<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.000003" unitdist="mm" unit="mm" style="lines" multiple="1" display="no" altdistance="0.000003" altunitdist="mm" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="-19.602140625" y1="-7.73393125" x2="85.25279375" y2="-7.401521875" width="0.6096" layer="20"/>
<wire x1="85.25279375" y1="-7.401521875" x2="87.136059375" y2="79.4760625" width="0.6096" layer="20"/>
<wire x1="87.136059375" y1="79.4760625" x2="-17.909803125" y2="78.952296875" width="0.6096" layer="20"/>
<wire x1="-17.909803125" y1="78.952296875" x2="-19.602140625" y2="-7.73393125" width="0.6096" layer="20"/>
<text x="33.570471875" y="21.988975" size="6.4516" layer="16" font="vector" ratio="13" rot="MR0">CNC</text>
<text x="82.3624" y="41.6177" size="2.54" layer="16" font="vector" ratio="22" distance="70" rot="MR270">KAQKK System</text>
<hole x="-11.915071875" y="67.709834375" drill="0.6"/>
<hole x="77.728778125" y="68.26483125" drill="0.6"/>
<hole x="72.617821875" y="-2.028634375" drill="0.6"/>
<hole x="-10.7317125" y="-2.520040625" drill="0.6"/>
<text x="1.525290625" y="60.957615625" size="1.778" layer="16" rot="MR0">végállás</text>
<text x="1.98390625" y="58.171040625" size="1.778" layer="16" rot="MR0">vészstop</text>
<text x="13.901765625" y="47.416734375" size="1.778" layer="16" rot="MR0">X</text>
<text x="-10.18130625" y="46.790725" size="1.778" layer="16" rot="MR0">Y</text>
<text x="-9.90779375" y="35.7532125" size="1.778" layer="16" rot="MR0">Z</text>
<text x="-8.17630625" y="12.71695625" size="1.778" layer="16" rot="MR270">kontraszt</text>
<text x="76.711125" y="17.458090625" size="1.778" layer="16" rot="MR0">+5v</text>
</plain>
<libraries>
<library name="display-lcd">
<packages>
<package name="TUXGR_16X2_R2">
<description>&lt;b&gt;Tuxgraphics LCD display 16x2 characters&lt;/b&gt; reflective, without background light&lt;p&gt;
Source: tuxgr_12x2_r2.pdf</description>
<wire x1="-39.9" y1="17.9" x2="39.9" y2="17.9" width="0.2032" layer="21"/>
<wire x1="39.9" y1="17.9" x2="39.9" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="39.9" y1="-17.9" x2="-39.9" y2="-17.9" width="0.2032" layer="21"/>
<wire x1="-39.9" y1="-17.9" x2="-39.9" y2="17.9" width="0.2032" layer="21"/>
<wire x1="-36.75" y1="12" x2="36.75" y2="12" width="0.2032" layer="21"/>
<wire x1="36.75" y1="12" x2="36.75" y2="-12.6" width="0.2032" layer="21"/>
<wire x1="36.75" y1="-12.6" x2="-36.75" y2="-12.6" width="0.2032" layer="21"/>
<wire x1="-36.75" y1="-12.6" x2="-36.75" y2="12" width="0.2032" layer="21"/>
<wire x1="-32.15" y1="6.5" x2="32.15" y2="6.5" width="0.2032" layer="21"/>
<wire x1="32.15" y1="6.5" x2="32.15" y2="-7.1" width="0.2032" layer="21"/>
<wire x1="32.15" y1="-7.1" x2="-32.15" y2="-7.1" width="0.2032" layer="21"/>
<wire x1="-32.15" y1="-7.1" x2="-32.15" y2="6.5" width="0.2032" layer="21"/>
<pad name="1" x="-32" y="15.5" drill="1" diameter="1.6764"/>
<pad name="2" x="-29.46" y="15.5" drill="1" diameter="1.6764"/>
<pad name="3" x="-26.92" y="15.5" drill="1" diameter="1.6764"/>
<pad name="4" x="-24.38" y="15.5" drill="1" diameter="1.6764"/>
<pad name="5" x="-21.84" y="15.5" drill="1" diameter="1.6764"/>
<pad name="6" x="-19.3" y="15.5" drill="1" diameter="1.6764"/>
<pad name="7" x="-16.76" y="15.5" drill="1" diameter="1.6764"/>
<pad name="8" x="-14.22" y="15.5" drill="1" diameter="1.6764"/>
<pad name="9" x="-11.68" y="15.5" drill="1" diameter="1.6764"/>
<pad name="10" x="-9.14" y="15.5" drill="1" diameter="1.6764"/>
<pad name="11" x="-6.6" y="15.5" drill="1" diameter="1.6764"/>
<pad name="12" x="-4.06" y="15.5" drill="1" diameter="1.6764"/>
<pad name="13" x="-1.52" y="15.5" drill="1" diameter="1.6764"/>
<pad name="14" x="1.02" y="15.5" drill="1" diameter="1.6764"/>
<pad name="15" x="3.56" y="15.5" drill="1" diameter="1.6764"/>
<pad name="16" x="6.1" y="15.5" drill="1" diameter="1.6764"/>
<text x="-38.1" y="18.415" size="1.27" layer="25">&gt;NAME</text>
<text x="0.635" y="18.415" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-28.85" y1="0.1" x2="-25.9" y2="4.45" layer="21"/>
<rectangle x1="-28.85" y1="-5.05" x2="-25.9" y2="-0.7" layer="21"/>
<rectangle x1="-25.2" y1="0.1" x2="-22.25" y2="4.45" layer="21"/>
<rectangle x1="-25.2" y1="-5.05" x2="-22.25" y2="-0.7" layer="21"/>
<rectangle x1="-21.55" y1="0.1" x2="-18.6" y2="4.45" layer="21"/>
<rectangle x1="-21.55" y1="-5.05" x2="-18.6" y2="-0.7" layer="21"/>
<rectangle x1="-17.9" y1="0.1" x2="-14.95" y2="4.45" layer="21"/>
<rectangle x1="-17.9" y1="-5.05" x2="-14.95" y2="-0.7" layer="21"/>
<rectangle x1="-14.25" y1="0.1" x2="-11.3" y2="4.45" layer="21"/>
<rectangle x1="-14.25" y1="-5.05" x2="-11.3" y2="-0.7" layer="21"/>
<rectangle x1="-10.6" y1="0.1" x2="-7.65" y2="4.45" layer="21"/>
<rectangle x1="-10.6" y1="-5.05" x2="-7.65" y2="-0.7" layer="21"/>
<rectangle x1="-6.95" y1="0.1" x2="-4" y2="4.45" layer="21"/>
<rectangle x1="-6.95" y1="-5.05" x2="-4" y2="-0.7" layer="21"/>
<rectangle x1="-3.3" y1="0.1" x2="-0.35" y2="4.45" layer="21"/>
<rectangle x1="-3.3" y1="-5.05" x2="-0.35" y2="-0.7" layer="21"/>
<rectangle x1="0.35" y1="0.1" x2="3.3" y2="4.45" layer="21"/>
<rectangle x1="0.35" y1="-5.05" x2="3.3" y2="-0.7" layer="21"/>
<rectangle x1="4" y1="0.1" x2="6.95" y2="4.45" layer="21"/>
<rectangle x1="4" y1="-5.05" x2="6.95" y2="-0.7" layer="21"/>
<rectangle x1="7.65" y1="0.1" x2="10.6" y2="4.45" layer="21"/>
<rectangle x1="7.65" y1="-5.05" x2="10.6" y2="-0.7" layer="21"/>
<rectangle x1="11.3" y1="0.1" x2="14.25" y2="4.45" layer="21"/>
<rectangle x1="11.3" y1="-5.05" x2="14.25" y2="-0.7" layer="21"/>
<rectangle x1="14.95" y1="0.1" x2="17.9" y2="4.45" layer="21"/>
<rectangle x1="14.95" y1="-5.05" x2="17.9" y2="-0.7" layer="21"/>
<rectangle x1="18.6" y1="0.1" x2="21.55" y2="4.45" layer="21"/>
<rectangle x1="18.6" y1="-5.05" x2="21.55" y2="-0.7" layer="21"/>
<rectangle x1="22.25" y1="0.1" x2="25.2" y2="4.45" layer="21"/>
<rectangle x1="22.25" y1="-5.05" x2="25.2" y2="-0.7" layer="21"/>
<rectangle x1="25.9" y1="0.1" x2="28.85" y2="4.45" layer="21"/>
<rectangle x1="25.9" y1="-5.05" x2="28.85" y2="-0.7" layer="21"/>
<hole x="-37.5" y="-15.5" drill="2.5"/>
<hole x="37.5" y="-15.5" drill="2.5"/>
<hole x="-37.5" y="15.5" drill="2.5"/>
<hole x="37.5" y="15.5" drill="2.5"/>
</package>
</packages>
</library>
<library name="pot">
<packages>
<package name="ECP10S">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;</description>
<wire x1="-0.381" y1="0.381" x2="-0.381" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.016" x2="0.381" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.016" x2="0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0.381" x2="1.016" y2="0.381" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.381" x2="1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.381" x2="0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.381" x2="0.381" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-1.016" x2="-0.381" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.016" x2="-0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.381" x2="-1.016" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.381" x2="-0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="5.08" x2="-4.953" y2="4.191" width="0.1524" layer="21"/>
<wire x1="4.953" y1="5.08" x2="4.064" y2="5.08" width="0.1524" layer="21"/>
<wire x1="1.524" y1="5.08" x2="-1.524" y2="5.08" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="5.08" x2="-4.064" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="5.08" x2="-4.064" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="5.08" x2="-4.953" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="4.191" x2="-4.064" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="4.191" x2="-4.953" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="4.064" y1="4.191" x2="4.953" y2="4.191" width="0.1524" layer="21"/>
<wire x1="4.953" y1="4.191" x2="4.953" y2="5.08" width="0.1524" layer="21"/>
<wire x1="4.064" y1="5.08" x2="4.064" y2="4.191" width="0.1524" layer="21"/>
<wire x1="4.064" y1="5.08" x2="1.524" y2="5.08" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-6.096" x2="4.953" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-6.096" x2="4.953" y2="4.191" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-6.096" x2="4.064" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-6.985" x2="-4.064" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-6.096" x2="-4.064" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-6.096" x2="-4.064" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-6.985" x2="-4.445" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-7.747" x2="-4.953" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-7.747" x2="-4.953" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-6.985" x2="4.445" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-7.747" x2="4.445" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-7.747" x2="4.953" y2="-6.096" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<circle x="-2.794" y="-4.826" radius="1.27" width="0.1524" layer="51"/>
<circle x="2.794" y="-4.826" radius="1.27" width="0.1524" layer="51"/>
<circle x="0" y="1.524" radius="0.127" width="0.3048" layer="21"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<pad name="S" x="0" y="5.08" drill="1.3208" shape="octagon"/>
<pad name="A" x="-2.54" y="-5.08" drill="1.3208" shape="octagon"/>
<pad name="E" x="2.54" y="-5.08" drill="1.3208" shape="octagon"/>
<text x="-3.302" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.572" y="-3.302" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.508" y1="5.08" x2="0.508" y2="5.461" layer="51"/>
</package>
</packages>
</library>
<library name="microchip">
<description>&lt;b&gt;Microchip PIC Microcontrollers and other Devices&lt;/b&gt;&lt;p&gt;
Based on the following sources :
&lt;ul&gt;
&lt;li&gt;Microchip Data Book, 1993
&lt;li&gt;THE EMERGING WORLD STANDARD, 1995/1996
&lt;li&gt;Microchip, Technical Library CD-ROM, June 1998
&lt;li&gt;www.microchip.com
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL40">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type P</description>
<wire x1="-25.4" y1="-1.27" x2="-25.4" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="1.27" x2="-25.4" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="25.4" y1="-6.223" x2="25.4" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.223" x2="-25.4" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.223" x2="25.4" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.223" x2="25.4" y2="-6.223" width="0.1524" layer="21"/>
<pad name="1" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-25.781" y="-6.096" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-21.59" y="-2.2352" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="rcl">
<packages>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="C050-024X044">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.159" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-2.159" y2="0.381" layer="51"/>
</package>
<package name="0309V">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="E3,5-8">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 3.5 mm, diameter 8 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
</packages>
</library>
<library name="switch-dil">
<description>&lt;b&gt;DIL Switches and Code Switches&lt;/b&gt;&lt;p&gt;
<packages>
<package name="DIP02YL">
<description>&lt;b&gt;DIL/CODE SWITCH&lt;/b&gt;&lt;p&gt;</description>
