<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TO92">
<description>&lt;b&gt;TO-92&lt;/b&gt;</description>
<wire x1="-2.095" y1="-1.651" x2="-0.7869" y2="2.5484" width="0.1524" layer="21" curve="-111.097684"/>
<wire x1="0.7869" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.097684"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.254" y1="-0.254" x2="-0.286" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.286" y1="-0.254" x2="0.286" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.286" y1="-0.254" x2="2.254" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.7864" y1="2.5484" x2="0.7864" y2="2.5484" width="0.1524" layer="51" curve="-34.298964"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO220H">
<description>&lt;b&gt;TO-220&lt;/b&gt;</description>
<wire x1="-5.207" y1="-7.62" x2="5.207" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.255" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-7.62" x2="5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="5.207" y1="4.826" x2="4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="4.318" y1="4.826" x2="4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="4.318" y1="6.35" x2="5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="5.207" y1="6.35" x2="5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-7.62" x2="-5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.826" x2="-4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="4.826" x2="-4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="6.35" x2="-5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="6.35" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<circle x="0" y="4.826" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="43"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="42"/>
<pad name="1" x="-2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.461" y="-10.922" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.366" y="-11.049" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="2.159" y1="-11.049" x2="2.921" y2="-10.414" layer="21"/>
<rectangle x1="-0.381" y1="-11.049" x2="0.381" y2="-10.414" layer="21"/>
<rectangle x1="-2.921" y1="-11.049" x2="-2.159" y2="-10.414" layer="21"/>
<rectangle x1="-3.175" y1="-10.414" x2="-1.905" y2="-7.62" layer="21"/>
<rectangle x1="-0.635" y1="-10.414" x2="0.635" y2="-7.62" layer="21"/>
<rectangle x1="1.905" y1="-10.414" x2="3.175" y2="-7.62" layer="21"/>
<hole x="0" y="4.826" drill="3.302"/>
</package>
<package name="TO39">
<description>&lt;b&gt;Metal Can Package&lt;/b&gt;</description>
<wire x1="-4.0386" y1="-3.5306" x2="-3.5052" y2="-2.9972" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-3.5306" x2="-3.5052" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-4.064" x2="-4.0386" y2="-3.5306" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.8608" width="0.0508" layer="21"/>
<pad name="1" x="0" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<text x="-2.794" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO252">
<description>&lt;b&gt;SMALL OUTLINE TRANSISTOR&lt;/b&gt;&lt;p&gt;
TS-003</description>
<wire x1="3.2766" y1="3.8354" x2="3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-2.159" x2="-3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-2.159" x2="-3.2766" y2="3.8354" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="3.835" x2="3.2774" y2="3.8346" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="3.937" x2="-2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="4.6482" x2="-2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="-2.1082" y1="5.1054" x2="2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="2.1082" y1="5.1054" x2="2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="4.6482" x2="2.5654" y2="3.937" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="3.937" x2="-2.5654" y2="3.937" width="0.2032" layer="51"/>
<smd name="3" x="0" y="2.5" dx="5.4" dy="6.2" layer="1"/>
<smd name="1" x="-2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<smd name="2" x="2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7178" y1="-5.1562" x2="-1.8542" y2="-2.2606" layer="51"/>
<rectangle x1="1.8542" y1="-5.1562" x2="2.7178" y2="-2.2606" layer="51"/>
<rectangle x1="-0.4318" y1="-3.0226" x2="0.4318" y2="-2.2606" layer="21"/>
<polygon width="0.1998" layer="51">
<vertex x="-2.5654" y="3.937"/>
<vertex x="-2.5654" y="4.6482"/>
<vertex x="-2.1082" y="5.1054"/>
<vertex x="2.1082" y="5.1054"/>
<vertex x="2.5654" y="4.6482"/>
<vertex x="2.5654" y="3.937"/>
</polygon>
</package>
<package name="TO220V">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="78XX">
<wire x1="-7.62" y1="-5.08" x2="7.62" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="2.54" width="0.4064" layer="94"/>
<wire x1="7.62" y1="2.54" x2="-7.62" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="2.54" x2="-7.62" y2="-5.08" width="0.4064" layer="94"/>
<text x="-7.62" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="3.175" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.032" y="-4.318" size="1.524" layer="95">GND</text>
<pin name="VI" x="-10.16" y="0" length="short" direction="in"/>
<pin name="GND" x="0" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="VO" x="10.16" y="0" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="78*" prefix="IC">
<description>Positive &lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;&lt;p&gt;
Source:&lt;br&gt;
http://cache.national.com/ds/LM/LM78L05.pdf&lt;br&gt;
http://www.fairchildsemi.com/ds/LM/LM7805.pdf</description>
<gates>
<gate name="A1" symbol="78XX" x="0" y="0"/>
</gates>
<devices>
<device name="Z" package="TO92">
<connects>
<connect gate="A1" pin="GND" pad="2"/>
<connect gate="A1" pin="VI" pad="3"/>
<connect gate="A1" pin="VO" pad="1"/>
</connects>
<technologies>
<technology name="L05"/>
<technology name="L08"/>
<technology name="L12"/>
<technology name="L15"/>
<technology name="L18"/>
<technology name="L24"/>
</technologies>
</device>
<device name="T" package="TO220H">
<connects>
<connect gate="A1" pin="VI" pad="1"/>
<connect gate="A1" pin="VO" pad="3"/>
</connects>
<technologies>
<technology name="05"/>
<technology name="06"/>
<technology name="08"/>
<technology name="12"/>
<technology name="15"/>
<technology name="18"/>
<technology name="24"/>
</technologies>
</device>
<device name="H" package="TO39">
<connects>
<connect gate="A1" pin="GND" pad="3"/>
<connect gate="A1" pin="VO" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="L" package="TO92">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DT" package="TO252">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TV" package="TO220V">
<connects>
</connects>
<technologies>
<technology name="6"/>
<technology name="8"/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="capacitor-wima">
<description>&lt;b&gt;WIMA Capacitors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="C10B4">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 13.4 x 4 mm, grid 10.16 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-3.429" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C10B5">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 13.4 x 5 mm, grid 10.16 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-5.08" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C10B6">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 13.4 x 6 mm, grid 10.16 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-5.08" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B5">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 5 mm, grid 15 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-7.493" y="2.794" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B6">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 6 mm, grid 15 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="3.302" size="1.397" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C15B7">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 7 mm, grid 15 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="3.81" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B8">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 8 mm, grid 15 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="4.318" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B9">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 9 mm, grid 15 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="4.699" size="1.397" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C2.5-2">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 2.5 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.651" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-4">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 4 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<text x="-1.651" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 5 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-1.778" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-6">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 6 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="2.667" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C22.5B10">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 10 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="-11.303" y="5.588" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C22.5B11">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 11 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="5.842" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C22.5B6">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 6 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="3.302" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C22.5B7">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 7 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C22.5B8">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 8 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="4.572" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B11">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 11 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" diameter="3.1496" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" diameter="3.1496" shape="octagon"/>
<text x="-13.716" y="5.842" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B13">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 13 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-13.716" y="6.858" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B15">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 15 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-13.716" y="7.874" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B17">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 17 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-13.716" y="8.763" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B20">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 20 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-13.589" y="10.414" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C27.5B9">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 9 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<text x="-13.589" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C37.5B15">
<description>&lt;B&gt;MKP4&lt;/B&gt;, 42 x 15 mm, grid 37.5 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" diameter="3.1496" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" diameter="3.1496" shape="octagon"/>
<text x="-18.796" y="7.874" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C37.5B19">
<description>&lt;B&gt;MKP4&lt;/B&gt;, 42 x 19 mm, grid 37.5 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-18.796" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C37.5B20">
<description>&lt;B&gt;MKP4&lt;/B&gt;, 42 x 20 mm, grid 37.5 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-18.796" y="10.414" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C5B2.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 2.5 mm, grid 5.08 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-2.032" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B3">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 3 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B3.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 4 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B4.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 4.5 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 5 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B5.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 5.5 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C5B7.2">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 7.2 mm, grid 5.08 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B3">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 3 mm, grid 7.62 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<text x="-3.81" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B4">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 4 mm, grid 7.62 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<text x="-3.81" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B5">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 5 mm, grid 7.62 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.81" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B6">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 6 mm, grid 7.62 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-3.683" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.889" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-3">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 3 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-1.651" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="C">
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="C" prefix="C" uservalue="yes">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;&lt;p&gt;
naming: grid - package width</description>
<gates>
<gate name="G$1" symbol="C" x="0" y="0"/>
</gates>
<devices>
<device name="10/4" package="C10B4">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="10/5" package="C10B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="10/6" package="C10B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/5" package="C15B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/6" package="C15B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/7" package="C15B7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/8" package="C15B8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/9" package="C15B9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/2" package="C2.5-2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/4" package="C2.5-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/5" package="C2.5-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/6" package="C2.5-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/10" package="C22.5B10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/11" package="C22.5B11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/6" package="C22.5B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/7" package="C22.5B7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/8" package="C22.5B8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/11" package="C27.5B11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/13" package="C27.5B13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/15" package="C27.5B15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/17" package="C27.5B17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/20" package="C27.5B20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/9" package="C27.5B9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37/15" package="C37.5B15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37/19" package="C37.5B19">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37/20" package="C37.5B20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/2.5" package="C5B2.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/3" package="C5B3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/3.5" package="C5B3.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/4.5" package="C5B4.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/5" package="C5B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/5.5" package="C5B5.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/7.2" package="C5B7.2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/3" package="C7.5B3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/4" package="C7.5B4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/5" package="C7.5B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/6" package="C7.5B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2,5-3" package="C2.5-3">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="microchip">
<description>&lt;b&gt;Microchip PIC Microcontrollers and other Devices&lt;/b&gt;&lt;p&gt;
Based on the following sources :
&lt;ul&gt;
&lt;li&gt;Microchip Data Book, 1993
&lt;li&gt;THE EMERGING WORLD STANDARD, 1995/1996
&lt;li&gt;Microchip, Technical Library CD-ROM, June 1998
&lt;li&gt;www.microchip.com
&lt;/ul&gt;
<packages>
<package name="PLCC-44">
<description>&lt;b&gt;PLASTIC LEADED CHIP CARRIER&lt;/b&gt;&lt;p&gt;
square, package type L</description>
<wire x1="-8.29" y1="7.79" x2="-7.79" y2="8.29" width="0.1524" layer="51"/>
<wire x1="-7.79" y1="8.29" x2="7.79" y2="8.29" width="0.1524" layer="51"/>
<wire x1="7.79" y1="8.29" x2="8.29" y2="7.79" width="0.1524" layer="51"/>
<wire x1="8.29" y1="7.79" x2="8.29" y2="-7.79" width="0.1524" layer="51"/>
<wire x1="8.29" y1="-7.79" x2="7.79" y2="-8.29" width="0.1524" layer="51"/>
<wire x1="7.79" y1="-8.29" x2="-7.04" y2="-8.29" width="0.1524" layer="51"/>
<wire x1="-7.04" y1="-8.29" x2="-8.2901" y2="-6.73" width="0.1524" layer="51"/>
<wire x1="-8.2901" y1="-6.73" x2="-8.29" y2="7.79" width="0.1524" layer="51"/>
<wire x1="7.54" y1="7.79" x2="7.79" y2="7.54" width="0.0508" layer="51"/>
<wire x1="7.79" y1="7.54" x2="7.79" y2="-7.54" width="0.0508" layer="51"/>
<wire x1="7.79" y1="-7.54" x2="7.54" y2="-7.79" width="0.0508" layer="51"/>
<wire x1="7.54" y1="-7.79" x2="-7.04" y2="-7.79" width="0.0508" layer="51"/>
<wire x1="-7.04" y1="-7.79" x2="-8.2901" y2="-6.73" width="0.0508" layer="51"/>
<wire x1="-7.04" y1="-8.29" x2="-7.04" y2="-7.79" width="0.0508" layer="51"/>
<wire x1="-7.04" y1="-7.79" x2="-7.04" y2="7.79" width="0.0508" layer="51"/>
<wire x1="-7.04" y1="7.79" x2="7.54" y2="7.79" width="0.0508" layer="51"/>
<wire x1="-7.79" y1="8.29" x2="-7.04" y2="7.79" width="0.0508" layer="51"/>
<wire x1="7.54" y1="7.79" x2="7.79" y2="8.29" width="0.0508" layer="51"/>
<wire x1="7.79" y1="7.54" x2="8.29" y2="7.79" width="0.0508" layer="51"/>
<wire x1="7.79" y1="-8.29" x2="7.54" y2="-7.79" width="0.0508" layer="51"/>
<wire x1="8.29" y1="-7.79" x2="7.79" y2="-7.54" width="0.0508" layer="51"/>
<wire x1="-5.91" y1="8.29" x2="-5.52" y2="8.29" width="0.1524" layer="21"/>
<wire x1="-4.64" y1="8.29" x2="-4.25" y2="8.29" width="0.1524" layer="21"/>
<wire x1="-3.37" y1="8.29" x2="-2.98" y2="8.29" width="0.1524" layer="21"/>
<wire x1="-2.1" y1="8.29" x2="-1.71" y2="8.29" width="0.1524" layer="21"/>
<wire x1="-0.83" y1="8.29" x2="-0.44" y2="8.29" width="0.1524" layer="21"/>
