<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="mm" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="transistor">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TO126">
<description>&lt;b&gt;TO 126 horizontal&lt;/b&gt;</description>
<wire x1="-3.937" y1="-1.27" x2="-3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="-3.937" y1="9.144" x2="3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="3.937" y1="9.144" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="1.2393" y1="3.1591" x2="1.9493" y2="3.8858" width="0.127" layer="21" curve="25.67749"/>
<wire x1="0.7687" y1="3.6188" x2="1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-0.7687" y1="3.6188" x2="-1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-1.4787" y1="4.3456" x2="-1.9493" y2="3.8858" width="0.127" layer="21"/>
<wire x1="-1.9493" y1="3.8858" x2="-1.2393" y2="3.1591" width="0.127" layer="21" curve="25.67749"/>
<wire x1="0.508" y1="6.6509" x2="0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="6.6509" x2="-0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="7.3088" x2="0.508" y2="7.3088" width="0.127" layer="21" curve="-25.679633"/>
<wire x1="1.4787" y1="4.3456" x2="1.9493" y2="3.8858" width="0.127" layer="21"/>
<circle x="-3.1242" y="-0.4826" radius="0.4318" width="0" layer="21"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="42"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="43"/>
<circle x="0" y="5.08" radius="1.651" width="0.127" layer="21"/>
<pad name="1" x="-2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<text x="-2.54" y="7.62" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-0.889" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.508" y="-0.889" size="1.27" layer="51" ratio="10">2</text>
<text x="1.778" y="-0.889" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-0.635" y1="-3.048" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-3.429" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-5.207" x2="-1.905" y2="-3.429" layer="51"/>
<rectangle x1="-0.381" y1="-3.429" x2="0.381" y2="-1.27" layer="21"/>
<rectangle x1="-0.381" y1="-5.207" x2="0.381" y2="-3.429" layer="51"/>
<rectangle x1="1.905" y1="-3.429" x2="2.667" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-5.207" x2="2.667" y2="-3.429" layer="51"/>
<hole x="0" y="5.08" drill="3.302"/>
</package>
</packages>
<symbols>
<symbol name="NPN">
<wire x1="2.54" y1="2.54" x2="0.508" y2="1.524" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-1.524" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.778" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.54" y1="-2.04" x2="0.308" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-2.413" x2="2.286" y2="-2.413" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.413" x2="1.778" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.778" x2="1.524" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.524" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.032" width="0.254" layer="94"/>
<text x="-10.16" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="E" x="2.54" y="-5.08" visible="off" length="short" direction="pas" swaplevel="3" rot="R90"/>
<pin name="C" x="2.54" y="5.08" visible="off" length="short" direction="pas" swaplevel="2" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="BD139" prefix="T">
<description>&lt;b&gt;NPN TRANSISTOR&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="NPN" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO126">
<connects>
<connect gate="G$1" pin="B" pad="3"/>
<connect gate="G$1" pin="C" pad="2"/>
<connect gate="G$1" pin="E" pad="1"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor-fet">
<description>&lt;b&gt;Field Effect Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
Symbols changed according to IEC617&lt;p&gt;
All types, packages and assignment to symbols and pins checked&lt;p&gt;
Package outlines partly checked&lt;p&gt;
&lt;p&gt;
JFET = junction FET&lt;p&gt;
IGBT-x = insulated gate bipolar transistor&lt;p&gt;
x=N: NPN; x=P: PNP&lt;p&gt;
IGFET-mc-nnn; (IGFET=insulated gate field effect transistor)&lt;P&gt;
m=D: depletion mode (Verdr&amp;auml;ngungstyp)&lt;p&gt;
m=E: enhancement mode (Anreicherungstyp)&lt;p&gt;
c: N=N-channel; P=P-Channel&lt;p&gt;
GDSB: gate, drain, source, bulk&lt;p&gt;
&lt;p&gt;
by R. Vogg  15.March.2002</description>
<packages>
<package name="TO92">
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-2.6549" y2="-0.254" width="0.127" layer="21" curve="-32.781"/>
<wire x1="-2.6549" y1="-0.254" x2="-0.7863" y2="2.5485" width="0.127" layer="21" curve="-78.3185"/>
<wire x1="0.7863" y1="2.5484" x2="2.0945" y2="-1.651" width="0.127" layer="21" curve="-111.1"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.2537" y1="-0.254" x2="-0.2863" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.2863" y1="-0.254" x2="2.2537" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.127" layer="51" curve="-34.2936"/>
<pad name="1" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.635" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-2.159" y="0" size="1.27" layer="51" ratio="10">3</text>
<text x="1.143" y="0" size="1.27" layer="51" ratio="10">1</text>
</package>
</packages>
<symbols>
<symbol name="JFET-N">
<wire x1="0" y1="-3.81" x2="0" y2="3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-1.905" x2="-1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-2.54" x2="-2.54" y2="-3.175" width="0.254" layer="94"/>
<text x="-10.16" y="2.413" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="0" size="1.778" layer="96">&gt;VALUE</text>
<text x="2.54" y="0.635" size="1.524" layer="95">D</text>
<text x="2.54" y="-4.445" size="1.524" layer="95">S</text>
<text x="-4.445" y="-4.445" size="1.524" layer="95">G</text>
<pin name="G" x="-5.08" y="-2.54" visible="off" length="middle" direction="pas"/>
<pin name="D" x="5.08" y="2.54" visible="off" length="middle" direction="pas" rot="R180"/>
<pin name="S" x="5.08" y="-2.54" visible="off" length="middle" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="BF245" prefix="Q">
<description>&lt;b&gt;N-Channel Junction FET&lt;/b&gt;&lt;p&gt;
http://www.onsemi.com/pub/Collateral/BF245A-D.PDF</description>
<gates>
<gate name="G$1" symbol="JFET-N" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO92">
<connects>
<connect gate="G$1" pin="D" pad="1"/>
<connect gate="G$1" pin="G" pad="3"/>
<connect gate="G$1" pin="S" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="pot">
<description>&lt;b&gt;Potentiometers&lt;/b&gt;&lt;p&gt;
Beckman, Copal, Piher, Spectrol, Schukat&lt;p&gt;
<packages>
<package name="B25P">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;&lt;p&gt;
Beckman Helitrim 25</description>
<wire x1="3.175" y1="3.429" x2="-3.175" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-3.429" x2="-2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="3.175" y1="3.429" x2="3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-3.429" x2="3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-3.175" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.524" x2="3.429" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.254" x2="3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-3.429" x2="-3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="3.429" x2="-3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="3.175" x2="-3.429" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-0.254" x2="-3.429" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-1.524" x2="-3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0" x2="1.524" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.762" x2="0.762" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0.762" x2="0.381" y2="1.143" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.143" x2="0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.286" x2="-0.381" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.286" x2="-0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.143" x2="-0.762" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0.762" x2="-1.524" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.762" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.524" x2="0.381" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-1.524" x2="0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.381" x2="0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.032" y2="-1.651" width="0.3048" layer="51"/>
<wire x1="1.778" y1="-1.397" x2="2.032" y2="-1.651" width="0.3048" layer="51"/>
<wire x1="2.3876" y1="0.381" x2="2.7686" y2="0.381" width="0.3048" layer="21"/>
<wire x1="1.778" y1="2.032" x2="2.032" y2="2.286" width="0.3048" layer="21"/>
<wire x1="0" y1="2.7178" x2="0" y2="3.0988" width="0.3048" layer="21"/>
<wire x1="-1.905" y1="2.032" x2="-2.159" y2="2.286" width="0.3048" layer="21"/>
<wire x1="-2.3876" y1="0.381" x2="-2.7686" y2="0.381" width="0.3048" layer="21"/>
<wire x1="0.381" y1="1.524" x2="-0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.381" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.524" x2="-0.381" y2="1.143" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.762" x2="-0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.762" x2="0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.762" x2="-0.381" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.048" x2="-2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.048" x2="1.016" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-3.429" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.429" x2="-0.635" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.429" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-3.429" x2="2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.429" x2="3.175" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.048" x2="-1.016" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-3.048" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<circle x="0" y="0.381" radius="2.032" width="0.1524" layer="51"/>
<pad name="A" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="S" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1496" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.413" y="-2.794" size="0.9906" layer="21" ratio="12">3</text>
<text x="-2.921" y="-2.794" size="0.9906" layer="21" ratio="12">1</text>
</package>
<package name="B25U">
<wire x1="-0.381" y1="-0.381" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-0.381" x2="-0.381" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-1.524" x2="0.381" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-1.524" x2="0.381" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-0.381" x2="0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-0.762" x2="-0.381" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-0.762" x2="0.381" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-0.762" x2="-0.381" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.429" x2="3.175" y2="-3.429" width="0.1524" layer="21"/>
<pad name="A" x="2.54" y="-0.889" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="-0.889" drill="0.8128" shape="long" rot="R90"/>
<pad name="S" x="0" y="-0.889" drill="0.8128" shape="long" rot="R90"/>
<text x="-3.175" y="-2.794" size="0.9906" layer="21" ratio="12">3</text>
<text x="2.413" y="-2.794" size="0.9906" layer="21" ratio="12">1</text>
</package>
<package name="B25V">
<wire x1="3.429" y1="3.556" x2="3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.413" x2="0.381" y2="2.286" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.413" x2="0.381" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.159" x2="0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.159" x2="0.127" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.667" x2="0.127" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.286" x2="0.381" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.286" x2="0.254" y2="2.159" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.54" x2="0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.413" x2="0.127" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.127" y1="2.413" x2="-2.032" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.127" y1="2.413" x2="0.127" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.127" y1="2.032" x2="0.127" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0.127" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0.127" y1="2.794" x2="0" y2="2.921" width="0.1524" layer="21"/>
<wire x1="0" y1="2.921" x2="0" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.048" x2="3.429" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.778" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.54" y1="1.143" x2="3.429" y2="1.143" width="0.1524" layer="51"/>
<wire x1="3.429" y1="1.27" x2="3.429" y2="0" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.429" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.778" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="3.429" y1="3.556" x2="2.54" y2="3.556" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.556" x2="-2.54" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.556" x2="-3.429" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-3.048" x2="-3.429" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="0" x2="-3.429" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="1.27" x2="-3.429" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.778" x2="-2.54" y2="3.556" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.778" x2="2.54" y2="3.556" width="0.1524" layer="21"/>
<pad name="A" x="2.54" y="0.635" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="0.635" drill="0.8128" shape="long" rot="R90"/>
<pad name="S" x="0" y="0.635" drill="0.8128" shape="long" rot="R90"/>
<text x="-3.302" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.4036" y="-4.826" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.048" y="-2.032" size="1.27" layer="21" ratio="10">3</text>
<text x="2.159" y="-1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-0.381" y="1.778" size="1.27" layer="21" ratio="10"> 3 </text>
<rectangle x1="-1.524" y1="3.556" x2="-0.254" y2="4.191" layer="21"/>
<rectangle x1="0.254" y1="3.556" x2="1.524" y2="4.191" layer="21"/>
<rectangle x1="-0.254" y1="3.556" x2="0.254" y2="3.81" layer="21"/>
</package>
<package name="B25X">
<wire x1="-3.429" y1="-3.048" x2="-3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="-3.429" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-1.27" x2="-3.429" y2="1.143" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.556" x2="3.429" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.556" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.143" x2="3.429" y2="1.143" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.143" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.27" x2="3.429" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-2.54" x2="3.429" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.556" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-3.429" y2="3.556" width="0.1524" layer="21"/>
<pad name="A" x="2.54" y="-1.905" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="-1.905" drill="0.8128" shape="long" rot="R90"/>
<text x="-3.302" y="4.572" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.4036" y="-4.699" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.048" y="-0.762" size="1.27" layer="21" ratio="10">3</text>
