<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.4">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="15" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="15" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="15" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="15" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="116" name="centerDrill" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="-10.16" y1="-6.35" x2="79.99" y2="-6.35" width="0.254" layer="20"/>
<wire x1="79.99" y1="-6.35" x2="79.99" y2="33.96" width="0.254" layer="20"/>
<wire x1="79.99" y1="33.96" x2="-10.16" y2="33.96" width="0.254" layer="20"/>
<wire x1="-10.16" y1="33.96" x2="-10.16" y2="-6.35" width="0.254" layer="20"/>
<wire x1="15.875" y1="7.62" x2="15.875" y2="5.715" width="0.8128" layer="42"/>
<wire x1="15.875" y1="5.715" x2="16.51" y2="5.08" width="0.8128" layer="42"/>
<wire x1="12.7" y1="22.86" x2="12.7" y2="26.67" width="0.8128" layer="42"/>
<text x="45.72" y="-3.81" size="1.778" layer="16" rot="MR0">ESR-Meter</text>
<circle x="5.08" y="25.4" radius="0.379" width="0.358" layer="116"/>
<circle x="5.08" y="20.32" radius="0.379" width="0.358" layer="116"/>
<circle x="12.7" y="15.24" radius="0.328" width="0.256" layer="116"/>
<circle x="12.7" y="12.7" radius="0.328" width="0.256" layer="116"/>
<circle x="5.08" y="7.62" radius="0.379" width="0.358" layer="116"/>
<circle x="5.08" y="2.54" radius="0.379" width="0.358" layer="116"/>
<circle x="50.8" y="8.89" radius="0.328" width="0.256" layer="116"/>
<circle x="48.26" y="8.89" radius="0.328" width="0.256" layer="116"/>
<circle x="71.755" y="15.24" radius="0.328" width="0.256" layer="116"/>
<circle x="71.755" y="12.7" radius="0.328" width="0.256" layer="116"/>
<circle x="-2.54" y="19.05" radius="0.328" width="0.256" layer="116"/>
<circle x="-2.54" y="26.67" radius="0.328" width="0.256" layer="116"/>
<circle x="-2.54" y="1.27" radius="0.328" width="0.256" layer="116"/>
<circle x="-2.54" y="8.89" radius="0.328" width="0.256" layer="116"/>
<circle x="12.7" y="19.05" radius="0.328" width="0.256" layer="116"/>
<circle x="12.7" y="26.67" radius="0.328" width="0.256" layer="116"/>
<circle x="43.18" y="24.13" radius="0.474" width="0.548" layer="116"/>
<circle x="49.53" y="24.13" radius="0.474" width="0.548" layer="116"/>
<circle x="0" y="13.97" radius="0.474" width="0.548" layer="116"/>
<circle x="4.445" y="13.97" radius="0.328" width="0.256" layer="116"/>
<circle x="6.35" y="15.24" radius="0.328" width="0.256" layer="116"/>
<circle x="6.35" y="12.7" radius="0.328" width="0.256" layer="116"/>
<circle x="21.59" y="17.645" radius="0.375" width="0.35" layer="116"/>
<circle x="21.59" y="24.265" radius="0.375" width="0.35" layer="116"/>
<circle x="41.91" y="10.795" radius="0.328" width="0.256" layer="116"/>
<circle x="39.37" y="10.795" radius="0.328" width="0.256" layer="116"/>
<circle x="69.215" y="22.86" radius="0.474" width="0.548" layer="116"/>
<circle x="69.215" y="5.08" radius="0.474" width="0.548" layer="116"/>
<circle x="18.415" y="6.35" radius="0.328" width="0.256" layer="116"/>
<circle x="16.51" y="5.08" radius="0.328" width="0.256" layer="116"/>
<circle x="18.415" y="3.81" radius="0.328" width="0.256" layer="116"/>
<circle x="18.415" y="10.16" radius="0.328" width="0.256" layer="116"/>
<circle x="20.32" y="11.43" radius="0.328" width="0.256" layer="116"/>
<circle x="18.415" y="12.7" radius="0.328" width="0.256" layer="116"/>
<circle x="26.035" y="3.81" radius="0.328" width="0.256" layer="116"/>
<circle x="26.035" y="8.89" radius="0.328" width="0.256" layer="116"/>
<circle x="26.035" y="6.35" radius="0.328" width="0.256" layer="116"/>
<circle x="62.23" y="24.13" radius="0.328" width="0.256" layer="116"/>
<circle x="62.23" y="19.05" radius="0.328" width="0.256" layer="116"/>
<circle x="62.23" y="21.59" radius="0.328" width="0.256" layer="116"/>
<circle x="55.88" y="24.13" radius="0.328" width="0.256" layer="116"/>
<circle x="55.88" y="19.05" radius="0.328" width="0.256" layer="116"/>
<circle x="55.88" y="21.59" radius="0.328" width="0.256" layer="116"/>
<circle x="62.865" y="12.065" radius="0.474" width="0.548" layer="116"/>
<circle x="58.42" y="8.255" radius="0.474" width="0.548" layer="116"/>
<circle x="62.865" y="5.08" radius="0.474" width="0.548" layer="116"/>
<circle x="54.61" y="12.065" radius="0.474" width="0.548" layer="116"/>
<circle x="54.61" y="5.08" radius="0.474" width="0.548" layer="116"/>
<circle x="34.29" y="15.24" radius="0.328" width="0.256" layer="116"/>
<circle x="33.02" y="13.335" radius="0.328" width="0.256" layer="116"/>
<circle x="31.75" y="15.24" radius="0.328" width="0.256" layer="116"/>
<circle x="31.75" y="20.32" radius="0.328" width="0.256" layer="116"/>
<circle x="33.02" y="22.225" radius="0.328" width="0.256" layer="116"/>
<circle x="34.29" y="20.32" radius="0.328" width="0.256" layer="116"/>
<circle x="76.2" y="30.48" radius="0.825" width="1.25" layer="116"/>
<circle x="76.2" y="-2.54" radius="0.825" width="1.25" layer="116"/>
<circle x="-6.35" y="-2.54" radius="0.825" width="1.25" layer="116"/>
<circle x="-6.35" y="30.48" radius="0.825" width="1.25" layer="116"/>
<circle x="-6.35" y="22.86" radius="0.474" width="0.548" layer="116"/>
<circle x="-6.35" y="5.08" radius="0.474" width="0.548" layer="116"/>
<circle x="-6.35" y="13.97" radius="0.474" width="0.548" layer="116"/>
<circle x="29.845" y="3.81" radius="0.325" width="0.25" layer="116"/>
<circle x="43.815" y="3.81" radius="0.325" width="0.25" layer="116"/>
</plain>
<libraries>
<library name="rcl">
<packages>
<package name="E5-10,5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="E2,5-6E">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.159" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.254" x2="-2.413" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="M1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