<wire x1="3.81" y1="-3.81" x2="3.81" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="3.81" x2="-3.81" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.635" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.905" y2="1.27" width="0.254" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-1.905" y2="-0.635" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="1.905" y2="-1.27" width="0.254" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.905" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="1.905" y1="1.27" x2="0.635" y2="1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="1.27" x2="0.635" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-0.9398" x2="-0.635" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-0.9398" x2="-1.905" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-0.9398" x2="-0.635" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-0.635" x2="-0.635" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-0.635" x2="-1.905" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-0.635" x2="-0.635" y2="1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="-0.9398" x2="1.905" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="0.635" y1="-0.9398" x2="0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="1.905" y1="-0.9398" x2="1.905" y2="-0.635" width="0.254" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="1.905" y2="-0.635" width="0.254" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="0.635" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="1.905" y1="-0.635" x2="1.905" y2="1.27" width="0.254" layer="21"/>
<wire x1="3.81" y1="-3.81" x2="2.032" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-3.81" x2="-2.032" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="3.81" x2="-2.032" y2="3.81" width="0.1524" layer="21"/>
<wire x1="3.81" y1="3.81" x2="2.032" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-3.81" x2="-0.508" y2="-3.81" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-3.81" x2="0.508" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-3.81" x2="2.032" y2="-3.81" width="0.1524" layer="51"/>
<wire x1="2.032" y1="3.81" x2="0.508" y2="3.81" width="0.1524" layer="51"/>
<wire x1="0.508" y1="3.81" x2="-0.508" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="-2.032" y2="3.81" width="0.1524" layer="51"/>
<circle x="-2.794" y="-2.794" radius="0.254" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-1.651" y="-3.048" size="1.27" layer="51" ratio="10">1</text>
<text x="0.889" y="-3.048" size="1.27" layer="51" ratio="10">2</text>
<text x="-4.1402" y="-3.7592" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.5052" y="-3.1496" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-1.651" y="1.7018" size="1.27" layer="51" ratio="10">ON</text>
</package>
</packages>
</library>
<library name="74ttl-din">
<description>&lt;b&gt;TTL Devices with DIN Symbols&lt;/b&gt;&lt;p&gt;
CadSoft and the author do not warrant that this library is free from error
or will meet your specific requirements.&lt;p&gt;
&lt;author&gt;Created by Holger Bettenbühl, hol.bet.@rhein-main.net&lt;/author&gt;</description>
<packages>
<package name="DIL20">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="12.7" y1="2.921" x2="-12.7" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="12.7" y1="2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="2.921" x2="-12.7" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="-12.7" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.016" x2="-12.7" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-13.081" y="-3.048" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.779" y="-0.381" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-amp-mt">
<description>&lt;b&gt;AMP Connectors, Type MT&lt;/b&gt;&lt;p&gt;
include  Type MT6; con-amp-mt6.lbr&lt;p&gt;
<packages>
<package name="S06P">
<description>&lt;b&gt;AMP MT CONNECTOR&lt;/b&gt;</description>
<wire x1="0.891" y1="-0.381" x2="1.653" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="1.653" y1="-0.381" x2="1.653" y2="0.381" width="0.1524" layer="51"/>
<wire x1="1.653" y1="0.381" x2="0.891" y2="0.381" width="0.1524" layer="51"/>
<wire x1="0.891" y1="0.381" x2="0.891" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="0.891" y1="0.381" x2="1.653" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="1.653" y1="0.381" x2="0.891" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.891" y1="-0.381" x2="-5.891" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-5.891" y1="0.381" x2="-6.653" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-6.653" y1="0.381" x2="-5.891" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-6.653" y1="0.381" x2="-6.653" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.891" y1="0.381" x2="-6.653" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-6.653" y1="-0.381" x2="-5.891" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-3.351" y1="-0.381" x2="-3.351" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-4.113" y1="0.381" x2="-3.351" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-3.351" y1="0.381" x2="-4.113" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-4.113" y1="-0.381" x2="-3.351" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-3.351" y1="0.381" x2="-4.113" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-4.113" y1="0.381" x2="-4.113" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-0.862" y1="-0.381" x2="-0.862" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-0.862" y1="0.381" x2="-1.624" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-1.624" y1="0.381" x2="-1.624" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-1.624" y1="-0.381" x2="-0.862" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-0.862" y1="0.381" x2="-1.624" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-1.624" y1="0.381" x2="-0.862" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="5.869" y1="0.381" x2="5.869" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="6.631" y1="0.381" x2="5.869" y2="0.381" width="0.1524" layer="51"/>
<wire x1="6.631" y1="-0.381" x2="6.631" y2="0.381" width="0.1524" layer="51"/>
<wire x1="5.869" y1="0.381" x2="6.631" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="6.631" y1="0.381" x2="5.869" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="5.869" y1="-0.381" x2="6.631" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="3.38" y1="0.381" x2="3.38" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="4.142" y1="0.381" x2="3.38" y2="0.381" width="0.1524" layer="51"/>
<wire x1="4.142" y1="-0.381" x2="4.142" y2="0.381" width="0.1524" layer="51"/>
<wire x1="3.38" y1="0.381" x2="4.142" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="4.142" y1="0.381" x2="3.38" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="3.38" y1="-0.381" x2="4.142" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="8.638" y1="-2.667" x2="8.892" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="8.638" y1="2.667" x2="8.892" y2="2.413" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.812" y1="2.413" x2="-8.558" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.812" y1="-2.413" x2="-8.558" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.32" y1="3.683" x2="9.4" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-8.558" y1="2.667" x2="8.638" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-8.558" y1="-2.667" x2="-7.669" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-8.812" y1="-2.413" x2="-8.812" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-9.828" y1="3.175" x2="-9.828" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="9.4" y1="3.683" x2="9.908" y2="3.175" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.828" y1="-3.175" x2="-9.32" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.828" y1="3.175" x2="-9.32" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.4" y1="-3.683" x2="9.908" y2="-3.175" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.288" y1="-2.667" x2="-7.288" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-7.288" y1="-3.683" x2="-7.669" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-7.669" y1="-2.667" x2="-7.669" y2="-3.683" width="0.0508" layer="21"/>
<wire x1="-7.669" y1="-2.667" x2="-7.288" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-7.669" y1="-3.683" x2="-9.32" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-8.812" y1="-1.27" x2="8.892" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.812" y1="1.27" x2="8.892" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.812" y1="-1.27" x2="-8.812" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.812" y1="1.27" x2="-8.812" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-7.288" y1="-2.667" x2="-7.288" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.288" y1="-2.159" x2="7.368" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="8.892" y1="-1.27" x2="8.892" y2="1.27" width="0.1524" layer="21"/>
<wire x1="8.892" y1="1.27" x2="8.892" y2="2.413" width="0.1524" layer="21"/>
<wire x1="8.892" y1="-2.413" x2="8.892" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="9.908" y1="3.175" x2="9.908" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="7.749" y1="-2.667" x2="8.638" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="7.749" y1="-2.667" x2="7.749" y2="-3.683" width="0.0508" layer="21"/>
<wire x1="9.4" y1="-3.683" x2="7.749" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="7.749" y1="-3.683" x2="7.368" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="7.368" y1="-2.667" x2="7.749" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="7.368" y1="-3.683" x2="7.368" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="7.368" y1="-2.667" x2="7.368" y2="-2.159" width="0.1524" layer="21"/>
<pad name="3" x="1.25" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-6.25" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-3.75" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-1.25" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="3.75" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="6.25" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-9.8028" y="4.191" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.4208" y="4.191" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="7.5708" y="-0.635" size="1.27" layer="21" ratio="10">1</text>
<text x="-8.482" y="-0.635" size="1.27" layer="21" ratio="10">6</text>
</package>
</packages>
</library>
<library name="con-subd">
<description>&lt;b&gt;SUB-D Connectors&lt;/b&gt;&lt;p&gt;
Harting&lt;br&gt;
NorComp&lt;br&gt;
&lt;p&gt;
PREFIX :&lt;br&gt;
H = High density&lt;br&gt;
F = Female&lt;br&gt;
M = Male&lt;p&gt;
NUMBER: Number of pins&lt;p&gt;
SUFFIX :&lt;br&gt;
H = Horizontal&lt;br&gt;
V = Vertical &lt;br&gt;
P = Shield pin on housing&lt;br&gt;
B = No mounting holes&lt;br&gt;
S = Pins individually placeable (Single)&lt;br&gt;
D = Direct mounting &lt;p&gt;
<packages>
<package name="F25VP">
<description>&lt;b&gt;SUB-D&lt;/b&gt;</description>
<wire x1="-18.5674" y1="-2.9464" x2="-19.3548" y2="2.3368" width="0.1524" layer="21"/>
<wire x1="17.272" y1="-3.937" x2="18.5807" y2="-2.905" width="0.1524" layer="21" curve="76.489196"/>
<wire x1="18.034" y1="3.937" x2="19.3495" y2="2.3038" width="0.1524" layer="21" curve="-102.298925"/>
<wire x1="19.3548" y1="2.3114" x2="18.5674" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="3.937" x2="18.034" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-19.3541" y1="2.3268" x2="-18.034" y2="3.937" width="0.1524" layer="21" curve="-101.30773"/>
