LCD display
Symptom
Cause and Remedy
OVERLOAD
Speaker short, amplifier failure
Speaker short and failure in power amplifier, pre-amplifier circuits. Check for faulty parts and replace with new parts if necessary.
Humidity protection activated
FANLOCK
The fan stops suddenly.
Failure in fan or fan control circuits. Check for faulty parts and replace with new parts if necessary.
F70
Communication error between sub micro processor and its peripheral LSI
Failure sub-micro processor and its peripherals LSI. Check for faulty parts and replace with new parts if necessary.
F76
When the power is turned on, the unit power automatically turns off; the power cannot be turned on.
Failure in the power circuit system of the unit. This may happen when the direct current electricity is supplied to speaker terminals. Check for the above and replace with new parts if necessary.
