<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="12.5" unitdist="mil" unit="mil" style="lines" multiple="1" display="no" altdistance="6.25" altunitdist="mil" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="200" name="200bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="231" name="Eagle3D_PG1" color="7" fill="1" visible="yes" active="yes"/>
<layer number="232" name="Eagle3D_PG2" color="7" fill="1" visible="yes" active="yes"/>
<layer number="233" name="Eagle3D_PG3" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="7" fill="1" visible="yes" active="yes"/>
<layer number="251" name="SMDround" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<plain>
<wire x1="7.62" y1="40.64" x2="49.51" y2="40.64" width="0" layer="20"/>
<wire x1="49.51" y1="40.64" x2="49.51" y2="86.03" width="0" layer="20"/>
<wire x1="49.51" y1="86.03" x2="7.62" y2="86.03" width="0" layer="20"/>
<wire x1="7.62" y1="86.03" x2="7.62" y2="40.64" width="0" layer="20"/>
</plain>
<libraries>
<library name="transistor-power">
<description>&lt;b&gt;Power Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TO220AH">
<description>&lt;b&gt;Molded Package&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="B" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="C" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="1.016" layer="21" ratio="10">A17,5mm</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C1206">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="E5-8,5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO201-15">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 5.6 mm, horizontal, grid 15.24 mm</description>
<wire x1="-1.27" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.143" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.5842" x2="1.143" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.794" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.794" x2="-5.08" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.223" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.223" y2="0" width="1.27" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.4986" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.4986" shape="long"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.191" y1="-2.794" x2="-3.429" y2="2.794" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-5.08" y2="0.635" layer="21"/>
<rectangle x1="5.08" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
</package>
<package name="MELF-MLL41">
<description>&lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;
Package DO-213AB = http://www.diotec.com/pdf/sm4001.pdf</description>
<wire x1="2.0828" y1="1.1938" x2="-2.159" y2="1.1938" width="0.1524" layer="51"/>
<wire x1="2.0828" y1="-1.1938" x2="-2.1336" y2="-1.1938" width="0.1524" layer="51"/>
<wire x1="0.627" y1="1" x2="-0.746" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.746" y1="0" x2="0.627" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-1" x2="0.627" y2="1" width="0.2032" layer="21"/>
<wire x1="1.1208" y1="1.1938" x2="-1.097" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="1.1208" y1="-1.1938" x2="-1.0716" y2="-1.1938" width="0.1524" layer="21"/>
<smd name="C" x="-2.625" y="0" dx="2.5" dy="3" layer="1"/>
<smd name="A" x="2.625" y="0" dx="2.5" dy="3" layer="1"/>
<text x="-2.663" y="1.724" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.663" y="-2.994" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.0574" y1="-1.27" x2="2.5654" y2="1.27" layer="51"/>
<rectangle x1="-2.6162" y1="-1.27" x2="-2.1082" y2="1.27" layer="51"/>
<rectangle x1="-1.4478" y1="-1.1938" x2="-0.5588" y2="1.1938" layer="51"/>