<wire x1="-18.5749" y1="-2.9295" x2="-17.272" y2="-3.937" width="0.1524" layer="21" curve="75.428151"/>
<wire x1="-17.272" y1="-3.937" x2="17.272" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="-6.223" x2="-23.749" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="-6.223" x2="-21.209" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="-6.096" x2="-21.209" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-6.096" x2="-21.209" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-6.223" x2="21.209" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-25.908" y1="-6.223" x2="-23.749" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="-5.588" x2="-25.908" y2="-6.223" width="0.1524" layer="21" curve="90"/>
<wire x1="25.908" y1="-6.223" x2="26.543" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="25.908" y1="6.223" x2="23.749" y2="6.223" width="0.1524" layer="21"/>
<wire x1="26.543" y1="5.588" x2="26.543" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="25.908" y1="6.223" x2="26.543" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<wire x1="-26.543" y1="5.588" x2="-26.543" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="5.588" x2="-25.908" y2="6.223" width="0.1524" layer="21" curve="-90"/>
<wire x1="21.209" y1="-6.223" x2="21.209" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="21.209" y1="-6.223" x2="23.749" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="21.209" y1="-6.096" x2="23.749" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="23.749" y1="-6.096" x2="23.749" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="23.749" y1="-6.223" x2="25.908" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="21.209" y1="6.223" x2="21.209" y2="6.096" width="0.1524" layer="21"/>
<wire x1="21.209" y1="6.223" x2="-21.209" y2="6.223" width="0.1524" layer="21"/>
<wire x1="21.209" y1="6.096" x2="23.749" y2="6.096" width="0.1524" layer="21"/>
<wire x1="23.749" y1="6.096" x2="23.749" y2="6.223" width="0.1524" layer="21"/>
<wire x1="23.749" y1="6.223" x2="21.209" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="6.223" x2="-23.749" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="6.223" x2="-25.908" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="6.096" x2="-21.209" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="6.096" x2="-21.209" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="6.223" x2="-23.749" y2="6.223" width="0.1524" layer="21"/>
<circle x="1.3716" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="0" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-1.3716" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-23.5204" y="0" radius="1.651" width="0.1524" layer="21"/>
<circle x="23.5204" y="0" radius="1.651" width="0.1524" layer="21"/>
<circle x="2.7686" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-2.7686" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="4.1402" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-4.1402" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="5.5118" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="8.2804" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="6.9088" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="9.652" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="11.049" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="12.4206" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="13.7922" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="15.1892" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="16.5608" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-5.5118" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-8.2804" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-11.049" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-6.9088" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-9.652" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-12.4206" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-13.7922" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-16.5608" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-15.1892" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<pad name="1" x="16.5608" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="2" x="13.7922" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="3" x="11.049" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="4" x="8.2804" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="5" x="5.5118" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="6" x="2.7686" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="7" x="0" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="8" x="-2.7686" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="9" x="-5.5118" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="10" x="-8.2804" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="11" x="-11.049" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="12" x="-13.7922" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="13" x="-16.5608" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="14" x="15.1892" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="15" x="12.4206" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="16" x="9.652" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="17" x="6.9088" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="18" x="4.1402" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="19" x="1.3716" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="20" x="-1.3716" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="21" x="-4.1402" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="22" x="-6.9088" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="23" x="-9.652" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="24" x="-12.4206" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="25" x="-15.1892" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="G1" x="-23.5204" y="0" drill="3.302" diameter="5.08"/>
<pad name="G2" x="23.5204" y="0" drill="3.302" diameter="5.08"/>
<text x="16.256" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="13.335" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="10.668" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<text x="7.874" y="2.54" size="0.9906" layer="21" ratio="12">4</text>
<text x="5.08" y="2.54" size="0.9906" layer="21" ratio="12">5</text>
<text x="2.286" y="2.54" size="0.9906" layer="21" ratio="12">6</text>
<text x="-0.381" y="2.54" size="0.9906" layer="21" ratio="12">7</text>
<text x="-3.175" y="2.54" size="0.9906" layer="21" ratio="12">8</text>
<text x="-5.969" y="2.54" size="0.9906" layer="21" ratio="12">9</text>
<text x="-26.416" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="6.985" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-9.017" y="2.54" size="0.9906" layer="21" ratio="12">10</text>
<text x="-11.684" y="2.54" size="0.9906" layer="21" ratio="12">11</text>
<text x="-14.478" y="2.54" size="0.9906" layer="21" ratio="12">12</text>
<text x="-17.272" y="2.54" size="0.9906" layer="21" ratio="12">13</text>
<text x="-16.129" y="-3.556" size="0.9906" layer="21" ratio="12">25</text>
<text x="-13.335" y="-3.556" size="0.9906" layer="21" ratio="12">24</text>
<text x="-10.414" y="-3.556" size="0.9906" layer="21" ratio="12">23</text>
<text x="-7.62" y="-3.556" size="0.9906" layer="21" ratio="12">22</text>
<text x="-4.953" y="-3.556" size="0.9906" layer="21" ratio="12">21</text>
<text x="-2.286" y="-3.556" size="0.9906" layer="21" ratio="12">20</text>
<text x="0.635" y="-3.556" size="0.9906" layer="21" ratio="12">19</text>
<text x="3.302" y="-3.556" size="0.9906" layer="21" ratio="12">18</text>
<text x="5.969" y="-3.556" size="0.9906" layer="21" ratio="12">17</text>
<text x="8.763" y="-3.556" size="0.9906" layer="21" ratio="12">16</text>
<text x="11.557" y="-3.556" size="0.9906" layer="21" ratio="12">15</text>
<text x="14.351" y="-3.556" size="0.9906" layer="21" ratio="12">14</text>
</package>
</packages>
</library>
<library name="con-garry">
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
&lt;a href="www.mpe-connector.de"&gt;Menufacturer&lt;/a&gt;&lt;p&gt;
<packages>
<package name="332-10">
<description>&lt;b&gt;10 Pin - 2mm Dual Row&lt;/b&gt;&lt;p&gt;
Source: www.mpe-connector.de / garry_shortform_2012.pdf</description>
<wire x1="-4.85" y1="-1.9" x2="4.85" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-1.9" x2="4.85" y2="-0.4" width="0.2032" layer="21"/>
<wire x1="4.85" y1="0.4" x2="4.85" y2="1.9" width="0.2032" layer="21"/>
<wire x1="4.85" y1="1.9" x2="-4.85" y2="1.9" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="1.9" x2="-4.85" y2="0.4" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-0.4" x2="-4.85" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="0.4" x2="-4.85" y2="-0.4" width="0.2032" layer="21" curve="-129.185"/>
<wire x1="4.85" y1="-0.4" x2="4.85" y2="0.4" width="0.2032" layer="21" curve="-129.185"/>
<pad name="1" x="-4" y="-1" drill="0.9" diameter="1.27"/>
<pad name="2" x="-4" y="1" drill="0.9" diameter="1.27"/>
<pad name="3" x="-2" y="-1" drill="0.9" diameter="1.27"/>
<pad name="4" x="-2" y="1" drill="0.9" diameter="1.27"/>
<pad name="5" x="0" y="-1" drill="0.9" diameter="1.27"/>
<pad name="6" x="0" y="1" drill="0.9" diameter="1.27"/>
<pad name="7" x="2" y="-1" drill="0.9" diameter="1.27"/>
<pad name="8" x="2" y="1" drill="0.9" diameter="1.27"/>
<pad name="9" x="4" y="-1" drill="0.9" diameter="1.27"/>
<pad name="10" x="4" y="1" drill="0.9" diameter="1.27"/>
<text x="-4.65" y="-1.75" size="0.3048" layer="21" font="vector">1</text>
<rectangle x1="-4.25" y1="-1.25" x2="-3.75" y2="-0.75" layer="51"/>
<rectangle x1="-4.25" y1="0.75" x2="-3.75" y2="1.25" layer="51"/>
<rectangle x1="-2.25" y1="-1.25" x2="-1.75" y2="-0.75" layer="51"/>
<rectangle x1="-2.25" y1="0.75" x2="-1.75" y2="1.25" layer="51"/>
<rectangle x1="-0.25" y1="-1.25" x2="0.25" y2="-0.75" layer="51"/>
<rectangle x1="-0.25" y1="0.75" x2="0.25" y2="1.25" layer="51"/>
<rectangle x1="1.75" y1="-1.25" x2="2.25" y2="-0.75" layer="51"/>
<rectangle x1="1.75" y1="0.75" x2="2.25" y2="1.25" layer="51"/>
<rectangle x1="3.75" y1="-1.25" x2="4.25" y2="-0.75" layer="51"/>
<rectangle x1="3.75" y1="0.75" x2="4.25" y2="1.25" layer="51"/>
<text x="-4.62" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="1.73" y="2.54" size="1.27" layer="27">&gt;VALUE</text>
<wire x1="-4" y1="1" x2="-4" y2="-6" width="0.55" layer="51"/>
<wire x1="-2" y1="1" x2="-2" y2="-6" width="0.55" layer="51"/>
<wire x1="0" y1="1" x2="0" y2="-6" width="0.55" layer="51"/>
<wire x1="2" y1="1" x2="2" y2="-6" width="0.55" layer="51"/>
<wire x1="4" y1="1" x2="4" y2="-6" width="0.55" layer="51"/>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK300/2">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="5.08" y1="6.223" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="5.588" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="6.223" x2="5.588" y2="1.397" width="0.1524" layer="21"/>
