<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="1" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.1" altunitdist="mm" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<dimension x1="107" y1="80" x2="107" y2="28" x3="114" y3="54" layer="20"/>
<wire x1="106" y1="80" x2="26" y2="80" width="0.4064" layer="20"/>
<wire x1="26" y1="80" x2="26" y2="28" width="0.4064" layer="20"/>
<wire x1="106" y1="80" x2="106" y2="28" width="0.4064" layer="20"/>
<wire x1="106" y1="28" x2="26" y2="28" width="0.4064" layer="20"/>
<polygon width="0.4064" layer="41">
<vertex x="97" y="28"/>
<vertex x="97" y="37"/>
<vertex x="106" y="37"/>
<vertex x="106" y="28"/>
</polygon>
<vertex x="26" y="28"/>
<vertex x="26" y="37"/>
<vertex x="35" y="37"/>
<vertex x="35" y="28"/>
</polygon>
<dimension x1="26" y1="80" x2="106" y2="80" x3="66" y3="82" layer="20"/>
<vertex x="26" y="71"/>
<vertex x="26" y="80"/>
<vertex x="35" y="80"/>
<vertex x="35" y="71"/>
</polygon>
<vertex x="97" y="71"/>
<vertex x="97" y="80"/>
<vertex x="106" y="80"/>
<vertex x="106" y="71"/>
</polygon>
</plain>
<libraries>
<library name="alkatreszek">
<packages>
<package name="DIL08">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;</description>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.794" x2="5.08" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.794" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.3594" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.81" y="-0.9906" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL16">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="10.16" y1="2.921" x2="-10.16" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.921" x2="-10.16" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="-10.16" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.016" x2="-10.16" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-10.541" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-7.493" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LED3MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="R1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
</packages>
</library>
<library name="wirepad">
<description>&lt;b&gt;Single Pads&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="2,15/1,0">
<description>&lt;b&gt;THROUGH-HOLE PAD&lt;/b&gt;</description>
<wire x1="1.143" y1="-1.143" x2="1.143" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-1.143" x2="0.635" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.635" x2="1.143" y2="1.143" width="0.1524" layer="21"/>
<wire x1="1.143" y1="1.143" x2="0.635" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.143" x2="-1.143" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="1.143" x2="-1.143" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.635" x2="-1.143" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-1.143" x2="-0.635" y2="-1.143" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.016" width="0.1524" layer="51"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-1.143" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="1" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="switch-tact">
<description>&lt;b&gt;Diptronics THMD &amp; SMD tact switches&lt;/b&gt;
&lt;p&gt;&lt;ul&gt;
&lt;li&gt;DTS-3: 3.5x6mm THMD tact switch
&lt;li&gt;DTS-6, DTS-64: 6x6mm THMD tact switch
&lt;li&gt;DTSM-3: 3.5x6mm SMD tact switch
&lt;li&gt;DTSM-6, DTSM-64: 6x6mm SMD tact switch
&lt;/ul&gt;&lt;/p&gt;
&lt;p&gt;&lt;b&gt;Doublecheck before using!&lt;/b&gt;&lt;/p&gt;</description>
<packages>
<package name="DTS-6">
<wire x1="-3.1" y1="3.1" x2="3.1" y2="3.1" width="0.2032" layer="51"/>
<wire x1="3.1" y1="3.1" x2="3.1" y2="-3.1" width="0.2032" layer="51"/>
<wire x1="3.1" y1="-3.1" x2="-3.1" y2="-3.1" width="0.2032" layer="51"/>
<wire x1="-3.1" y1="-3.1" x2="-3.1" y2="3.1" width="0.2032" layer="51"/>
<wire x1="1.5" y1="3.1" x2="-1.5" y2="3.1" width="0.2032" layer="21"/>
