<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.635" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="-8.255" x2="173.97" y2="-8.255" width="0" layer="20"/>
<wire x1="173.97" y1="-8.255" x2="173.97" y2="122.86" width="0" layer="20"/>
<wire x1="173.97" y1="122.86" x2="0" y2="122.86" width="0" layer="20"/>
<wire x1="0" y1="122.86" x2="0" y2="-8.255" width="0" layer="20"/>
</plain>
<libraries>
<library name="resistor">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;tr valign="top"&gt;
&lt;/td&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="M1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
MELF 0.25 W</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="C1206K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SO08">
<description>&lt;b&gt;Small Outline Package 8&lt;/b&gt;&lt;br&gt;
NS Package M08A</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
<package name="TO220H">
<description>&lt;b&gt;TO-220&lt;/b&gt;</description>
<wire x1="-5.207" y1="-7.62" x2="5.207" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.255" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-7.62" x2="5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="5.207" y1="4.826" x2="4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="4.318" y1="4.826" x2="4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="4.318" y1="6.35" x2="5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="5.207" y1="6.35" x2="5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-7.62" x2="-5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.826" x2="-4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="4.826" x2="-4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="6.35" x2="-5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="6.35" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<circle x="0" y="4.826" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="43"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="42"/>
<pad name="1" x="-2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.461" y="-10.922" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.366" y="-11.049" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="2.159" y1="-11.049" x2="2.921" y2="-10.414" layer="21"/>
<rectangle x1="-0.381" y1="-11.049" x2="0.381" y2="-10.414" layer="21"/>
<rectangle x1="-2.921" y1="-11.049" x2="-2.159" y2="-10.414" layer="21"/>
<rectangle x1="-3.175" y1="-10.414" x2="-1.905" y2="-7.62" layer="21"/>
<rectangle x1="-0.635" y1="-10.414" x2="0.635" y2="-7.62" layer="21"/>
<rectangle x1="1.905" y1="-10.414" x2="3.175" y2="-7.62" layer="21"/>
<hole x="0" y="4.826" drill="3.302"/>
</package>
</packages>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SOT23">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="rectifier">
<description>&lt;b&gt;Rectifiers&lt;/b&gt;&lt;p&gt;
General Instrument, Semikron, Diotec, Fagor&lt;p&gt;
<packages>
<package name="DFS">
<description>&lt;b&gt;Surface Mount Glass Passivated Bridge Rectifiers&lt;/hb&gt;&lt;p&gt;
Source: Comchip Bridge Rectifiers DF005S-G thru DF10S-G.pdf</description>
<wire x1="-4.05" y1="3.1" x2="4.05" y2="3.1" width="0.254" layer="21"/>
<wire x1="4.05" y1="3.1" x2="4.05" y2="-3.1" width="0.254" layer="21"/>
<wire x1="4.05" y1="-3.1" x2="-4.05" y2="-3.1" width="0.254" layer="21"/>
<wire x1="-4.05" y1="-3.1" x2="-4.05" y2="3.1" width="0.254" layer="21"/>
<wire x1="-2.55" y1="-1.675" x2="-2" y2="-1.675" width="0.1016" layer="21"/>
<wire x1="-2.275" y1="-1.925" x2="-2.275" y2="-1.4" width="0.1016" layer="21"/>
<wire x1="1.99" y1="-1.675" x2="2.54" y2="-1.675" width="0.1016" layer="21"/>
<wire x1="-2.25" y1="1.75" x2="-2.625" y2="1.75" width="0.1016" layer="21" curve="172.37185"/>
<wire x1="-1.875" y1="1.75" x2="-2.25" y2="1.75" width="0.1016" layer="21" curve="-172.37185"/>
<wire x1="2.25" y1="1.75" x2="2.625" y2="1.75" width="0.1016" layer="21" curve="172.37185"/>
<wire x1="1.875" y1="1.75" x2="2.25" y2="1.75" width="0.1016" layer="21" curve="-172.37185"/>
<smd name="+" x="-2.55" y="-4.5" dx="1.5" dy="1.7" layer="1"/>
<smd name="-" x="2.55" y="-4.5" dx="1.5" dy="1.7" layer="1"/>
<smd name="AC2" x="2.55" y="4.5" dx="1.5" dy="1.7" layer="1" rot="R180"/>
<smd name="AC1" x="-2.55" y="4.5" dx="1.5" dy="1.7" layer="1" rot="R180"/>
<text x="-4.6" y="-3.225" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.425" y="-3.3" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-3.2" y1="-5.1" x2="-1.9" y2="-3.2" layer="51"/>
<rectangle x1="1.9" y1="-5.1" x2="3.2" y2="-3.2" layer="51"/>
<rectangle x1="1.9" y1="3.2" x2="3.2" y2="5.1" layer="51" rot="R180"/>
<rectangle x1="-3.2" y1="3.2" x2="-1.9" y2="5.1" layer="51" rot="R180"/>
</package>
</packages>
</library>
<library name="rcl">
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;/ul&gt;
&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;P&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
  &lt;TR&gt;
      &lt;P&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
    &lt;/TD&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="PANASONIC_G">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G&lt;/b&gt;</description>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="-2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="1" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-1" x2="5.1" y2="-2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-1" width="0.1016" layer="21"/>
<wire x1="-4.85" y1="-1" x2="4.85" y2="-1" width="0.1016" layer="21" curve="156.699401"/>
<wire x1="-4.85" y1="1" x2="4.85" y2="1" width="0.1016" layer="21" curve="-156.699401"/>
<wire x1="-3.25" y1="3.7" x2="-3.25" y2="-3.65" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="4.95" width="0.1016" layer="51"/>
<smd name="-" x="-4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<smd name="+" x="4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<text x="-2.55" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.55" y="-2.675" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-5.85" y1="-0.45" x2="-4.9" y2="0.45" layer="51"/>
<rectangle x1="4.9" y1="-0.45" x2="5.85" y2="0.45" layer="51"/>
<polygon width="0.1016" layer="51">
<vertex x="-3.3" y="3.6"/>
<vertex x="-4.05" y="2.75"/>
<vertex x="-4.65" y="1.55"/>
<vertex x="-4.85" y="0.45"/>
<vertex x="-4.85" y="-0.45"/>
<vertex x="-4.65" y="-1.55"/>
<vertex x="-4.05" y="-2.75"/>
<vertex x="-3.3" y="-3.6"/>
<vertex x="-3.3" y="3.55"/>
</polygon>
</package>
<package name="PANASONIC_D">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D&lt;/b&gt;</description>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="0.95" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="0.95" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-0.95" x2="3.25" y2="-1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.95" width="0.1016" layer="21" curve="-144.299363"/>
<wire x1="-2.95" y1="-0.95" x2="2.95" y2="-0.95" width="0.1016" layer="21" curve="144.299363"/>
<wire x1="-2.1" y1="2.25" x2="-2.1" y2="-2.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="3.1" width="0.1016" layer="51"/>
<smd name="-" x="-2.4" y="0" dx="3" dy="1.4" layer="1"/>
<smd name="+" x="2.4" y="0" dx="3" dy="1.4" layer="1"/>
<text x="-1.75" y="1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-1.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-0.35" x2="-3.05" y2="0.35" layer="51"/>
<rectangle x1="3.05" y1="-0.35" x2="3.65" y2="0.35" layer="51"/>
<vertex x="-2.15" y="2.15"/>
<vertex x="-2.6" y="1.6"/>
<vertex x="-2.9" y="0.9"/>
<vertex x="-3.05" y="0"/>
<vertex x="-2.9" y="-0.95"/>
<vertex x="-2.55" y="-1.65"/>
<vertex x="-2.15" y="-2.15"/>
<vertex x="-2.15" y="2.1"/>
</polygon>
</package>
</packages>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
<packages>
<package name="RR1U">
<description>&lt;b&gt;RELAY&lt;/b&gt;&lt;p&gt;
reed, polarity, 1 x switch with shield</description>
<wire x1="-0.635" y1="-0.254" x2="0.635" y2="-0.254" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.286" x2="-0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="-0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.635" y2="-0.635" width="0.254" layer="21"/>
<wire x1="0.635" y1="-0.254" x2="0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-0.635" x2="0.635" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-0.635" x2="-0.635" y2="-0.254" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.905" x2="0.635" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="0.635" x2="-8.763" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="9.652" y1="2.794" x2="-9.652" y2="2.794" width="0.1524" layer="21"/>
<wire x1="9.652" y1="-2.794" x2="-9.652" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="9.652" y1="-2.794" x2="9.652" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="0.635" x2="-9.652" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-9.652" y1="0.635" x2="-9.652" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-0.635" x2="-9.652" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-9.652" y1="-0.635" x2="-9.652" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-9.652" y1="-0.635" x2="-9.652" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.905" x2="-1.143" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.524" x2="-1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-1.905" x2="1.905" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="1.27" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.27" x2="7.62" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="7.62" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.762" x2="-7.62" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.762" x2="-1.27" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.54" x2="-7.62" y2="2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.254" x2="2.54" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.905" y1="0.254" x2="0.635" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0" y1="0.254" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0.254" x2="-3.175" y2="0.254" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.254" x2="5.08" y2="0.254" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.254" x2="5.08" y2="0.762" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="-1.27" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.032" x2="-7.62" y2="2.032" width="0.1524" layer="21"/>
<circle x="7.62" y="1.27" radius="0.127" width="0.3048" layer="21"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-8.001" y="-2.286" size="1.27" layer="21" ratio="10" rot="R90">1</text>
<text x="-2.54" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.445" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RR2A">
reed, polarity, 2 x norm. open</description>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="0.254" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.524" x2="7.62" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.524" x2="7.62" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.524" x2="-1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.54" x2="-7.62" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.524" x2="1.27" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.254" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.254" x2="-7.62" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.254" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="7.62" y2="0.254" width="0.1524" layer="21"/>
</package>
</packages>
</library>
<library name="74xx-eu">
<description>&lt;b&gt;TTL Devices, 74xx Series with European Symbols&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Texas Instruments &lt;i&gt;TTL Data Book&lt;/i&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;Volume 1, 1996.
