<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.4">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="inch" style="dots" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<text x="30.48" y="30.48" size="5.08" layer="16" rot="MR0">+</text>
<text x="29.21" y="17.78" size="5.08" layer="16" rot="MR0">-</text>
<wire x1="19.05" y1="54.61" x2="106.68" y2="54.61" width="0.4064" layer="20"/>
<wire x1="106.68" y1="54.61" x2="106.68" y2="13.97" width="0.4064" layer="20"/>
<wire x1="106.68" y1="13.97" x2="19.05" y2="13.97" width="0.4064" layer="20"/>
<wire x1="19.05" y1="13.97" x2="19.05" y2="54.61" width="0.4064" layer="20"/>
<dimension x1="19.05" y1="13.97" x2="15.24" y2="54.61" x3="15.24" y3="34.29" textsize="3.81" layer="20" dtype="vertical" precision="1"/>
<dimension x1="19.05" y1="54.61" x2="106.68" y2="57.15" x3="62.865" y3="58.42" textsize="3.81" layer="20" dtype="horizontal" precision="1"/>
</plain>
<libraries>
<library name="74xx-eu">
<description>&lt;b&gt;TTL Devices, 74xx Series with European Symbols&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Texas Instruments &lt;i&gt;TTL Data Book&lt;/i&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;Volume 1, 1996.
&lt;li&gt;TTL Data Book, Volume 2 , 1993
&lt;li&gt;National Seminconductor Databook 1990, ALS/LS Logic
&lt;li&gt;ttl 74er digital data dictionary, ECA Electronic + Acustic GmbH, ISBN 3-88109-032-0
&lt;li&gt;http://icmaster.com/ViewCompare.asp
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK300/2">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="5.08" y1="6.223" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="5.588" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="6.223" x2="5.588" y2="1.397" width="0.1524" layer="21"/>
<wire x1="5.588" y1="1.397" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-5.461" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-5.207" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.064" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.588" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="0.4572" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="0.254" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-6.223" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="-0.4826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="0.4572" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-6.223" x2="-0.4826" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="0.4572" y2="0.254" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-4.318" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-0.4826" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-4.318" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="4.1402" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="0.8382" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="-3.683" x2="0.8382" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-0.8636" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-4.1656" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-3.683" x2="-4.1656" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-0.508" x2="-3.7846" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="-0.508" x2="-1.2446" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0.8382" y1="-0.508" x2="1.2192" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="4.1402" y1="-0.508" x2="3.7592" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-6.223" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.651" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.175" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="3.429" x2="0.4572" y2="5.969" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="5.969" x2="4.5212" y2="5.969" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="5.969" x2="4.5212" y2="3.429" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="3.429" x2="0.4572" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-0.4826" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-4.5466" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="3.429" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="5.969" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="3.9574" y1="4.0849" x2="4.0131" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="1.016" y1="4.1656" x2="4.0038" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="0.8636" y1="5.0038" x2="4.0178" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="0.9144" y1="5.0546" x2="1.0581" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="0.8636" y1="4.445" x2="3.9116" y2="5.08" width="0.1524" layer="21"/>
