<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="mm" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="modul">
<packages>
<package name="MODUL">
<wire x1="-11.25" y1="-11.56" x2="-11.25" y2="11.56" width="0.254" layer="21"/>
<wire x1="-11.25" y1="11.56" x2="-14.15" y2="11.56" width="0.254" layer="21"/>
<wire x1="-14.15" y1="11.56" x2="-14.15" y2="-11.56" width="0.254" layer="21"/>
<wire x1="-14.15" y1="-11.56" x2="-11.25" y2="-11.56" width="0.254" layer="21"/>
<wire x1="-13.8" y1="-11.45" x2="-13.8" y2="11.45" width="0.1524" layer="21"/>
<wire x1="-12.192" y1="-10.795" x2="-13.335" y2="-9.652" width="0.1524" layer="51"/>
<wire x1="-12.446" y1="-8.382" x2="-12.827" y2="-6.858" width="0.1524" layer="51"/>
<wire x1="-13.335" y1="-5.588" x2="-12.065" y2="-4.572" width="0.1524" layer="51"/>
<wire x1="-13.081" y1="-3.302" x2="-12.319" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-13.335" y1="-0.508" x2="-12.065" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-13.081" y1="1.778" x2="-12.319" y2="3.302" width="0.1524" layer="51"/>
<wire x1="-13.335" y1="4.572" x2="-12.065" y2="5.588" width="0.1524" layer="51"/>
<wire x1="-12.192" y1="6.985" x2="-13.335" y2="8.128" width="0.1524" layer="51"/>
<wire x1="-12.192" y1="9.525" x2="-13.335" y2="10.668" width="0.1524" layer="51"/>
<circle x="-12.7" y="-10.16" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="-7.62" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="-5.08" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="-2.54" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="2.54" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="5.08" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="7.62" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="10.16" radius="0.889" width="0.1524" layer="51"/>
<pad name="1" x="-12.7" y="-10.16" drill="1.2" shape="long" rot="R180"/>
<pad name="2" x="-12.7" y="-7.62" drill="1.2" shape="long" rot="R180"/>
<pad name="3" x="-12.7" y="-5.08" drill="1.2" shape="long" rot="R180"/>
<pad name="4" x="-12.7" y="-2.54" drill="1.2" shape="long" rot="R180"/>
<pad name="5" x="-12.7" y="0" drill="1.2" shape="long" rot="R180"/>
<pad name="6" x="-12.7" y="2.54" drill="1.2" shape="long" rot="R180"/>
<pad name="7" x="-12.7" y="5.08" drill="1.2" shape="long" rot="R180"/>
<pad name="8" x="-12.7" y="7.62" drill="1.2" shape="long" rot="R180"/>
<pad name="9" x="-12.7" y="10.16" drill="1.2" shape="long" rot="R180"/>
<wire x1="14.15" y1="-11.56" x2="14.15" y2="11.56" width="0.254" layer="21"/>
<wire x1="14.15" y1="11.56" x2="11.25" y2="11.56" width="0.254" layer="21"/>
<wire x1="11.25" y1="11.56" x2="11.25" y2="-11.56" width="0.254" layer="21"/>
<wire x1="11.25" y1="-11.56" x2="14.15" y2="-11.56" width="0.254" layer="21"/>
<wire x1="11.6" y1="-11.45" x2="11.6" y2="11.45" width="0.1524" layer="21"/>
<wire x1="13.208" y1="-10.795" x2="12.065" y2="-9.652" width="0.1524" layer="51"/>
<wire x1="12.954" y1="-8.382" x2="12.573" y2="-6.858" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-5.588" x2="13.335" y2="-4.572" width="0.1524" layer="51"/>
<wire x1="12.319" y1="-3.302" x2="13.081" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-0.508" x2="13.335" y2="0.508" width="0.1524" layer="51"/>
<wire x1="12.319" y1="1.778" x2="13.081" y2="3.302" width="0.1524" layer="51"/>
<wire x1="12.065" y1="4.572" x2="13.335" y2="5.588" width="0.1524" layer="51"/>
<wire x1="13.208" y1="6.985" x2="12.065" y2="8.128" width="0.1524" layer="51"/>
<wire x1="13.208" y1="9.525" x2="12.065" y2="10.668" width="0.1524" layer="51"/>
<circle x="12.7" y="-10.16" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="-7.62" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="-5.08" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="-2.54" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="2.54" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="5.08" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="7.62" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="10.16" radius="0.889" width="0.1524" layer="51"/>
<pad name="10" x="12.7" y="-10.16" drill="1.2" shape="long" rot="R180"/>
<pad name="11" x="12.7" y="-7.62" drill="1.2" shape="long" rot="R180"/>
<pad name="12" x="12.7" y="-5.08" drill="1.2" shape="long" rot="R180"/>
<pad name="13" x="12.7" y="-2.54" drill="1.2" shape="long" rot="R180"/>
