<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="1.16" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="1" altunitdist="mm" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="-2.32" y1="64.96" x2="4.64" y2="80.04" width="0.4064" layer="17"/>
<wire x1="0" y1="64.96" x2="10.44" y2="80.04" width="0.4064" layer="17"/>
<wire x1="3.48" y1="64.96" x2="16.24" y2="80.04" width="0.4064" layer="17"/>
<wire x1="5.8" y1="64.96" x2="22.04" y2="80.04" width="0.4064" layer="17"/>
<wire x1="8.12" y1="64.96" x2="27.84" y2="80.04" width="0.4064" layer="17"/>
<wire x1="10.44" y1="64.96" x2="33.64" y2="80.04" width="0.4064" layer="17"/>
<wire x1="13.92" y1="64.96" x2="39.44" y2="78.88" width="0.4064" layer="17"/>
<wire x1="71.92" y1="64.96" x2="51.04" y2="80.04" width="0.4064" layer="17"/>
<wire x1="74.24" y1="64.96" x2="56.84" y2="80.04" width="0.4064" layer="17"/>
<wire x1="77.72" y1="64.96" x2="62.64" y2="80.04" width="0.4064" layer="17"/>
<wire x1="80.04" y1="64.96" x2="68.44" y2="80.04" width="0.4064" layer="17"/>
<wire x1="82.36" y1="64.96" x2="74.24" y2="80.04" width="0.4064" layer="17"/>
<wire x1="84.68" y1="63.8" x2="80.04" y2="80.04" width="0.4064" layer="17"/>
<wire x1="80.04" y1="59.16" x2="92.8" y2="59.16" width="0.4064" layer="17"/>
<wire x1="92.8" y1="59.16" x2="96.28" y2="59.16" width="0.4064" layer="17"/>
<wire x1="92.8" y1="59.16" x2="92.8" y2="56.84" width="0.4064" layer="17"/>
<wire x1="70.76" y1="61.48" x2="77.72" y2="61.48" width="0.4064" layer="17"/>
<wire x1="77.72" y1="61.48" x2="77.72" y2="56.84" width="0.4064" layer="17"/>
<wire x1="70.76" y1="61.48" x2="70.76" y2="63.8" width="0.4064" layer="17"/>
<wire x1="70.76" y1="63.8" x2="52.2" y2="77.72" width="0.4064" layer="17"/>
<wire x1="44.08" y1="77.72" x2="16.24" y2="61.48" width="0.4064" layer="17"/>
<wire x1="44.08" y1="77.72" x2="52.2" y2="77.72" width="0.4064" layer="17"/>
<wire x1="69.6" y1="59.16" x2="69.6" y2="62.64" width="0.4064" layer="17"/>
<wire x1="34.8" y1="64.96" x2="37.12" y2="64.96" width="0.4064" layer="17"/>
<wire x1="37.12" y1="64.96" x2="37.12" y2="67.28" width="0.4064" layer="17"/>
<wire x1="37.12" y1="67.28" x2="37.12" y2="69.6" width="0.4064" layer="17"/>
<wire x1="37.12" y1="67.28" x2="45.24" y2="67.28" width="0.4064" layer="17"/>
<wire x1="49.88" y1="71.92" x2="52.2" y2="68.44" width="0.4064" layer="17"/>
<wire x1="52.2" y1="71.92" x2="54.52" y2="71.92" width="0.4064" layer="17"/>
<wire x1="54.52" y1="71.92" x2="54.52" y2="60.32" width="0.4064" layer="17"/>
<wire x1="54.52" y1="60.32" x2="53.36" y2="60.32" width="0.4064" layer="17"/>
<wire x1="25.52" y1="52.2" x2="34.8" y2="52.2" width="0.4064" layer="17"/>
<wire x1="34.8" y1="52.2" x2="44.08" y2="62.64" width="0.4064" layer="17"/>
<wire x1="44.08" y1="62.64" x2="48.72" y2="62.64" width="0.4064" layer="17"/>
<wire x1="48.72" y1="62.64" x2="49.88" y2="66.12" width="0.4064" layer="17"/>
<wire x1="49.88" y1="60.32" x2="52.2" y2="67.28" width="0.4064" layer="17"/>
<wire x1="47.56" y1="67.28" x2="46.4" y2="63.8" width="0.4064" layer="17"/>
<wire x1="46.4" y1="63.8" x2="42.92" y2="63.8" width="0.4064" layer="17"/>
<wire x1="42.92" y1="63.8" x2="34.8" y2="54.52" width="0.4064" layer="17"/>
<wire x1="34.8" y1="54.52" x2="22.04" y2="54.52" width="0.4064" layer="17"/>
<wire x1="22.04" y1="54.52" x2="22.04" y2="52.2" width="0.4064" layer="17"/>
<wire x1="22.04" y1="52.2" x2="25.52" y2="45.24" width="0.4064" layer="17"/>
<wire x1="22.04" y1="44.08" x2="22.04" y2="42.92" width="0.4064" layer="17"/>
<wire x1="22.04" y1="41.76" x2="22.04" y2="42.92" width="0.4064" layer="17"/>
<wire x1="22.04" y1="42.92" x2="30.16" y2="42.92" width="0.4064" layer="17"/>
<wire x1="30.16" y1="42.92" x2="30.16" y2="44.08" width="0.4064" layer="17"/>