<text x="2.159" y="-0.635" size="1.27" layer="21" ratio="10">1</text>
</package>
<package name="B64W">
Beckman Helitrim 64</description>
<wire x1="3.175" y1="1.016" x2="-3.175" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.016" x2="-3.175" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0.762" x2="-3.175" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-0.762" x2="-3.175" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-3.302" x2="-0.762" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-3.302" x2="0.762" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="0.762" y1="-3.302" x2="3.175" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-3.302" x2="3.175" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.762" x2="3.175" y2="0.762" width="0.1524" layer="51"/>
<wire x1="3.175" y1="0.762" x2="3.175" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.143" x2="1.651" y2="-2.159" width="0.3048" layer="21"/>
<wire x1="-0.254" y1="-1.778" x2="-0.635" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.778" x2="-0.381" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.778" x2="-0.381" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-2.032" x2="-0.508" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-2.032" x2="-0.635" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-1.524" x2="-0.635" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-1.905" x2="-0.381" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-1.905" x2="-0.508" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-1.651" x2="-0.508" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.778" x2="-0.635" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-2.159" x2="-0.635" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-2.286" x2="-0.635" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.397" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.762" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.778" x2="-0.635" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="1.524" y1="-1.016" x2="3.048" y2="-1.524" width="0.1524" layer="21" curve="233.130102"/>
<wire x1="1.27" y1="-1.524" x2="3.048" y2="-1.524" width="0.1524" layer="51" curve="-163.739795"/>
<pad name="A" x="2.54" y="0" drill="0.8128" shape="long"/>
<pad name="E" x="-2.54" y="0" drill="0.8128" shape="long"/>
<pad name="S" x="0" y="-2.54" drill="0.8128" shape="long"/>
<text x="-3.175" y="1.4732" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-4.953" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.651" y="-0.508" size="1.27" layer="21" ratio="10">3</text>
<text x="0.762" y="-0.508" size="1.27" layer="21" ratio="10">1</text>
<text x="-0.127" y="-2.413" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="B64Y">
<wire x1="3.175" y1="2.032" x2="-3.175" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.032" x2="-3.175" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.397" x2="-3.175" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-1.397" x2="-3.175" y2="-2.2098" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.2098" x2="3.175" y2="-2.2098" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.2098" x2="3.175" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.397" x2="3.175" y2="1.397" width="0.1524" layer="51"/>
<wire x1="3.175" y1="1.397" x2="3.175" y2="2.032" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-0.127" x2="1.651" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-1.397" x2="-1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.397" x2="-1.016" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-1.651" x2="-1.143" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-1.651" x2="-1.27" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-1.143" x2="-1.27" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.524" x2="-1.016" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.524" x2="-1.143" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.27" x2="-1.143" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.397" x2="-1.27" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.397" x2="-2.794" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.397" x2="-1.27" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.778" x2="-1.27" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-1.905" x2="-1.27" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.016" x2="-1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-0.889" x2="-1.397" y2="-1.905" width="0.1524" layer="21"/>
<circle x="2.159" y="-0.635" radius="0.889" width="0.1524" layer="51"/>
<pad name="A" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="S" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-3.175" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.032" y="0.508" size="1.27" layer="51" ratio="10">1</text>
<text x="-2.032" y="0.508" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="SP19L">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;</description>
<wire x1="-10.16" y1="-2.413" x2="9.525" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-2.413" x2="9.525" y2="2.667" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.667" x2="-10.16" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.667" x2="-10.16" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.588" y1="1.27" x2="5.207" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.588" y1="1.27" x2="5.461" y2="1.143" width="0.1524" layer="21"/>
<wire x1="5.588" y1="1.27" x2="5.461" y2="1.397" width="0.1524" layer="21"/>
<wire x1="5.334" y1="1.016" x2="5.334" y2="1.524" width="0.1524" layer="21"/>
<wire x1="5.334" y1="1.016" x2="5.207" y2="0.889" width="0.1524" layer="21"/>
<wire x1="5.334" y1="1.524" x2="5.207" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.461" y1="1.143" x2="5.461" y2="1.397" width="0.1524" layer="21"/>
<wire x1="5.461" y1="1.143" x2="5.334" y2="1.016" width="0.1524" layer="21"/>
<wire x1="5.461" y1="1.397" x2="5.334" y2="1.524" width="0.1524" layer="21"/>
<wire x1="5.207" y1="1.27" x2="5.207" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0.889" x2="5.207" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.762" x2="5.207" y2="0.889" width="0.1524" layer="21"/>
<wire x1="5.207" y1="1.651" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.778" x2="5.08" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="5.207" y2="1.27" width="0.1524" layer="21"/>
<pad name="A" x="5.715" y="-1.27" drill="1.016" shape="long"/>
<pad name="E" x="-6.985" y="-1.27" drill="1.016" shape="long"/>
<pad name="S" x="-1.905" y="1.27" drill="1.016" shape="long"/>
<text x="-12.573" y="-2.413" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-4.445" y="-1.778" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.985" y="-1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-9.525" y="-1.905" size="1.27" layer="21" ratio="10">3</text>
<text x="-4.572" y="0.635" size="1.27" layer="21" ratio="10">2</text>
<text x="4.953" y="0.635" size="1.27" layer="21" ratio="10"> 3 </text>
<text x="0.762" y="0.635" size="1.27" layer="21" ratio="10"> 1 </text>
<rectangle x1="-12.065" y1="-1.27" x2="-10.16" y2="-0.381" layer="21"/>
<rectangle x1="-12.065" y1="0.381" x2="-10.16" y2="1.27" layer="21"/>
<rectangle x1="-11.557" y1="-0.381" x2="-10.16" y2="0.381" layer="21"/>
</package>
<package name="CA6H">
distributor Schukat</description>
<wire x1="3.302" y1="1.27" x2="3.302" y2="0.127" width="0.1524" layer="51"/>
<wire x1="1.143" y1="0" x2="-1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0" x2="-3.175" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="3.175" x2="-2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="3.175" x2="-3.175" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.556" x2="-2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="3.556" x2="1.016" y2="3.556" width="0.1524" layer="51"/>
<wire x1="2.032" y1="3.429" x2="1.905" y2="3.556" width="0.1524" layer="21"/>
<wire x1="2.032" y1="3.429" x2="2.032" y2="3.175" width="0.1524" layer="21"/>
<wire x1="1.397" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="51"/>
<wire x1="1.143" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.127" x2="3.175" y2="0" width="0.1524" layer="51"/>
<wire x1="3.302" y1="3.048" x2="3.175" y2="3.175" width="0.1524" layer="21"/>
<wire x1="3.175" y1="3.175" x2="2.032" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="3.175" x2="-3.302" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.302" y2="0.127" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0.127" x2="-3.302" y2="1.27" width="0.1524" layer="51"/>
<wire x1="3.175" y1="0" x2="1.143" y2="0" width="0.1524" layer="51"/>
<wire x1="3.302" y1="1.27" x2="3.302" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.27" x2="-3.302" y2="3.048" width="0.1524" layer="21"/>
<wire x1="1.397" y1="3.175" x2="2.032" y2="3.175" width="0.1524" layer="21"/>
<wire x1="1.143" y1="3.429" x2="2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="1.905" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.556" x2="-1.016" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="21"/>
<pad name="A" x="-2.54" y="0" drill="1.016" shape="long"/>
<pad name="S" x="0" y="2.54" drill="1.016" shape="long"/>
<pad name="E" x="2.54" y="0" drill="1.016" shape="long"/>
<text x="-2.54" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="CA6V">
<wire x1="-0.254" y1="0.254" x2="-0.254" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="0.889" x2="0.254" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.889" x2="0.254" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.254" x2="0.889" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.254" x2="0.889" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.254" x2="0.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.254" x2="0.254" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.889" x2="-0.254" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.889" x2="-0.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.254" x2="-0.889" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-0.254" x2="-0.889" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.254" x2="-0.254" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.889" y1="3.81" x2="-0.889" y2="3.81" width="0.1524" layer="51"/>
<wire x1="3.429" y1="3.81" x2="0.889" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-0.889" x2="-1.397" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.889" x2="1.397" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0" x2="1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.016" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.016" x2="1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0" y1="1.397" x2="0" y2="1.905" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-3.81" x2="1.651" y2="-3.81" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-3.81" x2="-1.651" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-3.81" x2="-3.429" y2="-3.81" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-3.81" x2="3.81" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="3.429" y1="3.81" x2="3.81" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.81" y1="3.429" x2="-3.429" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.81" y1="-3.429" x2="-3.429" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="3.81" y1="-1.524" x2="3.81" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="3.81" x2="-0.889" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-3.429" x2="-3.81" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="3.81" y1="-1.524" x2="3.81" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="3.429" x2="-3.81" y2="-1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="A" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-2.54" y="4.191" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-5.461" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.508" y1="-3.048" x2="3.683" y2="-2.032" layer="51"/>
<rectangle x1="2.159" y1="-2.667" x2="3.683" y2="0" layer="51"/>
<rectangle x1="-3.683" y1="-2.667" x2="-2.159" y2="0" layer="51"/>
<rectangle x1="-3.683" y1="-3.048" x2="-0.508" y2="-2.032" layer="51"/>
<rectangle x1="1.905" y1="-3.81" x2="3.175" y2="-3.048" layer="51"/>
<rectangle x1="-3.175" y1="-3.81" x2="-1.905" y2="-3.048" layer="51"/>
</package>
<package name="CA9H">
<wire x1="4.953" y1="4.572" x2="4.953" y2="0.127" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.381" x2="1.016" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="4.064" y1="0" x2="2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="1.016" y1="0" x2="-1.016" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="0" x2="-4.826" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0" x2="-2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="1.016" y1="-0.381" x2="-1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.381" x2="-2.413" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-0.381" x2="2.54" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-0.254" x2="2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="2.54" y1="0" x2="1.016" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.381" x2="-2.54" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0" x2="-4.064" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.254" x2="-1.016" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-0.254" x2="1.016" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.254" x2="2.54" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="4.699" x2="-3.683" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="4.699" x2="-4.826" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="5.08" x2="-3.683" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="5.08" x2="3.556" y2="5.08" width="0.1524" layer="21"/>
<wire x1="3.683" y1="4.953" x2="3.556" y2="5.08" width="0.1524" layer="21"/>
<wire x1="3.683" y1="4.953" x2="3.683" y2="4.699" width="0.1524" layer="21"/>
<wire x1="3.683" y1="4.699" x2="-3.683" y2="4.699" width="0.1524" layer="21"/>
<wire x1="3.683" y1="4.953" x2="-3.683" y2="4.953" width="0.1524" layer="21"/>
<wire x1="4.953" y1="0.127" x2="4.826" y2="0" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0" x2="4.064" y2="0" width="0.1524" layer="21"/>
<wire x1="4.953" y1="4.572" x2="4.826" y2="4.699" width="0.1524" layer="21"/>
<wire x1="4.826" y1="4.699" x2="3.683" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.699" x2="-4.953" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0" x2="-4.953" y2="0.127" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="0.127" x2="-4.953" y2="4.572" width="0.1524" layer="21"/>
<pad name="A" x="-2.54" y="0" drill="1.3208" shape="octagon"/>
<pad name="S" x="0" y="2.54" drill="1.3208" shape="octagon"/>
<pad name="E" x="2.54" y="0" drill="1.3208" shape="octagon"/>
<text x="-2.54" y="5.588" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="CA9V">
<wire x1="-0.381" y1="0.381" x2="-0.381" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.651" x2="0.381" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.651" x2="0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0.381" x2="1.016" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.127" x2="1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.381" x2="0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.381" x2="0.381" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-1.651" x2="-0.381" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.651" x2="-0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.381" x2="-1.016" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.127" x2="-0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="1.524" y1="5.08" x2="-1.524" y2="5.08" width="0.1524" layer="51"/>