<wire x1="0.44" y1="8.29" x2="0.83" y2="8.29" width="0.1524" layer="21"/>
<wire x1="6.79" y1="8.29" x2="7.79" y2="8.29" width="0.1524" layer="21"/>
<wire x1="7.79" y1="8.29" x2="8.29" y2="7.79" width="0.1524" layer="21"/>
<wire x1="8.29" y1="7.79" x2="8.29" y2="6.79" width="0.1524" layer="21"/>
<wire x1="8.29" y1="3.37" x2="8.29" y2="2.98" width="0.1524" layer="21"/>
<wire x1="8.29" y1="2.1" x2="8.29" y2="1.71" width="0.1524" layer="21"/>
<wire x1="8.29" y1="0.83" x2="8.29" y2="0.44" width="0.1524" layer="21"/>
<wire x1="8.29" y1="-0.44" x2="8.29" y2="-0.83" width="0.1524" layer="21"/>
<wire x1="8.29" y1="-1.71" x2="8.29" y2="-2.1" width="0.1524" layer="21"/>
<wire x1="8.29" y1="-2.98" x2="8.29" y2="-3.37" width="0.1524" layer="21"/>
<wire x1="8.29" y1="-6.79" x2="8.29" y2="-7.79" width="0.1524" layer="21"/>
<wire x1="8.29" y1="-7.79" x2="7.79" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="7.79" y1="-8.29" x2="6.79" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="0.83" y1="-8.29" x2="0.44" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="-0.44" y1="-8.29" x2="-0.83" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="-1.71" y1="-8.29" x2="-2.1" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="-2.98" y1="-8.29" x2="-3.37" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="-4.25" y1="-8.29" x2="-4.64" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="-5.52" y1="-8.29" x2="-5.91" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="-6.79" y1="-8.29" x2="-7.04" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="-7.04" y1="-8.29" x2="-8.24" y2="-6.79" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="-3.37" x2="-8.29" y2="-2.98" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="-2.1" x2="-8.29" y2="-1.71" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="-0.83" x2="-8.29" y2="-0.44" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="0.44" x2="-8.29" y2="0.83" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="1.71" x2="-8.29" y2="2.1" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="2.98" x2="-8.29" y2="3.37" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="6.79" x2="-8.29" y2="7.79" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="7.79" x2="-7.79" y2="8.29" width="0.1524" layer="21"/>
<wire x1="-7.79" y1="8.29" x2="-6.79" y2="8.29" width="0.1524" layer="21"/>
<wire x1="-7.04" y1="7.79" x2="-6.75" y2="7.79" width="0.0508" layer="21"/>
<wire x1="-5.95" y1="7.79" x2="-5.48" y2="7.79" width="0.0508" layer="21"/>
<wire x1="-4.68" y1="7.79" x2="-4.21" y2="7.79" width="0.0508" layer="21"/>
<wire x1="-3.41" y1="7.79" x2="-2.94" y2="7.79" width="0.0508" layer="21"/>
<wire x1="-2.14" y1="7.79" x2="-1.67" y2="7.79" width="0.0508" layer="21"/>
<wire x1="-0.87" y1="7.79" x2="-0.4" y2="7.79" width="0.0508" layer="21"/>
<wire x1="0.4" y1="7.79" x2="0.87" y2="7.79" width="0.0508" layer="21"/>
<wire x1="6.75" y1="7.79" x2="7.54" y2="7.79" width="0.0508" layer="21"/>
<wire x1="7.54" y1="7.79" x2="7.79" y2="7.54" width="0.0508" layer="21"/>
<wire x1="7.79" y1="7.54" x2="7.79" y2="6.75" width="0.0508" layer="21"/>
<wire x1="7.79" y1="3.41" x2="7.79" y2="2.94" width="0.0508" layer="21"/>
<wire x1="7.79" y1="2.14" x2="7.79" y2="1.67" width="0.0508" layer="21"/>
<wire x1="7.79" y1="0.87" x2="7.79" y2="0.4" width="0.0508" layer="21"/>
<wire x1="7.79" y1="-0.4" x2="7.79" y2="-0.87" width="0.0508" layer="21"/>
<wire x1="7.79" y1="-1.67" x2="7.79" y2="-2.14" width="0.0508" layer="21"/>
<wire x1="7.79" y1="-2.94" x2="7.79" y2="-3.41" width="0.0508" layer="21"/>
<wire x1="7.79" y1="-6.75" x2="7.79" y2="-7.54" width="0.0508" layer="21"/>
<wire x1="7.79" y1="-7.54" x2="7.54" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="7.54" y1="-7.79" x2="6.75" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="0.87" y1="-7.79" x2="0.4" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="-0.4" y1="-7.79" x2="-0.87" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="-1.67" y1="-7.79" x2="-2.14" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="-2.94" y1="-7.79" x2="-3.41" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="-4.21" y1="-7.79" x2="-4.68" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="-5.48" y1="-7.79" x2="-5.95" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="-6.75" y1="-7.79" x2="-7.04" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="-7.79" x2="-8.27" y2="-6.75" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="-7.79" x2="-7.04" y2="-6.75" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="-3.41" x2="-7.04" y2="-2.94" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="-2.14" x2="-7.04" y2="-1.67" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="-0.87" x2="-7.04" y2="-0.4" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="0.4" x2="-7.04" y2="0.87" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="1.67" x2="-7.04" y2="2.14" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="2.94" x2="-7.04" y2="3.41" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="6.75" x2="-7.04" y2="7.79" width="0.0508" layer="21"/>
<wire x1="-7.79" y1="8.29" x2="-7.04" y2="7.79" width="0.0508" layer="21"/>
<wire x1="7.79" y1="7.54" x2="8.29" y2="7.79" width="0.0508" layer="21"/>
<wire x1="7.54" y1="7.79" x2="7.79" y2="8.29" width="0.1524" layer="21"/>
<wire x1="8.29" y1="-7.79" x2="7.79" y2="-7.54" width="0.0508" layer="21"/>
<wire x1="7.79" y1="-8.29" x2="7.54" y2="-7.79" width="0.1524" layer="21"/>
<wire x1="-7.04" y1="-8.29" x2="-7.04" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="2.14" y1="-7.79" x2="1.67" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="3.41" y1="-7.79" x2="2.94" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="2.1" y1="-8.29" x2="1.71" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="3.37" y1="-8.29" x2="2.98" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="1.71" y1="8.29" x2="2.1" y2="8.29" width="0.1524" layer="21"/>
<wire x1="2.98" y1="8.29" x2="3.37" y2="8.29" width="0.1524" layer="21"/>
<wire x1="1.67" y1="7.79" x2="2.14" y2="7.79" width="0.0508" layer="21"/>
<wire x1="2.94" y1="7.79" x2="3.41" y2="7.79" width="0.0508" layer="21"/>
<wire x1="4.25" y1="8.29" x2="4.64" y2="8.29" width="0.1524" layer="21"/>
<wire x1="5.52" y1="8.29" x2="5.91" y2="8.29" width="0.1524" layer="21"/>
<wire x1="4.21" y1="7.79" x2="4.68" y2="7.79" width="0.0508" layer="21"/>
<wire x1="5.48" y1="7.79" x2="5.95" y2="7.79" width="0.0508" layer="21"/>
<wire x1="8.29" y1="4.64" x2="8.29" y2="4.25" width="0.1524" layer="21"/>
<wire x1="8.29" y1="5.91" x2="8.29" y2="5.52" width="0.1524" layer="21"/>
<wire x1="7.79" y1="4.68" x2="7.79" y2="4.21" width="0.0508" layer="21"/>
<wire x1="7.79" y1="5.95" x2="7.79" y2="5.48" width="0.0508" layer="21"/>
<wire x1="-8.29" y1="4.25" x2="-8.29" y2="4.64" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="5.52" x2="-8.29" y2="5.91" width="0.1524" layer="21"/>
<wire x1="-7.04" y1="4.21" x2="-7.04" y2="4.68" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="5.48" x2="-7.04" y2="5.95" width="0.0508" layer="21"/>
<wire x1="-8.29" y1="-4.64" x2="-8.29" y2="-4.25" width="0.1524" layer="21"/>
<wire x1="-8.29" y1="-5.91" x2="-8.29" y2="-5.52" width="0.1524" layer="21"/>
<wire x1="-7.04" y1="-4.68" x2="-7.04" y2="-4.21" width="0.0508" layer="21"/>
<wire x1="-7.04" y1="-5.95" x2="-7.04" y2="-5.48" width="0.0508" layer="21"/>
<wire x1="8.29" y1="-4.25" x2="8.29" y2="-4.64" width="0.1524" layer="21"/>
<wire x1="8.29" y1="-5.52" x2="8.29" y2="-5.91" width="0.1524" layer="21"/>
<wire x1="7.79" y1="-4.21" x2="7.79" y2="-4.68" width="0.0508" layer="21"/>
<wire x1="7.79" y1="-5.48" x2="7.79" y2="-5.95" width="0.0508" layer="21"/>
<wire x1="4.68" y1="-7.79" x2="4.21" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="5.95" y1="-7.79" x2="5.48" y2="-7.79" width="0.0508" layer="21"/>
<wire x1="4.64" y1="-8.29" x2="4.25" y2="-8.29" width="0.1524" layer="21"/>
<wire x1="5.91" y1="-8.29" x2="5.52" y2="-8.29" width="0.1524" layer="21"/>
<circle x="-5.9601" y="0" radius="0.5001" width="0.0508" layer="51"/>
<circle x="-5.9601" y="0" radius="0.5001" width="0.0508" layer="21"/>
<smd name="8" x="-5.08" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="9" x="-3.81" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="10" x="-2.54" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="11" x="-1.27" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="12" x="0" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="13" x="1.27" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="14" x="2.54" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="36" x="-2.54" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="35" x="-1.27" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="34" x="0" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="33" x="1.27" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="32" x="2.54" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="31" x="3.81" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="30" x="5.08" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="6" x="-7.86" y="-6.35" dx="1.8" dy="0.76" layer="1"/>
<smd name="3" x="-7.86" y="-2.54" dx="1.8" dy="0.76" layer="1"/>
<smd name="2" x="-7.86" y="-1.27" dx="1.8" dy="0.76" layer="1"/>
<smd name="1" x="-7.86" y="0" dx="1.8" dy="0.76" layer="1"/>
<smd name="44" x="-7.86" y="1.27" dx="1.8" dy="0.76" layer="1"/>
<smd name="43" x="-7.86" y="2.54" dx="1.8" dy="0.76" layer="1"/>
<smd name="42" x="-7.86" y="3.81" dx="1.8" dy="0.76" layer="1"/>
<smd name="18" x="7.86" y="-6.35" dx="1.8" dy="0.76" layer="1"/>
<smd name="21" x="7.86" y="-2.54" dx="1.8" dy="0.76" layer="1"/>
<smd name="22" x="7.86" y="-1.27" dx="1.8" dy="0.76" layer="1"/>
<smd name="23" x="7.86" y="0" dx="1.8" dy="0.76" layer="1"/>
<smd name="24" x="7.86" y="1.27" dx="1.8" dy="0.76" layer="1"/>
<smd name="25" x="7.86" y="2.54" dx="1.8" dy="0.76" layer="1"/>
<smd name="26" x="7.86" y="3.81" dx="1.8" dy="0.76" layer="1"/>
<smd name="15" x="3.81" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="16" x="5.08" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="37" x="-3.81" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="38" x="-5.08" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="29" x="6.35" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="27" x="7.86" y="5.08" dx="1.8" dy="0.76" layer="1"/>
<smd name="28" x="7.86" y="6.35" dx="1.8" dy="0.76" layer="1"/>
<smd name="20" x="7.86" y="-3.81" dx="1.8" dy="0.76" layer="1"/>
<smd name="19" x="7.86" y="-5.08" dx="1.8" dy="0.76" layer="1"/>
<smd name="17" x="6.35" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="4" x="-7.86" y="-3.81" dx="1.8" dy="0.76" layer="1"/>
<smd name="5" x="-7.86" y="-5.08" dx="1.8" dy="0.76" layer="1"/>
<smd name="41" x="-7.86" y="5.08" dx="1.8" dy="0.76" layer="1"/>
<smd name="40" x="-7.86" y="6.35" dx="1.8" dy="0.76" layer="1"/>
<smd name="39" x="-6.35" y="7.86" dx="0.76" dy="1.8" layer="1"/>
<smd name="7" x="-6.35" y="-7.86" dx="0.76" dy="1.8" layer="1"/>
<text x="-6.604" y="9.144" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.604" y="-10.922" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.92" y1="8.2901" x2="-2.16" y2="8.76" layer="51"/>
<rectangle x1="-1.65" y1="8.2901" x2="-0.89" y2="8.76" layer="51"/>
<rectangle x1="-0.38" y1="8.2901" x2="0.38" y2="8.76" layer="51"/>
<rectangle x1="0.89" y1="8.2901" x2="1.65" y2="8.76" layer="51"/>
<rectangle x1="2.16" y1="8.2901" x2="2.92" y2="8.76" layer="51"/>
<rectangle x1="3.43" y1="8.2901" x2="4.19" y2="8.76" layer="51"/>
<rectangle x1="4.7" y1="8.2901" x2="5.46" y2="8.76" layer="51"/>
<rectangle x1="8.2901" y1="3.43" x2="8.76" y2="4.19" layer="51"/>
<rectangle x1="8.2901" y1="2.16" x2="8.76" y2="2.92" layer="51"/>
<rectangle x1="8.2901" y1="0.89" x2="8.76" y2="1.65" layer="51"/>
<rectangle x1="8.2901" y1="-0.38" x2="8.76" y2="0.38" layer="51"/>
<rectangle x1="8.2901" y1="-1.65" x2="8.76" y2="-0.89" layer="51"/>
<rectangle x1="8.2901" y1="-2.92" x2="8.76" y2="-2.16" layer="51"/>
<rectangle x1="8.2901" y1="-6.73" x2="8.76" y2="-5.97" layer="51"/>
<rectangle x1="-5.46" y1="-8.76" x2="-4.7" y2="-8.2901" layer="51"/>
<rectangle x1="-4.19" y1="-8.76" x2="-3.43" y2="-8.2901" layer="51"/>
<rectangle x1="-2.92" y1="-8.76" x2="-2.16" y2="-8.2901" layer="51"/>
<rectangle x1="-1.65" y1="-8.76" x2="-0.89" y2="-8.2901" layer="51"/>
<rectangle x1="-0.38" y1="-8.76" x2="0.38" y2="-8.2901" layer="51"/>
<rectangle x1="0.89" y1="-8.76" x2="1.65" y2="-8.2901" layer="51"/>
<rectangle x1="2.16" y1="-8.76" x2="2.92" y2="-8.2901" layer="51"/>
<rectangle x1="-8.76" y1="3.43" x2="-8.2901" y2="4.19" layer="51"/>
<rectangle x1="-8.76" y1="2.16" x2="-8.2901" y2="2.92" layer="51"/>
<rectangle x1="-8.76" y1="0.89" x2="-8.2901" y2="1.65" layer="51"/>
<rectangle x1="-8.76" y1="-0.38" x2="-8.2901" y2="0.38" layer="51"/>
<rectangle x1="-8.76" y1="-1.65" x2="-8.2901" y2="-0.89" layer="51"/>
<rectangle x1="-8.76" y1="-2.92" x2="-8.2901" y2="-2.16" layer="51"/>
<rectangle x1="-8.7599" y1="-6.73" x2="-8.29" y2="-5.97" layer="51"/>
<rectangle x1="-4.19" y1="8.2901" x2="-3.43" y2="8.76" layer="51"/>
<rectangle x1="-5.46" y1="8.2901" x2="-4.7" y2="8.76" layer="51"/>
<rectangle x1="3.43" y1="-8.76" x2="4.19" y2="-8.2901" layer="51"/>
<rectangle x1="4.7" y1="-8.76" x2="5.46" y2="-8.2901" layer="51"/>
<rectangle x1="-8.76" y1="4.7" x2="-8.2901" y2="5.46" layer="51"/>
<rectangle x1="-8.76" y1="5.97" x2="-8.2901" y2="6.73" layer="51"/>
<rectangle x1="-8.76" y1="-4.19" x2="-8.2901" y2="-3.43" layer="51"/>
<rectangle x1="-8.76" y1="-5.46" x2="-8.2901" y2="-4.7" layer="51"/>
<rectangle x1="5.97" y1="-8.76" x2="6.73" y2="-8.2901" layer="51"/>
<rectangle x1="8.2901" y1="-5.46" x2="8.76" y2="-4.7" layer="51"/>
<rectangle x1="8.2901" y1="-4.19" x2="8.76" y2="-3.43" layer="51"/>
<rectangle x1="8.2901" y1="4.7" x2="8.76" y2="5.46" layer="51"/>
<rectangle x1="8.2901" y1="5.97" x2="8.76" y2="6.73" layer="51"/>
<rectangle x1="5.97" y1="8.2901" x2="6.73" y2="8.76" layer="51"/>
<rectangle x1="-6.73" y1="8.2901" x2="-5.97" y2="8.76" layer="51"/>
<rectangle x1="-6.73" y1="-8.76" x2="-5.97" y2="-8.2901" layer="51"/>
</package>
<package name="MQFP44-2">
<description>&lt;b&gt;Plastic Metric Quad Flat Pack&lt;/b&gt;&lt;p&gt;
package type PQ</description>
<wire x1="-5" y1="-4.5" x2="-4.5" y2="-5" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="-5" x2="4.5" y2="-5" width="0.1524" layer="21"/>
<wire x1="4.5" y1="-5" x2="5" y2="-4.5" width="0.1524" layer="21"/>
<wire x1="5" y1="-4.5" x2="5" y2="4.5" width="0.1524" layer="21"/>
<wire x1="5" y1="4.5" x2="4.5" y2="5" width="0.1524" layer="21"/>
<wire x1="4.5" y1="5" x2="-4.5" y2="5" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="5" x2="-5" y2="4.5" width="0.1524" layer="21"/>
<wire x1="-5" y1="4.5" x2="-5" y2="-4.5" width="0.1524" layer="21"/>
<circle x="-3.5001" y="-3.5001" radius="0.5001" width="0.1524" layer="21"/>
<smd name="1" x="-4" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="2" x="-3.2" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="3" x="-2.4" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="4" x="-1.6" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="5" x="-0.8" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="6" x="0" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="7" x="0.8" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="8" x="1.6" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="9" x="2.4" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="10" x="3.2" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="11" x="4" y="-6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="12" x="6.1" y="-4" dx="2.2" dy="0.35" layer="1"/>
<smd name="13" x="6.1" y="-3.2" dx="2.2" dy="0.35" layer="1"/>
<smd name="14" x="6.1" y="-2.4" dx="2.2" dy="0.35" layer="1"/>
<smd name="15" x="6.1" y="-1.6" dx="2.2" dy="0.35" layer="1"/>
<smd name="16" x="6.1" y="-0.8" dx="2.2" dy="0.35" layer="1"/>
<smd name="17" x="6.1" y="0" dx="2.2" dy="0.35" layer="1"/>
<smd name="18" x="6.1" y="0.8" dx="2.2" dy="0.35" layer="1"/>
<smd name="19" x="6.1" y="1.6" dx="2.2" dy="0.35" layer="1"/>
<smd name="20" x="6.1" y="2.4" dx="2.2" dy="0.35" layer="1"/>
<smd name="21" x="6.1" y="3.2" dx="2.2" dy="0.35" layer="1"/>
<smd name="22" x="6.1" y="4" dx="2.2" dy="0.35" layer="1"/>
<smd name="23" x="4" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="24" x="3.2" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="25" x="2.4" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="26" x="1.6" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="27" x="0.8" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="28" x="0" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="29" x="-0.8" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="30" x="-1.6" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="31" x="-2.4" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="32" x="-3.2" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="33" x="-4" y="6.1" dx="0.35" dy="2.2" layer="1"/>
<smd name="34" x="-6.1" y="4" dx="2.2" dy="0.35" layer="1"/>
<smd name="35" x="-6.1" y="3.2" dx="2.2" dy="0.35" layer="1"/>
<smd name="36" x="-6.1" y="2.4" dx="2.2" dy="0.35" layer="1"/>
<smd name="37" x="-6.1" y="1.6" dx="2.2" dy="0.35" layer="1"/>
<smd name="38" x="-6.1" y="0.8" dx="2.2" dy="0.35" layer="1"/>
<smd name="39" x="-6.1" y="0" dx="2.2" dy="0.35" layer="1"/>
<smd name="40" x="-6.1" y="-0.8" dx="2.2" dy="0.35" layer="1"/>
<smd name="41" x="-6.1" y="-1.6" dx="2.2" dy="0.35" layer="1"/>
<smd name="42" x="-6.1" y="-2.4" dx="2.2" dy="0.35" layer="1"/>
<smd name="43" x="-6.1" y="-3.2" dx="2.2" dy="0.35" layer="1"/>
<smd name="44" x="-6.1" y="-4" dx="2.2" dy="0.35" layer="1"/>
<text x="-4.064" y="7.493" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-1.397" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.175" y1="5" x2="-3.825" y2="6.5999" layer="51"/>
<rectangle x1="-3.3749" y1="5" x2="-3.0249" y2="6.5999" layer="51"/>
<rectangle x1="-2.5751" y1="5" x2="-2.225" y2="6.5999" layer="51"/>
<rectangle x1="-1.775" y1="5" x2="-1.4249" y2="6.5999" layer="51"/>
<rectangle x1="-0.9751" y1="5" x2="-0.6251" y2="6.5999" layer="51"/>
<rectangle x1="-0.175" y1="5" x2="0.175" y2="6.5999" layer="51"/>
<rectangle x1="0.6251" y1="5" x2="0.9751" y2="6.5999" layer="51"/>
<rectangle x1="1.4249" y1="5" x2="1.775" y2="6.5999" layer="51"/>
<rectangle x1="2.225" y1="5" x2="2.5751" y2="6.5999" layer="51"/>
<rectangle x1="3.0249" y1="5" x2="3.3749" y2="6.5999" layer="51"/>
<rectangle x1="3.825" y1="5" x2="4.175" y2="6.5999" layer="51"/>
<rectangle x1="5" y1="3.0249" x2="6.5999" y2="3.3749" layer="51"/>
<rectangle x1="5" y1="3.825" x2="6.5999" y2="4.175" layer="51"/>
<rectangle x1="5" y1="2.225" x2="6.5999" y2="2.5751" layer="51"/>
<rectangle x1="5" y1="1.4249" x2="6.5999" y2="1.775" layer="51"/>
<rectangle x1="5" y1="0.6251" x2="6.5999" y2="0.9751" layer="51"/>
<rectangle x1="5" y1="-0.175" x2="6.5999" y2="0.175" layer="51"/>
<rectangle x1="5" y1="-0.9751" x2="6.5999" y2="-0.6251" layer="51"/>
<rectangle x1="5" y1="-1.775" x2="6.5999" y2="-1.4249" layer="51"/>
<rectangle x1="5" y1="-2.5751" x2="6.5999" y2="-2.225" layer="51"/>
