<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="mm" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="12" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="7" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="43.18" x2="85.07" y2="43.18" width="0" layer="20"/>
<wire x1="85.07" y1="43.18" x2="85.07" y2="100" width="0" layer="20"/>
<wire x1="85.07" y1="100" x2="0" y2="100" width="0" layer="20"/>
<wire x1="0" y1="100" x2="0" y2="43.18" width="0" layer="20"/>
</plain>
<libraries>
<library name="modul">
<packages>
<package name="MODUL">
<wire x1="-11.25" y1="-11.56" x2="-11.25" y2="11.56" width="0.254" layer="21"/>
<wire x1="-11.25" y1="11.56" x2="-14.15" y2="11.56" width="0.254" layer="21"/>
<wire x1="-14.15" y1="11.56" x2="-14.15" y2="-11.56" width="0.254" layer="21"/>
<wire x1="-14.15" y1="-11.56" x2="-11.25" y2="-11.56" width="0.254" layer="21"/>
<wire x1="-13.8" y1="-11.45" x2="-13.8" y2="11.45" width="0.1524" layer="21"/>
<wire x1="-12.192" y1="-10.795" x2="-13.335" y2="-9.652" width="0.1524" layer="51"/>
<wire x1="-12.446" y1="-8.382" x2="-12.827" y2="-6.858" width="0.1524" layer="51"/>
<wire x1="-13.335" y1="-5.588" x2="-12.065" y2="-4.572" width="0.1524" layer="51"/>
<wire x1="-13.081" y1="-3.302" x2="-12.319" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-13.335" y1="-0.508" x2="-12.065" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-13.081" y1="1.778" x2="-12.319" y2="3.302" width="0.1524" layer="51"/>
<wire x1="-13.335" y1="4.572" x2="-12.065" y2="5.588" width="0.1524" layer="51"/>
<wire x1="-12.192" y1="6.985" x2="-13.335" y2="8.128" width="0.1524" layer="51"/>
<wire x1="-12.192" y1="9.525" x2="-13.335" y2="10.668" width="0.1524" layer="51"/>
<circle x="-12.7" y="-10.16" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="-7.62" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="-5.08" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="-2.54" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="2.54" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="5.08" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="7.62" radius="0.889" width="0.1524" layer="51"/>
<circle x="-12.7" y="10.16" radius="0.889" width="0.1524" layer="51"/>
<pad name="1" x="-12.7" y="-10.16" drill="1.2" shape="long" rot="R180"/>
<pad name="2" x="-12.7" y="-7.62" drill="1.2" shape="long" rot="R180"/>
<pad name="3" x="-12.7" y="-5.08" drill="1.2" shape="long" rot="R180"/>
<pad name="4" x="-12.7" y="-2.54" drill="1.2" shape="long" rot="R180"/>
<pad name="5" x="-12.7" y="0" drill="1.2" shape="long" rot="R180"/>
<pad name="6" x="-12.7" y="2.54" drill="1.2" shape="long" rot="R180"/>
<pad name="7" x="-12.7" y="5.08" drill="1.2" shape="long" rot="R180"/>
<pad name="8" x="-12.7" y="7.62" drill="1.2" shape="long" rot="R180"/>
<pad name="9" x="-12.7" y="10.16" drill="1.2" shape="long" rot="R180"/>
<wire x1="14.15" y1="-11.56" x2="14.15" y2="11.56" width="0.254" layer="21"/>
<wire x1="14.15" y1="11.56" x2="11.25" y2="11.56" width="0.254" layer="21"/>
<wire x1="11.25" y1="11.56" x2="11.25" y2="-11.56" width="0.254" layer="21"/>
<wire x1="11.25" y1="-11.56" x2="14.15" y2="-11.56" width="0.254" layer="21"/>
<wire x1="11.6" y1="-11.45" x2="11.6" y2="11.45" width="0.1524" layer="21"/>
<wire x1="13.208" y1="-10.795" x2="12.065" y2="-9.652" width="0.1524" layer="51"/>
<wire x1="12.954" y1="-8.382" x2="12.573" y2="-6.858" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-5.588" x2="13.335" y2="-4.572" width="0.1524" layer="51"/>
