 *         Flowcode Quad Seven Segment Display Component Code
 * File: 7seg4.c
 * (c) 2009 Matrix Multimedia Ltd.
 * http://www.matrixmultimedia.com
 * Software License Agreement
 * The software supplied herewith by Matrix Multimedia Ltd (the
 * “Company”) for its Flowcode graphical programming language is
 * intended and supplied to you, the Company’s customer, for use
 * solely and exclusively on the Company's products. The software
 * is owned by the Company, and is protected under applicable
 * copyright laws. All rights are reserved. Any use in violation
 * of the foregoing restrictions may subject the user to criminal
 * sanctions under applicable laws, as well as to civil liability
 * for the breach of the terms and conditions of this licence.
 * THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
 * WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
 * TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
 * PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
 * IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
 * CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
 * Changelog:
 *  date  | by | description
 * 120607 | BR | Created
 * 160707 | ST | Modified to work with CTL file
 * 230409 | BR | Fixed incorrect definition names
 * 130509 | BR | Added % definitions to DefinesCode section
 * 030909 | BR | Added BoostC and HiTECH definitions
 * 071011 | BR | Converted component C file to universal component code
 * 011211 | BR | Updated FC_CAL_Bit functions
 Return & parameter types:
   void
   MX_UINT8
   MX_UINT16
   MX_STRING
 Pin directions:
   0 = OUTPUT
   2 = INPUT
   3 = BIDIRECTIONAL
[Settings]
CLSID={000F31EC-100D-4545-BB78-95A1FE1D53FB}
IsAnalogue=0
MultipleAllowed=1
Description=Quad Seven Segment Display Flowcode Component
NOTE: For simulation to work, these macros _MUST_ remain at the indicated index:
	1=ShowDigit
[MacroNames]
Count=1
1=ShowDigit
[MacroReturns]
1=void
[MacroIsPrivate]
1=0
[MacroParameters_ShowDigit]
Count=3
1=Digit
2=Value
3=DecimalPoint
[MacroParamTypes_ShowDigit]
1=MX_UINT8
2=MX_UINT8
3=MX_UINT8
 * ADDITIONAL CODE
/*DefinesCode_Start*/
/**** Macro Substitutions ****
a = Unique Reference
b = Segment Port letter
c = Common Port letter
d = Segment Pin 0
e = Segment Pin 1
f = Segment Pin 2
g = Segment Pin 3
h = Segment Pin 4
i = Segment Pin 5
j = Segment Pin 6
k = Segment Pin 7
l = Common Pin 0
m = Common Pin 1
n = Common Pin 2
o = Common Pin 3
p = Display Type 0=Common Cathode, 1=Common Anode
#define %a_MX_7SEG_SEG_PORT		port%b
#define %a_MX_7SEG_SEG_TRIS		tris%b
#define %a_MX_7SEG_COM_PORT		port%c
#define %a_MX_7SEG_COM_TRIS		tris%c
#define %a_MX_7SEG_SEG_PIN0		%d
#define %a_MX_7SEG_SEG_PIN1		%e
#define %a_MX_7SEG_SEG_PIN2		%f
#define %a_MX_7SEG_SEG_PIN3		%g
#define %a_MX_7SEG_SEG_PIN4		%h
#define %a_MX_7SEG_SEG_PIN5		%i
#define %a_MX_7SEG_SEG_PIN6		%j
#define %a_MX_7SEG_SEG_PIN7		%k
#define %a_MX_7SEG_COM_PIN0		%l
#define %a_MX_7SEG_COM_PIN1		%m
#define %a_MX_7SEG_COM_PIN2		%n
#define %a_MX_7SEG_COM_PIN3		%o
#define %a_MX_7SEG_COM_TYPE 	1	//%p
#ifndef MX_7SEG_ARRAY
 #define MX_7SEG_ARRAY
 ROMARRAY_S SegmentArray ROMARRAY_E = {192, 249, 164, 176, 153, 146, 130, 248, 128, 152, 191, 136, 131, 198, 161, 134, 142, 137, 207, 241, 199, 200, 163, 140, 156, 193, 206, 255};		//Create ROM pattern array for the display
#endif
/*DefinesCode_End*/
/*InitialisationCode_Start*/
/*InitialisationCode_End*/
/*InterruptCode_Start*/
/*InterruptCode_End*/
void ShowDigit(MX_UINT8 Digit, MX_UINT8 Value, MX_UINT8 DecimalPoint)
/*Macro_ShowDigit_Start*/
	if (Digit <= 3)
		//get pattern for digit
		MX_UINT8 cSegmentValue = SegmentArray[Value % 28];
		if (DecimalPoint)
			cSegmentValue = cSegmentValue & 0x7F;
		//display the digit
		#if (%a_MX_7SEG_COM_TYPE == 1)						//Common Anode - Low = on, High = off
			if (cSegmentValue & 0x01)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN0);
			else FC_CAL_Bit_Low_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN0);
			if (cSegmentValue & 0x02)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN1);
			else FC_CAL_Bit_Low_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN1);
			if (cSegmentValue & 0x04)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN2);
			else FC_CAL_Bit_Low_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN2);
			if (cSegmentValue & 0x08)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN3);
			else FC_CAL_Bit_Low_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN3);
			if (cSegmentValue & 0x10)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN4);
			else FC_CAL_Bit_Low_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN4);
			if (cSegmentValue & 0x20)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN5);
			else FC_CAL_Bit_Low_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN5);
			if (cSegmentValue & 0x40)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN6);
			else FC_CAL_Bit_Low_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN6);
			if (cSegmentValue & 0x80)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN7);
			else FC_CAL_Bit_Low_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN7);
			FC_CAL_Bit_Low_DDR(%a_MX_7SEG_COM_PORT, %a_MX_7SEG_COM_TRIS, %a_MX_7SEG_COM_PIN0);
			FC_CAL_Bit_Low_DDR(%a_MX_7SEG_COM_PORT, %a_MX_7SEG_COM_TRIS, %a_MX_7SEG_COM_PIN1);
			FC_CAL_Bit_Low_DDR(%a_MX_7SEG_COM_PORT, %a_MX_7SEG_COM_TRIS, %a_MX_7SEG_COM_PIN2);
			FC_CAL_Bit_Low_DDR(%a_MX_7SEG_COM_PORT, %a_MX_7SEG_COM_TRIS, %a_MX_7SEG_COM_PIN3);
			if (Digit == 0)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_COM_PORT, %a_MX_7SEG_COM_TRIS, %a_MX_7SEG_COM_PIN0);
			if (Digit == 1)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_COM_PORT, %a_MX_7SEG_COM_TRIS, %a_MX_7SEG_COM_PIN1);
			if (Digit == 2)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_COM_PORT, %a_MX_7SEG_COM_TRIS, %a_MX_7SEG_COM_PIN2);
			if (Digit == 3)
				FC_CAL_Bit_High_DDR(%a_MX_7SEG_COM_PORT, %a_MX_7SEG_COM_TRIS, %a_MX_7SEG_COM_PIN3);
		#else												//Common Cathode - Low = off, High = on
			else FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN0);
			else FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN1);
			else FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN2);
			else FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN3);
			else FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN4);
			else FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN5);
			else FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN6);
			else FC_CAL_Bit_High_DDR(%a_MX_7SEG_SEG_PORT, %a_MX_7SEG_SEG_TRIS, %a_MX_7SEG_SEG_PIN7);
			if (Digit == 0)
			if (Digit == 1)
			if (Digit == 2)
			if (Digit == 3)
		#endif
/*Macro_ShowDigit_End*/
