<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="1" unitdist="mm" unit="mm" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="94.3921" y1="4.2393" x2="94.353" y2="52.8397" width="0" layer="20"/>
<wire x1="94.353" y1="52.8397" x2="41.9288" y2="52.8147" width="0" layer="20"/>
<wire x1="41.9288" y1="52.8147" x2="41.9271" y2="4.3929" width="0" layer="20"/>
<wire x1="41.9271" y1="4.3929" x2="94.3921" y2="4.2393" width="0" layer="20"/>
</plain>
<libraries>
<library name="74xx-eu">
<description>&lt;b&gt;TTL Devices, 74xx Series with European Symbols&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Texas Instruments &lt;i&gt;TTL Data Book&lt;/i&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;Volume 1, 1996.
&lt;li&gt;TTL Data Book, Volume 2 , 1993
&lt;li&gt;National Seminconductor Databook 1990, ALS/LS Logic
&lt;li&gt;ttl 74er digital data dictionary, ECA Electronic + Acustic GmbH, ISBN 3-88109-032-0
&lt;li&gt;http://icmaster.com/ViewCompare.asp
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL14">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="DIL08">
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="battery">
<description>&lt;b&gt;Lithium Batteries and NC Accus&lt;/b&gt;&lt;p&gt;
<packages>
<package name="AB9V">
<description>&lt;B&gt;9-V BATTERY CLIP&lt;/B&gt;</description>
<wire x1="-2.54" y1="-3.175" x2="-2.54" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="3.175" width="0.254" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-3.175" y2="2.54" width="0.254" layer="21"/>
<wire x1="-2.54" y1="4.318" x2="-1.778" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="5.08" x2="1.778" y2="5.08" width="0.1524" layer="21"/>
<wire x1="2.54" y1="4.318" x2="1.778" y2="5.08" width="0.1524" layer="21"/>
<wire x1="2.54" y1="4.318" x2="2.54" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-5.08" x2="2.54" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-5.08" x2="-1.778" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-4.318" x2="-1.778" y2="-5.08" width="0.1524" layer="21"/>
<circle x="0" y="2.54" radius="1.27" width="0.1524" layer="51"/>
<circle x="0" y="-2.54" radius="1.27" width="0.1524" layer="51"/>
<pad name="-" x="0" y="-2.54" drill="1.1176" diameter="3.1496" shape="octagon"/>
<pad name="+" x="0" y="2.54" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-1.905" y="-1.143" size="1.27" layer="21" ratio="16" rot="R90">9V</text>
<text x="-3.81" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.445" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="SFH482">
<description>&lt;B&gt;IR LED&lt;/B&gt;&lt;p&gt;
infrared emitting diode, Infineon
TO-18, lead spacing 2.54 mm, cathode marking&lt;p&gt;
Inifineon</description>
<wire x1="-2.159" y1="1.524" x2="-2.794" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.159" x2="-2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.159" x2="-2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0" y1="1.778" x2="1.5358" y2="0.8959" width="0.1524" layer="21" curve="-59.743278"/>
<wire x1="-1.5358" y1="0.8959" x2="0" y2="1.778" width="0.1524" layer="21" curve="-59.743278"/>
<wire x1="-1.5358" y1="-0.8959" x2="0" y2="-1.778" width="0.1524" layer="21" curve="59.743278"/>
<wire x1="0" y1="-1.778" x2="1.5358" y2="-0.8959" width="0.1524" layer="21" curve="59.743278"/>
<wire x1="1.5142" y1="0.9318" x2="1.778" y2="0" width="0.1524" layer="51" curve="-31.606487"/>
<wire x1="1.5" y1="-0.9546" x2="1.778" y2="0" width="0.1524" layer="51" curve="32.472615"/>
<wire x1="-1.778" y1="0" x2="-1.5142" y2="-0.9318" width="0.1524" layer="51" curve="31.606487"/>
<wire x1="-1.778" y1="0" x2="-1.5" y2="0.9546" width="0.1524" layer="51" curve="-32.472615"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0.0539" y1="-1.0699" x2="1.0699" y2="-0.0539" width="0.1524" layer="51" curve="90"/>
<circle x="0" y="0" radius="2.667" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.413" width="0.254" layer="21"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-1.27" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-4.318" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="ptc-ntc">
<description>&lt;b&gt;PTC and NTC Resistors&lt;/b&gt;&lt;p&gt;
Siemens, Philips, Valvo&lt;p&gt;
<packages>
<package name="SOD70">
<description>&lt;b&gt;SOD 70&lt;/b&gt;&lt;p&gt;
Source: 153627-da-01-en-Temperatur-Sensor_KTY10-6_Philips.pdf</description>
<wire x1="-1.6" y1="-1.6" x2="1.6" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-1.6" y1="-1.625" x2="1.625" y2="-1.6" width="0.2032" layer="21" curve="-270"/>
<pad name="1" x="-1.27" y="0" drill="0.7" diameter="1.27"/>
<pad name="2" x="1.27" y="0" drill="0.7" diameter="1.27"/>
<text x="-2.286" y="2.794" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.286" y="-3.302" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="0207/7">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="C050-025X075">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-040X050">