&lt;li&gt;TTL Data Book, Volume 2 , 1993
&lt;li&gt;National Seminconductor Databook 1990, ALS/LS Logic
&lt;li&gt;ttl 74er digital data dictionary, ECA Electronic + Acustic GmbH, ISBN 3-88109-032-0
&lt;li&gt;http://icmaster.com/ViewCompare.asp
&lt;/ul&gt;
<packages>
<package name="SO14">
<description>&lt;b&gt;Small Outline package&lt;/b&gt; 150 mil</description>
<wire x1="4.064" y1="1.9558" x2="-4.064" y2="1.9558" width="0.1524" layer="51"/>
<wire x1="4.064" y1="-1.9558" x2="4.445" y2="-1.5748" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.445" y1="1.5748" x2="-4.064" y2="1.9558" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.064" y1="1.9558" x2="4.445" y2="1.5748" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.445" y1="-1.5748" x2="-4.064" y2="-1.9558" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.064" y1="-1.9558" x2="4.064" y2="-1.9558" width="0.1524" layer="51"/>
<wire x1="4.445" y1="-1.5748" x2="4.445" y2="1.5748" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.5748" x2="-4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.445" y2="-1.5748" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="-0.508" width="0.1524" layer="21" curve="-180"/>
<wire x1="-4.445" y1="-1.6002" x2="4.445" y2="-1.6002" width="0.0508" layer="21"/>
<smd name="1" x="-3.81" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="-3.81" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-2.54" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-1.27" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="-2.54" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="-1.27" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="0" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="0" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="1.27" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="2.54" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="1.27" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="2.54" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="3.81" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="3.81" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<text x="-3.175" y="-0.762" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.826" y="-1.905" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-0.254" y1="1.9558" x2="0.254" y2="3.0988" layer="51"/>
<rectangle x1="-4.064" y1="-3.0988" x2="-3.556" y2="-1.9558" layer="51"/>
<rectangle x1="-2.794" y1="-3.0988" x2="-2.286" y2="-1.9558" layer="51"/>
<rectangle x1="-1.524" y1="-3.0734" x2="-1.016" y2="-1.9304" layer="51"/>
<rectangle x1="-0.254" y1="-3.0988" x2="0.254" y2="-1.9558" layer="51"/>
<rectangle x1="-1.524" y1="1.9558" x2="-1.016" y2="3.0988" layer="51"/>
<rectangle x1="-2.794" y1="1.9558" x2="-2.286" y2="3.0988" layer="51"/>
<rectangle x1="-4.064" y1="1.9558" x2="-3.556" y2="3.0988" layer="51"/>
<rectangle x1="1.016" y1="1.9558" x2="1.524" y2="3.0988" layer="51"/>
<rectangle x1="2.286" y1="1.9558" x2="2.794" y2="3.0988" layer="51"/>
<rectangle x1="3.556" y1="1.9558" x2="4.064" y2="3.0988" layer="51"/>
<rectangle x1="1.016" y1="-3.0988" x2="1.524" y2="-1.9558" layer="51"/>
<rectangle x1="2.286" y1="-3.0988" x2="2.794" y2="-1.9558" layer="51"/>
<rectangle x1="3.556" y1="-3.0988" x2="4.064" y2="-1.9558" layer="51"/>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK300/3">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="7.5438" y1="6.223" x2="7.5438" y2="3.175" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="6.223" x2="-7.5438" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="6.223" x2="8.0518" y2="6.223" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="6.223" x2="8.0518" y2="1.397" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="1.397" x2="7.5438" y2="1.651" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-5.461" x2="7.5438" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="-5.207" x2="7.5438" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-3.81" x2="7.5438" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="-4.064" x2="7.5438" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-3.81" x2="8.0518" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-6.223" x2="-2.032" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.254" x2="2.032" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-6.223" x2="2.032" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-6.223" x2="2.9718" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-6.223" x2="-2.9718" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-6.223" x2="-2.032" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="0.254" x2="-7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="-6.223" x2="-7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="-6.223" x2="-2.9718" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.318" x2="2.032" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.318" x2="-2.032" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-4.318" x2="2.032" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-4.318" x2="-7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-4.318" x2="-2.9718" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="-4.318" x2="-7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-3.683" x2="1.651" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-3.683" x2="-1.651" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-3.683" x2="-1.651" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="-3.683" x2="-3.3528" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="-3.683" x2="-6.6548" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.6548" y1="-3.683" x2="-6.6548" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-6.6548" y1="-0.508" x2="-6.2738" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-3.3528" y1="-0.508" x2="-3.7338" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-0.508" x2="-1.27" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.508" x2="1.27" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-7.5438" y1="-6.223" x2="-7.5438" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="0.635" x2="-7.5438" y2="3.175" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="1.651" x2="7.5438" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="0.635" x2="7.5438" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="3.175" x2="7.5438" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="3.175" x2="-7.5438" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="3.175" x2="7.5438" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="3.429" x2="-2.032" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="5.969" x2="2.032" y2="5.969" width="0.1524" layer="21"/>
<wire x1="2.032" y1="5.969" x2="2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="2.032" y1="3.429" x2="-2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="3.429" x2="-2.9718" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="3.429" x2="-7.0358" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="3.429" x2="-7.0358" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="5.969" x2="-7.0358" y2="5.969" width="0.1524" layer="21"/>
