<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
</layers>
<library>
<description>&lt;b&gt;Generic Memories&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TSOP32">
<description>&lt;b&gt;Thin Small Outline Package&lt;/b&gt;</description>
<wire x1="-9" y1="3.9" x2="9" y2="3.9" width="0.254" layer="21"/>
<wire x1="9" y1="3.9" x2="9" y2="-3.9" width="0.254" layer="21"/>
<wire x1="9" y1="-3.9" x2="-9" y2="-3.9" width="0.254" layer="21"/>
<wire x1="-9" y1="-3.9" x2="-9" y2="3.9" width="0.254" layer="21"/>
<circle x="-8.21" y="3" radius="0.4" width="0.254" layer="21"/>
<smd name="1" x="-9.85" y="3.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="2" x="-9.85" y="3.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="3" x="-9.85" y="2.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="4" x="-9.85" y="2.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="5" x="-9.85" y="1.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="6" x="-9.85" y="1.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="7" x="-9.85" y="0.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="8" x="-9.85" y="0.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="9" x="-9.85" y="-0.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="10" x="-9.85" y="-0.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="11" x="-9.85" y="-1.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="12" x="-9.85" y="-1.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="13" x="-9.85" y="-2.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="14" x="-9.85" y="-2.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="15" x="-9.85" y="-3.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="16" x="-9.85" y="-3.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="17" x="9.85" y="-3.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="18" x="9.85" y="-3.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="19" x="9.85" y="-2.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="20" x="9.85" y="-2.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="21" x="9.85" y="-1.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="22" x="9.85" y="-1.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="23" x="9.85" y="-0.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="24" x="9.85" y="-0.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="25" x="9.85" y="0.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="26" x="9.85" y="0.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="27" x="9.85" y="1.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="28" x="9.85" y="1.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="29" x="9.85" y="2.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="30" x="9.85" y="2.75" dx="1.2" dy="0.36" layer="1"/>
<smd name="31" x="9.85" y="3.25" dx="1.2" dy="0.36" layer="1"/>
<smd name="32" x="9.85" y="3.75" dx="1.2" dy="0.36" layer="1"/>
<text x="-9.144" y="4.318" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.128" y="-0.508" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-10.1096" y1="3.5976" x2="-9.0428" y2="3.9024" layer="51"/>
<rectangle x1="-10.1096" y1="3.0976" x2="-9.0428" y2="3.4024" layer="51"/>
<rectangle x1="-10.1096" y1="2.5976" x2="-9.0428" y2="2.9024" layer="51"/>
<rectangle x1="-10.1096" y1="2.0976" x2="-9.0428" y2="2.4024" layer="51"/>
<rectangle x1="-10.1096" y1="1.5976" x2="-9.0428" y2="1.9024" layer="51"/>
<rectangle x1="-10.1096" y1="1.0976" x2="-9.0428" y2="1.4024" layer="51"/>
<rectangle x1="-10.1096" y1="0.5976" x2="-9.0428" y2="0.9024" layer="51"/>
<rectangle x1="-10.1096" y1="0.0976" x2="-9.0428" y2="0.4024" layer="51"/>
<rectangle x1="-10.1096" y1="-0.4024" x2="-9.0428" y2="-0.0976" layer="51"/>
<rectangle x1="-10.1096" y1="-0.9024" x2="-9.0428" y2="-0.5976" layer="51"/>
<rectangle x1="-10.1096" y1="-1.4024" x2="-9.0428" y2="-1.0976" layer="51"/>
<rectangle x1="-10.1096" y1="-1.9024" x2="-9.0428" y2="-1.5976" layer="51"/>
<rectangle x1="-10.1096" y1="-2.4024" x2="-9.0428" y2="-2.0976" layer="51"/>
<rectangle x1="-10.1096" y1="-2.9024" x2="-9.0428" y2="-2.5976" layer="51"/>
<rectangle x1="-10.1096" y1="-3.4024" x2="-9.0428" y2="-3.0976" layer="51"/>
<rectangle x1="-10.1096" y1="-3.9024" x2="-9.0428" y2="-3.5976" layer="51"/>
<rectangle x1="9.0428" y1="-3.9024" x2="10.1096" y2="-3.5976" layer="51"/>
<rectangle x1="9.0428" y1="-3.4024" x2="10.1096" y2="-3.0976" layer="51"/>
<rectangle x1="9.0428" y1="-2.9024" x2="10.1096" y2="-2.5976" layer="51"/>
<rectangle x1="9.0428" y1="-2.4024" x2="10.1096" y2="-2.0976" layer="51"/>
<rectangle x1="9.0428" y1="-1.9024" x2="10.1096" y2="-1.5976" layer="51"/>
<rectangle x1="9.0428" y1="-1.4024" x2="10.1096" y2="-1.0976" layer="51"/>
<rectangle x1="9.0428" y1="-0.9024" x2="10.1096" y2="-0.5976" layer="51"/>
<rectangle x1="9.0428" y1="-0.4024" x2="10.1096" y2="-0.0976" layer="51"/>
<rectangle x1="9.0428" y1="0.0976" x2="10.1096" y2="0.4024" layer="51"/>
<rectangle x1="9.0428" y1="0.5976" x2="10.1096" y2="0.9024" layer="51"/>
<rectangle x1="9.0428" y1="1.0976" x2="10.1096" y2="1.4024" layer="51"/>
<rectangle x1="9.0428" y1="1.5976" x2="10.1096" y2="1.9024" layer="51"/>
<rectangle x1="9.0428" y1="2.0976" x2="10.1096" y2="2.4024" layer="51"/>
<rectangle x1="9.0428" y1="2.5976" x2="10.1096" y2="2.9024" layer="51"/>
<rectangle x1="9.0428" y1="3.0976" x2="10.1096" y2="3.4024" layer="51"/>
<rectangle x1="9.0428" y1="3.5976" x2="10.1096" y2="3.9024" layer="51"/>
</package>
<package name="SOP32X">
<description>&lt;b&gt;Small Outline Package&lt;/b&gt; X large</description>
<wire x1="10.22" y1="-4.5" x2="-10.22" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-10.22" y1="-4.5" x2="-10.22" y2="-4" width="0.2032" layer="51"/>
<wire x1="-10.22" y1="-4" x2="-10.22" y2="4.5" width="0.2032" layer="51"/>
<wire x1="-10.22" y1="4.5" x2="10.22" y2="4.5" width="0.2032" layer="51"/>
<wire x1="10.22" y1="-4" x2="-10.22" y2="-4" width="0.2032" layer="51"/>
<wire x1="10.22" y1="4.5" x2="10.22" y2="-4" width="0.2032" layer="51"/>
<wire x1="10.22" y1="-4" x2="10.22" y2="-4.5" width="0.2032" layer="51"/>
<smd name="2" x="-8.255" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="13" x="5.715" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-9.525" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="-6.985" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="-5.715" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="14" x="6.985" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="12" x="4.445" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="11" x="3.175" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="-3.175" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="9" x="0.635" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="-4.445" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-1.905" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="10" x="1.905" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-0.635" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="15" x="8.255" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="16" x="9.525" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="17" x="9.525" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="18" x="8.255" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="19" x="6.985" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="20" x="5.715" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="21" x="4.445" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="22" x="3.175" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="23" x="1.905" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="24" x="0.635" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="25" x="-0.635" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="26" x="-1.905" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="27" x="-3.175" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="28" x="-4.445" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="29" x="-5.715" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="30" x="-6.985" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="31" x="-8.255" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="32" x="-9.525" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<text x="-10.668" y="-4.445" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.017" y="-0.508" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-9.77" y1="-6.12" x2="-9.28" y2="-4.6" layer="51"/>
<rectangle x1="-8.5" y1="-6.12" x2="-8.01" y2="-4.6" layer="51"/>
<rectangle x1="-7.23" y1="-6.12" x2="-6.74" y2="-4.6" layer="51"/>
<rectangle x1="-5.96" y1="-6.12" x2="-5.47" y2="-4.6" layer="51"/>
<rectangle x1="-4.69" y1="-6.12" x2="-4.2" y2="-4.6" layer="51"/>
<rectangle x1="-3.42" y1="-6.12" x2="-2.93" y2="-4.6" layer="51"/>
<rectangle x1="-2.15" y1="-6.12" x2="-1.66" y2="-4.6" layer="51"/>
<rectangle x1="-0.88" y1="-6.12" x2="-0.39" y2="-4.6" layer="51"/>
<rectangle x1="0.39" y1="-6.12" x2="0.88" y2="-4.6" layer="51"/>
<rectangle x1="1.66" y1="-6.12" x2="2.15" y2="-4.6" layer="51"/>
<rectangle x1="2.93" y1="-6.12" x2="3.42" y2="-4.6" layer="51"/>
<rectangle x1="4.2" y1="-6.12" x2="4.69" y2="-4.6" layer="51"/>
<rectangle x1="5.47" y1="-6.12" x2="5.96" y2="-4.6" layer="51"/>
<rectangle x1="6.74" y1="-6.12" x2="7.23" y2="-4.6" layer="51"/>
<rectangle x1="8.01" y1="-6.12" x2="8.5" y2="-4.6" layer="51"/>
<rectangle x1="9.28" y1="-6.12" x2="9.77" y2="-4.6" layer="51"/>
<rectangle x1="9.28" y1="4.6" x2="9.77" y2="6.12" layer="51"/>
<rectangle x1="8.01" y1="4.6" x2="8.5" y2="6.12" layer="51"/>
<rectangle x1="6.74" y1="4.6" x2="7.23" y2="6.12" layer="51"/>
<rectangle x1="5.47" y1="4.6" x2="5.96" y2="6.12" layer="51"/>
<rectangle x1="4.2" y1="4.6" x2="4.69" y2="6.12" layer="51"/>
<rectangle x1="2.93" y1="4.6" x2="3.42" y2="6.12" layer="51"/>
<rectangle x1="1.66" y1="4.6" x2="2.15" y2="6.12" layer="51"/>
<rectangle x1="0.39" y1="4.6" x2="0.88" y2="6.12" layer="51"/>
<rectangle x1="-0.88" y1="4.6" x2="-0.39" y2="6.12" layer="51"/>
<rectangle x1="-2.15" y1="4.6" x2="-1.66" y2="6.12" layer="51"/>
<rectangle x1="-3.42" y1="4.6" x2="-2.93" y2="6.12" layer="51"/>
<rectangle x1="-4.69" y1="4.6" x2="-4.2" y2="6.12" layer="51"/>
<rectangle x1="-5.96" y1="4.6" x2="-5.47" y2="6.12" layer="51"/>
<rectangle x1="-7.23" y1="4.6" x2="-6.74" y2="6.12" layer="51"/>
<rectangle x1="-8.5" y1="4.6" x2="-8.01" y2="6.12" layer="51"/>
<rectangle x1="-9.77" y1="4.6" x2="-9.28" y2="6.12" layer="51"/>
</package>
<package name="SOP32W">
<description>&lt;b&gt;Small Outline Package&lt;/b&gt; widt</description>
<wire x1="10.32" y1="-3.7" x2="-10.32" y2="-3.7" width="0.2032" layer="51"/>
<wire x1="-10.32" y1="-3.7" x2="-10.32" y2="-3.2" width="0.2032" layer="51"/>
<wire x1="-10.32" y1="-3.2" x2="-10.32" y2="3.7" width="0.2032" layer="51"/>
<wire x1="-10.32" y1="3.7" x2="10.32" y2="3.7" width="0.2032" layer="51"/>
<wire x1="10.32" y1="-3.2" x2="-10.32" y2="-3.2" width="0.2032" layer="51"/>
<wire x1="10.32" y1="3.7" x2="10.32" y2="-3.2" width="0.2032" layer="51"/>
<wire x1="10.32" y1="-3.2" x2="10.32" y2="-3.7" width="0.2032" layer="51"/>
<smd name="2" x="-8.255" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="13" x="5.715" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-9.525" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="-6.985" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="-5.715" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="14" x="6.985" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="12" x="4.445" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="11" x="3.175" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="-3.175" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="9" x="0.635" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="-4.445" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-1.905" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="10" x="1.905" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-0.635" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="15" x="8.255" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="16" x="9.525" y="-4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="17" x="9.525" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="18" x="8.255" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="19" x="6.985" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="20" x="5.715" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="21" x="4.445" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="22" x="3.175" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="23" x="1.905" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="24" x="0.635" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="25" x="-0.635" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="26" x="-1.905" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="27" x="-3.175" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="28" x="-4.445" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="29" x="-5.715" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="30" x="-6.985" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="31" x="-8.255" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="32" x="-9.525" y="4.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-10.668" y="-3.683" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.525" y="-0.508" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-9.77" y1="-5.32" x2="-9.28" y2="-3.8" layer="51"/>
<rectangle x1="-8.5" y1="-5.32" x2="-8.01" y2="-3.8" layer="51"/>
<rectangle x1="-7.23" y1="-5.32" x2="-6.74" y2="-3.8" layer="51"/>
<rectangle x1="-5.96" y1="-5.32" x2="-5.47" y2="-3.8" layer="51"/>
<rectangle x1="-4.69" y1="-5.32" x2="-4.2" y2="-3.8" layer="51"/>
<rectangle x1="-3.42" y1="-5.32" x2="-2.93" y2="-3.8" layer="51"/>
<rectangle x1="-2.15" y1="-5.32" x2="-1.66" y2="-3.8" layer="51"/>
<rectangle x1="-0.88" y1="-5.32" x2="-0.39" y2="-3.8" layer="51"/>
<rectangle x1="0.39" y1="-5.32" x2="0.88" y2="-3.8" layer="51"/>
<rectangle x1="1.66" y1="-5.32" x2="2.15" y2="-3.8" layer="51"/>
<rectangle x1="2.93" y1="-5.32" x2="3.42" y2="-3.8" layer="51"/>
<rectangle x1="4.2" y1="-5.32" x2="4.69" y2="-3.8" layer="51"/>
<rectangle x1="5.47" y1="-5.32" x2="5.96" y2="-3.8" layer="51"/>
<rectangle x1="6.74" y1="-5.32" x2="7.23" y2="-3.8" layer="51"/>
<rectangle x1="8.01" y1="-5.32" x2="8.5" y2="-3.8" layer="51"/>
<rectangle x1="9.28" y1="-5.32" x2="9.77" y2="-3.8" layer="51"/>
<rectangle x1="9.28" y1="3.8" x2="9.77" y2="5.32" layer="51"/>
<rectangle x1="8.01" y1="3.8" x2="8.5" y2="5.32" layer="51"/>
<rectangle x1="6.74" y1="3.8" x2="7.23" y2="5.32" layer="51"/>
<rectangle x1="5.47" y1="3.8" x2="5.96" y2="5.32" layer="51"/>
<rectangle x1="4.2" y1="3.8" x2="4.69" y2="5.32" layer="51"/>
<rectangle x1="2.93" y1="3.8" x2="3.42" y2="5.32" layer="51"/>
<rectangle x1="1.66" y1="3.8" x2="2.15" y2="5.32" layer="51"/>
<rectangle x1="0.39" y1="3.8" x2="0.88" y2="5.32" layer="51"/>
<rectangle x1="-0.88" y1="3.8" x2="-0.39" y2="5.32" layer="51"/>
<rectangle x1="-2.15" y1="3.8" x2="-1.66" y2="5.32" layer="51"/>
<rectangle x1="-3.42" y1="3.8" x2="-2.93" y2="5.32" layer="51"/>
<rectangle x1="-4.69" y1="3.8" x2="-4.2" y2="5.32" layer="51"/>
<rectangle x1="-5.96" y1="3.8" x2="-5.47" y2="5.32" layer="51"/>
<rectangle x1="-7.23" y1="3.8" x2="-6.74" y2="5.32" layer="51"/>
<rectangle x1="-8.5" y1="3.8" x2="-8.01" y2="5.32" layer="51"/>
<rectangle x1="-9.77" y1="3.8" x2="-9.28" y2="5.32" layer="51"/>
</package>
<package name="SOP32L">
<description>&lt;b&gt;Small Outline Package&lt;/b&gt; large</description>
<wire x1="10.22" y1="-5.516" x2="-10.22" y2="-5.516" width="0.2032" layer="51"/>
<wire x1="-10.22" y1="-5.516" x2="-10.22" y2="-4.762" width="0.2032" layer="51"/>
<wire x1="-10.22" y1="-4.762" x2="-10.22" y2="5.516" width="0.2032" layer="51"/>
<wire x1="-10.22" y1="5.516" x2="10.22" y2="5.516" width="0.2032" layer="51"/>
<wire x1="10.22" y1="-4.762" x2="-10.22" y2="-4.762" width="0.2032" layer="51"/>
<wire x1="10.22" y1="5.516" x2="10.22" y2="-4.762" width="0.2032" layer="51"/>
<wire x1="10.22" y1="-4.762" x2="10.22" y2="-5.516" width="0.2032" layer="51"/>
<circle x="-8.89" y="-3.81" radius="0.635" width="0.254" layer="21"/>
<smd name="2" x="-8.255" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="13" x="5.715" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-9.525" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="-6.985" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="-5.715" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="14" x="6.985" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="12" x="4.445" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="11" x="3.175" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="-3.175" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="9" x="0.635" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="-4.445" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-1.905" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="10" x="1.905" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-0.635" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="15" x="8.255" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="16" x="9.525" y="-6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="17" x="9.525" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="18" x="8.255" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="19" x="6.985" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="20" x="5.715" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="21" x="4.445" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="22" x="3.175" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="23" x="1.905" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="24" x="0.635" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="25" x="-0.635" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="26" x="-1.905" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="27" x="-3.175" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="28" x="-4.445" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="29" x="-5.715" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="30" x="-6.985" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="31" x="-8.255" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<smd name="32" x="-9.525" y="6.416" dx="0.6" dy="2.2" layer="1"/>
<text x="-10.668" y="-5.207" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-8.509" y="-0.762" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-9.77" y1="-7.136" x2="-9.28" y2="-5.616" layer="51"/>
<rectangle x1="-8.5" y1="-7.136" x2="-8.01" y2="-5.616" layer="51"/>
<rectangle x1="-7.23" y1="-7.136" x2="-6.74" y2="-5.616" layer="51"/>
<rectangle x1="-5.96" y1="-7.136" x2="-5.47" y2="-5.616" layer="51"/>
<rectangle x1="-4.69" y1="-7.136" x2="-4.2" y2="-5.616" layer="51"/>
<rectangle x1="-3.42" y1="-7.136" x2="-2.93" y2="-5.616" layer="51"/>
<rectangle x1="-2.15" y1="-7.136" x2="-1.66" y2="-5.616" layer="51"/>
<rectangle x1="-0.88" y1="-7.136" x2="-0.39" y2="-5.616" layer="51"/>
<rectangle x1="0.39" y1="-7.136" x2="0.88" y2="-5.616" layer="51"/>
<rectangle x1="1.66" y1="-7.136" x2="2.15" y2="-5.616" layer="51"/>
<rectangle x1="2.93" y1="-7.136" x2="3.42" y2="-5.616" layer="51"/>
<rectangle x1="4.2" y1="-7.136" x2="4.69" y2="-5.616" layer="51"/>
<rectangle x1="5.47" y1="-7.136" x2="5.96" y2="-5.616" layer="51"/>
<rectangle x1="6.74" y1="-7.136" x2="7.23" y2="-5.616" layer="51"/>
<rectangle x1="8.01" y1="-7.136" x2="8.5" y2="-5.616" layer="51"/>
<rectangle x1="9.28" y1="-7.136" x2="9.77" y2="-5.616" layer="51"/>
<rectangle x1="9.28" y1="5.616" x2="9.77" y2="7.136" layer="51"/>
<rectangle x1="8.01" y1="5.616" x2="8.5" y2="7.136" layer="51"/>
<rectangle x1="6.74" y1="5.616" x2="7.23" y2="7.136" layer="51"/>
<rectangle x1="5.47" y1="5.616" x2="5.96" y2="7.136" layer="51"/>
<rectangle x1="4.2" y1="5.616" x2="4.69" y2="7.136" layer="51"/>
