<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.4">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.01" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="yes" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="yes" active="yes"/>
<layer number="103" name="tMap" color="7" fill="1" visible="yes" active="yes"/>
<layer number="104" name="Name" color="7" fill="1" visible="yes" active="yes"/>
<layer number="105" name="tPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="106" name="bPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="107" name="Crop" color="7" fill="1" visible="yes" active="yes"/>
<layer number="108" name="fp8" color="7" fill="1" visible="yes" active="yes"/>
<layer number="109" name="fp9" color="7" fill="1" visible="yes" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="yes" active="yes"/>
<layer number="111" name="LPC17xx" color="7" fill="1" visible="yes" active="yes"/>
<layer number="112" name="tSilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="yes" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="126" name="_bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="127" name="_tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="128" name="_bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="yes" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="yes" active="yes"/>
<layer number="152" name="_bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="yes" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="yes" active="yes"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="yes" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="yes" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="yes" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="yes" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="yes" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="yes" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="215" name="215bmp" color="16" fill="1" visible="yes" active="yes"/>
<layer number="216" name="216bmp" color="17" fill="1" visible="yes" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="yes" active="yes"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="yes" active="yes"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="yes" active="yes"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="yes" active="yes"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="yes" active="yes"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="yes" active="yes"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="yes" active="yes"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="yes" active="yes"/>
<layer number="248" name="Housing" color="7" fill="1" visible="yes" active="yes"/>
<layer number="249" name="Edge" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<plain>
<wire x1="39.37" y1="-15.24" x2="171.43" y2="-15.24" width="0.6096" layer="20"/>
<wire x1="171.43" y1="-15.24" x2="171.43" y2="87.3" width="0.6096" layer="20"/>
<wire x1="171.43" y1="87.3" x2="39.37" y2="87.3" width="0.6096" layer="20"/>
<wire x1="39.37" y1="87.3" x2="39.37" y2="-15.24" width="0.6096" layer="20"/>
<wire x1="151.13" y1="-59.69" x2="151.13" y2="-90.17" width="0.6096" layer="20"/>
<wire x1="151.13" y1="-90.17" x2="217.17" y2="-90.17" width="0.6096" layer="20"/>
<wire x1="217.17" y1="-90.17" x2="217.17" y2="-59.69" width="0.6096" layer="20"/>
<wire x1="217.17" y1="-59.69" x2="151.13" y2="-59.69" width="0.6096" layer="20"/>
<circle x="162.56" y="-74.93" radius="1.79605" width="0.6096" layer="20"/>
<circle x="184.15" y="-74.93" radius="1.79605" width="0.6096" layer="20"/>
<circle x="205.74" y="-74.93" radius="1.79605" width="0.6096" layer="20"/>
<dimension x1="39.37" y1="-15.24" x2="171.43" y2="-15.24" x3="105.4" y3="-29.21" textsize="3.5" layer="16"/>
<dimension x1="171.43" y1="-15.24" x2="171.43" y2="87.3" x3="190.5" y3="36.03" textsize="3.5" layer="16"/>
</plain>
<libraries>
<library name="SparkFun">
<description>Spark Fun Electronics' preferred foot prints. &lt;b&gt;Not to be used for commercial purposes.&lt;/b&gt; We've spent an enormous amount of time creating and checking these footprints and parts. If you enjoy using this library, please buy one of our products at www.sparkfun.com.</description>
<packages>
<package name="DIL-08">
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.7" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.7" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.7" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.7" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.7" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.7" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.7" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.7" diameter="1.9304" shape="octagon" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LED3MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108" cap="flat"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949" cap="flat"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022" cap="flat"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215" cap="flat"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701" cap="flat"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822" cap="flat"/>
<wire x1="1.5748" y1="1.2954" x2="1.5748" y2="0.7874" width="0.254" layer="21"/>
<wire x1="1.5748" y1="-1.2954" x2="1.5748" y2="-0.8382" width="0.254" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" diameter="1.8796"/>
<pad name="K" x="1.27" y="0" drill="0.8128" diameter="1.8796"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL28-3">
<wire x1="-17.78" y1="-1.27" x2="-17.78" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="-1.27" x2="-17.78" y2="1.27" width="0.2032" layer="21" curve="180"/>
<wire x1="17.78" y1="-3.048" x2="17.78" y2="3.048" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="3.048" x2="-17.78" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="3.048" x2="-17.526" y2="3.048" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="-3.048" x2="-17.526" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="17.78" y1="-3.048" x2="17.526" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="17.78" y1="3.048" x2="17.526" y2="3.048" width="0.2032" layer="21"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-15.24" y="0" size="0.6096" layer="25" ratio="10">&gt;NAME</text>
<text x="-15.24" y="-1.27" size="0.6096" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="HC49U-V">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-2.921" y1="-2.286" x2="2.921" y2="-2.286" width="0.4064" layer="21"/>
<wire x1="-2.921" y1="2.286" x2="2.921" y2="2.286" width="0.4064" layer="21"/>
<wire x1="-2.921" y1="-1.778" x2="2.921" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.778" x2="-2.921" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.778" x2="2.921" y2="-1.778" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.921" y1="2.286" x2="2.921" y2="-2.286" width="0.4064" layer="21" curve="-180"/>
<wire x1="-2.921" y1="2.286" x2="-2.921" y2="-2.286" width="0.4064" layer="21" curve="180"/>
<wire x1="-2.921" y1="1.778" x2="-2.921" y2="-1.778" width="0.1524" layer="21" curve="180"/>
<wire x1="-0.254" y1="0.889" x2="0.254" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.889" x2="0.254" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.889" x2="-0.254" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.889" x2="-0.254" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.889" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.889" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.413" y="0" drill="0.8128"/>
<pad name="2" x="2.413" y="0" drill="0.8128"/>
<text x="-5.08" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.191" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-2.794" x2="3.81" y2="2.794" layer="43"/>
<rectangle x1="-4.318" y1="-2.54" x2="-3.81" y2="2.54" layer="43"/>
<rectangle x1="-4.826" y1="-2.286" x2="-4.318" y2="2.286" layer="43"/>
<rectangle x1="-5.334" y1="-1.778" x2="-4.826" y2="1.778" layer="43"/>
<rectangle x1="-5.588" y1="-1.27" x2="-5.334" y2="1.016" layer="43"/>
<rectangle x1="3.81" y1="-2.54" x2="4.318" y2="2.54" layer="43"/>
<rectangle x1="4.318" y1="-2.286" x2="4.826" y2="2.286" layer="43"/>
<rectangle x1="4.826" y1="-1.778" x2="5.334" y2="1.778" layer="43"/>
<rectangle x1="5.334" y1="-1.016" x2="5.588" y2="1.016" layer="43"/>
</package>
<package name="TACTILE-PTH">
<description>&lt;b&gt;OMRON SWITCH&lt;/b&gt;</description>
<wire x1="3.048" y1="1.016" x2="3.048" y2="2.54" width="0.2032" layer="51"/>
<wire x1="3.048" y1="2.54" x2="2.54" y2="3.048" width="0.2032" layer="51"/>
<wire x1="2.54" y1="-3.048" x2="3.048" y2="-2.54" width="0.2032" layer="51"/>
<wire x1="3.048" y1="-2.54" x2="3.048" y2="-1.016" width="0.2032" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-3.048" y2="2.54" width="0.2032" layer="51"/>
<wire x1="-3.048" y1="2.54" x2="-3.048" y2="1.016" width="0.2032" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-3.048" y2="-2.54" width="0.2032" layer="51"/>
<wire x1="-3.048" y1="-2.54" x2="-3.048" y2="-1.016" width="0.2032" layer="51"/>
<wire x1="2.54" y1="-3.048" x2="2.159" y2="-3.048" width="0.2032" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-2.159" y2="-3.048" width="0.2032" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-2.159" y2="3.048" width="0.2032" layer="51"/>
<wire x1="2.54" y1="3.048" x2="2.159" y2="3.048" width="0.2032" layer="51"/>
<wire x1="2.159" y1="3.048" x2="-2.159" y2="3.048" width="0.2032" layer="21"/>
<wire x1="-2.159" y1="-3.048" x2="2.159" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="3.048" y1="0.998" x2="3.048" y2="-1.016" width="0.2032" layer="21"/>
<wire x1="-3.048" y1="1.028" x2="-3.048" y2="-1.016" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="0.508" width="0.2032" layer="51"/>
<wire x1="-2.54" y1="-0.508" x2="-2.54" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="-2.54" y1="0.508" x2="-2.159" y2="-0.381" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.778" width="0.2032" layer="21"/>
<pad name="1" x="-3.2512" y="2.2606" drill="1.016" diameter="1.8796"/>
<pad name="2" x="3.2512" y="2.2606" drill="1.016" diameter="1.8796"/>
<pad name="3" x="-3.2512" y="-2.2606" drill="1.016" diameter="1.8796"/>
<pad name="4" x="3.2512" y="-2.2606" drill="1.016" diameter="1.8796"/>
<text x="-2.54" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="0309V">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="C0805">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="C075-042X103">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" shape="octagon"/>
<text x="-4.699" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-6">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E3,5-8">
grid 3.5 mm, diameter 8 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RTRIMT93YA">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; VISHAY&lt;p&gt;
Cermet, abgedichtet nach IP67</description>
<wire x1="2.15" y1="-4.75" x2="2.15" y2="4.75" width="0.254" layer="21"/>
<wire x1="2.15" y1="4.75" x2="-2.55" y2="4.75" width="0.254" layer="21"/>
<wire x1="-2.55" y1="4.75" x2="-2.55" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-2.55" y1="-4.75" x2="2.15" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-0.75" y1="2.6" x2="-0.3" y2="3.3" width="0.1524" layer="21" curve="-311.390901"/>
<wire x1="-0.75" y1="2.6" x2="-0.3" y2="3.3" width="0.1524" layer="51" curve="48.609099"/>
<pad name="1" x="0" y="-2.54" drill="0.6096"/>
<pad name="2" x="0" y="0" drill="0.6096"/>
<pad name="3" x="0" y="2.54" drill="0.6096"/>
<text x="-3.04" y="-4.89" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.01" y="-4.89" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.45" y1="2.5" x2="-1.15" y2="4.4" layer="21"/>
</package>
<package name="0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.7" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.7" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0411/15">
type 0411, grid 15 mm</description>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DO41-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="MINIMELF">
<description>&lt;b&gt;Mini Melf Diode&lt;/b&gt;</description>
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.5" y1="0.5" x2="-0.5" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.5" y1="0" x2="0.5" y2="-0.5" width="0.2032" layer="21"/>
<wire x1="0.5" y1="-0.5" x2="0.5" y2="0.5" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
</packages>
</library>
<library name="transistor-power">
<description>&lt;b&gt;Power Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO220BV">
<description>&lt;b&gt;Molded Package&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="G" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="D" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="S" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="TO220V">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
</package>
</packages>
</library>
<library name="con-dinkle">
<packages>
<package name="EK500V4R-B">
<description>&lt;b&gt;Dinkle® 5mm Pitch Terminal Block - 2 Way - Back Half&lt;/b&gt;
&lt;p&gt;Rated at 20A, 300VAC&lt;/p&gt;
&lt;p&gt;Cable size: 2mm²
&lt;p&gt;Dinkle Series EK508V&lt;/p&gt;
&lt;p&gt;Altronics Part: P2024A&lt;/p&gt;</description>
<wire x1="0" y1="5" x2="7.5" y2="5" width="0.127" layer="21"/>
<wire x1="0" y1="5" x2="0" y2="16.5" width="0.127" layer="21"/>
