<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="yes"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Bemassung" color="7" fill="1" visible="yes" active="yes"/>
<layer number="102" name="Changes" color="12" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="yes" active="yes"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="OrgLBR" color="13" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<plain>
<text x="57.785" y="33.02" size="1.778" layer="16" ratio="15" rot="MR0">1</text>
<text x="10.795" y="43.815" size="1.778" layer="16" ratio="15" rot="MR0">1</text>
<wire x1="-1.27" y1="-1.27" x2="85.09" y2="-1.27" width="0.4064" layer="20"/>
<wire x1="85.09" y1="-1.27" x2="85.09" y2="53.975" width="0.4064" layer="20"/>
<wire x1="85.09" y1="53.975" x2="-1.27" y2="53.975" width="0.4064" layer="20"/>
<wire x1="-1.27" y1="53.975" x2="-1.27" y2="-1.27" width="0.4064" layer="20"/>
</plain>
<libraries>
<library name="display-lcd">
<description>&lt;b&gt;Hitachi, Data Modul, Tuxgraphics - LCD Displays&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TUXGR_16X2_R2">
<description>&lt;b&gt;Tuxgraphics LCD display 16x2 characters&lt;/b&gt; reflective, without background light&lt;p&gt;
Source: tuxgr_12x2_r2.pdf</description>
<wire x1="-39.9" y1="17.9" x2="39.9" y2="17.9" width="0.2032" layer="21"/>
<wire x1="39.9" y1="17.9" x2="39.9" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="39.9" y1="-17.9" x2="-39.9" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="-39.9" y1="-17.9" x2="-39.9" y2="17.9" width="0.2032" layer="21"/>
<wire x1="-36.75" y1="12" x2="36.75" y2="12" width="0.2032" layer="21"/>
<wire x1="36.75" y1="12" x2="36.75" y2="-12.6" width="0.2032" layer="21"/>
<wire x1="36.75" y1="-12.6" x2="-36.75" y2="-12.6" width="0.2032" layer="21"/>
<wire x1="-36.75" y1="-12.6" x2="-36.75" y2="12" width="0.2032" layer="21"/>
<wire x1="-32.15" y1="6.5" x2="32.15" y2="6.5" width="0.2032" layer="21"/>
<wire x1="32.15" y1="6.5" x2="32.15" y2="-7.1" width="0.2032" layer="21"/>
<wire x1="32.15" y1="-7.1" x2="-32.15" y2="-7.1" width="0.2032" layer="21"/>
<wire x1="-32.15" y1="-7.1" x2="-32.15" y2="6.5" width="0.2032" layer="21"/>
<text x="-38.1" y="18.415" size="1.27" layer="25">&gt;NAME</text>
<text x="0.635" y="18.415" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-28.85" y1="0.1" x2="-25.9" y2="4.45" layer="21"/>
<rectangle x1="-28.85" y1="-5.05" x2="-25.9" y2="-0.7" layer="21"/>
<rectangle x1="-25.2" y1="0.1" x2="-22.25" y2="4.45" layer="21"/>
<rectangle x1="-25.2" y1="-5.05" x2="-22.25" y2="-0.7" layer="21"/>
<rectangle x1="-21.55" y1="0.1" x2="-18.6" y2="4.45" layer="21"/>
<rectangle x1="-21.55" y1="-5.05" x2="-18.6" y2="-0.7" layer="21"/>
<rectangle x1="-17.9" y1="0.1" x2="-14.95" y2="4.45" layer="21"/>
<rectangle x1="-17.9" y1="-5.05" x2="-14.95" y2="-0.7" layer="21"/>
<rectangle x1="-14.25" y1="0.1" x2="-11.3" y2="4.45" layer="21"/>
<rectangle x1="-14.25" y1="-5.05" x2="-11.3" y2="-0.7" layer="21"/>
<rectangle x1="-10.6" y1="0.1" x2="-7.65" y2="4.45" layer="21"/>
<rectangle x1="-10.6" y1="-5.05" x2="-7.65" y2="-0.7" layer="21"/>
<rectangle x1="-6.95" y1="0.1" x2="-4" y2="4.45" layer="21"/>
<rectangle x1="-6.95" y1="-5.05" x2="-4" y2="-0.7" layer="21"/>
<rectangle x1="-3.3" y1="0.1" x2="-0.35" y2="4.45" layer="21"/>
<rectangle x1="-3.3" y1="-5.05" x2="-0.35" y2="-0.7" layer="21"/>
<rectangle x1="0.35" y1="0.1" x2="3.3" y2="4.45" layer="21"/>
<rectangle x1="0.35" y1="-5.05" x2="3.3" y2="-0.7" layer="21"/>
<rectangle x1="4" y1="0.1" x2="6.95" y2="4.45" layer="21"/>
<rectangle x1="4" y1="-5.05" x2="6.95" y2="-0.7" layer="21"/>
<rectangle x1="7.65" y1="0.1" x2="10.6" y2="4.45" layer="21"/>
<rectangle x1="7.65" y1="-5.05" x2="10.6" y2="-0.7" layer="21"/>
<rectangle x1="11.3" y1="0.1" x2="14.25" y2="4.45" layer="21"/>
<rectangle x1="11.3" y1="-5.05" x2="14.25" y2="-0.7" layer="21"/>
<rectangle x1="14.95" y1="0.1" x2="17.9" y2="4.45" layer="21"/>
<rectangle x1="14.95" y1="-5.05" x2="17.9" y2="-0.7" layer="21"/>
<rectangle x1="18.6" y1="0.1" x2="21.55" y2="4.45" layer="21"/>
<rectangle x1="18.6" y1="-5.05" x2="21.55" y2="-0.7" layer="21"/>
<rectangle x1="22.25" y1="0.1" x2="25.2" y2="4.45" layer="21"/>
<rectangle x1="22.25" y1="-5.05" x2="25.2" y2="-0.7" layer="21"/>
<rectangle x1="25.9" y1="0.1" x2="28.85" y2="4.45" layer="21"/>
<rectangle x1="25.9" y1="-5.05" x2="28.85" y2="-0.7" layer="21"/>
<hole x="-37.5" y="-15.5" drill="2.5"/>
<hole x="37.5" y="-15.5" drill="2.5"/>
<hole x="-37.5" y="15.5" drill="2.5"/>
<hole x="37.5" y="15.5" drill="2.5"/>
<pad name="P$1" x="-31.75" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$2" x="-29.21" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$3" x="-26.67" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$4" x="-24.13" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$5" x="-21.59" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$6" x="-19.05" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$7" x="-16.51" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$8" x="-13.97" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$9" x="-11.43" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$10" x="-8.89" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$11" x="-6.35" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$12" x="-3.81" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$13" x="-1.27" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$14" x="1.27" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$15" x="3.81" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
<pad name="P$16" x="6.35" y="15.24" drill="0.8" diameter="1.6764" shape="long" rot="R90"/>
</package>
</packages>
</library>
<library name="pic16f690">
<packages>
<package name="DIL20">
<wire x1="12.7" y1="2.921" x2="-12.7" y2="2.921" width="0.127" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="12.7" y2="-2.921" width="0.127" layer="21"/>
