<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.5" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="1" altunitdist="mm" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="yes" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="yes" active="yes"/>
<layer number="103" name="fp3" color="7" fill="1" visible="no" active="yes"/>
<layer number="104" name="Name" color="7" fill="1" visible="yes" active="yes"/>
<layer number="105" name="Beschreib" color="9" fill="1" visible="yes" active="yes"/>
<layer number="106" name="BGA-Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="107" name="BD-Top" color="5" fill="1" visible="yes" active="yes"/>
<layer number="108" name="fp8" color="7" fill="1" visible="no" active="yes"/>
<layer number="109" name="fp9" color="7" fill="1" visible="no" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="no" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="yes" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="no" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="no" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="no" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="no" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="yes" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="yes" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="no"/>
<layer number="201" name="201bmp" color="2" fill="1" visible="no" active="no"/>
<layer number="202" name="202bmp" color="3" fill="1" visible="no" active="no"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="yes" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="yes" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="yes" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="yes" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="yes" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="yes" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="no" active="yes"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="50" y2="0" width="0" layer="20"/>
<wire x1="50" y1="0" x2="50" y2="50" width="0" layer="20"/>
<wire x1="50" y1="50" x2="0" y2="50" width="0" layer="20"/>
<hole x="7" y="46" drill="3.2"/>
<hole x="43" y="46" drill="3.2"/>
<hole x="35" y="15" drill="3.2"/>
<hole x="15" y="15" drill="3.2"/>
<text x="40" y="3" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">ServoShifter REV A</text>
<text x="40" y="1" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">kiu</text>
<text x="14" y="4" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="14" y="3" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="14" y="2" size="0.8128" layer="25" font="vector" ratio="11" align="center">CTL</text>
<text x="19" y="7" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="19" y="6" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="19" y="9" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="19" y="8" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="19" y="4" size="0.8128" layer="25" font="vector" ratio="11" align="center">QH/D</text>
<text x="19" y="3" size="0.8128" layer="25" font="vector" ratio="11" align="center">RCK</text>
<text x="19" y="2" size="0.8128" layer="25" font="vector" ratio="11" align="center">SCK</text>
<wire x1="0" y1="50" x2="0" y2="0" width="0" layer="20"/>
<wire x1="21" y1="10" x2="17" y2="10" width="0.1" layer="25"/>
<wire x1="17" y1="10" x2="17" y2="1" width="0.1" layer="25"/>
<wire x1="17" y1="1" x2="21" y2="1" width="0.1" layer="25"/>
<wire x1="21" y1="1" x2="21" y2="10" width="0.1" layer="25"/>
<wire x1="12" y1="1" x2="16" y2="1" width="0.1" layer="25"/>
<wire x1="16" y1="1" x2="16" y2="5" width="0.1" layer="25"/>
<wire x1="16" y1="5" x2="12" y2="5" width="0.1" layer="25"/>
<wire x1="12" y1="5" x2="12" y2="1" width="0.1" layer="25"/>
<text x="19" y="5" size="0.8128" layer="25" font="vector" ratio="11" align="center">NC</text>
<text x="27.5" y="31" size="1.016" layer="1" font="vector" ratio="20" align="bottom-right">kiu</text>
<text x="27" y="3" size="1.016" layer="26" font="vector" ratio="14" rot="MR0" align="bottom-right">ORDER 43284 III</text>
<wire x1="12" y1="7" x2="12" y2="5" width="0.1" layer="25"/>
<wire x1="16" y1="5" x2="16" y2="7" width="0.1" layer="25"/>
<wire x1="21" y1="10" x2="21" y2="12" width="0.1" layer="25"/>
<wire x1="17" y1="12" x2="17" y2="10" width="0.1" layer="25"/>
<text x="19" y="11" size="0.8128" layer="25" font="vector" ratio="11" align="center">CON</text>
<wire x1="21" y1="12" x2="17" y2="12" width="0.1" layer="25"/>
<wire x1="16" y1="7" x2="12" y2="7" width="0.1" layer="25"/>
<text x="14" y="6" size="0.8128" layer="25" font="vector" ratio="11" align="center">SERVO</text>
<wire x1="53" y1="0" x2="103" y2="0" width="0" layer="20"/>
<wire x1="103" y1="0" x2="103" y2="50" width="0" layer="20"/>
<wire x1="103" y1="50" x2="53" y2="50" width="0" layer="20"/>
<hole x="60" y="46" drill="3.2"/>
<hole x="96" y="46" drill="3.2"/>
<hole x="88" y="15" drill="3.2"/>
<hole x="68" y="15" drill="3.2"/>
<text x="93" y="3" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">ServoShifter REV A</text>
<text x="93" y="1" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">kiu</text>
<text x="67" y="4" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="67" y="3" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="67" y="2" size="0.8128" layer="25" font="vector" ratio="11" align="center">CTL</text>
<text x="72" y="7" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="72" y="6" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="72" y="9" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="72" y="8" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="72" y="4" size="0.8128" layer="25" font="vector" ratio="11" align="center">QH/D</text>
<text x="72" y="3" size="0.8128" layer="25" font="vector" ratio="11" align="center">RCK</text>
<text x="72" y="2" size="0.8128" layer="25" font="vector" ratio="11" align="center">SCK</text>
<wire x1="53" y1="50" x2="53" y2="0" width="0" layer="20"/>
<wire x1="74" y1="10" x2="70" y2="10" width="0.1" layer="25"/>
<wire x1="70" y1="10" x2="70" y2="1" width="0.1" layer="25"/>
<wire x1="70" y1="1" x2="74" y2="1" width="0.1" layer="25"/>
<wire x1="74" y1="1" x2="74" y2="10" width="0.1" layer="25"/>
<wire x1="65" y1="1" x2="69" y2="1" width="0.1" layer="25"/>
<wire x1="69" y1="1" x2="69" y2="5" width="0.1" layer="25"/>
<wire x1="69" y1="5" x2="65" y2="5" width="0.1" layer="25"/>
<wire x1="65" y1="5" x2="65" y2="1" width="0.1" layer="25"/>
<text x="72" y="5" size="0.8128" layer="25" font="vector" ratio="11" align="center">NC</text>
<text x="80.5" y="31" size="1.016" layer="1" font="vector" ratio="20" align="bottom-right">kiu</text>
<text x="80" y="3" size="1.016" layer="26" font="vector" ratio="14" rot="MR0" align="bottom-right">ORDER 43284 III</text>
<wire x1="65" y1="7" x2="65" y2="5" width="0.1" layer="25"/>
<wire x1="69" y1="5" x2="69" y2="7" width="0.1" layer="25"/>
<wire x1="74" y1="10" x2="74" y2="12" width="0.1" layer="25"/>
<wire x1="70" y1="12" x2="70" y2="10" width="0.1" layer="25"/>
<text x="72" y="11" size="0.8128" layer="25" font="vector" ratio="11" align="center">CON</text>
<wire x1="74" y1="12" x2="70" y2="12" width="0.1" layer="25"/>
<wire x1="69" y1="7" x2="65" y2="7" width="0.1" layer="25"/>
<text x="67" y="6" size="0.8128" layer="25" font="vector" ratio="11" align="center">SERVO</text>
<wire x1="0" y1="-53" x2="50" y2="-53" width="0" layer="20"/>
<wire x1="50" y1="-53" x2="50" y2="-3" width="0" layer="20"/>
<wire x1="50" y1="-3" x2="0" y2="-3" width="0" layer="20"/>
<hole x="7" y="-7" drill="3.2"/>
<hole x="43" y="-7" drill="3.2"/>
<hole x="35" y="-38" drill="3.2"/>
<hole x="15" y="-38" drill="3.2"/>
<text x="40" y="-50" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">ServoShifter REV A</text>
<text x="40" y="-52" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">kiu</text>
<text x="14" y="-49" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="14" y="-50" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="14" y="-51" size="0.8128" layer="25" font="vector" ratio="11" align="center">CTL</text>
<text x="19" y="-46" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="19" y="-47" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="19" y="-44" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="19" y="-45" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="19" y="-49" size="0.8128" layer="25" font="vector" ratio="11" align="center">QH/D</text>
<text x="19" y="-50" size="0.8128" layer="25" font="vector" ratio="11" align="center">RCK</text>
<text x="19" y="-51" size="0.8128" layer="25" font="vector" ratio="11" align="center">SCK</text>
<wire x1="0" y1="-3" x2="0" y2="-53" width="0" layer="20"/>
<wire x1="21" y1="-43" x2="17" y2="-43" width="0.1" layer="25"/>
<wire x1="17" y1="-43" x2="17" y2="-52" width="0.1" layer="25"/>
<wire x1="17" y1="-52" x2="21" y2="-52" width="0.1" layer="25"/>
<wire x1="21" y1="-52" x2="21" y2="-43" width="0.1" layer="25"/>
<wire x1="12" y1="-52" x2="16" y2="-52" width="0.1" layer="25"/>
<wire x1="16" y1="-52" x2="16" y2="-48" width="0.1" layer="25"/>
<wire x1="16" y1="-48" x2="12" y2="-48" width="0.1" layer="25"/>
<wire x1="12" y1="-48" x2="12" y2="-52" width="0.1" layer="25"/>
<text x="19" y="-48" size="0.8128" layer="25" font="vector" ratio="11" align="center">NC</text>
<text x="27.5" y="-22" size="1.016" layer="1" font="vector" ratio="20" align="bottom-right">kiu</text>
<text x="27" y="-50" size="1.016" layer="26" font="vector" ratio="14" rot="MR0" align="bottom-right">ORDER 43284 III</text>
<wire x1="12" y1="-46" x2="12" y2="-48" width="0.1" layer="25"/>
<wire x1="16" y1="-48" x2="16" y2="-46" width="0.1" layer="25"/>
<wire x1="21" y1="-43" x2="21" y2="-41" width="0.1" layer="25"/>
<wire x1="17" y1="-41" x2="17" y2="-43" width="0.1" layer="25"/>
<text x="19" y="-42" size="0.8128" layer="25" font="vector" ratio="11" align="center">CON</text>
<wire x1="21" y1="-41" x2="17" y2="-41" width="0.1" layer="25"/>
<wire x1="16" y1="-46" x2="12" y2="-46" width="0.1" layer="25"/>
<text x="14" y="-47" size="0.8128" layer="25" font="vector" ratio="11" align="center">SERVO</text>
<wire x1="53" y1="-53" x2="103" y2="-53" width="0" layer="20"/>
<wire x1="103" y1="-53" x2="103" y2="-3" width="0" layer="20"/>
<wire x1="103" y1="-3" x2="53" y2="-3" width="0" layer="20"/>
<hole x="60" y="-7" drill="3.2"/>
<hole x="96" y="-7" drill="3.2"/>
<hole x="88" y="-38" drill="3.2"/>
<hole x="68" y="-38" drill="3.2"/>
<text x="93" y="-50" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">ServoShifter REV A</text>
<text x="93" y="-52" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">kiu</text>
<text x="67" y="-49" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="67" y="-50" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="67" y="-51" size="0.8128" layer="25" font="vector" ratio="11" align="center">CTL</text>
<text x="72" y="-46" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="72" y="-47" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="72" y="-44" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="72" y="-45" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="72" y="-49" size="0.8128" layer="25" font="vector" ratio="11" align="center">QH/D</text>
<text x="72" y="-50" size="0.8128" layer="25" font="vector" ratio="11" align="center">RCK</text>
<text x="72" y="-51" size="0.8128" layer="25" font="vector" ratio="11" align="center">SCK</text>
<wire x1="53" y1="-3" x2="53" y2="-53" width="0" layer="20"/>
<wire x1="74" y1="-43" x2="70" y2="-43" width="0.1" layer="25"/>
<wire x1="70" y1="-43" x2="70" y2="-52" width="0.1" layer="25"/>
<wire x1="70" y1="-52" x2="74" y2="-52" width="0.1" layer="25"/>
<wire x1="74" y1="-52" x2="74" y2="-43" width="0.1" layer="25"/>
<wire x1="65" y1="-52" x2="69" y2="-52" width="0.1" layer="25"/>
<wire x1="69" y1="-52" x2="69" y2="-48" width="0.1" layer="25"/>
<wire x1="69" y1="-48" x2="65" y2="-48" width="0.1" layer="25"/>
<wire x1="65" y1="-48" x2="65" y2="-52" width="0.1" layer="25"/>
<text x="72" y="-48" size="0.8128" layer="25" font="vector" ratio="11" align="center">NC</text>
<text x="80.5" y="-22" size="1.016" layer="1" font="vector" ratio="20" align="bottom-right">kiu</text>
<text x="80" y="-50" size="1.016" layer="26" font="vector" ratio="14" rot="MR0" align="bottom-right">ORDER 43284 III</text>
<wire x1="65" y1="-46" x2="65" y2="-48" width="0.1" layer="25"/>
<wire x1="69" y1="-48" x2="69" y2="-46" width="0.1" layer="25"/>
<wire x1="74" y1="-43" x2="74" y2="-41" width="0.1" layer="25"/>
<wire x1="70" y1="-41" x2="70" y2="-43" width="0.1" layer="25"/>
<text x="72" y="-42" size="0.8128" layer="25" font="vector" ratio="11" align="center">CON</text>
<wire x1="74" y1="-41" x2="70" y2="-41" width="0.1" layer="25"/>
<wire x1="69" y1="-46" x2="65" y2="-46" width="0.1" layer="25"/>
<text x="67" y="-47" size="0.8128" layer="25" font="vector" ratio="11" align="center">SERVO</text>
<wire x1="105.5" y1="-1" x2="105.5" y2="49" width="0" layer="20"/>
<wire x1="105.5" y1="49" x2="155.5" y2="49" width="0" layer="20"/>
<wire x1="155.5" y1="49" x2="155.5" y2="-1" width="0" layer="20"/>
<wire x1="155.5" y1="-1" x2="105.5" y2="-1" width="0" layer="20"/>
<hole x="112.5" y="45" drill="3.2"/>
<hole x="120.5" y="14" drill="3.2"/>
<hole x="148.5" y="45" drill="3.2"/>
<hole x="140.5" y="14" drill="3.2"/>
<text x="118.5" y="6" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="118.5" y="5" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="118.5" y="8" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="118.5" y="7" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="118.5" y="3" size="0.8128" layer="25" font="vector" ratio="11" align="center">MOSI</text>
<text x="118.5" y="2" size="0.8128" layer="25" font="vector" ratio="11" align="center">SS</text>
<text x="118.5" y="1" size="0.8128" layer="25" font="vector" ratio="11" align="center">SCK</text>
<wire x1="120.5" y1="9" x2="116.5" y2="9" width="0.1" layer="25"/>
<wire x1="116.5" y1="9" x2="116.5" y2="0" width="0.1" layer="25"/>
<wire x1="116.5" y1="0" x2="120.5" y2="0" width="0.1" layer="25"/>
<wire x1="120.5" y1="0" x2="120.5" y2="9" width="0.1" layer="25"/>
<text x="118.5" y="4" size="0.8128" layer="25" font="vector" ratio="11" align="center">NC</text>
<wire x1="120.5" y1="11" x2="116.5" y2="11" width="0.1" layer="25"/>
<text x="118.5" y="10" size="0.8128" layer="25" font="vector" ratio="11" align="center">CON2</text>
<wire x1="116.5" y1="9" x2="116.5" y2="11" width="0.1" layer="25"/>
<wire x1="120.5" y1="9" x2="120.5" y2="11" width="0.1" layer="25"/>
<text x="118.5" y="21" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="118.5" y="22" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="118.5" y="19" size="0.8128" layer="25" font="vector" ratio="11" align="center">SDA</text>
<text x="118.5" y="18" size="0.8128" layer="25" font="vector" ratio="11" align="center">SCL</text>
<wire x1="120.5" y1="23" x2="116.5" y2="23" width="0.1" layer="25"/>
<wire x1="116.5" y1="23" x2="116.5" y2="17" width="0.1" layer="25"/>
<wire x1="116.5" y1="17" x2="120.5" y2="17" width="0.1" layer="25"/>
<wire x1="120.5" y1="17" x2="120.5" y2="23" width="0.1" layer="25"/>
<text x="118.5" y="20" size="0.8128" layer="25" font="vector" ratio="11" align="center">NC</text>
<wire x1="120.5" y1="25" x2="116.5" y2="25" width="0.1" layer="25"/>
<text x="118.5" y="24" size="0.8128" layer="25" font="vector" ratio="11" align="center">CON1</text>
<wire x1="116.5" y1="23" x2="116.5" y2="25" width="0.1" layer="25"/>
<wire x1="120.5" y1="23" x2="120.5" y2="25" width="0.1" layer="25"/>
<text x="118.5" y="28" size="0.8128" layer="25" font="vector" ratio="11" align="center">TX</text>
<text x="118.5" y="29" size="0.8128" layer="25" font="vector" ratio="11" align="center">RX</text>
<wire x1="120.5" y1="30" x2="116.5" y2="30" width="0.1" layer="25"/>
<wire x1="116.5" y1="30" x2="116.5" y2="26" width="0.1" layer="25"/>
<wire x1="116.5" y1="26" x2="120.5" y2="26" width="0.1" layer="25"/>
<wire x1="120.5" y1="26" x2="120.5" y2="30" width="0.1" layer="25"/>
<text x="118.5" y="27" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<wire x1="120.5" y1="32" x2="116.5" y2="32" width="0.1" layer="25"/>
<text x="118.5" y="31" size="0.8128" layer="25" font="vector" ratio="11" align="center">RXTX</text>
<wire x1="116.5" y1="30" x2="116.5" y2="32" width="0.1" layer="25"/>
<wire x1="120.5" y1="30" x2="120.5" y2="32" width="0.1" layer="25"/>
<text x="112.5" y="1" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="112.5" y="2" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<wire x1="114.5" y1="3" x2="110.5" y2="3" width="0.1" layer="25"/>
<wire x1="110.5" y1="3" x2="110.5" y2="0" width="0.1" layer="25"/>
<wire x1="110.5" y1="0" x2="114.5" y2="0" width="0.1" layer="25"/>
<wire x1="114.5" y1="0" x2="114.5" y2="3" width="0.1" layer="25"/>
<text x="109.5" y="1.5" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">PWR</text>
<wire x1="108.5" y1="0" x2="110.5" y2="0" width="0.1" layer="25"/>
<wire x1="110.5" y1="3" x2="108.5" y2="3" width="0.1" layer="25"/>
<wire x1="108.5" y1="3" x2="108.5" y2="0" width="0.1" layer="25"/>
<text x="126" y="36.5" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">ServoControl REV A</text>
<text x="126" y="34.5" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">kiu</text>
<text x="114" y="36.5" size="1.016" layer="26" font="vector" ratio="14" rot="MR0" align="bottom-right">ORDER 43284 I</text>
<text x="124" y="19.5" size="1.016" layer="1" font="vector" ratio="20" align="bottom-right">kiu</text>
<wire x1="105.5" y1="-54.5" x2="105.5" y2="-4.5" width="0" layer="20"/>
<wire x1="105.5" y1="-4.5" x2="155.5" y2="-4.5" width="0" layer="20"/>
<wire x1="155.5" y1="-4.5" x2="155.5" y2="-54.5" width="0" layer="20"/>
<wire x1="155.5" y1="-54.5" x2="105.5" y2="-54.5" width="0" layer="20"/>
<hole x="112.5" y="-8.5" drill="3.2"/>
<hole x="120.5" y="-39.5" drill="3.2"/>
<hole x="148.5" y="-8.5" drill="3.2"/>
<hole x="140.5" y="-39.5" drill="3.2"/>
<text x="145" y="-14" size="0.8128" layer="25" font="vector" ratio="11" align="center-left">0x90 LM75</text>
<text x="145" y="-15" size="0.8128" layer="25" font="vector" ratio="11" align="center-left">0x68 DS1307</text>
<wire x1="144" y1="-16" x2="154" y2="-16" width="0.1" layer="25"/>
<wire x1="154" y1="-16" x2="154" y2="-13" width="0.1" layer="25"/>
<wire x1="154" y1="-13" x2="144" y2="-13" width="0.1" layer="25"/>
<wire x1="144" y1="-13" x2="144" y2="-16" width="0.1" layer="25"/>
<text x="143" y="-14.5" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">I2C</text>
<wire x1="142" y1="-13" x2="142" y2="-16" width="0.1" layer="25"/>
<wire x1="142" y1="-13" x2="144" y2="-13" width="0.1" layer="25"/>
<wire x1="142" y1="-16" x2="144" y2="-16" width="0.1" layer="25"/>
<text x="140.5" y="-49.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<text x="140.5" y="-48.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">VCC</text>
<text x="140.5" y="-51.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">SDA</text>
<text x="140.5" y="-52.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">SCL</text>
<wire x1="142.5" y1="-47.5" x2="138.5" y2="-47.5" width="0.1" layer="25"/>
<wire x1="138.5" y1="-47.5" x2="138.5" y2="-53.5" width="0.1" layer="25"/>
<wire x1="138.5" y1="-53.5" x2="142.5" y2="-53.5" width="0.1" layer="25"/>
<wire x1="142.5" y1="-53.5" x2="142.5" y2="-47.5" width="0.1" layer="25"/>
<text x="140.5" y="-50.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">NC</text>
<wire x1="142.5" y1="-45.5" x2="138.5" y2="-45.5" width="0.1" layer="25"/>
<text x="140.5" y="-46.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">CON</text>
<wire x1="138.5" y1="-47.5" x2="138.5" y2="-45.5" width="0.1" layer="25"/>
<wire x1="142.5" y1="-47.5" x2="142.5" y2="-45.5" width="0.1" layer="25"/>
<text x="118" y="-25.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">TX</text>
<text x="118" y="-24.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">RX</text>
<wire x1="120" y1="-23.5" x2="116" y2="-23.5" width="0.1" layer="25"/>
<wire x1="116" y1="-23.5" x2="116" y2="-27.5" width="0.1" layer="25"/>
<wire x1="116" y1="-27.5" x2="120" y2="-27.5" width="0.1" layer="25"/>
<wire x1="120" y1="-27.5" x2="120" y2="-23.5" width="0.1" layer="25"/>
<text x="118" y="-26.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">GND</text>
<wire x1="120" y1="-21.5" x2="116" y2="-21.5" width="0.1" layer="25"/>
<text x="118" y="-22.5" size="0.8128" layer="25" font="vector" ratio="11" align="center">RXTX</text>
<wire x1="116" y1="-23.5" x2="116" y2="-21.5" width="0.1" layer="25"/>
<wire x1="120" y1="-23.5" x2="120" y2="-21.5" width="0.1" layer="25"/>
<text x="154" y="-19.5" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">ServoReference REV A</text>
<text x="154" y="-21.5" size="1.016" layer="25" font="vector" ratio="14" align="bottom-right">kiu</text>
<text x="141.5" y="-19.5" size="1.016" layer="26" font="vector" ratio="14" rot="MR0" align="bottom-right">ORDER 43284 II</text>
<text x="116.5" y="-32.5" size="1.016" layer="1" font="vector" ratio="20" rot="R180" align="bottom-right">kiu</text>
<text x="118" y="-45" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">GND</text>
<text x="119" y="-45" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">VCC</text>
<text x="115" y="-45" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">SDA</text>
<text x="116" y="-45" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">SCL</text>
<wire x1="114" y1="-43" x2="114" y2="-47" width="0.1" layer="25"/>
<wire x1="114" y1="-47" x2="120" y2="-47" width="0.1" layer="25"/>
<wire x1="120" y1="-47" x2="120" y2="-43" width="0.1" layer="25"/>
<wire x1="120" y1="-43" x2="114" y2="-43" width="0.1" layer="25"/>
<text x="117" y="-45" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">NC</text>
<wire x1="112" y1="-43" x2="112" y2="-47" width="0.1" layer="25"/>
<text x="113" y="-45" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">RTC</text>
<wire x1="114" y1="-47" x2="112" y2="-47" width="0.1" layer="25"/>
<wire x1="114" y1="-43" x2="112" y2="-43" width="0.1" layer="25"/>
<text x="112.5" y="-15.5" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">GND</text>
<text x="111.5" y="-15.5" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">VCC</text>
<text x="109.5" y="-15.5" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">INT</text>
<text x="110.5" y="-15.5" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">INTI</text>
<wire x1="108.5" y1="-13.5" x2="108.5" y2="-17.5" width="0.1" layer="25"/>
<wire x1="108.5" y1="-17.5" x2="113.5" y2="-17.5" width="0.1" layer="25"/>
<wire x1="113.5" y1="-17.5" x2="113.5" y2="-13.5" width="0.1" layer="25"/>
<wire x1="113.5" y1="-13.5" x2="108.5" y2="-13.5" width="0.1" layer="25"/>
<wire x1="106.5" y1="-13.5" x2="106.5" y2="-17.5" width="0.1" layer="25"/>
<text x="107.5" y="-15.5" size="0.8128" layer="25" font="vector" ratio="11" rot="R90" align="center">DCF77</text>
<wire x1="108.5" y1="-17.5" x2="106.5" y2="-17.5" width="0.1" layer="25"/>
<wire x1="108.5" y1="-13.5" x2="106.5" y2="-13.5" width="0.1" layer="25"/>
</plain>
<libraries>
<library name="pinhead">
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="2X08">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-10.16" y1="-1.905" x2="-9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="2.54" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="2.54" x2="7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.54" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.54" x2="10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<text x="-10.16" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.16" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-9.144" y1="-1.524" x2="-8.636" y2="-1.016" layer="51"/>
<rectangle x1="-9.144" y1="1.016" x2="-8.636" y2="1.524" layer="51"/>
<rectangle x1="-6.604" y1="1.016" x2="-6.096" y2="1.524" layer="51"/>
<rectangle x1="-6.604" y1="-1.524" x2="-6.096" y2="-1.016" layer="51"/>
<rectangle x1="-4.064" y1="1.016" x2="-3.556" y2="1.524" layer="51"/>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="-1.016" layer="51"/>
<rectangle x1="-1.524" y1="1.016" x2="-1.016" y2="1.524" layer="51"/>
<rectangle x1="1.016" y1="1.016" x2="1.524" y2="1.524" layer="51"/>
<rectangle x1="3.556" y1="1.016" x2="4.064" y2="1.524" layer="51"/>
<rectangle x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.016" layer="51"/>
<rectangle x1="1.016" y1="-1.524" x2="1.524" y2="-1.016" layer="51"/>
<rectangle x1="3.556" y1="-1.524" x2="4.064" y2="-1.016" layer="51"/>
<rectangle x1="6.096" y1="1.016" x2="6.604" y2="1.524" layer="51"/>
<rectangle x1="6.096" y1="-1.524" x2="6.604" y2="-1.016" layer="51"/>
<rectangle x1="8.636" y1="1.016" x2="9.144" y2="1.524" layer="51"/>
<rectangle x1="8.636" y1="-1.524" x2="9.144" y2="-1.016" layer="51"/>
</package>
<package name="1X03">
<wire x1="-3.175" y1="1.27" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-3.8862" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
</package>
<package name="2X03">
<wire x1="-3.81" y1="-1.905" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<text x="-3.81" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="51"/>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="51"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="51"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="51"/>
</package>
<package name="2X05">
<wire x1="-6.35" y1="-1.905" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.905" x2="-6.35" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.905" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.35" y2="1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="1.905" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<text x="-6.35" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="-1.016" layer="51"/>
<rectangle x1="-5.334" y1="1.016" x2="-4.826" y2="1.524" layer="51"/>
<rectangle x1="4.826" y1="1.016" x2="5.334" y2="1.524" layer="51"/>
<rectangle x1="4.826" y1="-1.524" x2="5.334" y2="-1.016" layer="51"/>
</package>
<package name="1X05">
<wire x1="1.905" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-6.4262" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.254" x2="-4.826" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C0805">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="153CLV-0505">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt;&lt;p&gt;
SMD (Chip) Long Life Vertical 153 CLV&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="1.75" y1="-2.65" x2="-2.65" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-2.65" x2="-2.65" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-1.1" x2="-2.65" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.65" y1="1.1" x2="-2.65" y2="2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.65" x2="1.75" y2="2.65" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.75" x2="2.65" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.1" x2="2.65" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="2.65" y1="-1.1" x2="2.65" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.75" x2="1.75" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.65" x2="2.65" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-0.95" x2="2.2" y2="-0.95" width="0.2032" layer="21" curve="133.28887"/>
<wire x1="-2.2" y1="-0.95" x2="-2.2" y2="0.95" width="0.2032" layer="51" curve="-46.71113"/>
<wire x1="-2.2" y1="0.95" x2="2.2" y2="0.95" width="0.2032" layer="21" curve="-133.28887"/>
<wire x1="2.2" y1="-0.95" x2="2.2" y2="0.95" width="0.2032" layer="51" curve="46.71113"/>
<smd name="+" x="2.2" y="0" dx="3" dy="1.6" layer="1"/>
<smd name="-" x="-2.2" y="0" dx="3" dy="1.6" layer="1"/>
<text x="-2.74" y="2.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.775" y="-4.235" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0405">
<wire x1="1.25" y1="-2.15" x2="-2.15" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-2.15" x2="-2.15" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-1.1" x2="-2.15" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="1.1" x2="-2.15" y2="2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="1.25" y2="2.15" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.25" x2="2.15" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.1" x2="2.15" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.05" x2="2.15" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.15" y1="-1.25" x2="1.25" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.15" x2="2.15" y2="1.25" width="0.2032" layer="21"/>
<wire x1="-1.65" y1="-0.95" x2="1.65" y2="-0.95" width="0.2032" layer="21" curve="120.136976"/>
<wire x1="-1.65" y1="-0.95" x2="-1.65" y2="0.95" width="0.2032" layer="51" curve="-59.863024"/>
<wire x1="-1.65" y1="0.95" x2="1.65" y2="0.95" width="0.2032" layer="21" curve="-120.136976"/>
<wire x1="1.65" y1="-0.95" x2="1.65" y2="0.95" width="0.2032" layer="51" curve="59.863024"/>
<smd name="+" x="1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<smd name="-" x="-1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<text x="-2.24" y="2.48" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.275" y="-3.735" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
</packages>
</library>
<library name="74xx-eu">
<description>&lt;b&gt;TTL Devices, 74xx Series with European Symbols&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Texas Instruments &lt;i&gt;TTL Data Book&lt;/i&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;Volume 1, 1996.