<wire x1="3.1" y1="-1" x2="3.1" y2="1" width="0.2032" layer="21"/>
<wire x1="1.5" y1="-3.1" x2="-1.5" y2="-3.1" width="0.2032" layer="21"/>
<wire x1="-3.1" y1="-1" x2="-3.1" y2="1" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="1.75" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.75" width="0.2032" layer="21"/>
<pad name="1" x="-3.25" y="2.25" drill="1" shape="long"/>
<pad name="2" x="3.25" y="2.25" drill="1" shape="long"/>
<pad name="3" x="-3.25" y="-2.25" drill="1" shape="long"/>
<pad name="4" x="3.25" y="-2.25" drill="1" shape="long"/>
<text x="-2.54" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0mil"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="20mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="IC1" library="alkatreszek" package="DIL08" value="TINY11LP" x="38.05" y="46.95" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="19" y="66" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="19" y="66" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="19" y="66" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="19" y="66" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="IC2" library="alkatreszek" package="DIL16" value="74HC595N" x="56.13" y="47.65" rot="R180"/>
<element name="LED1" library="alkatreszek" package="LED3MM" value="TLLG4400" x="42.13" y="68.06" rot="R180">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="18" y="96" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="18" y="96" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="LED2" library="alkatreszek" package="LED3MM" value="TLLG4400" x="42.1" y="63.06" rot="R180">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="4" y="91" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="4" y="91" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="R1" library="alkatreszek" package="R1206" value="" x="37.79" y="68.07"/>
<element name="R2" library="alkatreszek" package="R1206" value="" x="37.71" y="63.07"/>
<element name="LED3" library="alkatreszek" package="LED3MM" value="TLLG4400" x="42.07" y="58.06" rot="R180">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="-10" y="86" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="-10" y="86" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="LED4" library="alkatreszek" package="LED3MM" value="TLLG4400" x="53.87" y="68.02">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="78" y="35" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="78" y="35" size="1.778" layer="27" display="off"/>
</element>
<element name="R3" library="alkatreszek" package="R1206" value="" x="37.63" y="58.07"/>
<element name="R4" library="alkatreszek" package="R1206" value="" x="58.45" y="67.93" rot="R180"/>
<element name="LED5" library="alkatreszek" package="LED3MM" value="TLLG4400" x="53.9" y="63.02">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="92" y="30" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="92" y="30" size="1.778" layer="27" display="off"/>
</element>
<element name="LED6" library="alkatreszek" package="LED3MM" value="TLLG4400" x="53.93" y="58.02">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="106" y="25" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="106" y="25" size="1.778" layer="27" display="off"/>
</element>
<element name="R5" library="alkatreszek" package="R1206" value="" x="58.53" y="62.93" rot="R180"/>
<element name="R6" library="alkatreszek" package="R1206" value="" x="58.61" y="57.93" rot="R180"/>
<element name="LED7" library="alkatreszek" package="LED3MM" value="TLLG4400" x="47.9" y="62.87" rot="R90">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="86" y="87" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="86" y="87" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="LED8" library="alkatreszek" package="LED3MM" value="TLLG4400" x="63.9" y="58.9" rot="R90">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="102" y="97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="102" y="97" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="R7" library="alkatreszek" package="R1206" value="" x="47.95" y="67.44" rot="R270"/>