grid 2.5 mm, outline 4 x 5 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.286" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO35-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-0.762" x2="2.286" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="crystal">
<description>&lt;b&gt;Crystals and Crystal Resonators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="HC49/S">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-3.048" y1="-2.159" x2="3.048" y2="-2.159" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="2.159" x2="3.048" y2="2.159" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="-1.651" x2="3.048" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.048" y1="1.651" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="0.254" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.762" x2="0.254" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.762" x2="-0.254" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.762" x2="-0.254" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.762" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.762" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="2.159" x2="-3.048" y2="-2.159" width="0.4064" layer="21" curve="180"/>
<wire x1="3.048" y1="-2.159" x2="3.048" y2="2.159" width="0.4064" layer="21" curve="180"/>
<wire x1="-3.048" y1="1.651" x2="-3.048" y2="-1.651" width="0.1524" layer="21" curve="180"/>
<wire x1="3.048" y1="-1.651" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="180"/>
<pad name="1" x="-2.413" y="0" drill="0.8128"/>
<pad name="2" x="2.413" y="0" drill="0.8128"/>
<text x="-5.08" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.445" y1="-2.54" x2="4.445" y2="2.54" layer="43"/>
<rectangle x1="-5.08" y1="-1.905" x2="-4.445" y2="1.905" layer="43"/>
<rectangle x1="-5.715" y1="-1.27" x2="-5.08" y2="1.27" layer="43"/>
<rectangle x1="4.445" y1="-1.905" x2="5.08" y2="1.905" layer="43"/>
<rectangle x1="5.08" y1="-1.27" x2="5.715" y2="1.27" layer="43"/>
</package>
</packages>
</library>
<library name="v-reg">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="78LXX">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-0.7863" y2="2.5485" width="0.1524" layer="21" curve="-111.098957"/>
<wire x1="0.7868" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.09954"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.1524" layer="51" curve="-34.293591"/>
<pad name="OUT" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="GND" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="IN" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-0.635" y="0.889" size="1.27" layer="51" ratio="10">-</text>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.778" y="-0.635" size="1.27" layer="51" ratio="10">O</text>
<text x="0.635" y="-0.635" size="1.27" layer="51" ratio="10">I</text>
</package>
</packages>
</library>
<library name="piher">
<description>&lt;b&gt;Piher Potentiometers&lt;/b&gt;&lt;p&gt;
PC-16/16 mm carbon types&lt;p&gt;
<packages>
<package name="PC16S">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;&lt;p&gt;
single carbon potentiometer, 16 mm</description>
<wire x1="-7.9" y1="0.1" x2="-4.9" y2="0.1" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="0.1" x2="4.9" y2="0.1" width="0.2032" layer="21"/>
<wire x1="4.9" y1="0.1" x2="7.9" y2="0.1" width="0.2032" layer="21"/>
<wire x1="-7.9" y1="8" x2="7.9" y2="8" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="-8.8" x2="4.5" y2="-8.8" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="0.1" x2="-4.9" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="-3.7" x2="-4.9" y2="-8.4" width="0.2032" layer="21"/>
<wire x1="4.9" y1="0.1" x2="4.9" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="4.9" y1="-3.7" x2="4.9" y2="-8.4" width="0.2032" layer="21"/>
<wire x1="-7.9" y1="8" x2="-7.9" y2="0.1" width="0.2032" layer="21"/>
<wire x1="7.9" y1="0.1" x2="7.9" y2="8" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-44.9" x2="2.9" y2="-44.9" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-8.9" x2="-2.9" y2="-44.9" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-8.9" x2="2.9" y2="-44.9" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="-8.4" x2="-4.5" y2="-8.8" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-8.8" x2="4.9" y2="-8.4" width="0.2032" layer="21"/>
<wire x1="-5.7" y1="-1.9" x2="-4.9" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="-1.9" x2="4.9" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="4.9" y1="-1.9" x2="5.7" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="5.7" y1="-1.9" x2="6.4" y2="-2" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-2" x2="6.7" y2="-2.1" width="0.2032" layer="21"/>