<rectangle x1="5" y1="-3.3749" x2="6.5999" y2="-3.0249" layer="51"/>
<rectangle x1="5" y1="-4.175" x2="6.5999" y2="-3.825" layer="51"/>
<rectangle x1="3.825" y1="-6.5999" x2="4.175" y2="-5" layer="51"/>
<rectangle x1="3.0249" y1="-6.5999" x2="3.3749" y2="-5" layer="51"/>
<rectangle x1="2.225" y1="-6.5999" x2="2.5751" y2="-5" layer="51"/>
<rectangle x1="1.4249" y1="-6.5999" x2="1.775" y2="-5" layer="51"/>
<rectangle x1="0.6251" y1="-6.5999" x2="0.9751" y2="-5" layer="51"/>
<rectangle x1="-0.175" y1="-6.5999" x2="0.175" y2="-5" layer="51"/>
<rectangle x1="-0.9751" y1="-6.5999" x2="-0.6251" y2="-5" layer="51"/>
<rectangle x1="-1.775" y1="-6.5999" x2="-1.4249" y2="-4.9751" layer="51"/>
<rectangle x1="-2.5751" y1="-6.5999" x2="-2.225" y2="-5" layer="51"/>
<rectangle x1="-3.3749" y1="-6.5999" x2="-3.0249" y2="-5" layer="51"/>
<rectangle x1="-4.175" y1="-6.5999" x2="-3.825" y2="-5" layer="51"/>
<rectangle x1="-6.5999" y1="-4.175" x2="-5" y2="-3.825" layer="51"/>
<rectangle x1="-6.5999" y1="-3.3749" x2="-5" y2="-3.0249" layer="51"/>
<rectangle x1="-6.5999" y1="-2.5751" x2="-5" y2="-2.225" layer="51"/>
<rectangle x1="-6.5999" y1="-0.9751" x2="-5" y2="-0.6251" layer="51"/>
<rectangle x1="-6.5999" y1="-1.775" x2="-5" y2="-1.4249" layer="51"/>
<rectangle x1="-6.5999" y1="0.6251" x2="-5" y2="0.9751" layer="51"/>
<rectangle x1="-6.5999" y1="-0.175" x2="-5" y2="0.175" layer="51"/>
<rectangle x1="-6.5999" y1="2.225" x2="-5" y2="2.5751" layer="51"/>
<rectangle x1="-6.5999" y1="1.4249" x2="-5" y2="1.775" layer="51"/>
<rectangle x1="-6.5999" y1="3.825" x2="-5" y2="4.175" layer="51"/>
<rectangle x1="-6.5999" y1="3.0249" x2="-5" y2="3.3749" layer="51"/>
</package>
<package name="TQFP44">
<description>&lt;b&gt;Thin Quad Flat Pack&lt;/b&gt;&lt;p&gt;
package type TQ</description>
<wire x1="-4.8" y1="4.4" x2="-4.4" y2="4.8" width="0.2032" layer="21"/>
<wire x1="-4.4" y1="4.8" x2="4.4" y2="4.8" width="0.2032" layer="21"/>
<wire x1="4.4" y1="4.8" x2="4.8" y2="4.4" width="0.2032" layer="21"/>
<wire x1="4.8" y1="4.4" x2="4.8" y2="-4.4" width="0.2032" layer="21"/>
<wire x1="4.8" y1="-4.4" x2="4.4" y2="-4.8" width="0.2032" layer="21"/>
<wire x1="4.4" y1="-4.8" x2="-4.4" y2="-4.8" width="0.2032" layer="21"/>
<wire x1="-4.4" y1="-4.8" x2="-4.8" y2="-4.4" width="0.2032" layer="21"/>
<wire x1="-4.8" y1="-4.4" x2="-4.8" y2="4.4" width="0.2032" layer="21"/>
<circle x="-4" y="4" radius="0.2827" width="0.254" layer="21"/>
<smd name="1" x="-5.8" y="4" dx="1.5" dy="0.5" layer="1"/>
<smd name="2" x="-5.8" y="3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="3" x="-5.8" y="2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="4" x="-5.8" y="1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="5" x="-5.8" y="0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="6" x="-5.8" y="0" dx="1.5" dy="0.5" layer="1"/>
<smd name="7" x="-5.8" y="-0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="8" x="-5.8" y="-1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="9" x="-5.8" y="-2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="10" x="-5.8" y="-3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="11" x="-5.8" y="-4" dx="1.5" dy="0.5" layer="1"/>
<smd name="12" x="-4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="13" x="-3.2" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="14" x="-2.4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="15" x="-1.6" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="16" x="-0.8" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="17" x="0" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="18" x="0.8" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="19" x="1.6" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="20" x="2.4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="21" x="3.2" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="22" x="4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="23" x="5.8" y="-4" dx="1.5" dy="0.5" layer="1"/>
<smd name="24" x="5.8" y="-3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="25" x="5.8" y="-2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="26" x="5.8" y="-1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="27" x="5.8" y="-0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="28" x="5.8" y="0" dx="1.5" dy="0.5" layer="1"/>
<smd name="29" x="5.8" y="0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="30" x="5.8" y="1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="31" x="5.8" y="2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="32" x="5.8" y="3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="33" x="5.8" y="4" dx="1.5" dy="0.5" layer="1"/>
<smd name="34" x="4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="35" x="3.2" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="36" x="2.4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="37" x="1.6" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="38" x="0.8" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="39" x="0" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="40" x="-0.8" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="41" x="-1.6" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="42" x="-2.4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="43" x="-3.2" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="44" x="-4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<text x="-4.064" y="6.858" size="1.778" layer="25">&gt;NAME</text>
<text x="-4.064" y="-1.7701" size="1.778" layer="27">&gt;VALUE</text>
<rectangle x1="-6.1001" y1="3.8001" x2="-4.95" y2="4.1999" layer="51"/>
<rectangle x1="-6.1001" y1="3" x2="-4.95" y2="3.4" layer="51"/>
<rectangle x1="-6.1001" y1="2.1999" x2="-4.95" y2="2.5999" layer="51"/>
<rectangle x1="-6.1001" y1="1.4" x2="-4.95" y2="1.8001" layer="51"/>
<rectangle x1="-6.1001" y1="0.5999" x2="-4.95" y2="1" layer="51"/>
<rectangle x1="-6.1001" y1="-0.1999" x2="-4.95" y2="0.1999" layer="51"/>
<rectangle x1="-6.1001" y1="-1" x2="-4.95" y2="-0.5999" layer="51"/>
<rectangle x1="-6.1001" y1="-1.8001" x2="-4.95" y2="-1.4" layer="51"/>
<rectangle x1="-6.1001" y1="-2.5999" x2="-4.95" y2="-2.1999" layer="51"/>
<rectangle x1="-6.1001" y1="-3.4" x2="-4.95" y2="-3" layer="51"/>
<rectangle x1="-6.1001" y1="-4.1999" x2="-4.95" y2="-3.8001" layer="51"/>
<rectangle x1="-4.1999" y1="-6.1001" x2="-3.8001" y2="-4.95" layer="51"/>
<rectangle x1="-3.4" y1="-6.1001" x2="-3" y2="-4.95" layer="51"/>
<rectangle x1="-2.5999" y1="-6.1001" x2="-2.1999" y2="-4.95" layer="51"/>
<rectangle x1="-1.8001" y1="-6.1001" x2="-1.4" y2="-4.95" layer="51"/>
<rectangle x1="-1" y1="-6.1001" x2="-0.5999" y2="-4.95" layer="51"/>
<rectangle x1="-0.1999" y1="-6.1001" x2="0.1999" y2="-4.95" layer="51"/>
<rectangle x1="0.5999" y1="-6.1001" x2="1" y2="-4.95" layer="51"/>
<rectangle x1="1.4" y1="-6.1001" x2="1.8001" y2="-4.95" layer="51"/>
<rectangle x1="2.1999" y1="-6.1001" x2="2.5999" y2="-4.95" layer="51"/>
<rectangle x1="3" y1="-6.1001" x2="3.4" y2="-4.95" layer="51"/>
<rectangle x1="3.8001" y1="-6.1001" x2="4.1999" y2="-4.95" layer="51"/>
<rectangle x1="4.95" y1="-4.1999" x2="6.1001" y2="-3.8001" layer="51"/>
<rectangle x1="4.95" y1="-3.4" x2="6.1001" y2="-3" layer="51"/>
<rectangle x1="4.95" y1="-2.5999" x2="6.1001" y2="-2.1999" layer="51"/>
<rectangle x1="4.95" y1="-1.8001" x2="6.1001" y2="-1.4" layer="51"/>
<rectangle x1="4.95" y1="-1" x2="6.1001" y2="-0.5999" layer="51"/>
<rectangle x1="4.95" y1="-0.1999" x2="6.1001" y2="0.1999" layer="51"/>
<rectangle x1="4.95" y1="0.5999" x2="6.1001" y2="1" layer="51"/>
<rectangle x1="4.95" y1="1.4" x2="6.1001" y2="1.8001" layer="51"/>
<rectangle x1="4.95" y1="2.1999" x2="6.1001" y2="2.5999" layer="51"/>
<rectangle x1="4.95" y1="3" x2="6.1001" y2="3.4" layer="51"/>
<rectangle x1="4.95" y1="3.8001" x2="6.1001" y2="4.1999" layer="51"/>
<rectangle x1="3.8001" y1="4.95" x2="4.1999" y2="6.1001" layer="51"/>
<rectangle x1="3" y1="4.95" x2="3.4" y2="6.1001" layer="51"/>
<rectangle x1="2.1999" y1="4.95" x2="2.5999" y2="6.1001" layer="51"/>
<rectangle x1="1.4" y1="4.95" x2="1.8001" y2="6.1001" layer="51"/>
<rectangle x1="0.5999" y1="4.95" x2="1" y2="6.1001" layer="51"/>
<rectangle x1="-0.1999" y1="4.95" x2="0.1999" y2="6.1001" layer="51"/>
<rectangle x1="-1" y1="4.95" x2="-0.5999" y2="6.1001" layer="51"/>
<rectangle x1="-1.8001" y1="4.95" x2="-1.4" y2="6.1001" layer="51"/>
<rectangle x1="-2.5999" y1="4.95" x2="-2.1999" y2="6.1001" layer="51"/>
<rectangle x1="-3.4" y1="4.95" x2="-3" y2="6.1001" layer="51"/>
<rectangle x1="-4.1999" y1="4.95" x2="-3.8001" y2="6.1001" layer="51"/>
</package>
<package name="DIL40">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type P</description>
<wire x1="-25.4" y1="-1.27" x2="-25.4" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="1.27" x2="-25.4" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="25.4" y1="-6.223" x2="25.4" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.223" x2="-25.4" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.223" x2="25.4" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.223" x2="25.4" y2="-6.223" width="0.1524" layer="21"/>
<pad name="1" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-25.781" y="-6.096" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-21.59" y="-2.2352" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="S44">
<description>&lt;b&gt;PLCC SOCKET&lt;/b&gt;</description>
<wire x1="-10.16" y1="11.684" x2="-11.684" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="10.16" x2="-11.684" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="6.985" x2="-6.985" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-10.414" x2="-7.239" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-10.414" x2="-10.414" y2="-9.398" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-9.398" x2="-8.255" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-7.239" x2="-8.255" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-8.255" x2="-6.985" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-9.398" x2="-5.461" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-9.398" x2="-5.461" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-10.414" x2="-4.699" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-10.414" x2="-4.699" y2="-9.398" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-8.255" x2="-4.699" y2="-9.398" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="-8.255" x2="-4.191" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-8.255" x2="-2.921" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-9.525" x2="-2.921" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-9.525" x2="-2.921" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-10.414" x2="-2.159" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-10.414" x2="-2.159" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-8.255" x2="-2.159" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-8.255" x2="-1.651" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-8.255" x2="-0.381" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-9.525" x2="-0.381" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-9.525" x2="-0.381" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-10.414" x2="0.381" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-10.414" x2="0.381" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-8.255" x2="0.381" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-8.255" x2="0.889" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="10.414" y1="9.398" x2="8.255" y2="7.239" width="0.1524" layer="21"/>
<wire x1="10.414" y1="9.398" x2="9.398" y2="10.414" width="0.1524" layer="21"/>
<wire x1="9.398" y1="10.414" x2="7.239" y2="8.255" width="0.1524" layer="21"/>
<wire x1="8.255" y1="7.239" x2="8.255" y2="6.985" width="0.1524" layer="21"/>
<wire x1="8.255" y1="5.969" x2="8.255" y2="5.461" width="0.1524" layer="51"/>
<wire x1="8.255" y1="5.461" x2="9.398" y2="5.461" width="0.1524" layer="51"/>
<wire x1="10.414" y1="5.461" x2="9.398" y2="5.461" width="0.1524" layer="21"/>
<wire x1="10.414" y1="5.461" x2="10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="9.398" y1="4.699" x2="10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="9.398" y1="4.699" x2="8.255" y2="4.699" width="0.1524" layer="51"/>
<wire x1="8.255" y1="4.699" x2="8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="8.255" y1="3.429" x2="8.255" y2="2.921" width="0.1524" layer="51"/>
<wire x1="8.255" y1="2.921" x2="9.398" y2="2.921" width="0.1524" layer="51"/>
<wire x1="10.414" y1="2.921" x2="9.398" y2="2.921" width="0.1524" layer="21"/>
<wire x1="10.414" y1="2.921" x2="10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="9.398" y1="2.159" x2="10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="9.398" y1="2.159" x2="8.255" y2="1.651" width="0.1524" layer="51"/>
<wire x1="8.255" y1="0.889" x2="8.255" y2="0.381" width="0.1524" layer="51"/>
<wire x1="8.255" y1="0.381" x2="9.398" y2="0.381" width="0.1524" layer="51"/>
<wire x1="10.414" y1="0.381" x2="9.398" y2="0.381" width="0.1524" layer="21"/>
<wire x1="10.414" y1="0.381" x2="10.414" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-0.381" x2="10.414" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-0.381" x2="8.255" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-0.381" x2="8.255" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-6.985" x2="-8.255" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-5.969" x2="-8.255" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-5.461" x2="-9.398" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.461" x2="-9.398" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-5.461" x2="-10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-4.699" x2="-10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-4.699" x2="-8.255" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-4.699" x2="-8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-3.429" x2="-8.255" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-2.921" x2="-9.398" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-2.921" x2="-9.398" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-2.921" x2="-10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-2.159" x2="-10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-2.159" x2="-8.255" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-2.159" x2="-8.255" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-0.889" x2="-8.255" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-0.381" x2="-9.398" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-0.381" x2="-9.398" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-0.381" x2="-10.414" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="0.381" x2="-10.414" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="0.381" x2="-8.255" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="0.381" x2="-8.255" y2="0.889" width="0.1524" layer="51"/>
<wire x1="7.239" y1="8.255" x2="6.985" y2="8.255" width="0.1524" layer="21"/>
<wire x1="5.969" y1="8.255" x2="5.461" y2="8.255" width="0.1524" layer="51"/>
<wire x1="5.461" y1="8.255" x2="5.461" y2="9.398" width="0.1524" layer="51"/>
<wire x1="5.461" y1="10.414" x2="5.461" y2="9.398" width="0.1524" layer="21"/>
<wire x1="5.461" y1="10.414" x2="4.699" y2="10.414" width="0.1524" layer="21"/>
<wire x1="4.699" y1="9.398" x2="4.699" y2="10.414" width="0.1524" layer="21"/>
<wire x1="4.699" y1="9.398" x2="4.699" y2="8.255" width="0.1524" layer="51"/>
<wire x1="4.699" y1="8.255" x2="4.191" y2="8.255" width="0.1524" layer="51"/>
<wire x1="3.429" y1="8.255" x2="2.921" y2="8.255" width="0.1524" layer="51"/>
<wire x1="2.921" y1="8.255" x2="2.921" y2="9.398" width="0.1524" layer="51"/>
<wire x1="2.921" y1="10.414" x2="2.921" y2="9.398" width="0.1524" layer="21"/>
<wire x1="2.921" y1="10.414" x2="2.159" y2="10.414" width="0.1524" layer="21"/>
<wire x1="2.159" y1="9.398" x2="2.159" y2="10.414" width="0.1524" layer="21"/>
<wire x1="2.159" y1="9.398" x2="2.159" y2="8.255" width="0.1524" layer="51"/>
<wire x1="2.159" y1="8.255" x2="1.651" y2="8.255" width="0.1524" layer="51"/>
<wire x1="0.889" y1="8.255" x2="0.381" y2="8.255" width="0.1524" layer="51"/>
<wire x1="0.381" y1="8.255" x2="0.381" y2="9.398" width="0.1524" layer="51"/>
<wire x1="0.381" y1="10.414" x2="0.381" y2="9.398" width="0.1524" layer="21"/>
<wire x1="0.381" y1="10.414" x2="-0.381" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="9.398" x2="-0.381" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="9.398" x2="-0.381" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="8.255" x2="-0.889" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="8.255" x2="-2.159" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="8.255" x2="-2.159" y2="9.398" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="10.414" x2="-2.159" y2="9.398" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="10.414" x2="-2.921" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="9.398" x2="-2.921" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="9.398" x2="-2.921" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="8.255" x2="-3.429" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="8.255" x2="-4.699" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="8.255" x2="-4.699" y2="9.398" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="10.414" x2="-4.699" y2="9.398" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="10.414" x2="-5.461" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="9.398" x2="-5.461" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="9.398" x2="-5.461" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="8.255" x2="-5.969" y2="8.255" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-8.255" x2="2.159" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-9.525" x2="2.159" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-9.525" x2="2.159" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-10.414" x2="2.921" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-10.414" x2="2.921" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-8.255" x2="2.921" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-8.255" x2="3.429" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-8.255" x2="4.699" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-9.525" x2="4.699" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-9.525" x2="4.699" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-10.414" x2="5.461" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-10.414" x2="5.461" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-8.255" x2="5.461" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-8.255" x2="5.969" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="5.969" x2="-8.255" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="5.461" x2="-9.398" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="5.461" x2="-9.398" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="5.461" x2="-10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="4.699" x2="-10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="4.699" x2="-8.255" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="4.699" x2="-8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="3.429" x2="-8.255" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="2.921" x2="-9.398" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="2.921" x2="-9.398" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.921" x2="-10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="2.159" x2="-10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-10.414" x2="-6.731" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="-8.255" x2="-6.985" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="-10.414" x2="-5.969" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-8.255" x2="-5.969" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="-8.255" x2="-5.969" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-10.414" x2="-4.191" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-10.414" x2="-3.429" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-8.255" x2="-3.429" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-10.414" x2="-1.651" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-10.414" x2="-0.889" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-8.255" x2="-0.889" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-10.414" x2="0.889" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-10.414" x2="1.651" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-8.255" x2="1.651" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="10.414" y1="6.731" x2="8.255" y2="6.731" width="0.1524" layer="51"/>
