<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.4">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.002" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="RS1">
<description>&lt;B&gt;ELL&lt;/B&gt;</description>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<wire x1="-3.175" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-3.175" y2="13.0175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="13.0175" x2="3.175" y2="13.0175" width="0.1524" layer="21"/>
<wire x1="3.175" y1="13.0175" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="1.524" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="11.1252" x2="-0.9652" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="10.2108" x2="1.3208" y2="6.35" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="4.4704" x2="1.3208" y2="3.5052" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="0" x2="1.3208" y2="1.5748" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="1.5748" x2="-0.3048" y2="1.5748" width="0.6096" layer="1"/>
<wire x1="2.8448" y1="1.5748" x2="1.3208" y2="1.5748" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="1.5748" x2="1.3208" y2="2.54" width="0.6096" layer="1"/>
<wire x1="2.8448" y1="2.54" x2="1.3208" y2="2.54" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="2.54" x2="1.3208" y2="3.5052" width="0.6096" layer="1"/>
<wire x1="1.27" y1="3.5052" x2="-0.3048" y2="3.5052" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="3.5052" x2="2.8956" y2="3.5052" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="3.5052" x2="1.27" y2="3.5052" width="0.6096" layer="1"/>
<wire x1="1.27" y1="3.5052" x2="1.27" y2="4.4704" width="0.6096" layer="1"/>
<wire x1="1.27" y1="4.4704" x2="1.3208" y2="4.4704" width="0.6096" layer="1"/>
<wire x1="2.8448" y1="4.4704" x2="1.3208" y2="4.4704" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="4.4704" x2="1.3208" y2="5.3848" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="5.3848" x2="-0.3048" y2="5.3848" width="0.6096" layer="1"/>
<wire x1="2.8956" y1="5.3848" x2="1.3208" y2="5.3848" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="5.3848" x2="1.3208" y2="6.35" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="6.35" x2="2.8448" y2="6.35" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="6.35" x2="1.27" y2="6.35" width="0.6096" layer="1"/>
<wire x1="1.27" y1="6.35" x2="1.27" y2="7.3152" width="0.6096" layer="1"/>
<wire x1="1.27" y1="7.3152" x2="-0.3048" y2="7.3152" width="0.6096" layer="1"/>
<wire x1="2.8448" y1="7.3152" x2="1.27" y2="7.3152" width="0.6096" layer="1"/>
<wire x1="1.27" y1="7.3152" x2="1.27" y2="8.2804" width="0.6096" layer="1"/>
<wire x1="2.8956" y1="8.2804" x2="1.27" y2="8.2804" width="0.6096" layer="1"/>
<wire x1="1.27" y1="8.2804" x2="1.27" y2="9.1948" width="0.6096" layer="1"/>
<wire x1="1.27" y1="9.1948" x2="-0.3556" y2="9.1948" width="0.6096" layer="1"/>
<wire x1="2.8956" y1="9.1948" x2="1.27" y2="9.1948" width="0.6096" layer="1"/>
<wire x1="1.27" y1="9.1948" x2="1.27" y2="10.2108" width="0.6096" layer="1"/>
<wire x1="1.27" y1="10.2108" x2="1.3208" y2="10.2108" width="0.6096" layer="1"/>
<wire x1="2.8956" y1="10.2108" x2="1.3208" y2="10.2108" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="10.2108" x2="1.3208" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="11.1252" x2="1.9304" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="2.8448" y1="11.1252" x2="1.9304" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="1.9304" y1="12.6492" x2="1.9304" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="1.3208" y1="11.1252" x2="0.9652" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="0.9652" y1="12.7" x2="0.9652" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="0.9652" y1="11.1252" x2="0" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="0" y1="12.7" x2="0" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="0" y1="11.1252" x2="-0.9652" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="-0.9652" y1="12.7" x2="-0.9652" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="-2.8448" y1="11.1252" x2="-1.9304" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="-1.9304" y1="12.7" x2="-1.9304" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="-1.9304" y1="11.1252" x2="-1.27" y2="11.1252" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="11.1252" x2="-1.27" y2="10.16" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="10.16" x2="-2.8448" y2="10.16" width="0.6096" layer="1"/>
<wire x1="0.3048" y1="10.16" x2="-1.27" y2="10.16" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="10.16" x2="-1.27" y2="9.1948" width="0.6096" layer="1"/>
<wire x1="-2.8448" y1="9.1948" x2="-1.27" y2="9.1948" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="9.1948" x2="-1.27" y2="8.2804" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="8.2804" x2="-2.8448" y2="8.2804" width="0.6096" layer="1"/>
<wire x1="0.3556" y1="8.2804" x2="-1.27" y2="8.2804" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="8.2804" x2="-1.27" y2="7.3152" width="0.6096" layer="1"/>
<wire x1="-2.8448" y1="7.3152" x2="-1.27" y2="7.3152" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="7.3152" x2="-1.27" y2="6.2992" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="6.2992" x2="-2.8448" y2="6.2992" width="0.6096" layer="1"/>
<wire x1="0.3556" y1="6.2992" x2="-1.27" y2="6.2992" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="6.2992" x2="-1.27" y2="5.334" width="0.6096" layer="1"/>
<wire x1="-2.8448" y1="5.334" x2="-1.27" y2="5.334" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="5.334" x2="-1.27" y2="4.3688" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="4.3688" x2="-2.8956" y2="4.3688" width="0.6096" layer="1"/>
<wire x1="0.3556" y1="4.3688" x2="-1.27" y2="4.3688" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="4.3688" x2="-1.27" y2="3.5052" width="0.6096" layer="1"/>
<wire x1="-2.8956" y1="3.5052" x2="-1.27" y2="3.5052" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="3.5052" x2="-1.27" y2="2.54" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="2.54" x2="-2.8448" y2="2.54" width="0.6096" layer="1"/>
<wire x1="0.3048" y1="2.54" x2="-1.27" y2="2.54" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="1.524" width="0.6096" layer="1"/>
<wire x1="-2.8956" y1="1.524" x2="-1.27" y2="1.524" width="0.6096" layer="1"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-0.0508" width="0.6096" layer="1"/>
</package>
</packages>
<symbols>
<symbol name="RS1">
<wire x1="2.54" y1="1.27" x2="-2.54" y2="1.27" width="0.254" layer="94"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="-1.27" width="0.254" layer="94"/>
<text x="-2.286" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.27" x2="2.54" y2="1.27" width="0.254" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="RS1" prefix="D">
<description>&lt;B&gt;NYAK Ellanallas&lt;/B&gt;</description>
<gates>
<gate name="1" symbol="RS1" x="0" y="0"/>
</gates>
<devices>
<device name="" package="RS1">
<connects>
<connect gate="1" pin="A" pad="1"/>
<connect gate="1" pin="C" pad="2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