<rectangle x1="2.93" y1="5.616" x2="3.42" y2="7.136" layer="51"/>
<rectangle x1="1.66" y1="5.616" x2="2.15" y2="7.136" layer="51"/>
<rectangle x1="0.39" y1="5.616" x2="0.88" y2="7.136" layer="51"/>
<rectangle x1="-0.88" y1="5.616" x2="-0.39" y2="7.136" layer="51"/>
<rectangle x1="-2.15" y1="5.616" x2="-1.66" y2="7.136" layer="51"/>
<rectangle x1="-3.42" y1="5.616" x2="-2.93" y2="7.136" layer="51"/>
<rectangle x1="-4.69" y1="5.616" x2="-4.2" y2="7.136" layer="51"/>
<rectangle x1="-5.96" y1="5.616" x2="-5.47" y2="7.136" layer="51"/>
<rectangle x1="-7.23" y1="5.616" x2="-6.74" y2="7.136" layer="51"/>
<rectangle x1="-8.5" y1="5.616" x2="-8.01" y2="7.136" layer="51"/>
<rectangle x1="-9.77" y1="5.616" x2="-9.28" y2="7.136" layer="51"/>
</package>
<package name="SOP28X">
<wire x1="8.95" y1="-4.5" x2="-8.95" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-8.95" y1="-4.5" x2="-8.95" y2="-4" width="0.2032" layer="51"/>
<wire x1="-8.95" y1="-4" x2="-8.95" y2="4.5" width="0.2032" layer="51"/>
<wire x1="-8.95" y1="4.5" x2="8.95" y2="4.5" width="0.2032" layer="51"/>
<wire x1="8.95" y1="-4" x2="-8.95" y2="-4" width="0.2032" layer="51"/>
<wire x1="8.95" y1="4.5" x2="8.95" y2="-4" width="0.2032" layer="51"/>
<wire x1="8.95" y1="-4" x2="8.95" y2="-4.5" width="0.2032" layer="51"/>
<smd name="2" x="-6.985" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="13" x="6.985" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-8.255" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="-5.715" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="-4.445" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="14" x="8.255" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="12" x="5.715" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="11" x="4.445" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="-1.905" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="9" x="1.905" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="-3.175" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="10" x="3.175" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="0.635" y="-5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="15" x="8.255" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="16" x="6.985" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="17" x="5.715" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="18" x="4.445" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="19" x="3.175" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="20" x="1.905" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="21" x="0.635" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="22" x="-0.635" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="23" x="-1.905" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="24" x="-3.175" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="25" x="-4.445" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="26" x="-5.715" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="27" x="-6.985" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<smd name="28" x="-8.255" y="5.4" dx="0.6" dy="2.2" layer="1"/>
<text x="-9.398" y="-4.445" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-7.493" y="-0.508" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DIL16">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="10.16" y1="2.921" x2="-10.16" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.921" x2="-10.16" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="-10.16" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.016" x2="-10.16" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-10.541" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-7.493" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL18">
<wire x1="11.43" y1="2.921" x2="-11.43" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.921" x2="-11.43" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="-11.43" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.016" x2="-11.43" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-11.684" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-9.525" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL20">
<wire x1="12.7" y1="2.921" x2="-12.7" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="12.7" y1="2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="2.921" x2="-12.7" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="-12.7" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.016" x2="-12.7" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-13.081" y="-3.048" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.779" y="-0.381" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DIL24">
<wire x1="-15.24" y1="6.731" x2="-15.24" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-6.731" x2="-15.24" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="1.016" x2="-15.24" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-15.24" y1="-6.731" x2="15.24" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.731" x2="15.24" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.731" x2="-15.24" y2="6.731" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-15.494" y="-6.731" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-11.303" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL28">
<wire x1="17.78" y1="6.731" x2="-17.78" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-6.731" x2="17.78" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="17.78" y1="6.731" x2="17.78" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="6.731" x2="-17.78" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-6.731" x2="-17.78" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.016" x2="-17.78" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-18.161" y="-6.604" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.779" y="-0.889" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="DIL32">
<wire x1="20.32" y1="6.731" x2="-20.32" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-6.731" x2="20.32" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="20.32" y1="6.731" x2="20.32" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="6.731" x2="-20.32" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-6.731" x2="-20.32" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="1.016" x2="-20.32" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-20.701" y="-6.604" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-16.891" y="-0.889" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="DIL40">
<wire x1="25.4" y1="6.731" x2="-25.4" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.731" x2="25.4" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="25.4" y1="6.731" x2="25.4" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.731" x2="-25.4" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.731" x2="-25.4" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.889" x2="-25.4" y2="-1.143" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-25.908" y="-6.604" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-17.145" y="-1.016" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="DIL48">
<wire x1="-29.845" y1="-6.604" x2="29.845" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="29.845" y1="-6.604" x2="29.845" y2="6.604" width="0.1524" layer="21"/>
<wire x1="29.845" y1="6.604" x2="-29.845" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="6.604" x2="-29.845" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="-6.604" x2="-29.845" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="0.889" x2="-29.845" y2="-1.143" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-29.21" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-26.67" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="26.67" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="29.21" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="29.21" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="26.67" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="41" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="42" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="43" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="44" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="45" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="46" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="47" x="-26.67" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="48" x="-29.21" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-30.226" y="-6.35" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-16.637" y="-1.016" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL22-3">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.3 inch</description>
<wire x1="-14.605" y1="-0.635" x2="-14.605" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="0.635" x2="-14.605" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="14.605" y1="-2.794" x2="14.605" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-2.794" x2="14.605" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="2.794" x2="-14.605" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="2.794" x2="14.605" y2="2.794" width="0.1524" layer="21"/>
<pad name="1" x="-12.7" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="12.7" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-12.7" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-14.9098" y="-2.667" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-10.795" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="PCDIP28-CAPHAT">
<description>&lt;b&gt;28-pin PCDIP, CAPHAT(TM) Package&lt;/b&gt; PCDIP28 (PC)&lt;p&gt;
Source: http://www.st.com/stonline/books/pdf/docs/2611.pdf#search=%22M48T35%22</description>
<wire x1="18.85" y1="9.325" x2="-18.85" y2="9.325" width="0.1524" layer="21"/>
<wire x1="-18.85" y1="-9.325" x2="18.85" y2="-9.325" width="0.1524" layer="21"/>
<wire x1="18.85" y1="9.325" x2="18.85" y2="-9.325" width="0.1524" layer="21"/>
<wire x1="-18.85" y1="9.325" x2="-18.85" y2="1" width="0.1524" layer="21"/>
<wire x1="-18.85" y1="-9.325" x2="-18.85" y2="-1" width="0.1524" layer="21"/>
<wire x1="-18.85" y1="1" x2="-18.85" y2="-1" width="0.1524" layer="21" curve="-180"/>
<text x="-19.685" y="-8.255" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-12.065" y="-0.635" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="SOH28-SNAPHAT">
<description>&lt;b&gt;28-pin SOH28 (MH)&lt;/b&gt;&lt;p&gt;
<wire x1="9.15" y1="-4.35" x2="-9.15" y2="-4.35" width="0.2032" layer="51"/>
<wire x1="-9.15" y1="-4.35" x2="-9.15" y2="-4" width="0.2032" layer="51"/>
<wire x1="-9.15" y1="-4" x2="-9.15" y2="4.35" width="0.2032" layer="51"/>
<wire x1="-9.15" y1="4.35" x2="9.15" y2="4.35" width="0.2032" layer="51"/>
<wire x1="9.15" y1="-4" x2="-9.15" y2="-4" width="0.2032" layer="51"/>
<wire x1="9.15" y1="4.35" x2="9.15" y2="-4" width="0.2032" layer="51"/>
<wire x1="9.15" y1="-4" x2="9.15" y2="-4.35" width="0.2032" layer="51"/>
<wire x1="-9.025" y1="0.55" x2="-7.435" y2="0.55" width="0.1016" layer="21"/>
<wire x1="-7.435" y1="0.55" x2="-7.435" y2="2.825" width="0.1016" layer="21" curve="180"/>
<wire x1="-7.435" y1="2.825" x2="-9.025" y2="2.825" width="0.1016" layer="21"/>
<wire x1="-7.435" y1="-0.575" x2="-9.025" y2="-0.575" width="0.1016" layer="21"/>
<wire x1="-7.435" y1="-2.85" x2="-7.435" y2="-0.575" width="0.1016" layer="21" curve="180"/>
<wire x1="-9.025" y1="-2.85" x2="-7.435" y2="-2.85" width="0.1016" layer="21"/>
<wire x1="9.025" y1="-0.55" x2="7.435" y2="-0.55" width="0.1016" layer="21"/>
<wire x1="7.435" y1="-0.55" x2="7.435" y2="-2.825" width="0.1016" layer="21" curve="180"/>
<wire x1="7.435" y1="-2.825" x2="9.025" y2="-2.825" width="0.1016" layer="21"/>
<wire x1="7.435" y1="0.575" x2="9.025" y2="0.575" width="0.1016" layer="21"/>
<wire x1="7.435" y1="2.85" x2="7.435" y2="0.575" width="0.1016" layer="21" curve="180"/>
<wire x1="9.025" y1="2.85" x2="7.435" y2="2.85" width="0.1016" layer="21"/>
<circle x="-7.435" y="-1.7" radius="0.875" width="0.1016" layer="21"/>
<circle x="-7.435" y="1.7" radius="0.875" width="0.1016" layer="21"/>
<circle x="-7.435" y="1.7" radius="0.301" width="0.1016" layer="21"/>
<circle x="-7.435" y="-1.7" radius="0.301" width="0.1016" layer="21"/>
<circle x="7.435" y="1.7" radius="0.875" width="0.1016" layer="21"/>
<circle x="7.435" y="-1.7" radius="0.875" width="0.1016" layer="21"/>
<circle x="7.435" y="-1.7" radius="0.301" width="0.1016" layer="21"/>
<circle x="7.435" y="1.7" radius="0.301" width="0.1016" layer="21"/>
<text x="-9.525" y="-4.445" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-5.08" y="-0.635" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-8.5" y1="-6.345" x2="-8.01" y2="-4.4" layer="51"/>
<rectangle x1="-7.23" y1="-6.345" x2="-6.74" y2="-4.4" layer="51"/>
<rectangle x1="-5.96" y1="-6.345" x2="-5.47" y2="-4.4" layer="51"/>
<rectangle x1="-4.69" y1="-6.345" x2="-4.2" y2="-4.4" layer="51"/>
<rectangle x1="-3.42" y1="-6.345" x2="-2.93" y2="-4.4" layer="51"/>
<rectangle x1="-2.15" y1="-6.345" x2="-1.66" y2="-4.4" layer="51"/>
<rectangle x1="-0.88" y1="-6.345" x2="-0.39" y2="-4.4" layer="51"/>
<rectangle x1="0.39" y1="-6.345" x2="0.88" y2="-4.4" layer="51"/>
<rectangle x1="1.66" y1="-6.345" x2="2.15" y2="-4.4" layer="51"/>
<rectangle x1="2.93" y1="-6.345" x2="3.42" y2="-4.4" layer="51"/>
<rectangle x1="4.2" y1="-6.345" x2="4.69" y2="-4.4" layer="51"/>
<rectangle x1="5.47" y1="-6.345" x2="5.96" y2="-4.4" layer="51"/>
<rectangle x1="6.74" y1="-6.345" x2="7.23" y2="-4.4" layer="51"/>
<rectangle x1="8.01" y1="-6.345" x2="8.5" y2="-4.4" layer="51"/>
<rectangle x1="8.01" y1="4.4" x2="8.5" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="6.74" y1="4.4" x2="7.23" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="5.47" y1="4.4" x2="5.96" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="4.2" y1="4.4" x2="4.69" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="2.93" y1="4.4" x2="3.42" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="1.66" y1="4.4" x2="2.15" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="0.39" y1="4.4" x2="0.88" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="-0.88" y1="4.4" x2="-0.39" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="-2.15" y1="4.4" x2="-1.66" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="-3.42" y1="4.4" x2="-2.93" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="-4.69" y1="4.4" x2="-4.2" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="-5.96" y1="4.4" x2="-5.47" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="-7.23" y1="4.4" x2="-6.74" y2="6.345" layer="51" rot="R180"/>
<rectangle x1="-8.5" y1="4.4" x2="-8.01" y2="6.345" layer="51" rot="R180"/>
</package>
<package name="PLCC32R">
<description>&lt;b&gt;PLASTIC LEADED CHIP CARRIER&lt;/b&gt;&lt;p&gt;
rectangle</description>
<wire x1="-5.61" y1="-6.93" x2="5.61" y2="-6.93" width="0.2032" layer="51"/>
<wire x1="5.61" y1="-6.93" x2="5.61" y2="6.93" width="0.2032" layer="51"/>
<wire x1="5.61" y1="6.93" x2="-4.77" y2="6.93" width="0.2032" layer="51"/>
<wire x1="-4.77" y1="6.93" x2="-5.61" y2="6.09" width="0.2032" layer="51"/>
<wire x1="-5.61" y1="6.09" x2="-5.61" y2="-6.93" width="0.2032" layer="51"/>
<circle x="0" y="5.4" radius="0.3" width="0.6096" layer="51"/>
<smd name="1" x="0" y="6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="2" x="-1.27" y="6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="-2.54" y="6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="-3.81" y="6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="-5.7" y="3.81" dx="2.2" dy="0.6" layer="1"/>
<smd name="7" x="-5.7" y="2.54" dx="2.2" dy="0.6" layer="1"/>
<smd name="8" x="-5.7" y="1.27" dx="2.2" dy="0.6" layer="1"/>
<smd name="9" x="-5.7" y="0" dx="2.2" dy="0.6" layer="1"/>
<smd name="10" x="-5.7" y="-1.27" dx="2.2" dy="0.6" layer="1"/>
<smd name="11" x="-5.7" y="-2.54" dx="2.2" dy="0.6" layer="1"/>
<smd name="12" x="-5.7" y="-3.81" dx="2.2" dy="0.6" layer="1"/>
<smd name="5" x="-5.7" y="5.08" dx="2.2" dy="0.6" layer="1"/>
<smd name="13" x="-5.7" y="-5.08" dx="2.2" dy="0.6" layer="1"/>
<smd name="14" x="-3.81" y="-6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="15" x="-2.54" y="-6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="16" x="-1.27" y="-6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="17" x="0" y="-6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="18" x="1.27" y="-6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="19" x="2.54" y="-6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="20" x="3.81" y="-6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="21" x="5.7" y="-5.08" dx="2.2" dy="0.6" layer="1"/>
<smd name="22" x="5.7" y="-3.81" dx="2.2" dy="0.6" layer="1"/>
<smd name="23" x="5.7" y="-2.54" dx="2.2" dy="0.6" layer="1"/>
<smd name="24" x="5.7" y="-1.27" dx="2.2" dy="0.6" layer="1"/>
<smd name="25" x="5.7" y="0" dx="2.2" dy="0.6" layer="1"/>
<smd name="26" x="5.7" y="1.27" dx="2.2" dy="0.6" layer="1"/>
<smd name="27" x="5.7" y="2.54" dx="2.2" dy="0.6" layer="1"/>
<smd name="28" x="5.7" y="3.81" dx="2.2" dy="0.6" layer="1"/>
<smd name="29" x="5.7" y="5.08" dx="2.2" dy="0.6" layer="1"/>
<smd name="30" x="3.81" y="6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="31" x="2.54" y="6.9" dx="0.6" dy="2.2" layer="1"/>
<smd name="32" x="1.27" y="6.9" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.825" y="5.2751" size="1.778" layer="25" rot="R270">&gt;NAME</text>
<text x="0.6949" y="5.2451" size="1.778" layer="27" rot="R270">&gt;VALUE</text>
<rectangle x1="-0.2601" y1="6.9499" x2="0.27" y2="7.5301" layer="51"/>
<rectangle x1="-1.5301" y1="6.9499" x2="-1" y2="7.5301" layer="51"/>
<rectangle x1="-2.8001" y1="6.9499" x2="-2.27" y2="7.5301" layer="51"/>
<rectangle x1="-4.0701" y1="6.9499" x2="-3.54" y2="7.5301" layer="51"/>
<rectangle x1="-6.3299" y1="4.8199" x2="-5.7501" y2="5.35" layer="51"/>
<rectangle x1="-6.3299" y1="3.5499" x2="-5.7501" y2="4.08" layer="51"/>
<rectangle x1="-6.3299" y1="2.2799" x2="-5.7501" y2="2.81" layer="51"/>
<rectangle x1="-6.3299" y1="1.0099" x2="-5.7501" y2="1.54" layer="51"/>
<rectangle x1="-6.3299" y1="-0.2601" x2="-5.7501" y2="0.27" layer="51"/>
<rectangle x1="-6.3299" y1="-1.5301" x2="-5.7501" y2="-1" layer="51"/>
<rectangle x1="-6.3299" y1="-2.8001" x2="-5.7501" y2="-2.27" layer="51"/>
<rectangle x1="-6.3299" y1="-4.0701" x2="-5.7501" y2="-3.54" layer="51"/>
<rectangle x1="-6.3299" y1="-5.3401" x2="-5.7501" y2="-4.81" layer="51"/>
<rectangle x1="-4.08" y1="-7.5301" x2="-3.5499" y2="-6.9499" layer="51"/>
<rectangle x1="-2.81" y1="-7.5301" x2="-2.2799" y2="-6.9499" layer="51"/>
<rectangle x1="-1.54" y1="-7.5301" x2="-1.0099" y2="-6.9499" layer="51"/>
<rectangle x1="-0.27" y1="-7.5301" x2="0.2601" y2="-6.9499" layer="51"/>
<rectangle x1="1" y1="-7.5301" x2="1.5301" y2="-6.9499" layer="51"/>
<rectangle x1="2.27" y1="-7.5301" x2="2.8001" y2="-6.9499" layer="51"/>
<rectangle x1="3.54" y1="-7.5301" x2="4.0701" y2="-6.9499" layer="51"/>
<rectangle x1="5.7501" y1="-5.35" x2="6.3299" y2="-4.8199" layer="51"/>
<rectangle x1="5.7501" y1="-4.08" x2="6.3299" y2="-3.5499" layer="51"/>
<rectangle x1="5.7501" y1="-2.81" x2="6.3299" y2="-2.2799" layer="51"/>
<rectangle x1="5.7501" y1="-1.54" x2="6.3299" y2="-1.0099" layer="51"/>
<rectangle x1="5.7501" y1="-0.27" x2="6.3299" y2="0.2601" layer="51"/>
<rectangle x1="5.7501" y1="1" x2="6.3299" y2="1.5301" layer="51"/>
<rectangle x1="5.7501" y1="2.27" x2="6.3299" y2="2.8001" layer="51"/>
<rectangle x1="5.7501" y1="3.54" x2="6.3299" y2="4.0701" layer="51"/>
<rectangle x1="5.7501" y1="4.81" x2="6.3299" y2="5.3401" layer="51"/>
<rectangle x1="3.5499" y1="6.9499" x2="4.08" y2="7.5301" layer="51"/>
<rectangle x1="2.2799" y1="6.9499" x2="2.81" y2="7.5301" layer="51"/>
<rectangle x1="1.0099" y1="6.9499" x2="1.54" y2="7.5301" layer="51"/>
</package>
<package name="TFBGA48">