MELF 0.25 W</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="C1206">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
</packages>
</library>
<library name="v-reg">
<packages>
<package name="78LXX">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-0.7863" y2="2.5485" width="0.1524" layer="21" curve="-111.098957"/>
<wire x1="0.7868" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.09954"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.1524" layer="51" curve="-34.293591"/>
<pad name="OUT" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="GND" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="IN" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-0.635" y="0.889" size="1.27" layer="51" ratio="10">-</text>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.778" y="-0.635" size="1.27" layer="51" ratio="10">O</text>
<text x="0.635" y="-0.635" size="1.27" layer="51" ratio="10">I</text>
</package>
</packages>
</library>
<library name="pot">
<packages>
<package name="S64W">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;&lt;p&gt;
Spectrol</description>
<wire x1="-4.826" y1="-1.27" x2="4.826" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.064" y1="0.508" x2="3.048" y2="-0.508" width="0.3048" layer="21"/>
<wire x1="-4.826" y1="3.81" x2="4.826" y2="3.81" width="0.1524" layer="21"/>
<wire x1="4.826" y1="3.81" x2="4.826" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.27" x2="-4.826" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0" x2="-2.413" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="0" x2="-2.159" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="0" x2="-2.159" y2="0.127" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="-0.254" x2="-2.286" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="-0.254" x2="-2.413" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="0.254" x2="-2.413" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-0.127" x2="-2.159" y2="0.127" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-0.127" x2="-2.286" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="0.127" x2="-2.286" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="0" x2="-2.413" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.381" x2="-2.413" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.508" x2="-2.413" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="0.381" x2="-2.54" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0.508" x2="-2.54" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="0" x2="-2.413" y2="0" width="0.1524" layer="51"/>
<circle x="3.556" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="3.556" y="0" radius="0.635" width="0.0508" layer="21"/>
<pad name="A" x="2.54" y="1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="S" x="0" y="1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-4.826" y="4.1402" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.8006" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="1.905" size="1.27" layer="21" ratio="10">3</text>
<text x="3.556" y="1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-1.905" y="-0.635" size="1.27" layer="51" ratio="10">3</text>
</package>
</packages>
</library>
<library name="linear">
<packages>
<package name="SO08">
<description>&lt;b&gt;Small Outline Package 8&lt;/b&gt;&lt;br&gt;
NS Package M08A</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
</library>
<library name="led">
<packages>
<package name="LED3MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-fet">
<packages>
<package name="TO92">
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-2.6549" y2="-0.254" width="0.127" layer="21" curve="-32.78104"/>
<wire x1="-2.6549" y1="-0.254" x2="-0.7863" y2="2.5485" width="0.127" layer="21" curve="-78.318477"/>
<wire x1="0.7863" y1="2.5484" x2="2.0945" y2="-1.651" width="0.127" layer="21" curve="-111.09954"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.2537" y1="-0.254" x2="-0.2863" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.2863" y1="-0.254" x2="2.2537" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.127" layer="51" curve="-34.293591"/>
<pad name="1" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-0.635" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-2.159" y="0" size="1.27" layer="51" ratio="10">3</text>
<text x="1.143" y="0" size="1.27" layer="51" ratio="10">1</text>
</package>
</packages>
</library>
<library name="gabor-lib">
<packages>
<package name="D1206">
<wire x1="0.5" y1="0.5" x2="-0.5" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.5" y1="0" x2="0.5" y2="-0.5" width="0.2032" layer="21"/>
<wire x1="0.5" y1="-0.5" x2="0.5" y2="0.5" width="0.2032" layer="21"/>
<rectangle x1="-0.6096" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
<package name="TO92-CBE">
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="1.016" y="0" size="1.27" layer="51" ratio="10">3</text>
<text x="-2.032" y="0" size="1.27" layer="51" ratio="10">1</text>
</package>
<package name="RADIALINDUCTOR">
<description>&lt;b&gt;Radial Lead RF Chokes&lt;/b&gt;&lt;p&gt;
Grid: 7mm, Diameter:11,7mm</description>
<circle x="0" y="0" radius="5.85" width="0.127" layer="21"/>
<pad name="1" x="-3.31" y="0" drill="1" diameter="2.54" shape="octagon"/>
<pad name="2" x="3.31" y="0" drill="1" diameter="2.54" shape="octagon"/>
<text x="-5.7756" y="5.9026" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.7756" y="-7.6806" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<packages>
<package name="DO35-7">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="solpad">
<description>&lt;b&gt;Solder Pads/Test Points&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SE14">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt;
drill 1.4 mm</description>