<wire x1="12.7" y1="2.921" x2="12.7" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-12.7" y1="2.921" x2="-12.7" y2="1.016" width="0.127" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="-12.7" y2="-1.016" width="0.127" layer="21"/>
<wire x1="-12.7" y1="1.016" x2="-12.7" y2="-1.016" width="0.127" layer="21" curve="-180"/>
<pad name="1" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.08" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="special">
<packages>
<package name="QS">
<description>&lt;B&gt;CRYSTAL&lt;/B&gt;</description>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.0508" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.0508" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.429" y2="-1.778" width="0.0508" layer="21" curve="-180"/>
<wire x1="3.429" y1="2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21" curve="-180"/>
<wire x1="-3.429" y1="2.286" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="180"/>
<wire x1="-3.429" y1="1.778" x2="-3.429" y2="-1.778" width="0.0508" layer="21" curve="180"/>
<pad name="1" x="-2.54" y="0" drill="0.6096" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="0.6096" shape="long" rot="R90"/>
<text x="-5.08" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.08" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
<library name="relay">
<packages>
<package name="HE751">
<description>&lt;b&gt;RELAY&lt;/b&gt;&lt;p&gt;
reed, 1 x norm. open, Hamlin</description>
<wire x1="-5.08" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.635" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-0.635" y1="0" x2="0.635" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="-0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="-0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-0.635" x2="0.635" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-0.635" x2="-0.635" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.905" x2="0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-9.271" y1="0.635" x2="-9.271" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="9.652" y1="2.794" x2="-9.652" y2="2.794" width="0.1524" layer="21"/>
<wire x1="9.652" y1="-2.794" x2="-9.652" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="9.652" y1="-2.794" x2="9.652" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="0.635" x2="-9.652" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-9.652" y1="0.635" x2="-9.652" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="-0.635" x2="-9.652" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-9.652" y1="-0.635" x2="-9.652" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-9.652" y1="-0.635" x2="-9.652" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="2.54" x2="7.62" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.27" x2="1.524" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.27" x2="7.62" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.54" x2="-7.62" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="1.27" y2="1.905" width="0.254" layer="21"/>
<wire x1="1.016" y1="1.27" x2="1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.524" x2="1.524" y2="1.27" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-8.001" y="-2.286" size="1.27" layer="21" ratio="10" rot="R90">1</text>
<text x="-2.54" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.445" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="resistor">
<packages>
<package name="C0603">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.356" y1="0.432" x2="0.356" y2="0.432" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.419" x2="0.356" y2="-0.419" width="0.1016" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.1" dy="1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.1" dy="1" layer="1"/>
<text x="-0.889" y="0.762" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.889" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8382" y1="-0.4699" x2="-0.3381" y2="0.4801" layer="51"/>
<rectangle x1="0.3302" y1="-0.4699" x2="0.8303" y2="0.4801" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="R0603">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<text x="-0.889" y="0.889" size="1.27" layer="25">&gt;NAME</text>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="M1206">
MELF 0.25 W</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="C/6032-28R">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 Reflow solder&lt;/b&gt;&lt;p&gt;
KEMET U / EIA 6032-15</description>
<wire x1="-2.8" y1="1.55" x2="2.8" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="1.55" x2="2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-1.55" x2="-2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.8" y1="-1.55" x2="-2.8" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<smd name="-" x="-2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<text x="-3" y="1.825" size="1.27" layer="25">&gt;NAME</text>
<text x="-3" y="-3.05" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3" y1="-1.1" x2="-2.85" y2="1.1" layer="51"/>
<rectangle x1="2.85" y1="-1.1" x2="3" y2="1.1" layer="51"/>
<rectangle x1="1.95" y1="-1.575" x2="2.45" y2="1.575" layer="51"/>
</package>
</packages>
</library>
<library name="pot">
<packages>
<package name="CA6H">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;&lt;p&gt;
distributor Schukat</description>
<wire x1="3.302" y1="1.27" x2="3.302" y2="0.127" width="0.1524" layer="51"/>
<wire x1="1.143" y1="0" x2="-1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0" x2="-3.175" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="3.175" x2="-2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="3.175" x2="-3.175" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.556" x2="-2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="3.556" x2="1.016" y2="3.556" width="0.1524" layer="51"/>
<wire x1="2.032" y1="3.429" x2="1.905" y2="3.556" width="0.1524" layer="21"/>
<wire x1="2.032" y1="3.429" x2="2.032" y2="3.175" width="0.1524" layer="21"/>
<wire x1="1.397" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="51"/>
<wire x1="1.143" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.127" x2="3.175" y2="0" width="0.1524" layer="51"/>
