<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.4">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="no" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="no" active="yes"/>
<layer number="103" name="tMap" color="7" fill="1" visible="no" active="yes"/>
<layer number="104" name="Name" color="16" fill="1" visible="no" active="yes"/>
<layer number="105" name="tPlate" color="7" fill="1" visible="no" active="yes"/>
<layer number="106" name="bPlate" color="7" fill="1" visible="no" active="yes"/>
<layer number="107" name="Crop" color="7" fill="1" visible="no" active="yes"/>
<layer number="108" name="tplace-old" color="10" fill="1" visible="yes" active="yes"/>
<layer number="109" name="ref-old" color="11" fill="1" visible="yes" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="no" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="no" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="no" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="no" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="no" active="yes"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="no" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="no" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="no" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="no" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="no" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="no" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="no" active="yes"/>
</layers>
<board>
<plain>
<wire x1="-20.32" y1="0" x2="99.04" y2="0" width="0.8128" layer="20"/>
<wire x1="99.04" y1="0" x2="99.04" y2="45.39" width="0.8128" layer="20"/>
<wire x1="99.04" y1="45.39" x2="-20.32" y2="45.39" width="0.8128" layer="20"/>
<wire x1="-20.32" y1="45.39" x2="-20.32" y2="0" width="0.8128" layer="20"/>
</plain>
<libraries>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TO220ACV">
<wire x1="-5.207" y1="-2.54" x2="5.207" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="3.175" x2="-5.207" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.54" x2="5.207" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-0.254" x2="4.318" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-0.254" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="1.27" x2="5.207" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="1.27" x2="5.207" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.54" x2="-5.207" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-0.254" x2="-4.318" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-0.254" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.27" x2="-5.207" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="1.27" x2="-5.207" y2="3.175" width="0.1524" layer="21"/>
<pad name="C" x="-2.54" y="0" drill="0.6" diameter="2.54" shape="octagon" rot="R90"/>
<pad name="A" x="2.54" y="0" drill="0.6" diameter="2.54" shape="octagon" rot="R90"/>
<text x="-5.08" y="-4.699" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.207" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.127" layer="21"/>
</package>
<package name="DO41-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="C" x="-5.08" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="E5-13">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5.08 mm, diameter 13 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-0.889" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.27" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.445" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="6.985" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.6" diameter="2.54" shape="octagon"/>
<pad name="-" x="2.54" y="0" drill="0.6" diameter="2.54" shape="octagon"/>
<text x="6.3754" y="4.1148" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-3.937" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.889" y2="1.27" layer="21"/>
</package>
<package name="E2,5-7">
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E2,5-5">
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.6" diameter="1.778" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.6" diameter="1.778" shape="octagon"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RTRIM3006P">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; BOURNS&lt;p&gt;</description>
<wire x1="-10.6" y1="2.25" x2="-10.6" y2="-2.25" width="0.254" layer="21"/>
<wire x1="-10.6" y1="-2.25" x2="8.25" y2="-2.25" width="0.254" layer="21"/>
<wire x1="8.25" y1="-2.25" x2="8.25" y2="2.25" width="0.254" layer="21"/>
<wire x1="8.25" y1="2.25" x2="-10.6" y2="2.25" width="0.254" layer="21"/>
<wire x1="8.35" y1="1.35" x2="9.8" y2="1.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="1.35" x2="9.8" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="0.35" x2="9.3" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.3" y1="0.35" x2="9.3" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.3" y1="-0.35" x2="9.8" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="-0.35" x2="9.8" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="-1.35" x2="8.35" y2="-1.35" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="1.27" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="2" x="0" y="-1.27" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="3" x="5.08" y="1.27" drill="0.6" diameter="1.9304" shape="octagon"/>
<text x="-10.7" y="2.7" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.05" y="-1.65" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
</packages>
</library>
<library name="SparkFun-PowerIC">
<description>&lt;h3&gt;SparkFun Electronics' preferred foot prints&lt;/h3&gt;
In this library you'll find drivers, regulators, and amplifiers.&lt;br&gt;&lt;br&gt;
We've spent an enormous amount of time creating and checking these footprints and parts, but it is the end user's responsibility to ensure correctness and suitablity for a given componet or application. If you enjoy using this library, please buy one of our products at www.sparkfun.com.
