<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="DIL16">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="10.16" y1="2.921" x2="-10.16" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.921" x2="-10.16" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="-10.16" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.016" x2="-10.16" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" diameter="1.9304" shape="long" rot="R90"/>
<text x="2.921" y="0.889" size="1.27" layer="25" ratio="10" rot="R180">&gt;NAME</text>
</package>
<package name="SOCKED-16">
<description>&lt;b&gt;Dual In Line Socket&lt;/b&gt;</description>
<wire x1="10.16" y1="3.81" x2="-10.16" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-3.81" x2="10.16" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-3.81" x2="-10.16" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="3.81" x2="-10.16" y2="1.016" width="0.1524" layer="21"/>
<wire x1="10.16" y1="3.81" x2="10.16" y2="-3.81" width="0.1524" layer="21"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" diameter="1.6764" shape="long" rot="R90"/>
<text x="1.778" y="0.381" size="1.27" layer="25" ratio="10" rot="R180">&gt;NAME</text>
</package>
</packages>
<symbols>
<symbol name="MAX232">
<pin name="C1+" x="-12.7" y="10.16" visible="pin" length="middle"/>
<pin name="V+" x="-12.7" y="7.62" visible="pin" length="middle"/>
<pin name="C1-" x="-12.7" y="5.08" visible="pin" length="middle"/>
<pin name="C2+" x="-12.7" y="2.54" visible="pin" length="middle"/>
<pin name="C2-" x="-12.7" y="0" visible="pin" length="middle"/>
<pin name="V-" x="-12.7" y="-2.54" visible="pin" length="middle"/>
<pin name="T2O" x="-12.7" y="-5.08" visible="pin" length="middle"/>
<pin name="R2I" x="-12.7" y="-7.62" visible="pin" length="middle"/>
<pin name="R2O" x="12.7" y="-7.62" visible="pin" length="middle" rot="R180"/>
<pin name="T2I" x="12.7" y="-5.08" visible="pin" length="middle" rot="R180"/>
<pin name="T1I" x="12.7" y="-2.54" visible="pin" length="middle" rot="R180"/>
<pin name="R1O" x="12.7" y="0" visible="pin" length="middle" rot="R180"/>
<pin name="R1I" x="12.7" y="2.54" visible="pin" length="middle" rot="R180"/>
<pin name="T1O" x="12.7" y="5.08" visible="pin" length="middle" rot="R180"/>
<pin name="GND" x="12.7" y="7.62" visible="pin" length="middle" rot="R180"/>
<pin name="VCC" x="12.7" y="10.16" visible="pin" length="middle" rot="R180"/>
<wire x1="-7.62" y1="12.7" x2="7.62" y2="12.7" width="0.254" layer="94"/>
<wire x1="7.62" y1="12.7" x2="7.62" y2="-10.16" width="0.254" layer="94"/>
<wire x1="7.62" y1="-10.16" x2="-7.62" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-10.16" x2="-7.62" y2="12.7" width="0.254" layer="94"/>
<text x="-3.556" y="13.97" size="1.27" layer="95">&gt;NAME</text>
</symbol>
<symbol name="DIL16">
<wire x1="-5.08" y1="8.89" x2="-5.08" y2="-11.43" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-11.43" x2="5.08" y2="-11.43" width="0.254" layer="94"/>
<wire x1="5.08" y1="-11.43" x2="5.08" y2="8.89" width="0.254" layer="94"/>
<wire x1="5.08" y1="8.89" x2="2.54" y2="8.89" width="0.254" layer="94"/>
<wire x1="-5.08" y1="8.89" x2="-2.54" y2="8.89" width="0.254" layer="94"/>
<wire x1="-2.54" y1="8.89" x2="2.54" y2="8.89" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="9.525" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-13.97" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="9" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="10" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="12" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MAX232">
<gates>
<gate name="G$1" symbol="MAX232" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL16">
<connects>
<connect gate="G$1" pin="C1+" pad="1"/>
<connect gate="G$1" pin="C1-" pad="3"/>
<connect gate="G$1" pin="C2+" pad="4"/>
<connect gate="G$1" pin="C2-" pad="5"/>
<connect gate="G$1" pin="GND" pad="15"/>
<connect gate="G$1" pin="R1I" pad="13"/>
<connect gate="G$1" pin="R1O" pad="12"/>
<connect gate="G$1" pin="R2I" pad="8"/>
<connect gate="G$1" pin="R2O" pad="9"/>
<connect gate="G$1" pin="T1I" pad="11"/>
<connect gate="G$1" pin="T1O" pad="14"/>
<connect gate="G$1" pin="T2I" pad="10"/>
<connect gate="G$1" pin="T2O" pad="7"/>
<connect gate="G$1" pin="V+" pad="2"/>
<connect gate="G$1" pin="V-" pad="6"/>
<connect gate="G$1" pin="VCC" pad="16"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="2" package="SOCKED-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL16" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Dual In Line&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="DIL16" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOCKED-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