<wire x1="6.7" y1="-2.1" x2="6.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="6.7" y1="-3.5" x2="6.4" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-3.6" x2="5.7" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="5.7" y1="-3.7" x2="4.9" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="4.9" y1="-3.7" x2="-4.9" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="-3.7" x2="-5.7" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-5.7" y1="-3.7" x2="-6.4" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.6" x2="-6.7" y2="-3.5" width="0.2032" layer="21"/>
<wire x1="-6.7" y1="-3.5" x2="-6.7" y2="-2.1" width="0.2032" layer="21"/>
<wire x1="-6.7" y1="-2.1" x2="-6.4" y2="-2" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-2" x2="-5.7" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-2.4" x2="3" y2="-2.2" width="0.2032" layer="21"/>
<wire x1="3" y1="-2.2" x2="2.2" y2="-2" width="0.2032" layer="21"/>
<wire x1="2.2" y1="-2" x2="1.4" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-2.4" x2="-3" y2="-2.2" width="0.2032" layer="21"/>
<wire x1="-3" y1="-2.2" x2="-2.2" y2="-2" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-2" x2="-1.4" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="-3" y1="-3.4" x2="-2.2" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-3.6" x2="-1.4" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-3.2" x2="3" y2="-3.4" width="0.2032" layer="21"/>
<wire x1="3" y1="-3.4" x2="2.2" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="2.2" y1="-3.6" x2="1.4" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-3.2" x2="-3.8" y2="-3.4" width="0.2032" layer="21"/>
<wire x1="-3.8" y1="-3.4" x2="-4.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-4.6" y1="-3.6" x2="-5.4" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-2.4" x2="-3.8" y2="-2.2" width="0.2032" layer="21"/>
<wire x1="-3.8" y1="-2.2" x2="-4.6" y2="-2" width="0.2032" layer="21"/>
<wire x1="-4.6" y1="-2" x2="-5.4" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-2.4" x2="3.8" y2="-2.2" width="0.2032" layer="21"/>
<wire x1="3.8" y1="-2.2" x2="4.6" y2="-2" width="0.2032" layer="21"/>
<wire x1="4.6" y1="-2" x2="5.4" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-3.2" x2="3.8" y2="-3.4" width="0.2032" layer="21"/>
<wire x1="3.8" y1="-3.4" x2="4.6" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="4.6" y1="-3.6" x2="5.4" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-2.4" x2="-3.4" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-2.4" x2="3.4" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="-3.4072" y1="-3.2" x2="-3.0072" y2="-3.4" width="0.2032" layer="21"/>
<pad name="1A" x="-5" y="6.5" drill="1.2" shape="long" rot="R90"/>
<pad name="1S" x="0" y="6.5" drill="1.2" shape="long" rot="R90"/>
<pad name="1E" x="5" y="6.5" drill="1.2" shape="long" rot="R90"/>
<text x="-8.32" y="0.52" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="9.9" y="0.52" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="pot">
<description>&lt;b&gt;Potentiometers&lt;/b&gt;&lt;p&gt;
Beckman, Copal, Piher, Spectrol, Schukat&lt;p&gt;
<packages>
<package name="CA9V">
distributor Schukat</description>
<wire x1="-0.381" y1="0.381" x2="-0.381" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.651" x2="0.381" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.651" x2="0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0.381" x2="1.016" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.127" x2="1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.381" x2="0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.381" x2="0.381" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-1.651" x2="-0.381" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.651" x2="-0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.381" x2="-1.016" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.127" x2="-0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="1.524" y1="5.08" x2="-1.524" y2="5.08" width="0.1524" layer="51"/>
<wire x1="4.572" y1="5.08" x2="1.524" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.524" x2="-2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.524" x2="2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0" x2="-2.413" y2="0" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0" x2="2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.778" x2="-2.032" y2="2.032" width="0.1524" layer="21"/>
<wire x1="1.778" y1="1.778" x2="2.032" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0" y1="2.413" x2="0" y2="2.921" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-5.08" x2="1.143" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-5.08" x2="-1.143" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-5.08" x2="-3.937" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-3.937" y1="-5.08" x2="-4.572" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="4.572" y1="-5.08" x2="4.953" y2="-4.699" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="5.08" x2="4.953" y2="4.699" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.953" y1="4.699" x2="-4.572" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.953" y1="-4.699" x2="-4.572" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="-5.08" x2="3.937" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="4.953" y1="4.699" x2="4.953" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="5.08" x2="-1.524" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.699" x2="-4.953" y2="4.699" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<pad name="S" x="0" y="5.08" drill="1.3208" shape="long"/>
