RS is the sensing resistor of the PFC boost converter. During the steady state, line input current x RS = IGAINMOD x 3.5K. Since the maximum output voltage of the gain modulator is IGAINMOD max x 3.5K= 0.8V during the steady state, RS x line input current will be limited below 0.8V as well. Therefore, to choose RS, we use the following equation: RS =0.8V x Vinpeak/(2x Line Input power) For example, if the minimum input voltage is 80VAC, and the maximum input rms power is 200Watt, RS = (0.8V x 80V x 1.414)/(2 x 200) = 0.226 ?.
