<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="mic" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.1" altunitdist="mic" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="-0.0177" y1="0.0207" x2="80.7821" y2="-0.103" width="0" layer="20"/>
<wire x1="80.7821" y1="-0.103" x2="80.7821" y2="62.8319" width="0" layer="20"/>
<wire x1="80.7821" y1="62.8319" x2="0.1501" y2="62.9308" width="0" layer="20"/>
<wire x1="0.1501" y1="62.9308" x2="-0.0177" y2="0.0207" width="0" layer="20"/>
<circle x="59.2794" y="15.1806" radius="1.0454" width="1.27" layer="17"/>
<circle x="55.2738" y="15.1585" radius="1.0454" width="1.27" layer="17"/>
<circle x="51.2473" y="15.1709" radius="1.0454" width="1.27" layer="17"/>
<circle x="51.2468" y="19.9562" radius="1.0454" width="1.27" layer="17"/>
<circle x="59.2862" y="19.9419" radius="1.0454" width="1.27" layer="17"/>
<circle x="18.9149" y="25.9019" radius="1.0583" width="1.016" layer="18"/>
<circle x="33.879" y="33.5734" radius="1.0583" width="1.016" layer="18"/>
<circle x="18.8877" y="33.5534" radius="1.0583" width="1.016" layer="18"/>
<circle x="33.894" y="25.8929" radius="1.0583" width="1.016" layer="18"/>
<circle x="37.7104" y="27.483" radius="1.0583" width="1.016" layer="18"/>
<circle x="43.2898" y="32.5093" radius="0.8348" width="0.8128" layer="18"/>
<circle x="59.2735" y="25.1998" radius="0.8348" width="0.8128" layer="18"/>
<circle x="59.2768" y="32.8182" radius="0.8348" width="0.8128" layer="18"/>
<circle x="44.2607" y="39.9156" radius="0.8348" width="0.8128" layer="17"/>
<circle x="58.418" y="48.4854" radius="0.8348" width="0.8128" layer="18"/>
<circle x="44.8814" y="45.8778" radius="0.8348" width="0.8128" layer="18"/>
<circle x="44.8714" y="50.7183" radius="0.8348" width="0.8128" layer="18"/>
<circle x="27.9658" y="47.1277" radius="0.7634" width="0.8128" layer="18"/>
<circle x="30.7658" y="47.1102" radius="0.7634" width="0.8128" layer="18"/>
<circle x="30.7483" y="39.4732" radius="0.7634" width="0.8128" layer="18"/>
<circle x="27.9598" y="39.4964" radius="0.7634" width="0.8128" layer="18"/>
<circle x="54.0493" y="55.1517" radius="0.8348" width="0.8128" layer="18"/>
<circle x="2.87" y="27.0444" radius="1.9794" width="0.8128" layer="1"/>
<circle x="2.8355" y="58.0764" radius="1.9794" width="0.8128" layer="1"/>
<circle x="77.8468" y="58.0623" radius="1.9794" width="0.8128" layer="1"/>
<circle x="77.8468" y="27.0618" radius="1.9794" width="0.8128" layer="1"/>
<circle x="56.0429" y="35.3029" radius="0.8348" width="0.8128" layer="18"/>
<circle x="24.9049" y="11.4702" radius="0.8348" width="0.8128" layer="18"/>
<circle x="63.6661" y="35.2978" radius="0.8348" width="0.8128" layer="18"/>
<circle x="34.1043" y="39.9133" radius="0.7634" width="0.8128" layer="18"/>
</plain>
<libraries>
<library name="lcd_2x16_led_backlight">
<packages>
<package name="HY-1602F">
<wire x1="-5.46" y1="2.5" x2="74.54" y2="2.5" width="0.127" layer="21"/>
<wire x1="74.54" y1="2.5" x2="74.54" y2="-33.5" width="0.127" layer="21"/>
<wire x1="74.54" y1="-33.5" x2="-5.46" y2="-33.5" width="0.127" layer="27"/>
<wire x1="-5.46" y1="-33.5" x2="-5.46" y2="2.5" width="0.127" layer="21"/>
<wire x1="-0.46" y1="-3" x2="69.54" y2="-3" width="0.127" layer="21"/>
<wire x1="69.54" y1="-3" x2="69.54" y2="-28" width="0.127" layer="21"/>
<wire x1="-0.46" y1="-3" x2="-0.46" y2="-28" width="0.127" layer="21"/>
<wire x1="-0.46" y1="-28" x2="69.54" y2="-28" width="0.127" layer="21"/>
<circle x="-2.96" y="0" radius="3.5693" width="0.127" layer="49"/>
<circle x="72.04" y="0" radius="3.5735" width="0.127" layer="49"/>
<circle x="72.04" y="-31" radius="3.5735" width="0.127" layer="49"/>
<circle x="-2.96" y="-31" radius="3.5693" width="0.127" layer="49"/>
<pad name="1" x="2.54" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="2" x="5.08" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="3" x="7.62" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="4" x="10.16" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="5" x="12.7" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="6" x="15.24" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="7" x="17.78" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="8" x="20.32" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="9" x="22.86" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="10" x="25.4" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="11" x="27.94" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="12" x="30.48" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="13" x="33.02" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="14" x="35.56" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="15" x="38.1" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="16" x="40.64" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<text x="-5.46" y="2.8" size="1.27" layer="25">&gt;NAME</text>
<hole x="-2.96" y="0" drill="2.5"/>
<hole x="72.04" y="0" drill="2.5"/>
<hole x="-2.96" y="-31" drill="2.5"/>
<hole x="72.04" y="-31" drill="2.5"/>
</package>
</packages>
</library>
<library name="con-amp-quick">
<packages>
<package name="06P">
<description>&lt;b&gt;AMP QUICK CONNECTOR&lt;/b&gt;</description>
<wire x1="-5.461" y1="1.778" x2="-5.334" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="1.651" x2="-5.08" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.397" x2="-4.826" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="1.651" x2="-4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-2.286" x2="-7.366" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-5.334" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="2.54" x2="-7.366" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="1.778" x2="-7.366" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-1.778" x2="-7.366" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-1.778" x2="-6.985" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.778" x2="-5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.778" x2="-6.985" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.524" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.778" x2="-4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.524" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.524" x2="-5.334" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-1.524" x2="-4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="-4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.524" x2="-7.366" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.524" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-1.524" x2="-7.366" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="2.54" x2="-6.604" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="2.54" x2="-6.096" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="2.667" x2="-6.604" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="2.54" x2="-4.064" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.54" x2="-3.556" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.413" x2="-4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="2.413" x2="-5.334" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-2.159" x2="-2.794" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-2.159" x2="-2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.286" x2="-2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.778" x2="-0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.778" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.778" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.778" x2="-1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