File Name                         Description
msp430g2x13_ca_01.c                    Comp_A, Output Reference Voltages on P1.1
msp430g2x13_ca_02.c                    Comp_A, Detect Threshold, Set P1.0 if P1.1 > 0.25*Vcc
msp430g2x13_ca_03.c                    Comp_A, Simple 2.2V Low Battery Detect
msp430g2x33_adc10_01.c                 ADC10, Sample A1, AVcc Ref, Set P1.0 if > 0.5*AVcc
msp430g2x33_adc10_02.c                 ADC10, Sample A1, 1.5V Ref, Set P1.0 if > 0.2V
msp430g2x33_adc10_03.c                 ADC10, Sample A10 Temp, Set P1.0 if Temp ++ ~2C
msp430g2x33_adc10_04.c                 ADC10, Sample A1, Signed, Set P1.0 if > 0.5*AVcc
msp430g2x33_adc10_05.c                 ADC10, Sample A11, Lo_Batt, Set P1.0 if < 2.3V
msp430g2x33_adc10_06.c                 ADC10, Output Internal Vref on P1.4 & ADCCLK on P1.3
msp430g2x33_adc10_07.c                 ADC10, DTC Sample A1 32x, AVcc, Repeat Single, DCO
msp430g2x33_adc10_08.c                 ADC10, DTC Sample A1 32x, 1.5V, Repeat Single, DCO
msp430g2x33_adc10_09.c                 ADC10, DTC Sample A10 32x, 1.5V, Repeat Single, DCO
msp430g2x33_adc10_10.c                 ADC10, DTC Sample A2-0, AVcc, Single Sequence, DCO
msp430g2x33_adc10_11.c                 ADC10, Sample A1, 1.5V, TA1 Trig, Set P1.0 if > 0.5V
msp430g2x33_adc10_12.c                 ADC10, Sample A7, 1.5V, TA1 Trig, Ultra-Low Pwr
msp430g2x33_adc10_13.c                 ADC10, DTC Sample A1 32x, AVcc, TA0 Trig, DCO
msp430g2x33_adc10_14.c                 ADC10, DTC Sample A1-0 16x, AVcc, Repeat Seq, DCO
msp430g2x33_adc10_16.c                 ADC10, DTC Sample A0 -> TA1, AVcc, DCO
msp430g2x33_adc10_temp.c               ADC10, Sample A10 Temp and Convert to oC and oF
msp430g2xx3_1.c                        Software Toggle P1.0
msp430g2xx3_1_vlo.c                    Software Toggle P1.0, MCLK = VLO/8
msp430g2xx3_LFxtal_nmi.c               LFXT1 Oscillator Fault Detection
msp430g2xx3_P1_01.c                    Software Poll P1.4, Set P1.0 if P1.4 = 1
msp430g2xx3_P1_02.c                    Software Port Interrupt Service on P1.4 from LPM4
msp430g2xx3_P1_03.c                    Poll P1 With Software with Internal Pull-up
msp430g2xx3_P1_04.c                    P1 Interrupt from LPM4 with Internal Pull-up
msp430g2xx3_clks.c                     Basic Clock, Output Buffered SMCLK, ACLK and MCLK/10
msp430g2xx3_dco_calib.c                Basic Clock, Output Buffered clocks with preloaded DCO
msp430g2xx3_dco_flashcal.c             DCO Calibration Constants Programmer
msp430g2xx3_flashwrite_01.c            Flash In-System Programming, Copy SegC to SegD
msp430g2xx3_lpm3.c                     Basic Clock, LPM3 Using WDT ISR, 32kHz ACLK
msp430g2xx3_lpm3_vlo.c                 Basic Clock, LPM3 Using WDT ISR, VLO ACLK
msp430g2xx3_nmi.c                      Basic Clock, Configure RST/NMI as NMI
msp430g2xx3_pinosc_01.c                Capacitive Touch, Pin Oscillator Method, 1 button
msp430g2xx3_pinosc_02.c                Capacitive Touch, Pin Oscillator Method, 4-buttons
msp430g2xx3_pinosc_03.c                4-button Capacitive Touch, Pin Oscillator Method, ACLK CCR
msp430g2xx3_pinosc_04.c                Capacitive Touch, Pin Oscillator Method, 5 buttons, UART
msp430g2xx3_ta_01.c                    Timer_A, Toggle P1.0, CCR0 Cont. Mode ISR, DCO SMCLK
msp430g2xx3_ta_02.c                    Timer_A, Toggle P1.0, CCR0 Up Mode ISR, DCO SMCLK
msp430g2xx3_ta_03.c                    Timer_A, Toggle P1.0, Overflow ISR, DCO SMCLK
msp430g2xx3_ta_04.c                    Timer_A, Toggle P1.0, Overflow ISR, 32kHz ACLK
msp430g2xx3_ta_05.c                    Timer_A, Toggle P1.0, CCR0 Up Mode ISR, 32kHz ACLK
msp430g2xx3_ta_06.c                    Timer_A, Toggle P1.0, CCR1 Cont. Mode ISR, DCO SMCLK