<wire x1="34.8" y1="45.24" x2="39.44" y2="45.24" width="0.4064" layer="17"/>
<wire x1="39.44" y1="45.24" x2="39.44" y2="47.56" width="0.4064" layer="17"/>
<wire x1="39.44" y1="49.88" x2="39.44" y2="52.2" width="0.4064" layer="17"/>
<wire x1="39.44" y1="52.2" x2="45.24" y2="52.2" width="0.4064" layer="17"/>
<wire x1="45.24" y1="53.36" x2="45.24" y2="59.16" width="0.4064" layer="17"/>
<wire x1="47.56" y1="44.08" x2="54.52" y2="44.08" width="0.4064" layer="17"/>
<wire x1="58" y1="44.08" x2="62.64" y2="44.08" width="0.4064" layer="17"/>
<wire x1="62.64" y1="44.08" x2="62.64" y2="47.56" width="0.4064" layer="17"/>
<wire x1="58" y1="52.2" x2="54.52" y2="52.2" width="0.4064" layer="17"/>
<wire x1="54.52" y1="52.2" x2="47.56" y2="59.16" width="0.4064" layer="17"/>
<wire x1="49.88" y1="59.16" x2="49.88" y2="60.32" width="0.4064" layer="17"/>
<wire x1="84.68" y1="56.84" x2="87" y2="56.84" width="0.4064" layer="17"/>
<wire x1="87" y1="56.84" x2="88.16" y2="52.2" width="0.4064" layer="17"/>
<wire x1="81.2" y1="52.2" x2="82.36" y2="52.2" width="0.4064" layer="17"/>
<wire x1="82.36" y1="52.2" x2="84.68" y2="52.2" width="0.4064" layer="17"/>
<wire x1="82.36" y1="55.68" x2="82.36" y2="52.2" width="0.4064" layer="17"/>
<wire x1="84.68" y1="44.08" x2="85.84" y2="44.08" width="0.4064" layer="17"/>
<wire x1="85.84" y1="44.08" x2="88.16" y2="44.08" width="0.4064" layer="17"/>
<wire x1="74.24" y1="55.68" x2="74.24" y2="54.52" width="0.4064" layer="17"/>
<wire x1="74.24" y1="54.52" x2="74.24" y2="53.36" width="0.4064" layer="17"/>
<wire x1="74.24" y1="53.36" x2="76.56" y2="53.36" width="0.4064" layer="17"/>
<wire x1="76.56" y1="53.36" x2="78.88" y2="53.36" width="0.4064" layer="17"/>
<wire x1="78.88" y1="53.36" x2="80.04" y2="55.68" width="0.4064" layer="17"/>
<wire x1="76.56" y1="53.36" x2="76.56" y2="48.72" width="0.4064" layer="17"/>
<wire x1="76.56" y1="48.72" x2="76.56" y2="39.44" width="0.4064" layer="17"/>
<wire x1="76.56" y1="48.72" x2="85.84" y2="48.72" width="0.4064" layer="17"/>
<wire x1="85.84" y1="48.72" x2="90.48" y2="48.72" width="0.4064" layer="17"/>
<wire x1="90.48" y1="48.72" x2="90.48" y2="55.68" width="0.4064" layer="17"/>
<wire x1="85.84" y1="48.72" x2="85.84" y2="44.08" width="0.4064" layer="17"/>
<wire x1="54.52" y1="60.32" x2="64.96" y2="60.32" width="0.4064" layer="17"/>
<wire x1="74.24" y1="54.52" x2="61.48" y2="54.52" width="0.4064" layer="17"/>
<wire x1="61.48" y1="54.52" x2="54.52" y2="54.52" width="0.4064" layer="17"/>
<wire x1="54.52" y1="54.52" x2="49.88" y2="59.16" width="0.4064" layer="17"/>
<wire x1="39.44" y1="69.6" x2="40.6" y2="71.92" width="0.4064" layer="17"/>
<wire x1="40.6" y1="71.92" x2="49.88" y2="71.92" width="0.4064" layer="17"/>
<wire x1="12.76" y1="49.88" x2="12.76" y2="55.68" width="0.4064" layer="17"/>
<wire x1="3.48" y1="55.68" x2="3.48" y2="49.88" width="0.4064" layer="17"/>
<wire x1="42.92" y1="39.44" x2="42.92" y2="48.72" width="0.4064" layer="17"/>
<wire x1="42.92" y1="48.72" x2="59.16" y2="48.72" width="0.4064" layer="17"/>
<wire x1="59.16" y1="48.72" x2="61.48" y2="54.52" width="0.4064" layer="17"/>
<wire x1="62.64" y1="49.88" x2="66.12" y2="49.88" width="0.4064" layer="17"/>
<wire x1="66.12" y1="49.88" x2="66.12" y2="39.44" width="0.4064" layer="17"/>
<wire x1="66.12" y1="39.44" x2="52.2" y2="39.44" width="0.4064" layer="17"/>
<wire x1="19.72" y1="49.88" x2="19.72" y2="40.6" width="0.4064" layer="17"/>
<wire x1="19.72" y1="40.6" x2="20.88" y2="39.44" width="0.4064" layer="17" curve="90"/>
<wire x1="20.88" y1="39.44" x2="42.92" y2="39.44" width="0.4064" layer="17"/>
<wire x1="81.2" y1="45.24" x2="78.88" y2="45.24" width="0.4064" layer="17"/>