</package>
<package name="SOD80C">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
</packages>
</library>
<library name="inductors">
<description>&lt;b&gt;Inductors and Filters&lt;/b&gt;&lt;p&gt;
Based on the previous library ind-a.lbr&lt;p&gt;
<packages>
<package name="ED26">
<description>&lt;B&gt;INDUCTOR&lt;/B&gt;</description>
<wire x1="-6.985" y1="0" x2="-12.573" y2="-1.27" width="1.016" layer="51"/>
<wire x1="-6.731" y1="-1.27" x2="-12.065" y2="-3.429" width="1.016" layer="51"/>
<wire x1="-6.858" y1="1.143" x2="-12.446" y2="1.524" width="1.016" layer="51"/>
<wire x1="-6.477" y1="-2.54" x2="-11.176" y2="-5.588" width="1.016" layer="21"/>
<wire x1="-5.969" y1="-3.556" x2="-10.287" y2="-7.112" width="1.016" layer="21"/>
<wire x1="-5.334" y1="-4.445" x2="-9.271" y2="-8.382" width="1.016" layer="21"/>
<wire x1="-4.572" y1="-5.334" x2="-8.128" y2="-9.525" width="1.016" layer="21"/>
<wire x1="-3.683" y1="-5.842" x2="-6.858" y2="-10.414" width="1.016" layer="21"/>
<wire x1="-2.794" y1="-6.477" x2="-5.461" y2="-11.303" width="1.016" layer="21"/>
<wire x1="-1.778" y1="-6.731" x2="-3.81" y2="-11.938" width="1.016" layer="21"/>
<wire x1="-0.762" y1="-7.112" x2="-1.651" y2="-12.319" width="1.016" layer="21"/>
<wire x1="0.381" y1="-7.112" x2="0.381" y2="-12.446" width="1.016" layer="21"/>
<wire x1="1.397" y1="-6.858" x2="2.413" y2="-12.192" width="1.016" layer="21"/>
<wire x1="2.54" y1="-6.604" x2="4.572" y2="-11.684" width="1.016" layer="21"/>
<wire x1="3.556" y1="-6.096" x2="6.223" y2="-10.795" width="1.016" layer="21"/>
<wire x1="4.572" y1="-5.334" x2="8.001" y2="-9.525" width="1.016" layer="21"/>
<wire x1="5.461" y1="-4.572" x2="9.398" y2="-8.128" width="1.016" layer="21"/>
<wire x1="6.096" y1="-3.556" x2="10.795" y2="-6.35" width="1.016" layer="21"/>
<wire x1="6.604" y1="-2.54" x2="11.684" y2="-4.699" width="1.016" layer="21"/>
<wire x1="6.858" y1="-1.397" x2="12.319" y2="-2.413" width="1.016" layer="21"/>
<wire x1="6.985" y1="-0.381" x2="12.573" y2="-0.381" width="1.016" layer="21"/>
<wire x1="6.985" y1="0.635" x2="12.446" y2="1.524" width="1.016" layer="21"/>
<wire x1="6.858" y1="1.651" x2="12.065" y2="3.302" width="1.016" layer="21"/>
<wire x1="6.477" y1="2.667" x2="11.557" y2="4.953" width="1.016" layer="21"/>
<wire x1="5.969" y1="3.683" x2="10.541" y2="6.731" width="1.016" layer="21"/>
<wire x1="5.334" y1="4.572" x2="9.398" y2="8.255" width="1.016" layer="21"/>
<wire x1="4.572" y1="5.207" x2="8.001" y2="9.525" width="1.016" layer="21"/>
<wire x1="3.683" y1="5.969" x2="6.604" y2="10.541" width="1.016" layer="21"/>
<wire x1="2.667" y1="6.477" x2="5.08" y2="11.43" width="1.016" layer="21"/>
<wire x1="1.524" y1="6.858" x2="2.921" y2="12.192" width="1.016" layer="21"/>
<wire x1="0.381" y1="6.985" x2="0.635" y2="12.573" width="1.016" layer="21"/>
<wire x1="-0.762" y1="6.985" x2="-1.524" y2="12.319" width="1.016" layer="21"/>
<wire x1="-1.778" y1="6.731" x2="-3.556" y2="11.938" width="1.016" layer="21"/>
<wire x1="-2.921" y1="6.35" x2="-5.588" y2="11.176" width="1.016" layer="21"/>
<wire x1="-3.937" y1="5.842" x2="-7.239" y2="10.16" width="1.016" layer="21"/>
<wire x1="-4.826" y1="5.08" x2="-9.017" y2="8.763" width="1.016" layer="21"/>
<wire x1="-5.588" y1="4.064" x2="-10.414" y2="7.112" width="1.016" layer="21"/>
<wire x1="-6.223" y1="3.175" x2="-11.303" y2="5.461" width="1.016" layer="21"/>
<wire x1="-6.731" y1="2.286" x2="-12.065" y2="3.556" width="1.016" layer="21"/>
<wire x1="-7.3819" y1="-1.8901" x2="-7.3819" y2="1.8901" width="0.1524" layer="21" curve="331.276467"/>
<wire x1="-11.9146" y1="-1.8991" x2="-11.9146" y2="1.8991" width="0.1524" layer="21" curve="341.887309"/>
