  Defusable Clock Firmware
  Copyright (C) 2011 nootropic design, LLC
  All rights reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
#include <EEPROM.h>
#define CLOCK 2
#define LATCH 3
#define DATA 4
#define COLON 13
#define MIN_BUTTON 0
#define HOUR_BUTTON 1
#define DET_BUTTON 2
#define ALARM_BUTTON 3
#define MIN_BUTTON_PIN 9
#define HOUR_BUTTON_PIN 10
#define DET_BUTTON_PIN 12
#define ALARM_BUTTON_PIN 15
#define LED_PM 16
#define LED_ALARM 17
#define LED_TOP 18
#define LED_DET 19
#define BUZZER 11
#define WIRE_1 5
#define WIRE_2 6
#define WIRE_3 7
#define WIRE_4 8
#define TIMER1_SECOND_START 49910
#define COUNTDOWN_DURATION 10
#define SNOOZE_MINUTES 9
#define ALARM_OFF 0
#define ALARM_ON 1
#define ALARM_DET 2
volatile byte hours = 12;
volatile byte minutes = 0;
volatile byte seconds = 0;
volatile boolean pm = false;
volatile unsigned int countdownSeconds;
volatile boolean ticked = false;
boolean displayCountdown = false;
boolean countdownRunning = false;
byte buttonPins[4] = {MIN_BUTTON_PIN, HOUR_BUTTON_PIN, DET_BUTTON_PIN, ALARM_BUTTON_PIN};
byte buttonState[4] = {HIGH, HIGH, HIGH, HIGH};
unsigned long buttonChange[4] = {0L, 0L, 0L, 0L};
byte alarmHours = 12;
byte alarmMinutes = 0;
boolean alarmpm = false;
byte alarmMode = ALARM_OFF;
volatile boolean alarmRinging = false;
boolean displayAlarmTime = false;
// Set to true if you want the PM LED on during PM hours.  I think it's too bright and
// annoying, so I'm setting this to false by default.
boolean usePMIndicator = false;
byte snoozeHours = 12;
byte snoozeMinutes = 0;
byte snoozepm = false;
boolean snoozeActivated = false;
boolean blank = false;
volatile byte currentDigit = 0;
void setup() {
  pinMode(CLOCK, OUTPUT);
  pinMode(LATCH, OUTPUT);
  pinMode(DATA, OUTPUT);
  pinMode(COLON, OUTPUT);
  digitalWrite(COLON, LOW);
  pinMode(LED_PM, OUTPUT);
  pinMode(LED_ALARM, OUTPUT);
  pinMode(LED_TOP, OUTPUT);
  pinMode(LED_DET, OUTPUT);
  pinMode(BUZZER, OUTPUT);
  pinMode(HOUR_BUTTON_PIN, INPUT);
  pinMode(MIN_BUTTON_PIN, INPUT);
  pinMode(ALARM_BUTTON_PIN, INPUT);
  pinMode(DET_BUTTON_PIN, INPUT);
  pinMode(WIRE_1, INPUT);
  pinMode(WIRE_2, INPUT);
  pinMode(WIRE_3, INPUT);
  pinMode(WIRE_4, INPUT);
  digitalWrite(HOUR_BUTTON_PIN, HIGH);
  digitalWrite(MIN_BUTTON_PIN, HIGH);
  digitalWrite(ALARM_BUTTON_PIN, HIGH);
  digitalWrite(DET_BUTTON_PIN, HIGH);
  digitalWrite(WIRE_1, HIGH);
  digitalWrite(WIRE_2, HIGH);
  digitalWrite(WIRE_3, HIGH);
  digitalWrite(WIRE_4, HIGH);
  // Read time from EEPROM
  hours = EEPROM.read(0);
  minutes = EEPROM.read(1);
  seconds = EEPROM.read(2);
  pm = EEPROM.read(3);
  alarmHours = EEPROM.read(4);
  alarmMinutes = EEPROM.read(5);
  alarmpm = EEPROM.read(6);
  alarmMode = EEPROM.read(7);
  if ((hours == 0) || (hours > 12) || (alarmHours == 0) || (alarmHours > 12) || (minutes >= 60) || (alarmMinutes >= 60) || (alarmMode > ALARM_DET)) {
    // invalid data in EEPROM (first time power up)
    hours = 12;
    minutes = 0;
    seconds = 0;
    alarmHours = 12;
    alarmMinutes = 0;
    pm = false;
    alarmpm = false;
  // Initialize timers.
