<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="12.5" unitdist="mil" unit="mil" style="lines" multiple="1" display="no" altdistance="6.25" altunitdist="mil" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="53" name="tPadExt" color="7" fill="1" visible="no" active="no"/>
<layer number="54" name="bPadExt" color="1" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Hidden" color="15" fill="1" visible="no" active="yes"/>
<layer number="102" name="Changes" color="12" fill="1" visible="no" active="yes"/>
<layer number="106" name="segment" color="15" fill="1" visible="no" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="no" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="no" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="no"/>
<layer number="231" name="Eagle3D_PG1" color="14" fill="1" visible="no" active="yes"/>
<layer number="232" name="Eagle3D_PG2" color="14" fill="2" visible="no" active="yes"/>
<layer number="233" name="Eagle3D_PG3" color="14" fill="4" visible="no" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="no" active="yes"/>
</layers>
<board>
<plain>
<wire x1="22.225" y1="7.62" x2="160.635" y2="7.62" width="0" layer="20"/>
<wire x1="160.635" y1="7.62" x2="160.635" y2="88.57" width="0" layer="20"/>
<wire x1="160.635" y1="88.57" x2="22.225" y2="88.57" width="0" layer="20"/>
<wire x1="22.225" y1="88.57" x2="22.225" y2="7.62" width="0" layer="20"/>
<wire x1="19.3675" y1="22.225" x2="-12.3825" y2="22.225" width="0" layer="20"/>
<wire x1="-12.3825" y1="22.225" x2="-12.3825" y2="70.485" width="0" layer="20"/>
<wire x1="-12.3825" y1="70.485" x2="19.3675" y2="70.485" width="0" layer="20"/>
<wire x1="19.3675" y1="70.485" x2="19.3675" y2="22.225" width="0" layer="20"/>
<text x="-8.5725" y="44.45" size="1.778" layer="20" rot="R270">48x32mm</text>
<text x="135.89" y="10.795" size="1.778" layer="20">140x81mm</text>
</plain>
<libraries>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SO16">
<description>&lt;b&gt;Small Outline Package 16&lt;/b&gt;</description>
<wire x1="4.699" y1="1.9558" x2="-4.699" y2="1.9558" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.9558" x2="5.08" y2="-1.5748" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.5748" x2="-4.699" y2="1.9558" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.9558" x2="5.08" y2="1.5748" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.5748" x2="-4.699" y2="-1.9558" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="-1.9558" x2="4.699" y2="-1.9558" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.5748" x2="5.08" y2="1.5748" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.5748" x2="-5.08" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.508" x2="-5.08" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.508" x2="-5.08" y2="-1.5748" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.508" x2="-5.08" y2="-0.508" width="0.1524" layer="21" curve="-180"/>
<wire x1="-5.08" y1="-1.6002" x2="5.08" y2="-1.6002" width="0.0508" layer="21"/>
<smd name="1" x="-4.445" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="16" x="-4.445" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-3.175" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="15" x="-3.175" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="-1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="-0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="-0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="3.175" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="3.175" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="4.445" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="4.445" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<text x="-4.064" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.207" y="-2.032" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-0.889" y1="1.9558" x2="-0.381" y2="3.0988" layer="51"/>
<rectangle x1="-4.699" y1="-3.0988" x2="-4.191" y2="-1.9558" layer="51"/>
<rectangle x1="-3.429" y1="-3.0988" x2="-2.921" y2="-1.9558" layer="51"/>
<rectangle x1="-2.159" y1="-3.0734" x2="-1.651" y2="-1.9304" layer="51"/>
<rectangle x1="-0.889" y1="-3.0988" x2="-0.381" y2="-1.9558" layer="51"/>
<rectangle x1="-2.159" y1="1.9558" x2="-1.651" y2="3.0988" layer="51"/>
<rectangle x1="-3.429" y1="1.9558" x2="-2.921" y2="3.0988" layer="51"/>
<rectangle x1="-4.699" y1="1.9558" x2="-4.191" y2="3.0988" layer="51"/>
<rectangle x1="0.381" y1="-3.0988" x2="0.889" y2="-1.9558" layer="51"/>
<rectangle x1="1.651" y1="-3.0988" x2="2.159" y2="-1.9558" layer="51"/>
<rectangle x1="2.921" y1="-3.0988" x2="3.429" y2="-1.9558" layer="51"/>
<rectangle x1="4.191" y1="-3.0988" x2="4.699" y2="-1.9558" layer="51"/>
<rectangle x1="0.381" y1="1.9558" x2="0.889" y2="3.0988" layer="51"/>
<rectangle x1="1.651" y1="1.9558" x2="2.159" y2="3.0988" layer="51"/>
<rectangle x1="2.921" y1="1.9558" x2="3.429" y2="3.0988" layer="51"/>
<rectangle x1="4.191" y1="1.9558" x2="4.699" y2="3.0988" layer="51"/>
</package>
</packages>
</library>
<library name="Labor">
<description>Labor Bib</description>
<packages>
<description>&lt;b&gt;SO-16, SMD&lt;/b&gt;&lt;br&gt;
SOIC IC package, 16 pins</description>
<wire x1="-4.445" y1="-1.905" x2="-4.445" y2="-2.8575" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.8575" x2="-3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.905" x2="-1.905" y2="-2.8575" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.8575" x2="-0.635" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.905" x2="-4.445" y2="2.8575" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.8575" x2="-3.175" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.905" x2="-1.905" y2="2.8575" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.905" x2="-0.635" y2="2.8575" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.8575" x2="0.635" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.8575" x2="1.905" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.8575" x2="3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.905" x2="0.635" y2="2.8575" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.905" x2="1.905" y2="2.8575" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.905" x2="3.175" y2="2.8575" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.8575" x2="4.445" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.905" x2="4.445" y2="2.8575" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.905" x2="-5.08" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="0.635" y2="1.905" width="0.4064" layer="21"/>
<wire x1="-2.8575" y1="-0.9525" x2="5.08" y2="-0.9525" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.08" y2="-0.635" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="1.905" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.4064" layer="21" curve="180"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-0.635" width="0.254" layer="51" curve="-180"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0.635" width="0.254" layer="51"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="-1.27" width="0.254" layer="51"/>
<wire x1="0.635" y1="1.905" x2="5.08" y2="1.905" width="0.4064" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-0.9525" width="0.4064" layer="21"/>
<wire x1="5.08" y1="-0.9525" x2="5.08" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="0.635" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="5.08" y2="1.27" width="0.254" layer="51"/>
<wire x1="5.08" y1="1.27" x2="5.08" y2="-1.27" width="0.254" layer="51"/>
<wire x1="5.08" y1="-1.27" x2="-5.08" y2="-1.27" width="0.254" layer="51"/>
<circle x="-3.81" y="-0.9525" radius="0.4762" width="0" layer="21"/>
<smd name="1" x="-4.445" y="-2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="2" x="-3.175" y="-2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="3" x="-1.905" y="-2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="4" x="-0.635" y="-2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="5" x="0.635" y="-2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="6" x="1.905" y="-2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="7" x="3.175" y="-2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="8" x="4.445" y="-2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="9" x="4.445" y="2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="10" x="3.175" y="2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="11" x="1.905" y="2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="12" x="0.635" y="2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="13" x="-0.635" y="2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="14" x="-1.905" y="2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="15" x="-3.175" y="2.8575" dx="0.635" dy="1.778" layer="1"/>
<smd name="16" x="-4.445" y="2.8575" dx="0.635" dy="1.778" layer="1"/>
<text x="-2.8575" y="-0.3175" size="1.27" layer="25" ratio="14">&gt;NAME</text>
<text x="-2.8575" y="-0.3175" size="1.27" layer="27" ratio="14">&gt;VALUE</text>
<text x="-5.3975" y="-1.27" size="1.27" layer="51" ratio="16" rot="R90">&gt;NAME</text>
</package>
</packages>
</library>
<library name="transistor-power">
<description>&lt;b&gt;Power Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO220BV">
<description>&lt;b&gt;Molded Package&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="G" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="D" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="S" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="R1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="C1206">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="EB22,5D">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 10.16 mm, diameter 22.5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<circle x="0" y="0" radius="11.303" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="2.0066" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="2.0066" diameter="4.5974" shape="octagon"/>
<text x="8.4074" y="8.509" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
<package name="0411/15">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0411, grid 15 mm</description>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0411/12">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="E5-8,5">
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="E7,5-16">
grid 7.62 mm, diameter 16 mm</description>
<wire x1="0.635" y1="0" x2="2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.905" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.905" x2="-0.254" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.905" x2="-0.254" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.905" x2="-0.889" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-5.969" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.762" x2="-6.731" y2="0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="8.255" width="0.1524" layer="21"/>
<pad name="-" x="3.81" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<pad name="+" x="-3.81" y="0" drill="1.016" diameter="3.1496"/>
<text x="7.874" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.2926" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.905" x2="0.889" y2="1.905" layer="21"/>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="SMB">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="-2.2606" y1="1.905" x2="2.2606" y2="1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="2.2606" y2="-1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="-2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="2.2606" y1="-1.905" x2="2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="0.193" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.193" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.193" y1="-1" x2="0.193" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="A" x="2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<text x="-2.159" y="2.159" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.0922" x2="-2.2606" y2="1.0922" layer="51"/>
<rectangle x1="2.2606" y1="-1.0922" x2="2.794" y2="1.0922" layer="51"/>
<rectangle x1="-1.35" y1="-1.9" x2="-0.8" y2="1.9" layer="51"/>
</package>
<package name="MELF-MLL41">
<description>&lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;
Package DO-213AB = http://www.diotec.com/pdf/sm4001.pdf</description>
<wire x1="2.0828" y1="1.1938" x2="-2.159" y2="1.1938" width="0.1524" layer="51"/>
<wire x1="2.0828" y1="-1.1938" x2="-2.1336" y2="-1.1938" width="0.1524" layer="51"/>
<wire x1="0.627" y1="1" x2="-0.746" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.746" y1="0" x2="0.627" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-1" x2="0.627" y2="1" width="0.2032" layer="21"/>
<wire x1="1.1208" y1="1.1938" x2="-1.097" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="1.1208" y1="-1.1938" x2="-1.0716" y2="-1.1938" width="0.1524" layer="21"/>
<smd name="C" x="-2.625" y="0" dx="2.5" dy="3" layer="1"/>
<smd name="A" x="2.625" y="0" dx="2.5" dy="3" layer="1"/>
<text x="-2.663" y="1.724" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.663" y="-2.994" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.0574" y1="-1.27" x2="2.5654" y2="1.27" layer="51"/>
<rectangle x1="-2.6162" y1="-1.27" x2="-2.1082" y2="1.27" layer="51"/>
<rectangle x1="-1.4478" y1="-1.1938" x2="-0.5588" y2="1.1938" layer="51"/>
</package>
<package name="DO41-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="DO34Z7">
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.127" y1="0.508" x2="-0.127" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
</package>
<package name="TO3P">
3-lead molded, horizontal</description>
<wire x1="-8.255" y1="-1.778" x2="8.255" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.397" x2="7.62" y2="-1.397" width="0.0508" layer="21"/>
<wire x1="7.62" y1="10.287" x2="7.62" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.778" x2="-8.255" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="10.287" x2="-6.35" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="10.287" x2="-8.255" y2="17.653" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="12.192" x2="-6.35" y2="15.748" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="17.653" x2="-6.35" y2="15.748" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="16.129" x2="-7.62" y2="17.653" width="0.0508" layer="21"/>
<wire x1="-6.096" y1="16.129" x2="-6.096" y2="11.811" width="0.0508" layer="21"/>
<wire x1="-7.62" y1="10.287" x2="-6.096" y2="11.811" width="0.0508" layer="21"/>
<wire x1="-7.62" y1="10.287" x2="-7.62" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="8.255" y1="19.812" x2="8.255" y2="17.653" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="17.653" x2="-8.255" y2="19.812" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="19.812" x2="-8.255" y2="19.812" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="19.812" x2="-7.62" y2="17.653" width="0.0508" layer="21"/>
<wire x1="8.255" y1="19.812" x2="7.62" y2="19.812" width="0.1524" layer="21"/>
<wire x1="7.62" y1="19.812" x2="-7.62" y2="19.812" width="0.1524" layer="21"/>
<wire x1="7.62" y1="19.812" x2="7.62" y2="17.653" width="0.0508" layer="21"/>
<wire x1="7.62" y1="17.653" x2="6.096" y2="16.129" width="0.0508" layer="21"/>
<wire x1="6.35" y1="15.748" x2="8.255" y2="17.653" width="0.1524" layer="21"/>
<wire x1="8.255" y1="17.653" x2="8.255" y2="10.287" width="0.1524" layer="21"/>
<wire x1="6.35" y1="12.192" x2="6.35" y2="15.748" width="0.1524" layer="21"/>
<wire x1="6.096" y1="16.129" x2="6.096" y2="11.811" width="0.0508" layer="21"/>
<wire x1="8.255" y1="10.287" x2="6.35" y2="12.192" width="0.1524" layer="21"/>
<wire x1="7.62" y1="10.287" x2="6.096" y2="11.811" width="0.0508" layer="21"/>
<wire x1="8.255" y1="10.287" x2="8.255" y2="-1.778" width="0.1524" layer="21"/>
<circle x="0" y="13.97" radius="1.651" width="0.1524" layer="21"/>
<circle x="0" y="13.97" radius="3.81" width="0" layer="42"/>
<circle x="0" y="13.97" radius="3.81" width="0" layer="43"/>
<pad name="1" x="-5.588" y="-7.62" drill="1.6002" shape="long" rot="R90"/>
<pad name="2" x="0" y="-7.62" drill="1.6002" shape="long" rot="R90"/>