<description>&lt;b&gt;48-ball Thin-profile, Fine-pitch Ball Grid Array&lt;/b&gt; (TFBGA) 6mm x 8mm SST Package Code: B3K&lt;p&gt;
Source: http://www.sst.com/dotAsset/40782.pdf</description>
<wire x1="-2.9" y1="3.9" x2="2.9" y2="3.9" width="0.2032" layer="21"/>
<wire x1="2.9" y1="3.9" x2="2.9" y2="-3.9" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-3.9" x2="-2.9" y2="-3.9" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-3.9" x2="-2.9" y2="3.9" width="0.2032" layer="21"/>
<circle x="-2" y="2.8" radius="0.225" width="0" layer="29"/>
<circle x="-2" y="2" radius="0.225" width="0" layer="29"/>
<circle x="-2" y="1.2" radius="0.225" width="0" layer="29"/>
<circle x="-2" y="0.4" radius="0.225" width="0" layer="29"/>
<circle x="-2" y="-0.4" radius="0.225" width="0" layer="29"/>
<circle x="-2" y="-1.2" radius="0.225" width="0" layer="29"/>
<circle x="-2" y="-2" radius="0.225" width="0" layer="29"/>
<circle x="-2" y="-2.8" radius="0.225" width="0" layer="29"/>
<circle x="-1.2" y="2.8" radius="0.225" width="0" layer="29"/>
<circle x="-1.2" y="2" radius="0.225" width="0" layer="29"/>
<circle x="-1.2" y="1.2" radius="0.225" width="0" layer="29"/>
<circle x="-1.2" y="0.4" radius="0.225" width="0" layer="29"/>
<circle x="-1.2" y="-0.4" radius="0.225" width="0" layer="29"/>
<circle x="-1.2" y="-1.2" radius="0.225" width="0" layer="29"/>
<circle x="-1.2" y="-2" radius="0.225" width="0" layer="29"/>
<circle x="-1.2" y="-2.8" radius="0.225" width="0" layer="29"/>
<circle x="-0.4" y="2.8" radius="0.225" width="0" layer="29"/>
<circle x="-0.4" y="2" radius="0.225" width="0" layer="29"/>
<circle x="-0.4" y="1.2" radius="0.225" width="0" layer="29"/>
<circle x="-0.4" y="0.4" radius="0.225" width="0" layer="29"/>
<circle x="-0.4" y="-0.4" radius="0.225" width="0" layer="29"/>
<circle x="-0.4" y="-1.2" radius="0.225" width="0" layer="29"/>
<circle x="-0.4" y="-2" radius="0.225" width="0" layer="29"/>
<circle x="-0.4" y="-2.8" radius="0.225" width="0" layer="29"/>
<circle x="0.4" y="2.8" radius="0.225" width="0" layer="29"/>
<circle x="0.4" y="2" radius="0.225" width="0" layer="29"/>
<circle x="0.4" y="1.2" radius="0.225" width="0" layer="29"/>
<circle x="0.4" y="0.4" radius="0.225" width="0" layer="29"/>
<circle x="0.4" y="-0.4" radius="0.225" width="0" layer="29"/>
<circle x="0.4" y="-1.2" radius="0.225" width="0" layer="29"/>
<circle x="0.4" y="-2" radius="0.225" width="0" layer="29"/>
<circle x="0.4" y="-2.8" radius="0.225" width="0" layer="29"/>
<circle x="1.2" y="2.8" radius="0.225" width="0" layer="29"/>
<circle x="1.2" y="2" radius="0.225" width="0" layer="29"/>
<circle x="1.2" y="1.2" radius="0.225" width="0" layer="29"/>
<circle x="1.2" y="0.4" radius="0.225" width="0" layer="29"/>
<circle x="1.2" y="-0.4" radius="0.225" width="0" layer="29"/>
<circle x="1.2" y="-1.2" radius="0.225" width="0" layer="29"/>
<circle x="1.2" y="-2" radius="0.225" width="0" layer="29"/>
<circle x="1.2" y="-2.8" radius="0.225" width="0" layer="29"/>
<circle x="2" y="2.8" radius="0.225" width="0" layer="29"/>
<circle x="2" y="2" radius="0.225" width="0" layer="29"/>
<circle x="2" y="1.2" radius="0.225" width="0" layer="29"/>
<circle x="2" y="0.4" radius="0.225" width="0" layer="29"/>
<circle x="2" y="-0.4" radius="0.225" width="0" layer="29"/>
<circle x="2" y="-1.2" radius="0.225" width="0" layer="29"/>
<circle x="2" y="-2" radius="0.225" width="0" layer="29"/>
<circle x="2" y="-2.8" radius="0.225" width="0" layer="29"/>
<smd name="A1" x="-2" y="2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B1" x="-2" y="2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C1" x="-2" y="1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D1" x="-2" y="0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E1" x="-2" y="-0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F1" x="-2" y="-1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G1" x="-2" y="-2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H1" x="-2" y="-2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A2" x="-1.2" y="2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B2" x="-1.2" y="2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C2" x="-1.2" y="1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D2" x="-1.2" y="0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E2" x="-1.2" y="-0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F2" x="-1.2" y="-1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G2" x="-1.2" y="-2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H2" x="-1.2" y="-2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A3" x="-0.4" y="2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B3" x="-0.4" y="2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C3" x="-0.4" y="1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D3" x="-0.4" y="0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E3" x="-0.4" y="-0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F3" x="-0.4" y="-1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G3" x="-0.4" y="-2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H3" x="-0.4" y="-2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A4" x="0.4" y="2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B4" x="0.4" y="2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C4" x="0.4" y="1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D4" x="0.4" y="0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E4" x="0.4" y="-0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F4" x="0.4" y="-1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G4" x="0.4" y="-2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H4" x="0.4" y="-2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A5" x="1.2" y="2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B5" x="1.2" y="2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C5" x="1.2" y="1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D5" x="1.2" y="0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E5" x="1.2" y="-0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F5" x="1.2" y="-1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G5" x="1.2" y="-2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H5" x="1.2" y="-2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A6" x="2" y="2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B6" x="2" y="2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C6" x="2" y="1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D6" x="2" y="0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E6" x="2" y="-0.4" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F6" x="2" y="-1.2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G6" x="2" y="-2" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H6" x="2" y="-2.8" dx="0.5" dy="0.5" layer="1" roundness="100" stop="no" cream="no"/>
<text x="-3.0208" y="4.1462" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.0208" y="-5.9242" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="21">
<vertex x="-2.9" y="3.1"/>
<vertex x="-2.1" y="3.9"/>
<vertex x="-2.9" y="3.9"/>
</polygon>
</package>
<package name="TSOP50-II">
<description>&lt;b&gt;TSOP 50&lt;/b&gt; Type II&lt;p&gt;
Source: www.issi.com .. IS42S16100.pdf</description>
<wire x1="-10.3" y1="5.05" x2="10.3" y2="5.05" width="0.2032" layer="51"/>
<wire x1="10.3" y1="5.05" x2="10.3" y2="-5.05" width="0.2032" layer="21"/>
<wire x1="10.3" y1="-5.05" x2="-10.3" y2="-5.05" width="0.2032" layer="51"/>
<wire x1="-10.3" y1="-5.05" x2="-10.3" y2="5.05" width="0.2032" layer="21"/>
<circle x="-9.2" y="-4" radius="0.4" width="0" layer="21"/>
<smd name="1" x="-9.6" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="2" x="-8.8" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="3" x="-8" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="4" x="-7.2" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="5" x="-6.4" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="6" x="-5.6" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="7" x="-4.8" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="8" x="-4" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="9" x="-3.2" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="10" x="-2.4" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="11" x="-1.6" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="12" x="-0.8" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="13" x="0" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="14" x="0.8" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="15" x="1.6" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="16" x="2.4" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="17" x="3.2" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="18" x="4" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="19" x="4.8" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="20" x="5.6" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="21" x="6.4" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="22" x="7.2" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="23" x="8" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="24" x="8.8" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="25" x="9.6" y="-5.6" dx="0.5" dy="1.1" layer="1" stop="no" cream="no"/>
<smd name="26" x="9.6" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="27" x="8.8" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="28" x="8" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="29" x="7.2" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="30" x="6.4" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="31" x="5.6" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="32" x="4.8" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="33" x="4" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="34" x="3.2" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="35" x="2.4" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="36" x="1.6" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="37" x="0.8" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="38" x="0" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="39" x="-0.8" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="40" x="-1.6" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="41" x="-2.4" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="42" x="-3.2" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="43" x="-4" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="44" x="-4.8" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="45" x="-5.6" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="46" x="-6.4" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="47" x="-7.2" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="48" x="-8" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="49" x="-8.8" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<smd name="50" x="-9.6" y="5.6" dx="0.5" dy="1.1" layer="1" rot="R180" stop="no" cream="no"/>
<text x="-10.8" y="-4.4" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-6" y="-0.4" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-9.9" y1="-6.225" x2="-9.3" y2="-4.975" layer="29"/>
<rectangle x1="-9.8" y1="-6.125" x2="-9.4" y2="-5.075" layer="31"/>
<rectangle x1="-9.1" y1="-6.225" x2="-8.5" y2="-4.975" layer="29"/>
<rectangle x1="-9" y1="-6.125" x2="-8.6" y2="-5.075" layer="31"/>
<rectangle x1="-8.3" y1="-6.225" x2="-7.7" y2="-4.975" layer="29"/>
<rectangle x1="-8.2" y1="-6.125" x2="-7.8" y2="-5.075" layer="31"/>
<rectangle x1="-7.5" y1="-6.225" x2="-6.9" y2="-4.975" layer="29"/>
<rectangle x1="-7.4" y1="-6.125" x2="-7" y2="-5.075" layer="31"/>
<rectangle x1="-6.7" y1="-6.225" x2="-6.1" y2="-4.975" layer="29"/>
<rectangle x1="-6.6" y1="-6.125" x2="-6.2" y2="-5.075" layer="31"/>
<rectangle x1="-5.9" y1="-6.225" x2="-5.3" y2="-4.975" layer="29"/>
<rectangle x1="-5.8" y1="-6.125" x2="-5.4" y2="-5.075" layer="31"/>
<rectangle x1="-5.1" y1="-6.225" x2="-4.5" y2="-4.975" layer="29"/>
<rectangle x1="-5" y1="-6.125" x2="-4.6" y2="-5.075" layer="31"/>
<rectangle x1="-4.3" y1="-6.225" x2="-3.7" y2="-4.975" layer="29"/>
<rectangle x1="-4.2" y1="-6.125" x2="-3.8" y2="-5.075" layer="31"/>
<rectangle x1="-3.5" y1="-6.225" x2="-2.9" y2="-4.975" layer="29"/>
<rectangle x1="-3.4" y1="-6.125" x2="-3" y2="-5.075" layer="31"/>
<rectangle x1="-2.7" y1="-6.225" x2="-2.1" y2="-4.975" layer="29"/>
<rectangle x1="-2.6" y1="-6.125" x2="-2.2" y2="-5.075" layer="31"/>
<rectangle x1="-1.9" y1="-6.225" x2="-1.3" y2="-4.975" layer="29"/>
<rectangle x1="-1.8" y1="-6.125" x2="-1.4" y2="-5.075" layer="31"/>
<rectangle x1="-1.1" y1="-6.225" x2="-0.5" y2="-4.975" layer="29"/>
<rectangle x1="-1" y1="-6.125" x2="-0.6" y2="-5.075" layer="31"/>
<rectangle x1="-0.3" y1="-6.225" x2="0.3" y2="-4.975" layer="29"/>
<rectangle x1="-0.2" y1="-6.125" x2="0.2" y2="-5.075" layer="31"/>
<rectangle x1="0.5" y1="-6.225" x2="1.1" y2="-4.975" layer="29"/>
<rectangle x1="0.6" y1="-6.125" x2="1" y2="-5.075" layer="31"/>
<rectangle x1="1.3" y1="-6.225" x2="1.9" y2="-4.975" layer="29"/>
<rectangle x1="1.4" y1="-6.125" x2="1.8" y2="-5.075" layer="31"/>
<rectangle x1="2.1" y1="-6.225" x2="2.7" y2="-4.975" layer="29"/>
<rectangle x1="2.2" y1="-6.125" x2="2.6" y2="-5.075" layer="31"/>
<rectangle x1="2.9" y1="-6.225" x2="3.5" y2="-4.975" layer="29"/>
<rectangle x1="3" y1="-6.125" x2="3.4" y2="-5.075" layer="31"/>
<rectangle x1="3.7" y1="-6.225" x2="4.3" y2="-4.975" layer="29"/>
<rectangle x1="3.8" y1="-6.125" x2="4.2" y2="-5.075" layer="31"/>
<rectangle x1="4.5" y1="-6.225" x2="5.1" y2="-4.975" layer="29"/>
<rectangle x1="4.6" y1="-6.125" x2="5" y2="-5.075" layer="31"/>
<rectangle x1="5.3" y1="-6.225" x2="5.9" y2="-4.975" layer="29"/>
<rectangle x1="5.4" y1="-6.125" x2="5.8" y2="-5.075" layer="31"/>
<rectangle x1="6.1" y1="-6.225" x2="6.7" y2="-4.975" layer="29"/>
<rectangle x1="6.2" y1="-6.125" x2="6.6" y2="-5.075" layer="31"/>
<rectangle x1="6.9" y1="-6.225" x2="7.5" y2="-4.975" layer="29"/>
<rectangle x1="7" y1="-6.125" x2="7.4" y2="-5.075" layer="31"/>
<rectangle x1="7.7" y1="-6.225" x2="8.3" y2="-4.975" layer="29"/>
<rectangle x1="7.8" y1="-6.125" x2="8.2" y2="-5.075" layer="31"/>
<rectangle x1="8.5" y1="-6.225" x2="9.1" y2="-4.975" layer="29"/>
<rectangle x1="8.6" y1="-6.125" x2="9" y2="-5.075" layer="31"/>
<rectangle x1="9.3" y1="-6.225" x2="9.9" y2="-4.975" layer="29"/>
<rectangle x1="9.4" y1="-6.125" x2="9.8" y2="-5.075" layer="31"/>
<rectangle x1="9.3" y1="4.975" x2="9.9" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="9.4" y1="5.075" x2="9.8" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="8.5" y1="4.975" x2="9.1" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="8.6" y1="5.075" x2="9" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="7.7" y1="4.975" x2="8.3" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="7.8" y1="5.075" x2="8.2" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="6.9" y1="4.975" x2="7.5" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="7" y1="5.075" x2="7.4" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="6.1" y1="4.975" x2="6.7" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="6.2" y1="5.075" x2="6.6" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="5.3" y1="4.975" x2="5.9" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="5.4" y1="5.075" x2="5.8" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="4.5" y1="4.975" x2="5.1" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="4.6" y1="5.075" x2="5" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="3.7" y1="4.975" x2="4.3" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="3.8" y1="5.075" x2="4.2" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="2.9" y1="4.975" x2="3.5" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="3" y1="5.075" x2="3.4" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="2.1" y1="4.975" x2="2.7" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="2.2" y1="5.075" x2="2.6" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="1.3" y1="4.975" x2="1.9" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="1.4" y1="5.075" x2="1.8" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="0.5" y1="4.975" x2="1.1" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="0.6" y1="5.075" x2="1" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-0.3" y1="4.975" x2="0.3" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-0.2" y1="5.075" x2="0.2" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-1.1" y1="4.975" x2="-0.5" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-1" y1="5.075" x2="-0.6" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-1.9" y1="4.975" x2="-1.3" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-1.8" y1="5.075" x2="-1.4" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-2.7" y1="4.975" x2="-2.1" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-2.6" y1="5.075" x2="-2.2" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-3.5" y1="4.975" x2="-2.9" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-3.4" y1="5.075" x2="-3" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-4.3" y1="4.975" x2="-3.7" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-4.2" y1="5.075" x2="-3.8" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-5.1" y1="4.975" x2="-4.5" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-5" y1="5.075" x2="-4.6" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-5.9" y1="4.975" x2="-5.3" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-5.8" y1="5.075" x2="-5.4" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-6.7" y1="4.975" x2="-6.1" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-6.6" y1="5.075" x2="-6.2" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-7.5" y1="4.975" x2="-6.9" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-7.4" y1="5.075" x2="-7" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-8.3" y1="4.975" x2="-7.7" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-8.2" y1="5.075" x2="-7.8" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-9.1" y1="4.975" x2="-8.5" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-9" y1="5.075" x2="-8.6" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-9.9" y1="4.975" x2="-9.3" y2="6.225" layer="29" rot="R180"/>
<rectangle x1="-9.8" y1="5.075" x2="-9.4" y2="6.125" layer="31" rot="R180"/>
<rectangle x1="-9.8" y1="-6" x2="-9.4" y2="-5.05" layer="51"/>
<rectangle x1="-9" y1="-6" x2="-8.6" y2="-5.05" layer="51"/>
<rectangle x1="-8.2" y1="-6" x2="-7.8" y2="-5.05" layer="51"/>
<rectangle x1="-7.4" y1="-6" x2="-7" y2="-5.05" layer="51"/>
<rectangle x1="-6.6" y1="-6" x2="-6.2" y2="-5.05" layer="51"/>
<rectangle x1="-5.8" y1="-6" x2="-5.4" y2="-5.05" layer="51"/>
<rectangle x1="-5" y1="-6" x2="-4.6" y2="-5.05" layer="51"/>
<rectangle x1="-4.2" y1="-6" x2="-3.8" y2="-5.05" layer="51"/>
<rectangle x1="-3.4" y1="-6" x2="-3" y2="-5.05" layer="51"/>
<rectangle x1="-2.6" y1="-6" x2="-2.2" y2="-5.05" layer="51"/>
<rectangle x1="-1.8" y1="-6" x2="-1.4" y2="-5.05" layer="51"/>
<rectangle x1="-1" y1="-6" x2="-0.6" y2="-5.05" layer="51"/>
<rectangle x1="-0.2" y1="-6" x2="0.2" y2="-5.05" layer="51"/>
<rectangle x1="0.6" y1="-6" x2="1" y2="-5.05" layer="51"/>
<rectangle x1="1.4" y1="-6" x2="1.8" y2="-5.05" layer="51"/>
<rectangle x1="2.2" y1="-6" x2="2.6" y2="-5.05" layer="51"/>
<rectangle x1="3" y1="-6" x2="3.4" y2="-5.05" layer="51"/>
<rectangle x1="3.8" y1="-6" x2="4.2" y2="-5.05" layer="51"/>
<rectangle x1="4.6" y1="-6" x2="5" y2="-5.05" layer="51"/>
<rectangle x1="5.4" y1="-6" x2="5.8" y2="-5.05" layer="51"/>
<rectangle x1="6.2" y1="-6" x2="6.6" y2="-5.05" layer="51"/>
<rectangle x1="7" y1="-6" x2="7.4" y2="-5.05" layer="51"/>
<rectangle x1="7.8" y1="-6" x2="8.2" y2="-5.05" layer="51"/>
<rectangle x1="8.6" y1="-6" x2="9" y2="-5.05" layer="51"/>
<rectangle x1="9.4" y1="-6" x2="9.8" y2="-5.05" layer="51"/>
<rectangle x1="9.4" y1="5.05" x2="9.8" y2="6" layer="51" rot="R180"/>