<wire x1="-1.524" y1="0.635" x2="-1.524" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="1.524" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.524" x2="1.524" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.635" x2="1.524" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.524" x2="0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-1.524" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="0.381" width="0.254" layer="51"/>
<pad name="MP" x="0" y="0" drill="1.397" diameter="2.54" shape="octagon"/>
<text x="-1.397" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.381" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="2,8">
<description>&lt;b&gt;MOUNTING HOLE&lt;/b&gt; 2.8 mm with drill center</description>
<wire x1="-1.778" y1="0" x2="0" y2="-1.778" width="2.286" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="1.778" x2="1.778" y2="0" width="2.286" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="0.635" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="2.032" layer="40"/>
<circle x="0" y="0" radius="2.54" width="2.032" layer="39"/>
<circle x="0" y="0" radius="2.54" width="2.032" layer="41"/>
<circle x="0" y="0" radius="2.54" width="2.032" layer="42"/>
<circle x="0" y="0" radius="2.54" width="2.032" layer="43"/>
<circle x="0" y="0" radius="1.5" width="0.2032" layer="21"/>
<hole x="0" y="0" drill="2.8"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
</autorouter>
<elements>
<element name="D1" library="diode" package="DO35-7" value="1N4148" x="-2.54" y="22.86" smashed="yes" rot="R270">
<attribute name="NAME" x="-0.381" y="29.845" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-1.397" y="25.654" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="D4" library="diode" package="DO35-7" value="1N4148" x="-2.54" y="5.08" smashed="yes" rot="R270">
<attribute name="NAME" x="-2.794" y="-1.905" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-5.207" y="8.509" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C1" library="rcl" package="E5-10,5" value="470uF/16V" x="5.08" y="22.86" smashed="yes" rot="R270">
<attribute name="NAME" x="4.064" y="28.7782" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="1.8542" y="25.9842" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C6" library="rcl" package="E5-10,5" value="470uF/16V" x="5.08" y="5.08" smashed="yes" rot="R270">
<attribute name="NAME" x="4.064" y="-1.7018" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="1.8542" y="8.2042" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="IC1" library="v-reg" package="78LXX" value="78L05" x="6.35" y="13.97" smashed="yes" rot="R90">
<attribute name="NAME" x="10.16" y="17.78" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="7.62" y="17.145" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C2" library="rcl" package="E2,5-6E" value="10uF/6V" x="12.7" y="13.97" smashed="yes" rot="R270">
<attribute name="NAME" x="11.557" y="9.144" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="9.017" y="9.525" size="1.27" layer="27" ratio="10"/>
</element>
<element name="L1" library="gabor-lib" package="RADIALINDUCTOR" value="11mH" x="21.59" y="20.955" smashed="yes" rot="R90">
<attribute name="NAME" x="20.8944" y="27.4926" size="1.27" layer="25"/>
<attribute name="VALUE" x="24.1906" y="21.6506" size="1.27" layer="27" rot="R180"/>
</element>
<element name="C3" library="rcl" package="C1206" value="220pF" x="24.13" y="20.955" smashed="yes" rot="MR270">
<attribute name="NAME" x="22.86" y="24.13" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="26.67" y="22.225" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="C5" library="rcl" package="C1206" value="220pF" x="26.035" y="14.605" smashed="yes" rot="MR180">
<attribute name="NAME" x="21.59" y="15.24" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="24.765" y="17.145" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="R10" library="rcl" package="M1206" value="12k" x="15.875" y="8.89" smashed="yes" rot="MR270">
<attribute name="NAME" x="14.605" y="10.16" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="18.415" y="10.16" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="R2" library="rcl" package="M1206" value="100k" x="26.035" y="11.43" smashed="yes" rot="MR0">
<attribute name="NAME" x="23.495" y="10.795" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="27.305" y="8.89" size="1.27" layer="28" rot="MR0"/>
</element>
<element name="R5" library="pot" package="S64W" value="1k" x="24.765" y="6.35" rot="R270"/>
<element name="IC3" library="linear" package="SO08" value="TL071D" x="33.655" y="6.985" smashed="yes" rot="MR0">
<attribute name="NAME" x="30.988" y="7.62" size="1.27" layer="26" rot="MR270"/>
<attribute name="VALUE" x="29.718" y="5.08" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R11" library="rcl" package="M1206" value="6.8k" x="40.64" y="5.08" smashed="yes" rot="MR270">
<attribute name="NAME" x="39.37" y="8.89" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="43.18" y="6.35" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="LED1" library="led" package="LED3MM" value="" x="40.64" y="10.795" smashed="yes" rot="R180">
<attribute name="NAME" x="38.735" y="14.351" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="38.735" y="12.446" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R8" library="rcl" package="M1206" value="12" x="47.625" y="16.51" smashed="yes" rot="MR90">
<attribute name="NAME" x="48.895" y="12.7" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="45.085" y="15.24" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R7" library="rcl" package="M1206" value="12" x="43.815" y="16.51" smashed="yes" rot="MR90">
<attribute name="NAME" x="45.085" y="12.7" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="41.275" y="15.24" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R6" library="rcl" package="M1206" value="0.3" x="50.8" y="16.51" smashed="yes" rot="MR90">