<wire x1="8.255" y1="6.731" x2="8.255" y2="6.985" width="0.1524" layer="51"/>
<wire x1="10.414" y1="6.731" x2="10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="5.969" x2="10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="10.414" y1="4.191" x2="8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="10.414" y1="4.191" x2="10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="8.255" y1="3.429" x2="10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="10.414" y1="1.651" x2="8.255" y2="1.651" width="0.1524" layer="51"/>
<wire x1="10.414" y1="1.651" x2="10.414" y2="0.889" width="0.1524" layer="51"/>
<wire x1="8.255" y1="0.889" x2="10.414" y2="0.889" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-0.889" x2="8.255" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-0.889" x2="10.414" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-1.651" x2="10.414" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-6.731" x2="-8.255" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-6.731" x2="-10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-5.969" x2="-10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-4.191" x2="-8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-4.191" x2="-10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-3.429" x2="-10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-1.651" x2="-8.255" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-1.651" x2="-10.414" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-0.889" x2="-10.414" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0.889" x2="-8.255" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0.889" x2="-10.414" y2="1.651" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.651" x2="-10.414" y2="1.651" width="0.1524" layer="51"/>
<wire x1="6.731" y1="10.414" x2="6.731" y2="8.255" width="0.1524" layer="51"/>
<wire x1="6.731" y1="8.255" x2="6.985" y2="8.255" width="0.1524" layer="51"/>
<wire x1="6.731" y1="10.414" x2="5.969" y2="10.414" width="0.1524" layer="51"/>
<wire x1="5.969" y1="8.255" x2="5.969" y2="10.414" width="0.1524" layer="51"/>
<wire x1="4.191" y1="10.414" x2="4.191" y2="8.255" width="0.1524" layer="51"/>
<wire x1="4.191" y1="10.414" x2="3.429" y2="10.414" width="0.1524" layer="51"/>
<wire x1="3.429" y1="8.255" x2="3.429" y2="10.414" width="0.1524" layer="51"/>
<wire x1="1.651" y1="10.414" x2="1.651" y2="8.255" width="0.1524" layer="51"/>
<wire x1="1.651" y1="10.414" x2="0.889" y2="10.414" width="0.1524" layer="51"/>
<wire x1="0.889" y1="8.255" x2="0.889" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="10.414" x2="-0.889" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="10.414" x2="-1.651" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="8.255" x2="-1.651" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="10.414" x2="-3.429" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="10.414" x2="-4.191" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="8.255" x2="-4.191" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="10.414" x2="-5.969" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="10.414" x2="-6.731" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="8.255" x2="-6.731" y2="10.414" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-10.414" x2="3.429" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-10.414" x2="4.191" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-8.255" x2="4.191" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-10.414" x2="5.969" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-10.414" x2="6.731" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="7.112" y1="-8.255" x2="6.731" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="6.731" y1="-8.255" x2="6.731" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="6.731" x2="-8.255" y2="6.731" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="6.731" x2="-10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="5.969" x2="-10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="4.191" x2="-8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="4.191" x2="-10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="3.429" x2="-10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-6.731" x2="8.255" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-6.731" x2="8.255" y2="-7.112" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-6.731" x2="10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-5.969" x2="10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-5.969" x2="8.255" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-5.461" x2="9.398" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-5.461" x2="9.398" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-5.461" x2="10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-4.699" x2="10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-4.699" x2="8.255" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-4.699" x2="8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-3.429" x2="8.255" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-2.921" x2="9.398" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-2.921" x2="9.398" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.921" x2="10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-2.159" x2="10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.112" y1="-8.255" x2="8.255" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-8.255" x2="8.255" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.651" x2="8.255" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-2.159" x2="9.398" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="8.255" x2="-6.731" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="6.731" x2="-8.255" y2="6.985" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="2.159" x2="-8.255" y2="2.159" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="2.159" x2="-8.255" y2="1.651" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-4.191" x2="8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-4.191" x2="10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-3.429" x2="10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-11.049" x2="-11.049" y2="-11.684" width="0.1524" layer="21" curve="90"/>
<wire x1="11.049" y1="-11.684" x2="-11.049" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-11.684" x2="11.684" y2="-11.049" width="0.1524" layer="21" curve="90"/>
<wire x1="11.049" y1="11.684" x2="-10.16" y2="11.684" width="0.1524" layer="21"/>
<wire x1="11.684" y1="11.049" x2="11.684" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="11.049" y1="11.684" x2="11.684" y2="11.049" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="3.81" x2="1.27" y2="3.81" width="0.1524" layer="21"/>
<wire x1="1.27" y1="3.81" x2="0" y2="5.08" width="0.1524" layer="21"/>
<wire x1="0" y1="5.08" x2="-1.27" y2="3.81" width="0.1524" layer="21"/>
<circle x="-2.54" y="2.54" radius="1.27" width="0.1524" layer="21"/>
<circle x="2.54" y="2.54" radius="1.27" width="0.1524" layer="21"/>
<circle x="-2.54" y="-2.54" radius="1.27" width="0.1524" layer="21"/>
<circle x="2.54" y="-2.54" radius="1.27" width="0.1524" layer="21"/>
<pad name="1" x="1.27" y="6.35" drill="0.8128"/>
<pad name="2" x="-1.27" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="4" x="-3.81" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="5" x="-3.81" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="6" x="-6.35" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="7" x="-8.89" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="8" x="-6.35" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="9" x="-8.89" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="10" x="-6.35" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="11" x="-8.89" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="12" x="-6.35" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="13" x="-8.89" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="14" x="-6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="15" x="-8.89" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="16" x="-6.35" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="17" x="-8.89" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="18" x="-6.35" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="19" x="-6.35" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="20" x="-3.81" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="21" x="-3.81" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="22" x="-1.27" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="23" x="-1.27" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="24" x="1.27" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="25" x="1.27" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="26" x="3.81" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="27" x="3.81" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="28" x="6.35" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="29" x="8.89" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="30" x="6.35" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="31" x="8.89" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="32" x="6.35" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="33" x="8.89" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="34" x="6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="35" x="8.89" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="36" x="6.35" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="37" x="8.89" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="38" x="6.35" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="39" x="8.89" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="40" x="6.35" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="41" x="6.35" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="42" x="3.81" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="43" x="3.81" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="44" x="1.27" y="8.89" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="11.938" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-10.16" y="11.938" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="8.255" y="-10.795" size="1.27" layer="21" ratio="10">44</text>
<rectangle x1="-0.508" y1="2.159" x2="0.508" y2="4.064" layer="21"/>
<rectangle x1="-0.889" y1="3.81" x2="0.889" y2="4.191" layer="21"/>
<rectangle x1="-0.635" y1="4.191" x2="0.635" y2="4.445" layer="21"/>
<rectangle x1="-0.381" y1="4.445" x2="0.381" y2="4.699" layer="21"/>
<rectangle x1="-0.127" y1="4.699" x2="0.127" y2="4.953" layer="21"/>
<rectangle x1="-1.143" y1="3.81" x2="-0.889" y2="3.937" layer="21"/>
<rectangle x1="-1.016" y1="3.937" x2="-0.889" y2="4.064" layer="21"/>
<rectangle x1="-0.762" y1="4.191" x2="-0.635" y2="4.318" layer="21"/>
<rectangle x1="-0.508" y1="4.445" x2="-0.381" y2="4.572" layer="21"/>
<rectangle x1="-0.254" y1="4.699" x2="-0.127" y2="4.826" layer="21"/>
<rectangle x1="0.127" y1="4.699" x2="0.254" y2="4.826" layer="21"/>
<rectangle x1="0.381" y1="4.445" x2="0.508" y2="4.572" layer="21"/>
<rectangle x1="0.635" y1="4.191" x2="0.762" y2="4.318" layer="21"/>
<rectangle x1="0.889" y1="3.81" x2="1.143" y2="3.937" layer="21"/>
<rectangle x1="0.889" y1="3.937" x2="1.016" y2="4.064" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="PIC17F874">
<wire x1="-20.32" y1="27.94" x2="17.78" y2="27.94" width="0.254" layer="94"/>
<wire x1="17.78" y1="27.94" x2="17.78" y2="-30.48" width="0.254" layer="94"/>
<wire x1="17.78" y1="-30.48" x2="-20.32" y2="-30.48" width="0.254" layer="94"/>
<wire x1="-20.32" y1="-30.48" x2="-20.32" y2="27.94" width="0.254" layer="94"/>
<text x="-20.32" y="29.21" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-33.02" size="1.778" layer="96">&gt;VALUE</text>
<text x="-3.81" y="25.4" size="1.524" layer="95">VDD</text>
<text x="-3.81" y="-29.21" size="1.524" layer="95">VSS</text>
<pin name="!MCLR/THV" x="-22.86" y="22.86" length="short" direction="in"/>
<pin name="RA0/AN0" x="-22.86" y="17.78" length="short"/>
<pin name="RA1/AN1" x="-22.86" y="15.24" length="short"/>
<pin name="RA2/AN2" x="-22.86" y="12.7" length="short"/>
<pin name="RA3/AN3" x="-22.86" y="10.16" length="short"/>
<pin name="RA4/T0CKI" x="-22.86" y="7.62" length="short"/>
<pin name="RA5/AN4" x="-22.86" y="5.08" length="short"/>
<pin name="RE0/!RD/AN5" x="-22.86" y="2.54" length="short"/>
<pin name="RE1/!WR/AN6" x="-22.86" y="0" length="short"/>
<pin name="RE2/!CS/AN7" x="-22.86" y="-2.54" length="short"/>
<pin name="OSC1/CLKIN" x="-22.86" y="-7.62" length="short" direction="in"/>
<pin name="OSC2/CLKOUT" x="-22.86" y="-10.16" length="short" direction="out"/>
<pin name="RC0/T1OSO" x="-22.86" y="-12.7" length="short"/>
<pin name="RC1/T1OSI" x="-22.86" y="-15.24" length="short"/>
<pin name="RC2/CCP1" x="-22.86" y="-17.78" length="short"/>
<pin name="RC3/SCK" x="-22.86" y="-20.32" length="short"/>
<pin name="RD0/PSP0" x="-22.86" y="-22.86" length="short"/>
<pin name="RD1/PSP1" x="-22.86" y="-25.4" length="short"/>
<pin name="RD2/PSP2" x="20.32" y="-25.4" length="short" rot="R180"/>
<pin name="RD3/PSP3" x="20.32" y="-22.86" length="short" rot="R180"/>
<pin name="SDI/RC4" x="20.32" y="-20.32" length="short" rot="R180"/>
<pin name="SDO/RC5" x="20.32" y="-17.78" length="short" rot="R180"/>
<pin name="TX/RC6" x="20.32" y="-15.24" length="short" rot="R180"/>
<pin name="RX/RC7" x="20.32" y="-12.7" length="short" rot="R180"/>
<pin name="PSP4/RD4" x="20.32" y="-10.16" length="short" rot="R180"/>
<pin name="PSP5/RD5" x="20.32" y="-7.62" length="short" rot="R180"/>
<pin name="PSP6/RD6" x="20.32" y="-5.08" length="short" rot="R180"/>
<pin name="PSP7/RD7" x="20.32" y="-2.54" length="short" rot="R180"/>
<pin name="VSS" x="0" y="-33.02" visible="pad" length="short" direction="pwr" rot="R90"/>
<pin name="VDD" x="0" y="30.48" visible="pad" length="short" direction="pwr" rot="R270"/>
<pin name="INT/RB0" x="20.32" y="2.54" length="short" rot="R180"/>
<pin name="RB1" x="20.32" y="5.08" length="short" rot="R180"/>
<pin name="RB2" x="20.32" y="7.62" length="short" rot="R180"/>
<pin name="PGM/RB3" x="20.32" y="10.16" length="short" rot="R180"/>
<pin name="RB4" x="20.32" y="12.7" length="short" rot="R180"/>
<pin name="RB5" x="20.32" y="15.24" length="short" rot="R180"/>
<pin name="PGC/RB6" x="20.32" y="17.78" length="short" rot="R180"/>
<pin name="PGD/RB7" x="20.32" y="20.32" length="short" rot="R180"/>
<pin name="VDD@1" x="-2.54" y="30.48" visible="pad" length="short" direction="pwr" rot="R270"/>
<pin name="VSS@1" x="-2.54" y="-33.02" visible="pad" length="short" direction="pwr" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="PIC16F87*" prefix="IC">
<description>&lt;B&gt;MICROCONTROLLER&lt;/B&gt;</description>
<gates>
<gate name="G$1" symbol="PIC17F874" x="0" y="0"/>
</gates>
<devices>
<device name="L" package="PLCC-44">
<connects>
<connect gate="G$1" pin="!MCLR/THV" pad="2"/>
<connect gate="G$1" pin="INT/RB0" pad="36"/>
<connect gate="G$1" pin="OSC1/CLKIN" pad="14"/>
<connect gate="G$1" pin="OSC2/CLKOUT" pad="15"/>
<connect gate="G$1" pin="PGC/RB6" pad="43"/>
<connect gate="G$1" pin="PGD/RB7" pad="44"/>
<connect gate="G$1" pin="PGM/RB3" pad="39"/>
<connect gate="G$1" pin="PSP4/RD4" pad="30"/>
<connect gate="G$1" pin="PSP5/RD5" pad="31"/>
<connect gate="G$1" pin="PSP6/RD6" pad="32"/>
<connect gate="G$1" pin="PSP7/RD7" pad="33"/>
<connect gate="G$1" pin="RA0/AN0" pad="3"/>
<connect gate="G$1" pin="RA1/AN1" pad="4"/>
<connect gate="G$1" pin="RA2/AN2" pad="5"/>
<connect gate="G$1" pin="RA3/AN3" pad="6"/>
<connect gate="G$1" pin="RA4/T0CKI" pad="7"/>
<connect gate="G$1" pin="RA5/AN4" pad="8"/>
<connect gate="G$1" pin="RB1" pad="37"/>
<connect gate="G$1" pin="RB2" pad="38"/>
<connect gate="G$1" pin="RB4" pad="41"/>
<connect gate="G$1" pin="RB5" pad="42"/>
<connect gate="G$1" pin="RC0/T1OSO" pad="16"/>
<connect gate="G$1" pin="RC1/T1OSI" pad="18"/>
<connect gate="G$1" pin="RC2/CCP1" pad="19"/>
<connect gate="G$1" pin="RC3/SCK" pad="20"/>
<connect gate="G$1" pin="RD0/PSP0" pad="21"/>
<connect gate="G$1" pin="RD1/PSP1" pad="22"/>
<connect gate="G$1" pin="RD2/PSP2" pad="23"/>
<connect gate="G$1" pin="RD3/PSP3" pad="24"/>
<connect gate="G$1" pin="RE0/!RD/AN5" pad="9"/>
<connect gate="G$1" pin="RE1/!WR/AN6" pad="10"/>
<connect gate="G$1" pin="RE2/!CS/AN7" pad="11"/>
<connect gate="G$1" pin="RX/RC7" pad="29"/>
<connect gate="G$1" pin="SDI/RC4" pad="25"/>
<connect gate="G$1" pin="SDO/RC5" pad="26"/>
<connect gate="G$1" pin="TX/RC6" pad="27"/>
<connect gate="G$1" pin="VDD" pad="12"/>
<connect gate="G$1" pin="VDD@1" pad="35"/>
<connect gate="G$1" pin="VSS" pad="13"/>
<connect gate="G$1" pin="VSS@1" pad="34"/>
</connects>
<technologies>
<technology name="4">
<attribute name="MF" value="MICROCHIP" constant="no"/>
<attribute name="MPN" value="PIC16F874-04/L" constant="no"/>
<attribute name="OC_FARNELL" value="9761160" constant="no"/>
<attribute name="OC_NEWARK" value="23C5056" constant="no"/>
</technology>
<technology name="7">
<attribute name="MPN" value="PIC16F877-20/L" constant="no"/>
<attribute name="OC_FARNELL" value="1660042" constant="no"/>
<attribute name="OC_NEWARK" value="12C1952" constant="no"/>
</technology>
</technologies>
</device>
<device name="PQ" package="MQFP44-2">
<connects>
<connect gate="G$1" pin="!MCLR/THV" pad="18"/>
<connect gate="G$1" pin="INT/RB0" pad="8"/>
<connect gate="G$1" pin="OSC1/CLKIN" pad="30"/>
<connect gate="G$1" pin="OSC2/CLKOUT" pad="31"/>
<connect gate="G$1" pin="PGC/RB6" pad="16"/>
<connect gate="G$1" pin="PGD/RB7" pad="17"/>
<connect gate="G$1" pin="PGM/RB3" pad="11"/>
<connect gate="G$1" pin="PSP4/RD4" pad="2"/>
<connect gate="G$1" pin="PSP5/RD5" pad="3"/>
<connect gate="G$1" pin="PSP6/RD6" pad="4"/>
<connect gate="G$1" pin="PSP7/RD7" pad="5"/>
<connect gate="G$1" pin="RA0/AN0" pad="19"/>
<connect gate="G$1" pin="RA1/AN1" pad="20"/>