&lt;li&gt;TTL Data Book, Volume 2 , 1993
&lt;li&gt;National Seminconductor Databook 1990, ALS/LS Logic
&lt;li&gt;ttl 74er digital data dictionary, ECA Electronic + Acustic GmbH, ISBN 3-88109-032-0
&lt;li&gt;http://icmaster.com/ViewCompare.asp
&lt;/ul&gt;
<packages>
<package name="SO16">
<description>&lt;b&gt;Small Outline package&lt;/b&gt; 150 mil</description>
<wire x1="4.699" y1="1.9558" x2="-4.699" y2="1.9558" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-1.9558" x2="5.08" y2="-1.5748" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.5748" x2="-4.699" y2="1.9558" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.9558" x2="5.08" y2="1.5748" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.5748" x2="-4.699" y2="-1.9558" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="-1.9558" x2="4.699" y2="-1.9558" width="0.1524" layer="51"/>
<wire x1="5.08" y1="-1.5748" x2="5.08" y2="1.5748" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.5748" x2="-5.08" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.508" x2="-5.08" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.508" x2="-5.08" y2="-1.5748" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.508" x2="-5.08" y2="-0.508" width="0.1524" layer="21" curve="-180"/>
<wire x1="-5.08" y1="-1.6002" x2="5.08" y2="-1.6002" width="0.0508" layer="21"/>
<smd name="1" x="-4.445" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="16" x="-4.445" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-3.175" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="15" x="-3.175" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="-1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="-0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="-0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="3.175" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="3.175" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="4.445" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="4.445" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<text x="-3.81" y="-0.762" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.461" y="-1.905" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-0.889" y1="1.9558" x2="-0.381" y2="3.0988" layer="51"/>
<rectangle x1="-4.699" y1="-3.0988" x2="-4.191" y2="-1.9558" layer="51"/>
<rectangle x1="-3.429" y1="-3.0988" x2="-2.921" y2="-1.9558" layer="51"/>
<rectangle x1="-2.159" y1="-3.0734" x2="-1.651" y2="-1.9304" layer="51"/>
<rectangle x1="-0.889" y1="-3.0988" x2="-0.381" y2="-1.9558" layer="51"/>
<rectangle x1="-2.159" y1="1.9558" x2="-1.651" y2="3.0988" layer="51"/>
<rectangle x1="-3.429" y1="1.9558" x2="-2.921" y2="3.0988" layer="51"/>
<rectangle x1="-4.699" y1="1.9558" x2="-4.191" y2="3.0988" layer="51"/>
<rectangle x1="0.381" y1="-3.0988" x2="0.889" y2="-1.9558" layer="51"/>
<rectangle x1="1.651" y1="-3.0988" x2="2.159" y2="-1.9558" layer="51"/>
<rectangle x1="2.921" y1="-3.0988" x2="3.429" y2="-1.9558" layer="51"/>
<rectangle x1="4.191" y1="-3.0988" x2="4.699" y2="-1.9558" layer="51"/>
<rectangle x1="0.381" y1="1.9558" x2="0.889" y2="3.0988" layer="51"/>
<rectangle x1="1.651" y1="1.9558" x2="2.159" y2="3.0988" layer="51"/>
<rectangle x1="2.921" y1="1.9558" x2="3.429" y2="3.0988" layer="51"/>
<rectangle x1="4.191" y1="1.9558" x2="4.699" y2="3.0988" layer="51"/>
</package>
</packages>
</library>
<library name="atmel">
<description>&lt;b&gt;AVR Devices&lt;/b&gt;&lt;p&gt;
Configurable logic, microcontrollers, nonvolatile memories&lt;p&gt;
Based on the following sources:&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;www.atmel.com
&lt;li&gt;CD-ROM : Configurable Logic Microcontroller Nonvolatile Memory
&lt;li&gt;CadSoft download site, www.cadsoft.de or www.cadsoftusa.com , file at90smcu_v400.zip
&lt;li&gt;avr.lbr
&lt;/ul&gt;
&lt;author&gt;Revised by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TQFP32-08">
<description>&lt;B&gt;Thin Plasic Quad Flat Package&lt;/B&gt; Grid 0.8 mm</description>
<wire x1="3.505" y1="3.505" x2="3.505" y2="-3.505" width="0.1524" layer="21"/>
<wire x1="3.505" y1="-3.505" x2="-3.505" y2="-3.505" width="0.1524" layer="21"/>
<wire x1="-3.505" y1="-3.505" x2="-3.505" y2="3.15" width="0.1524" layer="21"/>
<wire x1="-3.15" y1="3.505" x2="3.505" y2="3.505" width="0.1524" layer="21"/>
<wire x1="-3.15" y1="3.505" x2="-3.505" y2="3.15" width="0.1524" layer="21"/>
<circle x="-2.7432" y="2.7432" radius="0.3592" width="0.1524" layer="21"/>
<smd name="1" x="-4.2926" y="2.8" dx="1.27" dy="0.5588" layer="1"/>
<smd name="2" x="-4.2926" y="2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="3" x="-4.2926" y="1.2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="4" x="-4.2926" y="0.4" dx="1.27" dy="0.5588" layer="1"/>
<smd name="5" x="-4.2926" y="-0.4" dx="1.27" dy="0.5588" layer="1"/>
<smd name="6" x="-4.2926" y="-1.2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="7" x="-4.2926" y="-2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="8" x="-4.2926" y="-2.8" dx="1.27" dy="0.5588" layer="1"/>
<smd name="9" x="-2.8" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="10" x="-2" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="11" x="-1.2" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="12" x="-0.4" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="13" x="0.4" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="14" x="1.2" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="15" x="2" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="16" x="2.8" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="17" x="4.2926" y="-2.8" dx="1.27" dy="0.5588" layer="1"/>
<smd name="18" x="4.2926" y="-2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="19" x="4.2926" y="-1.2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="20" x="4.2926" y="-0.4" dx="1.27" dy="0.5588" layer="1"/>
<smd name="21" x="4.2926" y="0.4" dx="1.27" dy="0.5588" layer="1"/>
<smd name="22" x="4.2926" y="1.2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="23" x="4.2926" y="2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="24" x="4.2926" y="2.8" dx="1.27" dy="0.5588" layer="1"/>
<smd name="25" x="2.8" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="26" x="2" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="27" x="1.2" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="28" x="0.4" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="29" x="-0.4" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="30" x="-1.2" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="31" x="-2" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="32" x="-2.8" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<text x="-2.7686" y="5.08" size="0.8128" layer="25">&gt;NAME</text>
<text x="-3.0226" y="-1.27" size="0.8128" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5466" y1="2.5714" x2="-3.556" y2="3.0286" layer="51"/>
<rectangle x1="-4.5466" y1="1.7714" x2="-3.556" y2="2.2286" layer="51"/>
<rectangle x1="-4.5466" y1="0.9714" x2="-3.556" y2="1.4286" layer="51"/>
<rectangle x1="-4.5466" y1="0.1714" x2="-3.556" y2="0.6286" layer="51"/>
<rectangle x1="-4.5466" y1="-0.6286" x2="-3.556" y2="-0.1714" layer="51"/>
<rectangle x1="-4.5466" y1="-1.4286" x2="-3.556" y2="-0.9714" layer="51"/>
<rectangle x1="-4.5466" y1="-2.2286" x2="-3.556" y2="-1.7714" layer="51"/>
<rectangle x1="-4.5466" y1="-3.0286" x2="-3.556" y2="-2.5714" layer="51"/>
<rectangle x1="-3.0286" y1="-4.5466" x2="-2.5714" y2="-3.556" layer="51"/>
<rectangle x1="-2.2286" y1="-4.5466" x2="-1.7714" y2="-3.556" layer="51"/>
<rectangle x1="-1.4286" y1="-4.5466" x2="-0.9714" y2="-3.556" layer="51"/>
<rectangle x1="-0.6286" y1="-4.5466" x2="-0.1714" y2="-3.556" layer="51"/>
<rectangle x1="0.1714" y1="-4.5466" x2="0.6286" y2="-3.556" layer="51"/>
<rectangle x1="0.9714" y1="-4.5466" x2="1.4286" y2="-3.556" layer="51"/>
<rectangle x1="1.7714" y1="-4.5466" x2="2.2286" y2="-3.556" layer="51"/>
<rectangle x1="2.5714" y1="-4.5466" x2="3.0286" y2="-3.556" layer="51"/>
<rectangle x1="3.556" y1="-3.0286" x2="4.5466" y2="-2.5714" layer="51"/>
<rectangle x1="3.556" y1="-2.2286" x2="4.5466" y2="-1.7714" layer="51"/>
<rectangle x1="3.556" y1="-1.4286" x2="4.5466" y2="-0.9714" layer="51"/>
<rectangle x1="3.556" y1="-0.6286" x2="4.5466" y2="-0.1714" layer="51"/>
<rectangle x1="3.556" y1="0.1714" x2="4.5466" y2="0.6286" layer="51"/>
<rectangle x1="3.556" y1="0.9714" x2="4.5466" y2="1.4286" layer="51"/>
<rectangle x1="3.556" y1="1.7714" x2="4.5466" y2="2.2286" layer="51"/>
<rectangle x1="3.556" y1="2.5714" x2="4.5466" y2="3.0286" layer="51"/>
<rectangle x1="2.5714" y1="3.556" x2="3.0286" y2="4.5466" layer="51"/>
<rectangle x1="1.7714" y1="3.556" x2="2.2286" y2="4.5466" layer="51"/>
<rectangle x1="0.9714" y1="3.556" x2="1.4286" y2="4.5466" layer="51"/>
<rectangle x1="0.1714" y1="3.556" x2="0.6286" y2="4.5466" layer="51"/>
<rectangle x1="-0.6286" y1="3.556" x2="-0.1714" y2="4.5466" layer="51"/>
<rectangle x1="-1.4286" y1="3.556" x2="-0.9714" y2="4.5466" layer="51"/>
<rectangle x1="-2.2286" y1="3.556" x2="-1.7714" y2="4.5466" layer="51"/>
<rectangle x1="-3.0286" y1="3.556" x2="-2.5714" y2="4.5466" layer="51"/>
</package>
</packages>
</library>
<library name="con-wago-508">
<description>&lt;b&gt;Wago Screw Clamps&lt;/b&gt;&lt;p&gt;
Grid 5.08 mm&lt;p&gt;
<packages>
<package name="W237-132">
<description>&lt;b&gt;WAGO SREW CLAMP&lt;/b&gt;</description>
<wire x1="-3.5306" y1="-1.651" x2="-1.524" y2="0.3556" width="0.254" layer="51"/>
<wire x1="1.6256" y1="-1.6764" x2="3.5306" y2="0.3556" width="0.254" layer="51"/>
<wire x1="-5.08" y1="4.191" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-3.429" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.413" x2="-1.651" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.413" x2="1.651" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-2.413" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.413" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.445" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.191" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-2.413" x2="3.429" y2="-2.413" width="0.1524" layer="51"/>
<circle x="-2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="-2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<text x="-4.445" y="1.27" size="1.27" layer="51" ratio="10">1</text>
<text x="0.6858" y="1.2192" size="1.27" layer="51" ratio="10">2</text>
<text x="-3.81" y="-6.985" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.81" y="-4.318" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
<library name="i2c">
<description>&lt;b&gt;I²C Bus Devices&lt;/b&gt;
&lt;p&gt;
See &lt;a href="http://www.philipslogic.com/products/i2c/"&gt;http://www.philipslogic.com/products/i2c/&lt;/a&gt; for more devices.