  // Timer1 is used to keep the clock time
  // Timer2 is used for the display multiplexing
  // Disable the timer overflow interrupt
  TIMSK2 &= ~(1 << TOIE2);
  // Set timer2 to normal mode
  TCCR2A &= ~((1 << WGM21) | (1 << WGM20));
  TCCR2B &= ~(1 << WGM22);
  // Use internal I/O clock
  ASSR &= ~(1 << AS2);
  // Disable compare match interrupt
  TIMSK2 &= ~(1 << OCIE2A);
  // Prescalar is clock divided by 128
  TCCR2B |= (1 << CS22);
  TCCR2B &= ~(1 << CS21);
  TCCR2B |= (1 << CS20);
  // Start the counting at 0
  TCNT2 = 0;
  // Enable the timer2 overflow interrupt
  TIMSK2 |= (1 << TOIE2);
  // init timer1
  // set prescaler to 1024
  TIMSK1 &= ~(1<<TOIE1);
  TCCR1A = 0;
  TCCR1B = (1<<CS12) | (1<<CS10);
  TIMSK1 |= (1<<TOIE1);
  // With prescalar of 1024, TCNT1 increments 15,625 times per second
  // 65535 - 15625 = 49910
  TCNT1 = TIMER1_SECOND_START;
  randomSeed(analogRead(0));
void loop() {
  if (ticked) {
    ticked = false;
    // write info to EEPROM
    EEPROM.write(0, hours);
    EEPROM.write(1, minutes);
    EEPROM.write(2, seconds);
    EEPROM.write(3, pm);
    EEPROM.write(4, alarmHours);
    EEPROM.write(5, alarmMinutes);
    EEPROM.write(6, alarmpm);
    EEPROM.write(7, alarmMode);
  if (alarmRinging) {
    if (alarmMode == ALARM_ON) {
      ringAlarm();
    if (alarmMode == ALARM_DET) {
      for(int i=0;i<4;i++) {
	beep(3900, 250, false);
	delay(250);
      displayCountdown = true;
      countdownSeconds = COUNTDOWN_DURATION;
      countdown();
  delay(10); // this helps with button debouncing
  // check input
  if (buttonPressed(ALARM_BUTTON)) {
    displayAlarmTime = true;
    if (alarmpm) {
      digitalWrite(LED_PM, HIGH);
    } else {
      digitalWrite(LED_PM, LOW);
    if (alarmMode == ALARM_OFF) {
      digitalWrite(LED_ALARM, LOW);
      digitalWrite(LED_DET, LOW);
    } else {
      digitalWrite(LED_ALARM, HIGH);
	digitalWrite(LED_DET, HIGH);
      } else {
  } else {
  if (buttonPressedNew(HOUR_BUTTON) || buttonHeld(HOUR_BUTTON, 150)) {
    if ((!displayAlarmTime) && (!displayCountdown)) {
      hours++;
      if (hours == 12) {
	pm = !pm;
      if (hours == 13) {
	hours = 1;
      if (pm) {
      } else {
    if (displayAlarmTime) {
      // setting the alarm
      alarmHours++;
      if (alarmHours == 12) {
	alarmpm = !alarmpm;
      if (alarmHours == 13) {
	alarmHours = 1;
      if (alarmpm) {
      } else {
      snoozeHours = alarmHours;
      snoozeMinutes = alarmMinutes;
      snoozepm = alarmpm;
    if (displayCountdown) {
      if (countdownSeconds < 5940) {
	countdownSeconds += 60;
  } else {
    if ((!displayAlarmTime) && (!buttonPressed(HOUR_BUTTON))) {
      if ((pm) && (usePMIndicator)) {
      } else {
  if (buttonPressedNew(MIN_BUTTON) || buttonHeld(MIN_BUTTON, 150)) {
      minutes++;
      if (minutes == 60) {
	minutes = 0;
      seconds = 0;
      alarmMinutes++;
      if (alarmMinutes == 60) {
	alarmMinutes = 0;
      snoozepm = alarmpm;
      if (countdownSeconds < 5999) {
	countdownSeconds++;
  if (buttonPressedNew(DET_BUTTON)) {
      alarmMode++;
      if (alarmMode > ALARM_DET) {
      return;
    // The DET button has been pressed but not released yet.