<pad name="3" x="5.588" y="-7.62" drill="1.6002" shape="long" rot="R90"/>
<text x="-8.636" y="-1.778" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-5.08" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.477" y="17.78" size="0.9906" layer="21" ratio="10">A21,6mm</text>
<rectangle x1="-6.223" y1="-7.493" x2="-4.953" y2="-5.588" layer="51"/>
<rectangle x1="-0.635" y1="-7.493" x2="0.635" y2="-5.588" layer="51"/>
<rectangle x1="4.953" y1="-7.493" x2="6.223" y2="-5.588" layer="51"/>
<rectangle x1="-1.524" y1="-3.302" x2="1.524" y2="-1.778" layer="21"/>
<rectangle x1="4.572" y1="-3.302" x2="6.604" y2="-1.778" layer="21"/>
<rectangle x1="-0.635" y1="-5.588" x2="0.635" y2="-3.302" layer="21"/>
<rectangle x1="4.953" y1="-5.588" x2="6.223" y2="-3.302" layer="21"/>
<rectangle x1="-6.604" y1="-3.302" x2="-4.572" y2="-1.778" layer="21"/>
<rectangle x1="-6.223" y1="-5.588" x2="-4.953" y2="-3.302" layer="21"/>
<hole x="0" y="13.97" drill="3.6068"/>
</package>
</packages>
</library>
<library name="optocoupler">
<description>&lt;b&gt;Opto Couplers&lt;/b&gt;&lt;p&gt;
Siemens, Hewlett-Packard, Texas Instuments, Sharp, Motorola&lt;p&gt;
<packages>
<package name="DIL04">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="2.54" y1="2.921" x2="-2.54" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="2.54" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.921" x2="2.54" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.921" x2="-2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-1.27" y="-3.81" drill="0.8128" shape="offset" rot="R270"/>
<pad name="2" x="1.27" y="-3.81" drill="0.8128" shape="offset" rot="R270"/>
<pad name="3" x="1.27" y="3.81" drill="0.8128" shape="offset" rot="R90"/>
<pad name="4" x="-1.27" y="3.81" drill="0.8128" shape="offset" rot="R90"/>
<text x="4.191" y="-2.921" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-2.921" y="-2.667" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
</packages>
</library>
<library name="resistor">
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;/ul&gt;
&lt;p&gt;
&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;/td&gt;
&lt;P&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
  &lt;TR&gt;
      &lt;P&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
    &lt;/TD&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
chip</description>
<text x="-1.397" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
chip</description>
<text x="-1.27" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="rectifier">
<description>&lt;b&gt;Rectifiers&lt;/b&gt;&lt;p&gt;
General Instrument, Semikron, Diotec, Fagor&lt;p&gt;
<packages>
<package name="FB15A">
<description>&lt;b&gt;FAGOR RECTIFIER&lt;/b&gt;&lt;p&gt;
grid 3 x 5 mm</description>
<wire x1="-11.056" y1="-2.54" x2="-11.056" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.264" y1="2.54" x2="9.264" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.056" y1="2.54" x2="5.708" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.708" y1="2.54" x2="9.264" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.978" y1="-1.778" x2="7.994" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-9.532" y1="-1.651" x2="-8.516" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-3.4106" y1="-1.651" x2="-2.7502" y2="-1.651" width="0.1524" layer="21" curve="180"/>
<wire x1="-4.071" y1="-1.651" x2="-3.4106" y2="-1.651" width="0.1524" layer="21" curve="-180"/>
<wire x1="1.5424" y1="-1.651" x2="2.2028" y2="-1.651" width="0.1524" layer="21" curve="180"/>
<wire x1="0.882" y1="-1.651" x2="1.5424" y2="-1.651" width="0.1524" layer="21" curve="-180"/>
<wire x1="9.264" y1="-2.54" x2="5.708" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.708" y1="-2.54" x2="-11.056" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.024" y1="-2.159" x2="-9.024" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="5.708" y1="2.54" x2="5.708" y2="-2.54" width="0.1524" layer="21"/>
<pad name="-" x="7.5114" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="+" x="-7.5" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="AC2" x="2.533" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="AC1" x="-2.4962" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-11.056" y="3.048" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.42" y="3.048" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-11" y1="-2.5" x2="9.5" y2="2.5" layer="43"/>
</package>
</packages>
</library>
<library name="inductors">
<description>&lt;b&gt;Inductors and Filters&lt;/b&gt;&lt;p&gt;
Based on the previous library ind-a.lbr&lt;p&gt;
<packages>
<package name="ED26">
<description>&lt;B&gt;INDUCTOR&lt;/B&gt;</description>
<wire x1="-6.985" y1="0" x2="-12.573" y2="-1.27" width="1.016" layer="51"/>
<wire x1="-6.731" y1="-1.27" x2="-12.065" y2="-3.429" width="1.016" layer="51"/>
<wire x1="-6.858" y1="1.143" x2="-12.446" y2="1.524" width="1.016" layer="51"/>
<wire x1="-6.477" y1="-2.54" x2="-11.176" y2="-5.588" width="1.016" layer="21"/>
<wire x1="-5.969" y1="-3.556" x2="-10.287" y2="-7.112" width="1.016" layer="21"/>
<wire x1="-5.334" y1="-4.445" x2="-9.271" y2="-8.382" width="1.016" layer="21"/>
<wire x1="-4.572" y1="-5.334" x2="-8.128" y2="-9.525" width="1.016" layer="21"/>
<wire x1="-3.683" y1="-5.842" x2="-6.858" y2="-10.414" width="1.016" layer="21"/>
<wire x1="-2.794" y1="-6.477" x2="-5.461" y2="-11.303" width="1.016" layer="21"/>
<wire x1="-1.778" y1="-6.731" x2="-3.81" y2="-11.938" width="1.016" layer="21"/>
<wire x1="-0.762" y1="-7.112" x2="-1.651" y2="-12.319" width="1.016" layer="21"/>
<wire x1="0.381" y1="-7.112" x2="0.381" y2="-12.446" width="1.016" layer="21"/>
<wire x1="1.397" y1="-6.858" x2="2.413" y2="-12.192" width="1.016" layer="21"/>
<wire x1="2.54" y1="-6.604" x2="4.572" y2="-11.684" width="1.016" layer="21"/>
<wire x1="3.556" y1="-6.096" x2="6.223" y2="-10.795" width="1.016" layer="21"/>
<wire x1="4.572" y1="-5.334" x2="8.001" y2="-9.525" width="1.016" layer="21"/>
<wire x1="5.461" y1="-4.572" x2="9.398" y2="-8.128" width="1.016" layer="21"/>
<wire x1="6.096" y1="-3.556" x2="10.795" y2="-6.35" width="1.016" layer="21"/>
<wire x1="6.604" y1="-2.54" x2="11.684" y2="-4.699" width="1.016" layer="21"/>
<wire x1="6.858" y1="-1.397" x2="12.319" y2="-2.413" width="1.016" layer="21"/>
<wire x1="6.985" y1="-0.381" x2="12.573" y2="-0.381" width="1.016" layer="21"/>
<wire x1="6.985" y1="0.635" x2="12.446" y2="1.524" width="1.016" layer="21"/>
<wire x1="6.858" y1="1.651" x2="12.065" y2="3.302" width="1.016" layer="21"/>
<wire x1="6.477" y1="2.667" x2="11.557" y2="4.953" width="1.016" layer="21"/>
<wire x1="5.969" y1="3.683" x2="10.541" y2="6.731" width="1.016" layer="21"/>
<wire x1="5.334" y1="4.572" x2="9.398" y2="8.255" width="1.016" layer="21"/>
<wire x1="4.572" y1="5.207" x2="8.001" y2="9.525" width="1.016" layer="21"/>
<wire x1="3.683" y1="5.969" x2="6.604" y2="10.541" width="1.016" layer="21"/>
<wire x1="2.667" y1="6.477" x2="5.08" y2="11.43" width="1.016" layer="21"/>
<wire x1="1.524" y1="6.858" x2="2.921" y2="12.192" width="1.016" layer="21"/>
<wire x1="0.381" y1="6.985" x2="0.635" y2="12.573" width="1.016" layer="21"/>
<wire x1="-0.762" y1="6.985" x2="-1.524" y2="12.319" width="1.016" layer="21"/>
<wire x1="-1.778" y1="6.731" x2="-3.556" y2="11.938" width="1.016" layer="21"/>
<wire x1="-2.921" y1="6.35" x2="-5.588" y2="11.176" width="1.016" layer="21"/>
<wire x1="-3.937" y1="5.842" x2="-7.239" y2="10.16" width="1.016" layer="21"/>
<wire x1="-4.826" y1="5.08" x2="-9.017" y2="8.763" width="1.016" layer="21"/>
<wire x1="-5.588" y1="4.064" x2="-10.414" y2="7.112" width="1.016" layer="21"/>
<wire x1="-6.223" y1="3.175" x2="-11.303" y2="5.461" width="1.016" layer="21"/>
<wire x1="-6.731" y1="2.286" x2="-12.065" y2="3.556" width="1.016" layer="21"/>
<wire x1="-7.3819" y1="-1.8901" x2="-7.3819" y2="1.8901" width="0.1524" layer="21" curve="331.276467"/>
<wire x1="-11.9146" y1="-1.8991" x2="-11.9146" y2="1.8991" width="0.1524" layer="21" curve="341.887309"/>
<wire x1="-11.9146" y1="1.8991" x2="-11.9146" y2="-1.8991" width="0.1524" layer="51" curve="18.112691"/>
<wire x1="-7.3819" y1="1.8901" x2="-7.3819" y2="-1.8901" width="0.1524" layer="51" curve="28.723533"/>
<pad name="2" x="-6.35" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="1" x="-13.335" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-4.445" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="13.335" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="2.54" size="1.27" layer="21" ratio="10">DÝ1,0</text>
</package>
</packages>
</library>
<library name="capacitor-wima">
<description>&lt;b&gt;WIMA Capacitors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="C7.5B3">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 3 mm, grid 7.62 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<text x="-3.81" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B3">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 3 mm, grid 5.08 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B7">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 7 mm, grid 15 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-7.493" y="3.81" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="ptc-ntc">
<description>&lt;b&gt;PTC and NTC Resistors&lt;/b&gt;&lt;p&gt;
Siemens, Philips, Valvo&lt;p&gt;
<packages>
<package name="N644B">
<description>&lt;b&gt;PHILIPS NTC&lt;/b&gt;</description>
<wire x1="2.413" y1="-8.001" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-2.54" x2="2.413" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="8.001" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-8.001" x2="-2.413" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="8.001" x2="-2.413" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-2.54" x2="-2.413" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="8.001" x2="2.413" y2="8.001" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="3.937" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.937" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21" curve="71.482795"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="-71.479717"/>
<pad name="1" x="-5.08" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="5.08" y="0" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.302" y="2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="0.889" y="-5.08" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="3.2258" y1="-0.4064" x2="3.8608" y2="0.4064" layer="21"/>
<rectangle x1="-3.8608" y1="-0.4064" x2="-3.2258" y2="0.4064" layer="21"/>
</package>
</packages>
</library>
<library name="fuse">
<description>&lt;b&gt;Fuses and Fuse Holders&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TR5">
<description>&lt;b&gt;FUSE&lt;/b&gt;&lt;p&gt;
Wickmann</description>
<wire x1="-2.159" y1="0" x2="2.159" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-0.381" x2="1.27" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0.381" x2="1.27" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0.381" x2="-1.27" y2="0.381" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.318" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.778" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.778" shape="long" rot="R90"/>
<text x="-2.54" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/3">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-7.5184" y1="-3.556" x2="-7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-3.556" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-8.0264" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="3.175" x2="-8.0264" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="2.032" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="-7.5184" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="-2.159" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="1.016" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-3.9878" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.0198" y1="-1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-1.016" x2="1.016" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-6.0198" y1="-1.016" x2="-3.9878" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="-1.016" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="1.016" y1="1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-6.0198" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.9878" y1="1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.9878" y1="-1.016" x2="6.0198" y2="1.016" width="0.6096" layer="51"/>
<wire x1="3.9878" y1="-1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="6.0198" y2="1.397" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="3.9878" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="6.0198" y1="1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<circle x="0" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-7.5946" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.5946" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.731" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-1.905" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="3.175" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<rectangle x1="-2.8956" y1="-1.905" x2="-2.1336" y2="1.905" layer="21"/>
<rectangle x1="2.1336" y1="-1.905" x2="2.8956" y2="1.905" layer="21"/>
</package>
<package name="AK500/2">
<wire x1="-5.08" y1="-3.556" x2="-5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.556" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.588" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="3.175" x2="-5.588" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="2.032" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="-5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.159" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="-1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="3.5306" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-1.4986" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.5306" y1="-1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.4986" y1="-1.016" x2="3.5306" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-3.5306" y1="-1.016" x2="-1.4986" y2="1.016" width="0.6096" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="1.4986" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.5306" y1="1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-3.5306" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-1.4986" y1="1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<circle x="2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="0.635" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<rectangle x1="-0.381" y1="-1.905" x2="0.381" y2="1.905" layer="21"/>
</package>
</packages>
</library>
<library name="con-amp">
<description>&lt;b&gt;AMP Connectors&lt;/b&gt;&lt;p&gt;
RJ45 Jack connectors&lt;br&gt;
 Based on the previous libraris:
 &lt;ul&gt;
 &lt;li&gt;amp.lbr
 &lt;li&gt;amp-j.lbr
 &lt;li&gt;amp-mta.lbr
 &lt;li&gt;amp-nlok.lbr
 &lt;li&gt;amp-sim.lbr
 &lt;li&gt;amp-micro-match.lbr
 &lt;/ul&gt;
 Sources :
 &lt;ul&gt;
 &lt;li&gt;Catalog 82066 Revised 11-95
 &lt;li&gt;Product Guide 296785 Rev. 8-99
 &lt;li&gt;Product Guide CD-ROM 1999
 &lt;li&gt;www.amp.com
 &lt;/ul&gt;
<packages>
<package name="10X02MTA">
<description>&lt;b&gt;AMP MTA connector&lt;/b&gt;&lt;p&gt;
Source: http://ecommas.tycoelectronics.com .. ENG_CD_640456_W.pdf</description>
<wire x1="-2.54" y1="-1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="1.27" width="0.1524" layer="21"/>
<pad name="2" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-2.6162" y="-3.2512" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.5461" y="2.1509" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="21"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="21"/>
</package>
<package name="10X06MTA">
<wire x1="-7.62" y1="-1.27" x2="-7.62" y2="1.27" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.27" x2="-7.62" y2="1.27" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.27" x2="7.62" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.27" x2="7.62" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.27" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="1.27" width="0.1524" layer="21"/>
