//   MSP430 USCI I2C Transmitter and Receiver
//  Description: This code configures the MSP430's USCI module as
//  I2C master capable of transmitting and receiving bytes.
//  ***THIS IS THE MASTER CODE***
//                    Master
//                 MSP430F2619
//         /|\|              XIN|-
//          --|RST          XOUT|-
//            |         SDA/P3.1|------->
//            |         SCL/P3.2|------->
// Note: External pull-ups are needed for SDA & SCL
// Uli Kretzschmar
// Texas Instruments Deutschland GmbH
// November 2007
// Built with IAR Embedded Workbench Version: 3.42A
//#include "msp430x26x.h"                        // device specific header
//#include "msp430x22x4.h"
//#include "msp430x23x0.h"
//#include "msp430xG46x.h"
// ...                                         // more devices are possible
#include "msp430.h"
#include "TI_USCI_I2C_master.h"
signed char byteCtr;
unsigned char *TI_receive_field;
unsigned char *TI_transmit_field;
// void TI_USCI_I2C_receiveinit(unsigned char slave_address,
//                              unsigned char prescale)
// This function initializes the USCI module for master-receive operation.
// IN:   unsigned char slave_address   =>  Slave Address
//       unsigned char prescale        =>  SCL clock adjustment
                             unsigned char prescale){
  P1SEL |= SDA_PIN + SCL_PIN;                 // Assign I2C pins to USCI_B0
  P1SEL2 |= SDA_PIN + SCL_PIN;                 // Assign I2C pins to USCI_B0
  UCB0CTL1 = UCSWRST;                        // Enable SW reset
  UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;       // I2C Master, synchronous mode
  UCB0CTL1 = UCSSEL_2 + UCSWRST;              // Use SMCLK, keep SW reset
  UCB0BR0 = prescale;                         // set prescaler
  UCB0BR1 = 0;
  UCB0I2CSA = slave_address;                  // set slave address
  UCB0CTL1 &= ~UCSWRST;                       // Clear SW reset, resume operation
  UCB0I2CIE = UCNACKIE;
  IE2 = UCB0RXIE;                            // Enable RX interrupt
// void TI_USCI_I2C_transmitinit(unsigned char slave_address,
// This function initializes the USCI module for master-transmit operation.
  UCB0BR1 = 0;
  UCB0I2CSA = slave_address;                  // Set slave address
  IE2 = UCB0TXIE;                            // Enable TX ready interrupt
// void TI_USCI_I2C_receive(unsigned char byteCount, unsigned char *field)
// This function is used to start an I2C commuincation in master-receiver mode.
// IN:   unsigned char byteCount  =>  number of bytes that should be read
//       unsigned char *field     =>  array variable used to store received data
void TI_USCI_I2C_receive(unsigned char byteCount, unsigned char *field){
  TI_receive_field = field;
  if ( byteCount == 1 ){
    byteCtr = 0 ;
    __disable_interrupt();
    UCB0CTL1 |= UCTXSTT;                      // I2C start condition
    while (UCB0CTL1 & UCTXSTT);               // Start condition sent?
    UCB0CTL1 |= UCTXSTP;                      // I2C stop condition
    __enable_interrupt();
  } else if ( byteCount > 1 ) {
    byteCtr = byteCount - 2 ;
  } else
    while (1);                                // illegal parameter
// void TI_USCI_I2C_transmit(unsigned char byteCount, unsigned char *field)
// This function is used to start an I2C commuincation in master-transmit mode.
// IN:   unsigned char byteCount  =>  number of bytes that should be transmitted
//       unsigned char *field     =>  array variable. Its content will be sent.
void TI_USCI_I2C_transmit(unsigned char byteCount, unsigned char *field){
  TI_transmit_field = field;
  byteCtr = byteCount;
  UCB0CTL1 |= UCTR + UCTXSTT;                 // I2C TX, start condition
// unsigned char TI_USCI_I2C_slave_present(unsigned char slave_address)
// This function is used to look for a slave address on the I2C bus.
// OUT:  unsigned char                =>  0: address was not found,
//                                        1: address found
unsigned char TI_USCI_I2C_slave_present(unsigned char slave_address){
  unsigned char ie2_bak, slaveadr_bak, ucb0i2cie, returnValue;
  ucb0i2cie = UCB0I2CIE;                      // restore old UCB0I2CIE
  ie2_bak = IE2;                              // store IE2 register
  slaveadr_bak = UCB0I2CSA;                   // store old slave address
  UCB0I2CIE &= ~ UCNACKIE;                    // no NACK interrupt
  IE2 &= ~(UCB0TXIE + UCB0RXIE);              // no RX or TX interrupts
  UCB0CTL1 |= UCTR + UCTXSTT + UCTXSTP;       // I2C TX, start condition
  while (UCB0CTL1 & UCTXSTP);                 // wait for STOP condition
  returnValue = !(UCB0STAT & UCNACKIFG);
  IE2 = ie2_bak;                              // restore IE2
  UCB0I2CSA = slaveadr_bak;                   // restore old slave address
  UCB0I2CIE = ucb0i2cie;                      // restore old UCB0CTL1
  return returnValue;                         // return whether or not
                                              // a NACK occured
// unsigned char TI_USCI_I2C_notready()
// This function is used to check if there is commuincation in progress.
// OUT:  unsigned char  =>  0: I2C bus is idle,
//                          1: communication is in progress
unsigned char TI_USCI_I2C_notready(){
  return (UCB0STAT & UCBBUSY);
#pragma vector = USCIAB0RX_VECTOR
__interrupt void USCIAB0RX_ISR(void)
  if (UCB0STAT & UCNACKIFG){            // send STOP if slave sends NACK
    UCB0STAT &= ~UCNACKIFG;
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void)
  if (IFG2 & UCB0RXIFG){
    if ( byteCtr == 0 ){
      *TI_receive_field = UCB0RXBUF;
      TI_receive_field++;
    else {
      TI_receive_field++;
      byteCtr--;
  else {
    if (byteCtr == 0){
      IFG2 &= ~UCB0TXIFG;                     // Clear USCI_B0 TX int flag
    else {
      UCB0TXBUF = *TI_transmit_field;
      TI_transmit_field++;
      byteCtr--;