<connect gate="G$1" pin="RA2/AN2" pad="21"/>
<connect gate="G$1" pin="RA3/AN3" pad="22"/>
<connect gate="G$1" pin="RA4/T0CKI" pad="23"/>
<connect gate="G$1" pin="RA5/AN4" pad="24"/>
<connect gate="G$1" pin="RB1" pad="9"/>
<connect gate="G$1" pin="RB2" pad="10"/>
<connect gate="G$1" pin="RB4" pad="14"/>
<connect gate="G$1" pin="RB5" pad="15"/>
<connect gate="G$1" pin="RC0/T1OSO" pad="32"/>
<connect gate="G$1" pin="RC1/T1OSI" pad="35"/>
<connect gate="G$1" pin="RC2/CCP1" pad="36"/>
<connect gate="G$1" pin="RC3/SCK" pad="37"/>
<connect gate="G$1" pin="RD0/PSP0" pad="38"/>
<connect gate="G$1" pin="RD1/PSP1" pad="39"/>
<connect gate="G$1" pin="RD2/PSP2" pad="40"/>
<connect gate="G$1" pin="RD3/PSP3" pad="41"/>
<connect gate="G$1" pin="RE0/!RD/AN5" pad="25"/>
<connect gate="G$1" pin="RE1/!WR/AN6" pad="26"/>
<connect gate="G$1" pin="RE2/!CS/AN7" pad="27"/>
<connect gate="G$1" pin="RX/RC7" pad="1"/>
<connect gate="G$1" pin="SDI/RC4" pad="42"/>
<connect gate="G$1" pin="SDO/RC5" pad="43"/>
<connect gate="G$1" pin="TX/RC6" pad="44"/>
<connect gate="G$1" pin="VDD" pad="7"/>
<connect gate="G$1" pin="VDD@1" pad="28"/>
<connect gate="G$1" pin="VSS" pad="6"/>
<connect gate="G$1" pin="VSS@1" pad="29"/>
</connects>
<technologies>
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="PIC16F874-20I/PQ" constant="no"/>
<attribute name="OC_FARNELL" value="1084251" constant="no"/>
<attribute name="OC_NEWARK" value="97K7435" constant="no"/>
</technology>
<attribute name="MPN" value="PIC16F877-04/PQ" constant="no"/>
<attribute name="OC_FARNELL" value="9761357" constant="no"/>
<attribute name="OC_NEWARK" value="23C5094" constant="no"/>
</technology>
</technologies>
</device>
<device name="PT" package="TQFP44">
<connects>
</connects>
<technologies>
<attribute name="MPN" value="PIC16F874-04/PQ" constant="no"/>
<attribute name="OC_NEWARK" value="97K7429" constant="no"/>
</technology>
<attribute name="OC_FARNELL" value="9761411" constant="no"/>
</technology>
</technologies>
</device>
<device name="P" package="DIL40">
<connects>
<connect gate="G$1" pin="!MCLR/THV" pad="1"/>
<connect gate="G$1" pin="INT/RB0" pad="33"/>
<connect gate="G$1" pin="OSC1/CLKIN" pad="13"/>
<connect gate="G$1" pin="OSC2/CLKOUT" pad="14"/>
<connect gate="G$1" pin="PGC/RB6" pad="39"/>
<connect gate="G$1" pin="PGD/RB7" pad="40"/>
<connect gate="G$1" pin="PGM/RB3" pad="36"/>
<connect gate="G$1" pin="PSP4/RD4" pad="27"/>
<connect gate="G$1" pin="PSP5/RD5" pad="28"/>
<connect gate="G$1" pin="PSP6/RD6" pad="29"/>
<connect gate="G$1" pin="PSP7/RD7" pad="30"/>
<connect gate="G$1" pin="RA0/AN0" pad="2"/>
<connect gate="G$1" pin="RA1/AN1" pad="3"/>
<connect gate="G$1" pin="RA2/AN2" pad="4"/>
<connect gate="G$1" pin="RA3/AN3" pad="5"/>
<connect gate="G$1" pin="RA4/T0CKI" pad="6"/>
<connect gate="G$1" pin="RA5/AN4" pad="7"/>
<connect gate="G$1" pin="RB1" pad="34"/>
<connect gate="G$1" pin="RB2" pad="35"/>
<connect gate="G$1" pin="RB4" pad="37"/>
<connect gate="G$1" pin="RB5" pad="38"/>
<connect gate="G$1" pin="RC0/T1OSO" pad="15"/>
<connect gate="G$1" pin="RC1/T1OSI" pad="16"/>
<connect gate="G$1" pin="RC2/CCP1" pad="17"/>
<connect gate="G$1" pin="RC3/SCK" pad="18"/>
<connect gate="G$1" pin="RD0/PSP0" pad="19"/>
<connect gate="G$1" pin="RD1/PSP1" pad="20"/>
<connect gate="G$1" pin="RD2/PSP2" pad="21"/>
<connect gate="G$1" pin="RD3/PSP3" pad="22"/>
<connect gate="G$1" pin="RE0/!RD/AN5" pad="8"/>
<connect gate="G$1" pin="RE1/!WR/AN6" pad="9"/>
<connect gate="G$1" pin="RE2/!CS/AN7" pad="10"/>
<connect gate="G$1" pin="RX/RC7" pad="26"/>
<connect gate="G$1" pin="SDI/RC4" pad="23"/>
<connect gate="G$1" pin="SDO/RC5" pad="24"/>
<connect gate="G$1" pin="TX/RC6" pad="25"/>
<connect gate="G$1" pin="VDD" pad="11"/>
<connect gate="G$1" pin="VDD@1" pad="32"/>
<connect gate="G$1" pin="VSS" pad="12"/>
<connect gate="G$1" pin="VSS@1" pad="31"/>
</connects>
<technologies>
<attribute name="MPN" value="PIC16F874-04I/P" constant="no"/>
<attribute name="OC_FARNELL" value="1196797" constant="no"/>
<attribute name="OC_NEWARK" value="24M5903" constant="no"/>
</technology>
<attribute name="MPN" value="PIC16F877-04/P" constant="no"/>
<attribute name="OC_FARNELL" value="9761349" constant="no"/>
<attribute name="OC_NEWARK" value="61K3463" constant="no"/>
</technology>
</technologies>
</device>
<device name="SO" package="S44">
<connects>
</connects>
<technologies>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="uln-udn">
<description>&lt;b&gt;Driver Arrays&lt;/b&gt;&lt;p&gt;
ULN and UDN Series&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL18">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="11.43" y1="2.921" x2="-11.43" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.921" x2="-11.43" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="-11.43" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.016" x2="-11.43" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-11.684" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-9.525" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SO20W">
<description>&lt;b&gt;Small Outline Package&lt;/b&gt; wide</description>
<wire x1="6.1214" y1="3.7338" x2="-6.1214" y2="3.7338" width="0.1524" layer="21"/>
<wire x1="6.1214" y1="-3.7338" x2="6.5024" y2="-3.3528" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.5024" y1="3.3528" x2="-6.1214" y2="3.7338" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.1214" y1="3.7338" x2="6.5024" y2="3.3528" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.5024" y1="-3.3528" x2="-6.1214" y2="-3.7338" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.1214" y1="-3.7338" x2="6.1214" y2="-3.7338" width="0.1524" layer="21"/>
<wire x1="6.5024" y1="-3.3528" x2="6.5024" y2="3.3528" width="0.1524" layer="21"/>
<wire x1="-6.5024" y1="3.3528" x2="-6.5024" y2="-3.3528" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-3.3782" x2="6.477" y2="-3.3782" width="0.0508" layer="21"/>
<wire x1="-6.5024" y1="1.27" x2="-6.5024" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<smd name="1" x="-5.715" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-4.445" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-3.175" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="-1.905" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="-0.635" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="0.635" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="1.905" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="3.175" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="3.175" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="1.905" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="15" x="0.635" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="16" x="-0.635" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="17" x="-1.905" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="18" x="-3.175" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="19" x="-4.445" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="20" x="-5.715" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="4.445" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="5.715" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="4.445" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="5.715" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<text x="-4.826" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="-3.556" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-5.969" y1="-3.8608" x2="-5.461" y2="-3.7338" layer="21"/>
<rectangle x1="-5.969" y1="-5.334" x2="-5.461" y2="-3.8608" layer="51"/>
<rectangle x1="-4.699" y1="-3.8608" x2="-4.191" y2="-3.7338" layer="21"/>
<rectangle x1="-4.699" y1="-5.334" x2="-4.191" y2="-3.8608" layer="51"/>
<rectangle x1="-3.429" y1="-3.8608" x2="-2.921" y2="-3.7338" layer="21"/>
<rectangle x1="-3.429" y1="-5.334" x2="-2.921" y2="-3.8608" layer="51"/>
<rectangle x1="-2.159" y1="-3.8608" x2="-1.651" y2="-3.7338" layer="21"/>
<rectangle x1="-2.159" y1="-5.334" x2="-1.651" y2="-3.8608" layer="51"/>
<rectangle x1="-0.889" y1="-5.334" x2="-0.381" y2="-3.8608" layer="51"/>
<rectangle x1="-0.889" y1="-3.8608" x2="-0.381" y2="-3.7338" layer="21"/>
<rectangle x1="0.381" y1="-3.8608" x2="0.889" y2="-3.7338" layer="21"/>
<rectangle x1="0.381" y1="-5.334" x2="0.889" y2="-3.8608" layer="51"/>
<rectangle x1="1.651" y1="-3.8608" x2="2.159" y2="-3.7338" layer="21"/>
<rectangle x1="1.651" y1="-5.334" x2="2.159" y2="-3.8608" layer="51"/>
<rectangle x1="2.921" y1="-3.8608" x2="3.429" y2="-3.7338" layer="21"/>
<rectangle x1="2.921" y1="-5.334" x2="3.429" y2="-3.8608" layer="51"/>
<rectangle x1="-5.969" y1="3.8608" x2="-5.461" y2="5.334" layer="51"/>
<rectangle x1="-5.969" y1="3.7338" x2="-5.461" y2="3.8608" layer="21"/>
<rectangle x1="-4.699" y1="3.7338" x2="-4.191" y2="3.8608" layer="21"/>
<rectangle x1="-4.699" y1="3.8608" x2="-4.191" y2="5.334" layer="51"/>
<rectangle x1="-3.429" y1="3.7338" x2="-2.921" y2="3.8608" layer="21"/>
<rectangle x1="-3.429" y1="3.8608" x2="-2.921" y2="5.334" layer="51"/>
<rectangle x1="-2.159" y1="3.7338" x2="-1.651" y2="3.8608" layer="21"/>
<rectangle x1="-2.159" y1="3.8608" x2="-1.651" y2="5.334" layer="51"/>
<rectangle x1="-0.889" y1="3.7338" x2="-0.381" y2="3.8608" layer="21"/>
<rectangle x1="-0.889" y1="3.8608" x2="-0.381" y2="5.334" layer="51"/>
<rectangle x1="0.381" y1="3.7338" x2="0.889" y2="3.8608" layer="21"/>
<rectangle x1="0.381" y1="3.8608" x2="0.889" y2="5.334" layer="51"/>
<rectangle x1="1.651" y1="3.7338" x2="2.159" y2="3.8608" layer="21"/>
<rectangle x1="1.651" y1="3.8608" x2="2.159" y2="5.334" layer="51"/>
<rectangle x1="2.921" y1="3.7338" x2="3.429" y2="3.8608" layer="21"/>
<rectangle x1="2.921" y1="3.8608" x2="3.429" y2="5.334" layer="51"/>
<rectangle x1="4.191" y1="3.7338" x2="4.699" y2="3.8608" layer="21"/>
<rectangle x1="5.461" y1="3.7338" x2="5.969" y2="3.8608" layer="21"/>
<rectangle x1="4.191" y1="3.8608" x2="4.699" y2="5.334" layer="51"/>
<rectangle x1="5.461" y1="3.8608" x2="5.969" y2="5.334" layer="51"/>
<rectangle x1="4.191" y1="-3.8608" x2="4.699" y2="-3.7338" layer="21"/>
<rectangle x1="5.461" y1="-3.8608" x2="5.969" y2="-3.7338" layer="21"/>
<rectangle x1="4.191" y1="-5.334" x2="4.699" y2="-3.8608" layer="51"/>
<rectangle x1="5.461" y1="-5.334" x2="5.969" y2="-3.8608" layer="51"/>
</package>
<package name="SO18W">
<wire x1="5.4864" y1="3.7338" x2="-5.4864" y2="3.7338" width="0.1524" layer="21"/>
<wire x1="5.4864" y1="-3.7338" x2="5.8674" y2="-3.3528" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.8674" y1="3.3528" x2="-5.4864" y2="3.7338" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.4864" y1="3.7338" x2="5.8674" y2="3.3528" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.8674" y1="-3.3528" x2="-5.4864" y2="-3.7338" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.4864" y1="-3.7338" x2="5.4864" y2="-3.7338" width="0.1524" layer="21"/>
<wire x1="5.8674" y1="-3.3528" x2="5.8674" y2="3.3528" width="0.1524" layer="21"/>
<wire x1="-5.8674" y1="3.3528" x2="-5.8674" y2="-3.3528" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.3782" x2="5.842" y2="-3.3782" width="0.0508" layer="21"/>
<wire x1="-5.8674" y1="1.27" x2="-5.8674" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<smd name="1" x="-5.08" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-3.81" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-2.54" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="-1.27" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="0" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="1.27" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="2.54" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="3.81" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="3.81" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="2.54" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="1.27" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="0" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="15" x="-1.27" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="16" x="-2.54" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="17" x="-3.81" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="18" x="-5.08" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="5.08" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="5.08" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<text x="-4.191" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.223" y="-3.556" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-5.334" y1="-3.8608" x2="-4.826" y2="-3.7338" layer="21"/>
<rectangle x1="-5.334" y1="-5.334" x2="-4.826" y2="-3.8608" layer="51"/>
<rectangle x1="-4.064" y1="-3.8608" x2="-3.556" y2="-3.7338" layer="21"/>
<rectangle x1="-4.064" y1="-5.334" x2="-3.556" y2="-3.8608" layer="51"/>
<rectangle x1="-2.794" y1="-3.8608" x2="-2.286" y2="-3.7338" layer="21"/>
<rectangle x1="-2.794" y1="-5.334" x2="-2.286" y2="-3.8608" layer="51"/>
<rectangle x1="-1.524" y1="-3.8608" x2="-1.016" y2="-3.7338" layer="21"/>
<rectangle x1="-1.524" y1="-5.334" x2="-1.016" y2="-3.8608" layer="51"/>
<rectangle x1="-0.254" y1="-5.334" x2="0.254" y2="-3.8608" layer="51"/>
<rectangle x1="-0.254" y1="-3.8608" x2="0.254" y2="-3.7338" layer="21"/>
<rectangle x1="1.016" y1="-3.8608" x2="1.524" y2="-3.7338" layer="21"/>
<rectangle x1="1.016" y1="-5.334" x2="1.524" y2="-3.8608" layer="51"/>
<rectangle x1="2.286" y1="-3.8608" x2="2.794" y2="-3.7338" layer="21"/>
<rectangle x1="2.286" y1="-5.334" x2="2.794" y2="-3.8608" layer="51"/>
<rectangle x1="3.556" y1="-3.8608" x2="4.064" y2="-3.7338" layer="21"/>
<rectangle x1="3.556" y1="-5.334" x2="4.064" y2="-3.8608" layer="51"/>
<rectangle x1="-5.334" y1="3.8608" x2="-4.826" y2="5.334" layer="51"/>
<rectangle x1="-5.334" y1="3.7338" x2="-4.826" y2="3.8608" layer="21"/>
<rectangle x1="-4.064" y1="3.7338" x2="-3.556" y2="3.8608" layer="21"/>
<rectangle x1="-4.064" y1="3.8608" x2="-3.556" y2="5.334" layer="51"/>
<rectangle x1="-2.794" y1="3.7338" x2="-2.286" y2="3.8608" layer="21"/>
<rectangle x1="-2.794" y1="3.8608" x2="-2.286" y2="5.334" layer="51"/>
<rectangle x1="-1.524" y1="3.7338" x2="-1.016" y2="3.8608" layer="21"/>
<rectangle x1="-1.524" y1="3.8608" x2="-1.016" y2="5.334" layer="51"/>
<rectangle x1="-0.254" y1="3.7338" x2="0.254" y2="3.8608" layer="21"/>
<rectangle x1="-0.254" y1="3.8608" x2="0.254" y2="5.334" layer="51"/>
<rectangle x1="1.016" y1="3.7338" x2="1.524" y2="3.8608" layer="21"/>
<rectangle x1="1.016" y1="3.8608" x2="1.524" y2="5.334" layer="51"/>
<rectangle x1="2.286" y1="3.7338" x2="2.794" y2="3.8608" layer="21"/>
<rectangle x1="2.286" y1="3.8608" x2="2.794" y2="5.334" layer="51"/>
<rectangle x1="3.556" y1="3.7338" x2="4.064" y2="3.8608" layer="21"/>
<rectangle x1="3.556" y1="3.8608" x2="4.064" y2="5.334" layer="51"/>
<rectangle x1="4.826" y1="3.7338" x2="5.334" y2="3.8608" layer="21"/>
<rectangle x1="4.826" y1="3.8608" x2="5.334" y2="5.334" layer="51"/>
<rectangle x1="4.826" y1="-3.8608" x2="5.334" y2="-3.7338" layer="21"/>
<rectangle x1="4.826" y1="-5.334" x2="5.334" y2="-3.8608" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="UDN2981A">
<wire x1="-7.62" y1="12.7" x2="7.62" y2="12.7" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-12.7" x2="7.62" y2="12.7" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-12.7" x2="-7.62" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="12.7" x2="-7.62" y2="-12.7" width="0.4064" layer="94"/>
<text x="-7.62" y="13.462" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
<pin name="I1" x="-12.7" y="10.16" length="middle" direction="in"/>
<pin name="I2" x="-12.7" y="7.62" length="middle" direction="in"/>
<pin name="I3" x="-12.7" y="5.08" length="middle" direction="in"/>
<pin name="I4" x="-12.7" y="2.54" length="middle" direction="in"/>
<pin name="I5" x="-12.7" y="0" length="middle" direction="in"/>
<pin name="I6" x="-12.7" y="-2.54" length="middle" direction="in"/>
<pin name="I7" x="-12.7" y="-5.08" length="middle" direction="in"/>
<pin name="I8" x="-12.7" y="-7.62" length="middle" direction="in"/>
<pin name="O8" x="12.7" y="-7.62" length="middle" direction="oc" rot="R180"/>
<pin name="O1" x="12.7" y="10.16" length="middle" direction="oc" rot="R180"/>
<pin name="O2" x="12.7" y="7.62" length="middle" direction="oc" rot="R180"/>
<pin name="O3" x="12.7" y="5.08" length="middle" direction="oc" rot="R180"/>
<pin name="O4" x="12.7" y="2.54" length="middle" direction="oc" rot="R180"/>
<pin name="O5" x="12.7" y="0" length="middle" direction="oc" rot="R180"/>
<pin name="O6" x="12.7" y="-2.54" length="middle" direction="oc" rot="R180"/>
<pin name="O7" x="12.7" y="-5.08" length="middle" direction="oc" rot="R180"/>
<pin name="VS" x="-12.7" y="-10.16" length="middle" direction="pas"/>
<pin name="GND" x="12.7" y="-10.16" length="middle" direction="pwr" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="UDN298*" prefix="IC">
<description>&lt;b&gt;DRIVER ARRAY&lt;/b&gt;&lt;p&gt;
Source: Allegro Microsystems Inc. / UDN2981-UDN2984.pdf</description>
<gates>
<gate name="1" symbol="UDN2981A" x="0" y="0"/>
</gates>
<devices>
<device name="A" package="DIL18">
<connects>
<connect gate="1" pin="GND" pad="10"/>
<connect gate="1" pin="I1" pad="1"/>
<connect gate="1" pin="I2" pad="2"/>
<connect gate="1" pin="I3" pad="3"/>
<connect gate="1" pin="I4" pad="4"/>
<connect gate="1" pin="I5" pad="5"/>
<connect gate="1" pin="I6" pad="6"/>
<connect gate="1" pin="I7" pad="7"/>
<connect gate="1" pin="I8" pad="8"/>
<connect gate="1" pin="O1" pad="18"/>
<connect gate="1" pin="O2" pad="17"/>
<connect gate="1" pin="O3" pad="16"/>
<connect gate="1" pin="O4" pad="15"/>
<connect gate="1" pin="O5" pad="14"/>
<connect gate="1" pin="O6" pad="13"/>
<connect gate="1" pin="O7" pad="12"/>
<connect gate="1" pin="O8" pad="11"/>
<connect gate="1" pin="VS" pad="9"/>
</connects>
<technologies>
<technology name="1"/>
<technology name="2"/>
<technology name="3"/>
<technology name="4"/>
</technologies>
</device>
<device name="SLW" package="SO20W">
<connects>
<connect gate="1" pin="GND" pad="12"/>
<connect gate="1" pin="O1" pad="20"/>
<connect gate="1" pin="O2" pad="19"/>
<connect gate="1" pin="O3" pad="18"/>
<connect gate="1" pin="O4" pad="17"/>
<connect gate="1" pin="O5" pad="16"/>
<connect gate="1" pin="O6" pad="15"/>
<connect gate="1" pin="O7" pad="14"/>
<connect gate="1" pin="O8" pad="13"/>
</connects>
<technologies>
</technologies>
</device>
<device name="LW" package="SO18W">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
<packages>
</packages>
<symbols>
<symbol name="VDD">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.905" x2="0" y2="1.27" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="VDD" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="GND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="VDD" prefix="VDD">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="VDD" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GND" prefix="GND">
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-amp-mt">
<description>&lt;b&gt;AMP Connectors, Type MT&lt;/b&gt;&lt;p&gt;
include  Type MT6; con-amp-mt6.lbr&lt;p&gt;
<packages>
<package name="L02P">
<description>&lt;b&gt;AMP MT CONNECTOR&lt;/b&gt;</description>
<wire x1="2.418" y1="-4.345" x2="-2.331" y2="-4.345" width="0.1524" layer="21"/>