<wire x1="78.88" y1="45.24" x2="78.88" y2="37.12" width="0.4064" layer="17"/>
<wire x1="78.88" y1="37.12" x2="15.08" y2="37.12" width="0.4064" layer="17"/>
<wire x1="15.08" y1="37.12" x2="15.08" y2="41.76" width="0.4064" layer="17"/>
<wire x1="15.08" y1="41.76" x2="5.8" y2="41.76" width="0.4064" layer="17"/>
<wire x1="5.8" y1="47.56" x2="5.8" y2="41.76" width="0.4064" layer="17"/>
<wire x1="-3.48" y1="49.88" x2="-2.32" y2="49.88" width="0.4064" layer="17"/>
<wire x1="-2.32" y1="49.88" x2="3.48" y2="49.88" width="0.4064" layer="17"/>
<wire x1="3.48" y1="49.88" x2="9.28" y2="49.88" width="0.4064" layer="17"/>
<wire x1="9.28" y1="49.88" x2="12.76" y2="49.88" width="0.4064" layer="17"/>
<wire x1="12.76" y1="49.88" x2="19.72" y2="49.88" width="0.4064" layer="17"/>
<wire x1="9.28" y1="45.24" x2="9.28" y2="49.88" width="0.4064" layer="17"/>
<wire x1="8.12" y1="55.68" x2="8.12" y2="56.84" width="0.4064" layer="17"/>
<wire x1="8.12" y1="56.84" x2="9.28" y2="56.84" width="0.4064" layer="17"/>
<wire x1="9.28" y1="56.84" x2="10.44" y2="56.84" width="0.4064" layer="17"/>
<wire x1="9.28" y1="52.2" x2="9.28" y2="56.84" width="0.4064" layer="17"/>
<wire x1="5.8" y1="52.2" x2="5.8" y2="56.84" width="0.4064" layer="17"/>
<wire x1="-9.28" y1="81.2" x2="-9.28" y2="82.36" width="0.4064" layer="17"/>
<wire x1="-9.28" y1="82.36" x2="-3.48" y2="82.36" width="0.4064" layer="17"/>
<wire x1="-3.48" y1="82.36" x2="2.32" y2="82.36" width="0.4064" layer="17"/>
<wire x1="2.32" y1="82.36" x2="8.12" y2="82.36" width="0.4064" layer="17"/>
<wire x1="8.12" y1="82.36" x2="13.92" y2="82.36" width="0.4064" layer="17"/>
<wire x1="13.92" y1="82.36" x2="19.72" y2="82.36" width="0.4064" layer="17"/>
<wire x1="19.72" y1="82.36" x2="25.52" y2="82.36" width="0.4064" layer="17"/>
<wire x1="25.52" y1="82.36" x2="31.32" y2="82.36" width="0.4064" layer="17"/>
<wire x1="31.32" y1="82.36" x2="37.12" y2="82.36" width="0.4064" layer="17"/>
<wire x1="37.12" y1="82.36" x2="42.92" y2="82.36" width="0.4064" layer="17"/>
<wire x1="42.92" y1="82.36" x2="48.72" y2="82.36" width="0.4064" layer="17"/>
<wire x1="48.72" y1="82.36" x2="54.52" y2="82.36" width="0.4064" layer="17"/>
<wire x1="54.52" y1="82.36" x2="60.32" y2="82.36" width="0.4064" layer="17"/>
<wire x1="60.32" y1="82.36" x2="66.12" y2="82.36" width="0.4064" layer="17"/>
<wire x1="66.12" y1="82.36" x2="71.92" y2="82.36" width="0.4064" layer="17"/>
<wire x1="71.92" y1="82.36" x2="77.72" y2="82.36" width="0.4064" layer="17"/>
<wire x1="77.72" y1="82.36" x2="83.52" y2="82.36" width="0.4064" layer="17"/>
<wire x1="83.52" y1="82.36" x2="89.32" y2="82.36" width="0.4064" layer="17"/>
<wire x1="89.32" y1="82.36" x2="95.12" y2="82.36" width="0.4064" layer="17"/>
<wire x1="-3.48" y1="82.36" x2="-3.48" y2="80.04" width="0.4064" layer="17"/>
<wire x1="2.32" y1="82.36" x2="2.32" y2="81.2" width="0.4064" layer="17"/>
<wire x1="8.12" y1="82.36" x2="8.12" y2="80.04" width="0.4064" layer="17"/>
<wire x1="13.92" y1="82.36" x2="13.92" y2="81.2" width="0.4064" layer="17"/>
<wire x1="19.72" y1="82.36" x2="19.72" y2="80.04" width="0.4064" layer="17"/>
<wire x1="25.52" y1="82.36" x2="25.52" y2="80.04" width="0.4064" layer="17"/>
<wire x1="31.32" y1="82.36" x2="31.32" y2="80.04" width="0.4064" layer="17"/>
<wire x1="37.12" y1="82.36" x2="37.12" y2="80.04" width="0.4064" layer="17"/>
<wire x1="42.92" y1="82.36" x2="42.92" y2="80.04" width="0.4064" layer="17"/>
<wire x1="48.72" y1="82.36" x2="48.72" y2="80.04" width="0.4064" layer="17"/>
<wire x1="54.52" y1="82.36" x2="54.52" y2="80.04" width="0.4064" layer="17"/>
<wire x1="60.32" y1="82.36" x2="60.32" y2="81.2" width="0.4064" layer="17"/>
<wire x1="66.12" y1="82.36" x2="66.12" y2="81.2" width="0.4064" layer="17"/>
