<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.025" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.00625" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="yes"/>
<layer number="21" name="tPlace" color="8" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="13.5" y1="9.53" x2="99.53" y2="9.53" width="0" layer="20"/>
<wire x1="99.53" y1="9.53" x2="99.53" y2="50.16" width="0" layer="20"/>
<wire x1="99.53" y1="50.16" x2="13.5" y2="50.16" width="0" layer="20"/>
<wire x1="13.5" y1="50.16" x2="13.5" y2="9.53" width="0" layer="20"/>
</plain>
<libraries>
<library name="microchip-pic18fxx5x">
<packages>
<package name="DIL28-3">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type SP</description>
<wire x1="-17.78" y1="-1.27" x2="-17.78" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.27" x2="-17.78" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="17.78" y1="-2.54" x2="17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.54" x2="-17.78" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.54" x2="17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="-2.54" x2="17.78" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-17.907" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-15.748" y="-0.9398" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-cypressindustries">
<packages>
<package name="85-32004-00X">
<description>&lt;b&gt;USB B TYPE SINGLE R/A DIP&lt;/b&gt; With Rear Shell, Without Rear Shell&lt;p&gt;
Source: http://www.cypressindustries.com/pdf/85-32004-00x.pdf</description>
<wire x1="-10.225" y1="5.9625" x2="-10.225" y2="-5.9625" width="0.1016" layer="21"/>
<wire x1="-10.225" y1="-5.9625" x2="6.1625" y2="-5.9625" width="0.1016" layer="51"/>
<wire x1="6.1625" y1="-5.9625" x2="6.1625" y2="5.9625" width="0.1016" layer="21"/>
<wire x1="6.1625" y1="5.9625" x2="-10.225" y2="5.9625" width="0.1016" layer="51"/>
<wire x1="1.15" y1="6.0125" x2="0.975" y2="7.175" width="0.1016" layer="51"/>
<wire x1="0.975" y1="7.175" x2="-0.975" y2="7.175" width="0.1016" layer="51"/>
<wire x1="-0.975" y1="7.175" x2="-1.1375" y2="6.025" width="0.1016" layer="51"/>
<wire x1="-1.15" y1="-6.0125" x2="-0.975" y2="-7.175" width="0.1016" layer="51"/>
<wire x1="-0.975" y1="-7.175" x2="0.975" y2="-7.175" width="0.1016" layer="51"/>
<wire x1="0.975" y1="-7.175" x2="1.1375" y2="-6.025" width="0.1016" layer="51"/>
<wire x1="-1.8375" y1="5.9625" x2="-10.225" y2="5.9625" width="0.1016" layer="21"/>
<wire x1="-10.225" y1="-5.9625" x2="-1.8375" y2="-5.9625" width="0.1016" layer="21"/>
<wire x1="6.1625" y1="5.9625" x2="1.775" y2="5.9625" width="0.1016" layer="21"/>
<wire x1="1.775" y1="-5.9625" x2="6.1625" y2="-5.9625" width="0.1016" layer="21"/>
<pad name="M1" x="0" y="6.02" drill="2.3" diameter="3" rot="R270"/>
<pad name="M2" x="0" y="-6.02" drill="2.3" diameter="3" rot="R270"/>
<pad name="2" x="4.71" y="1.25" drill="0.92" diameter="1.27" rot="R270"/>
<pad name="3" x="2.71" y="1.25" drill="0.92" diameter="1.27" rot="R270"/>
<pad name="1" x="4.71" y="-1.25" drill="0.92" diameter="1.27" rot="R270"/>
<pad name="4" x="2.71" y="-1.25" drill="0.92" diameter="1.27" rot="R270"/>
<text x="-7.62" y="6.35" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.62" y="1.27" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="rcl">
<packages>
<package name="0204V">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0204/5">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="C025-024X044">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
</packages>
</library>
<library name="special">
<packages>
<package name="QS">
<description>&lt;B&gt;CRYSTAL&lt;/B&gt;</description>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.0508" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.0508" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.429" y2="-1.778" width="0.0508" layer="21" curve="-180"/>
<wire x1="3.429" y1="2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21" curve="-180"/>
<wire x1="-3.429" y1="2.286" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="180"/>
<wire x1="-3.429" y1="1.778" x2="-3.429" y2="-1.778" width="0.0508" layer="21" curve="180"/>
<pad name="1" x="-2.54" y="0" drill="0.6096" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="0.6096" shape="long" rot="R90"/>
<text x="-5.08" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.08" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
<library name="inductor-neosid">
<packages>
<package name="BS11">
<description>NOMINAL &lt;b&gt;INDUCTANCE&lt;/b&gt;&lt;p&gt;
grid 5 mm, diameter 10.5 mm, height 13.5 mm</description>
<circle x="0" y="0" radius="5.15" width="0.2032" layer="21"/>
<pad name="1" x="-2.5" y="0" drill="0.7" shape="long" rot="R90"/>
<pad name="2" x="2.5" y="0" drill="0.7" shape="long" rot="R90"/>
<text x="3.854" y="4.032" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.25" y="-3" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-molex">
<packages>
<package name="7395-06">
<description>&lt;b&gt;MOLEX 2.54mm KK RA CONNECTOR&lt;/b&gt;
