<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="12" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="14" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="15" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="12" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="15" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="9" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="100" name="gnd" color="9" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<plain>
<wire x1="-1.27" y1="0" x2="89.84" y2="0" width="0" layer="20"/>
<wire x1="89.84" y1="0" x2="89.84" y2="68.57" width="0" layer="20"/>
<wire x1="89.84" y1="68.57" x2="-1.27" y2="68.57" width="0" layer="20"/>
<wire x1="-1.27" y1="68.57" x2="-1.27" y2="0" width="0" layer="20"/>
<dimension x1="-1.27" y1="0" x2="90.17" y2="0" x3="44.45" y3="-8.89" layer="20"/>
<rectangle x1="26.67" y1="11.43" x2="44.45" y2="24.13" layer="16"/>
<rectangle x1="16.51" y1="36.83" x2="24.13" y2="48.26" layer="16"/>
<rectangle x1="17.78" y1="12.7" x2="25.4" y2="24.13" layer="16"/>
<rectangle x1="16.51" y1="48.26" x2="19.05" y2="49.53" layer="16"/>
<rectangle x1="16.51" y1="46.99" x2="24.13" y2="49.53" layer="16"/>
<rectangle x1="43.18" y1="22.86" x2="46.99" y2="24.13" layer="16"/>
<rectangle x1="44.45" y1="19.05" x2="46.99" y2="20.32" layer="16"/>
<rectangle x1="44.45" y1="15.24" x2="46.99" y2="16.51" layer="16"/>
<rectangle x1="44.45" y1="11.43" x2="46.99" y2="12.7" layer="16"/>
<rectangle x1="26.67" y1="8.89" x2="27.94" y2="11.43" layer="16"/>
<rectangle x1="30.48" y1="8.89" x2="31.75" y2="11.43" layer="16"/>
<rectangle x1="34.29" y1="8.89" x2="35.56" y2="11.43" layer="16"/>
<rectangle x1="38.1" y1="8.89" x2="39.37" y2="11.43" layer="16"/>
<rectangle x1="41.91" y1="8.89" x2="43.18" y2="11.43" layer="16"/>
<rectangle x1="26.67" y1="24.13" x2="27.94" y2="26.67" layer="16"/>
<rectangle x1="30.48" y1="24.13" x2="31.75" y2="26.67" layer="16"/>
<rectangle x1="34.29" y1="24.13" x2="35.56" y2="26.67" layer="16"/>
<rectangle x1="38.1" y1="24.13" x2="39.37" y2="25.4" layer="16"/>
<rectangle x1="41.91" y1="24.13" x2="43.18" y2="26.67" layer="16"/>
<rectangle x1="16.51" y1="49.53" x2="17.78" y2="52.07" layer="16"/>
<rectangle x1="19.05" y1="49.53" x2="20.32" y2="52.07" layer="16"/>
<rectangle x1="22.86" y1="49.53" x2="24.13" y2="52.07" layer="16"/>
<rectangle x1="16.51" y1="34.29" x2="17.78" y2="36.83" layer="16"/>
<rectangle x1="24.13" y1="48.26" x2="26.67" y2="49.53" layer="16"/>
<rectangle x1="24.13" y1="36.83" x2="26.67" y2="38.1" layer="16"/>
<rectangle x1="24.13" y1="40.64" x2="26.67" y2="41.91" layer="16"/>
<rectangle x1="24.13" y1="44.45" x2="26.67" y2="45.72" layer="16"/>
<rectangle x1="19.05" y1="34.29" x2="20.32" y2="36.83" layer="16"/>
<rectangle x1="21.59" y1="34.29" x2="22.86" y2="36.83" layer="16"/>
<rectangle x1="17.78" y1="24.13" x2="19.05" y2="25.4" layer="16"/>
<rectangle x1="17.78" y1="25.4" x2="19.05" y2="26.67" layer="16"/>
<rectangle x1="20.32" y1="24.13" x2="21.59" y2="26.67" layer="16"/>
<rectangle x1="22.86" y1="24.13" x2="24.13" y2="26.67" layer="16"/>
<rectangle x1="17.78" y1="10.16" x2="19.05" y2="12.7" layer="16"/>
<rectangle x1="20.32" y1="10.16" x2="21.59" y2="12.7" layer="16"/>
<rectangle x1="22.86" y1="10.16" x2="24.13" y2="12.7" layer="16"/>
<rectangle x1="29.21" y1="13.97" x2="41.91" y2="21.59" layer="1"/>
<dimension x1="89.84" y1="68.57" x2="90.17" y2="0" x3="101.440846875" y3="34.3400375" layer="20"/>
</plain>
<libraries>
<library name="switch-omron">
<description>&lt;b&gt;Omron Switches&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="B3F-10XX">
<description>&lt;b&gt;OMRON SWITCH&lt;/b&gt;</description>
<wire x1="3.302" y1="-0.762" x2="3.048" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-0.762" x2="3.302" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.762" x2="3.302" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="1.016" x2="3.048" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0.762" x2="-3.048" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="2.54" x2="2.54" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-3.048" x2="3.048" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="3.048" y1="-2.54" x2="3.048" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-3.048" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="2.54" x2="-3.048" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-3.048" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-2.54" x2="-3.048" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="-1.27" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="1.27" width="0.0508" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="1.27" y2="1.27" width="0.0508" layer="51"/>
<wire x1="-1.27" y1="3.048" x2="-1.27" y2="2.794" width="0.0508" layer="21"/>
<wire x1="1.27" y1="2.794" x2="-1.27" y2="2.794" width="0.0508" layer="21"/>
<wire x1="1.27" y1="2.794" x2="1.27" y2="3.048" width="0.0508" layer="21"/>
<wire x1="1.143" y1="-2.794" x2="-1.27" y2="-2.794" width="0.0508" layer="21"/>
<wire x1="1.143" y1="-2.794" x2="1.143" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-1.27" y1="-2.794" x2="-1.27" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="2.54" y1="-3.048" x2="2.159" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-2.159" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-3.048" x2="-1.27" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.048" x2="-2.159" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="3.048" x2="2.159" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.159" y1="3.048" x2="1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="1.27" y1="3.048" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="3.048" x2="-2.159" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.048" x2="1.143" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-3.048" x2="2.159" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.762" x2="3.048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.762" x2="3.048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.762" x2="-3.048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-2.159" x2="1.27" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="1.27" y1="2.286" x2="-1.27" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.508" x2="-2.413" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="0.508" x2="-2.159" y2="-0.381" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="21"/>
<circle x="-2.159" y="-2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="2.159" y="-2.032" radius="0.508" width="0.1524" layer="51"/>
<circle x="2.159" y="2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="-2.159" y="2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="0.635" width="0.0508" layer="51"/>
<circle x="0" y="0" radius="0.254" width="0.1524" layer="21"/>
<pad name="1" x="-3.2512" y="2.2606" drill="1.016" shape="long"/>
<pad name="3" x="-3.2512" y="-2.2606" drill="1.016" shape="long"/>
<pad name="2" x="3.2512" y="2.2606" drill="1.016" shape="long"/>
<pad name="4" x="3.2512" y="-2.2606" drill="1.016" shape="long"/>
<text x="-3.048" y="3.683" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.318" y="1.651" size="1.27" layer="51" ratio="10">1</text>
<text x="3.556" y="1.524" size="1.27" layer="51" ratio="10">2</text>
<text x="-4.572" y="-2.794" size="1.27" layer="51" ratio="10">3</text>
<text x="3.556" y="-2.794" size="1.27" layer="51" ratio="10">4</text>
</package>
</packages>
</library>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="LED3MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C1206">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="M1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
MELF 0.25 W</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="SMC_C">
<description>&lt;b&gt;Chip Capacitor &lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194, B 45 197, B 45 198&lt;br&gt;
Source: www.farnell.com/datasheets/247.pdf</description>
<wire x1="-2.85" y1="1.55" x2="2.85" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="1.55" x2="2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="-1.55" x2="-2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.85" y1="-1.55" x2="-2.85" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.4" dy="2.4" layer="1" rot="R180"/>
<text x="-1.905" y="1.905" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3" y1="-1.1" x2="-2.8" y2="1.1" layer="51"/>
<rectangle x1="2.8" y1="-1.1" x2="3" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-2.85" y1="-1.55" x2="-1.9" y2="1.55" layer="51"/>
</package>
<package name="UD-8X10_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 8 x 10 mm&lt;p&gt;
Source: http://products.nichicon.co.jp/en/pdf/XJA043/e-ud.pdf</description>
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="3.3" x2="4.1" y2="-3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="4.1" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.875" x2="3.85" y2="0.875" width="0.1016" layer="21" curve="-154.459402"/>
<wire x1="-4.1" y1="0.825" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="3.85" y1="-0.875" x2="-3.85" y2="-0.875" width="0.1016" layer="21" curve="-154.459402"/>
<circle x="0" y="0" radius="3.95" width="0.1016" layer="51"/>
<smd name="-" x="-3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<smd name="+" x="3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<text x="-3.81" y="4.445" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.016" layer="27">&gt;VALUE</text>
<polygon width="0.1016" layer="51">
<vertex x="-3.05" y="2.475" curve="77.887741"/>
<vertex x="-3.05" y="-2.475"/>
</polygon>
</package>
<package name="SMC_D">
<wire x1="-3.5" y1="2.1" x2="3.5" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="2.1" x2="3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="-2.1" x2="-3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.5" y1="-2.1" x2="-3.5" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="-3.15" y="0" dx="2.4" dy="2.8" layer="1"/>
<smd name="-" x="3.15" y="0" dx="2.4" dy="2.8" layer="1" rot="R180"/>
<text x="-2.54" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.45" y2="1.2" layer="51"/>
<rectangle x1="3.45" y1="-1.2" x2="3.65" y2="1.2" layer="51" rot="R180"/>
<rectangle x1="-3.5" y1="-2.1" x2="-2.4" y2="2.1" layer="51"/>
</package>
<package name="UD-5X5,8_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 5 x 5.8 mm&lt;p&gt;
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.8" x2="2.6" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="2.6" width="0.1016" layer="51"/>
<wire x1="-2.3" y1="0.85" x2="2.275" y2="0.9" width="0.1016" layer="21" curve="-137.986421"/>
<wire x1="-2.6" y1="0.7" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="2.3" y1="-0.85" x2="-2.275" y2="-0.9" width="0.1016" layer="21" curve="-137.986421"/>
<circle x="0" y="0" radius="2.4501" width="0.1016" layer="51"/>
<smd name="-" x="-1.7" y="0" dx="2.3" dy="1" layer="1"/>
<smd name="+" x="1.725" y="0" dx="2.3" dy="1" layer="1"/>
<text x="-2.54" y="3.175" size="1.016" layer="25">&gt;NAME</text>
<vertex x="-1.55" y="1.875" curve="100.118878"/>
<vertex x="-1.55" y="-1.875"/>
</polygon>
</package>
<package name="UD-6,3X5,8_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 5.8 mm&lt;p&gt;
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="2.45" x2="3.25" y2="-2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="3.25" width="0.1016" layer="51"/>
<wire x1="-3" y1="0.775" x2="2.975" y2="0.85" width="0.1016" layer="21" curve="-149.753145"/>
<wire x1="-3.25" y1="0.8" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="3" y1="-0.775" x2="-2.975" y2="-0.85" width="0.1016" layer="21" curve="-149.753145"/>
<circle x="0" y="0" radius="3.1001" width="0.1016" layer="51"/>
<smd name="-" x="-2.35" y="0" dx="2.8" dy="1" layer="1"/>
<smd name="+" x="2.35" y="0" dx="2.8" dy="1" layer="1"/>
<text x="-3.175" y="3.81" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.175" y="-4.445" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="2.15" curve="88.581463"/>
<vertex x="-2.2" y="-2.15"/>
</polygon>
</package>
</packages>
</library>
<library name="con-amp-quick">
<description>&lt;b&gt;AMP Connectors, Type QUICK&lt;/b&gt;&lt;p&gt;
<packages>
<package name="03P">
<description>&lt;b&gt;AMP QUICK CONNECTOR&lt;/b&gt;</description>
<wire x1="-1.651" y1="1.778" x2="-1.524" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.651" x2="-1.27" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.397" x2="-1.016" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.651" x2="-0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-2.159" x2="-1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-2.286" x2="-3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.159" x2="-1.524" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.159" x2="-1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.54" x2="-3.556" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.778" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.778" x2="-3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.778" x2="-3.175" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.778" x2="-1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.778" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.778" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.556" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.54" x2="-2.794" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.54" x2="-2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.667" x2="-2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.54" x2="-0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.413" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.413" x2="-1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.397" x2="1.524" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.651" x2="1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.159" x2="1.016" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.159" x2="1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-2.286" x2="1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.778" x2="3.556" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.778" x2="3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.778" x2="3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.778" x2="3.175" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.778" x2="3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.778" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.778" x2="0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.778" x2="1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-1.524" x2="1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.524" x2="1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.524" x2="3.556" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.54" x2="2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.667" x2="2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.413" x2="1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.413" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.889" y1="1.778" x2="1.016" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.651" x2="1.27" y2="1.397" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.667" x2="-0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.54" x2="-0.254" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.413" x2="-1.016" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.54" x2="-2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.778" x2="-3.556" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.778" x2="0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.651" x2="-1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.651" x2="-1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.651" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.651" x2="1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.778" x2="-1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.286" x2="1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.778" x2="1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.159" x2="1.016" y2="-2.286" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-2.032" y="0.9398" size="0.9906" layer="21" ratio="12" rot="R90">1</text>