<wire x1="-11.9146" y1="1.8991" x2="-11.9146" y2="-1.8991" width="0.1524" layer="51" curve="18.112691"/>
<wire x1="-7.3819" y1="1.8901" x2="-7.3819" y2="-1.8901" width="0.1524" layer="51" curve="28.723533"/>
<pad name="2" x="-6.35" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="1" x="-13.335" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-4.445" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="13.335" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="2.54" size="1.27" layer="21" ratio="10">DÝ1,0</text>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/3">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-7.5184" y1="-3.556" x2="-7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-3.556" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-8.0264" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="3.175" x2="-8.0264" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="2.032" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="-7.5184" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="-2.159" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="1.016" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-3.9878" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.0198" y1="-1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-1.016" x2="1.016" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-6.0198" y1="-1.016" x2="-3.9878" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="-1.016" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="1.016" y1="1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-6.0198" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.9878" y1="1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.9878" y1="-1.016" x2="6.0198" y2="1.016" width="0.6096" layer="51"/>
<wire x1="3.9878" y1="-1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="6.0198" y2="1.397" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="3.9878" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="6.0198" y1="1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<circle x="0" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-7.5946" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.5946" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.731" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-1.905" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="3.175" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<rectangle x1="-2.8956" y1="-1.905" x2="-2.1336" y2="1.905" layer="21"/>
<rectangle x1="2.1336" y1="-1.905" x2="2.8956" y2="1.905" layer="21"/>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="3,3-PAD">
<description>&lt;b&gt;MOUNTING PAD&lt;/b&gt; 3.3 mm, round</description>
<wire x1="-2.159" y1="0" x2="0" y2="-2.159" width="2.4892" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.159" x2="2.159" y2="0" width="2.4892" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="3.683" width="1.27" layer="39"/>
<circle x="0" y="0" radius="3.683" width="1.27" layer="40"/>
<circle x="0" y="0" radius="3.556" width="1.016" layer="43"/>
<circle x="0" y="0" radius="1.7" width="0.2032" layer="21"/>
<pad name="B3,3" x="0" y="0" drill="3.3" diameter="5.842"/>
</package>
</packages>
</library>
<library name="34063_">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;/p&gt;