msp430g2xx3_ta_07.c                    Timer_A, Toggle P1.0-2, Cont. Mode ISR, DCO SMCLK
msp430g2xx3_ta_08.c                    Timer_A, Toggle P1.0-2, Cont. Mode ISR, 32kHz ACLK
msp430g2xx3_ta_10.c                    Timer_A, Toggle P1.1/TA0, Up Mode, DCO SMCLK
msp430g2xx3_ta_11.c                    Timer_A, Toggle P1.1/TA0, Up Mode, 32kHz ACLK
msp430g2xx3_ta_13.c                    Timer_A, Toggle P1.1/TA0, Up/Down Mode, DCO SMCLK
msp430g2xx3_ta_14.c                    Timer_A, Toggle P1.1/TA0, Up/Down Mode, 32kHz ACLK
msp430g2xx3_ta_16.c                    Timer_A, PWM TA1-2, Up Mode, DCO SMCLK
msp430g2xx3_ta_17.c                    Timer_A, PWM TA1, Up Mode, 32kHz ACLK
msp430g2xx3_ta_19.c                    Timer_A, PWM TA1, Up/Down Mode, DCO SMCLK
msp430g2xx3_ta_20.c                    Timer_A, PWM TA1, Up/Down Mode, 32kHz ACLK
msp430g2xx3_ta_uart2400.c              Timer_A, Ultra-Low Pwr UART 2400 Echo, 32kHz ACLK
msp430g2xx3_ta_uart9600.c              Timer_A, Ultra-Low Pwr UART 9600 Echo, 32kHz ACLK
msp430g2xx3_uscia0_irda_01.c           USCI_A0 IrDA External Loopback Test, 8MHz SMCLK
msp430g2xx3_uscia0_irda_02.c           USCI_A0 IrDA Monitor, 8MHz SMCLK
msp430g2xx3_uscia0_irda_03.c           USCI_A0 IrDA Physical Layer Comm, 8MHz SMCLK
msp430g2xx3_uscia0_spi_09.c            USCI_A0, SPI 3-Wire Master Incremented Data
msp430g2xx3_uscia0_spi_10.c            USCI_A0, SPI 3-Wire Slave Data Echo
msp430g2xx3_uscia0_uart_01_115k.c      USCI_A0, 115200 UART Echo ISR, DCO SMCLK
msp430g2xx3_uscia0_uart_01_115k_lpm.c    USCI_A0, 115200 UART Echo ISR, DCO SMCLK, LPM4
msp430g2xx3_uscia0_uart_01_19200.c     USCI_A0, 19200 UART Echo ISR, DCO SMCLK
msp430g2xx3_uscia0_uart_01_9600.c      USCI_A0, 9600 UART Echo ISR, DCO SMCLK
msp430g2xx3_uscia0_uart_05_9600.c      USCI_A0, Ultra-Low Pwr UART 9600 Echo ISR, 32kHz ACLK
msp430g2xx3_uscia0_uart_06_9600.c      USCI_A0, Ultra-Low Pwr UART 9600 String, 32kHz ACLK
msp430g2xx3_uscia0_uart_07_9600.c      USCI_A0, Ultra-Low Pwr UART 9600 RX/TX, 32kHz ACLK
msp430g2xx3_uscia0_uart_08_9600.c      USCI_A0, UART 9600 Full-Duplex Transceiver, 32kHz ACLK
msp430g2xx3_uscib0_i2c_01.c            USCI_B0 I2C Master to TMP100, Set P1.0 if Temp > 28C
msp430g2xx3_uscib0_i2c_02.c            USCI_B0 I2C Master Interface to PCF8574, Read/Write
msp430g2xx3_uscib0_i2c_03.c            USCI_B0 I2C Master Interface to DAC8571, Write
msp430g2xx3_uscib0_i2c_04.c            USCI_B0 I2C Master RX single bytes from MSP430 Slave
msp430g2xx3_uscib0_i2c_05.c            USCI_B0 I2C Slave TX single bytes to MSP430 Master
msp430g2xx3_uscib0_i2c_06.c            USCI_B0 I2C Master TX single bytes to MSP430 Slave
msp430g2xx3_uscib0_i2c_07.c            USCI_B0 I2C Slave RX single bytes from MSP430 Master
msp430g2xx3_uscib0_i2c_08.c            USCI_B0 I2C Master TX multiple bytes to MSP430 Slave
msp430g2xx3_uscib0_i2c_09.c            USCI_B0 I2C Slave RX multiple bytes from MSP430 Master
msp430g2xx3_uscib0_i2c_10.c            USCI_B0 I2C Master RX multiple bytes from MSP430 Slave
msp430g2xx3_uscib0_i2c_11.c            USCI_B0 I2C Slave TX multiple bytes to MSP430 Master
msp430g2xx3_uscib0_i2c_12.c            USCI_B0 I2C Master TX/RX multiple bytes from MSP430 Slave
msp430g2xx3_uscib0_i2c_13.c            USCI_B0 I2C Slave RX/TX multiple bytes to MSP430 Master
msp430g2xx3_wdt_01.c                   WDT, Toggle P1.0, Interval Overflow ISR, DCO SMCLK
msp430g2xx3_wdt_02.c                   WDT, Toggle P1.0, Interval Overflow ISR, 32kHz ACLK
msp430g2xx3_wdt_04.c                   WDT+ Failsafe Clock, DCO SMCLK
msp430g2xx3_wdt_05.c                   Reset on Invalid Address fetch, Toggle P1.0
msp430g2xx3_wdt_06.c                   WDT+ Failsafe Clock, 32kHz ACLK
msp430g2xx3_wdt_07.c                   WDT+ periodic reset
