<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="no"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="avr-7">
<description>&lt;b&gt;AVR Devices&lt;/b&gt;&lt;p&gt;
Version 7 - August 1, 2011.&lt;br&gt;&lt;br&gt;
Added ATmega164P/324P/644P devices for DIP and TQFP.
&lt;p&gt;
Version 4 - March 11, 2008.&lt;br&gt;&lt;br&gt;
This library now includes ONLY ATMEL AVR microcontrollers.  It is the result of merging all other available device libraries available at http://www.cadsoft.de/download as of the time it was made.  In addition to the legacy AT90* devices, it includes most ATMEGA devices including the new 48/88/168, most ATTiny devices and a set of ISP and JTAG pin headers.&lt;p&gt;
Based on the following sources:&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;www.atmel.com
&lt;li&gt; file at90smcu_v400.zip
&lt;li&gt;avr.lbr and atmel.lbr as provided by CadSoft
&lt;li&gt;avr-1.lbr by David Blundell
&lt;li&gt;avr-2.lbr by Boris Zalokar
&lt;li&gt;avr-3.lbr by Carson Reynolds
&lt;li&gt;attiny24_44_84.lbr by Pawel Szramowski (ATTiny24/44/84 devices)
&lt;li&gt;atmel.lbr by Bob Starr (ISP headers)
&lt;li&gt;moates_custom_parts.lbr (edge ISP)
&lt;li&gt;other misc sources
&lt;/ul&gt;
&lt;author&gt;Revised by David Blundell (blundar at gmail dot com) and others.&lt;/author&gt;
&lt;p&gt;
&lt;author&gt;Added Mega162, Tiny2313 John Lussmyer (cougar at casadelgato.com)&lt;/author&gt;
&lt;p&gt;
&lt;author&gt;Added XMega A1,A3,A4,D3,D4 John Lussmyer Aug 1, 2011(cougar at casadelgato.com)&lt;/author&gt;</description>
<packages>
<package name="DIL28-3">
<description>&lt;B&gt;Dual In Line&lt;/B&gt; 0.3 inch</description>
<wire x1="-18.542" y1="-0.635" x2="-18.542" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="0.635" x2="-18.542" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="-18.542" y1="-2.794" x2="18.542" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="2.794" x2="-18.542" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="2.794" x2="18.542" y2="2.794" width="0.1524" layer="21"/>
<wire x1="18.542" y1="2.794" x2="18.542" y2="-2.794" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-19.2024" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-15.875" y="-0.635" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="AVR-ISP-6">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;&lt;p&gt; JTAG 6 Pin, 0.1" Straight</description>
<wire x1="-3.81" y1="2.54" x2="3.81" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="-2.54" width="0.254" layer="21"/>
<wire x1="3.81" y1="-2.54" x2="-3.81" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-2.54" x2="-3.81" y2="2.54" width="0.254" layer="21"/>
<pad name="1" x="-2.54" y="-1.27" drill="1.016" shape="square"/>
<pad name="2" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<text x="-3.81" y="-4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="3.175" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="51"/>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="51"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="51"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="51"/>
</package>
<package name="AVR-ISP-6R">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;&lt;p&gt; AVR ISP 6 Pin, 0.1" Right Angle</description>
<wire x1="3.81" y1="-3.175" x2="1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="1.27" y1="-5.715" x2="3.81" y2="-5.715" width="0.254" layer="21"/>
<wire x1="3.81" y1="-5.715" x2="3.81" y2="-3.175" width="0.254" layer="21"/>
<wire x1="2.54" y1="-10.795" x2="2.54" y2="-6.35" width="0.762" layer="51"/>
<wire x1="1.27" y1="-3.175" x2="-1.27" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-5.715" x2="1.27" y2="-5.715" width="0.254" layer="21"/>
<wire x1="0" y1="-10.795" x2="0" y2="-6.35" width="0.762" layer="51"/>
<wire x1="-1.27" y1="-3.175" x2="-3.81" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-3.175" x2="-3.81" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-5.715" x2="-1.27" y2="-5.715" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-10.795" x2="-2.54" y2="-6.35" width="0.762" layer="51"/>
<text x="4.445" y="-1.27" size="1.27" layer="25" ratio="12" rot="R270">&gt;NAME</text>
<text x="-5.715" y="-1.27" size="1.27" layer="27" ratio="12" rot="R270">&gt;VALUE</text>
<rectangle x1="2.159" y1="-6.223" x2="2.921" y2="-5.715" layer="51" rot="R180"/>
<rectangle x1="-0.381" y1="-6.223" x2="0.381" y2="-5.715" layer="51" rot="R180"/>
<rectangle x1="-2.921" y1="-6.223" x2="-2.159" y2="-5.715" layer="51" rot="R180"/>
<rectangle x1="2.159" y1="-3.175" x2="2.921" y2="-2.159" layer="21" rot="R180"/>
<rectangle x1="-0.381" y1="-3.175" x2="0.381" y2="-2.159" layer="21" rot="R180"/>
<rectangle x1="2.159" y1="-0.381" x2="2.921" y2="0.381" layer="21" rot="R180"/>
<rectangle x1="2.159" y1="-2.159" x2="2.921" y2="-0.381" layer="51" rot="R180"/>
<rectangle x1="-0.381" y1="-2.159" x2="0.381" y2="-0.381" layer="51" rot="R180"/>
<rectangle x1="-0.381" y1="-0.381" x2="0.381" y2="0.381" layer="21" rot="R180"/>
<rectangle x1="-2.921" y1="-3.175" x2="-2.159" y2="-2.159" layer="21" rot="R180"/>
<rectangle x1="-2.921" y1="-0.381" x2="-2.159" y2="0.381" layer="21" rot="R180"/>
<rectangle x1="-2.921" y1="-2.159" x2="-2.159" y2="-0.381" layer="51" rot="R180"/>
</package>
</packages>
<symbols>
<symbol name="ATMEGA48/88/168">
<wire x1="-25.4" y1="30.48" x2="25.4" y2="30.48" width="0.254" layer="94"/>
<wire x1="25.4" y1="30.48" x2="25.4" y2="-33.02" width="0.254" layer="94"/>
<wire x1="25.4" y1="-33.02" x2="-25.4" y2="-33.02" width="0.254" layer="94"/>
<wire x1="-25.4" y1="-33.02" x2="-25.4" y2="30.48" width="0.254" layer="94"/>
<text x="-25.4" y="33.02" size="1.778" layer="95" rot="MR180">&gt;NAME</text>
<text x="-25.4" y="-35.56" size="1.778" layer="96">&gt;VALUE</text>
<pin name="PB5(SCK/PCINT5)" x="30.48" y="-30.48" length="middle" rot="R180"/>