<rectangle x1="8.6" y1="5.05" x2="9" y2="6" layer="51" rot="R180"/>
<rectangle x1="7.8" y1="5.05" x2="8.2" y2="6" layer="51" rot="R180"/>
<rectangle x1="7" y1="5.05" x2="7.4" y2="6" layer="51" rot="R180"/>
<rectangle x1="6.2" y1="5.05" x2="6.6" y2="6" layer="51" rot="R180"/>
<rectangle x1="5.4" y1="5.05" x2="5.8" y2="6" layer="51" rot="R180"/>
<rectangle x1="4.6" y1="5.05" x2="5" y2="6" layer="51" rot="R180"/>
<rectangle x1="3.8" y1="5.05" x2="4.2" y2="6" layer="51" rot="R180"/>
<rectangle x1="3" y1="5.05" x2="3.4" y2="6" layer="51" rot="R180"/>
<rectangle x1="2.2" y1="5.05" x2="2.6" y2="6" layer="51" rot="R180"/>
<rectangle x1="1.4" y1="5.05" x2="1.8" y2="6" layer="51" rot="R180"/>
<rectangle x1="0.6" y1="5.05" x2="1" y2="6" layer="51" rot="R180"/>
<rectangle x1="-0.2" y1="5.05" x2="0.2" y2="6" layer="51" rot="R180"/>
<rectangle x1="-1" y1="5.05" x2="-0.6" y2="6" layer="51" rot="R180"/>
<rectangle x1="-1.8" y1="5.05" x2="-1.4" y2="6" layer="51" rot="R180"/>
<rectangle x1="-2.6" y1="5.05" x2="-2.2" y2="6" layer="51" rot="R180"/>
<rectangle x1="-3.4" y1="5.05" x2="-3" y2="6" layer="51" rot="R180"/>
<rectangle x1="-4.2" y1="5.05" x2="-3.8" y2="6" layer="51" rot="R180"/>
<rectangle x1="-5" y1="5.05" x2="-4.6" y2="6" layer="51" rot="R180"/>
<rectangle x1="-5.8" y1="5.05" x2="-5.4" y2="6" layer="51" rot="R180"/>
<rectangle x1="-6.6" y1="5.05" x2="-6.2" y2="6" layer="51" rot="R180"/>
<rectangle x1="-7.4" y1="5.05" x2="-7" y2="6" layer="51" rot="R180"/>
<rectangle x1="-8.2" y1="5.05" x2="-7.8" y2="6" layer="51" rot="R180"/>
<rectangle x1="-9" y1="5.05" x2="-8.6" y2="6" layer="51" rot="R180"/>
<rectangle x1="-9.8" y1="5.05" x2="-9.4" y2="6" layer="51" rot="R180"/>
</package>
<package name="MBGA60">
<description>&lt;b&gt;Mimi Ball Grid Array mBGA - 10.1 x 6.4 mm&lt;/b&gt; Package Code: B (60 Ball)&lt;p&gt;
<wire x1="-3.15" y1="5" x2="3.15" y2="5" width="0.2032" layer="21"/>
<wire x1="3.15" y1="5" x2="3.15" y2="-5" width="0.2032" layer="21"/>
<wire x1="3.15" y1="-5" x2="-3.15" y2="-5" width="0.2032" layer="21"/>
<wire x1="-3.15" y1="-5" x2="-3.15" y2="5" width="0.2032" layer="21"/>
<circle x="-1.95" y="4.55" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="3.9" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="3.25" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="2.6" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="1.95" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="1.3" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="0.65" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="0" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="-0.65" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="-1.3" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="-1.95" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="-2.6" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="-3.25" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="-3.9" radius="0.2" width="0" layer="29"/>
<circle x="-1.95" y="-4.55" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="4.55" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="3.9" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="3.25" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="2.6" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="1.95" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="1.3" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="0.65" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="0" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="-0.65" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="-1.3" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="-1.95" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="-2.6" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="-3.25" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="-3.9" radius="0.2" width="0" layer="29"/>
<circle x="-1.3" y="-4.55" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="4.55" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="3.9" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="3.25" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="2.6" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="1.95" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="1.3" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="0.65" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="0" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="-0.65" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="-1.3" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="-1.95" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="-2.6" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="-3.25" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="-3.9" radius="0.2" width="0" layer="29"/>
<circle x="1.3" y="-4.55" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="4.55" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="3.9" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="3.25" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="2.6" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="1.95" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="1.3" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="0.65" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="0" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="-0.65" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="-1.3" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="-1.95" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="-2.6" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="-3.25" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="-3.9" radius="0.2" width="0" layer="29"/>
<circle x="1.95" y="-4.55" radius="0.2" width="0" layer="29"/>
<smd name="A1" x="-1.95" y="4.55" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B1" x="-1.95" y="3.9" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C1" x="-1.95" y="3.25" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D1" x="-1.95" y="2.6" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E1" x="-1.95" y="1.95" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F1" x="-1.95" y="1.3" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G1" x="-1.95" y="0.65" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H1" x="-1.95" y="0" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J1" x="-1.95" y="-0.65" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K1" x="-1.95" y="-1.3" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L1" x="-1.95" y="-1.95" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="M1" x="-1.95" y="-2.6" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="N1" x="-1.95" y="-3.25" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="P1" x="-1.95" y="-3.9" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="R1" x="-1.95" y="-4.55" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A2" x="-1.3" y="4.55" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B2" x="-1.3" y="3.9" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C2" x="-1.3" y="3.25" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D2" x="-1.3" y="2.6" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E2" x="-1.3" y="1.95" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F2" x="-1.3" y="1.3" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G2" x="-1.3" y="0.65" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H2" x="-1.3" y="0" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J2" x="-1.3" y="-0.65" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K2" x="-1.3" y="-1.3" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L2" x="-1.3" y="-1.95" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="M2" x="-1.3" y="-2.6" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="N2" x="-1.3" y="-3.25" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="P2" x="-1.3" y="-3.9" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="R2" x="-1.3" y="-4.55" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A6" x="1.3" y="4.55" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B6" x="1.3" y="3.9" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C6" x="1.3" y="3.25" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D6" x="1.3" y="2.6" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E6" x="1.3" y="1.95" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F6" x="1.3" y="1.3" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G6" x="1.3" y="0.65" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H6" x="1.3" y="0" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J6" x="1.3" y="-0.65" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K6" x="1.3" y="-1.3" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L6" x="1.3" y="-1.95" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="M6" x="1.3" y="-2.6" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="N6" x="1.3" y="-3.25" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="P6" x="1.3" y="-3.9" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="R6" x="1.3" y="-4.55" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A7" x="1.95" y="4.55" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B7" x="1.95" y="3.9" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C7" x="1.95" y="3.25" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D7" x="1.95" y="2.6" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E7" x="1.95" y="1.95" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F7" x="1.95" y="1.3" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G7" x="1.95" y="0.65" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H7" x="1.95" y="0" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J7" x="1.95" y="-0.65" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K7" x="1.95" y="-1.3" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L7" x="1.95" y="-1.95" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="M7" x="1.95" y="-2.6" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="N7" x="1.95" y="-3.25" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="P7" x="1.95" y="-3.9" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="R7" x="1.95" y="-4.55" dx="0.45" dy="0.45" layer="1" roundness="100" stop="no" cream="no"/>
<text x="-3.048" y="5.334" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.302" y="-6.604" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.125" y="4.05"/>
<vertex x="-2.2" y="4.975"/>
<vertex x="-3.125" y="4.975"/>
</polygon>
</package>
<package name="TSOP48">
<description>&lt;b&gt;48-Lead Thin Small Outline Package (TSOP)&lt;/b&gt; 12mm x 20mm SST Package Code: EK&lt;p&gt;
Source: http://www.sst.com/dotAsset/40687.pdf</description>
<wire x1="-9.15" y1="6" x2="9.15" y2="6" width="0.2032" layer="21"/>
<wire x1="9.15" y1="6" x2="9.15" y2="-6" width="0.2032" layer="51"/>
<wire x1="9.15" y1="-6" x2="-9.15" y2="-6" width="0.2032" layer="21"/>
<wire x1="-9.15" y1="-6" x2="-9.15" y2="6" width="0.2032" layer="51"/>
<circle x="-8" y="5" radius="0.4" width="0" layer="21"/>
<smd name="1" x="-9.625" y="5.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="2" x="-9.625" y="5.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="3" x="-9.625" y="4.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="4" x="-9.625" y="4.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="5" x="-9.625" y="3.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="6" x="-9.625" y="3.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="7" x="-9.625" y="2.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="8" x="-9.625" y="2.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="9" x="-9.625" y="1.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="10" x="-9.625" y="1.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="11" x="-9.625" y="0.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="12" x="-9.625" y="0.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="13" x="-9.625" y="-0.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="14" x="-9.625" y="-0.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="15" x="-9.625" y="-1.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="16" x="-9.625" y="-1.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="17" x="-9.625" y="-2.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="18" x="-9.625" y="-2.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="19" x="-9.625" y="-3.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="20" x="-9.625" y="-3.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="21" x="-9.625" y="-4.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="22" x="-9.625" y="-4.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="23" x="-9.625" y="-5.25" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="24" x="-9.625" y="-5.75" dx="1.1" dy="0.3" layer="1" stop="no"/>
<smd name="25" x="9.625" y="-5.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="26" x="9.625" y="-5.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="27" x="9.625" y="-4.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="28" x="9.625" y="-4.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="29" x="9.625" y="-3.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="30" x="9.625" y="-3.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="31" x="9.625" y="-2.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="32" x="9.625" y="-2.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="33" x="9.625" y="-1.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="34" x="9.625" y="-1.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="35" x="9.625" y="-0.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="36" x="9.625" y="-0.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="37" x="9.625" y="0.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="38" x="9.625" y="0.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="39" x="9.625" y="1.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="40" x="9.625" y="1.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="41" x="9.625" y="2.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="42" x="9.625" y="2.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="43" x="9.625" y="3.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="44" x="9.625" y="3.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="45" x="9.625" y="4.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="46" x="9.625" y="4.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="47" x="9.625" y="5.25" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<smd name="48" x="9.625" y="5.75" dx="1.1" dy="0.3" layer="1" rot="R180" stop="no"/>
<text x="-8.5" y="6.5" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.5" y="-0.5" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-10.225" y1="5.55" x2="-9.025" y2="5.95" layer="29"/>
<rectangle x1="-10.225" y1="5.05" x2="-9.025" y2="5.45" layer="29"/>
<rectangle x1="-10.225" y1="4.55" x2="-9.025" y2="4.95" layer="29"/>
<rectangle x1="-10.225" y1="4.05" x2="-9.025" y2="4.45" layer="29"/>
<rectangle x1="-10.225" y1="3.55" x2="-9.025" y2="3.95" layer="29"/>
<rectangle x1="-10.225" y1="3.05" x2="-9.025" y2="3.45" layer="29"/>
<rectangle x1="-10.225" y1="2.55" x2="-9.025" y2="2.95" layer="29"/>
<rectangle x1="-10.225" y1="2.05" x2="-9.025" y2="2.45" layer="29"/>
<rectangle x1="-10.225" y1="1.55" x2="-9.025" y2="1.95" layer="29"/>
<rectangle x1="-10.225" y1="1.05" x2="-9.025" y2="1.45" layer="29"/>
<rectangle x1="-10.225" y1="0.55" x2="-9.025" y2="0.95" layer="29"/>
<rectangle x1="-10.225" y1="0.05" x2="-9.025" y2="0.45" layer="29"/>
<rectangle x1="-10.225" y1="-0.45" x2="-9.025" y2="-0.05" layer="29"/>
<rectangle x1="-10.225" y1="-0.95" x2="-9.025" y2="-0.55" layer="29"/>
<rectangle x1="-10.225" y1="-1.45" x2="-9.025" y2="-1.05" layer="29"/>
<rectangle x1="-10.225" y1="-1.95" x2="-9.025" y2="-1.55" layer="29"/>
<rectangle x1="-10.225" y1="-2.45" x2="-9.025" y2="-2.05" layer="29"/>
<rectangle x1="-10.225" y1="-2.95" x2="-9.025" y2="-2.55" layer="29"/>
<rectangle x1="-10.225" y1="-3.45" x2="-9.025" y2="-3.05" layer="29"/>
<rectangle x1="-10.225" y1="-3.95" x2="-9.025" y2="-3.55" layer="29"/>
<rectangle x1="-10.225" y1="-4.45" x2="-9.025" y2="-4.05" layer="29"/>
<rectangle x1="-10.225" y1="-4.95" x2="-9.025" y2="-4.55" layer="29"/>
<rectangle x1="-10.225" y1="-5.45" x2="-9.025" y2="-5.05" layer="29"/>
<rectangle x1="-10.225" y1="-5.95" x2="-9.025" y2="-5.55" layer="29"/>
<rectangle x1="9.025" y1="-5.95" x2="10.225" y2="-5.55" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-5.45" x2="10.225" y2="-5.05" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-4.95" x2="10.225" y2="-4.55" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-4.45" x2="10.225" y2="-4.05" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-3.95" x2="10.225" y2="-3.55" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-3.45" x2="10.225" y2="-3.05" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-2.95" x2="10.225" y2="-2.55" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-2.45" x2="10.225" y2="-2.05" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-1.95" x2="10.225" y2="-1.55" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-1.45" x2="10.225" y2="-1.05" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-0.95" x2="10.225" y2="-0.55" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="-0.45" x2="10.225" y2="-0.05" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="0.05" x2="10.225" y2="0.45" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="0.55" x2="10.225" y2="0.95" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="1.05" x2="10.225" y2="1.45" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="1.55" x2="10.225" y2="1.95" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="2.05" x2="10.225" y2="2.45" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="2.55" x2="10.225" y2="2.95" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="3.05" x2="10.225" y2="3.45" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="3.55" x2="10.225" y2="3.95" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="4.05" x2="10.225" y2="4.45" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="4.55" x2="10.225" y2="4.95" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="5.05" x2="10.225" y2="5.45" layer="29" rot="R180"/>
<rectangle x1="9.025" y1="5.55" x2="10.225" y2="5.95" layer="29" rot="R180"/>
<rectangle x1="-10.1" y1="5.625" x2="-9.225" y2="5.875" layer="51"/>
<rectangle x1="-10.1" y1="5.125" x2="-9.225" y2="5.375" layer="51"/>
<rectangle x1="-10.1" y1="4.625" x2="-9.225" y2="4.875" layer="51"/>
<rectangle x1="-10.1" y1="4.125" x2="-9.225" y2="4.375" layer="51"/>
<rectangle x1="-10.1" y1="3.625" x2="-9.225" y2="3.875" layer="51"/>
<rectangle x1="-10.1" y1="3.125" x2="-9.225" y2="3.375" layer="51"/>
<rectangle x1="-10.1" y1="2.625" x2="-9.225" y2="2.875" layer="51"/>
<rectangle x1="-10.1" y1="2.125" x2="-9.225" y2="2.375" layer="51"/>
<rectangle x1="-10.1" y1="1.625" x2="-9.225" y2="1.875" layer="51"/>
<rectangle x1="-10.1" y1="1.125" x2="-9.225" y2="1.375" layer="51"/>
<rectangle x1="-10.1" y1="0.625" x2="-9.225" y2="0.875" layer="51"/>
<rectangle x1="-10.1" y1="0.125" x2="-9.225" y2="0.375" layer="51"/>
<rectangle x1="-10.1" y1="-0.375" x2="-9.225" y2="-0.125" layer="51"/>
<rectangle x1="-10.1" y1="-0.875" x2="-9.225" y2="-0.625" layer="51"/>
<rectangle x1="-10.1" y1="-1.375" x2="-9.225" y2="-1.125" layer="51"/>
<rectangle x1="-10.1" y1="-1.875" x2="-9.225" y2="-1.625" layer="51"/>
<rectangle x1="-10.1" y1="-2.375" x2="-9.225" y2="-2.125" layer="51"/>
<rectangle x1="-10.1" y1="-2.875" x2="-9.225" y2="-2.625" layer="51"/>
<rectangle x1="-10.1" y1="-3.375" x2="-9.225" y2="-3.125" layer="51"/>
<rectangle x1="-10.1" y1="-3.875" x2="-9.225" y2="-3.625" layer="51"/>
<rectangle x1="-10.1" y1="-4.375" x2="-9.225" y2="-4.125" layer="51"/>
<rectangle x1="-10.1" y1="-4.875" x2="-9.225" y2="-4.625" layer="51"/>