<attribute name="NAME" x="50.165" y="12.065" size="1.27" layer="26" rot="MR90"/>
<attribute name="VALUE" x="48.26" y="15.24" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="IC2" library="linear" package="SO08" value="LM318D" x="66.04" y="-0.635" smashed="yes" rot="MR90">
<attribute name="NAME" x="64.77" y="3.683" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="64.135" y="3.302" size="1.27" layer="28" rot="MR180"/>
</element>
<element name="D3" library="gabor-lib" package="D1206" value="1N4148" x="74.295" y="17.145" smashed="yes" rot="MR270">
<attribute name="NAME" x="73.66" y="22.225" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="76.835" y="18.415" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="D2" library="gabor-lib" package="D1206" value="1N4148" x="69.215" y="17.145" smashed="yes" rot="MR270">
<attribute name="NAME" x="68.326" y="14.605" size="1.27" layer="26" ratio="10" rot="MR180"/>
<attribute name="VALUE" x="71.882" y="19.304" size="1.27" layer="28" ratio="10" rot="MR270"/>
</element>
<element name="R12" library="rcl" package="M1206" value="100" x="39.37" y="16.51" smashed="yes" rot="MR90">
<attribute name="NAME" x="40.64" y="19.05" size="1.27" layer="26" rot="MR0"/>
<attribute name="VALUE" x="36.83" y="15.24" size="1.27" layer="28" rot="MR90"/>
</element>
<element name="R4" library="rcl" package="M1206" value="12k" x="20.955" y="7.62" smashed="yes" rot="MR270">
<attribute name="NAME" x="19.685" y="10.795" size="1.27" layer="26" rot="MR180"/>
<attribute name="VALUE" x="23.495" y="7.62" size="1.27" layer="28" rot="MR270"/>
</element>
<element name="T2" library="gabor-lib" package="TO92-CBE" value="BC182" x="33.02" y="20.32" smashed="yes">
<attribute name="NAME" x="34.29" y="24.765" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="36.195" y="19.05" size="1.27" layer="27" ratio="10"/>
</element>
<element name="T1" library="gabor-lib" package="TO92-CBE" value="BC182" x="33.02" y="15.24" smashed="yes" rot="R180">
<attribute name="NAME" x="31.75" y="10.795" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="29.845" y="16.51" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="Q1" library="transistor-fet" package="TO92" value="2N3819" x="18.415" y="5.08" smashed="yes" rot="R90">
<attribute name="NAME" x="19.685" y="1.905" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="15.24" y="1.905" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="Q3" library="transistor-fet" package="TO92" value="2N3820" x="18.415" y="11.43" smashed="yes" rot="R270">
<attribute name="NAME" x="17.145" y="14.605" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="21.59" y="14.605" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="GND" library="solpad" package="SE14" value="SE14" x="0" y="13.97"/>
<element name="~" library="solpad" package="SE14" value="SE14" x="-6.35" y="13.97"/>
<element name="V-" library="solpad" package="SE14" value="SE14" x="-6.35" y="5.08"/>
<element name="V+" library="solpad" package="SE14" value="SE14" x="-6.35" y="22.86"/>
<element name="D5" library="diode" package="DO35-7" value="1N4148" x="12.7" y="22.86" smashed="yes" rot="R270">
<attribute name="NAME" x="12.954" y="28.575" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="10.033" y="25.146" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R13" library="rcl" package="M1206" value="0.3" x="55.245" y="15.24" rot="MR0"/>
<element name="R14" library="pot" package="S64W" value="200" x="63.5" y="21.59" smashed="yes" rot="R90">
<attribute name="NAME" x="63.246" y="28.8798" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="66.421" y="16.7894" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R15" library="pot" package="S64W" value="50" x="57.15" y="21.59" smashed="yes" rot="R90">
<attribute name="NAME" x="56.896" y="28.8798" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="60.071" y="16.7894" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C7" library="rcl" package="E2,5-6E" value="47uF" x="49.53" y="8.89" smashed="yes" rot="R180">
<attribute name="NAME" x="50.673" y="13.716" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="46.863" y="11.43" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C8" library="rcl" package="C1206" value="100nF" x="49.53" y="11.43" rot="MR180"/>
<element name="SW_5" library="solpad" package="SE14" value="SE14" x="54.61" y="5.08" smashed="yes">
<attribute name="NAME" x="49.403" y="1.778" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="54.61" y="5.461" size="0.0254" layer="27"/>
</element>
<element name="SW_4" library="solpad" package="SE14" value="SE14" x="54.61" y="12.065"/>
<element name="SW_3" library="solpad" package="SE14" value="SE14" x="62.865" y="5.08"/>
<element name="SW_1" library="solpad" package="SE14" value="SE14" x="62.865" y="12.065"/>
<element name="SW_2" library="solpad" package="SE14" value="SE14" x="58.42" y="8.255" smashed="yes" rot="R90">
<attribute name="NAME" x="61.087" y="3.302" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="58.039" y="8.255" size="0.0254" layer="27" rot="R90"/>
</element>
<element name="ESR1" library="solpad" package="SE14" value="SE14" x="43.18" y="24.13"/>
<element name="ESR2" library="solpad" package="SE14" value="SE14" x="49.53" y="24.13"/>
<element name="C9" library="rcl" package="E2,5-6E" value="47uF" x="71.755" y="13.97" smashed="yes" rot="R270">
<attribute name="NAME" x="71.247" y="17.399" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="69.215" y="11.303" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="D7" library="gabor-lib" package="D1206" value="1N4148" x="74.295" y="10.795" rot="MR270"/>
<element name="D8" library="gabor-lib" package="D1206" value="1N4148" x="69.215" y="10.795" rot="MR270"/>
