# 1 "proba.c"
# 52 "C:\PROGRA~1\HI-TEC~1\PICC\9.83\include\pic10f222.h"
volatile control unsigned char OPTION @ 0x000;
volatile unsigned char INDF @ 0x000;
volatile unsigned char TMR0 @ 0x001;
volatile unsigned char PCL @ 0x002;
volatile unsigned char STATUS @ 0x003;
volatile bit CARRY @ ((unsigned)&STATUS*8)+0;
volatile bit DC @ ((unsigned)&STATUS*8)+1;
volatile bit ZERO @ ((unsigned)&STATUS*8)+2;
volatile bit nPD @ ((unsigned)&STATUS*8)+3;
volatile bit nTO @ ((unsigned)&STATUS*8)+4;
volatile bit GPWUF @ ((unsigned)&STATUS*8)+7;
volatile union {
struct {
unsigned C : 1;
unsigned DC : 1;
unsigned Z : 1;
unsigned nPD : 1;
unsigned nTO : 1;
unsigned : 2;
unsigned GPWUF : 1;
} STATUSbits @ 0x003;
volatile unsigned char FSR @ 0x004;
volatile unsigned char OSCCAL @ 0x005;
volatile bit FOSC4 @ ((unsigned)&OSCCAL*8)+0;
volatile bit CAL0 @ ((unsigned)&OSCCAL*8)+1;
volatile bit CAL1 @ ((unsigned)&OSCCAL*8)+2;
volatile bit CAL2 @ ((unsigned)&OSCCAL*8)+3;
volatile bit CAL3 @ ((unsigned)&OSCCAL*8)+4;
volatile bit CAL4 @ ((unsigned)&OSCCAL*8)+5;
volatile bit CAL5 @ ((unsigned)&OSCCAL*8)+6;
volatile bit CAL6 @ ((unsigned)&OSCCAL*8)+7;
volatile union {
struct {
unsigned FOSC4 : 1;
unsigned CAL : 7;
struct {
unsigned : 1;
unsigned CAL0 : 1;
unsigned CAL1 : 1;
unsigned CAL2 : 1;
unsigned CAL3 : 1;
unsigned CAL4 : 1;
unsigned CAL5 : 1;
unsigned CAL6 : 1;
} OSCCALbits @ 0x005;
volatile unsigned char GPIO @ 0x006;
volatile control unsigned char TRIS @ 0x006;
volatile control unsigned char TRISGPIO @ 0x006;
volatile bit GP0 @ ((unsigned)&GPIO*8)+0;
volatile bit GP1 @ ((unsigned)&GPIO*8)+1;
volatile bit GP2 @ ((unsigned)&GPIO*8)+2;
volatile bit GP3 @ ((unsigned)&GPIO*8)+3;
volatile union {
struct {
unsigned GP0 : 1;
unsigned GP1 : 1;
unsigned GP2 : 1;
unsigned GP3 : 1;
} GPIObits @ 0x006;
volatile unsigned char ADCON0 @ 0x007;
volatile bit ADON @ ((unsigned)&ADCON0*8)+0;
volatile bit GO_nDONE @ ((unsigned)&ADCON0*8)+1;
volatile bit GO @ ((unsigned)&ADCON0*8)+1;
volatile bit CHS0 @ ((unsigned)&ADCON0*8)+2;
volatile bit CHS1 @ ((unsigned)&ADCON0*8)+3;
volatile bit ANS0 @ ((unsigned)&ADCON0*8)+6;
volatile bit ANS1 @ ((unsigned)&ADCON0*8)+7;
volatile bit nDONE @ ((unsigned)&ADCON0*8)+1;
volatile union {
struct {
unsigned ADON : 1;
unsigned GO_nDONE : 1;
unsigned CHS : 2;
unsigned : 2;
unsigned ANS : 2;
struct {
unsigned : 1;
unsigned GO : 1;
unsigned CHS0 : 1;
unsigned CHS1 : 1;
unsigned : 2;
unsigned ANS0 : 1;
unsigned ANS1 : 1;
struct {
unsigned : 1;
unsigned nDONE : 1;
} ADCON0bits @ 0x007;
volatile unsigned char ADRES @ 0x008;
volatile bit ADRES0 @ ((unsigned)&ADRES*8)+0;
volatile bit ADRES1 @ ((unsigned)&ADRES*8)+1;
volatile bit ADRES2 @ ((unsigned)&ADRES*8)+2;
volatile bit ADRES3 @ ((unsigned)&ADRES*8)+3;
volatile bit ADRES4 @ ((unsigned)&ADRES*8)+4;
volatile bit ADRES5 @ ((unsigned)&ADRES*8)+5;
volatile bit ADRES6 @ ((unsigned)&ADRES*8)+6;
volatile bit ADRES7 @ ((unsigned)&ADRES*8)+7;
volatile union {
struct {
unsigned ADRES0 : 1;
unsigned ADRES1 : 1;
unsigned ADRES2 : 1;
unsigned ADRES3 : 1;
unsigned ADRES4 : 1;
unsigned ADRES5 : 1;
unsigned ADRES6 : 1;