<wire x1="5.588" y1="1.397" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-5.461" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-5.207" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.064" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.588" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="0.4572" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="0.254" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-6.223" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="-0.4826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="0.4572" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-6.223" x2="-0.4826" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="0.4572" y2="0.254" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-4.318" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-0.4826" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-4.318" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="4.1402" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="0.8382" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="-3.683" x2="0.8382" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-0.8636" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-4.1656" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-3.683" x2="-4.1656" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-0.508" x2="-3.7846" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="-0.508" x2="-1.2446" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0.8382" y1="-0.508" x2="1.2192" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="4.1402" y1="-0.508" x2="3.7592" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-6.223" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.651" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.175" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="3.429" x2="0.4572" y2="5.969" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="5.969" x2="4.5212" y2="5.969" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="5.969" x2="4.5212" y2="3.429" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="3.429" x2="0.4572" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-0.4826" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-4.5466" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="3.429" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="5.969" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="3.9574" y1="4.0849" x2="4.0131" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="1.016" y1="4.1656" x2="4.0038" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="0.8636" y1="5.0038" x2="4.0178" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="0.9144" y1="5.0546" x2="1.0581" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="0.8636" y1="4.445" x2="3.9116" y2="5.08" width="0.1524" layer="21"/>
<wire x1="0.9906" y1="4.318" x2="4.0386" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-1.0464" y1="4.0849" x2="-0.9907" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-3.9878" y1="4.1656" x2="-1" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-4.1402" y1="5.0038" x2="-0.9858" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-4.0894" y1="5.0546" x2="-3.9457" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-4.1402" y1="4.445" x2="-1.0922" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="4.318" x2="-0.9652" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="0.254" x2="-0.8636" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="0.635" x2="-4.1656" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="0.635" x2="-0.8636" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="4.1402" y2="0.635" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="51"/>
<wire x1="4.5212" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="0.254" x2="0.8382" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.4958" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="0.5842" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-3.7846" y1="-2.54" x2="-1.2446" y2="0.254" layer="51"/>
<rectangle x1="1.2192" y1="-2.54" x2="3.7592" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="resistor-net">
<description>&lt;b&gt;Generic Resistor Networks&lt;/b&gt;&lt;p&gt;
<packages>
<package name="RN-9">
<description>&lt;b&gt;RESISTOR NETWORK&lt;/b&gt;</description>
<wire x1="11.43" y1="-1.27" x2="11.43" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.27" x2="-11.43" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.27" x2="-10.795" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.27" x2="-10.795" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.27" x2="-9.525" y2="0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="1.27" x2="-8.89" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.27" x2="-9.525" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.27" x2="-8.89" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.27" x2="-8.89" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.27" x2="-11.43" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.27" x2="11.43" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.7696" y1="0.6096" x2="-9.5504" y2="-0.6096" width="0.1524" layer="51"/>
<wire x1="-10.7696" y1="-0.6096" x2="-9.5504" y2="0.6096" width="0.1524" layer="51"/>
<pad name="1" x="-10.16" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-8.89" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-8.89" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="28mil"/>
<param name="mdWirePad" value="18mil"/>
<param name="mdWireVia" value="18mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="0"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="DIS1" library="display-lcd" package="TUXGR_16X2_R2" value="TUXGR_16X2_R2" x="49.626646875" y="-16.662321875"/>
<element name="R9" library="pot" package="ECP10S" value="" x="1.290240625" y="4.9122875" rot="R270"/>
<element name="IC1" library="microchip" package="DIL40" value="PIC16F887" x="36.83" y="25.4" rot="R180">
<attribute name="OC_NEWARK" value="24M5903" x="-2.54" y="74.93" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="PIC16F874-04I/P" x="-2.54" y="74.93" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="-2.54" y="74.93" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1196797" x="-2.54" y="74.93" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="R1" library="rcl" package="0207/10" value="1-10k" x="64.77" y="27.94" rot="R90"/>
<element name="C1" library="rcl" package="C050-024X044" value="100n" x="67.869753125" y="20.651159375" rot="R270"/>
<element name="S2" library="switch-dil" package="DIP02YL" value="" x="39.279484375" y="48.614475">
<attribute name="OC_NEWARK" value="unknown" x="39.279484375" y="48.614475" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="39.279484375" y="48.614475" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="39.279484375" y="48.614475" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="39.279484375" y="48.614475" size="1.778" layer="27" display="off"/>
</element>
<element name="V1" library="74ttl-din" package="DIL20" value="74244N" x="57.1122625" y="42.278953125" rot="R180"/>
<element name="SV1" library="con-amp-mt" package="S06P" value="" x="-0.25185625" y="48.48614375">
<attribute name="OC_NEWARK" value="unknown" x="-0.25185625" y="48.48614375" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="-0.25185625" y="48.48614375" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="-0.25185625" y="48.48614375" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="-0.25185625" y="48.48614375" size="1.778" layer="27" display="off"/>
</element>
<element name="SV2" library="con-amp-mt" package="S06P" value="" x="0.760453125" y="34.845571875">
<attribute name="OC_NEWARK" value="unknown" x="0.760453125" y="34.845571875" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="0.760453125" y="34.845571875" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="0.760453125" y="34.845571875" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="0.760453125" y="34.845571875" size="1.778" layer="27" display="off"/>
</element>
<element name="SV3" library="con-amp-mt" package="S06P" value="" x="23.900290625" y="48.480784375">
<attribute name="OC_NEWARK" value="unknown" x="23.900290625" y="48.480784375" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="23.900290625" y="48.480784375" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="23.900290625" y="48.480784375" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="23.900290625" y="48.480784375" size="1.778" layer="27" display="off"/>
</element>
<element name="X2" library="con-subd" package="F25VP" value="" x="51.877759375" y="60.77281875">
<attribute name="OC_NEWARK" value="unknown" x="51.877759375" y="60.77281875" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="51.877759375" y="60.77281875" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="51.877759375" y="60.77281875" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="51.877759375" y="60.77281875" size="1.778" layer="27" display="off"/>
</element>
<element name="X1" library="con-garry" package="332-10" value="332-10" x="33.022140625" y="12.276009375"/>
<element name="SV4" library="con-amp-mt" package="S06P" value="" x="12.40731875" y="60.203178125">
<attribute name="OC_NEWARK" value="unknown" x="12.40731875" y="60.203178125" size="2.54" layer="27" font="vector" ratio="22" display="off"/>
<attribute name="MPN" value="" x="12.40731875" y="60.203178125" size="2.54" layer="27" font="vector" ratio="22" display="off"/>
<attribute name="MF" value="" x="12.40731875" y="60.203178125" size="2.54" layer="27" font="vector" ratio="22" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="12.40731875" y="60.203178125" size="2.54" layer="27" font="vector" ratio="22" display="off"/>
</element>
<element name="R2" library="rcl" package="0309V" value="" x="41.91" y="38.1"/>
<element name="R3" library="rcl" package="0309V" value="" x="36.83" y="40.64" rot="R180"/>
<element name="X3" library="con-ptr500" package="AK300/2" value="" x="71.27961875" y="9.16865" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="71.27961875" y="9.16865" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="71.27961875" y="9.16865" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="71.27961875" y="9.16865" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="71.27961875" y="9.16865" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="C2" library="rcl" package="E3,5-8" value="" x="73.954040625" y="22.88039375"/>
<element name="RN1" library="resistor-net" package="RN-9" value="" x="58.40851875" y="52.002234375" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="58.40851875" y="52.002234375" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="58.40851875" y="52.002234375" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="58.40851875" y="52.002234375" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="58.40851875" y="52.002234375" size="1.778" layer="27" rot="R180" display="off"/>
</element>
</elements>
<signals>
<signal name="N$25">
<contactref element="DIS1" pad="7"/>
</signal>
<signal name="N$26">
<contactref element="DIS1" pad="8"/>
</signal>
<signal name="N$27">
<contactref element="DIS1" pad="9"/>
</signal>
<signal name="N$28">
<contactref element="DIS1" pad="10"/>
</signal>
<signal name="N$33">
<contactref element="DIS1" pad="15"/>
</signal>
<signal name="N$34">
<contactref element="DIS1" pad="16"/>
</signal>
<signal name="N$12">
<contactref element="DIS1" pad="3"/>
<contactref element="R9" pad="S"/>
<wire x1="22.759028125" y1="-0.885384375" x2="22.913271875" y2="-0.92170625" width="0.6096" layer="16"/>
<wire x1="20.27068125" y1="4.910671875" x2="22.759028125" y2="-0.885384375" width="1.016" layer="16"/>
<wire x1="22.913271875" y1="-0.92170625" x2="22.706646875" y2="-1.162321875" width="0.6096" layer="16"/>
<wire x1="20.27068125" y1="4.910671875" x2="6.370240625" y2="4.9122875" width="1.016" layer="16"/>
</signal>
<signal name="N$1">
<contactref element="DIS1" pad="12"/>