&lt;p&gt;&lt;date&gt;2008-05-16&lt;/date&gt;, updates by &lt;author&gt;Eike Schmidt&lt;/author&gt;&lt;/p&gt;&lt;ul&gt;&lt;li&gt;integrated library "ltc_swr.lbr" with switching regulators from &lt;a href=http://www.linear.com&gt;Linear Technology&lt;/a&gt;, created by &lt;author&gt;Claudius Stern&lt;/author&gt;&lt;/li&gt;&lt;li&gt;added step-down switching regulator LT1767&lt;/li&gt;&lt;li&gt;combined identical symbols for positive regulators&lt;/li&gt;&lt;li&gt;added packages SO8 and SOT89 for 78Lxx and 79Lxx&lt;/li&gt;&lt;li&gt;added package SO8 for LM317L and LM337L&lt;/li&gt;&lt;li&gt;added linear regulators L4931, L4949E, LM2931&lt;/li&gt;&lt;li&gt;added micropower, ultra-low dropout family LP298x&lt;/li&gt;&lt;li&gt;added ultra-low dropout regulators IRU1205, TK112, TK113&lt;/li&gt;&lt;li&gt;added low power, low dropout regulator family S-812&lt;/li&gt;&lt;li&gt;added NPN "Simple Switcher"(c) family LM257x&lt;/li&gt;&lt;li&gt;added DMOS "Simple Switcher"(c) family LM267x&lt;/li&gt;&lt;li&gt;added NPN Darlington switching regulator MC34063A&lt;/li&gt;&lt;li&gt;added LED boost drivers PR4401, PR4402, PR4403&lt;/li&gt;&lt;/ul&gt;</description>
<packages>
<package name="SO08">
<description>&lt;b&gt;SMALL OUTLINE INTEGRATED CIRCUIT&lt;/b&gt;&lt;p&gt;
body 3.9 mm/JEDEC MS-012AA</description>
<wire x1="-2.9" y1="3.9" x2="2.9" y2="3.9" width="0.1998" layer="39"/>
<wire x1="2.9" y1="3.9" x2="2.9" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="2.9" y1="-3.9" x2="-2.9" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="-2.9" y1="-3.9" x2="-2.9" y2="3.9" width="0.1998" layer="39"/>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.9" width="0.1778" layer="21"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.1778" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="1.9" width="0.1778" layer="21"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.1778" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.0508" layer="51"/>
<circle x="-1.905" y="-0.9525" radius="0.2245" width="0" layer="21"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-3.175" y="-1.905" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.445" y="-1.905" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1501" y1="-3.1001" x2="-1.6599" y2="-2" layer="51"/>
<rectangle x1="-0.8801" y1="-3.1001" x2="-0.3899" y2="-2" layer="51"/>
<rectangle x1="0.3899" y1="-3.1001" x2="0.8801" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="-3.1001" x2="2.1501" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="2" x2="2.1501" y2="3.1001" layer="51"/>
<rectangle x1="0.3899" y1="2" x2="0.8801" y2="3.1001" layer="51"/>
<rectangle x1="-0.8801" y1="2" x2="-0.3899" y2="3.1001" layer="51"/>
<rectangle x1="-2.1501" y1="2" x2="-1.6599" y2="3.1001" layer="51"/>
</package>
</packages>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SOT23-BEC">
<description>TO-236 ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="Q1" library="transistor-power" package="TO220AH" value="IRF540N" x="30.48" y="82.55"/>
<element name="R5" library="rcl" package="R1206" value="" x="36.83" y="57.15" rot="MR270"/>
<element name="R6" library="rcl" package="R1206" value="" x="36.195" y="60.96" rot="MR0"/>
<element name="C3" library="rcl" package="E5-8,5" value="" x="35.56" y="53.34" rot="R180"/>
<element name="D1" library="diode" package="DO201-15" value="HER608G" x="39.37" y="67.31" rot="R90"/>
<element name="C4" library="rcl" package="E5-8,5" value="" x="19.05" y="53.34"/>
<element name="L1" library="inductors" package="ED26" value="ED26" x="17.78" y="78.74" rot="R90"/>
<element name="X1" library="con-ptr500" package="AK500/3" value="" x="26.67" y="44.45">
<attribute name="OC_NEWARK" value="unknown" x="57.15" y="10.16" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="57.15" y="10.16" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="57.15" y="10.16" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="57.15" y="10.16" size="1.778" layer="27" display="off"/>
