<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="ISD1730PY">
<pad name="P$1" x="-7.62" y="3.81" drill="0.8" shape="long"/>
<pad name="P$2" x="-7.62" y="1.27" drill="0.8" shape="long"/>
<pad name="P$3" x="-7.62" y="-1.27" drill="0.8" shape="long"/>
<pad name="P$4" x="-7.62" y="-3.81" drill="0.8" shape="long"/>
<pad name="P$5" x="-7.62" y="-6.35" drill="0.8" shape="long"/>
<pad name="P$6" x="-7.62" y="-8.89" drill="0.8" shape="long"/>
<pad name="P$7" x="-7.62" y="-11.43" drill="0.8" shape="long"/>
<pad name="P$8" x="-7.62" y="-13.97" drill="0.8" shape="long"/>
<pad name="P$9" x="-7.62" y="-16.51" drill="0.8" shape="long"/>
<pad name="P$10" x="-7.62" y="6.35" drill="0.8" shape="long"/>
<pad name="P$11" x="-7.62" y="8.89" drill="0.8" shape="long"/>
<pad name="P$12" x="-7.62" y="11.43" drill="0.8" shape="long"/>
<pad name="P$13" x="-7.62" y="13.97" drill="0.8" shape="long"/>
<pad name="P$14" x="-7.62" y="16.51" drill="0.8" shape="long"/>
<pad name="P$16" x="8.89" y="-16.51" drill="0.8" shape="long"/>
<pad name="P$17" x="8.89" y="13.97" drill="0.8" shape="long"/>
<pad name="P$18" x="8.89" y="11.43" drill="0.8" shape="long"/>
<pad name="P$19" x="8.89" y="8.89" drill="0.8" shape="long"/>
<pad name="P$20" x="8.89" y="6.35" drill="0.8" shape="long"/>
<pad name="P$21" x="8.89" y="3.81" drill="0.8" shape="long"/>
<pad name="P$22" x="8.89" y="1.27" drill="0.8" shape="long"/>
<pad name="P$23" x="8.89" y="-1.27" drill="0.8" shape="long"/>
<pad name="P$24" x="8.89" y="-3.81" drill="0.8" shape="long"/>
<pad name="P$25" x="8.89" y="-6.35" drill="0.8" shape="long"/>
<pad name="P$26" x="8.89" y="-8.89" drill="0.8" shape="long"/>
<pad name="P$27" x="8.89" y="-11.43" drill="0.8" shape="long"/>
<pad name="P$28" x="8.89" y="-13.97" drill="0.8" shape="long"/>
<pad name="P$29" x="8.89" y="16.51" drill="0.8" shape="long"/>
<wire x1="-6.35" y1="17.78" x2="7.62" y2="17.78" width="0.4064" layer="21"/>
<wire x1="7.62" y1="17.78" x2="7.62" y2="16.51" width="0.4064" layer="21"/>
<wire x1="7.62" y1="16.51" x2="7.62" y2="13.97" width="0.4064" layer="21"/>
<wire x1="7.62" y1="13.97" x2="7.62" y2="11.43" width="0.4064" layer="21"/>
<wire x1="7.62" y1="11.43" x2="7.62" y2="8.89" width="0.4064" layer="21"/>
<wire x1="7.62" y1="8.89" x2="7.62" y2="6.35" width="0.4064" layer="21"/>
<wire x1="7.62" y1="6.35" x2="7.62" y2="3.81" width="0.4064" layer="21"/>
<wire x1="7.62" y1="3.81" x2="7.62" y2="1.27" width="0.4064" layer="21"/>
<wire x1="7.62" y1="1.27" x2="7.62" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="7.62" y1="-1.27" x2="7.62" y2="-3.81" width="0.4064" layer="21"/>
<wire x1="7.62" y1="-3.81" x2="7.62" y2="-6.35" width="0.4064" layer="21"/>
<wire x1="7.62" y1="-6.35" x2="7.62" y2="-8.89" width="0.4064" layer="21"/>
<wire x1="7.62" y1="-8.89" x2="7.62" y2="-11.43" width="0.4064" layer="21"/>
<wire x1="7.62" y1="-11.43" x2="7.62" y2="-13.97" width="0.4064" layer="21"/>
<wire x1="7.62" y1="-13.97" x2="7.62" y2="-16.51" width="0.4064" layer="21"/>
<wire x1="7.62" y1="-16.51" x2="7.62" y2="-17.78" width="0.4064" layer="21"/>