<wire x1="4.572" y1="5.08" x2="1.524" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.524" x2="-2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.524" x2="2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0" x2="-2.413" y2="0" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0" x2="2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.778" x2="-2.032" y2="2.032" width="0.1524" layer="21"/>
<wire x1="1.778" y1="1.778" x2="2.032" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0" y1="2.413" x2="0" y2="2.921" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-5.08" x2="1.143" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-5.08" x2="-1.143" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-5.08" x2="-3.937" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-3.937" y1="-5.08" x2="-4.572" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="4.572" y1="-5.08" x2="4.953" y2="-4.699" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="5.08" x2="4.953" y2="4.699" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.953" y1="4.699" x2="-4.572" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.953" y1="-4.699" x2="-4.572" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="-5.08" x2="3.937" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="4.953" y1="4.699" x2="4.953" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="5.08" x2="-1.524" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.699" x2="-4.953" y2="4.699" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<pad name="S" x="0" y="5.08" drill="1.3208" shape="long"/>
<pad name="A" x="-2.54" y="-5.08" drill="1.3208" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="-5.08" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.461" y="-5.08" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.731" y="-5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.508" y1="5.08" x2="0.508" y2="5.461" layer="51"/>
<rectangle x1="2.032" y1="-5.461" x2="3.048" y2="-3.683" layer="51"/>
<rectangle x1="1.397" y1="-3.683" x2="4.572" y2="-2.667" layer="21"/>
<rectangle x1="3.048" y1="-2.667" x2="4.572" y2="0" layer="21"/>
<rectangle x1="-4.572" y1="-2.667" x2="-3.048" y2="0" layer="21"/>
<rectangle x1="-4.572" y1="-3.683" x2="-1.397" y2="-2.667" layer="21"/>
<rectangle x1="-3.048" y1="-5.461" x2="-2.032" y2="-3.683" layer="51"/>
</package>
<package name="CA14V">
<wire x1="0.381" y1="1.651" x2="1.016" y2="1.143" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.143" x2="1.016" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.016" x2="0.381" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.016" x2="0.381" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.651" x2="-0.381" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.016" x2="-1.016" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.016" x2="-1.016" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.143" x2="-0.381" y2="1.651" width="0.1524" layer="21"/>
<wire x1="6.731" y1="7.112" x2="-6.731" y2="7.112" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-2.159" x2="-2.667" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.159" x2="2.667" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="0" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0" x2="3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="2.159" x2="-2.54" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.159" x2="2.54" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0" y1="3.048" x2="0" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-7.112" x2="5.842" y2="-7.112" width="0.1524" layer="51"/>
<wire x1="3.683" y1="-7.112" x2="3.048" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="-7.112" x2="-6.477" y2="-7.112" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="-7.112" x2="-6.731" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-7.112" x2="7.112" y2="-6.731" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="7.112" x2="7.112" y2="6.731" width="0.1524" layer="21" curve="-90"/>
<wire x1="-7.112" y1="6.731" x2="-6.731" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="-7.112" y1="-6.731" x2="-6.731" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="-7.112" x2="6.477" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="7.112" y1="6.731" x2="7.112" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="-6.731" x2="-7.112" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="7.112" y1="-4.953" x2="5.842" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="7.112" y1="-4.953" x2="7.112" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-6.35" x2="5.842" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-6.35" x2="5.842" y2="-7.112" width="0.1524" layer="51"/>
<wire x1="5.842" y1="-7.112" x2="4.318" y2="-7.112" width="0.1524" layer="51"/>
<wire x1="4.318" y1="-6.35" x2="4.318" y2="-7.112" width="0.1524" layer="51"/>
<wire x1="4.318" y1="-7.112" x2="3.683" y2="-7.112" width="0.1524" layer="51"/>
<wire x1="4.318" y1="-6.35" x2="4.318" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-4.953" x2="3.048" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-7.112" x2="3.048" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-7.112" x2="-3.048" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.953" x2="-7.112" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="-4.953" x2="-7.112" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-6.223" x2="-5.842" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="-5.842" y1="-6.35" x2="-5.842" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-6.223" x2="-4.318" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-6.223" x2="-4.318" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-4.953" x2="-4.318" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-7.112" x2="-3.048" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-7.112" x2="-3.683" y2="-7.112" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.937" width="0.1524" layer="51"/>
<pad name="S" x="0" y="5.08" drill="1.3208" shape="octagon"/>
<pad name="A" x="-5.08" y="-7.62" drill="1.3208" shape="octagon"/>
<pad name="E" x="5.08" y="-7.62" drill="1.3208" shape="octagon"/>
<text x="-6.985" y="7.62" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.318" y1="-7.112" x2="5.842" y2="-6.223" layer="51"/>
<rectangle x1="4.318" y1="-6.223" x2="5.842" y2="-4.953" layer="21"/>
<rectangle x1="1.524" y1="-4.953" x2="6.731" y2="-3.683" layer="21"/>
<rectangle x1="4.064" y1="-3.683" x2="6.731" y2="0" layer="21"/>
<rectangle x1="-5.842" y1="-7.112" x2="-4.318" y2="-6.223" layer="51"/>
<rectangle x1="-5.842" y1="-6.223" x2="-4.318" y2="-4.953" layer="21"/>
<rectangle x1="-6.731" y1="-4.953" x2="-1.524" y2="-3.683" layer="21"/>
<rectangle x1="-6.731" y1="-3.683" x2="-4.064" y2="0" layer="21"/>
<rectangle x1="4.318" y1="-7.874" x2="5.842" y2="-7.112" layer="51"/>
<rectangle x1="-5.842" y1="-7.874" x2="-4.318" y2="-7.112" layer="51"/>
</package>
<package name="CA14H">
<wire x1="7.112" y1="5.588" x2="7.112" y2="0.127" width="0.1524" layer="21"/>
<wire x1="6.477" y1="0" x2="3.683" y2="0" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0" x2="-6.985" y2="0" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="-2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.381" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.381" x2="2.54" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.254" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.381" x2="-2.54" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-6.477" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.254" x2="2.54" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="5.715" x2="-3.683" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="5.715" x2="-6.985" y2="5.715" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="6.096" x2="-3.683" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="6.096" x2="1.016" y2="6.096" width="0.1524" layer="51"/>
<wire x1="3.683" y1="5.969" x2="3.556" y2="6.096" width="0.1524" layer="21"/>
<wire x1="3.683" y1="5.969" x2="3.683" y2="5.715" width="0.1524" layer="21"/>
<wire x1="1.397" y1="5.715" x2="-1.397" y2="5.715" width="0.1524" layer="51"/>
<wire x1="1.143" y1="5.969" x2="-1.143" y2="5.969" width="0.1524" layer="51"/>
<wire x1="7.112" y1="0.127" x2="6.985" y2="0" width="0.1524" layer="21"/>
<wire x1="6.985" y1="0" x2="6.477" y2="0" width="0.1524" layer="21"/>
<wire x1="7.112" y1="5.588" x2="6.985" y2="5.715" width="0.1524" layer="21"/>
<wire x1="6.985" y1="5.715" x2="3.683" y2="5.715" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="5.715" x2="-7.112" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="0" x2="-7.112" y2="0.127" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="0.127" x2="-7.112" y2="5.588" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="1.397" y1="5.715" x2="3.683" y2="5.715" width="0.1524" layer="21"/>
<wire x1="3.683" y1="5.969" x2="1.143" y2="5.969" width="0.1524" layer="21"/>
<wire x1="1.016" y1="6.096" x2="3.556" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="6.096" x2="-3.556" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="5.969" x2="-1.143" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="5.715" x2="-3.683" y2="5.715" width="0.1524" layer="21"/>
<pad name="A" x="-5.08" y="0" drill="1.3208" shape="long"/>
<pad name="E" x="5.08" y="0" drill="1.3208" shape="long"/>
<text x="-2.54" y="6.604" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.191" y="1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="CT6">
Copal</description>
<wire x1="3.302" y1="3.556" x2="-3.302" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-3.556" x2="3.302" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="3.302" y1="3.556" x2="3.556" y2="3.302" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-3.556" x2="3.556" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-3.302" x2="3.556" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-3.556" x2="-3.556" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="3.556" x2="-3.556" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="3.302" x2="-3.556" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-0.381" x2="1.524" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.381" x2="1.524" y2="0.381" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.381" x2="0.762" y2="0.381" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0.381" x2="0.381" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0.762" x2="0.381" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.016" x2="0.635" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.016" x2="0" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0" y1="1.651" x2="-0.635" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.016" x2="-0.381" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.016" x2="-0.381" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.762" x2="-0.762" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0.381" x2="-1.524" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.381" x2="-1.524" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.381" x2="-0.762" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.762" x2="-0.762" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.762" x2="0.762" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-1.778" x2="1.651" y2="-1.778" width="0.1524" layer="51" curve="-272.584334"/>
<wire x1="-1.778" y1="-1.778" x2="-2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.778" x2="2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.5146" y1="0" x2="2.8956" y2="0" width="0.1524" layer="51"/>
<wire x1="1.778" y1="1.651" x2="2.032" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="2.4638" x2="0" y2="2.8448" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-2.5146" y1="0" x2="-2.8956" y2="0" width="0.1524" layer="51"/>
<pad name="A" x="2.5146" y="0" drill="0.8128" shape="octagon"/>
<pad name="E" x="-2.5146" y="0" drill="0.8128" shape="octagon"/>
<pad name="S" x="0" y="-2.54" drill="0.8128" shape="octagon"/>
<text x="-3.302" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.2766" y="-5.207" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.048" y="-3.175" size="0.9906" layer="21" ratio="12">3</text>
<text x="2.159" y="-3.175" size="0.9906" layer="21" ratio="12">1</text>
</package>
<package name="ECP10P">
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.191" y1="2.54" x2="4.191" y2="3.302" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.302" x2="4.191" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.54" x2="-4.191" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="3.302" x2="-4.191" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="-4.953" y2="3.302" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.302" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.191" y1="2.54" x2="1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="-1.524" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="2.54" x2="-4.191" y2="2.54" width="0.1524" layer="21"/>
<text x="-4.826" y="-4.191" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.762" y="-4.191" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.508" y1="2.54" x2="0.508" y2="2.794" layer="51"/>
</package>
<package name="ECP10S">
<wire x1="-0.381" y1="0.381" x2="-0.381" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.016" x2="0.381" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.016" x2="0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0.381" x2="1.016" y2="0.381" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.381" x2="1.016" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.381" x2="0.381" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-1.016" x2="-0.381" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.016" x2="-0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.381" x2="-1.016" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.381" x2="-0.381" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="5.08" x2="-4.953" y2="4.191" width="0.1524" layer="21"/>
<wire x1="4.953" y1="5.08" x2="4.064" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="5.08" x2="-4.064" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="5.08" x2="-4.064" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="5.08" x2="-4.953" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="4.191" x2="-4.064" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="4.191" x2="-4.953" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="4.064" y1="4.191" x2="4.953" y2="4.191" width="0.1524" layer="21"/>
<wire x1="4.953" y1="4.191" x2="4.953" y2="5.08" width="0.1524" layer="21"/>
<wire x1="4.064" y1="5.08" x2="4.064" y2="4.191" width="0.1524" layer="21"/>