<pin name="PB7(XTAL2/TOSC2/PCINT7)" x="-30.48" y="7.62" length="middle"/>
<pin name="PB6(XTAL1/TOSC1/PCINT6)" x="-30.48" y="12.7" length="middle"/>
<pin name="GND@1" x="-30.48" y="-27.94" length="middle" direction="pwr"/>
<pin name="VCC@1" x="-30.48" y="0" length="middle" direction="pwr"/>
<pin name="AGND" x="-30.48" y="-22.86" length="middle" direction="pwr"/>
<pin name="AREF" x="-30.48" y="-10.16" length="middle" direction="pas"/>
<pin name="AVCC" x="-30.48" y="-7.62" length="middle" direction="pas"/>
<pin name="PB4(MISO/PCINT4)" x="30.48" y="-27.94" length="middle" rot="R180"/>
<pin name="PB3(MOSI/OC2A/PCINT3)" x="30.48" y="-25.4" length="middle" rot="R180"/>
<pin name="PB2(SS/OC1B/PCINT2)" x="30.48" y="-22.86" length="middle" rot="R180"/>
<pin name="PB1(OC1A/PCINT1)" x="30.48" y="-20.32" length="middle" rot="R180"/>
<pin name="PB0(ICP1/CLKO/PCINT0)" x="30.48" y="-17.78" length="middle" rot="R180"/>
<pin name="PD7(AIN1/PCINT23)" x="30.48" y="-12.7" length="middle" rot="R180"/>
<pin name="PD6(AIN0/OC0A/PCINT22)" x="30.48" y="-10.16" length="middle" rot="R180"/>
<pin name="PD5(T1/OC0B/PCINT21)" x="30.48" y="-7.62" length="middle" rot="R180"/>
<pin name="PD4(T0/XCK/PCINT20)" x="30.48" y="-5.08" length="middle" rot="R180"/>
<pin name="PD3(INT1/OC2B/PCINT19)" x="30.48" y="-2.54" length="middle" rot="R180"/>
<pin name="PD2(INT0/PCINT18)" x="30.48" y="0" length="middle" rot="R180"/>
<pin name="PD1(TXD/PCINT17)" x="30.48" y="2.54" length="middle" rot="R180"/>
<pin name="PD0(RXD/PCINT16)" x="30.48" y="5.08" length="middle" rot="R180"/>
<pin name="PC5(ADC5/SCLPCINT13)" x="30.48" y="15.24" length="middle" rot="R180"/>
<pin name="PC4(ADC4/SDA/PCINT12)" x="30.48" y="17.78" length="middle" rot="R180"/>
<pin name="PC3(ADC3/PCINT11)" x="30.48" y="20.32" length="middle" rot="R180"/>
<pin name="PC2(ADC2/PCINT10)" x="30.48" y="22.86" length="middle" rot="R180"/>
<pin name="PC1(ADC1/PCINT9)" x="30.48" y="25.4" length="middle" rot="R180"/>
<pin name="PC0(ADC0/PCINT8)" x="30.48" y="27.94" length="middle" rot="R180"/>
<pin name="PC6(/RESET/PCINT14)" x="-30.48" y="27.94" length="middle"/>
</symbol>
<symbol name="AVR-ISP-6">
<wire x1="-6.35" y1="-5.08" x2="6.35" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-5.08" x2="6.35" y2="5.08" width="0.4064" layer="94"/>
<wire x1="6.35" y1="5.08" x2="-6.35" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="5.08" x2="-6.35" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-1.905" y1="2.54" x2="-1.27" y2="2.54" width="1.016" layer="94"/>
<wire x1="-1.905" y1="0" x2="-1.27" y2="0" width="1.016" layer="94"/>
<wire x1="-1.905" y1="-2.54" x2="-1.27" y2="-2.54" width="1.016" layer="94"/>
<wire x1="1.27" y1="2.54" x2="1.905" y2="2.54" width="1.016" layer="94"/>
<wire x1="1.27" y1="0" x2="1.905" y2="0" width="1.016" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.905" y2="-2.54" width="1.016" layer="94"/>
<text x="-6.35" y="6.35" size="1.778" layer="95" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-8.255" size="1.778" layer="94" ratio="10">AVR ISP</text>
<text x="7.62" y="0.635" size="1.143" layer="94" ratio="10">MOSI</text>
<text x="-11.176" y="0.635" size="1.143" layer="94" ratio="10">SCK</text>
<text x="-11.176" y="3.175" size="1.143" layer="94" ratio="10">MISO</text>
<text x="7.62" y="3.175" size="1.143" layer="94" ratio="10">VCC</text>
<text x="-11.176" y="-1.905" size="1.143" layer="94" ratio="10">RST</text>
<text x="7.62" y="-1.905" size="1.143" layer="94" ratio="10">GND</text>
<pin name="3" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="2" x="5.08" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="5" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="1" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="6" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="4" x="5.08" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MEGA48/88/168-PU" prefix="IC">
<gates>
<gate name="1" symbol="ATMEGA48/88/168" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL28-3">
<connects>
<connect gate="1" pin="AGND" pad="22"/>
<connect gate="1" pin="AREF" pad="21"/>
<connect gate="1" pin="AVCC" pad="20"/>
<connect gate="1" pin="GND@1" pad="8"/>
<connect gate="1" pin="PB0(ICP1/CLKO/PCINT0)" pad="14"/>
<connect gate="1" pin="PB1(OC1A/PCINT1)" pad="15"/>
<connect gate="1" pin="PB2(SS/OC1B/PCINT2)" pad="16"/>
<connect gate="1" pin="PB3(MOSI/OC2A/PCINT3)" pad="17"/>
<connect gate="1" pin="PB4(MISO/PCINT4)" pad="18"/>
<connect gate="1" pin="PB5(SCK/PCINT5)" pad="19"/>
<connect gate="1" pin="PB6(XTAL1/TOSC1/PCINT6)" pad="9"/>
<connect gate="1" pin="PB7(XTAL2/TOSC2/PCINT7)" pad="10"/>
<connect gate="1" pin="PC0(ADC0/PCINT8)" pad="23"/>
<connect gate="1" pin="PC1(ADC1/PCINT9)" pad="24"/>
<connect gate="1" pin="PC2(ADC2/PCINT10)" pad="25"/>
<connect gate="1" pin="PC3(ADC3/PCINT11)" pad="26"/>
<connect gate="1" pin="PC4(ADC4/SDA/PCINT12)" pad="27"/>
<connect gate="1" pin="PC5(ADC5/SCLPCINT13)" pad="28"/>
<connect gate="1" pin="PC6(/RESET/PCINT14)" pad="1"/>
<connect gate="1" pin="PD0(RXD/PCINT16)" pad="2"/>
<connect gate="1" pin="PD1(TXD/PCINT17)" pad="3"/>
<connect gate="1" pin="PD2(INT0/PCINT18)" pad="4"/>
<connect gate="1" pin="PD3(INT1/OC2B/PCINT19)" pad="5"/>
<connect gate="1" pin="PD4(T0/XCK/PCINT20)" pad="6"/>
<connect gate="1" pin="PD5(T1/OC0B/PCINT21)" pad="11"/>
<connect gate="1" pin="PD6(AIN0/OC0A/PCINT22)" pad="12"/>
<connect gate="1" pin="PD7(AIN1/PCINT23)" pad="13"/>
<connect gate="1" pin="VCC@1" pad="7"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AVR-ISP-6" prefix="JP">
<description>&lt;b&gt;AVR ISP-6&lt;/b&gt;&lt;p&gt; Serial Programming Header</description>
<gates>
<gate name="G$1" symbol="AVR-ISP-6" x="0" y="0"/>
</gates>
<devices>
<device name="VERT" package="AVR-ISP-6">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
<device name="HORZ" package="AVR-ISP-6R">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="maxim">