.524" x2="-1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.54" x2="-1.524" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.54" x2="-0.254" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.54" x2="-1.016" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.667" x2="-1.524" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.413" x2="-2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.54" x2="-1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.413" x2="-2.794" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.413" x2="-2.794" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.54" x2="-2.794" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.667" x2="-4.064" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.54" x2="-4.064" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="2.413" x2="-4.826" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="2.54" x2="-6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="1.778" x2="-7.366" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="1.778" x2="-2.794" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.778" x2="-2.286" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="1.651" x2="-4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="1.651" x2="-5.334" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.778" x2="-2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.778" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.778" x2="-5.715" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.286" x2="-2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.778" x2="-1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-2.159" x2="-2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-2.159" x2="2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-2.286" x2="0.254" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-2.159" x2="2.286" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-2.159" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.778" x2="0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.778" x2="1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.778" x2="0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.778" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.524" x2="2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-1.524" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="1.524" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.667" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<wire x1="3.556" y1="2.54" x2="3.556" y2="2.667" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.54" x2="4.064" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.413" x2="2.794" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.413" x2="2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.397" x2="5.334" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.334" y1="1.651" x2="5.461" y2="1.778" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-2.159" x2="4.826" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.461" y1="1.778" x2="7.366" y2="1.778" width="0.1524" layer="21"/>
<wire x1="7.366" y1="1.778" x2="7.366" y2="2.54" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-1.778" x2="7.366" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-1.778" x2="6.985" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="7.366" y1="1.778" x2="7.366" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.778" x2="6.985" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.778" x2="4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.524" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.778" x2="5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.524" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-1.524" x2="5.334" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-1.524" x2="5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.524" x2="7.366" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.524" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-1.524" x2="7.366" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.096" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="7.366" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.667" x2="6.096" y2="2.667" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.413" x2="5.334" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.413" x2="4.826" y2="2.413" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.413" x2="4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.778" x2="4.826" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.651" x2="5.08" y2="1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.54" x2="4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.667" x2="3.556" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.413" x2="2.794" y2="2.413" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.54" x2="1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.778" x2="2.286" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.778" x2="2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.778" x2="2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.651" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.334" y1="1.651" x2="5.334" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.778" x2="1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-2.286" x2="4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.778" x2="5.715" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.159" x2="4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.778" x2="-0.254" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.778" x2="2.794" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.159" x2="-0.254" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.159" x2="0.254" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.159" x2="-0.254" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.778" x2="-0.635" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-1.524" x2="-0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.778" x2="-0.254" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.413" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.54" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.254" y2="2.413" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="-3.81" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="6" x="6.35" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-5.842" y="0.9398" size="0.9906" layer="21" ratio="12" rot="R90">1</text>
<text x="-7.366" y="2.9464" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.366" y="-3.8354" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.6802" y1="-0.3302" x2="-6.0198" y2="0.3302" layer="51"/>
<rectangle x1="-4.1402" y1="-0.3302" x2="-3.4798" y2="0.3302" layer="51"/>
<rectangle x1="-1.6002" y1="-0.3302" x2="-0.9398" y2="0.3302" layer="51"/>
<rectangle x1="0.9398" y1="-0.3302" x2="1.6002" y2="0.3302" layer="51"/>
<rectangle x1="3.4798" y1="-0.3302" x2="4.1402" y2="0.3302" layer="51"/>
<rectangle x1="6.0198" y1="-0.3302" x2="6.6802" y2="0.3302" layer="51"/>
</package>
<package name="03P">