<element name="M+" library="solpad" package="SE14" value="SE14" x="69.215" y="22.86"/>
<element name="M-" library="solpad" package="SE14" value="SE14" x="69.215" y="5.08"/>
<element name="U$1" library="holes" package="2,8" value="" x="76.2" y="30.48"/>
<element name="U$2" library="holes" package="2,8" value="" x="76.2" y="-2.54"/>
<element name="U$3" library="holes" package="2,8" value="" x="-6.35" y="-2.54"/>
<element name="U$4" library="holes" package="2,8" value="" x="-6.35" y="30.48"/>
</elements>
<signals>
<signal name="N$1">
<contactref element="D1" pad="A"/>
<contactref element="D4" pad="C"/>
<contactref element="~" pad="MP"/>
<polygon width="0.254" layer="16" isolate="0.254">
<vertex x="-10.16" y="20.32"/>
<vertex x="-5.08" y="20.32"/>
<vertex x="-3.81" y="21.59"/>
<vertex x="0" y="21.59"/>
<vertex x="0" y="6.35"/>
<vertex x="-3.81" y="6.35"/>
<vertex x="-5.08" y="7.62"/>
<vertex x="-10.16" y="7.62"/>
</polygon>
<wire x1="-2.54" y1="19.05" x2="-2.54" y2="13.97" width="0.8128" layer="16"/>
<wire x1="-2.54" y1="13.97" x2="-2.54" y2="8.89" width="0.8128" layer="16"/>
<wire x1="-6.35" y1="13.97" x2="-2.54" y2="13.97" width="0.8128" layer="16"/>
</signal>
<signal name="GND">
<contactref element="C1" pad="-"/>
<contactref element="C6" pad="+"/>
<contactref element="IC1" pad="GND"/>
<contactref element="C2" pad="-"/>
<contactref element="R5" pad="A"/>
<contactref element="R11" pad="2"/>
<contactref element="R8" pad="1"/>
<contactref element="Q1" pad="2"/>
<contactref element="R10" pad="2"/>
<wire x1="15.875" y1="5.715" x2="16.51" y2="5.08" width="0.8128" layer="16"/>
<wire x1="15.875" y1="7.49" x2="15.875" y2="5.715" width="0.8128" layer="16"/>
<contactref element="GND" pad="MP"/>
<wire x1="5.08" y1="20.32" x2="2.54" y2="20.32" width="0.8128" layer="16"/>
<wire x1="2.54" y1="20.32" x2="0" y2="17.78" width="0.8128" layer="16"/>
<wire x1="0" y1="17.78" x2="0" y2="13.97" width="0.8128" layer="16"/>
<wire x1="5.08" y1="7.62" x2="2.54" y2="7.62" width="0.8128" layer="16"/>
<wire x1="2.54" y1="7.62" x2="0" y2="10.16" width="0.8128" layer="16"/>
<wire x1="0" y1="10.16" x2="0" y2="13.97" width="0.8128" layer="16"/>
<wire x1="4.445" y1="13.97" x2="4.445" y2="17.145" width="0.8128" layer="16"/>
<wire x1="4.445" y1="17.145" x2="5.08" y2="17.78" width="0.8128" layer="16"/>
<wire x1="5.08" y1="17.78" x2="5.08" y2="20.32" width="0.8128" layer="16"/>
<wire x1="12.7" y1="12.7" x2="10.16" y2="12.7" width="0.8128" layer="16"/>
<wire x1="10.16" y1="12.7" x2="8.255" y2="10.795" width="0.8128" layer="16"/>
<wire x1="8.255" y1="10.795" x2="5.715" y2="10.795" width="0.8128" layer="16"/>
<wire x1="5.715" y1="10.795" x2="4.445" y2="12.065" width="0.8128" layer="16"/>
<wire x1="4.445" y1="12.065" x2="4.445" y2="13.97" width="0.8128" layer="16"/>
<wire x1="14.605" y1="1.905" x2="12.7" y2="3.81" width="0.8128" layer="16"/>
<wire x1="12.7" y1="3.81" x2="12.7" y2="7.62" width="0.8128" layer="16"/>
<wire x1="12.7" y1="7.62" x2="12.7" y2="12.7" width="0.8128" layer="16"/>
<wire x1="15.875" y1="7.49" x2="12.83" y2="7.49" width="0.8128" layer="16"/>
<wire x1="12.83" y1="7.49" x2="12.7" y2="7.62" width="0.8128" layer="16"/>
<wire x1="14.605" y1="1.905" x2="21.59" y2="1.905" width="0.8128" layer="16"/>
<wire x1="21.59" y1="1.905" x2="23.495" y2="3.81" width="0.8128" layer="16"/>
<wire x1="23.495" y1="3.81" x2="26.035" y2="3.81" width="0.8128" layer="16"/>
<wire x1="26.035" y1="3.81" x2="29.845" y2="3.81" width="0.8128" layer="16"/>
<via x="29.845" y="3.81" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="29.845" y1="3.81" x2="43.815" y2="3.81" width="0.8128" layer="1"/>
<via x="43.815" y="3.81" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="43.815" y1="3.81" x2="40.77" y2="3.81" width="0.8128" layer="16"/>
<wire x1="40.77" y1="3.81" x2="40.64" y2="3.68" width="0.8128" layer="16"/>
<contactref element="R7" pad="1"/>
<contactref element="C8" pad="1"/>
<contactref element="C7" pad="-"/>
<contactref element="SW_5" pad="MP"/>
<wire x1="43.815" y1="15.11" x2="45.72" y2="15.11" width="0.8128" layer="16"/>
<wire x1="45.72" y1="15.11" x2="47.625" y2="15.11" width="0.8128" layer="16"/>
<wire x1="43.815" y1="3.81" x2="43.815" y2="9.525" width="0.8128" layer="16"/>
<wire x1="43.815" y1="9.525" x2="45.72" y2="11.43" width="0.8128" layer="16"/>
<wire x1="45.72" y1="11.43" x2="45.72" y2="15.11" width="0.8128" layer="16"/>
<wire x1="48.26" y1="8.89" x2="48.26" y2="11.3" width="0.8128" layer="16"/>
<wire x1="48.26" y1="11.3" x2="48.13" y2="11.43" width="0.8128" layer="16"/>
<wire x1="43.815" y1="3.81" x2="45.72" y2="3.81" width="0.8128" layer="16"/>
<wire x1="45.72" y1="3.81" x2="46.355" y2="4.445" width="0.8128" layer="16"/>
<wire x1="46.355" y1="4.445" x2="46.355" y2="5.08" width="0.8128" layer="16"/>
<wire x1="46.355" y1="5.08" x2="46.355" y2="8.255" width="0.8128" layer="16"/>
<wire x1="46.355" y1="8.255" x2="46.99" y2="8.89" width="0.8128" layer="16"/>
<wire x1="46.99" y1="8.89" x2="48.26" y2="8.89" width="0.8128" layer="16"/>
<wire x1="54.61" y1="5.08" x2="46.355" y2="5.08" width="0.8128" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="C2" pad="+"/>
<contactref element="IC1" pad="OUT"/>
<contactref element="C3" pad="1"/>
<contactref element="L1" pad="2"/>
<contactref element="D5" pad="A"/>
<wire x1="12.7" y1="15.24" x2="12.7" y2="19.05" width="0.8128" layer="16"/>
<wire x1="6.35" y1="12.7" x2="7.62" y2="12.7" width="0.8128" layer="16"/>
<wire x1="7.62" y1="12.7" x2="10.16" y2="15.24" width="0.8128" layer="16"/>
<wire x1="10.16" y1="15.24" x2="12.7" y2="15.24" width="0.8128" layer="16"/>
<wire x1="21.59" y1="24.265" x2="23.36" y2="24.265" width="0.8128" layer="16"/>
<wire x1="23.36" y1="24.265" x2="24.13" y2="23.495" width="0.8128" layer="16"/>
<wire x1="24.13" y1="23.495" x2="24.13" y2="22.355" width="0.8128" layer="16"/>