&lt;p&gt;
Version history:&lt;br&gt;
02 Jun 2004 v1.00 Created by Eelco Huininga (&lt;a href="mailto:eelcapone@beer.com"&gt;eelcapone@NOSPAMbeer.com&lt;/a&gt;)&lt;br&gt;
30 Aug 2004 v1.01 Updated by P. Klaja (added PCF8583)&lt;br&gt;
04 Dec 2004 v1.02 Updated by Eelco Huininga (added 82B715)&lt;br&gt;
19 Dec 2004 v1.03 Bugfix: 82B715 package SO08 had pin 6 and 7 swapped&lt;br&gt;</description>
<packages>
<package name="SO08">
<wire x1="-2.9" y1="3.9" x2="2.9" y2="3.9" width="0.1998" layer="39"/>
<wire x1="2.9" y1="3.9" x2="2.9" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="2.9" y1="-3.9" x2="-2.9" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="-2.9" y1="-3.9" x2="-2.9" y2="3.9" width="0.1998" layer="39"/>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-3.175" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.445" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1501" y1="-3.1001" x2="-1.6599" y2="-2" layer="51"/>
<rectangle x1="-0.8801" y1="-3.1001" x2="-0.3899" y2="-2" layer="51"/>
<rectangle x1="0.3899" y1="-3.1001" x2="0.8801" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="-3.1001" x2="2.1501" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="2" x2="2.1501" y2="3.1001" layer="51"/>
<rectangle x1="0.3899" y1="2" x2="0.8801" y2="3.1001" layer="51"/>
<rectangle x1="-0.8801" y1="2" x2="-0.3899" y2="3.1001" layer="51"/>
<rectangle x1="-2.1501" y1="2" x2="-1.6599" y2="3.1001" layer="51"/>
</package>
</packages>
</library>
<library name="kiu">
<description>&lt;strong&gt;kiu&lt;/strong&gt;</description>
<packages>
<package name="1X4RM5">
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0.635" x2="8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.635" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0.635" x2="-8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-0.635" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-8.9662" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.89" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="-7.874" y1="-0.254" x2="-7.366" y2="0.254" layer="51"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="en">&lt;b&gt;HAKA  Design-Regeln für Zwillingsleiterplatten (Stand 12.12.2008):&lt;/b&gt;&lt;br&gt;
&lt;br&gt;
Diese DRU-Datei enthält alle erforderlichen Design Einstellungen, damit Ihre Zwillingsleiterplatten bei uns fehlerfrei und kostengünstig produziert werden können. Die Optionen Shapes und Misc sind nicht relevant und der minimale Wert für Roundness Shapes sollte auf 0 gesetzt werden. &lt;br&gt;
&lt;br&gt;
Übersicht der &lt;b&gt; HAKA &lt;/b&gt; Regeln:&lt;br&gt;
&lt;br&gt;
&lt;b&gt;allgemein:&lt;/b&gt;
&lt;P&gt;
minimale Leiterbahnbreite/-abstand: 0.2 mm&lt;br&gt;
Strichstärke für Kupferschrift sollte mind. 0.2 mm sein um gut lesbar zu bleiben&lt;br&gt;
kleinster Bohrdurchmesser: 0.5 mm --&gt; kleinstes Lötauge 0.9mm&lt;br&gt;
&lt;font color=&quot;red&quot;&gt;&lt;b&gt;Achtung:Maximale Größe über Alles: 100mm  x 160mm (bei Einzelplatten incl. 5mm Fräsabstand!!)&lt;/b&gt;&lt;/font&gt;&lt;br&gt;
&lt;br&gt;
&lt;b&gt;Restringe um DK-Bohrungen:&lt;/b&gt;&lt;br&gt;
Aussenlagen: 0.2 mm&lt;br&gt;
&lt;br&gt;
Polygon-Isolierungen: 0.3 mm&lt;br&gt;
&lt;br&gt;
&lt;font color=&quot;red&quot;&gt;&lt;b&gt;Achtung:&lt;/b&gt;&lt;/font&gt;&lt;br&gt;
Verwenden Sie bitte nur den Vektor-Font, da nur dieser bei der Gerber-Ausgabe generiert werden kann, andere Schriftarten können zu Fehlern führen!&lt;br&gt;
Die Linienstärke  für Polygone  sollte größer sein als 0.2mm. Es entstehen ansonsten extrem große Datenmengen, weil Eagle die  Polygone mit der angegebenen Strichstärke füllt. &lt;br&gt;
&lt;br&gt;
&lt;b&gt; Fräskonturen:&lt;/b&gt;&lt;br&gt;
 werden im Dimension-Layer die Fräswege mit einem 2mm Werkzeug gezeichnet, so können diese Daten direkt als Fräsprogramm übernommen, und so die Leiterplatten kostenfrei mit jeder Kontur gefräst werden!&lt;br&gt;
Der Abstand vom Kupfer zur Kontur muß mindestens 0.2mm betragen!&lt;br&gt;
&lt;br&gt;
weitere Informationen finden Sie unter  &lt;b&gt; &lt;font color=&quot;blue&quot;&gt; www.haka-lp.de &lt;/b&gt;&lt;/font&gt; oder bei: &lt;br&gt;&lt;b&gt;&lt;font color=&quot;blue&quot;&gt;HAKA Elektronik-Leiterplatten GmbH -  Am Zankwald 12 -  66583 Spiesen-Elversberg - Tel.: 06821/730893&lt;/b&gt;&lt;/font&gt;
</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm"/>
<param name="mdWireWire" value="0.2mm"/>
<param name="mdWirePad" value="0.2mm"/>
<param name="mdWireVia" value="0.2mm"/>
<param name="mdPadPad" value="0.15mm"/>
<param name="mdPadVia" value="0.2mm"/>
<param name="mdViaVia" value="0.2mm"/>
<param name="mdSmdPad" value="0mil"/>
<param name="mdSmdVia" value="0mil"/>
<param name="mdSmdSmd" value="0mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="0.2mm"/>
<param name="mdDrill" value="0.2mm"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="0.2mm"/>
<param name="msDrill" value="0.5mm"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0"/>
<param name="rvPadInner" value="0"/>
<param name="rvPadBottom" value="0"/>
<param name="rvViaOuter" value="0"/>
<param name="rvViaInner" value="0"/>
<param name="rvMicroViaOuter" value="0"/>
<param name="rvMicroViaInner" value="0"/>
<param name="rlMinPadTop" value="0.2mm"/>
<param name="rlMaxPadTop" value="20mm"/>
<param name="rlMinPadInner" value="0.4mm"/>
<param name="rlMaxPadInner" value="20mm"/>
<param name="rlMinPadBottom" value="0.2mm"/>
<param name="rlMaxPadBottom" value="20mm"/>
<param name="rlMinViaOuter" value="0.2mm"/>
<param name="rlMaxViaOuter" value="20mm"/>
<param name="rlMinViaInner" value="0.4mm"/>
<param name="rlMaxViaInner" value="20mm"/>
<param name="rlMinMicroViaOuter" value="9.99mm"/>
<param name="rlMaxMicroViaOuter" value="20mm"/>
<param name="rlMinMicroViaInner" value="9.99mm"/>
<param name="rlMaxMicroViaInner" value="20mm"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="0"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="0.1mm"/>
<param name="mlMaxStopFrame" value="0.1mm"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="5000"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="CON1" library="pinhead" package="2X08" value="" x="6" y="15" smashed="yes" rot="R90">
<attribute name="NAME" x="4" y="3" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="10.445" y="4.84" size="1.27" layer="27" rot="R90"/>
</element>
<element name="CON2" library="pinhead" package="2X08" value="" x="44" y="15" smashed="yes" rot="R270">
<attribute name="NAME" x="46.5" y="4" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="39.555" y="25.16" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S7" library="pinhead" package="1X03" value="" x="11" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="12" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="7.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S6" library="pinhead" package="1X03" value="" x="15" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="16" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="11.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S5" library="pinhead" package="1X03" value="" x="19" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="20" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="15.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S4" library="pinhead" package="1X03" value="" x="23" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="24" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="19.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S3" library="pinhead" package="1X03" value="" x="27" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="28" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="23.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S2" library="pinhead" package="1X03" value="" x="31" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="32" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="27.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S1" library="pinhead" package="1X03" value="" x="35" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="36" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="31.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S0" library="pinhead" package="1X03" value="" x="39" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="40" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="35.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C1" library="rcl" package="C0805" value="100n" x="17" y="23" smashed="yes" rot="R270">
<attribute name="NAME" x="18" y="21.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="18" y="26.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="IC1" library="74xx-eu" package="SO16" value="74HC595D" x="25" y="23" smashed="yes" rot="R180">
<attribute name="VALUE" x="29.5" y="18" size="1.27" layer="27" ratio="10" rot="R180"/>
<attribute name="NAME" x="26.5" y="29" size="1.27" layer="25" ratio="10" rot="R180"/>
</element>
<element name="C5" library="rcl" package="C0805" value="10n" x="7.5" y="39" smashed="yes" rot="R270">
<attribute name="NAME" x="6.77" y="36.27" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="6.5" y="33.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C3" library="rcl" package="153CLV-0505" value="100u" x="12" y="22" smashed="yes" rot="R90">
<attribute name="NAME" x="13.5" y="25.5" size="1.27" layer="25"/>
<attribute name="VALUE" x="8.5" y="26" size="1.27" layer="27"/>
</element>
<element name="C4" library="rcl" package="153CLV-0505" value="100u" x="38" y="22" smashed="yes" rot="R90">
<attribute name="NAME" x="34.5" y="25.5" size="1.27" layer="25"/>
<attribute name="VALUE" x="38" y="26" size="1.27" layer="27"/>
</element>
<element name="C6" library="rcl" package="C0805" value="10n" x="42.5" y="39" smashed="yes" rot="R270">
<attribute name="NAME" x="42" y="36.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="42" y="33.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C2" library="rcl" package="C0805" value="100n" x="33" y="23" smashed="yes" rot="R270">
<attribute name="NAME" x="30.5" y="21.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="30.5" y="26.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C7" library="rcl" package="153CLV-0405" value="10u" x="3" y="39" rot="R270"/>
<element name="C8" library="rcl" package="153CLV-0405" value="10u" x="47" y="39" rot="R270"/>
<element name="CON3" library="pinhead" package="2X08" value="" x="59" y="15" smashed="yes" rot="R90">
<attribute name="NAME" x="57" y="3" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="63.445" y="4.84" size="1.27" layer="27" rot="R90"/>
</element>
<element name="CON4" library="pinhead" package="2X08" value="" x="97" y="15" smashed="yes" rot="R270">
<attribute name="NAME" x="99.5" y="4" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="92.555" y="25.16" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S8" library="pinhead" package="1X03" value="" x="64" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="65" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="60.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S9" library="pinhead" package="1X03" value="" x="68" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="69" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="64.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S10" library="pinhead" package="1X03" value="" x="72" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="73" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="68.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S11" library="pinhead" package="1X03" value="" x="76" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="77" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="72.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S12" library="pinhead" package="1X03" value="" x="80" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="81" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="76.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S13" library="pinhead" package="1X03" value="" x="84" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="85" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="80.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S14" library="pinhead" package="1X03" value="" x="88" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="89" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="84.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S15" library="pinhead" package="1X03" value="" x="92" y="37.5" smashed="yes" rot="R270">
<attribute name="NAME" x="93" y="43" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="88.825" y="41.31" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C9" library="rcl" package="C0805" value="100n" x="70" y="23" smashed="yes" rot="R270">
<attribute name="NAME" x="71" y="21.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="71" y="26.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="IC2" library="74xx-eu" package="SO16" value="74HC595D" x="78" y="23" smashed="yes" rot="R180">
<attribute name="VALUE" x="82.5" y="18" size="1.27" layer="27" ratio="10" rot="R180"/>
<attribute name="NAME" x="79.5" y="29" size="1.27" layer="25" ratio="10" rot="R180"/>
</element>
<element name="C10" library="rcl" package="C0805" value="10n" x="60.5" y="39" smashed="yes" rot="R270">
<attribute name="NAME" x="59.77" y="36.27" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="59.5" y="33.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C11" library="rcl" package="153CLV-0505" value="100u" x="65" y="22" smashed="yes" rot="R90">
<attribute name="NAME" x="66.5" y="25.5" size="1.27" layer="25"/>
<attribute name="VALUE" x="61.5" y="26" size="1.27" layer="27"/>
</element>
<element name="C12" library="rcl" package="153CLV-0505" value="100u" x="91" y="22" smashed="yes" rot="R90">
<attribute name="NAME" x="87.5" y="25.5" size="1.27" layer="25"/>
<attribute name="VALUE" x="91" y="26" size="1.27" layer="27"/>
</element>
<element name="C13" library="rcl" package="C0805" value="10n" x="95.5" y="39" smashed="yes" rot="R270">
<attribute name="NAME" x="95" y="36.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="95" y="33.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C14" library="rcl" package="C0805" value="100n" x="86" y="23" smashed="yes" rot="R270">
<attribute name="NAME" x="83.5" y="21.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="83.5" y="26.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C15" library="rcl" package="153CLV-0405" value="10u" x="56" y="39" rot="R270"/>
<element name="C16" library="rcl" package="153CLV-0405" value="10u" x="100" y="39" rot="R270"/>
<element name="CON5" library="pinhead" package="2X08" value="" x="6" y="-38" smashed="yes" rot="R90">
<attribute name="NAME" x="4" y="-50" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="10.445" y="-48.16" size="1.27" layer="27" rot="R90"/>
</element>
<element name="CON6" library="pinhead" package="2X08" value="" x="44" y="-38" smashed="yes" rot="R270">
<attribute name="NAME" x="46.5" y="-49" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="39.555" y="-27.84" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S16" library="pinhead" package="1X03" value="" x="11" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="12" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="7.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S17" library="pinhead" package="1X03" value="" x="15" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="16" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="11.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S18" library="pinhead" package="1X03" value="" x="19" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="20" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="15.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S19" library="pinhead" package="1X03" value="" x="23" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="24" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="19.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S20" library="pinhead" package="1X03" value="" x="27" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="28" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="23.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S21" library="pinhead" package="1X03" value="" x="31" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="32" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="27.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S22" library="pinhead" package="1X03" value="" x="35" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="36" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="31.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S23" library="pinhead" package="1X03" value="" x="39" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="40" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="35.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C17" library="rcl" package="C0805" value="100n" x="17" y="-30" smashed="yes" rot="R270">
<attribute name="NAME" x="18" y="-31.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="18" y="-26.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="IC3" library="74xx-eu" package="SO16" value="74HC595D" x="25" y="-30" smashed="yes" rot="R180">
<attribute name="VALUE" x="29.5" y="-35" size="1.27" layer="27" ratio="10" rot="R180"/>
<attribute name="NAME" x="26.5" y="-24" size="1.27" layer="25" ratio="10" rot="R180"/>
</element>
<element name="C18" library="rcl" package="C0805" value="10n" x="7.5" y="-14" smashed="yes" rot="R270">
<attribute name="NAME" x="6.77" y="-16.73" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="6.5" y="-19.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C19" library="rcl" package="153CLV-0505" value="100u" x="12" y="-31" smashed="yes" rot="R90">
<attribute name="NAME" x="13.5" y="-27.5" size="1.27" layer="25"/>
<attribute name="VALUE" x="8.5" y="-27" size="1.27" layer="27"/>
</element>
<element name="C20" library="rcl" package="153CLV-0505" value="100u" x="38" y="-31" smashed="yes" rot="R90">
<attribute name="NAME" x="34.5" y="-27.5" size="1.27" layer="25"/>
<attribute name="VALUE" x="38" y="-27" size="1.27" layer="27"/>
</element>
<element name="C21" library="rcl" package="C0805" value="10n" x="42.5" y="-14" smashed="yes" rot="R270">
<attribute name="NAME" x="42" y="-16.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="42" y="-19.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C22" library="rcl" package="C0805" value="100n" x="33" y="-30" smashed="yes" rot="R270">
<attribute name="NAME" x="30.5" y="-31.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="30.5" y="-26.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C23" library="rcl" package="153CLV-0405" value="10u" x="3" y="-14" rot="R270"/>
<element name="C24" library="rcl" package="153CLV-0405" value="10u" x="47" y="-14" rot="R270"/>
<element name="CON7" library="pinhead" package="2X08" value="" x="59" y="-38" smashed="yes" rot="R90">
<attribute name="NAME" x="57" y="-50" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="63.445" y="-48.16" size="1.27" layer="27" rot="R90"/>
</element>
<element name="CON8" library="pinhead" package="2X08" value="" x="97" y="-38" smashed="yes" rot="R270">
<attribute name="NAME" x="99.5" y="-49" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="92.555" y="-27.84" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S24" library="pinhead" package="1X03" value="" x="64" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="65" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="60.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S25" library="pinhead" package="1X03" value="" x="68" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="69" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="64.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S26" library="pinhead" package="1X03" value="" x="72" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="73" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="68.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S27" library="pinhead" package="1X03" value="" x="76" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="77" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="72.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S28" library="pinhead" package="1X03" value="" x="80" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="81" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="76.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S29" library="pinhead" package="1X03" value="" x="84" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="85" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="80.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S30" library="pinhead" package="1X03" value="" x="88" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="89" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="84.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="S31" library="pinhead" package="1X03" value="" x="92" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="93" y="-10" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="88.825" y="-11.69" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C25" library="rcl" package="C0805" value="100n" x="70" y="-30" smashed="yes" rot="R270">