&lt;b&gt;Licensing:&lt;/b&gt; CC v3.0 Share-Alike You are welcome to use this library for commercial purposes. For attribution, we ask that when you begin to sell your device using our footprint, you email us with a link to the product being sold. We want bragging rights that we helped (in a very small part) to create your 8th world wonder. We would like the opportunity to feature your device on our homepage.</description>
<packages>
<package name="TO220-ADJ">
<wire x1="5.08" y1="-1.905" x2="-5.08" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.08" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.2032" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="1.905" width="0.2032" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="5.08" y1="1.905" x2="-5.08" y2="1.905" width="0.2032" layer="21"/>
<wire x1="5.08" y1="2.54" x2="8.255" y2="2.54" width="0.2032" layer="51"/>
<wire x1="8.255" y1="2.54" x2="8.255" y2="-5.715" width="0.2032" layer="51"/>
<wire x1="8.255" y1="-5.715" x2="9.525" y2="-5.715" width="0.2032" layer="51"/>
<wire x1="9.525" y1="-5.715" x2="9.525" y2="3.81" width="0.2032" layer="51"/>
<wire x1="9.525" y1="3.81" x2="-9.525" y2="3.81" width="0.2032" layer="51"/>
<wire x1="-9.525" y1="3.81" x2="-9.525" y2="-5.715" width="0.2032" layer="51"/>
<wire x1="-9.525" y1="-5.715" x2="-8.255" y2="-5.715" width="0.2032" layer="51"/>
<wire x1="-8.255" y1="-5.715" x2="-8.255" y2="2.54" width="0.2032" layer="51"/>
<wire x1="-8.255" y1="2.54" x2="-5.08" y2="2.54" width="0.2032" layer="51"/>
<pad name="ADJ" x="-2.54" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="OUT" x="0" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="IN" x="2.54" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
</package>
<package name="TO220-ADJ2">
<pad name="ADJ" x="-2.54" y="0" drill="0.6" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="OUT" x="2.54" y="0" drill="0.6" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="IN" x="0" y="0" drill="0.6" diameter="1.9304" shape="octagon" rot="R90"/>
</package>
</packages>
</library>
<library name="capacitor-wima">
<description>&lt;b&gt;WIMA Capacitors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="C5B2.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 2.5 mm, grid 5.08 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<text x="-2.032" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
<library name="con-molex">
<description>&lt;b&gt;Molex Connectors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="6410-04">
<description>&lt;b&gt;MOLEX 2.54mm KK  CONNECTOR&lt;/b&gt;</description>
<wire x1="-3.81" y1="2.54" x2="-3.81" y2="2.921" width="0.127" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.556" y1="2.921" x2="-3.81" y2="2.921" width="0.127" layer="21"/>
<wire x1="-3.81" y1="2.921" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="5.08" y1="0" x2="5.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="5.08" y1="2.921" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-2.667" y2="-2.921" width="0.127" layer="21"/>
<wire x1="5.08" y1="0" x2="5.08" y2="-2.921" width="0.254" layer="21"/>
<wire x1="5.08" y1="-2.921" x2="-2.667" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-4.826" y1="-2.921" x2="-4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-4.445" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.286" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.286" x2="-0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.921" x2="-1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.286" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.921" x2="3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.286" x2="4.445" y2="-2.286" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.286" x2="4.445" y2="-2.921" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.921" x2="5.08" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.556" y2="1.905" width="0.254" layer="21"/>