<wire x1="0.9906" y1="4.318" x2="4.0386" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-1.0464" y1="4.0849" x2="-0.9907" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-3.9878" y1="4.1656" x2="-1" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-4.1402" y1="5.0038" x2="-0.9858" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-4.0894" y1="5.0546" x2="-3.9457" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-4.1402" y1="4.445" x2="-1.0922" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="4.318" x2="-0.9652" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="0.254" x2="-0.8636" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="0.635" x2="-4.1656" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="0.635" x2="-0.8636" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="4.1402" y2="0.635" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="51"/>
<wire x1="4.5212" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="0.254" x2="0.8382" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.4958" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="0.5842" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-3.7846" y1="-2.54" x2="-1.2446" y2="0.254" layer="51"/>
<rectangle x1="1.2192" y1="-2.54" x2="3.7592" y2="0.254" layer="51"/>
</package>
<package name="AK300/3">
<wire x1="7.5438" y1="6.223" x2="7.5438" y2="3.175" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="6.223" x2="-7.5438" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="6.223" x2="8.0518" y2="6.223" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="6.223" x2="8.0518" y2="1.397" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="1.397" x2="7.5438" y2="1.651" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-5.461" x2="7.5438" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="-5.207" x2="7.5438" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-3.81" x2="7.5438" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="-4.064" x2="7.5438" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-3.81" x2="8.0518" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-6.223" x2="-2.032" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.254" x2="2.032" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-6.223" x2="2.032" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-6.223" x2="2.9718" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-6.223" x2="-2.9718" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-6.223" x2="-2.032" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="0.254" x2="-7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="-6.223" x2="-7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="-6.223" x2="-2.9718" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.318" x2="2.032" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.318" x2="-2.032" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-4.318" x2="2.032" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-4.318" x2="-7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-4.318" x2="-2.9718" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="-4.318" x2="-7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-3.683" x2="1.651" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-3.683" x2="-1.651" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-3.683" x2="-1.651" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="-3.683" x2="-3.3528" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="-3.683" x2="-6.6548" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.6548" y1="-3.683" x2="-6.6548" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-6.6548" y1="-0.508" x2="-6.2738" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-3.3528" y1="-0.508" x2="-3.7338" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-0.508" x2="-1.27" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.508" x2="1.27" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-7.5438" y1="-6.223" x2="-7.5438" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="0.635" x2="-7.5438" y2="3.175" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="1.651" x2="7.5438" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="0.635" x2="7.5438" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="3.175" x2="7.5438" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="3.175" x2="-7.5438" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="3.175" x2="7.5438" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="3.429" x2="-2.032" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="5.969" x2="2.032" y2="5.969" width="0.1524" layer="21"/>
