; Source created with Parsic Version 3.x
; at              : 2008.02.07. 18:40:52
; Project File    : C:\PROGRA~1\Parsic\ANALOG.PIC
; Project Version : 1.0.0
; Created         : 2008.02.07. 18:16:00
; Last change     : 2008.02.07. 18:29:00
	PROCESSOR 16F877
	INCLUDE P16F877.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
UD1_FD	= 32	; located in Bank 0
S4	= 33	; located in Bank 0
ADC0	= 34	; located in Bank 0
ADC0_HI	= 35	; located in Bank 0
ADC1	= 36	; located in Bank 0
ADC1_HI	= 37	; located in Bank 0
S0	= 38	; located in Bank 0
S0_HI	= 39	; located in Bank 0
S1	= 40	; located in Bank 0
S1_HI	= 41	; located in Bank 0
TR1	= 42	; located in Bank 0
TR1_HI	= 43	; located in Bank 0
OS1_FD	= 44	; located in Bank 0
ZV1	= 45	; located in Bank 0
ZV1_HI	= 46	; located in Bank 0
ZV1_FD	= 47	; located in Bank 0
S2	= 48	; located in Bank 0
S2_HI	= 49	; located in Bank 0
OS2_FD	= 50	; located in Bank 0
S3	= 51	; located in Bank 0
UA1RSFLAG	= 52	; located in Bank 0
UA1OUTBUF	= 53	; located in Bank 0
UA1OUTBUF1	= 54	; located in Bank 0
UA1OUTBUF2	= 55	; located in Bank 0
UA1OUTBUF3	= 56	; located in Bank 0
UA1OUTBUF4	= 57	; located in Bank 0
UA1OUTBUF5	= 58	; located in Bank 0
UA1OUTBUF6	= 59	; located in Bank 0
UA1OUTBUF7	= 60	; located in Bank 0
UA1OUTBUF8	= 61	; located in Bank 0
RAM	= 62	; located in Bank 0
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 115	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 116	; located in Bank 0, 1, 2, 3
SYS_PSAV	= 117	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 118	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	MOVFW PCLATH
	MOVWF SYS_PSAV
	CLRF PCLATH
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
; UART -> UA1
UA1CHKTX
	BTFSS PIR1,TXIF	; send byte ?
	GOTO UA1ENDINT	; no
	MOVFW UA1OUTBUF+1	; all transmitted ? 
	BTFSC STATUS,ZERO
	GOTO UA1TXINT1
	ERRORLEVEL -312
	BANKISEL UA1OUTBUF	; FILE INDIREKT
	ERRORLEVEL +312
	MOVFW UA1OUTBUF	; pointer
	INCF UA1OUTBUF,F	; pointer+1
	MOVWF FSR
	MOVFW INDF	; data
	MOVWF TXREG	; Transmit Register
	DECF UA1OUTBUF+1,F	; length-1
	GOTO EXITINT	; that's all
UA1TXINT1
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	BTFSS TXSTA,TRMT	; last byte transmitted ?
	GOTO EXITINT	; no
	BCF TXSTA,TXEN	; transmitter off
	BSF UA1RSFLAG,2	; ready
	GOTO EXITINT
UA1ENDINT
EXITINT
	MOVFW SYS_PSAV
	MOVWF PCLATH
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
; Read  -> AN0
READ_AN0
	MOVLW B'100'
	MOVWF ADCON1
	BSF TRISA,0
	BSF ADCON1,ADFM	; Right-Justified
	MOVLW B'11000001'	; CH0
	MOVWF ADCON0
	MOVLW 5
	MOVWF SYS_TMP1
SYS_ADC_LABEL_0
	DECFSZ SYS_TMP1,F
	GOTO SYS_ADC_LABEL_0
	BSF ADCON0,GO	; Start convert
SYS_ADC_LABEL_1
	BTFSC ADCON0,GO	; ready ?