<pad name="A" x="-2.54" y="-5.08" drill="1.3208" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="-5.08" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.461" y="-5.08" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.731" y="-5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.508" y1="5.08" x2="0.508" y2="5.461" layer="51"/>
<rectangle x1="2.032" y1="-5.461" x2="3.048" y2="-3.683" layer="51"/>
<rectangle x1="1.397" y1="-3.683" x2="4.572" y2="-2.667" layer="21"/>
<rectangle x1="3.048" y1="-2.667" x2="4.572" y2="0" layer="21"/>
<rectangle x1="-4.572" y1="-2.667" x2="-3.048" y2="0" layer="21"/>
<rectangle x1="-4.572" y1="-3.683" x2="-1.397" y2="-2.667" layer="21"/>
<rectangle x1="-3.048" y1="-5.461" x2="-2.032" y2="-3.683" layer="51"/>
</package>
</packages>
</library>
<library name="wirepad">
<description>&lt;b&gt;Single Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="1,6/0,8">
<description>&lt;b&gt;THROUGH-HOLE PAD&lt;/b&gt;</description>
<wire x1="-0.762" y1="0.762" x2="-0.508" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0.762" x2="-0.762" y2="0.508" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0.762" x2="0.762" y2="0.508" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0.762" x2="0.508" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-0.508" x2="0.762" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-0.762" x2="0.508" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.762" x2="-0.762" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-0.762" x2="-0.762" y2="-0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.635" width="0.1524" layer="51"/>
<pad name="1" x="0" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-0.762" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.6" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="0"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="IC1" library="74xx-eu" package="DIL14" value="74HC132N" x="56.7074" y="44.9449" rot="R180"/>
<element name="IC2" library="linear" package="DIL08" value="LM358N" x="55.793" y="19.888" rot="R270"/>
<element name="G1" library="battery" package="AB9V" value="AB9V" x="88.0203" y="45.1582" rot="R180"/>
<element name="D2" library="led" package="SFH482" value="SFH482" x="53.0006" y="32.057" rot="R90"/>
<element name="R1" library="ptc-ntc" package="SOD70" value="10K" x="67.405" y="32.1216" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="36.925" y="62.6016" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="36.925" y="62.6016" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="36.925" y="62.6016" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="36.925" y="62.6016" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="R2" library="pot" package="CA9V" value="1K" x="78.0711" y="19.7682" rot="R180"/>
<element name="R4" library="rcl" package="0207/7" value="2.2K" x="75.5234" y="32.1862" rot="R270"/>
<element name="C2" library="rcl" package="C025-040X050" value="470nF" x="67.4838" y="36.8724" rot="R90"/>
<element name="R7" library="rcl" package="0207/7" value="2.2M" x="67.2888" y="44.9519" rot="R270"/>
<element name="C4" library="rcl" package="C025-040X050" value="33pF" x="77.1863" y="47.6116"/>
<element name="C5" library="rcl" package="C025-040X050" value="33pF" x="77.1897" y="42.7887"/>
<element name="C6" library="rcl" package="C050-025X075" value="27pF" x="45.9837" y="38.4761" rot="R180"/>
<element name="R8" library="rcl" package="0207/7" value="1.5K" x="43.4585" y="31.9721" rot="R270"/>
<element name="R9" library="rcl" package="0207/7" value="10K" x="46.0862" y="31.9729" rot="R270"/>
<element name="D3" library="diode" package="DO35-10" value="1N4148DO35-10" x="46.0904" y="19.7928" rot="R90"/>
<element name="C8" library="rcl" package="C025-040X050" value="47pF" x="46.0879" y="10.2701" rot="R270"/>
<element name="R10" library="rcl" package="0207/7" value="1M" x="43.5865" y="19.7768" rot="R90"/>
<element name="D4" library="diode" package="DO35-10" value="1N4148DO35-10" x="48.7213" y="19.7452" rot="R90"/>
<element name="R11" library="rcl" package="0207/7" value="220" x="55.7797" y="13.1418" rot="R180"/>
<element name="C9" library="rcl" package="C050-025X075" value="47nF" x="55.8109" y="27.2956" rot="R180"/>
<element name="R13" library="rcl" package="0207/7" value="8.2L" x="72.8314" y="32.1869" rot="R90"/>