</element>
<element name="C5" library="rcl" package="C1206" value="100nF" x="20.32" y="50.8" rot="MR180"/>
<element name="C6" library="rcl" package="C1206" value="100nF" x="34.29" y="50.8" rot="MR0"/>
<element name="H1" library="holes" package="3,3-PAD" value="MOUNT-PAD-ROUND3.3" x="45.4025" y="75.8825"/>
<element name="H2" library="holes" package="3,3-PAD" value="MOUNT-PAD-ROUND3.3" x="45.4025" y="46.355"/>
<element name="H3" library="holes" package="3,3-PAD" value="MOUNT-PAD-ROUND3.3" x="11.43" y="75.8825"/>
<element name="H4" library="holes" package="3,3-PAD" value="MOUNT-PAD-ROUND3.3" x="11.43" y="46.355"/>
<element name="D2" library="diode" package="MELF-MLL41" value="Z15" x="31.75" y="72.39" rot="MR180"/>
<element name="IC1" library="34063_" package="SO08" value="MC34063AD" x="24.765" y="61.595" rot="MR180"/>
<element name="R1" library="rcl" package="R1206" value="50mOhm" x="14.605" y="57.15" rot="MR270"/>
<element name="R3" library="rcl" package="R1206" value="50mOhm" x="17.145" y="57.15" rot="MR270"/>
<element name="C1" library="rcl" package="C1206" value="1nF" x="31.115" y="61.595" rot="MR180"/>
<element name="C2" library="rcl" package="C1206" value="non" x="28.575" y="53.975" rot="MR270"/>
<element name="R7" library="rcl" package="R1206" value="220R" x="17.145" y="61.595" rot="MR0"/>
<element name="D3" library="diode" package="SOD80C" value="PMLL41SOD80C" x="24.13" y="74.6125" rot="MR0"/>
<element name="R2" library="rcl" package="R1206" value="220R" x="26.3525" y="67.6275" rot="MR0"/>
<element name="T1" library="transistor" package="SOT23-BEC" value="" x="25.7175" y="70.8025" rot="MR180"/>
<element name="R4" library="rcl" package="R1206" value="4R7" x="22.5425" y="69.85" rot="MR270"/>
</elements>
<signals>
<signal name="GND">
<contactref element="C4" pad="-"/>
<contactref element="X1" pad="2"/>
<contactref element="C5" pad="2"/>
<wire x1="21.72" y1="50.8" x2="21.72" y2="53.21" width="2.032" layer="16"/>
<wire x1="21.72" y1="53.21" x2="21.59" y2="53.34" width="1.6764" layer="16"/>
<wire x1="21.72" y1="50.8" x2="22.86" y2="50.8" width="2.032" layer="16"/>
<wire x1="22.86" y1="50.8" x2="26.67" y2="46.99" width="2.032" layer="16"/>
<wire x1="26.67" y1="46.99" x2="26.67" y2="44.45" width="2.032" layer="16"/>
<wire x1="30.48" y1="50.8" x2="28.2575" y2="48.5775" width="2.032" layer="16"/>
<wire x1="28.2575" y1="48.5775" x2="26.67" y2="46.99" width="2.032" layer="16"/>
<wire x1="20.955" y1="53.975" x2="21.59" y2="53.34" width="0.6096" layer="16"/>
<contactref element="IC1" pad="4"/>
<contactref element="R5" pad="2"/>
<contactref element="C3" pad="-"/>
<contactref element="C6" pad="2"/>
<wire x1="32.89" y1="50.8" x2="32.89" y2="53.21" width="2.032" layer="16"/>
<wire x1="32.89" y1="53.21" x2="33.02" y2="53.34" width="1.6764" layer="16"/>
<wire x1="36.83" y1="55.728" x2="36.678" y2="55.728" width="0.6096" layer="16"/>
<wire x1="36.678" y1="55.728" x2="34.925" y2="53.975" width="0.6096" layer="16"/>
<wire x1="34.925" y1="53.975" x2="33.02" y2="53.975" width="0.6096" layer="16"/>
<contactref element="Q1" pad="E"/>
<contactref element="D2" pad="A"/>
<wire x1="33.02" y1="76.2" x2="33.02" y2="74.295" width="2.032" layer="16"/>
<wire x1="33.02" y1="74.295" x2="33.02" y2="73.025" width="2.032" layer="16"/>
<wire x1="33.02" y1="73.025" x2="33.02" y2="72.39" width="0.6096" layer="16"/>
<wire x1="33.02" y1="72.39" x2="34.375" y2="72.39" width="0.6096" layer="16"/>
<contactref element="C1" pad="2"/>
<contactref element="C2" pad="2"/>
<wire x1="32.537" y1="64.135" x2="32.537" y2="61.617" width="1.6764" layer="16"/>