<wire x1="12.319" y1="-3.302" x2="13.081" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-0.508" x2="13.335" y2="0.508" width="0.1524" layer="51"/>
<wire x1="12.319" y1="1.778" x2="13.081" y2="3.302" width="0.1524" layer="51"/>
<wire x1="12.065" y1="4.572" x2="13.335" y2="5.588" width="0.1524" layer="51"/>
<wire x1="13.208" y1="6.985" x2="12.065" y2="8.128" width="0.1524" layer="51"/>
<wire x1="13.208" y1="9.525" x2="12.065" y2="10.668" width="0.1524" layer="51"/>
<circle x="12.7" y="-10.16" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="-7.62" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="-5.08" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="-2.54" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="2.54" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="5.08" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="7.62" radius="0.889" width="0.1524" layer="51"/>
<circle x="12.7" y="10.16" radius="0.889" width="0.1524" layer="51"/>
<pad name="10" x="12.7" y="-10.16" drill="1.2" shape="long" rot="R180"/>
<pad name="11" x="12.7" y="-7.62" drill="1.2" shape="long" rot="R180"/>
<pad name="12" x="12.7" y="-5.08" drill="1.2" shape="long" rot="R180"/>
<pad name="13" x="12.7" y="-2.54" drill="1.2" shape="long" rot="R180"/>
<pad name="14" x="12.7" y="0" drill="1.2" shape="long" rot="R180"/>
<pad name="15" x="12.7" y="2.54" drill="1.2" shape="long" rot="R180"/>
<pad name="16" x="12.7" y="5.08" drill="1.2" shape="long" rot="R180"/>
<pad name="17" x="12.7" y="7.62" drill="1.2" shape="long" rot="R180"/>
<pad name="18" x="12.7" y="10.16" drill="1.2" shape="long" rot="R180"/>
<wire x1="-7.75" y1="12.52" x2="-2.41" y2="12.52" width="0.254" layer="21"/>
<wire x1="-2.41" y1="12.52" x2="-2.41" y2="15.42" width="0.254" layer="21"/>
<wire x1="-2.41" y1="15.42" x2="-7.75" y2="15.42" width="0.254" layer="21"/>
<wire x1="-7.75" y1="15.42" x2="-7.75" y2="12.52" width="0.254" layer="21"/>
<wire x1="-7.64" y1="15.07" x2="-2.52" y2="15.07" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="13.462" x2="-5.842" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-4.572" y1="13.716" x2="-3.048" y2="14.097" width="0.1524" layer="51"/>
<circle x="-6.35" y="13.97" radius="0.889" width="0.1524" layer="51"/>
<circle x="-3.81" y="13.97" radius="0.889" width="0.1524" layer="51"/>
<pad name="19" x="-6.35" y="13.97" drill="1.2" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="13.97" drill="1.2" shape="long" rot="R90"/>
<wire x1="2.41" y1="12.52" x2="7.75" y2="12.52" width="0.254" layer="21"/>
<wire x1="7.75" y1="12.52" x2="7.75" y2="15.42" width="0.254" layer="21"/>
<wire x1="7.75" y1="15.42" x2="2.41" y2="15.42" width="0.254" layer="21"/>
<wire x1="2.41" y1="15.42" x2="2.41" y2="12.52" width="0.254" layer="21"/>
<wire x1="2.52" y1="15.07" x2="7.64" y2="15.07" width="0.1524" layer="21"/>
<wire x1="3.175" y1="13.462" x2="4.318" y2="14.605" width="0.1524" layer="51"/>
<wire x1="5.588" y1="13.716" x2="7.112" y2="14.097" width="0.1524" layer="51"/>
<circle x="3.81" y="13.97" radius="0.889" width="0.1524" layer="51"/>
<circle x="6.35" y="13.97" radius="0.889" width="0.1524" layer="51"/>
<pad name="21" x="3.81" y="13.97" drill="1.2" shape="long" rot="R90"/>
<pad name="22" x="6.35" y="13.97" drill="1.2" shape="long" rot="R90"/>
<wire x1="-6.545" y1="-3.25" x2="-2.345" y2="-3.25" width="0.254" layer="21"/>
<wire x1="-2.345" y1="-3.25" x2="-2.345" y2="3.25" width="0.254" layer="21"/>
<wire x1="-2.345" y1="3.25" x2="-6.545" y2="3.25" width="0.254" layer="21"/>