<wire x1="4.064" y1="5.08" x2="1.524" y2="5.08" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-6.096" x2="4.953" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-6.096" x2="4.953" y2="4.191" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-6.096" x2="4.064" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-6.985" x2="-4.064" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-6.096" x2="-4.064" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-6.096" x2="-4.064" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-6.985" x2="-4.445" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-7.747" x2="-4.953" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-7.747" x2="-4.953" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-6.985" x2="4.445" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-7.747" x2="4.445" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-7.747" x2="4.953" y2="-6.096" width="0.1524" layer="21"/>
<circle x="-2.794" y="-4.826" radius="1.27" width="0.1524" layer="51"/>
<circle x="2.794" y="-4.826" radius="1.27" width="0.1524" layer="51"/>
<circle x="0" y="1.524" radius="0.127" width="0.3048" layer="21"/>
<pad name="A" x="-2.54" y="-5.08" drill="1.3208" shape="octagon"/>
<pad name="E" x="2.54" y="-5.08" drill="1.3208" shape="octagon"/>
<text x="-3.302" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.572" y="-3.302" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
<package name="LI10">
Piher</description>
<wire x1="3.175" y1="-4.445" x2="3.175" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-5.715" x2="-3.175" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="-3.175" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.175" x2="-0.635" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-4.445" x2="-1.27" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-4.445" x2="-1.27" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="1.27" y1="-5.715" x2="1.27" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="1.27" y1="-4.445" x2="0.635" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-4.445" x2="0.635" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.175" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="2.794" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="0.889" y1="1.397" x2="-0.127" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.381" x2="-0.508" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0.889" x2="0.381" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.127" x2="0.762" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-0.508" x2="0" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.508" x2="-0.889" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-5.715" x2="2.794" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-5.715" x2="-2.794" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-5.715" x2="1.27" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-3.175" x2="2.794" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-3.683" x2="2.794" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="-3.175" x2="-2.794" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-3.683" x2="-2.794" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="2.794" y1="-5.715" x2="1.27" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="-5.715" x2="-1.27" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="3.5657" y1="-4.1362" x2="5.461" y2="0" width="0.1524" layer="21" curve="49.236245"/>
<wire x1="-5.461" y1="0" x2="-3.6049" y2="-4.1021" width="0.1524" layer="21" curve="48.691198"/>
<wire x1="3.175" y1="-4.445" x2="3.683" y2="-4.064" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-4.445" x2="-3.683" y2="-4.064" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="0" x2="-1.448" y2="5.2655" width="0.1524" layer="21" curve="-74.623636"/>
<wire x1="1.4616" y1="5.2618" x2="5.461" y2="0" width="0.1524" layer="21" curve="-74.476215"/>
<wire x1="0" y1="5.461" x2="1.5185" y2="5.2456" width="0.1524" layer="51" curve="-16.144661"/>
<wire x1="-1.4824" y1="5.2559" x2="0" y2="5.461" width="0.1524" layer="51" curve="-15.750767"/>
<circle x="0" y="0" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.794" width="0.0508" layer="21"/>
<text x="-1.27" y="-7.62" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
<package name="LI15">
Piher</description>
<wire x1="6.35" y1="-6.604" x2="6.35" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-7.62" x2="-6.35" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="-4.445" x2="-5.08" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.81" x2="-3.175" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-5.08" x2="-3.175" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-6.35" x2="-3.556" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-6.35" x2="-3.556" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-7.62" x2="3.556" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-6.35" x2="3.175" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-6.35" x2="3.175" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-5.08" x2="5.08" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.81" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-7.62" x2="5.969" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-7.62" x2="-5.969" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-3.556" y1="-7.62" x2="3.556" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-4.445" x2="5.969" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-6.35" x2="5.969" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="-4.445" x2="-5.969" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-6.35" x2="-5.969" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-7.62" x2="3.556" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="-7.62" x2="-3.556" y2="-7.62" width="0.1524" layer="51"/>
<wire x1="6.35" y1="-6.604" x2="6.35" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-6.731" x2="-6.35" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0" x2="7.62" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="6.3402" y1="-4.2268" x2="7.62" y2="0" width="0.1524" layer="21" curve="33.690004"/>
<wire x1="-7.62" y1="0" x2="-6.3402" y2="-4.2268" width="0.1524" layer="21" curve="33.690004"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.81" width="0.1524" layer="51"/>
<pad name="A" x="-5.08" y="-7.62" drill="1.3208" shape="long"/>
<pad name="E" x="5.08" y="-7.62" drill="1.3208" shape="long"/>
<text x="-2.54" y="-9.398" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-3.429" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
<package name="RJ6">
Copal</description>
<wire x1="1.8796" y1="0" x2="2.1336" y2="0" width="0.254" layer="51"/>
<wire x1="0" y1="1.8796" x2="0" y2="2.1336" width="0.254" layer="51"/>
<wire x1="-2.1336" y1="0" x2="-1.8796" y2="0" width="0.254" layer="51"/>
<wire x1="1.3208" y1="1.3208" x2="1.4986" y2="1.4986" width="0.254" layer="21"/>
<wire x1="-1.3208" y1="1.3208" x2="-1.4986" y2="1.4986" width="0.254" layer="21"/>
<wire x1="-1.4986" y1="-1.4986" x2="-1.3208" y2="-1.3208" width="0.254" layer="51"/>
<wire x1="1.4986" y1="-1.4986" x2="1.3208" y2="-1.3208" width="0.254" layer="51"/>
<wire x1="-0.635" y1="-0.635" x2="0.635" y2="0.635" width="0.8128" layer="51"/>
<circle x="0" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="3.556" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="A" x="-1.778" y="-0.508" drill="0.8128" shape="octagon"/>
<pad name="S" x="0" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="E" x="1.778" y="-0.508" drill="0.8128" shape="octagon"/>
<text x="0.762" y="-2.921" size="0.9906" layer="21" ratio="12">3</text>
<text x="-1.27" y="-2.921" size="0.9906" layer="21" ratio="12">1</text>
<text x="-2.54" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RJ6S">
Copal</description>
<wire x1="-3.556" y1="-3.683" x2="-3.556" y2="2.921" width="0.1524" layer="21"/>
<wire x1="3.556" y1="2.921" x2="3.556" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.54" x2="1.397" y2="-2.667" width="0.1524" layer="51"/>
<wire x1="1.524" y1="-2.54" x2="1.397" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="1.27" y1="-2.794" x2="1.27" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="1.27" y1="-2.794" x2="1.143" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="1.27" y1="-2.286" x2="1.143" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-2.667" x2="1.397" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-2.667" x2="1.27" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-2.413" x2="1.27" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="1.524" y1="-2.54" x2="1.143" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-2.54" x2="-2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-2.54" x2="1.143" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-2.921" x2="1.143" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.016" y1="-3.048" x2="1.143" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-2.159" x2="1.016" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="1.016" y1="-2.032" x2="1.016" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-3.556" y1="-3.683" x2="3.556" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.556" y1="2.921" x2="-3.556" y2="2.921" width="0.1524" layer="21"/>
<pad name="S" x="0" y="-2.54" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.4036" y="-5.334" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.048" y="1.143" size="1.27" layer="21" ratio="10">3</text>
<text x="2.159" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-1.524" y1="2.921" x2="-0.254" y2="3.556" layer="21"/>
<rectangle x1="0.254" y1="2.921" x2="1.524" y2="3.556" layer="21"/>
<rectangle x1="-0.254" y1="2.921" x2="0.254" y2="3.175" layer="21"/>
</package>
<package name="RJ9W">
Copal</description>
<wire x1="-4.572" y1="-2.413" x2="4.572" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="4.572" y1="2.286" x2="4.572" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="4.572" y1="2.286" x2="-4.572" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-2.413" x2="-4.572" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="2.794" y2="-1.651" width="0.3048" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.016" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.762" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.762" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.524" x2="-0.889" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.524" x2="-1.016" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.016" x2="-1.016" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.397" x2="-0.762" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.397" x2="-0.889" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.143" x2="-0.889" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.27" x2="-1.016" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.651" x2="-1.016" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-1.778" x2="-1.016" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.889" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.143" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.27" x2="-1.016" y2="-1.27" width="0.1524" layer="21"/>
<circle x="3.302" y="-1.143" radius="0.889" width="0.1524" layer="51"/>
<circle x="3.302" y="-1.143" radius="0.635" width="0.0508" layer="21"/>
<text x="-4.572" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.429" y="0.127" size="1.27" layer="51" ratio="10">1</text>
<text x="-4.318" y="0" size="1.27" layer="51" ratio="10">3</text>
<text x="0" y="-1.905" size="1.27" layer="21" ratio="10">3</text>
</package>
<package name="RS3">
Copal</description>
<wire x1="4.826" y1="-4.826" x2="4.826" y2="4.8006" width="0.1524" layer="21"/>
<wire x1="4.826" y1="4.8006" x2="-4.826" y2="4.8006" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.8006" x2="-4.826" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-0.3302" y1="-1.5748" x2="0.3048" y2="-1.5748" width="0.254" layer="21"/>
<wire x1="0.3048" y1="-1.5748" x2="0.3048" y2="0.635" width="0.254" layer="21"/>
<wire x1="0.3048" y1="0.635" x2="0.381" y2="0.635" width="0.254" layer="21"/>
<wire x1="0.635" y1="0.635" x2="0" y2="1.905" width="0.254" layer="21"/>
<wire x1="0" y1="1.905" x2="-0.635" y2="0.635" width="0.254" layer="21"/>
<wire x1="-0.3302" y1="0.635" x2="-0.3302" y2="-1.5748" width="0.254" layer="21"/>
<wire x1="0" y1="-1.524" x2="-0.127" y2="-1.524" width="0.254" layer="21"/>
<wire x1="-0.127" y1="1.524" x2="-0.127" y2="-1.524" width="0.254" layer="21"/>
<wire x1="-0.127" y1="1.524" x2="0.127" y2="1.524" width="0.254" layer="21"/>
<wire x1="0.127" y1="1.524" x2="0.127" y2="-1.524" width="0.254" layer="21"/>
<wire x1="0.254" y1="0.635" x2="0.3048" y2="0.635" width="0.254" layer="21"/>
<wire x1="0.381" y1="1.016" x2="0.381" y2="0.635" width="0.254" layer="21"/>
<wire x1="0.381" y1="0.635" x2="0.635" y2="0.635" width="0.254" layer="21"/>
<wire x1="-0.635" y1="0.635" x2="-0.381" y2="0.635" width="0.254" layer="21"/>
<wire x1="-0.3302" y1="0.635" x2="-0.254" y2="0.635" width="0.254" layer="21"/>
<wire x1="-0.381" y1="1.016" x2="-0.381" y2="0.635" width="0.254" layer="21"/>
<wire x1="-0.381" y1="0.635" x2="-0.3302" y2="0.635" width="0.254" layer="21"/>
<wire x1="-4.826" y1="-4.826" x2="-3.81" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-3.937" x2="-3.81" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-4.826" x2="3.81" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-3.937" x2="3.81" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-3.937" x2="-3.81" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="-0.7581" y1="-2.0215" x2="0" y2="2.159" width="0.254" layer="21" curve="-159.443138"/>
<wire x1="0" y1="2.159" x2="0.7581" y2="-2.0215" width="0.254" layer="21" curve="-159.443138"/>
<wire x1="0" y1="3.556" x2="1.8543" y2="3.0343" width="0.1524" layer="21" curve="-31.429813"/>
<wire x1="-1.8295" y1="3.0492" x2="0" y2="3.556" width="0.1524" layer="21" curve="-30.963201"/>
<wire x1="0" y1="-3.556" x2="3.0493" y2="1.8295" width="0.1524" layer="21" curve="120.96244"/>
<wire x1="-3.0875" y1="1.7643" x2="0" y2="-3.5559" width="0.1524" layer="21" curve="119.743785"/>
<wire x1="-0.9047" y1="-1.9603" x2="0" y2="-2.159" width="0.254" layer="51" curve="24.773812"/>
<wire x1="0" y1="-2.159" x2="0.9655" y2="-1.9311" width="0.254" layer="51" curve="26.563946"/>
<wire x1="-3.556" y1="0" x2="-1.6937" y2="3.1268" width="0.1524" layer="51" curve="-61.557324"/>
<wire x1="1.5903" y1="3.1806" x2="3.556" y2="0" width="0.1524" layer="51" curve="-63.435137"/>
<pad name="A" x="-2.54" y="2.54" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="2.54" drill="0.8128" shape="long" rot="R90"/>
<text x="-4.826" y="5.207" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.2766" y="-5.6642" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.191" y="-3.556" size="1.27" layer="21" ratio="10">1</text>
<text x="3.302" y="-3.556" size="1.27" layer="21" ratio="10">3</text>
</package>
<package name="S63P">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;&lt;p&gt;
Spectrol</description>
<wire x1="4.699" y1="-4.6482" x2="4.699" y2="4.7498" width="0.1524" layer="21"/>
<wire x1="4.699" y1="4.7498" x2="-4.699" y2="4.7498" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="4.7498" x2="-4.699" y2="-4.6482" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="-0.635" y2="0.635" width="0.6096" layer="21"/>
<wire x1="-4.699" y1="-4.6482" x2="-3.937" y2="-4.6482" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-4.064" x2="-3.937" y2="-4.6482" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.6482" x2="3.937" y2="-4.6482" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-4.064" x2="3.937" y2="-4.6482" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-4.064" x2="-3.937" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.81" x2="2.413" y2="3.683" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.81" x2="2.413" y2="3.937" width="0.1524" layer="21"/>
