################
	movfw	com.out
	movwf	lcd.shift2
	movwf	lcd.shift2.dec
				Lcd.Register.controll ;#### Long.Macro 
	goto	LCD
; 		###	Delay ... Subrutin's		 ###		
				Lcd.text.cmd.timer.macro ;### Long.Macro
	return
				slide.s3				;### Long.Macro 
	return
table					
    movwf    index			
	movlw	.11
	subwf	index,w
	movlw	.10
	skpnc
	movwf	index
    movlw    high(num)
    movwf    PCLATH
    movlw    low(num)
    addwf     index,w
    btfsc      STATUS,C
    incf    	    PCLATH,f
    movwf    PCL
num
	retlw		.48		;	0
	retlw		.49		;	1
	retlw		.50		;	2
	retlw		.51		;	3
	retlw		.52		;	4
	retlw		.53		;	5
	retlw		.54		;	6
	retlw		.55		;	7
	retlw		.56		;	8
	retlw		.57		;	9
	retlw		.58		;	L
;Inside.transmission
;	call		Start.15us
;	call		oFF
;	movlw	.200
;	movwf	servo.carry	
;	movlw	.8
;	movwf	bit2
;cycle
;	rrf		servo.carry,f
;	skpnc
;	call		one.50us
;	skpc
;	call		zero.25us
;	call		oFF
;	decfsz	bit2,f
;	goto	cycle
;	call		pajze
;	goto	Inside.transmission	
;Start.15us
;	bsf		out
;	movlw	.30
;	goto	clock
;one.50us
;	bsf		out
;	movlw	.75
;	goto	clock
;zero.25us
;	bsf		out
;	movlw	.50
;	goto	clock
;oFF
;	bcf		out
;	movlw	.30
;	goto	clock
;pajze
;	movlw	0xff
;clock	
;	movwf	t1
;	decfsz	t1,f
;	goto	$-1
;	bcf		out
;	return
	end