<element name="R14" library="rcl" package="0207/7" value="4.7K" x="91.7327" y="31.6587" rot="R270"/>
<element name="R15" library="rcl" package="0207/7" value="2.2K" x="83.6831" y="28.0408" rot="R180"/>
<element name="R16" library="pot" package="CA9V" value="1K" x="89.1789" y="19.7811" rot="R180"/>
<element name="R17" library="rcl" package="0207/7" value="1.5K" x="63.2033" y="32.067" rot="R270"/>
<element name="D5" library="led" package="SFH482" value="SFH482" x="58.9075" y="32.048" rot="R270"/>
<element name="R18" library="rcl" package="0207/7" value="1.5K" x="48.6232" y="31.9386" rot="R90"/>
<element name="C1" library="rcl" package="C050-025X075" value="33pF" x="83.6124" y="32.9382" rot="R90"/>
<element name="C7" library="rcl" package="C025-040X050" value="33pF" x="55.8022" y="9.7442" rot="R180"/>
<element name="Q1" library="crystal" package="HC49/S" value="" x="71.7599" y="45.2107" rot="R270">
<attribute name="OC_NEWARK" value="unknown" x="71.7599" y="45.2107" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="71.7599" y="45.2107" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="71.7599" y="45.2107" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="1667008" x="71.7599" y="45.2107" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="IC3" library="v-reg" package="78LXX" value="" x="79.2717" y="37.5728"/>
<element name="C10" library="rcl" package="C025-040X050" value="470nF" x="82.561" y="45.1659" rot="R90"/>
<element name="R3" library="piher" package="PC16S" value="PC16S" x="83.5893" y="4.2801">
<attribute name="OC_NEWARK" value="unknown" x="83.5893" y="4.2801" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="83.5893" y="4.2801" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="83.5893" y="4.2801" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="4452940" x="83.5893" y="4.2801" size="1.778" layer="27" display="off"/>
</element>
<element name="R5" library="pot" package="CA9V" value="" x="67.4791" y="19.6847" rot="R180"/>
<element name="PAD1" library="wirepad" package="1,6/0,8" value="" x="43.4516" y="26.4809"/>
<element name="PAD2" library="wirepad" package="1,6/0,8" value="" x="50.5476" y="9.0174"/>
</elements>
<signals>
<signal name="N$1">
<contactref element="IC1" pad="1"/>
<contactref element="IC1" pad="2"/>
<contactref element="R7" pad="1"/>
<contactref element="C4" pad="1"/>
<contactref element="Q1" pad="1"/>
<wire x1="75.9163" y1="47.6116" x2="75.9042" y2="47.6237" width="1.27" layer="16"/>
<wire x1="75.9042" y1="47.6237" x2="71.7599" y2="47.6237" width="1.27" layer="16"/>
<wire x1="67.2888" y1="48.7619" x2="67.2888" y2="48.7747" width="1.27" layer="16"/>
<wire x1="61.7874" y1="48.7549" x2="64.3274" y2="48.7549" width="1.27" layer="16"/>
<wire x1="64.3274" y1="48.7549" x2="64.3274" y2="48.7619" width="1.27" layer="16"/>
<wire x1="64.3274" y1="48.7619" x2="67.2888" y2="48.7619" width="1.27" layer="16"/>
<wire x1="67.2888" y1="48.7619" x2="70.6217" y2="48.7619" width="1.27" layer="16"/>
<wire x1="70.6217" y1="48.7619" x2="71.7599" y2="47.6237" width="1.27" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="IC1" pad="3"/>
<contactref element="R7" pad="2"/>
<contactref element="C5" pad="1"/>
<contactref element="IC1" pad="9"/>
<contactref element="IC1" pad="10"/>
<contactref element="Q1" pad="2"/>
<wire x1="75.9197" y1="42.7887" x2="75.9107" y2="42.7977" width="1.27" layer="16"/>
<wire x1="75.9107" y1="42.7977" x2="71.7599" y2="42.7977" width="1.27" layer="16"/>
<wire x1="71.7599" y1="42.7977" x2="70.1041" y2="41.1419" width="1.27" layer="16"/>
<wire x1="70.1041" y1="41.1419" x2="67.2888" y2="41.1419" width="1.27" layer="16"/>
<wire x1="67.2888" y1="41.1419" x2="67.2888" y2="43.1059" width="1.27" layer="16"/>
<wire x1="67.2888" y1="43.1059" x2="65.7616" y2="44.6331" width="1.27" layer="16"/>
<wire x1="65.7616" y1="44.6331" x2="59.2833" y2="44.6331" width="1.27" layer="16"/>
<wire x1="59.2833" y1="44.6331" x2="54.0681" y2="44.6331" width="1.27" layer="16"/>
<wire x1="54.0681" y1="44.6331" x2="52.8785" y2="43.4435" width="1.27" layer="16"/>
<wire x1="59.2474" y1="48.7549" x2="59.2474" y2="44.669" width="1.27" layer="16"/>
<wire x1="59.2474" y1="44.669" x2="59.2833" y2="44.6331" width="1.27" layer="16"/>
<wire x1="51.6274" y1="41.1349" x2="52.8785" y2="41.1349" width="1.27" layer="16"/>
<wire x1="52.8785" y1="41.1349" x2="54.1674" y2="41.1349" width="1.27" layer="16"/>
<wire x1="52.8785" y1="43.4435" x2="52.8785" y2="41.1349" width="1.27" layer="16"/>
</signal>
<signal name="GND">
<contactref element="C2" pad="2"/>
<contactref element="C4" pad="2"/>
<contactref element="C5" pad="2"/>
<contactref element="IC1" pad="7"/>
<contactref element="C9" pad="2"/>
<contactref element="IC2" pad="4"/>
<contactref element="R14" pad="1"/>
<contactref element="R18" pad="1"/>
<contactref element="C7" pad="2"/>
<contactref element="C1" pad="2"/>
<contactref element="G1" pad="-"/>