<rectangle x1="-10.1" y1="-5.375" x2="-9.225" y2="-5.125" layer="51"/>
<rectangle x1="-10.1" y1="-5.875" x2="-9.225" y2="-5.625" layer="51"/>
<rectangle x1="9.225" y1="-5.875" x2="10.1" y2="-5.625" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-5.375" x2="10.1" y2="-5.125" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-4.875" x2="10.1" y2="-4.625" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-4.375" x2="10.1" y2="-4.125" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-3.875" x2="10.1" y2="-3.625" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-3.375" x2="10.1" y2="-3.125" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-2.875" x2="10.1" y2="-2.625" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-2.375" x2="10.1" y2="-2.125" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-1.875" x2="10.1" y2="-1.625" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-1.375" x2="10.1" y2="-1.125" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-0.875" x2="10.1" y2="-0.625" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="-0.375" x2="10.1" y2="-0.125" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="0.125" x2="10.1" y2="0.375" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="0.625" x2="10.1" y2="0.875" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="1.125" x2="10.1" y2="1.375" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="1.625" x2="10.1" y2="1.875" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="2.125" x2="10.1" y2="2.375" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="2.625" x2="10.1" y2="2.875" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="3.125" x2="10.1" y2="3.375" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="3.625" x2="10.1" y2="3.875" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="4.125" x2="10.1" y2="4.375" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="4.625" x2="10.1" y2="4.875" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="5.125" x2="10.1" y2="5.375" layer="51" rot="R180"/>
<rectangle x1="9.225" y1="5.625" x2="10.1" y2="5.875" layer="51" rot="R180"/>
</package>
<package name="WFBGA48">
<description>&lt;b&gt;48-Ball Very-Very-Thin-Profile, Fine-Pitch Ball Grid Array (WFBGA)&lt;/b&gt; 4mm x 6mm SST Package Code: M1Q&lt;p&gt;
<wire x1="-1.9" y1="2.9" x2="1.9" y2="2.9" width="0.2032" layer="21"/>
<wire x1="1.9" y1="2.9" x2="1.9" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="1.9" y1="-2.9" x2="-1.9" y2="-2.9" width="0.2032" layer="21"/>
<wire x1="-1.9" y1="-2.9" x2="-1.9" y2="2.9" width="0.2032" layer="21"/>
<circle x="-1.25" y="2.5" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="2" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="1.5" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="1" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="0.5" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="0" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="-0.5" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="-1" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="-1.5" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="-2" radius="0.16" width="0" layer="29"/>
<circle x="-0.75" y="2.5" radius="0.16" width="0" layer="29"/>
<circle x="-0.75" y="2" radius="0.16" width="0" layer="29"/>
<circle x="-0.75" y="1.5" radius="0.16" width="0" layer="29"/>
<circle x="-0.75" y="1" radius="0.16" width="0" layer="29"/>
<circle x="-0.75" y="-1" radius="0.16" width="0" layer="29"/>
<circle x="-0.75" y="-1.5" radius="0.16" width="0" layer="29"/>
<circle x="-0.75" y="-2" radius="0.16" width="0" layer="29"/>
<circle x="-0.25" y="2.5" radius="0.16" width="0" layer="29"/>
<circle x="-0.25" y="2" radius="0.16" width="0" layer="29"/>
<circle x="-0.25" y="1.5" radius="0.16" width="0" layer="29"/>
<circle x="-0.25" y="-1.5" radius="0.16" width="0" layer="29"/>
<circle x="-0.25" y="-2" radius="0.16" width="0" layer="29"/>
<circle x="0.25" y="2.5" radius="0.16" width="0" layer="29"/>
<circle x="0.25" y="2" radius="0.16" width="0" layer="29"/>
<circle x="0.25" y="1.5" radius="0.16" width="0" layer="29"/>
<circle x="0.25" y="-1.5" radius="0.16" width="0" layer="29"/>
<circle x="0.25" y="-2" radius="0.16" width="0" layer="29"/>
<circle x="0.75" y="2.5" radius="0.16" width="0" layer="29"/>
<circle x="0.75" y="2" radius="0.16" width="0" layer="29"/>
<circle x="0.75" y="1.5" radius="0.16" width="0" layer="29"/>
<circle x="0.75" y="1" radius="0.16" width="0" layer="29"/>
<circle x="0.75" y="-1" radius="0.16" width="0" layer="29"/>
<circle x="0.75" y="-1.5" radius="0.16" width="0" layer="29"/>
<circle x="0.75" y="-2" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="2.5" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="2" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="1.5" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="1" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="0.5" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="0" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="-0.5" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="-1" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="-1.5" radius="0.16" width="0" layer="29"/>
<circle x="1.25" y="-2" radius="0.16" width="0" layer="29"/>
<circle x="-1.25" y="-2.5" radius="0.16" width="0" layer="29"/>
<circle x="-0.75" y="-2.5" radius="0.16" width="0" layer="29"/>
<circle x="-0.25" y="-2.5" radius="0.16" width="0" layer="29"/>
<circle x="0.25" y="-2.5" radius="0.16" width="0" layer="29"/>
<circle x="0.75" y="-2.5" radius="0.16" width="0" layer="29"/>
<smd name="A1" x="-1.25" y="2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B1" x="-1.25" y="2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C1" x="-1.25" y="1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D1" x="-1.25" y="1" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E1" x="-1.25" y="0.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F1" x="-1.25" y="0" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G1" x="-1.25" y="-0.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H1" x="-1.25" y="-1" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J1" x="-1.25" y="-1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K1" x="-1.25" y="-2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A2" x="-0.75" y="2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B2" x="-0.75" y="2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C2" x="-0.75" y="1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D2" x="-0.75" y="1" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H2" x="-0.75" y="-1" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J2" x="-0.75" y="-1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K2" x="-0.75" y="-2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A3" x="-0.25" y="2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B3" x="-0.25" y="2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C3" x="-0.25" y="1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J3" x="-0.25" y="-1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K3" x="-0.25" y="-2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A4" x="0.25" y="2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B4" x="0.25" y="2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C4" x="0.25" y="1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J4" x="0.25" y="-1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K4" x="0.25" y="-2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A5" x="0.75" y="2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B5" x="0.75" y="2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C5" x="0.75" y="1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D5" x="0.75" y="1" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H5" x="0.75" y="-1" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J5" x="0.75" y="-1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K5" x="0.75" y="-2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A6" x="1.25" y="2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B6" x="1.25" y="2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C6" x="1.25" y="1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D6" x="1.25" y="1" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E6" x="1.25" y="0.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F6" x="1.25" y="0" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G6" x="1.25" y="-0.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H6" x="1.25" y="-1" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J6" x="1.25" y="-1.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K6" x="1.25" y="-2" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L1" x="-1.25" y="-2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L2" x="-0.75" y="-2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L3" x="-0.25" y="-2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L4" x="0.25" y="-2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L5" x="0.75" y="-2.5" dx="0.32" dy="0.32" layer="1" roundness="100" stop="no" cream="no"/>
<text x="-2" y="3.5" size="1.27" layer="25">&gt;NAME</text>
<text x="-2" y="-4.5" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-1.9" y="2.325"/>
<vertex x="-1.325" y="2.9"/>
<vertex x="-1.9" y="2.9"/>
</polygon>
</package>
<package name="XFBGA48">
<description>&lt;b&gt;48-Bump Extremely-Thin-Profile, Fine-Pitch Land Grid Array (XFLGA)&lt;/b&gt; 4mm x 6mm SST Package Code: C1Q&lt;p&gt;
<smd name="A1" x="-1.25" y="2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B1" x="-1.25" y="2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C1" x="-1.25" y="1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D1" x="-1.25" y="1" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E1" x="-1.25" y="0.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F1" x="-1.25" y="0" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G1" x="-1.25" y="-0.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H1" x="-1.25" y="-1" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J1" x="-1.25" y="-1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K1" x="-1.25" y="-2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A2" x="-0.75" y="2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B2" x="-0.75" y="2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C2" x="-0.75" y="1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D2" x="-0.75" y="1" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H2" x="-0.75" y="-1" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J2" x="-0.75" y="-1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K2" x="-0.75" y="-2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A3" x="-0.25" y="2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B3" x="-0.25" y="2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C3" x="-0.25" y="1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J3" x="-0.25" y="-1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K3" x="-0.25" y="-2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A4" x="0.25" y="2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B4" x="0.25" y="2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C4" x="0.25" y="1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J4" x="0.25" y="-1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K4" x="0.25" y="-2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A5" x="0.75" y="2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B5" x="0.75" y="2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C5" x="0.75" y="1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D5" x="0.75" y="1" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H5" x="0.75" y="-1" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J5" x="0.75" y="-1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K5" x="0.75" y="-2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="A6" x="1.25" y="2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="B6" x="1.25" y="2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="C6" x="1.25" y="1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="D6" x="1.25" y="1" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="E6" x="1.25" y="0.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="F6" x="1.25" y="0" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="G6" x="1.25" y="-0.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="H6" x="1.25" y="-1" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="J6" x="1.25" y="-1.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="K6" x="1.25" y="-2" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L1" x="-1.25" y="-2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L2" x="-0.75" y="-2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L3" x="-0.25" y="-2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L4" x="0.25" y="-2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
<smd name="L5" x="0.75" y="-2.5" dx="0.29" dy="0.29" layer="1" roundness="100" stop="no" cream="no"/>
</polygon>
</package>
<package name="TSSOP8">
<description>&lt;b&gt;8-Pin Molded TSSOP, JEDEC (MT8)&lt;/b&gt; Package Number MTC08&lt;p&gt;
Source: www.fairchildsemi.com</description>
<wire x1="-2.15" y1="-1.4" x2="2.15" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="2.15" y1="-1.4" x2="2.15" y2="1.4" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.4" x2="-2.15" y2="1.4" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="1.4" x2="-2.15" y2="-1.4" width="0.2032" layer="21"/>
<circle x="-1.625" y="0.65" radius="0.325" width="0" layer="21"/>
<smd name="1" x="-2.925" y="0.975" dx="1.2" dy="0.35" layer="1"/>
<smd name="2" x="-2.925" y="0.325" dx="1.2" dy="0.35" layer="1"/>
<smd name="3" x="-2.925" y="-0.325" dx="1.2" dy="0.35" layer="1"/>
<smd name="4" x="-2.925" y="-0.975" dx="1.2" dy="0.35" layer="1"/>
<smd name="5" x="2.925" y="-0.975" dx="1.2" dy="0.35" layer="1"/>
<smd name="6" x="2.925" y="-0.325" dx="1.2" dy="0.35" layer="1"/>
<smd name="7" x="2.925" y="0.325" dx="1.2" dy="0.35" layer="1"/>
<smd name="8" x="2.925" y="0.975" dx="1.2" dy="0.35" layer="1"/>
<text x="-2.925" y="1.625" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.25" y="-2.925" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.2" y1="0.85" x2="-2.2" y2="1.1" layer="51"/>
<rectangle x1="-3.2" y1="0.2" x2="-2.2" y2="0.45" layer="51"/>
<rectangle x1="-3.2" y1="-0.45" x2="-2.2" y2="-0.2" layer="51"/>
<rectangle x1="-3.2" y1="-1.1" x2="-2.2" y2="-0.85" layer="51"/>
<rectangle x1="2.2" y1="-1.1" x2="3.2" y2="-0.85" layer="51"/>
<rectangle x1="2.2" y1="-0.45" x2="3.2" y2="-0.2" layer="51"/>
<rectangle x1="2.2" y1="0.2" x2="3.2" y2="0.45" layer="51"/>
<rectangle x1="2.2" y1="0.85" x2="3.2" y2="1.1" layer="51"/>
</package>
<package name="M8">
<description>&lt;b&gt;Molded Package, Small Outline, 0.15 Wide, 8-Lead (M8)&lt;/b&gt; Package Number M08A&lt;p&gt;
<wire x1="2.4" y1="1.905" x2="2.4" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="2.4" y1="-1.905" x2="-2.4" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-2.4" y1="-1.905" x2="-2.4" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-2.4" y1="1.905" x2="2.4" y2="1.905" width="0.2032" layer="21"/>
<circle x="-1.8" y="-1.3" radius="0.3" width="0" layer="21"/>
<smd name="2" x="-0.635" y="-2.63" dx="0.6" dy="1.4" layer="1"/>
<smd name="7" x="-0.635" y="2.63" dx="0.6" dy="1.4" layer="1"/>
<smd name="1" x="-1.905" y="-2.63" dx="0.6" dy="1.4" layer="1"/>
<smd name="3" x="0.635" y="-2.63" dx="0.6" dy="1.4" layer="1"/>
<smd name="4" x="1.905" y="-2.63" dx="0.6" dy="1.4" layer="1"/>
<smd name="8" x="-1.905" y="2.63" dx="0.6" dy="1.4" layer="1"/>
<smd name="6" x="0.635" y="2.63" dx="0.6" dy="1.4" layer="1"/>
<smd name="5" x="1.905" y="2.63" dx="0.6" dy="1.4" layer="1"/>
<text x="-2.667" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-1.905" y="-1.27" size="0.3048" layer="48">SO8 Medium</text>
<text x="-1.905" y="-0.635" size="0.3048" layer="48">Microchip</text>
<rectangle x1="-2.1501" y1="-3.1" x2="-1.6599" y2="-2" layer="51"/>
<rectangle x1="-0.8801" y1="-3.1" x2="-0.3899" y2="-2" layer="51"/>
<rectangle x1="0.3899" y1="-3.1" x2="0.8801" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="-3.1" x2="2.1501" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="2" x2="2.1501" y2="3.1" layer="51"/>
<rectangle x1="0.3899" y1="2" x2="0.8801" y2="3.1" layer="51"/>
<rectangle x1="-0.8801" y1="2" x2="-0.3899" y2="3.1" layer="51"/>
<rectangle x1="-2.1501" y1="2" x2="-1.6599" y2="3.1" layer="51"/>
</package>
<package name="DIL08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="315">
<wire x1="-7.62" y1="-20.32" x2="7.62" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-20.32" x2="7.62" y2="20.32" width="0.4064" layer="94"/>
<wire x1="7.62" y1="20.32" x2="-7.62" y2="20.32" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="20.32" x2="-7.62" y2="-20.32" width="0.4064" layer="94"/>
<text x="-7.62" y="20.955" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-22.86" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A0" x="-12.7" y="17.78" length="middle" direction="in"/>
<pin name="A1" x="-12.7" y="15.24" length="middle" direction="in"/>
<pin name="A2" x="-12.7" y="12.7" length="middle" direction="in"/>
<pin name="A3" x="-12.7" y="10.16" length="middle" direction="in"/>
<pin name="A4" x="-12.7" y="7.62" length="middle" direction="in"/>
<pin name="A5" x="-12.7" y="5.08" length="middle" direction="in"/>
<pin name="DO" x="12.7" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="!WE" x="-12.7" y="-17.78" length="middle" direction="in"/>
<pin name="!CS" x="-12.7" y="-15.24" length="middle" direction="in"/>
<pin name="DI" x="12.7" y="12.7" length="middle" direction="in" rot="R180"/>
<pin name="A11" x="-12.7" y="-10.16" length="middle" direction="in"/>
<pin name="A10" x="-12.7" y="-7.62" length="middle" direction="in"/>
<pin name="A9" x="-12.7" y="-5.08" length="middle" direction="in"/>
<pin name="A8" x="-12.7" y="-2.54" length="middle" direction="in"/>
<pin name="A7" x="-12.7" y="0" length="middle" direction="in"/>
<pin name="A6" x="-12.7" y="2.54" length="middle" direction="in"/>
</symbol>
<symbol name="406">
<wire x1="-7.62" y1="-17.78" x2="7.62" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-17.78" x2="7.62" y2="17.78" width="0.4064" layer="94"/>
<wire x1="7.62" y1="17.78" x2="-7.62" y2="17.78" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="17.78" x2="-7.62" y2="-17.78" width="0.4064" layer="94"/>
<text x="-7.62" y="18.415" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A6" x="-12.7" y="0" length="middle" direction="in"/>
<pin name="A5" x="-12.7" y="2.54" length="middle" direction="in"/>
<pin name="A4" x="-12.7" y="5.08" length="middle" direction="in"/>
<pin name="A3" x="-12.7" y="7.62" length="middle" direction="in"/>
<pin name="A0" x="-12.7" y="15.24" length="middle" direction="in"/>
<pin name="A1" x="-12.7" y="12.7" length="middle" direction="in"/>
<pin name="A2" x="-12.7" y="10.16" length="middle" direction="in"/>
<pin name="CE1" x="-12.7" y="-12.7" length="middle" direction="in"/>
<pin name="CE2" x="-12.7" y="-15.24" length="middle" direction="in"/>
<pin name="O4" x="12.7" y="7.62" length="middle" direction="oc" rot="R180"/>
<pin name="O3" x="12.7" y="10.16" length="middle" direction="oc" rot="R180"/>
<pin name="O2" x="12.7" y="12.7" length="middle" direction="oc" rot="R180"/>
<pin name="O1" x="12.7" y="15.24" length="middle" direction="oc" rot="R180"/>
<pin name="A9" x="-12.7" y="-7.62" length="middle" direction="in"/>
<pin name="A8" x="-12.7" y="-5.08" length="middle" direction="in"/>
<pin name="A7" x="-12.7" y="-2.54" length="middle" direction="in"/>
</symbol>
<symbol name="426">
<pin name="O4" x="12.7" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="12.7" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="12.7" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O1" x="12.7" y="15.24" length="middle" direction="hiz" rot="R180"/>