<wire x1="45.4981375" y1="-0.664209375" x2="45.566646875" y2="-1.162321875" width="0.6096" layer="16"/>
<contactref element="IC1" pad="38"/>
<wire x1="55.88" y1="17.78" x2="55.88" y2="17.510665625" width="0.6096" layer="16"/>
<wire x1="55.88" y1="17.510665625" x2="56.023653125" y2="17.358503125" width="0.6096" layer="16"/>
<wire x1="56.023653125" y1="17.358503125" x2="55.967440625" y2="14.4743" width="1.016" layer="16"/>
<wire x1="55.967440625" y1="14.4743" x2="45.560240625" y2="0.628240625" width="1.016" layer="16"/>
<wire x1="45.560240625" y1="0.628240625" x2="45.5602375" y2="-0.2456125" width="1.016" layer="16"/>
<wire x1="45.5602375" y1="-0.2456125" x2="45.4981375" y2="-0.664209375" width="0.6096" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="DIS1" pad="14"/>
<wire x1="50.646571875" y1="-1.007484375" x2="50.646646875" y2="-1.162321875" width="1.016" layer="16"/>
<contactref element="IC1" pad="40"/>
<wire x1="60.96" y1="17.78" x2="60.96" y2="14.761928125" width="1.016" layer="16"/>
<wire x1="60.96" y1="14.761928125" x2="50.4207" y2="0.6108" width="1.016" layer="16"/>
<wire x1="50.4207" y1="0.6108" x2="50.47148125" y2="-1.07433125" width="1.016" layer="16"/>
<wire x1="50.47148125" y1="-1.07433125" x2="50.646646875" y2="-1.162321875" width="0.6096" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="DIS1" pad="13"/>
<wire x1="48.02985625" y1="-0.71775625" x2="48.106646875" y2="-1.162321875" width="0.6096" layer="16"/>
<contactref element="IC1" pad="39"/>
<wire x1="58.42" y1="17.78" x2="58.383021875" y2="16.945396875" width="0.6096" layer="16"/>
<wire x1="58.383021875" y1="16.945396875" x2="58.3951125" y2="17.06841875" width="0.6096" layer="16"/>
<wire x1="58.3951125" y1="17.06841875" x2="58.395109375" y2="14.4779375" width="1.016" layer="16"/>
<wire x1="58.395109375" y1="14.4779375" x2="48.25474375" y2="0.856975" width="1.016" layer="16"/>
<wire x1="48.25474375" y1="0.856975" x2="48.3082875" y2="-1.496390625" width="1.016" layer="16"/>
<wire x1="48.3082875" y1="-1.496390625" x2="48.106646875" y2="-1.162321875" width="0.6096" layer="16"/>
</signal>
<signal name="GND">
<contactref element="DIS1" pad="1"/>
<contactref element="IC1" pad="12"/>
<contactref element="IC1" pad="31"/>
<polygon width="0.6096" layer="16">
<vertex x="83.14814375" y="-5.92799375"/>
<vertex x="-16.027125" y="-6.59764375"/>
<vertex x="-15.180921875" y="78.10500625"/>
<vertex x="85.1336125" y="77.836546875"/>
</polygon>
<contactref element="DIS1" pad="5"/>
<contactref element="C1" pad="2"/>
<contactref element="X2" pad="18"/>
<contactref element="X2" pad="19"/>
<contactref element="X2" pad="20"/>
<contactref element="X2" pad="21"/>
<contactref element="X2" pad="22"/>
<contactref element="X2" pad="23"/>
<contactref element="X2" pad="24"/>
<contactref element="X2" pad="25"/>
<contactref element="X2" pad="G2"/>
<contactref element="V1" pad="10"/>
<wire x1="50.506159375" y1="59.35041875" x2="50.5551125" y2="59.54614375" width="0.6096" layer="16"/>
<contactref element="SV3" pad="5"/>
<contactref element="SV1" pad="5"/>
<contactref element="SV2" pad="5"/>
<contactref element="X1" pad="10"/>
<via x="37.010128125" y="13.285003125" extent="1-16" drill="0.5" diameter="1.6764"/>
<via x="17.626659375" y="-1.14589375" extent="1-16" drill="0.5" diameter="1.778"/>
<wire x1="36.83" y1="13.97" x2="37.010128125" y2="13.285003125" width="0.6096" layer="16"/>
<wire x1="36.83" y1="13.97" x2="37.022140625" y2="13.276009375" width="0.6096" layer="16"/>
<wire x1="17.652128125" y1="-0.664475" x2="17.626659375" y2="-1.14589375" width="0.6096" layer="16"/>
<wire x1="17.652128125" y1="-0.664475" x2="17.626646875" y2="-1.162321875" width="0.6096" layer="16"/>
<wire x1="20.219484375" y1="47.71898125" x2="20.219484375" y2="47.65826875" width="0.6096" layer="16"/>
<wire x1="41.938721875" y1="20.34415" x2="41.89579375" y2="20.387078125" width="0.6096" layer="16"/>
<via x="27.71858125" y="-1.129225" extent="1-16" drill="0.5" diameter="1.9304"/>
<contactref element="R2" pad="2"/>
<contactref element="R3" pad="2"/>
<wire x1="27.83345625" y1="-0.610334375" x2="27.71858125" y2="-1.129225" width="0.254" layer="16"/>
<wire x1="27.83345625" y1="-0.610334375" x2="27.786646875" y2="-1.162321875" width="0.254" layer="16"/>
<contactref element="X3" pad="1"/>
<contactref element="R9" pad="E"/>
<wire x1="41.89579375" y1="20.387078125" x2="42.08565" y2="20.245609375" width="0.3048" layer="16"/>
<contactref element="C2" pad="-"/>
<wire x1="21.73298125" y1="31.402721875" x2="21.73298125" y2="31.381328125" width="0.3048" layer="16"/>
<wire x1="21.73298125" y1="31.381328125" x2="21.711590625" y2="31.3599375" width="0.3048" layer="16"/>
<wire x1="21.711590625" y1="31.3599375" x2="21.711590625" y2="31.38133125" width="0.3048" layer="16"/>
<wire x1="21.711590625" y1="31.38133125" x2="21.6902" y2="31.402721875" width="0.3048" layer="16"/>
<wire x1="21.6902" y1="31.402721875" x2="21.6902" y2="31.63803125" width="0.3048" layer="16"/>
<wire x1="21.6902" y1="31.63803125" x2="26.46068125" y2="29.850490625" width="0.3048" layer="16"/>
<wire x1="26.46068125" y1="29.850490625" x2="17.29399375" y2="29.850490625" width="0.3048" layer="16"/>
<wire x1="17.29399375" y1="29.850490625" x2="18.876025" y2="29.99633125" width="0.3048" layer="16"/>
<wire x1="21.58740625" y1="19.8550125" x2="21.58740625" y2="14.86373125" width="0.3048" layer="16"/>
<wire x1="21.58740625" y1="14.86373125" x2="21.478640625" y2="14.665846875" width="0.3048" layer="16"/>
<wire x1="44.498071875" y1="34.4770625" x2="44.498071875" y2="29.97873125" width="0.3048" layer="16"/>
<wire x1="44.498071875" y1="29.97873125" x2="44.405621875" y2="29.88628125" width="0.3048" layer="16"/>
<wire x1="44.405621875" y1="29.88628125" x2="44.405621875" y2="29.855471875" width="0.3048" layer="16"/>
<wire x1="-3.850028125" y1="48.83679375" x2="-2.67363125" y2="50.804809375" width="0.6096" layer="16"/>
<wire x1="38.1" y1="17.78" x2="38.49820625" y2="17.78" width="0.4064" layer="16"/>
<wire x1="38.49820625" y1="17.78" x2="38.49820625" y2="15.14463125" width="0.4064" layer="16"/>
<via x="38.49820625" y="15.14463125" extent="1-16" drill="0.6" shape="square"/>
<wire x1="38.49820625" y1="15.14463125" x2="64.09595625" y2="15.14463125" width="0.4064" layer="1"/>
<wire x1="64.09595625" y1="15.14463125" x2="64.09595625" y2="14.941346875" width="0.4064" layer="1"/>
<via x="64.09595625" y="14.941346875" extent="1-16" drill="0.6" shape="square"/>
<wire x1="64.09595625" y1="14.941346875" x2="63.384909375" y2="14.941346875" width="0.4064" layer="16"/>
<wire x1="63.384909375" y1="14.941346875" x2="63.384909375" y2="7.21656875" width="0.4064" layer="16"/>
<wire x1="35.56" y1="40.64" x2="35.127221875" y2="40.64" width="0.4064" layer="16"/>
<wire x1="35.127221875" y1="40.64" x2="35.127221875" y2="43.998865625" width="0.4064" layer="16"/>
<via x="35.127221875" y="43.998865625" extent="1-16" drill="0.6" shape="square"/>
<wire x1="35.127221875" y1="43.998865625" x2="19.96185625" y2="43.998865625" width="0.4064" layer="1"/>
<wire x1="19.96185625" y1="43.998865625" x2="19.96185625" y2="44.1398875" width="0.4064" layer="1"/>
<via x="19.96185625" y="44.1398875" extent="1-16" drill="0.6" shape="square"/>
<wire x1="19.96185625" y1="44.1398875" x2="20.150290625" y2="44.1398875" width="0.4064" layer="16"/>
<wire x1="20.150290625" y1="44.1398875" x2="20.150290625" y2="48.480784375" width="0.4064" layer="16"/>
<wire x1="56.017959375" y1="59.35041875" x2="55.698221875" y2="55.277675" width="0.4064" layer="16"/>
<via x="55.698221875" y="55.277675" extent="1-16" drill="0.6" shape="square"/>
<wire x1="55.698221875" y1="55.277675" x2="52.611740625" y2="55.277675" width="0.4064" layer="1"/>
<via x="52.611740625" y="55.277675" extent="1-16" drill="0.6" shape="square"/>
<wire x1="52.611740625" y1="55.277675" x2="52.611740625" y2="55.24935625" width="0.4064" layer="16"/>
<via x="52.611740625" y="55.24935625" extent="1-16" drill="0.6" shape="square"/>
<wire x1="52.611740625" y1="55.24935625" x2="50.03495625" y2="55.277675" width="0.4064" layer="1"/>
<via x="50.03495625" y="55.277675" extent="1-16" drill="0.6" shape="square"/>
<wire x1="50.03495625" y1="55.277675" x2="50.506159375" y2="59.35041875" width="0.4064" layer="16"/>
<wire x1="47.737559375" y1="59.35041875" x2="47.288271875" y2="57.1750125" width="0.4064" layer="16"/>
<wire x1="47.288271875" y1="57.1750125" x2="46.89184375" y2="55.19271875" width="0.4064" layer="16"/>
<via x="46.89184375" y="55.19271875" extent="1-16" drill="0.6" shape="square"/>
<wire x1="46.89184375" y1="55.19271875" x2="50.03495625" y2="55.277675" width="0.4064" layer="1"/>
<wire x1="20.150290625" y1="48.480784375" x2="20.219484375" y2="47.71898125" width="0" layer="19" extent="16-16"/>
<wire x1="-4.00185625" y1="48.48614375" x2="-3.850028125" y2="48.83679375" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$5">
<contactref element="IC1" pad="7"/>
<contactref element="V1" pad="7"/>
<wire x1="46.12871875" y1="30.45145" x2="45.72" y2="33.02" width="0.3048" layer="16"/>
<wire x1="51.576253125" y1="30.448396875" x2="46.12871875" y2="30.45145" width="0.3048" layer="16"/>
<wire x1="51.998365625" y1="30.84466875" x2="51.576253125" y2="30.448396875" width="0.3048" layer="16"/>
<wire x1="52.009246875" y1="43.673815625" x2="51.998365625" y2="30.84466875" width="0.3048" layer="16"/>
<wire x1="53.34" y1="45.72" x2="52.009246875" y2="43.673815625" width="0.3048" layer="16"/>
<wire x1="53.34" y1="45.72" x2="53.3022625" y2="46.088953125" width="0.6096" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="IC1" pad="6"/>
<contactref element="V1" pad="9"/>
<wire x1="48.2222625" y1="46.088953125" x2="48.26" y2="41.91" width="0.3048" layer="16"/>
<wire x1="48.26" y1="41.91" x2="46.99" y2="40.64" width="0.3048" layer="16"/>
<wire x1="46.99" y1="40.64" x2="46.99" y2="35.56" width="0.3048" layer="16"/>
<wire x1="46.99" y1="35.56" x2="48.26" y2="33.02" width="0.3048" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="IC1" pad="5"/>
<contactref element="V1" pad="12"/>
<wire x1="50.8" y1="35.56" x2="50.8" y2="33.02" width="0.6096" layer="16"/>
<wire x1="48.26" y1="38.1" x2="50.8" y2="35.56" width="0.6096" layer="16"/>
<wire x1="48.26" y1="38.1" x2="48.2222625" y2="38.468953125" width="0.6096" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="IC1" pad="4"/>
<contactref element="V1" pad="14"/>
<wire x1="53.34" y1="38.1" x2="53.34" y2="33.02" width="0.6096" layer="16"/>
<wire x1="53.34" y1="38.1" x2="53.3022625" y2="38.468953125" width="0.6096" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="IC1" pad="3"/>
<contactref element="V1" pad="16"/>
<wire x1="55.88" y1="35.56" x2="55.88" y2="33.02" width="0.6096" layer="16"/>
<wire x1="58.42" y1="38.1" x2="55.88" y2="35.56" width="0.6096" layer="16"/>
<wire x1="58.42" y1="38.1" x2="58.3822625" y2="38.468953125" width="0.6096" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="IC1" pad="2"/>
<contactref element="V1" pad="18"/>
<wire x1="63.5" y1="38.1" x2="63.246803125" y2="36.6172125" width="0.6096" layer="16"/>
<wire x1="63.246803125" y1="36.6172125" x2="58.497746875" y2="34.88621875" width="0.6096" layer="16"/>
<wire x1="58.497746875" y1="34.88621875" x2="58.497746875" y2="33.02" width="0.6096" layer="16"/>
<wire x1="58.497746875" y1="33.02" x2="58.42" y2="33.02" width="0.6096" layer="16"/>
<wire x1="63.5" y1="38.1" x2="63.4622625" y2="38.468953125" width="0.6096" layer="16"/>
</signal>
<signal name="N$37">
<contactref element="IC1" pad="1"/>