<element name="R8" library="alkatreszek" package="R1206" value="" x="64.15" y="64.32" rot="R270"/>
<element name="IC3" library="alkatreszek" package="DIL16" value="74HC595N" x="80.99" y="46.65" rot="R180"/>
<element name="LED9" library="alkatreszek" package="LED3MM" value="TLLG4400" x="79.07" y="67.9" rot="R180">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="27" y="106" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="27" y="106" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="LED10" library="alkatreszek" package="LED3MM" value="TLLG4400" x="79.13" y="62.82" rot="R180">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="55" y="106" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="55" y="106" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="R9" library="alkatreszek" package="R1206" value="" x="74.6" y="68.15"/>
<element name="R10" library="alkatreszek" package="R1206" value="" x="74.52" y="63.15"/>
<element name="LED11" library="alkatreszek" package="LED3MM" value="TLLG4400" x="79.1" y="57.82" rot="R180">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="41" y="101" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="41" y="101" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="LED12" library="alkatreszek" package="LED3MM" value="TLLG4400" x="91.184" y="67.926">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="143.254" y="24.746" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="143.254" y="24.746" size="1.778" layer="27" display="off"/>
</element>
<element name="R11" library="alkatreszek" package="R1206" value="" x="74.44" y="58.15"/>
<element name="R12" library="alkatreszek" package="R1206" value="" x="95.64" y="67.85" rot="R180"/>
<element name="LED13" library="alkatreszek" package="LED3MM" value="TLLG4400" x="91.124" y="62.752">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="115.254" y="14.492" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="115.254" y="14.492" size="1.778" layer="27" display="off"/>
</element>
<element name="LED14" library="alkatreszek" package="LED3MM" value="TLLG4400" x="90.9" y="58.006">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="129" y="9.746" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="129" y="9.746" size="1.778" layer="27" display="off"/>
</element>
<element name="R13" library="alkatreszek" package="R1206" value="" x="95.72" y="62.85" rot="R180"/>
<element name="R14" library="alkatreszek" package="R1206" value="" x="95.2" y="58.15"/>
<element name="LED15" library="alkatreszek" package="LED3MM" value="TLLG4400" x="84.74" y="62.93" rot="R90">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="133" y="115" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="133" y="115" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="LED16" library="alkatreszek" package="LED3MM" value="TLLG4400" x="68.66" y="58.87" rot="R90">
<attribute name="MF" value="VISHAY SEMICONDUCTOR" x="122" y="83" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="1612435" x="122" y="83" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="R15" library="alkatreszek" package="R1206" value="" x="85.15" y="67.88" rot="R270"/>
<element name="R16" library="alkatreszek" package="R1206" value="" x="68.23" y="64.24" rot="R270"/>
<element name="R17" library="alkatreszek" package="0207/10" value="" x="99.18" y="46.03" rot="R180"/>
<element name="PAD2" library="wirepad" package="2,15/1,0" value="" x="61" y="31"/>
<element name="VCC" library="wirepad" package="2,15/1,0" value="" x="65" y="31"/>
<element name="S1" library="switch-tact" package="DTS-6" value="DTS-6" x="97" y="41"/>