<wire x1="21.59" y1="24.265" x2="16.51" y2="19.185" width="0.8128" layer="16"/>
<wire x1="16.51" y1="19.185" x2="16.51" y2="16.51" width="0.8128" layer="16"/>
<wire x1="16.51" y1="16.51" x2="15.24" y2="15.24" width="0.8128" layer="16"/>
<wire x1="15.24" y1="15.24" x2="12.7" y2="15.24" width="0.8128" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="C5" pad="2"/>
<contactref element="R2" pad="1"/>
<wire x1="27.435" y1="14.605" x2="27.435" y2="11.43" width="0.8128" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="R2" pad="2"/>
<contactref element="R5" pad="E"/>
<wire x1="24.635" y1="11.43" x2="24.635" y2="10.29" width="0.8128" layer="16"/>
<wire x1="24.635" y1="10.29" x2="26.035" y2="8.89" width="0.8128" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="IC3" pad="6"/>
<contactref element="T1" pad="2"/>
<wire x1="33.02" y1="13.335" x2="33.02" y2="9.585" width="0.6096" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="IC3" pad="3"/>
<contactref element="R5" pad="S"/>
<wire x1="26.035" y1="6.35" x2="32.385" y2="6.35" width="0.6096" layer="16"/>
<wire x1="32.385" y1="6.35" x2="33.02" y2="5.715" width="0.6096" layer="16"/>
<wire x1="33.02" y1="5.715" x2="33.02" y2="4.385" width="0.6096" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="R11" pad="1"/>
<contactref element="LED1" pad="A"/>
<contactref element="T2" pad="2"/>
<wire x1="41.91" y1="10.795" x2="40.64" y2="9.525" width="0.6096" layer="16"/>
<wire x1="40.64" y1="9.525" x2="40.64" y2="6.48" width="0.6096" layer="16"/>
<wire x1="33.02" y1="22.225" x2="40.005" y2="22.225" width="0.6096" layer="16"/>
<wire x1="40.005" y1="22.225" x2="41.91" y2="20.32" width="0.6096" layer="16"/>
<wire x1="41.91" y1="20.32" x2="41.91" y2="10.795" width="0.6096" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="R7" pad="2"/>
<contactref element="R8" pad="2"/>
<contactref element="R6" pad="2"/>
<contactref element="IC2" pad="3"/>
<contactref element="ESR2" pad="MP"/>
<wire x1="43.815" y1="17.91" x2="45.72" y2="17.91" width="0.8128" layer="16"/>
<wire x1="45.72" y1="17.91" x2="47.625" y2="17.91" width="0.8128" layer="16"/>
<wire x1="49.53" y1="24.13" x2="45.72" y2="20.32" width="0.8128" layer="16"/>
<wire x1="45.72" y1="20.32" x2="45.72" y2="17.91" width="0.8128" layer="16"/>
<wire x1="47.625" y1="17.91" x2="50.8" y2="17.91" width="0.8128" layer="16"/>
<wire x1="53.975" y1="17.145" x2="57.785" y2="17.145" width="0.6096" layer="16"/>
<wire x1="57.785" y1="17.145" x2="58.42" y2="16.51" width="0.6096" layer="16"/>
<wire x1="58.42" y1="16.51" x2="58.42" y2="12.065" width="0.6096" layer="16"/>
<wire x1="58.42" y1="12.065" x2="60.96" y2="9.525" width="0.6096" layer="16"/>
<wire x1="60.96" y1="9.525" x2="60.96" y2="6.985" width="0.6096" layer="16"/>
<wire x1="60.96" y1="6.985" x2="60.325" y2="6.35" width="0.6096" layer="16"/>
<wire x1="60.325" y1="6.35" x2="60.325" y2="3.81" width="0.6096" layer="16"/>
<wire x1="60.325" y1="3.81" x2="61.595" y2="2.54" width="0.6096" layer="16"/>
<wire x1="53.975" y1="17.145" x2="53.21" y2="17.91" width="0.6096" layer="16"/>
<wire x1="53.21" y1="17.91" x2="50.8" y2="17.91" width="0.6096" layer="16"/>
<wire x1="63.44" y1="0" x2="64.77" y2="0" width="0.6096" layer="16"/>
<wire x1="64.77" y1="0" x2="65.405" y2="0.635" width="0.6096" layer="16"/>
<wire x1="65.405" y1="0.635" x2="65.405" y2="1.905" width="0.6096" layer="16"/>
<wire x1="65.405" y1="1.905" x2="64.77" y2="2.54" width="0.6096" layer="16"/>
<wire x1="64.77" y1="2.54" x2="61.595" y2="2.54" width="0.6096" layer="16"/>
</signal>
<signal name="V+">
<contactref element="IC2" pad="7"/>
<contactref element="D1" pad="C"/>
<contactref element="C1" pad="+"/>
<contactref element="IC3" pad="7"/>
<contactref element="T1" pad="1"/>
<contactref element="V+" pad="MP"/>
<contactref element="IC1" pad="IN"/>
<contactref element="D5" pad="C"/>
<wire x1="-6.35" y1="22.86" x2="-6.35" y2="24.765" width="0.8128" layer="16"/>
<wire x1="-6.35" y1="24.765" x2="-4.445" y2="26.67" width="0.8128" layer="16"/>
<wire x1="-4.445" y1="26.67" x2="-2.54" y2="26.67" width="0.8128" layer="16"/>
<wire x1="-2.54" y1="26.67" x2="1.27" y2="26.67" width="0.8128" layer="16"/>
<wire x1="1.27" y1="26.67" x2="2.54" y2="25.4" width="0.8128" layer="16"/>
<wire x1="2.54" y1="25.4" x2="5.08" y2="25.4" width="0.8128" layer="16"/>
<wire x1="5.08" y1="25.4" x2="7.62" y2="25.4" width="0.8128" layer="16"/>
<wire x1="7.62" y1="25.4" x2="8.89" y2="26.67" width="0.8128" layer="16"/>
<wire x1="8.89" y1="26.67" x2="12.7" y2="26.67" width="0.8128" layer="16"/>
<wire x1="12.7" y1="22.86" x2="12.7" y2="26.67" width="0.8128" layer="16"/>
<wire x1="12.7" y1="26.67" x2="27.305" y2="26.67" width="0.8128" layer="16"/>
<wire x1="34.29" y1="9.585" x2="34.29" y2="8.255" width="0.6096" layer="16"/>
<wire x1="34.29" y1="8.255" x2="33.655" y2="7.62" width="0.6096" layer="16"/>
<wire x1="33.655" y1="7.62" x2="30.48" y2="7.62" width="0.6096" layer="16"/>
<wire x1="30.48" y1="7.62" x2="29.845" y2="8.255" width="0.6096" layer="16"/>
<wire x1="29.845" y1="8.255" x2="29.845" y2="15.24" width="0.6096" layer="16"/>
<wire x1="29.845" y1="15.24" x2="27.305" y2="17.78" width="0.6096" layer="16"/>
<wire x1="27.305" y1="17.78" x2="27.305" y2="26.67" width="0.6096" layer="16"/>
<wire x1="34.29" y1="15.24" x2="34.29" y2="9.585" width="0.6096" layer="16"/>
<polygon width="0.254" layer="16" isolate="0.254" rank="2">
<vertex x="-10.16" y="34.29"/>
<vertex x="8.89" y="34.29"/>
<vertex x="8.89" y="20.32"/>
</polygon>
<wire x1="27.305" y1="26.67" x2="70.485" y2="26.67" width="0.8128" layer="16"/>
<wire x1="70.485" y1="26.67" x2="77.47" y2="19.685" width="0.8128" layer="16"/>
<wire x1="77.47" y1="19.685" x2="77.47" y2="7.62" width="0.8128" layer="16"/>
<wire x1="77.47" y1="7.62" x2="76.2" y2="6.35" width="0.8128" layer="16"/>
