 *                Microchip USB C18 Firmware Version 1.0
 * FileName:        typedefs.h
 * Dependencies:    See INCLUDES section below
 * Processor:       PIC18
 * Compiler:        C18 2.30.01+
 * Company:         Microchip Technology, Inc.
 * Software License Agreement
 * The software supplied herewith by Microchip Technology Incorporated
 * (the “Company”) for its PICmicro® Microcontroller is intended and
 * supplied to you, the Company’s customer, for use solely and
 * exclusively on Microchip PICmicro Microcontroller products. The
 * software is owned by the Company and/or its supplier, and is
 * protected under applicable copyright laws. All rights are reserved.
 * Any use in violation of the foregoing restrictions may subject the
 * user to criminal sanctions under applicable laws, as well as to
 * civil liability for the breach of the terms and conditions of this
 * license.
 * THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
 * WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
 * TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
 * PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
 * IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
 * CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
 * Author               Date        Comment
 * Rawin Rojvanit       11/19/04    Original.
#ifndef TYPEDEFS_H
#define TYPEDEFS_H
typedef unsigned char   byte;           // 8-bit
typedef unsigned int    word;           // 16-bit
typedef unsigned long   dword;          // 32-bit
typedef union _BYTE
    byte _byte;
    struct
        unsigned b0:1;
        unsigned b1:1;
        unsigned b2:1;
        unsigned b3:1;
        unsigned b4:1;
        unsigned b5:1;
        unsigned b6:1;
        unsigned b7:1;
} BYTE;
typedef union _WORD
    word _word;
    struct
        byte byte0;
        byte byte1;
    struct
        BYTE Byte0;
        BYTE Byte1;
    struct
        BYTE LowB;
        BYTE HighB;
    struct
        byte v[2];
} WORD;
#define LSB(a)      ((a).v[0])
#define MSB(a)      ((a).v[1])
typedef union _DWORD
    dword _dword;
    struct
        byte byte0;
        byte byte1;
        byte byte2;
        byte byte3;
    struct
        word word0;
        word word1;
    struct
        BYTE Byte0;
        BYTE Byte1;
        BYTE Byte2;
        BYTE Byte3;
    struct
        WORD Word0;
        WORD Word1;
    struct
        byte v[4];
} DWORD;
#define LOWER_LSB(a)    ((a).v[0])
#define LOWER_MSB(a)    ((a).v[1])
#define UPPER_LSB(a)    ((a).v[2])
#define UPPER_MSB(a)    ((a).v[3])
typedef void(*pFunc)(void);
typedef union _POINTER
    struct
        byte bLow;
        byte bHigh;
        //byte bUpper;
    word _word;                         // bLow & bHigh
    //pFunc _pFunc;                       // Usage: ptr.pFunc(); Init: ptr.pFunc = &<Function>;
    byte* bRam;                         // Ram byte pointer: 2 bytes pointer pointing
                                        // to 1 byte of data
    word* wRam;                         // Ram word poitner: 2 bytes poitner pointing
                                        // to 2 bytes of data
    rom byte* bRom;                     // Size depends on compiler setting
    rom word* wRom;
    //rom near byte* nbRom;               // Near = 2 bytes pointer
    //rom near word* nwRom;
    //rom far byte* fbRom;                // Far = 3 bytes pointer
    //rom far word* fwRom;
} POINTER;
typedef enum _BOOL { FALSE = 0, TRUE } BOOL;
#define OK      TRUE
#define FAIL    FALSE
#endif //TYPEDEFS_H