<wire x1="71.92" y1="82.36" x2="71.92" y2="81.2" width="0.4064" layer="17"/>
<wire x1="77.72" y1="82.36" x2="77.72" y2="80.04" width="0.4064" layer="17"/>
<wire x1="83.52" y1="82.36" x2="83.52" y2="80.04" width="0.4064" layer="17"/>
<wire x1="89.32" y1="82.36" x2="89.32" y2="80.04" width="0.4064" layer="17"/>
<wire x1="95.12" y1="82.36" x2="95.12" y2="81.2" width="0.4064" layer="17"/>
<wire x1="95.12" y1="82.36" x2="99.76" y2="82.36" width="0.4064" layer="17"/>
<wire x1="-2.32" y1="55.68" x2="-2.32" y2="49.88" width="0.4064" layer="17"/>
<wire x1="42.92" y1="39.44" x2="47.56" y2="39.44" width="0.4064" layer="17"/>
<text x="71.92" y="39.44" size="1.4224" layer="25">-</text>
<wire x1="0" y1="56.84" x2="0" y2="61.48" width="0.4064" layer="17"/>
<wire x1="0" y1="61.48" x2="16.24" y2="61.48" width="0.4064" layer="17"/>
<text x="0" y="46.4" size="1.778" layer="23" rot="R90">1u</text>
<text x="10.44" y="46.4" size="1.778" layer="23" rot="R90">1K</text>
<text x="16.24" y="40.6" size="1.778" layer="23">1K</text>
<text x="82.36" y="46.4" size="1.778" layer="23" rot="R90">330K</text>
<text x="85.84" y="46.4" size="1.778" layer="23" rot="R90">62K</text>
<text x="89.32" y="47.56" size="1.778" layer="23" rot="R90">1K</text>
<text x="55.68" y="46.4" size="1.778" layer="23" rot="R90">10K</text>
<text x="59.16" y="46.4" size="1.778" layer="23" rot="R90">10K</text>
<text x="31.32" y="46.4" size="1.778" layer="23" rot="R90">10K</text>
<text x="35.96" y="46.4" size="1.778" layer="23" rot="R90">10K</text>
<text x="17.4" y="53.36" size="1.778" layer="23">2x1N4148</text>
<text x="41.76" y="44.08" size="1.778" layer="23" rot="R90">10u</text>
<text x="66.12" y="45.24" size="1.778" layer="23" rot="R90">10u</text>
<text x="27.84" y="60.32" size="1.778" layer="23">100u/16v</text>
<text x="38.28" y="70.76" size="1.778" layer="23">100n</text>
<text x="49.88" y="73.08" size="1.778" layer="23">100n</text>
<text x="95.12" y="55.68" size="1.778" layer="23">Dot/Bar</text>
<text x="46.4" y="46.4" size="1.778" layer="23">47K</text>
<wire x1="69.6" y1="59.16" x2="75.4" y2="59.16" width="0.4064" layer="17"/>
<wire x1="71.92" y1="39.44" x2="71.92" y2="42.92" width="0.4064" layer="17"/>
<wire x1="71.92" y1="42.92" x2="68.44" y2="42.92" width="0.4064" layer="17"/>
<wire x1="68.44" y1="42.92" x2="68.44" y2="51.04" width="0.4064" layer="17"/>
<wire x1="68.44" y1="58" x2="64.96" y2="60.32" width="0.4064" layer="17"/>
<wire x1="99.76" y1="61.48" x2="97.44" y2="61.48" width="0.4064" layer="17"/>
<wire x1="95.12" y1="61.48" x2="77.72" y2="61.48" width="0.4064" layer="17"/>
<wire x1="-3.48" y1="47.56" x2="-3.48" y2="45.24" width="0.4064" layer="17"/>
<wire x1="-3.48" y1="45.24" x2="-2.32" y2="45.24" width="0.4064" layer="17"/>
<wire x1="-2.32" y1="45.24" x2="1.16" y2="41.76" width="0.4064" layer="17" curve="-90"/>
<wire x1="1.16" y1="41.76" x2="5.8" y2="41.76" width="0.4064" layer="17"/>
<wire x1="82.36" y1="39.44" x2="89.32" y2="39.44" width="0.4064" layer="17"/>
<wire x1="89.32" y1="39.44" x2="89.32" y2="40.6" width="0.4064" layer="17"/>
<wire x1="89.32" y1="40.6" x2="93.96" y2="45.24" width="0.4064" layer="17" curve="-90"/>
<wire x1="93.96" y1="45.24" x2="99.76" y2="45.24" width="0.4064" layer="17"/>
<wire x1="99.76" y1="45.24" x2="99.76" y2="82.36" width="0.4064" layer="17"/>
<wire x1="-4.64" y1="64.96" x2="-4.64" y2="68.44" width="0.4064" layer="17"/>
<wire x1="-4.64" y1="68.44" x2="-5.8" y2="68.44" width="0.4064" layer="17"/>
<wire x1="-5.8" y1="68.44" x2="-8.12" y2="70.76" width="0.4064" layer="17"/>
<wire x1="-8.12" y1="70.76" x2="-8.12" y2="75.4" width="0.4064" layer="17"/>
<wire x1="-8.12" y1="75.4" x2="-5.8" y2="77.72" width="0.4064" layer="17"/>
<wire x1="-5.8" y1="77.72" x2="-1.16" y2="77.72" width="0.4064" layer="17"/>