<wire x1="2.418" y1="6.45" x2="2.926" y2="7.339" width="0.1524" layer="21"/>
<wire x1="2.418" y1="-3.456" x2="-2.331" y2="-3.456" width="0.1524" layer="21"/>
<wire x1="2.418" y1="-3.456" x2="2.418" y2="-4.345" width="0.1524" layer="21"/>
<wire x1="2.418" y1="6.45" x2="2.418" y2="5.815" width="0.1524" layer="21"/>
<wire x1="2.418" y1="5.815" x2="2.418" y2="-3.456" width="0.1524" layer="21"/>
<wire x1="2.418" y1="5.815" x2="-2.331" y2="5.815" width="0.1524" layer="21"/>
<wire x1="-2.331" y1="-3.456" x2="-2.331" y2="-4.345" width="0.1524" layer="21"/>
<wire x1="-2.331" y1="5.815" x2="-2.331" y2="-3.456" width="0.1524" layer="21"/>
<wire x1="-4.871" y1="-5.869" x2="-4.871" y2="7.339" width="0.1524" layer="21"/>
<wire x1="-4.871" y1="7.339" x2="-2.839" y2="7.339" width="0.1524" layer="21"/>
<wire x1="-2.839" y1="7.339" x2="-2.331" y2="6.45" width="0.1524" layer="21"/>
<wire x1="-2.331" y1="6.45" x2="-2.331" y2="5.815" width="0.1524" layer="21"/>
<wire x1="4.933" y1="-5.869" x2="4.933" y2="7.339" width="0.1524" layer="21"/>
<wire x1="4.933" y1="7.339" x2="2.926" y2="7.339" width="0.1524" layer="21"/>
<wire x1="1.25" y1="3.529" x2="1.25" y2="3.021" width="0.6604" layer="21"/>
<wire x1="4.933" y1="-5.869" x2="2.241" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="0.259" y1="-5.869" x2="2.241" y2="-5.869" width="0.1524" layer="51"/>
<wire x1="0.259" y1="-5.869" x2="-0.249" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="-2.23" y1="-5.869" x2="-0.249" y2="-5.869" width="0.1524" layer="51"/>
<wire x1="-2.23" y1="-5.869" x2="-4.871" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="-1.25" y1="3.529" x2="-1.25" y2="3.021" width="0.6604" layer="21"/>
<pad name="2" x="-1.25" y="-6.25" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="1.25" y="-6.25" drill="1.016" shape="long" rot="R90"/>
<text x="-4.7698" y="-8.79" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.195" y="-1.17" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="4.3742" y="-4.345" size="1.27" layer="21" ratio="10" rot="R90">1</text>
<text x="-2.7886" y="-4.472" size="1.27" layer="21" ratio="10" rot="R90">2</text>
<rectangle x1="0.9452" y1="-3.456" x2="1.5548" y2="3.148" layer="21"/>
<rectangle x1="0.9452" y1="-6.504" x2="1.5548" y2="-5.869" layer="51"/>
<rectangle x1="-1.544" y1="-3.456" x2="-0.9344" y2="3.148" layer="21"/>
<rectangle x1="-1.544" y1="-6.504" x2="-0.9344" y2="-5.869" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="M">
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="1.27" y2="0" width="0.6096" layer="94"/>
<text x="-0.508" y="1.016" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<text x="0.254" y="-2.413" size="1.778" layer="96">&gt;VALUE</text>
<pin name="S" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="L02P" prefix="SV" uservalue="yes">
<gates>
<gate name="-1" symbol="M" x="0" y="2.54" addlevel="always"/>
<gate name="-2" symbol="M" x="0" y="-2.54" addlevel="always"/>
</gates>
<devices>
<device name="" package="L02P">
<connects>
<connect gate="-1" pin="S" pad="1"/>
<connect gate="-2" pin="S" pad="2"/>
</connects>
<technologies>
<technology name="">
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-lstb">
<description>&lt;b&gt;Pin Headers&lt;/b&gt;&lt;p&gt;
Naming:&lt;p&gt;
MA = male&lt;p&gt;
# contacts - # rows&lt;p&gt;
W = angled&lt;p&gt;
<packages>
<package name="MA03-1">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-3.175" y1="1.27" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-3.81" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-0.635" size="1.27" layer="21" ratio="10">1</text>
<text x="-3.81" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="MA03-1">
<wire x1="3.81" y1="-5.08" x2="-1.27" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="-1.27" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="3.81" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="3.81" y2="5.08" width="0.4064" layer="94"/>
<text x="-1.27" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<text x="-1.27" y="5.842" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MA03-1" prefix="SV" uservalue="yes">
<gates>
<gate name="G$1" symbol="MA03-1" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MA03-1">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="resistor">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;tr valign="top"&gt;
&lt;/td&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="R0402">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.762" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R0603">
chip</description>
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<text x="-0.889" y="0.889" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.889" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
</package>
<package name="R0805">
chip</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.762" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.762" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="R0805W">
chip, wave soldering</description>
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
<text x="-0.635" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.159" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1005">
chip</description>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="R1206">
chip</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.397" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R1206W">
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="21"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="21"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
</package>
<package name="R1210">
chip</description>
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.27" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
</package>
<package name="R1210W">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="21"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="21"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<text x="-1.651" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010">
chip</description>
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-1.027" y1="1.245" x2="1.027" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.002" y1="-1.245" x2="1.016" y2="-1.245" width="0.1524" layer="21"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-2.159" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="R2010W">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="21"/>
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
<text x="-2.286" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.286" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R2012">
chip</description>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="R2012W">
<text x="-0.635" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R2512">
chip</description>
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="1.473" x2="1.498" y2="1.473" width="0.1524" layer="21"/>
<wire x1="-1.473" y1="-1.473" x2="1.498" y2="-1.473" width="0.1524" layer="21"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<text x="-2.667" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.667" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R2512W">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="21"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="21"/>
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-2.794" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3216">
chip</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="R3216W">
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3225">
chip</description>
<text x="-1.397" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="R3225W">
<text x="-1.397" y="1.524" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="R5025">
chip</description>
<wire x1="-0.9" y1="1.245" x2="0.9" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-0.875" y1="-1.245" x2="0.925" y2="-1.245" width="0.1524" layer="21"/>
</package>
<package name="R5025W">
<text x="-2.286" y="1.651" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="R6332">
chip</description>
<text x="-2.794" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R6332W">
<text x="-2.921" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.921" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="M0805">
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1.016" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.016" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="M1206">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
</package>
<package name="M1406">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="0.6858" y1="0.762" x2="-0.6858" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="-0.762" x2="-0.6858" y2="-0.762" width="0.1524" layer="21"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
<package name="M2012">
</package>
<package name="M2309">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<wire x1="1.651" y1="1.1684" x2="-1.6764" y2="1.1684" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.1684" x2="-1.651" y2="-1.1684" width="0.1524" layer="21"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.794" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
</package>
<package name="M3216">
</package>
<package name="M3516">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M5923">
</package>
<package name="0204/5">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0204V">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/15">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0309/10">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
</package>
<package name="0309/12">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="0309V">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="0411/12">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="0411/15">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0411V">
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="0414/15">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
</package>
<package name="0414V">
type 0414, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
</package>
<package name="0617/17">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="0617/22">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
<package name="0617V">
type 0617, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="0922/22">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="P0613V">
type 0613, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="P0613/15">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="P0817/22">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
</package>
<package name="P0817V">
type 0817, grid 6.35 mm</description>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
</package>
<package name="V234/12">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
</package>
<package name="V235/17">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="V526-0">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102R">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102W">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0204R">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0204W">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0207R">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0207W">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="0922V">
type 0922, grid 7.5 mm</description>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="RDH/15">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="MINI_MELF-0102AX">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<hole x="0" y="0" drill="1.3"/>
</package>
</packages>
<symbols>
<symbol name="R-EU">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="R-EU_" prefix="R" uservalue="yes">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="R-EU" x="0" y="0"/>
</gates>
<devices>
<device name="R0402" package="R0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="R0603" package="R0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805" package="R0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805W" package="R0805W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1005" package="R1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206" package="R1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206W" package="R1206W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210" package="R1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210W" package="R1210W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010" package="R2010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010W" package="R2010W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012" package="R2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012W" package="R2012W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512" package="R2512">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512W" package="R2512W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216" package="R3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216W" package="R3216W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225" package="R3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225W" package="R3225W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025" package="R5025">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025W" package="R5025W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332" package="R6332">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332W" package="R6332W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M0805" package="M0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1206" package="M1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1406" package="M1406">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2012" package="M2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2309" package="M2309">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3216" package="M3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3516" package="M3516">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M5923" package="M5923">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/2V" package="0204V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/10" package="0309/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/12" package="0309/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/V" package="0309V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/12" package="0411/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/15" package="0411/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/3V" package="0411V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/15" package="0414/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/5V" package="0414V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/17" package="0617/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/22" package="0617/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/5V" package="0617V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922/22" package="0922/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/5V" package="P0613V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/15" package="P0613/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/22" package="P0817/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/7V" package="P0817V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V234/12" package="V234/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V235/17" package="V235/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V526-0" package="V526-0">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102R" package="MINI_MELF-0102R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102W" package="MINI_MELF-0102W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204R" package="MINI_MELF-0204R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204W" package="MINI_MELF-0204W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207R" package="MINI_MELF-0207R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207W" package="MINI_MELF-0207W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922V" package="0922V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RDH/15" package="RDH/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102AX" package="MINI_MELF-0102AX">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-garry">
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
&lt;a href="www.mpe-connector.de"&gt;Menufacturer&lt;/a&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="332-02">
<description>&lt;b&gt;2 Pin - 2mm Dual Row&lt;/b&gt;&lt;p&gt;
Source: www.mpe-connector.de / garry_shortform_2012.pdf</description>
<wire x1="-0.85" y1="-1.9" x2="0.85" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="0.85" y1="-1.9" x2="0.85" y2="-0.4" width="0.2032" layer="21"/>
<wire x1="0.85" y1="0.4" x2="0.85" y2="1.9" width="0.2032" layer="21"/>
<wire x1="0.85" y1="1.9" x2="-0.85" y2="1.9" width="0.2032" layer="21"/>
<wire x1="-0.85" y1="1.9" x2="-0.85" y2="0.4" width="0.2032" layer="21"/>
<wire x1="-0.85" y1="-0.4" x2="-0.85" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="-0.85" y1="0.4" x2="-0.85" y2="-0.4" width="0.2032" layer="21" curve="-129.185"/>
<wire x1="0.85" y1="-0.4" x2="0.85" y2="0.4" width="0.2032" layer="21" curve="-129.185"/>
<pad name="1" x="0" y="-1" drill="0.9" diameter="1.27"/>
<pad name="2" x="0" y="1" drill="0.9" diameter="1.27"/>
<text x="-0.65" y="-1.75" size="0.3048" layer="21" font="vector">1</text>
<text x="-0.62" y="-3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.62" y="2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.25" y1="-1.25" x2="0.25" y2="-0.75" layer="51"/>
<rectangle x1="-0.25" y1="0.75" x2="0.25" y2="1.25" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="MV">
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.6096" layer="94"/>
<text x="2.54" y="-0.762" size="1.524" layer="95">&gt;NAME</text>
<text x="-0.762" y="1.397" size="1.778" layer="96">&gt;VALUE</text>
<pin name="S" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="332-02" prefix="X">
<gates>
<gate name="-1" symbol="MV" x="-10.16" y="0" addlevel="always"/>
<gate name="-2" symbol="MV" x="10.16" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="332-02">
<connects>
<connect gate="-1" pin="S" pad="1"/>
<connect gate="-2" pin="S" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="IC1" library="linear" deviceset="78*" device="T" technology="05"/>
<part name="C1" library="capacitor-wima" deviceset="C" device="2,5-3"/>
<part name="C2" library="capacitor-wima" deviceset="C" device="2,5-3"/>
<part name="IC2" library="microchip" deviceset="PIC16F87*" device="P" technology="7"/>
<part name="IC3" library="uln-udn" deviceset="UDN298*" device="A" technology="1"/>
<part name="IC4" library="uln-udn" deviceset="UDN298*" device="A" technology="1"/>
<part name="IC5" library="uln-udn" deviceset="UDN298*" device="A" technology="1"/>
<part name="IC6" library="uln-udn" deviceset="UDN298*" device="A" technology="1"/>
<part name="VDD1" library="supply1" deviceset="VDD" device=""/>
<part name="VDD2" library="supply1" deviceset="VDD" device=""/>
<part name="VDD3" library="supply1" deviceset="VDD" device=""/>
<part name="VDD4" library="supply1" deviceset="VDD" device=""/>
<part name="VDD5" library="supply1" deviceset="VDD" device=""/>