<wire x1="-3.556" y1="1.905" x2="3.556" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.556" y1="1.905" x2="3.81" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.81" y1="1.905" x2="3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.556" y2="1.397" width="0.254" layer="21"/>
<wire x1="-3.556" y1="2.921" x2="-3.556" y2="1.905" width="0.254" layer="21"/>
<wire x1="-3.556" y1="1.397" x2="3.556" y2="1.397" width="0.254" layer="21"/>
<wire x1="3.556" y1="1.397" x2="3.81" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.556" y1="2.921" x2="3.556" y2="1.905" width="0.254" layer="21"/>
<pad name="4" x="-3.81" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="1" x="3.81" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<text x="-5.0531" y="3.2751" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="5.6881" y="-0.7381" size="1.27" layer="21" ratio="14">1</text>
<text x="-6.2499" y="-0.6873" size="1.27" layer="21" ratio="14">4</text>
<text x="-5.0531" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
</package>
<package name="6410-03">
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="2.921" width="0.127" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.286" y1="2.921" x2="-2.54" y2="2.921" width="0.127" layer="21"/>
<wire x1="-2.54" y1="2.921" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="2.921" width="0.254" layer="21"/>
<wire x1="3.81" y1="2.921" x2="-1.27" y2="2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-2.921" x2="-1.27" y2="-2.921" width="0.127" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-1.27" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-3.556" y1="-2.921" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.921" x2="-3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.286" x2="-1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.286" x2="-1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.921" x2="-0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.921" x2="-0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.286" x2="0.635" y2="-2.286" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.286" x2="0.635" y2="-2.921" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.921" x2="1.905" y2="-2.921" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.921" x2="1.905" y2="-2.286" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.286" x2="3.175" y2="-2.286" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.286" x2="3.175" y2="-2.921" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="3.81" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="-2.286" y1="1.905" x2="2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.286" y1="1.905" x2="2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="2.921" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.286" y2="1.397" width="0.254" layer="21"/>
<wire x1="-2.286" y1="2.921" x2="-2.286" y2="1.905" width="0.254" layer="21"/>
<wire x1="-2.286" y1="1.397" x2="2.286" y2="1.397" width="0.254" layer="21"/>
<wire x1="2.286" y1="1.397" x2="2.54" y2="1.905" width="0.254" layer="21"/>
<wire x1="2.286" y1="2.921" x2="2.286" y2="1.905" width="0.254" layer="21"/>
<pad name="3" x="-2.54" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="1" x="2.54" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<text x="-3.7831" y="3.2751" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="4.4181" y="-0.7381" size="1.27" layer="21" ratio="14">1</text>
<text x="-4.9799" y="-0.6873" size="1.27" layer="21" ratio="14">3</text>