<wire x1="1.4682" y1="4.0849" x2="1.5239" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-1.4732" y1="4.1656" x2="1.5146" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="-1.6256" y1="5.0038" x2="1.5288" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-1.5748" y1="5.0546" x2="-1.4311" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-1.6256" y1="4.445" x2="1.4224" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.4986" y1="4.318" x2="1.5494" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-3.5102" y1="4.0849" x2="-3.4545" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-6.4516" y1="4.1656" x2="-3.4638" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-6.604" y1="5.0038" x2="-3.4496" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-6.5532" y1="5.0546" x2="-6.4095" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-6.604" y1="4.445" x2="-3.556" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="4.318" x2="-3.429" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="0.254" x2="-6.6548" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="0.254" x2="-3.3528" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="0.254" x2="-6.6548" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-7.5438" y1="0.635" x2="-6.6548" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.6548" y1="0.635" x2="-3.3528" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-3.3528" y1="0.635" x2="-1.651" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="0.635" x2="6.6548" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="0.635" x2="-1.651" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.032" y1="0.254" x2="1.651" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.254" x2="-1.651" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.254" x2="1.651" y2="0.254" width="0.1524" layer="51"/>
<wire x1="6.6548" y1="0.635" x2="3.3782" y2="0.635" width="0.1524" layer="51"/>
<wire x1="1.6764" y1="0.635" x2="3.3528" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="-6.223" x2="7.5438" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="0.254" x2="7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="-4.318" x2="7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="0.254" x2="6.6548" y2="0.254" width="0.1524" layer="21"/>
<wire x1="3.3782" y1="0.254" x2="6.6548" y2="0.254" width="0.1524" layer="51"/>
<wire x1="2.9718" y1="0.254" x2="3.3782" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-6.223" x2="2.9718" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-6.223" x2="7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-4.318" x2="7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="6.6548" y1="-3.683" x2="3.3528" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="6.6548" y1="-3.683" x2="6.6548" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="6.6548" y1="-0.508" x2="6.2738" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="3.3528" y1="-0.508" x2="3.7084" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="3.3528" y1="-3.683" x2="3.3528" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="3.429" x2="2.9718" y2="5.969" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="5.969" x2="7.0358" y2="5.969" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="5.969" x2="7.0358" y2="3.429" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="3.429" x2="2.9718" y2="3.429" width="0.1524" layer="21"/>
<wire x1="6.472" y1="4.0849" x2="6.5277" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="3.5306" y1="4.1656" x2="6.5184" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="3.3782" y1="5.0038" x2="6.5324" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="3.429" y1="5.0546" x2="3.5727" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="3.3782" y1="4.445" x2="6.4262" y2="5.08" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="4.318" x2="6.5532" y2="4.953" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-4.318" x2="2.9718" y2="0.254" width="0.1524" layer="21"/>
<pad name="1" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-7.5692" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.5692" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.985" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="-1.905" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<text x="3.175" y="1.27" size="1.27" layer="21" ratio="10">3</text>
<rectangle x1="-6.2738" y1="-2.54" x2="-3.7338" y2="0.254" layer="51"/>
<rectangle x1="-1.27" y1="-2.54" x2="1.27" y2="0.254" layer="51"/>
<rectangle x1="3.7338" y1="-2.54" x2="6.2738" y2="0.254" layer="51"/>
</package>
<package name="AK300/2">
<wire x1="5.08" y1="6.223" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="5.588" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="6.223" x2="5.588" y2="1.397" width="0.1524" layer="21"/>
<wire x1="5.588" y1="1.397" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-5.461" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-5.207" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.064" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.588" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="0.4572" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="0.254" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-6.223" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="-0.4826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="0.4572" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-6.223" x2="-0.4826" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="0.4572" y2="0.254" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-4.318" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-0.4826" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-4.318" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="4.1402" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="0.8382" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="-3.683" x2="0.8382" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-0.8636" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-4.1656" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-3.683" x2="-4.1656" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-0.508" x2="-3.7846" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="-0.508" x2="-1.2446" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0.8382" y1="-0.508" x2="1.2192" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="4.1402" y1="-0.508" x2="3.7592" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-6.223" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.651" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.175" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="3.429" x2="0.4572" y2="5.969" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="5.969" x2="4.5212" y2="5.969" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="5.969" x2="4.5212" y2="3.429" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="3.429" x2="0.4572" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-0.4826" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-4.5466" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="3.429" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="5.969" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="3.9574" y1="4.0849" x2="4.0131" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="1.016" y1="4.1656" x2="4.0038" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="0.8636" y1="5.0038" x2="4.0178" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="0.9144" y1="5.0546" x2="1.0581" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="0.8636" y1="4.445" x2="3.9116" y2="5.08" width="0.1524" layer="21"/>
<wire x1="0.9906" y1="4.318" x2="4.0386" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-1.0464" y1="4.0849" x2="-0.9907" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-3.9878" y1="4.1656" x2="-1" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-4.1402" y1="5.0038" x2="-0.9858" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-4.0894" y1="5.0546" x2="-3.9457" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-4.1402" y1="4.445" x2="-1.0922" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="4.318" x2="-0.9652" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="0.254" x2="-0.8636" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="0.635" x2="-4.1656" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="0.635" x2="-0.8636" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="4.1402" y2="0.635" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="51"/>
<wire x1="4.5212" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="0.254" x2="0.8382" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.4958" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="0.5842" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-3.7846" y1="-2.54" x2="-1.2446" y2="0.254" layer="51"/>