<element name="10" library="wirepad" package="2,15/1,0" value="" x="29" y="56"/>
<element name="12" library="wirepad" package="2,15/1,0" value="" x="29" y="50"/>
<element name="11" library="wirepad" package="2,15/1,0" value="" x="29" y="53"/>
<element name="13" library="wirepad" package="2,15/1,0" value="" x="29" y="47"/>
</elements>
<signals>
<signal name="GND">
<contactref element="R1" pad="1"/>
<contactref element="R2" pad="1"/>
<contactref element="R3" pad="1"/>
<contactref element="R4" pad="1"/>
<contactref element="R5" pad="1"/>
<contactref element="R6" pad="1"/>
<contactref element="R7" pad="1"/>
<contactref element="R8" pad="1"/>
<contactref element="IC1" pad="4"/>
<contactref element="IC2" pad="13"/>
<contactref element="IC3" pad="13"/>
<contactref element="R17" pad="2"/>
<contactref element="IC2" pad="8"/>
<contactref element="IC3" pad="8"/>
<contactref element="PAD2" pad="1"/>
<wire x1="82.26" y1="42.84" x2="94.1" y2="46.03" width="0" layer="19" extent="1-1"/>
<wire x1="72.1" y1="50.46" x2="82.26" y2="42.84" width="0" layer="19" extent="1-1"/>
<wire x1="60.032" y1="57.93" x2="72.1" y2="50.46" width="0" layer="19" extent="1-1"/>
<wire x1="59.952" y1="62.93" x2="60.032" y2="57.93" width="0" layer="19" extent="1-1"/>
<wire x1="59.872" y1="67.93" x2="59.952" y2="62.93" width="0" layer="19" extent="1-1"/>
<wire x1="64.15" y1="65.742" x2="59.872" y2="67.93" width="0" layer="19" extent="1-1"/>
<wire x1="47.95" y1="68.862" x2="59.872" y2="67.93" width="0" layer="19" extent="1-1"/>
<wire x1="36.368" y1="68.07" x2="47.95" y2="68.862" width="0" layer="19" extent="1-1"/>
<wire x1="36.288" y1="63.07" x2="36.368" y2="68.07" width="0" layer="19" extent="1-1"/>
<wire x1="36.208" y1="58.07" x2="36.288" y2="63.07" width="0" layer="19" extent="1-1"/>
<wire x1="34.24" y1="50.76" x2="36.208" y2="58.07" width="0" layer="19" extent="1-1"/>
<wire x1="47.24" y1="51.46" x2="36.208" y2="58.07" width="0" layer="19" extent="1-1"/>
<wire x1="57.4" y1="43.84" x2="47.24" y2="51.46" width="0" layer="19" extent="1-1"/>
<wire x1="61" y1="31" x2="57.4" y2="43.84" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="+3V3">
<contactref element="IC3" pad="10"/>
<contactref element="IC2" pad="10"/>
<contactref element="IC2" pad="16"/>
<contactref element="IC3" pad="16"/>
<contactref element="S1" pad="4"/>
<contactref element="IC1" pad="8"/>
<contactref element="VCC" pad="1"/>
<wire x1="89.88" y1="42.84" x2="100.25" y2="38.75" width="0" layer="19" extent="1-1"/>
<wire x1="74.64" y1="42.84" x2="89.88" y2="42.84" width="0" layer="19" extent="1-1"/>
<wire x1="65.02" y1="43.84" x2="74.64" y2="42.84" width="0" layer="19" extent="1-1"/>
<wire x1="65" y1="31" x2="65.02" y2="43.84" width="0" layer="19" extent="1-1"/>
<wire x1="49.78" y1="43.84" x2="65.02" y2="43.84" width="0" layer="19" extent="1-1"/>
<wire x1="41.86" y1="43.14" x2="49.78" y2="43.84" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$1">
<contactref element="IC2" pad="7"/>
<contactref element="LED8" pad="A"/>
<wire x1="49.78" y1="51.46" x2="63.9" y2="57.63" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$2">
<contactref element="IC2" pad="6"/>
<contactref element="LED7" pad="A"/>
<wire x1="52.32" y1="51.46" x2="47.9" y2="61.6" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$3">
<contactref element="IC2" pad="5"/>
<contactref element="LED6" pad="A"/>
<wire x1="54.86" y1="51.46" x2="52.66" y2="58.02" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$4">
<contactref element="IC2" pad="4"/>
<contactref element="LED5" pad="A"/>
<wire x1="57.4" y1="51.46" x2="52.63" y2="63.02" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$5">
<contactref element="IC2" pad="3"/>
<contactref element="LED4" pad="A"/>
<wire x1="59.94" y1="51.46" x2="52.6" y2="68.02" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$6">
<contactref element="IC2" pad="2"/>
<contactref element="LED3" pad="A"/>