<text x="-3.556" y="2.9464" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.8354" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.8702" y1="-0.3302" x2="-2.2098" y2="0.3302" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3302" x2="0.3302" y2="0.3302" layer="51"/>
<rectangle x1="2.2098" y1="-0.3302" x2="2.8702" y2="0.3302" layer="51"/>
</package>
<package name="02P">
<wire x1="-2.286" y1="2.54" x2="-2.286" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.778" x2="-0.381" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.778" x2="-0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.651" x2="0" y2="1.397" width="0.1524" layer="21"/>
<wire x1="0" y1="1.397" x2="0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.651" x2="0.381" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.159" x2="-0.254" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.286" x2="-2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.159" x2="-0.254" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.159" x2="0.254" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-2.286" x2="0.254" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.778" x2="2.286" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.778" x2="2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.778" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.778" x2="-2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.778" x2="-1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.778" x2="2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.778" x2="1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.778" x2="2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.778" x2="0.635" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-1.524" x2="0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-1.524" x2="0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.524" x2="0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.524" x2="-0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.524" x2="2.286" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.524" x2="-2.286" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.54" x2="-1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.54" x2="-1.524" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.54" x2="-1.016" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.667" x2="-1.524" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="1.524" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.667" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.413" x2="0.254" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.413" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.413" x2="-0.254" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.54" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-0.762" y="0.9398" size="0.9906" layer="21" ratio="12" rot="R90">1</text>
<text x="-2.286" y="2.9464" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.8354" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.6002" y1="-0.3302" x2="-0.9398" y2="0.3302" layer="51"/>
<rectangle x1="0.9398" y1="-0.3302" x2="1.6002" y2="0.3302" layer="51"/>
</package>
</packages>
</library>
<library name="micro-philips">
<description>&lt;b&gt;Philips Microcontroller Devices&lt;/b&gt;&lt;p&gt;
http://www-eu2.semiconductors.com&lt;p&gt;
<packages>
<package name="TSSOP24">
<description>&lt;b&gt;Thin Shrink Small Outline Plastic 24&lt;/b&gt;&lt;p&gt;
Source: MAX3223-MAX3243.pdf</description>
<wire x1="-3.8146" y1="-2.2828" x2="3.8146" y2="-2.2828" width="0.1524" layer="21"/>
<wire x1="3.8146" y1="2.2828" x2="3.8146" y2="-2.2828" width="0.1524" layer="21"/>
<wire x1="3.8146" y1="2.2828" x2="-3.8146" y2="2.2828" width="0.1524" layer="21"/>
<wire x1="-3.8146" y1="-2.2828" x2="-3.8146" y2="2.2828" width="0.1524" layer="21"/>
<wire x1="-3.586" y1="-2.0542" x2="3.586" y2="-2.0542" width="0.0508" layer="21"/>
<wire x1="3.586" y1="2.0542" x2="3.586" y2="-2.0542" width="0.0508" layer="21"/>
<wire x1="3.586" y1="2.0542" x2="-3.586" y2="2.0542" width="0.0508" layer="21"/>
<wire x1="-3.586" y1="-2.0542" x2="-3.586" y2="2.0542" width="0.0508" layer="21"/>
<circle x="-2.9256" y="-1.2192" radius="0.4572" width="0.1524" layer="21"/>
<smd name="1" x="-3.575" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="2" x="-2.925" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="3" x="-2.275" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="4" x="-1.625" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="5" x="-0.975" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="6" x="-0.325" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="7" x="0.325" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="8" x="0.975" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="9" x="1.625" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="10" x="2.275" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="11" x="2.925" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="12" x="3.575" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="13" x="3.575" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="14" x="2.925" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="15" x="2.275" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="16" x="1.625" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="17" x="0.975" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="18" x="0.325" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="19" x="-0.325" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="20" x="-0.975" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="21" x="-1.625" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="22" x="-2.275" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="23" x="-2.925" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="24" x="-3.575" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<text x="-4.1956" y="-2.0828" size="1.016" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="5.1862" y="-2.0828" size="1.016" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-3.6766" y1="-3.121" x2="-3.4734" y2="-2.2828" layer="51"/>
<rectangle x1="-3.0266" y1="-3.121" x2="-2.8234" y2="-2.2828" layer="51"/>
<rectangle x1="-2.3766" y1="-3.121" x2="-2.1734" y2="-2.2828" layer="51"/>
<rectangle x1="-1.7266" y1="-3.121" x2="-1.5234" y2="-2.2828" layer="51"/>
<rectangle x1="-1.0766" y1="-3.121" x2="-0.8734" y2="-2.2828" layer="51"/>
<rectangle x1="-0.4266" y1="-3.121" x2="-0.2234" y2="-2.2828" layer="51"/>
<rectangle x1="0.2234" y1="-3.121" x2="0.4266" y2="-2.2828" layer="51"/>
<rectangle x1="0.8734" y1="-3.121" x2="1.0766" y2="-2.2828" layer="51"/>
<rectangle x1="1.5234" y1="-3.121" x2="1.7266" y2="-2.2828" layer="51"/>
<rectangle x1="2.1734" y1="-3.121" x2="2.3766" y2="-2.2828" layer="51"/>
<rectangle x1="2.8234" y1="-3.121" x2="3.0266" y2="-2.2828" layer="51"/>
<rectangle x1="3.4734" y1="-3.121" x2="3.6766" y2="-2.2828" layer="51"/>
<rectangle x1="3.4734" y1="2.2828" x2="3.6766" y2="3.121" layer="51"/>
<rectangle x1="2.8234" y1="2.2828" x2="3.0266" y2="3.121" layer="51"/>
<rectangle x1="2.1734" y1="2.2828" x2="2.3766" y2="3.121" layer="51"/>
<rectangle x1="1.5234" y1="2.2828" x2="1.7266" y2="3.121" layer="51"/>
<rectangle x1="0.8734" y1="2.2828" x2="1.0766" y2="3.121" layer="51"/>
<rectangle x1="0.2234" y1="2.2828" x2="0.4266" y2="3.121" layer="51"/>
<rectangle x1="-0.4266" y1="2.2828" x2="-0.2234" y2="3.121" layer="51"/>
<rectangle x1="-1.0766" y1="2.2828" x2="-0.8734" y2="3.121" layer="51"/>
<rectangle x1="-1.7266" y1="2.2828" x2="-1.5234" y2="3.121" layer="51"/>
<rectangle x1="-2.3766" y1="2.2828" x2="-2.1734" y2="3.121" layer="51"/>
<rectangle x1="-3.0266" y1="2.2828" x2="-2.8234" y2="3.121" layer="51"/>
<rectangle x1="-3.6766" y1="2.2828" x2="-3.4734" y2="3.121" layer="51"/>
</package>
<package name="SSOP24">
<description>&lt;b&gt;Small Shrink Outline Package&lt;/b&gt;&lt;p&gt;
SOT340-1 / JEDEC MO-150AG</description>
<wire x1="-5.063" y1="-3.756" x2="4.988" y2="-3.756" width="0.1524" layer="21"/>
<wire x1="4.988" y1="-3.756" x2="5.008" y2="3.796" width="0.1524" layer="21"/>
<wire x1="5.008" y1="3.796" x2="-5.043" y2="3.796" width="0.1524" layer="21"/>
<wire x1="-5.063" y1="-3.756" x2="-5.043" y2="3.796" width="0.1524" layer="21"/>
<wire x1="-4.629" y1="-3.406" x2="4.574" y2="-3.416" width="0.0508" layer="21"/>
<wire x1="4.574" y1="3.396" x2="4.574" y2="-3.416" width="0.0508" layer="21"/>
<wire x1="4.574" y1="3.396" x2="-4.629" y2="3.396" width="0.0508" layer="21"/>
<wire x1="-4.629" y1="-3.406" x2="-4.629" y2="3.396" width="0.0508" layer="21"/>
<circle x="-3.6879" y="-2.457" radius="0.635" width="0.1524" layer="21"/>
<smd name="1" x="-4.34" y="-4.85" dx="0.4" dy="1.2" layer="1"/>
<smd name="2" x="-3.525" y="-4.86" dx="0.4" dy="1.2" layer="1"/>
<smd name="3" x="-2.785" y="-4.88" dx="0.4" dy="1.2" layer="1"/>
<smd name="4" x="-1.995" y="-4.86" dx="0.4" dy="1.2" layer="1"/>
<smd name="5" x="-1.19" y="-4.89" dx="0.4" dy="1.2" layer="1"/>
<smd name="6" x="-0.385" y="-4.87" dx="0.4" dy="1.2" layer="1"/>
<smd name="7" x="0.44" y="-4.87" dx="0.4" dy="1.2" layer="1"/>
<smd name="8" x="1.245" y="-4.87" dx="0.4" dy="1.2" layer="1"/>
<smd name="9" x="2.065" y="-4.86" dx="0.4" dy="1.2" layer="1"/>
<smd name="10" x="2.86" y="-4.86" dx="0.4" dy="1.2" layer="1"/>
<smd name="11" x="3.665" y="-4.86" dx="0.4" dy="1.2" layer="1"/>
<smd name="12" x="4.49" y="-4.86" dx="0.4" dy="1.2" layer="1"/>
<smd name="13" x="4.455" y="4.88" dx="0.4" dy="1.2" layer="1"/>
<smd name="14" x="3.665" y="4.87" dx="0.4" dy="1.2" layer="1"/>
<smd name="15" x="2.855" y="4.87" dx="0.4" dy="1.2" layer="1"/>
<smd name="16" x="2.025" y="4.87" dx="0.4" dy="1.2" layer="1"/>
<smd name="17" x="1.205" y="4.87" dx="0.4" dy="1.2" layer="1"/>
<smd name="18" x="0.414" y="4.85" dx="0.4" dy="1.2" layer="1"/>
<smd name="19" x="-0.37" y="4.852" dx="0.4" dy="1.2" layer="1"/>
<smd name="20" x="-1.135" y="4.87" dx="0.4" dy="1.2" layer="1"/>
<smd name="21" x="-1.945" y="4.84" dx="0.4" dy="1.2" layer="1"/>
<smd name="22" x="-2.725" y="4.85" dx="0.4" dy="1.2" layer="1"/>
<smd name="23" x="-3.535" y="4.87" dx="0.4" dy="1.2" layer="1"/>
<smd name="24" x="-4.305" y="4.89" dx="0.4" dy="1.2" layer="1"/>
<text x="-6.8246" y="2.5373" size="1.27" layer="25" ratio="10" rot="R270">&gt;NAME</text>
<text x="-3.8919" y="0" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.485" y1="-5.05" x2="-4.185" y2="-3.85" layer="51"/>
<rectangle x1="-3.685" y1="-5.05" x2="-3.385" y2="-3.85" layer="51"/>
<rectangle x1="-2.925" y1="-5.07" x2="-2.625" y2="-3.87" layer="51"/>
<rectangle x1="-2.135" y1="-5.05" x2="-1.835" y2="-3.85" layer="51"/>
<rectangle x1="-1.335" y1="-5.05" x2="-1.035" y2="-3.85" layer="51"/>
<rectangle x1="-0.535" y1="-5.04" x2="-0.235" y2="-3.84" layer="51"/>
<rectangle x1="0.275" y1="-5.04" x2="0.575" y2="-3.84" layer="51"/>
<rectangle x1="1.095" y1="-5.07" x2="1.395" y2="-3.87" layer="51"/>
<rectangle x1="1.905" y1="-5.07" x2="2.205" y2="-3.87" layer="51"/>
<rectangle x1="2.695" y1="-5.03" x2="2.995" y2="-3.83" layer="51"/>
<rectangle x1="3.505" y1="-5.02" x2="3.805" y2="-3.82" layer="51"/>
<rectangle x1="4.345" y1="-5.05" x2="4.645" y2="-3.85" layer="51"/>
<rectangle x1="4.305" y1="3.85" x2="4.605" y2="5.05" layer="51"/>
<rectangle x1="3.545" y1="3.85" x2="3.845" y2="5.05" layer="51"/>
<rectangle x1="2.715" y1="3.87" x2="3.015" y2="5.07" layer="51"/>
<rectangle x1="1.865" y1="3.82" x2="2.165" y2="5.02" layer="51"/>
<rectangle x1="1.055" y1="3.85" x2="1.355" y2="5.05" layer="51"/>
<rectangle x1="0.275" y1="3.87" x2="0.575" y2="5.07" layer="51"/>
<rectangle x1="-0.495" y1="3.85" x2="-0.195" y2="5.05" layer="51"/>
<rectangle x1="-1.285" y1="3.83" x2="-0.985" y2="5.03" layer="51"/>
<rectangle x1="-2.085" y1="3.87" x2="-1.785" y2="5.07" layer="51"/>
<rectangle x1="-2.875" y1="3.86" x2="-2.575" y2="5.06" layer="51"/>
<rectangle x1="-3.685" y1="3.85" x2="-3.385" y2="5.05" layer="51"/>
<rectangle x1="-4.455" y1="3.86" x2="-4.155" y2="5.06" layer="51"/>
</package>
</packages>
</library>
<library name="v-reg">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="DPACK">
<description>&lt;b&gt;DPAK&lt;/b&gt;&lt;p&gt;
PLASTIC PACKAGE CASE 369C-01&lt;br&gt;
Source: http://www.onsemi.co.jp .. LM317M-D.PDF</description>
<wire x1="3.2766" y1="3.8354" x2="3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-2.159" x2="-3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-2.159" x2="-3.2766" y2="3.8354" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="3.835" x2="3.2774" y2="3.8346" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="3.937" x2="-2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="4.6482" x2="-2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="-2.1082" y1="5.1054" x2="2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="2.1082" y1="5.1054" x2="2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="4.6482" x2="2.5654" y2="3.937" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="3.937" x2="-2.5654" y2="3.937" width="0.2032" layer="51"/>
<smd name="4" x="0" y="2.38" dx="5.8" dy="6.2" layer="1"/>
<smd name="1" x="-2.28" y="-4.8" dx="1.6" dy="3" layer="1"/>
<smd name="3" x="2.28" y="-4.8" dx="1.6" dy="3" layer="1"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7178" y1="-5.1562" x2="-1.8542" y2="-2.2606" layer="51"/>
<rectangle x1="1.8542" y1="-5.1562" x2="2.7178" y2="-2.2606" layer="51"/>
<rectangle x1="-0.4318" y1="-3.0226" x2="0.4318" y2="-2.2606" layer="21"/>
<polygon width="0.1998" layer="51">
<vertex x="-2.5654" y="3.937"/>
<vertex x="-2.5654" y="4.6482"/>
<vertex x="-2.1082" y="5.1054"/>
<vertex x="2.1082" y="5.1054"/>
<vertex x="2.5654" y="4.6482"/>
<vertex x="2.5654" y="3.937"/>
</polygon>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="MELF-MLL41">
<description>&lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;
Package DO-213AB = http://www.diotec.com/pdf/sm4001.pdf</description>
<wire x1="2.0828" y1="1.1938" x2="-2.159" y2="1.1938" width="0.1524" layer="51"/>