<text x="-3.7831" y="-4.5989" size="0.8128" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="3,0">
<description>&lt;b&gt;MOUNTING HOLE&lt;/b&gt; 3.0 mm with drill center</description>
<wire x1="-2.159" y1="0" x2="0" y2="-2.159" width="2.4892" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.159" x2="2.159" y2="0" width="2.4892" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="0.762" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="39"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="43"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="40"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="41"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="42"/>
<circle x="0" y="0" radius="1.6" width="0.2032" layer="21"/>
<text x="-1.27" y="-3.81" size="1.27" layer="48">3,0</text>
<hole x="0" y="0" drill="3"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="D1" library="diode" package="TO220ACV" value="MUR860" x="2.54" y="29.21" rot="R270"/>
<element name="D2" library="diode" package="TO220ACV" value="MUR860" x="11.43" y="29.21" rot="R270"/>
<element name="D3" library="diode" package="TO220ACV" value="MUR860" x="2.54" y="16.51" rot="R270"/>
<element name="D4" library="diode" package="TO220ACV" value="MUR860" x="11.43" y="16.51" rot="R270"/>
<element name="C1" library="rcl" package="E5-13" value="1000u/35V" x="22.86" y="30.48" rot="R270"/>
<element name="C2" library="capacitor-wima" package="C5B2.5" value="100n/63V" x="48.26" y="27.94" rot="R270"/>
<element name="IC1" library="SparkFun-PowerIC" package="TO220-ADJ" value="LM317" x="55.88" y="36.83" rot="R180"/>
<element name="IC2" library="SparkFun-PowerIC" package="TO220-ADJ2" value="LM337" x="55.88" y="8.89"/>
<element name="R1" library="rcl" package="RTRIM3006P" value="5k" x="78.74" y="38.1"/>
<element name="R3" library="rcl" package="RTRIM3006P" value="5k" x="77.47" y="7.62"/>
<element name="D5" library="diode" package="DO41-10" value="1N4004" x="57.15" y="30.48"/>
<element name="D7" library="diode" package="DO41-10" value="1N4004" x="57.15" y="15.24" rot="R180"/>
<element name="C6" library="rcl" package="E5-13" value="1000u/35V" x="22.86" y="15.24" rot="R270"/>
<element name="C7" library="capacitor-wima" package="C5B2.5" value="100n/63V" x="48.26" y="17.78" rot="R270"/>
<element name="C4" library="rcl" package="E2,5-5" value="10u/35V" x="69.85" y="26.67" rot="R270"/>
<element name="C8" library="rcl" package="E2,5-5" value="10u/35V" x="69.85" y="19.05" rot="R270"/>
<element name="R2" library="rcl" package="0207/10" value="240R" x="57.15" y="26.67"/>
<element name="R4" library="rcl" package="0207/10" value="240R" x="57.15" y="19.05" rot="R180"/>
<element name="D8" library="diode" package="DO41-10" value="1N4004" x="72.39" y="13.97"/>
<element name="D6" library="diode" package="DO41-10" value="1N4004" x="72.39" y="31.75" rot="R180"/>
<element name="C5" library="rcl" package="E2,5-7" value="100u/35V" x="77.47" y="26.67" rot="R270"/>
<element name="C9" library="rcl" package="E2,5-7" value="100u/35V" x="77.47" y="19.05" rot="R270"/>
<element name="VIN" library="con-molex" package="6410-04" value="2x17VAC" x="-10.16" y="22.86" rot="R270">
<attribute name="OC_NEWARK" value="unknown" x="-10.16" y="22.86" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="-10.16" y="22.86" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="-10.16" y="22.86" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="-10.16" y="22.86" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="VOUT" library="con-molex" package="6410-03" value="2x15VDC" x="85.09" y="22.86" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="85.09" y="22.86" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="85.09" y="22.86" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="85.09" y="22.86" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="85.09" y="22.86" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="H1" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="93.98" y="5.08"/>