<wire x1="2.032" y1="5.969" x2="2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="2.032" y1="3.429" x2="-2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="3.429" x2="-2.9718" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="3.429" x2="-7.0358" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="3.429" x2="-7.0358" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="5.969" x2="-7.0358" y2="5.969" width="0.1524" layer="21"/>
<wire x1="1.4682" y1="4.0849" x2="1.5239" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-1.4732" y1="4.1656" x2="1.5146" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="-1.6256" y1="5.0038" x2="1.5288" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-1.5748" y1="5.0546" x2="-1.4311" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-1.6256" y1="4.445" x2="1.4224" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.4986" y1="4.318" x2="1.5494" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-3.5102" y1="4.0849" x2="-3.4545" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-6.4516" y1="4.1656" x2="-3.4638" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-6.604" y1="5.0038" x2="-3.4496" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-6.5532" y1="5.0546" x2="-6.4095" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-6.604" y1="4.445" x2="-3.556" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="4.318" x2="-3.429" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="0.254" x2="-6.6548" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="0.254" x2="-3.3528" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="0.254" x2="-6.6548" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-7.5438" y1="0.635" x2="-6.6548" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.6548" y1="0.635" x2="-3.3528" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-3.3528" y1="0.635" x2="-1.651" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="0.635" x2="6.6548" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="0.635" x2="-1.651" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.032" y1="0.254" x2="1.651" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.254" x2="-1.651" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.254" x2="1.651" y2="0.254" width="0.1524" layer="51"/>
<wire x1="6.6548" y1="0.635" x2="3.3782" y2="0.635" width="0.1524" layer="51"/>
<wire x1="1.6764" y1="0.635" x2="3.3528" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="-6.223" x2="7.5438" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="0.254" x2="7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="-4.318" x2="7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="0.254" x2="6.6548" y2="0.254" width="0.1524" layer="21"/>
<wire x1="3.3782" y1="0.254" x2="6.6548" y2="0.254" width="0.1524" layer="51"/>
<wire x1="2.9718" y1="0.254" x2="3.3782" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-6.223" x2="2.9718" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-6.223" x2="7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-4.318" x2="7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="6.6548" y1="-3.683" x2="3.3528" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="6.6548" y1="-3.683" x2="6.6548" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="6.6548" y1="-0.508" x2="6.2738" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="3.3528" y1="-0.508" x2="3.7084" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="3.3528" y1="-3.683" x2="3.3528" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="3.429" x2="2.9718" y2="5.969" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="5.969" x2="7.0358" y2="5.969" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="5.969" x2="7.0358" y2="3.429" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="3.429" x2="2.9718" y2="3.429" width="0.1524" layer="21"/>