<wire x1="43.34" y1="58.06" x2="62.48" y2="51.46" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$7">
<contactref element="IC2" pad="1"/>
<contactref element="LED2" pad="A"/>
<wire x1="43.37" y1="63.06" x2="65.02" y2="51.46" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$8">
<contactref element="IC2" pad="15"/>
<contactref element="LED1" pad="A"/>
<wire x1="62.48" y1="43.84" x2="43.4" y2="68.06" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$9">
<contactref element="LED1" pad="K"/>
<contactref element="R1" pad="2"/>
<wire x1="39.212" y1="68.07" x2="40.86" y2="68.06" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$10">
<contactref element="LED2" pad="K"/>
<contactref element="R2" pad="2"/>
<wire x1="39.132" y1="63.07" x2="40.83" y2="63.06" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$11">
<contactref element="LED3" pad="K"/>
<contactref element="R3" pad="2"/>
<wire x1="39.052" y1="58.07" x2="40.8" y2="58.06" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$12">
<contactref element="LED4" pad="K"/>
<contactref element="R4" pad="2"/>
<wire x1="55.14" y1="68.02" x2="57.028" y2="67.93" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$13">
<contactref element="LED5" pad="K"/>
<contactref element="R5" pad="2"/>
<wire x1="55.17" y1="63.02" x2="57.108" y2="62.93" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$14">
<contactref element="LED6" pad="K"/>
<contactref element="R6" pad="2"/>
<wire x1="55.2" y1="58.02" x2="57.188" y2="57.93" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$15">
<contactref element="LED7" pad="K"/>
<contactref element="R7" pad="2"/>
<wire x1="47.95" y1="66.018" x2="47.9" y2="64.14" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$16">
<contactref element="LED8" pad="K"/>
<contactref element="R8" pad="2"/>
<wire x1="63.9" y1="60.17" x2="64.15" y2="62.898" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="GND1">
<contactref element="R9" pad="1"/>
<contactref element="R10" pad="1"/>
<contactref element="R11" pad="1"/>
<contactref element="R12" pad="1"/>
<contactref element="R13" pad="1"/>
<contactref element="R14" pad="1"/>
<contactref element="R15" pad="1"/>
<contactref element="R16" pad="1"/>
<wire x1="97.142" y1="62.85" x2="97.062" y2="67.85" width="0" layer="19" extent="1-1"/>
<wire x1="93.778" y1="58.15" x2="97.142" y2="62.85" width="0" layer="19" extent="1-1"/>
<wire x1="85.15" y1="69.302" x2="97.062" y2="67.85" width="0" layer="19" extent="1-1"/>
<wire x1="73.178" y1="68.15" x2="85.15" y2="69.302" width="0" layer="19" extent="1-1"/>
<wire x1="73.098" y1="63.15" x2="73.178" y2="68.15" width="0" layer="19" extent="1-1"/>
<wire x1="73.018" y1="58.15" x2="73.098" y2="63.15" width="0" layer="19" extent="1-1"/>
<wire x1="68.23" y1="65.662" x2="73.098" y2="63.15" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$17">
<contactref element="IC3" pad="7"/>
<contactref element="LED16" pad="A"/>
<wire x1="74.64" y1="50.46" x2="68.66" y2="57.6" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$18">
<contactref element="IC3" pad="6"/>
<contactref element="LED15" pad="A"/>
<wire x1="77.18" y1="50.46" x2="84.74" y2="61.66" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$19">
<contactref element="IC3" pad="5"/>
<contactref element="LED14" pad="A"/>
<wire x1="79.72" y1="50.46" x2="89.63" y2="58.006" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$20">
<contactref element="IC3" pad="4"/>
<contactref element="LED13" pad="A"/>
<wire x1="82.26" y1="50.46" x2="89.854" y2="62.752" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$21">
<contactref element="IC3" pad="3"/>
<contactref element="LED12" pad="A"/>
<wire x1="84.8" y1="50.46" x2="89.914" y2="67.926" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$22">
<contactref element="IC3" pad="2"/>
<contactref element="LED11" pad="A"/>
