;                         DIGITAL FREQUENCY COUNTER
RS	equ	0x2
RW	equ	0x1
EN	equ	0x0
gate	equ	0x20
cnt1	equ	0x21
cnt2	equ	0x22
cnt3	equ	0x23
TMR02	equ	0x24
count1	equ	0x25
count2	equ	0x26
	org	0x00
	goto	start
int_del	movlw	0x05		;delay 5.000 ms (4 MHz clock)
	movwf	count1
d1	movlw	0xA5
	movwf	count2
d2	decfsz	count2, f
	goto	d2
	decfsz	count1, f
	goto	d1
	retlw	0x00
lcd_dat	movwf	PORTB		;load data into PORTB
	bsf	STATUS, RP0   	; select Register-Page 1**************************
	movlw	b'00000000'	;define PORTB as output
	movwf	TRISB
	bcf	STATUS, RP0	; select Register-Page 0 ************************
	bsf	PORTA, RS	;rs = data
	bcf	PORTA, RW	;r/w = write
	bsf	PORTA, EN	;toggle enable
	bcf	PORTA, EN
	movlw	b'11111111'	;define PORTB as input
	movwf	TRISB
	bcf	PORTA, RS	;rs = instruction
	bsf	PORTA, RW	;r/w = read
out1	bsf	PORTA, EN	;enable high
	btfss	PORTB, 7	;test busy flag
	goto	out2
	bcf	PORTA, EN	;enable low
	goto	out1
out2	bcf	PORTA, EN	;enable low
	retlw	0x00
lcd_com	movwf	PORTB		;load instruction into PORTB
	movwf	TRISB
	bcf	PORTA, EN
	movwf	TRISB
inst1	bsf	PORTA, EN	;enable high
	goto	inst2
	goto	inst1
inst2	bcf	PORTA, EN	;enable low
	retlw	0x00
count	bcf	PORTA, 3
	bcf	PORTA, 2
	clrf	cnt3
	clrf	TMR0
	clrf	TMR02
	bsf	PORTA, 2	;toggle TMR0 pin
	bcf	PORTA, 2
	movf	gate, w		;get gate time
	movwf	count1
	bsf	PORTA, 3	;start count
fr4	movlw	0xFA
	movwf	count2
	goto	fr6
fr5	nop
	nop
	nop
	nop
	nop
	nop
fr6	movf	TMR0, w		;test for TMR0 rollover (12)
	subwf	TMR02, f	; TMR02 = TMR02 - W(TMR0)
	btfss	STATUS, z	; TMR02 == 0?
	goto	fr7		; nem
	nop
	goto	fr8
fr7	btfsc	STATUS, c	; TMR02 > 0?
	incf	cnt3, f		; igen
fr8	movwf	TMR02		; TMR02 = TMR0
	nop
	nop
	nop
	decfsz	count2, f
	goto	fr5
	decfsz	count1, f
	goto	fr4
	bcf	PORTA, 3	;stop count
	movf	TMR0, w		;get TMR0 count
	movwf	cnt2
	subwf	TMR02, f	;test for TMR0 rollover
	btfss	STATUS, c
	goto	fr9
	btfss	STATUS, z
	incf	cnt3, f
fr9	clrf	cnt1		;set to get prescaler count
fr10	decf	cnt1, f
	bcf	PORTA, 2
	movf	TMR0, w		;test if TMR0 has changed
	xorwf	cnt2, w
	btfsc	STATUS, z
	goto	fr10
	retlw	0x00
cnvt	movlw	0x00		; BCD nullazas
	movwf	0x2c
	movwf	0x2d
	movwf	0x2e
	movwf	0x2f
	movwf	0x30
	movwf	0x31
	movwf	0x32
	movwf	0x33
	movlw	24		; kulso ciklus 24
	movwf	count2
big5	movlw	0x2c		; nagyobb-e 5-nel ciklus
	movwf	FSR		; bcd kezdo cim
big51	movlw	5
	subwf	INDF, w		; bcd szam - 5	
	btfss	STATUS, c	; bcd >= 5
	goto	big5-v		; nem