<wire x1="7.62" y1="-17.78" x2="-6.35" y2="-17.78" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="-17.78" x2="-6.35" y2="-16.51" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="-16.51" x2="-6.35" y2="-13.97" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="-13.97" x2="-6.35" y2="-11.43" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="-11.43" x2="-6.35" y2="-8.89" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="-8.89" x2="-6.35" y2="-6.35" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="-6.35" x2="-6.35" y2="-3.81" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="-3.81" x2="-6.35" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="-1.27" x2="-6.35" y2="1.27" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="1.27" x2="-6.35" y2="3.81" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="3.81" x2="-6.35" y2="6.35" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="6.35" x2="-6.35" y2="8.89" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="8.89" x2="-6.35" y2="11.43" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="11.43" x2="-6.35" y2="13.97" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="16.51" x2="-6.35" y2="17.78" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="16.51" x2="-6.35" y2="16.51" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="16.51" x2="-6.35" y2="13.97" width="0.4064" layer="21"/>
<wire x1="-6.35" y1="13.97" x2="-7.62" y2="13.97" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="11.43" x2="-6.35" y2="11.43" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="8.89" x2="-6.35" y2="8.89" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="6.35" x2="-6.35" y2="6.35" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="3.81" x2="-6.35" y2="3.81" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.27" x2="-6.35" y2="1.27" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="-1.27" x2="-6.35" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-6.35" y2="-3.81" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-6.35" y2="-6.35" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="-8.89" x2="-6.35" y2="-8.89" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="-11.43" x2="-6.35" y2="-11.43" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="-13.97" x2="-6.35" y2="-13.97" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="-16.51" x2="-6.35" y2="-16.51" width="0.4064" layer="21"/>
<wire x1="8.89" y1="16.51" x2="7.62" y2="16.51" width="0.4064" layer="21"/>
<wire x1="8.89" y1="13.97" x2="7.62" y2="13.97" width="0.4064" layer="21"/>
<wire x1="8.89" y1="11.43" x2="7.62" y2="11.43" width="0.4064" layer="21"/>
<wire x1="8.89" y1="8.89" x2="7.62" y2="8.89" width="0.4064" layer="21"/>
<wire x1="8.89" y1="6.35" x2="7.62" y2="6.35" width="0.4064" layer="21"/>
<wire x1="8.89" y1="3.81" x2="7.62" y2="3.81" width="0.4064" layer="21"/>
<wire x1="8.89" y1="1.27" x2="7.62" y2="1.27" width="0.4064" layer="21"/>
<wire x1="8.89" y1="-1.27" x2="7.62" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="8.89" y1="-3.81" x2="7.62" y2="-3.81" width="0.4064" layer="21"/>
<wire x1="8.89" y1="-6.35" x2="7.62" y2="-6.35" width="0.4064" layer="21"/>
<wire x1="8.89" y1="-8.89" x2="7.62" y2="-8.89" width="0.4064" layer="21"/>
<wire x1="8.89" y1="-11.43" x2="7.62" y2="-11.43" width="0.4064" layer="21"/>
<wire x1="8.89" y1="-13.97" x2="7.62" y2="-13.97" width="0.4064" layer="21"/>
<wire x1="8.89" y1="-16.51" x2="7.62" y2="-16.51" width="0.4064" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="ISD1730PY">
<pin name="VCCD" x="17.78" y="12.7" length="middle" rot="R180"/>
<pin name="LED" x="17.78" y="15.24" length="middle" rot="R180"/>
<pin name="RESET" x="17.78" y="17.78" length="middle" rot="R180"/>
