# Automatically-generated file. Do not edit!
-include ../makefile.init
SHELL := cmd.exe
RM := rm -rf
USER_OBJS :=
LIBS :=
PROJ :=
O_SRCS :=
C_SRCS :=
S_SRCS :=
S_UPPER_SRCS :=
OBJ_SRCS :=
ASM_SRCS :=
PREPROCESSING_SRCS :=
OBJS :=
OBJS_AS_ARGS :=
C_DEPS :=
C_DEPS_AS_ARGS :=
EXECUTABLES :=
OUTPUT_FILE_PATH :=
OUTPUT_FILE_PATH_AS_ARGS :=
HEX_FLASH_FILE_PATH :=
HEX_FLASH_FILE_PATH_AS_ARGS :=
HEX_EEPROM_FILE_PATH :=
HEX_EEPROM_FILE_PATH_AS_ARGS :=
LSS_FILE_PATH :=
LSS_FILE_PATH_AS_ARGS :=
MAP_FILE_PATH :=
MAP_FILE_PATH_AS_ARGS :=
AVR_APP_PATH :=C:/Program Files (x86)/Atmel/AVR Studio 5.0/extensions/Application/Avr ToolChain/bin/
QUOTE := "
ADDITIONAL_DEPENDENCIES:=
# Every subdirectory with source files must be described here
SUBDIRS :=
# Add inputs and outputs from these tool invocations to the build variables
C_SRCS +=  \
../ATtiny2313_Thermostat.c
PREPROCESSING_SRCS +=
ASM_SRCS +=
OBJS +=  \
ATtiny2313_Thermostat.o
OBJS_AS_ARGS +=  \
C_DEPS +=  \
ATtiny2313_Thermostat.d
C_DEPS_AS_ARGS +=  \
OUTPUT_FILE_PATH +=ATtiny2313_Thermostat.elf
OUTPUT_FILE_PATH_AS_ARGS +=ATtiny2313_Thermostat.elf
HEX_FLASH_FILE_PATH +=ATtiny2313_Thermostat.hex
HEX_FLASH_FILE_PATH_AS_ARGS +=ATtiny2313_Thermostat.hex
HEX_EEPROM_FILE_PATH +=ATtiny2313_Thermostat.eep
HEX_EEPROM_FILE_PATH_AS_ARGS +=ATtiny2313_Thermostat.eep
LSS_FILE_PATH +=ATtiny2313_Thermostat.lss
LSS_FILE_PATH_AS_ARGS +=ATtiny2313_Thermostat.lss
MAP_FILE_PATH =ATtiny2313_Thermostat.map
MAP_FILE_PATH_AS_ARGS =ATtiny2313_Thermostat.map
ADDITIONAL_DEPENDENCIES:= $(HEX_FLASH_FILE_PATH) $(LSS_FILE_PATH) $(HEX_EEPROM_FILE_PATH) size
# AVR/GNU C Compiler
./%.o: .././%.c ../ATtiny2313_Thermostat.avrgccproj
	@echo Building file: $<
	@echo Invoking: AVR/GNU C Compiler
	$(QUOTE)$(AVR_APP_PATH)avr-gcc.exe$(QUOTE) -funsigned-char -funsigned-bitfields -Os -fpack-struct -fshort-enums -g2 -Wall -Werror -c  -mmcu=attiny2313   -MMD -MP -MF"$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -o"$@" "$<"
	@echo Finished building: $<
# AVR/GNU Assembler
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
endif
-include ../makefile.defs
# All Target
all: $(OUTPUT_FILE_PATH) $(ADDITIONAL_DEPENDENCIES)
# AVR/GNU C Linker
$(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS)
	@echo Building target: $@
	@echo Invoking: AVR/GNU C Linker
	$(QUOTE)$(AVR_APP_PATH)avr-gcc.exe$(QUOTE)  -mmcu=attiny2313  -Wl,-Map=$(MAP_FILE_PATH_AS_ARGS) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS)
	@echo Finished building target: $@
$(HEX_FLASH_FILE_PATH): $(OUTPUT_FILE_PATH)
	$(QUOTE)$(AVR_APP_PATH)avr-objcopy.exe$(QUOTE) -O ihex -R .eeprom -R .fuse -R .lock -R .signature  $(QUOTE)$<$(QUOTE) $(QUOTE)$@$(QUOTE)
$(HEX_EEPROM_FILE_PATH): $(OUTPUT_FILE_PATH)
	-$(QUOTE)$(AVR_APP_PATH)avr-objcopy.exe$(QUOTE) -j .eeprom --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0 --no-change-warnings -O ihex $(QUOTE)$<$(QUOTE) $(QUOTE)$@$(QUOTE) || exit 0
$(LSS_FILE_PATH): $(OUTPUT_FILE_PATH)
	$(QUOTE)$(AVR_APP_PATH)avr-objdump.exe$(QUOTE) -h -S $(QUOTE)$<$(QUOTE) > $(QUOTE)$@$(QUOTE)
	@$(QUOTE)$(AVR_APP_PATH)avr-size.exe$(QUOTE) -C --mcu=attiny2313 $(OUTPUT_FILE_PATH_AS_ARGS)
# Other Targets
clean:
	-$(RM) $(OBJS_AS_ARGS)$(C_DEPS_AS_ARGS) $(QUOTE)$(EXECUTABLES)$(QUOTE) $(OUTPUT_FILE_PATH_AS_ARGS) $(HEX_FLASH_FILE_PATH_AS_ARGS) $(HEX_EEPROM_FILE_PATH_AS_ARGS) $(LSS_FILE_PATH_AS_ARGS) $(MAP_FILE_PATH_AS_ARGS)
.PHONY: all clean dependents
.SECONDARY:
-include ../makefile.targets