<wire x1="-1.651" y1="1.778" x2="-1.524" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.651" x2="-1.27" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.397" x2="-1.016" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.651" x2="-0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-2.159" x2="-1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-2.286" x2="-3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.159" x2="-1.524" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.159" x2="-1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.54" x2="-3.556" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.778" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.778" x2="-3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.778" x2="-3.175" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.556" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.54" x2="-2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.667" x2="-2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.54" x2="-0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.413" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.413" x2="-1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.397" x2="1.524" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.651" x2="1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.159" x2="1.016" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.159" x2="1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-2.286" x2="1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.778" x2="3.556" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.778" x2="3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.778" x2="3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.778" x2="3.175" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.778" x2="3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-1.524" x2="1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.524" x2="1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.524" x2="3.556" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.54" x2="2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.667" x2="2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.413" x2="1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.413" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.889" y1="1.778" x2="1.016" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.651" x2="1.27" y2="1.397" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.667" x2="-0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.413" x2="-1.016" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.54" x2="-2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.778" x2="-3.556" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.778" x2="0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.651" x2="-1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.651" x2="-1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.651" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.651" x2="1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.778" x2="-1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.286" x2="1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.778" x2="1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.159" x2="1.016" y2="-2.286" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-2.032" y="0.9398" size="0.9906" layer="21" ratio="12" rot="R90">1</text>
<text x="-3.556" y="2.9464" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.8354" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.8702" y1="-0.3302" x2="-2.2098" y2="0.3302" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3302" x2="0.3302" y2="0.3302" layer="51"/>
<rectangle x1="2.2098" y1="-0.3302" x2="2.8702" y2="0.3302" layer="51"/>
</package>
</packages>
</library>
<library name="crystal">
<packages>
<package name="HC49U-V">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-2.921" y1="-2.286" x2="2.921" y2="-2.286" width="0.4064" layer="21"/>
<wire x1="-2.921" y1="2.286" x2="2.921" y2="2.286" width="0.4064" layer="21"/>
<wire x1="-2.921" y1="-1.778" x2="2.921" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.778" x2="-2.921" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.778" x2="2.921" y2="-1.778" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.921" y1="2.286" x2="2.921" y2="-2.286" width="0.4064" layer="21" curve="-180"/>
<wire x1="-2.921" y1="2.286" x2="-2.921" y2="-2.286" width="0.4064" layer="21" curve="180"/>
<wire x1="-2.921" y1="1.778" x2="-2.921" y2="-1.778" width="0.1524" layer="21" curve="180"/>
<wire x1="-0.254" y1="0.889" x2="0.254" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.889" x2="0.254" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.889" x2="-0.254" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.889" x2="-0.254" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.889" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.889" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.413" y="0" drill="0.8128"/>
<pad name="2" x="2.413" y="0" drill="0.8128"/>
<text x="-5.08" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.191" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-2.794" x2="3.81" y2="2.794" layer="43"/>
<rectangle x1="-4.318" y1="-2.54" x2="-3.81" y2="2.54" layer="43"/>
<rectangle x1="-4.826" y1="-2.286" x2="-4.318" y2="2.286" layer="43"/>
<rectangle x1="-5.334" y1="-1.778" x2="-4.826" y2="1.778" layer="43"/>
<rectangle x1="-5.588" y1="-1.27" x2="-5.334" y2="1.016" layer="43"/>
<rectangle x1="3.81" y1="-2.54" x2="4.318" y2="2.54" layer="43"/>
<rectangle x1="4.318" y1="-2.286" x2="4.826" y2="2.286" layer="43"/>
<rectangle x1="4.826" y1="-1.778" x2="5.334" y2="1.778" layer="43"/>
<rectangle x1="5.334" y1="-1.016" x2="5.588" y2="1.016" layer="43"/>
</package>
</packages>
</library>
<library name="linear">
<packages>
<package name="TO220V">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
</library>
<library name="rcl">
<packages>
<package name="C025-025X050">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="E2,5-5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="C150-072X183">
grid 15 mm, outline 7.2 x 18.3 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" shape="octagon"/>
<text x="-8.509" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-064X183">
grid 15 mm, outline 6.4 x 18.3 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-8,5">
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="0207/2V">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-4">
grid 5.05 mm, diameter 4 mm</description>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="-1.397" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.905"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.905" shape="octagon"/>
<text x="2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="21"/>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="diode">
<packages>
<package name="DO35-7">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO34-7">
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="inductor-neosid">
<packages>
<package name="BS11">
<description>NOMINAL &lt;b&gt;INDUCTANCE&lt;/b&gt;&lt;p&gt;
grid 5 mm, diameter 10.5 mm, height 13.5 mm</description>
<circle x="0" y="0" radius="5.15" width="0.2032" layer="21"/>
<pad name="1" x="-2.5" y="0" drill="0.7" shape="long" rot="R90"/>
<pad name="2" x="2.5" y="0" drill="0.7" shape="long" rot="R90"/>
<text x="3.854" y="4.032" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.25" y="-3" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="switch">
<packages>
<package name="320-916">
<description>&lt;b&gt;TOGGLE SWITCH&lt;/b&gt;&lt;p&gt;
distributor RS Components</description>