&lt;br&gt;Fixed Orientation</description>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="-1.905" width="0.254" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.985" y2="-1.905" width="0.254" layer="21"/>
<wire x1="6.985" y1="-1.905" x2="6.985" y2="-2.54" width="0.254" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="5.715" y2="-2.54" width="0.254" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="5.715" y2="-1.905" width="0.254" layer="21"/>
<wire x1="5.715" y1="-1.905" x2="4.445" y2="-1.905" width="0.254" layer="21"/>
<wire x1="4.445" y1="-1.905" x2="4.445" y2="-2.54" width="0.254" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="3.175" y2="-2.54" width="0.254" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="3.175" y2="-1.905" width="0.254" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="1.905" y2="-1.905" width="0.254" layer="21"/>
<wire x1="1.905" y1="-1.905" x2="1.905" y2="-2.54" width="0.254" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.905" x2="-0.635" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-1.905" x2="-0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="-1.905" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-1.905" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-1.905" x2="-3.175" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-1.905" x2="-3.175" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-4.445" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-4.445" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-1.905" x2="-5.715" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-1.905" x2="-5.715" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-6.985" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-6.985" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-6.985" y1="-1.905" x2="-7.62" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-7.62" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-5.08" x2="-6.731" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-6.731" y1="-5.08" x2="0.889" y2="-5.08" width="0.254" layer="21"/>
<wire x1="0.889" y1="-5.08" x2="1.2192" y2="-5.08" width="0.127" layer="21"/>
<wire x1="1.2192" y1="-5.08" x2="6.35" y2="-5.08" width="0.254" layer="21"/>
<wire x1="6.35" y1="-5.08" x2="7.62" y2="-5.08" width="0.254" layer="21"/>
<wire x1="6.35" y1="-5.08" x2="6.35" y2="-13.081" width="0.254" layer="21"/>
<wire x1="6.35" y1="-13.081" x2="6.096" y2="-13.589" width="0.254" layer="21"/>
<wire x1="6.096" y1="-13.589" x2="1.2192" y2="-13.589" width="0.254" layer="21"/>
<wire x1="1.2192" y1="-13.589" x2="1.2192" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="1.2192" y1="-11.6586" x2="1.2192" y2="-5.08" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="-6.35" y2="-13.081" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-13.081" x2="-6.096" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-6.096" y1="-13.589" x2="-1.2192" y2="-13.589" width="0.254" layer="21"/>
<wire x1="-1.2192" y1="-13.589" x2="-1.2192" y2="-5.08" width="0.254" layer="21"/>
<wire x1="1.27" y1="-5.08" x2="0.889" y2="-5.08" width="0.254" layer="51"/>
<wire x1="0.889" y1="-5.08" x2="0.889" y2="-11.303" width="0.254" layer="21"/>
<wire x1="0.889" y1="-11.303" x2="1.2192" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-6.731" y1="-5.08" x2="-6.731" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-6.731" y1="-11.303" x2="-6.4008" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="6.731" y1="-5.08" x2="6.731" y2="-11.303" width="0.254" layer="21"/>
<wire x1="6.731" y1="-11.303" x2="6.4008" y2="-11.6586" width="0.254" layer="21"/>
<wire x1="-0.889" y1="-5.08" x2="-0.889" y2="-11.303" width="0.254" layer="21"/>
<wire x1="-0.889" y1="-11.303" x2="-1.2192" y2="-11.6586" width="0.254" layer="21"/>
<pad name="1" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="7.7201" y="2.9479" size="1.016" layer="25" ratio="14" rot="R180">&gt;NAME</text>
<text x="5.8659" y="-3.4021" size="1.27" layer="21" ratio="14" rot="R270">1</text>
<text x="-6.7833" y="-3.2751" size="1.27" layer="21" ratio="14" rot="R270">6</text>
<text x="-2.4399" y="2.9479" size="0.8128" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="6.096" y1="-2.5146" x2="6.604" y2="-0.2794" layer="51"/>
<rectangle x1="3.556" y1="-2.5146" x2="4.064" y2="-0.2794" layer="51"/>
<rectangle x1="1.016" y1="-2.5146" x2="1.524" y2="-0.2794" layer="51"/>
<rectangle x1="-1.524" y1="-2.5146" x2="-1.016" y2="-0.2794" layer="51"/>
<rectangle x1="-4.064" y1="-2.5146" x2="-3.556" y2="-0.2794" layer="51"/>
<rectangle x1="-6.604" y1="-2.5146" x2="-6.096" y2="-0.2794" layer="51"/>
</package>
</packages>
</library>
<library name="diode">
<packages>
<package name="DO34-7">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="led">
<packages>