<attribute name="NAME" x="71" y="-31.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="71" y="-26.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="IC4" library="74xx-eu" package="SO16" value="74HC595D" x="78" y="-30" smashed="yes" rot="R180">
<attribute name="VALUE" x="82.5" y="-35" size="1.27" layer="27" ratio="10" rot="R180"/>
<attribute name="NAME" x="79.5" y="-24" size="1.27" layer="25" ratio="10" rot="R180"/>
</element>
<element name="C26" library="rcl" package="C0805" value="10n" x="60.5" y="-14" smashed="yes" rot="R270">
<attribute name="NAME" x="59.77" y="-16.73" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="59.5" y="-19.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C27" library="rcl" package="153CLV-0505" value="100u" x="65" y="-31" smashed="yes" rot="R90">
<attribute name="NAME" x="66.5" y="-27.5" size="1.27" layer="25"/>
<attribute name="VALUE" x="61.5" y="-27" size="1.27" layer="27"/>
</element>
<element name="C28" library="rcl" package="153CLV-0505" value="100u" x="91" y="-31" smashed="yes" rot="R90">
<attribute name="NAME" x="87.5" y="-27.5" size="1.27" layer="25"/>
<attribute name="VALUE" x="91" y="-27" size="1.27" layer="27"/>
</element>
<element name="C29" library="rcl" package="C0805" value="10n" x="95.5" y="-14" smashed="yes" rot="R270">
<attribute name="NAME" x="95" y="-16.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="95" y="-19.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C30" library="rcl" package="C0805" value="100n" x="86" y="-30" smashed="yes" rot="R270">
<attribute name="NAME" x="83.5" y="-31.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="83.5" y="-26.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C31" library="rcl" package="153CLV-0405" value="10u" x="56" y="-14" rot="R270"/>
<element name="C32" library="rcl" package="153CLV-0405" value="10u" x="100" y="-14" rot="R270"/>
<element name="CON9" library="pinhead" package="2X08" value="" x="149.5" y="14" smashed="yes" rot="R90">
<attribute name="NAME" x="147" y="25" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="153.945" y="3.84" size="1.27" layer="27" rot="R90"/>
</element>
<element name="IC5" library="atmel" package="TQFP32-08" value="MEGA8-AI" x="130.5" y="24" smashed="yes" rot="R90">
<attribute name="OC_NEWARK" value="73M8863" x="130.5" y="24" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="ATMEGA8-16AU" x="130.5" y="24" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="130.5" y="24" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="9171371" x="130.5" y="24" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="125.42" y="21.2314" size="0.8128" layer="25" rot="R90"/>
<attribute name="VALUE" x="131.77" y="20.9774" size="0.8128" layer="27" rot="R90"/>
</element>
<element name="RXTX" library="pinhead" package="1X03" value="" x="111.5" y="30" rot="R270"/>
<element name="R2" library="rcl" package="R0805" value="20k" x="139.5" y="5" smashed="yes">
<attribute name="NAME" x="136.75" y="2.75" size="1.27" layer="25"/>
<attribute name="VALUE" x="140.25" y="2.75" size="1.27" layer="27"/>
</element>
<element name="PWR" library="con-wago-508" package="W237-132" value="" x="147.5" y="34" rot="R270">
<attribute name="OC_NEWARK" value="unknown" x="147.5" y="34" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="147.5" y="34" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="147.5" y="34" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="147.5" y="34" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="C33" library="rcl" package="C0805" value="100n" x="127.5" y="16.5" smashed="yes" rot="R180">
<attribute name="NAME" x="127" y="19" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="123.5" y="17.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C34" library="rcl" package="153CLV-0505" value="100u" x="138.5" y="36" smashed="yes" rot="R270">
<attribute name="NAME" x="137" y="40.5" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="143.5" y="40.5" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C35" library="rcl" package="C0805" value="100n" x="133.5" y="37" smashed="yes" rot="R270">
<attribute name="NAME" x="133" y="40.5" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="130.96" y="38.77" size="1.27" layer="27" rot="R270"/>
</element>
<element name="ISP" library="pinhead" package="2X03" value="" x="130.5" y="7.5" smashed="yes" rot="R90">
<attribute name="NAME" x="125.5" y="6.5" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="134.945" y="3.69" size="1.27" layer="27" rot="R90"/>
</element>
<element name="R1" library="rcl" package="R0805" value="10k" x="133.5" y="16.5" smashed="yes" rot="R180">
<attribute name="NAME" x="136" y="19" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="136.5" y="17.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C36" library="rcl" package="C0805" value="100n" x="132.5" y="33" smashed="yes" rot="R180">
<attribute name="NAME" x="130" y="33.5" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="132.77" y="31.54" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R4" library="rcl" package="R0805" value="4k7" x="139.5" y="1.5" smashed="yes" rot="R180">
<attribute name="NAME" x="139" y="0.5" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="143" y="0.5" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R3" library="rcl" package="R0805" value="4k7" x="139.5" y="8.5" smashed="yes" rot="R180">
<attribute name="NAME" x="139" y="7.5" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="143" y="7.5" size="1.27" layer="27" rot="R180"/>
</element>
<element name="CON10" library="pinhead" package="2X05" value="" x="111.5" y="14" smashed="yes" rot="R270">
<attribute name="NAME" x="114" y="22.5" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="107.055" y="20.35" size="1.27" layer="27" rot="R270"/>
</element>
<element name="MODE" library="pinhead" package="1X05" value="" x="130.5" y="45" rot="R180"/>
<element name="IC6" library="atmel" package="TQFP32-08" value="MEGA8-AI" x="130.5" y="-29.5" rot="R90">
<attribute name="OC_NEWARK" value="73M8863" x="140.66" y="-6.64" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="ATMEGA8-16AU" x="140.66" y="-6.64" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="140.66" y="-6.64" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="9171371" x="140.66" y="-6.64" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="RTC" library="pinhead" package="1X05" value="" x="113.5" y="-50.5" smashed="yes">
<attribute name="NAME" x="107.0738" y="-48.6712" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="107.15" y="-53.675" size="1.27" layer="27"/>
</element>
<element name="RXTX1" library="pinhead" package="1X03" value="" x="111.5" y="-23.5" rot="R270"/>
<element name="IC7" library="i2c" package="SO08" value="LM75AD" x="130.5" y="-15.5" smashed="yes" rot="R270">
<attribute name="NAME" x="129.5" y="-12.5" size="1.27" layer="25"/>
<attribute name="VALUE" x="127" y="-19.5" size="1.27" layer="27"/>
</element>
<element name="R5" library="rcl" package="R0805" value="4k7" x="122.5" y="-13.5" smashed="yes" rot="R180">
<attribute name="NAME" x="121" y="-14.5" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="125" y="-14.5" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R6" library="rcl" package="R0805" value="4k7" x="122.5" y="-17" smashed="yes" rot="R180">
<attribute name="NAME" x="121" y="-18" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="125" y="-18" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C37" library="rcl" package="C0805" value="100n" x="137.5" y="-14.5" smashed="yes" rot="R270">
<attribute name="NAME" x="139" y="-13.5" size="1.27" layer="25" rot="R270"/>
<attribute name="VALUE" x="135" y="-12.5" size="1.27" layer="27" rot="R270"/>
</element>
<element name="C38" library="rcl" package="C0805" value="100n" x="133.5" y="-37" smashed="yes">
<attribute name="NAME" x="138" y="-36.5" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="131.5" y="-36" size="1.27" layer="27"/>
</element>
<element name="ISP1" library="pinhead" package="2X03" value="" x="130.5" y="-46" smashed="yes" rot="R90">
<attribute name="NAME" x="125.5" y="-47" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="134.945" y="-49.81" size="1.27" layer="27" rot="R90"/>
</element>
<element name="R7" library="rcl" package="R0805" value="10k" x="127.5" y="-37" smashed="yes" rot="R180">
<attribute name="NAME" x="125" y="-36.5" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="126.5" y="-36" size="1.27" layer="27"/>
</element>
<element name="C39" library="rcl" package="C0805" value="100n" x="133.5" y="-21.5" smashed="yes">
<attribute name="NAME" x="134.5" y="-24" size="1.27" layer="25"/>
<attribute name="VALUE" x="129.5" y="-24" size="1.27" layer="27"/>
</element>
<element name="CON11" library="pinhead" package="2X05" value="" x="149.5" y="-39.5" smashed="yes" rot="R90">
<attribute name="NAME" x="147" y="-48.5" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="153.945" y="-45.85" size="1.27" layer="27" rot="R90"/>
</element>
<element name="C40" library="rcl" package="153CLV-0505" value="100u" x="149.5" y="-27.5"/>
<element name="DCF77" library="kiu" package="1X4RM5" value="1X4RM5" x="127" y="-8.5" smashed="yes" rot="R180">
<attribute name="NAME" x="123.5" y="-10.5" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="124.5" y="-5.5" size="1.27" layer="27" rot="R180"/>
</element>
</elements>
<signals>
<signal name="VCC">
<contactref element="C1" pad="2"/>
<contactref element="CON1" pad="16"/>
<contactref element="CON1" pad="15"/>
<contactref element="CON1" pad="13"/>
<contactref element="CON1" pad="14"/>
<contactref element="IC1" pad="16"/>
<contactref element="IC1" pad="10"/>
<contactref element="S0" pad="2"/>
<contactref element="S1" pad="2"/>
<contactref element="S2" pad="2"/>
<contactref element="S3" pad="2"/>
<contactref element="S4" pad="2"/>
<contactref element="S5" pad="2"/>
<contactref element="S6" pad="2"/>
<contactref element="S7" pad="2"/>
<contactref element="C3" pad="+"/>
<contactref element="C5" pad="2"/>
<contactref element="C6" pad="2"/>
<wire x1="7.5" y1="38.05" x2="8.05" y2="37.5" width="1.27" layer="1"/>
<wire x1="8.05" y1="37.5" x2="11" y2="37.5" width="1.27" layer="1"/>
<wire x1="42.5" y1="38.05" x2="41.95" y2="37.5" width="1.27" layer="1"/>
<wire x1="41.95" y1="37.5" x2="39" y2="37.5" width="1.27" layer="1"/>
<wire x1="21.825" y1="19.9266" x2="21.825" y2="21.175" width="0.4064" layer="1"/>
<wire x1="21.825" y1="21.175" x2="21" y2="22" width="0.4064" layer="1"/>
<wire x1="21" y1="22" x2="17" y2="22" width="0.4064" layer="1"/>
<contactref element="C2" pad="2"/>
<wire x1="32" y1="20" x2="29.5184" y2="20" width="0.4064" layer="1"/>
<wire x1="29.5184" y1="20" x2="29.445" y2="19.9266" width="0.4064" layer="1"/>
<wire x1="32" y1="20" x2="33" y2="21" width="0.4064" layer="1"/>
<wire x1="33" y1="21" x2="33" y2="22.05" width="0.4064" layer="1"/>
<wire x1="12" y1="24.2" x2="14.15" y2="22.05" width="0.4064" layer="1"/>
<wire x1="14.15" y1="22.05" x2="17" y2="22.05" width="0.4064" layer="1"/>
<wire x1="11" y1="37.5" x2="15" y2="37.5" width="1.27" layer="1"/>
<wire x1="15" y1="37.5" x2="19" y2="37.5" width="1.27" layer="1"/>
<wire x1="19" y1="37.5" x2="23" y2="37.5" width="1.27" layer="1"/>
<wire x1="23" y1="37.5" x2="27" y2="37.5" width="1.27" layer="1"/>
<wire x1="27" y1="37.5" x2="31" y2="37.5" width="1.27" layer="1"/>
<wire x1="31" y1="37.5" x2="35" y2="37.5" width="1.27" layer="1"/>
<wire x1="35" y1="37.5" x2="39" y2="37.5" width="1.27" layer="1"/>
<wire x1="7.27" y1="23.89" x2="11.69" y2="23.89" width="1.27" layer="1"/>
<wire x1="11.69" y1="23.89" x2="12" y2="24.2" width="1.27" layer="1"/>
<wire x1="4.73" y1="21.35" x2="4.73" y2="23.89" width="1.27" layer="1"/>
<wire x1="7.27" y1="21.35" x2="4.73" y2="21.35" width="1.27" layer="1"/>
<wire x1="7.27" y1="23.89" x2="7.27" y2="21.35" width="1.27" layer="1"/>
<contactref element="CON2" pad="3"/>
<contactref element="CON2" pad="4"/>
<contactref element="CON2" pad="1"/>
<contactref element="CON2" pad="2"/>
<contactref element="C4" pad="+"/>
<wire x1="42.73" y1="23.89" x2="42.73" y2="21.35" width="1.27" layer="1"/>
<wire x1="42.73" y1="23.89" x2="38.31" y2="23.89" width="1.27" layer="1"/>
<wire x1="38.31" y1="23.89" x2="38" y2="24.2" width="1.27" layer="1"/>
<wire x1="38" y1="24.2" x2="35.85" y2="22.05" width="0.4064" layer="1"/>
<wire x1="35.85" y1="22.05" x2="33" y2="22.05" width="0.4064" layer="1"/>
<wire x1="4.73" y1="34.07" x2="4.73" y2="23.89" width="1.27" layer="1"/>
<wire x1="45.27" y1="23.89" x2="45.27" y2="34.07" width="1.27" layer="1"/>
<wire x1="45.27" y1="23.89" x2="45.27" y2="21.35" width="1.27" layer="1"/>
<wire x1="45.27" y1="21.35" x2="42.73" y2="21.35" width="1.27" layer="1"/>
<contactref element="C7" pad="+"/>
<contactref element="C8" pad="+"/>
<wire x1="4.73" y1="34.07" x2="3" y2="35.8" width="1.27" layer="1"/>
<wire x1="3" y1="35.8" x2="3" y2="37.2" width="1.27" layer="1"/>
<wire x1="45.27" y1="34.07" x2="47" y2="35.8" width="1.27" layer="1"/>
<wire x1="47" y1="35.8" x2="47" y2="37.2" width="1.27" layer="1"/>
<wire x1="7.5" y1="38.05" x2="6.65" y2="37.2" width="1.27" layer="1"/>
<wire x1="6.65" y1="37.2" x2="3" y2="37.2" width="1.27" layer="1"/>
<wire x1="42.5" y1="38.05" x2="43.35" y2="37.2" width="1.27" layer="1"/>
<wire x1="43.35" y1="37.2" x2="47" y2="37.2" width="1.27" layer="1"/>
<wire x1="17" y1="22.05" x2="17" y2="22" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="GND">
<contactref element="C1" pad="1"/>
<contactref element="CON1" pad="11"/>
<contactref element="CON1" pad="12"/>
<contactref element="CON1" pad="9"/>
<contactref element="CON1" pad="10"/>
<contactref element="IC1" pad="8"/>
<contactref element="IC1" pad="13"/>
<contactref element="S0" pad="1"/>
<contactref element="S1" pad="1"/>
<contactref element="S2" pad="1"/>
<contactref element="S3" pad="1"/>
<contactref element="S4" pad="1"/>
<contactref element="S5" pad="1"/>
<contactref element="S6" pad="1"/>
<contactref element="S7" pad="1"/>
<contactref element="C3" pad="-"/>
<contactref element="C5" pad="1"/>
<contactref element="C6" pad="1"/>
<wire x1="39" y1="40.04" x2="39.09" y2="39.95" width="1.27" layer="1"/>
<wire x1="39.09" y1="39.95" x2="42.5" y2="39.95" width="1.27" layer="1"/>
<wire x1="46.75" y1="39.95" x2="42.5" y2="39.95" width="1.27" layer="1"/>
<wire x1="11" y1="40.04" x2="10.91" y2="39.95" width="1.27" layer="1"/>
<wire x1="10.91" y1="39.95" x2="7.5" y2="39.95" width="1.27" layer="1"/>
<wire x1="3.25" y1="39.95" x2="7.5" y2="39.95" width="1.27" layer="1"/>
<wire x1="20.555" y1="26.0734" x2="20.555" y2="24.555" width="0.4064" layer="1"/>
<wire x1="20.555" y1="24.555" x2="20.5" y2="24.5" width="0.4064" layer="1"/>
<wire x1="20.5" y1="24.5" x2="20" y2="24" width="0.4064" layer="1"/>
<wire x1="20" y1="24" x2="17.05" y2="24" width="0.4064" layer="1"/>
<wire x1="25.635" y1="19.9266" x2="25.635" y2="22.865" width="0.4064" layer="1"/>
<wire x1="25.635" y1="22.865" x2="24.5" y2="24" width="0.4064" layer="1"/>
<wire x1="24.5" y1="24" x2="21" y2="24" width="0.4064" layer="1"/>
<wire x1="21" y1="24" x2="20.5" y2="24.5" width="0.4064" layer="1"/>
<contactref element="C2" pad="1"/>
<wire x1="12" y1="19.8" x2="12" y2="21" width="0.4064" layer="1"/>
<wire x1="33.05" y1="24" x2="33" y2="23.95" width="0.4064" layer="1"/>
<polygon width="0.4064" layer="16">
<vertex x="-1" y="-1"/>
<vertex x="51" y="-1"/>
<vertex x="51" y="51"/>
<vertex x="-1" y="51"/>
</polygon>
<polygon width="0.4064" layer="1">
</polygon>
<contactref element="CON2" pad="8"/>
<contactref element="CON2" pad="6"/>
<contactref element="CON2" pad="5"/>
<contactref element="CON2" pad="7"/>
<contactref element="C4" pad="-"/>
<contactref element="C7" pad="-"/>
<contactref element="C8" pad="-"/>
</signal>
<signal name="SC1">
<contactref element="IC1" pad="1"/>
<contactref element="S1" pad="3"/>
<wire x1="29.445" y1="26.0734" x2="29.445" y2="26.445" width="0.4064" layer="1"/>
<wire x1="29.445" y1="26.445" x2="35" y2="32" width="0.4064" layer="1"/>
<wire x1="35" y1="32" x2="35" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC3">
<contactref element="IC1" pad="3"/>
<contactref element="S3" pad="3"/>
<wire x1="26.905" y1="26.0734" x2="26.905" y2="27.905" width="0.4064" layer="1"/>
<wire x1="26.905" y1="27.905" x2="29" y2="30" width="0.4064" layer="1"/>
<wire x1="29" y1="30" x2="29" y2="32.96" width="0.4064" layer="1"/>
<wire x1="29" y1="32.96" x2="27" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC4">
<contactref element="IC1" pad="4"/>
<contactref element="S4" pad="3"/>
<wire x1="25.635" y1="26.0734" x2="25.635" y2="28.865" width="0.4064" layer="1"/>
<wire x1="25.635" y1="28.865" x2="23" y2="31.5" width="0.4064" layer="1"/>
<wire x1="23" y1="31.5" x2="23" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC5">
<contactref element="IC1" pad="5"/>
<contactref element="S5" pad="3"/>
<wire x1="24.365" y1="26.0734" x2="24.365" y2="28.135" width="0.4064" layer="1"/>
<wire x1="24.365" y1="28.135" x2="19" y2="33.5" width="0.4064" layer="1"/>
<wire x1="19" y1="33.5" x2="19" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC6">
<contactref element="IC1" pad="6"/>
<contactref element="S6" pad="3"/>
<wire x1="23.095" y1="26.0734" x2="23" y2="26.1684" width="0.4064" layer="1"/>
<wire x1="23.095" y1="27.405" x2="23.095" y2="26.0734" width="0.4064" layer="1"/>
<wire x1="23.095" y1="27.405" x2="20.5" y2="30" width="0.4064" layer="1"/>
<wire x1="20.5" y1="30" x2="19" y2="30" width="0.4064" layer="1"/>
<wire x1="19" y1="30" x2="15" y2="34" width="0.4064" layer="1"/>
<wire x1="15" y1="34" x2="15" y2="35" width="0.4064" layer="1"/>
<wire x1="15" y1="35" x2="15" y2="34.96" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="SC7">
<contactref element="IC1" pad="7"/>
<contactref element="S7" pad="3"/>
<wire x1="21.825" y1="26.0734" x2="21.825" y2="27.175" width="0.4064" layer="1"/>
<wire x1="21.825" y1="27.175" x2="21" y2="28" width="0.4064" layer="1"/>
<wire x1="21" y1="28" x2="17.96" y2="28" width="0.4064" layer="1"/>
<wire x1="17.96" y1="28" x2="11" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SS">
<contactref element="IC1" pad="12"/>
<contactref element="CON1" pad="3"/>
<contactref element="CON1" pad="4"/>
<wire x1="24.365" y1="19.9266" x2="24.365" y2="16.285" width="0.4064" layer="1"/>
<wire x1="24.365" y1="16.285" x2="32" y2="8.65" width="0.4064" layer="1"/>
<wire x1="48" y1="5" x2="47" y2="4" width="0.4064" layer="1"/>
<wire x1="47" y1="4" x2="3" y2="4" width="0.4064" layer="1"/>
<wire x1="3" y1="4" x2="2" y2="5" width="0.4064" layer="1"/>
<wire x1="4.73" y1="8.65" x2="2.65" y2="8.65" width="0.4064" layer="1"/>
<wire x1="2.65" y1="8.65" x2="2" y2="8" width="0.4064" layer="1"/>
<wire x1="2" y1="8" x2="2" y2="5" width="0.4064" layer="1"/>
<wire x1="47.35" y1="8.65" x2="48" y2="8" width="0.4064" layer="1"/>
<wire x1="48" y1="8" x2="48" y2="5" width="0.4064" layer="1"/>
<wire x1="7.27" y1="8.65" x2="4.73" y2="8.65" width="0.4064" layer="1"/>
<contactref element="CON2" pad="13"/>
<contactref element="CON2" pad="14"/>
<wire x1="47.35" y1="8.65" x2="45.27" y2="8.65" width="0.4064" layer="1"/>
<wire x1="45.27" y1="8.65" x2="42.73" y2="8.65" width="0.4064" layer="1"/>
<wire x1="42.73" y1="8.65" x2="32" y2="8.65" width="0.4064" layer="1"/>
</signal>
<signal name="SCK">
<contactref element="IC1" pad="11"/>
<contactref element="CON1" pad="1"/>
<contactref element="CON1" pad="2"/>