<contactref element="R9" pad="1"/>
<contactref element="C8" pad="2"/>
<contactref element="R10" pad="1"/>
<contactref element="IC3" pad="GND"/>
<contactref element="C10" pad="2"/>
<wire x1="53.2709" y1="27.2956" x2="52.4379" y2="28.1286" width="1.27" layer="16"/>
<wire x1="52.4379" y1="28.1286" x2="48.6232" y2="28.1286" width="1.27" layer="16"/>
<wire x1="54.3832" y1="16.078" x2="54.3832" y2="26.1833" width="1.27" layer="16"/>
<wire x1="54.3832" y1="26.1833" x2="53.2709" y2="27.2956" width="1.27" layer="16"/>
<wire x1="51.983" y1="16.078" x2="54.3832" y2="16.078" width="1.27" layer="16"/>
<contactref element="PAD2" pad="1"/>
<wire x1="46.0879" y1="9.0001" x2="44.6519" y2="9.0001" width="1.27" layer="16"/>
<wire x1="44.6519" y1="9.0001" x2="43.5865" y2="10.0655" width="1.27" layer="16"/>
<wire x1="43.5865" y1="10.0655" x2="43.5865" y2="15.9668" width="1.27" layer="16"/>
<wire x1="48.6232" y1="28.1286" x2="48.6232" y2="30.5934" width="1.27" layer="16"/>
<wire x1="48.6232" y1="30.5934" x2="46.0862" y2="33.1304" width="1.27" layer="16"/>
<wire x1="46.0862" y1="33.1304" x2="46.0862" y2="35.7829" width="1.27" layer="16"/>
<wire x1="78.4597" y1="42.7887" x2="78.4563" y2="42.7921" width="1.27" layer="16"/>
<wire x1="91.7327" y1="35.4687" x2="91.7232" y2="35.4782" width="1.27" layer="16"/>
<wire x1="91.7232" y1="35.4782" x2="83.6124" y2="35.4782" width="1.27" layer="16"/>
<wire x1="67.4838" y1="38.1424" x2="70.4159" y2="38.1424" width="1.27" layer="16"/>
<wire x1="70.4159" y1="38.1424" x2="72.7393" y2="40.2642" width="1.27" layer="16"/>
<wire x1="72.7393" y1="40.2642" x2="77.1931" y2="40.2642" width="1.27" layer="16"/>
<wire x1="77.1931" y1="40.2642" x2="77.9118" y2="40.9829" width="1.27" layer="16"/>
<wire x1="77.9118" y1="40.9829" x2="78.4597" y2="41.5308" width="1.27" layer="16"/>
<wire x1="78.4597" y1="41.5308" x2="78.4597" y2="42.7887" width="1.27" layer="16"/>
<wire x1="79.2717" y1="39.4778" x2="77.9118" y2="40.8377" width="1.27" layer="16"/>
<wire x1="77.9118" y1="40.8377" x2="77.9118" y2="40.9829" width="1.27" layer="16"/>
<wire x1="78.4597" y1="42.7887" x2="78.4597" y2="44.1589" width="1.27" layer="16"/>
<wire x1="78.4597" y1="44.1589" x2="80.7367" y2="46.4359" width="1.27" layer="16"/>
<wire x1="80.7367" y1="46.4359" x2="82.561" y2="46.4359" width="1.27" layer="16"/>
<wire x1="78.4563" y1="47.6116" x2="79.632" y2="46.4359" width="1.27" layer="16"/>
<wire x1="79.632" y1="46.4359" x2="80.7367" y2="46.4359" width="1.27" layer="16"/>
<wire x1="82.561" y1="46.4359" x2="83.8233" y2="47.6982" width="1.27" layer="16"/>
<wire x1="83.8233" y1="47.6982" x2="88.0203" y2="47.6982" width="1.27" layer="16"/>
<wire x1="88.0203" y1="47.6982" x2="89.7514" y2="47.6982" width="1.27" layer="16"/>
<wire x1="89.7514" y1="47.6982" x2="91.7327" y2="45.7169" width="1.27" layer="16"/>
<wire x1="91.7327" y1="45.7169" x2="91.7327" y2="35.4687" width="1.27" layer="16"/>
<wire x1="46.0879" y1="9.0001" x2="50.5303" y2="9.0001" width="1.27" layer="16"/>
<wire x1="50.5303" y1="9.0001" x2="50.5476" y2="9.0174" width="1.27" layer="16"/>
<wire x1="50.5476" y1="9.0174" x2="53.8054" y2="9.0174" width="1.27" layer="16"/>
<wire x1="53.8054" y1="9.0174" x2="54.5322" y2="9.7442" width="1.27" layer="16"/>
<wire x1="54.3832" y1="16.078" x2="54.5322" y2="15.929" width="1.27" layer="16"/>
<wire x1="54.5322" y1="15.929" x2="54.5322" y2="9.7442" width="1.27" layer="16"/>
<wire x1="49.0874" y1="48.7549" x2="49.0874" y2="50.7413" width="1.27" layer="16"/>
<wire x1="49.0874" y1="50.7413" x2="49.9517" y2="51.6056" width="1.27" layer="16"/>
<wire x1="49.9517" y1="51.6056" x2="75.9042" y2="51.6056" width="1.27" layer="16"/>
<wire x1="75.9042" y1="51.6056" x2="78.4563" y2="49.0535" width="1.27" layer="16"/>
<wire x1="78.4563" y1="49.0535" x2="78.4563" y2="47.6116" width="1.27" layer="16"/>
<wire x1="46.0862" y1="35.7829" x2="46.0862" y2="44.25" width="1.27" layer="16"/>
<wire x1="46.0862" y1="44.25" x2="49.0874" y2="47.2512" width="1.27" layer="16"/>
<wire x1="49.0874" y1="47.2512" x2="49.0874" y2="48.7549" width="1.27" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="C6" pad="1"/>
<contactref element="IC1" pad="8"/>
<wire x1="48.5237" y1="38.4761" x2="49.0874" y2="39.0398" width="1.27" layer="16"/>
<wire x1="49.0874" y1="39.0398" x2="49.0874" y2="41.1349" width="1.27" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="C6" pad="2"/>
<contactref element="R8" pad="1"/>
<wire x1="43.4585" y1="35.7821" x2="43.4585" y2="38.4613" width="1.27" layer="16"/>
<wire x1="43.4585" y1="38.4613" x2="43.4437" y2="38.4761" width="1.27" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="R8" pad="2"/>
<contactref element="R9" pad="2"/>
<contactref element="D3" pad="A"/>
<wire x1="46.0854" y1="28.1621" x2="46.0862" y2="28.1629" width="1.27" layer="16"/>
<wire x1="46.0904" y1="24.8728" x2="46.0904" y2="28.1587" width="1.27" layer="16"/>
