/*MCU - ATTiny2313 @ 1000000Hz Internal Freq.*/
#define F_CPU 1000000UL
#include <avr/io.h>
#include <util/delay.h>
//motor 1  H/bridge labak: PB0 elore, PB1 hatra;
//motor 2  H/bridge labak: PB5 JOBBRA, PB6 BALRA;
//input: PD0,PD1,PD4
//pwm out: PB3(OC1A);
//sw1 (s1): PD2
// sw2 (s2): PD3;
unsigned char sw1,sw2;
void delayms(uint16_t millis) {
  while ( millis ) {
    _delay_ms(1);
    millis--;
SIGNAL (SIG_INT0)
        //PWM sebesseg allito kapcsolok ellenorzese
    sw1 = (PIND & 0b00000100);
    sw2 = (PIND & 0b00001000);
      if (sw1==0) _duty =_duty-10;   //pwm sebesseg csokkentese mindket motornak;
      if (sw2==0) _duty =_duty+10; //pwm sebesseg novelese mindket motornak;
    _duty = (_duty*255)/100;         //motor sebesseg konvertalasa 0-100%-rol 0-255-re
     OCR1A = _duty;
     GIMSK  |= (0<<INT0);
SIGNAL (SIG_INT1)
     OCR1A = _duty;
    GIMSK  |= (0<<INT1);
int main(void){
  unsigned char sensor;
  unsigned int _duty=127;
  //-------------------------- I/O init----------------------------------------//
  DDRB = 0b11111111;   //PORTB  output;
  DDRD = 0x00;   //PORTD input port
  PORTD = 0b00001100;  //belso felhuzo ellenallasok aktivalasa a kapcsolokhoz.
  TCCR1A = 0b10100001; // 8 bites fazishelyes PWM (WGM10) || sima nem invertalt PWM (COM1A1,COM1B1);
  TCCR1B = 0b00000010; //cs11 BIT on: FCPU /8;
  // Pin 6 (PD2) es Pin 7 (PD3) erzekeles bekapcs.
  PCMSK |= (1<<PIND2) | (1<<PIND3);
  // interrupt on INT0 pin falling edge
  MCUCR = 0b00001010 //int0,int1 lefuto el eseten letrehoz egy megszakitas kerelmet
  // turn on interrupts!
  GIMSK  |= (1<<INT0) | (1<<INT1);
  while(1) {
    OCR1A = _duty;
     if((GICR & (1<<INT0)) == 0)
  // varakozas nehany szaz ms-ig, amig a nyomogomb befejezi a pergest
            _delay_ms(250);
    sensor = (PIND & 0b00010011); // szenzor ellenorzes
    switch(sensor)
			case 0b00000000:PORTB |= (1<<0);  //000 , elore, PB0
				  break;
			case 0b00000001:PORTB |= (1<<5);  //001, jobbra, PB5
				  break;
			case 0b00000010:PORTB |= (1<<0);		//010 , elore, PB0
				  break;
			case 0b00000011:PORTB |= (1<<5);		//011, jobbra, PB5
				  break;
			case 0b00010000:PORTB |= (1<<6);		//100, balra, PB6
				  break;
			case 0b00010001:PORTB |= (1<<0);		//101	, elore, PB0
                                  break;
			case 0b00010010:PORTB |= (1<<6);		//110	, balra, PB6
				  break;
			case 0b00010011:PORTB |= (0<<0);  PORTB |= (0<<1);PORTB |= (0<<5);  PORTB |= (0<<6);	//111 stop
		                  break;
			default:PORTB |= (1<<0);  //elore, PB0
                                break;