<element name="H2" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="93.98" y="40.64"/>
<element name="H3" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="-15.24" y="5.08"/>
<element name="H4" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="-15.24" y="40.64"/>
<element name="C3" library="capacitor-wima" package="C5B2.5" value="100n/63V" x="-3.81" y="22.86" rot="R90"/>
<element name="C10" library="rcl" package="E5-13" value="1000u/35V" x="38.1" y="30.48" rot="R270"/>
<element name="C11" library="rcl" package="E5-13" value="1000u/35V" x="38.1" y="15.24" rot="R270"/>
</elements>
<signals>
<signal name="N$1">
<contactref element="D1" pad="A"/>
<contactref element="D3" pad="C"/>
<wire x1="2.54" y1="19.05" x2="2.54" y2="22.86" width="1.016" layer="16"/>
<contactref element="VIN" pad="1"/>
<contactref element="C3" pad="1"/>
<wire x1="2.54" y1="22.86" x2="2.54" y2="26.67" width="1.016" layer="16"/>
<wire x1="-3.81" y1="20.32" x2="-5.08" y2="19.05" width="1.016" layer="16"/>
<wire x1="-5.08" y1="19.05" x2="-10.16" y2="19.05" width="1.016" layer="16"/>
<wire x1="-3.81" y1="20.32" x2="-2.54" y2="20.32" width="1.016" layer="16"/>
<wire x1="-2.54" y1="20.32" x2="0" y2="22.86" width="1.016" layer="16"/>
<wire x1="0" y1="22.86" x2="2.54" y2="22.86" width="1.016" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="D4" pad="C"/>
<contactref element="D2" pad="A"/>
<wire x1="11.43" y1="19.05" x2="11.43" y2="22.86" width="1.016" layer="16"/>
<wire x1="11.43" y1="22.86" x2="11.43" y2="26.67" width="1.016" layer="16"/>
<wire x1="6.35" y1="29.21" x2="7.62" y2="27.94" width="1.016" layer="16"/>
<wire x1="7.62" y1="27.94" x2="7.62" y2="24.13" width="1.016" layer="16"/>
<wire x1="7.62" y1="24.13" x2="8.89" y2="22.86" width="1.016" layer="16"/>
<wire x1="8.89" y1="22.86" x2="11.43" y2="22.86" width="1.016" layer="16"/>
<contactref element="VIN" pad="4"/>
<contactref element="C3" pad="2"/>
<wire x1="-3.81" y1="25.4" x2="-3.81" y2="27.94" width="1.016" layer="16"/>
<wire x1="-3.81" y1="27.94" x2="-2.54" y2="29.21" width="1.016" layer="16"/>
<wire x1="-2.54" y1="29.21" x2="6.35" y2="29.21" width="1.016" layer="16"/>
<wire x1="-10.16" y1="26.67" x2="-7.62" y2="26.67" width="1.016" layer="16"/>
<wire x1="-7.62" y1="26.67" x2="-6.35" y2="25.4" width="1.016" layer="16"/>
<wire x1="-6.35" y1="25.4" x2="-3.81" y2="25.4" width="1.016" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="D1" pad="C"/>
<contactref element="D2" pad="C"/>
<contactref element="IC1" pad="IN"/>
<contactref element="C1" pad="+"/>
<contactref element="C2" pad="1"/>
<contactref element="D5" pad="C"/>
<wire x1="2.54" y1="31.75" x2="11.43" y2="31.75" width="1.016" layer="16"/>
<wire x1="48.26" y1="31.75" x2="48.26" y2="30.48" width="1.016" layer="16"/>
<wire x1="11.43" y1="31.75" x2="22.86" y2="31.75" width="1.016" layer="16"/>
<wire x1="22.86" y1="31.75" x2="38.1" y2="31.75" width="1.016" layer="16"/>
<wire x1="38.1" y1="31.75" x2="48.26" y2="31.75" width="1.016" layer="16"/>
<wire x1="22.86" y1="33.02" x2="22.86" y2="31.75" width="1.016" layer="16"/>
<wire x1="48.26" y1="31.75" x2="52.07" y2="31.75" width="1.016" layer="16"/>
<wire x1="52.07" y1="31.75" x2="52.07" y2="30.48" width="1.016" layer="16"/>
<wire x1="53.34" y1="36.83" x2="52.07" y2="35.56" width="1.016" layer="16"/>
<wire x1="52.07" y1="35.56" x2="52.07" y2="31.75" width="1.016" layer="16"/>
<contactref element="C10" pad="+"/>