<rectangle x1="1.2192" y1="-2.54" x2="3.7592" y2="0.254" layer="51"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="12mil"/>
<param name="mdWirePad" value="12mil"/>
<param name="mdWireVia" value="12mil"/>
<param name="mdPadPad" value="12mil"/>
<param name="mdPadVia" value="12mil"/>
<param name="mdViaVia" value="12mil"/>
<param name="mdSmdPad" value="12mil"/>
<param name="mdSmdVia" value="12mil"/>
<param name="mdSmdSmd" value="12mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="25mil"/>
<param name="tpViaShape" value="octagon"/>
<param name="PrefDir.1" value="*"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="0"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="R11" library="resistor" package="M1206" value="10k" x="73.025" y="62.23" rot="R270"/>
<element name="R12" library="resistor" package="M1206" value="10k" x="77.47" y="62.23" rot="R270"/>
<element name="R15" library="resistor" package="M1206" value="9,1k" x="92.71" y="57.15" rot="R270"/>
<element name="R14" library="resistor" package="M1206" value="820" x="90.805" y="68.58"/>
<element name="R13" library="resistor" package="M1206" value="1M" x="74.93" y="69.215" rot="R270"/>
<element name="R19" library="resistor" package="M1206" value="1k" x="102.87" y="57.15" rot="R90"/>
<element name="IC11" library="linear" package="SO08" value="LM2903D" x="84.455" y="62.23" rot="R270"/>
<element name="Q1" library="transistor" package="SOT23" value="BC846" x="103.505" y="63.5" rot="R270"/>
<element name="B1" library="rectifier" package="DFS" value="DF06S" x="127.635" y="83.185" rot="R270"/>
<element name="C1" library="rcl" package="PANASONIC_G" value="" x="113.665" y="82.55" rot="R90"/>
<element name="C2" library="resistor" package="C1206K" value="" x="73.66" y="74.93" rot="R180"/>
<element name="C3" library="rcl" package="PANASONIC_D" value="" x="81.915" y="77.47" rot="R270"/>
<element name="C4" library="resistor" package="C1206K" value="" x="73.66" y="78.105" rot="R180"/>
<element name="K12" library="relay" package="RR1U" value="RR1U" x="118.745" y="68.58" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="95.885" y="109.22" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="95.885" y="109.22" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="95.885" y="109.22" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="95.885" y="109.22" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="R16" library="resistor" package="M1206" value="10k" x="97.79" y="57.15" rot="R90"/>
<element name="R17" library="resistor" package="M1206" value="10k" x="80.645" y="69.215" rot="R90"/>
<element name="R18" library="resistor" package="M1206" value="10k" x="95.25" y="63.5"/>
<element name="K11" library="relay" package="RR2A" value="RR2A" x="118.745" y="52.705" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="75.565" y="80.645" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="75.565" y="80.645" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="75.565" y="80.645" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="75.565" y="80.645" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="R21" library="resistor" package="M1206" value="10k" x="73.025" y="31.115" rot="R90"/>
<element name="R22" library="resistor" package="M1206" value="10k" x="77.47" y="31.115" rot="R90"/>
<element name="R25" library="resistor" package="M1206" value="9,1k" x="95.25" y="30.48"/>
<element name="R24" library="resistor" package="M1206" value="820" x="90.805" y="25.4"/>
<element name="R23" library="resistor" package="M1206" value="1M" x="80.645" y="24.13" rot="R90"/>
<element name="R29" library="resistor" package="M1206" value="1k" x="102.87" y="36.83" rot="R270"/>
<element name="IC22" library="linear" package="SO08" value="LM2903D" x="84.455" y="31.115" rot="R270"/>
<element name="Q2" library="transistor" package="SOT23" value="BC846" x="103.505" y="29.845" rot="R270"/>
<element name="K22" library="relay" package="RR1U" value="RR1U" x="118.745" y="19.685" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="79.375" y="26.035" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="79.375" y="26.035" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="79.375" y="26.035" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="79.375" y="26.035" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="R26" library="resistor" package="M1206" value="10k" x="97.79" y="36.83" rot="R270"/>
<element name="R27" library="resistor" package="M1206" value="10k" x="74.93" y="24.13" rot="R270"/>
<element name="R28" library="resistor" package="M1206" value="10k" x="92.71" y="36.83" rot="R270"/>
<element name="K21" library="relay" package="RR2A" value="RR2A" x="118.745" y="35.56" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="95.885" y="63.5" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="95.885" y="63.5" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="95.885" y="63.5" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="95.885" y="63.5" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="IC1222" library="74xx-eu" package="SO14" value="74AC02D" x="96.52" y="46.355" rot="R180"/>
<element name="IC3" library="linear" package="TO220H" value="7805T" x="98.425" y="81.915" rot="R270"/>
<element name="X1" library="con-ptr500" package="AK300/3" value="" x="144.145" y="22.225" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="144.145" y="22.225" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="144.145" y="22.225" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="144.145" y="22.225" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="144.145" y="22.225" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="X2" library="con-ptr500" package="AK300/3" value="" x="144.145" y="66.04" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="144.145" y="66.04" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="144.145" y="66.04" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="144.145" y="66.04" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="144.145" y="66.04" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="X3" library="con-ptr500" package="AK300/2" value="" x="144.145" y="36.195" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="144.145" y="36.195" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="144.145" y="36.195" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="144.145" y="36.195" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="144.145" y="36.195" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="X4" library="con-ptr500" package="AK300/2" value="" x="144.145" y="52.07" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="144.145" y="52.07" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="144.145" y="52.07" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="144.145" y="52.07" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="144.145" y="52.07" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="X5" library="con-ptr500" package="AK300/2" value="" x="79.375" y="52.705" rot="R270">
<attribute name="OC_NEWARK" value="unknown" x="79.375" y="52.705" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="79.375" y="52.705" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="79.375" y="52.705" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="79.375" y="52.705" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="X6" library="con-ptr500" package="AK300/2" value="" x="79.375" y="41.275" rot="R270">
<attribute name="OC_NEWARK" value="unknown" x="79.375" y="41.275" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="79.375" y="41.275" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="79.375" y="41.275" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="79.375" y="41.275" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="X7" library="con-ptr500" package="AK300/2" value="" x="144.145" y="84.455" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="144.145" y="84.455" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="144.145" y="84.455" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="144.145" y="84.455" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="144.145" y="84.455" size="1.778" layer="27" rot="R90" display="off"/>