<pad name="6" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-7.4762" y="2.2507" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="21"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="21"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="21"/>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="v-reg">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO92-CLP">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-0.7863" y2="2.5485" width="0.1524" layer="21" curve="-111.098957"/>
<wire x1="0.7868" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.09954"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.1524" layer="51" curve="-34.293591"/>
<pad name="R" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="A" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="C" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.3175" y="0.635" size="0.8128" layer="21">A</text>
<text x="-1.5875" y="-1.27" size="0.8128" layer="21">R</text>
<text x="0.9525" y="-1.27" size="0.8128" layer="21">C</text>
</package>
</packages>
</library>
<library name="trafo">
<description>&lt;b&gt;Transformers&lt;/b&gt;&lt;p&gt;
Based on the following previous libraries:
&lt;ul&gt;
&lt;li&gt;trafo-b.lbr: transformers from BLOCK
&lt;li&gt;trafo-e.lbr: transformers from ERA
&lt;li&gt;trafo-r.lbr: ring cores
&lt;/ul&gt;
<packages>
<package name="EI42-2">
<description>&lt;b&gt;TRANSFORMER&lt;/b&gt;&lt;p&gt;
1 primary winding, 2 secondary windings</description>
<wire x1="-19.304" y1="-21.463" x2="-18.034" y2="-22.733" width="0.254" layer="21" curve="90"/>
<wire x1="18.034" y1="22.733" x2="19.304" y2="21.463" width="0.254" layer="21" curve="-90"/>
<wire x1="18.034" y1="-22.733" x2="19.304" y2="-21.463" width="0.254" layer="21" curve="90"/>
<wire x1="19.304" y1="21.463" x2="19.304" y2="-21.463" width="0.254" layer="21"/>
<wire x1="-19.304" y1="21.463" x2="-18.034" y2="22.733" width="0.254" layer="21" curve="-90"/>
<wire x1="-19.304" y1="-21.463" x2="-19.304" y2="21.463" width="0.254" layer="21"/>
<wire x1="12.7" y1="-16.637" x2="13.335" y2="-16.002" width="0.254" layer="21" curve="90"/>
<wire x1="-13.335" y1="-16.002" x2="-12.7" y2="-16.637" width="0.254" layer="21" curve="90"/>
<wire x1="-12.7" y1="-16.637" x2="12.7" y2="-16.637" width="0.254" layer="21"/>
<wire x1="12.7" y1="16.637" x2="13.335" y2="16.002" width="0.254" layer="21" curve="-90"/>
<wire x1="-13.335" y1="16.002" x2="-12.7" y2="16.637" width="0.254" layer="21" curve="-90"/>
<wire x1="-12.7" y1="16.637" x2="12.7" y2="16.637" width="0.254" layer="21"/>
<wire x1="18.034" y1="-22.733" x2="-18.034" y2="-22.733" width="0.254" layer="21"/>
<wire x1="-13.335" y1="-10.287" x2="-13.335" y2="-14.605" width="0.254" layer="51"/>
<wire x1="-13.335" y1="10.287" x2="-13.335" y2="14.605" width="0.254" layer="51"/>
<wire x1="-13.335" y1="10.287" x2="-13.335" y2="-10.287" width="0.254" layer="21"/>
<wire x1="13.335" y1="16.002" x2="13.335" y2="14.224" width="0.254" layer="21"/>
<wire x1="13.335" y1="10.795" x2="13.335" y2="14.224" width="0.254" layer="51"/>
<wire x1="13.335" y1="10.795" x2="13.335" y2="9.144" width="0.254" layer="21"/>
<wire x1="13.335" y1="5.842" x2="13.335" y2="9.144" width="0.254" layer="51"/>
<wire x1="13.335" y1="5.842" x2="13.335" y2="-5.842" width="0.254" layer="21"/>
<wire x1="13.335" y1="-9.144" x2="13.335" y2="-5.842" width="0.254" layer="51"/>
<wire x1="13.335" y1="-9.144" x2="13.335" y2="-10.795" width="0.254" layer="21"/>
<wire x1="13.335" y1="-16.002" x2="13.335" y2="-14.224" width="0.254" layer="21"/>
<wire x1="13.335" y1="-14.224" x2="13.335" y2="-10.795" width="0.254" layer="51"/>
<wire x1="-13.335" y1="-16.002" x2="-13.335" y2="-14.605" width="0.254" layer="21"/>
<wire x1="-13.335" y1="14.605" x2="-13.335" y2="16.002" width="0.254" layer="21"/>
<wire x1="-18.034" y1="22.733" x2="18.034" y2="22.733" width="0.254" layer="21"/>
<wire x1="-3.175" y1="10.16" x2="-3.175" y2="-10.16" width="0.254" layer="21"/>
<wire x1="-1.27" y1="10.16" x2="-1.27" y2="-10.16" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-10.16" x2="-3.175" y2="-10.16" width="0.254" layer="21"/>
<wire x1="0" y1="10.16" x2="0" y2="-10.16" width="0.254" layer="21"/>
<wire x1="1.27" y1="10.16" x2="1.27" y2="1.27" width="0.254" layer="21"/>
<wire x1="1.27" y1="1.27" x2="3.175" y2="1.27" width="0.254" layer="21"/>
<wire x1="1.27" y1="10.16" x2="3.175" y2="10.16" width="0.254" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.175" y2="10.16" width="0.254" layer="21"/>
<wire x1="-3.175" y1="10.16" x2="-1.27" y2="10.16" width="0.254" layer="21"/>
<wire x1="-5.715" y1="10.16" x2="-3.175" y2="10.16" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-10.16" x2="-5.715" y2="-10.16" width="0.254" layer="21"/>
<wire x1="3.175" y1="1.27" x2="5.715" y2="1.27" width="0.254" layer="21"/>
<wire x1="3.175" y1="10.16" x2="5.715" y2="10.16" width="0.254" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="5.715" y2="-1.27" width="0.254" layer="21"/>
<wire x1="1.27" y1="-10.16" x2="3.175" y2="-10.16" width="0.254" layer="21"/>
<wire x1="3.175" y1="-10.16" x2="5.715" y2="-10.16" width="0.254" layer="21"/>
<wire x1="3.175" y1="-10.16" x2="3.175" y2="-1.27" width="0.254" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="-10.16" width="0.254" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="3.175" y2="-1.27" width="0.254" layer="21"/>
<circle x="-4.445" y="-9.271" radius="0.254" width="0.254" layer="21"/>
<circle x="4.445" y="2.159" radius="0.254" width="0.254" layer="21"/>
<circle x="-6.35" y="10.16" radius="0.635" width="0.254" layer="21"/>
<circle x="-6.35" y="-10.16" radius="0.635" width="0.254" layer="21"/>
<circle x="6.35" y="1.27" radius="0.635" width="0.254" layer="21"/>
<circle x="6.35" y="10.16" radius="0.635" width="0.254" layer="21"/>
<circle x="6.35" y="-1.27" radius="0.635" width="0.254" layer="21"/>
<circle x="6.35" y="-10.16" radius="0.635" width="0.254" layer="21"/>
<circle x="4.445" y="-8.636" radius="0.254" width="0.254" layer="21"/>
<pad name="1" x="-12.4968" y="12.4968" drill="1.1176" diameter="3.81" shape="octagon"/>
<pad name="5" x="-12.4968" y="-12.4968" drill="1.1176" diameter="3.81" shape="octagon"/>
<pad name="6" x="12.4968" y="-12.4968" drill="1.1176" diameter="3.175" shape="octagon"/>
<pad name="7" x="12.4968" y="-7.493" drill="1.1176" diameter="3.175" shape="octagon"/>
<pad name="9" x="12.4968" y="7.493" drill="1.1176" diameter="3.175" shape="octagon"/>
<pad name="10" x="12.4968" y="12.4968" drill="1.1176" diameter="3.175" shape="octagon"/>
<text x="-19.05" y="23.495" size="2.54" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-15.24" size="2.54" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.35" y="17.78" size="2.54" layer="21" ratio="10">EI42-2</text>
<text x="-7.62" y="-7.62" size="1.778" layer="21" ratio="10">P1</text>
<text x="5.08" y="-7.62" size="1.778" layer="21" ratio="10">S1</text>
<text x="5.08" y="3.175" size="1.778" layer="21" ratio="10">S2</text>
<rectangle x1="-3.175" y1="-10.16" x2="-1.27" y2="10.16" layer="21"/>
<rectangle x1="1.27" y1="-10.16" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="1.27" y1="1.27" x2="3.175" y2="10.16" layer="21"/>
</package>
</packages>
</library>
<library name="testpad">
<description>&lt;b&gt;Test Pins/Pads&lt;/b&gt;&lt;p&gt;
Cream on SMD OFF.&lt;br&gt;
new: Attribute TP_SIGNAL_NAME&lt;br&gt;
<packages>
<package name="P1-20">
<description>&lt;b&gt;TEST PAD&lt;/b&gt;</description>
<circle x="0" y="0" radius="1.016" width="0.1524" layer="51"/>
<pad name="TP" x="0" y="0" drill="2.0066" diameter="3.1496" shape="octagon"/>
<text x="-1.524" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0" size="0.0254" layer="27">&gt;VALUE</text>
<text x="-1.27" y="-3.175" size="1" layer="37">&gt;TP_SIGNAL_NAME</text>
<rectangle x1="-0.3302" y1="-0.3302" x2="0.3302" y2="0.3302" layer="51"/>
</package>
</packages>
</library>
<library name="inductor-neosid">
<description>&lt;b&gt;Neosid Chokes and Transformers&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Electronic Component Book, Part 2 : Chokes, Fixed Value Inductors
&lt;li&gt;Part 3 : Filters, Coil Assemblies, Thermoplastic Parts
&lt;li&gt;Part 4 : SMD Filters, Coils, Fixed Value Inductors
&lt;li&gt;www.neosid.de
&lt;/ul&gt;
<packages>
<package name="R18">
<description>&lt;B&gt;LINE FILTER&lt;/B&gt;&lt;p&gt;
R18, current compensation</description>
<wire x1="-8.5" y1="5.25" x2="-6.5" y2="7.25" width="0.2032" layer="51" curve="-180"/>
<wire x1="-8.5" y1="5.25" x2="-7.75" y2="4.5" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="7.25" x2="-5.75" y2="6.75" width="0.2032" layer="51"/>
<wire x1="6.5" y1="-7.25" x2="8.5" y2="-5.25" width="0.2032" layer="51" curve="180"/>
<wire x1="8.5" y1="-5.25" x2="7.75" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="6.5" y1="-7.25" x2="5.75" y2="-6.75" width="0.2032" layer="51"/>
<wire x1="-8.5" y1="-5.25" x2="-6.5" y2="-7.25" width="0.2032" layer="51" curve="180"/>
<wire x1="-6.5" y1="-7.25" x2="-5.75" y2="-6.75" width="0.2032" layer="51"/>
<wire x1="-8.5" y1="-5.25" x2="-7.75" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="6.5" y1="7.25" x2="8.5" y2="5.25" width="0.2032" layer="51" curve="-180"/>
<wire x1="6.5" y1="7.25" x2="5.75" y2="6.75" width="0.2032" layer="51"/>
<wire x1="8.5" y1="5.25" x2="7.75" y2="4.5" width="0.2032" layer="51"/>
<wire x1="-7.75" y1="-4.5" x2="-7.75" y2="4.5" width="0.2032" layer="21" curve="-60.282771"/>
<wire x1="-5.75" y1="6.75" x2="5.75" y2="6.75" width="0.2032" layer="21" curve="-80.852157"/>
<wire x1="7.75" y1="4.5" x2="7.75" y2="-4.5" width="0.2032" layer="21" curve="-60.282771"/>
<wire x1="-5.75" y1="-6.75" x2="5.75" y2="-6.75" width="0.2032" layer="21" curve="80.852157"/>
<circle x="0" y="0" radius="7.9" width="0.2032" layer="21"/>
<pad name="1" x="-7.5" y="6.25" drill="1.016" shape="long"/>
<pad name="3" x="-7.5" y="-6.25" drill="1.016" shape="long"/>
<pad name="2" x="7.5" y="6.25" drill="1.016" shape="long"/>
<pad name="4" x="7.5" y="-6.25" drill="1.016" shape="long"/>
<text x="4.108" y="8.358" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.925" y="-2.246" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="3,2-PAD">
<description>&lt;b&gt;MOUNTING PAD&lt;/b&gt; 3.2 mm, round</description>
<wire x1="-2.159" y1="0" x2="0" y2="-2.159" width="2.4892" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.159" x2="2.159" y2="0" width="2.4892" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="3.683" width="1.27" layer="39"/>
<circle x="0" y="0" radius="3.683" width="1.27" layer="40"/>
<circle x="0" y="0" radius="3.556" width="1.016" layer="43"/>
<circle x="0" y="0" radius="1.7" width="0.1524" layer="21"/>
<pad name="B3,2" x="0" y="0" drill="3.2" diameter="5.842"/>
<text x="-1.27" y="-3.81" size="1.27" layer="48">3,2</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="IC1" library="linear" package="SO16" value="TL494CD" x="5.3975" y="54.61" rot="MR180"/>
<element name="U$1" library="Labor" package="SO16" value="IR2110S" x="5.3975" y="41.275" rot="MR0"/>
<element name="Q1" library="transistor-power" package="TO220BV" value="IRF740" x="37.465" y="46.355" rot="R270"/>
<element name="Q2" library="transistor-power" package="TO220BV" value="IRF740" x="37.465" y="29.21" rot="R270"/>
<element name="R1" library="rcl" package="R1206" value="4R7" x="9.2075" y="29.845" rot="MR270"/>
<element name="R2" library="rcl" package="R1206" value="4R7" x="-0.3175" y="29.845" rot="MR270"/>
<element name="D1" library="diode" package="SMB" value="" x="-3.4925" y="41.275" rot="MR90"/>
<element name="C1" library="rcl" package="C1206" value="10uF" x="1.5875" y="34.29" rot="MR180"/>
<element name="D2" library="diode" package="SMB" value="5819" x="-3.4925" y="30.48" rot="MR270"/>
<element name="D3" library="diode" package="SMB" value="5819" x="12.3825" y="30.48" rot="MR270"/>
<element name="C2" library="rcl" package="C1206" value="10uF" x="7.3025" y="34.29" rot="MR180"/>
<element name="R3" library="rcl" package="R1206" value="Rt" x="10.4775" y="64.135" rot="MR270"/>
<element name="C3" library="rcl" package="C1206" value="Csoft" x="-1.5875" y="54.61" rot="MR270"/>
<element name="R4" library="rcl" package="R1206" value="Rsoft" x="5.3975" y="64.135" rot="MR270"/>
<element name="C4" library="rcl" package="C1206" value="Ct" x="7.9375" y="64.135" rot="MR90"/>
<element name="R5" library="rcl" package="R1206" value="" x="-4.7625" y="50.8" rot="MR90"/>
<element name="R6" library="rcl" package="R1206" value="RV2" x="-2.2225" y="64.135" rot="MR270"/>
<element name="R7" library="rcl" package="R1206" value="RV1" x="-4.7625" y="59.055" rot="MR270"/>
<element name="C5" library="rcl" package="C1206" value="100nF" x="13.0175" y="57.785" rot="MR180"/>
<element name="R8" library="rcl" package="R1206" value="470R" x="13.6525" y="51.435" rot="MR0"/>
<element name="R9" library="rcl" package="R1206" value="470R" x="13.6525" y="53.975" rot="MR0"/>
<element name="OK1" library="optocoupler" package="DIL04" value="PC817" x="78.105" y="12.065" rot="R90">
<attribute name="OC_NEWARK" value="97K7059" x="140.335" y="86.995" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="PC817X4J000F" x="140.335" y="86.995" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="140.335" y="86.995" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="9707727" x="140.335" y="86.995" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="R10" library="resistor" package="R1206" value="" x="14.2875" y="64.135" rot="MR270"/>
<element name="R11" library="resistor" package="R1206" value="" x="15.5575" y="39.37" rot="MR270"/>
<element name="R12" library="resistor" package="R1206" value="" x="2.8575" y="64.135" rot="MR270"/>
<element name="C6" library="resistor" package="C1206" value="" x="0.3175" y="64.135" rot="MR90"/>
<element name="C7" library="rcl" package="EB22,5D" value="min. 330uF" x="56.515" y="76.835"/>
<element name="C8" library="rcl" package="EB22,5D" value="min. 330uF" x="80.01" y="76.835"/>
<element name="R13" library="rcl" package="R1206" value="" x="56.515" y="74.295" rot="MR0"/>
<element name="R14" library="rcl" package="R1206" value="" x="56.515" y="79.375" rot="MR0"/>
<element name="R15" library="rcl" package="R1206" value="" x="56.515" y="76.835" rot="MR0"/>
<element name="R16" library="rcl" package="R1206" value="" x="80.01" y="71.755" rot="MR0"/>
<element name="R17" library="rcl" package="R1206" value="" x="80.01" y="74.295" rot="MR0"/>
<element name="R18" library="rcl" package="R1206" value="" x="80.01" y="76.835" rot="MR0"/>
<element name="B1" library="rectifier" package="FB15A" value="" x="96.52" y="75.565" rot="R270"/>
<element name="C9" library="capacitor-wima" package="C7.5B3" value="" x="102.235" y="75.565" rot="R270"/>
<element name="C10" library="capacitor-wima" package="C7.5B3" value="" x="132.08" y="76.2" rot="R90"/>
<element name="R19" library="ptc-ntc" package="N644B" value="5R" x="141.605" y="71.12">
<attribute name="OC_NEWARK" value="unknown" x="205.105" y="7.62" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="205.105" y="7.62" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="205.105" y="7.62" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="205.105" y="7.62" size="1.778" layer="27" display="off"/>
</element>
<element name="F1" library="fuse" package="TR5" value="5A" x="140.97" y="84.455" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="55.88" y="144.145" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="55.88" y="144.145" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="55.88" y="144.145" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="55.88" y="144.145" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="X1" library="con-ptr500" package="AK500/3" value="" x="156.21" y="69.85" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="232.41" y="90.17" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="232.41" y="90.17" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="232.41" y="90.17" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="232.41" y="90.17" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="D4" library="diode" package="MELF-MLL41" value="Z15" x="31.115" y="42.545" rot="MR270"/>
