CS.	REFERENCIA				rtk				X.	        X.
1	R101					0.33 				3		3
2	R22,R202				150				3		6
2	R20,R21					220				3		6
1	R102					330				3		3
2	R13,R12					470				3		6
1	R103					820				3		3
1	R201					1K				3		3
1	R9					1K5				3		3
5	R2,R16,R17,R18,R19			4K7				3		15
1	R3					10K				3		3
1	R8					15K				3		3
4	R4,R5,R6,R7				22K 1%				6		24
2	R10,R11					39K				3		6
3	R14,R23,R24				100K				3		9
1	R15					120K				3		3
1	R1					150K				3		3
1	POT101					470R multi			180		180
1	POT1					2K   multi			180		180
4	POT2,POT3,POT4,POT202			10K  multi			180		720
1	POT201					47K  multi			180		180
1	C2					3p3  ceramic			10		10
1	C3					5p6  ceramic			10		10
1	C1					150p ceramic			10		10
7	CU1+,CU1-,CU2+,CU2-,CU3+,CU3-,C203	100n polyester			25		175
5	C102,C106,C110,C4,C5			220n polyester			30		150
1	C201					270n polyester			30		30
3	C103,C107,C111				1u 16V  tantal			25		75
4	C202,C108,C112,C-DP			10u 16V tantal  		25		100
1	C104					1000u 16V electrolt		40		40
2	C109,C105				1000u 25V electrolt		40		80
1	C101					4700u 25V electrolt		120		120
3	D101,D102,D103				1N4007				7		21
4	D3,D4,D5,D6				1N4148				4		16
1	D7					LED     			15		15
2	T1,T2					BC547				12		24
3	T201,T202,T203				BC557				12		36
2	U1,U2					TL084				75		150
1	U3					LF356				92		92
1	U201					CA3162				900		900
1	U202					CA3161				250		250
1	U101					L200				200		200
1	U102					LM7805				50		50
1	U103					LM7905				50		50
2	Z1,Z2					Z  14 pins			20		40
1	Z3					Z   8 pins			15		15
2	Z201,Z202				Z  16 pins			20		40
1	Z-DP					z  30 pins large.       	120		120
1	J1					Jumper 2 x 4.			25		25
1	J101					Jumper 2 x 1.			10		10
4	TP2,TP1,TP101,TP102			Test point 			5		20
1	SW101					Interruptor			90		90
1	CON1					Conector BNC hembra		450		450
1	CON101					Conector alimentacin		30		30
1	CON2					Jack stereo 3.5mm hembra	30		30
3	DP201,DP202,DP203			Display 7segs. anod com. 	140		420
1	DISIP101				Disipador 35mm x 15mm		150		150
1	BOX					BOX 150 x 70 x 50 mm		600		600
2002.03.03. M.Zoli