<wire x1="80.37" y1="57.82" x2="87.34" y2="50.46" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$23">
<contactref element="IC3" pad="1"/>
<contactref element="LED10" pad="A"/>
<wire x1="89.88" y1="50.46" x2="80.4" y2="62.82" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$24">
<contactref element="IC3" pad="15"/>
<contactref element="LED9" pad="A"/>
<wire x1="87.34" y1="42.84" x2="80.34" y2="67.9" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$25">
<contactref element="LED9" pad="K"/>
<contactref element="R9" pad="2"/>
<wire x1="76.022" y1="68.15" x2="77.8" y2="67.9" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$26">
<contactref element="LED10" pad="K"/>
<contactref element="R10" pad="2"/>
<wire x1="75.942" y1="63.15" x2="77.86" y2="62.82" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$27">
<contactref element="LED11" pad="K"/>
<contactref element="R11" pad="2"/>
<wire x1="75.862" y1="58.15" x2="77.83" y2="57.82" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$28">
<contactref element="LED12" pad="K"/>
<contactref element="R12" pad="2"/>
<wire x1="92.454" y1="67.926" x2="94.218" y2="67.85" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$29">
<contactref element="LED13" pad="K"/>
<contactref element="R13" pad="2"/>
<wire x1="92.394" y1="62.752" x2="94.298" y2="62.85" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$30">
<contactref element="LED14" pad="K"/>
<contactref element="R14" pad="2"/>
<wire x1="92.17" y1="58.006" x2="96.622" y2="58.15" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$31">
<contactref element="LED15" pad="K"/>
<contactref element="R15" pad="2"/>
<wire x1="84.74" y1="64.2" x2="85.15" y2="66.458" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$32">
<contactref element="LED16" pad="K"/>
<contactref element="R16" pad="2"/>
<wire x1="68.23" y1="62.818" x2="68.66" y2="60.14" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$35">
<contactref element="IC2" pad="9"/>
<contactref element="IC3" pad="14"/>
<wire x1="47.24" y1="43.84" x2="84.8" y2="42.84" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$34">
<contactref element="IC2" pad="11"/>
<contactref element="IC3" pad="11"/>
<contactref element="IC1" pad="5"/>
<contactref element="11" pad="1"/>
<wire x1="52.32" y1="43.84" x2="77.18" y2="42.84" width="0" layer="19" extent="1-1"/>
<wire x1="34.24" y1="43.14" x2="52.32" y2="43.84" width="0" layer="19" extent="1-1"/>
<wire x1="29" y1="53" x2="34.24" y2="43.14" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$37">
<contactref element="IC2" pad="12"/>
<contactref element="IC3" pad="12"/>
<contactref element="IC1" pad="6"/>
<contactref element="12" pad="1"/>
<wire x1="54.86" y1="43.84" x2="79.72" y2="42.84" width="0" layer="19" extent="1-1"/>
<wire x1="36.78" y1="43.14" x2="54.86" y2="43.84" width="0" layer="19" extent="1-1"/>
<wire x1="29" y1="50" x2="36.78" y2="43.14" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$38">
<contactref element="IC1" pad="7"/>
<contactref element="IC2" pad="14"/>
<contactref element="13" pad="1"/>
<wire x1="39.32" y1="43.14" x2="59.94" y2="43.84" width="0" layer="19" extent="1-1"/>
<wire x1="29" y1="47" x2="39.32" y2="43.14" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$33">
<contactref element="IC1" pad="3"/>
<contactref element="S1" pad="1"/>
<contactref element="S1" pad="2"/>
<wire x1="93.75" y1="43.25" x2="100.25" y2="43.25" width="0" layer="19" extent="1-1"/>
<wire x1="36.78" y1="50.76" x2="93.75" y2="43.25" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$36">
<contactref element="S1" pad="3"/>
<contactref element="R17" pad="1"/>
<wire x1="93.75" y1="38.75" x2="104.26" y2="46.03" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$39">
<contactref element="10" pad="1"/>
<contactref element="IC1" pad="1"/>
<wire x1="29" y1="56" x2="41.86" y2="50.76" width="0" layer="19" extent="1-1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