<wire x1="-2.8702" y1="6.6802" x2="-3.5052" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-2.8702" y1="6.6802" x2="2.8702" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="6.0452" x2="2.8702" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="2.8702" y1="-6.6802" x2="3.5052" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="2.8702" y1="-6.6802" x2="-2.8702" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-6.0452" x2="-2.8702" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="2.286" x2="-4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.6002" y1="1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="3.5052" y1="-6.0452" x2="3.5052" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="6.0452" x2="3.5052" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="2.8702" x2="-3.5052" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-6.0452" x2="-3.5052" y2="-2.8194" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="51" curve="-270"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="51" curve="-233.130102"/>
<wire x1="-1.6002" y1="1.27" x2="1.6002" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-2.286" x2="-3.5052" y2="-2.8194" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-2.8194" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="4.318" y1="-2.286" x2="3.5052" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="-2.8702" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="4.318" y1="2.286" x2="3.5052" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="2.8702" x2="0" y2="5.08" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="2.286" x2="-3.5052" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="2.8702" x2="0" y2="5.08" width="0.1524" layer="51"/>
<pad name="3" x="0" y="-4.0132" drill="2.0066" shape="long"/>
<pad name="2" x="0" y="0" drill="2.0066" shape="long"/>
<pad name="1" x="0" y="4.0132" drill="2.0066" shape="long"/>
<text x="-2.54" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="320-938">
<wire x1="-5.4102" y1="6.6802" x2="-6.0452" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-5.4102" y1="6.6802" x2="5.4102" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="6.0452" y1="6.0452" x2="5.4102" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="5.4102" y1="-6.6802" x2="6.0452" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="5.4102" y1="-6.6802" x2="-5.4102" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="-6.0452" y1="-6.0452" x2="-5.4102" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="6.0452" y1="6.0452" x2="6.0452" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="-6.0452" y1="-6.0452" x2="-6.0452" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="4.318" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="2.286" x2="-4.318" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="4.318" y1="2.286" x2="0" y2="5.08" width="0.1524" layer="51"/>
<wire x1="0" y1="5.08" x2="-4.318" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-2.286" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="0" y1="-5.08" x2="4.318" y2="-2.286" width="0.1524" layer="51"/>
<pad name="3" x="-2.3876" y="-4.0132" drill="2.0066" shape="octagon"/>
<pad name="2" x="-2.3876" y="0" drill="2.0066" shape="octagon"/>
<pad name="1" x="-2.3876" y="4.0132" drill="2.0066" shape="octagon"/>
<pad name="4" x="2.3876" y="4.0132" drill="2.0066" shape="octagon"/>
<pad name="5" x="2.3876" y="0" drill="2.0066" shape="octagon"/>
<pad name="6" x="2.3876" y="-4.0132" drill="2.0066" shape="octagon"/>
<text x="-5.08" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="relay">
<packages>
<package name="GN-A">
<description>&lt;b&gt;ULTRA-SMALL PACKAGE SLIM POLARIZED RELAY&lt;/b&gt; NAiS&lt;p&gt;
Source: http://www.mew-europe.com/..  en_ds_61007_0000.pdf</description>
<wire x1="-5.235" y1="2.75" x2="5.165" y2="2.75" width="0.2032" layer="21"/>
<wire x1="5.165" y1="2.75" x2="5.165" y2="-2.75" width="0.2032" layer="21"/>
<wire x1="5.165" y1="-2.75" x2="-5.235" y2="-2.75" width="0.2032" layer="21"/>
<wire x1="-5.235" y1="-2.75" x2="-5.235" y2="2.75" width="0.2032" layer="21"/>
<smd name="1" x="-3.835" y="-2.65" dx="0.8" dy="3.1" layer="1"/>
<smd name="2" x="-0.635" y="-2.65" dx="0.8" dy="3.1" layer="1"/>
<smd name="3" x="1.565" y="-2.65" dx="0.8" dy="3.1" layer="1"/>
<smd name="4" x="3.765" y="-2.65" dx="0.8" dy="3.1" layer="1"/>
<smd name="8" x="-3.835" y="2.65" dx="0.8" dy="3.1" layer="1"/>
<smd name="7" x="-0.635" y="2.65" dx="0.8" dy="3.1" layer="1"/>
<smd name="6" x="1.565" y="2.65" dx="0.8" dy="3.1" layer="1"/>
<smd name="5" x="3.765" y="2.65" dx="0.8" dy="3.1" layer="1"/>
<text x="-5.715" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="6.985" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="special-drill">
<packages>
<package name="PAD_0.1250">
<description>&lt;b&gt;0.1250 Inch&lt;/b&gt;</description>
<pad name="1" x="0" y="0" drill="3.175" diameter="3.175"/>
<text x="0" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="0" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="pot">
<packages>
<package name="PT-10S">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;</description>
<wire x1="-1.905" y1="-1.27" x2="-1.27" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="3.175" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="0.635" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="3.175" x2="4.445" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="4.445" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="3.175" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="5.08" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<pad name="A" x="-2.54" y="-1.27" drill="1.016" shape="long"/>
<pad name="E" x="2.54" y="-1.27" drill="1.016" shape="long"/>
<pad name="S" x="0" y="1.27" drill="1.016" shape="long"/>
<text x="-2.54" y="3.7846" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.2164" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="microchip-5">
<packages>
<package name="SSOP20">
<description>&lt;b&gt;Shrink Small Outline Package&lt;/b&gt;&lt;p&gt;
package type SS</description>
<wire x1="-3.8" y1="-2.6" x2="3.8" y2="-2.6" width="0.2032" layer="21"/>
<wire x1="3.8" y1="-2.6" x2="3.8" y2="2.6" width="0.2032" layer="21"/>
<wire x1="3.8" y1="2.6" x2="-3.8" y2="2.6" width="0.2032" layer="21"/>
<smd name="1" x="-2.925" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="2" x="-2.275" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="3" x="-1.625" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="4" x="-0.975" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="5" x="-0.325" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="6" x="0.325" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="7" x="0.975" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="8" x="1.625" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="9" x="2.275" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="10" x="2.925" y="-3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="11" x="2.925" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="12" x="2.275" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="13" x="1.625" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="14" x="0.975" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="15" x="0.325" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="16" x="-0.325" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="17" x="-0.975" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="18" x="-1.625" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="19" x="-2.275" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<smd name="20" x="-2.925" y="3.625" dx="0.4" dy="1.5" layer="1"/>
<text x="-4.206" y="-2.5999" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.506" y="-2.5999" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-3.1028" y1="-3.937" x2="-2.7472" y2="-2.6416" layer="51"/>