  if (!buttonPressed(DET_BUTTON)) {
      countdown();
void ringAlarm() {
  int frequency = 3900;
  int duration = 250;  // each beep is .25s
  int us = 1000000 / frequency / 2;
  int toneLoopCount = (duration * ((float)frequency/1000.0));
  int pauseLoopCount = 20000;
  while (alarmRinging) {
    for(int i=0;i<toneLoopCount;i++) {
      PORTB |= (1 << 3);
	break;
      delayMicroseconds(us);
      PORTB &= ~(1 << 3);
      if (buttonPressed(DET_BUTTON)) {
	snooze();
	break;
    for(int i=0;i<pauseLoopCount;i++) {
	break;
	snooze();
	break;
  } // while (alarmRinging)
void snooze() {
  snoozeActivated = true;
  // set the snooze time to current time plus 9 minutes
  snoozeHours = hours;
  snoozepm = pm;
  snoozeMinutes = minutes + SNOOZE_MINUTES;
  if (snoozeMinutes >= 60) {
    snoozeMinutes -= 60;
    snoozeHours++;
    if (snoozeHours == 12) {
      snoozepm = !snoozepm;
    if (snoozeHours == 13) {
      snoozeHours = 1;
void countdown() {
  int ledCounter = 0;
  int ledCounterThreshold = 100000;
  byte ledCurrentState = HIGH;
  byte defusePin;
  byte detPin;
  boolean defused = false;
  countdownRunning = true;
  int fractionalSecond;
  // assign random pins
  defusePin = random(WIRE_1, (WIRE_4+1));
  detPin = defusePin;
  while (detPin == defusePin) {
    detPin = random(WIRE_1, (WIRE_4+1));
  digitalWrite(LED_PM, LOW); // turn off the PM LED
  // Keep track of how far we are into the current
  // second so we can correct later.
  fractionalSecond = TCNT1 - TIMER1_SECOND_START;
  // Reset back to the last second boundary so we can start the countdown
  // immediately and so that the first second isn't truncated
  beep(3800, 30);
  digitalWrite(LED_DET, ledCurrentState);
  while ((countdownSeconds > 0) && (!defused)) {
    for(int i=0;i<10000;i++) {
      // get input
      if (digitalRead(defusePin) == HIGH) {
	defused = true;
	break;
      if (digitalRead(detPin) == HIGH) {
	countdownSeconds = 0;
	break;
    delay(20);
    if (ledCounter++ > ledCounterThreshold) {
      ledCounter = 0;
      if (ledCurrentState == HIGH) {
	ledCurrentState = LOW;
      } else {
  if (!defused) {
    detonate();
  } else {
    beep(4500, 80);
    delay(2000);
  // Now to keep the time accurate, add back in the fractional
  // second that we took off when we started the countdown sequence.
  // Wait until we can add it back to TCNT1 without overflowing.
  while (TCNT1 >= (65535 - fractionalSecond));
  TCNT1 += fractionalSecond;
void detonate() {
  for(int i=0;i<8;i++) {
    beep(5000, 50, false);
    delay(25);
    delay(25);
  blank = true;
  for(int i=0;i<50;i++) {
    digitalWrite(random(LED_PM, LED_DET+1), HIGH);
    for(int j=0;j<5;j++) {
      beep(random(100, 300), 10);
    for(int led=LED_PM;led<=LED_DET;led++) {
      digitalWrite(led, LOW);
  delay(2000);
  blank = false;
// return true if the button is pressed.