<wire x1="0" y1="16.5" x2="10.16" y2="16.5" width="0.127" layer="21"/>
<wire x1="10.16" y1="16.5" x2="10.16" y2="5" width="0.127" layer="21"/>
<wire x1="10.16" y1="5" x2="0" y2="5" width="0.127" layer="21"/>
<wire x1="10.66" y1="15.215" x2="10.66" y2="16.215" width="0.127" layer="51"/>
<wire x1="10.16" y1="15.715" x2="10.66" y2="16.215" width="0.127" layer="51"/>
<wire x1="10.66" y1="15.215" x2="10.16" y2="15.715" width="0.127" layer="51"/>
<wire x1="9.76" y1="7.01" x2="9.76" y2="6.01" width="0.127" layer="51"/>
<wire x1="10.16" y1="6.51" x2="9.76" y2="6.01" width="0.127" layer="51"/>
<wire x1="9.76" y1="7.01" x2="10.16" y2="6.51" width="0.127" layer="51"/>
<wire x1="-0.5" y1="7.01" x2="-0.5" y2="6.01" width="0.127" layer="51"/>
<wire x1="0" y1="6.51" x2="-0.5" y2="6.01" width="0.127" layer="51"/>
<wire x1="-0.5" y1="7.01" x2="0" y2="6.51" width="0.127" layer="51"/>
<wire x1="0.5" y1="15.215" x2="0.5" y2="16.215" width="0.127" layer="51"/>
<wire x1="0" y1="15.715" x2="0.5" y2="16.215" width="0.127" layer="51"/>
<wire x1="0.5" y1="15.215" x2="0" y2="15.715" width="0.127" layer="51"/>
<wire x1="10.16" y1="16.5" x2="10.16" y2="15.715" width="0.127" layer="51"/>
<wire x1="10.16" y1="15.715" x2="10.16" y2="6.51" width="0.127" layer="51"/>
<wire x1="10.16" y1="6.51" x2="10.16" y2="5" width="0.127" layer="51"/>
<wire x1="10.16" y1="5" x2="0" y2="5" width="0.127" layer="51"/>
<wire x1="0" y1="5" x2="0" y2="16.5" width="0.127" layer="51"/>
<wire x1="0" y1="16.5" x2="10.16" y2="16.5" width="0.127" layer="51"/>
<circle x="2.54" y="10.75" radius="1.5" width="0.127" layer="51"/>
<circle x="7.62" y="10.75" radius="1.5" width="0.127" layer="51"/>
<pad name="P$1" x="2.54" y="15.24" drill="1" diameter="2.54" shape="octagon" rot="R90"/>
<pad name="P$2" x="7.62" y="15.24" drill="1" diameter="2.54" shape="octagon" rot="R90"/>
</package>
</packages>
</library>
<library name="inductors">
<description>&lt;b&gt;Inductors and Filters&lt;/b&gt;&lt;p&gt;
Based on the previous library ind-a.lbr&lt;p&gt;
<packages>
<package name="SFT830D">
<description>&lt;B&gt;INDUCTOR&lt;/B&gt;&lt;p&gt;
distributor Schukat</description>
<wire x1="3.175" y1="8.509" x2="3.175" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-8.509" x2="-3.175" y2="8.509" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="8.509" x2="3.175" y2="8.509" width="0.6096" layer="21"/>
<wire x1="-3.683" y1="7.874" x2="3.683" y2="7.874" width="0.6096" layer="21"/>
<wire x1="-3.683" y1="7.112" x2="3.683" y2="7.112" width="0.6096" layer="21"/>
<wire x1="-3.683" y1="6.223" x2="3.683" y2="6.223" width="0.6096" layer="21"/>
<wire x1="-3.683" y1="5.207" x2="3.683" y2="5.207" width="0.6096" layer="21"/>
<wire x1="3.683" y1="-5.207" x2="-3.683" y2="-5.207" width="0.6096" layer="21"/>
<wire x1="3.683" y1="-6.223" x2="-3.683" y2="-6.223" width="0.6096" layer="21"/>
<wire x1="3.683" y1="-7.112" x2="-3.683" y2="-7.112" width="0.6096" layer="21"/>
<wire x1="3.683" y1="-7.874" x2="-3.683" y2="-7.874" width="0.6096" layer="21"/>
<wire x1="-3.683" y1="4.191" x2="3.683" y2="4.191" width="0.6096" layer="21"/>
<wire x1="3.683" y1="-4.191" x2="-3.683" y2="-4.191" width="0.6096" layer="21"/>
<wire x1="-3.683" y1="0.127" x2="3.683" y2="0.127" width="0.6096" layer="21"/>
<wire x1="-5.08" y1="0" x2="-3.429" y2="0.635" width="0.6096" layer="51"/>
<wire x1="-2.159" y1="8.763" x2="2.159" y2="8.763" width="0.6096" layer="21"/>
<wire x1="-3.175" y1="-8.509" x2="3.175" y2="-8.509" width="0.6096" layer="21"/>
<wire x1="-2.159" y1="-8.763" x2="2.159" y2="-8.763" width="0.6096" layer="21"/>
<wire x1="-3.683" y1="3.048" x2="3.683" y2="3.048" width="0.6096" layer="21"/>
<wire x1="3.683" y1="-3.048" x2="-3.683" y2="-3.048" width="0.6096" layer="21"/>
<wire x1="3.683" y1="-1.651" x2="-3.683" y2="-1.651" width="0.6096" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="3.683" y2="1.651" width="0.6096" layer="21"/>
<wire x1="3.429" y1="-0.508" x2="5.08" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-4.445" y="2.032" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="5.842" y="2.032" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="semicon-smd-ipc">
<description>&lt;b&gt;IPC Standard SMD Semiconductors&lt;/b&gt;&lt;p&gt;
A few devices defined according to the IPC standard.&lt;p&gt;
Based on:&lt;p&gt;
IPC-SM-782&lt;br&gt;
IRevision A, August 1993&lt;br&gt;
Includes Amendment 1, October 1996&lt;p&gt;
<packages>
<package name="SOT23">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="optocoupler-2">
<description>&lt;b&gt;Opto Couplers&lt;/b&gt;&lt;p&gt;
Siemens, Hewlett-Packard, Texas Instuments, Sharp, Motorola&lt;p&gt;
<packages>
<package name="DIL04">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="2.54" y1="2.921" x2="-2.54" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="2.54" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.921" x2="2.54" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.921" x2="-2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="4.191" y="-2.921" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-2.921" y="-2.667" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
</packages>
</library>
<library name="nixieeeee">
<packages>
<package name="NIXIE-13">
<description>Eagle SCR autogenerated 13 pin Nixie socket</description>
<pad name="K5" x="-2.2636" y="4.3129" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="-2.2636" y="4.3129" radius="0.9" width="0.3" layer="21"/>
<pad name="K4" x="-4.0086" y="2.7669" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="-4.0086" y="2.7669" radius="0.9" width="0.3" layer="21"/>
<pad name="TL" x="-4.8353" y="0.5871" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="-4.8353" y="0.5871" radius="0.9" width="0.3" layer="21"/>
<pad name="K3" x="-4.5542" y="-1.7272" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="-4.5542" y="-1.7272" radius="0.9" width="0.3" layer="21"/>
<pad name="K2" x="-3.2299" y="-3.6458" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="-3.2299" y="-3.6458" radius="0.9" width="0.3" layer="21"/>
<pad name="K1" x="-1.1657" y="-4.7292" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="-1.1657" y="-4.7292" radius="0.9" width="0.3" layer="21"/>
<pad name="A" x="1.1657" y="-4.7292" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="1.1657" y="-4.7292" radius="0.9" width="0.3" layer="21"/>
<pad name="K0" x="3.2299" y="-3.6458" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="3.2299" y="-3.6458" radius="0.9" width="0.3" layer="21"/>
<pad name="K9" x="4.5542" y="-1.7272" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="4.5542" y="-1.7272" radius="0.9" width="0.3" layer="21"/>
<pad name="TP" x="4.8353" y="0.5871" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="4.8353" y="0.5871" radius="0.9" width="0.3" layer="21"/>
<pad name="K8" x="4.0086" y="2.7669" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="4.0086" y="2.7669" radius="0.9" width="0.3" layer="21"/>
<pad name="K7" x="2.2636" y="4.3129" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="2.2636" y="4.3129" radius="0.9" width="0.3" layer="21"/>
<pad name="K6" x="0" y="4.8708" drill="0.6" diameter="1.778" shape="octagon" rot="R180"/>
<circle x="0" y="4.8708" radius="0.9" width="0.3" layer="21"/>
<circle x="0" y="0" radius="5.6708" width="0.3" layer="21"/>
<circle x="0" y="0" radius="5.2708" width="0.1" layer="39"/>
<text x="-1.27" y="-3.81" size="0.8128" layer="21">1</text>
<text x="-2.54" y="-2.54" size="0.8128" layer="21">2</text>
<text x="-3.81" y="-1.27" size="0.8128" layer="21">3</text>
<text x="-3.81" y="0" size="0.8128" layer="21">tl</text>
<text x="-2.54" y="2.54" size="0.8128" layer="21">5</text>
<text x="-3.81" y="1.27" size="0.8128" layer="21">4</text>
<text x="0" y="2.54" size="0.8128" layer="21">6</text>
<text x="2.54" y="2.54" size="0.8128" layer="21" align="bottom-right">7</text>
<text x="3.81" y="1.27" size="0.8128" layer="21" align="bottom-right">8</text>
<text x="3.81" y="0" size="0.8128" layer="21" align="bottom-right">tp</text>
<text x="3.81" y="-1.27" size="0.8128" layer="21" align="bottom-right">9</text>
<text x="2.54" y="-2.54" size="0.8128" layer="21" align="bottom-right">0</text>
<text x="1.27" y="-3.81" size="0.8128" layer="21" align="bottom-right">a</text>
<circle x="0" y="0" radius="9.144" width="0.3" layer="21"/>
</package>
</packages>
</library>
<library name="74xx-eu">
<packages>
<package name="DIL16">
<wire x1="10.16" y1="2.921" x2="-10.16" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.921" x2="-10.16" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="-10.16" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.016" x2="-10.16" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-10.541" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-7.493" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="ds18b20">
<description>&lt;h1&gt;Dallas/Maxim 1-Wire/iButton devices&lt;/h1&gt;
&lt;p&gt;Onewire is a simple, low-cost bus system working with hundreds of devices on an up to 300m long one-wire (plus GND) bus system. It is relative slow (~16kBaud) but electrically undemanding, too. The onewire is hotplug-capable, if the host software supports it. The bus can be controlled by a single &amp;mu;C port pin or by special host adapter chips, which are available for RS232, Parallel, I&lt;sup&gt;2&lt;/sup&gt;C, and USB to onewire conversion. They are available as ready-to-run host adapter devices, too.&lt;/p&gt;
&lt;p&gt;The chips on the bus can be powered through the bus line, this is called "parasite power". All neccesary circuit and capacities for parasite power are on chip. Some chips need an additional power source to provide all features.&lt;/p&gt;
&lt;p&gt;iButton is an application for onewire devices, using special packaged onewire devices as keys or for data storage. All onewire chips have a unique serial number for technical reasons, and together with the hot-plug capability this makes them useable as unique keys. In addition, many onewire chips have additional memory (EPROM, EEPROM, RAM) on the chip, which can be used to store cryptographic keys. iButtons come in various packages which are protected against corrosive agents and weather influences.&lt;/p&gt;
&lt;p&gt;Get more info at &lt;tt&gt;http://www.maxim-ic.com/1-Wire.cfm&lt;/tt&gt;&lt;/p&gt;
&lt;p&gt;Linux driver at &lt;tt&gt;http://owfs.sf.net&lt;/tt&gt;&lt;/p&gt;
&lt;h3&gt;Copyright notice:&lt;/h3&gt;
&lt;p&gt;The devices in this library are copyrighted by various authors &amp;mdash; permission to use, distribute and modify this library is given to you at the terms of the LGPL. Copyright holders are&lt;/p&gt;
&lt;ul&gt;
&lt;li&gt;Jan Kandziora &amp;lt;jjj@gmx.de&amp;gt;&lt;/li&gt;
&lt;li&gt;Giovanni Varasano &amp;lt;giovanni.varasano@fastwebnet.it&amp;gt;&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;The authorship for each device is given in the device notes.&lt;/p&gt;</description>
<packages>
<package name="TO92-">
<description>&lt;b&gt;TO-92&lt;/b&gt;</description>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.1524" layer="21" curve="-129.583345" cap="flat"/>
<wire x1="1.136" y1="-0.127" x2="-1.136" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.413" y2="-1.1359" width="0.1524" layer="51" curve="50.416655" cap="flat"/>
<wire x1="-1.404" y1="-0.127" x2="-2.664" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-2.4135" y1="-1.1359" x2="-2.095" y2="-1.651" width="0.1524" layer="21" curve="13.038528" cap="flat"/>
<wire x1="-1.136" y1="-0.127" x2="-1.404" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.413" y2="1.1359" width="0.1524" layer="51" curve="50.416655" cap="flat"/>
<wire x1="2.664" y1="-0.127" x2="1.404" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="1.404" y1="-0.127" x2="1.136" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="2.095" y1="-1.651" x2="2.4247" y2="-1.1118" width="0.1524" layer="21" curve="13.609443" cap="flat"/>
<pad name="3" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="pinhead">
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="1X08">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="5.715" y1="1.27" x2="6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.27" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0.635" x2="10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-10.2362" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.16" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="-9.144" y1="-0.254" x2="-8.636" y2="0.254" layer="51"/>
<rectangle x1="8.636" y1="-0.254" x2="9.144" y2="0.254" layer="51"/>
</package>
<package name="1X07">
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.635" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0.635" x2="-8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-0.635" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0.635" x2="8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-8.9662" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.89" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="-5.334" y1="-0.254" x2="-4.826" y2="0.254" layer="51"/>
<rectangle x1="-7.874" y1="-0.254" x2="-7.366" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="adafruit">
<packages>
<package name="LED5MMRGB">
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.127" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.127" layer="21" curve="-286.260205"/>