<wire x1="46.0904" y1="28.1587" x2="46.0862" y2="28.1629" width="1.27" layer="16"/>
<contactref element="PAD1" pad="1"/>
<wire x1="43.4516" y1="26.4809" x2="43.4585" y2="26.4878" width="1.27" layer="16"/>
<wire x1="43.4585" y1="26.4878" x2="43.4585" y2="28.1621" width="1.27" layer="16"/>
<wire x1="43.4585" y1="28.1621" x2="43.4593" y2="28.1629" width="1.27" layer="16"/>
<wire x1="43.4593" y1="28.1629" x2="46.0862" y2="28.1629" width="1.27" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="D3" pad="C"/>
<contactref element="C8" pad="1"/>
<contactref element="R10" pad="2"/>
<contactref element="IC2" pad="3"/>
<wire x1="46.0879" y1="11.5401" x2="46.0904" y2="11.5401" width="1.27" layer="16"/>
<wire x1="46.0904" y1="11.5401" x2="46.0904" y2="14.7128" width="1.27" layer="16"/>
<wire x1="46.0904" y1="14.7128" x2="46.0904" y2="17.0886" width="1.27" layer="16"/>
<wire x1="46.0904" y1="17.0886" x2="46.9943" y2="17.9925" width="1.27" layer="16"/>
<wire x1="46.9943" y1="17.9925" x2="47.6198" y2="18.618" width="1.27" layer="16"/>
<wire x1="47.6198" y1="18.618" x2="51.983" y2="18.618" width="1.27" layer="16"/>
<wire x1="43.5865" y1="23.5868" x2="43.5865" y2="21.4003" width="1.27" layer="16"/>
<wire x1="43.5865" y1="21.4003" x2="46.9943" y2="17.9925" width="1.27" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="IC2" pad="2"/>
<contactref element="IC2" pad="1"/>
<contactref element="D4" pad="A"/>
<wire x1="51.983" y1="21.158" x2="51.983" y2="23.698" width="1.27" layer="16"/>
<wire x1="51.983" y1="23.698" x2="50.8558" y2="24.8252" width="1.27" layer="16"/>
<wire x1="50.8558" y1="24.8252" x2="48.7213" y2="24.8252" width="1.27" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="R11" pad="1"/>
<contactref element="IC2" pad="6"/>
<contactref element="C7" pad="1"/>
<contactref element="R5" pad="S"/>
<wire x1="57.4179" y1="17.8084" x2="58.2275" y2="18.618" width="1.27" layer="16"/>
<wire x1="58.2275" y1="18.618" x2="59.603" y2="18.618" width="1.27" layer="16"/>
<wire x1="59.5897" y1="13.1418" x2="66.0162" y2="13.1418" width="1.27" layer="16"/>
<wire x1="66.0162" y1="13.1418" x2="67.4791" y2="14.6047" width="1.27" layer="16"/>
<wire x1="57.0722" y1="9.7442" x2="57.4179" y2="10.0899" width="1.27" layer="16"/>
<wire x1="57.4179" y1="10.0899" x2="57.4179" y2="12.9646" width="1.27" layer="16"/>
<wire x1="57.4179" y1="13.1418" x2="57.4179" y2="17.8084" width="1.27" layer="16"/>
<wire x1="59.5897" y1="13.1418" x2="57.4179" y2="13.1418" width="1.27" layer="16"/>
<wire x1="57.4179" y1="13.1418" x2="57.4179" y2="12.9646" width="1.27" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="R1" pad="1"/>
<contactref element="R5" pad="A"/>
<wire x1="70.0191" y1="24.7647" x2="70.0658" y2="30.7308" width="1.27" layer="16"/>
<wire x1="70.0658" y1="30.7308" x2="68.675" y2="32.1216" width="1.27" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="R15" pad="2"/>
<contactref element="R2" pad="A"/>
<contactref element="R13" pad="1"/>
<wire x1="80.6111" y1="24.8482" x2="80.6111" y2="27.3028" width="1.27" layer="16"/>
<wire x1="80.6111" y1="27.3028" x2="79.8731" y2="28.0408" width="1.27" layer="16"/>
<wire x1="79.8731" y1="28.0408" x2="77.1809" y2="30.733" width="1.27" layer="16"/>
<wire x1="77.1809" y1="30.733" x2="74.3384" y2="30.733" width="1.27" layer="16"/>
<wire x1="74.3384" y1="30.733" x2="72.8314" y2="29.226" width="1.27" layer="16"/>
<wire x1="72.8314" y1="29.226" x2="72.8314" y2="28.3769" width="1.27" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="R15" pad="1"/>
<contactref element="R16" pad="E"/>
<wire x1="86.6389" y1="24.8611" x2="86.6389" y2="27.1866" width="1.27" layer="16"/>
<wire x1="86.6389" y1="27.1866" x2="87.4931" y2="28.0408" width="1.27" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="R2" pad="E"/>
<contactref element="R4" pad="2"/>
<wire x1="75.5311" y1="24.8482" x2="75.5234" y2="24.8559" width="1.27" layer="16"/>
<wire x1="75.5234" y1="24.8559" x2="75.5234" y2="28.3762" width="1.27" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="R16" pad="A"/>
<contactref element="R4" pad="1"/>
<contactref element="R14" pad="2"/>
<wire x1="91.7189" y1="24.8611" x2="91.7189" y2="27.8349" width="1.27" layer="16"/>
<wire x1="91.7189" y1="27.8349" x2="91.7327" y2="27.8487" width="1.27" layer="16"/>
<wire x1="91.7327" y1="27.8487" x2="86.684" y2="32.8974" width="1.27" layer="16"/>
<wire x1="86.684" y1="32.8974" x2="78.6222" y2="32.8974" width="1.27" layer="16"/>
<wire x1="78.6222" y1="32.8974" x2="75.5234" y2="35.9962" width="1.27" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="R16" pad="S"/>
<contactref element="R3" pad="1E"/>
<wire x1="88.5893" y1="10.7801" x2="89.1789" y2="11.3697" width="1.27" layer="16"/>
<wire x1="89.1789" y1="11.3697" x2="89.1789" y2="14.7011" width="1.27" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="R2" pad="S"/>
<contactref element="R3" pad="1A"/>