<wire x1="3.302" y1="3.048" x2="3.175" y2="3.175" width="0.1524" layer="21"/>
<wire x1="3.175" y1="3.175" x2="2.032" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="3.175" x2="-3.302" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.302" y2="0.127" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0.127" x2="-3.302" y2="1.27" width="0.1524" layer="51"/>
<wire x1="3.175" y1="0" x2="1.143" y2="0" width="0.1524" layer="51"/>
<wire x1="3.302" y1="1.27" x2="3.302" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.27" x2="-3.302" y2="3.048" width="0.1524" layer="21"/>
<wire x1="1.397" y1="3.175" x2="2.032" y2="3.175" width="0.1524" layer="21"/>
<wire x1="1.143" y1="3.429" x2="2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="1.905" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.556" x2="-1.016" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="21"/>
<pad name="A" x="-2.54" y="0" drill="1.016" shape="long"/>
<pad name="S" x="0" y="2.54" drill="1.016" shape="long"/>
<pad name="E" x="2.54" y="0" drill="1.016" shape="long"/>
<text x="-2.54" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="inductors">
<packages>
<package name="BC12">
<description>&lt;B&gt;INDUCTOR&lt;/B&gt;&lt;p&gt;
manufacturer Siemens</description>
<wire x1="-5.334" y1="2.032" x2="5.334" y2="2.032" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-2.032" x2="-5.334" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="6.096" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.096" y1="0" x2="-6.35" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.715" y1="-1.651" x2="-5.334" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="5.334" y1="2.032" x2="5.715" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.334" y1="-2.032" x2="5.715" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.715" y1="1.651" x2="-5.334" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.715" y1="-1.651" x2="5.715" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="5.715" y1="0.762" x2="5.715" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="5.715" y1="0.762" x2="5.715" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0.762" x2="-5.715" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="0.762" x2="-5.715" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.651" x2="-5.715" y2="-0.762" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="long"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="long"/>
<text x="-5.842" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-0.889" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="5.715" y1="-0.3048" x2="6.0198" y2="0.3048" layer="51"/>
<rectangle x1="-6.0198" y1="-0.3048" x2="-5.715" y2="0.3048" layer="51"/>
</package>
</packages>
</library>
<library name="wirepad">
<packages>
<package name="2,54/0,8">
<description>&lt;b&gt;THROUGH-HOLE PAD&lt;/b&gt;</description>
<wire x1="-1.27" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="0.762" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.762" x2="1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="0.762" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.27" x2="-1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="-0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.635" width="0.1524" layer="51"/>
<pad name="1" x="0" y="0" drill="0.8128" diameter="2.54" shape="octagon"/>
<text x="-1.27" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.6" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<packages>
<package name="SOD80C">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
</packages>
</library>
<library name="ZOLI">
<packages>
<package name="C3">
<wire x1="-3.81" y1="-2.54" x2="-3.81" y2="2.54" width="0.127" layer="21"/>
<wire x1="-3.81" y1="2.54" x2="3.81" y2="2.54" width="0.127" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="-2.54" width="0.127" layer="21"/>
<wire x1="3.81" y1="-2.54" x2="-3.81" y2="-2.54" width="0.127" layer="21"/>
<pad name="P$1" x="2.54" y="0" drill="0.8" diameter="1.778"/>
<pad name="P$2" x="-2.54" y="0" drill="0.8" diameter="1.778"/>
<text x="-2.54" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-5.08" size="1.27" layer="25">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="switch">
<packages>
<package name="M9040P">
<description>&lt;b&gt;TOGGLE SWITCH&lt;/b&gt;&lt;p&gt;
Marquardt</description>
<wire x1="-3.3528" y1="6.6802" x2="-3.9878" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="6.6802" x2="3.3528" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="3.9878" y1="6.0452" x2="3.3528" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="3.3782" y1="-6.6802" x2="4.0132" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="3.3782" y1="-6.6802" x2="-3.3782" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="-6.0452" x2="-3.3782" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="2.286" x2="-4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="3.9878" y2="2.5146" width="0.1524" layer="21"/>
<wire x1="0" y1="5.08" x2="-3.9878" y2="2.4892" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-2.286" x2="-4.0132" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="0" y1="-5.08" x2="4.0132" y2="-2.4892" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.6002" y1="1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="4.0132" y1="-6.0452" x2="4.0132" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="3.9878" y1="6.0452" x2="3.9878" y2="2.5146" width="0.1524" layer="21"/>
<wire x1="-3.9878" y1="2.4892" x2="-3.9878" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="-6.0452" x2="-4.0132" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="51" curve="-270"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="51" curve="-233.130102"/>
<wire x1="-1.6002" y1="1.27" x2="1.6002" y2="1.27" width="0.1524" layer="51"/>
<wire x1="3.9878" y1="2.5146" x2="0" y2="5.08" width="0.1524" layer="51"/>