<element name="D5" library="diode" package="MELF-MLL41" value="Z15" x="31.115" y="31.115" rot="MR270"/>
<element name="D6" library="diode" package="DO41-10" value="UF4003" x="46.355" y="48.26" rot="R270"/>
<element name="D7" library="diode" package="DO41-10" value="UF4003" x="46.355" y="29.845" rot="R270"/>
<element name="C11" library="capacitor-wima" package="C5B3" value="" x="50.8" y="33.655" rot="R90"/>
<element name="R20" library="rcl" package="0411/15" value="" x="50.8" y="46.99" rot="R90"/>
<element name="Q3" library="transistor-power" package="TO220BV" value="IRF740" x="37.465" y="82.55"/>
<element name="D8" library="diode" package="DO34Z7" value="Z15" x="30.48" y="67.945" rot="R270"/>
<element name="R21" library="rcl" package="0411/12" value="330k" x="26.67" y="67.31" rot="R270"/>
<element name="C12" library="rcl" package="E5-8,5" value="" x="38.1" y="70.485"/>
<element name="D9" library="diode" package="DO34Z7" value="Z15" x="38.735" y="75.565"/>
<element name="J1" library="con-amp" package="10X02MTA" value="" x="46.99" y="19.685"/>
<element name="D10" library="diode" package="SMB" value="" x="33.655" y="20.955" rot="MR180"/>
<element name="R22" library="rcl" package="R1206" value="47R" x="27.305" y="21.59" rot="MR180"/>
<element name="R23" library="rcl" package="R1206" value="10R" x="4.7625" y="29.845" rot="MR270"/>
<element name="VR1" library="v-reg" package="TO92-CLP" value="" x="154.305" y="38.735"/>
<element name="R24" library="rcl" package="R1206" value="6k8" x="85.725" y="12.7" rot="MR270"/>
<element name="R25" library="rcl" package="R1206" value="1k" x="142.24" y="33.655" rot="MR90"/>
<element name="R26" library="rcl" package="R1206" value="2.35K" x="142.24" y="40.64" rot="MR90"/>
<element name="R27" library="rcl" package="R1206" value="470R" x="148.59" y="40.64" rot="MR270"/>
<element name="R28" library="rcl" package="R1206" value="1K" x="153.67" y="34.29" rot="MR180"/>
<element name="C13" library="rcl" package="C1206" value="10nF" x="148.59" y="34.29" rot="MR90"/>
<element name="C14" library="rcl" package="E7,5-16" value="1500uF 35V" x="142.875" y="54.61" rot="R90"/>
<element name="C15" library="rcl" package="E7,5-16" value="1500uF 35V" x="124.46" y="54.61" rot="R90"/>
<element name="L2" library="inductors" package="ED26" value="ED26" x="133.985" y="31.75"/>
<element name="D11" library="diode" package="TO3P" value="" x="102.87" y="49.53" rot="R90"/>
<element name="D12" library="diode" package="TO3P" value="" x="102.87" y="30.48" rot="R90"/>
<element name="X2" library="con-ptr500" package="AK500/2" value="" x="156.21" y="52.07" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="156.21" y="52.07" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="156.21" y="52.07" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="156.21" y="52.07" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="156.21" y="52.07" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="TR1" library="trafo" package="EI42-2" value="" x="73.66" y="38.1"/>
<element name="C16" library="capacitor-wima" package="C15B7" value="" x="43.815" y="60.325"/>
<element name="TP1" library="testpad" package="P1-20" value="PTR1PAD1-20" x="98.425" y="52.07">
<attribute name="TP_SIGNAL_NAME" value="" x="98.425" y="52.07" size="1.778" layer="27" display="off"/>
</element>
<element name="L1" library="inductor-neosid" package="R18" value="" x="117.475" y="75.565" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="117.475" y="75.565" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="117.475" y="75.565" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="117.475" y="75.565" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="117.475" y="75.565" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="C17" library="rcl" package="C1206" value="" x="36.83" y="73.025" rot="MR0"/>
<element name="J2" library="con-amp" package="10X06MTA" value="" x="27.305" y="46.355" rot="R90"/>
<element name="J3" library="con-amp" package="10X06MTA" value="" x="27.305" y="31.115" rot="R90"/>
<element name="H1" library="holes" package="3,2-PAD" value="MOUNT-PAD-ROUND3.2" x="154.94" y="83.185"/>
<element name="H2" library="holes" package="3,2-PAD" value="MOUNT-PAD-ROUND3.2" x="154.94" y="13.335"/>
<element name="H3" library="holes" package="3,2-PAD" value="MOUNT-PAD-ROUND3.2" x="27.305" y="12.7"/>
<element name="H4" library="holes" package="3,2-PAD" value="MOUNT-PAD-ROUND3.2" x="27.305" y="83.185"/>
<element name="R29" library="rcl" package="R1206" value="0r" x="142.24" y="29.21" rot="MR180"/>
<element name="J4" library="con-amp" package="10X06MTA" value="" x="-4.1275" y="24.765" rot="R180"/>
<element name="J5" library="con-amp" package="10X06MTA" value="" x="11.1125" y="24.765" rot="R180"/>
</elements>
<signals>
<signal name="N$2">
<contactref element="R1" pad="2"/>
<contactref element="Q2" pad="G"/>
<contactref element="D3" pad="A"/>
<contactref element="D5" pad="C"/>
<wire x1="34.29" y1="32.385" x2="34.925" y2="31.75" width="1.016" layer="16"/>
<contactref element="J3" pad="3"/>
<wire x1="31.75" y1="32.385" x2="27.305" y2="32.385" width="1.016" layer="16"/>
<wire x1="34.29" y1="32.385" x2="31.75" y2="32.385" width="1.016" layer="16"/>
<wire x1="31.75" y1="32.385" x2="31.115" y2="33.02" width="1.016" layer="16"/>
<wire x1="31.115" y1="33.02" x2="31.115" y2="33.74" width="1.016" layer="16"/>
<contactref element="J5" pad="3"/>
<wire x1="9.8425" y1="24.765" x2="27.305" y2="32.385" width="0" layer="19" extent="1-16"/>
<wire x1="9.8425" y1="24.765" x2="9.8425" y2="28.575" width="0.8128" layer="16"/>
<wire x1="9.8425" y1="28.575" x2="9.2075" y2="28.575" width="0.8128" layer="16"/>
<wire x1="9.2075" y1="28.423" x2="12.2395" y2="28.423" width="0.8128" layer="16"/>
<wire x1="12.2395" y1="28.423" x2="12.3825" y2="28.28" width="0.8128" layer="16"/>
<wire x1="9.2075" y1="28.423" x2="9.2075" y2="28.575" width="0.8128" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="U$1" pad="8"/>
<contactref element="R2" pad="1"/>
<contactref element="D2" pad="C"/>
<wire x1="0.9525" y1="38.4175" x2="0.635" y2="38.4175" width="0.6096" layer="16"/>
<wire x1="0.635" y1="38.4175" x2="-3.4925" y2="34.29" width="0.6096" layer="16"/>
<wire x1="-3.4925" y1="34.29" x2="-3.4925" y2="32.68" width="0.6096" layer="16"/>
<wire x1="-0.3175" y1="31.267" x2="-0.3175" y2="31.75" width="0.6096" layer="16"/>
<wire x1="-0.3175" y1="31.75" x2="-3.4925" y2="31.75" width="0.8128" layer="16"/>
<wire x1="-3.4925" y1="31.75" x2="-3.4925" y2="32.68" width="0.6096" layer="16"/>
</signal>
<signal name="VS">
<contactref element="Q2" pad="D"/>
<contactref element="Q1" pad="S"/>
<contactref element="U$1" pad="6"/>
<contactref element="C1" pad="2"/>
<contactref element="D4" pad="A"/>
<contactref element="D6" pad="A"/>
<contactref element="D7" pad="C"/>
<contactref element="C11" pad="1"/>
<contactref element="TR1" pad="5"/>
<wire x1="61.1632" y1="25.6032" x2="55.6768" y2="25.6032" width="2.54" layer="16"/>
<wire x1="55.6768" y1="25.6032" x2="51.435" y2="29.845" width="2.54" layer="16"/>
<wire x1="51.435" y1="29.845" x2="50.8" y2="30.48" width="2.54" layer="16"/>
<wire x1="34.925" y1="29.21" x2="46.355" y2="29.21" width="2.1844" layer="16"/>
<wire x1="46.355" y1="29.21" x2="50.8" y2="29.21" width="2.54" layer="16"/>
<wire x1="50.8" y1="29.21" x2="51.435" y2="29.845" width="2.54" layer="16"/>
<wire x1="46.355" y1="34.925" x2="46.355" y2="29.21" width="2.54" layer="16"/>
<wire x1="34.925" y1="43.815" x2="45.72" y2="43.815" width="2.1844" layer="16"/>
<wire x1="45.72" y1="43.815" x2="46.355" y2="43.18" width="2.54" layer="16"/>
<wire x1="46.355" y1="43.18" x2="46.355" y2="34.925" width="2.54" layer="16"/>
<contactref element="J2" pad="6"/>
<wire x1="27.305" y1="40.005" x2="31.115" y2="40.005" width="1.016" layer="16"/>
<wire x1="31.115" y1="40.005" x2="34.925" y2="43.815" width="1.016" layer="16"/>
<contactref element="J4" pad="6"/>
<wire x1="27.305" y1="40.005" x2="2.2225" y2="24.765" width="0" layer="19" extent="1-16"/>
<wire x1="2.2225" y1="24.765" x2="2.2225" y2="33.525" width="0.8128" layer="16"/>
<wire x1="2.2225" y1="33.525" x2="2.9875" y2="34.29" width="0.8128" layer="16"/>
<wire x1="3.4925" y1="38.4175" x2="3.4925" y2="34.795" width="0.6096" layer="16"/>
<wire x1="3.4925" y1="34.795" x2="2.9875" y2="34.29" width="0.6096" layer="16"/>
<wire x1="50.8" y1="30.48" x2="50.8" y2="31.115" width="0" layer="19" extent="16-16"/>
<wire x1="31.115" y1="39.92" x2="31.115" y2="40.005" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$7">
<contactref element="D1" pad="C"/>
<contactref element="U$1" pad="7"/>
<contactref element="C1" pad="1"/>
<wire x1="2.2225" y1="38.4175" x2="2.2225" y2="36.83" width="0.6096" layer="16"/>
<wire x1="2.2225" y1="36.83" x2="0.3175" y2="34.925" width="0.6096" layer="16"/>
<wire x1="0.3175" y1="34.925" x2="0.3175" y2="34.42" width="0.6096" layer="16"/>
<wire x1="0.3175" y1="34.42" x2="0.1875" y2="34.29" width="0.6096" layer="16"/>
<wire x1="2.2225" y1="38.4175" x2="2.2225" y2="40.005" width="0.6096" layer="16"/>
<wire x1="2.2225" y1="40.005" x2="-3.4925" y2="40.005" width="0.6096" layer="16"/>
<wire x1="-3.4925" y1="40.005" x2="-3.4925" y2="39.075" width="0.6096" layer="16"/>
</signal>
<signal name="VCC">
<contactref element="IC1" pad="12"/>
<contactref element="C5" pad="1"/>
<contactref element="IC1" pad="8"/>
<contactref element="IC1" pad="11"/>
<contactref element="Q3" pad="S"/>
<contactref element="C12" pad="+"/>
<contactref element="D9" pad="C"/>
<contactref element="R23" pad="2"/>
<contactref element="C17" pad="2"/>
<wire x1="40.005" y1="80.01" x2="40.005" y2="77.47" width="1.016" layer="16"/>
<wire x1="40.005" y1="77.47" x2="38.1" y2="75.565" width="1.016" layer="16"/>
<wire x1="38.1" y1="75.565" x2="34.925" y2="75.565" width="1.016" layer="16"/>
<wire x1="34.925" y1="75.565" x2="34.925" y2="73.53" width="1.016" layer="16"/>
<wire x1="34.925" y1="73.53" x2="35.43" y2="73.025" width="1.016" layer="16"/>
<wire x1="35.43" y1="73.025" x2="35.43" y2="69.98" width="1.016" layer="16"/>
<wire x1="35.43" y1="69.98" x2="35.56" y2="70.485" width="1.016" layer="16"/>
<contactref element="R22" pad="1"/>
<contactref element="J3" pad="1"/>
<wire x1="23.495" y1="22.86" x2="23.495" y2="36.83" width="1.016" layer="16"/>
<wire x1="23.495" y1="36.83" x2="24.13" y2="37.465" width="1.016" layer="16"/>
<wire x1="27.305" y1="37.465" x2="24.13" y2="37.465" width="1.016" layer="16"/>
<wire x1="24.13" y1="37.465" x2="23.495" y2="38.1" width="1.016" layer="16"/>
<wire x1="23.495" y1="38.1" x2="23.495" y2="52.705" width="1.016" layer="16"/>
<wire x1="23.495" y1="52.705" x2="23.495" y2="67.6275" width="1.016" layer="16"/>
<wire x1="23.495" y1="22.86" x2="24.765" y2="21.59" width="1.016" layer="16"/>
<wire x1="24.765" y1="21.59" x2="25.883" y2="21.59" width="1.016" layer="16"/>
<wire x1="25.883" y1="21.59" x2="26.035" y2="21.59" width="1.016" layer="16"/>
<contactref element="J5" pad="1"/>
<wire x1="4.7625" y1="24.765" x2="27.305" y2="37.465" width="0" layer="19" extent="1-16"/>
<contactref element="J2" pad="1"/>
<contactref element="J4" pad="1"/>
<wire x1="27.305" y1="52.705" x2="-10.4775" y2="24.765" width="0" layer="19" extent="1-16"/>
<wire x1="27.305" y1="52.705" x2="23.495" y2="52.705" width="0.8128" layer="16"/>
<wire x1="4.7625" y1="28.423" x2="4.7625" y2="24.765" width="0.8128" layer="16"/>
<wire x1="6.0325" y1="51.5366" x2="7.3025" y2="51.5366" width="0.6096" layer="16"/>
<wire x1="7.3025" y1="51.5366" x2="7.3025" y2="53.34" width="0.6096" layer="16"/>
<wire x1="7.3025" y1="53.34" x2="9.8425" y2="55.88" width="0.6096" layer="16"/>
<wire x1="9.8425" y1="55.88" x2="9.8425" y2="57.6834" width="0.6096" layer="16"/>
<wire x1="9.8425" y1="57.6834" x2="11.5159" y2="57.6834" width="0.6096" layer="16"/>
<wire x1="11.5159" y1="57.6834" x2="11.6175" y2="57.785" width="0.6096" layer="16"/>
<wire x1="6.0325" y1="51.5366" x2="6.0325" y2="50.165" width="0.6096" layer="16"/>
<wire x1="6.0325" y1="50.165" x2="3.4925" y2="47.625" width="0.6096" layer="16"/>
<wire x1="3.4925" y1="47.625" x2="-8.5725" y2="47.625" width="0.6096" layer="16"/>
<wire x1="-8.5725" y1="47.625" x2="-10.4775" y2="45.72" width="0.6096" layer="16"/>
<wire x1="-10.4775" y1="45.72" x2="-10.4775" y2="24.765" width="0.6096" layer="16"/>
<wire x1="24.9525" y1="69.085" x2="23.495" y2="67.6275" width="1.016" layer="16"/>
<wire x1="24.9525" y1="69.085" x2="31.62" y2="69.085" width="1.016" layer="16"/>
<wire x1="31.62" y1="69.085" x2="32.7025" y2="70.1675" width="1.016" layer="16"/>
<wire x1="32.7025" y1="70.1675" x2="35.2425" y2="70.1675" width="1.016" layer="16"/>
<wire x1="35.2425" y1="70.1675" x2="35.56" y2="70.485" width="1.016" layer="16"/>
</signal>
<signal name="GND">
<contactref element="U$1" pad="2"/>
<contactref element="Q2" pad="S"/>
<contactref element="C2" pad="2"/>
<contactref element="U$1" pad="13"/>
<contactref element="U$1" pad="15"/>
<contactref element="R8" pad="1"/>
<contactref element="R9" pad="1"/>
<contactref element="D5" pad="A"/>
<contactref element="D7" pad="A"/>
<contactref element="IC1" pad="7"/>
<contactref element="C5" pad="2"/>
<contactref element="R3" pad="1"/>
<contactref element="C4" pad="2"/>
<contactref element="R4" pad="1"/>
<contactref element="IC1" pad="16"/>
<contactref element="R6" pad="1"/>
<contactref element="R10" pad="1"/>
<contactref element="C8" pad="-"/>
<contactref element="R16" pad="1"/>
<contactref element="R17" pad="1"/>
<contactref element="R18" pad="1"/>
<contactref element="B1" pad="-"/>
<contactref element="D8" pad="A"/>
<contactref element="C12" pad="-"/>
<contactref element="D9" pad="A"/>
<contactref element="J1" pad="1"/>
<contactref element="C17" pad="1"/>
<wire x1="81.432" y1="71.755" x2="81.432" y2="76.835" width="1.016" layer="16"/>
<wire x1="81.432" y1="76.835" x2="81.432" y2="74.295" width="1.016" layer="16"/>
<wire x1="81.432" y1="77.318" x2="81.915" y2="76.835" width="1.016" layer="16"/>
<wire x1="81.432" y1="76.835" x2="81.915" y2="76.835" width="1.016" layer="16"/>
<wire x1="34.925" y1="26.67" x2="36.83" y2="24.765" width="2.1844" layer="16"/>
<wire x1="36.83" y1="24.765" x2="46.355" y2="24.765" width="2.1844" layer="16"/>
<wire x1="96.52" y1="68.0536" x2="88.7914" y2="68.0536" width="2.54" layer="16"/>
<wire x1="88.7914" y1="68.0536" x2="85.4075" y2="71.4375" width="2.54" layer="16"/>
<wire x1="85.4075" y1="71.4375" x2="85.09" y2="71.755" width="2.54" layer="16"/>
<wire x1="85.09" y1="71.755" x2="85.09" y2="76.835" width="2.54" layer="16"/>
<wire x1="81.432" y1="74.295" x2="81.432" y2="76.352" width="1.016" layer="16"/>
<wire x1="81.432" y1="76.352" x2="81.915" y2="76.835" width="1.016" layer="16"/>
<wire x1="81.915" y1="76.835" x2="85.09" y2="76.835" width="1.016" layer="16"/>
<contactref element="J3" pad="4"/>
<contactref element="J3" pad="2"/>
<wire x1="34.925" y1="26.67" x2="32.385" y2="26.67" width="1.016" layer="16"/>
<wire x1="31.115" y1="27.94" x2="29.21" y2="29.845" width="1.016" layer="16"/>
<wire x1="29.21" y1="29.845" x2="27.305" y2="29.845" width="1.016" layer="16"/>
<wire x1="27.305" y1="34.925" x2="25.4" y2="34.925" width="1.016" layer="16"/>
<wire x1="25.4" y1="34.925" x2="24.765" y2="34.29" width="1.016" layer="16"/>
<wire x1="24.765" y1="34.29" x2="24.765" y2="31.115" width="1.016" layer="16"/>
<wire x1="24.765" y1="31.115" x2="26.035" y2="29.845" width="1.016" layer="16"/>
<wire x1="26.035" y1="29.845" x2="27.305" y2="29.845" width="1.016" layer="16"/>
<wire x1="42.545" y1="75.565" x2="42.545" y2="74.93" width="1.016" layer="16"/>
<wire x1="42.545" y1="74.93" x2="40.64" y2="73.025" width="1.016" layer="16"/>
<wire x1="40.64" y1="73.025" x2="40.64" y2="70.485" width="1.016" layer="16"/>
<wire x1="38.23" y1="73.025" x2="40.64" y2="73.025" width="1.016" layer="16"/>
<wire x1="42.545" y1="75.565" x2="45.085" y2="75.565" width="1.016" layer="16"/>
<wire x1="45.085" y1="75.565" x2="45.72" y2="74.93" width="1.016" layer="16"/>