<wire x1="2.0828" y1="-1.1938" x2="-2.1336" y2="-1.1938" width="0.1524" layer="51"/>
<wire x1="0.627" y1="1" x2="-0.746" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.746" y1="0" x2="0.627" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-1" x2="0.627" y2="1" width="0.2032" layer="21"/>
<wire x1="1.1208" y1="1.1938" x2="-1.097" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="1.1208" y1="-1.1938" x2="-1.0716" y2="-1.1938" width="0.1524" layer="21"/>
<smd name="C" x="-2.625" y="0" dx="2.5" dy="3" layer="1"/>
<smd name="A" x="2.625" y="0" dx="2.5" dy="3" layer="1"/>
<text x="-2.663" y="1.724" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.663" y="-2.994" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.0574" y1="-1.27" x2="2.5654" y2="1.27" layer="51"/>
<rectangle x1="-2.6162" y1="-1.27" x2="-2.1082" y2="1.27" layer="51"/>
<rectangle x1="-1.4478" y1="-1.1938" x2="-0.5588" y2="1.1938" layer="51"/>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="2,8-PAD-SQUARE">
<description>&lt;b&gt;MOUNTING PAD&lt;/b&gt; 2.8 mm, square</description>
<wire x1="-2.159" y1="0" x2="0" y2="-2.159" width="2.4892" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.159" x2="2.159" y2="0" width="2.4892" layer="51" curve="-90" cap="flat"/>
<wire x1="-3.556" y1="3.556" x2="3.556" y2="3.556" width="1.016" layer="43"/>
<wire x1="3.556" y1="3.556" x2="3.556" y2="-3.556" width="1.016" layer="43"/>
<wire x1="3.556" y1="-3.556" x2="-3.556" y2="-3.556" width="1.016" layer="43"/>
<wire x1="-3.556" y1="-3.556" x2="-3.556" y2="3.556" width="1.016" layer="43"/>
<wire x1="-3.556" y1="3.556" x2="3.556" y2="3.556" width="0.1524" layer="21"/>
<wire x1="3.556" y1="3.556" x2="3.556" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-3.556" x2="-3.556" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-3.556" x2="-3.556" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="3.556" x2="3.556" y2="3.556" width="1.016" layer="41"/>
<wire x1="3.556" y1="3.556" x2="3.556" y2="-3.556" width="1.016" layer="41"/>
<wire x1="3.556" y1="-3.556" x2="-3.556" y2="-3.556" width="1.016" layer="41"/>
<wire x1="-3.556" y1="-3.556" x2="-3.556" y2="3.556" width="1.016" layer="41"/>
<wire x1="-3.556" y1="3.556" x2="3.556" y2="3.556" width="1.016" layer="42"/>
<wire x1="3.556" y1="3.556" x2="3.556" y2="-3.556" width="1.016" layer="42"/>
<wire x1="3.556" y1="-3.556" x2="-3.556" y2="-3.556" width="1.016" layer="42"/>
<wire x1="-3.556" y1="-3.556" x2="-3.556" y2="3.556" width="1.016" layer="42"/>
<wire x1="-3.556" y1="3.556" x2="3.556" y2="3.556" width="1.016" layer="39"/>
<wire x1="3.556" y1="3.556" x2="3.556" y2="-3.556" width="1.016" layer="39"/>
<wire x1="3.556" y1="-3.556" x2="-3.556" y2="-3.556" width="1.016" layer="39"/>
<wire x1="-3.556" y1="-3.556" x2="-3.556" y2="3.556" width="1.016" layer="39"/>
<wire x1="-3.556" y1="3.556" x2="3.556" y2="3.556" width="1.016" layer="40"/>
<wire x1="3.556" y1="3.556" x2="3.556" y2="-3.556" width="1.016" layer="40"/>
<wire x1="3.556" y1="-3.556" x2="-3.556" y2="-3.556" width="1.016" layer="40"/>
<wire x1="-3.556" y1="-3.556" x2="-3.556" y2="3.556" width="1.016" layer="40"/>
<circle x="0" y="0" radius="0.762" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="1.5" width="0.2032" layer="21"/>
<pad name="B2,8" x="0" y="0" drill="2.8" diameter="5.842" shape="square"/>
</package>
</packages>
</library>
<library name="logo">
<description>&lt;b&gt;Electronic logos&lt;/b&gt;&lt;p&gt;</description>
<packages>
<package name="EAGLE-PLC-8MM">
<description>&lt;b&gt;EAGLE LOGO 8mm&lt;/b&gt;</description>
<polygon width="0.016" layer="21" spacing="1.016">
<vertex x="0.8176" y="0.0962"/>
<vertex x="0.7856" y="0.1122" curve="-59.299727"/>
<vertex x="0.7535" y="0.1603" curve="-36.272065"/>
<vertex x="0.7856" y="0.2886" curve="-25.568205"/>
<vertex x="0.8497" y="0.3527" curve="-27.67177"/>
<vertex x="0.994" y="0.4008" curve="27.788055"/>
<vertex x="1.0902" y="0.4329" curve="-11.580912"/>
<vertex x="1.1543" y="0.465" curve="48.491176"/>
<vertex x="1.2024" y="0.513" curve="64.139431"/>
<vertex x="1.1864" y="0.5932" curve="65.296882"/>
<vertex x="1.1222" y="0.6092" curve="30.070276"/>
<vertex x="1.0742" y="0.5771" curve="82.584994"/>
<vertex x="1.0742" y="0.497"/>
<vertex x="1.0421" y="0.529" curve="-62.022139"/>
<vertex x="1.0261" y="0.5932" curve="-33.267848"/>
<vertex x="1.0581" y="0.6413" curve="-26.324867"/>
<vertex x="1.1222" y="0.6734" curve="26.336683"/>
<vertex x="1.1864" y="0.7054" curve="10.549809"/>
<vertex x="1.2184" y="0.7374" curve="-10.551141"/>
<vertex x="1.2666" y="0.7856" curve="-26.294485"/>
<vertex x="1.2986" y="0.8016" curve="-7.899122"/>
<vertex x="1.491" y="0.8337" curve="20.881178"/>
<vertex x="1.6032" y="0.8658" curve="-6.414174"/>
<vertex x="1.7154" y="0.9138" curve="-17.383975"/>
<vertex x="1.7956" y="0.9298" curve="17.505549"/>
<vertex x="1.8758" y="0.9459" curve="12.916879"/>
<vertex x="2.004" y="1.01" curve="24.294116"/>
<vertex x="2.02" y="1.0261"/>
<vertex x="2.02" y="1.2666" curve="-10.8874"/>
<vertex x="2.0521" y="1.6032"/>
<vertex x="2.0521" y="2.0521"/>
<vertex x="2.02" y="2.0682" curve="-17.863642"/>
<vertex x="1.9078" y="2.1483" curve="-0.995312"/>
<vertex x="1.7956" y="2.2605" curve="0.954511"/>
<vertex x="1.6834" y="2.3727" curve="9.415246"/>
<vertex x="1.5872" y="2.4529" curve="-0.849826"/>
<vertex x="1.475" y="2.533" curve="18.795276"/>
<vertex x="1.4108" y="2.5651" curve="28.883836"/>
<vertex x="1.0742" y="2.5811" curve="12.180036"/>
<vertex x="0.6253" y="2.4369" curve="30.768704"/>
<vertex x="0.4489" y="2.2926" curve="-3.06188"/>
<vertex x="0.3046" y="2.1002" curve="9.337266"/>
<vertex x="0.2726" y="2.0521" curve="58.054486"/>
<vertex x="0.2726" y="1.9238" curve="15.61125"/>
<vertex x="0.3206" y="1.8597"/>
<vertex x="0.2565" y="1.8597" curve="-28.077742"/>
<vertex x="0.1282" y="1.8918" curve="-42.664526"/>
<vertex x="0.0321" y="2.004" curve="-30.841375"/>
<vertex x="0.016" y="2.2445" curve="-18.883124"/>
<vertex x="0.0962" y="2.4529"/>
<vertex x="0.0962" y="2.469"/>
<vertex x="0.0802" y="2.517" curve="-44.422272"/>
<vertex x="0.0962" y="2.7575" curve="-1.122304"/>
<vertex x="0.1603" y="2.8858" curve="-9.736104"/>
<vertex x="0.3206" y="3.1422" curve="-5.846414"/>
<vertex x="0.5611" y="3.4309" curve="-7.344668"/>
<vertex x="0.8978" y="3.7515"/>
<vertex x="0.8818" y="3.7034"/>
<vertex x="0.8978" y="3.7034"/>
<vertex x="1.0261" y="3.7835" curve="-10.819146"/>
<vertex x="1.2184" y="3.8798" curve="-15.571654"/>
<vertex x="1.5551" y="3.9599" curve="77.882025"/>
<vertex x="1.5711" y="3.9759" curve="17.676395"/>
<vertex x="1.5551" y="4.3126" curve="44.320363"/>
<vertex x="1.523" y="4.3607" curve="4.996701"/>
<vertex x="1.3146" y="4.489" curve="-18.081667"/>
<vertex x="1.0902" y="4.6653" curve="-13.963875"/>
<vertex x="0.8818" y="4.9539" curve="-35.920843"/>
<vertex x="0.8016" y="5.3707" curve="-20.063121"/>
<vertex x="0.9298" y="5.7875" curve="5.381596"/>
<vertex x="1.0902" y="6.1402" curve="0.75198"/>
<vertex x="1.2345" y="6.509" curve="-9.527283"/>
<vertex x="1.4589" y="6.9739" curve="7.906759"/>
<vertex x="1.5551" y="7.1663" curve="-24.14694"/>
<vertex x="1.6994" y="7.3747"/>
<vertex x="1.6674" y="7.3106" curve="16.006892"/>
<vertex x="1.6513" y="7.2625" curve="3.480082"/>
<vertex x="1.5872" y="6.8457" curve="-12.776986"/>
<vertex x="1.507" y="6.509" curve="1.180302"/>
<vertex x="1.3787" y="6.1402" curve="-2.117962"/>
<vertex x="1.2986" y="5.9158"/>
<vertex x="1.3146" y="5.9158"/>
<vertex x="1.3787" y="5.9639" curve="38.866879"/>
<vertex x="1.5711" y="6.2525" curve="-20.376265"/>
<vertex x="1.6513" y="6.4288" curve="16.138308"/>
<vertex x="1.8277" y="6.7815" curve="-13.228069"/>
<vertex x="2.0682" y="7.2946" curve="10.336798"/>
<vertex x="2.2926" y="7.7434" curve="-137.637301"/>
<vertex x="2.3086" y="7.7434" curve="-5.789837"/>
<vertex x="2.3246" y="7.6954" curve="-39.793544"/>
<vertex x="2.3086" y="7.487" curve="-41.517285"/>
<vertex x="2.2605" y="7.4389" curve="131.811139"/>
<vertex x="2.2605" y="7.4228"/>
<vertex x="2.2926" y="7.4389"/>
<vertex x="2.3246" y="7.4389"/>
<vertex x="2.3246" y="7.4228" curve="-24.17607"/>
<vertex x="2.2766" y="7.1984" curve="11.500036"/>
<vertex x="2.1964" y="6.9579" curve="-15.707877"/>
<vertex x="2.1483" y="6.8296" curve="0.173955"/>
<vertex x="2.0361" y="6.6212" curve="-0.815494"/>
<vertex x="1.9398" y="6.4449"/>
<vertex x="2.2926" y="2.7896"/>
<vertex x="0.2245" y="2.7414"/>
<vertex x="0.1603" y="2.6453"/>
<vertex x="0.1603" y="2.5651"/>
<vertex x="0.1763" y="2.517"/>
<vertex x="0.2084" y="2.501" curve="53.273252"/>
<vertex x="0.2726" y="2.501" curve="24.108136"/>
<vertex x="0.3527" y="2.5651" curve="78.5682"/>
<vertex x="0.3527" y="2.7094" curve="11.578843"/>
<vertex x="0.3206" y="2.7414"/>
<vertex x="0.5611" y="2.7414"/>
<vertex x="2.2926" y="2.7895"/>
<vertex x="2.469" y="0.7054"/>
<vertex x="2.3406" y="0.5771" curve="-22.67509"/>
<vertex x="2.2926" y="0.5451"/>
<vertex x="2.3086" y="0.497" curve="-87.370895"/>
<vertex x="2.1803" y="0.2245"/>
<vertex x="2.2285" y="0.2726" curve="90.09758"/>
<vertex x="2.2285" y="0.4489"/>
<vertex x="2.0682" y="0.4489"/>
<vertex x="2.0521" y="0.465" curve="-10.37032"/>
<vertex x="1.9719" y="0.5611" curve="88.239359"/>
<vertex x="1.8918" y="0.5771" curve="8.10195"/>
<vertex x="1.8277" y="0.529"/>
<vertex x="1.9238" y="0.465" curve="-22.679517"/>
<vertex x="2.02" y="0.3687" curve="-36.720985"/>
<vertex x="2.0682" y="0.1924" curve="-46.970633"/>
<vertex x="2.02" y="0.0962" curve="-20.364236"/>
<vertex x="1.9078" y="0.0321"/>
<vertex x="1.9719" y="0.0962" curve="90.03972"/>
<vertex x="1.9719" y="0.2405"/>
<vertex x="1.8597" y="0.2405"/>
<vertex x="1.8116" y="0.2886" curve="25.972673"/>
<vertex x="1.6834" y="0.3687" curve="38.047839"/>
<vertex x="1.539" y="0.3687" curve="29.317998"/>
<vertex x="1.491" y="0.3366" curve="9.46472"/>
<vertex x="1.4429" y="0.2726"/>
<vertex x="1.3787" y="0.2726"/>
<vertex x="1.2345" y="0.1763" curve="-0.131883"/>
<vertex x="1.1864" y="0.1443" curve="84.717527"/>
<vertex x="1.1703" y="0.0802" curve="17.152345"/>
<vertex x="1.2184" y="0.016"/>
<vertex x="1.1864" y="0.0321" curve="-36.568854"/>
<vertex x="1.1222" y="0.0962" curve="-53.54156"/>
<vertex x="1.1222" y="0.2084" curve="-20.247134"/>
<vertex x="1.2184" y="0.3366"/>
<vertex x="1.1543" y="0.3046"/>
<vertex x="0.9779" y="0.2245"/>
<vertex x="0.9619" y="0.2245"/>
<vertex x="0.9138" y="0.2726" curve="90"/>
<vertex x="0.8658" y="0.2726" curve="28.005406"/>
<vertex x="0.8176" y="0.1924" curve="33.96501"/>
</polygon>
<vertex x="1.9559" y="6.4449"/>
<vertex x="1.988" y="6.477" curve="9.535254"/>
<vertex x="2.1643" y="6.6854" curve="10.799912"/>
<vertex x="2.3406" y="6.9899" curve="-5.965907"/>
<vertex x="2.517" y="7.3266" curve="-16.048586"/>
<vertex x="2.7735" y="7.6473" curve="8.815412"/>
<vertex x="3.0942" y="8"/>
<vertex x="3.0942" y="7.9839"/>
<vertex x="3.0621" y="7.9198" curve="-6.289208"/>
<vertex x="2.8056" y="7.4709" curve="7.261198"/>
<vertex x="2.5811" y="7.0701"/>
<vertex x="2.6293" y="7.1022" curve="22.71057"/>
<vertex x="2.7414" y="7.2144" curve="-4.448251"/>
<vertex x="2.9499" y="7.503" curve="4.11136"/>
<vertex x="3.0782" y="7.6794" curve="-1.470295"/>
<vertex x="3.3667" y="8.0962" curve="0.589808"/>
<vertex x="3.6714" y="8.529" curve="-9.927428"/>
<vertex x="3.8317" y="8.7214" curve="12.260809"/>
<vertex x="3.8958" y="8.8016" curve="17.406694"/>
<vertex x="4.1362" y="9.3466" curve="-11.871574"/>
<vertex x="4.2164" y="9.555" curve="4.596018"/>
<vertex x="4.489" y="10.1482" curve="-18.310291"/>
<vertex x="4.9218" y="10.8537" curve="-98.44446"/>
<vertex x="4.9378" y="10.8537" curve="-28.135623"/>
<vertex x="4.9539" y="10.8216" curve="-25.129913"/>
<vertex x="4.9539" y="10.7094" curve="-5.371826"/>
<vertex x="4.8577" y="10.3566" curve="4.60597"/>
<vertex x="4.7454" y="9.9558" curve="-63.215004"/>
<vertex x="4.7294" y="9.9398" curve="-26.632166"/>
<vertex x="4.7134" y="9.9398" curve="100.406444"/>
<vertex x="4.6493" y="9.8918" curve="33.967796"/>
<vertex x="4.6653" y="9.8276" curve="-33.751413"/>
<vertex x="4.6814" y="9.7635" curve="-10.737517"/>
<vertex x="4.6653" y="9.6513" curve="8.155543"/>
<vertex x="4.6333" y="9.4589" curve="10.731697"/>
<vertex x="4.6333" y="9.2826"/>
<vertex x="4.6493" y="9.2826"/>
<vertex x="4.6814" y="9.2986" curve="20.734317"/>
<vertex x="4.8738" y="9.4429" curve="-4.484283"/>
<vertex x="5.0982" y="9.6673" curve="-15.526853"/>
<vertex x="5.2585" y="9.7795" curve="16.614976"/>
<vertex x="5.3707" y="9.8597" curve="-8.729444"/>
<vertex x="5.6433" y="10.0842" curve="10.249671"/>
<vertex x="5.8517" y="10.2605" curve="-11.104189"/>
<vertex x="6.1402" y="10.501" curve="7.787705"/>
<vertex x="6.3647" y="10.6773" curve="-22.138063"/>
<vertex x="6.525" y="10.7735" curve="-11.794013"/>
<vertex x="6.5891" y="10.7895" curve="-16.295981"/>
<vertex x="6.6212" y="10.7895" curve="-74.952359"/>
<vertex x="6.6373" y="10.7735" curve="-68.325313"/>
<vertex x="6.6212" y="10.7414"/>
<vertex x="6.509" y="10.6132" curve="15.061366"/>
<vertex x="6.4449" y="10.517" curve="-45.414772"/>
<vertex x="6.3166" y="10.4048" curve="36.816342"/>
<vertex x="6.2525" y="10.3566" curve="-14.605048"/>
<vertex x="6.1082" y="10.1963" curve="16.245916"/>
<vertex x="5.996" y="10.0681" curve="-31.540686"/>
<vertex x="5.8677" y="9.9558" curve="27.739933"/>
<vertex x="5.6914" y="9.8116" curve="32.56552"/>
<vertex x="5.6433" y="9.6834" curve="-81.454438"/>
<vertex x="5.6272" y="9.6673" curve="10.471524"/>
<vertex x="5.531" y="9.6513" curve="150.758252"/>
<vertex x="5.531" y="9.6352" curve="-44.763967"/>
<vertex x="5.5952" y="9.5871" curve="-84.166848"/>
<vertex x="5.5791" y="9.507" curve="16.860336"/>
<vertex x="5.483" y="9.4108" curve="-2.605998"/>
<vertex x="5.3707" y="9.2665" curve="78.377572"/>
<vertex x="5.3707" y="9.2184" curve="101.557396"/>
<vertex x="5.4349" y="9.2184" curve="-11.625252"/>
<vertex x="5.483" y="9.2665" curve="-3.571145"/>
<vertex x="5.7555" y="9.4749" curve="1.290415"/>
<vertex x="5.996" y="9.6513" curve="-0.073242"/>
<vertex x="6.3166" y="9.8918" curve="-20.515728"/>
<vertex x="6.3807" y="9.9238" curve="-32.729836"/>
<vertex x="6.4288" y="9.9238" curve="-57.742036"/>
<vertex x="6.4449" y="9.9078" curve="94.640556"/>
<vertex x="6.477" y="9.8918" curve="11.615898"/>
<vertex x="6.509" y="9.9078" curve="8.952575"/>
<vertex x="6.5731" y="9.9558" curve="-6.907085"/>
<vertex x="6.7174" y="10.0681" curve="-12.700753"/>
<vertex x="6.9579" y="10.1963" curve="-2.272613"/>
<vertex x="7.0862" y="10.2445" curve="-129.460723"/>
<vertex x="7.1022" y="10.2284" curve="2.589229"/>
<vertex x="7.0862" y="10.1803" curve="-36.829089"/>
<vertex x="7.006" y="10.0681" curve="11.133736"/>
<vertex x="6.8617" y="9.9398" curve="11.899739"/>
<vertex x="6.7174" y="9.7474" curve="-28.182306"/>
<vertex x="6.6373" y="9.6673" curve="64.883635"/>
<vertex x="6.6212" y="9.6352" curve="-100.954737"/>
<vertex x="6.6052" y="9.6192" curve="47.778041"/>
<vertex x="6.5571" y="9.6032" curve="12.208517"/>
<vertex x="6.4288" y="9.4589" curve="27.544495"/>
<vertex x="6.3968" y="9.3787" curve="-37.121826"/>
<vertex x="6.3647" y="9.3146" curve="0.230103"/>