unsigned ADRES7 : 1;
} ADRESbits @ 0x008;
# 27 "C:\PROGRA~1\HI-TEC~1\PICC\9.83\include\pic.h"
#pragma inline(_nop)
extern void _nop(void);
# 153
#pragma inline(_delay)
extern void _delay(unsigned long);
# 34 "proba.c"
asm("\tpsect config,class=CONFIG,delta=2"); asm("\tdw ""0xfeb");
# 62 "C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h"
char FCI_GETCHAR(char* sStr1, char iStr1_len, char iPos);
char FCI_GETLENGTH(char* sStr1, char iStr1_len);
char FCI_MIDSTRING(char* sSrc, char iSrc_len, char* sDst, char iDst_len, char iStart, char iCount);
char FCI_LEFTSTRING(char* sSrc, char iSrc_len, char* sDst, char iDst_len, char iCount);
char FCI_RIGHTSTRING(char* sSrc, char iSrc_len, char* sDst, char iDst_len, char iCount);
char FCI_CONCATENATE(char* sSrc1, char iSrc1_len, char* sSrc2, char iSrc2_len, char* sDst, char iDst_len);
char FCI_TOSTRING(int iSrc1, char* sDst, char iDst_len);
void FCI_TOLOWER(char* sSrc, char iSrc_len, char* sDst, char iDst_len);
void FCI_TOUPPER(char* sSrc, char iSrc_len, char* sDst, char iDst_len);
char FCI_COMPARE(char* sSrc1, char iSrc1_len, char* sSrc2, char iSrc2_len, char iNoCase);
char FCI_FLOAT_TO_STRING(float Number, char Precision, char* String, char MSZ_String);
char FCI_NUMBER_TO_HEX(short Number, char* String, char MSZ_String);
short FCI_STRING_TO_INT(char* String, char MSZ_String);
float FCI_STRING_TO_FLOAT(char* String, char MSZ_String);
void Wdt_msDelay(void);
void Wdt_Delay_S(short delay);
void Wdt_Delay_Ms(short delay);
char isinf(float f);
# 3 "C:\PROGRA~1\HI-TEC~1\PICC\9.83\include\math.h"
extern double fabs(double);
extern double floor(double);
extern double ceil(double);
extern double modf(double, double *);
extern double sqrt(double);
extern double atof(const char *);
extern double sin(double);
extern double cos(double);
extern double tan(double);
extern double asin(double);
extern double acos(double);
extern double atan(double);
extern double atan2(double, double);
extern double log(double);
extern double log10(double);
extern double pow(double, double);
extern double exp(double);
extern double sinh(double);
extern double cosh(double);
extern double tanh(double);
extern double eval_poly(double, const double *, int);
extern double frexp(double, int *);
extern double ldexp(double, int);
extern double fmod(double, double);
extern double trunc(double);
extern double round(double);
# 107 "C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h"
char ts_bit(char reg, char bt);
char test_bit(char reg, char bt);
void delay_10us(char del);
void delay_us(char del);
void delay_ms(char del);
void delay_s(char del);
void nop(void);
float float32_add(float a, float b);
float float32_sub(float a, float b);
float float32_mul(float a, float b);
float float32_div(float a, float b);
float float32_rem(float a, float b);
char float32_is_signaling_nan(float a);
char float32_eq(float a, float b);
char float32_ge(float a, float b);
char float32_gt(float a, float b);
char float32_le(float a, float b);
char float32_lt(float a, float b);
short float32_to_int32 (float a);
float float32_from_int32 (short a);
# 136
if (bt)
return 1;