<wire x1="4.0132" y1="-2.4892" x2="4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="-2.4892" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-3.9878" y1="2.4892" x2="-4.318" y2="2.286" width="0.1524" layer="21"/>
<pad name="3" x="0" y="-4.699" drill="1.8034" shape="long"/>
<pad name="2" x="0" y="0" drill="1.8034" shape="long"/>
<pad name="1" x="0" y="4.699" drill="1.8034" shape="long"/>
<text x="-3.81" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="M9040P2">
<wire x1="-5.6642" y1="6.6802" x2="-6.2992" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-5.6642" y1="6.6802" x2="5.6642" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="6.2992" y1="6.0452" x2="5.6642" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="5.6642" y1="-6.6802" x2="6.2992" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="5.6642" y1="-6.6802" x2="-5.6642" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="-6.2992" y1="-6.0452" x2="-5.6642" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="6.2992" y1="6.0452" x2="6.2992" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="-6.2992" y1="-6.0452" x2="-6.2992" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="4.318" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="2.286" x2="-4.318" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="4.318" y1="2.286" x2="0" y2="5.08" width="0.1524" layer="51"/>
<wire x1="0" y1="5.08" x2="-4.318" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-2.286" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="0" y1="-5.08" x2="4.318" y2="-2.286" width="0.1524" layer="51"/>
<pad name="3" x="-2.413" y="-4.699" drill="1.8034" shape="octagon"/>
<pad name="2" x="-2.413" y="0" drill="1.8034" shape="octagon"/>
<pad name="1" x="-2.413" y="4.699" drill="1.8034" shape="octagon"/>
<pad name="4" x="2.413" y="4.699" drill="1.8034" shape="octagon"/>
<pad name="5" x="2.413" y="0" drill="1.8034" shape="octagon"/>
<pad name="6" x="2.413" y="-4.699" drill="1.8034" shape="octagon"/>
<text x="-5.08" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="SOT223">
<description>&lt;b&gt;Small Outline Transistor&lt;/b&gt;</description>
<wire x1="3.2766" y1="1.778" x2="3.2766" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="3.2766" y1="-1.778" x2="-3.2766" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="-3.2766" y1="-1.778" x2="-3.2766" y2="1.778" width="0.2032" layer="21"/>
<wire x1="-3.2766" y1="1.778" x2="3.2766" y2="1.778" width="0.2032" layer="21"/>
<smd name="1" x="-2.3114" y="-3.0988" dx="1.2192" dy="2.2352" layer="1"/>
<smd name="2" x="0" y="-3.0988" dx="1.2192" dy="2.2352" layer="1"/>
<smd name="3" x="2.3114" y="-3.0988" dx="1.2192" dy="2.2352" layer="1"/>
<smd name="4" x="0" y="3.099" dx="3.6" dy="2.2" layer="1"/>
<text x="1.0208" y="-4.318" size="0.8128" layer="21" ratio="12">3</text>
<text x="1.905" y="2.54" size="0.8128" layer="21" ratio="12">4</text>
<text x="-3.4526" y="-4.318" size="0.8128" layer="21" ratio="12">1</text>
<text x="-1.2906" y="-4.3274" size="0.8128" layer="21" ratio="12">2</text>
<text x="-2.54" y="0.0508" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-1.3208" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6002" y1="1.8034" x2="1.6002" y2="3.6576" layer="51"/>
<rectangle x1="-0.4318" y1="-3.6576" x2="0.4318" y2="-1.8034" layer="51"/>
<rectangle x1="-2.7432" y1="-3.6576" x2="-1.8796" y2="-1.8034" layer="51"/>
<rectangle x1="1.8796" y1="-3.6576" x2="2.7432" y2="-1.8034" layer="51"/>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="2,8-PAD">
<description>&lt;b&gt;MOUNTING PAD&lt;/b&gt; 2.8 mm, round</description>
<wire x1="0" y1="2.921" x2="0" y2="2.667" width="0.0508" layer="21"/>
<wire x1="0" y1="-2.667" x2="0" y2="-2.921" width="0.0508" layer="21"/>
<wire x1="-1.778" y1="0" x2="0" y2="-1.778" width="2.286" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="1.778" x2="1.778" y2="0" width="2.286" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="0.635" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.175" width="0.8128" layer="39"/>
<circle x="0" y="0" radius="3.175" width="0.8128" layer="40"/>
<circle x="0" y="0" radius="3.175" width="0.8128" layer="43"/>
<circle x="0" y="0" radius="1.5" width="0.2032" layer="21"/>
<pad name="B2,8" x="0" y="0" drill="2.8" diameter="5.334"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C102-043X133">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-jack">
<description>&lt;b&gt;Jacks&lt;/b&gt;&lt;p&gt;
Power Connectors&lt;br&gt;
Phone Connectors&lt;br&gt;
Cinch Connectors&lt;br&gt;
<packages>
<package name="DCJ0303">
<description>&lt;b&gt;DC POWER JACK&lt;/b&gt; Pad shape changed to LONG 2007.07.26&lt;p&gt;
Source: DCJ0303.pdf</description>
<wire x1="1.65" y1="2.6" x2="-1.65" y2="2.6" width="0" layer="46"/>
<wire x1="-1.65" y1="2.6" x2="-1.65" y2="3.6" width="0" layer="46"/>
<wire x1="-1.65" y1="3.6" x2="1.65" y2="3.6" width="0" layer="46"/>
<wire x1="1.65" y1="3.6" x2="1.65" y2="2.6" width="0" layer="46"/>
<wire x1="5.3" y1="1.4" x2="4.3" y2="1.4" width="0" layer="46"/>
<wire x1="4.3" y1="1.4" x2="4.3" y2="-1.4" width="0" layer="46"/>
<wire x1="4.3" y1="-1.4" x2="5.3" y2="-1.4" width="0" layer="46"/>
<wire x1="5.3" y1="-1.4" x2="5.3" y2="1.4" width="0" layer="46"/>
<wire x1="1.4" y1="-3.5" x2="-1.4" y2="-3.5" width="0" layer="46"/>
<wire x1="-1.4" y1="-3.5" x2="-1.4" y2="-2.5" width="0" layer="46"/>
<wire x1="-1.4" y1="-2.5" x2="1.4" y2="-2.5" width="0" layer="46"/>
<wire x1="1.4" y1="-2.5" x2="1.4" y2="-3.5" width="0" layer="46"/>
<wire x1="-4.3" y1="-10.4" x2="4.3" y2="-10.4" width="0.2032" layer="21"/>
<wire x1="4.3" y1="-10.4" x2="4.3" y2="3.9" width="0.2032" layer="51"/>
<wire x1="4.3" y1="3.9" x2="-4.3" y2="3.9" width="0.2032" layer="51"/>
<wire x1="-4.3" y1="3.9" x2="-4.3" y2="-10.4" width="0.2032" layer="21"/>
<wire x1="-2.7" y1="3.9" x2="-4.3" y2="3.9" width="0.2032" layer="21"/>
<wire x1="4.3" y1="3.9" x2="2.7" y2="3.9" width="0.2032" layer="21"/>
<wire x1="-3" y1="-10.275" x2="-3" y2="-3" width="0.2032" layer="51" style="shortdash"/>
<wire x1="3" y1="-10.3" x2="3" y2="-3" width="0.2032" layer="51" style="shortdash"/>