</symbol>
<symbol name="1400">
<wire x1="-10.16" y1="-22.86" x2="5.08" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-22.86" x2="5.08" y2="22.86" width="0.4064" layer="94"/>
<wire x1="5.08" y1="22.86" x2="-10.16" y2="22.86" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="22.86" x2="-10.16" y2="-22.86" width="0.4064" layer="94"/>
<text x="-10.16" y="23.495" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-25.4" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A0" x="-15.24" y="20.32" length="middle" direction="in"/>
<pin name="A1" x="-15.24" y="17.78" length="middle" direction="in"/>
<pin name="A2" x="-15.24" y="15.24" length="middle" direction="in"/>
<pin name="A3" x="-15.24" y="12.7" length="middle" direction="in"/>
<pin name="A4" x="-15.24" y="10.16" length="middle" direction="in"/>
<pin name="A5" x="-15.24" y="7.62" length="middle" direction="in"/>
<pin name="A6" x="-15.24" y="5.08" length="middle" direction="in"/>
<pin name="DO" x="10.16" y="20.32" length="middle" direction="hiz" rot="R180"/>
<pin name="!WE" x="-15.24" y="-20.32" length="middle" direction="in"/>
<pin name="!CS" x="-15.24" y="-17.78" length="middle" direction="in"/>
<pin name="DI" x="10.16" y="15.24" length="middle" direction="in" rot="R180"/>
<pin name="A7" x="-15.24" y="2.54" length="middle" direction="in"/>
<pin name="A8" x="-15.24" y="0" length="middle" direction="in"/>
<pin name="A9" x="-15.24" y="-2.54" length="middle" direction="in"/>
<pin name="A10" x="-15.24" y="-5.08" length="middle" direction="in"/>
<pin name="A11" x="-15.24" y="-7.62" length="middle" direction="in"/>
<pin name="A12" x="-15.24" y="-10.16" length="middle" direction="in"/>
<pin name="A13" x="-15.24" y="-12.7" length="middle" direction="in"/>
</symbol>
<symbol name="1420">
<pin name="D3" x="12.7" y="10.16" length="middle" rot="R180"/>
<pin name="D2" x="12.7" y="12.7" length="middle" rot="R180"/>
<pin name="D1" x="12.7" y="15.24" length="middle" rot="R180"/>
<pin name="D0" x="12.7" y="17.78" length="middle" rot="R180"/>
</symbol>
<symbol name="1600">
<wire x1="-10.16" y1="-25.4" x2="5.08" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-25.4" x2="5.08" y2="25.4" width="0.4064" layer="94"/>
<wire x1="5.08" y1="25.4" x2="-10.16" y2="25.4" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="25.4" x2="-10.16" y2="-25.4" width="0.4064" layer="94"/>
<text x="-10.16" y="26.035" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-27.94" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A0" x="-15.24" y="22.86" length="middle" direction="in"/>
<pin name="A1" x="-15.24" y="20.32" length="middle" direction="in"/>
<pin name="A2" x="-15.24" y="17.78" length="middle" direction="in"/>
<pin name="A3" x="-15.24" y="15.24" length="middle" direction="in"/>
<pin name="A4" x="-15.24" y="12.7" length="middle" direction="in"/>
<pin name="A5" x="-15.24" y="10.16" length="middle" direction="in"/>
<pin name="A6" x="-15.24" y="7.62" length="middle" direction="in"/>
<pin name="A7" x="-15.24" y="5.08" length="middle" direction="in"/>
<pin name="DO" x="10.16" y="22.86" length="middle" direction="hiz" rot="R180"/>
<pin name="!WE" x="-15.24" y="-22.86" length="middle" direction="in"/>
<pin name="!CE" x="-15.24" y="-20.32" length="middle" direction="in"/>
<pin name="DI" x="10.16" y="17.78" length="middle" direction="in" rot="R180"/>
<pin name="A8" x="-15.24" y="2.54" length="middle" direction="in"/>
<pin name="A9" x="-15.24" y="0" length="middle" direction="in"/>
<pin name="A10" x="-15.24" y="-2.54" length="middle" direction="in"/>
<pin name="A11" x="-15.24" y="-5.08" length="middle" direction="in"/>
<pin name="A12" x="-15.24" y="-7.62" length="middle" direction="in"/>
<pin name="A13" x="-15.24" y="-10.16" length="middle" direction="in"/>
<pin name="A14" x="-15.24" y="-12.7" length="middle" direction="in"/>
<pin name="A15" x="-15.24" y="-15.24" length="middle" direction="in"/>
</symbol>
<symbol name="5349">
<wire x1="-7.62" y1="-15.24" x2="7.62" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-15.24" x2="7.62" y2="15.24" width="0.4064" layer="94"/>
<wire x1="7.62" y1="15.24" x2="-7.62" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="15.24" x2="-7.62" y2="-15.24" width="0.4064" layer="94"/>
<text x="-7.62" y="15.875" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-17.78" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A0" x="-12.7" y="12.7" length="middle" direction="in"/>
<pin name="A1" x="-12.7" y="10.16" length="middle" direction="in"/>
<pin name="A2" x="-12.7" y="7.62" length="middle" direction="in"/>
<pin name="A3" x="-12.7" y="5.08" length="middle" direction="in"/>
<pin name="A4" x="-12.7" y="2.54" length="middle" direction="in"/>
<pin name="O1" x="12.7" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="12.7" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="12.7" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="12.7" y="5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="12.7" y="2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="12.7" y="0" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="12.7" y="-2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O8" x="12.7" y="-5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="!CE" x="-12.7" y="-12.7" length="middle" direction="in"/>
<pin name="A5" x="-12.7" y="0" length="middle" direction="in"/>
<pin name="A6" x="-12.7" y="-2.54" length="middle" direction="in"/>
<pin name="A7" x="-12.7" y="-5.08" length="middle" direction="in"/>
<pin name="A8" x="-12.7" y="-7.62" length="middle" direction="in"/>
</symbol>
<symbol name="5341">
<wire x1="7.62" y1="-20.32" x2="7.62" y2="17.78" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="17.78" x2="-7.62" y2="-20.32" width="0.4064" layer="94"/>
<pin name="O5" x="12.7" y="5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="12.7" y="2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="12.7" y="0" length="middle" direction="hiz" rot="R180"/>
<pin name="O8" x="12.7" y="-2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="CE4" x="-12.7" y="-17.78" length="middle" direction="in"/>
<pin name="CE3" x="-12.7" y="-15.24" length="middle" direction="in"/>
<pin name="CE2" x="-12.7" y="-12.7" length="middle" direction="in"/>
<pin name="CE1" x="-12.7" y="-10.16" length="middle" direction="in"/>
</symbol>
<symbol name="5340">
<pin name="O5" x="12.7" y="5.08" length="middle" direction="oc" rot="R180"/>
<pin name="O6" x="12.7" y="2.54" length="middle" direction="oc" rot="R180"/>
<pin name="O7" x="12.7" y="0" length="middle" direction="oc" rot="R180"/>
<pin name="O8" x="12.7" y="-2.54" length="middle" direction="oc" rot="R180"/>
</symbol>
<symbol name="2015">
<wire x1="-10.16" y1="-20.32" x2="5.08" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-20.32" x2="5.08" y2="20.32" width="0.4064" layer="94"/>
<wire x1="5.08" y1="20.32" x2="-10.16" y2="20.32" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="20.32" x2="-10.16" y2="-20.32" width="0.4064" layer="94"/>
<text x="-10.16" y="20.955" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-22.86" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A7" x="-15.24" y="0" length="middle" direction="in"/>
<pin name="A6" x="-15.24" y="2.54" length="middle" direction="in"/>
<pin name="A5" x="-15.24" y="5.08" length="middle" direction="in"/>
<pin name="A4" x="-15.24" y="7.62" length="middle" direction="in"/>
<pin name="A3" x="-15.24" y="10.16" length="middle" direction="in"/>
<pin name="A2" x="-15.24" y="12.7" length="middle" direction="in"/>
<pin name="A1" x="-15.24" y="15.24" length="middle" direction="in"/>
<pin name="A0" x="-15.24" y="17.78" length="middle" direction="in"/>
<pin name="D0" x="10.16" y="17.78" length="middle" rot="R180"/>
<pin name="D1" x="10.16" y="15.24" length="middle" rot="R180"/>
<pin name="D2" x="10.16" y="12.7" length="middle" rot="R180"/>
<pin name="D3" x="10.16" y="10.16" length="middle" rot="R180"/>
<pin name="D4" x="10.16" y="7.62" length="middle" rot="R180"/>
<pin name="D5" x="10.16" y="5.08" length="middle" rot="R180"/>
<pin name="D6" x="10.16" y="2.54" length="middle" rot="R180"/>
<pin name="D7" x="10.16" y="0" length="middle" rot="R180"/>
<pin name="!CE" x="-15.24" y="-12.7" length="middle" direction="in"/>
<pin name="A10" x="-15.24" y="-7.62" length="middle" direction="in"/>
<pin name="!OE" x="-15.24" y="-15.24" length="middle" direction="in"/>
<pin name="!WE" x="-15.24" y="-17.78" length="middle" direction="in"/>
<pin name="A9" x="-15.24" y="-5.08" length="middle" direction="in"/>
<pin name="A8" x="-15.24" y="-2.54" length="middle" direction="in"/>
</symbol>
<symbol name="2063">
<wire x1="5.08" y1="-25.4" x2="5.08" y2="22.86" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="22.86" x2="-10.16" y2="-25.4" width="0.4064" layer="94"/>
<pin name="D0" x="10.16" y="20.32" length="middle" rot="R180"/>
<pin name="D1" x="10.16" y="17.78" length="middle" rot="R180"/>
<pin name="D2" x="10.16" y="15.24" length="middle" rot="R180"/>
<pin name="D3" x="10.16" y="12.7" length="middle" rot="R180"/>
<pin name="D4" x="10.16" y="10.16" length="middle" rot="R180"/>
<pin name="D5" x="10.16" y="7.62" length="middle" rot="R180"/>
<pin name="D6" x="10.16" y="5.08" length="middle" rot="R180"/>
<pin name="D7" x="10.16" y="2.54" length="middle" rot="R180"/>
<pin name="!CS1" x="-15.24" y="-15.24" length="middle" direction="in" function="dot"/>
<pin name="!OE" x="-15.24" y="-22.86" length="middle" direction="in" function="dot"/>
<pin name="CS2" x="-15.24" y="-17.78" length="middle" direction="in"/>
<pin name="!WE" x="-15.24" y="-20.32" length="middle" direction="in" function="dot"/>
</symbol>
<symbol name="2114">
<pin name="!CS" x="-12.7" y="-12.7" length="middle" direction="in" function="dot"/>
<pin name="!WE" x="-12.7" y="-15.24" length="middle" direction="in" function="dot"/>
<pin name="D3" x="12.7" y="7.62" length="middle" rot="R180"/>
<pin name="D2" x="12.7" y="10.16" length="middle" rot="R180"/>
<pin name="D1" x="12.7" y="12.7" length="middle" rot="R180"/>
<pin name="D0" x="12.7" y="15.24" length="middle" rot="R180"/>
</symbol>
<symbol name="2115">
<pin name="DO" x="12.7" y="15.24" length="middle" direction="oc" rot="R180"/>
<pin name="DI" x="12.7" y="10.16" length="middle" direction="in" rot="R180"/>
</symbol>
<symbol name="2125">
<pin name="!CS" x="-12.7" y="-12.7" length="middle" direction="in"/>
<pin name="DO" x="12.7" y="15.24" length="middle" direction="hiz" rot="R180"/>
<pin name="!WE" x="-12.7" y="-15.24" length="middle" direction="in"/>
</symbol>
<symbol name="2130">
<wire x1="-12.7" y1="-33.02" x2="12.7" y2="-33.02" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-33.02" x2="12.7" y2="33.02" width="0.4064" layer="94"/>
<wire x1="12.7" y1="33.02" x2="-12.7" y2="33.02" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="33.02" x2="-12.7" y2="-33.02" width="0.4064" layer="94"/>
<text x="-12.7" y="33.655" size="1.778" layer="95">&gt;NAME</text>
<text x="-12.7" y="-35.56" size="1.778" layer="96">&gt;VALUE</text>
<pin name="CE@1" x="-17.78" y="-20.32" length="middle" direction="in" function="dot"/>
<pin name="R/!W@1" x="-17.78" y="-25.4" length="middle" direction="in"/>
<pin name="BUSY@1" x="-17.78" y="-27.94" length="middle" direction="out" function="dot"/>
<pin name="INTL" x="-17.78" y="-30.48" length="middle" direction="out" function="dot"/>
<pin name="OE@1" x="-17.78" y="-22.86" length="middle" direction="in" function="dot"/>
<pin name="A0L" x="-17.78" y="30.48" length="middle" direction="in"/>
<pin name="A1L" x="-17.78" y="27.94" length="middle" direction="in"/>
<pin name="A2L" x="-17.78" y="25.4" length="middle" direction="in"/>
<pin name="A3L" x="-17.78" y="22.86" length="middle" direction="in"/>
<pin name="A4L" x="-17.78" y="20.32" length="middle" direction="in"/>
<pin name="A5L" x="-17.78" y="17.78" length="middle" direction="in"/>
<pin name="A6L" x="-17.78" y="15.24" length="middle" direction="in"/>
<pin name="A7L" x="-17.78" y="12.7" length="middle" direction="in"/>
<pin name="A8L" x="-17.78" y="10.16" length="middle" direction="in"/>
<pin name="A9L" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="I/O0L" x="-17.78" y="2.54" length="middle"/>
<pin name="I/O1L" x="-17.78" y="0" length="middle"/>
<pin name="I/O2L" x="-17.78" y="-2.54" length="middle"/>
<pin name="I/O3L" x="-17.78" y="-5.08" length="middle"/>
<pin name="I/O4L" x="-17.78" y="-7.62" length="middle"/>
<pin name="I/O5L" x="-17.78" y="-10.16" length="middle"/>
<pin name="I/O6L" x="-17.78" y="-12.7" length="middle"/>
<pin name="I/O7L" x="-17.78" y="-15.24" length="middle"/>
<pin name="I/O0R" x="17.78" y="2.54" length="middle" rot="R180"/>
<pin name="I/O1R" x="17.78" y="0" length="middle" rot="R180"/>
<pin name="I/O2R" x="17.78" y="-2.54" length="middle" rot="R180"/>
<pin name="I/O3R" x="17.78" y="-5.08" length="middle" rot="R180"/>
<pin name="I/O5R" x="17.78" y="-10.16" length="middle" rot="R180"/>
<pin name="I/O6R" x="17.78" y="-12.7" length="middle" rot="R180"/>
<pin name="I/O7R" x="17.78" y="-15.24" length="middle" rot="R180"/>
<pin name="A9R" x="17.78" y="7.62" length="middle" direction="in" rot="R180"/>
<pin name="A8R" x="17.78" y="10.16" length="middle" direction="in" rot="R180"/>
<pin name="A7R" x="17.78" y="12.7" length="middle" direction="in" rot="R180"/>
<pin name="A6R" x="17.78" y="15.24" length="middle" direction="in" rot="R180"/>
<pin name="A5R" x="17.78" y="17.78" length="middle" direction="in" rot="R180"/>
<pin name="A4R" x="17.78" y="20.32" length="middle" direction="in" rot="R180"/>
<pin name="A3R" x="17.78" y="22.86" length="middle" direction="in" rot="R180"/>
<pin name="I/O4R" x="17.78" y="-7.62" length="middle" rot="R180"/>
<pin name="A2R" x="17.78" y="25.4" length="middle" direction="in" rot="R180"/>
<pin name="A1R" x="17.78" y="27.94" length="middle" direction="in" rot="R180"/>
<pin name="A0R" x="17.78" y="30.48" length="middle" direction="in" rot="R180"/>
<pin name="OE@2" x="17.78" y="-22.86" length="middle" direction="in" function="dot" rot="R180"/>
<pin name="INTR" x="17.78" y="-30.48" length="middle" direction="out" function="dot" rot="R180"/>
<pin name="BUSY@2" x="17.78" y="-27.94" length="middle" direction="out" function="dot" rot="R180"/>
<pin name="R/!W@2" x="17.78" y="-25.4" length="middle" direction="in" rot="R180"/>
<pin name="CE@2" x="17.78" y="-20.32" length="middle" direction="in" function="dot" rot="R180"/>
</symbol>
<symbol name="2164">
<wire x1="7.62" y1="-17.78" x2="7.62" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="15.24" x2="-7.62" y2="-17.78" width="0.4064" layer="94"/>
<pin name="DI" x="12.7" y="7.62" length="middle" direction="in" rot="R180"/>
<pin name="!RAS" x="-12.7" y="-10.16" length="middle" direction="in"/>
<pin name="DO" x="12.7" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="!CAS" x="-12.7" y="-12.7" length="middle" direction="in"/>
<pin name="VSS" x="12.7" y="-15.24" length="middle" direction="pwr" rot="R180"/>
<pin name="VCC" x="12.7" y="-5.08" length="middle" direction="pwr" rot="R180"/>
</symbol>
<symbol name="2186">
<pin name="RDY" x="10.16" y="-20.32" length="middle" direction="out" rot="R180"/>
<pin name="!CE" x="-15.24" y="-15.24" length="middle" direction="in"/>
<pin name="!OE" x="-15.24" y="-17.78" length="middle" direction="in"/>
</symbol>
<symbol name="2187">
<wire x1="-10.16" y1="-22.86" x2="7.62" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-22.86" x2="7.62" y2="22.86" width="0.4064" layer="94"/>
<wire x1="7.62" y1="22.86" x2="-10.16" y2="22.86" width="0.4064" layer="94"/>
<pin name="!REF" x="12.7" y="-20.32" length="middle" direction="in" rot="R180"/>
<pin name="D0" x="12.7" y="20.32" length="middle" rot="R180"/>
<pin name="D1" x="12.7" y="17.78" length="middle" rot="R180"/>
<pin name="D2" x="12.7" y="15.24" length="middle" rot="R180"/>
<pin name="D3" x="12.7" y="12.7" length="middle" rot="R180"/>
<pin name="D4" x="12.7" y="10.16" length="middle" rot="R180"/>
<pin name="D5" x="12.7" y="7.62" length="middle" rot="R180"/>
<pin name="D6" x="12.7" y="5.08" length="middle" rot="R180"/>
<pin name="D7" x="12.7" y="2.54" length="middle" rot="R180"/>
</symbol>
<symbol name="5301">
</symbol>
<symbol name="5063">
<pin name="O4" x="12.7" y="5.08" length="middle" direction="oc" rot="R180"/>
<pin name="O3" x="12.7" y="7.62" length="middle" direction="oc" rot="R180"/>
<pin name="O2" x="12.7" y="10.16" length="middle" direction="oc" rot="R180"/>
<pin name="O1" x="12.7" y="12.7" length="middle" direction="oc" rot="R180"/>
</symbol>
<symbol name="7685">
<pin name="A10" x="-12.7" y="-10.16" length="middle" direction="in"/>
<pin name="!CE" x="-12.7" y="-15.24" length="middle" direction="in"/>
</symbol>
<symbol name="2620">
<pin name="!OE" x="-12.7" y="-12.7" length="middle" direction="in"/>
<pin name="!RAS" x="-12.7" y="-7.62" length="middle" direction="in"/>
<pin name="!CAS" x="-12.7" y="-10.16" length="middle" direction="in"/>
</symbol>
<symbol name="2630">
<wire x1="-10.16" y1="-12.7" x2="20.32" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="20.32" y1="-12.7" x2="20.32" y2="25.4" width="0.4064" layer="94"/>
<wire x1="20.32" y1="25.4" x2="-10.16" y2="25.4" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="25.4" x2="-10.16" y2="-12.7" width="0.4064" layer="94"/>
<text x="-10.16" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VSSP1" x="25.4" y="-7.62" length="middle" direction="in" rot="R180"/>
<pin name="SP-" x="-15.24" y="-7.62" length="middle" direction="in"/>
<pin name="VSSA" x="-15.24" y="5.08" length="middle" direction="in"/>
<pin name="SCLK" x="-15.24" y="10.16" length="middle" direction="in"/>
<pin name="MOSI" x="-15.24" y="12.7" length="middle" direction="in"/>
<pin name="VCCD" x="-15.24" y="22.86" length="middle" direction="in"/>
<pin name="MISO" x="-15.24" y="15.24" length="middle" direction="in"/>
<pin name="VCCA" x="25.4" y="5.08" length="middle" rot="R180"/>
<pin name="VCCP" x="-15.24" y="-10.16" length="middle"/>
<pin name="SP+" x="25.4" y="-10.16" length="middle" rot="R180"/>
<pin name="ROSC" x="25.4" y="2.54" length="middle" direction="in" rot="R180"/>
<pin name="MIC-" x="-15.24" y="-2.54" length="middle" direction="in"/>
<pin name="AGC" x="25.4" y="-2.54" length="middle" direction="in" rot="R180"/>
<pin name="VSSP2" x="-15.24" y="-5.08" length="middle" direction="in"/>
<pin name="ANALN" x="-15.24" y="2.54" length="middle" direction="in"/>
<pin name="MIC+" x="-15.24" y="0" length="middle" direction="in"/>
<pin name="AUD/AUX" x="25.4" y="-5.08" length="middle" direction="in" rot="R180"/>
<pin name="VSSD" x="25.4" y="22.86" length="middle" rot="R180"/>
<pin name="LED" x="-15.24" y="20.32" length="middle" function="dot"/>
<pin name="RESET" x="-15.24" y="17.78" length="middle" function="dot"/>
<pin name="SS" x="-15.24" y="7.62" length="middle" function="dot"/>
<pin name="INT/RDY" x="25.4" y="20.32" length="middle" function="dot" rot="R180"/>
<pin name="FWD" x="25.4" y="17.78" length="middle" function="dot" rot="R180"/>
<pin name="ERASE" x="25.4" y="15.24" length="middle" function="dot" rot="R180"/>
<pin name="REC" x="25.4" y="12.7" length="middle" function="dot" rot="R180"/>
<pin name="PLAY" x="25.4" y="10.16" length="middle" function="dot" rot="R180"/>
<pin name="FT" x="25.4" y="7.62" length="middle" function="dot" rot="R180"/>
<pin name="VOL" x="25.4" y="0" length="middle" function="dot" rot="R180"/>
</symbol>
<symbol name="5306">
</symbol>
<symbol name="2716">
<pin name="O0" x="10.16" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="O1" x="10.16" y="15.24" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="10.16" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="10.16" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="10.16" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="10.16" y="5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="10.16" y="2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="10.16" y="0" length="middle" direction="hiz" rot="R180"/>