<vertex x="6.2846" y="9.2344" curve="-22.90748"/>
<vertex x="6.2365" y="9.2024" curve="29.390331"/>
<vertex x="6.1723" y="9.1542" curve="14.896396"/>
<vertex x="6.1242" y="9.0741" curve="-24.086818"/>
<vertex x="6.0441" y="8.9619" curve="-9.069485"/>
<vertex x="5.8998" y="8.8497" curve="5.377967"/>
<vertex x="5.7234" y="8.7214" curve="12.55382"/>
<vertex x="5.6272" y="8.6252" curve="27.898883"/>
<vertex x="5.531" y="8.4168" curve="111.9613"/>
<vertex x="5.547" y="8.4008" curve="15.193441"/>
<vertex x="5.5952" y="8.4168" curve="1.203909"/>
<vertex x="5.7234" y="8.481" curve="-7.975621"/>
<vertex x="6.0601" y="8.6252" curve="9.518893"/>
<vertex x="6.493" y="8.8176" curve="-4.315679"/>
<vertex x="6.9098" y="9.026" curve="-6.493373"/>
<vertex x="7.4068" y="9.2184"/>
<vertex x="7.3907" y="9.1542" curve="-8.723707"/>
<vertex x="7.3426" y="9.01" curve="-44.404917"/>
<vertex x="7.2625" y="8.9298" curve="21.826703"/>
<vertex x="7.1182" y="8.8336" curve="-11.965719"/>
<vertex x="7.0381" y="8.7695" curve="10.423471"/>
<vertex x="6.8938" y="8.6573" curve="-14.106571"/>
<vertex x="6.7174" y="8.529" curve="9.440453"/>
<vertex x="6.5731" y="8.4328" curve="-1.128732"/>
<vertex x="6.4288" y="8.3206" curve="2.770026"/>
<vertex x="6.3486" y="8.2565" curve="-22.900757"/>
<vertex x="6.1723" y="8.1603" curve="2.594713"/>
<vertex x="6.028" y="8.1122" curve="13.590201"/>
<vertex x="5.8998" y="8.0481" curve="23.310508"/>
<vertex x="5.8196" y="7.9679" curve="89.430606"/>
<vertex x="5.8357" y="7.8878" curve="30.956334"/>
<vertex x="5.8838" y="7.8717" curve="9.364064"/>
<vertex x="6.4449" y="7.8878" curve="-12.648762"/>
<vertex x="6.9739" y="7.8878" curve="-12.424167"/>
<vertex x="7.4068" y="7.7915"/>
<vertex x="7.4068" y="7.7755" curve="-36.917604"/>
<vertex x="7.3907" y="7.7274" curve="-32.266075"/>
<vertex x="7.3266" y="7.6794" curve="-16.407639"/>
<vertex x="7.1823" y="7.6473" curve="13.960179"/>
<vertex x="7.022" y="7.6152" curve="0.304311"/>
<vertex x="6.9258" y="7.5831" curve="-14.572781"/>
<vertex x="6.7655" y="7.551" curve="14.521218"/>
<vertex x="6.6052" y="7.519" curve="-18.105047"/>
<vertex x="6.509" y="7.503" curve="-0.85735"/>
<vertex x="6.3326" y="7.503" curve="89.821786"/>
<vertex x="6.3006" y="7.4709" curve="53.41802"/>
<vertex x="6.3166" y="7.4389" curve="32.043165"/>
<vertex x="6.4449" y="7.3907" curve="-9.751781"/>
<vertex x="6.6373" y="7.3587" curve="-14.97858"/>
<vertex x="6.7174" y="7.3266" curve="-84.547378"/>
<vertex x="6.7334" y="7.2786" curve="-42.296717"/>
<vertex x="6.6854" y="7.2304" curve="25.836696"/>
<vertex x="6.6212" y="7.1823" curve="-53.150536"/>
<vertex x="6.509" y="7.1342" curve="-0.351173"/>
<vertex x="6.2525" y="7.1502" curve="-1.333315"/>
<vertex x="6.0441" y="7.1663" curve="10.149663"/>
<vertex x="5.9478" y="7.1663" curve="102.506276"/>
<vertex x="5.9158" y="7.1182" curve="54.746721"/>
<vertex x="5.9639" y="7.0701" curve="1.955175"/>
<vertex x="6.2846" y="6.9739" curve="-26.697454"/>
<vertex x="6.4288" y="6.8938" curve="11.13493"/>
<vertex x="6.5571" y="6.7976" curve="-1.456873"/>
<vertex x="6.6854" y="6.7174" curve="-33.33956"/>
<vertex x="6.7815" y="6.6052" curve="-84.612098"/>
<vertex x="6.7494" y="6.509" curve="-21.618861"/>
<vertex x="6.7014" y="6.493" curve="74.387198"/>
<vertex x="6.6693" y="6.4609" curve="52.610737"/>
<vertex x="6.6854" y="6.4128" curve="-36.551294"/>
<vertex x="6.7174" y="6.3486" curve="-106.260205"/>
<vertex x="6.7014" y="6.3326" curve="31.078962"/>
<vertex x="6.5731" y="6.3166" curve="-4.13513"/>
<vertex x="6.4449" y="6.2685" curve="34.010186"/>
<vertex x="6.3326" y="6.1883" curve="74.871742"/>
<vertex x="6.3326" y="6.1563" curve="-74.810713"/>
<vertex x="6.3326" y="6.0601" curve="111.74472"/>
<vertex x="6.3486" y="6.012" curve="-35.839447"/>
<vertex x="6.4449" y="5.9478" curve="-39.907111"/>
<vertex x="6.477" y="5.8517" curve="55.820603"/>
<vertex x="6.493" y="5.8196" curve="-80.737896"/>
<vertex x="6.509" y="5.7555" curve="-24.539881"/>
<vertex x="6.4449" y="5.6754" curve="24.460106"/>
<vertex x="6.3807" y="5.5952" curve="71.797988"/>
<vertex x="6.3968" y="5.499" curve="52.470725"/>
<vertex x="6.4449" y="5.483" curve="-15.727514"/>
<vertex x="6.5731" y="5.483" curve="-51.871929"/>
<vertex x="6.6212" y="5.4509" curve="-60.53878"/>
<vertex x="6.6212" y="5.4188" curve="-29.224049"/>
<vertex x="6.5731" y="5.3707" curve="6.652479"/>
<vertex x="6.477" y="5.3066" curve="86.928731"/>
<vertex x="6.4609" y="5.2104" curve="22.083517"/>
<vertex x="6.493" y="5.1783" curve="14.783491"/>
<vertex x="6.5571" y="5.1462" curve="-51.732714"/>
<vertex x="6.5891" y="5.1142" curve="-128.021533"/>
<vertex x="6.5731" y="5.0982"/>
<vertex x="6.4288" y="5.0822" curve="-12.651396"/>
<vertex x="6.3326" y="5.0822" curve="65.95794"/>
<vertex x="6.2365" y="5.0341" curve="83.535813"/>
<vertex x="6.2525" y="4.9539" curve="30.254833"/>
<vertex x="6.3326" y="4.9218" curve="-39.666127"/>
<vertex x="6.3647" y="4.9058" curve="-86.866058"/>
<vertex x="6.3647" y="4.8738" curve="-39.91929"/>
<vertex x="6.3006" y="4.8417" curve="33.117156"/>
<vertex x="6.1883" y="4.7936" curve="10.643659"/>
<vertex x="6.1563" y="4.7615" curve="78.914016"/>
<vertex x="6.1563" y="4.7294" curve="47.689798"/>
<vertex x="6.1883" y="4.7134" curve="-47.862442"/>
<vertex x="6.3166" y="4.6493"/>
<vertex x="6.1883" y="4.6172" curve="32.451143"/>
<vertex x="5.996" y="4.505" curve="139.517095"/>
<vertex x="6.012" y="4.473" curve="-12.998286"/>
<vertex x="6.0922" y="4.473"/>
<vertex x="5.996" y="4.4248"/>
<vertex x="6.1082" y="4.4088"/>
<vertex x="5.9158" y="4.3286" curve="22.09463"/>
<vertex x="5.7715" y="4.2325" curve="31.04676"/>
<vertex x="5.7074" y="4.1202" curve="65.346812"/>
<vertex x="5.7394" y="4.024" curve="41.072964"/>
<vertex x="5.7875" y="4.008" curve="23.736941"/>
<vertex x="5.9799" y="4.0561"/>
<vertex x="5.8998" y="4.008" curve="-21.917512"/>
<vertex x="5.7234" y="3.9438"/>
<vertex x="5.8036" y="3.9278" curve="15.859961"/>
<vertex x="6.0762" y="3.9118"/>
<vertex x="5.9639" y="3.8958" curve="-9.164493"/>
<vertex x="5.7074" y="3.8798" curve="2.028671"/>
<vertex x="5.2746" y="3.8798" curve="4.723927"/>
<vertex x="5.002" y="3.8637"/>
<vertex x="5.0982" y="3.7996"/>
<vertex x="4.9859" y="3.8156" curve="24.990515"/>
<vertex x="4.7775" y="3.7996" curve="66.654078"/>
<vertex x="4.6974" y="3.7034" curve="102.680383"/>
<vertex x="4.7134" y="3.6874" curve="-23.675738"/>
<vertex x="4.8898" y="3.6714" curve="-145.494696"/>
<vertex x="4.8898" y="3.6553" curve="-9.059381"/>
<vertex x="4.7454" y="3.6232" curve="73.057711"/>
<vertex x="4.7294" y="3.6072" curve="107.182451"/>
<vertex x="4.7454" y="3.5912" curve="-196.957104"/>
<vertex x="4.7454" y="3.5751" curve="16.915687"/>
<vertex x="4.7294" y="3.5751" curve="-2.678135"/>
<vertex x="4.6012" y="3.5591" curve="76.289762"/>
<vertex x="4.5851" y="3.543" curve="103.905915"/>
<vertex x="4.6012" y="3.527" curve="-42.181249"/>
<vertex x="4.6653" y="3.511"/>
<vertex x="4.5851" y="3.495" curve="30.409489"/>
<vertex x="4.4569" y="3.4309"/>
<vertex x="2.2124" y="3.4148"/>
</polygon>
<vertex x="2.2285" y="3.4148"/>
<vertex x="4.473" y="3.4309" curve="5.358163"/>
<vertex x="5.0661" y="3.4629" curve="6.655059"/>
<vertex x="5.4669" y="3.527" curve="-10.592709"/>
<vertex x="5.7234" y="3.5591" curve="16.367678"/>
<vertex x="5.996" y="3.6072" curve="0.52066"/>
<vertex x="6.1883" y="3.6714" curve="3.331047"/>
<vertex x="6.7494" y="3.8798" curve="-16.008303"/>
<vertex x="7.0701" y="3.9599"/>
<vertex x="6.5571" y="3.6393"/>
<vertex x="6.5891" y="3.6393"/>
<vertex x="6.7976" y="3.7354" curve="5.590685"/>
<vertex x="7.1663" y="3.9278" curve="-23.800087"/>
<vertex x="7.2625" y="3.9599" curve="-27.369826"/>
<vertex x="7.3907" y="3.9438" curve="-25.547953"/>
<vertex x="7.4389" y="3.9118"/>
<vertex x="7.2786" y="3.7354"/>
<vertex x="7.3587" y="3.7515"/>
<vertex x="7.4228" y="3.7515"/>
<vertex x="7.4068" y="3.7194" curve="-36.980188"/>
<vertex x="7.1984" y="3.511" curve="126.869898"/>
<vertex x="7.1984" y="3.495"/>
<vertex x="7.2304" y="3.495" curve="14.244537"/>
<vertex x="7.6152" y="3.543"/>
<vertex x="7.5992" y="3.479" curve="-51.511359"/>
<vertex x="7.519" y="3.3827" curve="12.987704"/>
<vertex x="7.4389" y="3.3346" curve="105.122857"/>
<vertex x="7.4389" y="3.2706" curve="21.696079"/>
<vertex x="7.503" y="3.2385" curve="23.846295"/>
<vertex x="7.7434" y="3.2224" curve="-1.900869"/>
<vertex x="7.8717" y="3.2385" curve="-100.880664"/>
<vertex x="7.8878" y="3.2224" curve="-48.921158"/>
<vertex x="7.7595" y="2.998" curve="108.454734"/>
<vertex x="7.7595" y="2.9819" curve="-18.284892"/>
<vertex x="7.8236" y="2.9178"/>
<vertex x="7.7434" y="2.8537"/>
<vertex x="7.7595" y="2.8537" curve="-49.543844"/>
<vertex x="7.9679" y="2.7575"/>
<vertex x="7.7755" y="2.7254" curve="-14.168038"/>
<vertex x="7.3907" y="2.7094"/>
<vertex x="7.4709" y="2.6293"/>
<vertex x="7.1182" y="2.6453" curve="17.209879"/>
<vertex x="6.8136" y="2.6132" curve="-10.340267"/>
<vertex x="6.7174" y="2.5972" curve="-3.342915"/>
<vertex x="6.012" y="2.5651" curve="-1.864592"/>
<vertex x="5.7875" y="2.5651"/>
<vertex x="5.8036" y="2.517" curve="16.102128"/>
<vertex x="5.8517" y="2.4208" curve="-1.769258"/>
<vertex x="5.8838" y="2.3727"/>
<vertex x="5.7394" y="2.4048" curve="-9.155542"/>
<vertex x="5.531" y="2.469" curve="29.158449"/>
<vertex x="5.2746" y="2.501" curve="35.966365"/>
<vertex x="4.9378" y="2.3406"/>
<vertex x="5.0341" y="2.2926" curve="-25.488415"/>
<vertex x="5.3867" y="2.004"/>
<vertex x="5.2906" y="2.0361"/>
<vertex x="5.3707" y="1.9398"/>
<vertex x="5.3226" y="1.9398" curve="-28.146288"/>
<vertex x="5.2585" y="1.9559" curve="24.377603"/>
<vertex x="5.1462" y="1.988"/>
<vertex x="5.1623" y="1.9398"/>
<vertex x="5.0822" y="1.9559" curve="-5.400585"/>
<vertex x="4.9539" y="1.988" curve="20.094582"/>
<vertex x="4.6814" y="2.02"/>
<vertex x="4.7936" y="1.9559" curve="-23.836481"/>
<vertex x="4.9378" y="1.8277"/>
<vertex x="4.7454" y="1.8918"/>
<vertex x="4.8096" y="1.8116"/>
<vertex x="4.8417" y="1.7635"/>
<vertex x="4.6653" y="1.7956" curve="2.671556"/>
<vertex x="4.3607" y="1.8437" curve="40.33344"/>
<vertex x="4.2164" y="1.8116" curve="73.429858"/>
<vertex x="4.1683" y="1.6834" curve="-78.724523"/>
<vertex x="4.1202" y="1.5711" curve="-26.848408"/>
<vertex x="3.9278" y="1.523"/>
<vertex x="4.024" y="1.3306"/>
<vertex x="3.8317" y="1.2826"/>
<vertex x="3.8317" y="1.1864"/>
<vertex x="3.7354" y="1.1864"/>
<vertex x="3.7835" y="1.1222"/>
<vertex x="3.5751" y="1.1543" curve="6.075652"/>
<vertex x="3.2545" y="1.1864" curve="95.594487"/>
<vertex x="3.2385" y="1.1703" curve="-5.984397"/>
<vertex x="3.2385" y="1.1222" curve="5.978463"/>
<vertex x="3.2385" y="1.0902" curve="-42.859306"/>
<vertex x="3.2064" y="0.994" curve="-10.176736"/>
<vertex x="3.1743" y="0.9619"/>
<vertex x="3.2706" y="0.8818"/>
<vertex x="3.1743" y="0.8497"/>
<vertex x="3.2224" y="0.8016"/>
<vertex x="3.0942" y="0.7856"/>
<vertex x="3.0621" y="0.7695"/>
<vertex x="3.1743" y="0.7214"/>
<vertex x="3.0942" y="0.7054"/>
<vertex x="2.9659" y="0.6894"/>
<vertex x="2.9338" y="0.6734"/>
<vertex x="2.9659" y="0.6092"/>
<vertex x="2.8537" y="0.6253"/>
<vertex x="2.8698" y="0.5932"/>
<vertex x="2.9659" y="0.513"/>
<vertex x="2.8698" y="0.529" curve="-24.703609"/>
<vertex x="2.5491" y="0.6573" curve="-9.048404"/>
<vertex x="2.469" y="0.7214"/>
</polygon>
<vertex x="0.1763" y="2.6774" curve="-14.439828"/>
<vertex x="0.2084" y="2.7254" curve="-54.505369"/>
<vertex x="0.2886" y="2.7575" curve="-51.008789"/>
<vertex x="0.3687" y="2.7094" curve="-52.792704"/>
<vertex x="0.3848" y="2.5811" curve="-51.43853"/>
<vertex x="0.3046" y="2.501" curve="-38.557826"/>
<vertex x="0.1763" y="2.501" curve="-51.59673"/>
<vertex x="0.1443" y="2.533" curve="-38.200579"/>
<vertex x="0.1443" y="2.6132" curve="-142.059184"/>
<vertex x="0.1763" y="2.6132" curve="-37.933958"/>
<vertex x="0.1763" y="2.5811" curve="37.972884"/>
<vertex x="0.1763" y="2.533" curve="52.288564"/>
<vertex x="0.1924" y="2.517" curve="37.303407"/>
<vertex x="0.2726" y="2.517" curve="39.995472"/>
<vertex x="0.3527" y="2.5811" curve="40.159001"/>
<vertex x="0.3687" y="2.6613" curve="56.100468"/>
<vertex x="0.3206" y="2.7254" curve="50.189602"/>
<vertex x="0.2245" y="2.7254" curve="76.231442"/>
<vertex x="0.2054" y="2.6919" curve="66.751209"/>
<vertex x="0.2282" y="2.6641" curve="23.432557"/>
<vertex x="0.2501" y="2.6623" curve="-76.539032"/>
<vertex x="0.2856" y="2.6457" curve="-87.52005"/>
<vertex x="0.262" y="2.5666" curve="-90"/>
<vertex x="0.2088" y="2.5698" curve="129.004897"/>
<vertex x="0.1763" y="2.5651"/>
<vertex x="0.1936" y="2.5991" curve="32.779081"/>
<vertex x="0.2084" y="2.5811" curve="90.358471"/>
<vertex x="0.2565" y="2.5811" curve="89.762751"/>
<vertex x="0.2565" y="2.6293" curve="37.085972"/>
<vertex x="0.2245" y="2.6453" curve="104.747533"/>
<vertex x="0.1909" y="2.6132"/>
<vertex x="0.1924" y="2.5972"/>
</polygon>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="12mil"/>
<param name="tpViaShape" value="octagon"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="*"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="VOL+" library="switch-omron" package="B3F-10XX" value="" x="59.69" y="35.56" rot="R180">
<attribute name="OC_NEWARK" value="36M3542" x="29.21" y="67.31" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="B3F-1000" x="29.21" y="67.31" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="29.21" y="67.31" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="176432" x="29.21" y="67.31" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="VOL-" library="switch-omron" package="B3F-10XX" value="" x="83.82" y="35.56" rot="R180">
<attribute name="OC_NEWARK" value="36M3542" x="41.91" y="67.31" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="B3F-1000" x="41.91" y="67.31" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="41.91" y="67.31" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="176432" x="41.91" y="67.31" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="MODE" library="switch-omron" package="B3F-10XX" value="" x="71.12" y="49.53" rot="R180">
<attribute name="OC_NEWARK" value="36M3542" x="8.89" y="68.58" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="B3F-1000" x="8.89" y="68.58" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="8.89" y="68.58" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="176432" x="8.89" y="68.58" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="MUTTE" library="switch-omron" package="B3F-10XX" value="" x="71.12" y="24.13">
<attribute name="OC_NEWARK" value="36M3542" x="90.17" y="-7.62" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="B3F-1000" x="90.17" y="-7.62" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="90.17" y="-7.62" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="176432" x="90.17" y="-7.62" size="1.778" layer="27" display="off"/>
</element>
<element name="LED1" library="led" package="LED3MM" value="" x="57.15" y="50.8" rot="R270"/>
<element name="LED2" library="led" package="LED3MM" value="" x="50.8" y="50.8" rot="R270"/>
<element name="LED3" library="led" package="LED3MM" value="" x="44.45" y="50.8" rot="R270"/>
