Wiring modules
Pin1    o       o   VPP
Pin23   o       o   VCC
Pin22   o       o   A15
Pin20   o       o   A13
Pin26   o       o   A11
        o       o   OE
        o       o   CE
MID0    o       o   GND
MID1    o       x   key
MID2    o       o   MID3
module      families
1           2532, 2716
2           2732
3           2764, 27128, 27256
4           27512, 2864, 28256
Known device types
device      family      Vpp         Method
2716        2716        25V         STANDARD
2716A       2716        21V         STANDARD
2716B       2716        12V         FAST
2732        2732        25V         STANDARD
2732A       2732        21V         STANDARD
2732B       2732        12V         FAST
2764        2764        21V         STANDARD
2764A       2764        12V         FAST
27C64       2764        12V         FAST
27128       27128       21V         STANDARD
27128A      27128       12V         FAST
27C128      27128       12V         QUICK
27256       27256       12V         FAST
27256A      27256       12V         QUICK
27C256      27256       12V         QUICK
27512       27512       12V         FAST
27512A      27512       12V         QUICK
27C512      27512       12V         QUICK
28C64       2864        12V         EEPROM
28C256      28256       12V         EEPROM
Programming methods
STANDARD
    - apply 50ms programming pulse
    - read back written byte for verifying
FAST
    - apply 1ms pulses (n, but maximum 25) until byte verifies OK
    - apply a 3n ms finalizing pulse
QUICK
    - apply 100us pulses (maximum 25) until byte verifies OK
EEPROM
    - apply a 100us starting pulse
    - wait 10ms for self-timing write to finish
EEFAST
    - wait for byte verifyes OK (maximum 10ms)
Commands
SHOW
    shows actual parameters
PROG [n]
    only in test mode
    turns on programming phase n or steps over all programming phases
:<intel hex line>
    must check if correct module installed
    writes or verifies bytes defined in hex line
ADDR [n|+]
    only in test mode
    sets device address to n or increments address by one
VPP <12V|21V|25V|ON|OFF>
    sets Vpp value
    only in test mode: turn Vpp on/off
TEST [ON|OFF]
    turns test mode on or off
DEVICE <family>
    sets up device family
METHOD <method>
    sets up programming method
POWER [ON|OFF]
    only in test mode
    turns device power on or off
READ [n][,m]
    reads bytes from device starting at address n to address m
CHECK
    checks if device is empty (all bytes are FF)
WRITE
    turns write mode on
VERIFY
    turns verify mode on
ERASE
    erases device if it is electronically erasable
LIST
    lists known device types
SELECT <device>
    selects a particular device from the list of known types
HELP
    lists known commands
OFFSET [n]
    sets addressing offset
CHKSUM [n][,m]
    calculate checksum from device starting at address n to address m