<pin name="VPP" x="-15.24" y="-17.78" length="middle" direction="in"/>
</symbol>
<symbol name="5600">
<wire x1="-7.62" y1="-12.7" x2="7.62" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-12.7" x2="7.62" y2="10.16" width="0.4064" layer="94"/>
<wire x1="7.62" y1="10.16" x2="-7.62" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="10.16" x2="-7.62" y2="-12.7" width="0.4064" layer="94"/>
<text x="-7.62" y="10.795" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
<pin name="O1" x="12.7" y="7.62" length="middle" direction="oc" rot="R180"/>
<pin name="O2" x="12.7" y="5.08" length="middle" direction="oc" rot="R180"/>
<pin name="O3" x="12.7" y="2.54" length="middle" direction="oc" rot="R180"/>
<pin name="O4" x="12.7" y="0" length="middle" direction="oc" rot="R180"/>
<pin name="O5" x="12.7" y="-2.54" length="middle" direction="oc" rot="R180"/>
<pin name="O6" x="12.7" y="-5.08" length="middle" direction="oc" rot="R180"/>
<pin name="O7" x="12.7" y="-7.62" length="middle" direction="oc" rot="R180"/>
<pin name="O8" x="12.7" y="-10.16" length="middle" direction="oc" rot="R180"/>
<pin name="A0" x="-12.7" y="7.62" length="middle" direction="in"/>
<pin name="A1" x="-12.7" y="5.08" length="middle" direction="in"/>
<pin name="A2" x="-12.7" y="2.54" length="middle" direction="in"/>
<pin name="A3" x="-12.7" y="0" length="middle" direction="in"/>
<pin name="A4" x="-12.7" y="-2.54" length="middle" direction="in"/>
<pin name="!CE" x="-12.7" y="-7.62" length="middle" direction="in"/>
</symbol>
<symbol name="5331">
<pin name="O1" x="12.7" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="12.7" y="5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="12.7" y="2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="12.7" y="0" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="12.7" y="-2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="12.7" y="-5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="12.7" y="-7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O8" x="12.7" y="-10.16" length="middle" direction="hiz" rot="R180"/>
</symbol>
<symbol name="2732">
<pin name="!OE!/VPP" x="-15.24" y="-17.78" length="middle" direction="in"/>
<pin name="A11" x="-15.24" y="-10.16" length="middle" direction="in"/>
</symbol>
<symbol name="27S40">
<pin name="O0" x="12.7" y="17.78" length="middle" direction="oc" rot="R180"/>
<pin name="!CS1" x="-12.7" y="-15.24" length="middle" direction="in"/>
<pin name="!CS2" x="-12.7" y="-17.78" length="middle" direction="in"/>
</symbol>
<symbol name="7134">
<pin name="O0" x="12.7" y="17.78" length="middle" direction="hiz" rot="R180"/>
</symbol>
<symbol name="27S43">
<pin name="CS2" x="-12.7" y="-17.78" length="middle" direction="in"/>
</symbol>
<symbol name="2764">
<pin name="VPP" x="-15.24" y="-22.86" length="middle" direction="in"/>
<pin name="O0" x="10.16" y="20.32" length="middle" direction="hiz" rot="R180"/>
<pin name="O1" x="10.16" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="10.16" y="15.24" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="10.16" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="10.16" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="10.16" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="10.16" y="5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="10.16" y="2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="!PGM" x="-15.24" y="-20.32" length="middle" direction="in"/>
</symbol>
<symbol name="2816">
</symbol>
<symbol name="2817">
<wire x1="5.08" y1="-22.86" x2="5.08" y2="20.32" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="20.32" x2="-10.16" y2="-22.86" width="0.4064" layer="94"/>
<pin name="RDY/!BSY" x="-15.24" y="-20.32" length="middle" direction="in"/>
</symbol>
<symbol name="2864">
<wire x1="-10.16" y1="-22.86" x2="10.16" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-22.86" x2="10.16" y2="22.86" width="0.4064" layer="94"/>
<wire x1="10.16" y1="22.86" x2="-10.16" y2="22.86" width="0.4064" layer="94"/>
<pin name="RDY/!B" x="15.24" y="-15.24" length="middle" direction="out" rot="R180"/>
<pin name="D0" x="15.24" y="20.32" length="middle" rot="R180"/>
<pin name="D1" x="15.24" y="17.78" length="middle" rot="R180"/>
<pin name="D2" x="15.24" y="15.24" length="middle" rot="R180"/>
<pin name="D3" x="15.24" y="12.7" length="middle" rot="R180"/>
<pin name="D4" x="15.24" y="10.16" length="middle" rot="R180"/>
<pin name="D5" x="15.24" y="7.62" length="middle" rot="R180"/>
<pin name="D6" x="15.24" y="5.08" length="middle" rot="R180"/>
<pin name="D7" x="15.24" y="2.54" length="middle" rot="R180"/>
</symbol>
<symbol name="3628">
<pin name="CS4" x="-12.7" y="-17.78" length="middle" direction="in"/>
<pin name="CS3" x="-12.7" y="-15.24" length="middle" direction="in"/>
<pin name="!CS2" x="-12.7" y="-12.7" length="middle" direction="in"/>
<pin name="!CS1" x="-12.7" y="-10.16" length="middle" direction="in"/>
</symbol>
<symbol name="3636">
<pin name="CS3" x="-12.7" y="-17.78" length="middle" direction="in"/>
<pin name="CS2" x="-12.7" y="-15.24" length="middle" direction="in"/>
<pin name="!CS1" x="-12.7" y="-12.7" length="middle" direction="in"/>
</symbol>
<symbol name="4161">
<wire x1="-10.16" y1="-20.32" x2="7.62" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="7.62" y1="20.32" x2="-10.16" y2="20.32" width="0.4064" layer="94"/>
<pin name="SIN" x="12.7" y="5.08" length="middle" direction="in" rot="R180"/>
<pin name="SCLK" x="-15.24" y="-17.78" length="middle" direction="in" function="clk"/>
<pin name="!SOE" x="-15.24" y="-15.24" length="middle" direction="in"/>
<pin name="DIN" x="12.7" y="7.62" length="middle" direction="in" rot="R180"/>
<pin name="!WE" x="-15.24" y="-10.16" length="middle" direction="in"/>
<pin name="!RAS" x="-15.24" y="-5.08" length="middle" direction="in"/>
<pin name="Q" x="12.7" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="!CAS" x="-15.24" y="-7.62" length="middle" direction="in"/>
<pin name="TR/QE" x="-15.24" y="-12.7" length="middle" direction="in" function="dot"/>
<pin name="SOUT" x="12.7" y="15.24" length="middle" direction="out" rot="R180"/>
<pin name="VSS" x="12.7" y="-17.78" length="middle" direction="pwr" rot="R180"/>
<pin name="VDD" x="12.7" y="-7.62" length="middle" direction="pwr" rot="R180"/>
</symbol>
<symbol name="4256">
</symbol>
<symbol name="9864">
<pin name="!CC" x="-15.24" y="-22.86" length="middle" direction="in"/>
</symbol>
<symbol name="5143">
<pin name="O0" x="10.16" y="22.86" length="middle" direction="hiz" rot="R180"/>
<pin name="O1" x="10.16" y="20.32" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="10.16" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="10.16" y="15.24" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="10.16" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="10.16" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="10.16" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="10.16" y="5.08" length="middle" direction="hiz" rot="R180"/>
</symbol>
<symbol name="51C68">
</symbol>
<symbol name="52B23">
<pin name="!CC" x="-15.24" y="-20.32" length="middle" direction="in"/>
</symbol>
<symbol name="5305">
</symbol>
<symbol name="6380">
</symbol>
<symbol name="7137">
</symbol>
<symbol name="7142E">
<pin name="O1" x="12.7" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="12.7" y="15.24" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="12.7" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="12.7" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="12.7" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="12.7" y="5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="12.7" y="2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O8" x="12.7" y="0" length="middle" direction="hiz" rot="R180"/>
<pin name="!CE2" x="-12.7" y="-17.78" length="middle" direction="in"/>
<pin name="!CE1" x="-12.7" y="-15.24" length="middle" direction="in"/>
</symbol>
<symbol name="99C68">
</symbol>
<symbol name="27010">
<wire x1="-10.16" y1="-30.48" x2="5.08" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-30.48" x2="5.08" y2="27.94" width="0.4064" layer="94"/>
<wire x1="5.08" y1="27.94" x2="-10.16" y2="27.94" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="27.94" x2="-10.16" y2="-30.48" width="0.4064" layer="94"/>
<text x="-10.16" y="28.575" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-33.02" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VPP" x="-15.24" y="-25.4" length="middle" direction="in"/>
<pin name="A16" x="-15.24" y="-15.24" length="middle" direction="in"/>
<pin name="A15" x="-15.24" y="-12.7" length="middle" direction="in"/>
<pin name="A12" x="-15.24" y="-5.08" length="middle" direction="in"/>
<pin name="A7" x="-15.24" y="7.62" length="middle" direction="in"/>
<pin name="A6" x="-15.24" y="10.16" length="middle" direction="in"/>
<pin name="A5" x="-15.24" y="12.7" length="middle" direction="in"/>
<pin name="A4" x="-15.24" y="15.24" length="middle" direction="in"/>
<pin name="A3" x="-15.24" y="17.78" length="middle" direction="in"/>
<pin name="A2" x="-15.24" y="20.32" length="middle" direction="in"/>
<pin name="A1" x="-15.24" y="22.86" length="middle" direction="in"/>
<pin name="A0" x="-15.24" y="25.4" length="middle" direction="in"/>
<pin name="O0" x="10.16" y="25.4" length="middle" direction="hiz" rot="R180"/>
<pin name="O1" x="10.16" y="22.86" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="10.16" y="20.32" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="10.16" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="10.16" y="15.24" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="10.16" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="10.16" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="10.16" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="A10" x="-15.24" y="0" length="middle" direction="in"/>
<pin name="!OE" x="-15.24" y="-22.86" length="middle" direction="in"/>
<pin name="A11" x="-15.24" y="-2.54" length="middle" direction="in"/>
<pin name="A9" x="-15.24" y="2.54" length="middle" direction="in"/>
<pin name="A8" x="-15.24" y="5.08" length="middle" direction="in"/>
<pin name="A13" x="-15.24" y="-7.62" length="middle" direction="in"/>
<pin name="A14" x="-15.24" y="-10.16" length="middle" direction="in"/>
<pin name="!PGM" x="-15.24" y="-27.94" length="middle" direction="in"/>
</symbol>
<symbol name="27011">
<wire x1="-10.16" y1="-25.4" x2="7.62" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-25.4" x2="7.62" y2="25.4" width="0.4064" layer="94"/>
<wire x1="7.62" y1="25.4" x2="-10.16" y2="25.4" width="0.4064" layer="94"/>
<pin name="VPP/!RST" x="-15.24" y="-22.86" length="middle" direction="in"/>
<pin name="D0/O0" x="12.7" y="22.86" length="middle" direction="hiz" rot="R180"/>
<pin name="D1/O1" x="12.7" y="20.32" length="middle" direction="hiz" rot="R180"/>
<pin name="D2/O2" x="12.7" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="12.7" y="15.24" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="12.7" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="12.7" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="12.7" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="12.7" y="5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="!OE" x="-15.24" y="-20.32" length="middle" direction="in"/>
<pin name="PGM/WE" x="-15.24" y="-17.78" length="middle" direction="in" function="dot"/>
</symbol>
<symbol name="27210">
<wire x1="-10.16" y1="-27.94" x2="10.16" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-27.94" x2="10.16" y2="27.94" width="0.4064" layer="94"/>
<wire x1="10.16" y1="27.94" x2="-10.16" y2="27.94" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="27.94" x2="-10.16" y2="-27.94" width="0.4064" layer="94"/>
<text x="-10.16" y="-30.48" size="1.778" layer="96">&gt;VALUE</text>
<pin name="!CE" x="-15.24" y="-17.78" length="middle" direction="in"/>
<pin name="O15" x="15.24" y="-12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O14" x="15.24" y="-10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O13" x="15.24" y="-7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O12" x="15.24" y="-5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O11" x="15.24" y="-2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O10" x="15.24" y="0" length="middle" direction="hiz" rot="R180"/>
<pin name="O9" x="15.24" y="2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O8" x="15.24" y="5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="15.24" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="15.24" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="15.24" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="15.24" y="15.24" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="15.24" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="15.24" y="20.32" length="middle" direction="hiz" rot="R180"/>
<pin name="O1" x="15.24" y="22.86" length="middle" direction="hiz" rot="R180"/>
<pin name="O0" x="15.24" y="25.4" length="middle" direction="hiz" rot="R180"/>
<pin name="!PGM" x="-15.24" y="-25.4" length="middle" direction="in"/>
<pin name="VCC" x="15.24" y="-17.78" length="middle" direction="pwr" rot="R180"/>
<pin name="GND@1" x="15.24" y="-22.86" length="middle" direction="pwr" rot="R180"/>
<pin name="GND@2" x="15.24" y="-25.4" length="middle" direction="pwr" rot="R180"/>
</symbol>
<symbol name="27256">
</symbol>
<symbol name="27512">
</symbol>
<symbol name="27513">
<pin name="!RST" x="-15.24" y="-22.86" length="middle" direction="in"/>
<pin name="O2" x="12.7" y="17.78" length="middle" direction="hiz" rot="R180"/>
<pin name="!OE!/VPP" x="-15.24" y="-20.32" length="middle" direction="in"/>
</symbol>
<symbol name="27916">
<pin name="PGM/WE" x="-15.24" y="-20.32" length="middle" direction="in" function="dot"/>
</symbol>
<symbol name="51C259">
<pin name="D0" x="12.7" y="12.7" length="middle" rot="R180"/>
<pin name="D1" x="12.7" y="10.16" length="middle" rot="R180"/>
<pin name="D2" x="12.7" y="7.62" length="middle" rot="R180"/>
<pin name="D3" x="12.7" y="5.08" length="middle" rot="R180"/>
</symbol>
<symbol name="76165">
<pin name="CE2" x="-12.7" y="-17.78" length="middle" direction="in"/>
<pin name="CE1" x="-12.7" y="-15.24" length="middle" direction="in"/>
</symbol>
<symbol name="76641">
<pin name="A12" x="-12.7" y="-12.7" length="middle" direction="in"/>
<pin name="!CE" x="-12.7" y="-17.78" length="middle" direction="in"/>
</symbol>
<symbol name="XL78C800">
<wire x1="-10.16" y1="-17.78" x2="5.08" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-17.78" x2="5.08" y2="17.78" width="0.4064" layer="94"/>
<wire x1="5.08" y1="17.78" x2="-10.16" y2="17.78" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="17.78" x2="-10.16" y2="-17.78" width="0.4064" layer="94"/>
<text x="-10.16" y="18.415" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
<pin name="CLK" x="-15.24" y="-12.7" length="middle" direction="in"/>
<pin name="I0" x="-15.24" y="15.24" length="middle" direction="in"/>
<pin name="I1" x="-15.24" y="12.7" length="middle" direction="in"/>
<pin name="I2" x="-15.24" y="10.16" length="middle" direction="in"/>
<pin name="I3" x="-15.24" y="7.62" length="middle" direction="in"/>
<pin name="I4" x="-15.24" y="5.08" length="middle" direction="in"/>
<pin name="I5" x="-15.24" y="2.54" length="middle" direction="in"/>
<pin name="I6" x="-15.24" y="0" length="middle" direction="in"/>
<pin name="I7" x="-15.24" y="-2.54" length="middle" direction="in"/>
<pin name="I8" x="-15.24" y="-5.08" length="middle" direction="in"/>
<pin name="I9" x="-15.24" y="-7.62" length="middle" direction="in"/>
<pin name="O9" x="10.16" y="-7.62" length="middle" rot="R180"/>
<pin name="O8" x="10.16" y="-5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O7" x="10.16" y="-2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O6" x="10.16" y="0" length="middle" direction="hiz" rot="R180"/>
<pin name="O5" x="10.16" y="2.54" length="middle" direction="hiz" rot="R180"/>
<pin name="O4" x="10.16" y="5.08" length="middle" direction="hiz" rot="R180"/>
<pin name="O3" x="10.16" y="7.62" length="middle" direction="hiz" rot="R180"/>
<pin name="O2" x="10.16" y="10.16" length="middle" direction="hiz" rot="R180"/>
<pin name="O1" x="10.16" y="12.7" length="middle" direction="hiz" rot="R180"/>
<pin name="O0" x="10.16" y="15.24" length="middle" rot="R180"/>
</symbol>
<symbol name="PWRN">
<text x="-0.635" y="-0.635" size="1.778" layer="95">&gt;NAME</text>
<text x="1.905" y="-5.588" size="1.27" layer="95" rot="R90">GND</text>
<text x="1.905" y="2.413" size="1.27" layer="95" rot="R90">VCC</text>
<pin name="GND" x="0" y="-7.62" visible="pad" length="middle" direction="pwr" rot="R90"/>
<pin name="VCC" x="0" y="7.62" visible="pad" length="middle" direction="pwr" rot="R270"/>
</symbol>
<symbol name="621024">
<wire x1="-10.16" y1="-30.48" x2="7.62" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="7.62" y1="27.94" x2="7.62" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="7.62" y1="27.94" x2="-10.16" y2="27.94" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="-30.48" x2="-10.16" y2="27.94" width="0.4064" layer="94"/>
<pin name="!CS1" x="-15.24" y="-25.4" length="middle" direction="in"/>
<pin name="I/O0" x="12.7" y="25.4" length="middle" rot="R180"/>
<pin name="I/O1" x="12.7" y="22.86" length="middle" rot="R180"/>
<pin name="I/O2" x="12.7" y="20.32" length="middle" rot="R180"/>
<pin name="I/O3" x="12.7" y="17.78" length="middle" rot="R180"/>
<pin name="I/O4" x="12.7" y="15.24" length="middle" rot="R180"/>
<pin name="I/O5" x="12.7" y="12.7" length="middle" rot="R180"/>
<pin name="I/O6" x="12.7" y="10.16" length="middle" rot="R180"/>
<pin name="I/O7" x="12.7" y="7.62" length="middle" rot="R180"/>
<pin name="NC" x="2.54" y="-10.16" visible="off" length="point" direction="nc" rot="R180"/>
<pin name="CS2" x="-15.24" y="-27.94" length="middle" direction="in"/>
</symbol>
<symbol name="1001">
<wire x1="-7.62" y1="-30.48" x2="7.62" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-30.48" x2="7.62" y2="27.94" width="0.4064" layer="94"/>
<wire x1="7.62" y1="27.94" x2="-7.62" y2="27.94" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="27.94" x2="-7.62" y2="-30.48" width="0.4064" layer="94"/>
<text x="-7.62" y="28.575" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-33.02" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A12" x="-10.16" y="-5.08" length="short" direction="in"/>
<pin name="A7" x="-10.16" y="7.62" length="short" direction="in"/>
<pin name="A6" x="-10.16" y="10.16" length="short" direction="in"/>
<pin name="A5" x="-10.16" y="12.7" length="short" direction="in"/>
<pin name="A4" x="-10.16" y="15.24" length="short" direction="in"/>
<pin name="A3" x="-10.16" y="17.78" length="short" direction="in"/>
<pin name="A2" x="-10.16" y="20.32" length="short" direction="in"/>
<pin name="A1" x="-10.16" y="22.86" length="short" direction="in"/>
<pin name="A0" x="-10.16" y="25.4" length="short" direction="in"/>
<pin name="O0" x="10.16" y="25.4" length="short" direction="hiz" rot="R180"/>
<pin name="O1" x="10.16" y="22.86" length="short" direction="hiz" rot="R180"/>
<pin name="O2" x="10.16" y="20.32" length="short" direction="hiz" rot="R180"/>
<pin name="O3" x="10.16" y="17.78" length="short" direction="hiz" rot="R180"/>
<pin name="O4" x="10.16" y="15.24" length="short" direction="hiz" rot="R180"/>
<pin name="O5" x="10.16" y="12.7" length="short" direction="hiz" rot="R180"/>
<pin name="O6" x="10.16" y="10.16" length="short" direction="hiz" rot="R180"/>
<pin name="O7" x="10.16" y="7.62" length="short" direction="hiz" rot="R180"/>
<pin name="CE2" x="-10.16" y="-25.4" length="short" direction="in"/>
<pin name="A10" x="-10.16" y="0" length="short" direction="in"/>
<pin name="!OE" x="-10.16" y="-27.94" length="short" direction="in"/>