<rectangle x1="-2.4529" y1="-3.937" x2="-2.0973" y2="-2.6416" layer="51"/>
<rectangle x1="-1.8029" y1="-3.937" x2="-1.4473" y2="-2.6416" layer="51"/>
<rectangle x1="-1.1529" y1="-3.937" x2="-0.7973" y2="-2.6416" layer="51"/>
<rectangle x1="-0.5029" y1="-3.937" x2="-0.1473" y2="-2.6416" layer="51"/>
<rectangle x1="0.1471" y1="-3.937" x2="0.5027" y2="-2.6416" layer="51"/>
<rectangle x1="0.7971" y1="-3.937" x2="1.1527" y2="-2.6416" layer="51"/>
<rectangle x1="1.4473" y1="-3.937" x2="1.8029" y2="-2.6416" layer="51"/>
<rectangle x1="2.0973" y1="-3.937" x2="2.4529" y2="-2.6416" layer="51"/>
<rectangle x1="2.7473" y1="-3.937" x2="3.1029" y2="-2.6416" layer="51"/>
<rectangle x1="2.7471" y1="2.6416" x2="3.1027" y2="3.937" layer="51"/>
<rectangle x1="2.0971" y1="2.6416" x2="2.4527" y2="3.937" layer="51"/>
<rectangle x1="1.4471" y1="2.6416" x2="1.8027" y2="3.937" layer="51"/>
<rectangle x1="0.7972" y1="2.6416" x2="1.1528" y2="3.937" layer="51"/>
<rectangle x1="0.1472" y1="2.6416" x2="0.5028" y2="3.937" layer="51"/>
<rectangle x1="-0.5027" y1="2.6416" x2="-0.1471" y2="3.937" layer="51"/>
<rectangle x1="-1.1527" y1="2.6416" x2="-0.7971" y2="3.937" layer="51"/>
<rectangle x1="-1.8027" y1="2.6416" x2="-1.4471" y2="3.937" layer="51"/>
<rectangle x1="-2.4527" y1="2.6416" x2="-2.0971" y2="3.937" layer="51"/>
<rectangle x1="-3.1027" y1="2.6416" x2="-2.7471" y2="3.937" layer="51"/>
<rectangle x1="-3.8999" y1="-2.5999" x2="-2.925" y2="2.5999" layer="27"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="32mil"/>
<param name="mdWirePad" value="32mil"/>
<param name="mdWireVia" value="32mil"/>
<param name="mdPadPad" value="32mil"/>
<param name="mdPadVia" value="32mil"/>
<param name="mdViaVia" value="32mil"/>
<param name="mdSmdPad" value="32mil"/>
<param name="mdSmdVia" value="32mil"/>
<param name="mdSmdSmd" value="32mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="10mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="20mil"/>
<param name="rlMaxPadTop" value="30mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="20mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="32mil"/>
<param name="mlMaxStopFrame" value="32mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="0mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="0"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="LCD1" library="lcd_2x16_led_backlight" package="HY-1602F" value="LCD_2X16_SIL" x="5.8106" y="58.0605"/>
<element name="ICSP" library="con-amp-quick" package="06P" value="" x="53.788" y="44.5698" rot="MR270"/>
<element name="Q1" library="crystal" package="HC49U-V" value="20MHz" x="44.8765" y="48.2965" rot="R90">
<attribute name="EAGLEUP" value="QS" x="44.8765" y="48.2965" size="1.778" layer="27" rot="R90" display="both"/>
</element>
<element name="IC1" library="linear" package="TO220V" value="7805TV" x="78.4734" y="35.7507" rot="R270"/>
<element name="C1" library="rcl" package="C025-025X050" value="" x="48.811" y="50.5373" rot="R90"/>
<element name="C2" library="rcl" package="C025-025X050" value="" x="48.777" y="44.5949" rot="R270"/>
<element name="R1" library="rcl" package="0204/7" value="" x="59.8553" y="35.3017" rot="R180"/>
<element name="R2" library="rcl" package="0204/7" value="" x="47.1122" y="32.4838" rot="R180"/>
<element name="R3" library="rcl" package="0207/2V" value="" x="39.0312" y="37.3987"/>
<element name="R4" library="rcl" package="0207/2V" value="" x="31.6335" y="50.3919" rot="R180"/>
<element name="R5" library="rcl" package="0207/2V" value="" x="61.5547" y="49.6502" rot="R90"/>
<element name="R6" library="rcl" package="0204/7" value="" x="30.7533" y="43.2914" rot="R90"/>
<element name="R7" library="rcl" package="0204/7" value="" x="27.9587" y="43.3084" rot="R270"/>
<element name="R8" library="rcl" package="0207/10" value="" x="39.1791" y="39.9144" rot="R180"/>
<element name="R9" library="rcl" package="0204/7" value="" x="59.2759" y="29.0095" rot="R270"/>
<element name="D1" library="diode" package="DO35-7" value="1N4148DO35-7" x="62.9726" y="53.5239" rot="R180"/>
<element name="D2" library="diode" package="DO35-7" value="1N4148DO35-7" x="23.6224" y="51.5042" rot="R90"/>
<element name="C3" library="rcl" package="E5-8,5" value="" x="67.2526" y="44.8492" rot="R180"/>
<element name="C7" library="rcl" package="E2,5-5" value="" x="67.9554" y="36.5505" rot="R90"/>
<element name="C5" library="rcl" package="E2,5-5" value="" x="38.4453" y="33.3998" rot="R180"/>
<element name="C4" library="rcl" package="E5-4" value="" x="27.5339" y="52.4072" rot="R90"/>
<element name="C6" library="rcl" package="C050-025X075" value="" x="58.104" y="45.8273" rot="R270"/>
<element name="C8" library="rcl" package="C150-072X183" value="" x="26.4052" y="25.8973" rot="R180"/>
<element name="C9" library="rcl" package="C150-072X183" value="" x="26.3815" y="33.5675" rot="R180"/>
<element name="C10" library="rcl" package="C150-064X183" value="" x="45.2019" y="27.4786"/>
<element name="L1" library="inductor-neosid" package="BS11" value="" x="42.9998" y="19.2198" rot="R90"/>
<element name="D3" library="diode" package="DO34-7" value="BAT46" x="70.2445" y="54.4175" rot="R90"/>
<element name="ON/OFF" library="switch" package="320-916" value="" x="75.8682" y="48.8453" rot="R180"/>
<element name="NULL" library="switch" package="320-916" value="" x="24.8822" y="17.5931" rot="R270"/>
<element name="L/C" library="switch" package="320-938" value="" x="55.2743" y="17.5448" rot="R90"/>
<element name="R11" library="rcl" package="0207/10" value="" x="48.9752" y="55.1507" rot="R180"/>
<element name="K1" library="relay" package="GN-A" value="GN200A1H" x="18.1241" y="41.3538" rot="R180"/>
<element name="C11" library="rcl" package="C025-025X050" value="" x="72.1295" y="34.4519" rot="R90"/>
<element name="R12" library="rcl" package="0204/7" value="" x="28.7119" y="11.4737"/>
<element name="LC" library="special-drill" package="PAD_0.1250" value="SPECIAL_DRILL_0.1250" x="70.5806" y="7.2605"/>
<element name="GND" library="special-drill" package="PAD_0.1250" value="SPECIAL_DRILL_0.1250" x="40.1006" y="7.2605"/>
<element name="EL" library="special-drill" package="PAD_0.1250" value="SPECIAL_DRILL_0.1250" x="9.6206" y="7.2605"/>
<element name="SL1" library="con-amp-quick" package="03P" value="" x="61.6581" y="58.2149" rot="R180"/>
<element name="R13" library="pot" package="PT-10S" value="" x="12.1349" y="50.9273" rot="R270"/>
<element name="IC2" library="microchip-5" package="SSOP20" value="PIC16F690SS" x="37.73" y="47.0126" rot="R180">
<attribute name="EAGLEUP" value="TSSOP20" x="37.73" y="47.0126" size="1.778" layer="27" rot="R180" display="both"/>
</element>
</elements>
<signals>
<signal name="N$1">
<contactref element="Q1" pad="1"/>
<contactref element="C2" pad="1"/>
<contactref element="IC2" pad="3"/>
<wire x1="44.8765" y1="45.8835" x2="48.777" y2="45.8649" width="0.8128" layer="16"/>
<wire x1="39.355" y1="50.6376" x2="39.3287" y2="49.3159" width="0.4064" layer="1"/>
<wire x1="39.3287" y1="49.3159" x2="44.8765" y2="45.8835" width="0.6096" layer="1"/>
</signal>
<signal name="N$2">
<contactref element="Q1" pad="2"/>
<contactref element="C1" pad="1"/>
<contactref element="IC2" pad="2"/>
<wire x1="44.8765" y1="50.7095" x2="47.8969" y2="49.2839" width="0.8128" layer="16"/>
<wire x1="47.8969" y1="49.2839" x2="48.811" y2="49.2673" width="0.8128" layer="16"/>
<wire x1="40.005" y1="50.6376" x2="39.9865" y2="52.0511" width="0.4064" layer="1"/>
<wire x1="39.9865" y1="52.0511" x2="41.7194" y2="52.0593" width="0.6096" layer="1"/>