<part name="VDD6" library="supply1" deviceset="VDD" device=""/>
<part name="GND1" library="supply1" deviceset="GND" device=""/>
<part name="GND2" library="supply1" deviceset="GND" device=""/>
<part name="GND3" library="supply1" deviceset="GND" device=""/>
<part name="GND4" library="supply1" deviceset="GND" device=""/>
<part name="GND5" library="supply1" deviceset="GND" device=""/>
<part name="GND6" library="supply1" deviceset="GND" device=""/>
<part name="C3" library="capacitor-wima" deviceset="C" device="2,5-3"/>
<part name="POWER" library="con-amp-mt" deviceset="L02P" device=""/>
<part name="SV1" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV2" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV3" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV4" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV5" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV6" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV7" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV8" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV9" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV10" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV11" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV12" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV13" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV14" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV15" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="SV16" library="con-lstb" deviceset="MA03-1" device=""/>
<part name="GND7" library="supply1" deviceset="GND" device=""/>
<part name="GND8" library="supply1" deviceset="GND" device=""/>
<part name="VDD7" library="supply1" deviceset="VDD" device=""/>
<part name="C4" library="capacitor-wima" deviceset="C" device="2,5-3"/>
<part name="GND9" library="supply1" deviceset="GND" device=""/>
<part name="GND10" library="supply1" deviceset="GND" device=""/>
<part name="GND11" library="supply1" deviceset="GND" device=""/>
<part name="R1" library="resistor" deviceset="R-EU_" device="0207/10" value="270 Ohm"/>
<part name="R2" library="resistor" deviceset="R-EU_" device="0207/10" value="470KOhm"/>
<part name="VDD8" library="supply1" deviceset="VDD" device=""/>
<part name="KAPCSOLO_CSATI" library="con-garry" deviceset="332-02" device=""/>
<part name="R3" library="resistor" deviceset="R-EU_" device="0207/10" value="10 KOhm"/>
<part name="VDD9" library="supply1" deviceset="VDD" device=""/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="IC1" gate="A1" x="-68.58" y="88.9"/>
<instance part="C1" gate="G$1" x="-81.28" y="81.28"/>
<instance part="C2" gate="G$1" x="-55.88" y="81.28"/>
<instance part="IC2" gate="G$1" x="101.6" y="71.12"/>
<instance part="IC3" gate="1" x="40.64" y="81.28" rot="R180"/>
<instance part="IC4" gate="1" x="40.64" y="40.64" rot="R180"/>
<instance part="IC5" gate="1" x="172.72" y="81.28"/>
<instance part="IC6" gate="1" x="172.72" y="38.1"/>
<instance part="VDD1" gate="G$1" x="-35.56" y="88.9" rot="R270"/>
<instance part="VDD2" gate="G$1" x="76.2" y="119.38" rot="R90"/>
<instance part="VDD3" gate="G$1" x="48.26" y="101.6" rot="R90"/>
<instance part="VDD4" gate="G$1" x="48.26" y="60.96" rot="R90"/>
<instance part="VDD5" gate="G$1" x="154.94" y="68.58" rot="R90"/>
<instance part="VDD6" gate="G$1" x="154.94" y="25.4" rot="R90"/>
<instance part="GND1" gate="1" x="-68.58" y="60.96"/>
<instance part="GND2" gate="1" x="104.14" y="22.86"/>
<instance part="GND3" gate="1" x="33.02" y="99.06"/>
<instance part="GND4" gate="1" x="33.02" y="58.42"/>
<instance part="GND5" gate="1" x="190.5" y="63.5"/>
<instance part="GND6" gate="1" x="190.5" y="20.32"/>
<instance part="C3" gate="G$1" x="88.9" y="114.3" rot="R180"/>
<instance part="POWER" gate="-1" x="-109.22" y="88.9"/>
<instance part="POWER" gate="-2" x="-109.22" y="83.82"/>
<instance part="SV1" gate="G$1" x="-10.16" y="137.16"/>
<instance part="SV2" gate="G$1" x="-10.16" y="121.92"/>
<instance part="SV3" gate="G$1" x="-10.16" y="106.68"/>
<instance part="SV4" gate="G$1" x="-10.16" y="91.44"/>
<instance part="SV5" gate="G$1" x="-10.16" y="45.72"/>
<instance part="SV6" gate="G$1" x="-10.16" y="30.48"/>
<instance part="SV7" gate="G$1" x="-10.16" y="15.24"/>
<instance part="SV8" gate="G$1" x="-10.16" y="-2.54"/>
<instance part="SV9" gate="G$1" x="238.76" y="137.16" rot="R180"/>
<instance part="SV10" gate="G$1" x="238.76" y="119.38" rot="R180"/>
<instance part="SV11" gate="G$1" x="238.76" y="101.6" rot="R180"/>
<instance part="SV12" gate="G$1" x="238.76" y="83.82" rot="R180"/>
<instance part="SV13" gate="G$1" x="238.76" y="45.72" rot="R180"/>
<instance part="SV14" gate="G$1" x="238.76" y="27.94" rot="R180"/>
<instance part="SV15" gate="G$1" x="238.76" y="10.16" rot="R180"/>
<instance part="SV16" gate="G$1" x="238.76" y="-7.62" rot="R180"/>
<instance part="GND7" gate="1" x="246.38" y="-27.94"/>
<instance part="GND8" gate="1" x="-20.32" y="-22.86"/>
<instance part="VDD7" gate="G$1" x="119.38" y="119.38" rot="R270"/>
<instance part="C4" gate="G$1" x="109.22" y="114.3" rot="R180"/>
<instance part="GND9" gate="1" x="96.52" y="22.86"/>
<instance part="GND10" gate="1" x="109.22" y="106.68"/>
<instance part="GND11" gate="1" x="88.9" y="106.68"/>
<instance part="R1" gate="G$1" x="20.32" y="66.04"/>
<instance part="R2" gate="G$1" x="-7.62" y="66.04"/>
<instance part="VDD8" gate="G$1" x="-15.24" y="73.66"/>
<instance part="KAPCSOLO_CSATI" gate="-1" x="-12.7" y="60.96" rot="R180"/>
<instance part="KAPCSOLO_CSATI" gate="-2" x="-12.7" y="55.88" rot="R180"/>
<instance part="R3" gate="G$1" x="73.66" y="127"/>
<instance part="VDD9" gate="G$1" x="91.44" y="127" rot="R270"/>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RA0/AN0"/>
<pinref part="IC3" gate="1" pin="I8"/>
<wire x1="78.74" y1="88.9" x2="53.34" y2="88.9" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RA1/AN1"/>
<pinref part="IC3" gate="1" pin="I7"/>
<wire x1="78.74" y1="86.36" x2="53.34" y2="86.36" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RA2/AN2"/>
<pinref part="IC3" gate="1" pin="I6"/>
<wire x1="78.74" y1="83.82" x2="53.34" y2="83.82" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RA3/AN3"/>
<pinref part="IC3" gate="1" pin="I5"/>
<wire x1="78.74" y1="81.28" x2="53.34" y2="81.28" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RA4/T0CKI"/>
<pinref part="IC3" gate="1" pin="I4"/>
<wire x1="78.74" y1="78.74" x2="53.34" y2="78.74" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RA5/AN4"/>
<pinref part="IC3" gate="1" pin="I3"/>
<wire x1="78.74" y1="76.2" x2="53.34" y2="76.2" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RE0/!RD/AN5"/>
<pinref part="IC3" gate="1" pin="I2"/>
<wire x1="78.74" y1="73.66" x2="53.34" y2="73.66" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RE1/!WR/AN6"/>
<pinref part="IC3" gate="1" pin="I1"/>
<wire x1="78.74" y1="71.12" x2="53.34" y2="71.12" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="IC4" gate="1" pin="I8"/>
<wire x1="53.34" y1="48.26" x2="58.42" y2="48.26" width="0.1524" layer="91"/>
<wire x1="58.42" y1="48.26" x2="58.42" y2="63.5" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="OSC1/CLKIN"/>
<wire x1="58.42" y1="63.5" x2="78.74" y2="63.5" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="IC4" gate="1" pin="I7"/>
<wire x1="53.34" y1="45.72" x2="60.96" y2="45.72" width="0.1524" layer="91"/>
<wire x1="60.96" y1="45.72" x2="60.96" y2="60.96" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="OSC2/CLKOUT"/>
<wire x1="60.96" y1="60.96" x2="78.74" y2="60.96" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RC0/T1OSO"/>
<wire x1="78.74" y1="58.42" x2="63.5" y2="58.42" width="0.1524" layer="91"/>
<wire x1="63.5" y1="58.42" x2="63.5" y2="43.18" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="I6"/>
<wire x1="63.5" y1="43.18" x2="53.34" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RC1/T1OSI"/>
<wire x1="78.74" y1="55.88" x2="66.04" y2="55.88" width="0.1524" layer="91"/>
<wire x1="66.04" y1="55.88" x2="66.04" y2="40.64" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="I5"/>
<wire x1="66.04" y1="40.64" x2="53.34" y2="40.64" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RC2/CCP1"/>
<wire x1="78.74" y1="53.34" x2="68.58" y2="53.34" width="0.1524" layer="91"/>
<wire x1="68.58" y1="53.34" x2="68.58" y2="38.1" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="I4"/>
<wire x1="68.58" y1="38.1" x2="53.34" y2="38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RC3/SCK"/>
<wire x1="78.74" y1="50.8" x2="71.12" y2="50.8" width="0.1524" layer="91"/>
<wire x1="71.12" y1="50.8" x2="71.12" y2="35.56" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="I3"/>
<wire x1="71.12" y1="35.56" x2="53.34" y2="35.56" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RD0/PSP0"/>
<wire x1="78.74" y1="48.26" x2="73.66" y2="48.26" width="0.1524" layer="91"/>
<wire x1="73.66" y1="48.26" x2="73.66" y2="33.02" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="I2"/>
<wire x1="73.66" y1="33.02" x2="53.34" y2="33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RD1/PSP1"/>
<wire x1="78.74" y1="45.72" x2="76.2" y2="45.72" width="0.1524" layer="91"/>
<wire x1="76.2" y1="45.72" x2="76.2" y2="30.48" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="I1"/>
<wire x1="76.2" y1="30.48" x2="53.34" y2="30.48" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RD2/PSP2"/>
<wire x1="121.92" y1="45.72" x2="134.62" y2="45.72" width="0.1524" layer="91"/>
<wire x1="134.62" y1="45.72" x2="134.62" y2="30.48" width="0.1524" layer="91"/>
<pinref part="IC6" gate="1" pin="I8"/>
<wire x1="134.62" y1="30.48" x2="160.02" y2="30.48" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RD3/PSP3"/>
<wire x1="121.92" y1="48.26" x2="137.16" y2="48.26" width="0.1524" layer="91"/>
<wire x1="137.16" y1="48.26" x2="137.16" y2="33.02" width="0.1524" layer="91"/>
<pinref part="IC6" gate="1" pin="I7"/>
<wire x1="137.16" y1="33.02" x2="160.02" y2="33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="SDI/RC4"/>
<wire x1="121.92" y1="50.8" x2="139.7" y2="50.8" width="0.1524" layer="91"/>
<wire x1="139.7" y1="50.8" x2="139.7" y2="35.56" width="0.1524" layer="91"/>
<pinref part="IC6" gate="1" pin="I6"/>
<wire x1="139.7" y1="35.56" x2="160.02" y2="35.56" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="SDO/RC5"/>
<wire x1="121.92" y1="53.34" x2="142.24" y2="53.34" width="0.1524" layer="91"/>
<wire x1="142.24" y1="53.34" x2="142.24" y2="38.1" width="0.1524" layer="91"/>
<pinref part="IC6" gate="1" pin="I5"/>
<wire x1="142.24" y1="38.1" x2="160.02" y2="38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="TX/RC6"/>
<wire x1="121.92" y1="55.88" x2="144.78" y2="55.88" width="0.1524" layer="91"/>
<wire x1="144.78" y1="55.88" x2="144.78" y2="40.64" width="0.1524" layer="91"/>
<pinref part="IC6" gate="1" pin="I4"/>
<wire x1="144.78" y1="40.64" x2="160.02" y2="40.64" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RX/RC7"/>
<wire x1="121.92" y1="58.42" x2="147.32" y2="58.42" width="0.1524" layer="91"/>
<wire x1="147.32" y1="58.42" x2="147.32" y2="43.18" width="0.1524" layer="91"/>
<pinref part="IC6" gate="1" pin="I3"/>
<wire x1="147.32" y1="43.18" x2="160.02" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<wire x1="149.86" y1="60.96" x2="149.86" y2="45.72" width="0.1524" layer="91"/>
<pinref part="IC6" gate="1" pin="I2"/>
<wire x1="149.86" y1="45.72" x2="160.02" y2="45.72" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="PSP4/RD4"/>
<wire x1="149.86" y1="60.96" x2="121.92" y2="60.96" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="IC6" gate="1" pin="I1"/>
<wire x1="160.02" y1="48.26" x2="152.4" y2="48.26" width="0.1524" layer="91"/>
<wire x1="152.4" y1="48.26" x2="152.4" y2="63.5" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="PSP5/RD5"/>
<wire x1="152.4" y1="63.5" x2="121.92" y2="63.5" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="IC5" gate="1" pin="I7"/>
<wire x1="121.92" y1="76.2" x2="160.02" y2="76.2" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="RB1"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="IC5" gate="1" pin="I6"/>
<wire x1="121.92" y1="78.74" x2="160.02" y2="78.74" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="RB2"/>
</segment>
</net>
<net name="N$29" class="0">
<segment>
<pinref part="IC5" gate="1" pin="I4"/>
<wire x1="121.92" y1="83.82" x2="160.02" y2="83.82" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="RB4"/>
</segment>
</net>
<net name="N$31" class="0">
<segment>
<pinref part="IC5" gate="1" pin="I2"/>
<wire x1="121.92" y1="88.9" x2="160.02" y2="88.9" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="PGC/RB6"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="IC5" gate="1" pin="I1"/>
<wire x1="121.92" y1="91.44" x2="160.02" y2="91.44" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="PGD/RB7"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="IC1" gate="A1" pin="VI"/>
<wire x1="-78.74" y1="88.9" x2="-81.28" y2="88.9" width="0.1524" layer="91"/>
<pinref part="C1" gate="G$1" pin="1"/>
<wire x1="-81.28" y1="88.9" x2="-104.14" y2="88.9" width="0.1524" layer="91"/>
<wire x1="-81.28" y1="88.9" x2="-81.28" y2="83.82" width="0.1524" layer="91"/>
<junction x="-81.28" y="88.9"/>
<pinref part="POWER" gate="-1" pin="S"/>
</segment>
</net>
<net name="VDD" class="0">
<segment>
<pinref part="IC1" gate="A1" pin="VO"/>
<wire x1="-58.42" y1="88.9" x2="-55.88" y2="88.9" width="0.1524" layer="91"/>
<pinref part="C2" gate="G$1" pin="1"/>
<wire x1="-55.88" y1="88.9" x2="-38.1" y2="88.9" width="0.1524" layer="91"/>
<wire x1="-55.88" y1="88.9" x2="-55.88" y2="83.82" width="0.1524" layer="91"/>
<junction x="-55.88" y="88.9"/>
<pinref part="VDD1" gate="G$1" pin="VDD"/>
</segment>
<segment>
<pinref part="IC3" gate="1" pin="VS"/>
<wire x1="53.34" y1="91.44" x2="55.88" y2="91.44" width="0.1524" layer="91"/>
<wire x1="55.88" y1="91.44" x2="55.88" y2="101.6" width="0.1524" layer="91"/>
<wire x1="55.88" y1="101.6" x2="50.8" y2="101.6" width="0.1524" layer="91"/>
<pinref part="VDD3" gate="G$1" pin="VDD"/>
</segment>
<segment>
<pinref part="IC4" gate="1" pin="VS"/>
<wire x1="53.34" y1="50.8" x2="55.88" y2="50.8" width="0.1524" layer="91"/>
<wire x1="55.88" y1="50.8" x2="55.88" y2="60.96" width="0.1524" layer="91"/>
<wire x1="55.88" y1="60.96" x2="50.8" y2="60.96" width="0.1524" layer="91"/>
<pinref part="VDD4" gate="G$1" pin="VDD"/>
</segment>
<segment>
<pinref part="IC5" gate="1" pin="VS"/>
<wire x1="160.02" y1="71.12" x2="160.02" y2="68.58" width="0.1524" layer="91"/>
<wire x1="160.02" y1="68.58" x2="157.48" y2="68.58" width="0.1524" layer="91"/>
<pinref part="VDD5" gate="G$1" pin="VDD"/>
</segment>
<segment>
<pinref part="IC6" gate="1" pin="VS"/>
<wire x1="160.02" y1="27.94" x2="160.02" y2="25.4" width="0.1524" layer="91"/>
<wire x1="160.02" y1="25.4" x2="157.48" y2="25.4" width="0.1524" layer="91"/>
<pinref part="VDD6" gate="G$1" pin="VDD"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="VDD@1"/>
<wire x1="99.06" y1="101.6" x2="99.06" y2="119.38" width="0.1524" layer="91"/>
<pinref part="C3" gate="G$1" pin="2"/>
<wire x1="99.06" y1="119.38" x2="88.9" y2="119.38" width="0.1524" layer="91"/>
<pinref part="VDD2" gate="G$1" pin="VDD"/>
<wire x1="78.74" y1="119.38" x2="88.9" y2="119.38" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="VDD"/>
<wire x1="101.6" y1="101.6" x2="101.6" y2="119.38" width="0.1524" layer="91"/>
<pinref part="C4" gate="G$1" pin="2"/>
<wire x1="101.6" y1="119.38" x2="109.22" y2="119.38" width="0.1524" layer="91"/>
<pinref part="VDD7" gate="G$1" pin="VDD"/>
<wire x1="116.84" y1="119.38" x2="109.22" y2="119.38" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="VDD8" gate="G$1" pin="VDD"/>
<wire x1="-15.24" y1="71.12" x2="-15.24" y2="66.04" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="1"/>
<wire x1="-15.24" y1="66.04" x2="-12.7" y2="66.04" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="R3" gate="G$1" pin="2"/>
<pinref part="VDD9" gate="G$1" pin="VDD"/>
<wire x1="78.74" y1="127" x2="88.9" y2="127" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<pinref part="IC1" gate="A1" pin="GND"/>
<wire x1="-68.58" y1="81.28" x2="-68.58" y2="73.66" width="0.1524" layer="91"/>
<wire x1="-93.98" y1="83.82" x2="-93.98" y2="73.66" width="0.1524" layer="91"/>
<wire x1="-93.98" y1="73.66" x2="-81.28" y2="73.66" width="0.1524" layer="91"/>
<pinref part="C2" gate="G$1" pin="2"/>
<wire x1="-81.28" y1="73.66" x2="-68.58" y2="73.66" width="0.1524" layer="91"/>
<wire x1="-68.58" y1="73.66" x2="-55.88" y2="73.66" width="0.1524" layer="91"/>
<wire x1="-55.88" y1="73.66" x2="-55.88" y2="76.2" width="0.1524" layer="91"/>
<pinref part="C1" gate="G$1" pin="2"/>
<wire x1="-81.28" y1="76.2" x2="-81.28" y2="73.66" width="0.1524" layer="91"/>
<junction x="-81.28" y="73.66"/>
<junction x="-68.58" y="73.66"/>
<wire x1="-68.58" y1="73.66" x2="-68.58" y2="63.5" width="0.1524" layer="91"/>
<pinref part="GND1" gate="1" pin="GND"/>
<pinref part="POWER" gate="-2" pin="S"/>
<wire x1="-104.14" y1="83.82" x2="-93.98" y2="83.82" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC3" gate="1" pin="GND"/>
<wire x1="27.94" y1="91.44" x2="22.86" y2="91.44" width="0.1524" layer="91"/>
<wire x1="22.86" y1="91.44" x2="22.86" y2="101.6" width="0.1524" layer="91"/>
<wire x1="22.86" y1="101.6" x2="33.02" y2="101.6" width="0.1524" layer="91"/>
<pinref part="GND3" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="IC4" gate="1" pin="GND"/>
<wire x1="27.94" y1="50.8" x2="20.32" y2="50.8" width="0.1524" layer="91"/>
<wire x1="20.32" y1="50.8" x2="20.32" y2="60.96" width="0.1524" layer="91"/>
<wire x1="20.32" y1="60.96" x2="33.02" y2="60.96" width="0.1524" layer="91"/>
<pinref part="GND4" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="IC5" gate="1" pin="GND"/>
<wire x1="185.42" y1="71.12" x2="190.5" y2="71.12" width="0.1524" layer="91"/>
<wire x1="190.5" y1="71.12" x2="190.5" y2="66.04" width="0.1524" layer="91"/>
<pinref part="GND5" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="IC6" gate="1" pin="GND"/>
<wire x1="185.42" y1="27.94" x2="190.5" y2="27.94" width="0.1524" layer="91"/>
<wire x1="190.5" y1="27.94" x2="190.5" y2="22.86" width="0.1524" layer="91"/>
<pinref part="GND6" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="SV9" gate="G$1" pin="3"/>
<wire x1="246.38" y1="127" x2="246.38" y2="109.22" width="0.1524" layer="91"/>
<wire x1="246.38" y1="109.22" x2="246.38" y2="91.44" width="0.1524" layer="91"/>
<wire x1="246.38" y1="91.44" x2="246.38" y2="73.66" width="0.1524" layer="91"/>
<wire x1="246.38" y1="73.66" x2="246.38" y2="35.56" width="0.1524" layer="91"/>
<wire x1="246.38" y1="35.56" x2="246.38" y2="17.78" width="0.1524" layer="91"/>
<wire x1="246.38" y1="17.78" x2="246.38" y2="0" width="0.1524" layer="91"/>
<wire x1="246.38" y1="0" x2="246.38" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="246.38" y1="-17.78" x2="246.38" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="231.14" y1="134.62" x2="228.6" y2="134.62" width="0.1524" layer="91"/>
<wire x1="228.6" y1="134.62" x2="228.6" y2="127" width="0.1524" layer="91"/>
<wire x1="228.6" y1="127" x2="246.38" y2="127" width="0.1524" layer="91"/>
<pinref part="SV10" gate="G$1" pin="3"/>
<wire x1="231.14" y1="116.84" x2="228.6" y2="116.84" width="0.1524" layer="91"/>
