Specification
• AMPLIFIER SECTION
Rated minimum sine wave RMS power output
20 Hz-20 kHz both channels driven
0.3% total harmonic distortion
100 W per channel (6Ω )
1 kHz continuous power output both channels driven
105 W per channel (6Ω )
Total harmonic distortion
rated power at 20 Hz-20 kHz
0.3% (6Ω )
Power output each channel driven
0.9% total harmonic distortion at 1kHz
Front (L/ R)
100 W (6Ω )
Center
100 W (6Ω )
Surround (L/ R/ BACK)
100 W (6Ω )
Load impedance
Front (L/ R)
6-8Ω
Center
6-8Ω
6-8Ω
Frequency response
CD, TV, DVD/ DVD 6CH, DVR/ VCR, TAPE
10 Hz-44 kHz,± 3 dB
Input sensitivity
27 mV (200mV, IHF 66)
Input impedance
22 kΩ
S/ N (IHF A)
TV, DVD, DVR/ VCR (Digital Input)
85 dB (98dB, IHF 66)
Tone controls
BASS
50 Hz,+ 10 to -10 dB
TREBLE
20 kHz,+ 10 to -10 dB
Subwoofer frequency response (-6 dB)
7 Hz-200 Hz
Digital input
Optical (DVD: Fs 192 kHz Ready)
3
Coaxial
1
Digital output
Optical
1
• FM TUNER SECTION
Frequency range
87.9-107.9 MHz
Sensitivity
11.2 dBf (2μ V, IHF 58)
50 dB quieting sensitivity
MONO
18.3 dBf (4.5μ V, IHF 58)
STEREO
38.3 dBf (45μ V, IHF 58)
MONO
0.2%
STEREO
0.3%
S/ N
MONO
73 dB
STEREO
67 dB
Frequency response
20 Hz-15 kHz,+ 1 dB, -2 dB
Alternate channel selectivity
65 dB
Capture ratio
1.5 dB
Image rejection at 98 MHz
40 dB
Spurious response rejection at 98 MHz
75 dB
AM suppression
50 dB
Stereo separation
1 kHz
40 dB
10 kHz
30 dB
Antenna terminal
75Ω (unbalanced)
• AM TUNER SECTION
Frequency range
530-1710 kHz
Sensitivity
20μ V, 330μ V/ m
Selectivity
55 dB
IF rejection at 1000 kHz
50 dB
• VIDEO SECTION
Output voltage at 1V input (unbalanced)
1± 0.1 Vp-p
Maximum input voltage
1.5 Vp-p
Input/ output impedance
75Ω
S-Video
Input
TV, DVD, DVR/ VCR
Output
TV MONITOR
Component Video
Input
TV, DVD
Output
TV MONITOR
• GENERAL
Power supply
AC 120 V, 60 Hz
Power consumption
130 W
Dimensions (W× H× D)
430× 74× 375 mm (16-15/ 16 × 2-29/ 32 × 14-3/ 4 )
Mass
4.2 kg (9.2 lb.)
• DIN POWER
1 kHz, T.H. D1%
2 x 100 W (6Ω )
Power consumption in standby mode:
1 W
Notes:
1.
Specifications are subject to change without notice.
Mass and dimensions are approximate.
2.
Total harmonic distortion is measured by the digital spectrum analyzer.