<wire x1="32.537" y1="61.617" x2="32.515" y2="61.595" width="1.6764" layer="16"/>
<wire x1="32.537" y1="61.617" x2="32.537" y2="53.823" width="1.6764" layer="16"/>
<wire x1="32.537" y1="53.823" x2="33.02" y2="53.34" width="1.6764" layer="16"/>
<wire x1="30.48" y1="50.8" x2="32.89" y2="50.8" width="2.032" layer="16"/>
<wire x1="28.575" y1="52.575" x2="28.575" y2="48.895" width="0.6096" layer="16"/>
<wire x1="28.575" y1="48.895" x2="28.2575" y2="48.5775" width="0.6096" layer="16"/>
<wire x1="26.67" y1="64.195" x2="27.305" y2="64.195" width="0.8128" layer="16"/>
<wire x1="27.305" y1="64.195" x2="32.477" y2="64.195" width="0.8128" layer="16"/>
<wire x1="32.477" y1="64.195" x2="32.537" y2="64.135" width="0.6096" layer="16"/>
<polygon width="0.6096" layer="16" isolate="0.6096">
<vertex x="7.3025" y="86.36"/>
<vertex x="49.8475" y="86.36"/>
<vertex x="49.8475" y="40.3225"/>
<vertex x="7.3025" y="40.3225"/>
</polygon>
<contactref element="R2" pad="1"/>
<contactref element="T1" pad="C"/>
<wire x1="27.7745" y1="67.6275" x2="27.7745" y2="68.428" width="0.8128" layer="16"/>
<wire x1="27.7745" y1="68.428" x2="26.67" y2="69.5325" width="0.8128" layer="16"/>
<wire x1="26.67" y1="69.5325" x2="25.8875" y2="69.5325" width="0.8128" layer="16"/>
<wire x1="25.8875" y1="69.5325" x2="25.7175" y2="69.7025" width="0.6096" layer="16"/>
<wire x1="27.7745" y1="67.6275" x2="27.7745" y2="64.6645" width="0.8128" layer="16"/>
<wire x1="27.7745" y1="64.6645" x2="27.305" y2="64.195" width="0.8128" layer="16"/>
<wire x1="33.02" y1="74.295" x2="33.02" y2="72.7075" width="1.6764" layer="16"/>
<wire x1="33.02" y1="72.7075" x2="32.7025" y2="72.39" width="1.6764" layer="16"/>
<wire x1="32.7025" y1="72.39" x2="32.7025" y2="51.1175" width="1.6764" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="C4" pad="+"/>
<contactref element="X1" pad="1"/>
<contactref element="C5" pad="1"/>
<wire x1="21.6662" y1="44.45" x2="21.6662" y2="45.6438" width="2.032" layer="16"/>
<wire x1="21.6662" y1="45.6438" x2="16.51" y2="50.8" width="2.032" layer="16"/>
<wire x1="16.51" y1="50.8" x2="16.51" y2="53.34" width="2.032" layer="16"/>
<wire x1="16.51" y1="53.34" x2="16.51" y2="52.07" width="1.6764" layer="16"/>
<wire x1="16.51" y1="52.07" x2="17.78" y2="50.8" width="1.6764" layer="16"/>
<wire x1="17.78" y1="50.8" x2="19.05" y2="50.8" width="1.6764" layer="16"/>
<contactref element="IC1" pad="6"/>
<contactref element="R1" pad="2"/>
<contactref element="R3" pad="2"/>
<wire x1="16.51" y1="53.34" x2="16.51" y2="55.88" width="2.032" layer="16"/>
<wire x1="16.51" y1="55.88" x2="17.145" y2="55.88" width="1.6764" layer="16"/>
<wire x1="17.145" y1="55.88" x2="17.145" y2="55.728" width="1.6764" layer="16"/>
<wire x1="17.145" y1="55.728" x2="14.605" y2="55.728" width="1.6764" layer="16"/>
<wire x1="25.4" y1="58.995" x2="25.4" y2="56.515" width="0.6096" layer="16"/>
<wire x1="25.4" y1="56.515" x2="24.765" y2="55.88" width="0.6096" layer="16"/>
<wire x1="24.765" y1="55.88" x2="17.297" y2="55.88" width="0.6096" layer="16"/>
<wire x1="17.297" y1="55.88" x2="17.145" y2="55.728" width="0.6096" layer="16"/>
<wire x1="19.05" y1="50.8" x2="18.92" y2="50.8" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$11">
<contactref element="R6" pad="1"/>
<contactref element="C3" pad="+"/>
<contactref element="D1" pad="C"/>
<contactref element="X1" pad="3"/>
<contactref element="C6" pad="1"/>
<wire x1="38.1" y1="53.34" x2="38.1" y2="53.21" width="1.6764" layer="16"/>
<wire x1="38.1" y1="53.21" x2="35.69" y2="50.8" width="2.032" layer="16"/>
<wire x1="35.69" y1="50.8" x2="35.69" y2="48.4662" width="2.032" layer="16"/>