<wire x1="7.27" y1="6.11" x2="4.73" y2="6.11" width="0.4064" layer="1"/>
<wire x1="23.095" y1="19.9266" x2="23.095" y2="15.015" width="0.4064" layer="1"/>
<wire x1="23.095" y1="15.015" x2="32" y2="6.11" width="0.4064" layer="1"/>
<wire x1="7.27" y1="6.11" x2="32" y2="6.11" width="0.4064" layer="1"/>
<contactref element="CON2" pad="15"/>
<contactref element="CON2" pad="16"/>
<wire x1="45.27" y1="6.11" x2="42.73" y2="6.11" width="0.4064" layer="1"/>
<wire x1="32" y1="6.11" x2="42.73" y2="6.11" width="0.4064" layer="1"/>
</signal>
<signal name="SOUT">
<contactref element="IC1" pad="9"/>
<contactref element="CON1" pad="5"/>
<contactref element="CON1" pad="6"/>
<wire x1="4.73" y1="11.19" x2="7.27" y2="11.19" width="0.4064" layer="1"/>
<wire x1="20.555" y1="19.9266" x2="20.555" y2="13.555" width="0.4064" layer="1"/>
<wire x1="20.555" y1="13.555" x2="18" y2="11" width="0.4064" layer="1"/>
<wire x1="18" y1="11" x2="7.54" y2="11" width="0.4064" layer="1"/>
<wire x1="7.54" y1="11" x2="7.27" y2="11.19" width="0.4064" layer="1"/>
</signal>
<signal name="SIN">
<contactref element="IC1" pad="14"/>
<wire x1="26.905" y1="19.9266" x2="26.905" y2="16.095" width="0.4064" layer="1"/>
<wire x1="26.905" y1="16.095" x2="31.81" y2="11.19" width="0.4064" layer="1"/>
<contactref element="CON2" pad="11"/>
<contactref element="CON2" pad="12"/>
<wire x1="45.27" y1="11.19" x2="42.73" y2="11.19" width="0.4064" layer="1"/>
<wire x1="42.73" y1="11.19" x2="31.81" y2="11.19" width="0.4064" layer="1"/>
</signal>
<signal name="SC2">
<contactref element="IC1" pad="2"/>
<contactref element="S2" pad="3"/>
<wire x1="28.175" y1="26.0734" x2="28.175" y2="27.175" width="0.4064" layer="1"/>
<wire x1="28.175" y1="27.175" x2="31" y2="30" width="0.4064" layer="1"/>
<wire x1="31" y1="30" x2="31" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC0">
<contactref element="IC1" pad="15"/>
<contactref element="S0" pad="3"/>
<wire x1="39" y1="34.96" x2="39" y2="33.5" width="0.4064" layer="1"/>
<wire x1="39" y1="33.5" x2="31" y2="25.5" width="0.4064" layer="1"/>
<wire x1="31" y1="25.5" x2="31" y2="23" width="0.4064" layer="1"/>
<wire x1="28.175" y1="21.175" x2="28.175" y2="19.9266" width="0.4064" layer="1"/>
<wire x1="31" y1="23" x2="30" y2="22" width="0.4064" layer="1"/>
<wire x1="30" y1="22" x2="29" y2="22" width="0.4064" layer="1"/>
<wire x1="29" y1="22" x2="28.175" y2="21.175" width="0.4064" layer="1"/>
</signal>
<signal name="N$13">
<wire x1="7.4205" y1="27.992" x2="7.4205" y2="28.8175" width="0.254" layer="1"/>
<wire x1="7.4205" y1="27.1665" x2="7.4205" y2="27.992" width="0.254" layer="1"/>
<wire x1="7.4205" y1="27.992" x2="7.9285" y2="28.4365" width="0.254" layer="1"/>
<wire x1="7.9285" y1="28.4365" x2="7.9285" y2="29.262" width="0.254" layer="1"/>
<wire x1="7.4205" y1="28.8175" x2="7.9285" y2="29.262" width="0.254" layer="1"/>
</signal>
<signal name="N$14">
<wire x1="8.4365" y1="27.2935" x2="8.4365" y2="29.7065" width="0.254" layer="1"/>
<wire x1="11.3575" y1="32.183" x2="10.786" y2="31.675" width="0.254" layer="1"/>
<wire x1="11.3575" y1="29.897" x2="11.3575" y2="32.183" width="0.254" layer="1"/>
<wire x1="11.3575" y1="29.897" x2="8.4365" y2="27.2935" width="0.254" layer="1"/>
<wire x1="11.3575" y1="29.897" x2="12.056" y2="30.532" width="0.254" layer="1"/>
</signal>
<signal name="N$15">
<wire x1="8.9445" y1="28.4365" x2="9.5795" y2="29.008" width="0.254" layer="1"/>
<wire x1="8.9445" y1="29.262" x2="8.9445" y2="28.4365" width="0.254" layer="1"/>
<wire x1="8.9445" y1="29.262" x2="8.9445" y2="30.0875" width="0.254" layer="1"/>
<wire x1="8.9445" y1="30.0875" x2="9.4525" y2="30.532" width="0.254" layer="1"/>
<wire x1="9.4525" y1="29.7065" x2="9.4525" y2="30.532" width="0.254" layer="1"/>
<wire x1="8.9445" y1="29.262" x2="9.4525" y2="29.7065" width="0.254" layer="1"/>
</signal>
<signal name="N$19">
<wire x1="6.4045" y1="27.9285" x2="6.9125" y2="28.4365" width="0.254" layer="1"/>
<wire x1="6.4045" y1="27.1665" x2="6.4045" y2="27.9285" width="0.254" layer="1"/>
<wire x1="6.4045" y1="27.1665" x2="6.4045" y2="26.4045" width="0.254" layer="1"/>
<wire x1="6.4045" y1="27.1665" x2="6.9125" y2="27.6745" width="0.254" layer="1"/>
</signal>
<signal name="N$16">
<wire x1="10.151" y1="31.167" x2="9.8335" y2="30.8495" width="0.254" layer="1"/>
<wire x1="10.151" y1="29.516" x2="10.151" y2="31.167" width="0.254" layer="1"/>
<wire x1="10.151" y1="31.167" x2="10.405" y2="31.3575" width="0.254" layer="1"/>
</signal>
<signal name="N$1">
</signal>
<signal name="N$2">
</signal>
<signal name="N$3">
</signal>
<signal name="N$4">
</signal>
<signal name="VCC1">
<contactref element="C9" pad="2"/>
<contactref element="CON3" pad="16"/>
<contactref element="CON3" pad="15"/>
<contactref element="CON3" pad="13"/>
<contactref element="CON3" pad="14"/>
<contactref element="IC2" pad="16"/>
<contactref element="IC2" pad="10"/>
<contactref element="S15" pad="2"/>
<contactref element="S14" pad="2"/>
<contactref element="S13" pad="2"/>
<contactref element="S12" pad="2"/>
<contactref element="S11" pad="2"/>
<contactref element="S10" pad="2"/>
<contactref element="S9" pad="2"/>
<contactref element="S8" pad="2"/>
<contactref element="C11" pad="+"/>
<contactref element="C10" pad="2"/>
<contactref element="C13" pad="2"/>
<wire x1="60.5" y1="38.05" x2="61.05" y2="37.5" width="1.27" layer="1"/>
<wire x1="61.05" y1="37.5" x2="64" y2="37.5" width="1.27" layer="1"/>
<wire x1="95.5" y1="38.05" x2="94.95" y2="37.5" width="1.27" layer="1"/>
<wire x1="94.95" y1="37.5" x2="92" y2="37.5" width="1.27" layer="1"/>
<wire x1="74.825" y1="19.9266" x2="74.825" y2="21.175" width="0.4064" layer="1"/>
<wire x1="74.825" y1="21.175" x2="74" y2="22" width="0.4064" layer="1"/>
<wire x1="74" y1="22" x2="70" y2="22" width="0.4064" layer="1"/>
<contactref element="C14" pad="2"/>
<wire x1="85" y1="20" x2="82.5184" y2="20" width="0.4064" layer="1"/>
<wire x1="82.5184" y1="20" x2="82.445" y2="19.9266" width="0.4064" layer="1"/>
<wire x1="85" y1="20" x2="86" y2="21" width="0.4064" layer="1"/>
<wire x1="86" y1="21" x2="86" y2="22.05" width="0.4064" layer="1"/>
<wire x1="65" y1="24.2" x2="67.15" y2="22.05" width="0.4064" layer="1"/>
<wire x1="67.15" y1="22.05" x2="70" y2="22.05" width="0.4064" layer="1"/>
<wire x1="64" y1="37.5" x2="68" y2="37.5" width="1.27" layer="1"/>
<wire x1="68" y1="37.5" x2="72" y2="37.5" width="1.27" layer="1"/>
<wire x1="72" y1="37.5" x2="76" y2="37.5" width="1.27" layer="1"/>
<wire x1="76" y1="37.5" x2="80" y2="37.5" width="1.27" layer="1"/>
<wire x1="80" y1="37.5" x2="84" y2="37.5" width="1.27" layer="1"/>
<wire x1="84" y1="37.5" x2="88" y2="37.5" width="1.27" layer="1"/>
<wire x1="88" y1="37.5" x2="92" y2="37.5" width="1.27" layer="1"/>
<wire x1="60.27" y1="23.89" x2="64.69" y2="23.89" width="1.27" layer="1"/>
<wire x1="64.69" y1="23.89" x2="65" y2="24.2" width="1.27" layer="1"/>
<wire x1="57.73" y1="21.35" x2="57.73" y2="23.89" width="1.27" layer="1"/>
<wire x1="60.27" y1="21.35" x2="57.73" y2="21.35" width="1.27" layer="1"/>
<wire x1="60.27" y1="23.89" x2="60.27" y2="21.35" width="1.27" layer="1"/>
<contactref element="CON4" pad="3"/>
<contactref element="CON4" pad="4"/>
<contactref element="CON4" pad="1"/>
<contactref element="CON4" pad="2"/>
<contactref element="C12" pad="+"/>
<wire x1="95.73" y1="23.89" x2="95.73" y2="21.35" width="1.27" layer="1"/>
<wire x1="95.73" y1="23.89" x2="91.31" y2="23.89" width="1.27" layer="1"/>
<wire x1="91.31" y1="23.89" x2="91" y2="24.2" width="1.27" layer="1"/>
<wire x1="91" y1="24.2" x2="88.85" y2="22.05" width="0.4064" layer="1"/>
<wire x1="88.85" y1="22.05" x2="86" y2="22.05" width="0.4064" layer="1"/>
<wire x1="57.73" y1="34.07" x2="57.73" y2="23.89" width="1.27" layer="1"/>
<wire x1="98.27" y1="23.89" x2="98.27" y2="34.07" width="1.27" layer="1"/>
<wire x1="98.27" y1="23.89" x2="98.27" y2="21.35" width="1.27" layer="1"/>
<wire x1="98.27" y1="21.35" x2="95.73" y2="21.35" width="1.27" layer="1"/>
<contactref element="C15" pad="+"/>
<contactref element="C16" pad="+"/>
<wire x1="57.73" y1="34.07" x2="56" y2="35.8" width="1.27" layer="1"/>
<wire x1="56" y1="35.8" x2="56" y2="37.2" width="1.27" layer="1"/>
<wire x1="98.27" y1="34.07" x2="100" y2="35.8" width="1.27" layer="1"/>
<wire x1="100" y1="35.8" x2="100" y2="37.2" width="1.27" layer="1"/>
<wire x1="60.5" y1="38.05" x2="59.65" y2="37.2" width="1.27" layer="1"/>
<wire x1="59.65" y1="37.2" x2="56" y2="37.2" width="1.27" layer="1"/>
<wire x1="95.5" y1="38.05" x2="96.35" y2="37.2" width="1.27" layer="1"/>
<wire x1="96.35" y1="37.2" x2="100" y2="37.2" width="1.27" layer="1"/>
<wire x1="70" y1="22.05" x2="70" y2="22" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="GND1">
<contactref element="C9" pad="1"/>
<contactref element="CON3" pad="11"/>
<contactref element="CON3" pad="12"/>
<contactref element="CON3" pad="9"/>
<contactref element="CON3" pad="10"/>
<contactref element="IC2" pad="8"/>
<contactref element="IC2" pad="13"/>
<contactref element="S15" pad="1"/>
<contactref element="S14" pad="1"/>
<contactref element="S13" pad="1"/>
<contactref element="S12" pad="1"/>
<contactref element="S11" pad="1"/>
<contactref element="S10" pad="1"/>
<contactref element="S9" pad="1"/>
<contactref element="S8" pad="1"/>
<contactref element="C11" pad="-"/>
<contactref element="C10" pad="1"/>
<contactref element="C13" pad="1"/>
<wire x1="92" y1="40.04" x2="92.09" y2="39.95" width="1.27" layer="1"/>
<wire x1="92.09" y1="39.95" x2="95.5" y2="39.95" width="1.27" layer="1"/>
<wire x1="99.75" y1="39.95" x2="95.5" y2="39.95" width="1.27" layer="1"/>
<wire x1="64" y1="40.04" x2="63.91" y2="39.95" width="1.27" layer="1"/>
<wire x1="63.91" y1="39.95" x2="60.5" y2="39.95" width="1.27" layer="1"/>
<wire x1="56.25" y1="39.95" x2="60.5" y2="39.95" width="1.27" layer="1"/>
<wire x1="73.555" y1="26.0734" x2="73.555" y2="24.555" width="0.4064" layer="1"/>
<wire x1="73.555" y1="24.555" x2="73.5" y2="24.5" width="0.4064" layer="1"/>
<wire x1="73.5" y1="24.5" x2="73" y2="24" width="0.4064" layer="1"/>
<wire x1="73" y1="24" x2="70.05" y2="24" width="0.4064" layer="1"/>
<wire x1="78.635" y1="19.9266" x2="78.635" y2="22.865" width="0.4064" layer="1"/>
<wire x1="78.635" y1="22.865" x2="77.5" y2="24" width="0.4064" layer="1"/>
<wire x1="77.5" y1="24" x2="74" y2="24" width="0.4064" layer="1"/>
<wire x1="74" y1="24" x2="73.5" y2="24.5" width="0.4064" layer="1"/>
<contactref element="C14" pad="1"/>
<wire x1="65" y1="19.8" x2="65" y2="21" width="0.4064" layer="1"/>
<wire x1="86.05" y1="24" x2="86" y2="23.95" width="0.4064" layer="1"/>
<vertex x="52" y="-1"/>
<vertex x="104" y="-1"/>
<vertex x="104" y="51"/>
<vertex x="52" y="51"/>
</polygon>
</polygon>
<contactref element="CON4" pad="8"/>
<contactref element="CON4" pad="6"/>
<contactref element="CON4" pad="5"/>
<contactref element="CON4" pad="7"/>
<contactref element="C12" pad="-"/>
<contactref element="C15" pad="-"/>
<contactref element="C16" pad="-"/>
</signal>
<signal name="SC8">
<contactref element="IC2" pad="1"/>
<contactref element="S14" pad="3"/>
<wire x1="82.445" y1="26.0734" x2="82.445" y2="26.445" width="0.4064" layer="1"/>
<wire x1="82.445" y1="26.445" x2="88" y2="32" width="0.4064" layer="1"/>
<wire x1="88" y1="32" x2="88" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC9">
<contactref element="IC2" pad="3"/>
<contactref element="S12" pad="3"/>
<wire x1="79.905" y1="26.0734" x2="79.905" y2="27.905" width="0.4064" layer="1"/>
<wire x1="79.905" y1="27.905" x2="82" y2="30" width="0.4064" layer="1"/>
<wire x1="82" y1="30" x2="82" y2="32.96" width="0.4064" layer="1"/>
<wire x1="82" y1="32.96" x2="80" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC10">
<contactref element="IC2" pad="4"/>
<contactref element="S11" pad="3"/>
<wire x1="78.635" y1="26.0734" x2="78.635" y2="28.865" width="0.4064" layer="1"/>
<wire x1="78.635" y1="28.865" x2="76" y2="31.5" width="0.4064" layer="1"/>
<wire x1="76" y1="31.5" x2="76" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC11">
<contactref element="IC2" pad="5"/>
<contactref element="S10" pad="3"/>
<wire x1="77.365" y1="26.0734" x2="77.365" y2="28.135" width="0.4064" layer="1"/>
<wire x1="77.365" y1="28.135" x2="72" y2="33.5" width="0.4064" layer="1"/>
<wire x1="72" y1="33.5" x2="72" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC12">
<contactref element="IC2" pad="6"/>
<contactref element="S9" pad="3"/>
<wire x1="76.095" y1="26.0734" x2="76" y2="26.1684" width="0.4064" layer="1"/>
<wire x1="76.095" y1="27.405" x2="76.095" y2="26.0734" width="0.4064" layer="1"/>
<wire x1="76.095" y1="27.405" x2="73.5" y2="30" width="0.4064" layer="1"/>
<wire x1="73.5" y1="30" x2="72" y2="30" width="0.4064" layer="1"/>
<wire x1="72" y1="30" x2="68" y2="34" width="0.4064" layer="1"/>
<wire x1="68" y1="34" x2="68" y2="35" width="0.4064" layer="1"/>
<wire x1="68" y1="35" x2="68" y2="34.96" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="SC13">
<contactref element="IC2" pad="7"/>
<contactref element="S8" pad="3"/>
<wire x1="74.825" y1="26.0734" x2="74.825" y2="27.175" width="0.4064" layer="1"/>
<wire x1="74.825" y1="27.175" x2="74" y2="28" width="0.4064" layer="1"/>
<wire x1="74" y1="28" x2="70.96" y2="28" width="0.4064" layer="1"/>
<wire x1="70.96" y1="28" x2="64" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SS1">
<contactref element="IC2" pad="12"/>
<contactref element="CON3" pad="3"/>
<contactref element="CON3" pad="4"/>
<wire x1="77.365" y1="19.9266" x2="77.365" y2="16.285" width="0.4064" layer="1"/>
<wire x1="77.365" y1="16.285" x2="85" y2="8.65" width="0.4064" layer="1"/>
<wire x1="101" y1="5" x2="100" y2="4" width="0.4064" layer="1"/>
<wire x1="100" y1="4" x2="56" y2="4" width="0.4064" layer="1"/>
<wire x1="56" y1="4" x2="55" y2="5" width="0.4064" layer="1"/>
<wire x1="57.73" y1="8.65" x2="55.65" y2="8.65" width="0.4064" layer="1"/>
<wire x1="55.65" y1="8.65" x2="55" y2="8" width="0.4064" layer="1"/>
<wire x1="55" y1="8" x2="55" y2="5" width="0.4064" layer="1"/>
<wire x1="100.35" y1="8.65" x2="101" y2="8" width="0.4064" layer="1"/>
<wire x1="101" y1="8" x2="101" y2="5" width="0.4064" layer="1"/>
<wire x1="60.27" y1="8.65" x2="57.73" y2="8.65" width="0.4064" layer="1"/>
<contactref element="CON4" pad="13"/>
<contactref element="CON4" pad="14"/>
<wire x1="100.35" y1="8.65" x2="98.27" y2="8.65" width="0.4064" layer="1"/>
<wire x1="98.27" y1="8.65" x2="95.73" y2="8.65" width="0.4064" layer="1"/>
<wire x1="95.73" y1="8.65" x2="85" y2="8.65" width="0.4064" layer="1"/>
</signal>
<signal name="SCK1">
<contactref element="IC2" pad="11"/>
<contactref element="CON3" pad="1"/>
<contactref element="CON3" pad="2"/>
<wire x1="60.27" y1="6.11" x2="57.73" y2="6.11" width="0.4064" layer="1"/>
<wire x1="76.095" y1="19.9266" x2="76.095" y2="15.015" width="0.4064" layer="1"/>
<wire x1="76.095" y1="15.015" x2="85" y2="6.11" width="0.4064" layer="1"/>
<wire x1="60.27" y1="6.11" x2="85" y2="6.11" width="0.4064" layer="1"/>
<contactref element="CON4" pad="15"/>
<contactref element="CON4" pad="16"/>
<wire x1="98.27" y1="6.11" x2="95.73" y2="6.11" width="0.4064" layer="1"/>
<wire x1="85" y1="6.11" x2="95.73" y2="6.11" width="0.4064" layer="1"/>
</signal>
<signal name="SOUT1">
<contactref element="IC2" pad="9"/>
<contactref element="CON3" pad="5"/>
<contactref element="CON3" pad="6"/>
<wire x1="57.73" y1="11.19" x2="60.27" y2="11.19" width="0.4064" layer="1"/>
<wire x1="73.555" y1="19.9266" x2="73.555" y2="13.555" width="0.4064" layer="1"/>
<wire x1="73.555" y1="13.555" x2="71" y2="11" width="0.4064" layer="1"/>
<wire x1="71" y1="11" x2="60.54" y2="11" width="0.4064" layer="1"/>
<wire x1="60.54" y1="11" x2="60.27" y2="11.19" width="0.4064" layer="1"/>
</signal>
<signal name="SIN1">
<contactref element="IC2" pad="14"/>
<wire x1="79.905" y1="19.9266" x2="79.905" y2="16.095" width="0.4064" layer="1"/>
<wire x1="79.905" y1="16.095" x2="84.81" y2="11.19" width="0.4064" layer="1"/>
<contactref element="CON4" pad="11"/>
<contactref element="CON4" pad="12"/>
<wire x1="98.27" y1="11.19" x2="95.73" y2="11.19" width="0.4064" layer="1"/>
<wire x1="95.73" y1="11.19" x2="84.81" y2="11.19" width="0.4064" layer="1"/>
</signal>
<signal name="SC14">
<contactref element="IC2" pad="2"/>
<contactref element="S13" pad="3"/>
<wire x1="81.175" y1="26.0734" x2="81.175" y2="27.175" width="0.4064" layer="1"/>
<wire x1="81.175" y1="27.175" x2="84" y2="30" width="0.4064" layer="1"/>
<wire x1="84" y1="30" x2="84" y2="34.96" width="0.4064" layer="1"/>
</signal>
<signal name="SC15">
<contactref element="IC2" pad="15"/>
<contactref element="S15" pad="3"/>
<wire x1="92" y1="34.96" x2="92" y2="33.5" width="0.4064" layer="1"/>
<wire x1="92" y1="33.5" x2="84" y2="25.5" width="0.4064" layer="1"/>
<wire x1="84" y1="25.5" x2="84" y2="23" width="0.4064" layer="1"/>
<wire x1="81.175" y1="21.175" x2="81.175" y2="19.9266" width="0.4064" layer="1"/>
<wire x1="84" y1="23" x2="83" y2="22" width="0.4064" layer="1"/>
<wire x1="83" y1="22" x2="82" y2="22" width="0.4064" layer="1"/>
<wire x1="82" y1="22" x2="81.175" y2="21.175" width="0.4064" layer="1"/>
</signal>
<signal name="N$5">
<wire x1="60.4205" y1="27.992" x2="60.4205" y2="28.8175" width="0.254" layer="1"/>
<wire x1="60.4205" y1="27.1665" x2="60.4205" y2="27.992" width="0.254" layer="1"/>
<wire x1="60.4205" y1="27.992" x2="60.9285" y2="28.4365" width="0.254" layer="1"/>
<wire x1="60.9285" y1="28.4365" x2="60.9285" y2="29.262" width="0.254" layer="1"/>
<wire x1="60.4205" y1="28.8175" x2="60.9285" y2="29.262" width="0.254" layer="1"/>
</signal>
<signal name="N$6">
<wire x1="61.4365" y1="27.2935" x2="61.4365" y2="29.7065" width="0.254" layer="1"/>
<wire x1="64.3575" y1="32.183" x2="63.786" y2="31.675" width="0.254" layer="1"/>
<wire x1="64.3575" y1="29.897" x2="64.3575" y2="32.183" width="0.254" layer="1"/>
<wire x1="64.3575" y1="29.897" x2="61.4365" y2="27.2935" width="0.254" layer="1"/>
<wire x1="64.3575" y1="29.897" x2="65.056" y2="30.532" width="0.254" layer="1"/>
</signal>
<signal name="N$7">
<wire x1="61.9445" y1="28.4365" x2="62.5795" y2="29.008" width="0.254" layer="1"/>
<wire x1="61.9445" y1="29.262" x2="61.9445" y2="28.4365" width="0.254" layer="1"/>
<wire x1="61.9445" y1="29.262" x2="61.9445" y2="30.0875" width="0.254" layer="1"/>
<wire x1="61.9445" y1="30.0875" x2="62.4525" y2="30.532" width="0.254" layer="1"/>
<wire x1="62.4525" y1="29.7065" x2="62.4525" y2="30.532" width="0.254" layer="1"/>
<wire x1="61.9445" y1="29.262" x2="62.4525" y2="29.7065" width="0.254" layer="1"/>
</signal>
<signal name="N$8">
<wire x1="59.4045" y1="27.9285" x2="59.9125" y2="28.4365" width="0.254" layer="1"/>
<wire x1="59.4045" y1="27.1665" x2="59.4045" y2="27.9285" width="0.254" layer="1"/>
<wire x1="59.4045" y1="27.1665" x2="59.4045" y2="26.4045" width="0.254" layer="1"/>
<wire x1="59.4045" y1="27.1665" x2="59.9125" y2="27.6745" width="0.254" layer="1"/>
</signal>
<signal name="N$9">
<wire x1="63.151" y1="31.167" x2="62.8335" y2="30.8495" width="0.254" layer="1"/>
<wire x1="63.151" y1="29.516" x2="63.151" y2="31.167" width="0.254" layer="1"/>
<wire x1="63.151" y1="31.167" x2="63.405" y2="31.3575" width="0.254" layer="1"/>
</signal>
<signal name="VCC2">
<contactref element="C17" pad="2"/>
<contactref element="CON5" pad="16"/>
<contactref element="CON5" pad="15"/>
<contactref element="CON5" pad="13"/>
<contactref element="CON5" pad="14"/>
<contactref element="IC3" pad="16"/>
<contactref element="IC3" pad="10"/>
<contactref element="S23" pad="2"/>
<contactref element="S22" pad="2"/>
<contactref element="S21" pad="2"/>
<contactref element="S20" pad="2"/>
<contactref element="S19" pad="2"/>
<contactref element="S18" pad="2"/>
<contactref element="S17" pad="2"/>
<contactref element="S16" pad="2"/>
<contactref element="C19" pad="+"/>
<contactref element="C18" pad="2"/>
<contactref element="C21" pad="2"/>
<wire x1="7.5" y1="-14.95" x2="8.05" y2="-15.5" width="1.27" layer="1"/>
<wire x1="8.05" y1="-15.5" x2="11" y2="-15.5" width="1.27" layer="1"/>
<wire x1="42.5" y1="-14.95" x2="41.95" y2="-15.5" width="1.27" layer="1"/>
<wire x1="41.95" y1="-15.5" x2="39" y2="-15.5" width="1.27" layer="1"/>
<wire x1="21.825" y1="-33.0734" x2="21.825" y2="-31.825" width="0.4064" layer="1"/>
<wire x1="21.825" y1="-31.825" x2="21" y2="-31" width="0.4064" layer="1"/>
<wire x1="21" y1="-31" x2="17" y2="-31" width="0.4064" layer="1"/>
<contactref element="C22" pad="2"/>
<wire x1="32" y1="-33" x2="29.5184" y2="-33" width="0.4064" layer="1"/>