<description>&lt;b&gt;Maxim Components&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL16">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="10.16" y1="2.921" x2="-10.16" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.921" x2="-10.16" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="-10.16" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.016" x2="-10.16" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-10.541" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-7.493" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="MAX232">
<wire x1="-10.16" y1="15.24" x2="10.16" y2="15.24" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-17.78" x2="10.16" y2="15.24" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-17.78" x2="-10.16" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="15.24" x2="-10.16" y2="-17.78" width="0.4064" layer="94"/>
<text x="-10.16" y="15.875" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
<pin name="C1+" x="-15.24" y="12.7" length="middle"/>
<pin name="C1-" x="-15.24" y="7.62" length="middle"/>
<pin name="C2+" x="-15.24" y="2.54" length="middle"/>
<pin name="C2-" x="-15.24" y="-2.54" length="middle"/>
<pin name="T1IN" x="-15.24" y="-7.62" length="middle" direction="in"/>
<pin name="T2IN" x="-15.24" y="-10.16" length="middle" direction="in"/>
<pin name="R1OUT" x="-15.24" y="-12.7" length="middle" direction="out"/>
<pin name="R2OUT" x="-15.24" y="-15.24" length="middle" direction="out"/>
<pin name="V+" x="15.24" y="10.16" length="middle" rot="R180"/>
<pin name="V-" x="15.24" y="5.08" length="middle" rot="R180"/>
<pin name="T1OUT" x="15.24" y="-7.62" length="middle" direction="out" rot="R180"/>
<pin name="T2OUT" x="15.24" y="-10.16" length="middle" direction="out" rot="R180"/>
<pin name="R1IN" x="15.24" y="-12.7" length="middle" direction="in" rot="R180"/>
<pin name="R2IN" x="15.24" y="-15.24" length="middle" direction="in" rot="R180"/>
</symbol>
<symbol name="VCC-GND">
<text x="1.524" y="-5.08" size="1.016" layer="95" rot="R90">GND</text>
<text x="1.524" y="2.54" size="1.016" layer="95" rot="R90">VCC</text>
<text x="-0.762" y="-0.762" size="1.778" layer="95">&gt;NAME</text>
<pin name="VCC" x="0" y="7.62" visible="pad" length="middle" direction="pwr" rot="R270"/>
<pin name="GND" x="0" y="-7.62" visible="pad" length="middle" direction="pwr" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MAX232" prefix="IC">
<description>&lt;b&gt;RS232 TRANSEIVER&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="MAX232" x="0" y="0"/>
<gate name="P" symbol="VCC-GND" x="25.4" y="-5.08" addlevel="request"/>
</gates>
<devices>
<device name="" package="DIL16">
<connects>
<connect gate="G$1" pin="C1+" pad="1"/>
<connect gate="G$1" pin="C1-" pad="3"/>
<connect gate="G$1" pin="C2+" pad="4"/>
<connect gate="G$1" pin="C2-" pad="5"/>
<connect gate="G$1" pin="R1IN" pad="13"/>
<connect gate="G$1" pin="R1OUT" pad="12"/>
<connect gate="G$1" pin="R2IN" pad="8"/>
<connect gate="G$1" pin="R2OUT" pad="9"/>
<connect gate="G$1" pin="T1IN" pad="11"/>
<connect gate="G$1" pin="T1OUT" pad="14"/>
<connect gate="G$1" pin="T2IN" pad="10"/>
<connect gate="G$1" pin="T2OUT" pad="7"/>
<connect gate="G$1" pin="V+" pad="2"/>
<connect gate="G$1" pin="V-" pad="6"/>
<connect gate="P" pin="GND" pad="15"/>
<connect gate="P" pin="VCC" pad="16"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="MAXIM" constant="no"/>
<attribute name="MPN" value="MAX232ACPE+" constant="no"/>
<attribute name="OC_FARNELL" value="9723773" constant="no"/>
<attribute name="OC_NEWARK" value="68K4544" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
<packages>
</packages>
<symbols>
<symbol name="GND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="VCC">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="VCC" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="GND" prefix="GND">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="VCC" prefix="P+">
<gates>
<gate name="VCC" symbol="VCC" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="docu-dummy">
<description>Dummy symbols</description>
<packages>
</packages>
<symbols>
<symbol name="ELKO">
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="-1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-5.08" width="0.1524" layer="94"/>
<text x="-0.5842" y="0.4064" size="1.27" layer="94" rot="R90">+</text>
<rectangle x1="-1.651" y1="-2.54" x2="1.651" y2="-1.651" layer="94"/>
</symbol>
<symbol name="CAPACITOR">
<wire x1="0" y1="-5.08" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<wire x1="0" y1="-0.508" x2="0" y2="2.54" width="0.1524" layer="94"/>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
</symbol>
<symbol name="POTI">
<wire x1="-0.762" y1="-3.81" x2="0" y2="-3.81" width="0.254" layer="94"/>
<wire x1="0.762" y1="3.81" x2="0" y2="3.81" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.81" x2="-0.762" y2="-3.81" width="0.254" layer="94"/>
<wire x1="0.762" y1="-3.81" x2="0.762" y2="3.81" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="1.651" y2="0" width="0.1524" layer="94"/>
<wire x1="1.651" y1="0" x2="-2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-1.778" y2="1.524" width="0.1524" layer="94"/>
<wire x1="-1.778" y1="1.524" x2="-1.27" y2="2.286" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-1.27" y2="2.286" width="0.1524" layer="94"/>
<wire x1="0" y1="3.81" x2="0" y2="5.08" width="0.1524" layer="94"/>
<wire x1="0" y1="3.81" x2="-0.762" y2="3.81" width="0.254" layer="94"/>
<wire x1="0" y1="-5.08" x2="0" y2="-3.81" width="0.1524" layer="94"/>
<wire x1="0" y1="-3.81" x2="0.762" y2="-3.81" width="0.254" layer="94"/>
</symbol>
<symbol name="RESISTOR">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-5.08" y1="0" x2="-2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="5.08" y2="0" width="0.1524" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="ELKO" prefix="C">