<wire x1="3" y1="-3" x2="-3" y2="-3" width="0.2032" layer="51" style="shortdash"/>
<wire x1="-0.9" y1="-9" x2="-0.9" y2="-4.5" width="0.2032" layer="51" style="shortdash"/>
<wire x1="0.9" y1="-9" x2="0.9" y2="-4.5" width="0.2032" layer="51" style="shortdash"/>
<wire x1="-0.9" y1="-9" x2="0.9" y2="-9" width="0.2032" layer="51" curve="166.57811"/>
<wire x1="4.3" y1="-10.4" x2="4.3" y2="-2.45" width="0.2032" layer="21"/>
<wire x1="4.3" y1="2.3" x2="4.3" y2="3.9" width="0.2032" layer="21"/>
<pad name="1" x="0" y="3.1" drill="1" diameter="2" shape="long" rot="R180"/>
<pad name="3" x="0" y="-3" drill="1" diameter="2" shape="long" rot="R180"/>
<pad name="2" x="4.8" y="0" drill="1" diameter="2" shape="long" rot="R90"/>
<text x="6.35" y="-10.16" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-5.08" y="-10.16" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="DISPLAY1" library="display-lcd" package="TUXGR_16X2_R2" value="" x="41.91" y="33.02">
<attribute name="OC_NEWARK" value="unknown" x="95.25" y="13.97" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="95.25" y="13.97" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="95.25" y="13.97" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="95.25" y="13.97" size="1.778" layer="27" display="off"/>
</element>
<element name="U1" library="pic16f690" package="DIL20" value="16f690" x="44.45" y="33.02" rot="R180"/>
<element name="Q1" library="special" package="QS" value="20MHz" x="53.34" y="41.91" rot="R180"/>
<element name="K1" library="relay" package="HE751" value="HE751" x="21.59" y="33.3375" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="21.59" y="33.3375" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="21.59" y="33.3375" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="21.59" y="33.3375" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="21.59" y="33.3375" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="C1" library="resistor" package="C0603" value="22p" x="50.8" y="45.085" smashed="yes" rot="MR270">
<attribute name="NAME" x="52.08835625" y="46.68160625" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="51.37551875" y="45.04241875" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="C2" library="resistor" package="C0603" value="22p" x="55.88" y="45.085" smashed="yes" rot="MR270">
<attribute name="NAME" x="57.46078125" y="46.48281875" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="56.75891875" y="44.80131875" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R1" library="resistor" package="R0603" value="100k" x="50.165" y="23.8125" smashed="yes" rot="MR90">
<attribute name="NAME" x="49.644384375" y="25.612865625" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="49.585990625" y="17.978540625" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R2" library="resistor" package="R0603" value="100k" x="47.9425" y="20.0025" smashed="yes" rot="MR90">
<attribute name="NAME" x="47.347940625" y="16.06779375" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="45.624196875" y="17.23921875" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R3" library="resistor" package="R0603" value="100k" x="47.9425" y="23.8125" smashed="yes" rot="MR270">
<attribute name="NAME" x="48.528175" y="27.80294375" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="46.8772375" y="26.13324375" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="R4" library="resistor" package="R0603" value="47k" x="43.18" y="32.0675" smashed="yes" rot="MR90">
<attribute name="NAME" x="44.29403125" y="31.22353125" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="40.832959375" y="30.998378125" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R5" library="resistor" package="R0603" value="10k" x="48.26" y="34.29" smashed="yes" rot="MR270">
<attribute name="NAME" x="47.371" y="35.179" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="50.510640625" y="35.4602125" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="R6" library="resistor" package="R0603" value="220" x="40.64" y="23.8125" smashed="yes" rot="MR270">
<attribute name="NAME" x="41.28661875" y="27.877365625" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="41.214465625" y="22.4107125" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="R7" library="resistor" package="R0603" value="180" x="38.1" y="23.8125" smashed="yes" rot="MR270">
<attribute name="NAME" x="38.6945625" y="27.825303125" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="38.752546875" y="22.228490625" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="R8" library="resistor" package="R0603" value="1k" x="54.61" y="23.8125" smashed="yes" rot="MR270">
<attribute name="NAME" x="55.2173625" y="27.824634375" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="55.2124625" y="22.241134375" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="R9" library="resistor" package="R0603" value="1k" x="52.3875" y="23.8125" smashed="yes" rot="MR90">
<attribute name="NAME" x="51.7801375" y="25.504421875" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="51.91691875" y="20.277509375" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R10" library="pot" package="CA6H" value="5K" x="11.1125" y="38.1" rot="R90"/>
<element name="L1" library="inductors" package="BC12" value="100u" x="31.115" y="15.24" rot="R90"/>
<element name="GND" library="wirepad" package="2,54/0,8" value="" x="61.9125" y="18.7325"/>
<element name="LC" library="wirepad" package="2,54/0,8" value="" x="33.655" y="4.7625"/>
<element name="R12" library="resistor" package="R0603" value="47" x="8.5725" y="10.16" smashed="yes" rot="MR0">
<attribute name="NAME" x="10.28626875" y="11.76163125" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="9.61145625" y="7.490384375" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="D4" library="diode" package="SOD80C" value="5v1" x="12.7" y="20.32" smashed="yes" rot="MR0">