<element name="LED4" library="led" package="LED3MM" value="" x="38.1" y="50.8" rot="R270"/>
<element name="LED5" library="led" package="LED3MM" value="" x="31.75" y="50.8" rot="R270"/>
<element name="LED6" library="led" package="LED3MM" value="" x="59.69" y="25.4"/>
<element name="C4" library="rcl" package="C1206" value="100nF" x="39.37" y="40.64" rot="R180"/>
<element name="R1" library="rcl" package="M1206" value="330 ohm" x="55.88" y="21.59" rot="R180"/>
<element name="R2" library="rcl" package="M1206" value="330 ohm" x="57.15" y="57.15" rot="R90"/>
<element name="R3" library="rcl" package="M1206" value="330 ohm" x="50.8" y="57.15" rot="R90"/>
<element name="R4" library="rcl" package="M1206" value="330 ohm" x="44.45" y="57.15" rot="R90"/>
<element name="R5" library="rcl" package="M1206" value="330 ohm" x="38.1" y="57.15" rot="R90"/>
<element name="R6" library="rcl" package="M1206" value="330 ohm" x="31.75" y="57.15" rot="R90"/>
<element name="C3" library="rcl" package="SMC_C" value="4,7uF" x="39.37" y="27.94" rot="R90"/>
<element name="C1" library="rcl" package="SMC_C" value="1uF" x="50.8" y="39.37" rot="R270"/>
<element name="INPUT" library="con-amp-quick" package="03P" value="" x="48.26" y="5.08">
<attribute name="OC_NEWARK" value="unknown" x="119.38" y="-25.4" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="119.38" y="-25.4" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="119.38" y="-25.4" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="119.38" y="-25.4" size="1.778" layer="27" display="off"/>
</element>
<element name="C5" library="rcl" package="C1206" value="100nF" x="50.8" y="12.7" rot="R180"/>
<element name="C6" library="rcl" package="C1206" value="100nF" x="52.07" y="17.78" rot="R180"/>
<element name="C7" library="rcl" package="UD-8X10_NICHICON" value="470uF" x="31.75" y="30.48"/>
<element name="C8" library="rcl" package="SMC_D" value="10uF" x="49.53" y="26.67" rot="R180"/>
<element name="R7" library="rcl" package="M1206" value="22Ko" x="45.72" y="19.05"/>
<element name="R8" library="rcl" package="M1206" value="56Ko" x="44.45" y="12.7" rot="R180"/>
<element name="OUT1" library="con-amp-quick" package="02P" value="" x="39.37" y="5.08" smashed="yes" rot="MR0">
<attribute name="OC_NEWARK" value="unknown" x="16.51" y="-35.56" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="MPN" value="" x="16.51" y="-35.56" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="MF" value="" x="16.51" y="-35.56" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="16.51" y="-35.56" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="NAME" x="37.846" y="8.0264" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="41.656" y="1.2446" size="1.27" layer="28" ratio="10" rot="MR0"/>
</element>
<element name="OUT2" library="con-amp-quick" package="02P" value="" x="31.75" y="5.08">
<attribute name="OC_NEWARK" value="unknown" x="60.96" y="-35.56" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="60.96" y="-35.56" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="60.96" y="-35.56" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="60.96" y="-35.56" size="1.778" layer="27" display="off"/>
</element>
<element name="U$1" library="micro-philips" package="TSSOP24" value="" x="30.48" y="40.64">
<attribute name="IC1" value="" x="91.44" y="8.89" size="1.778" layer="27" display="off"/>
<attribute name="AUDIOPOTENCIMETER" value="MAX5468" x="91.44" y="8.89" size="1.778" layer="27" display="off"/>
</element>
<element name="IC1" library="v-reg" package="DPACK" value="LM317MDT" x="18.415" y="18.415" rot="R270"/>
<element name="LED7" library="led" package="LED3MM" value="" x="11.43" y="3.81" rot="R180"/>
<element name="R9" library="rcl" package="M1206" value="470 Ohm" x="22.225" y="32.385" smashed="yes" rot="R180">
<attribute name="NAME" x="24.765" y="31.115" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="25.4" y="35.56" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R10" library="rcl" package="M1206" value="2,7 Ko" x="15.875" y="32.385" rot="R180"/>
<element name="C11" library="rcl" package="C1206" value="100nF" x="17.78" y="10.16"/>
<element name="C12" library="rcl" package="C1206" value="100nF" x="4.445" y="31.115"/>
<element name="C13" library="rcl" package="UD-5X5,8_NICHICON" value="10uF" x="12.7" y="26.67"/>
<element name="D1" library="diode" package="MELF-MLL41" value="1N4007" x="24.13" y="6.35" rot="R90"/>
<element name="D2" library="diode" package="MELF-MLL41" value="1n4007" x="20.32" y="26.67"/>
<element name="BE12V" library="con-amp-quick" package="02P" value="" x="17.78" y="5.08" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="1.27" y="45.72" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="1.27" y="45.72" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="1.27" y="45.72" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="1.27" y="45.72" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="R11" library="rcl" package="M1206" value="1Ko" x="11.43" y="8.89"/>
<element name="C16" library="rcl" package="UD-8X10_NICHICON" value="100uF" x="5.08" y="15.24"/>
<element name="C17" library="rcl" package="UD-6,3X5,8_NICHICON" value="47uF" x="4.445" y="24.765" rot="R180"/>
<element name="C9" library="rcl" package="SMC_C" value="4,7uF" x="44.45" y="34.29" rot="R90"/>
<element name="D3" library="diode" package="MELF-MLL41" value="1N4007" x="21.59" y="50.8" rot="R180"/>
<element name="IC2" library="v-reg" package="DPACK" value="LM317MDT" x="17.78" y="43.18" rot="R270"/>
<element name="R12" library="rcl" package="M1206" value="470 Ohm" x="2.54" y="55.88" rot="R270"/>
<element name="R13" library="rcl" package="M1206" value="2,7 Ko" x="7.62" y="55.88" rot="R270"/>
<element name="C2" library="rcl" package="C1206" value="100nF" x="13.97" y="57.15" rot="R180"/>
<element name="C10" library="rcl" package="UD-6,3X5,8_NICHICON" value="47uF" x="5.08" y="47.625" smashed="yes">
<attribute name="NAME" x="1.905" y="51.435" size="1.016" layer="25"/>
<attribute name="VALUE" x="5.715" y="43.18" size="1.016" layer="27"/>
</element>
<element name="D4" library="diode" package="MELF-MLL41" value="1n4007" x="21.59" y="57.15" rot="R180"/>
<element name="C14" library="rcl" package="UD-5X5,8_NICHICON" value="10uF" x="12.7" y="50.8"/>
<element name="C15" library="rcl" package="C1206" value="100nF" x="13.97" y="36.83" rot="R180"/>
<element name="C18" library="rcl" package="UD-8X10_NICHICON" value="100uF" x="5.08" y="38.1"/>
<element name="H1" library="holes" package="2,8-PAD-SQUARE" value="MOUNT-PAD-SQUARE2.8" x="3.81" y="5.08"/>
<element name="H2" library="holes" package="2,8-PAD-SQUARE" value="MOUNT-PAD-SQUARE2.8" x="3.81" y="63.5"/>
<element name="H3" library="holes" package="2,8-PAD-SQUARE" value="MOUNT-PAD-SQUARE2.8" x="84.455" y="5.08"/>
<element name="H4" library="holes" package="2,8-PAD-SQUARE" value="MOUNT-PAD-SQUARE2.8" x="84.455" y="63.5"/>
<element name="U$4" library="logo" package="EAGLE-PLC-8MM" value="" x="64.77" y="7.62"/>
<element name="U$2" library="micro-philips" package="SSOP24" value="" x="35.56" y="17.78"/>
</elements>
<signals>
<signal name="MAX5486">
<contactref element="R6" pad="2"/>
<contactref element="R5" pad="2"/>
<contactref element="R4" pad="2"/>
<contactref element="R3" pad="2"/>
<contactref element="R2" pad="2"/>
<contactref element="C4" pad="1"/>
<contactref element="R1" pad="2"/>
<contactref element="U$1" pad="1"/>
<contactref element="U$1" pad="6"/>
<contactref element="U$1" pad="13"/>
<contactref element="U$1" pad="24"/>
<contactref element="IC2" pad="4"/>
<contactref element="R12" pad="1"/>
<contactref element="D4" pad="C"/>
<contactref element="C2" pad="1"/>
<contactref element="C10" pad="+"/>
<contactref element="D3" pad="A"/>
<wire x1="57.3024" y1="24.384" x2="54.5592" y2="21.6408" width="0.254" layer="1"/>
<wire x1="57.3024" y1="31.6992" x2="57.3024" y2="24.384" width="0.254" layer="1"/>
<wire x1="59.1312" y1="33.528" x2="57.3024" y2="31.6992" width="0.254" layer="1"/>
<wire x1="59.1312" y1="56.6928" x2="59.1312" y2="33.528" width="0.254" layer="1"/>
<wire x1="57.3024" y1="58.5216" x2="59.1312" y2="56.6928" width="0.254" layer="1"/>
<wire x1="54.5592" y1="21.6408" x2="54.48" y2="21.59" width="0.254" layer="1"/>
<wire x1="57.3024" y1="58.5216" x2="57.15" y2="58.55" width="0.254" layer="1"/>
<wire x1="11.8872" y1="43.2816" x2="7.62" y2="47.5488" width="0.254" layer="1"/>
<wire x1="20.1168" y1="43.2816" x2="19.2024" y2="43.2816" width="0.254" layer="1"/>
<wire x1="19.2024" y1="43.2816" x2="11.8872" y2="43.2816" width="0.254" layer="1"/>
<wire x1="7.62" y1="47.5488" x2="7.43" y2="47.625" width="0.254" layer="1"/>
<wire x1="20.1168" y1="43.2816" x2="20.16" y2="43.18" width="0.254" layer="1"/>
<wire x1="19.2024" y1="43.2816" x2="19.2024" y2="50.5968" width="0.254" layer="1"/>
<wire x1="19.2024" y1="50.5968" x2="18.965" y2="50.8" width="0.254" layer="1"/>
<wire x1="19.2024" y1="43.2816" x2="20.16" y2="43.18" width="0.254" layer="1"/>
<wire x1="17.3736" y1="59.1312" x2="15.5448" y2="57.3024" width="0.254" layer="1"/>
<wire x1="24.0792" y1="59.1312" x2="17.3736" y2="59.1312" width="0.254" layer="1"/>
<wire x1="24.0792" y1="57.3024" x2="24.0792" y2="59.1312" width="0.254" layer="1"/>
<wire x1="15.5448" y1="57.3024" x2="15.37" y2="57.15" width="0.254" layer="1"/>
<wire x1="24.0792" y1="57.3024" x2="24.215" y2="57.15" width="0.254" layer="1"/>
<wire x1="6.096" y1="57.3024" x2="2.7432" y2="57.3024" width="0.254" layer="1"/>
<wire x1="6.096" y1="58.2168" x2="6.096" y2="57.3024" width="0.254" layer="1"/>
<wire x1="7.0104" y1="59.1312" x2="6.096" y2="58.2168" width="0.254" layer="1"/>
<wire x1="15.24" y1="59.1312" x2="7.0104" y2="59.1312" width="0.254" layer="1"/>
<wire x1="15.24" y1="57.3024" x2="15.24" y2="59.1312" width="0.254" layer="1"/>
<wire x1="2.7432" y1="57.3024" x2="2.54" y2="57.28" width="0.254" layer="1"/>
<wire x1="15.24" y1="57.3024" x2="15.37" y2="57.15" width="0.254" layer="1"/>
<wire x1="26.8224" y1="43.2816" x2="26.8224" y2="39.3192" width="0.254" layer="1"/>
<wire x1="26.8224" y1="39.3192" x2="26.8224" y2="37.7952" width="0.254" layer="1"/>
<wire x1="26.8224" y1="37.7952" x2="26.905" y2="37.7222" width="0.254" layer="1"/>
<wire x1="26.8224" y1="43.2816" x2="26.905" y2="43.5578" width="0.254" layer="1"/>
<wire x1="30.1752" y1="39.3192" x2="30.1752" y2="37.7952" width="0.254" layer="1"/>
<wire x1="26.8224" y1="39.3192" x2="30.1752" y2="39.3192" width="0.254" layer="16"/>
<wire x1="30.1752" y1="37.7952" x2="30.155" y2="37.7222" width="0.254" layer="1"/>
<wire x1="39.3192" y1="42.0624" x2="40.5384" y2="40.8432" width="0.254" layer="1"/>
<wire x1="32.9184" y1="42.0624" x2="39.3192" y2="42.0624" width="0.254" layer="16"/>
<wire x1="30.1752" y1="39.3192" x2="32.9184" y2="42.0624" width="0.254" layer="16"/>
<wire x1="40.5384" y1="40.8432" x2="40.77" y2="40.64" width="0.254" layer="1"/>
<wire x1="50.5968" y1="58.8264" x2="44.5008" y2="58.8264" width="0.254" layer="1"/>
<wire x1="44.5008" y1="58.8264" x2="44.45" y2="58.55" width="0.254" layer="1"/>
<wire x1="50.5968" y1="58.8264" x2="50.8" y2="58.55" width="0.254" layer="1"/>
<wire x1="34.1376" y1="56.388" x2="34.1376" y2="54.5592" width="0.254" layer="1"/>
<wire x1="34.1376" y1="54.5592" x2="34.1376" y2="43.5864" width="0.254" layer="1"/>
<wire x1="32.004" y1="58.5216" x2="34.1376" y2="56.388" width="0.254" layer="1"/>
<wire x1="34.1376" y1="43.5864" x2="34.055" y2="43.5578" width="0.254" layer="1"/>
<wire x1="32.004" y1="58.5216" x2="31.75" y2="58.55" width="0.254" layer="1"/>
<wire x1="34.1376" y1="54.5592" x2="38.1" y2="58.5216" width="0.254" layer="1"/>
<wire x1="38.1" y1="58.5216" x2="38.1" y2="58.55" width="0.254" layer="1"/>
<wire x1="38.1" y1="58.8264" x2="44.196" y2="58.8264" width="0.254" layer="1"/>
<wire x1="44.196" y1="58.8264" x2="44.45" y2="58.55" width="0.254" layer="1"/>
<wire x1="38.1" y1="58.8264" x2="38.1" y2="58.55" width="0.254" layer="1"/>
<wire x1="26.8224" y1="52.1208" x2="26.8224" y2="43.5864" width="0.254" layer="1"/>
<wire x1="30.1752" y1="55.4736" x2="26.8224" y2="52.1208" width="0.254" layer="1"/>
<wire x1="30.1752" y1="56.9976" x2="30.1752" y2="55.4736" width="0.254" layer="1"/>
<wire x1="31.6992" y1="58.5216" x2="30.1752" y2="56.9976" width="0.254" layer="1"/>
<wire x1="26.8224" y1="43.5864" x2="26.905" y2="43.5578" width="0.254" layer="1"/>
<wire x1="31.6992" y1="58.5216" x2="31.75" y2="58.55" width="0.254" layer="1"/>
<wire x1="30.1752" y1="56.9976" x2="24.384" y2="56.9976" width="0.254" layer="1"/>
<wire x1="24.384" y1="56.9976" x2="24.215" y2="57.15" width="0.254" layer="1"/>
<wire x1="24.0792" y1="55.7784" x2="19.2024" y2="50.9016" width="0.254" layer="1"/>
<wire x1="24.0792" y1="56.9976" x2="24.0792" y2="55.7784" width="0.254" layer="1"/>
<wire x1="19.2024" y1="50.9016" x2="18.965" y2="50.8" width="0.254" layer="1"/>
<wire x1="24.0792" y1="56.9976" x2="24.215" y2="57.15" width="0.254" layer="1"/>
<wire x1="50.9016" y1="58.8264" x2="56.9976" y2="58.8264" width="0.254" layer="1"/>
<wire x1="56.9976" y1="58.8264" x2="57.15" y2="58.55" width="0.254" layer="1"/>
<wire x1="50.9016" y1="58.8264" x2="50.8" y2="58.55" width="0.254" layer="1"/>
<via x="30.1752" y="39.3192" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="26.8224" y="39.3192" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="39.3192" y="42.0624" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$2">
<contactref element="LED5" pad="A"/>
<contactref element="R6" pad="1"/>
<wire x1="31.6992" y1="52.1208" x2="31.6992" y2="55.4736" width="0.254" layer="1"/>
<wire x1="31.6992" y1="55.4736" x2="31.75" y2="55.75" width="0.254" layer="1"/>
<wire x1="31.6992" y1="52.1208" x2="31.75" y2="52.07" width="0.254" layer="1"/>
</signal>
<signal name="N$3">
<contactref element="LED4" pad="A"/>
<contactref element="R5" pad="1"/>
<wire x1="38.1" y1="52.07" x2="38.1" y2="55.75" width="0.254" layer="1"/>
</signal>
<signal name="N$4">
<contactref element="LED3" pad="A"/>
<contactref element="R4" pad="1"/>
<wire x1="44.5008" y1="52.1208" x2="44.5008" y2="55.4736" width="0.254" layer="1"/>
<wire x1="44.5008" y1="55.4736" x2="44.45" y2="55.75" width="0.254" layer="1"/>
<wire x1="44.5008" y1="52.1208" x2="44.45" y2="52.07" width="0.254" layer="1"/>
</signal>
<signal name="N$5">
<contactref element="LED2" pad="A"/>
<contactref element="R3" pad="1"/>
<wire x1="50.9016" y1="52.1208" x2="50.9016" y2="55.4736" width="0.254" layer="1"/>
<wire x1="50.9016" y1="55.4736" x2="50.8" y2="55.75" width="0.254" layer="1"/>
<wire x1="50.9016" y1="52.1208" x2="50.8" y2="52.07" width="0.254" layer="1"/>
</signal>
<signal name="N$6">
<contactref element="LED1" pad="A"/>
<contactref element="R2" pad="1"/>
<wire x1="57.3024" y1="52.1208" x2="57.3024" y2="55.4736" width="0.254" layer="1"/>
<wire x1="57.3024" y1="55.4736" x2="57.15" y2="55.75" width="0.254" layer="1"/>
<wire x1="57.3024" y1="52.1208" x2="57.15" y2="52.07" width="0.254" layer="1"/>
</signal>
<signal name="N$7">
<contactref element="LED6" pad="A"/>
<contactref element="R1" pad="1"/>
<wire x1="58.2168" y1="22.5552" x2="57.3024" y2="21.6408" width="0.254" layer="1"/>