<wire x1="29.5184" y1="-33" x2="29.445" y2="-33.0734" width="0.4064" layer="1"/>
<wire x1="32" y1="-33" x2="33" y2="-32" width="0.4064" layer="1"/>
<wire x1="33" y1="-32" x2="33" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="12" y1="-28.8" x2="14.15" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="14.15" y1="-30.95" x2="17" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="11" y1="-15.5" x2="15" y2="-15.5" width="1.27" layer="1"/>
<wire x1="15" y1="-15.5" x2="19" y2="-15.5" width="1.27" layer="1"/>
<wire x1="19" y1="-15.5" x2="23" y2="-15.5" width="1.27" layer="1"/>
<wire x1="23" y1="-15.5" x2="27" y2="-15.5" width="1.27" layer="1"/>
<wire x1="27" y1="-15.5" x2="31" y2="-15.5" width="1.27" layer="1"/>
<wire x1="31" y1="-15.5" x2="35" y2="-15.5" width="1.27" layer="1"/>
<wire x1="35" y1="-15.5" x2="39" y2="-15.5" width="1.27" layer="1"/>
<wire x1="7.27" y1="-29.11" x2="11.69" y2="-29.11" width="1.27" layer="1"/>
<wire x1="11.69" y1="-29.11" x2="12" y2="-28.8" width="1.27" layer="1"/>
<wire x1="4.73" y1="-31.65" x2="4.73" y2="-29.11" width="1.27" layer="1"/>
<wire x1="7.27" y1="-31.65" x2="4.73" y2="-31.65" width="1.27" layer="1"/>
<wire x1="7.27" y1="-29.11" x2="7.27" y2="-31.65" width="1.27" layer="1"/>
<contactref element="CON6" pad="3"/>
<contactref element="CON6" pad="4"/>
<contactref element="CON6" pad="1"/>
<contactref element="CON6" pad="2"/>
<contactref element="C20" pad="+"/>
<wire x1="42.73" y1="-29.11" x2="42.73" y2="-31.65" width="1.27" layer="1"/>
<wire x1="42.73" y1="-29.11" x2="38.31" y2="-29.11" width="1.27" layer="1"/>
<wire x1="38.31" y1="-29.11" x2="38" y2="-28.8" width="1.27" layer="1"/>
<wire x1="38" y1="-28.8" x2="35.85" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="35.85" y1="-30.95" x2="33" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="4.73" y1="-18.93" x2="4.73" y2="-29.11" width="1.27" layer="1"/>
<wire x1="45.27" y1="-29.11" x2="45.27" y2="-18.93" width="1.27" layer="1"/>
<wire x1="45.27" y1="-29.11" x2="45.27" y2="-31.65" width="1.27" layer="1"/>
<wire x1="45.27" y1="-31.65" x2="42.73" y2="-31.65" width="1.27" layer="1"/>
<contactref element="C23" pad="+"/>
<contactref element="C24" pad="+"/>
<wire x1="4.73" y1="-18.93" x2="3" y2="-17.2" width="1.27" layer="1"/>
<wire x1="3" y1="-17.2" x2="3" y2="-15.8" width="1.27" layer="1"/>
<wire x1="45.27" y1="-18.93" x2="47" y2="-17.2" width="1.27" layer="1"/>
<wire x1="47" y1="-17.2" x2="47" y2="-15.8" width="1.27" layer="1"/>
<wire x1="7.5" y1="-14.95" x2="6.65" y2="-15.8" width="1.27" layer="1"/>
<wire x1="6.65" y1="-15.8" x2="3" y2="-15.8" width="1.27" layer="1"/>
<wire x1="42.5" y1="-14.95" x2="43.35" y2="-15.8" width="1.27" layer="1"/>
<wire x1="43.35" y1="-15.8" x2="47" y2="-15.8" width="1.27" layer="1"/>
<wire x1="17" y1="-30.95" x2="17" y2="-31" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="GND2">
<contactref element="C17" pad="1"/>
<contactref element="CON5" pad="11"/>
<contactref element="CON5" pad="12"/>
<contactref element="CON5" pad="9"/>
<contactref element="CON5" pad="10"/>
<contactref element="IC3" pad="8"/>
<contactref element="IC3" pad="13"/>
<contactref element="S23" pad="1"/>
<contactref element="S22" pad="1"/>
<contactref element="S21" pad="1"/>
<contactref element="S20" pad="1"/>
<contactref element="S19" pad="1"/>
<contactref element="S18" pad="1"/>
<contactref element="S17" pad="1"/>
<contactref element="S16" pad="1"/>
<contactref element="C19" pad="-"/>
<contactref element="C18" pad="1"/>
<contactref element="C21" pad="1"/>
<wire x1="39" y1="-12.96" x2="39.09" y2="-13.05" width="1.27" layer="1"/>
<wire x1="39.09" y1="-13.05" x2="42.5" y2="-13.05" width="1.27" layer="1"/>
<wire x1="46.75" y1="-13.05" x2="42.5" y2="-13.05" width="1.27" layer="1"/>
<wire x1="11" y1="-12.96" x2="10.91" y2="-13.05" width="1.27" layer="1"/>
<wire x1="10.91" y1="-13.05" x2="7.5" y2="-13.05" width="1.27" layer="1"/>
<wire x1="3.25" y1="-13.05" x2="7.5" y2="-13.05" width="1.27" layer="1"/>
<wire x1="20.555" y1="-26.9266" x2="20.555" y2="-28.445" width="0.4064" layer="1"/>
<wire x1="20.555" y1="-28.445" x2="20.5" y2="-28.5" width="0.4064" layer="1"/>
<wire x1="20.5" y1="-28.5" x2="20" y2="-29" width="0.4064" layer="1"/>
<wire x1="20" y1="-29" x2="17.05" y2="-29" width="0.4064" layer="1"/>
<wire x1="25.635" y1="-33.0734" x2="25.635" y2="-30.135" width="0.4064" layer="1"/>
<wire x1="25.635" y1="-30.135" x2="24.5" y2="-29" width="0.4064" layer="1"/>
<wire x1="24.5" y1="-29" x2="21" y2="-29" width="0.4064" layer="1"/>
<wire x1="21" y1="-29" x2="20.5" y2="-28.5" width="0.4064" layer="1"/>
<contactref element="C22" pad="1"/>
<wire x1="12" y1="-33.2" x2="12" y2="-32" width="0.4064" layer="1"/>
<wire x1="33.05" y1="-29" x2="33" y2="-29.05" width="0.4064" layer="1"/>
<vertex x="-1" y="-54"/>
<vertex x="51" y="-54"/>
<vertex x="51" y="-2"/>
<vertex x="-1" y="-2"/>
</polygon>
</polygon>
<contactref element="CON6" pad="8"/>
<contactref element="CON6" pad="6"/>
<contactref element="CON6" pad="5"/>
<contactref element="CON6" pad="7"/>
<contactref element="C20" pad="-"/>
<contactref element="C23" pad="-"/>
<contactref element="C24" pad="-"/>
</signal>
<signal name="SC16">
<contactref element="IC3" pad="1"/>
<contactref element="S22" pad="3"/>
<wire x1="29.445" y1="-26.9266" x2="29.445" y2="-26.555" width="0.4064" layer="1"/>
<wire x1="29.445" y1="-26.555" x2="35" y2="-21" width="0.4064" layer="1"/>
<wire x1="35" y1="-21" x2="35" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC17">
<contactref element="IC3" pad="3"/>
<contactref element="S20" pad="3"/>
<wire x1="26.905" y1="-26.9266" x2="26.905" y2="-25.095" width="0.4064" layer="1"/>
<wire x1="26.905" y1="-25.095" x2="29" y2="-23" width="0.4064" layer="1"/>
<wire x1="29" y1="-23" x2="29" y2="-20.04" width="0.4064" layer="1"/>
<wire x1="29" y1="-20.04" x2="27" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC18">
<contactref element="IC3" pad="4"/>
<contactref element="S19" pad="3"/>
<wire x1="25.635" y1="-26.9266" x2="25.635" y2="-24.135" width="0.4064" layer="1"/>
<wire x1="25.635" y1="-24.135" x2="23" y2="-21.5" width="0.4064" layer="1"/>
<wire x1="23" y1="-21.5" x2="23" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC19">
<contactref element="IC3" pad="5"/>
<contactref element="S18" pad="3"/>
<wire x1="24.365" y1="-26.9266" x2="24.365" y2="-24.865" width="0.4064" layer="1"/>
<wire x1="24.365" y1="-24.865" x2="19" y2="-19.5" width="0.4064" layer="1"/>
<wire x1="19" y1="-19.5" x2="19" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC20">
<contactref element="IC3" pad="6"/>
<contactref element="S17" pad="3"/>
<wire x1="23.095" y1="-26.9266" x2="23" y2="-26.8316" width="0.4064" layer="1"/>
<wire x1="23.095" y1="-25.595" x2="23.095" y2="-26.9266" width="0.4064" layer="1"/>
<wire x1="23.095" y1="-25.595" x2="20.5" y2="-23" width="0.4064" layer="1"/>
<wire x1="20.5" y1="-23" x2="19" y2="-23" width="0.4064" layer="1"/>
<wire x1="19" y1="-23" x2="15" y2="-19" width="0.4064" layer="1"/>
<wire x1="15" y1="-19" x2="15" y2="-18" width="0.4064" layer="1"/>
<wire x1="15" y1="-18" x2="15" y2="-18.04" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="SC21">
<contactref element="IC3" pad="7"/>
<contactref element="S16" pad="3"/>
<wire x1="21.825" y1="-26.9266" x2="21.825" y2="-25.825" width="0.4064" layer="1"/>
<wire x1="21.825" y1="-25.825" x2="21" y2="-25" width="0.4064" layer="1"/>
<wire x1="21" y1="-25" x2="17.96" y2="-25" width="0.4064" layer="1"/>
<wire x1="17.96" y1="-25" x2="11" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SS2">
<contactref element="IC3" pad="12"/>
<contactref element="CON5" pad="3"/>
<contactref element="CON5" pad="4"/>
<wire x1="24.365" y1="-33.0734" x2="24.365" y2="-36.715" width="0.4064" layer="1"/>
<wire x1="24.365" y1="-36.715" x2="32" y2="-44.35" width="0.4064" layer="1"/>
<wire x1="48" y1="-48" x2="47" y2="-49" width="0.4064" layer="1"/>
<wire x1="47" y1="-49" x2="3" y2="-49" width="0.4064" layer="1"/>
<wire x1="3" y1="-49" x2="2" y2="-48" width="0.4064" layer="1"/>
<wire x1="4.73" y1="-44.35" x2="2.65" y2="-44.35" width="0.4064" layer="1"/>
<wire x1="2.65" y1="-44.35" x2="2" y2="-45" width="0.4064" layer="1"/>
<wire x1="2" y1="-45" x2="2" y2="-48" width="0.4064" layer="1"/>
<wire x1="47.35" y1="-44.35" x2="48" y2="-45" width="0.4064" layer="1"/>
<wire x1="48" y1="-45" x2="48" y2="-48" width="0.4064" layer="1"/>
<wire x1="7.27" y1="-44.35" x2="4.73" y2="-44.35" width="0.4064" layer="1"/>
<contactref element="CON6" pad="13"/>
<contactref element="CON6" pad="14"/>
<wire x1="47.35" y1="-44.35" x2="45.27" y2="-44.35" width="0.4064" layer="1"/>
<wire x1="45.27" y1="-44.35" x2="42.73" y2="-44.35" width="0.4064" layer="1"/>
<wire x1="42.73" y1="-44.35" x2="32" y2="-44.35" width="0.4064" layer="1"/>
</signal>
<signal name="SCK2">
<contactref element="IC3" pad="11"/>
<contactref element="CON5" pad="1"/>
<contactref element="CON5" pad="2"/>
<wire x1="7.27" y1="-46.89" x2="4.73" y2="-46.89" width="0.4064" layer="1"/>
<wire x1="23.095" y1="-33.0734" x2="23.095" y2="-37.985" width="0.4064" layer="1"/>
<wire x1="23.095" y1="-37.985" x2="32" y2="-46.89" width="0.4064" layer="1"/>
<wire x1="7.27" y1="-46.89" x2="32" y2="-46.89" width="0.4064" layer="1"/>
<contactref element="CON6" pad="15"/>
<contactref element="CON6" pad="16"/>
<wire x1="45.27" y1="-46.89" x2="42.73" y2="-46.89" width="0.4064" layer="1"/>
<wire x1="32" y1="-46.89" x2="42.73" y2="-46.89" width="0.4064" layer="1"/>
</signal>
<signal name="SOUT2">
<contactref element="IC3" pad="9"/>
<contactref element="CON5" pad="5"/>
<contactref element="CON5" pad="6"/>
<wire x1="4.73" y1="-41.81" x2="7.27" y2="-41.81" width="0.4064" layer="1"/>
<wire x1="20.555" y1="-33.0734" x2="20.555" y2="-39.445" width="0.4064" layer="1"/>
<wire x1="20.555" y1="-39.445" x2="18" y2="-42" width="0.4064" layer="1"/>
<wire x1="18" y1="-42" x2="7.54" y2="-42" width="0.4064" layer="1"/>
<wire x1="7.54" y1="-42" x2="7.27" y2="-41.81" width="0.4064" layer="1"/>
</signal>
<signal name="SIN2">
<contactref element="IC3" pad="14"/>
<wire x1="26.905" y1="-33.0734" x2="26.905" y2="-36.905" width="0.4064" layer="1"/>
<wire x1="26.905" y1="-36.905" x2="31.81" y2="-41.81" width="0.4064" layer="1"/>
<contactref element="CON6" pad="11"/>
<contactref element="CON6" pad="12"/>
<wire x1="45.27" y1="-41.81" x2="42.73" y2="-41.81" width="0.4064" layer="1"/>
<wire x1="42.73" y1="-41.81" x2="31.81" y2="-41.81" width="0.4064" layer="1"/>
</signal>
<signal name="SC22">
<contactref element="IC3" pad="2"/>
<contactref element="S21" pad="3"/>
<wire x1="28.175" y1="-26.9266" x2="28.175" y2="-25.825" width="0.4064" layer="1"/>
<wire x1="28.175" y1="-25.825" x2="31" y2="-23" width="0.4064" layer="1"/>
<wire x1="31" y1="-23" x2="31" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC23">
<contactref element="IC3" pad="15"/>
<contactref element="S23" pad="3"/>
<wire x1="39" y1="-18.04" x2="39" y2="-19.5" width="0.4064" layer="1"/>
<wire x1="39" y1="-19.5" x2="31" y2="-27.5" width="0.4064" layer="1"/>
<wire x1="31" y1="-27.5" x2="31" y2="-30" width="0.4064" layer="1"/>
<wire x1="28.175" y1="-31.825" x2="28.175" y2="-33.0734" width="0.4064" layer="1"/>
<wire x1="31" y1="-30" x2="30" y2="-31" width="0.4064" layer="1"/>
<wire x1="30" y1="-31" x2="29" y2="-31" width="0.4064" layer="1"/>
<wire x1="29" y1="-31" x2="28.175" y2="-31.825" width="0.4064" layer="1"/>
</signal>
<signal name="N$10">
<wire x1="7.4205" y1="-25.008" x2="7.4205" y2="-24.1825" width="0.254" layer="1"/>
<wire x1="7.4205" y1="-25.8335" x2="7.4205" y2="-25.008" width="0.254" layer="1"/>
<wire x1="7.4205" y1="-25.008" x2="7.9285" y2="-24.5635" width="0.254" layer="1"/>
<wire x1="7.9285" y1="-24.5635" x2="7.9285" y2="-23.738" width="0.254" layer="1"/>
<wire x1="7.4205" y1="-24.1825" x2="7.9285" y2="-23.738" width="0.254" layer="1"/>
</signal>
<signal name="N$11">
<wire x1="8.4365" y1="-25.7065" x2="8.4365" y2="-23.2935" width="0.254" layer="1"/>
<wire x1="11.3575" y1="-20.817" x2="10.786" y2="-21.325" width="0.254" layer="1"/>
<wire x1="11.3575" y1="-23.103" x2="11.3575" y2="-20.817" width="0.254" layer="1"/>
<wire x1="11.3575" y1="-23.103" x2="8.4365" y2="-25.7065" width="0.254" layer="1"/>
<wire x1="11.3575" y1="-23.103" x2="12.056" y2="-22.468" width="0.254" layer="1"/>
</signal>
<signal name="N$12">
<wire x1="8.9445" y1="-24.5635" x2="9.5795" y2="-23.992" width="0.254" layer="1"/>
<wire x1="8.9445" y1="-23.738" x2="8.9445" y2="-24.5635" width="0.254" layer="1"/>
<wire x1="8.9445" y1="-23.738" x2="8.9445" y2="-22.9125" width="0.254" layer="1"/>
<wire x1="8.9445" y1="-22.9125" x2="9.4525" y2="-22.468" width="0.254" layer="1"/>
<wire x1="9.4525" y1="-23.2935" x2="9.4525" y2="-22.468" width="0.254" layer="1"/>
<wire x1="8.9445" y1="-23.738" x2="9.4525" y2="-23.2935" width="0.254" layer="1"/>
</signal>
<signal name="N$17">
<wire x1="6.4045" y1="-25.0715" x2="6.9125" y2="-24.5635" width="0.254" layer="1"/>
<wire x1="6.4045" y1="-25.8335" x2="6.4045" y2="-25.0715" width="0.254" layer="1"/>
<wire x1="6.4045" y1="-25.8335" x2="6.4045" y2="-26.5955" width="0.254" layer="1"/>
<wire x1="6.4045" y1="-25.8335" x2="6.9125" y2="-25.3255" width="0.254" layer="1"/>
</signal>
<signal name="N$18">
<wire x1="10.151" y1="-21.833" x2="9.8335" y2="-22.1505" width="0.254" layer="1"/>
<wire x1="10.151" y1="-23.484" x2="10.151" y2="-21.833" width="0.254" layer="1"/>
<wire x1="10.151" y1="-21.833" x2="10.405" y2="-21.6425" width="0.254" layer="1"/>
</signal>
<signal name="VCC3">
<contactref element="C25" pad="2"/>
<contactref element="CON7" pad="16"/>
<contactref element="CON7" pad="15"/>
<contactref element="CON7" pad="13"/>
<contactref element="CON7" pad="14"/>
<contactref element="IC4" pad="16"/>
<contactref element="IC4" pad="10"/>
<contactref element="S31" pad="2"/>
<contactref element="S30" pad="2"/>
<contactref element="S29" pad="2"/>
<contactref element="S28" pad="2"/>
<contactref element="S27" pad="2"/>
<contactref element="S26" pad="2"/>
<contactref element="S25" pad="2"/>
<contactref element="S24" pad="2"/>
<contactref element="C27" pad="+"/>
<contactref element="C26" pad="2"/>
<contactref element="C29" pad="2"/>
<wire x1="60.5" y1="-14.95" x2="61.05" y2="-15.5" width="1.27" layer="1"/>
<wire x1="61.05" y1="-15.5" x2="64" y2="-15.5" width="1.27" layer="1"/>
<wire x1="95.5" y1="-14.95" x2="94.95" y2="-15.5" width="1.27" layer="1"/>
<wire x1="94.95" y1="-15.5" x2="92" y2="-15.5" width="1.27" layer="1"/>
<wire x1="74.825" y1="-33.0734" x2="74.825" y2="-31.825" width="0.4064" layer="1"/>
<wire x1="74.825" y1="-31.825" x2="74" y2="-31" width="0.4064" layer="1"/>
<wire x1="74" y1="-31" x2="70" y2="-31" width="0.4064" layer="1"/>
<contactref element="C30" pad="2"/>
<wire x1="85" y1="-33" x2="82.5184" y2="-33" width="0.4064" layer="1"/>
<wire x1="82.5184" y1="-33" x2="82.445" y2="-33.0734" width="0.4064" layer="1"/>
<wire x1="85" y1="-33" x2="86" y2="-32" width="0.4064" layer="1"/>
<wire x1="86" y1="-32" x2="86" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="65" y1="-28.8" x2="67.15" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="67.15" y1="-30.95" x2="70" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="64" y1="-15.5" x2="68" y2="-15.5" width="1.27" layer="1"/>
<wire x1="68" y1="-15.5" x2="72" y2="-15.5" width="1.27" layer="1"/>
<wire x1="72" y1="-15.5" x2="76" y2="-15.5" width="1.27" layer="1"/>
<wire x1="76" y1="-15.5" x2="80" y2="-15.5" width="1.27" layer="1"/>
<wire x1="80" y1="-15.5" x2="84" y2="-15.5" width="1.27" layer="1"/>
<wire x1="84" y1="-15.5" x2="88" y2="-15.5" width="1.27" layer="1"/>
<wire x1="88" y1="-15.5" x2="92" y2="-15.5" width="1.27" layer="1"/>
<wire x1="60.27" y1="-29.11" x2="64.69" y2="-29.11" width="1.27" layer="1"/>
<wire x1="64.69" y1="-29.11" x2="65" y2="-28.8" width="1.27" layer="1"/>
<wire x1="57.73" y1="-31.65" x2="57.73" y2="-29.11" width="1.27" layer="1"/>
<wire x1="60.27" y1="-31.65" x2="57.73" y2="-31.65" width="1.27" layer="1"/>
<wire x1="60.27" y1="-29.11" x2="60.27" y2="-31.65" width="1.27" layer="1"/>
<contactref element="CON8" pad="3"/>
<contactref element="CON8" pad="4"/>
<contactref element="CON8" pad="1"/>
<contactref element="CON8" pad="2"/>
<contactref element="C28" pad="+"/>
<wire x1="95.73" y1="-29.11" x2="95.73" y2="-31.65" width="1.27" layer="1"/>
<wire x1="95.73" y1="-29.11" x2="91.31" y2="-29.11" width="1.27" layer="1"/>
<wire x1="91.31" y1="-29.11" x2="91" y2="-28.8" width="1.27" layer="1"/>
<wire x1="91" y1="-28.8" x2="88.85" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="88.85" y1="-30.95" x2="86" y2="-30.95" width="0.4064" layer="1"/>
<wire x1="57.73" y1="-18.93" x2="57.73" y2="-29.11" width="1.27" layer="1"/>
<wire x1="98.27" y1="-29.11" x2="98.27" y2="-18.93" width="1.27" layer="1"/>
<wire x1="98.27" y1="-29.11" x2="98.27" y2="-31.65" width="1.27" layer="1"/>
<wire x1="98.27" y1="-31.65" x2="95.73" y2="-31.65" width="1.27" layer="1"/>
<contactref element="C31" pad="+"/>
<contactref element="C32" pad="+"/>
<wire x1="57.73" y1="-18.93" x2="56" y2="-17.2" width="1.27" layer="1"/>
<wire x1="56" y1="-17.2" x2="56" y2="-15.8" width="1.27" layer="1"/>
<wire x1="98.27" y1="-18.93" x2="100" y2="-17.2" width="1.27" layer="1"/>
<wire x1="100" y1="-17.2" x2="100" y2="-15.8" width="1.27" layer="1"/>
<wire x1="60.5" y1="-14.95" x2="59.65" y2="-15.8" width="1.27" layer="1"/>
<wire x1="59.65" y1="-15.8" x2="56" y2="-15.8" width="1.27" layer="1"/>
<wire x1="95.5" y1="-14.95" x2="96.35" y2="-15.8" width="1.27" layer="1"/>
<wire x1="96.35" y1="-15.8" x2="100" y2="-15.8" width="1.27" layer="1"/>
<wire x1="70" y1="-30.95" x2="70" y2="-31" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="GND3">
<contactref element="C25" pad="1"/>
<contactref element="CON7" pad="11"/>
<contactref element="CON7" pad="12"/>
<contactref element="CON7" pad="9"/>
<contactref element="CON7" pad="10"/>
<contactref element="IC4" pad="8"/>
<contactref element="IC4" pad="13"/>
<contactref element="S31" pad="1"/>
<contactref element="S30" pad="1"/>
<contactref element="S29" pad="1"/>
<contactref element="S28" pad="1"/>
<contactref element="S27" pad="1"/>
<contactref element="S26" pad="1"/>
<contactref element="S25" pad="1"/>
<contactref element="S24" pad="1"/>
<contactref element="C27" pad="-"/>
<contactref element="C26" pad="1"/>
<contactref element="C29" pad="1"/>
<wire x1="92" y1="-12.96" x2="92.09" y2="-13.05" width="1.27" layer="1"/>
<wire x1="92.09" y1="-13.05" x2="95.5" y2="-13.05" width="1.27" layer="1"/>
<wire x1="99.75" y1="-13.05" x2="95.5" y2="-13.05" width="1.27" layer="1"/>
<wire x1="64" y1="-12.96" x2="63.91" y2="-13.05" width="1.27" layer="1"/>
<wire x1="63.91" y1="-13.05" x2="60.5" y2="-13.05" width="1.27" layer="1"/>
<wire x1="56.25" y1="-13.05" x2="60.5" y2="-13.05" width="1.27" layer="1"/>
<wire x1="73.555" y1="-26.9266" x2="73.555" y2="-28.445" width="0.4064" layer="1"/>
<wire x1="73.555" y1="-28.445" x2="73.5" y2="-28.5" width="0.4064" layer="1"/>
<wire x1="73.5" y1="-28.5" x2="73" y2="-29" width="0.4064" layer="1"/>
<wire x1="73" y1="-29" x2="70.05" y2="-29" width="0.4064" layer="1"/>
<wire x1="78.635" y1="-33.0734" x2="78.635" y2="-30.135" width="0.4064" layer="1"/>
<wire x1="78.635" y1="-30.135" x2="77.5" y2="-29" width="0.4064" layer="1"/>
<wire x1="77.5" y1="-29" x2="74" y2="-29" width="0.4064" layer="1"/>
<wire x1="74" y1="-29" x2="73.5" y2="-28.5" width="0.4064" layer="1"/>
<contactref element="C30" pad="1"/>
<wire x1="65" y1="-33.2" x2="65" y2="-32" width="0.4064" layer="1"/>
<wire x1="86.05" y1="-29" x2="86" y2="-29.05" width="0.4064" layer="1"/>
<vertex x="52" y="-54"/>
<vertex x="104" y="-54"/>
<vertex x="104" y="-2"/>
<vertex x="52" y="-2"/>
</polygon>
</polygon>
<contactref element="CON8" pad="8"/>
<contactref element="CON8" pad="6"/>
<contactref element="CON8" pad="5"/>
<contactref element="CON8" pad="7"/>
<contactref element="C28" pad="-"/>
<contactref element="C31" pad="-"/>
<contactref element="C32" pad="-"/>
</signal>
<signal name="SC24">
<contactref element="IC4" pad="1"/>
<contactref element="S30" pad="3"/>
<wire x1="82.445" y1="-26.9266" x2="82.445" y2="-26.555" width="0.4064" layer="1"/>
<wire x1="82.445" y1="-26.555" x2="88" y2="-21" width="0.4064" layer="1"/>
<wire x1="88" y1="-21" x2="88" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC25">
<contactref element="IC4" pad="3"/>
<contactref element="S28" pad="3"/>