return 0;
if (reg & (1 << bt))
return (1 << bt);
return 0;
char count;
for(count=0; count<10; count++)
delay_us(del);
while (del > 1)
_delay((unsigned long)((1)*(8000000/4000000.0)));
del = del - 1;
while (del > 1)
_delay((unsigned long)((1)*(8000000/4000.0)));
del = del - 1;
char i;
for(i=0; i<del; i++)
delay_ms(250);
delay_ms(250);
delay_ms(250);
delay_ms(250);
void nop()
asm("NOP");
return (a + b);
return (a - b);
return (a * b);
return (a / b);
return (fmod(a, b));
return isinf(a);
return (a == b);
return (a >= b);
return (a > b);
return (a <= b);
return (a < b);
return ((int)a);
return ((float)a);
char tmp;
for (tmp = 0; tmp < iStr1_len; tmp++)
if (*sStr1 == 0)
break;
sStr1++;
if(iPos < tmp)
tmp = *sStr1;
else tmp = 0;
return (tmp);
char tmp;
if (*sStr1 == 0)
break;
sStr1++;
return (tmp);
char idx;
for (idx = 0; idx < iSrc_len; idx++)
if (*sSrc == 0)
break;
sSrc++;
if (iStart >= idx)
*sDst = 0;
else
if ((iStart + iCount) >= idx)
iCount = idx - iStart;
sSrc = 0;
for (idx = 0; idx < iStart; idx++)
sSrc++;
for (idx = 0; idx < iCount; idx++)
if (idx < iDst_len)
*sDst = *sSrc;
sDst++;
sSrc++;
else break;
if (idx < iDst_len)
*sDst = 0;
return (idx);
char idx = 0;
if (*sSrc == 0)
break;
sSrc++;
if (iCount > idx)
iCount = idx;
sSrc = 0;
if (idx < iDst_len)
*sDst = *sSrc;
sDst++;
sSrc++;
else break;
if (idx < iDst_len)
*sDst = 0;
return (idx);
char idx = 0;
char delta;
if (*sSrc == 0)
break;
sSrc++;
if (iCount > idx)
iCount = idx;
delta = idx - iCount;
sSrc = 0;
for (idx = 0; idx < delta; idx++)
sSrc++;
for(idx = 0; idx < iCount; idx++)
if (idx < iDst_len)
*sDst = *sSrc;
sDst++;
sSrc++;
else break;
if (idx < iDst_len)
*sDst = 0;
return (idx);
char tmp;
char idx = 0;
for (tmp=0; tmp<iSrc1_len; tmp++)
if (idx < iDst_len)
*sDst = *sSrc1;
sDst++;
sSrc1++;
if (*sSrc1 != 0)
idx++;
else break;
for (tmp=0; tmp<iSrc2_len; tmp++)
if (idx < iDst_len)
*sDst = *sSrc2;
sDst++;
sSrc2++;
if (*sSrc2 != 0)
idx++;
else break;
if (idx < iDst_len)
*sDst = 0;
return (idx);
char tmp1;
short tmp2;
char idx = 0;
if (iSrc1 < 0)
sDst[0] = '-';
idx++;
iSrc1 = 0 - iSrc1;
tmp2 = iSrc1;
if (iSrc1 >= 10000)
if (idx < iDst_len)
tmp1 = tmp2 / 10000;
sDst[idx] = '0' + tmp1;
idx++;
while (tmp1 > 0)
tmp2 = tmp2 - 10000;
tmp1--;
if (iSrc1 >= 1000)
if (idx < iDst_len)
tmp1 = tmp2 / 1000;
idx++;
while (tmp1 > 0)
tmp2 = tmp2 - 1000;
tmp1--;
if (iSrc1 >= 100)
if (idx < iDst_len)
tmp1 = tmp2 / 100;
idx++;
while (tmp1 > 0)
tmp2 = tmp2 - 100;
tmp1--;
if (iSrc1 >= 10)
if (idx < iDst_len)
tmp1 = tmp2 / 10;
idx++;
while (tmp1 > 0)
tmp2 = tmp2 - 10;
tmp1--;
if (idx < iDst_len)
sDst[idx] = '0' + tmp2;
idx++;
if (idx < iDst_len)
sDst[idx] = 0;
return (idx);
char idx;
char ch;
for (idx=0; idx<iSrc_len; idx++)
if (idx < iDst_len)
ch = sSrc[idx];
sDst[idx] = ch;
if (ch != 0)
if ((ch >= 'A') && (ch <= 'Z'))
sDst[idx] = (ch | 0x20);
} else {
break;
char idx;
char ch;
if (idx < iDst_len)
ch = sSrc[idx];
sDst[idx] = ch;
if (ch != 0)
if ((ch >= 'a') && (ch <= 'z'))
sDst[idx] = (ch & 0xDF);
} else {
break;
char iRetVal = 0;
char idx;
char ch1, ch2;
for (idx=0; idx < iSrc1_len; idx++)
if (idx < iSrc2_len)