boolean buttonPressed(byte button) {
  if (digitalRead(buttonPins[button]) == LOW) {
    // the button is currently pressed
    if (buttonState[button] == HIGH) {
      // if the button was not pressed before, update the state.
      buttonChange[button] = millis();
      buttonState[button] = LOW;
    return true;
  } else {
    // The button is currently not pressed
    if (buttonState[button] == LOW) {
      // if the button was pressed before, update the state.
      buttonState[button] = HIGH;
    return false;
// return true if the button is pressed and it is a new press (not held)
boolean buttonPressedNew(byte button) {
    // The button is currently pressed
      // This is a new press.
      return true;
    // This is not a new press.
    return false;
  } else {
    return false;
// return true if the button is pressed and has been held for at least n milliseconds
boolean buttonHeld(byte button, int n) {
      // if the button was not pressed before, update the state and return false.
      return false;
    if ((millis() - buttonChange[button]) >= n) {
      // the button has been pressed for over n milliseconds.
      // update the state change time even though the state hasn't changed.
      // we update the state change time so we can start the counting over
      return true;
    // The button is being held, but has not been held for longer than n milliseconds.
    return false;
  } else {
    return false;
void beep(int frequency, int duration) {
  beep(frequency, duration, true);
void beep(int frequency, int duration, boolean disableDisplayInterrupt) {
  int loopCount = (duration * ((float)frequency/1000.0));
  if (disableDisplayInterrupt) {
  for(int i=0;i<loopCount;i++) {
    PORTB |= (1 << 3);
    PORTB &= ~(1 << 3);
// This is the display interrupt to implement multiplexing of the digits.
ISR(TIMER2_OVF_vect) {
  byte nDigits = 4;
  byte data;
  byte digitValue;
  byte displayHours, displayMinutes;
  TCNT2 = 0;
  displayHours = hours;
  displayMinutes = minutes;
    displayHours = alarmHours;
    displayMinutes = alarmMinutes;
    displayHours = countdownSeconds / 60;
    displayMinutes = countdownSeconds % 60;
  if ((displayHours < 10) && (!displayCountdown)) {
    nDigits = 3;
  if (++currentDigit > (nDigits-1)) {
    currentDigit = 0;
  switch (currentDigit) {
  case 0:
    digitValue = displayMinutes % 10;
    break;
  case 1:
      digitValue = displayMinutes / 10;
    break;
  case 2:
    digitValue = displayHours % 10;
    break;
  case 3:
    digitValue = displayHours / 10;
    break;
  // Upper 4 bits of data are the value for the current digit.
  // They are loaded into shift register outputs QA-QD
  data = (digitValue << 4);
  // Lower 4 bits 3-0 represent which digit to turn on.
  // 3 is most significant digit, 0 is least
  // They are loaded into shift register outputs QE-QH
  // Digit transistors are active low, so set them all high
  data |= 0x0F;
  if (!blank) {
    // now turn off the bit for digit we want illuminated.
    data &= ~(1 << currentDigit);
  digitalWrite(LATCH, LOW);
  shiftOut(DATA, CLOCK, LSBFIRST, data);
  digitalWrite(LATCH, HIGH);
// Timer 1 interrupt.  This executes every second.
ISR(TIMER1_OVF_vect) {
  ticked = true;
  seconds++;
  if (seconds == 60) {
    seconds = 0;
    minutes++;
      minutes = 0;
      hours++;
      if (hours == 12) {
	pm = !pm;
      if (hours == 13) {
	hours = 1;
  if ((!countdownRunning) && (alarmMode != ALARM_OFF)) {
    if ((alarmHours == hours) && (alarmMinutes == minutes) && (seconds == 0) && (alarmpm == pm)) {
      alarmRinging = true;
    if ((snoozeActivated) && (snoozeHours == hours) && (snoozeMinutes == minutes) && (seconds == 0) && (snoozepm == pm)) {
  if ((countdownRunning) && (countdownSeconds > 0)) {
    beep(3800, 30);
    countdownSeconds--;