<description>&lt;b&gt;ELektrolyt Capacitor&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="ELKO" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C" prefix="C">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="CAPACITOR" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="POT" prefix="P">
<description>&lt;b&gt;POTENTIOMENTER&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="POTI" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="R" prefix="R">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="RESISTOR" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="wirepad">
<description>&lt;b&gt;Single Pads&lt;/b&gt;&lt;p&gt;
<packages>
</packages>
<symbols>
<symbol name="PAD-N">
<wire x1="-1.016" y1="1.016" x2="1.016" y2="-1.016" width="0.254" layer="94"/>
<wire x1="-1.016" y1="-1.016" x2="1.016" y2="1.016" width="0.254" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="PAD-N" prefix="X" uservalue="yes">
<description>&lt;b&gt;PAD SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="PAD-N" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="switch">
<description>&lt;b&gt;Switches&lt;/b&gt;&lt;p&gt;
Marquardt, Siemens, C&amp;K, ITT, and others&lt;p&gt;
<packages>
<package name="REKN">
<description>&lt;b&gt;PUSH SWITCH&lt;/b&gt;&lt;p&gt;
ITT-Cannon-Cannon</description>
<wire x1="-6.8999" y1="-6.1001" x2="-3.5999" y2="-6.1001" width="0.2032" layer="21"/>
<wire x1="-3.5999" y1="-6.1001" x2="6.8999" y2="-6.1001" width="0.2032" layer="21"/>
<wire x1="6.8999" y1="-6.1001" x2="6.8999" y2="6.1001" width="0.2032" layer="21"/>
<wire x1="6.8999" y1="6.1001" x2="-3.5999" y2="6.1001" width="0.2032" layer="21"/>
<wire x1="-3.5999" y1="6.1001" x2="-6.8999" y2="6.1001" width="0.2032" layer="21"/>
<wire x1="-6.8999" y1="6.1001" x2="-6.8999" y2="-6.1001" width="0.2032" layer="21"/>
<wire x1="-3.5999" y1="-6.1001" x2="-3.5999" y2="6.1001" width="0.2032" layer="21"/>
<wire x1="-3.5999" y1="-6.1001" x2="-2.54" y2="-4.064" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="-4.064" x2="-2.54" y2="4.064" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="4.064" x2="-3.5999" y2="6.1001" width="0.2032" layer="21"/>
<wire x1="6.8999" y1="-6.1001" x2="5.969" y2="-4.064" width="0.2032" layer="21"/>
<wire x1="5.969" y1="-4.064" x2="5.969" y2="4.064" width="0.2032" layer="21"/>
<wire x1="5.969" y1="4.064" x2="6.8999" y2="6.1001" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="4.064" x2="5.969" y2="4.064" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="-4.064" x2="5.969" y2="-4.064" width="0.2032" layer="21"/>
<pad name="0A" x="5.08" y="5.08" drill="0.8998" shape="long" rot="R90"/>
<pad name="1A" x="0" y="5.08" drill="0.8998" shape="long" rot="R90"/>
<pad name="A" x="-5.08" y="5.08" drill="0.8998" shape="long" rot="R90"/>
<pad name="B" x="-5.08" y="-5.08" drill="0.8998" shape="long" rot="R90"/>
<pad name="1B" x="0" y="-5.08" drill="0.8998" shape="long" rot="R90"/>
<pad name="0B" x="5.08" y="-5.08" drill="0.8998" shape="long" rot="R90"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<hole x="-5.08" y="0" drill="1.1"/>
<hole x="5.08" y="0" drill="1.1"/>
</package>
</packages>
<symbols>
<symbol name="NORMOPEN">
<wire x1="-2.54" y1="0" x2="-2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="5.08" y1="0" x2="5.08" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="0" x2="3.048" y2="1.778" width="0.2032" layer="94"/>
<wire x1="3.048" y1="0.508" x2="3.048" y2="0" width="0.2032" layer="94"/>
<wire x1="0.762" y1="1.016" x2="0.762" y2="1.524" width="0.2032" layer="94"/>
<wire x1="0.762" y1="2.032" x2="0.762" y2="2.794" width="0.2032" layer="94"/>
<wire x1="0.762" y1="2.794" x2="0.762" y2="3.048" width="0.2032" layer="94"/>
<wire x1="0.762" y1="3.556" x2="0.762" y2="4.064" width="0.2032" layer="94"/>
<wire x1="1.27" y1="4.064" x2="0.762" y2="4.064" width="0.2032" layer="94"/>
<wire x1="0.762" y1="4.064" x2="0.254" y2="4.064" width="0.2032" layer="94"/>
<wire x1="0.254" y1="2.286" x2="0.762" y2="2.794" width="0.1524" layer="94"/>
<wire x1="0.762" y1="2.794" x2="1.27" y2="2.286" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.2032" layer="94"/>
<wire x1="3.048" y1="0" x2="5.08" y2="0" width="0.2032" layer="94"/>
<circle x="-2.54" y="0" radius="0.508" width="0" layer="94"/>
<circle x="5.08" y="0" radius="0.508" width="0" layer="94"/>
<text x="-3.048" y="4.826" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-5.588" size="1.778" layer="96">&gt;VALUE</text>
<pin name="0@A" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="0@B" x="-5.08" y="-2.54" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="1@B" x="7.62" y="-2.54" visible="off" length="short" direction="pas" swaplevel="2" rot="R180"/>
<pin name="1@A" x="7.62" y="0" visible="off" length="short" direction="pas" swaplevel="2" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="REKN" prefix="S" uservalue="yes">
<gates>
<gate name="G$1" symbol="NORMOPEN" x="0" y="0"/>
</gates>
<devices>
<device name="" package="REKN">
<connects>
<connect gate="G$1" pin="0@A" pad="0A"/>
<connect gate="G$1" pin="0@B" pad="0B"/>
<connect gate="G$1" pin="1@A" pad="1A"/>
<connect gate="G$1" pin="1@B" pad="1B"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="IC1" library="avr-7" deviceset="MEGA48/88/168-PU" device=""/>
<part name="JP1" library="avr-7" deviceset="AVR-ISP-6" device="VERT"/>
<part name="IC2" library="maxim" deviceset="MAX232" device=""/>
<part name="GND1" library="supply1" deviceset="GND" device=""/>
<part name="GND2" library="supply1" deviceset="GND" device=""/>
<part name="C1" library="docu-dummy" deviceset="ELKO" device=""/>
<part name="C2" library="docu-dummy" deviceset="ELKO" device=""/>
<part name="C3" library="docu-dummy" deviceset="ELKO" device=""/>
<part name="C4" library="docu-dummy" deviceset="ELKO" device=""/>
<part name="GND3" library="supply1" deviceset="GND" device=""/>
<part name="P+1" library="supply1" deviceset="VCC" device=""/>