<pad name="14" x="12.7" y="0" drill="1.2" shape="long" rot="R180"/>
<pad name="15" x="12.7" y="2.54" drill="1.2" shape="long" rot="R180"/>
<pad name="16" x="12.7" y="5.08" drill="1.2" shape="long" rot="R180"/>
<pad name="17" x="12.7" y="7.62" drill="1.2" shape="long" rot="R180"/>
<pad name="18" x="12.7" y="10.16" drill="1.2" shape="long" rot="R180"/>
<wire x1="-7.75" y1="12.52" x2="-2.41" y2="12.52" width="0.254" layer="21"/>
<wire x1="-2.41" y1="12.52" x2="-2.41" y2="15.42" width="0.254" layer="21"/>
<wire x1="-2.41" y1="15.42" x2="-7.75" y2="15.42" width="0.254" layer="21"/>
<wire x1="-7.75" y1="15.42" x2="-7.75" y2="12.52" width="0.254" layer="21"/>
<wire x1="-7.64" y1="15.07" x2="-2.52" y2="15.07" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="13.462" x2="-5.842" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-4.572" y1="13.716" x2="-3.048" y2="14.097" width="0.1524" layer="51"/>
<circle x="-6.35" y="13.97" radius="0.889" width="0.1524" layer="51"/>
<circle x="-3.81" y="13.97" radius="0.889" width="0.1524" layer="51"/>
<pad name="19" x="-6.35" y="13.97" drill="1.2" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="13.97" drill="1.2" shape="long" rot="R90"/>
<wire x1="2.41" y1="12.52" x2="7.75" y2="12.52" width="0.254" layer="21"/>
<wire x1="7.75" y1="12.52" x2="7.75" y2="15.42" width="0.254" layer="21"/>
<wire x1="7.75" y1="15.42" x2="2.41" y2="15.42" width="0.254" layer="21"/>
<wire x1="2.41" y1="15.42" x2="2.41" y2="12.52" width="0.254" layer="21"/>
<wire x1="2.52" y1="15.07" x2="7.64" y2="15.07" width="0.1524" layer="21"/>
<wire x1="3.175" y1="13.462" x2="4.318" y2="14.605" width="0.1524" layer="51"/>
<wire x1="5.588" y1="13.716" x2="7.112" y2="14.097" width="0.1524" layer="51"/>
<circle x="3.81" y="13.97" radius="0.889" width="0.1524" layer="51"/>
<circle x="6.35" y="13.97" radius="0.889" width="0.1524" layer="51"/>
<pad name="21" x="3.81" y="13.97" drill="1.2" shape="long" rot="R90"/>
<pad name="22" x="6.35" y="13.97" drill="1.2" shape="long" rot="R90"/>
<wire x1="-6.545" y1="-3.25" x2="-2.345" y2="-3.25" width="0.254" layer="21"/>
<wire x1="-2.345" y1="-3.25" x2="-2.345" y2="3.25" width="0.254" layer="21"/>
<wire x1="-2.345" y1="3.25" x2="-6.545" y2="3.25" width="0.254" layer="21"/>
<wire x1="-6.545" y1="3.25" x2="-6.545" y2="-3.25" width="0.254" layer="21"/>
<circle x="-5.745" y="2.5" radius="0.1581" width="0.254" layer="21"/>
<rectangle x1="-7.27" y1="2.375" x2="-7.02" y2="3.475" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="1.725" x2="-7.02" y2="2.825" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="1.075" x2="-7.02" y2="2.175" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="0.425" x2="-7.02" y2="1.525" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-0.225" x2="-7.02" y2="0.875" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-0.875" x2="-7.02" y2="0.225" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-1.525" x2="-7.02" y2="-0.425" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-2.175" x2="-7.02" y2="-1.075" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-2.825" x2="-7.02" y2="-1.725" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-3.475" x2="-7.02" y2="-2.375" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-3.475" x2="-1.62" y2="-2.375" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-2.825" x2="-1.62" y2="-1.725" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-2.175" x2="-1.62" y2="-1.075" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-1.525" x2="-1.62" y2="-0.425" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-0.875" x2="-1.62" y2="0.225" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-0.225" x2="-1.62" y2="0.875" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="0.425" x2="-1.62" y2="1.525" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="1.075" x2="-1.62" y2="2.175" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="1.725" x2="-1.62" y2="2.825" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="2.375" x2="-1.62" y2="3.475" layer="51" rot="R270"/>
<wire x1="2.345" y1="-3.25" x2="6.545" y2="-3.25" width="0.254" layer="21"/>
<wire x1="6.545" y1="-3.25" x2="6.545" y2="3.25" width="0.254" layer="21"/>
<wire x1="6.545" y1="3.25" x2="2.345" y2="3.25" width="0.254" layer="21"/>
<wire x1="2.345" y1="3.25" x2="2.345" y2="-3.25" width="0.254" layer="21"/>
