RunAsDate v1.10
Copyright (c) 2007 - 2009 Nir Sofer
Web site: http://www.nirsoft.net
Description
RunAsDate is a small utility that allows you to run a program in the date
and time that you specify. This utility doesn't change the current system
date and time of your computer, but it only injects the date/time that
you specify into the desired application.
You can run multiple applications simultaneously, each application works
with different date and time, while the real date/time of your system
continues to run normally.
How does it work ?
RunAsDate intercepts the kernel API calls that returns the current date
and time (GetSystemTime, GetLocalTime, GetSystemTimeAsFileTime), and
replaces the current date/time with the date/time that you specify.
System Requirements
RunAsDate works under Windows 2000, Windows XP, Windows Server 2003,
Windows Server 2008, Windows Vista, and Windows 7. Older versions of
Windows are not supported. The is also x64 version available in a
separated download, for using with x64 applications.
Versions History
* Version 1.10:
  o Added auto complete support in the filename field.
  o Added x64 version.
* Version 1.05:
  o Fixed bug: When using 'Create Desktop Shortcut', the /immediate
    and /movetime options were not added to the shortcut's command-line
* Version 1.04:
  o The main dialog-box is now resizable.
* Version 1.03:
  o Added 'Immediate Mode' - Change the date immediately when the
    program starts.
* Version 1.02:
  o New option: Move the time forward according to the real time.
* Version 1.01:
  o New option: Create a shortcut on your desktop that will run a
    program with the date/time that you specify.
  o When you don't specify the time in the command-line, the current
    time will be used, instead of 00:00:00.
* Version 1.00 - First release.
Using RunAsDate
RunAsDate doesn't require any installation process or additional DLL
files. In order to start using it, simply copy the executable file
(RunAsDate.exe) to any folder you like, and run it.
In the main window of RunAsDate, select the desired date and time and the
application that you want to run. Optionally, you can also specify the
command-line parameters to run the program. Press the "Run" button to
start the application with the specified date/time.
Immediate Mode
In versions prior to 1.03, RunAsDate always waited until the kernel was
fully loaded, and only then injected the desired date/time. This mean
that some programs that get the date/time im very early stage, received
the real current date/time, instead of the fake date/time of RunAsDate.
Starting from version 1.03, when the 'Immediate Mode' is turned on,
RunAsDate inject the date/time immediately when the process starts,
without waiting to the kernel loading. However, this mode can also cause
troubles to some applications, especially if they were written in .NET
If executing an application from RunAsDate cause it to crash, you should
turn off the 'Immediate Mode'.
Using RunAsDate from Command-Line
You can also use RunAsDate from command-line, with the following syntax:
RunAsDate.exe {/immediate} {/movetime} [dd\mm\yyyy] {hh:mm:ss} [Program
to run] {Program parameters}
Examples:
RunAsDate.exe 22\10\2002 12:35:22 "C:\Program Files\Microsoft
Office\OFFICE11\OUTLOOK.EXE"
RunAsDate.exe 14\02\2005 "c:\temp\myprogram.exe" param1 param2
RunAsDate.exe /movetime 11\08\2004 16:21:42 "C:\Program Files\Microsoft
RunAsDate Limitations
* RunAsDate only works on 32-bit Windows applications. You cannot use
  it for old DOS 16-bit programs or for 64-bit Windows applications.
* RunAsDate will not affect applications that take the current
  date/time from another source. For example: application that loads the
  current date from remote server.
Translating RunAsDate To Another Language
RunAsDate allows you to easily translate all dialog-boxes and other
strings to other languages.
In order to do that, follow the instructions below:
1. Run RunAsDate with /savelangfile parameter:
   RunAsDate.exe /savelangfile
   A file named RunAsDate_lng.ini will be created in the folder of
   RunAsDate utility.
2. Open the created language file in Notepad or in any other text
   editor.
3. Translate the dialog-boxes and string entries to the desired
   language.
4. After you finish the translation, Run RunAsDate, and all translated
   strings will be loaded from the language file.
   If you want to run RunAsDate without the translation, simply rename
   the language file, or move it to another folder.
License
This utility is released as freeware. You are allowed to freely
distribute this utility via floppy disk, CD-ROM, Internet, or in any
other way, as long as you don't charge anything for this. If you
distribute this utility, you must include all files in the distribution
package, without any modification !
Be aware that selling this utility as a part of a software package is not
allowed !
Disclaimer
The software is provided "AS IS" without any warranty, either expressed
or implied, including, but not limited to, the implied warranties of
merchantability and fitness for a particular purpose. The author will not
be liable for any special, incidental, consequential or indirect damages
due to loss of data or any other reason.
Feedback
If you have any problem, suggestion, comment, or you found a bug in my
utility, you can send a message to nirsofer@yahoo.com
