15.1.2 Cabinet Parts List
TOP
PREVIOUS
NEXT
Ref. No.
Part No.
Part Name & Description
Remarks
CABINET AND CHASSIS
1
RAN0001MM-2
TUNER
[M]
2
REE1224
15P FFC WIRE
[M]
3
REE1225
14P FFC WIRE
[M]
4
REE1226
21P FFC WIRE
[M]
5
REE1227
14P FFC WIRE
[M]
6
REM0104
SMALL FAN
[M]
7
RGB0144-K
DIGITAL BADGE
[M]K
7
RGB0144-N
DIGITAL BADGE
[M]S
8
RGB0145-N
PANASONIC BADGE
[M]
9
RGK1611A-K
FRONT ORNAMENT L
[M]K
9
RGK1611A-S
FRONT ORNAMENT L
[M]S
10
RGK1612A-K
FRONT ORNAMENT R
[M]K
10
RGK1612A-S
FRONT ORNAMENT R
[M]S
11
RGK1613-K
TOP ORNAMENT
[M]K
11
RGK1613-S
TOP ORNAMENT
[M]S
12
RGK1614-S
VOLUME RING
[M]
13
RGK1615-K
SIDE ORNAMENT L
[M]
14
RGK1616-K
SIDE ORNAMENT R
[M]
15
RGK1683-K
RING SHEET
[M]
16
RGL0618-Q
LIGHT GUIDE
[M]
17
RGL0621-Q
LED LIGHT GUIDE
[M]
18
RGR0335B-A
REAR PANEL
[M]
19
RGU2177-H
POWER BUTTON
[M]K
19
RGU2177-K
POWER BUTTON
[M]S
20
RGU2178-H
TUNER BUTTON
[M]K
20
RGU2178-K
TUNER BUTTON
[M]S
21
RGU2179-S
SELECTOR BUTTON
[M]
22
RGW0396-K
VOLUME KNOB
[M]K
22
RGW0396-S
VOLUME KNOB
[M]S
23
RHD26016
SCREW (PHONE JACK)
[M]
24
RHD30007-1S
SCREW
[M]S
24
RHD30007-K1
SCREW
[M]K
25
RHD30070
EARTH TERMINAL
[M]
26
RHN90001
M9 NUT
[M]
27
RKA0132-K
SET LEG UNIT
[M]
28
RKF0664-K
FAN COVER
[M]
29
RKM0481-K
TOP CABINET
[M]K
29
RKM0481-S
TOP CABINET
[M]S
30
RKW0719-K
TOP ORNAMENT SHEET
[M]K
30
RKW0719-S
TOP ORNAMENT SHEET
[M]S
31
RKW0720A-Q1
FL WINDOW
[M]K
31
RKW0720-S1
FL WINDOW
[M]S
32
RKW0721-K
REMOTE WINDOW
[M]
33
RMC0465
TR SPRING
[M]
34
RMC0477
THERMISTOR SPRING
[M]
35
RFKJAXR45PPK
BOTTOM CHASSIS ASSY
[M]
36
RMN0203
PCB SUPPORT
[M]
37
RMN0724
PCB HOLDER
[M]
38
RMN0740
FL HOLDER
[M]
39
RMN0747
LED HOLDER
[M]
40
RMQ1183
FRONT SHEILD ANGLE
[M]
41
RMR1359-W
PCB SUPPORT (DECODER
[M]
42
RMR1517-W
REFLECTION PLATE A
[M]
43
RMR1518-W
REFLECTION PLATE B
[M]
44
RXX0265
DIGITAL HEAT SINK UN
[M]
45
SHE185-3
PCB SUPPORT
[M]
46
SHR411
PLASTIC RIVET
[M]
47
XTB3+16JFZ
SCREW
[M]
48
XTB3+6G
SCREW
[M]
49
XTB3+8J
SCREW
[M]
50
XTBS26+10J
SCREW
[M]
51
XTBS3+8JFZ1
SCREW
[M]
52
XTN26+4F
SCREW
[M]
53
XTW3+8T
SCREW
[M]
54
XYB3+F8
SCREW
[M]
55
XYN3+F10
SCREW
[M]
57
RGP0984B-K
FRONT PANEL
[M]S
57
RGP0984F-H
FRONT PANEL
[M]K
59
RMZ0339
ZENER COVER
[M]
60
RXX0266
D.D HEAT SINK UNIT
[M]
61
RGU2189-Q1
REMASTER BTN
[M]
TOP
PREVIOUS
NEXT