<wire x1="-6.545" y1="3.25" x2="-6.545" y2="-3.25" width="0.254" layer="21"/>
<circle x="-5.745" y="2.5" radius="0.1581" width="0.254" layer="21"/>
<rectangle x1="-7.27" y1="2.375" x2="-7.02" y2="3.475" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="1.725" x2="-7.02" y2="2.825" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="1.075" x2="-7.02" y2="2.175" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="0.425" x2="-7.02" y2="1.525" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-0.225" x2="-7.02" y2="0.875" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-0.875" x2="-7.02" y2="0.225" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-1.525" x2="-7.02" y2="-0.425" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-2.175" x2="-7.02" y2="-1.075" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-2.825" x2="-7.02" y2="-1.725" layer="51" rot="R270"/>
<rectangle x1="-7.27" y1="-3.475" x2="-7.02" y2="-2.375" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-3.475" x2="-1.62" y2="-2.375" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-2.825" x2="-1.62" y2="-1.725" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-2.175" x2="-1.62" y2="-1.075" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-1.525" x2="-1.62" y2="-0.425" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-0.875" x2="-1.62" y2="0.225" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="-0.225" x2="-1.62" y2="0.875" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="0.425" x2="-1.62" y2="1.525" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="1.075" x2="-1.62" y2="2.175" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="1.725" x2="-1.62" y2="2.825" layer="51" rot="R270"/>
<rectangle x1="-1.87" y1="2.375" x2="-1.62" y2="3.475" layer="51" rot="R270"/>
<wire x1="2.345" y1="-3.25" x2="6.545" y2="-3.25" width="0.254" layer="21"/>
<wire x1="6.545" y1="-3.25" x2="6.545" y2="3.25" width="0.254" layer="21"/>
<wire x1="6.545" y1="3.25" x2="2.345" y2="3.25" width="0.254" layer="21"/>
<wire x1="2.345" y1="3.25" x2="2.345" y2="-3.25" width="0.254" layer="21"/>
<circle x="3.145" y="2.5" radius="0.1581" width="0.254" layer="21"/>
<rectangle x1="1.62" y1="2.375" x2="1.87" y2="3.475" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="1.725" x2="1.87" y2="2.825" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="1.075" x2="1.87" y2="2.175" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="0.425" x2="1.87" y2="1.525" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-0.225" x2="1.87" y2="0.875" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-0.875" x2="1.87" y2="0.225" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-1.525" x2="1.87" y2="-0.425" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-2.175" x2="1.87" y2="-1.075" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-2.825" x2="1.87" y2="-1.725" layer="51" rot="R270"/>
<rectangle x1="1.62" y1="-3.475" x2="1.87" y2="-2.375" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-3.475" x2="7.27" y2="-2.375" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-2.825" x2="7.27" y2="-1.725" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-2.175" x2="7.27" y2="-1.075" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-1.525" x2="7.27" y2="-0.425" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-0.875" x2="7.27" y2="0.225" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="-0.225" x2="7.27" y2="0.875" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="0.425" x2="7.27" y2="1.525" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="1.075" x2="7.27" y2="2.175" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="1.725" x2="7.27" y2="2.825" layer="51" rot="R270"/>