</element>
</elements>
<signals>
<signal name="V+">
<contactref element="IC11" pad="8"/>
<contactref element="IC22" pad="8"/>
<wire x1="87.055" y1="33.02" x2="87.055" y2="64.135" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="V-">
<contactref element="IC11" pad="4"/>
<contactref element="IC22" pad="4"/>
<wire x1="81.855" y1="29.21" x2="81.855" y2="60.325" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="GND">
<contactref element="IC1222" pad="7"/>
</signal>
<signal name="VCC">
<contactref element="IC1222" pad="14"/>
</signal>
<signal name="N$1">
<contactref element="R11" pad="1"/>
<contactref element="R12" pad="1"/>
<contactref element="IC11" pad="3"/>
<contactref element="IC11" pad="6"/>
<wire x1="77.47" y1="63.5" x2="73.025" y2="63.5" width="0.254" layer="1"/>
<wire x1="73.025" y1="63.5" x2="73.025" y2="63.63" width="0.254" layer="1"/>
<wire x1="87.055" y1="61.595" x2="81.855" y2="61.595" width="0.254" layer="1"/>
<wire x1="78.74" y1="63.5" x2="77.47" y2="63.5" width="0.254" layer="1"/>
<wire x1="80.645" y1="61.595" x2="78.74" y2="63.5" width="0.254" layer="1"/>
<wire x1="81.855" y1="61.595" x2="80.645" y2="61.595" width="0.254" layer="1"/>
<wire x1="77.47" y1="63.5" x2="77.47" y2="63.63" width="0.254" layer="1"/>
</signal>
<signal name="GNDA">
<contactref element="Q1" pad="2"/>
<contactref element="C1" pad="-"/>
<contactref element="C2" pad="2"/>
<contactref element="C4" pad="2"/>
<contactref element="C3" pad="-"/>
<contactref element="IC3" pad="2"/>
<contactref element="B1" pad="-"/>
<contactref element="R16" pad="2"/>
<contactref element="Q2" pad="2"/>
<contactref element="R26" pad="2"/>
<wire x1="72.39" y1="78.105" x2="72.39" y2="74.93" width="0.254" layer="1"/>
<wire x1="72.39" y1="74.93" x2="72.16" y2="74.93" width="0.254" layer="1"/>
<wire x1="74.295" y1="80.01" x2="81.915" y2="80.01" width="0.254" layer="1"/>
<wire x1="72.39" y1="78.105" x2="74.295" y2="80.01" width="0.254" layer="1"/>
<wire x1="72.39" y1="78.105" x2="72.16" y2="78.105" width="0.254" layer="1"/>
<wire x1="83.82" y1="81.915" x2="85.725" y2="81.915" width="0.254" layer="1"/>
<wire x1="85.725" y1="81.915" x2="88.265" y2="81.915" width="0.254" layer="1"/>
<wire x1="81.915" y1="80.01" x2="83.82" y2="81.915" width="0.254" layer="1"/>
<wire x1="81.915" y1="80.01" x2="81.915" y2="79.87" width="0.254" layer="1"/>
<wire x1="101.6" y1="29.21" x2="102.235" y2="29.21" width="0.254" layer="1"/>
<wire x1="97.79" y1="33.02" x2="101.6" y2="29.21" width="0.254" layer="1"/>
<wire x1="97.79" y1="35.43" x2="97.79" y2="33.02" width="0.254" layer="1"/>
<wire x1="102.235" y1="29.21" x2="102.405" y2="28.895" width="0.254" layer="1"/>
<wire x1="100.965" y1="62.23" x2="102.235" y2="62.23" width="0.254" layer="1"/>
<wire x1="97.79" y1="59.055" x2="100.965" y2="62.23" width="0.254" layer="1"/>
<wire x1="102.235" y1="62.23" x2="102.405" y2="62.55" width="0.254" layer="1"/>
<wire x1="97.79" y1="59.055" x2="97.79" y2="58.55" width="0.254" layer="1"/>
<wire x1="114.935" y1="80.01" x2="122.555" y2="80.01" width="0.254" layer="1"/>
<wire x1="113.665" y1="78.74" x2="114.935" y2="80.01" width="0.254" layer="1"/>
<wire x1="122.555" y1="80.01" x2="123.135" y2="80.635" width="0.254" layer="1"/>
<wire x1="113.665" y1="78.74" x2="113.665" y2="78.3" width="0.254" layer="1"/>
<wire x1="100.33" y1="62.865" x2="100.965" y2="62.23" width="0.254" layer="1"/>
<wire x1="100.33" y1="66.04" x2="100.33" y2="62.865" width="0.254" layer="1"/>
<wire x1="112.395" y1="78.105" x2="105.41" y2="71.12" width="0.254" layer="1"/>
<wire x1="105.41" y1="71.12" x2="100.33" y2="66.04" width="0.254" layer="1"/>
<wire x1="113.665" y1="78.105" x2="112.395" y2="78.105" width="0.254" layer="1"/>
<wire x1="113.665" y1="78.105" x2="113.665" y2="78.3" width="0.254" layer="1"/>
<wire x1="111.125" y1="20.32" x2="102.87" y2="28.575" width="0.254" layer="1"/>
<wire x1="145.415" y1="20.32" x2="111.125" y2="20.32" width="0.254" layer="1"/>
<wire x1="147.32" y1="22.225" x2="145.415" y2="20.32" width="0.254" layer="1"/>
<wire x1="147.32" y1="71.12" x2="147.32" y2="22.225" width="0.254" layer="1"/>
<wire x1="139.065" y1="79.375" x2="147.32" y2="71.12" width="0.254" layer="1"/>
<wire x1="123.825" y1="79.375" x2="139.065" y2="79.375" width="0.254" layer="1"/>
<wire x1="123.19" y1="80.01" x2="123.825" y2="79.375" width="0.254" layer="1"/>
<wire x1="102.87" y1="28.575" x2="102.405" y2="28.895" width="0.254" layer="1"/>
<wire x1="123.19" y1="80.01" x2="123.135" y2="80.635" width="0.254" layer="1"/>
<wire x1="85.725" y1="85.09" x2="85.725" y2="81.915" width="0.254" layer="1"/>
<wire x1="86.36" y1="85.725" x2="85.725" y2="85.09" width="0.254" layer="1"/>
<wire x1="90.805" y1="85.725" x2="86.36" y2="85.725" width="0.254" layer="1"/>
<wire x1="105.41" y1="71.12" x2="90.805" y2="85.725" width="0.254" layer="1"/>
</signal>
<signal name="N$2">
<contactref element="R13" pad="2"/>
<contactref element="IC11" pad="2"/>
<contactref element="R14" pad="1"/>
<wire x1="78.105" y1="67.945" x2="74.93" y2="67.945" width="0.254" layer="1"/>
<wire x1="79.375" y1="69.215" x2="78.105" y2="67.945" width="0.254" layer="1"/>
<wire x1="88.265" y1="69.215" x2="79.375" y2="69.215" width="0.254" layer="1"/>
<wire x1="88.9" y1="68.58" x2="88.265" y2="69.215" width="0.254" layer="1"/>
<wire x1="74.93" y1="67.945" x2="74.93" y2="67.815" width="0.254" layer="1"/>
<wire x1="83.185" y1="62.865" x2="81.855" y2="62.865" width="0.254" layer="1"/>
<wire x1="88.9" y1="68.58" x2="83.185" y2="62.865" width="0.254" layer="1"/>
<wire x1="88.9" y1="68.58" x2="89.405" y2="68.58" width="0.254" layer="1"/>
</signal>
<signal name="N$4">
<contactref element="IC11" pad="5"/>
<contactref element="R14" pad="2"/>
<contactref element="R15" pad="1"/>
<wire x1="92.075" y1="59.69" x2="92.075" y2="60.325" width="0.254" layer="1"/>
<wire x1="92.075" y1="60.325" x2="92.075" y2="68.58" width="0.254" layer="1"/>
<wire x1="92.71" y1="59.055" x2="92.075" y2="59.69" width="0.254" layer="1"/>
<wire x1="92.075" y1="68.58" x2="92.205" y2="68.58" width="0.254" layer="1"/>
<wire x1="92.71" y1="59.055" x2="92.71" y2="58.55" width="0.254" layer="1"/>
<wire x1="92.075" y1="60.325" x2="87.055" y2="60.325" width="0.254" layer="1"/>
</signal>
<signal name="N$6">
<contactref element="IC1222" pad="3"/>
<contactref element="IC1222" pad="4"/>
<wire x1="97.79" y1="49.53" x2="96.52" y2="49.53" width="0.254" layer="1"/>
<wire x1="96.52" y1="49.53" x2="96.52" y2="49.4284" width="0.254" layer="1"/>
<wire x1="97.79" y1="49.53" x2="97.79" y2="49.4284" width="0.254" layer="1"/>
</signal>
<signal name="N$7">
<contactref element="R17" pad="1"/>
<contactref element="IC11" pad="1"/>
<contactref element="IC1222" pad="2"/>
<wire x1="80.645" y1="64.77" x2="80.645" y2="65.405" width="0.254" layer="1"/>
<wire x1="80.645" y1="65.405" x2="80.645" y2="67.815" width="0.254" layer="1"/>
<wire x1="81.28" y1="64.135" x2="80.645" y2="64.77" width="0.254" layer="1"/>
<wire x1="81.28" y1="64.135" x2="81.855" y2="64.135" width="0.254" layer="1"/>
<wire x1="99.06" y1="48.26" x2="99.06" y2="49.4284" width="0.254" layer="1"/>
<wire x1="98.425" y1="47.625" x2="99.06" y2="48.26" width="0.254" layer="1"/>
<wire x1="78.74" y1="47.625" x2="98.425" y2="47.625" width="0.254" layer="1"/>
<wire x1="71.12" y1="55.245" x2="78.74" y2="47.625" width="0.254" layer="1"/>
<wire x1="71.12" y1="64.77" x2="71.12" y2="55.245" width="0.254" layer="1"/>
<wire x1="71.755" y1="65.405" x2="71.12" y2="64.77" width="0.254" layer="1"/>
<wire x1="80.645" y1="65.405" x2="71.755" y2="65.405" width="0.254" layer="1"/>
</signal>
<signal name="N$8">
<contactref element="IC11" pad="7"/>
<contactref element="R18" pad="1"/>
<contactref element="IC1222" pad="6"/>
<wire x1="93.98" y1="69.85" x2="93.98" y2="63.5" width="0.254" layer="1"/>