<via x="45.72" y="74.93" extent="1-16" drill="0.5" diameter="1.6764" shape="square"/>
<wire x1="45.72" y1="74.93" x2="56.515" y2="64.135" width="1.016" layer="1"/>
<via x="56.515" y="64.135" extent="1-16" drill="0.5" diameter="1.6764" shape="square"/>
<wire x1="56.515" y1="64.135" x2="78.105" y2="64.135" width="1.016" layer="16"/>
<wire x1="78.105" y1="64.135" x2="85.4075" y2="71.4375" width="1.016" layer="16"/>
<wire x1="46.355" y1="24.765" x2="46.99" y2="24.765" width="2.54" layer="16"/>
<wire x1="46.99" y1="24.765" x2="48.895" y2="22.86" width="2.54" layer="16"/>
<wire x1="48.895" y1="22.86" x2="48.895" y2="19.685" width="2.54" layer="16"/>
<wire x1="48.895" y1="19.685" x2="50.165" y2="18.415" width="2.54" layer="16"/>
<wire x1="50.165" y1="18.415" x2="64.77" y2="18.415" width="2.54" layer="16"/>
<wire x1="64.77" y1="18.415" x2="68.58" y2="22.225" width="2.54" layer="16"/>
<wire x1="68.58" y1="22.225" x2="68.58" y2="53.34" width="2.54" layer="16"/>
<wire x1="68.58" y1="53.34" x2="85.725" y2="70.485" width="2.54" layer="16"/>
<wire x1="32.385" y1="26.67" x2="31.115" y2="27.94" width="1.016" layer="16"/>
<wire x1="31.115" y1="27.94" x2="31.115" y2="28.49" width="1.016" layer="16"/>
<contactref element="J5" pad="2"/>
<contactref element="J5" pad="4"/>
<wire x1="7.3025" y1="24.765" x2="27.305" y2="34.925" width="0" layer="19" extent="1-16"/>
<wire x1="12.3825" y1="24.765" x2="27.305" y2="29.845" width="0" layer="19" extent="1-16"/>
<wire x1="8.5725" y1="38.4175" x2="8.5725" y2="34.42" width="0.6096" layer="16"/>
<wire x1="8.5725" y1="34.42" x2="8.7025" y2="34.29" width="0.6096" layer="16"/>
<wire x1="7.3025" y1="24.765" x2="7.3025" y2="33.02" width="0.8128" layer="16"/>
<wire x1="7.3025" y1="33.02" x2="7.9375" y2="33.655" width="0.8128" layer="16"/>
<wire x1="7.9375" y1="33.655" x2="8.0675" y2="33.655" width="0.8128" layer="16"/>
<wire x1="8.0675" y1="33.655" x2="8.7025" y2="34.29" width="0.8128" layer="16"/>
<wire x1="8.5725" y1="38.4175" x2="8.5725" y2="42.545" width="0.6096" layer="16"/>
<wire x1="8.5725" y1="42.545" x2="8.5725" y2="44.1325" width="0.6096" layer="16"/>
<wire x1="6.0325" y1="44.1325" x2="6.0325" y2="42.545" width="0.6096" layer="16"/>
<wire x1="6.0325" y1="42.545" x2="8.5725" y2="42.545" width="0.6096" layer="16"/>
<wire x1="15.0745" y1="53.975" x2="15.0745" y2="51.435" width="0.6096" layer="16"/>
<wire x1="15.0745" y1="49.682" x2="14.9225" y2="49.53" width="0.6096" layer="16"/>
<wire x1="15.0745" y1="49.682" x2="15.0745" y2="46.507" width="0.6096" layer="16"/>
<wire x1="15.0745" y1="46.507" x2="11.1125" y2="42.545" width="0.6096" layer="16"/>
<wire x1="11.1125" y1="42.545" x2="8.5725" y2="42.545" width="0.6096" layer="16"/>
<wire x1="15.0745" y1="51.435" x2="15.0745" y2="49.682" width="0.6096" layer="16"/>
<wire x1="6.0325" y1="44.1325" x2="6.0325" y2="46.355" width="0.6096" layer="16"/>
<wire x1="8.5725" y1="44.1325" x2="8.5725" y2="46.355" width="0.6096" layer="16"/>
<wire x1="10.4775" y1="65.557" x2="7.9595" y2="65.557" width="0.6096" layer="16"/>
<wire x1="7.9595" y1="65.557" x2="7.9375" y2="65.535" width="0.6096" layer="16"/>
<wire x1="7.9375" y1="65.535" x2="5.4195" y2="65.535" width="0.6096" layer="16"/>
<wire x1="5.4195" y1="65.535" x2="5.3975" y2="65.557" width="0.6096" layer="16"/>
<wire x1="8.5725" y1="57.6834" x2="8.5725" y2="59.055" width="0.6096" layer="16"/>
<wire x1="8.5725" y1="59.055" x2="9.2075" y2="59.69" width="0.6096" layer="16"/>
<wire x1="9.2075" y1="59.69" x2="12.3825" y2="59.69" width="0.6096" layer="16"/>
<wire x1="12.3825" y1="59.69" x2="14.9225" y2="59.69" width="0.6096" layer="16"/>
<wire x1="14.9225" y1="57.785" x2="14.9225" y2="54.127" width="0.6096" layer="16"/>
<wire x1="14.9225" y1="54.127" x2="15.0745" y2="53.975" width="0.6096" layer="16"/>
<wire x1="5.3975" y1="65.557" x2="5.3975" y2="66.675" width="0.6096" layer="16"/>
<wire x1="5.3975" y1="66.675" x2="4.7625" y2="67.31" width="0.6096" layer="16"/>
<wire x1="4.7625" y1="67.31" x2="-1.5875" y2="67.31" width="0.6096" layer="16"/>
<wire x1="-1.5875" y1="67.31" x2="-2.2225" y2="66.675" width="0.6096" layer="16"/>
<wire x1="-2.2225" y1="66.675" x2="-2.2225" y2="65.557" width="0.6096" layer="16"/>
<wire x1="14.2875" y1="65.557" x2="10.4775" y2="65.557" width="0.6096" layer="16"/>
<wire x1="14.2875" y1="65.557" x2="12.5345" y2="65.557" width="0.6096" layer="16"/>
<wire x1="12.5345" y1="65.557" x2="12.3825" y2="65.405" width="0.6096" layer="16"/>
<wire x1="12.3825" y1="65.405" x2="12.3825" y2="59.69" width="0.6096" layer="16"/>
<wire x1="14.9225" y1="59.69" x2="14.9225" y2="57.785" width="0.6096" layer="16"/>
<wire x1="14.9225" y1="57.785" x2="14.2875" y2="57.785" width="0.6096" layer="16"/>
<wire x1="0.9525" y1="51.5366" x2="0.4191" y2="51.5366" width="0.6096" layer="16"/>
<wire x1="0.4191" y1="51.5366" x2="-0.3175" y2="50.8" width="0.6096" layer="16"/>
<wire x1="-0.3175" y1="50.8" x2="-6.6675" y2="50.8" width="0.6096" layer="16"/>
<wire x1="-6.6675" y1="50.8" x2="-7.3025" y2="51.435" width="0.6096" layer="16"/>
<wire x1="-7.3025" y1="51.435" x2="-7.3025" y2="54.61" width="0.6096" layer="16"/>
<via x="-7.3025" y="54.61" extent="1-16" drill="0.5" diameter="1.6764" shape="square"/>
<wire x1="-7.3025" y1="54.61" x2="-7.3025" y2="64.77" width="0.6096" layer="1"/>
<via x="-7.3025" y="64.77" extent="1-16" drill="0.5" diameter="1.6764" shape="square"/>
<wire x1="-7.3025" y1="64.77" x2="-6.6675" y2="65.405" width="0.6096" layer="16"/>
<wire x1="-6.6675" y1="65.405" x2="-2.3745" y2="65.405" width="0.6096" layer="16"/>
<wire x1="-2.3745" y1="65.405" x2="-2.2225" y2="65.557" width="0.6096" layer="16"/>
<wire x1="30.48" y1="64.135" x2="30.48" y2="64.77" width="1.016" layer="16"/>
<wire x1="30.48" y1="64.77" x2="33.9725" y2="68.2625" width="1.016" layer="16"/>
<wire x1="33.9725" y1="68.2625" x2="38.4175" y2="68.2625" width="1.016" layer="16"/>
<wire x1="38.4175" y1="68.2625" x2="40.64" y2="70.485" width="1.016" layer="16"/>
<wire x1="85.725" y1="70.485" x2="85.4075" y2="71.4375" width="0" layer="19" extent="16-16"/>
<wire x1="14.4175" y1="57.785" x2="14.2875" y2="57.785" width="0" layer="19" extent="16-16"/>
<wire x1="48.26" y1="19.685" x2="48.895" y2="19.685" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$11">
<contactref element="R4" pad="2"/>
<contactref element="IC1" pad="4"/>
<contactref element="C3" pad="1"/>
<wire x1="4.7625" y1="57.6834" x2="4.7625" y2="62.078" width="0.6096" layer="16"/>
<wire x1="4.7625" y1="62.078" x2="5.3975" y2="62.713" width="0.6096" layer="16"/>
<wire x1="4.7625" y1="57.6834" x2="4.7625" y2="55.245" width="0.6096" layer="16"/>
<wire x1="4.7625" y1="55.245" x2="-0.9525" y2="55.245" width="0.6096" layer="16"/>
<wire x1="-0.9525" y1="55.245" x2="-1.5875" y2="55.88" width="0.6096" layer="16"/>
<wire x1="-1.5875" y1="55.88" x2="-1.5875" y2="56.01" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$13">
<contactref element="IC1" pad="5"/>
<contactref element="C4" pad="1"/>
<wire x1="6.0325" y1="57.6834" x2="6.0325" y2="59.69" width="0.6096" layer="16"/>
<wire x1="6.0325" y1="59.69" x2="7.9375" y2="61.595" width="0.6096" layer="16"/>
<wire x1="7.9375" y1="61.595" x2="7.9375" y2="62.735" width="0.6096" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="R3" pad="2"/>
<contactref element="IC1" pad="6"/>
<wire x1="7.3025" y1="57.6834" x2="7.3025" y2="59.055" width="0.6096" layer="16"/>
<wire x1="7.3025" y1="59.055" x2="10.4775" y2="62.23" width="0.6096" layer="16"/>
<wire x1="10.4775" y1="62.23" x2="10.4775" y2="62.713" width="0.6096" layer="16"/>
<wire x1="10.4775" y1="62.865" x2="10.4775" y2="62.713" width="0.6096" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="R5" pad="1"/>
<contactref element="IC1" pad="15"/>
<wire x1="2.2225" y1="51.5366" x2="2.2225" y2="49.53" width="0.6096" layer="16"/>
<wire x1="2.2225" y1="49.53" x2="1.5875" y2="48.895" width="0.6096" layer="16"/>
<wire x1="1.5875" y1="48.895" x2="-4.2795" y2="48.895" width="0.6096" layer="16"/>
<wire x1="-4.2795" y1="48.895" x2="-4.7625" y2="49.378" width="0.6096" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="R6" pad="2"/>
<contactref element="R7" pad="1"/>
<contactref element="IC1" pad="2"/>
<contactref element="C6" pad="1"/>
<wire x1="2.2225" y1="57.6834" x2="2.2225" y2="60.325" width="0.6096" layer="16"/>
<wire x1="2.2225" y1="60.325" x2="0.3175" y2="62.23" width="0.6096" layer="16"/>
<wire x1="0.3175" y1="62.23" x2="0.3175" y2="62.735" width="0.6096" layer="16"/>
<wire x1="0.3175" y1="62.23" x2="-1.5875" y2="62.23" width="0.6096" layer="16"/>
<wire x1="-1.5875" y1="62.23" x2="-2.2225" y2="62.865" width="0.6096" layer="16"/>
<wire x1="-2.2225" y1="62.713" x2="-2.5265" y2="62.713" width="0.6096" layer="16"/>
<wire x1="-2.5265" y1="62.713" x2="-4.7625" y2="60.477" width="0.6096" layer="16"/>
<wire x1="-2.2225" y1="62.865" x2="-2.2225" y2="62.713" width="0.6096" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="U$1" pad="14"/>
<contactref element="R8" pad="2"/>
<contactref element="IC1" pad="9"/>
<wire x1="7.3025" y1="44.1325" x2="7.3025" y2="46.99" width="0.6096" layer="16"/>
<wire x1="7.3025" y1="46.99" x2="9.8425" y2="49.53" width="0.6096" layer="16"/>
<wire x1="9.8425" y1="49.53" x2="9.8425" y2="51.435" width="0.6096" layer="16"/>
<wire x1="9.8425" y1="51.435" x2="12.2305" y2="51.435" width="0.6096" layer="16"/>
<wire x1="9.8425" y1="51.435" x2="9.8425" y2="51.5366" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$24">
<contactref element="U$1" pad="12"/>
<contactref element="R9" pad="2"/>
<contactref element="IC1" pad="10"/>
<wire x1="4.7625" y1="44.1325" x2="4.7625" y2="46.99" width="0.6096" layer="16"/>
<wire x1="4.7625" y1="46.99" x2="6.6675" y2="48.895" width="0.6096" layer="16"/>
<wire x1="6.6675" y1="48.895" x2="7.9375" y2="48.895" width="0.6096" layer="16"/>
<wire x1="7.9375" y1="48.895" x2="8.5725" y2="49.53" width="0.6096" layer="16"/>
<wire x1="8.5725" y1="49.53" x2="8.5725" y2="51.5366" width="0.6096" layer="16"/>
<wire x1="8.5725" y1="51.5366" x2="8.5725" y2="53.34" width="0.6096" layer="16"/>
<wire x1="8.5725" y1="53.34" x2="9.2075" y2="53.975" width="0.6096" layer="16"/>
<wire x1="9.2075" y1="53.975" x2="12.2305" y2="53.975" width="0.6096" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="IC1" pad="1"/>
<contactref element="R10" pad="2"/>
<contactref element="R11" pad="1"/>
<wire x1="15.5575" y1="40.792" x2="15.5575" y2="44.45" width="0.6096" layer="16"/>
<wire x1="15.5575" y1="44.45" x2="16.8275" y2="45.72" width="0.6096" layer="16"/>
<wire x1="16.8275" y1="45.72" x2="16.8275" y2="60.173" width="0.6096" layer="16"/>
<wire x1="16.8275" y1="60.173" x2="14.2875" y2="62.713" width="0.6096" layer="16"/>
<wire x1="0.9525" y1="57.6834" x2="0.9525" y2="58.42" width="0.6096" layer="16"/>
<wire x1="0.9525" y1="58.42" x2="0.3175" y2="59.055" width="0.6096" layer="16"/>
<wire x1="0.3175" y1="59.055" x2="-8.5725" y2="59.055" width="0.6096" layer="16"/>
<wire x1="-7.3025" y1="68.58" x2="14.9225" y2="68.58" width="0.6096" layer="16"/>
<wire x1="14.9225" y1="68.58" x2="16.1925" y2="67.31" width="0.6096" layer="16"/>
<wire x1="16.1925" y1="67.31" x2="16.1925" y2="63.5" width="0.6096" layer="16"/>
<wire x1="16.1925" y1="63.5" x2="14.9225" y2="62.23" width="0.6096" layer="16"/>
<wire x1="14.9225" y1="62.23" x2="14.2875" y2="62.865" width="0.6096" layer="16"/>
<wire x1="14.2875" y1="62.713" x2="14.2875" y2="62.865" width="0.6096" layer="16"/>
<wire x1="14.2875" y1="62.713" x2="14.2875" y2="62.23" width="0.6096" layer="16"/>
<wire x1="-8.5725" y1="59.055" x2="-9.2075" y2="59.69" width="0.6096" layer="16"/>
<wire x1="-9.2075" y1="59.69" x2="-9.2075" y2="66.675" width="0.6096" layer="16"/>
<wire x1="-9.2075" y1="66.675" x2="-7.3025" y2="68.58" width="0.6096" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="R12" pad="1"/>
<contactref element="C6" pad="2"/>
<wire x1="0.3175" y1="65.535" x2="2.8355" y2="65.535" width="0.6096" layer="16"/>
<wire x1="2.8355" y1="65.535" x2="2.8575" y2="65.557" width="0.6096" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="R12" pad="2"/>
<contactref element="IC1" pad="3"/>
<wire x1="3.4925" y1="57.6834" x2="3.4925" y2="60.96" width="0.6096" layer="16"/>
<wire x1="3.4925" y1="60.96" x2="2.8575" y2="61.595" width="0.6096" layer="16"/>
<wire x1="2.8575" y1="61.595" x2="2.8575" y2="62.713" width="0.6096" layer="16"/>
</signal>
<signal name="VBUS/2">
<contactref element="C7" pad="-"/>
<contactref element="C8" pad="+"/>
<contactref element="R13" pad="1"/>
<contactref element="R16" pad="2"/>
<contactref element="R15" pad="1"/>
<contactref element="R18" pad="2"/>
<contactref element="R14" pad="1"/>
<contactref element="R17" pad="2"/>
<contactref element="C16" pad="2"/>
<wire x1="61.595" y1="76.835" x2="62.23" y2="76.835" width="2.54" layer="16"/>
<wire x1="62.23" y1="76.835" x2="63.5" y2="76.835" width="2.54" layer="16"/>
<wire x1="63.5" y1="76.835" x2="74.295" y2="76.835" width="2.54" layer="16"/>
<wire x1="74.295" y1="76.835" x2="74.93" y2="76.2" width="2.54" layer="16"/>
<wire x1="74.93" y1="76.2" x2="74.93" y2="76.835" width="2.54" layer="16"/>
<wire x1="51.308" y1="60.325" x2="51.308" y2="64.643" width="2.54" layer="16"/>
<wire x1="51.308" y1="64.643" x2="63.5" y2="76.835" width="2.54" layer="16"/>
<wire x1="74.93" y1="76.835" x2="78.588" y2="76.835" width="1.016" layer="16"/>
<wire x1="78.588" y1="76.835" x2="78.588" y2="74.295" width="1.016" layer="16"/>
<wire x1="78.588" y1="74.295" x2="78.588" y2="71.907" width="1.016" layer="16"/>
<wire x1="78.588" y1="71.907" x2="78.74" y2="71.755" width="1.016" layer="16"/>
<wire x1="57.937" y1="79.375" x2="57.937" y2="76.835" width="1.016" layer="16"/>
<wire x1="57.937" y1="76.835" x2="57.937" y2="74.295" width="1.016" layer="16"/>
<wire x1="57.937" y1="76.835" x2="62.23" y2="76.835" width="1.016" layer="16"/>
<wire x1="78.588" y1="71.907" x2="78.588" y2="71.755" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$37">
<contactref element="B1" pad="AC1"/>
<contactref element="C9" pad="1"/>
<contactref element="L1" pad="4"/>
<wire x1="109.975" y1="81.815" x2="104.04" y2="81.815" width="2.54" layer="16"/>
<wire x1="104.04" y1="81.815" x2="101.6" y2="79.375" width="2.54" layer="16"/>
<wire x1="102.235" y1="79.375" x2="101.6" y2="79.375" width="2.54" layer="16"/>
<wire x1="101.6" y1="79.375" x2="100.33" y2="78.105" width="2.54" layer="16"/>
<wire x1="100.33" y1="78.105" x2="96.5638" y2="78.105" width="2.54" layer="16"/>
<wire x1="96.5638" y1="78.105" x2="96.52" y2="78.0612" width="2.54" layer="16"/>
<wire x1="102.235" y1="79.375" x2="102.235" y2="77.47" width="2.54" layer="16"/>
<wire x1="102.235" y1="79.375" x2="102.235" y2="82.2325" width="2.54" layer="16"/>
</signal>
<signal name="N$38">
<contactref element="B1" pad="AC2"/>
<contactref element="C9" pad="2"/>
<contactref element="L1" pad="2"/>
<wire x1="109.975" y1="69.315" x2="104.675" y2="69.315" width="2.54" layer="16"/>
<wire x1="104.675" y1="69.315" x2="102.235" y2="71.755" width="2.54" layer="16"/>
<wire x1="102.235" y1="71.755" x2="100.965" y2="73.025" width="2.54" layer="16"/>
<wire x1="100.965" y1="73.025" x2="97.155" y2="73.025" width="2.54" layer="16"/>
<wire x1="97.155" y1="73.025" x2="96.52" y2="73.025" width="2.54" layer="16"/>
<wire x1="96.52" y1="73.025" x2="95.885" y2="73.025" width="2.54" layer="16"/>
<wire x1="96.52" y1="73.032" x2="97.148" y2="73.032" width="2.54" layer="16"/>
<wire x1="97.148" y1="73.032" x2="97.155" y2="73.025" width="2.54" layer="16"/>
<wire x1="96.52" y1="73.025" x2="96.52" y2="71.12" width="2.54" layer="16"/>
</signal>
<signal name="N$39">
<contactref element="X1" pad="1"/>
<contactref element="R19" pad="2"/>
<wire x1="156.21" y1="64.8462" x2="151.0538" y2="64.8462" width="2.54" layer="16"/>
<wire x1="151.0538" y1="64.8462" x2="146.685" y2="69.215" width="2.54" layer="16"/>
<wire x1="146.685" y1="69.215" x2="146.685" y2="70.485" width="2.54" layer="16"/>
<wire x1="146.685" y1="70.485" x2="147.32" y2="71.12" width="2.54" layer="16"/>
<wire x1="147.32" y1="71.12" x2="146.685" y2="71.12" width="2.54" layer="16"/>
<wire x1="146.685" y1="70.8025" x2="146.685" y2="71.12" width="2.54" layer="16"/>