<wire x1="58.2168" y1="25.2984" x2="58.2168" y2="22.5552" width="0.254" layer="1"/>
<wire x1="57.3024" y1="21.6408" x2="57.28" y2="21.59" width="0.254" layer="1"/>
<wire x1="58.2168" y1="25.2984" x2="58.42" y2="25.4" width="0.254" layer="1"/>
</signal>
<signal name="GND">
<contactref element="C4" pad="2"/>
<contactref element="C1" pad="-"/>
<contactref element="INPUT" pad="2"/>
<contactref element="U$1" pad="7"/>
<contactref element="U$1" pad="14"/>
<contactref element="R7" pad="1"/>
<contactref element="C8" pad="-"/>
<contactref element="C7" pad="-"/>
<contactref element="C6" pad="2"/>
<contactref element="C5" pad="2"/>
<contactref element="C12" pad="2"/>
<contactref element="R10" pad="2"/>
<contactref element="C11" pad="2"/>
<contactref element="C13" pad="-"/>
<contactref element="BE12V" pad="1"/>
<contactref element="R11" pad="2"/>
<contactref element="C16" pad="-"/>
<contactref element="C17" pad="-"/>
<contactref element="C14" pad="-"/>
<contactref element="R13" pad="2"/>
<contactref element="C15" pad="2"/>
<contactref element="C18" pad="-"/>
<contactref element="C10" pad="-"/>
<contactref element="C2" pad="2"/>
<contactref element="U$2" pad="1"/>
<contactref element="U$2" pad="14"/>
<contactref element="U$2" pad="24"/>
<wire x1="19.2024" y1="5.1816" x2="19.2024" y2="10.0584" width="0.254" layer="1"/>
<wire x1="19.2024" y1="10.0584" x2="19.18" y2="10.16" width="0.254" layer="1"/>
<wire x1="19.2024" y1="5.1816" x2="19.05" y2="5.08" width="0.254" layer="1"/>
<wire x1="7.9248" y1="14.0208" x2="12.8016" y2="9.144" width="0.254" layer="1"/>
<wire x1="2.1336" y1="14.0208" x2="6.096" y2="14.0208" width="0.254" layer="1"/>
<wire x1="6.096" y1="14.0208" x2="7.9248" y2="14.0208" width="0.254" layer="1"/>
<wire x1="2.1336" y1="15.24" x2="2.1336" y2="14.0208" width="0.254" layer="1"/>
<wire x1="12.8016" y1="9.144" x2="12.83" y2="8.89" width="0.254" layer="1"/>
<wire x1="2.1336" y1="15.24" x2="1.955" y2="15.24" width="0.254" layer="1"/>
<wire x1="17.0688" y1="3.048" x2="18.8976" y2="4.8768" width="0.254" layer="1"/>
<wire x1="13.716" y1="3.048" x2="17.0688" y2="3.048" width="0.254" layer="1"/>
<wire x1="13.716" y1="8.2296" x2="13.716" y2="3.048" width="0.254" layer="1"/>
<wire x1="13.1064" y1="8.8392" x2="13.716" y2="8.2296" width="0.254" layer="1"/>
<wire x1="18.8976" y1="4.8768" x2="19.05" y2="5.08" width="0.254" layer="1"/>
<wire x1="13.1064" y1="8.8392" x2="12.83" y2="8.89" width="0.254" layer="1"/>
<wire x1="11.2776" y1="55.7784" x2="12.4968" y2="56.9976" width="0.254" layer="1"/>
<wire x1="11.2776" y1="50.9016" x2="11.2776" y2="54.5592" width="0.254" layer="1"/>
<wire x1="11.2776" y1="54.5592" x2="11.2776" y2="55.7784" width="0.254" layer="1"/>
<wire x1="12.4968" y1="56.9976" x2="12.57" y2="57.15" width="0.254" layer="1"/>
<wire x1="11.2776" y1="50.9016" x2="11" y2="50.8" width="0.254" layer="1"/>
<wire x1="11.2776" y1="54.5592" x2="7.62" y2="54.5592" width="0.254" layer="1"/>
<wire x1="7.62" y1="54.5592" x2="7.62" y2="54.48" width="0.254" layer="1"/>
<wire x1="7.62" y1="52.7304" x2="2.7432" y2="47.8536" width="0.254" layer="1"/>
<wire x1="7.62" y1="54.48" x2="7.62" y2="52.7304" width="0.254" layer="1"/>
<wire x1="2.7432" y1="47.8536" x2="2.73" y2="47.625" width="0.254" layer="1"/>
<wire x1="6.7056" y1="30.48" x2="6.096" y2="31.0896" width="0.254" layer="1"/>
<wire x1="6.7056" y1="24.9936" x2="6.7056" y2="30.48" width="0.254" layer="1"/>
<wire x1="6.096" y1="31.0896" x2="5.845" y2="31.115" width="0.254" layer="1"/>
<wire x1="6.7056" y1="24.9936" x2="6.795" y2="24.765" width="0.254" layer="1"/>
<wire x1="5.7912" y1="34.4424" x2="2.1336" y2="38.1" width="0.254" layer="1"/>
<wire x1="5.7912" y1="31.3944" x2="5.7912" y2="34.4424" width="0.254" layer="1"/>
<wire x1="5.7912" y1="31.3944" x2="5.845" y2="31.115" width="0.254" layer="1"/>
<wire x1="2.1336" y1="47.244" x2="2.4384" y2="47.5488" width="0.254" layer="1"/>
<wire x1="2.1336" y1="38.1" x2="2.1336" y2="47.244" width="0.254" layer="1"/>
<wire x1="2.4384" y1="47.5488" x2="2.73" y2="47.625" width="0.254" layer="1"/>
<wire x1="2.1336" y1="38.1" x2="1.955" y2="38.1" width="0.254" layer="1"/>
<wire x1="6.096" y1="24.0792" x2="6.096" y2="14.0208" width="0.254" layer="1"/>
<wire x1="6.7056" y1="24.6888" x2="6.096" y2="24.0792" width="0.254" layer="1"/>
<wire x1="6.7056" y1="24.6888" x2="6.795" y2="24.765" width="0.254" layer="1"/>
<wire x1="14.3256" y1="35.052" x2="12.8016" y2="36.576" width="0.254" layer="1"/>
<wire x1="14.3256" y1="32.6136" x2="14.3256" y2="35.052" width="0.254" layer="1"/>
<wire x1="12.8016" y1="36.576" x2="12.57" y2="36.83" width="0.254" layer="1"/>
<wire x1="14.3256" y1="32.6136" x2="14.475" y2="32.385" width="0.254" layer="1"/>
<wire x1="14.3256" y1="29.8704" x2="11.2776" y2="26.8224" width="0.254" layer="1"/>
<wire x1="14.3256" y1="32.3088" x2="14.3256" y2="29.8704" width="0.254" layer="1"/>
<wire x1="11.2776" y1="26.8224" x2="11" y2="26.67" width="0.254" layer="1"/>
<wire x1="14.3256" y1="32.3088" x2="14.475" y2="32.385" width="0.254" layer="1"/>
<wire x1="28.6512" y1="13.1064" x2="31.0896" y2="13.1064" width="0.254" layer="1"/>
<wire x1="28.6512" y1="21.6408" x2="28.6512" y2="13.1064" width="0.254" layer="1"/>
<wire x1="29.5656" y1="22.5552" x2="28.6512" y2="21.6408" width="0.254" layer="1"/>
<wire x1="31.0896" y1="22.5552" x2="29.5656" y2="22.5552" width="0.254" layer="1"/>
<wire x1="31.0896" y1="13.1064" x2="31.22" y2="12.93" width="0.254" layer="1"/>
<wire x1="31.0896" y1="22.5552" x2="31.255" y2="22.67" width="0.254" layer="1"/>
<wire x1="30.7848" y1="32.6136" x2="30.7848" y2="35.052" width="0.254" layer="1"/>
<wire x1="30.7848" y1="35.052" x2="30.7848" y2="37.4904" width="0.254" layer="1"/>
<wire x1="28.6512" y1="30.48" x2="30.7848" y2="32.6136" width="0.254" layer="1"/>
<wire x1="30.7848" y1="37.4904" x2="30.805" y2="37.7222" width="0.254" layer="1"/>
<wire x1="30.7848" y1="23.1648" x2="31.0896" y2="22.86" width="0.254" layer="1"/>
<wire x1="30.7848" y1="28.3464" x2="30.7848" y2="23.1648" width="0.254" layer="1"/>
<wire x1="28.6512" y1="30.48" x2="30.7848" y2="28.3464" width="0.254" layer="1"/>
<wire x1="31.0896" y1="22.86" x2="31.255" y2="22.67" width="0.254" layer="1"/>
<wire x1="28.6512" y1="30.48" x2="28.625" y2="30.48" width="0.254" layer="1"/>
<wire x1="30.7848" y1="35.052" x2="14.3256" y2="35.052" width="0.254" layer="1"/>
<wire x1="33.528" y1="42.672" x2="33.528" y2="43.2816" width="0.254" layer="1"/>
<wire x1="36.8808" y1="42.672" x2="33.528" y2="42.672" width="0.254" layer="1"/>
<wire x1="37.7952" y1="43.5864" x2="36.8808" y2="42.672" width="0.254" layer="1"/>
<wire x1="52.4256" y1="43.5864" x2="37.7952" y2="43.5864" width="0.254" layer="1"/>
<wire x1="52.4256" y1="40.5384" x2="52.4256" y2="43.5864" width="0.254" layer="1"/>
<wire x1="51.2064" y1="39.3192" x2="52.4256" y2="40.5384" width="0.254" layer="1"/>
<wire x1="38.1" y1="39.3192" x2="51.2064" y2="39.3192" width="0.254" layer="1"/>
<wire x1="38.1" y1="40.5384" x2="38.1" y2="39.3192" width="0.254" layer="1"/>
<wire x1="33.528" y1="43.2816" x2="33.405" y2="43.5578" width="0.254" layer="1"/>
<wire x1="38.1" y1="40.5384" x2="37.97" y2="40.64" width="0.254" layer="1"/>
<wire x1="50.5968" y1="13.716" x2="49.6824" y2="12.8016" width="0.254" layer="1"/>
<wire x1="50.5968" y1="17.6784" x2="50.5968" y2="13.716" width="0.254" layer="1"/>
<wire x1="49.6824" y1="12.8016" x2="49.4" y2="12.7" width="0.254" layer="1"/>
<wire x1="50.5968" y1="17.6784" x2="50.67" y2="17.78" width="0.254" layer="1"/>
<wire x1="49.0728" y1="5.7912" x2="48.4632" y2="5.1816" width="0.254" layer="1"/>
<wire x1="49.0728" y1="12.192" x2="49.0728" y2="5.7912" width="0.254" layer="1"/>
<wire x1="49.3776" y1="12.4968" x2="49.0728" y2="12.192" width="0.254" layer="1"/>
<wire x1="48.4632" y1="5.1816" x2="48.26" y2="5.08" width="0.254" layer="1"/>
<wire x1="49.3776" y1="12.4968" x2="49.4" y2="12.7" width="0.254" layer="1"/>
<wire x1="39.3192" y1="23.4696" x2="39.3192" y2="22.86" width="0.254" layer="1"/>
<wire x1="39.624" y1="23.7744" x2="39.3192" y2="23.4696" width="0.254" layer="1"/>
<wire x1="44.196" y1="23.7744" x2="41.148" y2="23.7744" width="0.254" layer="1"/>
<wire x1="41.148" y1="23.7744" x2="39.624" y2="23.7744" width="0.254" layer="1"/>
<wire x1="44.196" y1="19.2024" x2="44.196" y2="23.7744" width="0.254" layer="1"/>
<wire x1="39.3192" y1="22.86" x2="39.225" y2="22.65" width="0.254" layer="1"/>
<wire x1="44.196" y1="19.2024" x2="44.32" y2="19.05" width="0.254" layer="1"/>
<wire x1="48.1584" y1="34.1376" x2="50.5968" y2="36.576" width="0.254" layer="1"/>
<wire x1="48.1584" y1="28.3464" x2="48.1584" y2="34.1376" width="0.254" layer="1"/>
<wire x1="46.6344" y1="26.8224" x2="48.1584" y2="28.3464" width="0.254" layer="1"/>
<wire x1="50.5968" y1="36.576" x2="50.8" y2="36.87" width="0.254" layer="1"/>
<wire x1="46.6344" y1="26.8224" x2="46.38" y2="26.67" width="0.254" layer="1"/>
<wire x1="46.3296" y1="25.908" x2="45.4152" y2="24.9936" width="0.254" layer="1"/>
<wire x1="45.4152" y1="24.9936" x2="44.196" y2="23.7744" width="0.254" layer="1"/>
<wire x1="46.3296" y1="26.5176" x2="46.3296" y2="25.908" width="0.254" layer="1"/>
<wire x1="46.3296" y1="26.5176" x2="46.38" y2="26.67" width="0.254" layer="1"/>
<wire x1="49.0728" y1="19.5072" x2="50.5968" y2="17.9832" width="0.254" layer="1"/>
<wire x1="49.0728" y1="21.336" x2="49.0728" y2="19.5072" width="0.254" layer="1"/>
<wire x1="45.4152" y1="24.9936" x2="49.0728" y2="21.336" width="0.254" layer="1"/>
<wire x1="50.5968" y1="17.9832" x2="50.67" y2="17.78" width="0.254" layer="1"/>
<wire x1="58.5216" y1="40.5384" x2="52.4256" y2="40.5384" width="0.254" layer="1"/>
<wire x1="58.5216" y1="37.4904" x2="58.5216" y2="40.5384" width="0.254" layer="1"/>
<wire x1="57.6072" y1="36.576" x2="58.5216" y2="37.4904" width="0.254" layer="1"/>
<wire x1="50.9016" y1="36.576" x2="57.6072" y2="36.576" width="0.254" layer="1"/>
<wire x1="50.9016" y1="36.576" x2="50.8" y2="36.87" width="0.254" layer="1"/>
<wire x1="37.7952" y1="32.6136" x2="30.7848" y2="32.6136" width="0.254" layer="1"/>
<wire x1="37.7952" y1="28.956" x2="37.7952" y2="32.6136" width="0.254" layer="1"/>
<wire x1="39.624" y1="27.1272" x2="37.7952" y2="28.956" width="0.254" layer="1"/>
<wire x1="41.148" y1="27.1272" x2="39.624" y2="27.1272" width="0.254" layer="1"/>
<wire x1="41.148" y1="23.7744" x2="41.148" y2="27.1272" width="0.254" layer="1"/>
<wire x1="16.764" y1="12.4968" x2="18.8976" y2="10.3632" width="0.254" layer="1"/>
<wire x1="16.764" y1="15.8496" x2="16.764" y2="12.4968" width="0.254" layer="1"/>
<wire x1="13.1064" y1="19.5072" x2="16.764" y2="15.8496" width="0.254" layer="1"/>
<wire x1="11.2776" y1="19.5072" x2="13.1064" y2="19.5072" width="0.254" layer="1"/>
<wire x1="11.2776" y1="26.5176" x2="11.2776" y2="19.5072" width="0.254" layer="1"/>
<wire x1="18.8976" y1="10.3632" x2="19.18" y2="10.16" width="0.254" layer="1"/>
<wire x1="11.2776" y1="26.5176" x2="11" y2="26.67" width="0.254" layer="1"/>
<polygon width="0.4064" layer="16" isolate="0.6096" orphans="yes">
<vertex x="-1.27" y="68.58"/>
<vertex x="-1.27" y="0"/>
<vertex x="90.17" y="0"/>
<vertex x="90.17" y="68.58"/>
</polygon>
<polygon width="0.4064" layer="1" isolate="0.6096" orphans="yes">
</polygon>
</signal>
<signal name="N$8">
<contactref element="LED1" pad="K"/>
<contactref element="U$1" pad="18"/>
<wire x1="30.7848" y1="46.3296" x2="30.7848" y2="43.5864" width="0.254" layer="1"/>
<wire x1="33.2232" y1="48.768" x2="30.7848" y2="46.3296" width="0.254" layer="1"/>
<wire x1="37.7952" y1="53.34" x2="33.2232" y2="48.768" width="0.254" layer="16"/>
<wire x1="53.34" y1="53.34" x2="37.7952" y2="53.34" width="0.254" layer="16"/>
<wire x1="57.15" y1="49.53" x2="53.34" y2="53.34" width="0.254" layer="16"/>
<wire x1="30.7848" y1="43.5864" x2="30.805" y2="43.5578" width="0.254" layer="1"/>
<via x="33.2232" y="48.768" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$1">
<contactref element="LED2" pad="K"/>
<contactref element="U$1" pad="19"/>
<wire x1="30.1752" y1="45.72" x2="30.1752" y2="43.5864" width="0.254" layer="1"/>
<wire x1="29.8704" y1="46.0248" x2="30.1752" y2="45.72" width="0.254" layer="1"/>
<wire x1="31.6992" y1="46.0248" x2="29.8704" y2="46.0248" width="0.254" layer="16"/>
<wire x1="36.2712" y1="50.5968" x2="31.6992" y2="46.0248" width="0.254" layer="16"/>
<wire x1="49.6824" y1="50.5968" x2="36.2712" y2="50.5968" width="0.254" layer="16"/>
<wire x1="50.5968" y1="49.6824" x2="49.6824" y2="50.5968" width="0.254" layer="16"/>
<wire x1="30.1752" y1="43.5864" x2="30.155" y2="43.5578" width="0.254" layer="1"/>
<wire x1="50.5968" y1="49.6824" x2="50.8" y2="49.53" width="0.254" layer="16"/>
<via x="29.8704" y="46.0248" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$9">
<contactref element="LED3" pad="K"/>
<contactref element="U$1" pad="20"/>
<wire x1="29.5656" y1="42.0624" x2="29.5656" y2="43.2816" width="0.254" layer="1"/>
<wire x1="35.9664" y1="48.4632" x2="29.5656" y2="42.0624" width="0.254" layer="16"/>
<wire x1="43.2816" y1="48.4632" x2="35.9664" y2="48.4632" width="0.254" layer="16"/>
<wire x1="44.196" y1="49.3776" x2="43.2816" y2="48.4632" width="0.254" layer="16"/>
<wire x1="29.5656" y1="43.2816" x2="29.505" y2="43.5578" width="0.254" layer="1"/>
<wire x1="44.196" y1="49.3776" x2="44.45" y2="49.53" width="0.254" layer="16"/>
<via x="29.5656" y="42.0624" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$10">
<contactref element="LED4" pad="K"/>
<contactref element="U$1" pad="21"/>
<wire x1="28.956" y1="44.5008" x2="28.956" y2="43.5864" width="0.254" layer="1"/>
<wire x1="29.2608" y1="44.8056" x2="28.956" y2="44.5008" width="0.254" layer="1"/>
<wire x1="31.3944" y1="44.8056" x2="29.2608" y2="44.8056" width="0.254" layer="16"/>
<wire x1="35.9664" y1="49.3776" x2="31.3944" y2="44.8056" width="0.254" layer="16"/>
<wire x1="38.1" y1="49.3776" x2="35.9664" y2="49.3776" width="0.254" layer="16"/>
<wire x1="28.956" y1="43.5864" x2="28.855" y2="43.5578" width="0.254" layer="1"/>
<wire x1="38.1" y1="49.3776" x2="38.1" y2="49.53" width="0.254" layer="16"/>
<via x="29.2608" y="44.8056" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$11">
<contactref element="LED5" pad="K"/>
<contactref element="U$1" pad="22"/>
<wire x1="28.3464" y1="46.0248" x2="28.3464" y2="43.5864" width="0.254" layer="1"/>
<wire x1="31.6992" y1="49.3776" x2="28.3464" y2="46.0248" width="0.254" layer="1"/>
<wire x1="28.3464" y1="43.5864" x2="28.205" y2="43.5578" width="0.254" layer="1"/>
<wire x1="31.6992" y1="49.3776" x2="31.75" y2="49.53" width="0.254" layer="1"/>
</signal>
<signal name="N$12">
<contactref element="LED6" pad="K"/>
<contactref element="U$1" pad="23"/>
<wire x1="27.432" y1="46.6344" x2="27.432" y2="43.5864" width="0.254" layer="1"/>
<wire x1="31.3944" y1="50.5968" x2="27.432" y2="46.6344" width="0.254" layer="1"/>
<wire x1="33.2232" y1="50.5968" x2="31.3944" y2="50.5968" width="0.254" layer="1"/>
<wire x1="34.1376" y1="50.5968" x2="33.2232" y2="50.5968" width="0.254" layer="16"/>
<wire x1="37.4904" y1="53.9496" x2="34.1376" y2="50.5968" width="0.254" layer="16"/>
<wire x1="56.6928" y1="53.9496" x2="37.4904" y2="53.9496" width="0.254" layer="16"/>
<wire x1="60.0456" y1="50.5968" x2="56.6928" y2="53.9496" width="0.254" layer="16"/>