<wire x1="6.472" y1="4.0849" x2="6.5277" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="3.5306" y1="4.1656" x2="6.5184" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="3.3782" y1="5.0038" x2="6.5324" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="3.429" y1="5.0546" x2="3.5727" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="3.3782" y1="4.445" x2="6.4262" y2="5.08" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="4.318" x2="6.5532" y2="4.953" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-4.318" x2="2.9718" y2="0.254" width="0.1524" layer="21"/>
<pad name="1" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-7.5692" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.5692" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.985" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="-1.905" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<text x="3.175" y="1.27" size="1.27" layer="21" ratio="10">3</text>
<rectangle x1="-6.2738" y1="-2.54" x2="-3.7338" y2="0.254" layer="51"/>
<rectangle x1="-1.27" y1="-2.54" x2="1.27" y2="0.254" layer="51"/>
<rectangle x1="3.7338" y1="-2.54" x2="6.2738" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
<packages>
<package name="G2R2">
<description>&lt;b&gt;RELAY&lt;/b&gt;&lt;p&gt;
2 x switch, Omron</description>
<wire x1="-4.699" y1="-6.604" x2="24.384" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="24.384" y1="6.477" x2="24.384" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="24.384" y1="6.477" x2="-4.699" y2="6.477" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-6.604" x2="-4.699" y2="6.477" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.0574" x2="-2.54" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="-0.6604" y1="1.1938" x2="-0.6604" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="-4.4196" y1="-1.3208" x2="-4.4196" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-4.4196" y1="1.1938" x2="-2.54" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.1938" x2="-1.2954" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-3.7846" y1="-1.3208" x2="-4.4196" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="-1.2954" y1="1.1938" x2="-3.7846" y2="-1.3208" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="1.1938" x2="-0.6604" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-0.6604" y1="-1.3208" x2="-2.54" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-1.3208" x2="-2.54" y2="-1.9304" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.3208" x2="-3.7846" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="16.637" y1="0.508" x2="16.9672" y2="0.8382" width="0.254" layer="21"/>
<wire x1="16.9672" y1="0.8382" x2="12.446" y2="0.8382" width="0.1524" layer="21"/>
<wire x1="16.9672" y1="0.8382" x2="17.526" y2="1.397" width="0.254" layer="21"/>
<wire x1="12.446" y1="0.8382" x2="12.446" y2="1.9812" width="0.1524" layer="21"/>
<wire x1="18.4912" y1="0.8382" x2="22.479" y2="0.8382" width="0.1524" layer="21"/>
<wire x1="22.479" y1="0.8382" x2="22.479" y2="1.9812" width="0.1524" layer="21"/>
<wire x1="17.526" y1="1.905" x2="17.526" y2="1.397" width="0.1524" layer="21"/>
<wire x1="16.637" y1="-0.381" x2="16.9672" y2="-0.7112" width="0.254" layer="21"/>
<wire x1="16.9672" y1="-0.7112" x2="12.446" y2="-0.7112" width="0.1524" layer="21"/>
<wire x1="16.9672" y1="-0.7112" x2="17.526" y2="-1.27" width="0.254" layer="21"/>
<wire x1="12.446" y1="-0.7112" x2="12.446" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="18.4912" y1="-0.7112" x2="22.479" y2="-0.7112" width="0.1524" layer="21"/>
<wire x1="22.479" y1="-0.7112" x2="22.479" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="17.526" y1="-1.778" x2="17.526" y2="-1.27" width="0.1524" layer="21"/>
<pad name="2" x="-2.54" y="3.81" drill="1.3208" shape="long" rot="R90"/>
<pad name="1" x="-2.54" y="-3.683" drill="1.3208" shape="long" rot="R90"/>
<pad name="O1" x="12.4714" y="3.81" drill="1.3208" shape="long" rot="R90"/>
<pad name="P1" x="17.4498" y="3.81" drill="1.3208" shape="long" rot="R90"/>
<pad name="S1" x="22.4536" y="3.81" drill="1.3208" shape="long" rot="R90"/>