<wire x1="-1.16" y1="77.72" x2="-1.16" y2="80.04" width="0.4064" layer="17"/>
<wire x1="-6.96" y1="80.04" x2="-9.28" y2="77.72" width="0.4064" layer="17"/>
<wire x1="-9.28" y1="77.72" x2="-9.28" y2="56.84" width="0.4064" layer="17"/>
<wire x1="-9.28" y1="56.84" x2="-4.64" y2="56.84" width="0.4064" layer="17"/>
<wire x1="87" y1="64.96" x2="84.68" y2="75.4" width="0.4064" layer="17"/>
<wire x1="84.68" y1="75.4" x2="85.84" y2="80.04" width="0.4064" layer="17"/>
<wire x1="89.32" y1="64.96" x2="87" y2="75.4" width="0.4064" layer="17"/>
<wire x1="87" y1="75.4" x2="91.64" y2="80.04" width="0.4064" layer="17"/>
<wire x1="97.44" y1="80.04" x2="97.44" y2="77.72" width="0.4064" layer="17"/>
<wire x1="97.44" y1="77.72" x2="91.64" y2="77.72" width="0.4064" layer="17"/>
<wire x1="91.64" y1="77.72" x2="89.32" y2="75.4" width="0.4064" layer="17"/>
<wire x1="89.32" y1="75.4" x2="89.32" y2="70.76" width="0.4064" layer="17"/>
<wire x1="89.32" y1="70.76" x2="92.8" y2="67.28" width="0.4064" layer="17"/>
<wire x1="92.8" y1="67.28" x2="92.8" y2="64.96" width="0.4064" layer="17"/>
<text x="93.96" y="63.8" size="1.778" layer="23">Jumper</text>
<wire x1="16.24" y1="63.8" x2="41.76" y2="77.72" width="0.4064" layer="18"/>
<wire x1="41.76" y1="77.72" x2="45.24" y2="80.04" width="0.4064" layer="18"/>
<wire x1="19.72" y1="49.88" x2="19.72" y2="55.68" width="0.4064" layer="18"/>
<wire x1="19.72" y1="55.68" x2="29" y2="55.68" width="0.4064" layer="18"/>
<wire x1="29" y1="55.68" x2="32.48" y2="64.96" width="0.4064" layer="18"/>
<wire x1="26.68" y1="66.12" x2="42.92" y2="75.4" width="0.4064" layer="18"/>
<wire x1="42.92" y1="75.4" x2="52.2" y2="75.4" width="0.4064" layer="18"/>
<wire x1="52.2" y1="75.4" x2="69.6" y2="62.64" width="0.4064" layer="18"/>
<wire x1="16.24" y1="56.84" x2="22.04" y2="56.84" width="0.4064" layer="18"/>
<wire x1="22.04" y1="56.84" x2="22.04" y2="62.64" width="0.4064" layer="18"/>
<wire x1="22.04" y1="62.64" x2="26.68" y2="66.12" width="0.4064" layer="18"/>
<wire x1="16.24" y1="61.48" x2="18.56" y2="59.16" width="0.4064" layer="18"/>
<wire x1="25.52" y1="59.16" x2="25.52" y2="62.64" width="0.4064" layer="18"/>
<wire x1="25.52" y1="62.64" x2="32.48" y2="67.28" width="0.4064" layer="18"/>
<wire x1="32.48" y1="67.28" x2="37.12" y2="67.28" width="0.4064" layer="18"/>
<text x="-5.8" y="84.68" size="1.778" layer="18" rot="R180">-40db</text>
<text x="-1.16" y="84.68" size="1.778" layer="18" rot="R180">-37</text>
<text x="4.64" y="84.68" size="1.778" layer="18" rot="R180">-34</text>
<text x="10.44" y="84.68" size="1.778" layer="18" rot="R180">-31</text>
<text x="16.24" y="84.68" size="1.778" layer="18" rot="R180">-28</text>
<text x="22.04" y="84.68" size="1.778" layer="18" rot="R180">-25</text>
<text x="27.84" y="84.68" size="1.778" layer="18" rot="R180">-22</text>
<text x="33.64" y="84.68" size="1.778" layer="18" rot="R180">-19</text>
<text x="39.44" y="84.68" size="1.778" layer="18" rot="R180">-16</text>
<text x="45.24" y="84.68" size="1.778" layer="18" rot="R180">-13</text>
<text x="51.04" y="84.68" size="1.778" layer="19" rot="R180">-10</text>
<text x="56.84" y="84.68" size="1.778" layer="19" rot="R180">-7</text>
<text x="62.64" y="84.68" size="1.778" layer="19" rot="R180">-5</text>
<text x="68.44" y="84.68" size="1.778" layer="19" rot="R180">-3</text>
<text x="74.24" y="84.68" size="1.778" layer="19" rot="R180">-1</text>
<text x="80.04" y="84.68" size="1.778" layer="19" rot="R180">0</text>
<text x="85.84" y="84.68" size="1.778" layer="1" rot="R180">+1</text>
<text x="91.64" y="84.68" size="1.778" layer="1" rot="R180">+2</text>
<text x="99.76" y="84.68" size="1.778" layer="1" rot="R180">+3db</text>