<rectangle x1="7.02" y1="2.375" x2="7.27" y2="3.475" layer="51" rot="R270"/>
<wire x1="-13.97" y1="15.24" x2="13.97" y2="15.24" width="0.127" layer="20"/>
<wire x1="13.97" y1="15.24" x2="13.97" y2="-15.24" width="0.127" layer="20"/>
<wire x1="13.97" y1="-15.24" x2="-13.97" y2="-15.24" width="0.127" layer="20"/>
<wire x1="-13.97" y1="-15.24" x2="-13.97" y2="15.24" width="0.127" layer="20"/>
<text x="-3.81" y="-13.97" size="1.27" layer="25">&gt;NAME</text>
<circle x="-12.7" y="13.97" radius="0.635" width="0.127" layer="21"/>
<circle x="12.7" y="13.97" radius="0.635" width="0.127" layer="21"/>
<circle x="-12.7" y="-13.97" radius="0.635" width="0.127" layer="21"/>
<circle x="12.7" y="-13.97" radius="0.635" width="0.127" layer="21"/>
</package>
</packages>
</library>
<library name="ic-package">
<description>&lt;b&gt;IC Packages an Sockets&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL14">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*2*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="0.2mm"/>
<param name="mdWirePad" value="0.2mm"/>
<param name="mdWireVia" value="0.2mm"/>
<param name="mdPadPad" value="0.2mm"/>
<param name="mdPadVia" value="0.2mm"/>
<param name="mdViaVia" value="0.2mm"/>
<param name="mdSmdPad" value="0.2mm"/>
<param name="mdSmdVia" value="0.2mm"/>
<param name="mdSmdSmd" value="0.2mm"/>
<param name="mdViaViaSameLayer" value="0.2mm"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="1mm"/>
<param name="mdDrill" value="0.2mm"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="0.8mm"/>
<param name="msDrill" value="0.6mm"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="0.2mm"/>
<param name="rlMaxPadTop" value="0.5mm"/>
<param name="rlMinPadInner" value="0.2mm"/>
<param name="rlMaxPadInner" value="0.5mm"/>
<param name="rlMinPadBottom" value="0.2mm"/>
<param name="rlMaxPadBottom" value="0.4mm"/>
<param name="rlMinViaOuter" value="0.2mm"/>
<param name="rlMaxViaOuter" value="0.5mm"/>
<param name="rlMinViaInner" value="0.2mm"/>
<param name="rlMaxViaInner" value="0.5mm"/>
<param name="rlMinMicroViaOuter" value="0.2mm"/>
<param name="rlMaxMicroViaOuter" value="0.5mm"/>
<param name="rlMinMicroViaInner" value="0.2mm"/>
<param name="rlMaxMicroViaInner" value="0.5mm"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="0.3mm"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="-"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="MODUL" library="modul" package="MODUL" value="MODUL" x="25.4" y="64.77"/>
<element name="IC1" library="ic-package" package="DIL14" value="" x="67.31" y="64.77" rot="R270"/>
</elements>
<signals>
<signal name="N$1">
<contactref element="IC1" pad="1"/>
<contactref element="MODUL" pad="17"/>
<wire x1="63.5" y1="72.39" x2="38.1" y2="72.39" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$2">
<contactref element="IC1" pad="2"/>
<contactref element="MODUL" pad="16"/>
<wire x1="63.5" y1="69.85" x2="38.1" y2="69.85" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$3">
<contactref element="IC1" pad="3"/>
<contactref element="MODUL" pad="15"/>
<wire x1="63.5" y1="67.31" x2="38.1" y2="67.31" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$4">
<contactref element="IC1" pad="7"/>
<contactref element="MODUL" pad="11"/>
<wire x1="63.5" y1="57.15" x2="38.1" y2="57.15" width="0" layer="19" extent="1-1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