<wire x1="2.286" y1="3.556" x2="2.286" y2="4.064" width="0.1524" layer="21"/>
<wire x1="2.286" y1="3.556" x2="2.159" y2="3.429" width="0.1524" layer="21"/>
<wire x1="2.286" y1="4.064" x2="2.159" y2="4.191" width="0.1524" layer="21"/>
<wire x1="2.413" y1="3.683" x2="2.413" y2="3.937" width="0.1524" layer="21"/>
<wire x1="2.413" y1="3.683" x2="2.286" y2="3.556" width="0.1524" layer="21"/>
<wire x1="2.413" y1="3.937" x2="2.286" y2="4.064" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.81" x2="2.159" y2="3.81" width="0.1524" layer="21"/>
<wire x1="2.159" y1="3.81" x2="-2.54" y2="3.81" width="0.1524" layer="21"/>
<wire x1="2.159" y1="3.81" x2="2.159" y2="4.191" width="0.1524" layer="21"/>
<wire x1="2.159" y1="3.429" x2="2.159" y2="3.81" width="0.1524" layer="21"/>
<wire x1="2.032" y1="3.302" x2="2.159" y2="3.429" width="0.1524" layer="21"/>
<wire x1="2.159" y1="4.191" x2="2.032" y2="4.318" width="0.1524" layer="21"/>
<wire x1="2.032" y1="4.318" x2="2.032" y2="3.302" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.905" width="0.1524" layer="51"/>
<pad name="S" x="0" y="2.54" drill="0.8128" shape="long" rot="R90"/>
<text x="-4.572" y="5.207" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-5.715" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.905" y="-3.81" size="1.27" layer="21" ratio="10">63P</text>
<text x="3.175" y="-2.54" size="1.27" layer="21" ratio="10">1</text>
<text x="-3.81" y="-2.54" size="1.27" layer="21" ratio="10">3</text>
<text x="1.651" y="3.175" size="1.27" layer="21" ratio="10"> 3 </text>
</package>
<package name="S63S">
<wire x1="-4.826" y1="-2.54" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.286" x2="4.826" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.54" x2="-2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.286" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-0.254" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.54" x2="4.826" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-2.032" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.667" x2="-2.032" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.794" x2="2.032" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.667" x2="2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="2.032" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-1.27" x2="2.032" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-1.524" x2="1.905" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-1.524" x2="1.778" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-1.016" x2="1.778" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-1.397" x2="2.032" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-1.397" x2="1.905" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-1.143" x2="1.905" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-1.27" x2="1.778" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-1.27" x2="-2.54" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-1.27" x2="1.778" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-1.651" x2="1.778" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-1.778" x2="1.778" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-0.889" x2="1.651" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.762" x2="1.651" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-2.794" x2="0.254" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.794" x2="-2.032" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.667" x2="0.254" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.794" x2="0.254" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.667" x2="-0.254" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.667" x2="-2.032" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.667" x2="-0.254" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.54" x2="0.254" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.667" x2="0.254" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.54" x2="2.032" y2="-2.54" width="0.1524" layer="21"/>
<pad name="A" x="2.54" y="1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="S" x="0" y="1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-4.826" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.8006" y="-4.445" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.572" y="0.635" size="1.27" layer="21" ratio="10">3</text>
<text x="3.556" y="0.635" size="1.27" layer="21" ratio="10">1</text>
<text x="2.54" y="-1.905" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="S63X">
<wire x1="-4.826" y1="-3.81" x2="-4.826" y2="1.016" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.016" x2="4.826" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-3.81" x2="-2.032" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.016" x2="-4.826" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-3.81" x2="-2.032" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-3.81" x2="-0.254" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-3.81" x2="4.826" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-3.937" x2="-0.254" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-3.937" x2="-2.032" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-4.064" x2="2.032" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-3.937" x2="2.032" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.54" x2="2.032" y2="-2.667" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-2.54" x2="2.032" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-2.794" x2="1.905" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-2.794" x2="1.778" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-2.667" x2="2.032" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-2.667" x2="1.905" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-2.413" x2="1.905" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-2.54" x2="1.778" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-2.54" x2="-2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-2.54" x2="1.778" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-2.921" x2="1.778" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-3.048" x2="1.778" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-2.159" x2="1.651" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-2.032" x2="1.651" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-4.064" x2="0.254" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-4.064" x2="-0.254" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-4.064" x2="-2.032" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-3.937" x2="-0.254" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-3.81" x2="0.254" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-3.81" x2="2.032" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-4.064" x2="0.254" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-3.937" x2="0.254" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-3.937" x2="2.032" y2="-3.937" width="0.1524" layer="21"/>
<text x="-4.826" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.8006" y="-5.715" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.572" y="-0.635" size="1.27" layer="21" ratio="10">3</text>
<text x="3.556" y="-0.635" size="1.27" layer="21" ratio="10">1</text>
<text x="2.54" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="S64W">
<wire x1="-4.826" y1="-1.27" x2="4.826" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.064" y1="0.508" x2="3.048" y2="-0.508" width="0.3048" layer="21"/>
<wire x1="-4.826" y1="3.81" x2="4.826" y2="3.81" width="0.1524" layer="21"/>
<wire x1="4.826" y1="3.81" x2="4.826" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.27" x2="-4.826" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0" x2="-2.413" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="0" x2="-2.159" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="0" x2="-2.159" y2="0.127" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="-0.254" x2="-2.286" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="-0.254" x2="-2.413" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="0.254" x2="-2.413" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-0.127" x2="-2.159" y2="0.127" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-0.127" x2="-2.286" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="0.127" x2="-2.286" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="0" x2="-2.413" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.381" x2="-2.413" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.508" x2="-2.413" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="0.381" x2="-2.54" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0.508" x2="-2.54" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="0" x2="-2.413" y2="0" width="0.1524" layer="51"/>
<circle x="3.556" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="3.556" y="0" radius="0.635" width="0.0508" layer="21"/>
<text x="-4.826" y="4.1402" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.8006" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="1.905" size="1.27" layer="21" ratio="10">3</text>
<text x="3.556" y="1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-1.905" y="-0.635" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="S64Y">
<wire x1="-4.826" y1="-2.54" x2="4.826" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.54" x2="4.826" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.54" x2="-4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-0.762" x2="3.048" y2="-1.778" width="0.3048" layer="21"/>
<wire x1="-4.826" y1="-2.54" x2="-4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.381" x2="-2.54" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-0.381" x2="-2.286" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-0.381" x2="-2.286" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.635" x2="-2.413" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.635" x2="-2.54" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.127" x2="-2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="-0.508" x2="-2.286" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="-0.508" x2="-2.413" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="-0.254" x2="-2.413" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.381" x2="-2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-2.667" y1="-0.889" x2="-2.54" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.667" y2="0.127" width="0.1524" layer="51"/>
<wire x1="-2.667" y1="0.127" x2="-2.667" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="-0.381" x2="-2.54" y2="-0.381" width="0.1524" layer="51"/>
<circle x="3.556" y="-1.27" radius="0.889" width="0.1524" layer="21"/>
<circle x="3.556" y="-1.27" radius="0.635" width="0.0508" layer="21"/>
<pad name="A" x="2.54" y="1.27" drill="0.8128" shape="long"/>
<pad name="E" x="-2.54" y="1.27" drill="0.8128" shape="long"/>
<pad name="S" x="0" y="-1.27" drill="0.8128" shape="long"/>
<text x="-4.826" y="2.8702" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.8006" y="-4.191" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="0.635" size="1.27" layer="21" ratio="10">3</text>
<text x="-2.032" y="-1.016" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="S75H">
<wire x1="1.778" y1="0" x2="1.905" y2="0" width="0.254" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.778" y2="0" width="0.254" layer="21"/>
<wire x1="0" y1="1.778" x2="0" y2="1.905" width="0.254" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.397" y2="1.397" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.397" y2="1.397" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-1.397" y2="-1.397" width="0.254" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="1.397" y2="-1.397" width="0.254" layer="51"/>
<circle x="0" y="0" radius="3.302" width="0.1524" layer="21"/>
<pad name="A" x="-1.778" y="-1.397" drill="0.8128" shape="octagon"/>
<pad name="S" x="0" y="0.381" drill="0.8128" shape="octagon"/>
<pad name="E" x="1.778" y="-1.397" drill="0.8128" shape="octagon"/>
<text x="0.762" y="-2.667" size="0.9906" layer="51" ratio="12">3</text>
<text x="-1.524" y="-2.667" size="0.9906" layer="51" ratio="12">1</text>
<text x="-3.302" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="S75P">
<wire x1="-0.635" y1="-0.635" x2="0.635" y2="0.635" width="0.6096" layer="21"/>
<wire x1="1.778" y1="0" x2="1.905" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="0" x2="-1.778" y2="0" width="0.1524" layer="51"/>
<wire x1="0" y1="1.778" x2="0" y2="1.905" width="0.1524" layer="51"/>
<wire x1="1.27" y1="1.27" x2="1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-1.397" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="1.397" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-3.2379" y1="-0.6476" x2="0" y2="-3.302" width="0.1524" layer="21" curve="78.690111"/>
<wire x1="0" y1="-3.302" x2="3.2426" y2="-0.6236" width="0.1524" layer="21" curve="79.114357"/>
<wire x1="-3.2278" y1="0.6725" x2="-0.889" y2="3.175" width="0.1524" layer="21" curve="-62.588748"/>
<wire x1="0.889" y1="3.175" x2="3.2278" y2="0.6725" width="0.1524" layer="21" curve="-62.588748"/>
<circle x="0" y="0" radius="3.302" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="1.397" width="0.1524" layer="21"/>
<pad name="A" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="S" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="0.762" y="-2.667" size="0.9906" layer="21" ratio="12">3</text>
<text x="-1.524" y="-2.667" size="0.9906" layer="21" ratio="12">1</text>
</package>
<package name="ST10">
Piher</description>
<wire x1="-1.905" y1="-1.27" x2="-1.27" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-1.905" x2="-1.143" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-1.905" x2="1.27" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="1.27" y1="-1.905" x2="1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="3.175" x2="-0.762" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.762" y1="2.54" x2="0.762" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="3.175" x2="-0.762" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="3.175" x2="0.762" y2="3.175" width="0.1524" layer="21"/>
<wire x1="0.762" y1="3.175" x2="4.445" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="4.445" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="3.175" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="3.937" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-0.635" x2="1.143" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.635" x2="-1.143" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-3.937" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-0.635" x2="-1.143" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="-1.27" x2="-3.937" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="4.445" y1="-1.27" x2="3.937" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-1.27" x2="-1.143" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-1.905" x2="-1.143" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="0.762" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.762" y1="2.54" x2="-0.762" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<pad name="A" x="-2.54" y="-1.27" drill="1.3208" shape="octagon"/>