<part name="GND4" library="supply1" deviceset="GND" device=""/>
<part name="P+2" library="supply1" deviceset="VCC" device=""/>
<part name="C5" library="docu-dummy" deviceset="C" device=""/>
<part name="C6" library="docu-dummy" deviceset="C" device="" value="100n"/>
<part name="X1" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X2" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X3" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X4" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X5" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X6" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X7" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X8" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X9" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X10" library="wirepad" deviceset="PAD-N" device=""/>
<part name="GND5" library="supply1" deviceset="GND" device=""/>
<part name="P+3" library="supply1" deviceset="VCC" device=""/>
<part name="P1" library="docu-dummy" deviceset="POT" device=""/>
<part name="X11" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X12" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X13" library="wirepad" deviceset="PAD-N" device=""/>
<part name="1" library="switch" deviceset="REKN" device=""/>
<part name="2" library="switch" deviceset="REKN" device=""/>
<part name="3" library="switch" deviceset="REKN" device=""/>
<part name="4" library="switch" deviceset="REKN" device=""/>
<part name="5" library="switch" deviceset="REKN" device=""/>
<part name="6" library="switch" deviceset="REKN" device=""/>
<part name="7" library="switch" deviceset="REKN" device=""/>
<part name="8" library="switch" deviceset="REKN" device=""/>
<part name="9" library="switch" deviceset="REKN" device=""/>
<part name="*" library="switch" deviceset="REKN" device=""/>
<part name="0" library="switch" deviceset="REKN" device=""/>
<part name="#" library="switch" deviceset="REKN" device=""/>
<part name="R1" library="docu-dummy" deviceset="R" device=""/>
<part name="R2" library="docu-dummy" deviceset="R" device=""/>
<part name="R3" library="docu-dummy" deviceset="R" device=""/>
<part name="R4" library="docu-dummy" deviceset="R" device=""/>
<part name="R5" library="docu-dummy" deviceset="R" device=""/>
<part name="R6" library="docu-dummy" deviceset="R" device=""/>
<part name="R7" library="docu-dummy" deviceset="R" device=""/>
<part name="X14" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X15" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X16" library="wirepad" deviceset="PAD-N" device=""/>
<part name="X17" library="wirepad" deviceset="PAD-N" device=""/>
<part name="P+4" library="supply1" deviceset="VCC" device=""/>
</parts>
<sheets>
<sheet>
<plain>
<text x="-2.54" y="38.1" size="1.778" layer="91">RXD - SERIAL</text>
<text x="-2.54" y="33.02" size="1.778" layer="91">TXD - SERIAL</text>
<text x="-2.54" y="27.94" size="1.778" layer="91">GND - SERIAL</text>
<text x="139.7" y="27.94" size="1.778" layer="91">14 (D7) - LCD</text>
<text x="139.7" y="33.02" size="1.778" layer="91">13 (D6) - LCD</text>
<text x="139.7" y="38.1" size="1.778" layer="91">12 (D5) - LCD</text>
<text x="139.7" y="43.18" size="1.778" layer="91">11 (D4) - LCD</text>
<text x="22.86" y="63.5" size="1.778" layer="91">6 (E) - LCD</text>
<text x="22.86" y="68.58" size="1.778" layer="91">4 (RS) - LCD</text>
<text x="139.7" y="53.34" size="1.778" layer="91">1 (GND) - LCD</text>
<text x="139.7" y="60.96" size="1.778" layer="91">2 (VCC) - LCD</text>
<text x="139.7" y="55.88" size="1.778" layer="91">3 (contrast) - LCD</text>
<text x="139.7" y="50.8" size="1.778" layer="91">5 (RW) - LCD</text>
<text x="182.88" y="40.64" size="1.778" layer="91">OC0A</text>
<text x="182.88" y="30.48" size="1.778" layer="91">OC1A</text>
<text x="182.88" y="78.74" size="1.778" layer="91">ADC0</text>
<text x="182.88" y="71.12" size="1.778" layer="91">INT0</text>
</plain>
<instances>
<instance part="IC1" gate="1" x="68.58" y="50.8"/>
<instance part="JP1" gate="G$1" x="68.58" y="99.06"/>
<instance part="IC2" gate="G$1" x="-27.94" y="45.72"/>
<instance part="GND1" gate="1" x="78.74" y="91.44"/>
<instance part="GND2" gate="1" x="-10.16" y="22.86"/>
<instance part="C1" gate="G$1" x="-48.26" y="48.26" rot="R270"/>
<instance part="C2" gate="G$1" x="-48.26" y="58.42" rot="R270"/>
<instance part="C3" gate="G$1" x="-7.62" y="55.88" rot="R90"/>
<instance part="C4" gate="G$1" x="-5.08" y="50.8" rot="R270"/>
<instance part="GND3" gate="1" x="7.62" y="45.72"/>
<instance part="P+1" gate="VCC" x="7.62" y="60.96"/>
<instance part="GND4" gate="1" x="30.48" y="15.24"/>
<instance part="P+2" gate="VCC" x="30.48" y="55.88"/>
<instance part="C5" gate="G$1" x="33.02" y="40.64" rot="R90"/>
<instance part="C6" gate="G$1" x="30.48" y="33.02" rot="R180"/>
<instance part="X1" gate="G$1" x="137.16" y="43.18"/>
<instance part="X2" gate="G$1" x="20.32" y="63.5"/>
<instance part="X3" gate="G$1" x="137.16" y="38.1"/>
<instance part="X4" gate="G$1" x="137.16" y="33.02"/>
<instance part="X5" gate="G$1" x="20.32" y="68.58"/>
<instance part="X6" gate="G$1" x="137.16" y="27.94"/>
<instance part="X7" gate="G$1" x="137.16" y="53.34"/>
<instance part="X8" gate="G$1" x="137.16" y="50.8"/>
<instance part="X9" gate="G$1" x="137.16" y="60.96"/>
<instance part="X10" gate="G$1" x="137.16" y="55.88"/>
<instance part="GND5" gate="1" x="129.54" y="48.26"/>
<instance part="P+3" gate="VCC" x="129.54" y="63.5"/>
<instance part="P1" gate="G$1" x="129.54" y="55.88"/>
<instance part="X11" gate="G$1" x="-5.08" y="27.94"/>
<instance part="X12" gate="G$1" x="-5.08" y="38.1"/>
<instance part="X13" gate="G$1" x="-5.08" y="33.02"/>
<instance part="1" gate="G$1" x="27.94" y="-7.62"/>
<instance part="2" gate="G$1" x="48.26" y="-7.62"/>
<instance part="3" gate="G$1" x="68.58" y="-7.62"/>
<instance part="4" gate="G$1" x="27.94" y="-20.32"/>
<instance part="5" gate="G$1" x="48.26" y="-20.32"/>
