# Name: Makefile
# Project: custom-class example
# Author: Christian Starkjohann
# Creation Date: 2008-04-06
# Tabsize: 4
# Copyright: (c) 2008 by OBJECTIVE DEVELOPMENT Software GmbH
# License: GNU GPL v2 (see License.txt), GNU GPL v3 or proprietary (CommercialLicense.txt)
# Concigure the following definitions according to your system.
# This Makefile has been tested on Mac OS X, Linux and Windows.
# Use the following 3 lines on Unix (uncomment the framework on Mac OS X):
USBFLAGS = `libusb-config --cflags`
USBLIBS = `libusb-config --libs`
EXE_SUFFIX =
# Use the following 3 lines on Windows and comment out the 3 above. You may
# have to change the include paths to where you installed libusb-win32
#USBFLAGS = -I/usr/local/include
#USBLIBS = -L/usr/local/lib -lusb
#EXE_SUFFIX = .exe
NAME = set-led
OBJECTS = opendevice.o $(NAME).o
CC		= gcc
CFLAGS	= $(CPPFLAGS) $(USBFLAGS) -O -g -Wall
LIBS	= $(USBLIBS)
PROGRAM = $(NAME)$(EXE_SUFFIX)
all: $(PROGRAM)
.c.o:
	$(CC) $(CFLAGS) -c $<
$(PROGRAM): $(OBJECTS)
	$(CC) -o $(PROGRAM) $(OBJECTS) $(LIBS)
strip: $(PROGRAM)
	strip $(PROGRAM)
clean:
	rm -f *.o $(PROGRAM)