ch1 = *sSrc1;
ch2 = *sSrc2;
if (iNoCase)
if ((ch1 >= 'a') && (ch1 <= 'z'))
ch1 = (ch1 & 0xDF);
if ((ch2 >= 'a') && (ch2 <= 'z'))
ch2 = (ch2 & 0xDF);
if (ch1 < ch2)
return(255);
else if (ch1 > ch2)
return(1);
sSrc1++;
sSrc2++;
else
if (*sSrc1 == 0)
return (0);
else
return (1);
if (iSrc1_len == iSrc2_len)
return (0);
else
if (*sSrc2 == 0)
return (0);
else
return (255);
# 1260
char i;
for (i=0; i<75; i++)
asm("clrwdt");
delay_us(10);
short i, j;
for (i=0; i<delay; i++)
for (j=0; j<1000; j++)
Wdt_msDelay();
short i;
Wdt_msDelay();
int whole;
char str_length;
char idx;
char stringidx = 0;
float real, temp;
char old;
char temp_string[10];
# 1324
whole = (int)Number;
temp = whole;
if (Number >= 0)
real = Number - temp;
else
if (whole == 0)
String[stringidx] = '-';
stringidx = stringidx + 1;
real = temp - Number;
str_length = FCI_TOSTRING(whole, temp_string, 5);
for (idx=0; idx<str_length; idx++)
if(stringidx < MSZ_String)
String[stringidx] = temp_string[idx];
String[stringidx] = '.';
for (idx = 0; idx < Precision; idx++)
if (stringidx >= MSZ_String)
break;
# 1372
real = real * 10;
whole = (int)real;
temp = whole;
real = real - temp;
String[stringidx] = '0' + whole;
String[stringidx] = 0;
return stringidx;
char stringidx;
char idx = 0;
char temp;
char digit[4] = {0,0,0,0};
unsigned int num;
if(Number < 256 && MSZ_String < 4)
return 0;
if(Number > 255 && MSZ_String < 6)
return 0;
String[0] = '0';
String[1] = 'x';
if(Number < 0)
num = 0 - Number;
num = 0xFFFF - (num - 1);
else
num = Number;
while (num > 0)
temp = num % 16;
num = num / 16;
if(temp > 9)
temp = temp - 10;
digit[idx] = temp + 'A';
else
digit[idx] = temp + '0';
idx = idx + 1;
for (stringidx = 2; stringidx < (idx + 2); stringidx++)
String[stringidx] = digit[idx - (stringidx - 1)];
return stringidx;
char bNegative = 0;
char idx = 0;
short RetVal = 0;
if(String[0] == '-')
bNegative = 1;
idx = 1;
while (idx < MSZ_String && String[idx] >= '0' && String[idx] <= '9')
RetVal = RetVal * 10;
RetVal = RetVal + (String[idx] - '0');
idx = idx + 1;
if (bNegative)
RetVal = 0 - RetVal;
return RetVal;
float RetVal = 0;
float real_divider = 1;
int whole, real;
char idx = 0;
char idx2 = 0;
char offset = 0;
char bNegative = 0;
char Comp_String[8];
bNegative = 1;
offset = 1;
for(idx=offset; idx<MSZ_String; idx++)
if(String[idx] == '.')
break;
whole = FCI_STRING_TO_INT (String, idx);
if(idx == MSZ_String)
# 1514
RetVal = (int)whole;
return RetVal;
offset = idx + 1;
if(String[idx] >= '0' && String[idx] <= '9')
Comp_String[idx - offset] = String[idx];
# 1530
real_divider = real_divider * 0.1;
else
break;
real = FCI_STRING_TO_INT (Comp_String, (idx - offset));
# 1554
RetVal = (float)real;
RetVal = RetVal * real_divider;
real_divider = (float)whole;
RetVal = RetVal + real_divider;
if (bNegative)
return RetVal;
char isinf(float f)
char* b;
b = (char*)&f;
if ((b[0] == 0) &&
(b[1] == 0) &&
(b[2] == 128) &&
((b[3] & 127) == 127))
return (255);
return (0);
# 49 "proba.c"
void main()
osccal = osccal & 0xFE;
ADCON0 = 0x00;
asm("movlw 0xDF");
asm("option");
char tvar;
# 64
while (1)
asm nop
mainendloop: goto mainendloop;