<pad name="E" x="2.54" y="-1.27" drill="1.3208" shape="octagon"/>
<pad name="S" x="0" y="1.27" drill="1.3208" shape="octagon"/>
<text x="-4.445" y="3.5306" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-4.0894" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ST15">
Piher</description>
<wire x1="-3.683" y1="-2.54" x2="-3.048" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-3.175" x2="3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-1.397" y2="2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.477" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-1.905" x2="3.683" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="3.683" y1="-1.905" x2="-3.683" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-6.477" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-1.905" x2="-3.683" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="-2.54" x2="-6.477" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="6.985" y1="-2.54" x2="6.477" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.54" x2="3.683" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="3.683" y1="-2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-3.175" x2="-3.048" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="1.397" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="51"/>
<wire x1="7.62" y1="1.905" x2="1.905" y2="1.905" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.905" x2="1.397" y2="1.905" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.905" x2="-1.905" y2="1.905" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="1.905" x2="-1.905" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.905" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="1.905" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-1.905" y2="1.905" width="0.1524" layer="21"/>
<pad name="A" x="-5.08" y="-2.54" drill="1.3208" shape="long"/>
<pad name="E" x="5.08" y="-2.54" drill="1.3208" shape="long"/>
<pad name="S" x="0" y="2.54" drill="1.3208" shape="long"/>
<text x="1.905" y="3.0226" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-0.6604" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SP19LKN">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;</description>
<wire x1="-9.525" y1="-2.413" x2="10.16" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-2.413" x2="10.16" y2="2.667" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.667" x2="-9.525" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.667" x2="-9.525" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="6.223" y1="1.27" x2="5.842" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.223" y1="1.27" x2="6.096" y2="1.143" width="0.1524" layer="21"/>
<wire x1="6.223" y1="1.27" x2="6.096" y2="1.397" width="0.1524" layer="21"/>
<wire x1="5.969" y1="1.016" x2="5.969" y2="1.524" width="0.1524" layer="21"/>
<wire x1="5.969" y1="1.016" x2="5.842" y2="0.889" width="0.1524" layer="21"/>
<wire x1="5.969" y1="1.524" x2="5.842" y2="1.651" width="0.1524" layer="21"/>
<wire x1="6.096" y1="1.143" x2="6.096" y2="1.397" width="0.1524" layer="21"/>
<wire x1="6.096" y1="1.143" x2="5.969" y2="1.016" width="0.1524" layer="21"/>
<wire x1="6.096" y1="1.397" x2="5.969" y2="1.524" width="0.1524" layer="21"/>
<wire x1="5.842" y1="1.27" x2="5.842" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="0.762" x2="5.842" y2="0.889" width="0.1524" layer="21"/>
<wire x1="5.842" y1="1.651" x2="5.715" y2="1.778" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.778" x2="5.715" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.27" x2="5.842" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.667" x2="-9.525" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="3.683" x2="-14.605" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="3.683" x2="-14.605" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="3.302" x2="-14.605" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="0.762" x2="-14.605" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-0.508" x2="-14.605" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-3.048" x2="-14.605" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-3.429" x2="-9.525" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-3.429" x2="-9.525" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="3.302" x2="-14.732" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-14.732" y1="3.302" x2="-14.732" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-14.732" y1="0.762" x2="-14.605" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-0.508" x2="-14.732" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-14.732" y1="-0.508" x2="-14.732" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-14.732" y1="-3.048" x2="-14.605" y2="-3.048" width="0.1524" layer="21"/>
<pad name="A" x="6.35" y="-1.27" drill="1.016" shape="long"/>
<pad name="E" x="-6.35" y="-1.27" drill="1.016" shape="long"/>
<pad name="S" x="-1.27" y="1.27" drill="1.016" shape="long"/>
<text x="-15.113" y="-3.429" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.81" y="-1.778" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="7.62" y="-1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-8.89" y="-1.905" size="1.27" layer="21" ratio="10">3</text>
<text x="-3.937" y="0.635" size="1.27" layer="21" ratio="10">2</text>
<text x="1.397" y="0.635" size="1.27" layer="21" ratio="10"> 1 </text>
<text x="5.588" y="0.635" size="1.27" layer="21" ratio="10"> 3 </text>
</package>
<package name="PT-10">
<wire x1="-3.175" y1="-4.064" x2="3.175" y2="-4.064" width="0.1524" layer="21" curve="-288.924644"/>
<wire x1="3.175" y1="-4.064" x2="3.175" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-5.715" x2="-3.175" y2="-4.064" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="-5.715" x2="-2.794" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-4.445" x2="-1.27" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-5.715" x2="1.27" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-3.175" x2="2.794" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-5.715" x2="3.175" y2="-5.715" width="0.1524" layer="51"/>
<pad name="A" x="-2.54" y="-5.08" drill="1.016" shape="octagon"/>
<pad name="E" x="2.54" y="-5.08" drill="1.016" shape="octagon"/>
<pad name="S" x="0" y="5.08" drill="1.016" shape="octagon"/>
<text x="-3.175" y="6.35" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="PT-10S">
<wire x1="-1.27" y1="-1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="3.175" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="0.635" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="3.175" x2="4.445" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="5.08" y2="-0.635" width="0.1524" layer="51"/>
<pad name="A" x="-2.54" y="-1.27" drill="1.016" shape="long"/>
<pad name="E" x="2.54" y="-1.27" drill="1.016" shape="long"/>
<pad name="S" x="0" y="1.27" drill="1.016" shape="long"/>
<text x="-2.54" y="3.7846" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.2164" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="PT-SPIN">
<wire x1="-8.89" y1="-2.54" x2="8.89" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-2.54" x2="8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.54" x2="-8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.54" x2="-8.89" y2="-2.54" width="0.1524" layer="21"/>
<pad name="S" x="-1.27" y="1.27" drill="0.8128" shape="long"/>
<pad name="E" x="6.35" y="-1.27" drill="0.8128" shape="long"/>
<pad name="A" x="-6.35" y="-1.27" drill="0.8128" shape="long"/>
<text x="-3.175" y="3.175" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-1.778" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-9.525" y1="-1.27" x2="-8.89" y2="1.27" layer="21"/>
<rectangle x1="-10.16" y1="0.381" x2="-9.525" y2="1.27" layer="21"/>
<rectangle x1="-10.16" y1="-1.27" x2="-9.525" y2="-0.381" layer="21"/>
</package>
<package name="CIP20C-4MM">
<description>&lt;b&gt;Carbon Rotary Potentiometers - 20 mm size&lt;/b&gt;&lt;p&gt;
Source: Radiohm .. RAD.pdf</description>
<wire x1="-10.1" y1="-1.125" x2="-10.1" y2="6.675" width="0.2032" layer="21"/>
<wire x1="-10.1" y1="6.675" x2="10.1" y2="6.675" width="0.2032" layer="21"/>
<wire x1="10.1" y1="6.675" x2="10.1" y2="-1.125" width="0.2032" layer="21"/>
<wire x1="10.1" y1="-1.125" x2="10.1" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="10.1" y1="-3.8" x2="-10.1" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="-10.1" y1="-3.8" x2="-10.1" y2="-1.125" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-3.9" x2="2.9" y2="-11.8" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-11.8" x2="-2.9" y2="-11.8" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-11.8" x2="-2.9" y2="-3.875" width="0.2032" layer="21"/>
<wire x1="1.9" y1="-11.9" x2="1.9" y2="-52.8" width="0.2032" layer="21"/>
<wire x1="1.9" y1="-52.8" x2="0.9" y2="-53.8" width="0.2032" layer="21"/>
<wire x1="0.9" y1="-53.8" x2="-0.9" y2="-53.8" width="0.2032" layer="21"/>
<wire x1="-0.9" y1="-53.8" x2="-1.9" y2="-52.8" width="0.2032" layer="21"/>
<wire x1="-1.9" y1="-52.8" x2="-1.9" y2="-11.875" width="0.2032" layer="21"/>
<wire x1="10.1" y1="-1.125" x2="-10.1" y2="-1.125" width="0.2032" layer="21"/>
<pad name="A" x="-5" y="0" drill="1.3" diameter="1.9304"/>
<pad name="S" x="0" y="0" drill="1.3" diameter="1.9304"/>
<pad name="E" x="5" y="0" drill="1.3" diameter="1.9304"/>
<text x="-10.16" y="6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.255" y="3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="CIP20C-6MM">
<wire x1="3.9" y1="-3.9" x2="3.9" y2="-11.8" width="0.2032" layer="21"/>
<wire x1="3.9" y1="-11.8" x2="-3.9" y2="-11.8" width="0.2032" layer="21"/>
<wire x1="-3.9" y1="-11.8" x2="-3.9" y2="-3.875" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-11.85" x2="2.9" y2="-52.8" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-52.8" x2="1.9" y2="-53.8" width="0.2032" layer="21"/>
<wire x1="1.9" y1="-53.8" x2="-1.9" y2="-53.8" width="0.2032" layer="21"/>
<wire x1="-1.9" y1="-53.8" x2="-2.9" y2="-52.8" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-52.8" x2="-2.9" y2="-11.875" width="0.2032" layer="21"/>
</package>
<package name="SM-42/43A">
<description>&lt;b&gt;COPAL ELECTRONICS SM-42/43 SURFACE MOUNT TRIMMERS&lt;/b&gt; Side adjustmet&lt;p&gt;
Source: smt-pots.pdf</description>
<wire x1="2.175" y1="-2.3" x2="2.175" y2="2.3" width="0.2032" layer="51"/>
<wire x1="2.175" y1="2.3" x2="-2.2" y2="2.3" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="2.3" x2="-2.2" y2="-2.3" width="0.2032" layer="51"/>
<wire x1="-2.2" y1="-2.3" x2="2.175" y2="-2.3" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="2.3" x2="-2.2" y2="1.2" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-1.2" x2="-2.2" y2="-2.3" width="0.2032" layer="21"/>
<smd name="3" x="2" y="-1.15" dx="1.3" dy="2" layer="1" rot="R90"/>
<smd name="2" x="-2" y="0" dx="2" dy="2" layer="1" rot="R90"/>
<smd name="1" x="2" y="1.15" dx="1.3" dy="2" layer="1" rot="R90"/>
<text x="-2.65" y="-3.975" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.75" y="2.7" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.95" y1="-1.425" x2="2.75" y2="-1.125" layer="51" rot="R90"/>
<rectangle x1="1.95" y1="1.125" x2="2.75" y2="1.425" layer="51" rot="R90"/>
<rectangle x1="-3" y1="-0.15" x2="-1.7" y2="0.15" layer="51" rot="R90"/>
<rectangle x1="-2.5875" y1="-1.6375" x2="-1.6875" y2="-1.3125" layer="21" rot="R90"/>
</package>
<package name="SM-42/43B">
<smd name="3" x="2.6" y="-1.15" dx="1.3" dy="1.3" layer="1" rot="R90"/>
<smd name="2" x="-2.6" y="0" dx="2" dy="1.3" layer="1" rot="R90"/>
<smd name="1" x="2.6" y="1.15" dx="1.3" dy="1.3" layer="1" rot="R90"/>
<text x="-2.575" y="-3.85" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.575" y="2.65" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.2" y1="-1.675" x2="3" y2="-0.875" layer="51" rot="R90"/>
<rectangle x1="2.2" y1="0.875" x2="3" y2="1.675" layer="51" rot="R90"/>
<rectangle x1="-3.2375" y1="-0.3875" x2="-1.9375" y2="0.3875" layer="51" rot="R90"/>
</package>
<package name="SM-42/43W">
<description>&lt;b&gt;COPAL ELECTRONICS SM-42/43 SURFACE MOUNT TRIMMERS&lt;/b&gt; Top adjustmet&lt;p&gt;
<wire x1="-2.3" y1="-1.625" x2="2.3" y2="-1.625" width="0.2032" layer="51"/>
<wire x1="2.3" y1="-1.625" x2="2.3" y2="1.65" width="0.2032" layer="21"/>
<wire x1="2.3" y1="1.65" x2="-2.3" y2="1.65" width="0.2032" layer="51"/>
<wire x1="-2.3" y1="1.65" x2="-2.3" y2="-1.625" width="0.2032" layer="21"/>
<wire x1="2.3" y1="1.65" x2="1.2" y2="1.65" width="0.2032" layer="21"/>
<wire x1="-1.2" y1="1.65" x2="-2.3" y2="1.65" width="0.2032" layer="21"/>
<wire x1="1.525" y1="1.175" x2="0.875" y2="0.525" width="0.2032" layer="51"/>
<circle x="1.2" y="0.85" radius="0.5505" width="0.2032" layer="51"/>
<smd name="1" x="-1.27" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0" y="1.45" dx="2" dy="1.6" layer="1"/>
<smd name="3" x="1.27" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<text x="-2.4" y="-3.625" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.4" y="2.475" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.675" y1="-1.95" x2="-0.875" y2="-1.65" layer="51"/>
<rectangle x1="0.875" y1="-1.95" x2="1.675" y2="-1.65" layer="51"/>
<rectangle x1="-0.65" y1="1.65" x2="0.65" y2="1.95" layer="51"/>
</package>
<package name="SM-42/43X">
<wire x1="1.525" y1="1.175" x2="0.875" y2="0.525" width="0.2032" layer="21"/>
<circle x="1.2" y="0.85" radius="0.5505" width="0.2032" layer="21"/>
<smd name="1" x="-1.27" y="-2.55" dx="1.3" dy="1.9" layer="1"/>
<smd name="2" x="0" y="2.55" dx="2" dy="1.9" layer="1"/>
<smd name="3" x="1.27" y="-2.55" dx="1.3" dy="1.9" layer="1"/>
<text x="-2.4" y="-5" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.4" y="3.675" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.675" y1="-2.85" x2="-0.875" y2="-1.65" layer="51"/>
<rectangle x1="0.875" y1="-2.85" x2="1.675" y2="-1.65" layer="51"/>
<rectangle x1="-0.65" y1="1.65" x2="0.65" y2="2.85" layer="51"/>
</package>
<package name="3223G">
<description>&lt;b&gt;3 mm SMD Trimming Potentiometer&lt;/b&gt; Side Adjust&lt;p&gt;
Source: http://www.bourns.com/data/global/PDFs/3223.PDF</description>
<wire x1="-1.85" y1="1.85" x2="1.85" y2="1.85" width="0.2032" layer="51"/>
<wire x1="1.85" y1="1.85" x2="1.85" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="1.85" y1="-1.85" x2="-1.85" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-1.85" y1="-1.85" x2="-1.85" y2="1.85" width="0.2032" layer="51"/>
<wire x1="-0.8975" y1="1.85" x2="1.85" y2="1.85" width="0.2032" layer="21"/>
<wire x1="1.85" y1="1.85" x2="1.85" y2="1.0075" width="0.2032" layer="21"/>
<wire x1="1.85" y1="-1.85" x2="-0.8975" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.85" y1="-1.0075" x2="1.85" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="-1.85" y1="-0.58" x2="-1.85" y2="0.58" width="0.2032" layer="21"/>
<smd name="1" x="-2.2" y="1.4" dx="2" dy="0.9" layer="1"/>
<smd name="2" x="2.2" y="0" dx="2" dy="1.3" layer="1"/>
<smd name="3" x="-2.2" y="-1.4" dx="2" dy="0.9" layer="1"/>
<text x="-1.5875" y="2.2225" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.4925" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.65" y1="1.075" x2="-1.925" y2="1.625" layer="51"/>
<rectangle x1="-2.65" y1="-1.625" x2="-1.925" y2="-1.075" layer="51"/>
<rectangle x1="1.925" y1="-0.5" x2="2.625" y2="0.5" layer="51"/>