<wire x1="-1.524" y1="0" x2="0.254" y2="0" width="0.127" layer="25"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-1.905" width="0.127" layer="25"/>
<wire x1="0.254" y1="-1.905" x2="-1.524" y2="-1.905" width="0.127" layer="25"/>
<wire x1="-1.524" y1="-1.905" x2="-1.524" y2="0" width="0.127" layer="25"/>
<circle x="0" y="0" radius="2.5" width="0.127" layer="21"/>
<pad name="1" x="-2.159" y="0.9684" drill="0.8" diameter="1.6764" rot="R90"/>
<pad name="2" x="-0.635" y="-0.9684" drill="0.8" diameter="1.6764" shape="octagon" rot="R90"/>
<pad name="3" x="0.889" y="0.9684" drill="0.8" diameter="1.6764" rot="R90"/>
<pad name="4" x="2.159" y="-0.9684" drill="0.8" diameter="1.6764" rot="R90"/>
<text x="-3.175" y="3.175" size="1.27" layer="21">&gt;NAME</text>
</package>
</packages>
</library>
<library name="SparkFun-DiscreteSemi">
<description>&lt;h3&gt;SparkFun Electronics' preferred foot prints&lt;/h3&gt;
In this library you'll find discrete semiconductors- transistors, diodes, TRIACs, optoisolators, etc.&lt;br&gt;&lt;br&gt;
We've spent an enormous amount of time creating and checking these footprints and parts, but it is the end user's responsibility to ensure correctness and suitablity for a given componet or application. If you enjoy using this library, please buy one of our products at www.sparkfun.com.
&lt;b&gt;Licensing:&lt;/b&gt; CC v3.0 Share-Alike You are welcome to use this library for commercial purposes. For attribution, we ask that when you begin to sell your device using our footprint, you email us with a link to the product being sold. We want bragging rights that we helped (in a very small part) to create your 8th world wonder. We would like the opportunity to feature your device on our homepage.</description>
<packages>
<package name="TO-92">
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-0.7863" y1="2.5485" x2="-2.0946" y2="-1.651" width="0.2032" layer="21" curve="111.098962"/>
<wire x1="2.0945" y1="-1.651" x2="0.7863" y2="2.548396875" width="0.2032" layer="21" curve="111.099507"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.2032" layer="21"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.2032" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.2032" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.2032" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" diameter="1.8796"/>
<pad name="2" x="0" y="1.905" drill="0.8128" diameter="1.8796"/>
<pad name="3" x="1.27" y="0" drill="0.8128" diameter="1.8796"/>
<text x="3.175" y="0.635" size="0.4064" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="0.4064" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO92-EBC">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line E B C from top&lt;p&gt;</description>
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="4,1">
<description>&lt;b&gt;MOUNTING HOLE&lt;/b&gt; 4.1 mm with drill center</description>
<wire x1="-2.54" y1="0" x2="0" y2="-2.54" width="3.9116" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.54" x2="2.54" y2="0" width="3.9116" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="4.4958" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="3.81" width="2.54" layer="39"/>
<circle x="0" y="0" radius="3.81" width="2.54" layer="40"/>
<circle x="0" y="0" radius="3.81" width="2.54" layer="41"/>
<circle x="0" y="0" radius="3.81" width="2.54" layer="42"/>
<circle x="0" y="0" radius="3.81" width="2.54" layer="43"/>
<circle x="0" y="0" radius="2.15" width="0.1524" layer="21"/>
<hole x="0" y="0" drill="4.1"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="15mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="15mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="IC2" library="SparkFun" package="DIL-08" value="MC34063" x="130.81" y="71.12" rot="R270"/>
<element name="R3" library="rcl" package="0309V" value="1R" x="130.81" y="78.74" rot="R180"/>
<element name="C6" library="rcl" package="C0805" value="2.2n" x="124.46" y="68.58" rot="MR270"/>
<element name="R6" library="rcl" package="R0805" value="10k" x="130.81" y="69.85" rot="MR180"/>
<element name="R4" library="rcl" package="R0805" value="1M5" x="124.46" y="63.5" rot="MR180"/>
<element name="C9" library="rcl" package="C075-042X103" value="100n/250V" x="119.38" y="67.31" rot="R90"/>
<element name="C10" library="rcl" package="E2,5-6" value="2.2u/250V" x="102.87" y="64.77" rot="R90"/>
<element name="D4" library="diode" package="DO41-10" value="BAV21" x="106.68" y="68.58" rot="R90"/>
<element name="C1" library="rcl" package="E3,5-8" value="220u/25V" x="139.7" y="77.47"/>
<element name="C2" library="rcl" package="C0805" value="100n" x="149.86" y="72.39" rot="MR270"/>
<element name="C8" library="rcl" package="E3,5-8" value="220u/25V" x="121.92" y="77.47" rot="R180"/>
<element name="R2" library="rcl" package="R0805" value="1k" x="121.92" y="71.12" rot="MR90"/>
<element name="C7" library="rcl" package="C0805" value="10n" x="130.81" y="67.31" rot="MR0"/>
<element name="T2" library="transistor-power" package="TO220BV" value="IRF740" x="100.33" y="73.66" rot="R90"/>
<element name="R5" library="rcl" package="RTRIMT93YA" value="200k" x="130.81" y="63.5" rot="R90"/>
<element name="D3" library="diode" package="MINIMELF" value="1N4148" x="111.76" y="71.12" rot="MR180"/>
<element name="C5" library="rcl" package="E2,5-6" value="22u/10V" x="139.7" y="69.85" rot="R90"/>
<element name="R1" library="rcl" package="R0805" value="270R" x="140.97" y="66.04" rot="MR0"/>
<element name="LED" library="SparkFun" package="LED3MM" value="" x="143.51" y="63.5"/>
<element name="C3" library="rcl" package="C0805" value="100n" x="142.24" y="69.85" rot="MR90"/>
<element name="IC1" library="linear" package="TO220V" value="7805" x="148.59" y="71.12" rot="R270"/>
<element name="12V" library="con-dinkle" package="EK500V4R-B" value="" x="167.64" y="67.31" rot="R90"/>
<element name="L1" library="inductors" package="SFT830D" value="220u" x="111.76" y="76.2" rot="R180"/>
<element name="T1" library="semicon-smd-ipc" package="SOT23" value="BC807" x="111.76" y="74.93" rot="MR0"/>
<element name="IC3" library="SparkFun" package="DIL28-3" value="ATMEGA328P" x="158.75" y="40.64" rot="R270"/>
<element name="Q1" library="SparkFun" package="HC49U-V" value="16MHz" x="149.86" y="34.29" rot="R270"/>
<element name="S1" library="SparkFun" package="TACTILE-PTH" value="RESET" x="158.75" y="62.23"/>
<element name="R7" library="rcl" package="R0805" value="10k" x="152.4" y="59.69" rot="MR90"/>
<element name="C11" library="rcl" package="C0805" value="18-22p" x="147.32" y="38.1" rot="MR270"/>
<element name="C12" library="rcl" package="C0805" value="18-22p" x="147.32" y="33.02" rot="MR90"/>
<element name="R19" library="rcl" package="0207/10" value="180R" x="58.42" y="27.94" rot="R270"/>
<element name="R20" library="rcl" package="0207/10" value="120R" x="55.88" y="29.21" rot="R270"/>
<element name="R21" library="rcl" package="0207/10" value="120R" x="68.58" y="30.48" rot="R270"/>
<element name="OK1" library="optocoupler-2" package="DIL04" value="TIL197" x="78.74" y="67.31" rot="R180"/>
<element name="OK2" library="optocoupler-2" package="DIL04" value="TIL197" x="83.82" y="67.31" rot="R180"/>
<element name="OK3" library="optocoupler-2" package="DIL04" value="TIL197" x="88.9" y="67.31" rot="R180"/>
<element name="R13" library="rcl" package="R0805" value="330R" x="149.86" y="54.61" rot="MR0"/>
<element name="R14" library="rcl" package="R0805" value="330R" x="149.86" y="52.07" rot="MR0"/>
<element name="R15" library="rcl" package="R0805" value="330R" x="149.86" y="49.53" rot="MR0"/>
<element name="DIGIT1" library="nixieeeee" package="NIXIE-13" value="NIXIE1" x="162.56" y="-74.93" rot="R180"/>
<element name="DIGIT2" library="nixieeeee" package="NIXIE-13" value="NIXIE1" x="184.15" y="-74.93" rot="R180"/>
<element name="DIGIT3" library="nixieeeee" package="NIXIE-13" value="NIXIE1" x="205.74" y="-74.93" rot="R180"/>
<element name="IC4" library="74xx-eu" package="DIL16" value="74141N" x="135.89" y="27.94" rot="R90"/>
<element name="R8" library="rcl" package="0411/15" value="15k/2W" x="62.23" y="52.07" rot="R270"/>
<element name="R9" library="rcl" package="0411/15" value="15k/2W" x="83.82" y="52.07" rot="R270"/>
<element name="R10" library="rcl" package="0411/15" value="15k/2W" x="105.41" y="52.07" rot="R270"/>
<element name="IC6" library="ds18b20" package="TO92-" value="DS18B20" x="143.51" y="45.72" rot="R270"/>
<element name="R11" library="rcl" package="R0805" value="4k7" x="147.32" y="44.45" rot="MR270"/>
<element name="R16" library="rcl" package="0207/10" value="180R" x="76.454" y="25.4"/>
<element name="R17" library="rcl" package="0207/10" value="120R" x="76.454" y="31.75"/>
<element name="R18" library="rcl" package="0207/10" value="120R" x="90.17" y="30.48" rot="R270"/>
<element name="R22" library="rcl" package="0207/10" value="180R" x="101.854" y="29.21" rot="R270"/>
<element name="R23" library="rcl" package="0207/10" value="120R" x="99.06" y="29.21" rot="R270"/>
<element name="R24" library="rcl" package="0207/10" value="120R" x="111.76" y="30.48" rot="R270"/>
<element name="JP1" library="pinhead" package="1X08" value="" x="162.56" y="-63.5" rot="R180"/>
<element name="JP2" library="pinhead" package="1X07" value="" x="162.56" y="-86.36"/>
<element name="JP3" library="pinhead" package="1X08" value="" x="184.15" y="-63.5" rot="R180"/>
<element name="JP4" library="pinhead" package="1X07" value="" x="184.15" y="-86.36"/>
<element name="JP5" library="pinhead" package="1X08" value="" x="205.74" y="-63.5" rot="R180"/>
<element name="JP6" library="pinhead" package="1X07" value="" x="205.74" y="-86.36"/>
<element name="JP11" library="pinhead" package="1X08" value="" x="63.5" y="40.64" rot="R180"/>
<element name="JP12" library="pinhead" package="1X07" value="" x="63.5" y="17.78"/>
<element name="JP13" library="pinhead" package="1X08" value="" x="85.09" y="40.64" rot="R180"/>
<element name="JP14" library="pinhead" package="1X07" value="" x="85.09" y="17.78"/>
<element name="JP15" library="pinhead" package="1X08" value="" x="106.68" y="40.64" rot="R180"/>
<element name="JP16" library="pinhead" package="1X07" value="" x="106.68" y="17.78"/>
<element name="LED1" library="adafruit" package="LED5MMRGB" value="RGBLED_CA-5MM" x="63.5" y="29.21" rot="R90"/>
<element name="LED2" library="adafruit" package="LED5MMRGB" value="RGBLED_CA-5MM" x="85.09" y="29.21" rot="R90"/>
<element name="LED3" library="adafruit" package="LED5MMRGB" value="RGBLED_CA-5MM" x="106.68" y="29.21" rot="R90"/>
<element name="T3" library="SparkFun-DiscreteSemi" package="TO-92" value="2N7000" x="52.07" y="24.13" rot="MR180"/>
<element name="T4" library="SparkFun-DiscreteSemi" package="TO-92" value="2N7000" x="50.8" y="29.21" rot="MR180"/>
<element name="T5" library="SparkFun-DiscreteSemi" package="TO-92" value="2N7000" x="48.26" y="34.29" rot="MR180"/>
<element name="T6" library="transistor" package="TO92-EBC" value="MPSA42" x="153.67" y="10.16" rot="R270"/>
<element name="R25" library="rcl" package="0207/10" value="10k" x="160.02" y="16.51" rot="R270"/>
<element name="H1" library="holes" package="4,1" value="MOUNT-HOLE4.1" x="165.1" y="81.28"/>
<element name="H2" library="holes" package="4,1" value="MOUNT-HOLE4.1" x="45.72" y="81.28"/>
<element name="H3" library="holes" package="4,1" value="MOUNT-HOLE4.1" x="45.72" y="-8.89"/>
<element name="H4" library="holes" package="4,1" value="MOUNT-HOLE4.1" x="165.1" y="-8.89"/>
</elements>
<signals>
<signal name="N$7">
<contactref element="R6" pad="2"/>
<contactref element="IC2" pad="5"/>
<contactref element="C7" pad="1"/>
<contactref element="R5" pad="1"/>
<contactref element="R5" pad="2"/>
<wire x1="131.76" y1="69.85" x2="131.76" y2="67.31" width="0.6096" layer="16"/>
<wire x1="134.62" y1="67.31" x2="131.76" y2="67.31" width="0.6096" layer="16"/>
<wire x1="130.81" y1="63.5" x2="131.76" y2="63.5" width="0.6096" layer="16"/>
<wire x1="131.76" y1="63.5" x2="131.76" y2="67.31" width="0.6096" layer="16"/>
<wire x1="133.35" y1="63.5" x2="131.76" y2="63.5" width="0.6096" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="T2" pad="D"/>
<contactref element="D4" pad="A"/>
<contactref element="L1" pad="2"/>
<wire x1="102.87" y1="73.66" x2="106.68" y2="73.66" width="0.6096" layer="16"/>
<wire x1="106.68" y1="73.66" x2="106.68" y2="76.2" width="0.6096" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="R4" pad="2"/>
<contactref element="R5" pad="3"/>
<wire x1="125.41" y1="63.5" x2="128.27" y2="63.5" width="0.6096" layer="16"/>
</signal>
<signal name="GND">
<contactref element="C1" pad="-"/>
<contactref element="C2" pad="2"/>
<contactref element="C10" pad="-"/>
<contactref element="C9" pad="2"/>
<contactref element="R6" pad="1"/>
<contactref element="C8" pad="-"/>
<contactref element="IC2" pad="4"/>
<contactref element="C6" pad="2"/>
<contactref element="R2" pad="1"/>
<contactref element="C7" pad="2"/>
<contactref element="T2" pad="S"/>
<contactref element="C3" pad="2"/>
<contactref element="C5" pad="-"/>
<contactref element="LED" pad="K"/>
<contactref element="IC1" pad="2"/>
<contactref element="12V" pad="P$1"/>
<contactref element="T1" pad="3"/>
<contactref element="IC6" pad="1"/>
<contactref element="IC4" pad="12"/>
<contactref element="IC3" pad="8"/>
<contactref element="IC3" pad="22"/>
<contactref element="C12" pad="2"/>
<contactref element="C11" pad="2"/>
<contactref element="S1" pad="1"/>
<contactref element="OK1" pad="2"/>
<contactref element="OK3" pad="2"/>