<attribute name="NAME" x="13.886596875" y="22.32565625" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="14.074040625" y="17.231878125" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="C5" library="resistor" package="C/6032-28R" value="10u" x="37.1475" y="17.4625" smashed="yes" rot="MR180">
<attribute name="NAME" x="33.4707875" y="20.765740625" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="33.00229375" y="15.514415625" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="D1" library="diode" package="SOD80C" value="PMLL4150" x="68.8975" y="22.86" smashed="yes" rot="MR180">
<attribute name="NAME" x="63.187940625" y="23.608275" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="71.919109375" y="23.336690625" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="C3" library="resistor" package="C/6032-28R" value="100u" x="69.215" y="28.575" smashed="yes" rot="MR0">
<attribute name="NAME" x="64.248934375" y="28.013390625" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="78.15579375" y="26.605728125" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="C6" library="resistor" package="C0603" value="100n" x="60.6425" y="34.6075" rot="MR90"/>
<element name="C8" library="ZOLI" package="C3" value="33n" x="24.4475" y="5.715" rot="R180"/>
<element name="C7" library="resistor" package="C/6032-28R" value="10u" x="43.18" y="21.9075" smashed="yes" rot="MR90">
<attribute name="NAME" x="43.956440625" y="26.1199125" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="42.654659375" y="14.3779875" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="EL" library="wirepad" package="2,54/0,8" value="" x="30.1625" y="4.7625"/>
<element name="D2" library="diode" package="SOD80C" value="PMLL4150" x="25.4" y="33.655" smashed="yes" rot="MR90">
<attribute name="NAME" x="27.40525625" y="32.618590625" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="22.087253125" y="28.9054125" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="S2" library="switch" package="M9040P" value="" x="14.2875" y="10.16" rot="R180"/>
<element name="S3" library="switch" package="M9040P2" value="" x="41.91" y="10.16" rot="R90"/>
<element name="S1" library="switch" package="M9040P" value="" x="69.5325" y="10.16"/>
<element name="IC1" library="linear" package="SOT223" value="UA78M05DCY" x="69.5325" y="34.6075" smashed="yes" rot="MR90">
<attribute name="NAME" x="77.7293875" y="33.14823125" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="75.142628125" y="28.690221875" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="C4" library="rcl" package="C102-043X133" value="1n" x="21.59" y="15.5575" rot="R90"/>
<element name="C9" library="rcl" package="C102-043X133" value="1n" x="26.035" y="15.5575" rot="R90"/>
<element name="GND2" library="wirepad" package="2,54/0,8" value="" x="7.9375" y="4.7625"/>
<element name="H1" library="holes" package="2,8-PAD" value="MOUNT-PAD-ROUND2.8" x="4.445" y="48.5775"/>
<element name="H2" library="holes" package="2,8-PAD" value="MOUNT-PAD-ROUND2.8" x="4.445" y="17.4625"/>
<element name="H3" library="holes" package="2,8-PAD" value="MOUNT-PAD-ROUND2.8" x="79.375" y="17.4625"/>
<element name="H4" library="holes" package="2,8-PAD" value="MOUNT-PAD-ROUND2.8" x="79.375" y="48.5775"/>
<element name="R11" library="resistor" package="M1206" value="68" x="44.45" y="43.4975" smashed="yes" rot="MR180">
<attribute name="NAME" x="43.18" y="42.2275" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="43.18" y="46.0375" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="J1" library="con-jack" package="DCJ0303" value="" x="56.515" y="6.35">
<attribute name="OC_NEWARK" value="unknown" x="56.515" y="6.35" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="56.515" y="6.35" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="56.515" y="6.35" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="56.515" y="6.35" size="1.778" layer="27" display="off"/>
</element>
<element name="9V" library="wirepad" package="2,54/0,8" value="" x="61.9125" y="14.9225"/>
<element name="C10" library="resistor" package="C/6032-28R" value="100u" x="69.5325" y="40.9575" smashed="yes" rot="MR0">
<attribute name="NAME" x="64.971490625" y="40.48595" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="71.767396875" y="43.17605625" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="C11" library="resistor" package="C0603" value="100n" x="69.215" y="25.4" smashed="yes" rot="MR0">
<attribute name="NAME" x="66.41350625" y="24.76605625" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="75.594734375" y="24.944065625" size="1.27" layer="28" rot="MR0"/>
</element>
</elements>
<signals>
<signal name="GND">
<contactref element="DISPLAY1" pad="P$1"/>
<contactref element="U1" pad="20"/>
<contactref element="C7" pad="-"/>
<contactref element="R2" pad="1"/>
<contactref element="C1" pad="1"/>
<contactref element="C2" pad="1"/>
<contactref element="K1" pad="6"/>
<contactref element="D2" pad="A"/>
<contactref element="R12" pad="2"/>
<contactref element="GND" pad="1"/>
<contactref element="D4" pad="A"/>
<contactref element="K1" pad="8"/>
<contactref element="C6" pad="1"/>
<contactref element="C3" pad="-"/>
<contactref element="DISPLAY1" pad="P$5"/>
<contactref element="R10" pad="A"/>
<contactref element="IC1" pad="2"/>
<contactref element="IC1" pad="4"/>
<contactref element="DISPLAY1" pad="P$16"/>
<contactref element="C9" pad="2"/>
<contactref element="GND2" pad="1"/>
<polygon width="0.4064" layer="16" isolate="0.8128">
<vertex x="0" y="52.705"/>
<vertex x="0" y="0"/>
<vertex x="83.82" y="0"/>
<vertex x="83.82" y="52.705"/>
</polygon>
<contactref element="S3" pad="5"/>
<contactref element="DISPLAY1" pad="P$7"/>
<contactref element="DISPLAY1" pad="P$8"/>
<contactref element="DISPLAY1" pad="P$9"/>
<contactref element="DISPLAY1" pad="P$10"/>
<contactref element="J1" pad="2"/>
<contactref element="J1" pad="3"/>
<contactref element="C11" pad="1"/>
<contactref element="C10" pad="-"/>
<wire x1="72.6315" y1="34.6075" x2="72.0575" y2="40.9575" width="0" layer="19" extent="16-16"/>
<wire x1="71.74" y1="28.575" x2="72.6315" y2="34.6075" width="0" layer="19" extent="16-16"/>
