14.1 IC801 (C2BBGF000440): System Control (Micro P)
TOP PREVIOUS NEXT
Pin NO.
Terminal Name
I/O
Function
1
LED_CK
O
LED Driver Control : Clock
2
LED_DT
I
LED Driver Control : Data
3
LED_ST
I/O
LED Driver Control : Strobe
4
E_DT
O
EEPROM Control : Data
5
E_CK
O
EEPROM Control : Clock
6
E_CS
O
EEPROM Control : Chip Select
7
REQS
I/O
Communication to Sub up : Request from Sub up
8
REQM
I/O
Communication to Sub up : Request from Main up
9
M_CK
O
Communication to Main up : Clock
10
M2S_DT
O
Communication to Main up : Serial Output
11
S2M_DT
I
Communication to Main up : Serial Input
12
F_BUSY
I/O
To rewrite up ROM : BUSY
13
F_CK
O
To rewrite up ROM : CLOCK
14
V_A
I/O
Video Selector Control : A
15
F_DA
I/O
To rewrite uP ROM : DATA
16
V_B
I/O
Video Selector Control : B
17
REMOTE
I
Remote Control Signal Input
18
CNVSS
(VPP)
12V supply to rewrite Flash ROM
19
RESET
Reset Input
20
AC__SYNC
Power Faillure Detection
21
FAN_LOCK
FAN LOCK Detection
22
XIN
10MHz Connect to Oscillator
23
XOUT
24
VSS
Connect to GND
25
MT_ALL
O
MUTE for all channel
26
MT_C/SR
O
MUTE for C/SURR
27
MT_SUB
O
MUTE for SUBWFR
28
MT_HP
O
MUTE for Headphones
29
OSD_CK
O
OSD Control : Clock
30
OSD_DT
I
OSD Control : Data
31
OSD_ST
I/O
OSD Control : Strobe
32
DC_DET
I
DC Short Detection
33
INI_OUT
O
Output for Initialize Setting
34
POWER_RLY
Power Relay Control (H ; ON)
35
M_RESET
O
RESET signal for sub up
36
FAN_CTRL
O
Cooling Fan Control Output
37
HP_SW
I
Headphone Detection
38
MT_2ND
O
MUTE for 2nd Audio
39
RDS_CK
O
RDS IC Control : Clock
40
RDS_DI
I
RDS IC Control : Data
41
INIT_IN1
I
Initialize Setting Input 1
42
INIT_IN2
I
Initialize Setting Input 2
43
TUN_SD
I
SD Input for Tuner
44
TUN_DI/ST
I
IF data/Stero detect input for tuner
45
TUN_CE
O
CE Output for tuner
46
SEL/TN/
DA_CK
O
Input Selector, Tuner and D/A Control : Clock
47
SEL/TN/
DA_DT
O
Input Selector, Tuner and D/A Control : Data
48
SEL_ST
O
Input Selector Control : Strobe
49
F_OE
O
To rewrite up ROM : ENABLE
50
FL_CK
O
FL Driver Control : Clock
51
FL_DT
I
FL Driver Control : Data
52
FL_ST
I/O
FL Driver Control : Strobe
53
AMP_RESET
O
TAS5036 Hardware Reset
54
DBL_SPD
I/O
Sample Rate Double Speed Control to the modulator IC
55
A/D_ATT
I/O
A/D attenuator Control
56
D/A_ST
I/O
D/A Control : Strobe
57
VCC
+5V power supply
58
VREF
VCC Connected
59
AVSS
GND Connected
60
THRM_DET
I
Thermal Warning Detection
61
SHORT_DET
I
Output Short Detection
62
SPKR_IN
O
Speaker Output Voltage Input for FAN Control
63
KEY2
I
Key input 2
64
KEY1
I
Key input 1
TOP PREVIOUS NEXT