<contactref element="OK2" pad="2"/>
<contactref element="T3" pad="1"/>
<contactref element="T5" pad="1"/>
<contactref element="T6" pad="E"/>
<wire x1="146.05" y1="71.12" x2="149.54" y2="71.12" width="0.6096" layer="16"/>
<wire x1="149.54" y1="71.12" x2="149.86" y2="71.44" width="0.6096" layer="16"/>
<wire x1="152.4" y1="71.12" x2="150.18" y2="71.12" width="0.6096" layer="16"/>
<wire x1="150.18" y1="71.12" x2="149.86" y2="71.44" width="0.6096" layer="16"/>
<wire x1="141.478" y1="77.47" x2="153.67" y2="77.47" width="0.6096" layer="16"/>
<wire x1="153.67" y1="77.47" x2="154.94" y2="76.2" width="0.6096" layer="16"/>
<wire x1="154.94" y1="76.2" x2="154.94" y2="71.12" width="0.6096" layer="16"/>
<wire x1="152.4" y1="71.12" x2="154.94" y2="71.12" width="0.6096" layer="16"/>
<wire x1="152.4" y1="69.85" x2="152.4" y2="71.12" width="0.6096" layer="16"/>
<wire x1="141.478" y1="77.47" x2="141.478" y2="79.502" width="0.6096" layer="16"/>
<wire x1="141.478" y1="79.502" x2="139.7" y2="81.28" width="0.6096" layer="16"/>
<wire x1="120.142" y1="77.47" x2="120.142" y2="80.01" width="0.6096" layer="16"/>
<wire x1="120.142" y1="80.01" x2="120.142" y2="80.772" width="0.6096" layer="16"/>
<wire x1="120.142" y1="80.772" x2="120.65" y2="81.28" width="0.6096" layer="16"/>
<wire x1="120.65" y1="81.28" x2="139.7" y2="81.28" width="0.6096" layer="16"/>
<wire x1="146.05" y1="71.12" x2="142.56" y2="71.12" width="0.6096" layer="16"/>
<wire x1="142.56" y1="71.12" x2="142.24" y2="70.8" width="0.6096" layer="16"/>
<wire x1="127" y1="67.31" x2="129.86" y2="67.31" width="0.6096" layer="16"/>
<wire x1="129.86" y1="69.85" x2="129.86" y2="67.31" width="0.6096" layer="16"/>
<wire x1="139.7" y1="71.12" x2="141.92" y2="71.12" width="0.6096" layer="16"/>
<wire x1="141.92" y1="71.12" x2="142.24" y2="70.8" width="0.6096" layer="16"/>
<wire x1="104.14" y1="80.01" x2="111.76" y2="80.01" width="0.6096" layer="16"/>
<wire x1="111.76" y1="80.01" x2="120.142" y2="80.01" width="0.6096" layer="16"/>
<wire x1="111.76" y1="76.03" x2="111.76" y2="80.01" width="0.6096" layer="16"/>
<wire x1="124.14" y1="67.31" x2="124.46" y2="67.63" width="0.6096" layer="16"/>
<wire x1="102.87" y1="67.31" x2="119.38" y2="67.31" width="0.6096" layer="16"/>
<wire x1="119.38" y1="67.31" x2="121.92" y2="67.31" width="0.6096" layer="16"/>
<wire x1="121.92" y1="67.31" x2="124.46" y2="67.31" width="0.6096" layer="16"/>
<wire x1="124.46" y1="67.31" x2="127" y2="67.31" width="0.6096" layer="16"/>
<wire x1="124.46" y1="67.63" x2="124.46" y2="67.31" width="0.6096" layer="16"/>
<wire x1="121.92" y1="70.17" x2="121.92" y2="67.31" width="0.6096" layer="16"/>
<wire x1="119.38" y1="71.12" x2="119.38" y2="67.31" width="0.6096" layer="16"/>
<wire x1="102.87" y1="67.31" x2="100.33" y2="67.31" width="0.6096" layer="16"/>
<wire x1="100.33" y1="67.31" x2="99.06" y2="68.58" width="0.6096" layer="16"/>
<wire x1="99.06" y1="68.58" x2="99.06" y2="76.2" width="0.6096" layer="16"/>
<wire x1="99.06" y1="76.2" x2="99.06" y2="78.74" width="0.6096" layer="16"/>
<wire x1="99.06" y1="78.74" x2="99.06" y2="80.01" width="0.6096" layer="16"/>
<wire x1="99.06" y1="80.01" x2="104.14" y2="80.01" width="0.6096" layer="16"/>
<wire x1="102.87" y1="76.2" x2="99.06" y2="76.2" width="0.6096" layer="16"/>
<wire x1="102.87" y1="66.04" x2="102.87" y2="67.31" width="0.6096" layer="16"/>
<contactref element="T4" pad="1"/>
<wire x1="77.47" y1="71.12" x2="77.47" y2="69.85" width="0.6096" layer="16"/>
<wire x1="77.47" y1="69.85" x2="78.74" y2="68.58" width="0.6096" layer="16"/>
<wire x1="78.74" y1="68.58" x2="82.55" y2="68.58" width="0.6096" layer="16"/>
<wire x1="82.55" y1="68.58" x2="87.63" y2="68.58" width="0.6096" layer="16"/>
<wire x1="87.63" y1="68.58" x2="93.98" y2="68.58" width="0.6096" layer="16"/>
<wire x1="82.55" y1="71.12" x2="82.55" y2="68.58" width="0.6096" layer="16"/>
<wire x1="87.63" y1="71.12" x2="87.63" y2="68.58" width="0.6096" layer="16"/>
<wire x1="93.98" y1="68.58" x2="99.06" y2="68.58" width="0.6096" layer="16"/>
<wire x1="132.08" y1="29.21" x2="133.35" y2="29.21" width="0.6096" layer="16"/>
<wire x1="133.35" y1="29.21" x2="134.62" y2="30.48" width="0.6096" layer="16"/>
<wire x1="134.62" y1="30.48" x2="134.62" y2="48.26" width="0.6096" layer="16"/>
<wire x1="134.62" y1="48.26" x2="134.62" y2="52.07" width="0.6096" layer="16"/>
<wire x1="134.62" y1="52.07" x2="133.35" y2="53.34" width="0.6096" layer="16"/>
<wire x1="133.35" y1="53.34" x2="52.07" y2="53.34" width="0.6096" layer="16"/>
<wire x1="46.99" y1="52.07" x2="46.99" y2="34.29" width="0.6096" layer="16"/>
<wire x1="143.51" y1="48.26" x2="134.62" y2="48.26" width="0.6096" layer="16"/>
<wire x1="152.4" y1="66.04" x2="152.4" y2="69.85" width="0.6096" layer="16"/>
<wire x1="144.78" y1="63.5" x2="144.78" y2="64.77" width="0.6096" layer="16"/>
<wire x1="144.78" y1="64.77" x2="146.05" y2="66.04" width="0.6096" layer="16"/>
<wire x1="146.05" y1="66.04" x2="152.4" y2="66.04" width="0.6096" layer="16"/>
<wire x1="52.07" y1="53.34" x2="52.07" y2="78.74" width="0.6096" layer="16"/>
<wire x1="52.07" y1="78.74" x2="53.34" y2="80.01" width="0.6096" layer="16"/>
<wire x1="53.34" y1="80.01" x2="99.06" y2="80.01" width="0.6096" layer="16"/>
<wire x1="46.99" y1="52.07" x2="48.26" y2="53.34" width="0.6096" layer="16"/>
<wire x1="48.26" y1="53.34" x2="52.07" y2="53.34" width="0.6096" layer="16"/>
<wire x1="147.32" y1="33.97" x2="147.32" y2="35.56" width="0.6096" layer="16"/>
<wire x1="147.32" y1="35.56" x2="147.32" y2="37.15" width="0.6096" layer="16"/>
<wire x1="154.94" y1="39.37" x2="151.13" y2="39.37" width="0.6096" layer="16"/>
<wire x1="151.13" y1="39.37" x2="149.86" y2="40.64" width="0.6096" layer="16"/>
<wire x1="149.86" y1="40.64" x2="146.05" y2="40.64" width="0.6096" layer="16"/>
<wire x1="146.05" y1="40.64" x2="144.78" y2="39.37" width="0.6096" layer="16"/>
<wire x1="144.78" y1="39.37" x2="144.78" y2="36.83" width="0.6096" layer="16"/>
<wire x1="144.78" y1="36.83" x2="146.05" y2="35.56" width="0.6096" layer="16"/>
<wire x1="146.05" y1="35.56" x2="147.32" y2="35.56" width="0.6096" layer="16"/>
<wire x1="154.94" y1="39.37" x2="156.21" y2="39.37" width="0.6096" layer="16"/>
<wire x1="156.21" y1="39.37" x2="157.48" y2="38.1" width="0.6096" layer="16"/>
<wire x1="157.48" y1="38.1" x2="157.48" y2="33.02" width="0.6096" layer="16"/>
<wire x1="157.48" y1="13.97" x2="156.21" y2="12.7" width="0.6096" layer="16"/>
<wire x1="156.21" y1="12.7" x2="152.4" y2="12.7" width="0.6096" layer="16"/>
<wire x1="50.8" y1="24.13" x2="49.53" y2="22.86" width="0.6096" layer="16"/>
<wire x1="49.53" y1="22.86" x2="49.53" y2="20.32" width="0.6096" layer="16"/>
<wire x1="49.53" y1="29.21" x2="48.26" y2="29.21" width="0.6096" layer="16"/>
<wire x1="48.26" y1="29.21" x2="46.99" y2="27.94" width="0.6096" layer="16"/>
<wire x1="46.99" y1="27.94" x2="46.99" y2="22.86" width="0.6096" layer="16"/>
<via x="46.99" y="20.32" extent="1-16" drill="0.7" shape="octagon"/>
<via x="49.53" y="20.32" extent="1-16" drill="0.7" shape="octagon"/>
<via x="46.99" y="22.86" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="46.99" y1="34.29" x2="45.72" y2="34.29" width="0.6096" layer="16"/>
<wire x1="45.72" y1="34.29" x2="44.45" y2="33.02" width="0.6096" layer="16"/>
<wire x1="44.45" y1="33.02" x2="44.45" y2="22.86" width="0.6096" layer="16"/>
<wire x1="46.99" y1="20.32" x2="46.99" y2="22.86" width="0.6096" layer="16"/>
<wire x1="165.1" y1="43.18" x2="165.1" y2="64.77" width="0.6096" layer="16"/>
<wire x1="152.4" y1="66.04" x2="155.4988" y2="66.04" width="0.6096" layer="16"/>
<wire x1="155.4988" y1="66.04" x2="155.4988" y2="64.4906" width="0.6096" layer="16"/>
<wire x1="165.1" y1="64.77" x2="163.83" y2="66.04" width="0.6096" layer="16"/>
<wire x1="163.83" y1="66.04" x2="155.4988" y2="66.04" width="0.6096" layer="16"/>
<wire x1="165.1" y1="43.18" x2="165.1" y2="41.91" width="0.6096" layer="16"/>
<wire x1="165.1" y1="41.91" x2="165.1" y2="34.29" width="0.6096" layer="16"/>
<wire x1="165.1" y1="34.29" x2="163.83" y2="33.02" width="0.6096" layer="16"/>
<wire x1="163.83" y1="33.02" x2="157.48" y2="33.02" width="0.6096" layer="16"/>
<wire x1="162.56" y1="41.91" x2="165.1" y2="41.91" width="0.6096" layer="16"/>
<wire x1="157.48" y1="33.02" x2="157.48" y2="13.97" width="0.6096" layer="16"/>
<wire x1="46.99" y1="22.86" x2="49.53" y2="22.86" width="0" layer="19" extent="16-16"/>
<wire x1="44.45" y1="22.86" x2="46.99" y2="22.86" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$6">
<contactref element="R3" pad="2"/>
<contactref element="IC2" pad="7"/>
<contactref element="IC2" pad="8"/>
<contactref element="IC2" pad="1"/>
<contactref element="C8" pad="+"/>
<contactref element="L1" pad="1"/>
<wire x1="134.62" y1="72.39" x2="134.62" y2="74.93" width="0.6096" layer="16"/>
<wire x1="127" y1="74.93" x2="129.54" y2="74.93" width="0.6096" layer="16"/>
<wire x1="129.54" y1="74.93" x2="134.62" y2="74.93" width="0.6096" layer="16"/>
<wire x1="129.54" y1="78.74" x2="129.54" y2="77.47" width="0.6096" layer="16"/>
<wire x1="129.54" y1="77.47" x2="129.54" y2="74.93" width="0.6096" layer="16"/>
<wire x1="123.698" y1="77.47" x2="129.54" y2="77.47" width="0.6096" layer="16"/>
<wire x1="123.698" y1="77.47" x2="123.698" y2="75.438" width="0.6096" layer="16"/>
<wire x1="123.698" y1="75.438" x2="123.19" y2="74.93" width="0.6096" layer="16"/>
<wire x1="116.84" y1="76.2" x2="118.11" y2="76.2" width="0.6096" layer="16"/>
<wire x1="118.11" y1="76.2" x2="119.38" y2="74.93" width="0.6096" layer="16"/>
<wire x1="119.38" y1="74.93" x2="123.19" y2="74.93" width="0.6096" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="IC2" pad="3"/>
<contactref element="C6" pad="1"/>
<wire x1="127" y1="69.85" x2="124.78" y2="69.85" width="0.6096" layer="16"/>
<wire x1="124.78" y1="69.85" x2="124.46" y2="69.53" width="0.6096" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="IC2" pad="2"/>
<contactref element="R2" pad="2"/>
<contactref element="D3" pad="A"/>
<contactref element="T1" pad="1"/>
<wire x1="112.71" y1="73.83" x2="112.71" y2="71.87" width="0.6096" layer="16"/>
<wire x1="112.71" y1="71.87" x2="113.46" y2="71.12" width="0.6096" layer="16"/>
<wire x1="127" y1="72.39" x2="125.73" y2="72.39" width="0.6096" layer="16"/>
<wire x1="125.73" y1="72.39" x2="124.46" y2="73.66" width="0.6096" layer="16"/>
<wire x1="124.46" y1="73.66" x2="121.92" y2="73.66" width="0.6096" layer="16"/>
<wire x1="121.92" y1="73.66" x2="118.11" y2="73.66" width="0.6096" layer="16"/>
<wire x1="118.11" y1="73.66" x2="116.84" y2="72.39" width="0.6096" layer="16"/>
<wire x1="116.84" y1="72.39" x2="115.57" y2="72.39" width="0.6096" layer="16"/>
<wire x1="115.57" y1="72.39" x2="114.3" y2="71.12" width="0.6096" layer="16"/>
<wire x1="114.3" y1="71.12" x2="113.46" y2="71.12" width="0.6096" layer="16"/>
<wire x1="121.92" y1="72.07" x2="121.92" y2="73.66" width="0.6096" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="T2" pad="G"/>
<contactref element="D3" pad="C"/>
<contactref element="T1" pad="2"/>
<wire x1="110.81" y1="73.83" x2="110.81" y2="71.87" width="0.6096" layer="16"/>
<wire x1="110.81" y1="71.87" x2="110.06" y2="71.12" width="0.6096" layer="16"/>
<wire x1="110.06" y1="71.12" x2="106.68" y2="71.12" width="0.6096" layer="16"/>
<wire x1="106.68" y1="71.12" x2="105.41" y2="71.12" width="0.6096" layer="16"/>
<wire x1="105.41" y1="71.12" x2="102.87" y2="71.12" width="0.6096" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="R1" pad="1"/>
<contactref element="LED" pad="A"/>
<wire x1="142.24" y1="63.5" x2="142.24" y2="65.72" width="0.6096" layer="16"/>
<wire x1="142.24" y1="65.72" x2="141.92" y2="66.04" width="0.6096" layer="16"/>
</signal>
<signal name="5V">
<contactref element="C3" pad="1"/>
<contactref element="IC1" pad="3"/>
<contactref element="R1" pad="2"/>
<contactref element="C5" pad="+"/>
<contactref element="R7" pad="2"/>
<contactref element="IC6" pad="3"/>
<contactref element="R11" pad="2"/>
<contactref element="IC3" pad="21"/>
<contactref element="IC3" pad="20"/>
<contactref element="IC3" pad="7"/>
<contactref element="IC4" pad="5"/>
<contactref element="LED2" pad="2"/>
<contactref element="LED1" pad="2"/>
<contactref element="LED3" pad="2"/>
<wire x1="146.05" y1="68.58" x2="142.56" y2="68.58" width="0.6096" layer="16"/>
<wire x1="142.56" y1="68.58" x2="142.24" y2="68.9" width="0.6096" layer="16"/>
<wire x1="139.7" y1="68.58" x2="141.92" y2="68.58" width="0.6096" layer="16"/>
<wire x1="141.92" y1="68.58" x2="142.24" y2="68.9" width="0.6096" layer="16"/>
<wire x1="139.7" y1="68.58" x2="139.7" y2="66.36" width="0.6096" layer="16"/>
<wire x1="139.7" y1="66.36" x2="140.02" y2="66.04" width="0.6096" layer="16"/>
<wire x1="138.43" y1="43.18" x2="137.16" y2="41.91" width="0.6096" layer="16"/>
<wire x1="138.43" y1="43.18" x2="143.51" y2="43.18" width="0.6096" layer="16"/>
<wire x1="139.7" y1="62.23" x2="139.7" y2="65.72" width="0.6096" layer="16"/>
<wire x1="139.7" y1="65.72" x2="140.02" y2="66.04" width="0.6096" layer="16"/>
<wire x1="143.51" y1="43.18" x2="147.32" y2="43.18" width="0.6096" layer="16"/>
<wire x1="147.32" y1="43.18" x2="149.86" y2="43.18" width="0.6096" layer="16"/>
<wire x1="149.86" y1="43.18" x2="151.13" y2="41.91" width="0.6096" layer="16"/>
<wire x1="151.13" y1="41.91" x2="154.94" y2="41.91" width="0.6096" layer="16"/>
<wire x1="147.32" y1="43.5" x2="147.32" y2="43.18" width="0.6096" layer="16"/>
<wire x1="154.94" y1="41.91" x2="158.75" y2="41.91" width="0.6096" layer="16"/>