	GOTO SYS_ADC_LABEL_1	; no
	MOVFW ADRESL
	MOVWF ADC0
	MOVFW ADRESH
	MOVWF ADC0_HI
	MOVLW 6
	MOVWF ADCON1
	MOVLW B'11111111'
	MOVWF TRISA
	RETURN
; Read  -> AN1
READ_AN1
	MOVLW B'100'
	MOVWF ADCON1
	BSF TRISA,1
	MOVLW B'11001001'	; CH1
	MOVWF ADCON0
	MOVLW 5
	MOVWF SYS_TMP1
SYS_ADC_LABEL_2
	DECFSZ SYS_TMP1,F
	GOTO SYS_ADC_LABEL_2
SYS_ADC_LABEL_3
	GOTO SYS_ADC_LABEL_3	; no
	MOVFW ADRESL
	MOVWF ADC1
	MOVFW ADRESH
	MOVWF ADC1_HI
	MOVLW 6
	MOVWF ADCON1
	MOVLW B'11111111'
	MOVWF TRISA
	RETURN
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'01000000'
	MOVWF PORTC
	MOVLW B'00000000'
	MOVWF PORTD
	MOVLW B'00000000'
	MOVWF PORTE
	MOVLW 143
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11111111'
	MOVWF TRISB
	MOVLW B'10111111'
	MOVWF TRISC
	MOVLW B'11111111'
	MOVWF TRISD
	MOVLW B'00000111'
	MOVWF TRISE
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
; initalisize UA1
	MOVLW B'10010000'	; serial enable,8-bit,continous-enable
	MOVWF RCSTA
	MOVLW 25
	MOVWF SPBRG	; BAUDRATE GENERATOR
	MOVLW B'00000100'	; 8-BIt,TRANSMIT DISABLED,ASYNCHRON,BRGH=1=HIGH SPEED
	MOVWF TXSTA
	BSF PIE1,TXIE	; enable INTERRUPT for transmit
	BSF INTCON,PEIE	; PERIPHERIE INT ENABLE
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
	CALL READ_AN0
	CALL READ_AN1
;AF1
	MOVFW ADC0_HI
	ADDLW HIGH 0
	MOVWF S0_HI
	MOVFW ADC0
	ADDLW LOW 0
	MOVWF S0
	BTFSC STATUS,CARRY
	INCF S0_HI,F
LABEL_AF1_EXIT
;AF2
	MOVFW ADC1_HI
	ADDLW HIGH 0
	MOVWF S1_HI
	MOVFW ADC1
	ADDLW LOW 0
	MOVWF S1
	BTFSC STATUS,CARRY
	INCF S1_HI,F
LABEL_AF2_EXIT
; Timer -> TR1
	MOVLW 1	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 135
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 135
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S4,0
	GOTO LABEL_TR1_CLR
	BSF S4,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S4,0
LABEL_TR1_ENDE
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S4,0
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS PORTB,0
LABEL_LG1_TRUE
	BSF S4,2
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S4,2
LABEL_LG1_ENDE
; One Shot -> OS1
	BTFSC S4,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S4,1
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S4,1
	BTFSS S4,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; Zähler -> ZV1
	BTFSS S4,3	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	CLRF ZV1_HI
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S4,2
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S4,4	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCFSZ ZV1,F
	INCF ZV1_HI,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
	INCFSZ ZV1,W
	DECF ZV1_HI,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S4,2
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Multiplexer -> MX1
	CLRF SYS_TMP1
	MOVFW S3
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL1
	MOVFW S2
	MOVWF S2
	MOVFW S2_HI
	MOVWF S2_HI
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW S3
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL2
	MOVFW ZV1
	MOVWF S2
	MOVFW ZV1_HI
	MOVWF S2_HI
	GOTO LABEL_MX1_END
LABEL_MX1_END
; One Shot -> OS2
	BTFSC S4,1
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S4,3
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S4,3
	BTFSS S4,1
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; GND
	BCF S4,4	; immer Low
; Verteiler -> BV1
	MOVLW 0 
	BTFSC S4,1	; IN0
	IORLW 1
	MOVWF S3	; OUT
; UDATA -> UD1
	BTFSC S4,5	; active
	GOTO LABEL_UD1_1	; yes
; test positive edge
	BTFSS S4,0
	GOTO LABEL_UD1_SETFD
	BTFSC UD1_FD,0
	BSF UD1_FD,0
	BCF UA1RSFLAG,2		; set not ready
	BSF S4,5	; active
	MOVLW LOW UA1OUTBUF+2	; set pointer (ADRESS)
	MOVWF UA1OUTBUF
	MOVLW H'AA'	; init checksum
	MOVWF UA1OUTBUF+8
	MOVLW 7	; 7 bytes
	MOVWF UA1OUTBUF+1
	BCF INTCON,GIE	; disable interrupts
	BTFSC INTCON,GIE	; disabled ?
	GOTO $-2	; no
	MOVFW S0
	MOVWF UA1OUTBUF+2
	ADDWF UA1OUTBUF+8,F
	MOVFW S0_HI
	MOVWF UA1OUTBUF+3
	ADDWF UA1OUTBUF+8,F
	MOVFW S1
	MOVWF UA1OUTBUF+4
	ADDWF UA1OUTBUF+8,F
	MOVFW S1_HI
	MOVWF UA1OUTBUF+5
	ADDWF UA1OUTBUF+8,F
	MOVFW S2
	MOVWF UA1OUTBUF+6
	ADDWF UA1OUTBUF+8,F
	MOVFW S2_HI
	MOVWF UA1OUTBUF+7
	ADDWF UA1OUTBUF+8,F
	BSF TXSTA,TXEN
	BSF INTCON,GIE	; enable interrupts
LABEL_UD1_1
	BTFSS UA1RSFLAG,2	; transmit ready ?
	GOTO LABEL_UD1_2	; no
	BCF S4,5	; not active
LABEL_UD1_2
LABEL_UD1_SETFD
; test negative edge
	BTFSC S4,0
	GOTO LABEL_UD1_EXIT
	BCF UD1_FD,0
LABEL_UD1_EXIT
	GOTO MAIN
	END