</package>
<package name="3223J">
<smd name="1" x="-2" y="1.4" dx="1.6" dy="0.9" layer="1"/>
<smd name="2" x="2" y="0" dx="1.6" dy="1.3" layer="1"/>
<smd name="3" x="-2" y="-1.4" dx="1.6" dy="0.9" layer="1"/>
</package>
<package name="3223W">
<description>&lt;b&gt;3 mm SMD Trimming Potentiometer&lt;/b&gt; Top Adjust&lt;p&gt;
<wire x1="-1.85" y1="1.5" x2="1.85" y2="1.5" width="0.2032" layer="51"/>
<wire x1="1.85" y1="1.5" x2="1.85" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="1.85" y1="-1.5" x2="-1.85" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="-1.85" y1="-1.5" x2="-1.85" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-1.85" y1="0.0875" x2="-1.85" y2="1.5" width="0.2032" layer="21"/>
<wire x1="-1.85" y1="1.5" x2="-1.0075" y2="1.5" width="0.2032" layer="21"/>
<wire x1="1.0075" y1="1.5" x2="1.85" y2="1.5" width="0.2032" layer="21"/>
<wire x1="1.85" y1="1.5" x2="1.85" y2="0.0875" width="0.2032" layer="21"/>
<wire x1="0.58" y1="-1.5" x2="-0.58" y2="-1.5" width="0.2032" layer="21"/>
<circle x="1.05" y="0.725" radius="0.5255" width="0.1016" layer="21"/>
<smd name="1" x="-1.4" y="-1.215" dx="0.9" dy="1.6" layer="1"/>
<smd name="3" x="1.4" y="-1.215" dx="0.9" dy="1.6" layer="1"/>
<smd name="2" x="0" y="1.215" dx="1.3" dy="1.3" layer="1"/>
<rectangle x1="0.55" y1="0.6" x2="1.55" y2="0.85" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="TPOT">
<wire x1="-0.762" y1="2.54" x2="-0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0.762" y1="-2.54" x2="0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="1.651" y2="0" width="0.1524" layer="94"/>
<wire x1="1.651" y1="0" x2="-1.8796" y2="1.7526" width="0.1524" layer="94"/>
<wire x1="0.762" y1="2.54" x2="-0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="-0.762" y1="-2.54" x2="0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-3.048" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-2.032" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="-2.1597" y1="1.2939" x2="-1.7018" y2="2.2352" width="0.1524" layer="94"/>
<text x="-5.969" y="-3.81" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="A" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="E" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="S" x="5.08" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="TRIM_EU-" prefix="R" uservalue="yes">
<gates>
<gate name="1" symbol="TPOT" x="0" y="0"/>
</gates>
<devices>
<device name="B25P" package="B25P">
<connects>
<connect gate="1" pin="A" pad="A"/>
<connect gate="1" pin="E" pad="E"/>
<connect gate="1" pin="S" pad="S"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="B25U" package="B25U">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B25V" package="B25V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B25X" package="B25X">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B64W" package="B64W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B64Y" package="B64Y">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B90P" package="SP19L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CA6H" package="CA6H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CA6V" package="CA6V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CA9H" package="CA9H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CA9V" package="CA9V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CA14V" package="CA14V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CA14H" package="CA14H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CT6" package="CT6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ECP10P" package="ECP10P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ECP10S" package="ECP10S">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LI10" package="LI10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LI15" package="LI15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RJ6" package="RJ6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RJ6S" package="RJ6S">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RJ9W" package="RJ9W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RS3" package="RS3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S43P" package="SP19L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S63P" package="S63P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S63S" package="S63S">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S63X" package="S63X">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S64W" package="S64W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S64Y" package="S64Y">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S75H" package="S75H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S75P" package="S75P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SP19L" package="SP19L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ST10" package="ST10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ST15" package="ST15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="T189" package="SP19LKN">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PT10" package="PT-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PT10S" package="PT-10S">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PTSPIN" package="PT-SPIN">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CIP20C-4MM" package="CIP20C-4MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CIP20C-6MM" package="CIP20C-6MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SM-42/43A" package="SM-42/43A">
<connects>
<connect gate="1" pin="A" pad="1"/>
<connect gate="1" pin="E" pad="3"/>
<connect gate="1" pin="S" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SM-42/43B" package="SM-42/43B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SM-42/43W" package="SM-42/43W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SM-42/43X" package="SM-42/43X">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3223G" package="3223G">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3223J" package="3223J">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3223W" package="3223W">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="docu-dummy">
<description>Dummy symbols</description>
<packages>
</packages>
<symbols>
<symbol name="RESISTOR">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-5.08" y1="0" x2="-2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="5.08" y2="0" width="0.1524" layer="94"/>
</symbol>
<symbol name="ELKO">
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="-1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-5.08" width="0.1524" layer="94"/>
<text x="-0.5842" y="0.4064" size="1.27" layer="94" rot="R90">+</text>
<rectangle x1="-1.651" y1="-2.54" x2="1.651" y2="-1.651" layer="94"/>
</symbol>
<symbol name="CAPACITOR">
<wire x1="0" y1="-5.08" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<wire x1="0" y1="-0.508" x2="0" y2="2.54" width="0.1524" layer="94"/>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="R" prefix="R">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="RESISTOR" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ELKO" prefix="C">
<description>&lt;b&gt;ELektrolyt Capacitor&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="ELKO" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C" prefix="C">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="CAPACITOR" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
 &lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
</packages>
<symbols>
<symbol name="GND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="GND" prefix="GND">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="display-hp">
<description>&lt;b&gt;Hewlett Packard LED Displays&lt;/b&gt;&lt;p&gt;
<packages>
<package name="HLMP6">
<description>&lt;b&gt;LED&lt;/b&gt;&lt;p&gt;
2 mm horizontal, RM 2.54 mm</description>
<wire x1="-2.413" y1="-1.27" x2="2.921" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.27" x2="2.921" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.27" x2="-2.413" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.27" x2="-2.413" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.889" x2="-2.794" y2="0.889" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.794" y1="0.889" x2="-2.413" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="0.889" x2="-2.413" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.889" x2="-2.413" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.889" x2="-2.413" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.635" x2="-2.794" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.508" x2="-3.048" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.254" x2="-3.302" y2="-0.254" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="3.429" y="0.127" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.429" y="-1.397" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="LED">
<wire x1="1.27" y1="2.54" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="2.54" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="2.54" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="5.08" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="-1.27" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="-2.032" y1="1.778" x2="-3.429" y2="0.381" width="0.1524" layer="94"/>
<wire x1="-3.429" y1="0.381" x2="-2.54" y2="0.762" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="0.762" x2="-3.048" y2="1.27" width="0.1524" layer="94"/>
<wire x1="-3.048" y1="1.27" x2="-3.429" y2="0.381" width="0.1524" layer="94"/>
<wire x1="-3.302" y1="-0.762" x2="-2.413" y2="-0.381" width="0.1524" layer="94"/>
<wire x1="-2.413" y1="-0.381" x2="-2.921" y2="0.127" width="0.1524" layer="94"/>
<wire x1="-2.921" y1="0.127" x2="-3.302" y2="-0.762" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="0.635" x2="-3.302" y2="-0.762" width="0.1524" layer="94"/>
<text x="3.302" y="-1.524" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="5.461" y="-1.524" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="K" x="0" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="A" x="0" y="5.08" visible="off" length="point" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="HLMP6" prefix="D">
2mm horizontal</description>
<gates>
<gate name="A" symbol="LED" x="0" y="0"/>
</gates>
<devices>
<device name="" package="HLMP6">
<connects>
<connect gate="A" pin="A" pad="A"/>
<connect gate="A" pin="K" pad="K"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="AGILENT TECHNOLOGIES" constant="no"/>
<attribute name="MPN" value="HLMP-6500" constant="no"/>
<attribute name="OC_FARNELL" value="1652490" constant="no"/>
<attribute name="OC_NEWARK" value="40K0088" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/2-H">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;&lt;p&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.</description>
<wire x1="-5.08" y1="-7.239" x2="-5.08" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-7.239" x2="-4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.429" x2="5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.429" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.429" x2="5.08" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.794" x2="5.461" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-3.429" x2="5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="2.159" x2="-0.4826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-2.794" x2="-0.4826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-2.794" x2="-4.5466" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="2.159" x2="-4.5466" y2="2.159" width="0.1524" layer="21"/>
<wire x1="0.4826" y1="2.159" x2="0.4826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.4826" y1="-2.794" x2="4.5466" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="4.5466" y1="-2.794" x2="4.5466" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.5466" y1="2.159" x2="0.4826" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.8006" y1="-3.048" x2="0.2286" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="4.8006" y1="-3.048" x2="4.8006" y2="2.413" width="0.0508" layer="21"/>
<wire x1="0.2286" y1="2.413" x2="4.8006" y2="2.413" width="0.0508" layer="21"/>
<wire x1="0.2286" y1="2.413" x2="0.2286" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-0.2286" y1="2.413" x2="-0.2286" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-4.8006" y1="2.413" x2="-0.2286" y2="2.413" width="0.0508" layer="21"/>
<wire x1="-4.8006" y1="2.413" x2="-4.8006" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-0.2286" y1="-3.048" x2="-4.8006" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-4.5466" y1="0" x2="-0.4826" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="-4.5466" y1="-2.413" x2="-4.2926" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.7366" y1="-2.667" x2="-0.4826" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.7366" y1="-2.667" x2="-4.2926" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-1.3716" y1="-2.413" x2="-1.1176" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.9116" y1="-2.667" x2="-3.6576" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.6576" y1="-0.127" x2="-3.6576" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6576" y1="-0.127" x2="-1.3716" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-1.3716" y1="-0.127" x2="-1.3716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6576" y1="-0.762" x2="-1.3716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6576" y1="-0.762" x2="-3.6576" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-1.3716" y1="-0.762" x2="-1.3716" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.81" x2="-5.08" y2="-3.81" width="0.0508" layer="21"/>
<wire x1="-5.08" y1="-3.81" x2="-5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.81" x2="5.08" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.4826" y1="0" x2="4.5466" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="1.3716" y1="-0.127" x2="3.6576" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="1.3716" y1="-0.127" x2="1.3716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3716" y1="-0.762" x2="3.6576" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3716" y1="-0.762" x2="1.3716" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.6576" y1="-0.762" x2="3.6576" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.6576" y1="-0.127" x2="3.6576" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-2.667" x2="1.3716" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="3.6576" y1="-2.413" x2="3.9116" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="4.2926" y1="-2.667" x2="0.7366" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="4.2926" y1="-2.667" x2="4.5466" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="0.4826" y1="-2.413" x2="0.7366" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.762" y1="-7.366" x2="-0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-7.239" x2="0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-7.366" x2="-4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-7.239" x2="-2.794" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-7.366" x2="-2.794" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-7.239" x2="-2.794" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-7.239" x2="-2.286" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-7.239" x2="-0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-7.366" x2="-2.286" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-7.366" x2="-0.762" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-7.239" x2="2.286" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-7.239" x2="2.794" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-7.366" x2="2.286" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-7.366" x2="2.794" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-7.239" x2="4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-7.366" x2="4.318" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-7.366" x2="4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-7.239" x2="5.08" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-7.366" x2="0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-7.239" x2="2.286" y2="-7.239" width="0.1524" layer="21"/>