<wire x1="145.0975" y1="71.12" x2="146.685" y2="71.12" width="2.54" layer="16"/>
</signal>
<signal name="N$40">
<contactref element="R19" pad="1"/>
<contactref element="C10" pad="1"/>
<contactref element="L1" pad="1"/>
<wire x1="124.975" y1="69.315" x2="130.275" y2="69.315" width="2.54" layer="16"/>
<wire x1="130.275" y1="69.315" x2="132.08" y2="71.12" width="2.54" layer="16"/>
<wire x1="132.08" y1="71.12" x2="136.525" y2="71.12" width="2.54" layer="16"/>
<wire x1="132.08" y1="72.39" x2="132.08" y2="71.12" width="2.54" layer="16"/>
<wire x1="136.525" y1="71.12" x2="140.335" y2="71.12" width="2.54" layer="16"/>
</signal>
<signal name="N$41">
<contactref element="C10" pad="2"/>
<contactref element="F1" pad="2"/>
<contactref element="L1" pad="3"/>
<wire x1="138.43" y1="84.455" x2="133.35" y2="84.455" width="2.54" layer="16"/>
<wire x1="133.35" y1="84.455" x2="132.08" y2="83.185" width="2.54" layer="16"/>
<wire x1="132.08" y1="83.185" x2="132.08" y2="81.915" width="2.54" layer="16"/>
<wire x1="132.08" y1="81.915" x2="132.08" y2="80.01" width="2.54" layer="16"/>
<wire x1="124.975" y1="81.815" x2="131.98" y2="81.815" width="2.54" layer="16"/>
<wire x1="131.98" y1="81.815" x2="132.08" y2="81.915" width="2.54" layer="16"/>
<wire x1="132.08" y1="80.01" x2="132.08" y2="77.1525" width="2.54" layer="16"/>
</signal>
<signal name="N$42">
<contactref element="F1" pad="1"/>
<contactref element="X1" pad="3"/>
<wire x1="156.21" y1="74.8538" x2="148.0312" y2="74.8538" width="2.54" layer="16"/>
<wire x1="148.0312" y1="74.8538" x2="143.51" y2="79.375" width="2.54" layer="16"/>
<wire x1="143.51" y1="79.375" x2="143.51" y2="85.09" width="2.54" layer="16"/>
<wire x1="143.51" y1="85.09" x2="143.51" y2="84.455" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="PE">
<contactref element="X1" pad="2"/>
<wire x1="156.21" y1="69.85" x2="155.575" y2="69.85" width="2.54" layer="16"/>
<wire x1="156.21" y1="69.85" x2="159.385" y2="69.85" width="2.54" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="C11" pad="2"/>
<contactref element="R20" pad="1"/>
<wire x1="50.8" y1="39.37" x2="50.8" y2="36.195" width="2.1844" layer="16"/>
<wire x1="50.8" y1="39.37" x2="50.8" y2="43.815" width="2.54" layer="16"/>
</signal>
<signal name="VBUS">
<contactref element="Q1" pad="D"/>
<contactref element="D6" pad="C"/>
<contactref element="C7" pad="+"/>
<contactref element="R13" pad="2"/>
<contactref element="R14" pad="2"/>
<contactref element="R15" pad="2"/>
<contactref element="B1" pad="+"/>
<contactref element="Q3" pad="D"/>
<contactref element="R21" pad="2"/>
<wire x1="34.925" y1="46.355" x2="36.83" y2="46.355" width="2.1844" layer="16"/>
<wire x1="96.52" y1="83.065" x2="51.315" y2="83.065" width="2.54" layer="16"/>
<wire x1="51.315" y1="83.065" x2="51.435" y2="81.28" width="2.54" layer="16"/>
<wire x1="51.435" y1="81.28" x2="51.435" y2="76.835" width="2.54" layer="16"/>
<wire x1="51.435" y1="76.835" x2="51.435" y2="74.93" width="2.54" layer="16"/>
<wire x1="51.435" y1="74.93" x2="41.275" y2="64.77" width="2.54" layer="16"/>
<wire x1="41.275" y1="64.77" x2="35.56" y2="64.77" width="2.54" layer="16"/>
<wire x1="35.56" y1="64.77" x2="32.385" y2="61.595" width="2.54" layer="16"/>
<wire x1="32.385" y1="61.595" x2="32.385" y2="60.96" width="2.54" layer="16"/>
<wire x1="32.385" y1="60.96" x2="32.385" y2="59.055" width="2.54" layer="16"/>
<wire x1="32.385" y1="59.055" x2="38.1" y2="53.34" width="2.54" layer="16"/>
<wire x1="38.1" y1="53.34" x2="38.1" y2="46.99" width="2.54" layer="16"/>
<wire x1="36.83" y1="46.355" x2="36.83" y2="46.99" width="1.016" layer="16"/>
<wire x1="36.83" y1="46.99" x2="38.1" y2="48.26" width="1.016" layer="16"/>
<wire x1="37.7825" y1="83.185" x2="52.07" y2="83.185" width="1.016" layer="16"/>
<wire x1="52.07" y1="83.185" x2="52.07" y2="81.28" width="1.016" layer="16"/>
<wire x1="52.07" y1="81.28" x2="51.435" y2="81.28" width="1.016" layer="16"/>
<wire x1="37.465" y1="80.01" x2="37.465" y2="82.8675" width="1.016" layer="16"/>
<wire x1="36.83" y1="46.355" x2="37.465" y2="46.355" width="2.1844" layer="16"/>
<wire x1="37.465" y1="46.355" x2="38.1" y2="46.99" width="2.1844" layer="16"/>
<wire x1="46.355" y1="53.34" x2="38.1" y2="53.34" width="2.1844" layer="16"/>
<wire x1="55.093" y1="79.375" x2="55.093" y2="76.835" width="1.016" layer="16"/>
<wire x1="55.093" y1="76.835" x2="55.093" y2="74.447" width="1.016" layer="16"/>
<wire x1="55.093" y1="74.447" x2="55.245" y2="74.295" width="1.016" layer="16"/>
<wire x1="55.093" y1="76.835" x2="51.435" y2="76.835" width="1.016" layer="16"/>
<wire x1="26.67" y1="60.96" x2="32.385" y2="60.96" width="1.016" layer="16"/>
<wire x1="46.355" y1="53.34" x2="46.355" y2="47.625" width="2.54" layer="16"/>
<wire x1="37.7825" y1="83.185" x2="37.465" y2="82.8675" width="1.016" layer="16"/>
<wire x1="55.093" y1="74.447" x2="55.093" y2="74.295" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$9">
<contactref element="Q3" pad="G"/>
<contactref element="R21" pad="1"/>
<contactref element="D8" pad="C"/>
<wire x1="34.925" y1="80.01" x2="31.75" y2="80.01" width="1.016" layer="16"/>
<wire x1="31.75" y1="80.01" x2="26.67" y2="74.93" width="1.016" layer="16"/>
<wire x1="26.67" y1="74.93" x2="26.67" y2="73.66" width="1.016" layer="16"/>
<wire x1="26.67" y1="73.66" x2="28.575" y2="73.66" width="1.016" layer="16"/>
<wire x1="28.575" y1="73.66" x2="30.48" y2="71.755" width="1.016" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="J1" pad="2"/>
<contactref element="D10" pad="A"/>
<wire x1="35.855" y1="20.955" x2="44.45" y2="20.955" width="1.016" layer="16"/>
<wire x1="44.45" y1="20.955" x2="45.72" y2="19.685" width="1.016" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="R22" pad="2"/>
<contactref element="D10" pad="C"/>
<wire x1="28.727" y1="21.59" x2="30.82" y2="21.59" width="1.016" layer="16"/>
<wire x1="30.82" y1="21.59" x2="31.455" y2="20.955" width="1.016" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="U$1" pad="3"/>
<contactref element="D1" pad="A"/>
<contactref element="C2" pad="1"/>
<contactref element="U$1" pad="11"/>
<contactref element="R23" pad="1"/>
<wire x1="7.3025" y1="38.4175" x2="7.3025" y2="36.83" width="0.6096" layer="16"/>
<wire x1="7.3025" y1="36.83" x2="6.0325" y2="35.56" width="0.6096" layer="16"/>
<wire x1="6.0325" y1="35.56" x2="6.0325" y2="34.42" width="0.6096" layer="16"/>
<wire x1="6.0325" y1="34.42" x2="5.9025" y2="34.29" width="0.6096" layer="16"/>
<wire x1="5.9025" y1="34.29" x2="5.9025" y2="32.407" width="0.8128" layer="16"/>
<wire x1="5.9025" y1="32.407" x2="4.7625" y2="31.267" width="0.8128" layer="16"/>
<wire x1="7.3025" y1="38.4175" x2="7.3025" y2="40.64" width="0.6096" layer="16"/>
<wire x1="7.3025" y1="40.64" x2="3.4925" y2="40.64" width="0.6096" layer="16"/>
<wire x1="3.4925" y1="40.64" x2="3.4925" y2="41.91" width="0.6096" layer="16"/>
<wire x1="3.4925" y1="44.1325" x2="3.4925" y2="41.91" width="0.6096" layer="16"/>
<wire x1="3.4925" y1="41.91" x2="-1.9275" y2="41.91" width="0.6096" layer="16"/>
<wire x1="-1.9275" y1="41.91" x2="-3.4925" y2="43.475" width="0.6096" layer="16"/>
<wire x1="3.4925" y1="44.1325" x2="3.4925" y2="46.355" width="0.6096" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="OK1" pad="1"/>
<contactref element="R24" pad="2"/>
<contactref element="R25" pad="1"/>
<wire x1="81.915" y1="10.795" x2="85.242" y2="10.795" width="0.8128" layer="16"/>
<wire x1="85.242" y1="10.795" x2="85.725" y2="11.278" width="0.8128" layer="16"/>
<wire x1="85.725" y1="11.278" x2="127.483" y2="11.278" width="0.8128" layer="16"/>
<wire x1="127.483" y1="11.278" x2="142.24" y2="26.035" width="0.8128" layer="16"/>
<wire x1="142.24" y1="26.035" x2="142.24" y2="32.233" width="0.6096" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="R27" pad="2"/>
<contactref element="R26" pad="1"/>
<contactref element="VR1" pad="R"/>
<contactref element="C13" pad="2"/>
<wire x1="142.24" y1="39.218" x2="148.438" y2="39.218" width="0.8128" layer="16"/>
<wire x1="148.438" y1="39.218" x2="148.59" y2="39.37" width="0.8128" layer="16"/>
<wire x1="148.59" y1="39.218" x2="148.59" y2="35.69" width="0.8128" layer="16"/>
<wire x1="153.035" y1="38.735" x2="149.073" y2="38.735" width="0.8128" layer="16"/>
<wire x1="149.073" y1="38.735" x2="148.59" y2="39.218" width="0.8128" layer="16"/>
<wire x1="148.438" y1="39.218" x2="148.59" y2="39.218" width="0.8128" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="R28" pad="1"/>
<contactref element="C13" pad="1"/>
<wire x1="148.59" y1="32.89" x2="150.848" y2="32.89" width="0.8128" layer="16"/>
<wire x1="150.848" y1="32.89" x2="152.248" y2="34.29" width="0.8128" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="D11" pad="2"/>
<contactref element="D12" pad="2"/>
<contactref element="L2" pad="1"/>
<wire x1="110.49" y1="49.53" x2="113.03" y2="49.53" width="2.54" layer="16"/>
<wire x1="113.03" y1="49.53" x2="114.935" y2="47.625" width="2.54" layer="16"/>
<wire x1="114.935" y1="47.625" x2="114.935" y2="31.75" width="2.54" layer="16"/>
<wire x1="114.935" y1="31.75" x2="113.665" y2="30.48" width="2.54" layer="16"/>
<wire x1="113.665" y1="30.48" x2="110.49" y2="30.48" width="2.54" layer="16"/>
<wire x1="120.65" y1="31.75" x2="114.935" y2="31.75" width="2.54" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="D11" pad="3"/>
<contactref element="D12" pad="1"/>
<contactref element="TR1" pad="10"/>
<wire x1="86.1568" y1="50.5968" x2="84.2518" y2="50.5968" width="2.54" layer="16"/>
<wire x1="84.2518" y1="50.5968" x2="82.55" y2="48.895" width="2.54" layer="16"/>
<wire x1="82.55" y1="48.895" x2="82.55" y2="40.005" width="2.54" layer="16"/>
<wire x1="82.55" y1="40.005" x2="82.55" y2="23.495" width="2.54" layer="16"/>
<wire x1="82.55" y1="23.495" x2="84.455" y2="21.59" width="2.54" layer="16"/>
<wire x1="84.455" y1="21.59" x2="107.188" y2="21.59" width="2.54" layer="16"/>
<wire x1="107.188" y1="21.59" x2="110.49" y2="24.892" width="2.54" layer="16"/>
<wire x1="110.49" y1="55.118" x2="109.728" y2="55.118" width="2.54" layer="16"/>
<wire x1="109.728" y1="55.118" x2="106.045" y2="51.435" width="2.54" layer="16"/>
<wire x1="106.045" y1="51.435" x2="106.045" y2="41.275" width="2.54" layer="16"/>
<wire x1="106.045" y1="41.275" x2="104.775" y2="40.005" width="2.54" layer="16"/>
<wire x1="104.775" y1="40.005" x2="82.55" y2="40.005" width="2.54" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="VR1" pad="A"/>
<contactref element="R27" pad="1"/>
<contactref element="C14" pad="-"/>
<contactref element="C15" pad="-"/>
<contactref element="X2" pad="2"/>
<contactref element="TP1" pad="TP"/>
<wire x1="142.8496" y1="58.3946" x2="142.875" y2="58.42" width="2.54" layer="16"/>
<wire x1="142.875" y1="58.42" x2="124.46" y2="58.42" width="2.54" layer="16"/>
<wire x1="154.305" y1="41.275" x2="153.67" y2="41.91" width="0.8128" layer="16"/>
<wire x1="154.305" y1="41.91" x2="151.13" y2="41.91" width="0.8128" layer="16"/>
<wire x1="151.13" y1="41.91" x2="148.742" y2="41.91" width="0.8128" layer="16"/>
<wire x1="148.742" y1="41.91" x2="148.59" y2="42.062" width="0.8128" layer="16"/>
<wire x1="148.59" y1="42.062" x2="148.742" y2="42.062" width="0.8128" layer="16"/>
<wire x1="124.46" y1="58.42" x2="104.775" y2="58.42" width="2.54" layer="16"/>
<wire x1="104.775" y1="58.42" x2="98.7425" y2="52.3875" width="2.54" layer="16"/>
<wire x1="98.7425" y1="52.3875" x2="98.425" y2="52.07" width="2.54" layer="16"/>
<wire x1="142.8496" y1="58.3946" x2="145.4404" y2="58.3946" width="2.54" layer="16"/>
<wire x1="145.4404" y1="58.3946" x2="149.225" y2="54.61" width="2.54" layer="16"/>
<wire x1="149.225" y1="54.61" x2="151.13" y2="54.61" width="2.54" layer="16"/>
<wire x1="151.13" y1="54.61" x2="156.21" y2="54.61" width="2.54" layer="16"/>
<wire x1="148.59" y1="42.062" x2="148.59" y2="41.91" width="0.8128" layer="16"/>
<wire x1="148.59" y1="41.91" x2="148.742" y2="41.91" width="0.8128" layer="16"/>
<wire x1="158.115" y1="54.61" x2="156.2354" y2="54.61" width="0.8128" layer="16"/>
<wire x1="156.2354" y1="54.61" x2="156.21" y2="54.5846" width="0.8128" layer="16"/>
<wire x1="154.305" y1="41.91" x2="154.305" y2="41.275" width="0.8128" layer="16"/>
<wire x1="154.305" y1="40.64" x2="154.305" y2="41.275" width="0.8128" layer="16"/>
<wire x1="151.13" y1="41.91" x2="151.13" y2="45.4025" width="0.8128" layer="16"/>
<via x="151.13" y="45.4025" extent="1-16" drill="0.5" diameter="1.6764" shape="square"/>
<wire x1="151.13" y1="45.4025" x2="151.13" y2="54.61" width="0.8128" layer="1"/>
<via x="151.13" y="54.61" extent="1-16" drill="0.5" diameter="1.6764" shape="square"/>
<wire x1="151.13" y1="54.61" x2="156.1846" y2="54.61" width="0.8128" layer="16"/>
<wire x1="156.1846" y1="54.61" x2="156.21" y2="54.5846" width="0.8128" layer="16"/>
<wire x1="105.0925" y1="58.1025" x2="104.775" y2="58.42" width="2.54" layer="16"/>
<wire x1="104.775" y1="58.42" x2="100.33" y2="58.42" width="2.54" layer="16"/>
<wire x1="100.33" y1="58.42" x2="94.2975" y2="52.3875" width="2.54" layer="16"/>
<wire x1="94.2975" y1="52.3875" x2="93.98" y2="52.07" width="2.54" layer="16"/>
<wire x1="93.98" y1="52.07" x2="98.425" y2="52.07" width="2.54" layer="16"/>
<wire x1="98.425" y1="52.07" x2="97.79" y2="52.07" width="2.54" layer="16"/>
<wire x1="97.79" y1="52.07" x2="97.4725" y2="52.3875" width="2.54" layer="16"/>
<wire x1="97.4725" y1="52.3875" x2="97.4725" y2="53.0225" width="2.54" layer="16"/>
<wire x1="97.4725" y1="53.0225" x2="101.2825" y2="56.8325" width="2.54" layer="16"/>
<wire x1="105.0925" y1="58.1025" x2="116.84" y2="58.1025" width="2.54" layer="16"/>
<wire x1="100.33" y1="58.42" x2="102.87" y2="60.96" width="2.54" layer="16"/>
<wire x1="102.87" y1="60.96" x2="142.24" y2="60.96" width="2.54" layer="16"/>
<wire x1="142.24" y1="60.96" x2="142.5575" y2="60.96" width="2.54" layer="16"/>
<wire x1="142.5575" y1="60.96" x2="145.7325" y2="57.785" width="2.54" layer="16"/>
<wire x1="145.7325" y1="57.785" x2="145.415" y2="57.785" width="2.54" layer="16"/>
<wire x1="145.415" y1="57.785" x2="142.24" y2="60.96" width="2.54" layer="16"/>
<wire x1="142.5575" y1="60.96" x2="146.685" y2="60.96" width="2.54" layer="16"/>
<wire x1="146.685" y1="60.96" x2="152.4" y2="55.245" width="2.54" layer="16"/>
<wire x1="152.4" y1="55.245" x2="156.845" y2="55.245" width="2.54" layer="16"/>
<wire x1="156.5275" y1="54.2925" x2="156.21" y2="54.2925" width="2.54" layer="16"/>
<wire x1="151.13" y1="54.2925" x2="146.3675" y2="54.2925" width="2.54" layer="16"/>
<wire x1="146.3675" y1="54.2925" x2="144.78" y2="55.88" width="2.54" layer="16"/>
<wire x1="144.78" y1="55.88" x2="115.57" y2="55.88" width="2.54" layer="16"/>
<wire x1="115.57" y1="55.88" x2="113.9825" y2="57.4675" width="2.54" layer="16"/>
<wire x1="113.9825" y1="57.4675" x2="141.605" y2="57.4675" width="2.54" layer="16"/>
<wire x1="141.605" y1="57.4675" x2="142.5575" y2="56.515" width="2.54" layer="16"/>
<wire x1="156.845" y1="55.245" x2="156.845" y2="54.9275" width="2.54" layer="16"/>
<wire x1="156.845" y1="54.9275" x2="156.21" y2="54.2925" width="2.54" layer="16"/>
<wire x1="156.21" y1="54.2925" x2="151.13" y2="54.2925" width="2.54" layer="16"/>
<wire x1="151.13" y1="54.2925" x2="146.3675" y2="59.055" width="2.54" layer="16"/>
<wire x1="98.7425" y1="52.3875" x2="98.7425" y2="45.085" width="2.54" layer="16"/>
<wire x1="98.7425" y1="45.085" x2="93.0275" y2="45.085" width="2.54" layer="16"/>
<wire x1="93.0275" y1="45.085" x2="93.0275" y2="51.1175" width="2.54" layer="16"/>
<wire x1="93.0275" y1="51.1175" x2="93.98" y2="52.07" width="2.54" layer="16"/>
<wire x1="94.2975" y1="52.3875" x2="94.2975" y2="46.6725" width="2.54" layer="16"/>
<wire x1="94.2975" y1="46.6725" x2="94.615" y2="46.355" width="2.54" layer="16"/>
<wire x1="94.615" y1="46.355" x2="96.52" y2="46.355" width="2.54" layer="16"/>
<wire x1="96.52" y1="46.355" x2="96.52" y2="50.165" width="2.54" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="R25" pad="2"/>
<contactref element="R26" pad="2"/>
<contactref element="L2" pad="2"/>
<contactref element="C15" pad="+"/>
<contactref element="C14" pad="+"/>
<contactref element="X2" pad="1"/>