<wire x1="38.1" y1="33.02" x2="38.1" y2="31.75" width="1.016" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="D3" pad="A"/>
<contactref element="D4" pad="A"/>
<contactref element="IC2" pad="IN"/>
<contactref element="D7" pad="A"/>
<contactref element="C6" pad="-"/>
<contactref element="C7" pad="2"/>
<wire x1="2.54" y1="13.97" x2="11.43" y2="13.97" width="1.016" layer="16"/>
<wire x1="11.43" y1="13.97" x2="22.86" y2="13.97" width="1.016" layer="16"/>
<wire x1="22.86" y1="13.97" x2="38.1" y2="13.97" width="1.016" layer="16"/>
<wire x1="38.1" y1="13.97" x2="48.26" y2="13.97" width="1.016" layer="16"/>
<wire x1="48.26" y1="13.97" x2="52.07" y2="13.97" width="1.016" layer="16"/>
<wire x1="52.07" y1="13.97" x2="54.61" y2="13.97" width="1.016" layer="16"/>
<wire x1="54.61" y1="13.97" x2="55.88" y2="12.7" width="1.016" layer="16"/>
<wire x1="55.88" y1="12.7" x2="55.88" y2="8.89" width="1.016" layer="16"/>
<wire x1="52.07" y1="15.24" x2="52.07" y2="13.97" width="1.016" layer="16"/>
<wire x1="48.26" y1="15.24" x2="48.26" y2="13.97" width="1.016" layer="16"/>
<wire x1="22.86" y1="12.7" x2="22.86" y2="13.97" width="1.016" layer="16"/>
<contactref element="C11" pad="-"/>
<wire x1="38.1" y1="12.7" x2="38.1" y2="13.97" width="1.016" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="D7" pad="C"/>
<contactref element="IC2" pad="OUT"/>
<contactref element="R4" pad="2"/>
<contactref element="D8" pad="A"/>
<contactref element="C9" pad="-"/>
<wire x1="58.42" y1="8.89" x2="58.42" y2="11.43" width="1.016" layer="16"/>
<wire x1="58.42" y1="11.43" x2="58.42" y2="15.24" width="1.016" layer="16"/>
<wire x1="58.42" y1="15.24" x2="62.23" y2="15.24" width="1.016" layer="16"/>
<wire x1="77.47" y1="13.97" x2="83.82" y2="13.97" width="1.016" layer="16"/>
<wire x1="52.07" y1="19.05" x2="57.15" y2="19.05" width="1.016" layer="16"/>
<wire x1="57.15" y1="19.05" x2="58.42" y2="17.78" width="1.016" layer="16"/>
<wire x1="58.42" y1="17.78" x2="58.42" y2="15.24" width="1.016" layer="16"/>
<wire x1="77.47" y1="17.78" x2="77.47" y2="13.97" width="1.016" layer="16"/>
<wire x1="58.42" y1="11.43" x2="76.2" y2="11.43" width="1.016" layer="16"/>
<wire x1="76.2" y1="11.43" x2="77.47" y2="12.7" width="1.016" layer="16"/>
<wire x1="77.47" y1="12.7" x2="77.47" y2="13.97" width="1.016" layer="16"/>
<contactref element="VOUT" pad="3"/>
<wire x1="85.09" y1="20.32" x2="85.09" y2="15.24" width="1.016" layer="16"/>
<wire x1="85.09" y1="15.24" x2="83.82" y2="13.97" width="1.016" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="D5" pad="A"/>
<contactref element="IC1" pad="OUT"/>
<contactref element="R2" pad="1"/>
<contactref element="D6" pad="C"/>
<contactref element="C5" pad="+"/>
<wire x1="55.88" y1="36.83" x2="55.88" y2="30.48" width="1.016" layer="16"/>
<wire x1="55.88" y1="30.48" x2="62.23" y2="30.48" width="1.016" layer="16"/>
<wire x1="77.47" y1="27.94" x2="77.47" y2="31.75" width="1.016" layer="16"/>
<wire x1="77.47" y1="31.75" x2="83.82" y2="31.75" width="1.016" layer="16"/>
<wire x1="52.07" y1="26.67" x2="54.61" y2="26.67" width="1.016" layer="16"/>
<wire x1="54.61" y1="26.67" x2="55.88" y2="27.94" width="1.016" layer="16"/>
<wire x1="55.88" y1="27.94" x2="55.88" y2="30.48" width="1.016" layer="16"/>
<contactref element="VOUT" pad="1"/>
<wire x1="85.09" y1="25.4" x2="85.09" y2="30.48" width="1.016" layer="16"/>
<wire x1="85.09" y1="30.48" x2="83.82" y2="31.75" width="1.016" layer="16"/>
<wire x1="55.88" y1="36.83" x2="55.88" y2="40.64" width="1.016" layer="16"/>
<wire x1="55.88" y1="40.64" x2="57.15" y2="41.91" width="1.016" layer="16"/>
<wire x1="57.15" y1="41.91" x2="73.66" y2="41.91" width="1.016" layer="16"/>
<wire x1="73.66" y1="41.91" x2="74.93" y2="40.64" width="1.016" layer="16"/>