<wire x1="35.69" y1="48.4662" x2="31.6738" y2="44.45" width="2.032" layer="16"/>
<wire x1="38.1" y1="53.34" x2="39.37" y2="54.61" width="2.032" layer="16"/>
<wire x1="39.37" y1="54.61" x2="39.37" y2="59.69" width="2.032" layer="16"/>
<wire x1="37.617" y1="60.96" x2="39.37" y2="60.96" width="0.6096" layer="16"/>
<wire x1="39.37" y1="60.96" x2="39.37" y2="59.69" width="0.6096" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="Q1" pad="C"/>
<contactref element="D1" pad="A"/>
<contactref element="L1" pad="2"/>
<wire x1="30.48" y1="76.2" x2="30.48" y2="79.375" width="2.032" layer="16"/>
<wire x1="30.48" y1="79.375" x2="19.05" y2="79.375" width="2.032" layer="16"/>
<wire x1="19.05" y1="79.375" x2="17.78" y2="78.105" width="2.032" layer="16"/>
<wire x1="17.78" y1="78.105" x2="17.78" y2="72.39" width="2.032" layer="16"/>
<wire x1="30.48" y1="79.375" x2="35.8775" y2="79.375" width="2.032" layer="16"/>
<wire x1="35.8775" y1="79.375" x2="39.37" y2="75.8825" width="2.032" layer="16"/>
<wire x1="39.37" y1="75.8825" x2="39.37" y2="74.6125" width="2.032" layer="16"/>
<wire x1="39.37" y1="74.6125" x2="39.37" y2="74.93" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$1">
<contactref element="R1" pad="1"/>
<contactref element="R3" pad="1"/>
<contactref element="IC1" pad="7"/>
<contactref element="L1" pad="1"/>
<contactref element="IC1" pad="1"/>
<contactref element="R7" pad="2"/>
<wire x1="14.605" y1="58.572" x2="15.875" y2="58.572" width="1.6764" layer="16"/>
<wire x1="15.875" y1="58.572" x2="17.145" y2="58.572" width="1.6764" layer="16"/>
<wire x1="15.723" y1="61.595" x2="15.875" y2="61.595" width="1.6764" layer="16"/>
<wire x1="15.875" y1="61.595" x2="15.875" y2="58.7375" width="2.032" layer="16"/>
<wire x1="15.875" y1="58.7375" x2="15.875" y2="58.572" width="2.032" layer="16"/>
<wire x1="15.875" y1="61.595" x2="15.875" y2="64.77" width="2.032" layer="16"/>
<wire x1="15.875" y1="64.77" x2="16.51" y2="65.405" width="2.032" layer="16"/>
<wire x1="16.51" y1="65.405" x2="17.78" y2="65.405" width="2.032" layer="16"/>
<wire x1="17.78" y1="65.405" x2="21.65" y2="65.405" width="0.6096" layer="16"/>
<wire x1="21.65" y1="65.405" x2="22.86" y2="64.195" width="0.6096" layer="16"/>
<wire x1="22.86" y1="64.195" x2="22.86" y2="62.865" width="0.6096" layer="16"/>
<wire x1="22.86" y1="62.865" x2="24.13" y2="61.595" width="0.6096" layer="16"/>
<wire x1="24.13" y1="61.595" x2="24.13" y2="58.995" width="0.6096" layer="16"/>
<wire x1="15.875" y1="58.7375" x2="20.955" y2="58.7375" width="1.6764" layer="16"/>
<wire x1="20.955" y1="58.7375" x2="20.32" y2="59.3725" width="1.6764" layer="16"/>
<wire x1="20.32" y1="59.3725" x2="16.1925" y2="59.3725" width="1.6764" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="IC1" pad="3"/>
<contactref element="C1" pad="1"/>
<wire x1="29.715" y1="61.595" x2="26.035" y2="61.595" width="0.6096" layer="16"/>
<wire x1="26.035" y1="61.595" x2="25.4" y2="62.23" width="0.6096" layer="16"/>
<wire x1="25.4" y1="62.23" x2="25.4" y2="64.195" width="0.6096" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="IC1" pad="5"/>
<contactref element="R5" pad="1"/>
<contactref element="R6" pad="2"/>
<contactref element="C2" pad="1"/>
<wire x1="26.67" y1="58.995" x2="26.67" y2="58.42" width="0.6096" layer="16"/>
<wire x1="26.67" y1="58.42" x2="26.67" y2="55.88" width="0.6096" layer="16"/>
<wire x1="26.67" y1="55.88" x2="27.305" y2="55.245" width="0.6096" layer="16"/>
<wire x1="27.305" y1="55.245" x2="28.445" y2="55.245" width="0.6096" layer="16"/>
<wire x1="28.445" y1="55.245" x2="28.575" y2="55.375" width="0.6096" layer="16"/>