<wire x1="228.6" y1="116.84" x2="228.6" y2="109.22" width="0.1524" layer="91"/>
<wire x1="228.6" y1="109.22" x2="246.38" y2="109.22" width="0.1524" layer="91"/>
<pinref part="SV11" gate="G$1" pin="3"/>
<wire x1="231.14" y1="99.06" x2="228.6" y2="99.06" width="0.1524" layer="91"/>
<wire x1="228.6" y1="99.06" x2="228.6" y2="91.44" width="0.1524" layer="91"/>
<wire x1="228.6" y1="91.44" x2="246.38" y2="91.44" width="0.1524" layer="91"/>
<pinref part="SV12" gate="G$1" pin="3"/>
<wire x1="231.14" y1="81.28" x2="228.6" y2="81.28" width="0.1524" layer="91"/>
<wire x1="228.6" y1="81.28" x2="228.6" y2="73.66" width="0.1524" layer="91"/>
<wire x1="228.6" y1="73.66" x2="246.38" y2="73.66" width="0.1524" layer="91"/>
<pinref part="SV13" gate="G$1" pin="3"/>
<wire x1="231.14" y1="43.18" x2="228.6" y2="43.18" width="0.1524" layer="91"/>
<wire x1="228.6" y1="43.18" x2="228.6" y2="35.56" width="0.1524" layer="91"/>
<wire x1="228.6" y1="35.56" x2="246.38" y2="35.56" width="0.1524" layer="91"/>
<pinref part="SV14" gate="G$1" pin="3"/>
<wire x1="231.14" y1="25.4" x2="228.6" y2="25.4" width="0.1524" layer="91"/>
<wire x1="228.6" y1="25.4" x2="228.6" y2="17.78" width="0.1524" layer="91"/>
<wire x1="228.6" y1="17.78" x2="246.38" y2="17.78" width="0.1524" layer="91"/>
<pinref part="SV15" gate="G$1" pin="3"/>
<wire x1="231.14" y1="7.62" x2="228.6" y2="7.62" width="0.1524" layer="91"/>
<wire x1="228.6" y1="7.62" x2="228.6" y2="0" width="0.1524" layer="91"/>
<wire x1="228.6" y1="0" x2="246.38" y2="0" width="0.1524" layer="91"/>
<pinref part="SV16" gate="G$1" pin="3"/>
<wire x1="231.14" y1="-10.16" x2="228.6" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="228.6" y1="-10.16" x2="228.6" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="228.6" y1="-17.78" x2="246.38" y2="-17.78" width="0.1524" layer="91"/>
<junction x="246.38" y="73.66"/>
<junction x="246.38" y="35.56"/>
<junction x="246.38" y="17.78"/>
<junction x="246.38" y="0"/>
<junction x="246.38" y="-17.78"/>
<junction x="246.38" y="109.22"/>
<junction x="246.38" y="91.44"/>
<pinref part="GND7" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="SV1" gate="G$1" pin="1"/>
<wire x1="-2.54" y1="134.62" x2="0" y2="134.62" width="0.1524" layer="91"/>
<wire x1="0" y1="134.62" x2="0" y2="129.54" width="0.1524" layer="91"/>
<wire x1="0" y1="129.54" x2="-20.32" y2="129.54" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="129.54" x2="-20.32" y2="114.3" width="0.1524" layer="91"/>
<pinref part="SV2" gate="G$1" pin="1"/>
<wire x1="-20.32" y1="114.3" x2="-20.32" y2="99.06" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="99.06" x2="-20.32" y2="81.28" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="81.28" x2="-20.32" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="53.34" x2="-20.32" y2="38.1" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="38.1" x2="-20.32" y2="22.86" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="22.86" x2="-20.32" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="5.08" x2="-20.32" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="-20.32" y1="-12.7" x2="-20.32" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="119.38" x2="0" y2="119.38" width="0.1524" layer="91"/>
<wire x1="0" y1="119.38" x2="0" y2="114.3" width="0.1524" layer="91"/>
<wire x1="0" y1="114.3" x2="-20.32" y2="114.3" width="0.1524" layer="91"/>
<pinref part="SV3" gate="G$1" pin="1"/>
<wire x1="-2.54" y1="104.14" x2="0" y2="104.14" width="0.1524" layer="91"/>
<wire x1="0" y1="104.14" x2="0" y2="99.06" width="0.1524" layer="91"/>
<wire x1="0" y1="99.06" x2="-20.32" y2="99.06" width="0.1524" layer="91"/>
<pinref part="SV4" gate="G$1" pin="1"/>
<wire x1="-2.54" y1="88.9" x2="0" y2="88.9" width="0.1524" layer="91"/>
<wire x1="0" y1="88.9" x2="0" y2="81.28" width="0.1524" layer="91"/>
<wire x1="0" y1="81.28" x2="-20.32" y2="81.28" width="0.1524" layer="91"/>
<pinref part="SV5" gate="G$1" pin="1"/>
<wire x1="-2.54" y1="43.18" x2="0" y2="43.18" width="0.1524" layer="91"/>
<wire x1="0" y1="43.18" x2="0" y2="38.1" width="0.1524" layer="91"/>
<wire x1="0" y1="38.1" x2="-20.32" y2="38.1" width="0.1524" layer="91"/>
<pinref part="SV6" gate="G$1" pin="1"/>
<wire x1="-2.54" y1="27.94" x2="0" y2="27.94" width="0.1524" layer="91"/>
<wire x1="0" y1="27.94" x2="0" y2="22.86" width="0.1524" layer="91"/>
<wire x1="0" y1="22.86" x2="-20.32" y2="22.86" width="0.1524" layer="91"/>
<pinref part="SV7" gate="G$1" pin="1"/>
<wire x1="-2.54" y1="12.7" x2="0" y2="12.7" width="0.1524" layer="91"/>
<wire x1="0" y1="12.7" x2="0" y2="5.08" width="0.1524" layer="91"/>
<wire x1="0" y1="5.08" x2="-20.32" y2="5.08" width="0.1524" layer="91"/>
<pinref part="SV8" gate="G$1" pin="1"/>
<wire x1="-2.54" y1="-5.08" x2="0" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="0" y1="-5.08" x2="0" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="0" y1="-12.7" x2="-20.32" y2="-12.7" width="0.1524" layer="91"/>
<junction x="-20.32" y="38.1"/>
<junction x="-20.32" y="22.86"/>
<junction x="-20.32" y="5.08"/>
<junction x="-20.32" y="-12.7"/>
<junction x="-20.32" y="114.3"/>
<junction x="-20.32" y="99.06"/>
<junction x="-20.32" y="81.28"/>
<pinref part="GND8" gate="1" pin="GND"/>
<wire x1="-20.32" y1="53.34" x2="-5.08" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-5.08" y1="53.34" x2="-5.08" y2="55.88" width="0.1524" layer="91"/>
<pinref part="KAPCSOLO_CSATI" gate="-2" pin="S"/>
<wire x1="-5.08" y1="55.88" x2="-10.16" y2="55.88" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND9" gate="1" pin="GND"/>
<wire x1="96.52" y1="25.4" x2="96.52" y2="33.02" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="VSS@1"/>
<wire x1="96.52" y1="33.02" x2="99.06" y2="33.02" width="0.1524" layer="91"/>
<wire x1="99.06" y1="33.02" x2="99.06" y2="38.1" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="VSS"/>
<wire x1="101.6" y1="38.1" x2="101.6" y2="33.02" width="0.1524" layer="91"/>
<wire x1="101.6" y1="33.02" x2="104.14" y2="33.02" width="0.1524" layer="91"/>
<wire x1="104.14" y1="33.02" x2="104.14" y2="25.4" width="0.1524" layer="91"/>
<pinref part="GND2" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="C4" gate="G$1" pin="1"/>
<wire x1="109.22" y1="111.76" x2="109.22" y2="109.22" width="0.1524" layer="91"/>
<pinref part="GND10" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="C3" gate="G$1" pin="1"/>
<wire x1="88.9" y1="111.76" x2="88.9" y2="109.22" width="0.1524" layer="91"/>
<pinref part="GND11" gate="1" pin="GND"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<pinref part="IC3" gate="1" pin="O8"/>
<wire x1="27.94" y1="88.9" x2="20.32" y2="88.9" width="0.1524" layer="91"/>
<wire x1="20.32" y1="88.9" x2="20.32" y2="139.7" width="0.1524" layer="91"/>
<pinref part="SV1" gate="G$1" pin="3"/>
<wire x1="20.32" y1="139.7" x2="-2.54" y2="139.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$36" class="0">
<segment>
<pinref part="SV1" gate="G$1" pin="2"/>
<wire x1="-2.54" y1="137.16" x2="17.78" y2="137.16" width="0.1524" layer="91"/>
<wire x1="17.78" y1="137.16" x2="17.78" y2="86.36" width="0.1524" layer="91"/>
<pinref part="IC3" gate="1" pin="O7"/>
<wire x1="17.78" y1="86.36" x2="27.94" y2="86.36" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$37" class="0">
<segment>
<pinref part="IC3" gate="1" pin="O6"/>
<wire x1="27.94" y1="83.82" x2="15.24" y2="83.82" width="0.1524" layer="91"/>
<wire x1="15.24" y1="83.82" x2="15.24" y2="124.46" width="0.1524" layer="91"/>
<pinref part="SV2" gate="G$1" pin="3"/>
<wire x1="15.24" y1="124.46" x2="-2.54" y2="124.46" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$38" class="0">
<segment>
<pinref part="SV2" gate="G$1" pin="2"/>
<wire x1="-2.54" y1="121.92" x2="12.7" y2="121.92" width="0.1524" layer="91"/>
<wire x1="12.7" y1="121.92" x2="12.7" y2="81.28" width="0.1524" layer="91"/>
<pinref part="IC3" gate="1" pin="O5"/>
<wire x1="12.7" y1="81.28" x2="27.94" y2="81.28" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$39" class="0">
<segment>
<pinref part="IC3" gate="1" pin="O4"/>
<wire x1="27.94" y1="78.74" x2="10.16" y2="78.74" width="0.1524" layer="91"/>
<wire x1="10.16" y1="78.74" x2="10.16" y2="109.22" width="0.1524" layer="91"/>
<pinref part="SV3" gate="G$1" pin="3"/>
<wire x1="10.16" y1="109.22" x2="-2.54" y2="109.22" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$40" class="0">
<segment>
<pinref part="SV3" gate="G$1" pin="2"/>
<wire x1="-2.54" y1="106.68" x2="7.62" y2="106.68" width="0.1524" layer="91"/>
<wire x1="7.62" y1="106.68" x2="7.62" y2="76.2" width="0.1524" layer="91"/>
<pinref part="IC3" gate="1" pin="O3"/>
<wire x1="7.62" y1="76.2" x2="27.94" y2="76.2" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$43" class="0">
<segment>
<pinref part="IC4" gate="1" pin="O8"/>
<pinref part="SV5" gate="G$1" pin="3"/>
<wire x1="27.94" y1="48.26" x2="-2.54" y2="48.26" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$44" class="0">
<segment>
<pinref part="SV5" gate="G$1" pin="2"/>
<pinref part="IC4" gate="1" pin="O7"/>
<wire x1="-2.54" y1="45.72" x2="27.94" y2="45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$45" class="0">
<segment>
<pinref part="IC4" gate="1" pin="O1"/>
<wire x1="27.94" y1="30.48" x2="25.4" y2="30.48" width="0.1524" layer="91"/>
<wire x1="25.4" y1="30.48" x2="25.4" y2="-2.54" width="0.1524" layer="91"/>
<pinref part="SV8" gate="G$1" pin="2"/>
<wire x1="25.4" y1="-2.54" x2="-2.54" y2="-2.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$46" class="0">
<segment>
<pinref part="SV8" gate="G$1" pin="3"/>
<wire x1="-2.54" y1="0" x2="22.86" y2="0" width="0.1524" layer="91"/>
<wire x1="22.86" y1="0" x2="22.86" y2="33.02" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="O2"/>
<wire x1="22.86" y1="33.02" x2="27.94" y2="33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$47" class="0">
<segment>
<pinref part="IC4" gate="1" pin="O3"/>
<wire x1="27.94" y1="35.56" x2="20.32" y2="35.56" width="0.1524" layer="91"/>
<wire x1="20.32" y1="35.56" x2="20.32" y2="15.24" width="0.1524" layer="91"/>
<pinref part="SV7" gate="G$1" pin="2"/>
<wire x1="20.32" y1="15.24" x2="-2.54" y2="15.24" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$48" class="0">
<segment>
<pinref part="SV7" gate="G$1" pin="3"/>
<wire x1="-2.54" y1="17.78" x2="17.78" y2="17.78" width="0.1524" layer="91"/>
<wire x1="17.78" y1="17.78" x2="17.78" y2="38.1" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="O4"/>
<wire x1="17.78" y1="38.1" x2="27.94" y2="38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$49" class="0">
<segment>
<pinref part="SV6" gate="G$1" pin="2"/>
<wire x1="-2.54" y1="30.48" x2="15.24" y2="30.48" width="0.1524" layer="91"/>
<wire x1="15.24" y1="30.48" x2="15.24" y2="40.64" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="O5"/>
<wire x1="15.24" y1="40.64" x2="27.94" y2="40.64" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$50" class="0">
<segment>
<pinref part="SV6" gate="G$1" pin="3"/>
<wire x1="-2.54" y1="33.02" x2="12.7" y2="33.02" width="0.1524" layer="91"/>
<wire x1="12.7" y1="33.02" x2="12.7" y2="43.18" width="0.1524" layer="91"/>
<pinref part="IC4" gate="1" pin="O6"/>
<wire x1="12.7" y1="43.18" x2="27.94" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$41" class="0">
<segment>
<pinref part="SV4" gate="G$1" pin="3"/>
<wire x1="-2.54" y1="93.98" x2="5.08" y2="93.98" width="0.1524" layer="91"/>
<wire x1="5.08" y1="93.98" x2="5.08" y2="73.66" width="0.1524" layer="91"/>
<pinref part="IC3" gate="1" pin="O2"/>
<wire x1="5.08" y1="73.66" x2="27.94" y2="73.66" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$42" class="0">
<segment>
<pinref part="IC3" gate="1" pin="O1"/>
<wire x1="27.94" y1="71.12" x2="2.54" y2="71.12" width="0.1524" layer="91"/>
<wire x1="2.54" y1="71.12" x2="2.54" y2="91.44" width="0.1524" layer="91"/>
<pinref part="SV4" gate="G$1" pin="2"/>
<wire x1="2.54" y1="91.44" x2="-2.54" y2="91.44" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$51" class="0">
<segment>
<pinref part="IC5" gate="1" pin="O1"/>
<wire x1="185.42" y1="91.44" x2="187.96" y2="91.44" width="0.1524" layer="91"/>
<wire x1="187.96" y1="91.44" x2="187.96" y2="139.7" width="0.1524" layer="91"/>
<pinref part="SV9" gate="G$1" pin="1"/>
<wire x1="187.96" y1="139.7" x2="231.14" y2="139.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$52" class="0">
<segment>
<pinref part="SV9" gate="G$1" pin="2"/>
<wire x1="231.14" y1="137.16" x2="190.5" y2="137.16" width="0.1524" layer="91"/>
<wire x1="190.5" y1="137.16" x2="190.5" y2="88.9" width="0.1524" layer="91"/>
<pinref part="IC5" gate="1" pin="O2"/>
<wire x1="190.5" y1="88.9" x2="185.42" y2="88.9" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$53" class="0">
<segment>
<pinref part="IC5" gate="1" pin="O3"/>
<wire x1="185.42" y1="86.36" x2="193.04" y2="86.36" width="0.1524" layer="91"/>
<wire x1="193.04" y1="86.36" x2="193.04" y2="121.92" width="0.1524" layer="91"/>
<pinref part="SV10" gate="G$1" pin="1"/>
<wire x1="193.04" y1="121.92" x2="231.14" y2="121.92" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$54" class="0">
<segment>
<pinref part="SV10" gate="G$1" pin="2"/>
<wire x1="231.14" y1="119.38" x2="195.58" y2="119.38" width="0.1524" layer="91"/>
<wire x1="195.58" y1="119.38" x2="195.58" y2="83.82" width="0.1524" layer="91"/>
<pinref part="IC5" gate="1" pin="O4"/>
<wire x1="195.58" y1="83.82" x2="185.42" y2="83.82" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$57" class="0">
<segment>
<pinref part="IC5" gate="1" pin="O7"/>
<wire x1="185.42" y1="76.2" x2="203.2" y2="76.2" width="0.1524" layer="91"/>
<wire x1="203.2" y1="76.2" x2="203.2" y2="86.36" width="0.1524" layer="91"/>
<pinref part="SV12" gate="G$1" pin="1"/>
<wire x1="203.2" y1="86.36" x2="231.14" y2="86.36" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$58" class="0">
<segment>
<pinref part="SV12" gate="G$1" pin="2"/>
<wire x1="231.14" y1="83.82" x2="205.74" y2="83.82" width="0.1524" layer="91"/>
<wire x1="205.74" y1="83.82" x2="205.74" y2="73.66" width="0.1524" layer="91"/>
<pinref part="IC5" gate="1" pin="O8"/>
<wire x1="205.74" y1="73.66" x2="185.42" y2="73.66" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$59" class="0">
<segment>
<pinref part="IC6" gate="1" pin="O1"/>
<pinref part="SV13" gate="G$1" pin="1"/>
<wire x1="185.42" y1="48.26" x2="231.14" y2="48.26" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$60" class="0">
<segment>
<pinref part="IC6" gate="1" pin="O2"/>
<pinref part="SV13" gate="G$1" pin="2"/>
<wire x1="185.42" y1="45.72" x2="231.14" y2="45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$61" class="0">
<segment>
<pinref part="IC6" gate="1" pin="O8"/>
<wire x1="185.42" y1="30.48" x2="195.58" y2="30.48" width="0.1524" layer="91"/>
<wire x1="195.58" y1="30.48" x2="195.58" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="SV16" gate="G$1" pin="2"/>
<wire x1="195.58" y1="-7.62" x2="231.14" y2="-7.62" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$62" class="0">
<segment>
<pinref part="IC6" gate="1" pin="O7"/>
<wire x1="185.42" y1="33.02" x2="198.12" y2="33.02" width="0.1524" layer="91"/>
<wire x1="198.12" y1="33.02" x2="198.12" y2="-5.08" width="0.1524" layer="91"/>
<pinref part="SV16" gate="G$1" pin="1"/>
<wire x1="198.12" y1="-5.08" x2="231.14" y2="-5.08" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$63" class="0">
<segment>
<pinref part="IC6" gate="1" pin="O6"/>
<wire x1="185.42" y1="35.56" x2="200.66" y2="35.56" width="0.1524" layer="91"/>
<wire x1="200.66" y1="35.56" x2="200.66" y2="10.16" width="0.1524" layer="91"/>
<pinref part="SV15" gate="G$1" pin="2"/>
<wire x1="200.66" y1="10.16" x2="231.14" y2="10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$64" class="0">
<segment>
<pinref part="IC6" gate="1" pin="O5"/>
<wire x1="185.42" y1="38.1" x2="203.2" y2="38.1" width="0.1524" layer="91"/>
<wire x1="203.2" y1="38.1" x2="203.2" y2="12.7" width="0.1524" layer="91"/>
<pinref part="SV15" gate="G$1" pin="1"/>
<wire x1="203.2" y1="12.7" x2="231.14" y2="12.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$65" class="0">
<segment>
<pinref part="IC6" gate="1" pin="O4"/>
<wire x1="185.42" y1="40.64" x2="205.74" y2="40.64" width="0.1524" layer="91"/>
<wire x1="205.74" y1="40.64" x2="205.74" y2="27.94" width="0.1524" layer="91"/>
<pinref part="SV14" gate="G$1" pin="2"/>
<wire x1="205.74" y1="27.94" x2="231.14" y2="27.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$66" class="0">
<segment>
<pinref part="IC6" gate="1" pin="O3"/>
<wire x1="185.42" y1="43.18" x2="208.28" y2="43.18" width="0.1524" layer="91"/>
<wire x1="208.28" y1="43.18" x2="208.28" y2="30.48" width="0.1524" layer="91"/>
<pinref part="SV14" gate="G$1" pin="1"/>
<wire x1="208.28" y1="30.48" x2="231.14" y2="30.48" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$55" class="0">
<segment>
<pinref part="IC5" gate="1" pin="O5"/>
<wire x1="185.42" y1="81.28" x2="198.12" y2="81.28" width="0.1524" layer="91"/>
<wire x1="198.12" y1="81.28" x2="198.12" y2="104.14" width="0.1524" layer="91"/>
<pinref part="SV11" gate="G$1" pin="1"/>
<wire x1="198.12" y1="104.14" x2="231.14" y2="104.14" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$56" class="0">
<segment>
<pinref part="SV11" gate="G$1" pin="2"/>
<wire x1="231.14" y1="101.6" x2="200.66" y2="101.6" width="0.1524" layer="91"/>
<wire x1="200.66" y1="101.6" x2="200.66" y2="78.74" width="0.1524" layer="91"/>
<pinref part="IC5" gate="1" pin="O6"/>
<wire x1="200.66" y1="78.74" x2="185.42" y2="78.74" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$67" class="0">
<segment>
<pinref part="IC5" gate="1" pin="I8"/>
<pinref part="IC2" gate="G$1" pin="INT/RB0"/>
<wire x1="121.92" y1="73.66" x2="160.02" y2="73.66" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RB5"/>
<pinref part="IC5" gate="1" pin="I3"/>
<wire x1="121.92" y1="86.36" x2="160.02" y2="86.36" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="IC5" gate="1" pin="I5"/>
<pinref part="IC2" gate="G$1" pin="PGM/RB3"/>
<wire x1="160.02" y1="81.28" x2="121.92" y2="81.28" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="RE2/!CS/AN7"/>
<wire x1="78.74" y1="68.58" x2="60.96" y2="68.58" width="0.1524" layer="91"/>
<wire x1="60.96" y1="68.58" x2="60.96" y2="66.04" width="0.1524" layer="91"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="25.4" y1="66.04" x2="60.96" y2="66.04" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$68" class="0">
<segment>
<pinref part="R1" gate="G$1" pin="1"/>
<wire x1="2.54" y1="60.96" x2="2.54" y2="66.04" width="0.1524" layer="91"/>
<wire x1="2.54" y1="66.04" x2="15.24" y2="66.04" width="0.1524" layer="91"/>
<wire x1="2.54" y1="66.04" x2="-2.54" y2="66.04" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="2"/>
<pinref part="KAPCSOLO_CSATI" gate="-1" pin="S"/>
<wire x1="-10.16" y1="60.96" x2="2.54" y2="60.96" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$69" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="!MCLR/THV"/>
<wire x1="78.74" y1="93.98" x2="60.96" y2="93.98" width="0.1524" layer="91"/>
<wire x1="60.96" y1="93.98" x2="60.96" y2="127" width="0.1524" layer="91"/>
<pinref part="R3" gate="G$1" pin="1"/>
<wire x1="60.96" y1="127" x2="68.58" y2="127" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