<pad name="O2" x="12.4714" y="-3.683" drill="1.3208" shape="long" rot="R90"/>
<pad name="P2" x="17.4498" y="-3.683" drill="1.3208" shape="long" rot="R90"/>
<pad name="S2" x="22.4536" y="-3.683" drill="1.3208" shape="long" rot="R90"/>
<text x="26.6446" y="-6.2992" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.81" y="-5.08" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="eagle-ltspice">
<description>Default symbols for import LTspice schematics&lt;p&gt;
2012-10-29 alf@cadsoft.de&lt;br&gt;</description>
<packages>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="ref-packages-longpad">
<description>&lt;b&gt;Reference Package&lt;/b&gt;&lt;p&gt;</description>
<packages>
<package name="C025-025X050">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="ref-packages">
<packages>
<package name="DO41-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="octagon"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="0"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="E$1" library="74xx-eu" package="DIL08" value="" x="40.64" y="33.02" rot="R90"/>
<element name="E$3" library="con-ptr500" package="AK300/2" value="" x="25.4" y="26.67" rot="R90"/>
<element name="E$4" library="relay" package="G2R2" value="" x="85.09" y="43.18" rot="R270"/>
<element name="E$2" library="74xx-eu" package="DIL08" value="" x="67.31" y="33.02" rot="R90"/>
<element name="D1" library="ref-packages" package="DO41-10" value="" x="29.21" y="41.91" rot="R270"/>
<element name="R3" library="eagle-ltspice" package="0207/10" value="47K" x="33.02" y="41.91" rot="R90"/>
<element name="C2" library="ref-packages-longpad" package="C025-025X050" value="22uF" x="40.64" y="21.59" rot="R90"/>
<element name="C3" library="ref-packages-longpad" package="C025-025X050" value="0.1uF" x="36.83" y="41.91" rot="R90"/>
<element name="C4" library="ref-packages-longpad" package="C025-025X050" value="0.1uF" x="48.26" y="30.48" rot="R270"/>
<element name="R5" library="eagle-ltspice" package="0207/10" value="47K" x="52.07" y="29.21" rot="R90"/>
<element name="D2" library="ref-packages" package="DO41-10" value="" x="55.88" y="29.21" rot="R270"/>
<element name="R6" library="eagle-ltspice" package="0207/10" value="47K" x="59.69" y="41.91" rot="R90"/>
<element name="R7" library="eagle-ltspice" package="0207/10" value="2K" x="59.69" y="29.21" rot="R90"/>
<element name="C5" library="ref-packages-longpad" package="C025-025X050" value="22uF" x="67.31" y="21.59" rot="R90"/>
<element name="C6" library="ref-packages-longpad" package="C025-025X050" value="0.1uF" x="63.5" y="41.91" rot="R90"/>
<element name="E$5" library="con-ptr500" package="AK300/3" value="" x="100.33" y="25.4" rot="R90"/>
<element name="E$6" library="con-ptr500" package="AK300/3" value="" x="100.33" y="43.18" rot="R90"/>
<element name="D3" library="ref-packages" package="DO41-10" value="" x="74.93" y="41.91" rot="R90"/>
<element name="C1" library="ref-packages-longpad" package="C025-025X050" value="22uF" x="49.53" y="41.91" rot="R90"/>
</elements>
<signals>
<signal name="S$10">
<contactref element="E$1" pad="2"/>
<wire x1="43.18" y1="31.75" x2="44.45" y2="31.75" width="0.8128" layer="16"/>
<wire x1="40.64" y1="29.21" x2="43.18" y2="31.75" width="0.8128" layer="16"/>
<wire x1="40.64" y1="25.4" x2="40.64" y2="29.21" width="0.8128" layer="16"/>
<wire x1="40.64" y1="25.4" x2="36.83" y2="25.4" width="0.8128" layer="16"/>
<wire x1="36.83" y1="25.4" x2="33.02" y2="29.21" width="0.8128" layer="16"/>
</signal>
<signal name="S$17">
<contactref element="R3" pad="1"/>
<contactref element="D1" pad="A"/>
<wire x1="33.02" y1="36.83" x2="29.21" y2="36.83" width="0.8128" layer="16"/>
<contactref element="E$1" pad="6"/>
<wire x1="36.83" y1="34.29" x2="33.02" y2="34.29" width="0.8128" layer="16"/>
<wire x1="33.02" y1="29.21" x2="33.02" y2="34.29" width="0.8128" layer="16"/>
<wire x1="33.02" y1="36.83" x2="33.02" y2="34.29" width="0.8128" layer="16" style="longdash"/>
</signal>
<signal name="S$5">
<contactref element="C2" pad="2"/>
<wire x1="40.64" y1="25.4" x2="40.64" y2="22.86" width="0.8128" layer="16"/>
</signal>
<signal name="S$6">
<contactref element="C3" pad="1"/>
<contactref element="E$1" pad="5"/>
<wire x1="36.83" y1="36.83" x2="36.83" y2="40.64" width="0.8128" layer="16"/>
</signal>