	movlw	3		; nagyobb, tehat +3
	addwf	INDF, f
big5-v	incf	FSR, f 
	movlw	0x34		
	xorwf	FSR, w
	btfss	STATUS, z	; nagyobb-e 5-nel ciklus vege
	goto	big51
rot	movlw	0x2c		; balra leptet ciklus
	movwf	FSR
rot1	bcf	STATUS, c	; clear carry bit
	rlf	INDF, f
	bcf	INDF, 4		; nem kell az 5. bit
	incf	FSR, f
	btfss	INDF, 3
	goto	rot-v
	decf	FSR, f
	bsf	INDF, 0	
	incf	FSR, f 
rot-v	movlw	0x33		
	xorwf	FSR, w
	btfss	STATUS, z	; balra leptet ciklus vege
	goto	rot1
	rlf	INDF, f
	btfss	cnt3, 7
	goto	rot_1
	bsf	INDF, 0	
rot_1	bcf	STATUS, c	; clear carry bit
	rlf	cnt3, f
	btfss	cnt2, 7
	goto	rot_2
	bsf	cnt3, 0	
rot_2	bcf	STATUS, c	; clear carry bit
	rlf	cnt2, f
	btfss	cnt1, 7
	goto	rot_3
	bsf	cnt2, 0	
rot_3	bcf	STATUS, c	; clear carry bit
	rlf	cnt1, f
	decfsz	count2, f	; kulso ciklus vege
	goto	big5
ascii	movlw	0x30
	addwf	0x2c, f
	addwf	0x2d, f
	addwf	0x2e, f
	addwf	0x2f, f
	addwf	0x30, f
	addwf	0x31, f
	addwf	0x32, f
	addwf	0x33, f
	retlw	0x00
;                                   START
start	movlw	7
	movwf	CMCON
	bsf	STATUS, RP0   	; select Register-Page 1 ****************************
	movlw	b'00110111'	; TMR0 = ext, 1/256
	movwf	OPTION_REG
	movlw	b'00010000'	; RA4 input
	movwf	TRISA
	movlw	b'00000000'	; RB output
	movwf	TRISB
	bcf	STATUS, RP0	; select Register-Page 0 ****************************
	call	int_del		; 15ms delay for LCD
	call	int_del
	call	int_del
	bsf	PORTB,	4	; 3x 0x30 out + 5ms delay
	bsf	PORTB,	5	
	bcf	PORTA, EN
	call	int_del
	bcf	PORTA, EN
	call	int_del
	bcf	PORTA, EN
	call	int_del
	movlw	0x38		;8bit display, 2 row, 5x8 font
	call	lcd_com
	movlw	b'00001100'	;display on, cursor off, blink cursor off
	call	lcd_com
	movlw	b'00000001'	;clear display
	call	lcd_com
	movlw	b'00000110'	;cursor forward
	call	lcd_com
	call	copyright
mhz	movlw	0x14		;0.1 sec gate
	movwf	gate
	call	count
	call	cnvt		;convert binary to BCD
	movlw	0x30		;test if "0"
	xorwf	0x2D, w
	btfss	STATUS, z
	goto	mhz1		; nem
	xorwf	0x2E, w
	btfsc	STATUS, z
	goto	khz1		; igen
mhz1	movlw	0x82		;set display address
	call	lcd_com
	movlw	0x02		;output first 2 characters
	movwf	count1
	movlw	0x2D		;MSD of freq
	movwf	fsr
mhz2	movlw	0x30		;test if "0"
	xorwf	INDF, w
	btfss	STATUS, z
	goto	mhz3
	movlw	0x20		;change preceeding "0's" to "space"
	call	lcd_dat
	incf	fsr, f
	decfsz	count1, f
	goto	mhz2
	goto	mhz4
mhz3	movf	INDF, w
	call	lcd_dat
	incf	fsr, f
	decfsz	count1, f
	goto	mhz3
mhz4	movlw	0x2E		;"."
