.SUBCKT szamolo  IO1 IO2 IO3 IO4 IO5 IO6 IO7 IO8 GND
VCCVCC  VCC 0 dc 5
aU3 [dU3.notLT
+      dU3.notRBI
+      4
+      3
+      2
+      1
+      dU3.notBIbackslashRBO
+      rU3.OA
+      rU3.OB
+      rU3.OC
+      rU3.OD
+      rU3.OE
+      rU3.OF
+      rU3.OG]
+     [dU3.OA
+      dU3.OB
+      dU3.OC
+      dU3.OD
+      dU3.OE
+      dU3.OF
+      dU3.OG] 74LS47__74STD__1
xU3.OA  ~dU3.OA  IO1 VCC GND TTL_DRVOC__NON__1
xU3.OD  ~dU3.OD  IO4 VCC GND TTL_DRVOC__NON__1
xU3.OE  ~dU3.OE  IO5 VCC GND TTL_DRVOC__NON__1
xU3.OF  ~dU3.OF  IO6 VCC GND TTL_DRVOC__NON__1
xU3.OC  ~dU3.OC  IO3 VCC GND TTL_DRVOC__NON__1
xU3.OB  ~dU3.OB  IO2 VCC GND TTL_DRVOC__NON__1
xU3.OG  ~dU3.OG  IO7 VCC GND TTL_DRVOC__NON__1
xU3.notLT VCC dU3.notLT VCC GND TTL_RCV__NON__1
xU3.notRBI VCC dU3.notRBI VCC GND TTL_RCV__NON__1
xU3.notBIbackslashRBO VCC dU3.notBIbackslashRBO VCC GND TTL_RCV__NON__1
aU2 [dU2.INA
+      1
+      dU2.R01
+      dU2.R02
+      dU2.R91
+      dU2.R92]
+     [1
+      2
+      3
+      4] 7490__74STD__1
xU2.R91 GND dU2.R91 VCC GND TTL_RCV__NON__1
xU2.R92 GND dU2.R92 VCC GND TTL_RCV__NON__1
xU2.R01 GND dU2.R01 VCC GND TTL_RCV__NON__1
xU2.INA IO8 dU2.INA VCC GND TTL_RCV__NON__1
xU2.R02 GND dU2.R02 VCC GND TTL_RCV__NON__1
.SUBCKT TTL_DRVOC__NON__1 1 2 3 4
aDACin1 [1] [8] aDAC
R1 5 3 1.6K
R2 4 6 1K
Q1 5 8 6 Qideal
Q2 2 6 4 Qideal
.MODEL Qideal NPN (rb= 10 is= 1e-14 bf= 400 re= 10 rc= 10 cje=2p cjc=2p)
.MODEL aDAC dac_bridge (out_low= 0.8 out_high = 2.0 out_undef= 0.8 )
.ENDS
.MODEL 74LS47__74STD__1 d_chip ( behaviour= "
+;74LS47 BCD TO SEVEN-SEGMENT DISPLAY OC 15V OUTPUTS
+/inputs ~LT ~RBI D C B A ~BI/RBO
+/outputs OA OB OC OD OE OF OG
+/table 20
+; LT' RBI' D C B A BI/RBO'  A B C D E F G
+   H   H   L L L L    H     L L L L L L H
+   H   H   L L L H    H     H L L H H H H
+   H   H   L L H L    H     L L H L L H L
+   H   H   L L H H    H     L L L L H H L 
+   H   H   L H L L    H     H L L H H L L
+   H   H   L H L H    H     L H L L H L L
+   H   H   L H H L    H     H H L L L L L
+   H   H   L H H H    H     L L L H H H H
+   H   H   H L L L    H     L L L L L L L
+   H   H   H L L H    H     L L L H H L L
+   H   H   H L H L    H     H H H L L H L
+   H   H   H L H H    H     H H L L H H L
+   H   H   H H L L    H     H L H H H L L
+   H   H   H H L H    H     L H H L H L L
+   H   H   H H H L    H     H H H L L L L
+   H   H   H H H H    H     H H H H H H H
+   X   X   X X X X    L     H H H H H H H
+   H   L   L L L L    L     H H H H H H H
+   L   X   X X X X    H     L L L L L L L
+   H   X   X X X X    H    L L L L L L L
+/delay 42
+;input output rise time fall time
+   A     OA    100n     100n
+   A     OB    100n     100n
+   A     OC    100n     100n
+   A     OD    100n     100n
+   A     OE    100n     100n
+   A     OF    100n     100n
+   A     OG    100n     100n
+   B     OA    100n     100n
+   B     OB    100n     100n
+   B     OC    100n     100n
+   B     OD    100n     100n
+   B     OE    100n     100n
+   B     OF    100n     100n
+   B     OG    100n     100n
+   C     OA    100n     100n
+   C     OB    100n     100n
+   C     OC    100n     100n
+   C     OD    100n     100n
+   C     OE    100n     100n
+   C     OF    100n     100n
+   C     OG    100n     100n
+   D     OA    100n     100n