<wire x1="127.635" y1="31.75" x2="127.635" y2="47.625" width="2.54" layer="16"/>
<wire x1="127.635" y1="47.625" x2="124.46" y2="50.8" width="2.54" layer="16"/>
<wire x1="124.46" y1="50.8" x2="142.24" y2="50.8" width="2.54" layer="16"/>
<wire x1="142.24" y1="50.8" x2="142.875" y2="50.8" width="2.54" layer="16"/>
<wire x1="142.24" y1="35.077" x2="140.818" y2="35.077" width="0.8128" layer="16"/>
<wire x1="140.818" y1="35.077" x2="139.7" y2="36.195" width="0.8128" layer="16"/>
<wire x1="139.7" y1="36.195" x2="139.7" y2="41.275" width="0.8128" layer="16"/>
<wire x1="139.7" y1="41.275" x2="140.335" y2="41.91" width="0.8128" layer="16"/>
<wire x1="140.335" y1="41.91" x2="142.088" y2="41.91" width="0.8128" layer="16"/>
<wire x1="142.088" y1="41.91" x2="142.24" y2="42.062" width="0.8128" layer="16"/>
<wire x1="142.24" y1="42.062" x2="142.24" y2="50.8" width="0.8128" layer="16"/>
<wire x1="142.875" y1="50.8" x2="144.145" y2="50.8" width="2.54" layer="16"/>
<wire x1="144.145" y1="50.8" x2="145.415" y2="49.53" width="2.54" layer="16"/>
<wire x1="145.415" y1="49.53" x2="156.1846" y2="49.53" width="2.54" layer="16"/>
<wire x1="156.1846" y1="49.53" x2="156.21" y2="49.5554" width="2.54" layer="16"/>
</signal>
<signal name="N$33">
<contactref element="TR1" pad="1"/>
<contactref element="R20" pad="2"/>
<contactref element="C16" pad="1"/>
<wire x1="61.1632" y1="50.5968" x2="54.8132" y2="50.5968" width="2.54" layer="16"/>
<wire x1="54.8132" y1="50.5968" x2="50.8" y2="54.61" width="2.54" layer="16"/>
<wire x1="50.8" y1="54.61" x2="45.085" y2="60.325" width="2.54" layer="16"/>
<wire x1="45.085" y1="60.325" x2="36.322" y2="60.325" width="2.54" layer="16"/>
</signal>
<signal name="OE">
<contactref element="J3" pad="5"/>
<contactref element="R11" pad="2"/>
<contactref element="OK1" pad="3"/>
<wire x1="28.575" y1="27.305" x2="27.305" y2="27.305" width="0.6096" layer="16"/>
<wire x1="74.295" y1="13.335" x2="36.195" y2="13.335" width="0.8128" layer="16"/>
<wire x1="27.305" y1="27.305" x2="27.94" y2="27.305" width="0.6096" layer="16"/>
<wire x1="27.94" y1="27.305" x2="31.75" y2="23.495" width="0.6096" layer="16"/>
<wire x1="31.75" y1="23.495" x2="33.02" y2="23.495" width="0.6096" layer="16"/>
<wire x1="33.02" y1="23.495" x2="33.655" y2="22.86" width="0.6096" layer="16"/>
<wire x1="33.655" y1="22.86" x2="33.655" y2="17.78" width="0.6096" layer="16"/>
<wire x1="33.655" y1="17.78" x2="35.56" y2="15.875" width="0.8128" layer="16"/>
<wire x1="35.56" y1="15.875" x2="35.56" y2="13.97" width="0.8128" layer="16"/>
<wire x1="35.56" y1="13.97" x2="36.195" y2="13.335" width="0.8128" layer="16"/>
<contactref element="J5" pad="5"/>
<wire x1="14.9225" y1="24.765" x2="27.305" y2="27.305" width="0" layer="19" extent="1-16"/>
<wire x1="14.9225" y1="24.765" x2="14.9225" y2="34.925" width="0.6096" layer="16"/>
<wire x1="14.9225" y1="34.925" x2="15.5575" y2="35.56" width="0.6096" layer="16"/>
<wire x1="15.5575" y1="35.56" x2="15.5575" y2="37.948" width="0.6096" layer="16"/>
<wire x1="15.5575" y1="37.948" x2="15.5575" y2="38.1" width="0.6096" layer="16"/>
</signal>
<signal name="OC">
<contactref element="J3" pad="6"/>
<contactref element="OK1" pad="4"/>
<contactref element="C3" pad="2"/>
<contactref element="IC1" pad="14"/>
<contactref element="R5" pad="2"/>
<contactref element="R7" pad="2"/>
<wire x1="74.295" y1="10.795" x2="33.655" y2="10.795" width="0.8128" layer="16"/>
<wire x1="27.305" y1="24.765" x2="27.305" y2="19.685" width="0.6096" layer="16"/>
<wire x1="33.02" y1="13.97" x2="33.02" y2="11.43" width="0.8128" layer="16"/>
<wire x1="33.02" y1="11.43" x2="33.655" y2="10.795" width="0.8128" layer="16"/>
<wire x1="27.305" y1="19.685" x2="33.02" y2="13.97" width="0.8128" layer="16"/>
<contactref element="J5" pad="6"/>
<wire x1="17.4625" y1="24.765" x2="27.305" y2="24.765" width="0" layer="19" extent="1-16"/>
<wire x1="3.4925" y1="51.5366" x2="3.4925" y2="53.975" width="0.6096" layer="16"/>
<wire x1="3.4925" y1="53.975" x2="-0.8225" y2="53.975" width="0.6096" layer="16"/>
<wire x1="-0.8225" y1="53.975" x2="-1.5875" y2="53.21" width="0.6096" layer="16"/>
<contactref element="IC1" pad="13"/>
<wire x1="3.4925" y1="51.5366" x2="4.6609" y2="51.5366" width="0.6096" layer="16"/>
<wire x1="4.6609" y1="51.5366" x2="4.7625" y2="51.435" width="0.6096" layer="16"/>
<wire x1="-4.7625" y1="57.633" x2="-4.7625" y2="55.245" width="0.6096" layer="16"/>
<wire x1="-2.8575" y1="53.34" x2="-1.7175" y2="53.34" width="0.6096" layer="16"/>
<wire x1="-1.7175" y1="53.34" x2="-1.5875" y2="53.21" width="0.6096" layer="16"/>
<wire x1="4.7625" y1="51.435" x2="3.4925" y2="51.435" width="0.6096" layer="16"/>
<wire x1="3.4925" y1="51.435" x2="3.4925" y2="51.5366" width="0.6096" layer="16"/>
<wire x1="-0.8225" y1="53.975" x2="-0.9525" y2="53.975" width="0.6096" layer="16"/>
<wire x1="-0.9525" y1="53.975" x2="-1.5875" y2="53.34" width="0.6096" layer="16"/>
<wire x1="-1.5875" y1="53.34" x2="-1.7175" y2="53.34" width="0.6096" layer="16"/>
<wire x1="-2.8575" y1="53.34" x2="-4.7625" y2="55.245" width="0.6096" layer="16"/>
<wire x1="-4.7625" y1="57.633" x2="-4.7625" y2="57.785" width="0.6096" layer="16"/>
<wire x1="-7.9375" y1="69.85" x2="15.5575" y2="69.85" width="0.6096" layer="16"/>
<wire x1="15.5575" y1="69.85" x2="18.0975" y2="67.31" width="0.6096" layer="16"/>
<wire x1="18.0975" y1="67.31" x2="18.0975" y2="27.305" width="0.6096" layer="16"/>
<wire x1="18.0975" y1="27.305" x2="17.4625" y2="26.67" width="0.6096" layer="16"/>
<wire x1="17.4625" y1="26.67" x2="17.4625" y2="24.765" width="0.6096" layer="16"/>
<wire x1="-4.7625" y1="52.222" x2="-3.9755" y2="52.222" width="0.6096" layer="16"/>
<wire x1="-3.9755" y1="52.222" x2="-2.8575" y2="53.34" width="0.6096" layer="16"/>
<wire x1="-4.7625" y1="57.785" x2="-9.2075" y2="57.785" width="0.6096" layer="16"/>
<wire x1="-9.2075" y1="57.785" x2="-10.4775" y2="59.055" width="0.6096" layer="16"/>
<wire x1="-10.4775" y1="59.055" x2="-10.4775" y2="67.31" width="0.6096" layer="16"/>
<wire x1="-10.4775" y1="67.31" x2="-7.9375" y2="69.85" width="0.6096" layer="16"/>
<wire x1="4.7625" y1="51.435" x2="4.7625" y2="51.5366" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$5">
<contactref element="U$1" pad="1"/>
<contactref element="R1" pad="1"/>
<contactref element="D3" pad="C"/>
<wire x1="9.2075" y1="31.267" x2="11.2645" y2="31.267" width="0.8128" layer="16"/>
<wire x1="11.2645" y1="31.267" x2="12.3825" y2="32.385" width="0.8128" layer="16"/>
<wire x1="12.3825" y1="32.385" x2="12.3825" y2="32.68" width="0.8128" layer="16"/>
<wire x1="9.8425" y1="38.4175" x2="9.8425" y2="36.83" width="0.6096" layer="16"/>
<wire x1="9.8425" y1="36.83" x2="12.3825" y2="34.29" width="0.6096" layer="16"/>
<wire x1="12.3825" y1="34.29" x2="12.3825" y2="32.68" width="0.6096" layer="16"/>
</signal>
<signal name="HO">
<contactref element="J2" pad="5"/>
<contactref element="R2" pad="2"/>
<contactref element="Q1" pad="G"/>
<contactref element="D2" pad="A"/>
<contactref element="D4" pad="C"/>
<wire x1="34.925" y1="48.895" x2="33.655" y2="48.895" width="1.016" layer="16"/>
<wire x1="33.655" y1="48.895" x2="31.75" y2="46.99" width="1.016" layer="16"/>
<wire x1="31.75" y1="46.99" x2="31.75" y2="45.085" width="1.016" layer="16"/>
<wire x1="31.75" y1="43.815" x2="30.48" y2="42.545" width="1.016" layer="16"/>
<wire x1="30.48" y1="42.545" x2="27.305" y2="42.545" width="1.016" layer="16"/>
<wire x1="31.75" y1="43.815" x2="31.75" y2="45.085" width="1.016" layer="16"/>
<wire x1="31.75" y1="45.085" x2="31.115" y2="45.085" width="1.016" layer="16"/>
<contactref element="J4" pad="5"/>
<wire x1="27.305" y1="42.545" x2="-0.3175" y2="24.765" width="0" layer="19" extent="1-16"/>
<wire x1="-3.4925" y1="28.28" x2="-0.4605" y2="28.28" width="0.8128" layer="16"/>
<wire x1="-0.4605" y1="28.28" x2="-0.3175" y2="28.423" width="0.6096" layer="16"/>
<wire x1="-0.3175" y1="28.423" x2="-0.3175" y2="24.765" width="0.8128" layer="16"/>
<wire x1="31.115" y1="45.085" x2="31.115" y2="45.17" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$1">
<contactref element="OK1" pad="2"/>
<contactref element="R29" pad="1"/>
<contactref element="R24" pad="1"/>
<wire x1="140.818" y1="29.21" x2="140.335" y2="29.21" width="0.8128" layer="16"/>
<wire x1="140.335" y1="29.21" x2="125.73" y2="14.605" width="0.8128" layer="16"/>
<wire x1="125.73" y1="14.605" x2="86.36" y2="14.605" width="0.8128" layer="16"/>
<wire x1="86.36" y1="14.605" x2="85.725" y2="13.97" width="0.8128" layer="16"/>
<wire x1="81.915" y1="13.335" x2="84.938" y2="13.335" width="0.8128" layer="16"/>
<wire x1="84.938" y1="13.335" x2="85.725" y2="14.122" width="0.8128" layer="16"/>
<wire x1="85.725" y1="13.97" x2="85.725" y2="14.122" width="0.8128" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="R28" pad="2"/>
<contactref element="VR1" pad="C"/>
<contactref element="R29" pad="2"/>
<wire x1="155.575" y1="38.735" x2="155.575" y2="34.29" width="0.8128" layer="16"/>
<wire x1="155.092" y1="34.29" x2="154.94" y2="34.29" width="0.8128" layer="16"/>
<wire x1="154.94" y1="34.29" x2="149.86" y2="29.21" width="0.8128" layer="16"/>
<wire x1="149.86" y1="29.21" x2="143.662" y2="29.21" width="0.8128" layer="16"/>
<wire x1="155.092" y1="34.29" x2="155.575" y2="34.29" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$29">
<wire x1="95.885" y1="67.945" x2="96.52" y2="67.945" width="2.54" layer="16"/>
<wire x1="96.52" y1="67.945" x2="97.155" y2="67.945" width="2.54" layer="16"/>
<wire x1="96.52" y1="67.945" x2="96.52" y2="64.77" width="2.54" layer="16"/>
</signal>
<signal name="N$34">
<wire x1="96.52" y1="78.105" x2="95.885" y2="78.105" width="2.54" layer="16"/>
<wire x1="96.52" y1="78.105" x2="96.52" y2="76.835" width="2.54" layer="16"/>
</signal>
<signal name="N$35">
<wire x1="96.52" y1="83.185" x2="97.155" y2="83.185" width="2.54" layer="16"/>
</signal>
<signal name="N$36">
<contactref element="J4" pad="4"/>
<contactref element="J2" pad="4"/>
<wire x1="27.305" y1="45.085" x2="-2.8575" y2="24.765" width="0" layer="19" extent="1-16"/>
</signal>
<signal name="N$43">
<contactref element="J2" pad="3"/>
<contactref element="J4" pad="3"/>
<wire x1="27.305" y1="47.625" x2="-5.3975" y2="24.765" width="0" layer="19" extent="1-16"/>
</signal>
<signal name="N$44">
<contactref element="J2" pad="2"/>
<contactref element="J4" pad="2"/>
<wire x1="27.305" y1="50.165" x2="-7.9375" y2="24.765" width="0" layer="19" extent="1-16"/>
</signal>
<signal name="N$8">
<wire x1="9.8425" y1="43.815" x2="9.8425" y2="46.355" width="0.6096" layer="16"/>
</signal>
<signal name="N$28">
<wire x1="2.2225" y1="43.815" x2="2.2225" y2="46.355" width="0.6096" layer="16"/>
</signal>
<signal name="N$45">
<wire x1="0.9525" y1="43.815" x2="0.9525" y2="46.355" width="0.6096" layer="16"/>
</signal>
<signal name="N$46">
<wire x1="159.7025" y1="87.63" x2="23.1775" y2="87.63" width="1.9304" layer="16"/>
<wire x1="23.1775" y1="87.63" x2="23.1775" y2="79.0575" width="1.9304" layer="16"/>
<wire x1="23.1775" y1="79.0575" x2="23.495" y2="79.0575" width="1.9304" layer="16"/>
<wire x1="23.495" y1="79.0575" x2="31.75" y2="87.3125" width="1.9304" layer="16"/>
<wire x1="159.7025" y1="87.63" x2="159.7025" y2="17.78" width="1.9304" layer="16"/>
<wire x1="159.7025" y1="17.78" x2="159.7025" y2="8.5725" width="1.9304" layer="16"/>
<wire x1="159.7025" y1="8.5725" x2="150.495" y2="8.5725" width="1.9304" layer="16"/>
<wire x1="150.495" y1="8.5725" x2="31.4325" y2="8.5725" width="1.9304" layer="16"/>
<wire x1="31.4325" y1="8.5725" x2="23.1775" y2="8.5725" width="1.9304" layer="16"/>
<wire x1="23.1775" y1="8.5725" x2="23.1775" y2="16.8275" width="1.9304" layer="16"/>
<wire x1="23.1775" y1="16.8275" x2="31.4325" y2="8.5725" width="1.9304" layer="16"/>
<wire x1="150.495" y1="8.5725" x2="159.7025" y2="17.78" width="1.9304" layer="16"/>
</signal>
<signal name="N$48">
<wire x1="109.855" y1="81.915" x2="113.665" y2="81.915" width="2.54" layer="16"/>
<wire x1="109.855" y1="81.915" x2="109.855" y2="79.375" width="2.54" layer="16"/>
<wire x1="109.855" y1="79.375" x2="113.9825" y2="79.375" width="2.54" layer="16"/>
<wire x1="113.9825" y1="79.375" x2="113.9825" y2="81.915" width="2.54" layer="16"/>
<wire x1="113.9825" y1="81.915" x2="113.665" y2="81.915" width="2.54" layer="16"/>
<wire x1="113.665" y1="81.915" x2="112.395" y2="80.645" width="2.54" layer="16"/>
</signal>
<signal name="N$49">
<wire x1="125.4125" y1="81.915" x2="120.65" y2="81.915" width="2.54" layer="16"/>
<wire x1="120.65" y1="81.915" x2="120.65" y2="79.375" width="2.54" layer="16"/>
<wire x1="120.65" y1="79.375" x2="124.7775" y2="79.375" width="2.54" layer="16"/>
<wire x1="124.7775" y1="79.375" x2="124.7775" y2="81.5975" width="2.54" layer="16"/>
</signal>
<signal name="N$50">
<wire x1="110.1725" y1="69.215" x2="113.9825" y2="69.215" width="2.54" layer="16"/>
<wire x1="113.9825" y1="69.215" x2="113.9825" y2="71.755" width="2.54" layer="16"/>
<wire x1="113.9825" y1="71.755" x2="113.665" y2="72.0725" width="2.54" layer="16"/>
<wire x1="113.665" y1="72.0725" x2="113.9825" y2="72.0725" width="2.54" layer="16"/>
<wire x1="113.665" y1="72.0725" x2="109.855" y2="72.0725" width="2.54" layer="16"/>
<wire x1="109.855" y1="72.0725" x2="109.855" y2="70.1675" width="2.54" layer="16"/>
<wire x1="109.855" y1="70.1675" x2="110.1725" y2="69.85" width="2.54" layer="16"/>
<wire x1="110.1725" y1="69.85" x2="111.4425" y2="69.85" width="2.54" layer="16"/>
<wire x1="111.4425" y1="69.85" x2="112.0775" y2="70.485" width="2.54" layer="16"/>
</signal>
<signal name="N$51">
<wire x1="125.095" y1="69.215" x2="120.9675" y2="69.215" width="2.54" layer="16"/>
<wire x1="125.095" y1="69.215" x2="125.095" y2="72.39" width="2.54" layer="16"/>
<wire x1="125.095" y1="72.39" x2="120.9675" y2="72.39" width="2.54" layer="16"/>
<wire x1="120.9675" y1="72.39" x2="120.9675" y2="70.1675" width="2.54" layer="16"/>
<wire x1="120.9675" y1="69.5325" x2="120.9675" y2="70.1675" width="2.54" layer="16"/>
<wire x1="120.9675" y1="70.1675" x2="121.92" y2="71.12" width="2.54" layer="16"/>
<wire x1="121.92" y1="71.12" x2="123.19" y2="71.12" width="2.54" layer="16"/>
<wire x1="123.19" y1="71.12" x2="123.5075" y2="70.8025" width="2.54" layer="16"/>
</signal>
<signal name="N$52">
<wire x1="110.8075" y1="54.9275" x2="106.9975" y2="54.9275" width="2.54" layer="16"/>
<wire x1="106.9975" y1="54.9275" x2="102.87" y2="50.8" width="2.54" layer="16"/>
<wire x1="102.87" y1="50.8" x2="102.87" y2="42.8625" width="2.54" layer="16"/>
<wire x1="102.87" y1="42.8625" x2="101.6" y2="41.5925" width="2.54" layer="16"/>
<wire x1="101.6" y1="41.5925" x2="82.55" y2="41.5925" width="2.54" layer="16"/>
<wire x1="82.55" y1="41.5925" x2="82.2325" y2="41.91" width="2.54" layer="16"/>
</signal>
<signal name="N$53">
<wire x1="86.36" y1="50.4825" x2="82.2325" y2="50.4825" width="2.54" layer="16"/>
<wire x1="82.2325" y1="50.4825" x2="80.9625" y2="49.2125" width="2.54" layer="16"/>
<wire x1="80.9625" y1="49.2125" x2="80.9625" y2="22.225" width="2.54" layer="16"/>
<wire x1="80.9625" y1="22.225" x2="82.8675" y2="20.32" width="2.54" layer="16"/>
<wire x1="82.8675" y1="20.32" x2="107.6325" y2="20.32" width="2.54" layer="16"/>
<wire x1="107.6325" y1="20.32" x2="111.4425" y2="24.13" width="2.54" layer="16"/>
<wire x1="111.4425" y1="24.13" x2="111.4425" y2="24.4475" width="2.54" layer="16"/>
<wire x1="111.4425" y1="24.4475" x2="111.125" y2="24.765" width="2.54" layer="16"/>
<wire x1="82.2325" y1="50.4825" x2="83.185" y2="51.435" width="2.54" layer="16"/>
<wire x1="83.185" y1="51.435" x2="86.0425" y2="51.435" width="2.54" layer="16"/>
<wire x1="86.0425" y1="51.435" x2="86.36" y2="51.1175" width="2.54" layer="16"/>
<wire x1="111.125" y1="24.765" x2="103.8225" y2="24.765" width="2.54" layer="16"/>
<wire x1="103.8225" y1="24.765" x2="100.0125" y2="20.955" width="2.54" layer="16"/>
<wire x1="100.0125" y1="20.955" x2="102.5525" y2="20.955" width="2.54" layer="16"/>
<wire x1="102.5525" y1="20.955" x2="104.4575" y2="22.86" width="2.54" layer="16"/>
<wire x1="104.4575" y1="22.86" x2="106.3625" y2="22.86" width="2.54" layer="16"/>
</signal>
<signal name="N$55">
<wire x1="110.8075" y1="43.815" x2="109.5375" y2="43.815" width="2.54" layer="16"/>