	call	lcd_dat
	movlw	0x05		;output last 5 characters
	movwf	count1	
mhz5	movf	INDF, w
	call	lcd_dat
	incf	fsr, f
	decfsz	count1, f
	goto	mhz5
	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x4D		;"M"
	call	lcd_dat
	movlw	0x48		;"H"
	call	lcd_dat
	movlw	0x7A		;"z"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	goto	mhz
khz	movlw	0x14		;0.1 sec gate
	movwf	gate
	call	count
	movlw	0x30		;test if 0
	xorwf	0x2D, w
	btfss	STATUS, z
	goto	mhz1
	movlw	0x32		;test if < 2
	subwf	0x2E, w
	btfsc	STATUS, c
	goto	mhz1
	xorwf	0x2E, w
	btfss	STATUS, z
	goto	khz1
	xorwf	0x2F, w
	btfsc	STATUS, z
	goto	xkhz
khz1	movlw	0x82		;set display address
	call	lcd_com
	movlw	0x05		;output first 5 characters
	movwf	count1
	movwf	fsr
khz2	movlw	0x30		;test if "0"
	xorwf	INDF, w
	btfss	STATUS, z
	goto	khz3
	call	lcd_dat
	incf	fsr, f
	decfsz	count1, f
	goto	khz2
	goto	khz4
khz3	movf	INDF, w
	call	lcd_dat
	incf	fsr, f
	decfsz	count1, f
	goto	khz3
khz4	movlw	0x2E		;"."
	call	lcd_dat
	movf	INDF, w		;output last 2 characters
	call	lcd_dat
	incf	fsr, f
	movf	INDF,w
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x4B		;"K"
	call	lcd_dat
	movlw	0x48		;"H"
	call	lcd_dat
	movlw	0x7A		;"z"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	goto	khz
xkhz	movlw	0xC8		;1 sec gate
	movwf	gate
	call	count
	xorwf	0x2D, w
	btfss	STATUS, z
	goto	khz
	subwf	0x2E, w
	btfsc	STATUS, c
	goto	khz
	xorwf	0x2E, w
	btfss	STATUS, z
	goto	xkhz1
	xorwf	0x2F, w
	btfsc	STATUS, z
	goto	hz0
xkhz1	movlw	0x82		;set display address
	call	lcd_com
	movlw	0x04		;output first 4 characters
	movwf	count1
	movwf	fsr
xkhz2	movlw	0x30		;test if "0"
	xorwf	INDF, w
	btfss	STATUS, z
	goto	xkhz3
	call	lcd_dat
	incf	fsr, f
	decfsz	count1, f
	goto	xkhz2
	goto	xkhz4
xkhz3	movf	INDF, w
	call	lcd_dat
	incf	fsr, f
	decfsz	count1, f
	goto	xkhz3
xkhz4	movlw	0x2E		;"."
	call	lcd_dat
	movf	INDF, w		;output last 3 characters
	call	lcd_dat
	incf	fsr, f
	movf	INDF, w
	call	lcd_dat
	incf	fsr, f
	movf	INDF, w
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x4B		;"K"
	call	lcd_dat
	movlw	0x48		;"H"
	call	lcd_dat
	movlw	0x7A		;"z"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	goto	xkhz
	movwf	gate
	call	count
	xorwf	0x2D, w
	btfss	STATUS, z
	goto	xkhz1
	xorwf	0x2E, w
	btfss	STATUS, z
	goto	xkhz1
	subwf	0x2F, w
	btfsc	STATUS, c
	goto	xkhz1
hz0	movlw	0x82		;set display address
	call	lcd_com
	movlw	0x07		;output first 7 characters
	movwf	count1
	movwf	fsr
hz1	movlw	0x30		;test if "0"
	xorwf	INDF, w
	btfss	STATUS, z
	goto	hz2
	call	lcd_dat
	incf	fsr, f
	decfsz	count1, f
	goto	hz1
	goto	hz3
hz2	movf	INDF, w
	call	lcd_dat
	incf	fsr, f
	decfsz	count1, f
	goto	hz2
hz3	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x48		;"H"
	call	lcd_dat
	movlw	0x7A		;"z"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	movlw	0x20		;"space"
	call	lcd_dat
	goto	hz
copyright	
	movlw	0x40		; uj karakter beir 40-47 -ig. ez ASCII 0
	call	lcd_com
	movlw	0x08		;
	call	lcd_dat
	movlw	0x14		;
	call	lcd_dat
	movlw	0x16		;
	call	lcd_dat
	movlw	0x1F		;
	call	lcd_dat
	movlw	0x16		;
	call	lcd_dat
	movlw	0x16		;
	call	lcd_dat
	movlw	0x15		;
	call	lcd_dat
	movlw	0x00		;
	call	lcd_dat
	movlw	0xCF		;display address
	call	lcd_com
	movlw	0x00		;"copyright"
	call	lcd_dat
	retlw	0x00
	end