<wire x1="79.905" y1="-26.9266" x2="79.905" y2="-25.095" width="0.4064" layer="1"/>
<wire x1="79.905" y1="-25.095" x2="82" y2="-23" width="0.4064" layer="1"/>
<wire x1="82" y1="-23" x2="82" y2="-20.04" width="0.4064" layer="1"/>
<wire x1="82" y1="-20.04" x2="80" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC26">
<contactref element="IC4" pad="4"/>
<contactref element="S27" pad="3"/>
<wire x1="78.635" y1="-26.9266" x2="78.635" y2="-24.135" width="0.4064" layer="1"/>
<wire x1="78.635" y1="-24.135" x2="76" y2="-21.5" width="0.4064" layer="1"/>
<wire x1="76" y1="-21.5" x2="76" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC27">
<contactref element="IC4" pad="5"/>
<contactref element="S26" pad="3"/>
<wire x1="77.365" y1="-26.9266" x2="77.365" y2="-24.865" width="0.4064" layer="1"/>
<wire x1="77.365" y1="-24.865" x2="72" y2="-19.5" width="0.4064" layer="1"/>
<wire x1="72" y1="-19.5" x2="72" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC28">
<contactref element="IC4" pad="6"/>
<contactref element="S25" pad="3"/>
<wire x1="76.095" y1="-26.9266" x2="76" y2="-26.8316" width="0.4064" layer="1"/>
<wire x1="76.095" y1="-25.595" x2="76.095" y2="-26.9266" width="0.4064" layer="1"/>
<wire x1="76.095" y1="-25.595" x2="73.5" y2="-23" width="0.4064" layer="1"/>
<wire x1="73.5" y1="-23" x2="72" y2="-23" width="0.4064" layer="1"/>
<wire x1="72" y1="-23" x2="68" y2="-19" width="0.4064" layer="1"/>
<wire x1="68" y1="-19" x2="68" y2="-18" width="0.4064" layer="1"/>
<wire x1="68" y1="-18" x2="68" y2="-18.04" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="SC29">
<contactref element="IC4" pad="7"/>
<contactref element="S24" pad="3"/>
<wire x1="74.825" y1="-26.9266" x2="74.825" y2="-25.825" width="0.4064" layer="1"/>
<wire x1="74.825" y1="-25.825" x2="74" y2="-25" width="0.4064" layer="1"/>
<wire x1="74" y1="-25" x2="70.96" y2="-25" width="0.4064" layer="1"/>
<wire x1="70.96" y1="-25" x2="64" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SS3">
<contactref element="IC4" pad="12"/>
<contactref element="CON7" pad="3"/>
<contactref element="CON7" pad="4"/>
<wire x1="77.365" y1="-33.0734" x2="77.365" y2="-36.715" width="0.4064" layer="1"/>
<wire x1="77.365" y1="-36.715" x2="85" y2="-44.35" width="0.4064" layer="1"/>
<wire x1="101" y1="-48" x2="100" y2="-49" width="0.4064" layer="1"/>
<wire x1="100" y1="-49" x2="56" y2="-49" width="0.4064" layer="1"/>
<wire x1="56" y1="-49" x2="55" y2="-48" width="0.4064" layer="1"/>
<wire x1="57.73" y1="-44.35" x2="55.65" y2="-44.35" width="0.4064" layer="1"/>
<wire x1="55.65" y1="-44.35" x2="55" y2="-45" width="0.4064" layer="1"/>
<wire x1="55" y1="-45" x2="55" y2="-48" width="0.4064" layer="1"/>
<wire x1="100.35" y1="-44.35" x2="101" y2="-45" width="0.4064" layer="1"/>
<wire x1="101" y1="-45" x2="101" y2="-48" width="0.4064" layer="1"/>
<wire x1="60.27" y1="-44.35" x2="57.73" y2="-44.35" width="0.4064" layer="1"/>
<contactref element="CON8" pad="13"/>
<contactref element="CON8" pad="14"/>
<wire x1="100.35" y1="-44.35" x2="98.27" y2="-44.35" width="0.4064" layer="1"/>
<wire x1="98.27" y1="-44.35" x2="95.73" y2="-44.35" width="0.4064" layer="1"/>
<wire x1="95.73" y1="-44.35" x2="85" y2="-44.35" width="0.4064" layer="1"/>
</signal>
<signal name="SCK3">
<contactref element="IC4" pad="11"/>
<contactref element="CON7" pad="1"/>
<contactref element="CON7" pad="2"/>
<wire x1="60.27" y1="-46.89" x2="57.73" y2="-46.89" width="0.4064" layer="1"/>
<wire x1="76.095" y1="-33.0734" x2="76.095" y2="-37.985" width="0.4064" layer="1"/>
<wire x1="76.095" y1="-37.985" x2="85" y2="-46.89" width="0.4064" layer="1"/>
<wire x1="60.27" y1="-46.89" x2="85" y2="-46.89" width="0.4064" layer="1"/>
<contactref element="CON8" pad="15"/>
<contactref element="CON8" pad="16"/>
<wire x1="98.27" y1="-46.89" x2="95.73" y2="-46.89" width="0.4064" layer="1"/>
<wire x1="85" y1="-46.89" x2="95.73" y2="-46.89" width="0.4064" layer="1"/>
</signal>
<signal name="SOUT3">
<contactref element="IC4" pad="9"/>
<contactref element="CON7" pad="5"/>
<contactref element="CON7" pad="6"/>
<wire x1="57.73" y1="-41.81" x2="60.27" y2="-41.81" width="0.4064" layer="1"/>
<wire x1="73.555" y1="-33.0734" x2="73.555" y2="-39.445" width="0.4064" layer="1"/>
<wire x1="73.555" y1="-39.445" x2="71" y2="-42" width="0.4064" layer="1"/>
<wire x1="71" y1="-42" x2="60.54" y2="-42" width="0.4064" layer="1"/>
<wire x1="60.54" y1="-42" x2="60.27" y2="-41.81" width="0.4064" layer="1"/>
</signal>
<signal name="SIN3">
<contactref element="IC4" pad="14"/>
<wire x1="79.905" y1="-33.0734" x2="79.905" y2="-36.905" width="0.4064" layer="1"/>
<wire x1="79.905" y1="-36.905" x2="84.81" y2="-41.81" width="0.4064" layer="1"/>
<contactref element="CON8" pad="11"/>
<contactref element="CON8" pad="12"/>
<wire x1="98.27" y1="-41.81" x2="95.73" y2="-41.81" width="0.4064" layer="1"/>
<wire x1="95.73" y1="-41.81" x2="84.81" y2="-41.81" width="0.4064" layer="1"/>
</signal>
<signal name="SC30">
<contactref element="IC4" pad="2"/>
<contactref element="S29" pad="3"/>
<wire x1="81.175" y1="-26.9266" x2="81.175" y2="-25.825" width="0.4064" layer="1"/>
<wire x1="81.175" y1="-25.825" x2="84" y2="-23" width="0.4064" layer="1"/>
<wire x1="84" y1="-23" x2="84" y2="-18.04" width="0.4064" layer="1"/>
</signal>
<signal name="SC31">
<contactref element="IC4" pad="15"/>
<contactref element="S31" pad="3"/>
<wire x1="92" y1="-18.04" x2="92" y2="-19.5" width="0.4064" layer="1"/>
<wire x1="92" y1="-19.5" x2="84" y2="-27.5" width="0.4064" layer="1"/>
<wire x1="84" y1="-27.5" x2="84" y2="-30" width="0.4064" layer="1"/>
<wire x1="81.175" y1="-31.825" x2="81.175" y2="-33.0734" width="0.4064" layer="1"/>
<wire x1="84" y1="-30" x2="83" y2="-31" width="0.4064" layer="1"/>
<wire x1="83" y1="-31" x2="82" y2="-31" width="0.4064" layer="1"/>
<wire x1="82" y1="-31" x2="81.175" y2="-31.825" width="0.4064" layer="1"/>
</signal>
<signal name="N$20">
<wire x1="60.4205" y1="-25.008" x2="60.4205" y2="-24.1825" width="0.254" layer="1"/>
<wire x1="60.4205" y1="-25.8335" x2="60.4205" y2="-25.008" width="0.254" layer="1"/>
<wire x1="60.4205" y1="-25.008" x2="60.9285" y2="-24.5635" width="0.254" layer="1"/>
<wire x1="60.9285" y1="-24.5635" x2="60.9285" y2="-23.738" width="0.254" layer="1"/>
<wire x1="60.4205" y1="-24.1825" x2="60.9285" y2="-23.738" width="0.254" layer="1"/>
</signal>
<signal name="N$21">
<wire x1="61.4365" y1="-25.7065" x2="61.4365" y2="-23.2935" width="0.254" layer="1"/>
<wire x1="64.3575" y1="-20.817" x2="63.786" y2="-21.325" width="0.254" layer="1"/>
<wire x1="64.3575" y1="-23.103" x2="64.3575" y2="-20.817" width="0.254" layer="1"/>
<wire x1="64.3575" y1="-23.103" x2="61.4365" y2="-25.7065" width="0.254" layer="1"/>
<wire x1="64.3575" y1="-23.103" x2="65.056" y2="-22.468" width="0.254" layer="1"/>
</signal>
<signal name="N$22">
<wire x1="61.9445" y1="-24.5635" x2="62.5795" y2="-23.992" width="0.254" layer="1"/>
<wire x1="61.9445" y1="-23.738" x2="61.9445" y2="-24.5635" width="0.254" layer="1"/>
<wire x1="61.9445" y1="-23.738" x2="61.9445" y2="-22.9125" width="0.254" layer="1"/>
<wire x1="61.9445" y1="-22.9125" x2="62.4525" y2="-22.468" width="0.254" layer="1"/>
<wire x1="62.4525" y1="-23.2935" x2="62.4525" y2="-22.468" width="0.254" layer="1"/>
<wire x1="61.9445" y1="-23.738" x2="62.4525" y2="-23.2935" width="0.254" layer="1"/>
</signal>
<signal name="N$23">
<wire x1="59.4045" y1="-25.0715" x2="59.9125" y2="-24.5635" width="0.254" layer="1"/>
<wire x1="59.4045" y1="-25.8335" x2="59.4045" y2="-25.0715" width="0.254" layer="1"/>
<wire x1="59.4045" y1="-25.8335" x2="59.4045" y2="-26.5955" width="0.254" layer="1"/>
<wire x1="59.4045" y1="-25.8335" x2="59.9125" y2="-25.3255" width="0.254" layer="1"/>
</signal>
<signal name="N$24">
<wire x1="63.151" y1="-21.833" x2="62.8335" y2="-22.1505" width="0.254" layer="1"/>
<wire x1="63.151" y1="-23.484" x2="63.151" y2="-21.833" width="0.254" layer="1"/>
<wire x1="63.151" y1="-21.833" x2="63.405" y2="-21.6425" width="0.254" layer="1"/>
</signal>
<signal name="GND4">
<contactref element="RXTX" pad="3"/>
<contactref element="IC5" pad="5"/>
<contactref element="IC5" pad="21"/>
<contactref element="CON9" pad="9"/>
<contactref element="CON9" pad="10"/>
<contactref element="CON9" pad="11"/>
<contactref element="CON9" pad="12"/>
<contactref element="IC5" pad="3"/>
<contactref element="C33" pad="2"/>
<contactref element="ISP" pad="6"/>
<contactref element="C36" pad="2"/>
<contactref element="CON10" pad="4"/>
<contactref element="CON10" pad="3"/>
<contactref element="C34" pad="-"/>
<contactref element="C35" pad="1"/>
<contactref element="PWR" pad="1"/>
<vertex x="104.5" y="50"/>
<vertex x="156.5" y="50"/>
<vertex x="156.5" y="-2"/>
<vertex x="104.5" y="-2"/>
</polygon>
</polygon>
<contactref element="MODE" pad="1"/>
</signal>
<signal name="VCC4">
<contactref element="CON9" pad="15"/>
<contactref element="CON9" pad="16"/>
<contactref element="CON9" pad="14"/>
<contactref element="CON9" pad="13"/>
<contactref element="R2" pad="1"/>
<contactref element="IC5" pad="18"/>
<contactref element="IC5" pad="6"/>
<contactref element="IC5" pad="4"/>
<contactref element="C33" pad="1"/>
<contactref element="ISP" pad="2"/>
<contactref element="R1" pad="2"/>
<contactref element="C36" pad="1"/>
<contactref element="CON10" pad="2"/>
<contactref element="CON10" pad="1"/>
<contactref element="C35" pad="2"/>
<contactref element="C34" pad="+"/>
<contactref element="PWR" pad="2"/>
<wire x1="148.23" y1="22.89" x2="148.23" y2="20.35" width="1.27" layer="1"/>
<wire x1="148.23" y1="22.89" x2="150.77" y2="22.89" width="1.27" layer="1"/>
<wire x1="150.77" y1="22.89" x2="150.77" y2="20.35" width="1.27" layer="1"/>
<wire x1="110.23" y1="19.08" x2="112.77" y2="19.08" width="0.4064" layer="1"/>
<wire x1="131.7" y1="19.7074" x2="131.7" y2="20.7" width="0.4064" layer="1"/>
<wire x1="131.7" y1="20.7" x2="132.5" y2="21.5" width="0.4064" layer="1"/>
<wire x1="132.5" y1="21.5" x2="132.5" y2="28.2926" width="0.4064" layer="1"/>
<wire x1="133" y1="3.5" x2="134.5" y2="5" width="0.4064" layer="1"/>
<wire x1="134.5" y1="5" x2="138.55" y2="5" width="0.4064" layer="1"/>
<wire x1="132.5" y1="28.2926" x2="132.5" y2="31" width="0.4064" layer="1"/>
<wire x1="130.5" y1="4" x2="130.5" y2="5.5" width="0.4064" layer="1"/>
<wire x1="130.5" y1="5.5" x2="130.5" y2="13.5" width="0.4064" layer="1"/>
<wire x1="130.5" y1="13.5" x2="130.5" y2="15.5" width="0.4064" layer="1"/>
<wire x1="130.5" y1="15.5" x2="130.5" y2="17.5" width="0.4064" layer="1"/>
<wire x1="148.23" y1="22.89" x2="148.23" y2="30.095" width="1.27" layer="1"/>
<wire x1="148.23" y1="30.095" x2="146.865" y2="31.46" width="1.27" layer="1"/>
<wire x1="138.5" y1="33.8" x2="144.525" y2="33.8" width="1.27" layer="1"/>
<wire x1="144.525" y1="33.8" x2="146.865" y2="31.46" width="1.27" layer="1"/>
<wire x1="133.5" y1="36.05" x2="136.25" y2="36.05" width="0.4064" layer="1"/>
<wire x1="136.25" y1="36.05" x2="138.5" y2="33.8" width="0.4064" layer="1"/>
<wire x1="131.7" y1="19.7074" x2="131.7" y2="18.7" width="0.4064" layer="1"/>
<wire x1="131.7" y1="18.7" x2="130.5" y2="17.5" width="0.4064" layer="1"/>
<wire x1="130.5" y1="17.5" x2="130.1" y2="17.9" width="0.4064" layer="1"/>
<wire x1="130.1" y1="17.9" x2="130.1" y2="19.7074" width="0.4064" layer="1"/>
<wire x1="130.5" y1="4" x2="131" y2="3.5" width="0.4064" layer="1"/>
<wire x1="131" y1="3.5" x2="133" y2="3.5" width="0.4064" layer="1"/>
<wire x1="129.23" y1="4.96" x2="129.96" y2="4.96" width="0.4064" layer="1"/>
<wire x1="129.96" y1="4.96" x2="130.5" y2="5.5" width="0.4064" layer="1"/>
<wire x1="128.45" y1="16.5" x2="129.5" y2="16.5" width="0.4064" layer="1"/>
<wire x1="129.5" y1="16.5" x2="130.5" y2="15.5" width="0.4064" layer="1"/>
<wire x1="132.55" y1="16.5" x2="131.5" y2="16.5" width="0.4064" layer="1"/>
<wire x1="131.5" y1="16.5" x2="130.5" y2="15.5" width="0.4064" layer="1"/>
<wire x1="132.5" y1="31" x2="133.5" y2="32" width="0.4064" layer="1"/>
<wire x1="133.5" y1="32" x2="133.5" y2="32.95" width="0.4064" layer="1"/>
<wire x1="133.5" y1="32.95" x2="133.45" y2="33" width="0.4064" layer="1"/>
<wire x1="133.45" y1="33" x2="133.45" y2="36" width="0.4064" layer="1"/>
<wire x1="133.45" y1="36" x2="133.5" y2="36.05" width="0.4064" layer="1"/>
<wire x1="109" y1="7" x2="124" y2="7" width="0.4064" layer="1"/>
<wire x1="124" y1="7" x2="130.5" y2="13.5" width="0.4064" layer="1"/>
<wire x1="109" y1="7" x2="108" y2="8" width="0.4064" layer="1"/>
<wire x1="108" y1="8" x2="108" y2="16.85" width="0.4064" layer="1"/>
<wire x1="108" y1="16.85" x2="110.23" y2="19.08" width="0.4064" layer="1"/>
</signal>
<signal name="SDA">
<contactref element="IC5" pad="27"/>
<contactref element="CON10" pad="8"/>
<contactref element="CON10" pad="7"/>
<wire x1="112.77" y1="11.46" x2="110.23" y2="11.46" width="0.4064" layer="1"/>
<wire x1="115.5" y1="23.5" x2="115.5" y2="12.5" width="0.4064" layer="1"/>
<wire x1="115.5" y1="12.5" x2="114.5" y2="11.5" width="0.4064" layer="1"/>
<wire x1="114.5" y1="11.5" x2="112.81" y2="11.5" width="0.4064" layer="1"/>
<wire x1="112.81" y1="11.5" x2="112.77" y2="11.46" width="0.4064" layer="1"/>
<wire x1="126.2074" y1="25.2" x2="123.8" y2="25.2" width="0.4064" layer="1"/>
<wire x1="123.8" y1="25.2" x2="123.5" y2="25.5" width="0.4064" layer="1"/>
<wire x1="123.5" y1="25.5" x2="117.5" y2="25.5" width="0.4064" layer="1"/>
<wire x1="117.5" y1="25.5" x2="115.5" y2="23.5" width="0.4064" layer="1"/>
</signal>
<signal name="SCL">
<contactref element="IC5" pad="28"/>
<contactref element="CON10" pad="10"/>
<contactref element="CON10" pad="9"/>
<wire x1="112.77" y1="8.92" x2="110.23" y2="8.92" width="0.4064" layer="1"/>
<wire x1="117" y1="23" x2="117" y2="11" width="0.4064" layer="1"/>
<wire x1="117" y1="11" x2="115" y2="9" width="0.4064" layer="1"/>
<wire x1="115" y1="9" x2="112.85" y2="9" width="0.4064" layer="1"/>
<wire x1="112.85" y1="9" x2="112.77" y2="8.92" width="0.4064" layer="1"/>
<wire x1="113" y1="8.69" x2="112.77" y2="8.92" width="0.4064" layer="1"/>
<wire x1="126.2074" y1="24.4" x2="124.9" y2="24.4" width="0.4064" layer="1"/>
<wire x1="124.9" y1="24.4" x2="124.5" y2="24" width="0.4064" layer="1"/>
<wire x1="124.5" y1="24" x2="118" y2="24" width="0.4064" layer="1"/>
<wire x1="118" y1="24" x2="117" y2="23" width="0.4064" layer="1"/>
</signal>
<signal name="N$25">
<contactref element="CON9" pad="6"/>
<contactref element="CON9" pad="5"/>
<contactref element="R4" pad="1"/>
<wire x1="150.77" y1="10.19" x2="148.23" y2="10.19" width="0.4064" layer="1"/>
<wire x1="140.45" y1="1.5" x2="153" y2="1.5" width="0.4064" layer="1"/>
<wire x1="153" y1="1.5" x2="154" y2="2.5" width="0.4064" layer="1"/>
<wire x1="150.77" y1="10.19" x2="152.81" y2="10.19" width="0.4064" layer="1"/>
<wire x1="152.81" y1="10.19" x2="154" y2="9" width="0.4064" layer="1"/>
<wire x1="154" y1="9" x2="154" y2="2.5" width="0.4064" layer="1"/>
</signal>
<signal name="N$26">
<contactref element="CON9" pad="1"/>
<contactref element="CON9" pad="2"/>
<contactref element="R3" pad="1"/>
<wire x1="150.77" y1="5.11" x2="148.23" y2="5.11" width="0.4064" layer="1"/>
<wire x1="148.23" y1="5.11" x2="144.84" y2="8.5" width="0.4064" layer="1"/>
<wire x1="144.84" y1="8.5" x2="140.45" y2="8.5" width="0.4064" layer="1"/>
</signal>
<signal name="SCK4">
<contactref element="ISP" pad="3"/>
<contactref element="IC5" pad="17"/>
<contactref element="R3" pad="2"/>
<via x="134" y="30" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="138.55" y1="8.5" x2="137.55" y2="7.5" width="0.4064" layer="1"/>
<wire x1="137.55" y1="7.5" x2="131.77" y2="7.5" width="0.4064" layer="1"/>
<wire x1="133.3" y1="28.2926" x2="133.3" y2="29.3" width="0.4064" layer="1"/>
<wire x1="133.3" y1="29.3" x2="134" y2="30" width="0.4064" layer="1"/>
<wire x1="133.3" y1="9.03" x2="133.3" y2="29.3" width="0.4064" layer="16"/>
<wire x1="133.3" y1="29.3" x2="134" y2="30" width="0.4064" layer="16"/>
<wire x1="131.77" y1="7.5" x2="133.3" y2="9.03" width="0.4064" layer="16"/>
</signal>
<signal name="RES">
<contactref element="ISP" pad="5"/>
<contactref element="IC5" pad="29"/>
<contactref element="R1" pad="1"/>
<via x="130.5" y="26.25" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="130.5" y1="26.25" x2="130.5" y2="11.31" width="0.4064" layer="16"/>
<wire x1="130.5" y1="11.31" x2="131.77" y2="10.04" width="0.4064" layer="16"/>
<wire x1="126.2074" y1="23.6" x2="127.1" y2="23.6" width="0.4064" layer="1"/>
<wire x1="127.1" y1="23.6" x2="127.5" y2="24" width="0.4064" layer="1"/>
<wire x1="127.5" y1="24" x2="127.5" y2="25.75" width="0.4064" layer="1"/>
<wire x1="127.5" y1="25.75" x2="128" y2="26.25" width="0.4064" layer="1"/>
<wire x1="128" y1="26.25" x2="130.5" y2="26.25" width="0.4064" layer="1"/>
<wire x1="131.77" y1="10.04" x2="131.77" y2="12.77" width="0.4064" layer="1"/>
<wire x1="131.77" y1="12.77" x2="134.5" y2="15.5" width="0.4064" layer="1"/>
<wire x1="134.5" y1="15.5" x2="134.5" y2="16.45" width="0.4064" layer="1"/>
<wire x1="134.5" y1="16.45" x2="134.45" y2="16.5" width="0.4064" layer="1"/>
</signal>
<signal name="MISO">
<contactref element="ISP" pad="1"/>
<contactref element="IC5" pad="16"/>
<wire x1="134.7926" y1="26.8" x2="134.7926" y2="27.7926" width="0.4064" layer="1"/>
<via x="135.5" y="28.5" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="135.5" y1="28.5" x2="135" y2="28" width="0.4064" layer="16"/>
<wire x1="135" y1="28" x2="135" y2="8.19" width="0.4064" layer="16"/>
<wire x1="131.77" y1="4.96" x2="135" y2="8.19" width="0.4064" layer="16"/>
<wire x1="134.7926" y1="27.7926" x2="135.5" y2="28.5" width="0.4064" layer="1"/>
</signal>
<signal name="MOSI">
<contactref element="ISP" pad="4"/>
<contactref element="IC5" pad="15"/>
<contactref element="R4" pad="2"/>
<wire x1="129.23" y1="7.5" x2="127.5" y2="7.5" width="0.4064" layer="1"/>
<wire x1="127.5" y1="7.5" x2="126.5" y2="6.5" width="0.4064" layer="1"/>
<wire x1="126.5" y1="6.5" x2="126.5" y2="2.5" width="0.4064" layer="1"/>
<wire x1="126.5" y1="2.5" x2="127.5" y2="1.5" width="0.4064" layer="1"/>
<wire x1="127.5" y1="1.5" x2="138.55" y2="1.5" width="0.4064" layer="1"/>
<wire x1="134.7926" y1="26" x2="136" y2="26" width="0.4064" layer="1"/>
<wire x1="136" y1="26" x2="137" y2="27" width="0.4064" layer="1"/>
<via x="137" y="27" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="137" y1="27" x2="136.5" y2="26.5" width="0.4064" layer="16"/>
<wire x1="136.5" y1="26.5" x2="136.5" y2="4" width="0.4064" layer="16"/>
<wire x1="136.5" y1="4" x2="134" y2="1.5" width="0.4064" layer="16"/>
<wire x1="134" y1="1.5" x2="127.5" y2="1.5" width="0.4064" layer="16"/>
<wire x1="127.5" y1="1.5" x2="126.5" y2="2.5" width="0.4064" layer="16"/>
<wire x1="126.5" y1="2.5" x2="126.5" y2="6.5" width="0.4064" layer="16"/>
<wire x1="126.5" y1="6.5" x2="127.5" y2="7.5" width="0.4064" layer="16"/>
<wire x1="127.5" y1="7.5" x2="129.23" y2="7.5" width="0.4064" layer="16"/>
</signal>
<signal name="SS4">
<contactref element="IC5" pad="14"/>
<contactref element="CON9" pad="3"/>
<contactref element="R2" pad="2"/>
<contactref element="CON9" pad="4"/>
<wire x1="151.5" y1="3" x2="145" y2="3" width="0.4064" layer="1"/>
<wire x1="145" y1="3" x2="143" y2="5" width="0.4064" layer="1"/>
<wire x1="143" y1="5" x2="140.45" y2="5" width="0.4064" layer="1"/>
<wire x1="150.77" y1="7.65" x2="148.23" y2="7.65" width="0.4064" layer="1"/>
<wire x1="134.7926" y1="25.2" x2="142.8" y2="25.2" width="0.4064" layer="1"/>
<wire x1="142.8" y1="25.2" x2="146" y2="22" width="0.4064" layer="1"/>
<wire x1="146" y1="22" x2="146" y2="9.88" width="0.4064" layer="1"/>
<wire x1="146" y1="9.88" x2="148.23" y2="7.65" width="0.4064" layer="1"/>
<wire x1="151.5" y1="3" x2="152.5" y2="4" width="0.4064" layer="1"/>
<wire x1="152.5" y1="4" x2="152.5" y2="7" width="0.4064" layer="1"/>
<wire x1="152.5" y1="7" x2="152" y2="7.5" width="0.4064" layer="1"/>
<wire x1="152" y1="7.5" x2="150.92" y2="7.5" width="0.4064" layer="1"/>
<wire x1="150.92" y1="7.5" x2="150.77" y2="7.65" width="0.4064" layer="1"/>
</signal>
<signal name="TX">
<contactref element="RXTX" pad="2"/>
<contactref element="IC5" pad="31"/>
<wire x1="126.2074" y1="22" x2="128.5" y2="22" width="0.4064" layer="1"/>
<wire x1="128.5" y1="22" x2="128.75" y2="22.25" width="0.4064" layer="1"/>
<via x="128.75" y="22.25" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="128.75" y1="22.25" x2="121" y2="30" width="0.4064" layer="16"/>
<wire x1="121" y1="30" x2="111.5" y2="30" width="0.4064" layer="16"/>