<wire x1="109.5375" y1="43.815" x2="109.5375" y2="35.8775" width="2.54" layer="16"/>
<wire x1="109.5375" y1="35.8775" x2="109.22" y2="35.56" width="2.54" layer="16"/>
<wire x1="110.49" y1="35.8775" x2="110.49" y2="34.925" width="2.54" layer="16"/>
<wire x1="110.49" y1="34.925" x2="100.6475" y2="34.925" width="2.54" layer="16"/>
<wire x1="100.6475" y1="34.925" x2="91.1225" y2="25.4" width="2.54" layer="16"/>
<wire x1="91.1225" y1="25.4" x2="86.0425" y2="25.4" width="2.54" layer="16"/>
<wire x1="86.0425" y1="25.4" x2="86.0425" y2="26.3525" width="2.54" layer="16"/>
<contactref element="D11" pad="1"/>
<contactref element="D12" pad="3"/>
<contactref element="TR1" pad="6"/>
<wire x1="86.1568" y1="25.6032" x2="89.1032" y2="25.6032" width="2.54" layer="16"/>
<wire x1="89.1032" y1="25.6032" x2="89.8525" y2="26.3525" width="2.54" layer="16"/>
<wire x1="89.8525" y1="26.3525" x2="99.695" y2="36.195" width="2.54" layer="16"/>
<wire x1="99.695" y1="36.195" x2="110.363" y2="36.195" width="2.54" layer="16"/>
<wire x1="110.363" y1="36.195" x2="110.49" y2="36.068" width="2.54" layer="16"/>
<wire x1="110.49" y1="36.068" x2="110.49" y2="43.942" width="2.54" layer="16"/>
<wire x1="86.0425" y1="26.3525" x2="89.8525" y2="26.3525" width="2.54" layer="16"/>
<wire x1="109.22" y1="35.56" x2="110.1725" y2="35.56" width="2.54" layer="16"/>
<wire x1="110.1725" y1="35.56" x2="110.49" y2="35.8775" width="2.54" layer="16"/>
<wire x1="110.49" y1="35.8775" x2="110.49" y2="42.8625" width="2.54" layer="16"/>
<wire x1="110.49" y1="42.8625" x2="111.125" y2="43.4975" width="2.54" layer="16"/>
<wire x1="111.125" y1="43.4975" x2="111.125" y2="34.925" width="2.54" layer="16"/>
<wire x1="111.125" y1="34.925" x2="101.9175" y2="34.925" width="2.54" layer="16"/>
<wire x1="101.9175" y1="34.925" x2="92.3925" y2="25.4" width="2.54" layer="16"/>
<wire x1="92.3925" y1="25.4" x2="91.1225" y2="25.4" width="2.54" layer="16"/>
<wire x1="92.3925" y1="25.4" x2="98.425" y2="25.4" width="2.54" layer="16"/>
<wire x1="98.425" y1="25.4" x2="107.315" y2="34.29" width="2.54" layer="16"/>
<wire x1="107.315" y1="34.29" x2="104.14" y2="34.29" width="2.54" layer="16"/>
<wire x1="104.14" y1="34.29" x2="103.505" y2="33.655" width="2.54" layer="16"/>
<wire x1="103.505" y1="33.655" x2="102.87" y2="33.655" width="2.54" layer="16"/>
<wire x1="102.87" y1="33.655" x2="96.52" y2="27.305" width="2.54" layer="16"/>
<wire x1="96.52" y1="27.305" x2="98.7425" y2="27.305" width="2.54" layer="16"/>
<wire x1="98.7425" y1="27.305" x2="104.14" y2="32.7025" width="2.54" layer="16"/>
</signal>
<signal name="N$56">
<wire x1="109.855" y1="49.53" x2="111.76" y2="51.435" width="2.54" layer="16"/>
<wire x1="111.76" y1="51.435" x2="114.3" y2="51.435" width="2.54" layer="16"/>
<wire x1="114.3" y1="51.435" x2="116.205" y2="49.53" width="2.54" layer="16"/>
<wire x1="116.205" y1="49.53" x2="116.205" y2="30.1625" width="2.54" layer="16"/>
<wire x1="116.205" y1="30.1625" x2="115.2525" y2="29.21" width="2.54" layer="16"/>
<wire x1="115.2525" y1="29.21" x2="114.935" y2="29.21" width="2.54" layer="16"/>
<wire x1="114.935" y1="29.21" x2="109.5375" y2="29.21" width="2.54" layer="16"/>
<wire x1="109.5375" y1="29.21" x2="109.5375" y2="30.48" width="2.54" layer="16"/>
<wire x1="109.5375" y1="30.48" x2="113.665" y2="30.48" width="2.54" layer="16"/>
<wire x1="113.665" y1="30.48" x2="114.935" y2="29.21" width="2.54" layer="16"/>
<wire x1="115.2525" y1="29.21" x2="122.2375" y2="29.21" width="2.54" layer="16"/>
<wire x1="122.2375" y1="29.21" x2="122.2375" y2="43.4975" width="2.54" layer="16"/>
<wire x1="122.2375" y1="43.4975" x2="116.5225" y2="49.2125" width="2.54" layer="16"/>
<wire x1="116.5225" y1="49.2125" x2="116.5225" y2="34.925" width="2.54" layer="16"/>
<wire x1="116.5225" y1="34.925" x2="118.4275" y2="33.02" width="2.54" layer="16"/>
<wire x1="118.4275" y1="33.02" x2="120.015" y2="33.02" width="2.54" layer="16"/>
<wire x1="120.015" y1="33.02" x2="120.015" y2="43.4975" width="2.54" layer="16"/>
<wire x1="120.015" y1="43.4975" x2="118.745" y2="44.7675" width="2.54" layer="16"/>
<wire x1="118.745" y1="44.7675" x2="118.4275" y2="44.7675" width="2.54" layer="16"/>
<wire x1="118.4275" y1="44.7675" x2="118.11" y2="45.085" width="2.54" layer="16"/>
<wire x1="118.11" y1="45.085" x2="118.11" y2="34.6075" width="2.54" layer="16"/>
</signal>
<signal name="N$57">
<wire x1="156.21" y1="49.53" x2="156.21" y2="48.895" width="2.54" layer="16"/>
<wire x1="154.94" y1="47.625" x2="155.2575" y2="47.625" width="2.54" layer="16"/>
<wire x1="155.2575" y1="47.625" x2="156.5275" y2="48.895" width="2.54" layer="16"/>
<wire x1="156.5275" y1="48.895" x2="156.21" y2="48.895" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$58">
<wire x1="146.05" y1="48.5775" x2="146.05" y2="47.9425" width="2.54" layer="16"/>
<wire x1="146.05" y1="47.9425" x2="156.21" y2="47.9425" width="2.54" layer="16"/>
<wire x1="156.21" y1="47.9425" x2="156.845" y2="48.5775" width="2.54" layer="16"/>
<wire x1="156.845" y1="48.5775" x2="156.845" y2="49.2125" width="2.54" layer="16"/>
<wire x1="156.845" y1="49.2125" x2="147.955" y2="49.2125" width="2.54" layer="16"/>
<wire x1="147.955" y1="49.2125" x2="146.3675" y2="47.625" width="2.54" layer="16"/>
<wire x1="146.3675" y1="47.625" x2="142.875" y2="47.625" width="2.54" layer="16"/>
<wire x1="142.875" y1="47.625" x2="141.9225" y2="48.5775" width="2.54" layer="16"/>
<wire x1="141.9225" y1="48.5775" x2="127.9525" y2="48.5775" width="2.54" layer="16"/>
<wire x1="127.9525" y1="48.5775" x2="127.635" y2="48.895" width="2.54" layer="16"/>
<wire x1="127.635" y1="48.895" x2="143.8275" y2="48.895" width="2.54" layer="16"/>
<wire x1="143.8275" y1="48.895" x2="144.145" y2="48.5775" width="2.54" layer="16"/>
<wire x1="144.145" y1="48.5775" x2="128.905" y2="48.5775" width="2.54" layer="16"/>
<wire x1="128.905" y1="48.5775" x2="128.5875" y2="48.26" width="2.54" layer="16"/>
<wire x1="128.5875" y1="48.26" x2="128.5875" y2="31.75" width="2.54" layer="16"/>
<wire x1="128.5875" y1="31.75" x2="127.9525" y2="31.115" width="2.54" layer="16"/>
<wire x1="127.9525" y1="31.115" x2="131.1275" y2="31.115" width="2.54" layer="16"/>
<wire x1="131.1275" y1="31.115" x2="132.3975" y2="32.385" width="2.54" layer="16"/>
<wire x1="132.3975" y1="32.385" x2="132.3975" y2="47.3075" width="2.54" layer="16"/>
<wire x1="132.3975" y1="47.3075" x2="133.0325" y2="47.9425" width="2.54" layer="16"/>
<wire x1="133.0325" y1="47.9425" x2="130.81" y2="47.9425" width="2.54" layer="16"/>
<wire x1="130.81" y1="47.9425" x2="130.4925" y2="47.625" width="2.54" layer="16"/>
<wire x1="130.4925" y1="47.625" x2="130.4925" y2="33.02" width="2.54" layer="16"/>
<wire x1="130.4925" y1="33.02" x2="129.8575" y2="32.385" width="2.54" layer="16"/>
<wire x1="131.1275" y1="31.115" x2="138.1125" y2="31.115" width="2.54" layer="16"/>
<wire x1="138.1125" y1="31.115" x2="139.065" y2="32.0675" width="2.54" layer="16"/>
<wire x1="139.065" y1="32.0675" x2="139.065" y2="33.655" width="2.54" layer="16"/>
<wire x1="139.065" y1="33.655" x2="137.16" y2="35.56" width="2.54" layer="16"/>
<wire x1="137.16" y1="35.56" x2="137.16" y2="42.545" width="2.54" layer="16"/>
<wire x1="137.16" y1="42.545" x2="139.3825" y2="44.7675" width="2.54" layer="16"/>
<wire x1="139.3825" y1="44.7675" x2="148.2725" y2="44.7675" width="2.54" layer="16"/>
<wire x1="148.2725" y1="44.7675" x2="148.59" y2="45.085" width="2.54" layer="16"/>
<wire x1="148.59" y1="45.085" x2="148.59" y2="46.6725" width="2.54" layer="16"/>
<wire x1="148.59" y1="46.6725" x2="133.985" y2="46.6725" width="2.54" layer="16"/>
<wire x1="133.985" y1="46.6725" x2="133.985" y2="33.02" width="2.54" layer="16"/>
<wire x1="133.985" y1="33.02" x2="134.3025" y2="32.7025" width="2.54" layer="16"/>
<wire x1="134.3025" y1="32.7025" x2="136.8425" y2="32.7025" width="2.54" layer="16"/>
<wire x1="136.8425" y1="32.7025" x2="136.8425" y2="33.02" width="2.54" layer="16"/>
<wire x1="136.8425" y1="33.02" x2="135.5725" y2="34.29" width="2.54" layer="16"/>
<wire x1="135.5725" y1="34.29" x2="135.5725" y2="44.7675" width="2.54" layer="16"/>
<wire x1="135.5725" y1="44.7675" x2="135.255" y2="45.085" width="2.54" layer="16"/>
<wire x1="135.255" y1="45.085" x2="137.4775" y2="45.085" width="2.54" layer="16"/>
</signal>
<signal name="N$32">
<wire x1="109.855" y1="16.8275" x2="80.645" y2="16.8275" width="2.54" layer="16"/>
<wire x1="109.855" y1="16.8275" x2="118.4275" y2="25.4" width="2.54" layer="16"/>
<wire x1="118.4275" y1="25.4" x2="125.4125" y2="25.4" width="2.54" layer="16"/>
<wire x1="125.4125" y1="25.4" x2="127.3175" y2="27.305" width="2.54" layer="16"/>
<wire x1="127.3175" y1="27.305" x2="134.62" y2="27.305" width="2.54" layer="16"/>
<wire x1="134.62" y1="27.305" x2="124.1425" y2="16.8275" width="2.54" layer="16"/>
<wire x1="124.1425" y1="16.8275" x2="113.03" y2="16.8275" width="2.54" layer="16"/>
<wire x1="110.1725" y1="16.8275" x2="113.03" y2="16.8275" width="2.54" layer="16"/>
<wire x1="113.03" y1="16.8275" x2="119.38" y2="23.1775" width="2.54" layer="16"/>
<wire x1="119.38" y1="23.1775" x2="126.0475" y2="23.1775" width="2.54" layer="16"/>
<wire x1="126.0475" y1="23.1775" x2="127.9525" y2="25.0825" width="2.54" layer="16"/>
<wire x1="127.9525" y1="25.0825" x2="130.175" y2="25.0825" width="2.54" layer="16"/>
<wire x1="130.175" y1="25.0825" x2="130.81" y2="25.7175" width="2.54" layer="16"/>
<wire x1="130.175" y1="25.0825" x2="123.825" y2="18.7325" width="2.54" layer="16"/>
<wire x1="123.825" y1="18.7325" x2="117.1575" y2="18.7325" width="2.54" layer="16"/>
<wire x1="117.1575" y1="18.7325" x2="116.84" y2="18.415" width="2.54" layer="16"/>
<wire x1="116.84" y1="18.415" x2="118.11" y2="18.415" width="2.54" layer="16"/>
<wire x1="118.11" y1="18.415" x2="120.65" y2="20.955" width="2.54" layer="16"/>
<wire x1="120.65" y1="20.955" x2="124.1425" y2="20.955" width="2.54" layer="16"/>
<wire x1="124.1425" y1="20.955" x2="124.46" y2="21.2725" width="2.54" layer="16"/>
</signal>
<signal name="N$47">
<wire x1="131.7625" y1="11.7475" x2="146.3675" y2="26.3525" width="2.54" layer="16"/>
<wire x1="146.3675" y1="26.3525" x2="151.13" y2="26.3525" width="2.54" layer="16"/>
<wire x1="151.13" y1="26.3525" x2="155.575" y2="30.7975" width="2.54" layer="16"/>
<wire x1="155.575" y1="30.7975" x2="155.8925" y2="30.7975" width="2.54" layer="16"/>
<wire x1="155.8925" y1="30.7975" x2="156.5275" y2="31.4325" width="2.54" layer="16"/>
<wire x1="156.5275" y1="31.4325" x2="156.21" y2="31.4325" width="2.54" layer="16"/>
<wire x1="156.21" y1="31.4325" x2="155.575" y2="30.7975" width="2.54" layer="16"/>
<wire x1="156.5275" y1="31.4325" x2="156.845" y2="31.4325" width="2.54" layer="16"/>
<wire x1="156.845" y1="31.4325" x2="156.845" y2="24.4475" width="2.54" layer="16"/>
<wire x1="156.845" y1="24.4475" x2="148.59" y2="16.1925" width="2.54" layer="16"/>
<wire x1="148.59" y1="16.1925" x2="148.2725" y2="16.1925" width="2.54" layer="16"/>
<wire x1="148.2725" y1="16.1925" x2="145.7325" y2="13.6525" width="2.54" layer="16"/>
<wire x1="145.7325" y1="13.6525" x2="146.05" y2="13.6525" width="2.54" layer="16"/>
<wire x1="146.05" y1="13.6525" x2="148.2725" y2="15.875" width="2.54" layer="16"/>
<wire x1="146.05" y1="13.6525" x2="145.0975" y2="12.7" width="2.54" layer="16"/>
<wire x1="145.0975" y1="12.7" x2="144.145" y2="11.7475" width="2.54" layer="16"/>
<wire x1="144.145" y1="11.7475" x2="131.7625" y2="11.7475" width="2.54" layer="16"/>
<wire x1="131.7625" y1="11.7475" x2="131.445" y2="11.43" width="2.54" layer="16"/>
<wire x1="131.445" y1="11.43" x2="143.8275" y2="11.43" width="2.54" layer="16"/>
<wire x1="143.8275" y1="11.43" x2="144.145" y2="11.7475" width="2.54" layer="16"/>
<wire x1="145.0975" y1="12.7" x2="136.2075" y2="12.7" width="2.54" layer="16"/>
<wire x1="136.2075" y1="12.7" x2="135.89" y2="13.0175" width="2.54" layer="16"/>
<wire x1="135.89" y1="13.0175" x2="143.1925" y2="13.0175" width="2.54" layer="16"/>
<wire x1="143.1925" y1="13.0175" x2="145.0975" y2="14.9225" width="2.54" layer="16"/>
<wire x1="145.0975" y1="14.9225" x2="137.16" y2="14.9225" width="2.54" layer="16"/>
<wire x1="137.16" y1="14.9225" x2="136.8425" y2="14.605" width="2.54" layer="16"/>
<wire x1="136.8425" y1="14.605" x2="137.4775" y2="14.605" width="2.54" layer="16"/>
<wire x1="137.4775" y1="14.605" x2="142.875" y2="20.0025" width="2.54" layer="16"/>
<wire x1="142.875" y1="20.0025" x2="142.875" y2="17.78" width="2.54" layer="16"/>
<wire x1="142.875" y1="17.78" x2="141.9225" y2="16.8275" width="2.54" layer="16"/>
<wire x1="141.9225" y1="16.8275" x2="146.05" y2="16.8275" width="2.54" layer="16"/>
<wire x1="146.05" y1="16.8275" x2="146.05" y2="18.7325" width="2.54" layer="16"/>
<wire x1="146.05" y1="18.7325" x2="144.145" y2="20.6375" width="2.54" layer="16"/>
<wire x1="144.145" y1="20.6375" x2="144.145" y2="19.05" width="2.54" layer="16"/>
<wire x1="144.145" y1="19.05" x2="144.4625" y2="18.7325" width="2.54" layer="16"/>
<wire x1="144.4625" y1="18.7325" x2="147.32" y2="18.7325" width="2.54" layer="16"/>
<wire x1="147.32" y1="18.7325" x2="148.2725" y2="17.78" width="2.54" layer="16"/>
<wire x1="148.2725" y1="17.78" x2="148.2725" y2="18.0975" width="2.54" layer="16"/>
<wire x1="148.2725" y1="18.0975" x2="149.86" y2="19.685" width="2.54" layer="16"/>
<wire x1="149.86" y1="19.685" x2="146.685" y2="19.685" width="2.54" layer="16"/>
<wire x1="146.685" y1="19.685" x2="146.05" y2="20.32" width="2.54" layer="16"/>
<wire x1="146.05" y1="20.32" x2="150.495" y2="20.32" width="2.54" layer="16"/>
<wire x1="150.495" y1="20.32" x2="155.2575" y2="25.0825" width="2.54" layer="16"/>
<wire x1="155.2575" y1="25.0825" x2="155.2575" y2="27.94" width="2.54" layer="16"/>
<wire x1="155.2575" y1="27.94" x2="149.225" y2="21.9075" width="2.54" layer="16"/>
<wire x1="149.225" y1="21.9075" x2="144.4625" y2="21.9075" width="2.54" layer="16"/>
<wire x1="144.4625" y1="21.9075" x2="144.145" y2="22.225" width="2.54" layer="16"/>
<wire x1="144.145" y1="22.225" x2="145.0975" y2="22.225" width="2.54" layer="16"/>
<wire x1="145.0975" y1="22.225" x2="147.6375" y2="24.765" width="2.54" layer="16"/>
<wire x1="147.6375" y1="24.765" x2="149.5425" y2="24.765" width="2.54" layer="16"/>
<wire x1="149.5425" y1="24.765" x2="149.86" y2="25.0825" width="2.54" layer="16"/>
<wire x1="149.86" y1="25.0825" x2="149.86" y2="24.765" width="2.54" layer="16"/>
<wire x1="149.86" y1="24.765" x2="148.59" y2="23.495" width="2.54" layer="16"/>
</signal>
<signal name="N$54">
<wire x1="153.3525" y1="45.4025" x2="153.3525" y2="43.4975" width="1.27" layer="16"/>
<wire x1="153.3525" y1="43.4975" x2="154.94" y2="43.4975" width="1.27" layer="16"/>
<wire x1="154.94" y1="43.4975" x2="156.21" y2="42.2275" width="1.27" layer="16"/>
<wire x1="156.21" y1="42.2275" x2="156.21" y2="40.64" width="1.27" layer="16"/>
<wire x1="156.21" y1="40.64" x2="157.1625" y2="39.6875" width="1.27" layer="16"/>
<wire x1="157.1625" y1="39.6875" x2="157.1625" y2="33.9725" width="1.27" layer="16"/>
<wire x1="157.1625" y1="33.9725" x2="157.48" y2="33.655" width="1.27" layer="16"/>
<wire x1="157.48" y1="33.655" x2="157.48" y2="45.4025" width="1.27" layer="16"/>
<wire x1="157.48" y1="45.4025" x2="153.67" y2="45.4025" width="1.27" layer="16"/>
<wire x1="153.3525" y1="45.4025" x2="153.67" y2="45.4025" width="1.27" layer="16"/>
<wire x1="153.67" y1="45.4025" x2="154.6225" y2="44.45" width="1.27" layer="16"/>
<wire x1="154.6225" y1="44.45" x2="156.5275" y2="44.45" width="1.27" layer="16"/>
<wire x1="156.5275" y1="44.45" x2="156.5275" y2="43.18" width="1.27" layer="16"/>
<wire x1="156.5275" y1="43.18" x2="156.845" y2="42.8625" width="1.27" layer="16"/>
<wire x1="156.845" y1="42.8625" x2="156.21" y2="42.8625" width="1.27" layer="16"/>
<wire x1="156.21" y1="42.8625" x2="155.575" y2="43.4975" width="1.27" layer="16"/>
</signal>
<signal name="N$59">
<wire x1="102.87" y1="41.275" x2="103.8225" y2="41.275" width="2.54" layer="16"/>
<wire x1="103.8225" y1="41.275" x2="103.8225" y2="42.8625" width="2.54" layer="16"/>
<wire x1="103.8225" y1="42.8625" x2="104.14" y2="42.8625" width="2.54" layer="16"/>
<wire x1="104.14" y1="42.8625" x2="104.14" y2="50.8" width="2.54" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