<signal name="S$7">
<contactref element="E$1" pad="3"/>
<contactref element="C4" pad="1"/>
<wire x1="48.26" y1="31.75" x2="45.72" y2="34.29" width="0.8128" layer="16"/>
<wire x1="45.72" y1="34.29" x2="44.45" y2="34.29" width="0.8128" layer="16"/>
</signal>
<signal name="S$12">
<contactref element="C6" pad="1"/>
<contactref element="E$2" pad="5"/>
<wire x1="63.5" y1="40.64" x2="63.5" y2="36.83" width="0.8128" layer="16"/>
</signal>
<signal name="S$22">
<contactref element="E$2" pad="1"/>
<wire x1="71.12" y1="29.21" x2="71.12" y2="17.78" width="1.27" layer="16"/>
<contactref element="C5" pad="1"/>
<wire x1="67.31" y1="17.78" x2="67.31" y2="20.32" width="1.27" layer="16"/>
<wire x1="71.12" y1="17.78" x2="67.31" y2="17.78" width="1.27" layer="16"/>
<contactref element="E$1" pad="1"/>
<wire x1="44.45" y1="17.78" x2="44.45" y2="29.21" width="1.27" layer="16"/>
<wire x1="44.45" y1="17.78" x2="67.31" y2="17.78" width="1.27" layer="16"/>
<contactref element="C2" pad="1"/>
<wire x1="40.64" y1="17.78" x2="40.64" y2="20.32" width="1.27" layer="16"/>
<wire x1="40.64" y1="17.78" x2="44.45" y2="17.78" width="1.27" layer="16"/>
<wire x1="34.29" y1="17.78" x2="40.64" y2="17.78" width="1.27" layer="16"/>
<wire x1="34.29" y1="17.78" x2="27.94" y2="24.13" width="1.27" layer="16"/>
<wire x1="27.94" y1="24.13" x2="25.4" y2="24.13" width="1.27" layer="16"/>
</signal>
<signal name="S$19">
<contactref element="C6" pad="2"/>
<wire x1="63.5" y1="50.8" x2="63.5" y2="43.18" width="0.8128" layer="16"/>
<contactref element="E$3" pad="1"/>
<contactref element="C3" pad="2"/>
<wire x1="36.83" y1="50.8" x2="36.83" y2="43.18" width="0.8128" layer="16"/>
<wire x1="27.94" y1="50.8" x2="36.83" y2="50.8" width="1.27" layer="16"/>
<wire x1="21.59" y1="44.45" x2="27.94" y2="50.8" width="1.27" layer="16"/>
<wire x1="21.59" y1="26.67" x2="24.13" y2="24.13" width="1.27" layer="16"/>
<wire x1="21.59" y1="44.45" x2="21.59" y2="26.67" width="1.27" layer="16"/>
<wire x1="24.13" y1="24.13" x2="25.4" y2="24.1554" width="1.27" layer="16"/>
<wire x1="63.5" y1="50.8" x2="49.53" y2="50.8" width="1.27" layer="16"/>
<wire x1="49.53" y1="50.8" x2="36.83" y2="50.8" width="1.27" layer="16"/>
<wire x1="74.93" y1="46.99" x2="74.93" y2="50.8" width="0.8128" layer="16"/>
<wire x1="74.93" y1="50.8" x2="63.5" y2="50.8" width="1.27" layer="16"/>
<wire x1="81.28" y1="45.72" x2="76.2" y2="50.8" width="1.27" layer="16"/>
<wire x1="76.2" y1="50.8" x2="74.93" y2="50.8" width="1.27" layer="16"/>
<contactref element="C1" pad="2"/>
<wire x1="49.53" y1="43.18" x2="49.53" y2="50.8" width="1.27" layer="16"/>
</signal>
<signal name="S$8">
<contactref element="E$6" pad="1"/>
<wire x1="96.52" y1="34.29" x2="100.33" y2="38.1762" width="1.27" layer="16"/>
<wire x1="81.28" y1="30.48" x2="85.09" y2="34.29" width="1.27" layer="16"/>
<wire x1="85.09" y1="34.29" x2="96.52" y2="34.29" width="1.27" layer="16"/>
</signal>
<signal name="S$18">
<contactref element="E$5" pad="1"/>
<wire x1="100.33" y1="20.32" x2="100.33" y2="20.3962" width="0.254" layer="16"/>
<wire x1="88.9" y1="20.32" x2="100.33" y2="20.32" width="1.27" layer="16"/>
</signal>
<signal name="S$20">
<contactref element="E$5" pad="3"/>
<wire x1="100.33" y1="30.48" x2="100.33" y2="30.4038" width="0.254" layer="16"/>
<wire x1="88.9" y1="30.48" x2="100.33" y2="30.48" width="1.27" layer="16"/>
</signal>
<signal name="S$11">
<contactref element="E$2" pad="4"/>
<contactref element="E$2" pad="8"/>
<wire x1="71.12" y1="36.83" x2="63.5" y2="29.21" width="0.8128" layer="16"/>
<contactref element="R6" pad="2"/>
<wire x1="55.88" y1="43.18" x2="59.69" y2="46.99" width="0.8128" layer="16"/>
<wire x1="60.96" y1="29.21" x2="63.5" y2="29.21" width="0.8128" layer="16"/>
<wire x1="55.88" y1="34.29" x2="60.96" y2="29.21" width="0.8128" layer="16"/>
<contactref element="D2" pad="C"/>
<wire x1="55.88" y1="34.29" x2="55.88" y2="43.18" width="0.8128" layer="16"/>
</signal>
<signal name="S$21">
<contactref element="D2" pad="A"/>
<wire x1="55.88" y1="24.13" x2="55.88" y2="26.67" width="0.8128" layer="16"/>
<wire x1="64.77" y1="26.67" x2="55.88" y2="26.67" width="0.8128" layer="16"/>
<wire x1="55.88" y1="26.67" x2="52.07" y2="26.67" width="0.8128" layer="16"/>
<contactref element="R5" pad="1"/>
<wire x1="52.07" y1="26.67" x2="52.07" y2="24.13" width="0.8128" layer="16"/>