<wire x1="41.7194" y1="52.0593" x2="44.8765" y2="50.7095" width="0.8128" layer="1"/>
</signal>
<signal name="N$3">
<contactref element="ICSP" pad="1"/>
<contactref element="R5" pad="2"/>
<contactref element="IC2" pad="4"/>
<wire x1="38.705" y1="50.6376" x2="38.7161" y2="52.2474" width="0.4064" layer="1"/>
<wire x1="38.7161" y1="52.2474" x2="40.336" y2="53.3242" width="0.4064" layer="1"/>
<wire x1="53.788" y1="50.9198" x2="54.8789" y2="50.9177" width="1.27" layer="16"/>
<wire x1="40.336" y1="53.3242" x2="50.9431" y2="53.3235" width="0.4064" layer="1"/>
<wire x1="50.9431" y1="53.3235" x2="53.788" y2="50.9198" width="0.8128" layer="1"/>
<wire x1="61.5547" y1="50.9202" x2="54.8789" y2="50.9177" width="1.27" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="ICSP" pad="4"/>
<contactref element="R8" pad="1"/>
<contactref element="IC2" pad="19"/>
<wire x1="40.0157" y1="42.3682" x2="40.005" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="40.0157" y1="42.3682" x2="42.092" y2="40.7917" width="0.4064" layer="1"/>
<wire x1="42.092" y1="40.7917" x2="44.2591" y2="39.9144" width="0.6096" layer="1"/>
<wire x1="52.1778" y1="43.2996" x2="53.788" y2="43.2998" width="0.8128" layer="16"/>
<wire x1="49.4462" y1="40.7638" x2="52.1778" y2="43.2996" width="0.8128" layer="16"/>
<wire x1="44.2591" y1="39.9144" x2="49.4462" y2="40.7638" width="0.8128" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="ICSP" pad="5"/>
<contactref element="IC2" pad="18"/>
<contactref element="R9" pad="1"/>
<wire x1="53.788" y1="40.7598" x2="59.2766" y2="40.7388" width="1.27" layer="16"/>
<wire x1="39.3627" y1="41.7653" x2="39.355" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="43.153" y1="37.4769" x2="39.3627" y2="41.7653" width="0.4064" layer="1"/>
<wire x1="43.153" y1="37.4769" x2="48.0256" y2="37.4722" width="0.8128" layer="1"/>
<wire x1="48.0256" y1="37.4722" x2="52.286" y2="40.7566" width="0.8128" layer="1"/>
<wire x1="52.286" y1="40.7566" x2="53.788" y2="40.7598" width="0.8128" layer="1"/>
<wire x1="59.2766" y1="40.7388" x2="59.2816" y2="34.7146" width="1.27" layer="16"/>
<wire x1="59.2816" y1="34.7146" x2="59.2759" y2="32.8195" width="1.27" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="LCD1" pad="14"/>
<contactref element="IC2" pad="5"/>
<wire x1="38.055" y1="50.6376" x2="38.0614" y2="52.9368" width="0.4064" layer="1"/>
<wire x1="38.0614" y1="52.9368" x2="41.3149" y2="56.2758" width="0.4064" layer="1"/>
<wire x1="41.3149" y1="56.2758" x2="41.3706" y2="58.0605" width="0.4064" layer="1"/>
</signal>
<signal name="N$9">
<contactref element="LCD1" pad="13"/>
<contactref element="IC2" pad="7"/>
<wire x1="36.755" y1="50.6376" x2="36.7532" y2="51.8632" width="0.4064" layer="1"/>
<wire x1="36.7532" y1="51.8632" x2="38.8306" y2="58.0605" width="0.4064" layer="1"/>
</signal>
<signal name="N$10">
<contactref element="LCD1" pad="12"/>
<contactref element="IC2" pad="8"/>
<wire x1="36.105" y1="50.6376" x2="36.0906" y2="56.0669" width="0.4064" layer="1"/>
<wire x1="36.0906" y1="56.0669" x2="36.2906" y2="58.0605" width="0.4064" layer="1"/>
</signal>
<signal name="N$11">
<contactref element="LCD1" pad="11"/>
<contactref element="IC2" pad="9"/>
<wire x1="35.455" y1="50.6376" x2="35.4406" y2="52.0434" width="0.4064" layer="1"/>
<wire x1="35.4406" y1="52.0434" x2="33.7439" y2="55.1745" width="0.4064" layer="1"/>
<wire x1="33.7439" y1="55.1745" x2="33.7506" y2="58.0605" width="0.4064" layer="1"/>
</signal>
<signal name="N$13">
<contactref element="LCD1" pad="15"/>
<contactref element="R11" pad="2"/>
<wire x1="43.8952" y1="55.1507" x2="43.9106" y2="58.0605" width="1.4224" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="LCD1" pad="4"/>
<contactref element="IC2" pad="11"/>
<wire x1="34.809" y1="43.8305" x2="34.805" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="34.5592" y1="43.7268" x2="34.809" y2="43.8305" width="0.4064" layer="1"/>
<wire x1="25.5252" y1="50.7863" x2="25.5189" y2="46.8653" width="0.8128" layer="1"/>
<wire x1="19.8261" y1="50.7775" x2="25.5252" y2="50.7863" width="0.8128" layer="1"/>
<wire x1="19.8261" y1="50.7775" x2="15.9571" y2="56.0427" width="0.8128" layer="1"/>
<wire x1="15.9571" y1="56.0427" x2="15.9706" y2="58.0605" width="0.8128" layer="1"/>
<wire x1="27.6313" y1="43.7298" x2="34.5592" y2="43.7268" width="0.8128" layer="1"/>
<wire x1="25.5189" y1="46.8653" x2="27.6313" y2="43.7298" width="0.8128" layer="1"/>
</signal>
<signal name="N$15">
<contactref element="LCD1" pad="6"/>
<contactref element="IC2" pad="10"/>
<wire x1="21.0552" y1="54.088" x2="21.0506" y2="58.0605" width="0.8128" layer="1"/>
<wire x1="22.5028" y1="52.4795" x2="21.0552" y2="54.088" width="0.8128" layer="1"/>
<wire x1="22.5028" y1="52.4795" x2="33.5488" y2="52.4394" width="0.8128" layer="1"/>
<wire x1="33.5488" y1="52.4394" x2="34.8034" y2="51.1326" width="0.4064" layer="1"/>
<wire x1="34.8034" y1="51.1326" x2="34.805" y2="50.6376" width="0.4064" layer="1"/>
</signal>
<signal name="N$16">
<contactref element="R7" pad="1"/>
<contactref element="IC2" pad="13"/>
<wire x1="36.121" y1="45.0629" x2="36.105" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="29.09" y1="45.0497" x2="36.121" y2="45.0629" width="0.4064" layer="1"/>
<wire x1="29.09" y1="45.0497" x2="27.9587" y2="47.1184" width="0.4064" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="R6" pad="2"/>
<contactref element="IC2" pad="14"/>
<wire x1="36.7437" y1="46.3121" x2="36.755" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="32.3215" y1="46.3535" x2="36.7437" y2="46.3121" width="0.4064" layer="1"/>
<wire x1="30.7533" y1="47.1014" x2="32.3215" y2="46.3535" width="0.4064" layer="1"/>
</signal>
<signal name="N$18">
<contactref element="R6" pad="1"/>
<contactref element="R7" pad="2"/>
<contactref element="NULL" pad="3"/>
<contactref element="EL" pad="1"/>
<contactref element="C8" pad="2"/>
<wire x1="9.6206" y1="7.2605" x2="9.6206" y2="10.4355" width="1.4224" layer="16"/>
<wire x1="9.6206" y1="10.4355" x2="20.869" y2="17.5931" width="1.4224" layer="16"/>
<wire x1="27.9587" y1="39.4984" x2="30.7533" y2="39.4814" width="1.4224" layer="16"/>
<wire x1="18.9122" y1="25.8973" x2="27.9587" y2="39.4984" width="1.4224" layer="16"/>
<wire x1="18.8774" y1="23.8271" x2="18.9122" y2="25.8973" width="1.4224" layer="16"/>
<wire x1="20.9077" y1="20.6275" x2="18.8774" y2="23.8271" width="1.4224" layer="16"/>
<wire x1="20.869" y1="17.5931" x2="20.9077" y2="20.6275" width="1.4224" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="LCD1" pad="3"/>
<contactref element="R13" pad="S"/>
<wire x1="13.4049" y1="50.9273" x2="13.4306" y2="58.0605" width="1.6764" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="LCD1" pad="2"/>
<contactref element="R13" pad="A"/>
<wire x1="10.8649" y1="53.4673" x2="10.8906" y2="58.0605" width="1.6764" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="R3" pad="2"/>
<contactref element="R4" pad="1"/>
<contactref element="IC2" pad="17"/>
<contactref element="IC2" pad="6"/>
<wire x1="37.4117" y1="48.9839" x2="37.4072" y2="49.0072" width="0.6096" layer="1"/>
<wire x1="37.4072" y1="49.0072" x2="37.4276" y2="49.5208" width="0.4064" layer="1"/>
<wire x1="37.4276" y1="49.5208" x2="37.405" y2="50.6376" width="0.4064" layer="1"/>
<wire x1="38.6845" y1="47.8392" x2="37.4117" y2="48.9839" width="0.6096" layer="1"/>
<wire x1="38.705" y1="43.3876" x2="38.6845" y2="47.8392" width="0.4064" layer="1"/>
<wire x1="38.7187" y1="42.0996" x2="38.705" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="38.7316" y1="41.2878" x2="38.7187" y2="42.0996" width="0.4064" layer="1"/>