<wire x1="76.2" y1="6.35" x2="74.93" y2="6.35" width="0.8128" layer="16"/>
<wire x1="74.93" y1="6.35" x2="73.025" y2="4.445" width="0.8128" layer="16"/>
<wire x1="73.025" y1="4.445" x2="73.025" y2="0.635" width="0.8128" layer="16"/>
<wire x1="73.025" y1="0.635" x2="71.12" y2="-1.27" width="0.8128" layer="16"/>
<wire x1="6.35" y1="15.24" x2="10.795" y2="19.685" width="0.8128" layer="16"/>
<wire x1="10.795" y1="19.685" x2="10.795" y2="20.955" width="0.8128" layer="16"/>
<wire x1="10.795" y1="20.955" x2="12.7" y2="22.86" width="0.8128" layer="16"/>
<wire x1="71.12" y1="-1.27" x2="69.85" y2="-1.27" width="0.8128" layer="16"/>
<wire x1="69.85" y1="-1.27" x2="68.64" y2="-1.27" width="0.6096" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="R12" pad="2"/>
<contactref element="T2" pad="3"/>
<wire x1="34.29" y1="20.32" x2="38.1" y2="20.32" width="0.6096" layer="16"/>
<wire x1="38.1" y1="20.32" x2="39.37" y2="19.05" width="0.6096" layer="16"/>
<wire x1="39.37" y1="19.05" x2="39.37" y2="17.91" width="0.6096" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="IC3" pad="2"/>
<contactref element="T1" pad="3"/>
<contactref element="T2" pad="1"/>
<wire x1="31.75" y1="20.32" x2="31.75" y2="18.415" width="0.8128" layer="16"/>
<wire x1="31.75" y1="18.415" x2="31.75" y2="17.78" width="0.8128" layer="16"/>
<wire x1="31.75" y1="17.78" x2="31.75" y2="17.145" width="0.8128" layer="16"/>
<wire x1="31.75" y1="17.145" x2="31.75" y2="15.24" width="0.8128" layer="16"/>
<wire x1="34.29" y1="4.385" x2="34.29" y2="6.35" width="0.6096" layer="16"/>
<wire x1="34.29" y1="6.35" x2="34.925" y2="6.985" width="0.6096" layer="16"/>
<wire x1="34.925" y1="6.985" x2="36.195" y2="6.985" width="0.6096" layer="16"/>
<wire x1="36.195" y1="6.985" x2="36.83" y2="7.62" width="0.6096" layer="16"/>
<wire x1="36.83" y1="7.62" x2="36.83" y2="16.51" width="0.6096" layer="16"/>
<wire x1="36.83" y1="16.51" x2="35.56" y2="17.78" width="0.6096" layer="16"/>
<wire x1="35.56" y1="17.78" x2="32.385" y2="17.78" width="0.6096" layer="16"/>
<wire x1="32.385" y1="17.78" x2="31.75" y2="17.145" width="0.6096" layer="16"/>
<wire x1="32.385" y1="17.78" x2="31.75" y2="18.415" width="0.6096" layer="16"/>
<wire x1="31.75" y1="17.78" x2="31.115" y2="17.78" width="0.8128" layer="16"/>
<wire x1="31.115" y1="17.78" x2="29.845" y2="17.78" width="0.8128" layer="16"/>
<wire x1="29.845" y1="17.78" x2="29.21" y2="18.415" width="0.8128" layer="16"/>
<wire x1="29.21" y1="18.415" x2="29.21" y2="23.495" width="0.8128" layer="16"/>
<wire x1="29.21" y1="23.495" x2="29.845" y2="24.13" width="0.8128" layer="16"/>
<wire x1="29.845" y1="24.13" x2="43.18" y2="24.13" width="0.8128" layer="16"/>
<wire x1="31.115" y1="17.78" x2="31.75" y2="18.415" width="0.6096" layer="16"/>
<wire x1="31.115" y1="17.78" x2="31.75" y2="17.145" width="0.6096" layer="16"/>
<contactref element="ESR1" pad="MP"/>
</signal>
<signal name="V-">
<contactref element="IC3" pad="4"/>
<contactref element="IC2" pad="4"/>
<contactref element="R12" pad="1"/>
<contactref element="LED1" pad="K"/>
<contactref element="C6" pad="-"/>
<contactref element="D4" pad="A"/>
<contactref element="V-" pad="MP"/>
<wire x1="-6.35" y1="5.08" x2="-6.35" y2="3.175" width="0.8128" layer="16"/>
<wire x1="-6.35" y1="3.175" x2="-4.445" y2="1.27" width="0.8128" layer="16"/>
<wire x1="-4.445" y1="1.27" x2="-2.54" y2="1.27" width="0.8128" layer="16"/>
<wire x1="-2.54" y1="1.27" x2="0" y2="1.27" width="0.8128" layer="16"/>
<wire x1="0" y1="1.27" x2="1.27" y2="2.54" width="0.8128" layer="16"/>
<wire x1="1.27" y1="2.54" x2="5.08" y2="2.54" width="0.8128" layer="16"/>
<wire x1="5.08" y1="0" x2="23.495" y2="0" width="0.8128" layer="16"/>
<wire x1="23.495" y1="0" x2="24.765" y2="1.27" width="0.8128" layer="16"/>
<wire x1="24.765" y1="1.27" x2="31.75" y2="1.27" width="0.8128" layer="16"/>
<wire x1="31.75" y1="1.27" x2="38.1" y2="1.27" width="0.8128" layer="16"/>
<wire x1="38.1" y1="1.27" x2="62.23" y2="1.27" width="0.8128" layer="16"/>
<wire x1="31.75" y1="4.385" x2="31.75" y2="1.27" width="0.6096" layer="16"/>
<wire x1="39.37" y1="15.11" x2="39.37" y2="10.795" width="0.6096" layer="16"/>
<wire x1="39.37" y1="10.795" x2="38.1" y2="9.525" width="0.6096" layer="16"/>
<wire x1="38.1" y1="9.525" x2="38.1" y2="1.27" width="0.6096" layer="16"/>
<vertex x="8.89" y="7.62"/>
<vertex x="8.89" y="-6.35"/>
<vertex x="-10.16" y="-6.35"/>
</polygon>
<wire x1="63.44" y1="1.27" x2="62.23" y2="1.27" width="0.6096" layer="16"/>
<wire x1="5.08" y1="0" x2="5.08" y2="2.54" width="0.8128" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="Q1" pad="3"/>
<contactref element="R4" pad="2"/>
<wire x1="20.955" y1="4.445" x2="20.955" y2="6.22" width="0.8128" layer="16"/>
<wire x1="20.32" y1="3.81" x2="20.955" y2="4.445" width="0.8128" layer="16"/>
<wire x1="18.415" y1="3.81" x2="20.32" y2="3.81" width="0.8128" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="Q3" pad="1"/>
<contactref element="Q1" pad="1"/>
<wire x1="18.415" y1="6.35" x2="18.415" y2="10.16" width="0.8128" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="Q3" pad="3"/>
<contactref element="R10" pad="1"/>
<wire x1="15.875" y1="10.29" x2="15.875" y2="12.065" width="0.8128" layer="16"/>
<wire x1="15.875" y1="12.065" x2="16.51" y2="12.7" width="0.8128" layer="16"/>
<wire x1="16.51" y1="12.7" x2="18.415" y2="12.7" width="0.8128" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="R4" pad="1"/>
<contactref element="Q3" pad="2"/>
<contactref element="C3" pad="2"/>
<contactref element="C5" pad="1"/>
<contactref element="L1" pad="1"/>
<wire x1="20.955" y1="10.795" x2="20.32" y2="11.43" width="0.8128" layer="16"/>
<wire x1="20.955" y1="9.02" x2="20.955" y2="10.795" width="0.8128" layer="16"/>
<wire x1="21.59" y1="17.645" x2="23.36" y2="17.645" width="0.8128" layer="16"/>
<wire x1="23.36" y1="17.645" x2="24.13" y2="18.415" width="0.8128" layer="16"/>