<contactref element="R1" pad="2"/>
<wire x1="64.77" y1="33.02" x2="60.96" y2="33.02" width="0.6096" layer="16"/>
</signal>
<signal name="N$43">
<contactref element="IC1" pad="9"/>
<contactref element="S2" pad="1"/>
<wire x1="40.64" y1="33.02" x2="40.3122625" y2="33.396175" width="0.6096" layer="16"/>
<wire x1="40.3122625" y1="33.396175" x2="38.129796875" y2="37.843" width="1.016" layer="16"/>
<wire x1="38.129796875" y1="37.843" x2="38.1" y2="40.64" width="1.016" layer="16"/>
<wire x1="38.1" y1="40.64" x2="38.009484375" y2="44.804475" width="1.016" layer="16"/>
<contactref element="R3" pad="1"/>
</signal>
<signal name="N$44">
<contactref element="IC1" pad="8"/>
<contactref element="S2" pad="2"/>
<wire x1="43.18" y1="33.02" x2="42.88205625" y2="33.414828125" width="0.6096" layer="16"/>
<wire x1="42.88205625" y1="33.414828125" x2="40.64" y2="38.1" width="1.016" layer="16"/>
<wire x1="40.64" y1="38.1" x2="40.549484375" y2="44.804475" width="1.016" layer="16"/>
<contactref element="R2" pad="1"/>
</signal>
<signal name="N$41">
</signal>
<signal name="N$45">
</signal>
<signal name="N$47">
</signal>
<signal name="N$48">
</signal>
<signal name="N$55">
<contactref element="X2" pad="1"/>
<contactref element="V1" pad="2"/>
<contactref element="RN1" pad="2"/>
<wire x1="68.438559375" y1="62.19521875" x2="68.691959375" y2="62.19521875" width="0.4064" layer="16"/>
<wire x1="68.691959375" y1="62.19521875" x2="68.691959375" y2="55.765821875" width="0.4064" layer="16"/>
<wire x1="68.691959375" y1="55.765821875" x2="65.987725" y2="53.9303125" width="0.4064" layer="16"/>
<wire x1="65.987725" y1="53.9303125" x2="66.02851875" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="66.02851875" y1="52.002234375" x2="66.0022625" y2="46.088953125" width="0.4064" layer="16"/>
</signal>
<signal name="N$56">
<contactref element="X2" pad="2"/>
<contactref element="V1" pad="4"/>
<contactref element="RN1" pad="3"/>
<wire x1="65.669959375" y1="62.19521875" x2="65.65639375" y2="62.19521875" width="0.4064" layer="16"/>
<wire x1="65.65639375" y1="62.19521875" x2="65.65639375" y2="55.4231" width="0.4064" layer="16"/>
<wire x1="65.65639375" y1="55.4231" x2="63.61089375" y2="53.34285625" width="0.4064" layer="16"/>
<wire x1="63.61089375" y1="53.34285625" x2="63.48851875" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="63.48851875" y1="52.002234375" x2="63.44936875" y2="50.13086875" width="0.4064" layer="16"/>
<wire x1="63.44936875" y1="50.13086875" x2="60.866534375" y2="47.547853125" width="0.4064" layer="16"/>
<wire x1="60.866534375" y1="47.547853125" x2="60.9222625" y2="46.088953125" width="0.4064" layer="16"/>
</signal>
<signal name="N$57">
<contactref element="X2" pad="3"/>
<contactref element="V1" pad="1"/>
<contactref element="RN1" pad="4"/>
<wire x1="62.9805" y1="62.248959375" x2="62.926759375" y2="62.19521875" width="0.6096" layer="16"/>
<wire x1="62.926759375" y1="62.19521875" x2="62.932871875" y2="62.218815625" width="0.4064" layer="16"/>
<wire x1="62.932871875" y1="62.218815625" x2="62.932871875" y2="55.6425375" width="0.4064" layer="16"/>
<wire x1="62.932871875" y1="55.6425375" x2="60.907725" y2="53.21238125" width="0.4064" layer="16"/>
<wire x1="60.907725" y1="53.21238125" x2="60.94851875" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="60.94851875" y1="52.002234375" x2="60.9257" y2="49.4995625" width="0.4064" layer="16"/>
<wire x1="60.9257" y1="49.4995625" x2="59.670503125" y2="48.1787375" width="0.4064" layer="16"/>
<wire x1="59.670503125" y1="48.1787375" x2="59.71945" y2="44.06606875" width="0.4064" layer="16"/>
<wire x1="59.71945" y1="44.06606875" x2="68.1349" y2="44.162221875" width="0.4064" layer="16"/>
<wire x1="68.1349" y1="44.162221875" x2="68.5422625" y2="46.088953125" width="0.4064" layer="16"/>
</signal>
<signal name="N$58">
<contactref element="X2" pad="4"/>
<contactref element="V1" pad="6"/>
<contactref element="RN1" pad="5"/>
<wire x1="60.158159375" y1="62.19521875" x2="60.4405" y2="62.19521875" width="0.4064" layer="16"/>
<wire x1="60.158159375" y1="62.19521875" x2="60.165703125" y2="62.2424125" width="0.4064" layer="16"/>
<wire x1="60.165703125" y1="62.2424125" x2="60.165703125" y2="56.05781875" width="0.4064" layer="16"/>
<wire x1="60.165703125" y1="56.05781875" x2="58.4493125" y2="53.604065625" width="0.4064" layer="16"/>
<wire x1="58.4493125" y1="53.604065625" x2="58.40851875" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="58.40851875" y1="52.002234375" x2="58.4196375" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="58.4196375" y1="52.002234375" x2="58.514015625" y2="49.455009375" width="0.4064" layer="16"/>
<wire x1="58.514015625" y1="49.455009375" x2="55.727275" y2="47.147771875" width="0.4064" layer="16"/>
<wire x1="55.727275" y1="47.147771875" x2="55.8422625" y2="46.088953125" width="0.4064" layer="16"/>
</signal>
<signal name="N$59">
<contactref element="X2" pad="5"/>
<contactref element="V1" pad="8"/>
<wire x1="50.5698875" y1="46.246215625" x2="50.7622625" y2="46.088953125" width="0.6096" layer="16"/>
<contactref element="RN1" pad="6"/>
<wire x1="57.389559375" y1="62.19521875" x2="57.43629375" y2="62.19521875" width="0.4064" layer="16"/>
<wire x1="57.43629375" y1="62.19521875" x2="57.43629375" y2="56.010625" width="0.4064" layer="16"/>
<wire x1="57.43629375" y1="56.010625" x2="55.786934375" y2="52.95144375" width="0.4064" layer="16"/>
<wire x1="55.786934375" y1="52.95144375" x2="55.86851875" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="55.86851875" y1="52.002234375" x2="55.71185" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="55.71185" y1="52.002234375" x2="55.64388125" y2="50.7357875" width="0.4064" layer="16"/>
<wire x1="55.64388125" y1="50.7357875" x2="50.738665625" y2="47.467590625" width="0.4064" layer="16"/>
<wire x1="50.738665625" y1="47.467590625" x2="50.7622625" y2="46.088953125" width="0.4064" layer="16"/>
</signal>
<signal name="N$60">
<contactref element="X2" pad="7"/>
<contactref element="V1" pad="13"/>
<contactref element="RN1" pad="8"/>
<wire x1="51.877759375" y1="62.19521875" x2="51.842378125" y2="62.25949375" width="0.4064" layer="16"/>
<wire x1="51.877759375" y1="62.19521875" x2="51.79188125" y2="62.10083125" width="0.4064" layer="16"/>
<wire x1="51.79188125" y1="62.10083125" x2="51.862665625" y2="58.420334375" width="0.4064" layer="16"/>
<wire x1="51.862665625" y1="58.420334375" x2="50.992478125" y2="53.4100375" width="0.4064" layer="16"/>
<wire x1="50.992478125" y1="53.4100375" x2="50.78851875" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="50.78851875" y1="52.002234375" x2="50.875040625" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="50.875040625" y1="52.002234375" x2="49.492059375" y2="49.373684375" width="0.4064" layer="16"/>
<wire x1="49.492059375" y1="49.373684375" x2="49.465109375" y2="49.347959375" width="0.4064" layer="16"/>
<wire x1="49.465109375" y1="49.347959375" x2="49.465109375" y2="41.123296875" width="0.4064" layer="16"/>
<wire x1="49.465109375" y1="41.123296875" x2="50.70563125" y2="39.87728125" width="0.4064" layer="16"/>
<wire x1="50.70563125" y1="39.87728125" x2="50.7622625" y2="38.468953125" width="0.4064" layer="16"/>
</signal>
<signal name="N$61">
<contactref element="X2" pad="8"/>
<contactref element="V1" pad="11"/>
<contactref element="RN1" pad="9"/>
<wire x1="49.109159375" y1="62.19521875" x2="49.112625" y2="62.19521875" width="0.4064" layer="16"/>
<wire x1="49.10319375" y1="58.326109375" x2="49.112625" y2="62.19521875" width="0.4064" layer="16"/>
<wire x1="49.10319375" y1="58.326109375" x2="48.289309375" y2="52.9628875" width="0.4064" layer="16"/>
<wire x1="48.289309375" y1="52.9628875" x2="48.24851875" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="48.24851875" y1="52.002234375" x2="46.997728125" y2="49.335790625" width="0.4064" layer="16"/>
<wire x1="46.997728125" y1="49.335790625" x2="46.997728125" y2="43.120715625" width="0.4064" layer="16"/>
<wire x1="46.997728125" y1="43.120715625" x2="45.597315625" y2="40.402140625" width="0.4064" layer="16"/>
<wire x1="45.597315625" y1="40.402140625" x2="45.6822625" y2="38.468953125" width="0.4064" layer="16"/>
</signal>
<signal name="N$62">
<contactref element="X2" pad="6"/>
<contactref element="V1" pad="19"/>
<contactref element="RN1" pad="7"/>
<wire x1="54.646359375" y1="62.19521875" x2="54.632971875" y2="56.5491875" width="0.4064" layer="16"/>
<wire x1="54.632971875" y1="56.5491875" x2="53.1153875" y2="52.681321875" width="0.4064" layer="16"/>
<wire x1="53.1153875" y1="52.681321875" x2="53.32851875" y2="52.002234375" width="0.4064" layer="16"/>
<wire x1="66.0022625" y1="38.468953125" x2="65.941409375" y2="35.643125" width="0.4064" layer="16"/>
<via x="65.941409375" y="35.643125" extent="1-16" drill="0.6" shape="square"/>
<wire x1="65.941409375" y1="35.643125" x2="71.52220625" y2="35.692084375" width="0.4064" layer="1"/>
<via x="71.52220625" y="35.692084375" extent="1-16" drill="0.6" shape="square"/>
<wire x1="71.52220625" y1="35.692084375" x2="71.6491625" y2="35.73780625" width="0.4064" layer="16"/>
<wire x1="71.6491625" y1="35.73780625" x2="72.458090625" y2="39.151184375" width="0.4064" layer="16"/>
<wire x1="72.458090625" y1="39.151184375" x2="72.452265625" y2="64.823484375" width="0.4064" layer="16"/>
<wire x1="72.452265625" y1="64.823484375" x2="54.97565" y2="64.823484375" width="0.4064" layer="16"/>
<wire x1="54.97565" y1="64.823484375" x2="54.646359375" y2="62.19521875" width="0.4064" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="SV2" pad="4"/>
<contactref element="IC1" pad="24"/>
<wire x1="18.8287375" y1="11.80520625" x2="20.32" y2="17.78" width="1.016" layer="16"/>
<wire x1="7.168434375" y1="11.7626125" x2="18.8287375" y2="11.80520625" width="1.016" layer="16"/>
<wire x1="-0.471096875" y1="33.919796875" x2="7.168434375" y2="11.7626125" width="1.016" layer="16"/>
<wire x1="-0.72685625" y1="33.52785" x2="-0.471096875" y2="33.919796875" width="0.254" layer="16"/>
<wire x1="-0.72685625" y1="33.52785" x2="-0.489546875" y2="34.845571875" width="0.254" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="SV2" pad="3"/>
<contactref element="IC1" pad="23"/>
<wire x1="16.450715625" y1="13.36455" x2="17.78" y2="17.78" width="1.016" layer="16"/>
<wire x1="9.659734375" y1="13.3717125" x2="16.450715625" y2="13.36455" width="1.016" layer="16"/>
<wire x1="2.044603125" y1="33.959271875" x2="9.659734375" y2="13.3717125" width="1.016" layer="16"/>
<wire x1="1.967178125" y1="34.7455625" x2="2.044603125" y2="33.959271875" width="0.254" layer="16"/>
<wire x1="1.967178125" y1="34.7455625" x2="2.010453125" y2="34.845571875" width="0.254" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="SV2" pad="2"/>
<contactref element="IC1" pad="22"/>
<wire x1="13.914621875" y1="15.0482375" x2="15.24" y2="17.78" width="1.016" layer="16"/>
<wire x1="11.6348125" y1="15.091871875" x2="13.914621875" y2="15.0482375" width="1.016" layer="16"/>
<wire x1="4.5739875" y1="34.366640625" x2="11.6348125" y2="15.091871875" width="1.016" layer="16"/>
<wire x1="4.5739875" y1="34.366640625" x2="4.510453125" y2="34.845571875" width="0.254" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="SV2" pad="1"/>
<contactref element="IC1" pad="21"/>
<wire x1="6.928384375" y1="34.7403875" x2="12.7" y2="17.78" width="1.016" layer="16"/>
<wire x1="7.146903125" y1="34.70924375" x2="6.928384375" y2="34.7403875" width="0.254" layer="16"/>
<wire x1="7.115740625" y1="34.51021875" x2="7.146903125" y2="34.70924375" width="0.254" layer="16"/>