<instance part="6" gate="G$1" x="68.58" y="-20.32"/>
<instance part="7" gate="G$1" x="27.94" y="-33.02"/>
<instance part="8" gate="G$1" x="48.26" y="-33.02"/>
<instance part="9" gate="G$1" x="68.58" y="-33.02"/>
<instance part="*" gate="G$1" x="27.94" y="-45.72"/>
<instance part="0" gate="G$1" x="48.26" y="-45.72"/>
<instance part="#" gate="G$1" x="68.58" y="-45.72"/>
<instance part="R1" gate="G$1" x="27.94" y="7.62"/>
<instance part="R2" gate="G$1" x="48.26" y="5.08"/>
<instance part="R3" gate="G$1" x="68.58" y="2.54"/>
<instance part="R4" gate="G$1" x="86.36" y="-12.7"/>
<instance part="R5" gate="G$1" x="86.36" y="-25.4"/>
<instance part="R6" gate="G$1" x="86.36" y="-38.1"/>
<instance part="R7" gate="G$1" x="86.36" y="-50.8"/>
<instance part="X14" gate="G$1" x="180.34" y="78.74"/>
<instance part="X15" gate="G$1" x="180.34" y="71.12"/>
<instance part="X16" gate="G$1" x="180.34" y="40.64"/>
<instance part="X17" gate="G$1" x="180.34" y="30.48"/>
<instance part="IC2" gate="P" x="-27.94" y="17.78" rot="R90"/>
<instance part="P+4" gate="VCC" x="-45.72" y="22.86"/>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PC6(/RESET/PCINT14)"/>
<pinref part="JP1" gate="G$1" pin="5"/>
<wire x1="38.1" y1="78.74" x2="38.1" y2="96.52" width="0.1524" layer="91"/>
<wire x1="38.1" y1="96.52" x2="63.5" y2="96.52" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PB5(SCK/PCINT5)"/>
<wire x1="99.06" y1="20.32" x2="167.64" y2="20.32" width="0.1524" layer="91"/>
<wire x1="167.64" y1="20.32" x2="167.64" y2="111.76" width="0.1524" layer="91"/>
<wire x1="167.64" y1="111.76" x2="53.34" y2="111.76" width="0.1524" layer="91"/>
<wire x1="53.34" y1="111.76" x2="53.34" y2="99.06" width="0.1524" layer="91"/>
<pinref part="JP1" gate="G$1" pin="3"/>
<wire x1="53.34" y1="99.06" x2="63.5" y2="99.06" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PB4(MISO/PCINT4)"/>
<wire x1="99.06" y1="22.86" x2="165.1" y2="22.86" width="0.1524" layer="91"/>
<wire x1="165.1" y1="22.86" x2="165.1" y2="109.22" width="0.1524" layer="91"/>
<wire x1="165.1" y1="109.22" x2="55.88" y2="109.22" width="0.1524" layer="91"/>
<wire x1="55.88" y1="109.22" x2="55.88" y2="101.6" width="0.1524" layer="91"/>
<pinref part="JP1" gate="G$1" pin="1"/>
<wire x1="55.88" y1="101.6" x2="63.5" y2="101.6" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PB3(MOSI/OC2A/PCINT3)"/>
<wire x1="99.06" y1="25.4" x2="162.56" y2="25.4" width="0.1524" layer="91"/>
<wire x1="162.56" y1="25.4" x2="162.56" y2="99.06" width="0.1524" layer="91"/>
<pinref part="JP1" gate="G$1" pin="4"/>
<wire x1="162.56" y1="99.06" x2="73.66" y2="99.06" width="0.1524" layer="91"/>
</segment>
</net>
<net name="GND" class="0">
<segment>
<pinref part="JP1" gate="G$1" pin="6"/>
<pinref part="GND1" gate="1" pin="GND"/>
<wire x1="73.66" y1="96.52" x2="78.74" y2="96.52" width="0.1524" layer="91"/>
<wire x1="78.74" y1="96.52" x2="78.74" y2="93.98" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND2" gate="1" pin="GND"/>
<wire x1="-10.16" y1="25.4" x2="-10.16" y2="27.94" width="0.1524" layer="91"/>
<wire x1="-10.16" y1="27.94" x2="-5.08" y2="27.94" width="0.1524" layer="91"/>
<wire x1="-10.16" y1="27.94" x2="-15.24" y2="27.94" width="0.1524" layer="91"/>
<wire x1="-15.24" y1="27.94" x2="-15.24" y2="17.78" width="0.1524" layer="91"/>
<junction x="-10.16" y="27.94"/>
<pinref part="IC2" gate="P" pin="GND"/>
<wire x1="-15.24" y1="17.78" x2="-20.32" y2="17.78" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="-2.54" y1="50.8" x2="7.62" y2="50.8" width="0.1524" layer="91"/>
<wire x1="7.62" y1="50.8" x2="7.62" y2="48.26" width="0.1524" layer="91"/>
<pinref part="GND3" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="IC1" gate="1" pin="GND@1"/>
<pinref part="GND4" gate="1" pin="GND"/>
<wire x1="38.1" y1="22.86" x2="30.48" y2="22.86" width="0.1524" layer="91"/>
<wire x1="30.48" y1="22.86" x2="30.48" y2="17.78" width="0.1524" layer="91"/>
<pinref part="IC1" gate="1" pin="AGND"/>
<wire x1="38.1" y1="27.94" x2="30.48" y2="27.94" width="0.1524" layer="91"/>
<wire x1="30.48" y1="27.94" x2="30.48" y2="22.86" width="0.1524" layer="91"/>
<junction x="30.48" y="22.86"/>
<wire x1="30.48" y1="27.94" x2="30.48" y2="30.48" width="0.1524" layer="91"/>
<junction x="30.48" y="27.94"/>
</segment>
<segment>
<wire x1="137.16" y1="50.8" x2="132.08" y2="50.8" width="0.1524" layer="91"/>
<wire x1="132.08" y1="50.8" x2="132.08" y2="53.34" width="0.1524" layer="91"/>
<pinref part="GND5" gate="1" pin="GND"/>
<wire x1="129.54" y1="50.8" x2="132.08" y2="50.8" width="0.1524" layer="91"/>
<junction x="132.08" y="50.8"/>
<wire x1="132.08" y1="53.34" x2="137.16" y2="53.34" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="T1IN"/>
<wire x1="-43.18" y1="38.1" x2="-55.88" y2="38.1" width="0.1524" layer="91"/>
<wire x1="-55.88" y1="38.1" x2="-55.88" y2="86.36" width="0.1524" layer="91"/>
<wire x1="-55.88" y1="86.36" x2="119.38" y2="86.36" width="0.1524" layer="91"/>
<wire x1="119.38" y1="86.36" x2="119.38" y2="55.88" width="0.1524" layer="91"/>
<pinref part="IC1" gate="1" pin="PD0(RXD/PCINT16)"/>
<wire x1="119.38" y1="55.88" x2="99.06" y2="55.88" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="R1OUT"/>
<wire x1="-43.18" y1="33.02" x2="-58.42" y2="33.02" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="33.02" x2="-58.42" y2="88.9" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="88.9" x2="121.92" y2="88.9" width="0.1524" layer="91"/>
<wire x1="121.92" y1="88.9" x2="121.92" y2="53.34" width="0.1524" layer="91"/>
<pinref part="IC1" gate="1" pin="PD1(TXD/PCINT17)"/>
<wire x1="121.92" y1="53.34" x2="99.06" y2="53.34" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="T1OUT"/>
<wire x1="-12.7" y1="38.1" x2="-5.08" y2="38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="R1IN"/>
<wire x1="-12.7" y1="33.02" x2="-5.08" y2="33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="V-"/>