<wire x1="162.56" y1="39.37" x2="160.02" y2="39.37" width="0.6096" layer="16"/>
<wire x1="160.02" y1="39.37" x2="158.75" y2="40.64" width="0.6096" layer="16"/>
<wire x1="162.56" y1="36.83" x2="162.56" y2="39.37" width="0.6096" layer="16"/>
<wire x1="157.48" y1="62.23" x2="158.75" y2="60.96" width="0.6096" layer="16"/>
<wire x1="158.75" y1="60.96" x2="158.75" y2="41.91" width="0.6096" layer="16"/>
<wire x1="158.75" y1="41.91" x2="158.75" y2="40.64" width="0.6096" layer="16"/>
<wire x1="157.48" y1="62.23" x2="152.4" y2="62.23" width="0.6096" layer="16"/>
<wire x1="152.4" y1="62.23" x2="148.59" y2="62.23" width="0.6096" layer="16"/>
<wire x1="148.59" y1="62.23" x2="147.32" y2="60.96" width="0.6096" layer="16"/>
<wire x1="147.32" y1="60.96" x2="140.97" y2="60.96" width="0.6096" layer="16"/>
<wire x1="140.97" y1="60.96" x2="139.7" y2="62.23" width="0.6096" layer="16"/>
<wire x1="152.4" y1="60.64" x2="152.4" y2="62.23" width="0.6096" layer="16"/>
<wire x1="107.6484" y1="28.575" x2="107.6484" y2="25.8604" width="0.6096" layer="16"/>
<wire x1="107.6484" y1="25.8604" x2="104.394" y2="22.606" width="0.6096" layer="16"/>
<wire x1="86.106" y1="22.606" x2="64.516" y2="22.606" width="0.6096" layer="16"/>
<wire x1="64.516" y1="22.606" x2="64.516" y2="28.5274" width="0.6096" layer="16"/>
<wire x1="64.516" y1="28.5274" x2="64.4684" y2="28.575" width="0.6096" layer="16"/>
<wire x1="86.0584" y1="28.575" x2="86.0584" y2="22.6536" width="0.6096" layer="16"/>
<wire x1="86.0584" y1="22.6536" x2="86.106" y2="22.606" width="0.6096" layer="16"/>
<wire x1="107.6484" y1="28.575" x2="107.696" y2="28.5274" width="0.6096" layer="16"/>
<wire x1="107.696" y1="28.5274" x2="107.696" y2="25.908" width="0.6096" layer="16"/>
<wire x1="107.696" y1="25.908" x2="107.6484" y2="25.8604" width="0.6096" layer="16"/>
<wire x1="104.394" y1="22.606" x2="86.106" y2="22.606" width="0.6096" layer="16"/>
<wire x1="64.516" y1="22.606" x2="63.246" y2="21.336" width="0.6096" layer="16"/>
<wire x1="63.246" y1="21.336" x2="54.61" y2="21.336" width="0.6096" layer="16"/>
<wire x1="54.61" y1="21.336" x2="53.086" y2="19.812" width="0.6096" layer="16"/>
<wire x1="53.086" y1="19.812" x2="53.086" y2="10.16" width="0.6096" layer="16"/>
<wire x1="53.086" y1="10.16" x2="55.626" y2="7.62" width="0.6096" layer="16"/>
<wire x1="55.626" y1="7.62" x2="134.874" y2="7.62" width="0.6096" layer="16"/>
<wire x1="134.874" y1="7.62" x2="136.74969375" y2="8.8704625" width="0.6096" layer="16"/>
<wire x1="136.74969375" y1="8.8704625" x2="137.16" y2="9.144" width="0.6096" layer="16"/>
<wire x1="137.16" y1="41.91" x2="137.16" y2="29.21" width="0.6096" layer="16"/>
<wire x1="137.16" y1="29.21" x2="137.16" y2="9.28076875" width="0.6096" layer="16"/>
<wire x1="137.16" y1="9.28076875" x2="136.74969375" y2="8.8704625" width="0.6096" layer="16"/>
<wire x1="139.7" y1="29.21" x2="137.16" y2="29.21" width="0.6096" layer="16"/>
</signal>
<signal name="+12V">
<contactref element="C1" pad="+"/>
<contactref element="C2" pad="1"/>
<contactref element="IC2" pad="6"/>
<contactref element="R3" pad="1"/>
<contactref element="IC1" pad="1"/>
<contactref element="12V" pad="P$2"/>
<wire x1="146.05" y1="73.66" x2="149.54" y2="73.66" width="0.6096" layer="16"/>
<wire x1="149.54" y1="73.66" x2="149.86" y2="73.34" width="0.6096" layer="16"/>
<wire x1="152.4" y1="74.93" x2="152.4" y2="73.66" width="0.6096" layer="16"/>
<wire x1="152.4" y1="73.66" x2="150.18" y2="73.66" width="0.6096" layer="16"/>
<wire x1="150.18" y1="73.66" x2="149.86" y2="73.34" width="0.6096" layer="16"/>
<wire x1="134.62" y1="69.85" x2="135.89" y2="69.85" width="0.6096" layer="16"/>
<wire x1="135.89" y1="69.85" x2="137.16" y2="71.12" width="0.6096" layer="16"/>
<wire x1="137.16" y1="71.12" x2="137.16" y2="73.66" width="0.6096" layer="16"/>
<wire x1="137.16" y1="73.66" x2="137.16" y2="77.47" width="0.6096" layer="16"/>
<wire x1="137.16" y1="77.47" x2="135.89" y2="78.74" width="0.6096" layer="16"/>
<wire x1="135.89" y1="78.74" x2="132.08" y2="78.74" width="0.6096" layer="16"/>
<wire x1="146.05" y1="73.66" x2="137.16" y2="73.66" width="0.6096" layer="16"/>
<wire x1="137.922" y1="77.47" x2="137.16" y2="77.47" width="0.6096" layer="16"/>
</signal>
<signal name="VPP">
<contactref element="D4" pad="C"/>
<contactref element="C10" pad="+"/>
<contactref element="C9" pad="1"/>
<contactref element="R4" pad="1"/>
<contactref element="OK3" pad="4"/>
<contactref element="OK2" pad="4"/>
<contactref element="OK1" pad="4"/>
<wire x1="123.51" y1="63.5" x2="119.38" y2="63.5" width="0.6096" layer="16"/>
<wire x1="119.38" y1="63.5" x2="106.68" y2="63.5" width="0.6096" layer="16"/>
<wire x1="106.68" y1="63.5" x2="102.87" y2="63.5" width="0.6096" layer="16"/>
<wire x1="80.01" y1="63.5" x2="80.01" y2="64.77" width="0.6096" layer="16"/>
<wire x1="80.01" y1="64.77" x2="81.28" y2="66.04" width="0.6096" layer="16"/>
<wire x1="81.28" y1="66.04" x2="85.09" y2="66.04" width="0.6096" layer="16"/>
<wire x1="85.09" y1="66.04" x2="88.9" y2="66.04" width="0.6096" layer="16"/>
<wire x1="88.9" y1="66.04" x2="90.17" y2="64.77" width="0.6096" layer="16"/>
<wire x1="90.17" y1="64.77" x2="90.17" y2="63.5" width="0.6096" layer="16"/>
<wire x1="85.09" y1="63.5" x2="85.09" y2="66.04" width="0.6096" layer="16"/>
<wire x1="90.17" y1="63.5" x2="102.87" y2="63.5" width="0.6096" layer="16"/>
</signal>
<signal name="A0">
<contactref element="IC3" pad="23"/>
</signal>
<signal name="A1">
<contactref element="IC3" pad="24"/>
</signal>
<signal name="A2">
<contactref element="IC3" pad="25"/>
</signal>
<signal name="A4/SDA">
<contactref element="IC3" pad="27"/>
</signal>
<signal name="A5/SCL">
<contactref element="IC3" pad="28"/>
</signal>
<signal name="D0/RX">
<contactref element="IC3" pad="2"/>
<contactref element="R13" pad="1"/>
<wire x1="150.81" y1="54.61" x2="154.94" y2="54.61" width="0.6096" layer="16"/>
</signal>
<signal name="D1/TX">
<contactref element="IC3" pad="3"/>
<contactref element="R14" pad="1"/>
<wire x1="150.81" y1="52.07" x2="154.94" y2="52.07" width="0.6096" layer="16"/>
</signal>
<signal name="D2">
<contactref element="IC3" pad="4"/>
<contactref element="R15" pad="1"/>
<wire x1="150.81" y1="49.53" x2="154.94" y2="49.53" width="0.6096" layer="16"/>
</signal>
<signal name="D3/PWM">
<contactref element="IC3" pad="5"/>
</signal>
<signal name="D4">
<contactref element="IC3" pad="6"/>
<contactref element="R11" pad="1"/>
<contactref element="IC6" pad="2"/>
<wire x1="154.94" y1="44.45" x2="151.13" y2="44.45" width="0.6096" layer="16"/>
<wire x1="151.13" y1="44.45" x2="149.86" y2="45.72" width="0.6096" layer="16"/>
<wire x1="149.86" y1="45.72" x2="147.32" y2="45.72" width="0.6096" layer="16"/>
<wire x1="147.32" y1="45.72" x2="143.51" y2="45.72" width="0.6096" layer="16"/>
<wire x1="147.32" y1="45.4" x2="147.32" y2="45.72" width="0.6096" layer="16"/>
</signal>
<signal name="D5/PWM">
<contactref element="IC3" pad="11"/>
<contactref element="IC4" pad="7"/>
<wire x1="154.94" y1="31.75" x2="153.67" y2="31.75" width="0.6096" layer="16"/>
<wire x1="153.67" y1="31.75" x2="152.4" y2="30.48" width="0.6096" layer="16"/>
<wire x1="152.4" y1="30.48" x2="144.78" y2="30.48" width="0.6096" layer="16"/>
<wire x1="144.78" y1="30.48" x2="143.51" y2="31.75" width="0.6096" layer="16"/>
<wire x1="143.51" y1="31.75" x2="142.24" y2="33.02" width="0.6096" layer="16"/>
<wire x1="142.24" y1="33.02" x2="140.97" y2="34.29" width="0.6096" layer="16"/>
<wire x1="140.97" y1="34.29" x2="139.7" y2="34.29" width="0.6096" layer="16"/>
</signal>
<signal name="D6/PWM">
<contactref element="IC3" pad="12"/>
<contactref element="IC4" pad="6"/>
<wire x1="139.7" y1="31.75" x2="140.97" y2="31.75" width="0.6096" layer="16"/>
<wire x1="140.97" y1="31.75" x2="142.24" y2="30.48" width="0.6096" layer="16"/>
<wire x1="142.24" y1="30.48" x2="143.51" y2="29.21" width="0.6096" layer="16"/>
<wire x1="143.51" y1="29.21" x2="154.94" y2="29.21" width="0.6096" layer="16"/>
</signal>
<signal name="D7">
<contactref element="IC3" pad="13"/>
<contactref element="IC4" pad="4"/>
<wire x1="154.94" y1="26.67" x2="153.67" y2="26.67" width="0.6096" layer="16"/>
<wire x1="153.67" y1="26.67" x2="152.4" y2="26.67" width="0.6096" layer="16"/>
<wire x1="152.4" y1="26.67" x2="143.51" y2="26.67" width="0.6096" layer="16"/>
<wire x1="143.51" y1="26.67" x2="142.24" y2="26.67" width="0.6096" layer="16"/>
<wire x1="142.24" y1="26.67" x2="139.7" y2="26.67" width="0.6096" layer="16"/>
</signal>
<signal name="D8">
<contactref element="IC3" pad="14"/>
<contactref element="IC4" pad="3"/>
<wire x1="139.7" y1="24.13" x2="140.97" y2="24.13" width="0.6096" layer="16"/>
<wire x1="140.97" y1="24.13" x2="142.24" y2="24.13" width="0.6096" layer="16"/>
<wire x1="154.94" y1="24.13" x2="153.67" y2="24.13" width="0.6096" layer="16"/>
<wire x1="153.67" y1="24.13" x2="143.51" y2="24.13" width="0.6096" layer="16"/>
<wire x1="143.51" y1="24.13" x2="142.24" y2="24.13" width="0.6096" layer="16"/>
</signal>
<signal name="D9/PWM">
<contactref element="IC3" pad="15"/>
<contactref element="T3" pad="2"/>
<wire x1="162.56" y1="24.13" x2="163.83" y2="24.13" width="0.6096" layer="16"/>
<wire x1="163.83" y1="24.13" x2="165.1" y2="22.86" width="0.6096" layer="16"/>
<wire x1="163.83" y1="1.27" x2="53.34" y2="1.27" width="0.6096" layer="16"/>
<wire x1="53.34" y1="1.27" x2="52.07" y2="2.54" width="0.6096" layer="16"/>
<wire x1="52.07" y1="2.54" x2="52.07" y2="22.225" width="0.6096" layer="16"/>
<wire x1="163.83" y1="1.27" x2="165.1" y2="2.54" width="0.6096" layer="16"/>
<wire x1="165.1" y1="2.54" x2="165.1" y2="22.86" width="0.6096" layer="16"/>
</signal>
<signal name="D10/PWM">
<contactref element="IC3" pad="16"/>
<contactref element="T4" pad="2"/>
<wire x1="50.8" y1="27.305" x2="48.895" y2="27.305" width="0.6096" layer="16"/>
<wire x1="48.895" y1="27.305" x2="48.26" y2="26.67" width="0.6096" layer="16"/>
<wire x1="48.26" y1="26.67" x2="48.26" y2="1.27" width="0.6096" layer="16"/>
<wire x1="48.26" y1="1.27" x2="49.53" y2="0" width="0.6096" layer="16"/>
<wire x1="49.53" y1="0" x2="165.1" y2="0" width="0.6096" layer="16"/>
<wire x1="165.1" y1="0" x2="166.37" y2="1.27" width="0.6096" layer="16"/>
<wire x1="166.37" y1="1.27" x2="166.37" y2="25.4" width="0.6096" layer="16"/>
<wire x1="166.37" y1="25.4" x2="165.1" y2="26.67" width="0.6096" layer="16"/>
<wire x1="165.1" y1="26.67" x2="162.56" y2="26.67" width="0.6096" layer="16"/>
</signal>
<signal name="D11/PWM/MOSI">
<contactref element="IC3" pad="17"/>
<contactref element="T5" pad="2"/>
<wire x1="162.56" y1="29.21" x2="166.37" y2="29.21" width="0.6096" layer="16"/>
<wire x1="166.37" y1="29.21" x2="167.64" y2="27.94" width="0.6096" layer="16"/>
<wire x1="167.64" y1="27.94" x2="167.64" y2="24.13" width="0.6096" layer="16"/>
<wire x1="167.64" y1="24.13" x2="167.64" y2="0" width="0.6096" layer="16"/>
<wire x1="167.64" y1="0" x2="166.37" y2="-1.27" width="0.6096" layer="16"/>
<wire x1="166.37" y1="-1.27" x2="46.99" y2="-1.27" width="0.6096" layer="16"/>
<wire x1="48.26" y1="32.385" x2="46.355" y2="32.385" width="0.6096" layer="16"/>
<wire x1="46.355" y1="32.385" x2="45.72" y2="31.75" width="0.6096" layer="16"/>
<wire x1="45.72" y1="31.75" x2="45.72" y2="0" width="0.6096" layer="16"/>
<wire x1="45.72" y1="0" x2="46.99" y2="-1.27" width="0.6096" layer="16"/>
</signal>
<signal name="D12/MISO">
<contactref element="IC3" pad="18"/>
<contactref element="R25" pad="1"/>
<wire x1="162.56" y1="31.75" x2="161.29" y2="31.75" width="0.6096" layer="16"/>
<wire x1="161.29" y1="31.75" x2="160.02" y2="30.48" width="0.6096" layer="16"/>
<wire x1="160.02" y1="30.48" x2="160.02" y2="21.59" width="0.6096" layer="16"/>
</signal>
<signal name="D13/SCK">
<contactref element="IC3" pad="19"/>
</signal>
<signal name="N$2">
<contactref element="IC3" pad="10"/>
<contactref element="Q1" pad="2"/>
<contactref element="C12" pad="1"/>
<wire x1="149.86" y1="31.877" x2="149.86" y2="33.02" width="0.6096" layer="16"/>
<wire x1="149.86" y1="33.02" x2="151.13" y2="34.29" width="0.6096" layer="16"/>
<wire x1="151.13" y1="34.29" x2="154.94" y2="34.29" width="0.6096" layer="16"/>
<wire x1="147.32" y1="32.07" x2="149.667" y2="32.07" width="0.6096" layer="16"/>
<wire x1="149.667" y1="32.07" x2="149.86" y2="31.877" width="0.6096" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="IC3" pad="9"/>
<contactref element="C11" pad="1"/>
<contactref element="Q1" pad="1"/>
<wire x1="149.86" y1="36.703" x2="154.813" y2="36.703" width="0.6096" layer="16"/>
<wire x1="154.813" y1="36.703" x2="154.94" y2="36.83" width="0.6096" layer="16"/>
<wire x1="147.32" y1="39.05" x2="148.91" y2="39.05" width="0.6096" layer="16"/>
<wire x1="148.91" y1="39.05" x2="149.86" y2="38.1" width="0.6096" layer="16"/>
<wire x1="149.86" y1="38.1" x2="149.86" y2="36.703" width="0.6096" layer="16"/>
</signal>
<signal name="RESET">
<contactref element="S1" pad="3"/>
<contactref element="IC3" pad="1"/>
<contactref element="R7" pad="1"/>
<wire x1="154.94" y1="57.15" x2="154.94" y2="58.42" width="0.6096" layer="16"/>
<wire x1="154.94" y1="58.42" x2="154.94" y2="59.4106" width="0.6096" layer="16"/>
<wire x1="154.94" y1="59.4106" x2="155.4988" y2="59.9694" width="0.6096" layer="16"/>
<wire x1="152.4" y1="58.74" x2="154.94" y2="58.74" width="0.6096" layer="16"/>
<wire x1="154.94" y1="58.74" x2="154.94" y2="58.42" width="0.6096" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="R13" pad="2"/>
<contactref element="OK1" pad="1"/>
<wire x1="58.42" y1="57.15" x2="57.15" y2="58.42" width="0.6096" layer="16"/>