<wire x1="78.5893" y1="10.7801" x2="78.0711" y2="11.2983" width="1.27" layer="16"/>
<wire x1="78.0711" y1="11.2983" x2="78.0711" y2="14.6882" width="1.27" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="IC2" pad="5"/>
<contactref element="C1" pad="1"/>
<contactref element="R3" pad="1S"/>
<wire x1="83.5893" y1="10.7801" x2="83.5893" y2="17.0186" width="1.27" layer="16"/>
<wire x1="83.5893" y1="17.0186" x2="82.2785" y2="18.3294" width="1.27" layer="16"/>
<wire x1="82.2785" y1="18.3294" x2="64.3561" y2="18.3294" width="1.27" layer="16"/>
<wire x1="64.3561" y1="18.3294" x2="62.1047" y2="16.078" width="1.27" layer="16"/>
<wire x1="62.1047" y1="16.078" x2="59.603" y2="16.078" width="1.27" layer="16"/>
<wire x1="83.6124" y1="30.3982" x2="83.6124" y2="19.6633" width="1.27" layer="16"/>
<wire x1="83.6124" y1="19.6633" x2="82.2785" y2="18.3294" width="1.27" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="R17" pad="1"/>
<contactref element="D5" pad="A"/>
<wire x1="58.9075" y1="33.318" x2="60.6443" y2="33.318" width="1.27" layer="16"/>
<wire x1="60.6443" y1="33.318" x2="63.2033" y2="35.877" width="1.27" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="D5" pad="K"/>
<contactref element="D2" pad="A"/>
<contactref element="IC2" pad="7"/>
<wire x1="53.0006" y1="30.787" x2="55.9997" y2="30.787" width="1.27" layer="16"/>
<wire x1="55.9997" y1="30.787" x2="58.8985" y2="30.787" width="1.27" layer="16"/>
<wire x1="58.8985" y1="30.787" x2="58.9075" y2="30.778" width="1.27" layer="16"/>
<wire x1="55.7858" y1="30.5731" x2="55.9997" y2="30.787" width="1.27" layer="16"/>
<wire x1="59.603" y1="21.158" x2="58.1775" y2="21.158" width="1.27" layer="16"/>
<wire x1="58.1775" y1="21.158" x2="56.3576" y2="22.9779" width="1.27" layer="16"/>
<wire x1="56.3576" y1="22.9779" x2="56.3576" y2="27.577" width="1.27" layer="16"/>
<wire x1="56.3576" y1="27.577" x2="55.7858" y2="28.1488" width="1.27" layer="16"/>
<wire x1="55.7858" y1="28.1488" x2="55.7858" y2="30.5731" width="1.27" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="R18" pad="2"/>
<contactref element="D2" pad="K"/>
<wire x1="48.6232" y1="35.7486" x2="51.0448" y2="33.327" width="1.27" layer="16"/>
<wire x1="51.0448" y1="33.327" x2="53.0006" y2="33.327" width="1.27" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="D4" pad="C"/>
<contactref element="R11" pad="2"/>
<wire x1="48.7213" y1="14.6652" x2="50.2447" y2="13.1418" width="1.27" layer="16"/>
<wire x1="50.2447" y1="13.1418" x2="51.9697" y2="13.1418" width="1.27" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="G1" pad="+"/>
<contactref element="IC3" pad="IN"/>
<contactref element="C10" pad="1"/>
<wire x1="80.5417" y1="37.5728" x2="83.6614" y2="40.6925" width="1.27" layer="16"/>
<wire x1="83.6614" y1="40.6925" x2="83.6614" y2="42.5948" width="1.27" layer="16"/>
<wire x1="88.0203" y1="42.6182" x2="83.6848" y2="42.6182" width="1.27" layer="16"/>
<wire x1="83.6848" y1="42.6182" x2="83.6614" y2="42.5948" width="1.27" layer="16"/>
<wire x1="82.561" y1="43.8959" x2="83.6614" y2="42.7955" width="1.27" layer="16"/>
<wire x1="83.6614" y1="42.7955" x2="83.6614" y2="42.5948" width="1.27" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="IC2" pad="8"/>
<contactref element="C9" pad="1"/>
<contactref element="C2" pad="1"/>
<contactref element="R1" pad="2"/>
<contactref element="R13" pad="2"/>
<contactref element="R17" pad="2"/>
<contactref element="IC1" pad="14"/>
<contactref element="IC3" pad="OUT"/>
<wire x1="58.3509" y1="27.2956" x2="62.2419" y2="27.2956" width="1.27" layer="16"/>
<wire x1="62.2419" y1="27.2956" x2="63.2033" y2="28.257" width="1.27" layer="16"/>
<wire x1="63.2033" y1="28.257" x2="63.2033" y2="29.1899" width="1.27" layer="16"/>
<wire x1="63.2033" y1="29.1899" x2="66.135" y2="32.1216" width="1.27" layer="16"/>
<wire x1="59.603" y1="23.698" x2="58.3509" y2="24.9501" width="1.27" layer="16"/>
<wire x1="58.3509" y1="24.9501" x2="58.3509" y2="27.2956" width="1.27" layer="16"/>
<wire x1="66.135" y1="32.1216" x2="66.135" y2="34.2536" width="1.27" layer="16"/>
<wire x1="66.135" y1="34.2536" x2="67.06655" y2="35.18515" width="1.27" layer="16"/>
<wire x1="67.06655" y1="35.18515" x2="67.4838" y2="35.6024" width="1.27" layer="16"/>
<wire x1="67.4838" y1="35.6024" x2="72.4369" y2="35.6024" width="1.27" layer="16"/>
<wire x1="72.4369" y1="35.6024" x2="72.8314" y2="35.9969" width="1.27" layer="16"/>
<wire x1="72.8314" y1="35.9969" x2="72.8314" y2="37.1624" width="1.27" layer="16"/>
<wire x1="72.8314" y1="37.1624" x2="73.6187" y2="37.9497" width="1.27" layer="16"/>
<wire x1="64.3274" y1="41.1349" x2="64.3274" y2="37.9243" width="1.27" layer="16"/>
<wire x1="64.3274" y1="37.9243" x2="67.06655" y2="35.18515" width="1.27" layer="16"/>
<wire x1="78.0017" y1="37.5728" x2="77.6248" y2="37.9497" width="1.27" layer="16"/>
<wire x1="77.6248" y1="37.9497" x2="73.6187" y2="37.9497" width="1.27" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