<wire x1="7.115740625" y1="34.51021875" x2="7.010453125" y2="34.845571875" width="0.254" layer="16"/>
</signal>
<signal name="N$35">
<contactref element="IC1" pad="27"/>
<contactref element="X1" pad="2"/>
<wire x1="27.94" y1="17.78" x2="27.812990625" y2="17.78" width="0.6096" layer="16"/>
<wire x1="27.812990625" y1="17.78" x2="27.937109375" y2="17.41896875" width="0.6096" layer="16"/>
<wire x1="27.937109375" y1="17.41896875" x2="28.01960625" y2="16.669446875" width="0.6096" layer="16"/>
<wire x1="28.01960625" y1="16.669446875" x2="27.92715625" y2="16.993934375" width="0.6096" layer="16"/>
<wire x1="27.92715625" y1="16.993934375" x2="27.877046875" y2="16.993934375" width="0.6096" layer="16"/>
<wire x1="27.877046875" y1="16.993934375" x2="27.877046875" y2="15.2361375" width="0.6096" layer="16"/>
<wire x1="27.877046875" y1="15.2361375" x2="29.022140625" y2="13.0809875" width="0.6096" layer="16"/>
<wire x1="29.022140625" y1="13.0809875" x2="29.022140625" y2="13.276009375" width="0.6096" layer="16"/>
</signal>
<signal name="N$36">
<contactref element="IC1" pad="28"/>
<contactref element="X1" pad="4"/>
<wire x1="30.48" y1="17.78" x2="30.351896875" y2="17.606225" width="0.6096" layer="16"/>
<wire x1="30.351896875" y1="17.606225" x2="30.347184375" y2="17.513790625" width="0.6096" layer="16"/>
<wire x1="30.347184375" y1="17.513790625" x2="30.260384375" y2="17.513790625" width="0.6096" layer="16"/>
<wire x1="30.260384375" y1="17.513790625" x2="30.260384375" y2="15.129028125" width="0.6096" layer="16"/>
<wire x1="30.260384375" y1="15.129028125" x2="30.260384375" y2="15.15580625" width="0.6096" layer="16"/>
<wire x1="30.260384375" y1="15.15580625" x2="30.31394375" y2="15.15580625" width="0.6096" layer="16"/>
<wire x1="30.31394375" y1="15.15580625" x2="30.31394375" y2="14.9148125" width="0.6096" layer="16"/>
<wire x1="30.31394375" y1="14.9148125" x2="30.31394375" y2="14.968365625" width="0.6096" layer="16"/>
<wire x1="30.31394375" y1="14.968365625" x2="30.963503125" y2="13.52326875" width="0.6096" layer="16"/>
<wire x1="30.963503125" y1="13.52326875" x2="31.022140625" y2="13.276009375" width="0.6096" layer="16"/>
</signal>
<signal name="N$38">
<contactref element="IC1" pad="29"/>
<contactref element="X1" pad="6"/>
<wire x1="33.02" y1="17.78" x2="33.022140625" y2="17.78" width="0.6096" layer="16"/>
<wire x1="33.022140625" y1="17.78" x2="33.022140625" y2="13.276009375" width="0.6096" layer="16"/>
</signal>
<signal name="N$39">
<contactref element="IC1" pad="30"/>
<contactref element="X1" pad="8"/>
<wire x1="35.56" y1="17.78" x2="35.543440625" y2="17.606225" width="0.6096" layer="16"/>
<wire x1="35.543440625" y1="17.606225" x2="35.080625" y2="15.5842375" width="0.6096" layer="16"/>
<wire x1="35.080625" y1="15.5842375" x2="35.080625" y2="13.276009375" width="0.6096" layer="16"/>
<wire x1="35.080625" y1="13.276009375" x2="35.022140625" y2="13.276009375" width="0.6096" layer="16"/>
</signal>
<signal name="N$51">
<via x="67.87740625" y="23.113596875" extent="1-16" drill="0.5" diameter="1.778" shape="square"/>
</signal>
<signal name="N$52">
<via x="64.7815875" y="22.91165625" extent="1-16" drill="0.5" diameter="1.778" shape="square"/>
</signal>
<signal name="N$53">
<via x="64.689075" y="33.1313125" extent="1-16" drill="0.5" diameter="1.778" shape="square"/>
</signal>
<signal name="N$68">
<via x="5.64610625" y="5.2979375" extent="1-16" drill="0.5" diameter="3.81" shape="octagon"/>
</signal>
<signal name="N$69">
<via x="-4.146071875" y="8.235646875" extent="1-16" drill="0.5" diameter="3.81" shape="octagon"/>
</signal>
<signal name="N$70">
<via x="3.093440625" y="5.218465625" extent="1-16" drill="0.5" diameter="3.81" shape="octagon"/>
</signal>
<signal name="N$73">
<via x="4.513971875" y="5.29695" extent="1-16" drill="0.5" diameter="3.81" shape="octagon"/>
</signal>
<signal name="N$75">
<via x="50.631028125" y="-1.33374375" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$76">
<via x="48.08981875" y="-1.231759375" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$77">
<via x="45.515053125" y="-1.215190625" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$78">
<via x="43.130609375" y="-1.18416875" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$79">
<via x="40.4460625" y="-1.06305625" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$80">
<via x="37.99865625" y="-1.242396875" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$81">
<via x="35.435809375" y="-1.178475" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$82">
<via x="32.791578125" y="-1.16650625" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$83">
<via x="30.303103125" y="-1.186815625" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$84">
<via x="25.229065625" y="-1.13015" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$85">
</signal>
<signal name="N$86">
<via x="22.612715625" y="-1.242396875" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$87">
<via x="20.129553125" y="-1.342015625" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$88">
<via x="53.231515625" y="-1.155015625" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$89">
<via x="55.88350625" y="-1.078275" extent="1-16" drill="0.5" diameter="1.9304"/>
</signal>
<signal name="N$74">
<via x="29.040915625" y="13.272184375" extent="1-16" drill="0.5" diameter="1.27"/>
</signal>
<signal name="N$90">
<via x="29.012190625" y="13.272184375" extent="1-16" drill="0.5" diameter="1.6764"/>
</signal>
<signal name="N$91">
<via x="31.0229375" y="13.272184375" extent="1-16" drill="0.5" diameter="1.6764"/>
</signal>
<signal name="N$92">
<via x="33.00495625" y="13.272184375" extent="1-16" drill="0.5" diameter="1.6764"/>
</signal>
<signal name="N$93">
<via x="35.030065625" y="13.272184375" extent="1-16" drill="0.5" diameter="1.6764"/>
</signal>
<signal name="N$94">
<via x="37.02645" y="11.289975" extent="1-16" drill="0.5" diameter="1.6764"/>
</signal>
<signal name="N$95">
<via x="35.015703125" y="11.289975" extent="1-16" drill="0.5" diameter="1.6764"/>
</signal>
<signal name="N$96">
<via x="33.01931875" y="11.289975" extent="1-16" drill="0.5" diameter="1.6764"/>
</signal>
<signal name="N$97">
<via x="31.0373" y="11.261246875" extent="1-16" drill="0.5" diameter="1.6764"/>
</signal>
<signal name="N$98">
<via x="29.026553125" y="11.2756125" extent="1-16" drill="0.5" diameter="1.6764"/>
</signal>
<signal name="N$99">
<contactref element="SV4" pad="1"/>
<contactref element="X2" pad="13"/>
<wire x1="35.316959375" y1="62.19521875" x2="35.110928125" y2="62.19521875" width="0.6096" layer="16"/>
<wire x1="35.110928125" y1="62.19521875" x2="33.3963875" y2="64.45826875" width="1.016" layer="16"/>
<wire x1="33.3963875" y1="64.45826875" x2="20.54273125" y2="64.48926875" width="1.016" layer="16"/>
<wire x1="20.54273125" y1="64.48926875" x2="18.729675" y2="62.223575" width="1.016" layer="16"/>
<wire x1="18.729675" y1="62.223575" x2="18.6803" y2="60.226159375" width="1.016" layer="16"/>
<wire x1="18.6803" y1="60.226159375" x2="18.65731875" y2="60.203178125" width="0.6096" layer="16"/>
</signal>
<signal name="N$100">
<contactref element="SV4" pad="2"/>
<contactref element="X2" pad="12"/>
<wire x1="38.085559375" y1="62.19521875" x2="38.126346875" y2="62.337484375" width="0.6096" layer="16"/>
<wire x1="38.126346875" y1="62.337484375" x2="34.932390625" y2="66.365071875" width="1.016" layer="16"/>
<wire x1="34.932390625" y1="66.365071875" x2="18.246265625" y2="66.326778125" width="1.016" layer="16"/>
<wire x1="18.246265625" y1="66.326778125" x2="16.23596875" y2="63.807453125" width="1.016" layer="16"/>
<wire x1="16.23596875" y1="63.807453125" x2="16.1380625" y2="60.222434375" width="1.016" layer="16"/>
<wire x1="16.1380625" y1="60.222434375" x2="16.15731875" y2="60.203178125" width="0.6096" layer="16"/>
</signal>
<signal name="N$101">
<contactref element="SV4" pad="3"/>
<contactref element="X2" pad="11"/>
<wire x1="40.828759375" y1="62.19521875" x2="40.99190625" y2="62.678353125" width="1.016" layer="16"/>
<wire x1="40.99190625" y1="62.678353125" x2="37.0294375" y2="68.118334375" width="1.016" layer="16"/>
<wire x1="37.0294375" y1="68.118334375" x2="16.271615625" y2="68.120871875" width="1.016" layer="16"/>
<wire x1="16.271615625" y1="68.120871875" x2="13.632303125" y2="64.699625" width="1.016" layer="16"/>
<wire x1="13.632303125" y1="64.699625" x2="13.587390625" y2="60.443028125" width="1.016" layer="16"/>
<wire x1="13.587390625" y1="60.443028125" x2="13.65731875" y2="60.203178125" width="0.6096" layer="16"/>
</signal>
<signal name="N$102">
<contactref element="SV4" pad="4"/>
<contactref element="X2" pad="10"/>
<wire x1="43.597359375" y1="62.19521875" x2="43.475" y2="63.147465625" width="1.016" layer="16"/>
<wire x1="43.475" y1="63.147465625" x2="38.759384375" y2="70.03201875" width="1.016" layer="16"/>
<wire x1="38.759384375" y1="70.03201875" x2="14.56255" y2="70.02755" width="1.016" layer="16"/>
<wire x1="14.56255" y1="70.02755" x2="11.181203125" y2="65.11136875" width="1.016" layer="16"/>
<wire x1="11.181203125" y1="65.11136875" x2="11.129696875" y2="60.2308" width="1.016" layer="16"/>
<wire x1="11.129696875" y1="60.2308" x2="11.15731875" y2="60.203178125" width="0.6096" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="SV1" pad="4"/>
<contactref element="IC1" pad="20"/>
<wire x1="12.4869125" y1="35.666515625" x2="12.7" y2="33.02" width="1.016" layer="16"/>
<wire x1="-1.4243" y1="44.81685" x2="12.4869125" y2="35.666515625" width="1.016" layer="16"/>
<wire x1="-1.317746875" y1="48.315475" x2="-1.4243" y2="44.81685" width="1.016" layer="16"/>
<wire x1="-1.317746875" y1="48.315475" x2="-1.50185625" y2="48.48614375" width="0.254" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="SV1" pad="3"/>
<contactref element="IC1" pad="19"/>
<wire x1="15.24" y1="36.260509375" x2="15.24" y2="33.02" width="1.016" layer="16"/>
<wire x1="1.12980625" y1="45.287196875" x2="15.24" y2="36.260509375" width="1.016" layer="16"/>
<wire x1="1.12980625" y1="48.77765625" x2="1.12980625" y2="45.287196875" width="1.016" layer="16"/>
<wire x1="1.12980625" y1="48.77765625" x2="0.99814375" y2="48.48614375" width="0.254" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="SV1" pad="2"/>
<contactref element="IC1" pad="18"/>
<wire x1="3.620146875" y1="45.832590625" x2="17.590121875" y2="36.929528125" width="1.016" layer="16"/>
<wire x1="17.590121875" y1="36.929528125" x2="17.749921875" y2="33.02" width="1.016" layer="16"/>
<wire x1="17.749921875" y1="33.02" x2="17.78" y2="33.02" width="0.6096" layer="16"/>
<wire x1="3.58933125" y1="49.011871875" x2="3.620146875" y2="45.832590625" width="1.016" layer="16"/>
<wire x1="3.58933125" y1="49.011871875" x2="3.49814375" y2="48.48614375" width="0.254" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="IC1" pad="17"/>
<contactref element="SV1" pad="1"/>
<wire x1="5.9140125" y1="46.279728125" x2="20.1703875" y2="37.680778125" width="1.016" layer="16"/>
<wire x1="20.1703875" y1="37.680778125" x2="20.19859375" y2="33.02" width="1.016" layer="16"/>
<wire x1="20.19859375" y1="33.02" x2="20.32" y2="33.02" width="0.6096" layer="16"/>
<wire x1="6.465303125" y1="48.24441875" x2="6.563078125" y2="48.26" width="0.6096" layer="16"/>
<wire x1="6.563078125" y1="48.26" x2="5.971490625" y2="48.351828125" width="0.6096" layer="16"/>
<wire x1="5.971490625" y1="48.351828125" x2="5.9140125" y2="46.279728125" width="0.6096" layer="16"/>
<wire x1="6.00601875" y1="48.518840625" x2="6.39563125" y2="48.615240625" width="0.254" layer="16"/>