<wire x1="24.13" y1="18.415" x2="24.13" y2="19.555" width="0.8128" layer="16"/>
<wire x1="21.59" y1="17.645" x2="20.32" y2="16.375" width="0.8128" layer="16"/>
<wire x1="20.32" y1="16.375" x2="20.32" y2="14.605" width="0.8128" layer="16"/>
<wire x1="20.32" y1="14.605" x2="20.32" y2="11.43" width="0.8128" layer="16"/>
<wire x1="24.635" y1="14.605" x2="20.32" y2="14.605" width="0.8128" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="R6" pad="1"/>
<contactref element="R13" pad="2"/>
<wire x1="50.8" y1="15.11" x2="53.845" y2="15.24" width="0.8128" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="R14" pad="S"/>
<contactref element="R14" pad="E"/>
<contactref element="SW_3" pad="MP"/>
<wire x1="62.23" y1="21.59" x2="62.23" y2="19.05" width="0.8128" layer="16"/>
<wire x1="62.23" y1="19.05" x2="64.135" y2="19.05" width="0.8128" layer="16"/>
<wire x1="64.135" y1="19.05" x2="65.405" y2="17.78" width="0.8128" layer="16"/>
<wire x1="65.405" y1="17.78" x2="65.405" y2="7.62" width="0.8128" layer="16"/>
<wire x1="65.405" y1="7.62" x2="62.865" y2="5.08" width="0.8128" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="R15" pad="S"/>
<contactref element="R15" pad="E"/>
<contactref element="SW_1" pad="MP"/>
<wire x1="55.88" y1="21.59" x2="55.88" y2="19.05" width="0.8128" layer="16"/>
<wire x1="55.88" y1="19.05" x2="58.42" y2="19.05" width="0.8128" layer="16"/>
<wire x1="58.42" y1="19.05" x2="59.69" y2="17.78" width="0.8128" layer="16"/>
<wire x1="59.69" y1="17.78" x2="59.69" y2="15.24" width="0.8128" layer="16"/>
<wire x1="59.69" y1="15.24" x2="62.865" y2="12.065" width="0.8128" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="C8" pad="2"/>
<contactref element="C7" pad="+"/>
<contactref element="SW_2" pad="MP"/>
<wire x1="50.8" y1="8.89" x2="50.8" y2="11.3" width="0.8128" layer="16"/>
<wire x1="50.8" y1="11.3" x2="50.93" y2="11.43" width="0.8128" layer="16"/>
<wire x1="50.8" y1="8.89" x2="54.61" y2="8.89" width="0.8128" layer="16"/>
<wire x1="54.61" y1="8.89" x2="55.245" y2="8.255" width="0.8128" layer="16"/>
<wire x1="55.245" y1="8.255" x2="58.42" y2="8.255" width="0.8128" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="SW_4" pad="MP"/>
<contactref element="R13" pad="1"/>
<wire x1="54.61" y1="12.065" x2="56.645" y2="14.1" width="0.8128" layer="16"/>
<wire x1="56.645" y1="14.1" x2="56.645" y2="15.24" width="0.8128" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="IC2" pad="6"/>
<contactref element="D3" pad="2"/>
<contactref element="D7" pad="1"/>
<wire x1="74.295" y1="15.745" x2="74.295" y2="13.97" width="0.8128" layer="16"/>
<wire x1="74.295" y1="13.97" x2="74.295" y2="12.195" width="0.8128" layer="16"/>
<wire x1="68.64" y1="0" x2="68.58" y2="0" width="0.6096" layer="16"/>
<wire x1="68.64" y1="0" x2="70.485" y2="0" width="0.6096" layer="16"/>
<wire x1="70.485" y1="0" x2="71.755" y2="1.27" width="0.6096" layer="16"/>
<wire x1="71.755" y1="1.27" x2="71.755" y2="5.08" width="0.6096" layer="16"/>
<wire x1="71.755" y1="5.08" x2="74.295" y2="7.62" width="0.6096" layer="16"/>
<wire x1="74.295" y1="7.62" x2="75.565" y2="7.62" width="0.6096" layer="16"/>
<wire x1="75.565" y1="7.62" x2="76.2" y2="8.255" width="0.6096" layer="16"/>
<wire x1="76.2" y1="8.255" x2="76.2" y2="13.335" width="0.6096" layer="16"/>
<wire x1="76.2" y1="13.335" x2="75.565" y2="13.97" width="0.6096" layer="16"/>
<wire x1="75.565" y1="13.97" x2="74.295" y2="13.97" width="0.6096" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="IC2" pad="2"/>
<contactref element="R14" pad="A"/>
<contactref element="R15" pad="A"/>
<contactref element="D2" pad="2"/>
<wire x1="55.88" y1="24.13" x2="62.23" y2="24.13" width="0.8128" layer="16"/>
<wire x1="62.23" y1="24.13" x2="64.77" y2="24.13" width="0.6096" layer="16"/>
<contactref element="D8" pad="1"/>
<wire x1="69.215" y1="15.745" x2="69.215" y2="13.97" width="0.8128" layer="16"/>
<wire x1="69.215" y1="13.97" x2="69.215" y2="12.195" width="0.8128" layer="16"/>
<wire x1="66.675" y1="13.97" x2="66.675" y2="22.225" width="0.6096" layer="16"/>
<wire x1="64.77" y1="24.13" x2="66.675" y2="22.225" width="0.6096" layer="16"/>
<wire x1="69.215" y1="13.97" x2="66.675" y2="13.97" width="0.6096" layer="16"/>
<wire x1="66.675" y1="13.97" x2="66.675" y2="-0.635" width="0.6096" layer="16"/>
<wire x1="66.675" y1="-0.635" x2="66.04" y2="-1.27" width="0.6096" layer="16"/>
<wire x1="66.04" y1="-1.27" x2="63.44" y2="-1.27" width="0.6096" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="D8" pad="2"/>
<contactref element="D7" pad="2"/>
<contactref element="C9" pad="-"/>
<contactref element="M-" pad="MP"/>
<wire x1="69.215" y1="9.395" x2="71.755" y2="9.395" width="0.8128" layer="16"/>
<wire x1="71.755" y1="9.395" x2="74.295" y2="9.395" width="0.8128" layer="16"/>
<wire x1="71.755" y1="12.7" x2="71.755" y2="9.395" width="0.8128" layer="16"/>
<wire x1="69.215" y1="5.08" x2="71.755" y2="7.62" width="0.8128" layer="16"/>
<wire x1="71.755" y1="7.62" x2="71.755" y2="9.395" width="0.8128" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="D2" pad="1"/>
<contactref element="D3" pad="1"/>
<contactref element="C9" pad="+"/>
<contactref element="M+" pad="MP"/>
<wire x1="69.215" y1="18.545" x2="71.755" y2="18.545" width="0.8128" layer="16"/>
<wire x1="71.755" y1="18.545" x2="74.295" y2="18.545" width="0.8128" layer="16"/>
<wire x1="71.755" y1="15.24" x2="71.755" y2="18.545" width="0.8128" layer="16"/>
<wire x1="69.215" y1="22.86" x2="71.755" y2="20.32" width="0.8128" layer="16"/>
<wire x1="71.755" y1="20.32" x2="71.755" y2="18.545" width="0.8128" layer="16"/>
</signal>
<signal name="N$23">
<polygon width="0.254" layer="16" isolate="0.3048" thermals="no" rank="5">
<vertex x="80.01" y="34.29"/>
<vertex x="80.01" y="-6.35"/>
</polygon>
</signal>
</signals>
</board>
</drawing>
</eagle>