<wire x1="37.2328" y1="49.0053" x2="34.1684" y2="49.0136" width="0.6096" layer="1"/>
<wire x1="34.1684" y1="49.0136" x2="32.9035" y2="50.3919" width="0.6096" layer="1"/>
<wire x1="37.4072" y1="49.0072" x2="37.2328" y2="49.0053" width="0.6096" layer="1"/>
<wire x1="40.3012" y1="37.3987" x2="38.7316" y2="41.2878" width="0.4064" layer="1"/>
</signal>
<signal name="N$22">
<contactref element="R3" pad="1"/>
<contactref element="R1" pad="2"/>
<contactref element="R2" pad="2"/>
<contactref element="C5" pad="+"/>
<contactref element="IC2" pad="16"/>
<wire x1="38.0433" y1="41.9699" x2="38.055" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="38.0444" y1="38.6355" x2="38.0232" y2="40.2144" width="0.4064" layer="1"/>
<wire x1="38.0232" y1="40.2144" x2="38.0433" y2="41.9699" width="0.4064" layer="1"/>
<wire x1="43.2861" y1="35.3138" x2="56.0453" y2="35.3017" width="1.27" layer="16"/>
<wire x1="39.7524" y1="35.3311" x2="43.2861" y2="35.3138" width="1.27" layer="16"/>
<wire x1="39.7524" y1="35.3311" x2="39.2046" y2="35.2959" width="1.27" layer="16"/>
<wire x1="39.7153" y1="33.3998" x2="39.7524" y2="35.3311" width="1.27" layer="16"/>
<wire x1="43.3022" y1="32.4838" x2="43.2861" y2="32.4838" width="1.27" layer="16"/>
<wire x1="43.2861" y1="32.4838" x2="43.2861" y2="35.3138" width="1.27" layer="16"/>
<wire x1="37.7612" y1="37.3987" x2="38.0444" y2="38.6355" width="0.4064" layer="1"/>
<wire x1="37.7612" y1="37.3987" x2="39.2046" y2="35.2959" width="1.27" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R4" pad="2"/>
<contactref element="C4" pad="+"/>
<contactref element="IC2" pad="15"/>
<wire x1="37.3945" y1="47.2537" x2="37.405" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="35.5573" y1="47.8388" x2="36.6326" y2="47.8496" width="0.6096" layer="1"/>
<wire x1="36.6326" y1="47.8496" x2="37.3945" y2="47.2537" width="0.6096" layer="1"/>
<wire x1="30.3635" y1="50.3919" x2="32.9738" y2="47.8404" width="0.6096" layer="1"/>
<wire x1="32.9738" y1="47.8404" x2="35.5573" y2="47.8388" width="0.6096" layer="1"/>
<wire x1="27.5339" y1="49.8672" x2="30.3635" y2="50.3919" width="1.27" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="IC1" pad="1"/>
<contactref element="C3" pad="+"/>
<contactref element="ON/OFF" pad="1"/>
<wire x1="75.8682" y1="44.8321" x2="75.9334" y2="38.2907" width="1.4224" layer="16"/>
<wire x1="69.7926" y1="44.8492" x2="75.8682" y2="44.8321" width="1.4224" layer="16"/>
</signal>
<signal name="GND">
<contactref element="C3" pad="-"/>
<contactref element="IC1" pad="2"/>
<contactref element="C7" pad="-"/>
<contactref element="C6" pad="2"/>
<contactref element="C11" pad="2"/>
<contactref element="LCD1" pad="7"/>
<contactref element="LCD1" pad="5"/>
<contactref element="LCD1" pad="1"/>
<contactref element="LCD1" pad="8"/>
<contactref element="LCD1" pad="9"/>
<contactref element="LCD1" pad="10"/>
<contactref element="LCD1" pad="16"/>
<contactref element="R12" pad="2"/>
<contactref element="R2" pad="1"/>
<contactref element="C4" pad="-"/>
<contactref element="K1" pad="3"/>
<contactref element="C10" pad="2"/>
<contactref element="GND" pad="1"/>
<contactref element="D2" pad="A"/>
<contactref element="K1" pad="8"/>
<contactref element="C1" pad="2"/>
<contactref element="C2" pad="2"/>
<contactref element="ICSP" pad="3"/>
<contactref element="SL1" pad="2"/>
<contactref element="K1" pad="6"/>
<contactref element="R13" pad="E"/>
<contactref element="IC2" pad="20"/>
<wire x1="28.6706" y1="58.0605" x2="31.2106" y2="58.0605" width="1.4224" layer="16"/>
<wire x1="26.1306" y1="58.0605" x2="28.6706" y2="58.0605" width="1.4224" layer="16"/>
<wire x1="23.5906" y1="58.0605" x2="26.1306" y2="58.0605" width="1.4224" layer="16"/>
<wire x1="72.1295" y1="35.7219" x2="67.9554" y2="37.8205" width="1.4224" layer="16"/>
<wire x1="75.9334" y1="35.7507" x2="72.1295" y2="35.7219" width="1.4224" layer="16"/>
<wire x1="67.9554" y1="37.8205" x2="64.7126" y2="44.8492" width="1.4224" layer="16"/>
<wire x1="18.5246" y1="61.5791" x2="18.5106" y2="58.0605" width="1.4224" layer="16"/>
<wire x1="23.574" y1="61.6006" x2="23.5906" y2="58.0605" width="1.4224" layer="16"/>
<wire x1="18.5246" y1="61.5791" x2="23.574" y2="61.6006" width="1.4224" layer="16"/>
<wire x1="32.5219" y1="11.4737" x2="40.1006" y2="7.2605" width="0.8128" layer="16"/>
<wire x1="8.3711" y1="61.5587" x2="18.5246" y2="61.5791" width="1.27" layer="16"/>
<wire x1="8.3506" y1="58.0605" x2="8.3711" y2="61.5587" width="1.27" layer="16"/>
<wire x1="64.7126" y1="44.8492" x2="62.5869" y2="44.8226" width="1.27" layer="16"/>
<wire x1="62.5869" y1="44.8226" x2="58.3791" y2="45.797" width="1.27" layer="16"/>
<wire x1="58.3791" y1="45.797" x2="53.788" y2="45.8398" width="1.27" layer="16"/>
<wire x1="58.3791" y1="45.797" x2="58.104" y2="43.2873" width="1.27" layer="16"/>
<wire x1="53.788" y1="45.8398" x2="51.9782" y2="45.8622" width="0.4064" layer="16"/>
<wire x1="51.9782" y1="45.8622" x2="48.777" y2="43.3249" width="0.4064" layer="16"/>
<wire x1="44.7554" y1="43.3918" x2="40.655" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="46.6844" y1="43.3919" x2="44.7554" y2="43.3918" width="0.8128" layer="1"/>
<wire x1="48.777" y1="43.3249" x2="46.6844" y2="43.3919" width="0.8128" layer="1"/>
<wire x1="48.9607" y1="55.1568" x2="48.811" y2="51.8073" width="1.27" layer="16"/>
<wire x1="46.4506" y1="58.0605" x2="48.9607" y2="55.1568" width="1.27" layer="16"/>
<wire x1="31.2106" y1="58.0605" x2="31.1584" y2="55.4412" width="1.27" layer="16"/>
<wire x1="40.1006" y1="7.2605" x2="59.2011" y2="7.2605" width="1.27" layer="16"/>
<wire x1="59.2011" y1="7.2605" x2="59.2011" y2="7.0865" width="1.27" layer="16"/>
<wire x1="16.5591" y1="38.7038" x2="16.5591" y2="41.3376" width="1.27" layer="1"/>
<wire x1="16.5591" y1="41.3376" x2="16.5591" y2="44.0038" width="1.27" layer="1"/>
<wire x1="16.5591" y1="44.0038" x2="16.5666" y2="47.282" width="1.27" layer="1"/>
<wire x1="16.5666" y1="47.282" x2="12.4567" y2="47.2885" width="1.27" layer="1"/>
<wire x1="12.4567" y1="47.2885" x2="10.8649" y2="48.3873" width="1.27" layer="1"/>
<wire x1="21.969" y1="41.3376" x2="21.9591" y2="38.7038" width="1.27" layer="1"/>
<wire x1="16.5591" y1="41.3376" x2="21.969" y2="41.3376" width="1.27" layer="1"/>
<wire x1="23.5906" y1="58.0605" x2="23.6224" y2="55.3142" width="1.27" layer="16"/>
<polygon width="0.4064" layer="16" spacing="0.6096" isolate="0.254" orphans="yes">
<vertex x="0.1542" y="62.7792"/>
<vertex x="80.9914" y="62.8353"/>
<vertex x="81.1973" y="-0.4223"/>
<vertex x="0.0498" y="-0.3029"/>
</polygon>
<via x="40.107" y="7.248" extent="1-16" drill="3" diameter="10"/>
<contactref element="L/C" pad="5"/>
<wire x1="31.2106" y1="58.0605" x2="31.1617" y2="61.6196" width="1.27" layer="16"/>
<wire x1="31.1617" y1="61.6196" x2="46.4710625" y2="61.584396875" width="1.27" layer="16"/>
<wire x1="46.4710625" y1="61.584396875" x2="46.4437" y2="61.5842" width="1.27" layer="16"/>
<wire x1="8.3506" y1="58.0605" x2="8.2657" y2="50.3193" width="1.27" layer="16"/>
<wire x1="8.2657" y1="50.3193" x2="10.8649" y2="48.3873" width="1.27" layer="16"/>
<wire x1="59.2011" y1="7.2605" x2="67.8733" y2="0.5842" width="1.27" layer="16"/>
<wire x1="67.8733" y1="0.5842" x2="80.5144" y2="0.5842" width="1.27" layer="16"/>
<wire x1="80.5144" y1="0.5842" x2="80.39351875" y2="22.440553125" width="1.27" layer="16"/>
<wire x1="80.39351875" y1="22.440553125" x2="80.32" y2="35.7334" width="1.27" layer="16"/>
<wire x1="80.32" y1="35.7334" x2="75.9334" y2="35.7507" width="1.27" layer="16"/>
<wire x1="55.2743" y1="19.9324" x2="52.6949" y2="27.4786" width="1.27" layer="16"/>