<wire x1="60.0456" y1="43.8912" x2="60.0456" y2="50.5968" width="0.254" layer="16"/>
<wire x1="54.5592" y1="38.4048" x2="60.0456" y2="43.8912" width="0.254" layer="16"/>
<wire x1="54.5592" y1="32.004" x2="54.5592" y2="38.4048" width="0.254" layer="16"/>
<wire x1="60.96" y1="25.6032" x2="54.5592" y2="32.004" width="0.254" layer="16"/>
<wire x1="27.432" y1="43.5864" x2="27.555" y2="43.5578" width="0.254" layer="1"/>
<wire x1="60.96" y1="25.6032" x2="60.96" y2="25.4" width="0.254" layer="16"/>
<via x="33.2232" y="50.5968" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$13">
<contactref element="U$1" pad="10"/>
<contactref element="C9" pad="-"/>
<wire x1="32.9184" y1="37.1856" x2="32.6136" y2="37.4904" width="0.254" layer="1"/>
<wire x1="32.9184" y1="36.8808" x2="32.9184" y2="37.1856" width="0.254" layer="1"/>
<wire x1="38.4048" y1="36.8808" x2="32.9184" y2="36.8808" width="0.254" layer="1"/>
<wire x1="38.7096" y1="37.1856" x2="38.4048" y2="36.8808" width="0.254" layer="1"/>
<wire x1="44.196" y1="37.1856" x2="38.7096" y2="37.1856" width="0.254" layer="1"/>
<wire x1="44.196" y1="36.8808" x2="44.196" y2="37.1856" width="0.254" layer="1"/>
<wire x1="32.6136" y1="37.4904" x2="32.755" y2="37.7222" width="0.254" layer="1"/>
<wire x1="44.196" y1="36.8808" x2="44.45" y2="36.79" width="0.254" layer="1"/>
</signal>
<signal name="N$15">
<contactref element="C3" pad="-"/>
<contactref element="U$1" pad="15"/>
<wire x1="32.9184" y1="42.9768" x2="32.6136" y2="43.2816" width="0.254" layer="1"/>
<wire x1="32.9184" y1="42.3672" x2="32.9184" y2="42.9768" width="0.254" layer="1"/>
<wire x1="35.052" y1="40.2336" x2="32.9184" y2="42.3672" width="0.254" layer="1"/>
<wire x1="39.0144" y1="36.2712" x2="35.052" y2="40.2336" width="0.254" layer="16"/>
<wire x1="39.3192" y1="35.9664" x2="39.0144" y2="36.2712" width="0.254" layer="1"/>
<wire x1="39.3192" y1="30.48" x2="39.3192" y2="35.9664" width="0.254" layer="1"/>
<wire x1="32.6136" y1="43.2816" x2="32.755" y2="43.5578" width="0.254" layer="1"/>
<wire x1="39.3192" y1="30.48" x2="39.37" y2="30.44" width="0.254" layer="1"/>
<via x="35.052" y="40.2336" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="39.0144" y="36.2712" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$16">
<contactref element="VOL-" pad="2"/>
<contactref element="MUTTE" pad="2"/>
<contactref element="MODE" pad="2"/>
<contactref element="VOL+" pad="2"/>
<wire x1="80.4672" y1="32.6136" x2="74.3712" y2="26.5176" width="0.254" layer="1"/>
<wire x1="80.4672" y1="33.2232" x2="80.4672" y2="32.6136" width="0.254" layer="1"/>
<wire x1="74.3712" y1="26.5176" x2="74.3712" y2="26.3906" width="0.254" layer="1"/>
<wire x1="80.4672" y1="33.2232" x2="80.5688" y2="33.2994" width="0.254" layer="1"/>
<wire x1="56.6928" y1="35.6616" x2="56.6928" y2="33.528" width="0.254" layer="16"/>
<wire x1="67.6656" y1="46.6344" x2="56.6928" y2="35.6616" width="0.254" layer="16"/>
<wire x1="67.6656" y1="47.244" x2="67.6656" y2="46.6344" width="0.254" layer="16"/>
<wire x1="56.6928" y1="33.528" x2="56.4388" y2="33.2994" width="0.254" layer="16"/>
<wire x1="67.6656" y1="47.244" x2="67.8688" y2="47.2694" width="0.254" layer="16"/>
<wire x1="67.9704" y1="46.0248" x2="80.4672" y2="33.528" width="0.254" layer="1"/>
<wire x1="67.9704" y1="47.244" x2="67.9704" y2="46.0248" width="0.254" layer="1"/>
<wire x1="80.4672" y1="33.528" x2="80.5688" y2="33.2994" width="0.254" layer="1"/>
<wire x1="67.9704" y1="47.244" x2="67.8688" y2="47.2694" width="0.254" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="VOL-" pad="4"/>
<contactref element="U$1" pad="2"/>
<wire x1="27.432" y1="36.8808" x2="27.432" y2="37.4904" width="0.254" layer="1"/>
<wire x1="25.908" y1="36.8808" x2="27.432" y2="36.8808" width="0.254" layer="1"/>
<wire x1="25.908" y1="52.4256" x2="25.908" y2="36.8808" width="0.254" layer="1"/>
<wire x1="29.2608" y1="55.7784" x2="25.908" y2="52.4256" width="0.254" layer="1"/>
<wire x1="29.8704" y1="56.388" x2="29.2608" y2="55.7784" width="0.254" layer="16"/>
<wire x1="72.2376" y1="56.388" x2="29.8704" y2="56.388" width="0.254" layer="16"/>
<wire x1="80.4672" y1="48.1584" x2="72.2376" y2="56.388" width="0.254" layer="16"/>
<wire x1="80.4672" y1="38.1" x2="80.4672" y2="48.1584" width="0.254" layer="16"/>
<wire x1="27.432" y1="37.4904" x2="27.555" y2="37.7222" width="0.254" layer="1"/>
<wire x1="80.4672" y1="38.1" x2="80.5688" y2="37.8206" width="0.254" layer="16"/>
<via x="29.2608" y="55.7784" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$18">
<contactref element="VOL+" pad="4"/>
<contactref element="U$1" pad="3"/>
<wire x1="28.3464" y1="36.2712" x2="28.3464" y2="37.4904" width="0.254" layer="1"/>
<wire x1="31.0896" y1="33.528" x2="28.3464" y2="36.2712" width="0.254" layer="16"/>
<wire x1="42.672" y1="33.528" x2="31.0896" y2="33.528" width="0.254" layer="16"/>
<wire x1="47.5488" y1="33.528" x2="42.672" y2="33.528" width="0.254" layer="1"/>
<wire x1="47.5488" y1="36.576" x2="47.5488" y2="33.528" width="0.254" layer="1"/>
<wire x1="49.3776" y1="38.4048" x2="47.5488" y2="36.576" width="0.254" layer="1"/>
<wire x1="56.388" y1="38.4048" x2="49.3776" y2="38.4048" width="0.254" layer="1"/>
<wire x1="56.388" y1="38.1" x2="56.388" y2="38.4048" width="0.254" layer="1"/>
<wire x1="28.3464" y1="37.4904" x2="28.205" y2="37.7222" width="0.254" layer="1"/>
<wire x1="56.388" y1="38.1" x2="56.4388" y2="37.8206" width="0.254" layer="1"/>
<via x="28.3464" y="36.2712" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="42.672" y="33.528" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$19">
<contactref element="MODE" pad="4"/>
<contactref element="U$1" pad="5"/>
<wire x1="29.5656" y1="38.7096" x2="29.5656" y2="37.7952" width="0.254" layer="1"/>
<wire x1="28.3464" y1="39.9288" x2="29.5656" y2="38.7096" width="0.254" layer="1"/>
<wire x1="28.3464" y1="42.0624" x2="28.3464" y2="39.9288" width="0.254" layer="1"/>
<wire x1="28.3464" y1="49.3776" x2="28.3464" y2="42.0624" width="0.254" layer="16"/>
<wire x1="26.5176" y1="51.2064" x2="28.3464" y2="49.3776" width="0.254" layer="16"/>
<wire x1="26.5176" y1="51.816" x2="26.5176" y2="51.2064" width="0.254" layer="16"/>
<wire x1="30.48" y1="55.7784" x2="26.5176" y2="51.816" width="0.254" layer="16"/>
<wire x1="63.7032" y1="55.7784" x2="30.48" y2="55.7784" width="0.254" layer="16"/>
<wire x1="67.6656" y1="51.816" x2="63.7032" y2="55.7784" width="0.254" layer="16"/>
<wire x1="29.5656" y1="37.7952" x2="29.505" y2="37.7222" width="0.254" layer="1"/>
<wire x1="67.6656" y1="51.816" x2="67.8688" y2="51.7906" width="0.254" layer="16"/>
<via x="28.3464" y="42.0624" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$20">
<contactref element="MUTTE" pad="4"/>
<contactref element="U$1" pad="4"/>
<wire x1="28.956" y1="36.8808" x2="28.956" y2="37.4904" width="0.254" layer="1"/>
<wire x1="29.8704" y1="35.9664" x2="28.956" y2="36.8808" width="0.254" layer="1"/>
<wire x1="31.3944" y1="35.9664" x2="29.8704" y2="35.9664" width="0.254" layer="16"/>
<wire x1="32.9184" y1="34.4424" x2="31.3944" y2="35.9664" width="0.254" layer="16"/>
<wire x1="42.9768" y1="34.4424" x2="32.9184" y2="34.4424" width="0.254" layer="16"/>
<wire x1="54.5592" y1="22.86" x2="42.9768" y2="34.4424" width="0.254" layer="16"/>
<wire x1="54.5592" y1="19.812" x2="54.5592" y2="22.86" width="0.254" layer="16"/>
<wire x1="74.3712" y1="19.812" x2="54.5592" y2="19.812" width="0.254" layer="1"/>
<wire x1="74.3712" y1="21.8694" x2="74.3712" y2="19.812" width="0.254" layer="1"/>
<wire x1="28.956" y1="37.4904" x2="28.855" y2="37.7222" width="0.254" layer="1"/>
<via x="29.8704" y="35.9664" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="54.5592" y="19.812" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$14">
<contactref element="C1" pad="+"/>
<contactref element="U$1" pad="12"/>
<wire x1="36.576" y1="40.2336" x2="34.1376" y2="37.7952" width="0.254" layer="1"/>
<wire x1="36.576" y1="41.4528" x2="36.576" y2="40.2336" width="0.254" layer="1"/>
<wire x1="38.1" y1="42.9768" x2="36.576" y2="41.4528" width="0.254" layer="1"/>
<wire x1="50.5968" y1="42.9768" x2="38.1" y2="42.9768" width="0.254" layer="1"/>
<wire x1="50.5968" y1="42.0624" x2="50.5968" y2="42.9768" width="0.254" layer="1"/>
<wire x1="34.1376" y1="37.7952" x2="34.055" y2="37.7222" width="0.254" layer="1"/>
<wire x1="50.5968" y1="42.0624" x2="50.8" y2="41.87" width="0.254" layer="1"/>
</signal>
<signal name="N$22">
<contactref element="INPUT" pad="1"/>
<contactref element="U$1" pad="17"/>
<wire x1="31.3944" y1="42.3672" x2="31.3944" y2="43.2816" width="0.254" layer="1"/>
<wire x1="31.0896" y1="42.0624" x2="31.3944" y2="42.3672" width="0.254" layer="1"/>
<wire x1="32.004" y1="42.0624" x2="31.0896" y2="42.0624" width="0.254" layer="16"/>
<wire x1="32.9184" y1="42.9768" x2="32.004" y2="42.0624" width="0.254" layer="16"/>
<wire x1="39.624" y1="42.9768" x2="32.9184" y2="42.9768" width="0.254" layer="16"/>
<wire x1="56.0832" y1="26.5176" x2="39.624" y2="42.9768" width="0.254" layer="16"/>
<wire x1="56.0832" y1="7.9248" x2="56.0832" y2="26.5176" width="0.254" layer="16"/>
<wire x1="51.2064" y1="3.048" x2="56.0832" y2="7.9248" width="0.254" layer="16"/>
<wire x1="47.5488" y1="3.048" x2="51.2064" y2="3.048" width="0.254" layer="16"/>
<wire x1="45.72" y1="4.8768" x2="47.5488" y2="3.048" width="0.254" layer="16"/>
<wire x1="31.3944" y1="43.2816" x2="31.455" y2="43.5578" width="0.254" layer="1"/>
<wire x1="45.72" y1="4.8768" x2="45.72" y2="5.08" width="0.254" layer="16"/>
<via x="31.0896" y="42.0624" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$25">
<contactref element="INPUT" pad="3"/>
<contactref element="U$1" pad="8"/>
<wire x1="31.3944" y1="37.1856" x2="31.3944" y2="37.4904" width="0.254" layer="1"/>
<wire x1="33.2232" y1="35.3568" x2="31.3944" y2="37.1856" width="0.254" layer="1"/>
<wire x1="42.9768" y1="35.3568" x2="33.2232" y2="35.3568" width="0.254" layer="16"/>
<wire x1="55.4736" y1="22.86" x2="42.9768" y2="35.3568" width="0.254" layer="16"/>
<wire x1="55.4736" y1="9.7536" x2="55.4736" y2="22.86" width="0.254" layer="16"/>
<wire x1="50.8" y1="5.08" x2="55.4736" y2="9.7536" width="0.254" layer="16"/>
<wire x1="31.3944" y1="37.4904" x2="31.455" y2="37.7222" width="0.254" layer="1"/>
<via x="33.2232" y="35.3568" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$26">
<contactref element="U$1" pad="9"/>
<contactref element="U$1" pad="11"/>
<contactref element="U$1" pad="16"/>
<wire x1="32.004" y1="43.2816" x2="32.004" y2="39.624" width="0.254" layer="1"/>
<wire x1="32.004" y1="39.624" x2="32.004" y2="37.7952" width="0.254" layer="1"/>
<wire x1="32.004" y1="37.7952" x2="32.105" y2="37.7222" width="0.254" layer="1"/>
<wire x1="32.004" y1="43.2816" x2="32.105" y2="43.5578" width="0.254" layer="1"/>
<wire x1="33.528" y1="38.1" x2="33.528" y2="37.7952" width="0.254" layer="1"/>
<wire x1="32.004" y1="39.624" x2="33.528" y2="38.1" width="0.254" layer="1"/>
<wire x1="33.528" y1="37.7952" x2="33.405" y2="37.7222" width="0.254" layer="1"/>
</signal>
<signal name="C9">
<contactref element="R7" pad="2"/>
<contactref element="R8" pad="1"/>
<contactref element="C8" pad="+"/>
<contactref element="U$2" pad="10"/>
<contactref element="U$2" pad="11"/>
<wire x1="39.3192" y1="13.1064" x2="38.4048" y2="13.1064" width="0.254" layer="1"/>
<wire x1="38.4048" y1="13.1064" x2="38.42" y2="12.92" width="0.254" layer="1"/>
<wire x1="39.3192" y1="13.1064" x2="39.225" y2="12.92" width="0.254" layer="1"/>
<wire x1="39.3192" y1="8.8392" x2="39.3192" y2="12.8016" width="0.254" layer="1"/>
<wire x1="39.9288" y1="8.2296" x2="39.3192" y2="8.8392" width="0.254" layer="1"/>
<wire x1="45.72" y1="8.2296" x2="39.9288" y2="8.2296" width="0.254" layer="1"/>
<wire x1="45.72" y1="12.4968" x2="45.72" y2="8.2296" width="0.254" layer="1"/>
<wire x1="39.3192" y1="12.8016" x2="39.225" y2="12.92" width="0.254" layer="1"/>
<wire x1="45.72" y1="12.4968" x2="45.85" y2="12.7" width="0.254" layer="1"/>
<wire x1="46.0248" y1="17.9832" x2="46.9392" y2="18.8976" width="0.254" layer="1"/>
<wire x1="46.0248" y1="12.8016" x2="46.0248" y2="17.9832" width="0.254" layer="1"/>
<wire x1="46.9392" y1="18.8976" x2="47.12" y2="19.05" width="0.254" layer="1"/>
<wire x1="46.0248" y1="12.8016" x2="45.85" y2="12.7" width="0.254" layer="1"/>
<wire x1="49.3776" y1="23.4696" x2="52.4256" y2="26.5176" width="0.254" layer="1"/>
<wire x1="49.3776" y1="22.2504" x2="49.3776" y2="23.4696" width="0.254" layer="1"/>
<wire x1="48.1584" y1="21.0312" x2="49.3776" y2="22.2504" width="0.254" layer="16"/>
<wire x1="47.244" y1="20.1168" x2="48.1584" y2="21.0312" width="0.254" layer="1"/>
<wire x1="47.244" y1="19.2024" x2="47.244" y2="20.1168" width="0.254" layer="1"/>
<wire x1="52.4256" y1="26.5176" x2="52.68" y2="26.67" width="0.254" layer="1"/>
<wire x1="47.244" y1="19.2024" x2="47.12" y2="19.05" width="0.254" layer="1"/>
<via x="49.3776" y="22.2504" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="48.1584" y="21.0312" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$21">
<contactref element="OUT1" pad="2"/>
<contactref element="U$2" pad="5"/>
<wire x1="34.4424" y1="7.9248" x2="34.4424" y2="12.8016" width="0.254" layer="1"/>
<wire x1="35.3568" y1="7.9248" x2="34.4424" y2="7.9248" width="0.254" layer="16"/>
<wire x1="38.1" y1="5.1816" x2="35.3568" y2="7.9248" width="0.254" layer="16"/>
<wire x1="34.4424" y1="12.8016" x2="34.37" y2="12.89" width="0.254" layer="1"/>
<wire x1="38.1" y1="5.1816" x2="38.1" y2="5.08" width="0.254" layer="16"/>
<via x="34.4424" y="7.9248" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$23">
<contactref element="OUT1" pad="1"/>
<contactref element="U$2" pad="6"/>
<wire x1="35.3568" y1="5.4864" x2="35.3568" y2="12.8016" width="0.254" layer="1"/>
<wire x1="37.7952" y1="3.048" x2="35.3568" y2="5.4864" width="0.254" layer="16"/>
<wire x1="38.7096" y1="3.048" x2="37.7952" y2="3.048" width="0.254" layer="16"/>
<wire x1="40.5384" y1="4.8768" x2="38.7096" y2="3.048" width="0.254" layer="16"/>
<wire x1="35.3568" y1="12.8016" x2="35.175" y2="12.91" width="0.254" layer="1"/>
<wire x1="40.5384" y1="4.8768" x2="40.64" y2="5.08" width="0.254" layer="16"/>
<via x="35.3568" y="5.4864" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$27">
<contactref element="OUT2" pad="1"/>
<contactref element="U$2" pad="20"/>
<wire x1="34.4424" y1="24.6888" x2="34.4424" y2="22.86" width="0.254" layer="1"/>
<wire x1="32.6136" y1="26.5176" x2="34.4424" y2="24.6888" width="0.254" layer="1"/>
<wire x1="32.004" y1="27.1272" x2="32.6136" y2="26.5176" width="0.254" layer="16"/>
<wire x1="29.8704" y1="27.1272" x2="32.004" y2="27.1272" width="0.254" layer="16"/>
<wire x1="28.0416" y1="25.2984" x2="29.8704" y2="27.1272" width="0.254" layer="1"/>
<wire x1="28.0416" y1="7.62" x2="28.0416" y2="25.2984" width="0.254" layer="1"/>
<wire x1="30.48" y1="5.1816" x2="28.0416" y2="7.62" width="0.254" layer="1"/>
<wire x1="34.4424" y1="22.86" x2="34.425" y2="22.65" width="0.254" layer="1"/>
<wire x1="30.48" y1="5.1816" x2="30.48" y2="5.08" width="0.254" layer="1"/>
<via x="32.6136" y="26.5176" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="29.8704" y="27.1272" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$28">