<wire x1="-12.7" y1="50.8" x2="-10.16" y2="50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="VCC" class="0">
<segment>
<pinref part="P+1" gate="VCC" pin="VCC"/>
<wire x1="-2.54" y1="55.88" x2="7.62" y2="55.88" width="0.1524" layer="91"/>
<wire x1="7.62" y1="55.88" x2="7.62" y2="58.42" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC1" gate="1" pin="VCC@1"/>
<pinref part="P+2" gate="VCC" pin="VCC"/>
<wire x1="38.1" y1="50.8" x2="30.48" y2="50.8" width="0.1524" layer="91"/>
<wire x1="30.48" y1="50.8" x2="30.48" y2="53.34" width="0.1524" layer="91"/>
<pinref part="IC1" gate="1" pin="AVCC"/>
<wire x1="38.1" y1="43.18" x2="30.48" y2="43.18" width="0.1524" layer="91"/>
<wire x1="30.48" y1="43.18" x2="30.48" y2="50.8" width="0.1524" layer="91"/>
<junction x="30.48" y="50.8"/>
<junction x="30.48" y="43.18"/>
<wire x1="30.48" y1="38.1" x2="30.48" y2="40.64" width="0.1524" layer="91"/>
<junction x="30.48" y="40.64"/>
<wire x1="30.48" y1="40.64" x2="30.48" y2="43.18" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="137.16" y1="60.96" x2="129.54" y2="60.96" width="0.1524" layer="91"/>
<pinref part="P+3" gate="VCC" pin="VCC"/>
</segment>
<segment>
<pinref part="P+4" gate="VCC" pin="VCC"/>
<pinref part="IC2" gate="P" pin="VCC"/>
<wire x1="-45.72" y1="20.32" x2="-45.72" y2="17.78" width="0.1524" layer="91"/>
<wire x1="-45.72" y1="17.78" x2="-35.56" y2="17.78" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="V+"/>
<wire x1="-12.7" y1="55.88" x2="-10.16" y2="55.88" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="C1+"/>
<wire x1="-43.18" y1="58.42" x2="-53.34" y2="58.42" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="C1-"/>
<wire x1="-53.34" y1="58.42" x2="-53.34" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-53.34" y1="53.34" x2="-43.18" y2="53.34" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="C2+"/>
<wire x1="-53.34" y1="48.26" x2="-43.18" y2="48.26" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="C2-"/>
<wire x1="-53.34" y1="48.26" x2="-53.34" y2="43.18" width="0.1524" layer="91"/>
<wire x1="-53.34" y1="43.18" x2="-43.18" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PB2(SS/OC1B/PCINT2)"/>
<wire x1="99.06" y1="27.94" x2="137.16" y2="27.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PB0(ICP1/CLKO/PCINT0)"/>
<wire x1="99.06" y1="33.02" x2="137.16" y2="33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PD7(AIN1/PCINT23)"/>
<wire x1="99.06" y1="38.1" x2="137.16" y2="38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PD5(T1/OC0B/PCINT21)"/>
<wire x1="99.06" y1="43.18" x2="137.16" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<wire x1="132.08" y1="55.88" x2="137.16" y2="55.88" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PB7(XTAL2/TOSC2/PCINT7)"/>
<wire x1="38.1" y1="58.42" x2="20.32" y2="58.42" width="0.1524" layer="91"/>
<wire x1="20.32" y1="58.42" x2="20.32" y2="63.5" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PB6(XTAL1/TOSC1/PCINT6)"/>
<wire x1="38.1" y1="63.5" x2="38.1" y2="73.66" width="0.1524" layer="91"/>
<wire x1="38.1" y1="73.66" x2="20.32" y2="73.66" width="0.1524" layer="91"/>
<wire x1="20.32" y1="73.66" x2="20.32" y2="68.58" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PB1(OC1A/PCINT1)"/>
<wire x1="99.06" y1="30.48" x2="180.34" y2="30.48" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PD6(AIN0/OC0A/PCINT22)"/>
<wire x1="99.06" y1="40.64" x2="180.34" y2="40.64" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PC0(ADC0/PCINT8)"/>
<wire x1="99.06" y1="78.74" x2="180.34" y2="78.74" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PD2(INT0/PCINT18)"/>
<wire x1="99.06" y1="50.8" x2="124.46" y2="50.8" width="0.1524" layer="91"/>
<wire x1="124.46" y1="50.8" x2="124.46" y2="71.12" width="0.1524" layer="91"/>
<wire x1="124.46" y1="71.12" x2="180.34" y2="71.12" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="*" gate="G$1" pin="0@A"/>
<wire x1="22.86" y1="-45.72" x2="20.32" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="20.32" y1="-45.72" x2="20.32" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="7" gate="G$1" pin="0@A"/>
<wire x1="20.32" y1="-33.02" x2="22.86" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="4" gate="G$1" pin="0@A"/>
<wire x1="22.86" y1="-20.32" x2="20.32" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="20.32" y1="-20.32" x2="20.32" y2="-33.02" width="0.1524" layer="91"/>
<junction x="20.32" y="-33.02"/>
<pinref part="1" gate="G$1" pin="0@A"/>
<wire x1="22.86" y1="-7.62" x2="20.32" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="20.32" y1="-7.62" x2="20.32" y2="-20.32" width="0.1524" layer="91"/>
<junction x="20.32" y="-20.32"/>
<wire x1="20.32" y1="-7.62" x2="20.32" y2="7.62" width="0.1524" layer="91"/>
<junction x="20.32" y="-7.62"/>
<wire x1="20.32" y1="7.62" x2="22.86" y2="7.62" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="8" gate="G$1" pin="0@A"/>
<wire x1="43.18" y1="-33.02" x2="40.64" y2="-33.02" width="0.1524" layer="91"/>
<wire x1="40.64" y1="-33.02" x2="40.64" y2="-45.72" width="0.1524" layer="91"/>
<pinref part="0" gate="G$1" pin="0@A"/>
<wire x1="40.64" y1="-45.72" x2="43.18" y2="-45.72" width="0.1524" layer="91"/>
<pinref part="5" gate="G$1" pin="0@A"/>
<wire x1="43.18" y1="-20.32" x2="40.64" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="40.64" y1="-20.32" x2="40.64" y2="-33.02" width="0.1524" layer="91"/>
<junction x="40.64" y="-33.02"/>
<pinref part="2" gate="G$1" pin="0@A"/>
<wire x1="43.18" y1="-7.62" x2="40.64" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="40.64" y1="-7.62" x2="40.64" y2="-20.32" width="0.1524" layer="91"/>
<junction x="40.64" y="-20.32"/>
<wire x1="40.64" y1="-7.62" x2="40.64" y2="5.08" width="0.1524" layer="91"/>
<junction x="40.64" y="-7.62"/>
<wire x1="40.64" y1="5.08" x2="43.18" y2="5.08" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PC5(ADC5/SCLPCINT13)"/>