<wire x1="93.345" y1="70.485" x2="93.98" y2="69.85" width="0.254" layer="1"/>
<wire x1="91.44" y1="70.485" x2="93.345" y2="70.485" width="0.254" layer="1"/>
<wire x1="90.805" y1="69.85" x2="91.44" y2="70.485" width="0.254" layer="1"/>
<wire x1="90.805" y1="65.405" x2="90.805" y2="69.85" width="0.254" layer="1"/>
<wire x1="88.265" y1="62.865" x2="90.805" y2="65.405" width="0.254" layer="1"/>
<wire x1="87.055" y1="62.865" x2="88.265" y2="62.865" width="0.254" layer="1"/>
<wire x1="93.98" y1="51.435" x2="93.98" y2="49.4284" width="0.254" layer="1"/>
<wire x1="90.805" y1="54.61" x2="93.98" y2="51.435" width="0.254" layer="1"/>
<wire x1="90.805" y1="56.515" x2="90.805" y2="54.61" width="0.254" layer="1"/>
<wire x1="91.44" y1="57.15" x2="90.805" y2="56.515" width="0.254" layer="1"/>
<wire x1="93.98" y1="57.15" x2="91.44" y2="57.15" width="0.254" layer="1"/>
<wire x1="94.615" y1="57.785" x2="93.98" y2="57.15" width="0.254" layer="1"/>
<wire x1="94.615" y1="62.865" x2="94.615" y2="57.785" width="0.254" layer="1"/>
<wire x1="93.98" y1="63.5" x2="94.615" y2="62.865" width="0.254" layer="1"/>
<wire x1="93.98" y1="63.5" x2="93.85" y2="63.5" width="0.254" layer="1"/>
</signal>
<signal name="N$9">
<contactref element="R19" pad="1"/>
<contactref element="IC1222" pad="1"/>
<contactref element="IC1222" pad="5"/>
<wire x1="102.87" y1="52.07" x2="102.87" y2="55.75" width="0.254" layer="1"/>
<wire x1="100.33" y1="49.53" x2="102.235" y2="51.435" width="0.254" layer="1"/>
<wire x1="102.235" y1="51.435" x2="102.87" y2="52.07" width="0.254" layer="1"/>
<wire x1="100.33" y1="49.53" x2="100.33" y2="49.4284" width="0.254" layer="1"/>
<wire x1="95.25" y1="50.165" x2="95.25" y2="49.4284" width="0.254" layer="1"/>
<wire x1="96.52" y1="51.435" x2="95.25" y2="50.165" width="0.254" layer="1"/>
<wire x1="102.235" y1="51.435" x2="96.52" y2="51.435" width="0.254" layer="1"/>
</signal>
<signal name="N$12">
<contactref element="Q1" pad="3"/>
<contactref element="K12" pad="6"/>
<contactref element="K11" pad="6"/>
<wire x1="100.965" y1="63.5" x2="104.605" y2="63.5" width="0.254" layer="1"/>
<wire x1="100.965" y1="65.405" x2="100.965" y2="63.5" width="0.254" layer="1"/>
<wire x1="106.045" y1="70.485" x2="103.505" y2="67.945" width="0.254" layer="1"/>
<wire x1="103.505" y1="67.945" x2="100.965" y2="65.405" width="0.254" layer="1"/>
<wire x1="111.76" y1="70.485" x2="106.045" y2="70.485" width="0.254" layer="1"/>
<wire x1="113.665" y1="72.39" x2="111.76" y2="70.485" width="0.254" layer="1"/>
<wire x1="113.665" y1="57.785" x2="113.665" y2="56.515" width="0.254" layer="1"/>
<wire x1="103.505" y1="67.945" x2="113.665" y2="57.785" width="0.254" layer="1"/>
</signal>
<signal name="N$5">
<contactref element="R15" pad="2"/>
<contactref element="R16" pad="1"/>
<wire x1="97.79" y1="55.88" x2="92.71" y2="55.88" width="0.254" layer="1"/>
<wire x1="92.71" y1="55.88" x2="92.71" y2="55.75" width="0.254" layer="1"/>
<wire x1="97.79" y1="55.88" x2="97.79" y2="55.75" width="0.254" layer="1"/>
</signal>
<signal name="N$36">
<contactref element="B1" pad="+"/>
<contactref element="C1" pad="+"/>
<contactref element="C4" pad="1"/>
<contactref element="IC3" pad="1"/>
<wire x1="113.665" y1="86.36" x2="122.555" y2="86.36" width="0.254" layer="1"/>
<wire x1="122.555" y1="86.36" x2="123.135" y2="85.735" width="0.254" layer="1"/>
<wire x1="80.645" y1="78.105" x2="75.16" y2="78.105" width="0.254" layer="1"/>
<wire x1="81.28" y1="77.47" x2="80.645" y2="78.105" width="0.254" layer="1"/>
<wire x1="83.185" y1="77.47" x2="81.28" y2="77.47" width="0.254" layer="1"/>
<wire x1="86.36" y1="80.645" x2="83.185" y2="77.47" width="0.254" layer="1"/>
<wire x1="90.17" y1="80.645" x2="86.36" y2="80.645" width="0.254" layer="1"/>
<wire x1="90.805" y1="81.28" x2="90.17" y2="80.645" width="0.254" layer="1"/>
<wire x1="90.805" y1="82.55" x2="90.805" y2="81.28" width="0.254" layer="1"/>
<wire x1="88.9" y1="84.455" x2="90.805" y2="82.55" width="0.254" layer="1"/>
<wire x1="88.265" y1="84.455" x2="88.9" y2="84.455" width="0.254" layer="1"/>
<wire x1="77.47" y1="86.36" x2="113.665" y2="86.36" width="0.254" layer="1"/>
<wire x1="70.485" y1="79.375" x2="77.47" y2="86.36" width="0.254" layer="1"/>
<wire x1="70.485" y1="73.66" x2="70.485" y2="79.375" width="0.254" layer="1"/>
<wire x1="71.12" y1="73.025" x2="70.485" y2="73.66" width="0.254" layer="1"/>
<wire x1="73.025" y1="73.025" x2="71.12" y2="73.025" width="0.254" layer="1"/>
<wire x1="73.66" y1="73.66" x2="73.025" y2="73.025" width="0.254" layer="1"/>
<wire x1="73.66" y1="76.835" x2="73.66" y2="73.66" width="0.254" layer="1"/>
<wire x1="74.93" y1="78.105" x2="73.66" y2="76.835" width="0.254" layer="1"/>
<wire x1="113.665" y1="86.36" x2="113.665" y2="86.8" width="0.254" layer="1"/>
<wire x1="74.93" y1="78.105" x2="75.16" y2="78.105" width="0.254" layer="1"/>
</signal>
<signal name="N$3">
<contactref element="R19" pad="2"/>
<contactref element="Q1" pad="1"/>
<wire x1="105.41" y1="64.77" x2="102.87" y2="64.77" width="0.254" layer="1"/>
<wire x1="106.045" y1="64.135" x2="105.41" y2="64.77" width="0.254" layer="1"/>
<wire x1="106.045" y1="62.23" x2="106.045" y2="64.135" width="0.254" layer="1"/>
<wire x1="102.87" y1="59.055" x2="106.045" y2="62.23" width="0.254" layer="1"/>
<wire x1="102.87" y1="64.77" x2="102.405" y2="64.45" width="0.254" layer="1"/>
<wire x1="102.87" y1="59.055" x2="102.87" y2="58.55" width="0.254" layer="1"/>
</signal>
<signal name="N$10">
<contactref element="R21" pad="1"/>
<contactref element="R22" pad="1"/>
<contactref element="IC22" pad="3"/>
<contactref element="IC22" pad="6"/>
<wire x1="77.47" y1="29.845" x2="73.025" y2="29.845" width="0.254" layer="1"/>
<wire x1="73.025" y1="29.845" x2="73.025" y2="29.715" width="0.254" layer="1"/>
<wire x1="87.055" y1="30.48" x2="81.855" y2="30.48" width="0.254" layer="1"/>
<wire x1="80.01" y1="29.845" x2="77.47" y2="29.845" width="0.254" layer="1"/>
<wire x1="80.645" y1="30.48" x2="80.01" y2="29.845" width="0.254" layer="1"/>
<wire x1="81.855" y1="30.48" x2="80.645" y2="30.48" width="0.254" layer="1"/>
<wire x1="77.47" y1="29.845" x2="77.47" y2="29.715" width="0.254" layer="1"/>
</signal>
<signal name="N$11">
<contactref element="R23" pad="2"/>
<contactref element="IC22" pad="2"/>
<contactref element="R24" pad="1"/>
<wire x1="89.405" y1="25.4" x2="80.645" y2="25.4" width="0.254" layer="1"/>
<wire x1="80.645" y1="25.4" x2="80.645" y2="25.53" width="0.254" layer="1"/>
<wire x1="79.375" y1="31.75" x2="81.855" y2="31.75" width="0.254" layer="1"/>
<wire x1="78.74" y1="31.115" x2="79.375" y2="31.75" width="0.254" layer="1"/>
<wire x1="71.755" y1="31.115" x2="78.74" y2="31.115" width="0.254" layer="1"/>
<wire x1="71.12" y1="30.48" x2="71.755" y2="31.115" width="0.254" layer="1"/>
<wire x1="71.12" y1="28.575" x2="71.12" y2="30.48" width="0.254" layer="1"/>
<wire x1="72.39" y1="27.305" x2="71.12" y2="28.575" width="0.254" layer="1"/>
<wire x1="79.375" y1="27.305" x2="72.39" y2="27.305" width="0.254" layer="1"/>
<wire x1="80.645" y1="26.035" x2="79.375" y2="27.305" width="0.254" layer="1"/>
<wire x1="80.645" y1="26.035" x2="80.645" y2="25.53" width="0.254" layer="1"/>
</signal>
<signal name="N$13">
<contactref element="IC22" pad="5"/>
<contactref element="R24" pad="2"/>
<contactref element="R25" pad="1"/>
<wire x1="92.71" y1="29.845" x2="92.71" y2="25.4" width="0.254" layer="1"/>
<wire x1="93.345" y1="30.48" x2="92.71" y2="29.845" width="0.254" layer="1"/>
<wire x1="92.71" y1="25.4" x2="92.205" y2="25.4" width="0.254" layer="1"/>
<wire x1="93.345" y1="30.48" x2="93.85" y2="30.48" width="0.254" layer="1"/>
<wire x1="88.265" y1="29.21" x2="87.055" y2="29.21" width="0.254" layer="1"/>
<wire x1="90.805" y1="31.75" x2="88.265" y2="29.21" width="0.254" layer="1"/>
<wire x1="90.805" y1="36.195" x2="90.805" y2="31.75" width="0.254" layer="1"/>
<wire x1="91.44" y1="36.83" x2="90.805" y2="36.195" width="0.254" layer="1"/>
<wire x1="93.98" y1="36.83" x2="91.44" y2="36.83" width="0.254" layer="1"/>