<wire x1="70.065" y1="25.4" x2="71.74" y2="28.575" width="0" layer="19" extent="16-16"/>
<wire x1="66.4337" y1="34.6075" x2="72.6315" y2="34.6075" width="0" layer="19" extent="16-16"/>
<wire x1="60.6425" y1="33.7575" x2="66.4337" y2="34.6075" width="0" layer="19" extent="16-16"/>
<wire x1="55.88" y1="29.21" x2="60.6425" y2="33.7575" width="0" layer="19" extent="16-16"/>
<wire x1="61.9125" y1="18.7325" x2="70.065" y2="25.4" width="0" layer="19" extent="16-16"/>
<wire x1="61.315" y1="6.35" x2="61.9125" y2="18.7325" width="0" layer="19" extent="1-1"/>
<wire x1="56.515" y1="3.35" x2="61.315" y2="6.35" width="0" layer="19" extent="1-1"/>
<wire x1="47.9425" y1="19.1525" x2="55.88" y2="29.21" width="0" layer="19" extent="16-16"/>
<wire x1="43.18" y1="19.3825" x2="47.9425" y2="19.1525" width="0" layer="19" extent="16-16"/>
<wire x1="41.91" y1="12.573" x2="43.18" y2="19.3825" width="0" layer="19" extent="16-16"/>
<wire x1="55.88" y1="45.935" x2="60.6425" y2="33.7575" width="0" layer="19" extent="16-16"/>
<wire x1="50.8" y1="45.935" x2="55.88" y2="45.935" width="0" layer="19" extent="16-16"/>
<wire x1="48.26" y1="48.26" x2="50.8" y2="45.935" width="0" layer="19" extent="16-16"/>
<wire x1="33.02" y1="48.26" x2="48.26" y2="48.26" width="0" layer="19" extent="1-1"/>
<wire x1="30.48" y1="48.26" x2="33.02" y2="48.26" width="0" layer="19" extent="1-1"/>
<wire x1="27.94" y1="48.26" x2="30.48" y2="48.26" width="0" layer="19" extent="1-1"/>
<wire x1="25.4" y1="48.26" x2="27.94" y2="48.26" width="0" layer="19" extent="1-1"/>
<wire x1="20.32" y1="48.26" x2="25.4" y2="48.26" width="0" layer="19" extent="1-1"/>
<wire x1="17.78" y1="40.9575" x2="20.32" y2="48.26" width="0" layer="19" extent="1-1"/>
<wire x1="25.4" y1="38.4175" x2="17.78" y2="40.9575" width="0" layer="19" extent="1-1"/>
<wire x1="25.4" y1="35.355" x2="25.4" y2="38.4175" width="0" layer="19" extent="16-16"/>
<wire x1="11.1125" y1="35.56" x2="17.78" y2="40.9575" width="0" layer="19" extent="1-1"/>
<wire x1="10.16" y1="48.26" x2="20.32" y2="48.26" width="0" layer="19" extent="1-1"/>
<wire x1="26.035" y1="20.6375" x2="25.4" y2="35.355" width="0" layer="19" extent="16-16"/>
<wire x1="11" y1="20.32" x2="26.035" y2="20.6375" width="0" layer="19" extent="16-16"/>
<wire x1="7.7225" y1="10.16" x2="11" y2="20.32" width="0" layer="19" extent="16-16"/>
<wire x1="7.9375" y1="4.7625" x2="7.7225" y2="10.16" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$1">
<contactref element="Q1" pad="2"/>
<contactref element="U1" pad="3"/>
<contactref element="C1" pad="2"/>
<wire x1="50.8" y1="41.91" x2="50.8" y2="44.235" width="0" layer="19" extent="16-16"/>
<wire x1="50.8" y1="36.83" x2="50.8" y2="41.91" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$2">
<contactref element="Q1" pad="1"/>
<contactref element="U1" pad="2"/>
<contactref element="C2" pad="2"/>
<wire x1="55.88" y1="41.91" x2="55.88" y2="44.235" width="0" layer="19" extent="16-16"/>
<wire x1="53.34" y1="36.83" x2="55.88" y2="41.91" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$14">
<contactref element="K1" pad="2"/>
<contactref element="U1" pad="12"/>
<contactref element="D2" pad="C"/>
<wire x1="25.4" y1="28.2575" x2="35.56" y2="29.21" width="0" layer="19" extent="1-1"/>
<wire x1="25.4" y1="31.955" x2="25.4" y2="28.2575" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$3">
<contactref element="R3" pad="1"/>
<contactref element="U1" pad="6"/>
<contactref element="U1" pad="17"/>
<contactref element="R4" pad="2"/>
<wire x1="43.18" y1="32.9175" x2="43.18" y2="36.83" width="0" layer="19" extent="16-16"/>
<wire x1="48.26" y1="29.21" x2="43.18" y2="32.9175" width="0" layer="19" extent="16-16"/>
<wire x1="47.9425" y1="24.6625" x2="48.26" y2="29.21" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$13">
<contactref element="R2" pad="2"/>
<contactref element="R3" pad="2"/>
<contactref element="U1" pad="16"/>
<contactref element="R1" pad="1"/>
<contactref element="C5" pad="+"/>
<wire x1="47.9425" y1="22.9625" x2="45.72" y2="29.21" width="0" layer="19" extent="16-16"/>
<wire x1="47.9425" y1="20.8525" x2="47.9425" y2="22.9625" width="0" layer="19" extent="16-16"/>
<wire x1="50.165" y1="22.9625" x2="47.9425" y2="22.9625" width="0" layer="19" extent="16-16"/>
<wire x1="39.6725" y1="17.4625" x2="47.9425" y2="20.8525" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$21">
<contactref element="L1" pad="1"/>
<contactref element="C5" pad="-"/>
<contactref element="C8" pad="P$2"/>
<contactref element="C4" pad="1"/>
<contactref element="C9" pad="1"/>
<contactref element="S3" pad="1"/>
<wire x1="31.115" y1="8.89" x2="34.6225" y2="17.4625" width="0" layer="19" extent="16-16"/>
<wire x1="26.9875" y1="5.715" x2="31.115" y2="8.89" width="0" layer="19" extent="1-1"/>
<wire x1="26.035" y1="10.4775" x2="26.9875" y2="5.715" width="0" layer="19" extent="1-1"/>
<wire x1="21.59" y1="10.4775" x2="26.035" y2="10.4775" width="0" layer="19" extent="1-1"/>
<wire x1="37.211" y1="7.747" x2="31.115" y2="8.89" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$26">
<contactref element="U1" pad="14"/>
<contactref element="R6" pad="1"/>
<wire x1="40.64" y1="24.6625" x2="40.64" y2="29.21" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$27">
<contactref element="R6" pad="2"/>
<contactref element="D4" pad="C"/>
<contactref element="C8" pad="P$1"/>
<contactref element="EL" pad="1"/>
<contactref element="S2" pad="3"/>
<contactref element="R7" pad="2"/>
<wire x1="38.1" y1="22.9625" x2="40.64" y2="22.9625" width="0" layer="19" extent="16-16"/>
<wire x1="30.1625" y1="4.7625" x2="38.1" y2="22.9625" width="0" layer="19" extent="16-16"/>
<wire x1="21.9075" y1="5.715" x2="30.1625" y2="4.7625" width="0" layer="19" extent="1-1"/>
<wire x1="14.2875" y1="14.859" x2="21.9075" y2="5.715" width="0" layer="19" extent="1-1"/>
<wire x1="14.4" y1="20.32" x2="14.2875" y2="14.859" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$28">
<contactref element="U1" pad="13"/>
<contactref element="R7" pad="1"/>