<circle x="3.145" y="2.5" radius="0.1581" width="0.254" layer="21"/>
<rectangle x1="1.62" y1="2.375" x2="1.87" y2="3.475" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="1.725" x2="1.87" y2="2.825" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="1.075" x2="1.87" y2="2.175" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="0.425" x2="1.87" y2="1.525" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-0.225" x2="1.87" y2="0.875" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-0.875" x2="1.87" y2="0.225" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-1.525" x2="1.87" y2="-0.425" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-2.175" x2="1.87" y2="-1.075" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-2.825" x2="1.87" y2="-1.725" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-3.475" x2="1.87" y2="-2.375" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-3.475" x2="7.27" y2="-2.375" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-2.825" x2="7.27" y2="-1.725" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-2.175" x2="7.27" y2="-1.075" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-1.525" x2="7.27" y2="-0.425" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-0.875" x2="7.27" y2="0.225" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-0.225" x2="7.27" y2="0.875" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="0.425" x2="7.27" y2="1.525" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="1.075" x2="7.27" y2="2.175" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="1.725" x2="7.27" y2="2.825" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="2.375" x2="7.27" y2="3.475" layer="51" rot="R270"/>
<wire x1="-13.97" y1="15.24" x2="13.97" y2="15.24" width="0.127" layer="20"/>
<wire x1="13.97" y1="15.24" x2="13.97" y2="-15.24" width="0.127" layer="20"/>
<wire x1="13.97" y1="-15.24" x2="-13.97" y2="-15.24" width="0.127" layer="20"/>
<wire x1="-13.97" y1="-15.24" x2="-13.97" y2="15.24" width="0.127" layer="20"/>
<text x="-3.81" y="-13.97" size="1.27" layer="25">&gt;NAME</text>
<circle x="-12.7" y="13.97" radius="0.635" width="0.127" layer="21"/>
<circle x="12.7" y="13.97" radius="0.635" width="0.127" layer="21"/>
<circle x="-12.7" y="-13.97" radius="0.635" width="0.127" layer="21"/>
<circle x="12.7" y="-13.97" radius="0.635" width="0.127" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="MODUL">
<pin name="P$1" x="-12.7" y="-10.16" visible="off" length="middle"/>
<pin name="P$2" x="-12.7" y="-7.62" visible="off" length="middle"/>
<pin name="P$3" x="-12.7" y="-5.08" visible="off" length="middle"/>
<pin name="P$4" x="-12.7" y="-2.54" visible="off" length="middle"/>
<pin name="P$5" x="-12.7" y="0" visible="off" length="middle"/>
<pin name="P$6" x="-12.7" y="2.54" visible="off" length="middle"/>
<pin name="P$7" x="-12.7" y="5.08" visible="off" length="middle"/>
<pin name="P$8" x="-12.7" y="7.62" visible="off" length="middle"/>
<pin name="P$9" x="-12.7" y="10.16" visible="off" length="middle"/>
<pin name="P$10" x="12.7" y="-10.16" visible="off" length="middle" rot="R180"/>
<pin name="P$11" x="12.7" y="-7.62" visible="off" length="middle" rot="R180"/>
<pin name="P$12" x="12.7" y="-5.08" visible="off" length="middle" rot="R180"/>
<pin name="P$13" x="12.7" y="-2.54" visible="off" length="middle" rot="R180"/>
<pin name="P$14" x="12.7" y="0" visible="off" length="middle" rot="R180"/>
<pin name="P$15" x="12.7" y="2.54" visible="off" length="middle" rot="R180"/>
<pin name="P$16" x="12.7" y="5.08" visible="off" length="middle" rot="R180"/>
<pin name="P$17" x="12.7" y="7.62" visible="off" length="middle" rot="R180"/>
<pin name="P$18" x="12.7" y="10.16" visible="off" length="middle" rot="R180"/>
<pin name="P$19" x="-5.08" y="17.78" visible="off" length="middle" rot="R270"/>
<pin name="P$20" x="-2.54" y="17.78" visible="off" length="middle" rot="R270"/>
<pin name="P$21" x="2.54" y="17.78" visible="off" length="middle" rot="R270"/>
<pin name="P$22" x="5.08" y="17.78" visible="off" length="middle" rot="R270"/>
<wire x1="-7.62" y1="12.7" x2="7.62" y2="12.7" width="0.254" layer="94"/>
<wire x1="7.62" y1="12.7" x2="7.62" y2="-12.7" width="0.254" layer="94"/>
<wire x1="7.62" y1="-12.7" x2="-7.62" y2="-12.7" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-12.7" x2="-7.62" y2="12.7" width="0.254" layer="94"/>