<text x="82.36" y="60.32" size="1.778" layer="23">LM3916</text>
<text x="5.8" y="60.32" size="1.778" layer="23">LM3915</text>
<text x="71.92" y="39.44" size="1.778" layer="23" rot="R180">-12V</text>
<text x="76.56" y="39.44" size="1.778" layer="23" rot="R180">0</text>
<text x="47.56" y="39.44" size="1.778" layer="23" rot="R180">0</text>
<text x="52.2" y="39.44" size="1.778" layer="23" rot="R180">BE</text>
<text x="84.68" y="39.44" size="1.778" layer="23" rot="R180">+12V</text>
<text x="52.2" y="64.96" size="1.778" layer="23" rot="R180">TL082</text>
</plain>
<libraries>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="LED3MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="ic-package">
<description>&lt;b&gt;IC Packages an Sockets&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL18">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="11.43" y1="2.921" x2="-11.43" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.921" x2="-11.43" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="-11.43" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.016" x2="-11.43" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-11.684" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-9.525" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL08">
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="resistor">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;tr valign="top"&gt;
&lt;/td&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="0207/7">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="E2-5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.032 mm, diameter 5 mm</description>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.778" x2="-0.762" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.524" x2="-1.016" y2="2.032" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="-" x="1.016" y="0" drill="0.8128" diameter="1.27" shape="octagon"/>
<pad name="+" x="-1.016" y="0" drill="0.8128" diameter="1.27"/>
<text x="2.54" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="51"/>
</package>
<package name="CTRIM808-BC7.5">
<description>&lt;b&gt;Trimm capacitor &lt;/b&gt; BC-Components</description>
<wire x1="1.3" y1="5.05" x2="3.35" y2="-1.6" width="0.254" layer="21" curve="-110.073805"/>
<wire x1="-3.35" y1="-1.6" x2="-1.3" y2="5.05" width="0.254" layer="21" curve="-110.073805"/>
<wire x1="-1.45" y1="-3" x2="1.45" y2="-3" width="0.254" layer="21" curve="39.851161"/>
<circle x="0" y="1" radius="4.25" width="0.254" layer="51"/>
<circle x="0" y="1" radius="1.271" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.3"/>
<pad name="2" x="0" y="5.08" drill="1.3"/>
<pad name="3" x="2.54" y="-2.54" drill="1.3"/>
<text x="-4.4684" y="-3.4056" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.77" y="-3.4056" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.2192" y1="0.6952" x2="1.2192" y2="1.3048" layer="21"/>
<hole x="0" y="1" drill="3"/>
</package>
</packages>
</library>
<library name="capacitor-wima">
<description>&lt;b&gt;WIMA Capacitors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="C2.5-5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 5 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.778" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO41-7">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 7.62 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.794" y2="0" width="0.762" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.794" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="1.1176"/>
<pad name="A" x="3.81" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="2.667" y2="0.381" layer="21"/>
<rectangle x1="-2.667" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="2,8-PAD">