<circle x="-2.5146" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="2.5146" y="0" radius="1.397" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="3.556" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-5.715" size="1.27" layer="21" ratio="10">1</text>
<text x="1.905" y="-5.715" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-3.6576" y1="-1.524" x2="-1.3716" y2="-0.762" layer="51"/>
<rectangle x1="1.3716" y1="-1.524" x2="3.6576" y2="-0.762" layer="51"/>
<rectangle x1="-3.6576" y1="-2.667" x2="-1.3716" y2="-1.524" layer="21"/>
<rectangle x1="1.3716" y1="-2.667" x2="3.6576" y2="-1.524" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="KL">
<circle x="1.27" y="0" radius="1.27" width="0.254" layer="94"/>
<text x="-1.27" y="0.889" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<pin name="KL" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="KLV">
<text x="-3.81" y="-3.683" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="AK500/2-H" prefix="X" uservalue="yes">
<gates>
<gate name="-1" symbol="KL" x="0" y="5.08" addlevel="always"/>
<gate name="-2" symbol="KLV" x="0" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="AK500/2-H">
<connects>
<connect gate="-1" pin="KL" pad="1"/>
<connect gate="-2" pin="KL" pad="2"/>
</connects>
<technologies>
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply2">
<packages>
</packages>
<symbols>
<symbol name="+09V">
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="94"/>
<wire x1="0" y1="0.635" x2="0" y2="1.905" width="0.1524" layer="94"/>
<circle x="0" y="1.27" radius="1.27" width="0.254" layer="94"/>
<text x="-1.905" y="3.175" size="1.778" layer="96">&gt;VALUE</text>
<pin name="+9V" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="+9V" prefix="SUPPLY">
<gates>
<gate name="G$1" symbol="+09V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="T1" library="transistor" deviceset="BD139" device=""/>
<part name="Q1" library="transistor-fet" deviceset="BF245" device=""/>
<part name="R1" library="pot" deviceset="TRIM_EU-" device="B25P"/>
<part name="R2" library="docu-dummy" deviceset="R" device=""/>
<part name="R3" library="docu-dummy" deviceset="R" device=""/>
<part name="R4" library="docu-dummy" deviceset="R" device=""/>
<part name="C1" library="docu-dummy" deviceset="ELKO" device=""/>
<part name="C2" library="docu-dummy" deviceset="ELKO" device=""/>
<part name="C3" library="docu-dummy" deviceset="C" device=""/>
<part name="GND1" library="supply1" deviceset="GND" device=""/>
<part name="D1" library="display-hp" deviceset="HLMP6" device=""/>
<part name="D2" library="display-hp" deviceset="HLMP6" device=""/>
<part name="D3" library="display-hp" deviceset="HLMP6" device=""/>
<part name="X1" library="con-ptr500" deviceset="AK500/2-H" device=""/>
<part name="SUPPLY1" library="supply2" deviceset="+9V" device=""/>
<part name="T2" library="transistor" deviceset="BD139" device=""/>
<part name="Q2" library="transistor-fet" deviceset="BF245" device=""/>
<part name="R5" library="pot" deviceset="TRIM_EU-" device="B25P"/>
<part name="R6" library="docu-dummy" deviceset="R" device=""/>
<part name="R7" library="docu-dummy" deviceset="R" device=""/>
<part name="R8" library="docu-dummy" deviceset="R" device=""/>
<part name="C4" library="docu-dummy" deviceset="ELKO" device=""/>
<part name="C5" library="docu-dummy" deviceset="ELKO" device=""/>
<part name="C6" library="docu-dummy" deviceset="C" device=""/>
<part name="GND2" library="supply1" deviceset="GND" device=""/>
<part name="D4" library="display-hp" deviceset="HLMP6" device=""/>
<part name="D5" library="display-hp" deviceset="HLMP6" device=""/>
<part name="D6" library="display-hp" deviceset="HLMP6" device=""/>
<part name="X2" library="con-ptr500" deviceset="AK500/2-H" device=""/>
<part name="SUPPLY2" library="supply2" deviceset="+9V" device=""/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="T1" gate="G$1" x="40.64" y="25.4"/>
<instance part="Q1" gate="G$1" x="17.78" y="45.72"/>
<instance part="R1" gate="1" x="25.4" y="25.4"/>
<instance part="R2" gate="G$1" x="30.48" y="68.58" rot="R90"/>
<instance part="R3" gate="G$1" x="38.1" y="68.58" rot="R90"/>
<instance part="R4" gate="G$1" x="7.62" y="30.48" rot="R90"/>
<instance part="C1" gate="G$1" x="25.4" y="68.58"/>
<instance part="C2" gate="G$1" x="30.48" y="35.56"/>
<instance part="C3" gate="G$1" x="-5.08" y="43.18" rot="R270"/>
<instance part="GND1" gate="1" x="-2.54" y="15.24"/>
<instance part="D1" gate="A" x="38.1" y="55.88"/>
<instance part="D2" gate="A" x="38.1" y="45.72"/>
<instance part="D3" gate="A" x="38.1" y="33.02"/>
<instance part="X1" gate="-1" x="-22.86" y="43.18"/>
<instance part="X1" gate="-2" x="-22.86" y="20.32"/>
<instance part="SUPPLY1" gate="G$1" x="0" y="78.74" rot="R90"/>
<instance part="T2" gate="G$1" x="119.38" y="20.32"/>
<instance part="Q2" gate="G$1" x="91.44" y="48.26"/>
<instance part="R5" gate="1" x="101.6" y="20.32"/>
<instance part="R6" gate="G$1" x="114.3" y="71.12" rot="R90"/>
<instance part="R7" gate="G$1" x="121.92" y="71.12" rot="R90"/>
<instance part="R8" gate="G$1" x="78.74" y="30.48" rot="R90"/>
<instance part="C4" gate="G$1" x="109.22" y="71.12"/>
<instance part="C5" gate="G$1" x="111.76" y="35.56"/>
<instance part="C6" gate="G$1" x="66.04" y="45.72" rot="R270"/>
<instance part="GND2" gate="1" x="60.96" y="5.08"/>
<instance part="D4" gate="A" x="121.92" y="58.42"/>
<instance part="D5" gate="A" x="121.92" y="48.26"/>
<instance part="D6" gate="A" x="121.92" y="35.56"/>
<instance part="X2" gate="-1" x="53.34" y="45.72"/>
<instance part="X2" gate="-2" x="50.8" y="12.7"/>
<instance part="SUPPLY2" gate="G$1" x="83.82" y="81.28" rot="R90"/>
</instances>
<busses>
</busses>
<nets>
<net name="N$4" class="0">
<segment>
<wire x1="30.48" y1="63.5" x2="30.48" y2="58.42" width="0.1524" layer="91"/>
<wire x1="30.48" y1="58.42" x2="25.4" y2="58.42" width="0.1524" layer="91"/>
<wire x1="25.4" y1="58.42" x2="25.4" y2="63.5" width="0.1524" layer="91"/>
<wire x1="25.4" y1="58.42" x2="25.4" y2="48.26" width="0.1524" layer="91"/>
<junction x="25.4" y="58.42"/>
<junction x="25.4" y="63.5"/>
<junction x="30.48" y="63.5"/>
<pinref part="Q1" gate="G$1" pin="D"/>
<wire x1="25.4" y1="48.26" x2="22.86" y2="48.26" width="0.1524" layer="91"/>
<junction x="22.86" y="48.26"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="D2" gate="A" pin="A"/>
<pinref part="D1" gate="A" pin="K"/>
<wire x1="38.1" y1="53.34" x2="38.1" y2="50.8" width="0.1524" layer="91"/>
<junction x="38.1" y="53.34"/>
<junction x="38.1" y="50.8"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="D2" gate="A" pin="K"/>
<pinref part="D3" gate="A" pin="A"/>
<wire x1="38.1" y1="43.18" x2="38.1" y2="38.1" width="0.1524" layer="91"/>
<junction x="38.1" y="43.18"/>
<junction x="38.1" y="38.1"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="Q1" gate="G$1" pin="G"/>
<wire x1="12.7" y1="43.18" x2="7.62" y2="43.18" width="0.1524" layer="91"/>
<wire x1="7.62" y1="43.18" x2="-2.54" y2="43.18" width="0.1524" layer="91"/>
<junction x="7.62" y="43.18"/>
<wire x1="7.62" y1="35.56" x2="7.62" y2="43.18" width="0.1524" layer="91"/>
<junction x="-2.54" y="43.18"/>
<junction x="7.62" y="35.56"/>
<junction x="12.7" y="43.18"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="R1" gate="1" pin="S"/>
<wire x1="30.48" y1="30.48" x2="30.48" y2="25.4" width="0.1524" layer="91"/>
<junction x="30.48" y="25.4"/>
<pinref part="T1" gate="G$1" pin="B"/>
<wire x1="38.1" y1="25.4" x2="30.48" y2="25.4" width="0.1524" layer="91"/>
<junction x="38.1" y="25.4"/>
<junction x="30.48" y="30.48"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="X1" gate="-1" pin="KL"/>
<wire x1="-17.78" y1="43.18" x2="-10.16" y2="43.18" width="0.1524" layer="91"/>
<junction x="-17.78" y="43.18"/>
<junction x="-10.16" y="43.18"/>
<wire x1="-10.16" y1="43.18" x2="-7.62" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="GND" class="0">
<segment>
<pinref part="T1" gate="G$1" pin="E"/>
<wire x1="43.18" y1="20.32" x2="25.4" y2="20.32" width="0.1524" layer="91"/>
<pinref part="R1" gate="1" pin="A"/>
<junction x="25.4" y="20.32"/>
<wire x1="25.4" y1="20.32" x2="7.62" y2="20.32" width="0.1524" layer="91"/>
<wire x1="7.62" y1="20.32" x2="-2.54" y2="20.32" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="20.32" x2="-17.78" y2="20.32" width="0.1524" layer="91"/>
<pinref part="X1" gate="-2" pin="KL"/>
<junction x="-17.78" y="20.32"/>
<junction x="-2.54" y="20.32"/>
<pinref part="GND1" gate="1" pin="GND"/>
<wire x1="-2.54" y1="17.78" x2="-2.54" y2="20.32" width="0.1524" layer="91"/>
<wire x1="7.62" y1="25.4" x2="7.62" y2="20.32" width="0.1524" layer="91"/>
<junction x="7.62" y="25.4"/>
<junction x="43.18" y="20.32"/>
<junction x="-2.54" y="17.78"/>
<junction x="7.62" y="20.32"/>
</segment>
<segment>
<pinref part="R5" gate="1" pin="A"/>
<wire x1="101.6" y1="15.24" x2="101.6" y2="12.7" width="0.1524" layer="91"/>
<pinref part="X2" gate="-2" pin="KL"/>
<wire x1="101.6" y1="12.7" x2="78.74" y2="12.7" width="0.1524" layer="91"/>
<pinref part="GND2" gate="1" pin="GND"/>
<wire x1="78.74" y1="12.7" x2="60.96" y2="12.7" width="0.1524" layer="91"/>
<wire x1="60.96" y1="12.7" x2="55.88" y2="12.7" width="0.1524" layer="91"/>
<wire x1="60.96" y1="7.62" x2="60.96" y2="12.7" width="0.1524" layer="91"/>
<junction x="60.96" y="12.7"/>
<wire x1="78.74" y1="25.4" x2="78.74" y2="12.7" width="0.1524" layer="91"/>
<junction x="78.74" y="12.7"/>
<pinref part="T2" gate="G$1" pin="E"/>
<wire x1="121.92" y1="15.24" x2="121.92" y2="12.7" width="0.1524" layer="91"/>
<wire x1="121.92" y1="12.7" x2="101.6" y2="12.7" width="0.1524" layer="91"/>
<junction x="101.6" y="12.7"/>
</segment>
</net>
<net name="+9V" class="0">
<segment>
<wire x1="25.4" y1="78.74" x2="30.48" y2="78.74" width="0.1524" layer="91"/>
<wire x1="38.1" y1="73.66" x2="38.1" y2="78.74" width="0.1524" layer="91"/>
<wire x1="38.1" y1="78.74" x2="30.48" y2="78.74" width="0.1524" layer="91"/>
<wire x1="30.48" y1="78.74" x2="30.48" y2="73.66" width="0.1524" layer="91"/>
<wire x1="25.4" y1="71.12" x2="25.4" y2="78.74" width="0.1524" layer="91"/>
<junction x="25.4" y="71.12"/>
<pinref part="SUPPLY1" gate="G$1" pin="+9V"/>
<junction x="25.4" y="78.74"/>
<junction x="30.48" y="78.74"/>
<junction x="30.48" y="73.66"/>
<junction x="38.1" y="73.66"/>
<junction x="2.54" y="78.74"/>
<wire x1="2.54" y1="78.74" x2="25.4" y2="78.74" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="109.22" y1="81.28" x2="114.3" y2="81.28" width="0.1524" layer="91"/>
<wire x1="114.3" y1="81.28" x2="121.92" y2="81.28" width="0.1524" layer="91"/>
<wire x1="121.92" y1="81.28" x2="121.92" y2="76.2" width="0.1524" layer="91"/>
<wire x1="114.3" y1="76.2" x2="114.3" y2="81.28" width="0.1524" layer="91"/>
<junction x="114.3" y="81.28"/>
<wire x1="109.22" y1="73.66" x2="109.22" y2="81.28" width="0.1524" layer="91"/>
<pinref part="SUPPLY2" gate="G$1" pin="+9V"/>
<wire x1="109.22" y1="81.28" x2="86.36" y2="81.28" width="0.1524" layer="91"/>
<junction x="109.22" y="81.28"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="Q1" gate="G$1" pin="S"/>
<junction x="30.48" y="38.1"/>
<wire x1="30.48" y1="43.18" x2="30.48" y2="38.1" width="0.1524" layer="91"/>
<wire x1="25.4" y1="43.18" x2="30.48" y2="43.18" width="0.1524" layer="91"/>
<junction x="25.4" y="43.18"/>
<wire x1="25.4" y1="43.18" x2="22.86" y2="43.18" width="0.1524" layer="91"/>
<wire x1="25.4" y1="43.18" x2="25.4" y2="30.48" width="0.1524" layer="91"/>
<pinref part="R1" gate="1" pin="E"/>
<junction x="25.4" y="30.48"/>
<junction x="22.86" y="43.18"/>
</segment>
</net>
<net name="N$1" class="0">
<segment>
<pinref part="T1" gate="G$1" pin="C"/>
<pinref part="D3" gate="A" pin="K"/>
<wire x1="38.1" y1="30.48" x2="43.18" y2="30.48" width="0.1524" layer="91"/>
<junction x="38.1" y="30.48"/>
<junction x="43.18" y="30.48"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="D1" gate="A" pin="A"/>
<wire x1="38.1" y1="63.5" x2="38.1" y2="60.96" width="0.1524" layer="91"/>
<junction x="38.1" y="60.96"/>
<junction x="38.1" y="63.5"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="D4" gate="A" pin="A"/>
<wire x1="121.92" y1="66.04" x2="121.92" y2="63.5" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="D4" gate="A" pin="K"/>
<pinref part="D5" gate="A" pin="A"/>
<wire x1="121.92" y1="55.88" x2="121.92" y2="53.34" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="D5" gate="A" pin="K"/>
<pinref part="D6" gate="A" pin="A"/>
<wire x1="121.92" y1="45.72" x2="121.92" y2="40.64" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="D6" gate="A" pin="K"/>
<pinref part="T2" gate="G$1" pin="C"/>
<wire x1="121.92" y1="33.02" x2="121.92" y2="25.4" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<wire x1="109.22" y1="66.04" x2="109.22" y2="63.5" width="0.1524" layer="91"/>
<pinref part="Q2" gate="G$1" pin="D"/>
<wire x1="109.22" y1="63.5" x2="109.22" y2="50.8" width="0.1524" layer="91"/>
<wire x1="109.22" y1="50.8" x2="96.52" y2="50.8" width="0.1524" layer="91"/>
<wire x1="114.3" y1="66.04" x2="114.3" y2="63.5" width="0.1524" layer="91"/>
<wire x1="114.3" y1="63.5" x2="109.22" y2="63.5" width="0.1524" layer="91"/>
<junction x="109.22" y="63.5"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="T2" gate="G$1" pin="B"/>
<pinref part="R5" gate="1" pin="S"/>
<wire x1="116.84" y1="20.32" x2="111.76" y2="20.32" width="0.1524" layer="91"/>
<wire x1="111.76" y1="20.32" x2="106.68" y2="20.32" width="0.1524" layer="91"/>
<wire x1="111.76" y1="30.48" x2="111.76" y2="20.32" width="0.1524" layer="91"/>
<junction x="111.76" y="20.32"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="R5" gate="1" pin="E"/>
<wire x1="101.6" y1="25.4" x2="101.6" y2="45.72" width="0.1524" layer="91"/>
<pinref part="Q2" gate="G$1" pin="S"/>
<wire x1="101.6" y1="45.72" x2="96.52" y2="45.72" width="0.1524" layer="91"/>
<wire x1="111.76" y1="38.1" x2="111.76" y2="45.72" width="0.1524" layer="91"/>
<wire x1="111.76" y1="45.72" x2="101.6" y2="45.72" width="0.1524" layer="91"/>
<junction x="101.6" y="45.72"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="X2" gate="-1" pin="KL"/>
<wire x1="58.42" y1="45.72" x2="60.96" y2="45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="Q2" gate="G$1" pin="G"/>
<wire x1="68.58" y1="45.72" x2="78.74" y2="45.72" width="0.1524" layer="91"/>
<wire x1="78.74" y1="45.72" x2="86.36" y2="45.72" width="0.1524" layer="91"/>
<wire x1="78.74" y1="35.56" x2="78.74" y2="45.72" width="0.1524" layer="91"/>
<junction x="78.74" y="45.72"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