<wire x1="94.615" y1="36.195" x2="93.98" y2="36.83" width="0.254" layer="1"/>
<wire x1="94.615" y1="31.115" x2="94.615" y2="36.195" width="0.254" layer="1"/>
<wire x1="93.98" y1="30.48" x2="94.615" y2="31.115" width="0.254" layer="1"/>
<wire x1="93.98" y1="30.48" x2="93.85" y2="30.48" width="0.254" layer="1"/>
</signal>
<signal name="N$14">
<contactref element="IC1222" pad="9"/>
<contactref element="IC1222" pad="13"/>
<wire x1="93.98" y1="44.45" x2="93.98" y2="43.2816" width="0.254" layer="1"/>
<wire x1="95.25" y1="45.72" x2="93.98" y2="44.45" width="0.254" layer="1"/>
<wire x1="101.6" y1="45.72" x2="95.25" y2="45.72" width="0.254" layer="1"/>
<wire x1="104.775" y1="42.545" x2="101.6" y2="45.72" width="0.254" layer="1"/>
<wire x1="104.775" y1="37.465" x2="104.775" y2="42.545" width="0.254" layer="1"/>
<wire x1="104.14" y1="36.83" x2="104.775" y2="37.465" width="0.254" layer="1"/>
<wire x1="101.6" y1="36.83" x2="104.14" y2="36.83" width="0.254" layer="1"/>
<wire x1="99.695" y1="38.735" x2="101.6" y2="36.83" width="0.254" layer="1"/>
<wire x1="99.695" y1="41.91" x2="99.695" y2="38.735" width="0.254" layer="1"/>
<wire x1="99.06" y1="42.545" x2="99.695" y2="41.91" width="0.254" layer="1"/>
<wire x1="99.06" y1="43.2816" x2="99.06" y2="42.545" width="0.254" layer="1"/>
</signal>
<signal name="N$15">
<contactref element="R27" pad="1"/>
<contactref element="IC22" pad="1"/>
<contactref element="IC1222" pad="8"/>
<wire x1="72.39" y1="26.035" x2="74.93" y2="26.035" width="0.254" layer="1"/>
<wire x1="70.485" y1="27.94" x2="72.39" y2="26.035" width="0.254" layer="1"/>
<wire x1="70.485" y1="38.1" x2="70.485" y2="27.94" width="0.254" layer="1"/>
<wire x1="78.105" y1="45.72" x2="70.485" y2="38.1" width="0.254" layer="1"/>
<wire x1="90.805" y1="45.72" x2="81.915" y2="45.72" width="0.254" layer="1"/>
<wire x1="81.915" y1="45.72" x2="78.105" y2="45.72" width="0.254" layer="1"/>
<wire x1="92.71" y1="43.815" x2="90.805" y2="45.72" width="0.254" layer="1"/>
<wire x1="74.93" y1="26.035" x2="74.93" y2="25.53" width="0.254" layer="1"/>
<wire x1="92.71" y1="43.815" x2="92.71" y2="43.2816" width="0.254" layer="1"/>
<wire x1="81.915" y1="45.72" x2="81.915" y2="33.02" width="0.254" layer="1"/>
<wire x1="81.915" y1="33.02" x2="81.855" y2="33.02" width="0.254" layer="1"/>
</signal>
<signal name="N$16">
<contactref element="IC22" pad="7"/>
<contactref element="R28" pad="1"/>
<contactref element="IC1222" pad="12"/>
<wire x1="93.98" y1="38.735" x2="92.71" y2="38.735" width="0.254" layer="1"/>
<wire x1="97.79" y1="42.545" x2="93.98" y2="38.735" width="0.254" layer="1"/>
<wire x1="97.79" y1="43.2816" x2="97.79" y2="42.545" width="0.254" layer="1"/>
<wire x1="92.71" y1="38.735" x2="92.71" y2="38.23" width="0.254" layer="1"/>
<wire x1="88.265" y1="31.75" x2="87.055" y2="31.75" width="0.254" layer="1"/>
<wire x1="90.17" y1="33.655" x2="88.265" y2="31.75" width="0.254" layer="1"/>
<wire x1="90.17" y1="36.83" x2="90.17" y2="33.655" width="0.254" layer="1"/>
<wire x1="91.44" y1="38.1" x2="90.17" y2="36.83" width="0.254" layer="1"/>
<wire x1="92.71" y1="38.1" x2="91.44" y2="38.1" width="0.254" layer="1"/>
<wire x1="92.71" y1="38.1" x2="92.71" y2="38.23" width="0.254" layer="1"/>
</signal>
<signal name="N$19">
<contactref element="R29" pad="1"/>
<contactref element="IC1222" pad="10"/>
<contactref element="IC1222" pad="11"/>
<wire x1="102.87" y1="43.18" x2="102.87" y2="38.23" width="0.254" layer="1"/>
<wire x1="100.965" y1="45.085" x2="102.87" y2="43.18" width="0.254" layer="1"/>
<wire x1="96.52" y1="45.085" x2="100.965" y2="45.085" width="0.254" layer="1"/>
<wire x1="95.25" y1="43.815" x2="95.885" y2="44.45" width="0.254" layer="1"/>
<wire x1="95.885" y1="44.45" x2="96.52" y2="45.085" width="0.254" layer="1"/>
<wire x1="95.25" y1="43.815" x2="95.25" y2="43.2816" width="0.254" layer="1"/>
<wire x1="95.885" y1="44.45" x2="96.52" y2="43.815" width="0.254" layer="1"/>
<wire x1="96.52" y1="43.815" x2="96.52" y2="43.2816" width="0.254" layer="1"/>
</signal>
<signal name="N$20">
<contactref element="Q2" pad="3"/>
<contactref element="K22" pad="6"/>
<contactref element="K21" pad="6"/>
<wire x1="107.315" y1="29.845" x2="104.605" y2="29.845" width="0.254" layer="1"/>
<wire x1="113.665" y1="23.495" x2="107.315" y2="29.845" width="0.254" layer="1"/>
<wire x1="104.14" y1="29.845" x2="113.665" y2="39.37" width="0.254" layer="1"/>
<wire x1="104.14" y1="29.845" x2="104.605" y2="29.845" width="0.254" layer="1"/>
</signal>
<signal name="N$22">
<contactref element="R25" pad="2"/>
<contactref element="R26" pad="1"/>
<wire x1="96.52" y1="33.655" x2="96.52" y2="30.48" width="0.254" layer="1"/>
<wire x1="95.885" y1="34.29" x2="96.52" y2="33.655" width="0.254" layer="1"/>
<wire x1="95.885" y1="36.195" x2="95.885" y2="34.29" width="0.254" layer="1"/>
<wire x1="97.79" y1="38.1" x2="95.885" y2="36.195" width="0.254" layer="1"/>
<wire x1="96.52" y1="30.48" x2="96.65" y2="30.48" width="0.254" layer="1"/>
<wire x1="97.79" y1="38.1" x2="97.79" y2="38.23" width="0.254" layer="1"/>
</signal>
<signal name="N$23">
<contactref element="R29" pad="2"/>
<contactref element="Q2" pad="1"/>
<wire x1="102.87" y1="35.43" x2="102.87" y2="31.115" width="0.254" layer="1"/>
<wire x1="102.87" y1="31.115" x2="102.405" y2="30.795" width="0.254" layer="1"/>
</signal>
<signal name="15V">
<contactref element="R13" pad="1"/>
<contactref element="C2" pad="1"/>
<contactref element="C3" pad="+"/>
<contactref element="K12" pad="2"/>
<contactref element="R17" pad="2"/>
<contactref element="R18" pad="2"/>
<contactref element="K11" pad="2"/>
<contactref element="K22" pad="2"/>
<contactref element="R23" pad="1"/>
<contactref element="R28" pad="2"/>
<contactref element="R27" pad="2"/>
<contactref element="K21" pad="2"/>
<contactref element="IC3" pad="3"/>
<wire x1="80.645" y1="22.86" x2="74.93" y2="22.86" width="0.254" layer="1"/>
<wire x1="92.71" y1="32.385" x2="92.71" y2="35.43" width="0.254" layer="1"/>
<wire x1="90.805" y1="30.48" x2="92.71" y2="32.385" width="0.254" layer="1"/>
<wire x1="90.805" y1="24.13" x2="90.805" y2="30.48" width="0.254" layer="1"/>
<wire x1="89.535" y1="22.86" x2="90.805" y2="24.13" width="0.254" layer="1"/>
<wire x1="80.645" y1="22.86" x2="89.535" y2="22.86" width="0.254" layer="1"/>
<wire x1="80.645" y1="22.86" x2="80.645" y2="22.73" width="0.254" layer="1"/>
<wire x1="123.825" y1="62.23" x2="123.825" y2="56.515" width="0.254" layer="1"/>
<wire x1="122.555" y1="63.5" x2="123.825" y2="62.23" width="0.254" layer="1"/>
<wire x1="122.555" y1="71.12" x2="122.555" y2="63.5" width="0.254" layer="1"/>
<wire x1="123.825" y1="72.39" x2="122.555" y2="71.12" width="0.254" layer="1"/>
<wire x1="123.825" y1="29.21" x2="123.825" y2="23.495" width="0.254" layer="1"/>
<wire x1="122.555" y1="30.48" x2="123.825" y2="29.21" width="0.254" layer="1"/>
<wire x1="122.555" y1="38.1" x2="122.555" y2="30.48" width="0.254" layer="1"/>
<wire x1="123.825" y1="39.37" x2="122.555" y2="38.1" width="0.254" layer="1"/>
<wire x1="74.93" y1="74.93" x2="74.93" y2="70.615" width="0.254" layer="1"/>
<wire x1="74.93" y1="74.93" x2="75.16" y2="74.93" width="0.254" layer="1"/>
<wire x1="74.93" y1="70.485" x2="80.645" y2="70.485" width="0.254" layer="1"/>
<wire x1="80.645" y1="70.485" x2="80.645" y2="70.615" width="0.254" layer="1"/>
<wire x1="75.16" y1="74.93" x2="81.915" y2="74.93" width="0.254" layer="1"/>
<wire x1="81.915" y1="74.93" x2="81.915" y2="75.07" width="0.254" layer="1"/>
<wire x1="96.52" y1="71.12" x2="96.52" y2="63.5" width="0.254" layer="1"/>
<wire x1="88.265" y1="79.375" x2="92.075" y2="75.565" width="0.254" layer="1"/>
<wire x1="92.075" y1="75.565" x2="96.52" y2="71.12" width="0.254" layer="1"/>
<wire x1="92.075" y1="75.565" x2="81.915" y2="75.565" width="0.254" layer="1"/>
<wire x1="81.915" y1="75.565" x2="81.915" y2="75.07" width="0.254" layer="1"/>
<wire x1="123.825" y1="41.275" x2="123.825" y2="39.37" width="0.254" layer="1"/>
<wire x1="107.95" y1="57.15" x2="123.825" y2="41.275" width="0.254" layer="1"/>