<description>&lt;b&gt;MOUNTING PAD&lt;/b&gt; 2.8 mm, round</description>
<wire x1="0" y1="2.921" x2="0" y2="2.667" width="0.0508" layer="21"/>
<wire x1="0" y1="-2.667" x2="0" y2="-2.921" width="0.0508" layer="21"/>
<wire x1="-1.778" y1="0" x2="0" y2="-1.778" width="2.286" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="1.778" x2="1.778" y2="0" width="2.286" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="0.635" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.175" width="0.8128" layer="39"/>
<circle x="0" y="0" radius="3.175" width="0.8128" layer="40"/>
<circle x="0" y="0" radius="3.175" width="0.8128" layer="43"/>
<circle x="0" y="0" radius="1.5" width="0.2032" layer="21"/>
<pad name="B2,8" x="0" y="0" drill="2.8" diameter="5.334"/>
</package>
</packages>
</library>
<library name="inductors">
<description>&lt;b&gt;Inductors and Filters&lt;/b&gt;&lt;p&gt;
Based on the previous library ind-a.lbr&lt;p&gt;
<packages>
<package name="BL03RN2">
<description>&lt;b&gt;Noise Suppression Products/EMI Suppression Filters, Lead EMIFIL(R) Inductor Type&lt;/b&gt;&lt;p&gt;
BL03RN2R1M1B / BL03RN2R1N1A / BL03RN2R1P1A / BL03RN2R1Q1A&lt;br&gt;
Source: http://www.murata.com .. BL01RN1_DS.pdf</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.65" layer="51"/>
<wire x1="2.54" y1="0" x2="1.27" y2="0" width="0.65" layer="51"/>
<circle x="-2.56" y="0" radius="1.0505" width="0.2032" layer="21"/>
<circle x="2.52" y="0" radius="1.0505" width="0.2032" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9" diameter="1.5"/>
<pad name="2" x="2.54" y="0" drill="0.9" diameter="1.5"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.27" y1="-0.325" x2="1.27" y2="0.325" layer="21"/>
</package>
</packages>
</library>
<library name="jumper">
<description>&lt;b&gt;Jumpers&lt;/b&gt;&lt;p&gt;
<packages>
<package name="JP1">
<description>&lt;b&gt;JUMPER&lt;/b&gt;</description>
<wire x1="-1.016" y1="0" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.54" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="1.016" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-1.27" drill="0.9144" shape="long"/>
<pad name="2" x="0" y="1.27" drill="0.9144" shape="long"/>
<text x="-1.651" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.921" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="0.9652" x2="0.3048" y2="1.5748" layer="51"/>
<rectangle x1="-0.3048" y1="-1.5748" x2="0.3048" y2="-0.9652" layer="51"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="D1" library="led" package="LED3MM" value="" x="-8.12" y="80.04"/>
<element name="D2" library="led" package="LED3MM" value="" x="-2.32" y="80.04"/>
<element name="D3" library="led" package="LED3MM" value="" x="3.48" y="80.04"/>
<element name="D4" library="led" package="LED3MM" value="" x="9.28" y="80.04"/>
<element name="D5" library="led" package="LED3MM" value="" x="15.08" y="80.04"/>
<element name="D6" library="led" package="LED3MM" value="" x="20.88" y="80.04"/>
<element name="D7" library="led" package="LED3MM" value="" x="26.68" y="80.04"/>
<element name="D8" library="led" package="LED3MM" value="" x="32.48" y="80.04"/>
<element name="D9" library="led" package="LED3MM" value="" x="38.28" y="80.04"/>
<element name="D10" library="led" package="LED3MM" value="" x="44.08" y="80.04"/>
<element name="D12" library="led" package="LED3MM" value="" x="55.68" y="80.04"/>
<element name="D13" library="led" package="LED3MM" value="" x="61.48" y="80.04"/>
<element name="D14" library="led" package="LED3MM" value="" x="67.28" y="80.04"/>
<element name="D15" library="led" package="LED3MM" value="" x="73.08" y="80.04"/>
<element name="D16" library="led" package="LED3MM" value="" x="78.88" y="80.04"/>