<contactref element="C4" pad="2"/>
<wire x1="52.07" y1="26.67" x2="49.53" y2="29.21" width="0.8128" layer="16"/>
<wire x1="49.53" y1="29.21" x2="48.26" y2="29.21" width="0.8128" layer="16"/>
<wire x1="64.77" y1="26.67" x2="69.85" y2="31.75" width="0.8128" layer="16"/>
<contactref element="E$2" pad="2"/>
<wire x1="69.85" y1="31.75" x2="71.12" y2="31.75" width="0.8128" layer="16"/>
</signal>
<signal name="S$9">
<contactref element="E$5" pad="2"/>
<wire x1="88.9" y1="25.4" x2="100.33" y2="25.4" width="1.27" layer="16"/>
</signal>
<signal name="S$15">
<wire x1="81.28" y1="25.4" x2="77.47" y2="27.94" width="1.27" layer="16"/>
<wire x1="77.47" y1="27.94" x2="77.47" y2="31.75" width="1.27" layer="16"/>
<contactref element="E$6" pad="2"/>
<wire x1="93.98" y1="36.83" x2="100.33" y2="43.18" width="1.27" layer="16"/>
<wire x1="77.47" y1="31.75" x2="82.55" y2="36.83" width="1.27" layer="16"/>
<wire x1="82.55" y1="36.83" x2="93.98" y2="36.83" width="1.27" layer="16"/>
</signal>
<signal name="S$13">
</signal>
<signal name="S$16">
<wire x1="81.28" y1="20.32" x2="74.93" y2="25.4" width="1.27" layer="16"/>
<wire x1="74.93" y1="25.4" x2="74.93" y2="33.02" width="1.27" layer="16"/>
<wire x1="74.93" y1="33.02" x2="81.28" y2="39.37" width="1.27" layer="16"/>
<wire x1="81.28" y1="39.37" x2="88.9" y2="39.37" width="1.27" layer="16"/>
<wire x1="88.9" y1="39.37" x2="97.79" y2="48.26" width="1.27" layer="16"/>
<wire x1="97.79" y1="48.26" x2="100.33" y2="48.26" width="1.27" layer="16"/>
</signal>
<signal name="S$4">
<contactref element="E$2" pad="7"/>
<contactref element="E$2" pad="6"/>
<wire x1="63.5" y1="31.75" x2="63.5" y2="34.29" width="0.8128" layer="16"/>
<wire x1="63.5" y1="34.29" x2="59.69" y2="34.29" width="0.8128" layer="16"/>
<contactref element="R6" pad="1"/>
<contactref element="R7" pad="2"/>
<wire x1="59.69" y1="34.29" x2="59.69" y2="36.83" width="0.8128" layer="16"/>
</signal>
<signal name="S$3">
<contactref element="D1" pad="C"/>
<wire x1="29.21" y1="46.99" x2="29.21" y2="41.91" width="0.8128" layer="16"/>
</signal>
<signal name="S$14">
<contactref element="E$4" pad="2"/>
<wire x1="88.9" y1="45.72" x2="86.36" y2="43.18" width="0.8128" layer="16"/>
<wire x1="86.36" y1="43.18" x2="78.74" y2="43.18" width="0.8128" layer="16"/>
<contactref element="E$2" pad="3"/>
<wire x1="74.93" y1="36.83" x2="72.39" y2="34.29" width="0.8128" layer="16"/>
<wire x1="72.39" y1="34.29" x2="71.12" y2="34.29" width="0.8128" layer="16"/>
<wire x1="78.74" y1="43.18" x2="74.93" y2="39.37" width="0.8128" layer="16"/>
<wire x1="74.93" y1="39.37" x2="74.93" y2="36.83" width="0.8128" layer="16"/>
</signal>
<signal name="S$1">
<contactref element="C5" pad="2"/>
<wire x1="67.31" y1="22.86" x2="60.96" y2="22.86" width="0.8128" layer="16"/>
<contactref element="R7" pad="1"/>
<wire x1="60.96" y1="22.86" x2="59.69" y2="24.13" width="0.8128" layer="16"/>
</signal>
<signal name="S$23">
<contactref element="E$1" pad="8"/>
<wire x1="36.83" y1="29.21" x2="38.1" y2="29.21" width="0.8128" layer="16"/>
<contactref element="E$1" pad="4"/>
<wire x1="44.45" y1="36.83" x2="49.53" y2="36.83" width="0.8128" layer="16"/>
<wire x1="49.53" y1="36.83" x2="52.07" y2="36.83" width="0.8128" layer="16"/>
<wire x1="52.07" y1="36.83" x2="55.88" y2="36.83" width="0.8128" layer="16"/>
<wire x1="44.45" y1="36.83" x2="44.45" y2="38.1" width="0.8128" layer="16"/>
<wire x1="44.45" y1="38.1" x2="40.64" y2="41.91" width="0.8128" layer="16"/>
<wire x1="40.64" y1="41.91" x2="33.02" y2="41.91" width="0.8128" layer="16"/>
<wire x1="33.02" y1="41.91" x2="29.21" y2="41.91" width="0.8128" layer="16"/>
<wire x1="29.21" y1="41.91" x2="25.4" y2="38.1" width="0.8128" layer="16"/>
<wire x1="25.4" y1="38.1" x2="25.4" y2="29.21" width="0.8128" layer="16"/>
<contactref element="R3" pad="2"/>
<wire x1="33.02" y1="46.99" x2="33.02" y2="41.91" width="0.8128" layer="16"/>
<contactref element="R5" pad="2"/>
<wire x1="52.07" y1="34.29" x2="52.07" y2="36.83" width="0.8128" layer="16"/>
<contactref element="C1" pad="1"/>
<wire x1="49.53" y1="40.64" x2="49.53" y2="36.83" width="0.8128" layer="16"/>
<wire x1="38.1" y1="29.21" x2="40.64" y2="31.75" width="0.8128" layer="16"/>
<wire x1="40.64" y1="31.75" x2="40.64" y2="41.91" width="0.8128" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