<wire x1="61.6581" y1="58.2149" x2="61.718834375" y2="61.570971875" width="1.27" layer="16"/>
<wire x1="61.718834375" y1="61.570971875" x2="61.724" y2="61.5321" width="1.27" layer="16"/>
<wire x1="61.724" y1="61.5321" x2="80.2762" y2="61.5321" width="1.27" layer="16"/>
<wire x1="80.2762" y1="61.5321" x2="80.32" y2="35.7334" width="1.27" layer="16"/>
<wire x1="46.4437" y1="61.5842" x2="61.718834375" y2="61.570971875" width="1.27" layer="16"/>
<wire x1="46.4506" y1="58.0605" x2="46.4710625" y2="61.584396875" width="1.27" layer="16"/>
<wire x1="52.6949" y1="27.4786" x2="70.3617" y2="27.4616" width="1.27" layer="16"/>
<wire x1="70.3617" y1="27.4616" x2="75.3792" y2="22.4367" width="1.27" layer="16"/>
<wire x1="75.3792" y1="22.4367" x2="80.39351875" y2="22.440553125" width="1.27" layer="16"/>
<wire x1="50.9222" y1="32.4838" x2="52.6949" y2="27.4786" width="1.27" layer="16"/>
</signal>
<signal name="+5V">
<contactref element="IC1" pad="3"/>
<contactref element="C7" pad="+"/>
<contactref element="C6" pad="1"/>
<contactref element="C11" pad="1"/>
<contactref element="R1" pad="1"/>
<contactref element="ICSP" pad="2"/>
<contactref element="R5" pad="1"/>
<contactref element="IC2" pad="1"/>
<wire x1="67.9554" y1="35.2805" x2="72.1295" y2="33.1819" width="1.4224" layer="16"/>
<wire x1="72.1295" y1="33.1819" x2="75.9334" y2="33.2107" width="1.6764" layer="16"/>
<wire x1="63.6653" y1="35.3017" x2="64.8724" y2="35.2831" width="1.4224" layer="16"/>
<wire x1="64.8724" y1="35.2831" x2="67.9554" y2="35.2805" width="1.4224" layer="16"/>
<wire x1="40.6383" y1="49.8427" x2="40.655" y2="50.6376" width="0.4064" layer="1"/>
<wire x1="40.6383" y1="49.8427" x2="46.7212" y2="47.5634" width="0.4064" layer="1"/>
<wire x1="46.7212" y1="47.5634" x2="50.7289" y2="47.5533" width="0.4064" layer="1"/>
<wire x1="50.7289" y1="47.5533" x2="52.0661" y2="48.371" width="0.8128" layer="1"/>
<wire x1="52.0661" y1="48.371" x2="53.788" y2="48.3798" width="0.8128" layer="1"/>
<wire x1="53.788" y1="48.3798" x2="58.104" y2="48.3673" width="1.27" layer="16"/>
<wire x1="61.448" y1="38.1085" x2="63.6653" y2="35.3017" width="1.27" layer="1"/>
<via x="61.5547" y="48.3802" extent="1-16" drill="0.6" shape="square"/>
<wire x1="61.5547" y1="48.3802" x2="58.104" y2="48.3673" width="1.27" layer="16"/>
<wire x1="61.448" y1="38.1085" x2="61.5547" y2="48.3802" width="1.27" layer="1"/>
</signal>
<signal name="N$12">
<contactref element="ON/OFF" pad="2"/>
<contactref element="D3" pad="C"/>
<contactref element="D1" pad="C"/>
<wire x1="70.2445" y1="50.6075" x2="66.7826" y2="53.5239" width="1.4224" layer="16"/>
<wire x1="70.2445" y1="50.6075" x2="75.8682" y2="48.8453" width="1.4224" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="NULL" pad="1"/>
<contactref element="R8" pad="2"/>
<wire x1="28.8954" y1="17.5931" x2="28.8978" y2="27.0892" width="1.27" layer="16"/>
<wire x1="28.8978" y1="27.0892" x2="28.8931" y2="34.4332" width="1.27" layer="16"/>
<wire x1="28.8931" y1="34.4332" x2="34.083" y2="38.5602" width="1.27" layer="16"/>
<wire x1="34.083" y1="38.5602" x2="34.0991" y2="39.9144" width="1.27" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="NULL" pad="2"/>
<contactref element="R12" pad="1"/>
<wire x1="24.9019" y1="11.4737" x2="24.8822" y2="17.5931" width="1.27" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="C5" pad="-"/>
<contactref element="C9" pad="1"/>
<contactref element="L1" pad="1"/>
<contactref element="C8" pad="1"/>
<contactref element="C10" pad="1"/>
<wire x1="42.9998" y1="16.7198" x2="47.3261" y2="16.7334" width="1.27" layer="16"/>
<wire x1="47.3261" y1="16.7334" x2="49.7124" y2="16.7036" width="1.27" layer="16"/>
<wire x1="33.885" y1="22.2835" x2="42.9998" y2="16.7198" width="1.27" layer="16"/>
<wire x1="33.8982" y1="25.8973" x2="33.8885" y2="27.5022" width="1.27" layer="16"/>
<wire x1="33.8885" y1="27.5022" x2="33.8745" y2="33.5675" width="1.27" layer="16"/>
<wire x1="33.885" y1="22.2835" x2="33.8982" y2="25.8973" width="1.27" layer="16"/>
<wire x1="33.8745" y1="33.5675" x2="37.1753" y2="33.3998" width="1.27" layer="16"/>
<wire x1="33.8885" y1="27.5022" x2="37.7089" y2="27.4786" width="1.27" layer="16"/>
<contactref element="L/C" pad="1"/>
<wire x1="51.2611" y1="15.1572" x2="49.7124" y2="16.7036" width="1.27" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="L1" pad="2"/>
<wire x1="42.9998" y1="21.7198" x2="49.7053" y2="21.7612" width="1.27" layer="16"/>
<wire x1="57.3184" y1="17.5396" x2="53.2394" y2="17.5364" width="0.8128" layer="16"/>
<contactref element="L/C" pad="3"/>
<contactref element="L/C" pad="4"/>
<wire x1="49.7053" y1="21.7612" x2="51.2611" y2="19.9324" width="1.27" layer="16"/>
<wire x1="59.2875" y1="15.1572" x2="57.3184" y2="17.5396" width="1.27" layer="16"/>
<wire x1="53.2394" y1="17.5364" x2="51.2611" y2="19.9324" width="1.27" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="R9" pad="2"/>
<contactref element="L/C" pad="6"/>
<wire x1="59.2875" y1="19.9324" x2="59.2759" y2="25.1995" width="1.27" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="C9" pad="2"/>
<contactref element="K1" pad="4"/>
<contactref element="K1" pad="5"/>
<wire x1="14.3592" y1="35.8134" x2="18.8885" y2="33.5675" width="1.27" layer="1"/>
<wire x1="14.3592" y1="35.8134" x2="14.3591" y2="38.7038" width="1.27" layer="1"/>
<wire x1="14.3591" y1="38.7038" x2="14.3591" y2="44.0038" width="1.27" layer="1"/>
</signal>
<signal name="N$33">
<contactref element="K1" pad="1"/>
<contactref element="D2" pad="C"/>
<contactref element="IC2" pad="12"/>
<wire x1="30.7281" y1="42.0641" x2="35.4399" y2="42.0508" width="0.4064" layer="1"/>
<wire x1="35.4399" y1="42.0508" x2="35.455" y2="43.3876" width="0.4064" layer="1"/>
<wire x1="26.6191" y1="42.0698" x2="30.7281" y2="42.0641" width="0.8128" layer="1"/>
<wire x1="21.9591" y1="44.0038" x2="23.6318" y2="44.0043" width="1.27" layer="1"/>
<wire x1="23.6318" y1="44.0043" x2="26.6191" y2="42.0698" width="1.27" layer="1"/>
<wire x1="23.6318" y1="44.0043" x2="23.6224" y2="47.6942" width="1.27" layer="1"/>
</signal>
<signal name="N$32">
<contactref element="D3" pad="A"/>
<contactref element="SL1" pad="1"/>
<wire x1="64.1981" y1="58.2149" x2="70.2445" y2="58.2275" width="1.6764" layer="16"/>
</signal>
<signal name="+9V">
<contactref element="SL1" pad="3"/>
<contactref element="D1" pad="A"/>
<contactref element="R11" pad="1"/>
<wire x1="59.1468" y1="55.1365" x2="59.1626" y2="53.5239" width="1.6764" layer="16"/>
<wire x1="59.1468" y1="55.1365" x2="59.1181" y2="58.2149" width="1.6764" layer="16"/>
<wire x1="54.0552" y1="55.1507" x2="59.1468" y2="55.1365" width="1.4224" layer="16"/>
</signal>
<signal name="N$4">
<wire x1="9.6046" y1="9.6635" x2="9.6297" y2="10.4158" width="1.4224" layer="1"/>
<wire x1="9.6297" y1="10.4158" x2="19.5891" y2="16.7722" width="1.4224" layer="1"/>
</signal>
<signal name="N$5">
<wire x1="57.4531" y1="11.7676" x2="68.3391" y2="8.0453" width="1.4224" layer="1"/>
<wire x1="57.4531" y1="11.7676" x2="56.0757" y2="13.9039" width="1.4224" layer="1"/>
</signal>
<signal name="N$34">
<via x="9.6169" y="7.2619" extent="1-16" drill="3" diameter="10"/>
</signal>
<signal name="N$35">
<via x="70.5604" y="7.2623" extent="1-16" drill="3" diameter="10"/>
</signal>
<signal name="N$31">
<contactref element="L/C" pad="2"/>
<contactref element="LC" pad="1"/>
<wire x1="55.2743" y1="15.1572" x2="57.4849" y2="11.7368" width="1.27" layer="16"/>
<wire x1="57.4849" y1="11.7368" x2="70.5806" y2="7.2605" width="1.27" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