<wire x1="74.93" y1="40.64" x2="74.93" y2="33.02" width="1.016" layer="16"/>
<wire x1="74.93" y1="33.02" x2="76.2" y2="31.75" width="1.016" layer="16"/>
<wire x1="76.2" y1="31.75" x2="77.47" y2="31.75" width="1.016" layer="16"/>
</signal>
<signal name="GND">
<contactref element="R3" pad="2"/>
<contactref element="R1" pad="2"/>
<contactref element="C1" pad="-"/>
<contactref element="C2" pad="2"/>
<contactref element="C6" pad="+"/>
<contactref element="C7" pad="1"/>
<contactref element="C4" pad="-"/>
<contactref element="C8" pad="+"/>
<contactref element="C5" pad="-"/>
<contactref element="C9" pad="+"/>
<contactref element="R1" pad="3"/>
<contactref element="R3" pad="3"/>
<wire x1="83.82" y1="39.37" x2="87.63" y2="39.37" width="1.016" layer="16"/>
<wire x1="78.74" y1="36.83" x2="78.74" y2="38.1" width="1.016" layer="16"/>
<wire x1="78.74" y1="38.1" x2="80.01" y2="39.37" width="1.016" layer="16"/>
<wire x1="80.01" y1="39.37" x2="83.82" y2="39.37" width="1.016" layer="16"/>
<wire x1="87.63" y1="39.37" x2="88.9" y2="38.1" width="1.016" layer="16"/>
<wire x1="88.9" y1="38.1" x2="88.9" y2="22.86" width="1.016" layer="16"/>
<wire x1="88.9" y1="22.86" x2="88.9" y2="7.62" width="1.016" layer="16"/>
<wire x1="-12.7" y1="22.86" x2="-13.97" y2="21.59" width="1.016" layer="16"/>
<wire x1="-13.97" y1="21.59" x2="-13.97" y2="17.78" width="1.016" layer="16"/>
<wire x1="-13.97" y1="17.78" x2="-12.7" y2="16.51" width="1.016" layer="16"/>
<contactref element="VIN" pad="2"/>
<contactref element="VOUT" pad="2"/>
<wire x1="85.09" y1="22.86" x2="88.9" y2="22.86" width="1.016" layer="16"/>
<wire x1="77.47" y1="6.35" x2="82.55" y2="6.35" width="1.016" layer="16"/>
<wire x1="82.55" y1="6.35" x2="87.63" y2="6.35" width="1.016" layer="16"/>
<wire x1="87.63" y1="6.35" x2="88.9" y2="7.62" width="1.016" layer="16"/>
<wire x1="82.55" y1="8.89" x2="82.55" y2="6.35" width="1.016" layer="16"/>
<contactref element="VIN" pad="3"/>
<wire x1="22.86" y1="17.78" x2="20.32" y2="17.78" width="1.016" layer="16"/>
<wire x1="20.32" y1="17.78" x2="17.78" y2="20.32" width="1.016" layer="16"/>
<wire x1="17.78" y1="20.32" x2="17.78" y2="22.86" width="1.016" layer="16"/>
<wire x1="17.78" y1="22.86" x2="17.78" y2="25.4" width="1.016" layer="16"/>
<wire x1="17.78" y1="25.4" x2="20.32" y2="27.94" width="1.016" layer="16"/>
<wire x1="20.32" y1="27.94" x2="22.86" y2="27.94" width="1.016" layer="16"/>
<wire x1="-12.7" y1="16.51" x2="13.97" y2="16.51" width="1.016" layer="16"/>
<wire x1="13.97" y1="16.51" x2="15.24" y2="17.78" width="1.016" layer="16"/>
<wire x1="15.24" y1="17.78" x2="15.24" y2="21.59" width="1.016" layer="16"/>
<wire x1="15.24" y1="21.59" x2="16.51" y2="22.86" width="1.016" layer="16"/>
<wire x1="16.51" y1="22.86" x2="17.78" y2="22.86" width="1.016" layer="16"/>
<wire x1="48.26" y1="20.32" x2="49.53" y2="20.32" width="1.016" layer="16"/>
<wire x1="49.53" y1="20.32" x2="50.8" y2="21.59" width="1.016" layer="16"/>
<wire x1="50.8" y1="21.59" x2="50.8" y2="22.86" width="1.016" layer="16"/>
<wire x1="77.47" y1="20.32" x2="69.85" y2="20.32" width="1.016" layer="16"/>
<wire x1="67.31" y1="22.86" x2="67.31" y2="24.13" width="1.016" layer="16"/>
<wire x1="67.31" y1="24.13" x2="68.58" y2="25.4" width="1.016" layer="16"/>
<wire x1="68.58" y1="25.4" x2="69.85" y2="25.4" width="1.016" layer="16"/>
<wire x1="77.47" y1="25.4" x2="69.85" y2="25.4" width="1.016" layer="16"/>
<wire x1="77.47" y1="25.4" x2="78.74" y2="25.4" width="1.016" layer="16"/>
<wire x1="78.74" y1="25.4" x2="80.01" y2="24.13" width="1.016" layer="16"/>
<wire x1="80.01" y1="24.13" x2="80.01" y2="22.86" width="1.016" layer="16"/>
<wire x1="80.01" y1="22.86" x2="80.01" y2="21.59" width="1.016" layer="16"/>