<pin name="A11" x="-10.16" y="-2.54" length="short" direction="in"/>
<pin name="A9" x="-10.16" y="2.54" length="short" direction="in"/>
<pin name="A8" x="-10.16" y="5.08" length="short" direction="in"/>
<pin name="A13" x="-10.16" y="-7.62" length="short" direction="in"/>
<pin name="A14" x="-10.16" y="-10.16" length="short" direction="in"/>
<pin name="!CE1" x="-10.16" y="-22.86" length="short" direction="in"/>
<pin name="!RW" x="-10.16" y="-20.32" length="short" direction="in"/>
<pin name="A15" x="-10.16" y="-12.7" length="short" direction="in"/>
<pin name="A16" x="-10.16" y="-15.24" length="short" direction="in"/>
</symbol>
<symbol name="NC">
<text x="0.762" y="-0.762" size="1.778" layer="95">&gt;NAME</text>
<pin name="NC" x="-2.54" y="0" visible="pad" length="short" direction="nc"/>
</symbol>
<symbol name="257">
<wire x1="-7.62" y1="-25.4" x2="7.62" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="7.62" y1="25.4" x2="-7.62" y2="25.4" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="25.4" x2="-7.62" y2="-25.4" width="0.4064" layer="94"/>
<text x="-7.62" y="26.035" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-27.94" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A12" x="-10.16" y="-7.62" length="short" direction="in"/>
<pin name="A7" x="-10.16" y="5.08" length="short" direction="in"/>
<pin name="A6" x="-10.16" y="7.62" length="short" direction="in"/>
<pin name="A5" x="-10.16" y="10.16" length="short" direction="in"/>
<pin name="A4" x="-10.16" y="12.7" length="short" direction="in"/>
<pin name="A3" x="-10.16" y="15.24" length="short" direction="in"/>
<pin name="A2" x="-10.16" y="17.78" length="short" direction="in"/>
<pin name="A1" x="-10.16" y="20.32" length="short" direction="in"/>
<pin name="A0" x="-10.16" y="22.86" length="short" direction="in"/>
<pin name="O0" x="10.16" y="22.86" length="short" direction="hiz" rot="R180"/>
<pin name="O1" x="10.16" y="20.32" length="short" direction="hiz" rot="R180"/>
<pin name="O2" x="10.16" y="17.78" length="short" direction="hiz" rot="R180"/>
<pin name="O3" x="10.16" y="15.24" length="short" direction="hiz" rot="R180"/>
<pin name="O4" x="10.16" y="12.7" length="short" direction="hiz" rot="R180"/>
<pin name="O5" x="10.16" y="10.16" length="short" direction="hiz" rot="R180"/>
<pin name="O6" x="10.16" y="7.62" length="short" direction="hiz" rot="R180"/>
<pin name="O7" x="10.16" y="5.08" length="short" direction="hiz" rot="R180"/>
<pin name="A10" x="-10.16" y="-2.54" length="short" direction="in"/>
<pin name="!OE" x="-10.16" y="-22.86" length="short" direction="in"/>
<pin name="A11" x="-10.16" y="-5.08" length="short" direction="in"/>
<pin name="A9" x="-10.16" y="0" length="short" direction="in"/>
<pin name="A8" x="-10.16" y="2.54" length="short" direction="in"/>
<pin name="A13" x="-10.16" y="-10.16" length="short" direction="in"/>
<pin name="A14" x="-10.16" y="-12.7" length="short" direction="in"/>
<pin name="!CE" x="-10.16" y="-20.32" length="short" direction="in"/>
<pin name="!RW" x="-10.16" y="-17.78" length="short" direction="in"/>
</symbol>
<symbol name="M48T35">
<wire x1="7.62" y1="25.4" x2="7.62" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="-25.4" x2="-7.62" y2="25.4" width="0.4064" layer="94"/>
<pin name="!W" x="-10.16" y="-17.78" length="short" direction="in"/>
<pin name="!E" x="-10.16" y="-20.32" length="short" direction="in"/>
<pin name="!G" x="-10.16" y="-22.86" length="short" direction="in"/>
<pin name="DQ0" x="10.16" y="22.86" length="short" rot="R180"/>
<pin name="DQ1" x="10.16" y="20.32" length="short" rot="R180"/>
<pin name="DQ2" x="10.16" y="17.78" length="short" rot="R180"/>
<pin name="DQ3" x="10.16" y="15.24" length="short" rot="R180"/>
<pin name="DQ4" x="10.16" y="12.7" length="short" rot="R180"/>
<pin name="DQ5" x="10.16" y="10.16" length="short" rot="R180"/>
<pin name="DQ6" x="10.16" y="7.62" length="short" rot="R180"/>
<pin name="DQ7" x="10.16" y="5.08" length="short" rot="R180"/>
</symbol>
<symbol name="SST39VF040">
<wire x1="7.62" y1="-30.48" x2="7.62" y2="30.48" width="0.4064" layer="94"/>
<wire x1="7.62" y1="30.48" x2="-7.62" y2="30.48" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="30.48" x2="-7.62" y2="-30.48" width="0.4064" layer="94"/>
<text x="-7.62" y="31.115" size="1.778" layer="95">&gt;NAME</text>
<pin name="A7" x="-10.16" y="10.16" length="short" direction="in"/>
<pin name="A6" x="-10.16" y="12.7" length="short" direction="in"/>
<pin name="A5" x="-10.16" y="15.24" length="short" direction="in"/>
<pin name="A4" x="-10.16" y="17.78" length="short" direction="in"/>
<pin name="A3" x="-10.16" y="20.32" length="short" direction="in"/>
<pin name="A2" x="-10.16" y="22.86" length="short" direction="in"/>
<pin name="A1" x="-10.16" y="25.4" length="short" direction="in"/>
<pin name="A0" x="-10.16" y="27.94" length="short" direction="in"/>
<pin name="D0" x="10.16" y="27.94" length="short" rot="R180"/>
<pin name="D1" x="10.16" y="25.4" length="short" rot="R180"/>
<pin name="D2" x="10.16" y="22.86" length="short" rot="R180"/>
<pin name="D3" x="10.16" y="20.32" length="short" rot="R180"/>
<pin name="D4" x="10.16" y="17.78" length="short" rot="R180"/>
<pin name="D5" x="10.16" y="15.24" length="short" rot="R180"/>
<pin name="D6" x="10.16" y="12.7" length="short" rot="R180"/>
<pin name="D7" x="10.16" y="10.16" length="short" rot="R180"/>
<pin name="!CE" x="-10.16" y="-22.86" length="short" direction="in"/>
<pin name="A10" x="-10.16" y="2.54" length="short" direction="in"/>
<pin name="!OE" x="-10.16" y="-25.4" length="short" direction="in"/>
<pin name="!WE" x="-10.16" y="-27.94" length="short" direction="in"/>
<pin name="A9" x="-10.16" y="5.08" length="short" direction="in"/>
<pin name="A8" x="-10.16" y="7.62" length="short" direction="in"/>
<pin name="A11" x="-10.16" y="0" length="short" direction="in"/>
<pin name="A12" x="-10.16" y="-2.54" length="short" direction="in"/>
<pin name="A13" x="-10.16" y="-5.08" length="short" direction="in"/>
<pin name="A14" x="-10.16" y="-7.62" length="short" direction="in"/>
<pin name="A15" x="-10.16" y="-10.16" length="short" direction="in"/>
<pin name="A16" x="-10.16" y="-12.7" length="short" direction="in"/>
<pin name="A17" x="-10.16" y="-15.24" length="short" direction="in"/>
<pin name="A18" x="-10.16" y="-17.78" length="short" direction="in"/>
</symbol>
<symbol name="SST39VF020">
<wire x1="-7.62" y1="-27.94" x2="7.62" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-27.94" x2="7.62" y2="30.48" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="30.48" x2="-7.62" y2="-27.94" width="0.4064" layer="94"/>
<text x="-7.62" y="-30.48" size="1.778" layer="96">&gt;VALUE</text>
<pin name="!WE" x="-10.16" y="-25.4" length="short" direction="in"/>
</symbol>
<symbol name="SST39VF010">
<wire x1="7.62" y1="-27.94" x2="7.62" y2="27.94" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="27.94" x2="-7.62" y2="-27.94" width="0.4064" layer="94"/>
<pin name="D0" x="10.16" y="25.4" length="short" rot="R180"/>
<pin name="D1" x="10.16" y="22.86" length="short" rot="R180"/>
<pin name="D2" x="10.16" y="20.32" length="short" rot="R180"/>
<pin name="D3" x="10.16" y="17.78" length="short" rot="R180"/>
<pin name="D4" x="10.16" y="15.24" length="short" rot="R180"/>
<pin name="D5" x="10.16" y="12.7" length="short" rot="R180"/>
<pin name="D6" x="10.16" y="10.16" length="short" rot="R180"/>
<pin name="D7" x="10.16" y="7.62" length="short" rot="R180"/>
</symbol>
<symbol name="SST39VF512">
<wire x1="-7.62" y1="-26.67" x2="7.62" y2="-26.67" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-26.67" x2="7.62" y2="25.4" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="25.4" x2="-7.62" y2="-26.67" width="0.4064" layer="94"/>
<text x="-7.62" y="-29.21" size="1.778" layer="96">&gt;VALUE</text>
<pin name="D0" x="10.16" y="22.86" length="short" rot="R180"/>
<pin name="D1" x="10.16" y="20.32" length="short" rot="R180"/>
<pin name="D2" x="10.16" y="17.78" length="short" rot="R180"/>
<pin name="D3" x="10.16" y="15.24" length="short" rot="R180"/>
<pin name="D4" x="10.16" y="12.7" length="short" rot="R180"/>
<pin name="D5" x="10.16" y="10.16" length="short" rot="R180"/>
<pin name="D6" x="10.16" y="7.62" length="short" rot="R180"/>
<pin name="D7" x="10.16" y="5.08" length="short" rot="R180"/>
<pin name="A15" x="-10.16" y="-15.24" length="short" direction="in"/>
</symbol>
<symbol name="PWRN2">
<pin name="GND@1" x="0" y="-7.62" visible="pad" length="middle" direction="pwr" rot="R90"/>
<pin name="VCC@1" x="0" y="7.62" visible="pad" length="middle" direction="pwr" rot="R270"/>
<pin name="VCC@2" x="2.54" y="7.62" visible="pad" length="middle" direction="pwr" rot="R270"/>
<pin name="GND@2" x="2.54" y="-7.62" visible="pad" length="middle" direction="pwr" rot="R90"/>
</symbol>
<symbol name="IS42S16100">
<wire x1="-10.16" y1="-38.1" x2="10.16" y2="-38.1" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-38.1" x2="10.16" y2="38.1" width="0.4064" layer="94"/>
<wire x1="10.16" y1="38.1" x2="-10.16" y2="38.1" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="38.1" x2="-10.16" y2="-38.1" width="0.4064" layer="94"/>
<text x="-10.16" y="38.735" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-40.64" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A7" x="-12.7" y="2.54" length="short" direction="in"/>
<pin name="A6" x="-12.7" y="5.08" length="short" direction="in"/>
<pin name="A5" x="-12.7" y="7.62" length="short" direction="in"/>
<pin name="A4" x="-12.7" y="10.16" length="short" direction="in"/>
<pin name="A3" x="-12.7" y="12.7" length="short" direction="in"/>
<pin name="A2" x="-12.7" y="15.24" length="short" direction="in"/>
<pin name="A1" x="-12.7" y="17.78" length="short" direction="in"/>
<pin name="A0" x="-12.7" y="20.32" length="short" direction="in"/>
<pin name="D0" x="12.7" y="20.32" length="short" rot="R180"/>
<pin name="D1" x="12.7" y="17.78" length="short" rot="R180"/>
<pin name="D2" x="12.7" y="15.24" length="short" rot="R180"/>
<pin name="D3" x="12.7" y="12.7" length="short" rot="R180"/>
<pin name="D4" x="12.7" y="10.16" length="short" rot="R180"/>
<pin name="D5" x="12.7" y="7.62" length="short" rot="R180"/>
<pin name="D6" x="12.7" y="5.08" length="short" rot="R180"/>
<pin name="D7" x="12.7" y="2.54" length="short" rot="R180"/>
<pin name="!CS" x="-12.7" y="-27.94" length="short" direction="in"/>
<pin name="A10" x="-12.7" y="-5.08" length="short" direction="in"/>
<pin name="!RAS" x="-12.7" y="-20.32" length="short" direction="in"/>
<pin name="!WE" x="-12.7" y="-25.4" length="short" direction="in"/>
<pin name="A9" x="-12.7" y="-2.54" length="short" direction="in"/>
<pin name="A8" x="-12.7" y="0" length="short" direction="in"/>
<pin name="A11" x="-12.7" y="-7.62" length="short" direction="in"/>
<pin name="UDQM" x="-12.7" y="-12.7" length="short" direction="in"/>
<pin name="LDQM" x="-12.7" y="-15.24" length="short" direction="in"/>
<pin name="!CAS" x="-12.7" y="-22.86" length="short" direction="in"/>
<pin name="CKE" x="-12.7" y="25.4" length="short" direction="in"/>
<pin name="CLK" x="-12.7" y="27.94" length="short" direction="in"/>
<pin name="D8" x="12.7" y="0" length="short" rot="R180"/>
<pin name="D9" x="12.7" y="-2.54" length="short" rot="R180"/>
<pin name="D10" x="12.7" y="-5.08" length="short" rot="R180"/>
<pin name="D11" x="12.7" y="-7.62" length="short" rot="R180"/>
<pin name="D12" x="12.7" y="-10.16" length="short" rot="R180"/>
<pin name="D13" x="12.7" y="-12.7" length="short" rot="R180"/>
<pin name="D14" x="12.7" y="-15.24" length="short" rot="R180"/>
<pin name="D15" x="12.7" y="-17.78" length="short" rot="R180"/>
<pin name="VDD@1" x="-12.7" y="35.56" length="short" direction="pwr"/>
<pin name="GND@1" x="-12.7" y="-35.56" length="short" direction="pwr"/>
<pin name="VDDQ@1" x="12.7" y="35.56" length="short" direction="pwr" rot="R180"/>
<pin name="GNDQ@1" x="12.7" y="-35.56" length="short" direction="pwr" rot="R180"/>
<pin name="GNDQ@2" x="12.7" y="-33.02" length="short" direction="pwr" rot="R180"/>
<pin name="GNDQ@3" x="12.7" y="-30.48" length="short" direction="pwr" rot="R180"/>
<pin name="GNDQ@4" x="12.7" y="-27.94" length="short" direction="pwr" rot="R180"/>
<pin name="VDDQ@2" x="12.7" y="33.02" length="short" direction="pwr" rot="R180"/>
<pin name="VDDQ@3" x="12.7" y="30.48" length="short" direction="pwr" rot="R180"/>
<pin name="VDDQ@4" x="12.7" y="27.94" length="short" direction="pwr" rot="R180"/>
<pin name="GND@2" x="-12.7" y="-33.02" length="short" direction="pwr"/>
<pin name="VDD@2" x="-12.7" y="33.02" length="short" direction="pwr"/>
</symbol>
<symbol name="IS42S16100B">
<wire x1="10.16" y1="-38.1" x2="10.16" y2="40.64" width="0.4064" layer="94"/>
<wire x1="10.16" y1="40.64" x2="-10.16" y2="40.64" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="40.64" x2="-10.16" y2="-38.1" width="0.4064" layer="94"/>
<text x="-10.16" y="41.275" size="1.778" layer="95">&gt;NAME</text>
<pin name="VDD@1" x="-12.7" y="38.1" length="short" direction="pwr"/>
<pin name="VDDQ@1" x="12.7" y="38.1" length="short" direction="pwr" rot="R180"/>
<pin name="VDDQ@2" x="12.7" y="35.56" length="short" direction="pwr" rot="R180"/>
<pin name="VDDQ@3" x="12.7" y="33.02" length="short" direction="pwr" rot="R180"/>
<pin name="VDDQ@4" x="12.7" y="30.48" length="short" direction="pwr" rot="R180"/>
<pin name="VDD@2" x="-12.7" y="35.56" length="short" direction="pwr"/>
<pin name="VDD@3" x="-12.7" y="33.02" length="short" direction="pwr"/>
</symbol>
<symbol name="SST39LF200A">
<wire x1="-10.16" y1="-35.56" x2="10.16" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-35.56" x2="10.16" y2="33.02" width="0.4064" layer="94"/>
<wire x1="10.16" y1="33.02" x2="-10.16" y2="33.02" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="33.02" x2="-10.16" y2="-35.56" width="0.4064" layer="94"/>
<text x="-10.16" y="33.655" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-38.1" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A7" x="-12.7" y="7.62" length="short" direction="in"/>
<pin name="A6" x="-12.7" y="10.16" length="short" direction="in"/>
<pin name="A5" x="-12.7" y="12.7" length="short" direction="in"/>
<pin name="A4" x="-12.7" y="15.24" length="short" direction="in"/>
<pin name="A3" x="-12.7" y="17.78" length="short" direction="in"/>
<pin name="A2" x="-12.7" y="20.32" length="short" direction="in"/>
<pin name="A1" x="-12.7" y="22.86" length="short" direction="in"/>
<pin name="A0" x="-12.7" y="25.4" length="short" direction="in"/>
<pin name="D0" x="12.7" y="25.4" length="short" rot="R180"/>
<pin name="D1" x="12.7" y="22.86" length="short" rot="R180"/>
<pin name="D2" x="12.7" y="20.32" length="short" rot="R180"/>
<pin name="D3" x="12.7" y="17.78" length="short" rot="R180"/>
<pin name="D4" x="12.7" y="15.24" length="short" rot="R180"/>
<pin name="D5" x="12.7" y="12.7" length="short" rot="R180"/>
<pin name="D6" x="12.7" y="10.16" length="short" rot="R180"/>
<pin name="D7" x="12.7" y="7.62" length="short" rot="R180"/>
<pin name="!CE" x="-12.7" y="-25.4" length="short" direction="in"/>
<pin name="A10" x="-12.7" y="0" length="short" direction="in"/>
<pin name="!WE" x="-12.7" y="-22.86" length="short" direction="in"/>
<pin name="A9" x="-12.7" y="2.54" length="short" direction="in"/>
<pin name="A8" x="-12.7" y="5.08" length="short" direction="in"/>
<pin name="A11" x="-12.7" y="-2.54" length="short" direction="in"/>
<pin name="D8" x="12.7" y="5.08" length="short" rot="R180"/>
<pin name="D9" x="12.7" y="2.54" length="short" rot="R180"/>
<pin name="D10" x="12.7" y="0" length="short" rot="R180"/>
<pin name="D11" x="12.7" y="-2.54" length="short" rot="R180"/>
<pin name="D12" x="12.7" y="-5.08" length="short" rot="R180"/>
<pin name="D13" x="12.7" y="-7.62" length="short" rot="R180"/>
<pin name="D14" x="12.7" y="-10.16" length="short" rot="R180"/>
<pin name="D15" x="12.7" y="-12.7" length="short" rot="R180"/>
<pin name="VDD@1" x="-12.7" y="30.48" length="short" direction="pwr"/>
<pin name="GND@1" x="-12.7" y="-33.02" length="short" direction="pwr"/>
<pin name="GND@2" x="-12.7" y="-30.48" length="short" direction="pwr"/>
<pin name="A12" x="-12.7" y="-5.08" length="short" direction="in"/>
<pin name="A13" x="-12.7" y="-7.62" length="short" direction="in"/>
<pin name="A14" x="-12.7" y="-10.16" length="short" direction="in"/>
<pin name="A15" x="-12.7" y="-12.7" length="short" direction="in"/>
<pin name="A16" x="-12.7" y="-15.24" length="short" direction="in"/>
<pin name="!OE" x="-12.7" y="-20.32" length="short" direction="in"/>
</symbol>
<symbol name="SST39LF400A">
<wire x1="10.16" y1="-38.1" x2="10.16" y2="33.02" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="33.02" x2="-10.16" y2="-38.1" width="0.4064" layer="94"/>
<pin name="!CE" x="-12.7" y="-27.94" length="short" direction="in"/>
<pin name="!OE" x="-12.7" y="-22.86" length="short" direction="in"/>
<pin name="A17" x="-12.7" y="-17.78" length="short" direction="in"/>
</symbol>
<symbol name="SST39LF800A">
<wire x1="-10.16" y1="-40.64" x2="10.16" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-40.64" x2="10.16" y2="33.02" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="33.02" x2="-10.16" y2="-40.64" width="0.4064" layer="94"/>
<text x="-10.16" y="-43.18" size="1.778" layer="96">&gt;VALUE</text>
<pin name="!CE" x="-12.7" y="-30.48" length="short" direction="in"/>
<pin name="!WE" x="-12.7" y="-27.94" length="short" direction="in"/>
<pin name="GND@1" x="-12.7" y="-38.1" length="short" direction="pwr"/>
<pin name="GND@2" x="-12.7" y="-35.56" length="short" direction="pwr"/>
<pin name="!OE" x="-12.7" y="-25.4" length="short" direction="in"/>
<pin name="A18" x="-12.7" y="-20.32" length="short" direction="in"/>
</symbol>
<symbol name="FM93C66">
<wire x1="-7.62" y1="7.62" x2="7.62" y2="7.62" width="0.254" layer="94"/>
<wire x1="7.62" y1="7.62" x2="7.62" y2="-7.62" width="0.254" layer="94"/>
<wire x1="7.62" y1="-7.62" x2="-7.62" y2="-7.62" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-7.62" x2="-7.62" y2="7.62" width="0.254" layer="94"/>
<text x="-7.62" y="8.89" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VCC" x="10.16" y="5.08" length="short" direction="pwr" rot="R180"/>
<pin name="VSS" x="10.16" y="-5.08" length="short" direction="pwr" rot="R180"/>
<pin name="CS" x="-10.16" y="2.54" length="short" direction="in"/>
<pin name="SK" x="-10.16" y="-2.54" length="short" direction="in"/>
<pin name="DI" x="-10.16" y="0" length="short" direction="in"/>
<pin name="DO" x="10.16" y="0" length="short" direction="hiz" rot="R180"/>
</symbol>
<symbol name="ISD">
</symbol>
</symbols>
<devicesets>
<deviceset name="ISD1730PY" prefix="IC" uservalue="yes">
<description>&lt;b&gt;MEMORY&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="2630" x="22.86" y="0"/>
</gates>
<devices>
<device name="" package="DIL28">
<connects>
<connect gate="A" pin="AGC" pad="18"/>
<connect gate="A" pin="ANALN" pad="9"/>
<connect gate="A" pin="AUD/AUX" pad="17"/>
<connect gate="A" pin="ERASE" pad="25"/>
<connect gate="A" pin="FT" pad="22"/>
<connect gate="A" pin="FWD" pad="26"/>
<connect gate="A" pin="INT/RDY" pad="27"/>
<connect gate="A" pin="LED" pad="2"/>
<connect gate="A" pin="MIC+" pad="10"/>
<connect gate="A" pin="MIC-" pad="11"/>
<connect gate="A" pin="MISO" pad="4"/>
<connect gate="A" pin="MOSI" pad="5"/>
<connect gate="A" pin="PLAY" pad="23"/>
<connect gate="A" pin="REC" pad="24"/>
<connect gate="A" pin="RESET" pad="3"/>
<connect gate="A" pin="ROSC" pad="20"/>
<connect gate="A" pin="SCLK" pad="6"/>
<connect gate="A" pin="SP+" pad="15"/>
<connect gate="A" pin="SP-" pad="13"/>
<connect gate="A" pin="SS" pad="7"/>
<connect gate="A" pin="VCCA" pad="21"/>
<connect gate="A" pin="VCCD" pad="1"/>
<connect gate="A" pin="VCCP" pad="14"/>
<connect gate="A" pin="VOL" pad="19"/>
<connect gate="A" pin="VSSA" pad="8"/>
<connect gate="A" pin="VSSD" pad="28"/>
<connect gate="A" pin="VSSP1" pad="16"/>
<connect gate="A" pin="VSSP2" pad="12"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