<contactref element="OUT2" pad="2"/>
<contactref element="U$2" pad="19"/>
<wire x1="35.052" y1="25.2984" x2="35.052" y2="22.86" width="0.254" layer="1"/>
<wire x1="32.3088" y1="28.0416" x2="35.052" y2="25.2984" width="0.254" layer="1"/>
<wire x1="27.432" y1="28.0416" x2="32.3088" y2="28.0416" width="0.254" layer="16"/>
<wire x1="26.2128" y1="26.8224" x2="27.432" y2="28.0416" width="0.254" layer="16"/>
<wire x1="26.2128" y1="8.8392" x2="26.2128" y2="26.8224" width="0.254" layer="16"/>
<wire x1="28.0416" y1="7.0104" x2="26.2128" y2="8.8392" width="0.254" layer="16"/>
<wire x1="31.0896" y1="7.0104" x2="28.0416" y2="7.0104" width="0.254" layer="16"/>
<wire x1="33.02" y1="5.08" x2="31.0896" y2="7.0104" width="0.254" layer="16"/>
<wire x1="35.052" y1="22.86" x2="35.19" y2="22.632" width="0.254" layer="1"/>
<via x="32.3088" y="28.0416" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$31">
<contactref element="C3" pad="+"/>
<contactref element="U$2" pad="17"/>
<wire x1="36.8808" y1="23.4696" x2="36.8808" y2="22.86" width="0.254" layer="1"/>
<wire x1="38.7096" y1="25.2984" x2="36.8808" y2="23.4696" width="0.254" layer="1"/>
<wire x1="39.3192" y1="25.2984" x2="38.7096" y2="25.2984" width="0.254" layer="1"/>
<wire x1="36.8808" y1="22.86" x2="36.765" y2="22.65" width="0.254" layer="1"/>
<wire x1="39.3192" y1="25.2984" x2="39.37" y2="25.44" width="0.254" layer="1"/>
</signal>
<signal name="N$35">
<contactref element="IC1" pad="1"/>
<contactref element="R10" pad="1"/>
<contactref element="R9" pad="2"/>
<contactref element="C13" pad="+"/>
<contactref element="D2" pad="A"/>
<wire x1="13.716" y1="25.908" x2="14.3256" y2="26.5176" width="0.254" layer="1"/>
<wire x1="13.716" y1="20.7264" x2="13.716" y2="25.908" width="0.254" layer="1"/>
<wire x1="14.3256" y1="26.5176" x2="14.425" y2="26.67" width="0.254" layer="1"/>
<wire x1="13.716" y1="20.7264" x2="13.615" y2="20.695" width="0.254" layer="1"/>
<wire x1="20.7264" y1="32.3088" x2="17.3736" y2="32.3088" width="0.254" layer="1"/>
<wire x1="17.3736" y1="32.3088" x2="17.275" y2="32.385" width="0.254" layer="1"/>
<wire x1="20.7264" y1="32.3088" x2="20.825" y2="32.385" width="0.254" layer="1"/>
<wire x1="21.0312" y1="28.6512" x2="22.86" y2="26.8224" width="0.254" layer="1"/>
<wire x1="21.0312" y1="32.3088" x2="21.0312" y2="28.6512" width="0.254" layer="1"/>
<wire x1="22.86" y1="26.8224" x2="22.945" y2="26.67" width="0.254" layer="1"/>
<wire x1="21.0312" y1="32.3088" x2="20.825" y2="32.385" width="0.254" layer="1"/>
<wire x1="17.0688" y1="29.2608" x2="14.6304" y2="26.8224" width="0.254" layer="1"/>
<wire x1="17.0688" y1="32.3088" x2="17.0688" y2="29.2608" width="0.254" layer="1"/>
<wire x1="14.6304" y1="26.8224" x2="14.425" y2="26.67" width="0.254" layer="1"/>
<wire x1="17.0688" y1="32.3088" x2="17.275" y2="32.385" width="0.254" layer="1"/>
</signal>
<signal name="N$30">
<contactref element="R11" pad="1"/>
<contactref element="LED7" pad="K"/>
<wire x1="10.0584" y1="3.9624" x2="10.0584" y2="8.8392" width="0.254" layer="1"/>
<wire x1="10.0584" y1="8.8392" x2="10.03" y2="8.89" width="0.254" layer="1"/>
<wire x1="10.0584" y1="3.9624" x2="10.16" y2="3.81" width="0.254" layer="1"/>
</signal>
<signal name="N$29">
<contactref element="C9" pad="+"/>
<contactref element="U$2" pad="8"/>
<wire x1="36.8808" y1="10.3632" x2="36.8808" y2="12.8016" width="0.254" layer="1"/>
<wire x1="39.624" y1="7.62" x2="36.8808" y2="10.3632" width="0.254" layer="1"/>
<wire x1="47.5488" y1="7.62" x2="39.624" y2="7.62" width="0.254" layer="1"/>
<wire x1="47.5488" y1="17.0688" x2="47.5488" y2="7.62" width="0.254" layer="1"/>
<wire x1="47.5488" y1="20.4216" x2="47.5488" y2="17.0688" width="0.254" layer="16"/>
<wire x1="47.244" y1="20.7264" x2="47.5488" y2="20.4216" width="0.254" layer="16"/>
<wire x1="47.244" y1="22.5552" x2="47.244" y2="20.7264" width="0.254" layer="16"/>
<wire x1="47.5488" y1="22.86" x2="47.244" y2="22.5552" width="0.254" layer="16"/>
<wire x1="47.5488" y1="28.6512" x2="47.5488" y2="22.86" width="0.254" layer="16"/>
<wire x1="46.3296" y1="29.8704" x2="47.5488" y2="28.6512" width="0.254" layer="16"/>
<wire x1="44.5008" y1="31.6992" x2="46.3296" y2="29.8704" width="0.254" layer="1"/>
<wire x1="36.8808" y1="12.8016" x2="36.805" y2="12.91" width="0.254" layer="1"/>
<wire x1="44.5008" y1="31.6992" x2="44.45" y2="31.79" width="0.254" layer="1"/>
<via x="47.5488" y="17.0688" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="46.3296" y="29.8704" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
<signal name="N$33">
<contactref element="R12" pad="2"/>
<contactref element="R13" pad="1"/>
<contactref element="IC2" pad="1"/>
<contactref element="C14" pad="+"/>
<contactref element="D4" pad="A"/>
<wire x1="6.096" y1="54.5592" x2="2.7432" y2="54.5592" width="0.254" layer="1"/>
<wire x1="6.096" y1="55.4736" x2="6.096" y2="54.5592" width="0.254" layer="1"/>
<wire x1="7.62" y1="56.9976" x2="6.096" y2="55.4736" width="0.254" layer="1"/>
<wire x1="2.7432" y1="54.5592" x2="2.54" y2="54.48" width="0.254" layer="1"/>
<wire x1="7.62" y1="56.9976" x2="7.62" y2="57.28" width="0.254" layer="1"/>
<wire x1="13.1064" y1="49.3776" x2="14.0208" y2="50.292" width="0.254" layer="1"/>
<wire x1="14.0208" y1="50.292" x2="14.3256" y2="50.5968" width="0.254" layer="1"/>
<wire x1="13.1064" y1="45.72" x2="13.1064" y2="49.3776" width="0.254" layer="1"/>
<wire x1="14.3256" y1="50.5968" x2="14.425" y2="50.8" width="0.254" layer="1"/>
<wire x1="13.1064" y1="45.72" x2="12.98" y2="45.46" width="0.254" layer="1"/>
<wire x1="14.6304" y1="52.7304" x2="18.8976" y2="56.9976" width="0.254" layer="1"/>
<wire x1="14.6304" y1="50.9016" x2="14.6304" y2="52.7304" width="0.254" layer="1"/>
<wire x1="18.8976" y1="56.9976" x2="18.965" y2="57.15" width="0.254" layer="1"/>
<wire x1="14.6304" y1="50.9016" x2="14.425" y2="50.8" width="0.254" layer="1"/>
<wire x1="11.2776" y1="57.3024" x2="7.62" y2="57.3024" width="0.254" layer="1"/>
<wire x1="11.2776" y1="58.2168" x2="11.2776" y2="57.3024" width="0.254" layer="1"/>
<wire x1="11.5824" y1="58.5216" x2="11.2776" y2="58.2168" width="0.254" layer="1"/>
<wire x1="14.0208" y1="58.5216" x2="11.5824" y2="58.5216" width="0.254" layer="1"/>
<wire x1="14.0208" y1="50.292" x2="14.0208" y2="58.5216" width="0.254" layer="1"/>
<wire x1="7.62" y1="57.3024" x2="7.62" y2="57.28" width="0.254" layer="1"/>
</signal>
<signal name="VCC">
<contactref element="IC1" pad="3"/>
<contactref element="C11" pad="1"/>
<contactref element="D1" pad="C"/>
<contactref element="BE12V" pad="2"/>
<contactref element="LED7" pad="A"/>
<contactref element="C16" pad="+"/>
<contactref element="IC2" pad="3"/>
<contactref element="C18" pad="+"/>
<contactref element="C15" pad="1"/>
<contactref element="D3" pad="C"/>
<wire x1="8.2296" y1="15.8496" x2="9.4488" y2="15.8496" width="0.254" layer="1"/>
<wire x1="9.4488" y1="15.8496" x2="13.4112" y2="15.8496" width="0.254" layer="1"/>
<wire x1="8.2296" y1="15.24" x2="8.2296" y2="15.8496" width="0.254" layer="1"/>
<wire x1="13.4112" y1="15.8496" x2="13.615" y2="16.135" width="0.254" layer="1"/>
<wire x1="8.2296" y1="15.24" x2="8.205" y2="15.24" width="0.254" layer="1"/>
<wire x1="16.4592" y1="5.1816" x2="16.4592" y2="10.0584" width="0.254" layer="1"/>
<wire x1="16.4592" y1="10.0584" x2="16.38" y2="10.16" width="0.254" layer="1"/>
<wire x1="16.4592" y1="5.1816" x2="16.51" y2="5.08" width="0.254" layer="1"/>
<wire x1="15.5448" y1="3.9624" x2="12.8016" y2="3.9624" width="0.254" layer="16"/>
<wire x1="16.4592" y1="4.8768" x2="15.5448" y2="3.9624" width="0.254" layer="16"/>
<wire x1="12.8016" y1="3.9624" x2="12.7" y2="3.81" width="0.254" layer="16"/>
<wire x1="16.4592" y1="4.8768" x2="16.51" y2="5.08" width="0.254" layer="16"/>
<wire x1="19.812" y1="3.6576" x2="24.0792" y2="3.6576" width="0.254" layer="1"/>
<wire x1="19.812" y1="3.048" x2="19.812" y2="3.6576" width="0.254" layer="1"/>
<wire x1="19.2024" y1="2.4384" x2="19.812" y2="3.048" width="0.254" layer="1"/>
<wire x1="12.8016" y1="2.4384" x2="19.2024" y2="2.4384" width="0.254" layer="1"/>
<wire x1="12.8016" y1="3.6576" x2="12.8016" y2="2.4384" width="0.254" layer="1"/>
<wire x1="24.0792" y1="3.6576" x2="24.13" y2="3.725" width="0.254" layer="1"/>
<wire x1="12.8016" y1="3.6576" x2="12.7" y2="3.81" width="0.254" layer="1"/>
<wire x1="16.1544" y1="13.4112" x2="13.716" y2="15.8496" width="0.254" layer="1"/>
<wire x1="16.1544" y1="10.3632" x2="16.1544" y2="13.4112" width="0.254" layer="1"/>
<wire x1="13.716" y1="15.8496" x2="13.615" y2="16.135" width="0.254" layer="1"/>
<wire x1="16.1544" y1="10.3632" x2="16.38" y2="10.16" width="0.254" layer="1"/>
<wire x1="13.1064" y1="39.0144" x2="15.24" y2="36.8808" width="0.254" layer="1"/>
<wire x1="13.1064" y1="40.8432" x2="13.1064" y2="39.0144" width="0.254" layer="1"/>
<wire x1="15.24" y1="36.8808" x2="15.37" y2="36.83" width="0.254" layer="1"/>
<wire x1="13.1064" y1="40.8432" x2="12.98" y2="40.9" width="0.254" layer="1"/>
<wire x1="23.7744" y1="50.292" x2="24.0792" y2="50.5968" width="0.254" layer="1"/>
<wire x1="23.7744" y1="40.2336" x2="23.7744" y2="50.292" width="0.254" layer="1"/>
<wire x1="20.4216" y1="36.8808" x2="23.7744" y2="40.2336" width="0.254" layer="1"/>
<wire x1="15.5448" y1="36.8808" x2="20.4216" y2="36.8808" width="0.254" layer="1"/>
<wire x1="24.0792" y1="50.5968" x2="24.215" y2="50.8" width="0.254" layer="1"/>
<wire x1="15.5448" y1="36.8808" x2="15.37" y2="36.83" width="0.254" layer="1"/>
<wire x1="13.1064" y1="38.1" x2="9.4488" y2="38.1" width="0.254" layer="1"/>
<wire x1="9.4488" y1="38.1" x2="8.205" y2="38.1" width="0.254" layer="1"/>
<wire x1="13.1064" y1="39.0144" x2="13.1064" y2="38.1" width="0.254" layer="1"/>
<wire x1="9.4488" y1="38.1" x2="9.4488" y2="15.8496" width="0.254" layer="1"/>
<wire x1="9.4488" y1="15.8496" x2="8.205" y2="15.24" width="0.254" layer="1"/>
<wire x1="8.2296" y1="38.1" x2="8.205" y2="38.1" width="0.254" layer="1"/>
</signal>
<signal name="+8,5V">
<contactref element="IC1" pad="4"/>
<contactref element="R9" pad="1"/>
<contactref element="C12" pad="1"/>
<contactref element="D1" pad="A"/>
<contactref element="D2" pad="C"/>
<contactref element="C17" pad="+"/>
<contactref element="R8" pad="2"/>
<contactref element="C6" pad="1"/>
<contactref element="C7" pad="+"/>
<contactref element="C5" pad="1"/>
<contactref element="U$2" pad="7"/>
<contactref element="U$2" pad="18"/>
<wire x1="53.34" y1="13.716" x2="52.4256" y2="12.8016" width="0.254" layer="1"/>
<wire x1="53.34" y1="17.6784" x2="53.34" y2="13.716" width="0.254" layer="1"/>
<wire x1="52.4256" y1="12.8016" x2="52.2" y2="12.7" width="0.254" layer="1"/>
<wire x1="53.34" y1="17.6784" x2="53.47" y2="17.78" width="0.254" layer="1"/>
<wire x1="36.2712" y1="12.4968" x2="35.9664" y2="12.8016" width="0.254" layer="1"/>
<wire x1="36.2712" y1="5.1816" x2="36.2712" y2="8.5344" width="0.254" layer="1"/>
<wire x1="36.2712" y1="8.5344" x2="36.2712" y2="12.4968" width="0.254" layer="1"/>
<wire x1="34.1376" y1="3.048" x2="36.2712" y2="5.1816" width="0.254" layer="1"/>
<wire x1="26.2128" y1="3.048" x2="34.1376" y2="3.048" width="0.254" layer="1"/>
<wire x1="26.2128" y1="7.0104" x2="26.2128" y2="3.048" width="0.254" layer="1"/>
<wire x1="24.384" y1="8.8392" x2="26.2128" y2="7.0104" width="0.254" layer="1"/>
<wire x1="35.9664" y1="12.8016" x2="36" y2="12.91" width="0.254" layer="1"/>
<wire x1="24.384" y1="8.8392" x2="24.13" y2="8.975" width="0.254" layer="1"/>
<wire x1="40.2336" y1="9.7536" x2="42.9768" y2="12.4968" width="0.254" layer="1"/>
<wire x1="40.2336" y1="9.144" x2="40.2336" y2="9.7536" width="0.254" layer="1"/>
<wire x1="39.624" y1="8.5344" x2="40.2336" y2="9.144" width="0.254" layer="16"/>
<wire x1="36.2712" y1="8.5344" x2="39.624" y2="8.5344" width="0.254" layer="16"/>
<wire x1="42.9768" y1="12.4968" x2="43.05" y2="12.7" width="0.254" layer="1"/>
<wire x1="49.6824" y1="10.0584" x2="52.1208" y2="12.4968" width="0.254" layer="1"/>
<wire x1="49.6824" y1="4.2672" x2="49.6824" y2="10.0584" width="0.254" layer="1"/>
<wire x1="48.4632" y1="3.048" x2="49.6824" y2="4.2672" width="0.254" layer="1"/>
<wire x1="34.1376" y1="3.048" x2="48.4632" y2="3.048" width="0.254" layer="1"/>
<wire x1="52.1208" y1="12.4968" x2="52.2" y2="12.7" width="0.254" layer="1"/>
<wire x1="35.9664" y1="29.5656" x2="35.9664" y2="22.86" width="0.254" layer="1"/>
<wire x1="35.052" y1="30.48" x2="35.9664" y2="29.5656" width="0.254" layer="1"/>
<wire x1="35.9664" y1="22.86" x2="35.974" y2="22.63" width="0.254" layer="1"/>
<wire x1="35.052" y1="30.48" x2="34.875" y2="30.48" width="0.254" layer="1"/>
<wire x1="2.1336" y1="30.48" x2="2.7432" y2="31.0896" width="0.254" layer="1"/>
<wire x1="2.1336" y1="24.9936" x2="2.1336" y2="25.2984" width="0.254" layer="1"/>
<wire x1="2.1336" y1="25.2984" x2="2.1336" y2="30.48" width="0.254" layer="1"/>
<wire x1="2.7432" y1="31.0896" x2="3.045" y2="31.115" width="0.254" layer="1"/>
<wire x1="2.1336" y1="24.9936" x2="2.095" y2="24.765" width="0.254" layer="1"/>
<wire x1="24.6888" y1="31.3944" x2="23.7744" y2="32.3088" width="0.254" layer="1"/>
<wire x1="24.6888" y1="22.2504" x2="24.6888" y2="31.3944" width="0.254" layer="1"/>
<wire x1="21.0312" y1="18.5928" x2="23.4696" y2="21.0312" width="0.254" layer="1"/>
<wire x1="23.4696" y1="21.0312" x2="24.6888" y2="22.2504" width="0.254" layer="1"/>
<wire x1="23.7744" y1="32.3088" x2="23.625" y2="32.385" width="0.254" layer="1"/>
<wire x1="21.0312" y1="18.5928" x2="20.795" y2="18.415" width="0.254" layer="1"/>
<wire x1="23.4696" y1="21.0312" x2="17.9832" y2="26.5176" width="0.254" layer="1"/>
<wire x1="17.9832" y1="26.5176" x2="17.695" y2="26.67" width="0.254" layer="1"/>
<wire x1="23.4696" y1="21.0312" x2="20.795" y2="18.415" width="0.254" layer="1"/>
<wire x1="4.572" y1="25.2984" x2="2.1336" y2="25.2984" width="0.254" layer="1"/>
<wire x1="15.5448" y1="25.2984" x2="4.572" y2="25.2984" width="0.254" layer="16"/>
<wire x1="17.6784" y1="25.2984" x2="15.5448" y2="25.2984" width="0.254" layer="1"/>
<wire x1="17.6784" y1="26.5176" x2="17.6784" y2="25.2984" width="0.254" layer="1"/>
<wire x1="17.6784" y1="26.5176" x2="17.695" y2="26.67" width="0.254" layer="1"/>
<wire x1="31.0896" y1="30.48" x2="34.875" y2="30.48" width="0.254" layer="1"/>
<wire x1="20.7264" y1="30.48" x2="31.0896" y2="30.48" width="0.254" layer="16"/>
<wire x1="15.5448" y1="25.2984" x2="20.7264" y2="30.48" width="0.254" layer="16"/>
<wire x1="21.0312" y1="12.192" x2="24.0792" y2="9.144" width="0.254" layer="1"/>
<wire x1="21.0312" y1="18.288" x2="21.0312" y2="12.192" width="0.254" layer="1"/>
<wire x1="24.0792" y1="9.144" x2="24.13" y2="8.975" width="0.254" layer="1"/>
<wire x1="21.0312" y1="18.288" x2="20.795" y2="18.415" width="0.254" layer="1"/>
<via x="40.2336" y="9.144" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="36.2712" y="8.5344" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="4.572" y="25.2984" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="15.5448" y="25.2984" extent="1-16" drill="0.6096" shape="octagon"/>
<via x="31.0896" y="30.48" extent="1-16" drill="0.6096" shape="octagon"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