<wire x1="99.06" y1="66.04" x2="106.68" y2="66.04" width="0.1524" layer="91"/>
<wire x1="106.68" y1="66.04" x2="106.68" y2="2.54" width="0.1524" layer="91"/>
<wire x1="106.68" y1="2.54" x2="73.66" y2="2.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$29" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PC4(ADC4/SDA/PCINT12)"/>
<wire x1="99.06" y1="68.58" x2="109.22" y2="68.58" width="0.1524" layer="91"/>
<wire x1="109.22" y1="68.58" x2="109.22" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-12.7" x2="109.22" y2="-12.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PC3(ADC3/PCINT11)"/>
<wire x1="99.06" y1="71.12" x2="111.76" y2="71.12" width="0.1524" layer="91"/>
<wire x1="111.76" y1="71.12" x2="111.76" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-25.4" x2="111.76" y2="-25.4" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$31" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PC2(ADC2/PCINT10)"/>
<wire x1="99.06" y1="73.66" x2="114.3" y2="73.66" width="0.1524" layer="91"/>
<wire x1="114.3" y1="73.66" x2="114.3" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-38.1" x2="114.3" y2="-38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PC1(ADC1/PCINT9)"/>
<wire x1="99.06" y1="76.2" x2="116.84" y2="76.2" width="0.1524" layer="91"/>
<wire x1="116.84" y1="76.2" x2="116.84" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-50.8" x2="116.84" y2="-50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$40" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PD4(T0/XCK/PCINT20)"/>
<wire x1="99.06" y1="45.72" x2="101.6" y2="45.72" width="0.1524" layer="91"/>
<wire x1="101.6" y1="45.72" x2="101.6" y2="7.62" width="0.1524" layer="91"/>
<wire x1="33.02" y1="7.62" x2="101.6" y2="7.62" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="IC1" gate="1" pin="PD3(INT1/OC2B/PCINT19)"/>
<wire x1="99.06" y1="48.26" x2="104.14" y2="48.26" width="0.1524" layer="91"/>
<wire x1="104.14" y1="48.26" x2="104.14" y2="5.08" width="0.1524" layer="91"/>
<wire x1="53.34" y1="5.08" x2="104.14" y2="5.08" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<pinref part="6" gate="G$1" pin="0@A"/>
<pinref part="3" gate="G$1" pin="0@A"/>
<wire x1="63.5" y1="-7.62" x2="60.96" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-7.62" x2="60.96" y2="2.54" width="0.1524" layer="91"/>
<junction x="60.96" y="-7.62"/>
<wire x1="60.96" y1="-7.62" x2="60.96" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-20.32" x2="63.5" y2="-20.32" width="0.1524" layer="91"/>
<junction x="60.96" y="-20.32"/>
<pinref part="9" gate="G$1" pin="0@A"/>
<wire x1="63.5" y1="-33.02" x2="60.96" y2="-33.02" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-33.02" x2="60.96" y2="-20.32" width="0.1524" layer="91"/>
<junction x="60.96" y="-33.02"/>
<pinref part="#" gate="G$1" pin="0@A"/>
<wire x1="63.5" y1="-45.72" x2="60.96" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-45.72" x2="60.96" y2="-33.02" width="0.1524" layer="91"/>
<wire x1="60.96" y1="2.54" x2="63.5" y2="2.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<pinref part="3" gate="G$1" pin="1@B"/>
<wire x1="76.2" y1="-12.7" x2="76.2" y2="-10.16" width="0.1524" layer="91"/>
<pinref part="2" gate="G$1" pin="1@B"/>
<wire x1="55.88" y1="-12.7" x2="55.88" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="55.88" y1="-12.7" x2="76.2" y2="-12.7" width="0.1524" layer="91"/>
<junction x="55.88" y="-12.7"/>
<pinref part="1" gate="G$1" pin="1@B"/>
<wire x1="35.56" y1="-10.16" x2="35.56" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="35.56" y1="-12.7" x2="55.88" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-12.7" x2="81.28" y2="-12.7" width="0.1524" layer="91"/>
<junction x="76.2" y="-12.7"/>
</segment>
</net>
<net name="N$36" class="0">
<segment>
<pinref part="6" gate="G$1" pin="1@B"/>
<wire x1="76.2" y1="-25.4" x2="76.2" y2="-22.86" width="0.1524" layer="91"/>
<pinref part="5" gate="G$1" pin="1@B"/>
<wire x1="55.88" y1="-25.4" x2="55.88" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="55.88" y1="-25.4" x2="76.2" y2="-25.4" width="0.1524" layer="91"/>
<junction x="55.88" y="-25.4"/>
<pinref part="4" gate="G$1" pin="1@B"/>
<wire x1="35.56" y1="-22.86" x2="35.56" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="35.56" y1="-25.4" x2="55.88" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-25.4" x2="81.28" y2="-25.4" width="0.1524" layer="91"/>
<junction x="76.2" y="-25.4"/>
</segment>
</net>
<net name="N$37" class="0">
<segment>
<pinref part="8" gate="G$1" pin="1@B"/>
<wire x1="55.88" y1="-38.1" x2="55.88" y2="-35.56" width="0.1524" layer="91"/>
<pinref part="9" gate="G$1" pin="1@B"/>
<wire x1="76.2" y1="-35.56" x2="76.2" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-38.1" x2="55.88" y2="-38.1" width="0.1524" layer="91"/>
<junction x="55.88" y="-38.1"/>
<wire x1="35.56" y1="-38.1" x2="55.88" y2="-38.1" width="0.1524" layer="91"/>
<pinref part="7" gate="G$1" pin="1@B"/>
<wire x1="35.56" y1="-35.56" x2="35.56" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-38.1" x2="81.28" y2="-38.1" width="0.1524" layer="91"/>
<junction x="76.2" y="-38.1"/>
</segment>
</net>
<net name="N$38" class="0">
<segment>
<pinref part="#" gate="G$1" pin="1@B"/>
<wire x1="76.2" y1="-50.8" x2="76.2" y2="-48.26" width="0.1524" layer="91"/>
<pinref part="0" gate="G$1" pin="1@B"/>
<pinref part="*" gate="G$1" pin="1@B"/>
<wire x1="35.56" y1="-48.26" x2="35.56" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="35.56" y1="-50.8" x2="55.88" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="55.88" y1="-50.8" x2="55.88" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="55.88" y1="-50.8" x2="76.2" y2="-50.8" width="0.1524" layer="91"/>
<junction x="55.88" y="-50.8"/>
<wire x1="76.2" y1="-50.8" x2="81.28" y2="-50.8" width="0.1524" layer="91"/>
<junction x="76.2" y="-50.8"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