<wire x1="80.01" y1="21.59" x2="78.74" y2="20.32" width="1.016" layer="16"/>
<wire x1="78.74" y1="20.32" x2="77.47" y2="20.32" width="1.016" layer="16"/>
<wire x1="69.85" y1="20.32" x2="68.58" y2="20.32" width="1.016" layer="16"/>
<wire x1="68.58" y1="20.32" x2="67.31" y2="21.59" width="1.016" layer="16"/>
<wire x1="67.31" y1="21.59" x2="67.31" y2="22.86" width="1.016" layer="16"/>
<wire x1="67.31" y1="22.86" x2="50.8" y2="22.86" width="1.016" layer="16"/>
<wire x1="85.09" y1="22.86" x2="80.01" y2="22.86" width="1.016" layer="16"/>
<wire x1="-10.16" y1="24.13" x2="-10.16" y2="22.86" width="1.016" layer="16"/>
<wire x1="-10.16" y1="22.86" x2="-10.16" y2="21.59" width="1.016" layer="16"/>
<wire x1="-12.7" y1="22.86" x2="-10.16" y2="22.86" width="1.016" layer="16"/>
<contactref element="C10" pad="-"/>
<contactref element="C11" pad="+"/>
<wire x1="22.86" y1="17.78" x2="38.1" y2="17.78" width="1.016" layer="16"/>
<wire x1="38.1" y1="17.78" x2="43.18" y2="17.78" width="1.016" layer="16"/>
<wire x1="43.18" y1="17.78" x2="45.72" y2="20.32" width="1.016" layer="16"/>
<wire x1="45.72" y1="20.32" x2="48.26" y2="20.32" width="1.016" layer="16"/>
<wire x1="22.86" y1="27.94" x2="38.1" y2="27.94" width="1.016" layer="16"/>
<wire x1="48.26" y1="25.4" x2="45.72" y2="25.4" width="1.016" layer="16"/>
<wire x1="45.72" y1="25.4" x2="43.18" y2="27.94" width="1.016" layer="16"/>
<wire x1="43.18" y1="27.94" x2="38.1" y2="27.94" width="1.016" layer="16"/>
<wire x1="50.8" y1="22.86" x2="50.8" y2="24.13" width="1.016" layer="16"/>
<wire x1="50.8" y1="24.13" x2="49.53" y2="25.4" width="1.016" layer="16"/>
<wire x1="49.53" y1="25.4" x2="48.26" y2="25.4" width="1.016" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="R1" pad="1"/>
<contactref element="IC1" pad="ADJ"/>
<wire x1="71.12" y1="39.37" x2="67.31" y2="39.37" width="1.016" layer="16"/>
<wire x1="67.31" y1="39.37" x2="59.69" y2="39.37" width="1.016" layer="16"/>
<wire x1="59.69" y1="39.37" x2="58.42" y2="38.1" width="1.016" layer="16"/>
<wire x1="58.42" y1="38.1" x2="58.42" y2="36.83" width="1.016" layer="16"/>
<contactref element="R2" pad="2"/>
<contactref element="C4" pad="+"/>
<contactref element="D6" pad="A"/>
<wire x1="62.23" y1="26.67" x2="64.77" y2="26.67" width="1.016" layer="16"/>
<wire x1="64.77" y1="26.67" x2="66.04" y2="27.94" width="1.016" layer="16"/>
<wire x1="69.85" y1="27.94" x2="67.31" y2="27.94" width="1.016" layer="16"/>
<wire x1="67.31" y1="27.94" x2="66.04" y2="27.94" width="1.016" layer="16"/>
<wire x1="67.31" y1="31.75" x2="67.31" y2="27.94" width="1.016" layer="16"/>
<wire x1="67.31" y1="31.75" x2="67.31" y2="39.37" width="1.016" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="R3" pad="1"/>
<contactref element="IC2" pad="ADJ"/>
<wire x1="53.34" y1="8.89" x2="53.34" y2="7.62" width="1.016" layer="16"/>
<wire x1="53.34" y1="7.62" x2="54.61" y2="6.35" width="1.016" layer="16"/>
<wire x1="54.61" y1="6.35" x2="68.58" y2="6.35" width="1.016" layer="16"/>
<wire x1="68.58" y1="6.35" x2="69.85" y2="7.62" width="1.016" layer="16"/>
<wire x1="69.85" y1="7.62" x2="69.85" y2="8.89" width="1.016" layer="16"/>
<contactref element="C8" pad="-"/>
<contactref element="R4" pad="1"/>
<contactref element="D8" pad="C"/>
<wire x1="62.23" y1="19.05" x2="64.77" y2="19.05" width="1.016" layer="16"/>
<wire x1="64.77" y1="19.05" x2="66.04" y2="17.78" width="1.016" layer="16"/>
<wire x1="66.04" y1="17.78" x2="67.31" y2="17.78" width="1.016" layer="16"/>
<wire x1="67.31" y1="17.78" x2="69.85" y2="17.78" width="1.016" layer="16"/>
<wire x1="67.31" y1="13.97" x2="67.31" y2="17.78" width="1.016" layer="16"/>
<wire x1="69.85" y1="8.89" x2="67.31" y2="13.97" width="0" layer="19" extent="1-1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