<element name="D17" library="led" package="LED3MM" value="" x="84.68" y="80.04"/>
<element name="D18" library="led" package="LED3MM" value="" x="90.48" y="80.04"/>
<element name="D19" library="led" package="LED3MM" value="" x="96.28" y="80.04"/>
<element name="IC2" library="ic-package" package="DIL18" value="" x="5.8" y="60.32"/>
<element name="IC1" library="ic-package" package="DIL08" value="" x="48.72" y="63.8"/>
<element name="R2" library="resistor" package="0207/7" value="" x="54.52" y="48.72" rot="R90"/>
<element name="R7" library="resistor" package="0207/7" value="" x="84.68" y="48.72" rot="R90"/>
<element name="R6" library="resistor" package="0207/7" value="" x="81.2" y="48.72" rot="R90"/>
<element name="R4" library="resistor" package="0207/7" value="" x="30.16" y="48.72" rot="R90"/>
<element name="R5" library="resistor" package="0207/7" value="" x="18.56" y="41.76" rot="R180"/>
<element name="R9" library="resistor" package="0207/7" value="" x="9.28" y="48.72" rot="R90"/>
<element name="R8" library="resistor" package="0207/7" value="" x="88.16" y="48.72" rot="R90"/>
<element name="R3" library="resistor" package="0207/7" value="" x="34.8" y="48.72" rot="R90"/>
<element name="R1" library="resistor" package="0207/7" value="" x="58" y="48.72" rot="R90"/>
<element name="C4" library="capacitor-wima" package="C2.5-5" value="" x="51.04" y="71.92" rot="R180"/>
<element name="C3" library="capacitor-wima" package="C2.5-5" value="" x="38.28" y="69.6"/>
<element name="D21" library="diode" package="DO41-7" value="" x="22.04" y="48.72" rot="R90"/>
<element name="D20" library="diode" package="DO41-7" value="" x="25.52" y="48.72" rot="R90"/>
<element name="C6" library="resistor" package="E2-5" value="" x="-3.48" y="48.72" rot="R90"/>
<element name="C5" library="resistor" package="E2-5" value="" x="39.44" y="48.72" rot="R270"/>
<element name="C1" library="resistor" package="E2-5" value="" x="33.64" y="64.96" rot="R180"/>
<element name="IC3" library="ic-package" package="DIL18" value="" x="82.36" y="60.32"/>
<element name="D11" library="led" package="LED3MM" value="" x="49.88" y="80.04"/>
<element name="P1" library="resistor" package="CTRIM808-BC7.5" value="" x="47.56" y="49.88" rot="R180"/>
<element name="C2" library="resistor" package="E2-5" value="" x="62.64" y="48.72" rot="R270"/>
<element name="E$32" library="holes" package="2,8-PAD" value="" x="-3.48" y="40.6"/>
<element name="E$33" library="holes" package="2,8-PAD" value="" x="-3.48" y="73.08"/>
<element name="E$34" library="holes" package="2,8-PAD" value="" x="93.96" y="73.08"/>
<element name="E$35" library="holes" package="2,8-PAD" value="" x="93.96" y="40.6"/>
<element name="ÁTKöTéS4" library="inductors" package="BL03RN2" value="" x="5.8" y="49.88" rot="R90"/>
<element name="ÁTKőTéS" library="inductors" package="BL03RN2" value="" x="77.72" y="59.16"/>
<element name="ÁTKőTéS2" library="inductors" package="BL03RN2" value="" x="68.44" y="54.52" rot="R90"/>
<element name="ÁTKőTéS3" library="inductors" package="BL03RN2" value="" x="22.04" y="59.16" rot="R180"/>
<element name="JP1" library="jumper" package="JP1" value="" x="96.28" y="60.32"/>
</elements>
<signals>
<signal name="S$2">
<via x="52.2" y="39.44" extent="1-16" drill="0.6" diameter="1.4224"/>
</signal>
<signal name="S$3">
<via x="71.92" y="39.44" extent="1-16" drill="0.6" diameter="1.4224"/>
</signal>
<signal name="S$4">
<via x="76.56" y="39.44" extent="1-16" drill="0.6" diameter="1.4224"/>
</signal>
<signal name="S$5">
<via x="82.36" y="39.44" extent="1-16" drill="0.6" diameter="1.4224"/>
</signal>
<signal name="+">
<via x="47.56" y="39.44" extent="1-16" drill="0.6" diameter="1.4224"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