<wire x1="96.52" y1="57.15" x2="107.95" y2="57.15" width="0.254" layer="1"/>
<wire x1="95.885" y1="57.785" x2="96.52" y2="57.15" width="0.254" layer="1"/>
<wire x1="95.885" y1="62.865" x2="95.885" y2="57.785" width="0.254" layer="1"/>
<wire x1="96.52" y1="63.5" x2="95.885" y2="62.865" width="0.254" layer="1"/>
<wire x1="96.52" y1="63.5" x2="96.65" y2="63.5" width="0.254" layer="1"/>
<wire x1="128.905" y1="51.435" x2="123.825" y2="56.515" width="0.254" layer="1"/>
<wire x1="145.415" y1="51.435" x2="128.905" y2="51.435" width="0.254" layer="1"/>
<wire x1="146.685" y1="50.165" x2="145.415" y2="51.435" width="0.254" layer="1"/>
<wire x1="146.685" y1="48.895" x2="146.685" y2="50.165" width="0.254" layer="1"/>
<wire x1="139.065" y1="41.275" x2="146.685" y2="48.895" width="0.254" layer="1"/>
<wire x1="123.825" y1="41.275" x2="139.065" y2="41.275" width="0.254" layer="1"/>
<wire x1="72.39" y1="25.4" x2="74.93" y2="22.86" width="0.254" layer="1"/>
<wire x1="71.755" y1="25.4" x2="72.39" y2="25.4" width="0.254" layer="1"/>
<wire x1="69.85" y1="27.305" x2="71.755" y2="25.4" width="0.254" layer="1"/>
<wire x1="69.85" y1="65.405" x2="69.85" y2="27.305" width="0.254" layer="1"/>
<wire x1="74.93" y1="70.485" x2="69.85" y2="65.405" width="0.254" layer="1"/>
<wire x1="74.93" y1="22.86" x2="74.93" y2="22.73" width="0.254" layer="1"/>
<wire x1="74.93" y1="70.485" x2="74.93" y2="70.615" width="0.254" layer="1"/>
</signal>
<signal name="N$32">
<contactref element="B1" pad="AC2"/>
<contactref element="X7" pad="1"/>
<wire x1="142.875" y1="80.645" x2="132.715" y2="80.645" width="0.254" layer="1"/>
<wire x1="144.145" y1="81.915" x2="142.875" y2="80.645" width="0.254" layer="1"/>
<wire x1="132.715" y1="80.645" x2="132.135" y2="80.635" width="0.254" layer="1"/>
<wire x1="144.145" y1="81.915" x2="144.145" y2="81.9404" width="0.254" layer="1"/>
</signal>
<signal name="N$33">
<contactref element="R11" pad="2"/>
<contactref element="X5" pad="2"/>
<wire x1="73.025" y1="57.15" x2="73.025" y2="60.83" width="0.254" layer="1"/>
<wire x1="79.375" y1="50.8" x2="73.025" y2="57.15" width="0.254" layer="1"/>
<wire x1="79.375" y1="50.8" x2="79.375" y2="50.2158" width="0.254" layer="1"/>
</signal>
<signal name="N$34">
<contactref element="R12" pad="2"/>
<contactref element="X5" pad="1"/>
<wire x1="77.47" y1="57.15" x2="77.47" y2="60.83" width="0.254" layer="1"/>
<wire x1="79.375" y1="55.245" x2="77.47" y2="57.15" width="0.254" layer="1"/>
<wire x1="79.375" y1="55.245" x2="79.375" y2="55.2196" width="0.254" layer="1"/>
</signal>
<signal name="N$35">
<contactref element="X6" pad="1"/>
<contactref element="R21" pad="2"/>
<wire x1="73.025" y1="36.83" x2="73.025" y2="32.515" width="0.254" layer="1"/>
<wire x1="79.375" y1="43.18" x2="73.025" y2="36.83" width="0.254" layer="1"/>
<wire x1="79.375" y1="43.18" x2="79.375" y2="43.7896" width="0.254" layer="1"/>
</signal>
<signal name="N$37">
<contactref element="X6" pad="2"/>
<contactref element="R22" pad="2"/>
<wire x1="77.47" y1="36.83" x2="77.47" y2="32.515" width="0.254" layer="1"/>
<wire x1="79.375" y1="38.735" x2="77.47" y2="36.83" width="0.254" layer="1"/>
<wire x1="79.375" y1="38.735" x2="79.375" y2="38.7858" width="0.254" layer="1"/>
</signal>
<signal name="N$24">
<contactref element="X3" pad="1"/>
<contactref element="K21" pad="7"/>
<wire x1="113.03" y1="41.275" x2="111.125" y2="39.37" width="0.254" layer="1"/>
<wire x1="114.3" y1="41.275" x2="113.03" y2="41.275" width="0.254" layer="1"/>
<wire x1="121.92" y1="33.655" x2="114.3" y2="41.275" width="0.254" layer="1"/>
<wire x1="121.92" y1="22.86" x2="121.92" y2="33.655" width="0.254" layer="1"/>
<wire x1="123.19" y1="21.59" x2="121.92" y2="22.86" width="0.254" layer="1"/>
<wire x1="124.46" y1="21.59" x2="123.19" y2="21.59" width="0.254" layer="1"/>
<wire x1="125.095" y1="22.225" x2="124.46" y2="21.59" width="0.254" layer="1"/>
<wire x1="125.095" y1="24.765" x2="125.095" y2="22.225" width="0.254" layer="1"/>
<wire x1="133.985" y1="33.655" x2="125.095" y2="24.765" width="0.254" layer="1"/>
<wire x1="144.145" y1="33.655" x2="133.985" y2="33.655" width="0.254" layer="1"/>
<wire x1="144.145" y1="33.655" x2="144.145" y2="33.6804" width="0.254" layer="1"/>
</signal>
<signal name="N$25">
<contactref element="X3" pad="2"/>
<contactref element="K21" pad="1"/>
<wire x1="143.51" y1="39.37" x2="126.365" y2="39.37" width="0.254" layer="1"/>
<wire x1="144.145" y1="38.735" x2="143.51" y2="39.37" width="0.254" layer="1"/>
<wire x1="144.145" y1="38.735" x2="144.145" y2="38.6842" width="0.254" layer="1"/>
</signal>
<signal name="N$29">
<contactref element="X4" pad="1"/>
<contactref element="K11" pad="7"/>
<wire x1="116.84" y1="50.8" x2="111.125" y2="56.515" width="0.254" layer="1"/>
<wire x1="143.51" y1="50.8" x2="116.84" y2="50.8" width="0.254" layer="1"/>
<wire x1="144.145" y1="50.165" x2="143.51" y2="50.8" width="0.254" layer="1"/>
<wire x1="144.145" y1="50.165" x2="144.145" y2="49.5554" width="0.254" layer="1"/>
</signal>
<signal name="N$30">
<contactref element="X4" pad="2"/>
<contactref element="K11" pad="1"/>
<wire x1="142.24" y1="56.515" x2="126.365" y2="56.515" width="0.254" layer="1"/>
<wire x1="144.145" y1="54.61" x2="142.24" y2="56.515" width="0.254" layer="1"/>
<wire x1="144.145" y1="54.61" x2="144.145" y2="54.5592" width="0.254" layer="1"/>
</signal>
<signal name="N$28">
<contactref element="K22" pad="14"/>
<contactref element="X1" pad="1"/>
<wire x1="142.875" y1="15.875" x2="126.365" y2="15.875" width="0.254" layer="1"/>
<wire x1="144.145" y1="17.145" x2="142.875" y2="15.875" width="0.254" layer="1"/>
<wire x1="144.145" y1="17.145" x2="144.145" y2="17.2212" width="0.254" layer="1"/>
</signal>
<signal name="N$21">
<contactref element="X2" pad="1"/>
<contactref element="K12" pad="14"/>
<wire x1="140.97" y1="64.77" x2="126.365" y2="64.77" width="0.254" layer="1"/>
<wire x1="144.145" y1="61.595" x2="140.97" y2="64.77" width="0.254" layer="1"/>
<wire x1="144.145" y1="61.595" x2="144.145" y2="61.0362" width="0.254" layer="1"/>
</signal>
<signal name="N$26">
<contactref element="X2" pad="2"/>
<contactref element="K12" pad="7"/>
<wire x1="113.03" y1="74.295" x2="111.125" y2="72.39" width="0.254" layer="1"/>
<wire x1="124.46" y1="74.295" x2="113.03" y2="74.295" width="0.254" layer="1"/>
<wire x1="125.095" y1="73.66" x2="124.46" y2="74.295" width="0.254" layer="1"/>
<wire x1="125.095" y1="71.12" x2="125.095" y2="73.66" width="0.254" layer="1"/>
<wire x1="130.175" y1="66.04" x2="125.095" y2="71.12" width="0.254" layer="1"/>
<wire x1="144.145" y1="66.04" x2="130.175" y2="66.04" width="0.254" layer="1"/>
</signal>
<signal name="N$27">
<contactref element="X2" pad="3"/>
<contactref element="K12" pad="1"/>
<wire x1="142.875" y1="72.39" x2="126.365" y2="72.39" width="0.254" layer="1"/>
<wire x1="144.145" y1="71.12" x2="142.875" y2="72.39" width="0.254" layer="1"/>
<wire x1="144.145" y1="71.12" x2="144.145" y2="71.0438" width="0.254" layer="1"/>
</signal>
<signal name="N$31">
<contactref element="X7" pad="2"/>
<contactref element="B1" pad="AC1"/>
<wire x1="144.145" y1="86.36" x2="132.715" y2="86.36" width="0.254" layer="1"/>
<wire x1="132.715" y1="86.36" x2="132.135" y2="85.735" width="0.254" layer="1"/>
<wire x1="144.145" y1="86.36" x2="144.145" y2="86.9442" width="0.254" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="X1" pad="2"/>
<contactref element="K22" pad="7"/>
<wire x1="113.665" y1="20.955" x2="111.125" y2="23.495" width="0.254" layer="1"/>
<wire x1="142.875" y1="20.955" x2="113.665" y2="20.955" width="0.254" layer="1"/>
<wire x1="144.145" y1="22.225" x2="142.875" y2="20.955" width="0.254" layer="1"/>
</signal>
<signal name="N$18">
<contactref element="X1" pad="3"/>
<contactref element="K22" pad="1"/>
<wire x1="140.97" y1="23.495" x2="126.365" y2="23.495" width="0.254" layer="1"/>
<wire x1="144.145" y1="26.67" x2="140.97" y2="23.495" width="0.254" layer="1"/>
<wire x1="144.145" y1="26.67" x2="144.145" y2="27.2288" width="0.254" layer="1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