+   D     OB    100n     100n
+   D     OC    100n     100n
+   D     OD    100n     100n
+   D     OE    100n     100n
+   D     OF    100n     100n
+   D     OG    100n     100n
+  ~RBI   OA    100n     100n
+  ~RBI   OB    100n     100n
+  ~RBI   OC    100n     100n
+  ~RBI   OD    100n     100n
+  ~RBI   OE    100n     100n
+  ~RBI   OF    100n     100n
+  ~RBI   OG    100n     100n
+  ~LT    OA    100n     100n
+  ~LT    OB    100n     100n
+  ~LT    OC    100n     100n
+  ~LT    OD    100n     100n
+  ~LT    OE    100n     100n
+  ~LT    OF    100n     100n
+  ~LT    OG    100n     100n
.SUBCKT TTL_RCV__NON__1 1 2 3 4
* TTL LOAD Model  1 = input, 2 = A/D out 3 = VCC 4= GND
*#L1
aADC1in [1] [2]  ADC1
.MODEL ADC1 adc_bridge (in_low= 2.5 in_high = 2.5 )
*#L1
.ENDS
.MODEL 7490__74STD__1 d_chip ( behaviour= "
+; 7490 DECADE COUNTER
+/inputs  INA INB R01 R02 R91 R92
+/outputs QA QB QC QD
+/module  CNT_90A
+/inputs  IN R01 R02 R91 R92
+/outputs Q
+;clock input_number edge{+|-} number_of_flags sync_entries async_entries
+/clock  IN - 1 1  3
+;SYNC
+; IN R01  R02 R91  R92 F NF
+  X   X   X    X   X   X   F+0
+;ASYNC
+  X   H   H    X   X   X L
+  X   X   X    H   H   X H
+  X   X   X    X   X   X F0
+/table 1
+; IN R01  R02 R91  R92 F Q
+  X   X    X   X    X  X F0
+/delay 5
+;input  output  Rise time  Fall time
+   IN     Q       16n        18n
+   R01    Q       X          40n
+   R02    Q       X          40n
+   R91    Q       X          30n
+   R92    Q       X          30n
+/constraint 9
+;   Name       Event From  Event To   Min/Max  Time
+ 'PULSE WIDTH'  LH    IN    HL   IN     MIN     15n
+ 'PULSE WIDTH'  LH    R01   HL   R01    MIN     15n
+ 'PULSE WIDTH'  LH    R02   HL   R02    MIN     15n
+ 'PULSE WIDTH'  LH    R91   HL   R91    MIN     15n
+ 'PULSE WIDTH'  LH    R92   HL   R92    MIN     15n
+ 'SETUP'        HL    IN    HL   R01    MIN     30n
+ 'SETUP'        HL    IN    HL   R02    MIN     30n
+ 'SETUP'        HL    IN    HL   R91    MIN     30n
+ 'SETUP'        HL    IN    HL   R92    MIN     30n
+/endmodule
+/module  CNT_90B
+/outputs Q1 Q2 Q3
+/clock IN  - 3 6 3
+;SYNC
+; IN R01 R02 R91 R92  F F F  NF   NF   NF
+  X   X       X    X     X      L L H  L     L     L
+  X   X       L    X     L      X X X  F+0 F+1 F+2
+  X   L       X    L     X      X X X  F+0 F+1 F+2
+  X   X       L    L     X      X X X  F+0 F+1 F+2
+  X   X       X    X      X     X X X  F0  F1  F2
+;ASYNC
+  X   H      H    X      X     X X X  L   L   L
+  X   X       X    H     H     X X X  L   L   H
+/table 1
+; IN R01 R02 R91 R92  F F F   Q1  Q2  Q3
+/delay 15
+   IN     Q1      16n        21n
+   IN     Q2      32n        35n
+   IN     Q3      32n        35n
+   R01    Q1      X          40n
+   R02    Q1      X          40n
+   R01    Q2      X          40n
+   R02    Q2      X          40n
+   R01    Q3      X          40n
+   R02    Q3      X          40n
+   R91    Q1      X          40n
+   R92    Q1      X          40n
+   R91    Q2      X          40n
+   R92    Q2      X          40n
+   R91    Q3      X          30n
+   R92    Q3      X          30n
+/constraint 9
+ 'PULSE WIDTH'  LH    IN    HL   IN     MIN     30n
+/endmodule
+/instance CNT_90A INA R01 R02  R91 R92 QA
+/instance CNT_90B INB R01 R02  R91 R92 QB QC QD
.ENDS