<wire x1="6.39563125" y1="48.615240625" x2="6.099834375" y2="48.666746875" width="0.254" layer="16"/>
<wire x1="6.099834375" y1="48.666746875" x2="6.465303125" y2="48.24441875" width="0.254" layer="16"/>
<wire x1="6.00601875" y1="48.518840625" x2="5.99814375" y2="48.48614375" width="1.016" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="SV3" pad="1"/>
<contactref element="IC1" pad="13"/>
<wire x1="30.48" y1="48.26" x2="30.48" y2="33.02" width="1.016" layer="16"/>
<wire x1="30.48" y1="48.26" x2="30.150290625" y2="48.480784375" width="0.254" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="SV3" pad="2"/>
<contactref element="IC1" pad="14"/>
<wire x1="27.94" y1="48.26" x2="27.94" y2="33.02" width="1.016" layer="16"/>
<wire x1="27.94" y1="48.26" x2="27.650290625" y2="48.480784375" width="0.254" layer="16"/>
</signal>
<signal name="N$32">
<contactref element="SV3" pad="3"/>
<contactref element="IC1" pad="15"/>
<wire x1="25.4" y1="48.26" x2="25.4" y2="33.02" width="1.016" layer="16"/>
<wire x1="25.4" y1="48.26" x2="25.150290625" y2="48.480784375" width="0.254" layer="16"/>
</signal>
<signal name="N$103">
<contactref element="SV3" pad="4"/>
<contactref element="IC1" pad="16"/>
<wire x1="22.86" y1="48.26" x2="22.86" y2="33.02" width="1.016" layer="16"/>
<wire x1="22.86" y1="48.26" x2="22.650290625" y2="48.480784375" width="0.254" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="IC1" pad="25"/>
<contactref element="X1" pad="3"/>
<wire x1="31.022140625" y1="11.276009375" x2="30.30088125" y2="9.32555" width="0.6096" layer="16"/>
<wire x1="30.30088125" y1="9.32555" x2="27.0235" y2="9.32555" width="0.6096" layer="16"/>
<wire x1="27.0235" y1="9.32555" x2="22.88063125" y2="14.70148125" width="0.6096" layer="16"/>
<wire x1="22.88063125" y1="14.70148125" x2="22.86" y2="17.78" width="0.6096" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="IC1" pad="26"/>
<contactref element="X1" pad="1"/>
<wire x1="29.022140625" y1="11.276009375" x2="27.734884375" y2="11.276009375" width="0.6096" layer="16"/>
<wire x1="27.734884375" y1="11.276009375" x2="27.487728125" y2="11.523165625" width="0.6096" layer="16"/>
<wire x1="27.487728125" y1="11.523165625" x2="25.414603125" y2="14.335415625" width="0.6096" layer="16"/>
<wire x1="25.414603125" y1="14.335415625" x2="25.4" y2="17.78" width="0.6096" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="DIS1" pad="2"/>
<contactref element="R9" pad="A"/>
<contactref element="R1" pad="1"/>
<contactref element="IC1" pad="11"/>
<contactref element="IC1" pad="32"/>
<contactref element="C1" pad="1"/>
<contactref element="S2" pad="3"/>
<contactref element="S2" pad="4"/>
<contactref element="V1" pad="20"/>
<contactref element="SV3" pad="6"/>
<contactref element="SV1" pad="6"/>
<contactref element="SV2" pad="6"/>
<contactref element="X1" pad="9"/>
<contactref element="SV4" pad="6"/>
<contactref element="X3" pad="2"/>
<wire x1="40.618659375" y1="52.362859375" x2="38.078659375" y2="52.362859375" width="1.016" layer="16"/>
<wire x1="38.078659375" y1="52.362859375" x2="38.009484375" y2="52.424475" width="0.6096" layer="16"/>
<wire x1="40.618659375" y1="52.362859375" x2="40.549484375" y2="52.424475" width="0.6096" layer="16"/>
<wire x1="38.009484375" y1="52.424475" x2="32.704996875" y2="52.509134375" width="0.6096" layer="16"/>
<wire x1="32.704996875" y1="52.509134375" x2="32.63435" y2="41.0773625" width="1.016" layer="16"/>
<wire x1="32.63435" y1="41.0773625" x2="32.612609375" y2="36.937840625" width="1.016" layer="16"/>
<wire x1="32.612609375" y1="36.937840625" x2="35.56" y2="34.29" width="1.016" layer="16"/>
<wire x1="35.56" y1="34.29" x2="35.56" y2="33.02" width="0.6096" layer="16"/>
<wire x1="-6.50185625" y1="48.48614375" x2="-6.45226875" y2="48.98356875" width="0.6096" layer="16"/>
<wire x1="-6.45226875" y1="48.98356875" x2="-3.25499375" y2="52.702434375" width="1.016" layer="16"/>
<wire x1="-3.25499375" y1="52.702434375" x2="6.175371875" y2="52.7148125" width="1.016" layer="16"/>
<wire x1="6.175371875" y1="52.7148125" x2="17.555728125" y2="52.719475" width="1.016" layer="16"/>
<wire x1="17.555728125" y1="52.719475" x2="17.650290625" y2="48.480784375" width="1.016" layer="16"/>
<wire x1="32.704996875" y1="52.509134375" x2="37.93008125" y2="52.415940625" width="0.6096" layer="16"/>
<wire x1="37.93008125" y1="52.415940625" x2="37.796940625" y2="52.71211875" width="0.6096" layer="16"/>
<wire x1="37.796940625" y1="52.71211875" x2="17.555728125" y2="52.719475" width="1.016" layer="16"/>
<wire x1="6.15731875" y1="60.203178125" x2="6.175371875" y2="52.7148125" width="1.016" layer="16"/>
<wire x1="-6.45226875" y1="48.98356875" x2="-6.45226875" y2="43.6069625" width="1.016" layer="16"/>
<wire x1="-6.45226875" y1="43.6069625" x2="-6.462396875" y2="40.2805875" width="1.016" layer="16"/>
<wire x1="-6.462396875" y1="40.2805875" x2="-6.462396875" y2="36.7243" width="1.016" layer="16"/>
<wire x1="-6.462396875" y1="36.7243" x2="-5.489546875" y2="34.845571875" width="1.016" layer="16"/>
<wire x1="-3.789759375" y1="7.4522875" x2="-3.875009375" y2="8.41146875" width="1.016" layer="16"/>
<wire x1="-3.875009375" y1="8.41146875" x2="-4.227640625" y2="9.79019375" width="1.016" layer="16"/>
<wire x1="-4.227640625" y1="9.79019375" x2="-5.515803125" y2="8.56575" width="1.016" layer="16"/>
<wire x1="-5.515803125" y1="8.56575" x2="-5.493703125" y2="32.34250625" width="1.016" layer="16"/>
<wire x1="-5.493703125" y1="32.34250625" x2="-5.489546875" y2="34.845571875" width="1.016" layer="16"/>
<wire x1="20.166646875" y1="-1.162321875" x2="18.609225" y2="0.949190625" width="1.016" layer="16"/>
<wire x1="18.609225" y1="0.949190625" x2="2.060328125" y2="0.86396875" width="1.016" layer="16"/>
<wire x1="2.060328125" y1="0.86396875" x2="-3.730265625" y2="8.3038" width="1.016" layer="16"/>
<wire x1="-3.730265625" y1="8.3038" x2="-3.789759375" y2="7.4522875" width="0.6096" layer="16"/>
<wire x1="37.022140625" y1="11.276009375" x2="39.177828125" y2="11.276009375" width="0.6096" layer="16"/>
<wire x1="39.177828125" y1="11.276009375" x2="39.177828125" y2="11.3266875" width="0.6096" layer="16"/>
<wire x1="39.177828125" y1="11.3266875" x2="40.6573375" y2="12.90429375" width="0.6096" layer="16"/>
<wire x1="40.6573375" y1="12.90429375" x2="40.64" y2="17.78" width="0.6096" layer="16"/>
<contactref element="C2" pad="+"/>
<wire x1="35.56" y1="33.02" x2="38.85663125" y2="23.130103125" width="1.016" layer="16"/>
<wire x1="38.85663125" y1="23.130103125" x2="40.64" y2="17.78" width="1.016" layer="16"/>
<wire x1="67.869753125" y1="23.191159375" x2="65.109234375" y2="23.1116375" width="0.6096" layer="16"/>
<wire x1="65.109234375" y1="23.1116375" x2="38.85663125" y2="23.130103125" width="1.016" layer="16"/>
<wire x1="64.77" y1="22.86" x2="65.109234375" y2="23.1116375" width="0.6096" layer="16"/>
<wire x1="64.77" y1="22.86" x2="64.820884375" y2="23.112665625" width="0.6096" layer="16"/>
<wire x1="64.820884375" y1="23.112665625" x2="64.8803" y2="22.949275" width="0.6096" layer="16"/>
<wire x1="64.8803" y1="22.949275" x2="66.33760625" y2="22.92134375" width="1.016" layer="16"/>
<wire x1="66.33760625" y1="22.92134375" x2="70.951084375" y2="22.888984375" width="1.016" layer="16"/>
<contactref element="RN1" pad="1"/>
<wire x1="70.951084375" y1="22.888984375" x2="72.176040625" y2="22.88039375" width="1.016" layer="16"/>
<wire x1="68.56851875" y1="52.002234375" x2="70.34658125" y2="49.0311625" width="0.4064" layer="16"/>
<wire x1="70.34658125" y1="49.0311625" x2="70.376528125" y2="41.411175" width="0.4064" layer="16"/>
<wire x1="70.376528125" y1="41.411175" x2="68.5422625" y2="38.468953125" width="0.4064" layer="16"/>
<wire x1="68.5422625" y1="38.468953125" x2="72.176040625" y2="22.88039375" width="0.4064" layer="16"/>
<wire x1="71.27961875" y1="11.65785" x2="70.951084375" y2="22.888984375" width="0.4064" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="DIS1" pad="4"/>
<contactref element="IC1" pad="35"/>
<wire x1="48.26" y1="17.78" x2="48.1033" y2="13.750659375" width="1.016" layer="16"/>
<wire x1="48.1033" y1="13.750659375" x2="40.34980625" y2="3.916178125" width="1.016" layer="16"/>
<wire x1="40.34980625" y1="3.916178125" x2="27.420884375" y2="3.91863125" width="1.016" layer="16"/>
<wire x1="27.420884375" y1="3.91863125" x2="25.246646875" y2="-1.162321875" width="1.016" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="DIS1" pad="6"/>
<contactref element="IC1" pad="36"/>
<wire x1="50.8" y1="17.78" x2="50.91711875" y2="14.716825" width="1.016" layer="16"/>
<wire x1="50.91711875" y1="14.716825" x2="41.169296875" y2="1.981553125" width="1.016" layer="16"/>
<wire x1="41.169296875" y1="1.981553125" x2="31.228575" y2="1.9814875" width="1.016" layer="16"/>
<wire x1="31.228575" y1="1.9814875" x2="30.326646875" y2="-1.162321875" width="1.016" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="DIS1" pad="11"/>
<contactref element="IC1" pad="37"/>
<wire x1="53.34" y1="17.78" x2="53.494775" y2="17.76861875" width="0.6096" layer="16"/>
<wire x1="53.494775" y1="17.76861875" x2="53.29920625" y2="17.5698875" width="0.6096" layer="16"/>
<wire x1="53.29920625" y1="17.5698875" x2="53.35090625" y2="14.705746875" width="1.016" layer="16"/>
<wire x1="53.35090625" y1="14.705746875" x2="43.20115625" y2="0.82133125" width="1.016" layer="16"/>
<wire x1="43.20115625" y1="0.82133125" x2="43.13036875" y2="-1.040503125" width="1.016" layer="16"/>
<wire x1="43.13036875" y1="-1.040503125" x2="43.026646875" y2="-1.162321875" width="0.6096" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="IC1" pad="33"/>
<contactref element="X1" pad="7"/>
<wire x1="35.022140625" y1="11.276009375" x2="35.022140625" y2="9.896025" width="0.6096" layer="16"/>
<wire x1="35.022140625" y1="9.896025" x2="35.099515625" y2="9.854325" width="0.3048" layer="16"/>
<wire x1="35.099515625" y1="9.854325" x2="40.533490625" y2="9.845696875" width="0.6096" layer="16"/>
<wire x1="40.533490625" y1="9.845696875" x2="43.253565625" y2="12.909640625" width="0.6096" layer="16"/>
<wire x1="43.253565625" y1="12.909640625" x2="43.253565625" y2="17.706434375" width="0.6096" layer="16"/>
<wire x1="43.253565625" y1="17.706434375" x2="43.18" y2="17.78" width="0.3048" layer="16"/>
</signal>
<signal name="N$40">
<contactref element="IC1" pad="34"/>
<contactref element="X1" pad="5"/>
<wire x1="33.022140625" y1="11.276009375" x2="33.03451875" y2="8.535896875" width="0.6096" layer="16"/>
<wire x1="33.03451875" y1="8.535896875" x2="33.134675" y2="8.463259375" width="0.3048" layer="16"/>
<wire x1="33.134675" y1="8.463259375" x2="41.73071875" y2="8.4584375" width="0.6096" layer="16"/>
<wire x1="41.73071875" y1="8.4584375" x2="45.502503125" y2="13.002071875" width="0.6096" layer="16"/>
<wire x1="45.502503125" y1="13.002071875" x2="45.502503125" y2="17.442953125" width="0.6096" layer="16"/>
<wire x1="45.502503125" y1="17.442953125" x2="45.72" y2="17.78" width="0.3048" layer="16"/>
</signal>
<signal name="N$42">
<contactref element="SV4" pad="5"/>
<contactref element="X2" pad="9"/>
<wire x1="8.65731875" y1="60.203178125" x2="8.54875" y2="60.203178125" width="1.016" layer="16"/>
<wire x1="8.54875" y1="60.203178125" x2="8.54875" y2="65.352365625" width="1.016" layer="16"/>
<wire x1="8.54875" y1="65.352365625" x2="13.711853125" y2="72.37859375" width="1.016" layer="16"/>
<wire x1="13.711853125" y1="72.37859375" x2="39.941634375" y2="72.43734375" width="1.016" layer="16"/>
<wire x1="39.941634375" y1="72.43734375" x2="46.365959375" y2="62.19521875" width="1.016" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