<wire x1="57.15" y1="58.42" x2="57.15" y2="73.66" width="0.6096" layer="16"/>
<wire x1="57.15" y1="73.66" x2="58.42" y2="74.93" width="0.6096" layer="16"/>
<wire x1="58.42" y1="74.93" x2="78.74" y2="74.93" width="0.6096" layer="16"/>
<wire x1="78.74" y1="74.93" x2="80.01" y2="73.66" width="0.6096" layer="16"/>
<wire x1="80.01" y1="73.66" x2="80.01" y2="71.12" width="0.6096" layer="16"/>
<wire x1="148.91" y1="54.61" x2="146.05" y2="54.61" width="0.6096" layer="16"/>
<wire x1="146.05" y1="54.61" x2="146.05" y2="57.15" width="0.6096" layer="16"/>
<wire x1="146.05" y1="57.15" x2="58.42" y2="57.15" width="0.6096" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="R14" pad="2"/>
<contactref element="OK2" pad="1"/>
<wire x1="85.09" y1="71.12" x2="85.09" y2="74.93" width="0.6096" layer="16"/>
<wire x1="85.09" y1="74.93" x2="83.82" y2="76.2" width="0.6096" layer="16"/>
<wire x1="83.82" y1="76.2" x2="57.15" y2="76.2" width="0.6096" layer="16"/>
<wire x1="57.15" y1="76.2" x2="55.88" y2="74.93" width="0.6096" layer="16"/>
<wire x1="55.88" y1="74.93" x2="55.88" y2="57.15" width="0.6096" layer="16"/>
<wire x1="55.88" y1="57.15" x2="57.15" y2="55.88" width="0.6096" layer="16"/>
<wire x1="57.15" y1="55.88" x2="144.78" y2="55.88" width="0.6096" layer="16"/>
<wire x1="144.78" y1="55.88" x2="144.78" y2="53.34" width="0.6096" layer="16"/>
<wire x1="148.91" y1="52.07" x2="146.05" y2="52.07" width="0.6096" layer="16"/>
<wire x1="146.05" y1="52.07" x2="144.78" y2="53.34" width="0.6096" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="R15" pad="2"/>
<contactref element="OK3" pad="1"/>
<wire x1="143.51" y1="54.61" x2="55.88" y2="54.61" width="0.6096" layer="16"/>
<wire x1="55.88" y1="54.61" x2="54.61" y2="55.88" width="0.6096" layer="16"/>
<wire x1="54.61" y1="55.88" x2="54.61" y2="76.2" width="0.6096" layer="16"/>
<wire x1="54.61" y1="76.2" x2="55.88" y2="77.47" width="0.6096" layer="16"/>
<wire x1="55.88" y1="77.47" x2="88.9" y2="77.47" width="0.6096" layer="16"/>
<wire x1="88.9" y1="77.47" x2="90.17" y2="76.2" width="0.6096" layer="16"/>
<wire x1="90.17" y1="76.2" x2="90.17" y2="71.12" width="0.6096" layer="16"/>
<wire x1="148.91" y1="49.53" x2="147.32" y2="49.53" width="0.6096" layer="16"/>
<wire x1="147.32" y1="49.53" x2="146.05" y2="49.53" width="0.6096" layer="16"/>
<wire x1="146.05" y1="49.53" x2="143.51" y2="52.07" width="0.6096" layer="16"/>
<wire x1="143.51" y1="52.07" x2="143.51" y2="54.61" width="0.6096" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="OK1" pad="3"/>
<contactref element="R8" pad="1"/>
<wire x1="77.47" y1="63.5" x2="77.47" y2="60.96" width="0.6096" layer="16"/>
<wire x1="77.47" y1="60.96" x2="76.2" y2="59.69" width="0.6096" layer="16"/>
<wire x1="76.2" y1="59.69" x2="62.23" y2="59.69" width="0.6096" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="OK2" pad="3"/>
<contactref element="R9" pad="1"/>
<wire x1="82.55" y1="63.5" x2="82.55" y2="60.96" width="0.6096" layer="16"/>
<wire x1="82.55" y1="60.96" x2="83.82" y2="59.69" width="0.6096" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="OK3" pad="3"/>
<contactref element="R10" pad="1"/>
<wire x1="87.63" y1="63.5" x2="87.63" y2="60.96" width="0.6096" layer="16"/>
<wire x1="87.63" y1="60.96" x2="88.9" y2="59.69" width="0.6096" layer="16"/>
<wire x1="88.9" y1="59.69" x2="105.41" y2="59.69" width="0.6096" layer="16"/>
</signal>
<signal name="ANODE1">
<contactref element="JP1" pad="5"/>
<contactref element="DIGIT1" pad="A"/>
<wire x1="161.29" y1="-63.5" x2="161.29" y2="-70.0965" width="0.6096" layer="16"/>
<wire x1="161.29" y1="-70.0965" x2="161.3943" y2="-70.2008" width="0.6096" layer="16"/>
</signal>
<signal name="ANODE2">
<contactref element="JP3" pad="5"/>
<contactref element="DIGIT2" pad="A"/>
<wire x1="182.88" y1="-63.5" x2="182.88" y2="-70.0965" width="0.6096" layer="16"/>
<wire x1="182.88" y1="-70.0965" x2="182.9843" y2="-70.2008" width="0.6096" layer="16"/>
</signal>
<signal name="ANODE3">
<contactref element="JP5" pad="5"/>
<contactref element="DIGIT3" pad="A"/>
<wire x1="204.47" y1="-63.5" x2="204.47" y2="-70.0965" width="0.6096" layer="16"/>
<wire x1="204.47" y1="-70.0965" x2="204.5743" y2="-70.2008" width="0.6096" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="R19" pad="2"/>
<contactref element="LED1" pad="1"/>
<wire x1="62.5316" y1="27.051" x2="58.801" y2="27.051" width="0.6096" layer="16"/>
<wire x1="58.801" y1="27.051" x2="58.42" y2="26.67" width="0.6096" layer="16"/>
<wire x1="58.42" y1="26.67" x2="58.42" y2="22.86" width="0.6096" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="R20" pad="2"/>
<contactref element="LED1" pad="3"/>
<wire x1="62.5316" y1="30.099" x2="56.769" y2="30.099" width="0.6096" layer="16"/>
<wire x1="56.769" y1="30.099" x2="55.88" y2="29.21" width="0.6096" layer="16"/>
<wire x1="55.88" y1="29.21" x2="55.88" y2="24.13" width="0.6096" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R21" pad="2"/>
<contactref element="LED1" pad="4"/>
<wire x1="64.4684" y1="31.369" x2="67.691" y2="31.369" width="0.6096" layer="16"/>
<wire x1="67.691" y1="31.369" x2="68.58" y2="30.48" width="0.6096" layer="16"/>
<wire x1="68.58" y1="30.48" x2="68.58" y2="25.4" width="0.6096" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="R18" pad="1"/>
<contactref element="R24" pad="1"/>
<contactref element="R21" pad="1"/>
<contactref element="T5" pad="3"/>
<wire x1="68.58" y1="35.56" x2="90.17" y2="35.56" width="0.6096" layer="16"/>
<wire x1="90.17" y1="35.56" x2="111.76" y2="35.56" width="0.6096" layer="16"/>
<wire x1="49.53" y1="34.29" x2="50.8" y2="35.56" width="0.6096" layer="16"/>
<wire x1="50.8" y1="35.56" x2="68.58" y2="35.56" width="0.6096" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="R16" pad="2"/>
<contactref element="LED2" pad="1"/>
<wire x1="84.1216" y1="27.051" x2="83.185" y2="27.051" width="0.6096" layer="16"/>
<wire x1="83.185" y1="27.051" x2="81.534" y2="25.4" width="0.6096" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="R17" pad="2"/>
<contactref element="LED2" pad="3"/>
<wire x1="81.534" y1="31.75" x2="82.4706" y2="31.75" width="0.6096" layer="16"/>
<wire x1="82.4706" y1="31.75" x2="84.1216" y2="30.099" width="0.6096" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="R18" pad="2"/>
<contactref element="LED2" pad="4"/>
<wire x1="86.0584" y1="31.369" x2="89.281" y2="31.369" width="0.6096" layer="16"/>
<wire x1="89.281" y1="31.369" x2="90.17" y2="30.48" width="0.6096" layer="16"/>
<wire x1="90.17" y1="30.48" x2="90.17" y2="25.4" width="0.6096" layer="16"/>
</signal>
<signal name="N$44">
<contactref element="R23" pad="1"/>
<contactref element="R20" pad="1"/>
<contactref element="R17" pad="1"/>
<contactref element="T4" pad="3"/>
<wire x1="52.07" y1="29.21" x2="52.07" y2="33.02" width="0.6096" layer="16"/>
<wire x1="52.07" y1="33.02" x2="53.34" y2="34.29" width="0.6096" layer="16"/>
<wire x1="53.34" y1="34.29" x2="55.88" y2="34.29" width="0.6096" layer="16"/>
<wire x1="55.88" y1="34.29" x2="68.834" y2="34.29" width="0.6096" layer="16"/>
<wire x1="71.374" y1="31.75" x2="68.834" y2="34.29" width="0.6096" layer="16"/>
<wire x1="71.374" y1="31.75" x2="71.374" y2="32.004" width="0.6096" layer="16"/>
<wire x1="99.06" y1="34.29" x2="73.914" y2="34.29" width="0.6096" layer="16"/>
<wire x1="73.914" y1="34.29" x2="71.374" y2="31.75" width="0.6096" layer="16"/>
</signal>
<signal name="N$46">
<contactref element="R22" pad="2"/>
<contactref element="LED3" pad="1"/>
<wire x1="105.7116" y1="27.051" x2="101.981" y2="27.051" width="0.6096" layer="16"/>
<wire x1="101.981" y1="27.051" x2="101.6" y2="26.67" width="0.6096" layer="16"/>
<wire x1="101.6" y1="26.67" x2="101.854" y2="24.13" width="0.6096" layer="16"/>
</signal>
<signal name="N$47">
<contactref element="R23" pad="2"/>
<contactref element="LED3" pad="3"/>
<wire x1="105.7116" y1="30.099" x2="99.949" y2="30.099" width="0.6096" layer="16"/>
<wire x1="99.949" y1="30.099" x2="99.06" y2="29.21" width="0.6096" layer="16"/>
<wire x1="99.06" y1="29.21" x2="99.06" y2="24.13" width="0.6096" layer="16"/>
</signal>
<signal name="N$48">
<contactref element="R24" pad="2"/>
<contactref element="LED3" pad="4"/>
<wire x1="107.6484" y1="31.369" x2="110.871" y2="31.369" width="0.6096" layer="16"/>
<wire x1="110.871" y1="31.369" x2="111.76" y2="30.48" width="0.6096" layer="16"/>
<wire x1="111.76" y1="30.48" x2="111.76" y2="25.4" width="0.6096" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="R22" pad="1"/>
<contactref element="R19" pad="1"/>
<contactref element="R16" pad="1"/>
<contactref element="T3" pad="3"/>
<wire x1="53.34" y1="24.13" x2="54.61" y2="25.4" width="0.6096" layer="16"/>
<wire x1="54.61" y1="25.4" x2="54.61" y2="31.75" width="0.6096" layer="16"/>
<wire x1="54.61" y1="31.75" x2="55.88" y2="33.02" width="0.6096" layer="16"/>
<wire x1="55.88" y1="33.02" x2="58.42" y2="33.02" width="0.6096" layer="16"/>
<wire x1="101.854" y1="34.29" x2="100.584" y2="33.02" width="0.6096" layer="16"/>
<wire x1="100.584" y1="33.02" x2="78.994" y2="33.02" width="0.6096" layer="16"/>
<wire x1="78.994" y1="33.02" x2="71.374" y2="25.4" width="0.6096" layer="16"/>
<wire x1="71.374" y1="25.4" x2="71.374" y2="28.956" width="0.6096" layer="16"/>
<wire x1="71.374" y1="28.956" x2="67.31" y2="33.02" width="0.6096" layer="16"/>
<wire x1="67.31" y1="33.02" x2="58.42" y2="33.02" width="0.6096" layer="16"/>
</signal>
<signal name="K0">
<contactref element="DIGIT1" pad="K0"/>
<contactref element="DIGIT2" pad="K0"/>
<contactref element="DIGIT3" pad="K0"/>
<contactref element="JP1" pad="7"/>
<contactref element="JP3" pad="7"/>
<contactref element="JP5" pad="7"/>
<wire x1="159.3301" y1="-71.2842" x2="157.6442" y2="-71.2842" width="0.6096" layer="16"/>
<wire x1="157.6442" y1="-71.2842" x2="156.21" y2="-69.85" width="0.6096" layer="16"/>
<wire x1="156.21" y1="-69.85" x2="156.21" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="180.9201" y1="-71.2842" x2="179.2342" y2="-71.2842" width="0.6096" layer="16"/>
<wire x1="179.2342" y1="-71.2842" x2="177.8" y2="-69.85" width="0.6096" layer="16"/>
<wire x1="177.8" y1="-69.85" x2="177.8" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="202.5101" y1="-71.2842" x2="200.8242" y2="-71.2842" width="0.6096" layer="16"/>
<wire x1="200.8242" y1="-71.2842" x2="199.39" y2="-69.85" width="0.6096" layer="16"/>
<wire x1="199.39" y1="-69.85" x2="199.39" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="180.9201" y1="-71.2842" x2="199.39" y2="-69.85" width="0" layer="19" extent="16-16"/>
<wire x1="159.3301" y1="-71.2842" x2="177.8" y2="-69.85" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="K9">
<contactref element="DIGIT1" pad="K9"/>
<contactref element="DIGIT2" pad="K9"/>
<contactref element="DIGIT3" pad="K9"/>
<contactref element="JP1" pad="8"/>
<contactref element="JP3" pad="8"/>
<contactref element="JP5" pad="8"/>
<wire x1="158.0058" y1="-73.2028" x2="154.4828" y2="-73.2028" width="0.6096" layer="16"/>
<wire x1="154.4828" y1="-73.2028" x2="153.67" y2="-72.39" width="0.6096" layer="16"/>
<wire x1="153.67" y1="-72.39" x2="153.67" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="179.5958" y1="-73.2028" x2="176.0728" y2="-73.2028" width="0.6096" layer="16"/>
<wire x1="176.0728" y1="-73.2028" x2="175.26" y2="-72.39" width="0.6096" layer="16"/>
<wire x1="175.26" y1="-72.39" x2="175.26" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="201.1858" y1="-73.2028" x2="197.6628" y2="-73.2028" width="0.6096" layer="16"/>
<wire x1="197.6628" y1="-73.2028" x2="196.85" y2="-72.39" width="0.6096" layer="16"/>
<wire x1="196.85" y1="-72.39" x2="196.85" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="179.5958" y1="-73.2028" x2="196.85" y2="-72.39" width="0" layer="19" extent="16-16"/>
<wire x1="158.0058" y1="-73.2028" x2="175.26" y2="-72.39" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="K8">
<contactref element="DIGIT1" pad="K8"/>
<contactref element="DIGIT2" pad="K8"/>
<contactref element="DIGIT3" pad="K8"/>
<contactref element="JP2" pad="2"/>
<contactref element="JP4" pad="2"/>
<contactref element="JP6" pad="2"/>
<wire x1="157.48" y1="-86.36" x2="157.48" y2="-78.7683" width="0.6096" layer="16"/>
<wire x1="157.48" y1="-78.7683" x2="158.5514" y2="-77.6969" width="0.6096" layer="16"/>
<wire x1="180.1414" y1="-77.6969" x2="180.1131" y2="-77.6969" width="0.6096" layer="16"/>
<wire x1="180.1131" y1="-77.6969" x2="179.07" y2="-78.74" width="0.6096" layer="16"/>
<wire x1="179.07" y1="-78.74" x2="179.07" y2="-86.36" width="0.6096" layer="16"/>
<wire x1="200.66" y1="-86.36" x2="200.66" y2="-78.7683" width="0.6096" layer="16"/>
<wire x1="200.66" y1="-78.7683" x2="201.7314" y2="-77.6969" width="0.6096" layer="16"/>
<wire x1="180.1414" y1="-77.6969" x2="200.66" y2="-78.7683" width="0" layer="19" extent="16-16"/>
<wire x1="158.5514" y1="-77.6969" x2="179.07" y2="-78.74" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="K7">
<contactref element="DIGIT1" pad="K7"/>
<contactref element="DIGIT2" pad="K7"/>
<contactref element="DIGIT3" pad="K7"/>
<contactref element="JP2" pad="3"/>
<contactref element="JP4" pad="3"/>
<contactref element="JP6" pad="3"/>
<wire x1="160.02" y1="-86.36" x2="160.02" y2="-79.5193" width="0.6096" layer="16"/>
<wire x1="160.02" y1="-79.5193" x2="160.2964" y2="-79.2429" width="0.6096" layer="16"/>
<wire x1="181.61" y1="-86.36" x2="181.61" y2="-79.5193" width="0.6096" layer="16"/>
<wire x1="181.61" y1="-79.5193" x2="181.8864" y2="-79.2429" width="0.6096" layer="16"/>