<pin name="MISO" x="-17.78" y="-5.08" length="middle"/>
<pin name="SCLK" x="-17.78" y="0" length="middle"/>
<pin name="SS" x="-17.78" y="2.54" length="middle"/>
<pin name="VSSA" x="17.78" y="5.08" length="middle" rot="R180"/>
<pin name="ANALN" x="-17.78" y="-12.7" length="middle"/>
<pin name="MIC+" x="-17.78" y="-7.62" length="middle"/>
<pin name="MIC-" x="-17.78" y="-10.16" length="middle"/>
<pin name="VSSP2" x="17.78" y="-2.54" length="middle" rot="R180"/>
<pin name="SP-" x="17.78" y="-7.62" length="middle" rot="R180"/>
<pin name="VCCP" x="17.78" y="2.54" length="middle" rot="R180"/>
<pin name="MOSI" x="-17.78" y="-2.54" length="middle"/>
<pin name="VSSD" x="17.78" y="10.16" length="middle" rot="R180"/>
<pin name="INT/RDY" x="17.78" y="-12.7" length="middle" rot="R180"/>
<pin name="FWD" x="-17.78" y="10.16" length="middle"/>
<pin name="ERASE" x="-17.78" y="12.7" length="middle"/>
<pin name="REC" x="-17.78" y="17.78" length="middle"/>
<pin name="PLAY" x="-17.78" y="15.24" length="middle"/>
<pin name="FT" x="-17.78" y="5.08" length="middle"/>
<pin name="VCCA" x="17.78" y="7.62" length="middle" rot="R180"/>
<pin name="ROSC" x="-17.78" y="-15.24" length="middle"/>
<pin name="VOL" x="-17.78" y="7.62" length="middle"/>
<pin name="AGC" x="17.78" y="-15.24" length="middle" rot="R180"/>
<pin name="AUD/AUX" x="17.78" y="-10.16" length="middle" rot="R180"/>
<pin name="VSSP1" x="17.78" y="0" length="middle" rot="R180"/>
<pin name="SP+" x="17.78" y="-5.08" length="middle" rot="R180"/>
<wire x1="-12.7" y1="20.32" x2="12.7" y2="20.32" width="0.254" layer="94"/>
<wire x1="12.7" y1="20.32" x2="12.7" y2="-17.78" width="0.254" layer="94"/>
<wire x1="12.7" y1="-17.78" x2="-12.7" y2="-17.78" width="0.254" layer="94"/>
<wire x1="-12.7" y1="-17.78" x2="-12.7" y2="20.32" width="0.254" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="ISD1730PY">
<gates>
<gate name="G$1" symbol="ISD1730PY" x="0" y="-2.54"/>
</gates>
<devices>
<device name="" package="ISD1730PY">
<connects>
<connect gate="G$1" pin="AGC" pad="P$18"/>
<connect gate="G$1" pin="ANALN" pad="P$9"/>
<connect gate="G$1" pin="AUD/AUX" pad="P$17"/>
<connect gate="G$1" pin="ERASE" pad="P$25"/>
<connect gate="G$1" pin="FT" pad="P$22"/>
<connect gate="G$1" pin="FWD" pad="P$26"/>
<connect gate="G$1" pin="INT/RDY" pad="P$27"/>
<connect gate="G$1" pin="LED" pad="P$2"/>
<connect gate="G$1" pin="MIC+" pad="P$10"/>
<connect gate="G$1" pin="MIC-" pad="P$11"/>
<connect gate="G$1" pin="MISO" pad="P$4"/>
<connect gate="G$1" pin="MOSI" pad="P$5"/>
<connect gate="G$1" pin="PLAY" pad="P$23"/>
<connect gate="G$1" pin="REC" pad="P$24"/>
<connect gate="G$1" pin="RESET" pad="P$3"/>
<connect gate="G$1" pin="ROSC" pad="P$20"/>
<connect gate="G$1" pin="SCLK" pad="P$6"/>
<connect gate="G$1" pin="SP+" pad="P$29"/>
<connect gate="G$1" pin="SP-" pad="P$13"/>
<connect gate="G$1" pin="SS" pad="P$7"/>
<connect gate="G$1" pin="VCCA" pad="P$21"/>
<connect gate="G$1" pin="VCCD" pad="P$1"/>
<connect gate="G$1" pin="VCCP" pad="P$14"/>
<connect gate="G$1" pin="VOL" pad="P$19"/>
<connect gate="G$1" pin="VSSA" pad="P$8"/>
<connect gate="G$1" pin="VSSD" pad="P$28"/>
<connect gate="G$1" pin="VSSP1" pad="P$16"/>
<connect gate="G$1" pin="VSSP2" pad="P$12"/>
</connects>
<technologies>
<technology name="">
<attribute name="ISD" value="1730PY" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