</signal>
<signal name="RX">
<contactref element="RXTX" pad="1"/>
<contactref element="IC5" pad="30"/>
<via x="128.75" y="24.75" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="126.2074" y1="22.8" x2="127.55" y2="22.8" width="0.4064" layer="1"/>
<wire x1="127.55" y1="22.8" x2="128.75" y2="24" width="0.4064" layer="1"/>
<wire x1="128.75" y1="24" x2="128.75" y2="24.75" width="0.4064" layer="1"/>
<wire x1="128.75" y1="24.75" x2="120.96" y2="32.54" width="0.4064" layer="16"/>
<wire x1="120.96" y1="32.54" x2="111.5" y2="32.54" width="0.4064" layer="16"/>
</signal>
<signal name="N$27">
<wire x1="137.9205" y1="18.992" x2="137.9205" y2="19.8175" width="0.254" layer="1"/>
<wire x1="137.9205" y1="18.1665" x2="137.9205" y2="18.992" width="0.254" layer="1"/>
<wire x1="137.9205" y1="18.992" x2="138.4285" y2="19.4365" width="0.254" layer="1"/>
<wire x1="138.4285" y1="19.4365" x2="138.4285" y2="20.262" width="0.254" layer="1"/>
<wire x1="137.9205" y1="19.8175" x2="138.4285" y2="20.262" width="0.254" layer="1"/>
</signal>
<signal name="N$28">
<wire x1="138.9365" y1="18.2935" x2="138.9365" y2="20.7065" width="0.254" layer="1"/>
<wire x1="141.8575" y1="23.183" x2="141.286" y2="22.675" width="0.254" layer="1"/>
<wire x1="141.8575" y1="20.897" x2="141.8575" y2="23.183" width="0.254" layer="1"/>
<wire x1="141.8575" y1="20.897" x2="138.9365" y2="18.2935" width="0.254" layer="1"/>
<wire x1="141.8575" y1="20.897" x2="142.556" y2="21.532" width="0.254" layer="1"/>
</signal>
<signal name="N$29">
<wire x1="139.4445" y1="19.4365" x2="140.0795" y2="20.008" width="0.254" layer="1"/>
<wire x1="139.4445" y1="20.262" x2="139.4445" y2="19.4365" width="0.254" layer="1"/>
<wire x1="139.4445" y1="20.262" x2="139.4445" y2="21.0875" width="0.254" layer="1"/>
<wire x1="139.4445" y1="21.0875" x2="139.9525" y2="21.532" width="0.254" layer="1"/>
<wire x1="139.9525" y1="20.7065" x2="139.9525" y2="21.532" width="0.254" layer="1"/>
<wire x1="139.4445" y1="20.262" x2="139.9525" y2="20.7065" width="0.254" layer="1"/>
</signal>
<signal name="N$30">
<wire x1="136.9045" y1="18.9285" x2="137.4125" y2="19.4365" width="0.254" layer="1"/>
<wire x1="136.9045" y1="18.1665" x2="136.9045" y2="18.9285" width="0.254" layer="1"/>
<wire x1="136.9045" y1="18.1665" x2="136.9045" y2="17.4045" width="0.254" layer="1"/>
<wire x1="136.9045" y1="18.1665" x2="137.4125" y2="18.6745" width="0.254" layer="1"/>
</signal>
<signal name="N$31">
<wire x1="140.651" y1="22.167" x2="140.3335" y2="21.8495" width="0.254" layer="1"/>
<wire x1="140.651" y1="20.516" x2="140.651" y2="22.167" width="0.254" layer="1"/>
<wire x1="140.651" y1="22.167" x2="140.905" y2="22.3575" width="0.254" layer="1"/>
</signal>
<signal name="M1">
<contactref element="MODE" pad="2"/>
<contactref element="IC5" pad="23"/>
<wire x1="128.5" y1="29.5" x2="128.5" y2="28.2926" width="0.4064" layer="1"/>
<wire x1="133.04" y1="45" x2="133.04" y2="42.54" width="0.4064" layer="1"/>
<wire x1="133.04" y1="42.54" x2="129.5" y2="39" width="0.4064" layer="1"/>
<wire x1="129.5" y1="39" x2="129.5" y2="30.5" width="0.4064" layer="1"/>
<wire x1="129.5" y1="30.5" x2="128.5" y2="29.5" width="0.4064" layer="1"/>
</signal>
<signal name="M2">
<contactref element="MODE" pad="3"/>
<contactref element="IC5" pad="24"/>
<wire x1="130.5" y1="45" x2="130.5" y2="42.5" width="0.4064" layer="1"/>
<wire x1="130.5" y1="42.5" x2="127.5" y2="39.5" width="0.4064" layer="1"/>
<wire x1="127.5" y1="39.5" x2="127.5" y2="28.4926" width="0.4064" layer="1"/>
<wire x1="127.5" y1="28.4926" x2="127.7" y2="28.2926" width="0.4064" layer="1"/>
</signal>
<signal name="M3">
<contactref element="MODE" pad="4"/>
<contactref element="IC5" pad="25"/>
<wire x1="127.96" y1="45" x2="127.96" y2="42.46" width="0.4064" layer="1"/>
<wire x1="127.96" y1="42.46" x2="126" y2="40.5" width="0.4064" layer="1"/>
<wire x1="126" y1="40.5" x2="126" y2="27.0074" width="0.4064" layer="1"/>
<wire x1="126" y1="27.0074" x2="126.2074" y2="26.8" width="0.4064" layer="1"/>
</signal>
<signal name="M4">
<contactref element="MODE" pad="5"/>
<contactref element="IC5" pad="26"/>
<wire x1="126.2074" y1="26" x2="125" y2="26" width="0.4064" layer="1"/>
<wire x1="125" y1="26" x2="124.5" y2="26.5" width="0.4064" layer="1"/>
<wire x1="124.5" y1="26.5" x2="124.5" y2="44.08" width="0.4064" layer="1"/>
<wire x1="124.5" y1="44.08" x2="125.42" y2="45" width="0.4064" layer="1"/>
</signal>
<signal name="GND5">
<contactref element="RXTX1" pad="3"/>
<contactref element="RTC" pad="4"/>
<contactref element="IC7" pad="7"/>
<contactref element="IC7" pad="6"/>
<contactref element="IC7" pad="5"/>
<contactref element="IC6" pad="3"/>
<contactref element="IC6" pad="5"/>
<contactref element="IC6" pad="21"/>
<contactref element="C37" pad="2"/>
<contactref element="IC7" pad="4"/>
<contactref element="C38" pad="2"/>
<contactref element="ISP1" pad="6"/>
<contactref element="C39" pad="2"/>
<contactref element="CON11" pad="8"/>
<contactref element="CON11" pad="7"/>
<contactref element="C40" pad="-"/>
<contactref element="DCF77" pad="1"/>
<polygon width="0.4064" layer="1">
<vertex x="104.5" y="-55.5"/>
<vertex x="156.5" y="-55.5"/>
<vertex x="156.5" y="-3.5"/>
<vertex x="104.5" y="-3.5"/>
</polygon>
<polygon width="0.4064" layer="16">
</polygon>
</signal>
<signal name="VCC5">
<contactref element="RTC" pad="5"/>
<contactref element="R6" pad="2"/>
<contactref element="IC6" pad="18"/>
<contactref element="C37" pad="1"/>
<contactref element="IC7" pad="8"/>
<contactref element="IC6" pad="4"/>
<contactref element="IC6" pad="6"/>
<contactref element="C38" pad="1"/>
<contactref element="R5" pad="2"/>
<contactref element="ISP1" pad="2"/>
<contactref element="R7" pad="2"/>
<contactref element="C39" pad="1"/>
<contactref element="CON11" pad="10"/>
<contactref element="CON11" pad="9"/>
<contactref element="C40" pad="+"/>
<wire x1="137.455" y1="-13.595" x2="137.5" y2="-13.55" width="0.4064" layer="1"/>
<contactref element="DCF77" pad="2"/>
<wire x1="133.1" y1="-13.595" x2="133.1" y2="-12.06" width="0.4064" layer="1"/>
<wire x1="137.455" y1="-13.595" x2="133.1" y2="-13.595" width="0.4064" layer="1"/>
<wire x1="130.1" y1="-33.7926" x2="130.1" y2="-32.9" width="0.4064" layer="1"/>
<wire x1="130.1" y1="-32.9" x2="131" y2="-32" width="0.4064" layer="1"/>
<wire x1="121.55" y1="-13.5" x2="121.55" y2="-17" width="0.4064" layer="1"/>
<wire x1="150.77" y1="-34.42" x2="148.23" y2="-34.42" width="0.4064" layer="1"/>
<wire x1="131" y1="-28" x2="131" y2="-32" width="0.4064" layer="1"/>
<wire x1="122.5" y1="-11.5" x2="121.5" y2="-12.5" width="0.4064" layer="1"/>
<wire x1="121.5" y1="-12.5" x2="121.5" y2="-13.45" width="0.4064" layer="1"/>
<wire x1="121.5" y1="-13.45" x2="121.55" y2="-13.5" width="0.4064" layer="1"/>
<wire x1="132.5" y1="-25.2074" x2="132.5" y2="-26.5" width="0.4064" layer="1"/>
<wire x1="132.5" y1="-26.5" x2="131" y2="-28" width="0.4064" layer="1"/>
<wire x1="133.1" y1="-12.06" x2="132.54" y2="-11.5" width="0.4064" layer="1"/>
<wire x1="132.54" y1="-11.5" x2="130.5" y2="-11.5" width="0.4064" layer="1"/>
<wire x1="130.5" y1="-11.5" x2="122.5" y2="-11.5" width="0.4064" layer="1"/>
<wire x1="129.54" y1="-8.5" x2="129.54" y2="-10.54" width="0.4064" layer="1"/>
<wire x1="129.54" y1="-10.54" x2="130.5" y2="-11.5" width="0.4064" layer="1"/>
<wire x1="131.7" y1="-33.7926" x2="131.7" y2="-36.15" width="0.4064" layer="1"/>
<wire x1="131.7" y1="-36.15" x2="132.55" y2="-37" width="0.4064" layer="1"/>
<wire x1="137.455" y1="-13.595" x2="143.095" y2="-13.595" width="0.4064" layer="1"/>
<wire x1="130.5" y1="-51" x2="134" y2="-51" width="0.4064" layer="16"/>
<wire x1="134" y1="-51" x2="146" y2="-39" width="0.4064" layer="16"/>
<wire x1="146" y1="-39" x2="146" y2="-36.65" width="0.4064" layer="16"/>
<wire x1="146" y1="-36.65" x2="148.23" y2="-34.42" width="0.4064" layer="16"/>
<wire x1="129.23" y1="-48.54" x2="129.23" y2="-49.73" width="0.4064" layer="16"/>
<wire x1="129.23" y1="-49.73" x2="130.5" y2="-51" width="0.4064" layer="16"/>
<wire x1="132.5" y1="-25.2074" x2="132.55" y2="-25.1574" width="0.4064" layer="1"/>
<wire x1="132.55" y1="-25.1574" x2="132.55" y2="-21.5" width="0.4064" layer="1"/>
<wire x1="132.55" y1="-21.5" x2="132.55" y2="-20.2" width="0.4064" layer="1"/>
<wire x1="131.25" y1="-18.9" x2="131.25" y2="-13.75" width="0.4064" layer="1"/>
<wire x1="131.25" y1="-13.75" x2="131.405" y2="-13.595" width="0.4064" layer="1"/>
<wire x1="131.405" y1="-13.595" x2="133.1" y2="-13.595" width="0.4064" layer="1"/>
<wire x1="131.25" y1="-18.9" x2="132.55" y2="-20.2" width="0.4064" layer="1"/>
<wire x1="131.7" y1="-33.7926" x2="131.7" y2="-32.7" width="0.4064" layer="1"/>
<wire x1="131.7" y1="-32.7" x2="131" y2="-32" width="0.4064" layer="1"/>
<wire x1="150.77" y1="-34.42" x2="150.77" y2="-28.43" width="0.4064" layer="1"/>
<wire x1="150.77" y1="-28.43" x2="151.7" y2="-27.5" width="0.4064" layer="1"/>
<wire x1="151.7" y1="-27.5" x2="151.7" y2="-22.2" width="0.4064" layer="1"/>
<wire x1="151.7" y1="-22.2" x2="143.095" y2="-13.595" width="0.4064" layer="1"/>
<wire x1="118.58" y1="-46.92" x2="126.5" y2="-39" width="0.4064" layer="1"/>
<wire x1="126.5" y1="-39" x2="126.5" y2="-37.05" width="0.4064" layer="1"/>
<wire x1="126.5" y1="-37.05" x2="126.55" y2="-37" width="0.4064" layer="1"/>
<wire x1="118.58" y1="-50.5" x2="119.08" y2="-51" width="0.4064" layer="16"/>
<wire x1="119.08" y1="-51" x2="130.5" y2="-51" width="0.4064" layer="16"/>
<wire x1="118.58" y1="-50.5" x2="118.58" y2="-46.92" width="0.4064" layer="1"/>
</signal>
<signal name="SDA1">
<contactref element="RTC" pad="1"/>
<contactref element="IC7" pad="1"/>
<contactref element="IC6" pad="27"/>
<contactref element="R5" pad="1"/>
<contactref element="CON11" pad="4"/>
<contactref element="CON11" pad="3"/>
<wire x1="130" y1="-14" x2="130" y2="-19" width="0.4064" layer="1"/>
<wire x1="127.9" y1="-13.595" x2="129.595" y2="-13.595" width="0.4064" layer="1"/>
<wire x1="129.595" y1="-13.595" x2="130" y2="-14" width="0.4064" layer="1"/>
<wire x1="150.77" y1="-42.04" x2="148.23" y2="-42.04" width="0.4064" layer="1"/>
<wire x1="127.9" y1="-13.595" x2="123.545" y2="-13.595" width="0.4064" layer="1"/>
<wire x1="123.545" y1="-13.595" x2="123.45" y2="-13.5" width="0.4064" layer="1"/>
<wire x1="148.23" y1="-42.04" x2="137.27" y2="-53" width="0.4064" layer="1"/>
<wire x1="137.27" y1="-53" x2="109.5" y2="-53" width="0.4064" layer="1"/>
<wire x1="126.2074" y1="-28.3" x2="124" y2="-28.3" width="0.4064" layer="1"/>
<wire x1="124" y1="-28.3" x2="114.7" y2="-28.3" width="0.4064" layer="1"/>
<wire x1="114.7" y1="-28.3" x2="108.42" y2="-34.58" width="0.4064" layer="1"/>
<wire x1="130" y1="-19" x2="124" y2="-25" width="0.4064" layer="1"/>
<wire x1="124" y1="-25" x2="124" y2="-28.3" width="0.4064" layer="1"/>
<wire x1="108.42" y1="-50.5" x2="108.42" y2="-51.92" width="0.4064" layer="1"/>
<wire x1="108.42" y1="-51.92" x2="109.5" y2="-53" width="0.4064" layer="1"/>
<wire x1="108.42" y1="-50.5" x2="108.42" y2="-34.58" width="0.4064" layer="1"/>
</signal>
<signal name="SCL1">
<contactref element="RTC" pad="2"/>
<contactref element="IC7" pad="2"/>
<contactref element="IC6" pad="28"/>
<contactref element="R6" pad="1"/>
<contactref element="CON11" pad="2"/>
<contactref element="CON11" pad="1"/>
<wire x1="150.77" y1="-44.58" x2="148.23" y2="-44.58" width="0.4064" layer="1"/>
<wire x1="127.9" y1="-14.865" x2="125.585" y2="-14.865" width="0.4064" layer="1"/>
<wire x1="125.585" y1="-14.865" x2="123.45" y2="-17" width="0.4064" layer="1"/>
<wire x1="148.23" y1="-44.58" x2="139.81" y2="-53" width="0.4064" layer="16"/>
<wire x1="139.81" y1="-53" x2="112.5" y2="-53" width="0.4064" layer="16"/>
<wire x1="122.4" y1="-29.1" x2="121.5" y2="-30" width="0.4064" layer="1"/>
<wire x1="121.5" y1="-30" x2="115.5" y2="-30" width="0.4064" layer="1"/>
<wire x1="115.5" y1="-30" x2="110.96" y2="-34.54" width="0.4064" layer="1"/>
<wire x1="126.2074" y1="-29.1" x2="127.4" y2="-29.1" width="0.4064" layer="1"/>
<wire x1="127.4" y1="-29.1" x2="129" y2="-27.5" width="0.4064" layer="1"/>
<via x="129" y="-27.5" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="129" y1="-27.5" x2="129" y2="-25.5" width="0.4064" layer="16"/>
<wire x1="129" y1="-25.5" x2="123.5" y2="-20" width="0.4064" layer="16"/>
<via x="123.5" y="-20" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="123.5" y1="-20" x2="123.5" y2="-17.05" width="0.4064" layer="1"/>
<wire x1="123.5" y1="-17.05" x2="123.45" y2="-17" width="0.4064" layer="1"/>
<wire x1="126.2074" y1="-29.1" x2="122.4" y2="-29.1" width="0.4064" layer="1"/>
<wire x1="110.96" y1="-50.5" x2="110.96" y2="-34.54" width="0.4064" layer="1"/>
<wire x1="110.96" y1="-50.5" x2="110.96" y2="-51.46" width="0.4064" layer="16"/>
<wire x1="110.96" y1="-51.46" x2="112.5" y2="-53" width="0.4064" layer="16"/>
</signal>
<signal name="77">
<contactref element="DCF77" pad="3"/>
<contactref element="IC6" pad="32"/>
<wire x1="109" y1="-18" x2="109" y2="-29" width="0.4064" layer="16"/>
<wire x1="126.2074" y1="-32.3" x2="126.0074" y2="-32.5" width="0.4064" layer="1"/>
<wire x1="126.0074" y1="-32.5" x2="123.5" y2="-32.5" width="0.4064" layer="1"/>
<via x="123.5" y="-32.5" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="123.5" y1="-32.5" x2="112.5" y2="-32.5" width="0.4064" layer="16"/>
<wire x1="112.5" y1="-32.5" x2="109" y2="-29" width="0.4064" layer="16"/>
<wire x1="124.46" y1="-8.5" x2="122.5" y2="-8.5" width="0.4064" layer="16"/>
<wire x1="122.5" y1="-8.5" x2="120" y2="-11" width="0.4064" layer="16"/>
<wire x1="120" y1="-11" x2="116" y2="-11" width="0.4064" layer="16"/>
<wire x1="116" y1="-11" x2="109" y2="-18" width="0.4064" layer="16"/>
</signal>
<signal name="77I">
<contactref element="DCF77" pad="4"/>
<contactref element="IC6" pad="1"/>
<wire x1="107.5" y1="-17.5" x2="107.5" y2="-30.5" width="0.4064" layer="16"/>
<wire x1="127.7" y1="-33.7926" x2="124.7926" y2="-33.7926" width="0.4064" layer="1"/>
<wire x1="124.7926" y1="-33.7926" x2="124.5" y2="-34" width="0.4064" layer="1"/>
<via x="124.5" y="-34" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="124.5" y1="-34" x2="111" y2="-34" width="0.4064" layer="16"/>
<wire x1="111" y1="-34" x2="107.5" y2="-30.5" width="0.4064" layer="16"/>
<wire x1="119.38" y1="-8.5" x2="116.5" y2="-8.5" width="0.4064" layer="16"/>
<wire x1="116.5" y1="-8.5" x2="107.5" y2="-17.5" width="0.4064" layer="16"/>
</signal>
<signal name="TX1">
<contactref element="RXTX1" pad="2"/>
<contactref element="IC6" pad="31"/>
<wire x1="126.2074" y1="-31.5" x2="129" y2="-31.5" width="0.4064" layer="1"/>
<via x="129" y="-31.5" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="129" y1="-31.5" x2="121" y2="-23.5" width="0.4064" layer="16"/>
<wire x1="111.5" y1="-23.5" x2="121" y2="-23.5" width="0.4064" layer="16"/>
</signal>
<signal name="RX1">
<contactref element="RXTX1" pad="1"/>
<contactref element="IC6" pad="30"/>
<wire x1="126.2074" y1="-30.7" x2="127.8" y2="-30.7" width="0.4064" layer="1"/>
<wire x1="127.8" y1="-30.7" x2="129" y2="-29.5" width="0.4064" layer="1"/>
<via x="129" y="-29.5" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="129" y1="-29.5" x2="120.46" y2="-20.96" width="0.4064" layer="16"/>
<wire x1="111.5" y1="-20.96" x2="120.46" y2="-20.96" width="0.4064" layer="16"/>
</signal>
<signal name="MOSI1">
<contactref element="IC6" pad="15"/>
<contactref element="ISP1" pad="4"/>
<via x="132.5" y="-29.5" extent="1-16" drill="0.6" shape="octagon"/>
<wire x1="132.5" y1="-29.5" x2="132.5" y2="-28.5" width="0.4064" layer="1"/>
<wire x1="132.5" y1="-28.5" x2="133.5" y2="-27.5" width="0.4064" layer="1"/>
<wire x1="134.7926" y1="-27.5" x2="133.5" y2="-27.5" width="0.4064" layer="1"/>
<wire x1="132.5" y1="-29.5" x2="132.5" y2="-36.5" width="0.4064" layer="16"/>
<wire x1="132.5" y1="-36.5" x2="127" y2="-42" width="0.4064" layer="16"/>
<wire x1="127" y1="-42" x2="127" y2="-45.5" width="0.4064" layer="16"/>
<wire x1="127" y1="-45.5" x2="127.5" y2="-46" width="0.4064" layer="16"/>
<wire x1="127.5" y1="-46" x2="129.23" y2="-46" width="0.4064" layer="16"/>
</signal>
<signal name="MISO1">
<contactref element="IC6" pad="16"/>
<contactref element="ISP1" pad="1"/>
<wire x1="134.7926" y1="-26.7" x2="135.7" y2="-26.7" width="0.4064" layer="1"/>
<wire x1="135.7" y1="-26.7" x2="136.5" y2="-27.5" width="0.4064" layer="1"/>
<wire x1="136.5" y1="-46" x2="136.5" y2="-27.5" width="0.4064" layer="1"/>
<wire x1="131.77" y1="-48.54" x2="133.96" y2="-48.54" width="0.4064" layer="1"/>
<wire x1="133.96" y1="-48.54" x2="136.5" y2="-46" width="0.4064" layer="1"/>
</signal>
<signal name="SCK5">
<contactref element="IC6" pad="17"/>
<contactref element="ISP1" pad="3"/>
<wire x1="131.77" y1="-46" x2="130.5" y2="-47.27" width="0.4064" layer="1"/>
<wire x1="132" y1="-51" x2="130.5" y2="-49.5" width="0.4064" layer="1"/>
<wire x1="130.5" y1="-47.27" x2="130.5" y2="-49.5" width="0.4064" layer="1"/>
<wire x1="132" y1="-51" x2="134" y2="-51" width="0.4064" layer="1"/>
<wire x1="136" y1="-25" x2="138" y2="-27" width="0.4064" layer="1"/>
<wire x1="138" y1="-27" x2="138" y2="-47" width="0.4064" layer="1"/>
<wire x1="138" y1="-47" x2="134" y2="-51" width="0.4064" layer="1"/>
<wire x1="136" y1="-25" x2="133.5074" y2="-25" width="0.4064" layer="1"/>
<wire x1="133.5074" y1="-25" x2="133.3" y2="-25.2074" width="0.4064" layer="1"/>
</signal>
<signal name="RES1">
<contactref element="ISP1" pad="5"/>
<contactref element="IC6" pad="29"/>
<contactref element="R7" pad="1"/>
<wire x1="122" y1="-34.5" x2="122" y2="-31" width="0.4064" layer="1"/>
<wire x1="122" y1="-31" x2="123.1" y2="-29.9" width="0.4064" layer="1"/>
<wire x1="126.2074" y1="-29.9" x2="123.1" y2="-29.9" width="0.4064" layer="1"/>
<wire x1="131.77" y1="-43.46" x2="131.77" y2="-42.27" width="0.4064" layer="1"/>
<wire x1="131.77" y1="-42.27" x2="128.45" y2="-38.95" width="0.4064" layer="1"/>
<wire x1="128.45" y1="-38.95" x2="128.45" y2="-37" width="0.4064" layer="1"/>
<wire x1="122" y1="-34.5" x2="123" y2="-35.5" width="0.4064" layer="1"/>
<wire x1="123" y1="-35.5" x2="127.5" y2="-35.5" width="0.4064" layer="1"/>
<wire x1="128.45" y1="-37" x2="128.45" y2="-36.45" width="0.4064" layer="1"/>
<wire x1="128.45" y1="-36.45" x2="127.5" y2="-35.5" width="0.4064" layer="1"/>
</signal>
<signal name="N$32">
<wire x1="140.9205" y1="-34.008" x2="140.9205" y2="-33.1825" width="0.254" layer="1"/>
<wire x1="140.9205" y1="-34.8335" x2="140.9205" y2="-34.008" width="0.254" layer="1"/>
<wire x1="140.9205" y1="-34.008" x2="141.4285" y2="-33.5635" width="0.254" layer="1"/>
<wire x1="141.4285" y1="-33.5635" x2="141.4285" y2="-32.738" width="0.254" layer="1"/>
<wire x1="140.9205" y1="-33.1825" x2="141.4285" y2="-32.738" width="0.254" layer="1"/>
</signal>
<signal name="N$33">
<wire x1="141.9365" y1="-34.7065" x2="141.9365" y2="-32.2935" width="0.254" layer="1"/>
<wire x1="144.8575" y1="-29.817" x2="144.286" y2="-30.325" width="0.254" layer="1"/>
<wire x1="144.8575" y1="-32.103" x2="144.8575" y2="-29.817" width="0.254" layer="1"/>
<wire x1="144.8575" y1="-32.103" x2="141.9365" y2="-34.7065" width="0.254" layer="1"/>
<wire x1="144.8575" y1="-32.103" x2="145.556" y2="-31.468" width="0.254" layer="1"/>
</signal>
<signal name="N$34">
<wire x1="142.4445" y1="-33.5635" x2="143.0795" y2="-32.992" width="0.254" layer="1"/>
<wire x1="142.4445" y1="-32.738" x2="142.4445" y2="-33.5635" width="0.254" layer="1"/>
<wire x1="142.4445" y1="-32.738" x2="142.4445" y2="-31.9125" width="0.254" layer="1"/>
<wire x1="142.4445" y1="-31.9125" x2="142.9525" y2="-31.468" width="0.254" layer="1"/>
<wire x1="142.9525" y1="-32.2935" x2="142.9525" y2="-31.468" width="0.254" layer="1"/>
<wire x1="142.4445" y1="-32.738" x2="142.9525" y2="-32.2935" width="0.254" layer="1"/>
</signal>
<signal name="N$35">
<wire x1="139.9045" y1="-34.0715" x2="140.4125" y2="-33.5635" width="0.254" layer="1"/>
<wire x1="139.9045" y1="-34.8335" x2="139.9045" y2="-34.0715" width="0.254" layer="1"/>
<wire x1="139.9045" y1="-34.8335" x2="139.9045" y2="-35.5955" width="0.254" layer="1"/>
<wire x1="139.9045" y1="-34.8335" x2="140.4125" y2="-34.3255" width="0.254" layer="1"/>
</signal>
<signal name="N$36">
<wire x1="143.651" y1="-30.833" x2="143.3335" y2="-31.1505" width="0.254" layer="1"/>
<wire x1="143.651" y1="-32.484" x2="143.651" y2="-30.833" width="0.254" layer="1"/>
<wire x1="143.651" y1="-30.833" x2="143.905" y2="-30.6425" width="0.254" layer="1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