<wire x1="203.2" y1="-86.36" x2="203.2" y2="-79.5193" width="0.6096" layer="16"/>
<wire x1="203.2" y1="-79.5193" x2="203.4764" y2="-79.2429" width="0.6096" layer="16"/>
<wire x1="181.8864" y1="-79.2429" x2="203.2" y2="-79.5193" width="0" layer="19" extent="16-16"/>
<wire x1="160.2964" y1="-79.2429" x2="181.61" y2="-79.5193" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="K6">
<contactref element="DIGIT1" pad="K6"/>
<contactref element="DIGIT2" pad="K6"/>
<contactref element="DIGIT3" pad="K6"/>
<contactref element="JP2" pad="4"/>
<contactref element="JP4" pad="4"/>
<contactref element="JP6" pad="4"/>
<wire x1="162.56" y1="-86.36" x2="162.56" y2="-79.8008" width="0.6096" layer="16"/>
<wire x1="184.15" y1="-86.36" x2="184.15" y2="-79.8008" width="0.6096" layer="16"/>
<wire x1="205.74" y1="-79.8008" x2="205.74" y2="-86.36" width="0.6096" layer="16"/>
<wire x1="184.15" y1="-79.8008" x2="205.74" y2="-79.8008" width="0" layer="19" extent="1-1"/>
<wire x1="162.56" y1="-79.8008" x2="184.15" y2="-79.8008" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="K5">
<contactref element="DIGIT1" pad="K5"/>
<contactref element="DIGIT2" pad="K5"/>
<contactref element="DIGIT3" pad="K5"/>
<contactref element="JP2" pad="5"/>
<contactref element="JP4" pad="5"/>
<contactref element="JP6" pad="5"/>
<wire x1="165.1" y1="-86.36" x2="165.1" y2="-79.5193" width="0.6096" layer="16"/>
<wire x1="165.1" y1="-79.5193" x2="164.8236" y2="-79.2429" width="0.6096" layer="16"/>
<wire x1="186.69" y1="-86.36" x2="186.69" y2="-79.5193" width="0.6096" layer="16"/>
<wire x1="186.69" y1="-79.5193" x2="186.4136" y2="-79.2429" width="0.6096" layer="16"/>
<wire x1="208.28" y1="-86.36" x2="208.28" y2="-79.5193" width="0.6096" layer="16"/>
<wire x1="208.28" y1="-79.5193" x2="208.0036" y2="-79.2429" width="0.6096" layer="16"/>
<wire x1="186.69" y1="-79.5193" x2="208.0036" y2="-79.2429" width="0" layer="19" extent="16-16"/>
<wire x1="165.1" y1="-79.5193" x2="186.4136" y2="-79.2429" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="K4">
<contactref element="DIGIT1" pad="K4"/>
<contactref element="DIGIT2" pad="K4"/>
<contactref element="DIGIT3" pad="K4"/>
<contactref element="JP2" pad="6"/>
<contactref element="JP4" pad="6"/>
<contactref element="JP6" pad="6"/>
<wire x1="166.5686" y1="-77.6969" x2="166.5969" y2="-77.6969" width="0.6096" layer="16"/>
<wire x1="166.5969" y1="-77.6969" x2="167.64" y2="-78.74" width="0.6096" layer="16"/>
<wire x1="167.64" y1="-78.74" x2="167.64" y2="-86.36" width="0.6096" layer="16"/>
<wire x1="189.23" y1="-86.36" x2="189.23" y2="-78.7683" width="0.6096" layer="16"/>
<wire x1="189.23" y1="-78.7683" x2="188.1586" y2="-77.6969" width="0.6096" layer="16"/>
<wire x1="210.82" y1="-86.36" x2="210.82" y2="-78.7683" width="0.6096" layer="16"/>
<wire x1="210.82" y1="-78.7683" x2="209.7486" y2="-77.6969" width="0.6096" layer="16"/>
<wire x1="189.23" y1="-78.7683" x2="209.7486" y2="-77.6969" width="0" layer="19" extent="16-16"/>
<wire x1="167.64" y1="-78.74" x2="188.1586" y2="-77.6969" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="K3">
<contactref element="DIGIT1" pad="K3"/>
<contactref element="DIGIT2" pad="K3"/>
<contactref element="DIGIT3" pad="K3"/>
<contactref element="JP1" pad="1"/>
<contactref element="JP3" pad="1"/>
<contactref element="JP5" pad="1"/>
<wire x1="167.1142" y1="-73.2028" x2="170.6372" y2="-73.2028" width="0.6096" layer="16"/>
<wire x1="170.6372" y1="-73.2028" x2="171.45" y2="-72.39" width="0.6096" layer="16"/>
<wire x1="171.45" y1="-72.39" x2="171.45" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="188.7042" y1="-73.2028" x2="192.2272" y2="-73.2028" width="0.6096" layer="16"/>
<wire x1="192.2272" y1="-73.2028" x2="193.04" y2="-72.39" width="0.6096" layer="16"/>
<wire x1="193.04" y1="-72.39" x2="193.04" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="210.2942" y1="-73.2028" x2="213.8172" y2="-73.2028" width="0.6096" layer="16"/>
<wire x1="213.8172" y1="-73.2028" x2="214.63" y2="-72.39" width="0.6096" layer="16"/>
<wire x1="214.63" y1="-72.39" x2="214.63" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="193.04" y1="-72.39" x2="210.2942" y2="-73.2028" width="0" layer="19" extent="16-16"/>
<wire x1="171.45" y1="-72.39" x2="188.7042" y2="-73.2028" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="K2">
<contactref element="DIGIT1" pad="K2"/>
<contactref element="DIGIT2" pad="K2"/>
<contactref element="DIGIT3" pad="K2"/>
<contactref element="JP1" pad="2"/>
<contactref element="JP3" pad="2"/>
<contactref element="JP5" pad="2"/>
<wire x1="165.7899" y1="-71.2842" x2="167.4758" y2="-71.2842" width="0.6096" layer="16"/>
<wire x1="167.4758" y1="-71.2842" x2="168.91" y2="-69.85" width="0.6096" layer="16"/>
<wire x1="168.91" y1="-69.85" x2="168.91" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="187.3799" y1="-71.2842" x2="189.0658" y2="-71.2842" width="0.6096" layer="16"/>
<wire x1="189.0658" y1="-71.2842" x2="190.5" y2="-69.85" width="0.6096" layer="16"/>
<wire x1="190.5" y1="-69.85" x2="190.5" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="208.9699" y1="-71.2842" x2="210.6558" y2="-71.2842" width="0.6096" layer="16"/>
<wire x1="210.6558" y1="-71.2842" x2="212.09" y2="-69.85" width="0.6096" layer="16"/>
<wire x1="212.09" y1="-69.85" x2="212.09" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="190.5" y1="-69.85" x2="208.9699" y2="-71.2842" width="0" layer="19" extent="16-16"/>
<wire x1="168.91" y1="-69.85" x2="187.3799" y2="-71.2842" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="K1">
<contactref element="DIGIT1" pad="K1"/>
<contactref element="DIGIT2" pad="K1"/>
<contactref element="DIGIT3" pad="K1"/>
<contactref element="JP1" pad="3"/>
<contactref element="JP3" pad="3"/>
<contactref element="JP5" pad="3"/>
<wire x1="163.7257" y1="-70.2008" x2="163.7257" y2="-68.6843" width="0.6096" layer="16"/>
<wire x1="163.7257" y1="-68.6843" x2="166.37" y2="-66.04" width="0.6096" layer="16"/>
<wire x1="166.37" y1="-66.04" x2="166.37" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="185.3157" y1="-70.2008" x2="185.3157" y2="-68.6843" width="0.6096" layer="16"/>
<wire x1="185.3157" y1="-68.6843" x2="187.96" y2="-66.04" width="0.6096" layer="16"/>
<wire x1="187.96" y1="-66.04" x2="187.96" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="206.9057" y1="-70.2008" x2="206.9057" y2="-68.6843" width="0.6096" layer="16"/>
<wire x1="206.9057" y1="-68.6843" x2="209.55" y2="-66.04" width="0.6096" layer="16"/>
<wire x1="209.55" y1="-66.04" x2="209.55" y2="-63.5" width="0.6096" layer="16"/>
<wire x1="187.96" y1="-66.04" x2="206.9057" y2="-68.6843" width="0" layer="19" extent="16-16"/>
<wire x1="166.37" y1="-66.04" x2="185.3157" y2="-68.6843" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$20">
<contactref element="DIGIT2" pad="TL"/>
<contactref element="JP4" pad="7"/>
<wire x1="188.9853" y1="-75.5171" x2="191.0871" y2="-75.5171" width="0.6096" layer="16"/>
<wire x1="191.0871" y1="-75.5171" x2="191.77" y2="-76.2" width="0.6096" layer="16"/>
<wire x1="191.77" y1="-76.2" x2="191.77" y2="-86.36" width="0.6096" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="JP11" pad="8"/>
<contactref element="JP13" pad="8"/>
<contactref element="JP15" pad="8"/>
<contactref element="IC4" pad="2"/>
<wire x1="139.7" y1="21.59" x2="142.24" y2="21.59" width="0.6096" layer="16"/>
<wire x1="142.24" y1="21.59" x2="143.51" y2="20.32" width="0.6096" layer="16"/>
<wire x1="143.51" y1="20.32" x2="143.51" y2="17.78" width="0.6096" layer="16"/>
<wire x1="143.51" y1="17.78" x2="142.24" y2="16.51" width="0.6096" layer="16"/>
<wire x1="118.11" y1="17.78" x2="119.38" y2="16.51" width="0.6096" layer="16"/>
<via x="142.24" y="16.51" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="119.38" y1="16.51" x2="121.92" y2="16.51" width="0.6096" layer="16"/>
<via x="121.92" y="16.51" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="54.61" y1="40.64" x2="54.61" y2="38.1" width="0.6096" layer="16"/>
<wire x1="54.61" y1="38.1" x2="55.88" y2="36.83" width="0.6096" layer="16"/>
<wire x1="55.88" y1="36.83" x2="76.2" y2="36.83" width="0.6096" layer="16"/>
<wire x1="76.2" y1="36.83" x2="97.79" y2="36.83" width="0.6096" layer="16"/>
<wire x1="76.2" y1="40.64" x2="76.2" y2="36.83" width="0.6096" layer="16"/>
<wire x1="97.79" y1="40.64" x2="97.79" y2="36.83" width="0.6096" layer="16"/>
<wire x1="97.79" y1="36.83" x2="116.84" y2="36.83" width="0.6096" layer="16"/>
<wire x1="116.84" y1="36.83" x2="118.11" y2="35.56" width="0.6096" layer="16"/>
<wire x1="118.11" y1="35.56" x2="118.11" y2="17.78" width="0.6096" layer="16"/>
<wire x1="121.92" y1="16.51" x2="139.7" y2="21.59" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$25">
<contactref element="JP15" pad="7"/>
<contactref element="JP11" pad="7"/>
<contactref element="JP13" pad="7"/>
<contactref element="IC4" pad="16"/>
<wire x1="132.08" y1="19.05" x2="129.54" y2="19.05" width="0.6096" layer="16"/>
<via x="121.92" y="19.05" extent="1-16" drill="0.6" shape="square"/>
<wire x1="119.38" y1="21.59" x2="121.92" y2="19.05" width="0.6096" layer="16"/>
<wire x1="100.33" y1="40.64" x2="100.33" y2="38.608" width="0.6096" layer="16"/>
<wire x1="100.33" y1="38.608" x2="101.092" y2="37.846" width="0.6096" layer="16"/>
<wire x1="101.092" y1="37.846" x2="118.11" y2="37.846" width="0.6096" layer="16"/>
<wire x1="118.11" y1="37.846" x2="119.38" y2="36.576" width="0.6096" layer="16"/>
<wire x1="119.38" y1="36.576" x2="119.38" y2="21.59" width="0.6096" layer="16"/>
<wire x1="57.15" y1="40.64" x2="57.15" y2="39.116" width="0.6096" layer="16"/>
<wire x1="57.15" y1="39.116" x2="58.42" y2="37.846" width="0.6096" layer="16"/>
<wire x1="58.42" y1="37.846" x2="73.406" y2="37.846" width="0.6096" layer="16"/>
<wire x1="73.406" y1="37.846" x2="74.422" y2="38.862" width="0.6096" layer="16"/>
<wire x1="74.422" y1="38.862" x2="74.422" y2="42.418" width="0.6096" layer="16"/>
<wire x1="74.422" y1="42.418" x2="75.184" y2="43.18" width="0.6096" layer="16"/>
<wire x1="75.184" y1="43.18" x2="78.232" y2="43.18" width="0.6096" layer="16"/>
<wire x1="78.232" y1="43.18" x2="78.74" y2="42.672" width="0.6096" layer="16"/>
<wire x1="78.74" y1="42.672" x2="78.74" y2="40.64" width="0.6096" layer="16"/>
<wire x1="78.74" y1="40.64" x2="78.74" y2="38.862" width="0.6096" layer="16"/>
<wire x1="78.74" y1="38.862" x2="79.756" y2="37.846" width="0.6096" layer="16"/>
<wire x1="79.756" y1="37.846" x2="94.996" y2="37.846" width="0.6096" layer="16"/>
<wire x1="94.996" y1="37.846" x2="96.012" y2="38.862" width="0.6096" layer="16"/>
<wire x1="96.012" y1="38.862" x2="96.012" y2="42.672" width="0.6096" layer="16"/>
<wire x1="96.012" y1="42.672" x2="96.774" y2="43.688" width="0.6096" layer="16"/>
<wire x1="96.774" y1="43.688" x2="99.568" y2="43.688" width="0.6096" layer="16"/>
<wire x1="99.568" y1="43.688" x2="100.33" y2="42.926" width="0.6096" layer="16"/>
<wire x1="100.33" y1="42.926" x2="100.33" y2="40.64" width="0.6096" layer="16"/>
<wire x1="121.92" y1="19.05" x2="129.54" y2="19.05" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$31">
<contactref element="JP11" pad="5"/>
<contactref element="R8" pad="2"/>
<wire x1="62.23" y1="40.64" x2="62.23" y2="44.45" width="0.6096" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="JP11" pad="3"/>
<contactref element="JP13" pad="3"/>
<contactref element="JP15" pad="3"/>
<contactref element="IC4" pad="15"/>
<wire x1="132.08" y1="21.59" x2="129.54" y2="21.59" width="0.6096" layer="16"/>
<wire x1="67.31" y1="40.64" x2="67.31" y2="45.974" width="0.6096" layer="16"/>
<wire x1="67.31" y1="45.974" x2="69.85" y2="48.514" width="0.6096" layer="16"/>
<wire x1="69.85" y1="48.514" x2="88.646" y2="48.514" width="0.6096" layer="16"/>
<wire x1="88.646" y1="48.514" x2="88.9" y2="48.514" width="0.6096" layer="16"/>
<wire x1="88.9" y1="48.514" x2="88.9" y2="40.64" width="0.6096" layer="16"/>
<wire x1="88.9" y1="40.64" x2="88.9" y2="48.26" width="0.6096" layer="16"/>
<wire x1="88.9" y1="48.26" x2="88.646" y2="48.514" width="0.6096" layer="16"/>
<wire x1="88.9" y1="48.514" x2="110.49" y2="48.514" width="0.6096" layer="16"/>
<wire x1="110.49" y1="40.64" x2="110.49" y2="48.514" width="0.6096" layer="16"/>
<wire x1="110.49" y1="48.514" x2="118.872" y2="48.514" width="0.6096" layer="16"/>
<wire x1="118.872" y1="48.514" x2="121.92" y2="45.466" width="0.6096" layer="16"/>
<wire x1="121.92" y1="45.466" x2="121.92" y2="21.59" width="0.6096" layer="16"/>
<via x="121.92" y="21.59" extent="1-16" drill="0.6" shape="square"/>
<wire x1="121.92" y1="21.59" x2="129.54" y2="21.59" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$32">
<contactref element="JP11" pad="2"/>
<contactref element="JP15" pad="2"/>
<contactref element="JP13" pad="2"/>
<contactref element="IC4" pad="8"/>
<wire x1="113.03" y1="52.07" x2="91.44" y2="52.07" width="0.6096" layer="16"/>
<wire x1="91.44" y1="52.07" x2="69.85" y2="52.07" width="0.6096" layer="16"/>
<wire x1="91.44" y1="40.64" x2="91.44" y2="44.45" width="0.6096" layer="16"/>
<via x="91.44" y="52.07" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="69.85" y1="40.64" x2="69.85" y2="44.45" width="0.6096" layer="16"/>
<via x="69.85" y="52.07" extent="1-16" drill="0.7" shape="octagon"/>
<via x="69.85" y="44.45" extent="1-16" drill="0.7" shape="octagon"/>
<via x="91.44" y="44.45" extent="1-16" drill="0.7" shape="octagon"/>
<via x="113.03" y="52.07" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="113.03" y1="40.64" x2="113.03" y2="44.45" width="0.6096" layer="16"/>