<wire x1="38.1" y1="24.6625" x2="38.1" y2="29.21" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$32">
<contactref element="R5" pad="1"/>
<contactref element="U1" pad="4"/>
<wire x1="48.26" y1="35.14" x2="48.26" y2="36.83" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="D7">
<contactref element="U1" pad="5"/>
<contactref element="DISPLAY1" pad="P$14"/>
<wire x1="45.72" y1="36.83" x2="43.18" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="D6">
<contactref element="U1" pad="7"/>
<contactref element="DISPLAY1" pad="P$13"/>
<wire x1="40.64" y1="36.83" x2="40.64" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="D5">
<contactref element="U1" pad="8"/>
<contactref element="DISPLAY1" pad="P$12"/>
<wire x1="38.1" y1="36.83" x2="38.1" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="RS">
<contactref element="U1" pad="11"/>
<contactref element="DISPLAY1" pad="P$4"/>
<wire x1="33.02" y1="29.21" x2="17.78" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$6">
<contactref element="U1" pad="15"/>
<contactref element="R4" pad="1"/>
<contactref element="C7" pad="+"/>
<wire x1="43.18" y1="29.21" x2="43.18" y2="31.2175" width="0" layer="19" extent="16-16"/>
<wire x1="43.18" y1="24.4325" x2="43.18" y2="29.21" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="+5V">
<contactref element="C6" pad="2"/>
<contactref element="R1" pad="2"/>
<contactref element="U1" pad="1"/>
<contactref element="R5" pad="2"/>
<contactref element="R10" pad="E"/>
<contactref element="DISPLAY1" pad="P$2"/>
<contactref element="IC1" pad="3"/>
<contactref element="R11" pad="1"/>
<contactref element="C10" pad="+"/>
<wire x1="66.4337" y1="36.9189" x2="67.0075" y2="40.9575" width="0" layer="19" extent="16-16"/>
<wire x1="60.6425" y1="35.4575" x2="66.4337" y2="36.9189" width="0" layer="19" extent="16-16"/>
<wire x1="55.88" y1="36.83" x2="60.6425" y2="35.4575" width="0" layer="19" extent="16-16"/>
<wire x1="48.26" y1="33.44" x2="55.88" y2="36.83" width="0" layer="19" extent="16-16"/>
<wire x1="50.165" y1="24.6625" x2="48.26" y2="33.44" width="0" layer="19" extent="16-16"/>
<wire x1="43.05" y1="43.4975" x2="48.26" y2="33.44" width="0" layer="19" extent="16-16"/>
<wire x1="12.7" y1="48.26" x2="43.05" y2="43.4975" width="0" layer="19" extent="16-16"/>
<wire x1="11.1125" y1="40.64" x2="12.7" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$7">
<contactref element="U1" pad="18"/>
<contactref element="R9" pad="2"/>
<wire x1="52.3875" y1="24.6625" x2="50.8" y2="29.21" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$8">
<contactref element="R8" pad="1"/>
<contactref element="U1" pad="19"/>
<wire x1="54.61" y1="24.6625" x2="53.34" y2="29.21" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$5">
<contactref element="D1" pad="C"/>
<contactref element="C3" pad="+"/>
<contactref element="IC1" pad="1"/>
<contactref element="C11" pad="2"/>
<wire x1="66.69" y1="28.575" x2="66.4337" y2="32.2961" width="0" layer="19" extent="16-16"/>
<wire x1="68.365" y1="25.4" x2="66.69" y2="28.575" width="0" layer="19" extent="16-16"/>
<wire x1="67.1975" y1="22.86" x2="68.365" y2="25.4" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$17">
<contactref element="R12" pad="1"/>
<contactref element="S2" pad="2"/>
<wire x1="9.4225" y1="10.16" x2="14.2875" y2="10.16" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$18">
<contactref element="S2" pad="1"/>
<contactref element="R8" pad="2"/>
<wire x1="14.2875" y1="5.461" x2="54.61" y2="22.9625" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$20">
<contactref element="S1" pad="2"/>
<contactref element="D1" pad="A"/>
<wire x1="69.5325" y1="10.16" x2="70.5975" y2="22.86" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$11">
<contactref element="L1" pad="2"/>
<contactref element="S3" pad="4"/>
<contactref element="S3" pad="3"/>
<wire x1="37.211" y1="12.573" x2="46.609" y2="7.747" width="0" layer="19" extent="1-1"/>
<wire x1="31.115" y1="21.59" x2="37.211" y2="12.573" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$19">
<contactref element="R9" pad="1"/>
<contactref element="S3" pad="6"/>
<wire x1="46.609" y1="12.573" x2="52.3875" y2="22.9625" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="D4">
<contactref element="U1" pad="9"/>
<contactref element="DISPLAY1" pad="P$11"/>
<wire x1="35.56" y1="36.83" x2="35.56" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="E">
<contactref element="U1" pad="10"/>
<contactref element="DISPLAY1" pad="P$6"/>
<wire x1="33.02" y1="36.83" x2="22.86" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$15">
<contactref element="R10" pad="S"/>
<contactref element="DISPLAY1" pad="P$3"/>
<wire x1="8.5725" y1="38.1" x2="15.24" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$4">
<contactref element="K1" pad="14"/>
<contactref element="C4" pad="2"/>
<wire x1="21.59" y1="20.6375" x2="17.78" y2="25.7175" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$12">
<contactref element="H3" pad="B2,8"/>
</signal>
<signal name="N$9">
<contactref element="R11" pad="2"/>
<contactref element="DISPLAY1" pad="P$15"/>
<wire x1="45.85" y1="43.4975" x2="45.72" y2="48.26" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$16">
<contactref element="LC" pad="1"/>
<contactref element="S3" pad="2"/>
<wire x1="33.655" y1="4.7625" x2="41.91" y2="7.747" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$23">
<via x="19.685" y="5.715" extent="1-16" drill="1" diameter="1.9304"/>
</signal>
<signal name="N$24">
<via x="21.59" y="13.335" extent="1-16" drill="1" diameter="1.9304"/>
</signal>
<signal name="N$25">
<via x="26.035" y="13.335" extent="1-16" drill="1" diameter="1.9304"/>
</signal>
<signal name="N$10">
<contactref element="S1" pad="3"/>
<contactref element="J1" pad="1"/>
<wire x1="56.515" y1="9.45" x2="69.5325" y2="5.461" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$22">
<contactref element="S1" pad="1"/>
<contactref element="9V" pad="1"/>
<wire x1="61.9125" y1="14.9225" x2="69.5325" y2="14.859" width="0" layer="19" extent="1-1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