<text x="0" y="-2.54" size="1.27" layer="95" rot="R90">&gt;NAME</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="MODUL">
<description>Niedziela</description>
<gates>
<gate name="G$1" symbol="MODUL" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MODUL">
<connects>
<connect gate="G$1" pin="P$1" pad="1"/>
<connect gate="G$1" pin="P$10" pad="10"/>
<connect gate="G$1" pin="P$11" pad="11"/>
<connect gate="G$1" pin="P$12" pad="12"/>
<connect gate="G$1" pin="P$13" pad="13"/>
<connect gate="G$1" pin="P$14" pad="14"/>
<connect gate="G$1" pin="P$15" pad="15"/>
<connect gate="G$1" pin="P$16" pad="16"/>
<connect gate="G$1" pin="P$17" pad="17"/>
<connect gate="G$1" pin="P$18" pad="18"/>
<connect gate="G$1" pin="P$19" pad="19"/>
<connect gate="G$1" pin="P$2" pad="2"/>
<connect gate="G$1" pin="P$20" pad="20"/>
<connect gate="G$1" pin="P$21" pad="21"/>
<connect gate="G$1" pin="P$22" pad="22"/>
<connect gate="G$1" pin="P$3" pad="3"/>
<connect gate="G$1" pin="P$4" pad="4"/>
<connect gate="G$1" pin="P$5" pad="5"/>
<connect gate="G$1" pin="P$6" pad="6"/>
<connect gate="G$1" pin="P$7" pad="7"/>
<connect gate="G$1" pin="P$8" pad="8"/>
<connect gate="G$1" pin="P$9" pad="9"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="ic-package">
<description>&lt;b&gt;IC Packages an Sockets&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL14">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SOCKET-14">
<description>&lt;b&gt;Dual In Line Socket&lt;/b&gt;</description>
<wire x1="8.89" y1="5.08" x2="-8.89" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-5.08" x2="8.89" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="8.89" y1="5.08" x2="8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="5.08" x2="-8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-5.08" x2="-8.89" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.54" x2="8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.54" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.54" x2="8.89" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.54" x2="8.89" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.54" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-2.54" x2="8.89" y2="-5.08" width="0.1524" layer="21"/>
<text x="-5.715" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-9.144" y="-3.937" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
</packages>
<symbols>
<symbol name="DIL14">
<wire x1="-5.08" y1="8.89" x2="-5.08" y2="-8.89" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-8.89" x2="5.08" y2="-8.89" width="0.254" layer="94"/>
<wire x1="5.08" y1="-8.89" x2="5.08" y2="8.89" width="0.254" layer="94"/>
<wire x1="5.08" y1="8.89" x2="2.54" y2="8.89" width="0.254" layer="94"/>
<wire x1="-5.08" y1="8.89" x2="-2.54" y2="8.89" width="0.254" layer="94"/>
<wire x1="-2.54" y1="8.89" x2="2.54" y2="8.89" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="9.525" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-11.43" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="10" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="12" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="DIL14" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Dual In Line / Socket&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="DIL14" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL14">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOCKET-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="MODUL" library="modul" deviceset="MODUL" device=""/>
<part name="IC1" library="ic-package" deviceset="DIL14" device=""/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="MODUL" gate="G$1" x="5.08" y="7.62"/>
<instance part="IC1" gate="G$1" x="53.34" y="7.62"/>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="1"/>
<pinref part="MODUL" gate="G$1" pin="P$17"/>
<wire x1="45.72" y1="15.24" x2="17.78" y2="15.24" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="2"/>
<pinref part="MODUL" gate="G$1" pin="P$16"/>
<wire x1="45.72" y1="12.7" x2="17.78" y2="12.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="3"/>
<pinref part="MODUL" gate="G$1" pin="P$15"/>
<wire x1="45.72" y1="10.16" x2="17.78" y2="10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="7"/>
<pinref part="MODUL" gate="G$1" pin="P$11"/>
<wire x1="45.72" y1="0" x2="17.78" y2="0" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