<wire x1="113.03" y1="52.07" x2="124.46" y2="52.07" width="0.6096" layer="16"/>
<wire x1="124.46" y1="52.07" x2="125.73" y2="50.8" width="0.6096" layer="16"/>
<wire x1="125.73" y1="50.8" x2="125.73" y2="40.64" width="0.6096" layer="16"/>
<wire x1="125.73" y1="40.64" x2="127" y2="39.37" width="0.6096" layer="16"/>
<wire x1="127" y1="39.37" x2="130.81" y2="39.37" width="0.6096" layer="16"/>
<wire x1="139.7" y1="36.83" x2="139.7" y2="38.1" width="0.6096" layer="16"/>
<wire x1="139.7" y1="38.1" x2="139.7" y2="39.37" width="0.6096" layer="16"/>
<via x="139.7" y="39.37" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="130.81" y1="39.37" x2="132.08" y2="39.37" width="0.6096" layer="16"/>
<wire x1="132.08" y1="39.37" x2="139.7" y2="39.37" width="0" layer="19" extent="16-16"/>
<wire x1="113.03" y1="44.45" x2="113.03" y2="52.07" width="0" layer="19" extent="16-16"/>
<wire x1="91.44" y1="44.45" x2="91.44" y2="52.07" width="0" layer="19" extent="16-16"/>
<wire x1="69.85" y1="44.45" x2="69.85" y2="52.07" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$33">
<contactref element="JP15" pad="1"/>
<contactref element="JP11" pad="1"/>
<contactref element="JP13" pad="1"/>
<contactref element="IC4" pad="9"/>
<wire x1="115.57" y1="50.8" x2="93.98" y2="50.8" width="0.6096" layer="16"/>
<wire x1="93.98" y1="50.8" x2="72.39" y2="50.8" width="0.6096" layer="16"/>
<wire x1="93.98" y1="40.64" x2="93.98" y2="44.45" width="0.6096" layer="16"/>
<via x="93.98" y="50.8" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="72.39" y1="40.64" x2="72.39" y2="44.45" width="0.6096" layer="16"/>
<via x="72.39" y="50.8" extent="1-16" drill="0.7" shape="octagon"/>
<via x="72.39" y="44.45" extent="1-16" drill="0.7" shape="octagon"/>
<via x="93.98" y="44.45" extent="1-16" drill="0.7" shape="octagon"/>
<via x="115.57" y="50.8" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="115.57" y1="40.64" x2="115.57" y2="44.45" width="0.6096" layer="16"/>
<wire x1="115.57" y1="50.8" x2="123.19" y2="50.8" width="0.6096" layer="16"/>
<wire x1="123.19" y1="50.8" x2="124.46" y2="49.53" width="0.6096" layer="16"/>
<wire x1="124.46" y1="49.53" x2="124.46" y2="38.1" width="0.6096" layer="16"/>
<wire x1="124.46" y1="38.1" x2="125.73" y2="36.83" width="0.6096" layer="16"/>
<wire x1="125.73" y1="36.83" x2="132.08" y2="36.83" width="0.6096" layer="16"/>
<wire x1="115.57" y1="50.8" x2="115.57" y2="44.45" width="0" layer="19" extent="16-16"/>
<wire x1="93.98" y1="44.45" x2="93.98" y2="50.8" width="0" layer="19" extent="16-16"/>
<wire x1="72.39" y1="44.45" x2="72.39" y2="50.8" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$35">
<contactref element="R9" pad="2"/>
<contactref element="JP13" pad="5"/>
<wire x1="83.82" y1="40.64" x2="83.82" y2="44.45" width="0.6096" layer="16"/>
</signal>
<signal name="N$36">
<contactref element="R10" pad="2"/>
<contactref element="JP15" pad="5"/>
<wire x1="105.41" y1="40.64" x2="105.41" y2="44.45" width="0.6096" layer="16"/>
</signal>
<signal name="N$37">
<contactref element="JP12" pad="6"/>
<contactref element="JP16" pad="6"/>
<contactref element="JP14" pad="6"/>
<contactref element="IC4" pad="1"/>
<wire x1="111.76" y1="6.35" x2="90.17" y2="6.35" width="0.6096" layer="16"/>
<via x="68.58" y="6.35" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="90.17" y1="6.35" x2="68.58" y2="6.35" width="0.6096" layer="16"/>
<wire x1="90.17" y1="17.78" x2="90.17" y2="13.97" width="0.6096" layer="16"/>
<via x="90.17" y="6.35" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="68.58" y1="17.78" x2="68.58" y2="13.97" width="0.6096" layer="16"/>
<via x="68.58" y="13.97" extent="1-16" drill="0.7" shape="octagon"/>
<via x="90.17" y="13.97" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="111.76" y1="6.35" x2="123.19" y2="6.35" width="0.6096" layer="16"/>
<via x="111.76" y="6.35" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="139.7" y1="19.05" x2="139.7" y2="7.62" width="0.6096" layer="16"/>
<wire x1="139.7" y1="7.62" x2="138.43" y2="6.35" width="0.6096" layer="16"/>
<wire x1="138.43" y1="6.35" x2="123.19" y2="6.35" width="0.6096" layer="16"/>
<wire x1="111.76" y1="17.78" x2="111.76" y2="13.97" width="0.6096" layer="16"/>
<wire x1="111.76" y1="6.35" x2="111.76" y2="13.97" width="0" layer="19" extent="16-16"/>
<wire x1="90.17" y1="13.97" x2="90.17" y2="6.35" width="0" layer="19" extent="16-16"/>
<wire x1="68.58" y1="13.97" x2="68.58" y2="6.35" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$34">
<contactref element="JP12" pad="5"/>
<contactref element="JP16" pad="5"/>
<contactref element="JP14" pad="5"/>
<contactref element="IC4" pad="10"/>
<wire x1="132.08" y1="34.29" x2="125.73" y2="34.29" width="0.6096" layer="16"/>
<wire x1="125.73" y1="34.29" x2="124.46" y2="33.02" width="0.6096" layer="16"/>
<wire x1="124.46" y1="33.02" x2="124.46" y2="14.732" width="0.6096" layer="16"/>
<wire x1="109.22" y1="20.574" x2="115.57" y2="20.574" width="0.6096" layer="16"/>
<wire x1="115.57" y1="20.574" x2="117.094" y2="19.05" width="0.6096" layer="16"/>
<wire x1="117.094" y1="19.05" x2="117.094" y2="16.764" width="0.6096" layer="16"/>
<wire x1="117.094" y1="16.764" x2="119.634" y2="14.224" width="0.6096" layer="16"/>
<wire x1="119.634" y1="14.224" x2="123.952" y2="14.224" width="0.6096" layer="16"/>
<wire x1="123.952" y1="14.224" x2="124.46" y2="14.732" width="0.6096" layer="16"/>
<wire x1="109.22" y1="17.78" x2="109.22" y2="20.574" width="0.6096" layer="16"/>
<wire x1="109.22" y1="20.574" x2="108.458" y2="21.336" width="0.6096" layer="16"/>
<wire x1="108.458" y1="21.336" x2="87.884" y2="21.336" width="0.6096" layer="16"/>
<wire x1="87.884" y1="21.336" x2="66.802" y2="21.336" width="0.6096" layer="16"/>
<wire x1="66.802" y1="21.336" x2="66.04" y2="20.574" width="0.6096" layer="16"/>
<wire x1="66.04" y1="20.574" x2="66.04" y2="17.78" width="0.6096" layer="16"/>
<wire x1="87.63" y1="17.78" x2="87.63" y2="21.082" width="0.6096" layer="16"/>
<wire x1="87.63" y1="21.082" x2="87.884" y2="21.336" width="0.6096" layer="16"/>
</signal>
<signal name="N$38">
<contactref element="JP12" pad="4"/>
<contactref element="JP16" pad="4"/>
<contactref element="JP14" pad="4"/>
<contactref element="IC4" pad="11"/>
<wire x1="132.08" y1="31.75" x2="127.762" y2="31.75" width="0.6096" layer="16"/>
<wire x1="127.762" y1="31.75" x2="125.73" y2="29.718" width="0.6096" layer="16"/>
<wire x1="125.73" y1="29.718" x2="125.73" y2="13.716" width="0.6096" layer="16"/>
<wire x1="125.73" y1="13.716" x2="124.206" y2="12.192" width="0.6096" layer="16"/>
<wire x1="124.206" y1="12.192" x2="108.204" y2="12.192" width="0.6096" layer="16"/>
<wire x1="108.204" y1="12.192" x2="106.68" y2="13.716" width="0.6096" layer="16"/>
<wire x1="106.68" y1="13.716" x2="106.68" y2="17.78" width="0.6096" layer="16"/>
<wire x1="106.68" y1="17.78" x2="106.68" y2="19.558" width="0.6096" layer="16"/>
<wire x1="106.68" y1="19.558" x2="105.918" y2="20.32" width="0.6096" layer="16"/>
<wire x1="105.918" y1="20.32" x2="97.282" y2="20.32" width="0.6096" layer="16"/>
<wire x1="97.282" y1="20.32" x2="96.012" y2="19.05" width="0.6096" layer="16"/>
<wire x1="96.012" y1="19.05" x2="96.012" y2="13.97" width="0.6096" layer="16"/>
<wire x1="96.012" y1="13.97" x2="94.234" y2="12.192" width="0.6096" layer="16"/>
<wire x1="94.234" y1="12.192" x2="86.868" y2="12.192" width="0.6096" layer="16"/>
<wire x1="86.868" y1="12.192" x2="85.09" y2="13.97" width="0.6096" layer="16"/>
<wire x1="85.09" y1="13.97" x2="85.09" y2="19.558" width="0.6096" layer="16"/>
<wire x1="85.09" y1="19.558" x2="84.328" y2="20.32" width="0.6096" layer="16"/>
<wire x1="84.328" y1="20.32" x2="75.438" y2="20.32" width="0.6096" layer="16"/>
<wire x1="75.438" y1="20.32" x2="74.422" y2="19.304" width="0.6096" layer="16"/>
<wire x1="74.422" y1="19.304" x2="74.422" y2="14.224" width="0.6096" layer="16"/>
<wire x1="74.422" y1="14.224" x2="72.39" y2="12.192" width="0.6096" layer="16"/>
<wire x1="72.39" y1="12.192" x2="65.278" y2="12.192" width="0.6096" layer="16"/>
<wire x1="65.278" y1="12.192" x2="63.5" y2="13.97" width="0.6096" layer="16"/>
<wire x1="63.5" y1="13.97" x2="63.5" y2="17.78" width="0.6096" layer="16"/>
<wire x1="85.09" y1="19.558" x2="85.09" y2="17.78" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="S$1">
<contactref element="JP12" pad="3"/>
<wire x1="60.96" y1="17.78" x2="60.96" y2="19.812" width="0.6096" layer="16"/>
<wire x1="60.96" y1="19.812" x2="60.452" y2="20.32" width="0.6096" layer="16"/>
<wire x1="60.452" y1="20.32" x2="55.118" y2="20.32" width="0.6096" layer="16"/>
<wire x1="55.118" y1="20.32" x2="54.356" y2="19.558" width="0.6096" layer="16"/>
<wire x1="54.356" y1="19.558" x2="54.356" y2="10.922" width="0.6096" layer="16"/>
<wire x1="54.356" y1="10.922" x2="56.134" y2="9.144" width="0.6096" layer="16"/>
</signal>
<signal name="N$39">
<contactref element="JP16" pad="3"/>
<contactref element="JP14" pad="3"/>
<contactref element="IC4" pad="14"/>
<wire x1="82.55" y1="17.78" x2="82.55" y2="13.97" width="0.6096" layer="16"/>
<via x="82.55" y="13.97" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="132.08" y1="24.13" x2="134.62" y2="24.13" width="0.6096" layer="16"/>
<wire x1="134.62" y1="24.13" x2="135.89" y2="22.86" width="0.6096" layer="16"/>
<wire x1="135.89" y1="22.86" x2="135.89" y2="10.668" width="0.6096" layer="16"/>
<wire x1="104.14" y1="17.78" x2="104.14" y2="13.97" width="0.6096" layer="16"/>
<wire x1="135.89" y1="10.668" x2="134.366" y2="9.144" width="0.6096" layer="16"/>
<wire x1="134.366" y1="9.144" x2="104.14" y2="9.144" width="0.6096" layer="16"/>
<wire x1="104.14" y1="9.144" x2="82.55" y2="9.144" width="0.6096" layer="16"/>
<via x="82.55" y="9.144" extent="1-16" drill="0.7" shape="octagon"/>
<via x="104.14" y="9.144" extent="1-16" drill="0.7" shape="octagon"/>
<wire x1="82.55" y1="9.144" x2="56.134" y2="9.144" width="0.6096" layer="16"/>
<wire x1="56.134" y1="9.144" x2="55.88" y2="9.398" width="0.6096" layer="16"/>
<wire x1="104.14" y1="9.144" x2="104.14" y2="13.97" width="0" layer="19" extent="16-16"/>
<wire x1="82.55" y1="13.97" x2="82.55" y2="9.144" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$40">
<contactref element="JP12" pad="2"/>
<contactref element="JP16" pad="2"/>
<contactref element="JP14" pad="2"/>
<contactref element="IC4" pad="13"/>
<wire x1="58.42" y1="17.78" x2="58.42" y2="12.446" width="0.6096" layer="16"/>
<wire x1="58.42" y1="12.446" x2="60.452" y2="10.414" width="0.6096" layer="16"/>
<wire x1="60.452" y1="10.414" x2="79.756" y2="10.414" width="0.6096" layer="16"/>
<wire x1="79.756" y1="10.414" x2="101.854" y2="10.414" width="0.6096" layer="16"/>
<wire x1="101.854" y1="10.414" x2="124.968" y2="10.414" width="0.6096" layer="16"/>
<wire x1="124.968" y1="10.414" x2="127.762" y2="13.208" width="0.6096" layer="16"/>
<wire x1="127.762" y1="13.208" x2="127.762" y2="24.638" width="0.6096" layer="16"/>
<wire x1="127.762" y1="24.638" x2="129.794" y2="26.67" width="0.6096" layer="16"/>
<wire x1="129.794" y1="26.67" x2="132.08" y2="26.67" width="0.6096" layer="16"/>
<wire x1="80.01" y1="17.78" x2="80.01" y2="10.668" width="0.6096" layer="16"/>
<wire x1="80.01" y1="10.668" x2="79.756" y2="10.414" width="0.6096" layer="16"/>
<wire x1="101.6" y1="17.78" x2="101.6" y2="10.668" width="0.6096" layer="16"/>
<wire x1="101.6" y1="10.668" x2="101.854" y2="10.414" width="0.6096" layer="16"/>
</signal>
<signal name="N$61">
</signal>
<signal name="N$66">
</signal>
<signal name="N$68">
</signal>
<signal name="N$72">
<contactref element="JP14" pad="7"/>
<wire x1="92.71" y1="17.78" x2="92.71" y2="13.97" width="0.6096" layer="16"/>
<via x="92.71" y="13.97" extent="1-16" drill="0.7" shape="octagon"/>
<via x="92.71" y="5.08" extent="1-16" drill="0.7" shape="octagon"/>
<contactref element="T6" pad="C"/>
<wire x1="92.71" y1="5.08" x2="151.13" y2="5.08" width="0.6096" layer="16"/>
<wire x1="151.13" y1="5.08" x2="152.4" y2="6.35" width="0.6096" layer="16"/>
<wire x1="152.4" y1="6.35" x2="152.4" y2="7.62" width="0.6096" layer="16"/>
<wire x1="92.71" y1="5.08" x2="92.71" y2="13.97" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$43">
<via x="110.49" y="44.45" extent="1-16" drill="0.7" shape="octagon"/>
</signal>
<signal name="N$45">
<via x="113.03" y="44.45" extent="1-16" drill="0.7" shape="octagon"/>
</signal>
<signal name="N$49">
<via x="115.57" y="44.45" extent="1-16" drill="0.7" shape="octagon"/>
</signal>
<signal name="N$50">
<via x="132.08" y="39.37" extent="1-16" drill="0.7" shape="octagon"/>
</signal>
<signal name="N$51">
</signal>
<signal name="N$41">
</signal>
<signal name="N$42">
</signal>
<signal name="N$52">
<via x="104.14" y="13.97" extent="1-16" drill="0.7" shape="octagon"/>
</signal>
<signal name="N$53">
<via x="111.76" y="13.97" extent="1-16" drill="0.7" shape="octagon"/>
</signal>
<signal name="N$54">
<via x="129.54" y="21.59" extent="1-16" drill="0.7" shape="octagon"/>
</signal>
<signal name="N$55">
<via x="129.54" y="19.05" extent="1-16" drill="0.7" shape="octagon"/>
</signal>
<signal name="N$56">
<contactref element="R25" pad="2"/>
<contactref element="T6" pad="B"/>
<wire x1="152.4" y1="10.16" x2="158.75" y2="10.16" width="0.6096" layer="16"/>
<wire x1="158.75" y1="10.16" x2="160.02" y2="11.43" width="0.6096" layer="16"/>
</signal>
<signal name="A3">
<contactref element="IC3" pad="26"/>
</signal>
<signal name="N$1">
<via x="44.45" y="22.86" extent="1-16" drill="0.7" shape="octagon"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