<wire x1="36.83" y1="58.572" x2="35.408" y2="58.572" width="0.6096" layer="16"/>
<wire x1="35.408" y1="58.572" x2="34.925" y2="59.055" width="0.6096" layer="16"/>
<wire x1="34.925" y1="59.055" x2="34.925" y2="60.808" width="0.6096" layer="16"/>
<wire x1="34.925" y1="60.808" x2="34.773" y2="60.96" width="0.6096" layer="16"/>
<wire x1="34.925" y1="59.055" x2="34.6075" y2="58.7375" width="0.6096" layer="16"/>
<via x="34.6075" y="58.7375" extent="1-16" drill="0.5" diameter="1.4224" shape="square"/>
<wire x1="34.6075" y1="58.7375" x2="29.5275" y2="58.7375" width="0.6096" layer="1"/>
<via x="29.5275" y="58.7375" extent="1-16" drill="0.5" diameter="1.4224" shape="square"/>
<wire x1="29.5275" y1="58.7375" x2="26.9875" y2="58.7375" width="0.6096" layer="16"/>
<wire x1="26.9875" y1="58.7375" x2="26.67" y2="58.42" width="0.6096" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="IC1" pad="8"/>
<contactref element="R7" pad="1"/>
<wire x1="22.86" y1="58.995" x2="22.86" y2="59.69" width="0.6096" layer="16"/>
<wire x1="22.86" y1="59.69" x2="20.955" y2="61.595" width="0.6096" layer="16"/>
<wire x1="20.955" y1="61.595" x2="18.567" y2="61.595" width="0.6096" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="D2" pad="C"/>
<wire x1="29.21" y1="72.305" x2="29.125" y2="72.39" width="1.6764" layer="16"/>
<contactref element="Q1" pad="B"/>
<wire x1="27.788" y1="76.352" x2="27.94" y2="76.2" width="0.6096" layer="16"/>
<wire x1="27.94" y1="76.2" x2="27.94" y2="74.295" width="0.8128" layer="16"/>
<wire x1="27.94" y1="74.295" x2="29.21" y2="73.025" width="0.8128" layer="16"/>
<wire x1="29.21" y1="73.025" x2="29.21" y2="72.39" width="0.6096" layer="16"/>
<wire x1="27.305" y1="76.2" x2="27.94" y2="76.2" width="0.8128" layer="16"/>
<contactref element="D3" pad="C"/>
<contactref element="T1" pad="E"/>
<wire x1="26.6675" y1="71.9025" x2="26.6675" y2="73.775" width="0.8128" layer="16"/>
<wire x1="26.6675" y1="73.775" x2="25.83" y2="74.6125" width="0.6096" layer="16"/>
<wire x1="25.83" y1="74.6125" x2="26.3525" y2="74.6125" width="0.6096" layer="16"/>
<wire x1="26.3525" y1="74.6125" x2="27.94" y2="76.2" width="0.8128" layer="16"/>
<wire x1="29.21" y1="72.39" x2="29.125" y2="72.39" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$2">
<contactref element="D3" pad="A"/>
<contactref element="T1" pad="B"/>
<contactref element="R4" pad="1"/>
<wire x1="24.7675" y1="71.9025" x2="23.173" y2="71.9025" width="0.8128" layer="16"/>
<wire x1="23.173" y1="71.9025" x2="22.5425" y2="71.272" width="0.6096" layer="16"/>
<wire x1="22.43" y1="74.6125" x2="22.43" y2="71.3845" width="0.8128" layer="16"/>
<wire x1="22.43" y1="71.3845" x2="22.5425" y2="71.272" width="0.6096" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="IC1" pad="2"/>
<contactref element="R2" pad="2"/>
<contactref element="R4" pad="2"/>
<wire x1="24.13" y1="64.195" x2="24.13" y2="67.31" width="0.6096" layer="16"/>
<wire x1="24.13" y1="67.31" x2="24.4475" y2="67.6275" width="0.6096" layer="16"/>
<wire x1="24.4475" y1="67.6275" x2="24.9305" y2="67.6275" width="0.6096" layer="16"/>
<wire x1="24.9305" y1="67.6275" x2="23.343" y2="67.6275" width="0.6096" layer="16"/>
<wire x1="23.343" y1="67.6275" x2="22.5425" y2="68.428" width="0.6096" layer="16"/>
<wire x1="24.9305" y1="67.6275" x2="25.0825" y2="67.6275" width="0.6096" layer="16"/>
</signal>
<signal name="N$8">
<wire x1="16.1925" y1="55.88" x2="14.9225" y2="55.88" width="1.6764" layer="16"/>
<wire x1="14.9225" y1="55.88" x2="14.605" y2="56.1975" width="1.6764" layer="16"/>
<wire x1="14.605" y1="56.1975" x2="20.955" y2="56.1975" width="1.6764" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