<package name="LED3MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361" cap="flat"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208" cap="flat"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165" cap="flat"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361" cap="flat"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337" cap="flat"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102" cap="flat"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876" cap="flat"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876" cap="flat"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90" cap="flat"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108" cap="flat"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949" cap="flat"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022" cap="flat"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215" cap="flat"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701" cap="flat"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822" cap="flat"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="switch-omron">
<packages>
<package name="B3F-10XX">
<description>&lt;b&gt;OMRON SWITCH&lt;/b&gt;</description>
<wire x1="3.302" y1="-0.762" x2="3.048" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-0.762" x2="3.302" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.762" x2="3.302" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="1.016" x2="3.048" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0.762" x2="-3.048" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="2.54" x2="2.54" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-3.048" x2="3.048" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="3.048" y1="-2.54" x2="3.048" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-3.048" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="2.54" x2="-3.048" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-3.048" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-2.54" x2="-3.048" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="-1.27" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="1.27" width="0.0508" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="1.27" y2="1.27" width="0.0508" layer="51"/>
<wire x1="-1.27" y1="3.048" x2="-1.27" y2="2.794" width="0.0508" layer="21"/>
<wire x1="1.27" y1="2.794" x2="-1.27" y2="2.794" width="0.0508" layer="21"/>
<wire x1="1.27" y1="2.794" x2="1.27" y2="3.048" width="0.0508" layer="21"/>
<wire x1="1.143" y1="-2.794" x2="-1.27" y2="-2.794" width="0.0508" layer="21"/>
<wire x1="1.143" y1="-2.794" x2="1.143" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-1.27" y1="-2.794" x2="-1.27" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="2.54" y1="-3.048" x2="2.159" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-2.159" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-3.048" x2="-1.27" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.048" x2="-2.159" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="3.048" x2="2.159" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.159" y1="3.048" x2="1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="1.27" y1="3.048" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="3.048" x2="-2.159" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.048" x2="1.143" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-3.048" x2="2.159" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.762" x2="3.048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.762" x2="3.048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.762" x2="-3.048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-2.159" x2="1.27" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="1.27" y1="2.286" x2="-1.27" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.508" x2="-2.413" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="0.508" x2="-2.159" y2="-0.381" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="21"/>
<circle x="-2.159" y="-2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="2.159" y="-2.032" radius="0.508" width="0.1524" layer="51"/>
<circle x="2.159" y="2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="-2.159" y="2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="0.635" width="0.0508" layer="51"/>
<circle x="0" y="0" radius="0.254" width="0.1524" layer="21"/>
<pad name="1" x="-3.2512" y="2.2606" drill="1.016" shape="long"/>
<pad name="3" x="-3.2512" y="-2.2606" drill="1.016" shape="long"/>
<pad name="2" x="3.2512" y="2.2606" drill="1.016" shape="long"/>
<pad name="4" x="3.2512" y="-2.2606" drill="1.016" shape="long"/>
<text x="-3.048" y="3.683" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.318" y="1.651" size="1.27" layer="51" ratio="10">1</text>
<text x="3.556" y="1.524" size="1.27" layer="51" ratio="10">2</text>
<text x="-4.572" y="-2.794" size="1.27" layer="51" ratio="10">3</text>
<text x="3.556" y="-2.794" size="1.27" layer="51" ratio="10">4</text>
</package>
</packages>
</library>
<library name="transistor-pnp">
<description>&lt;b&gt;PNP Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TO92-BCE">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
grid 5.08 mm</description>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583345"/>
<wire x1="1.136" y1="-0.127" x2="-1.136" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="50.416655"/>
<wire x1="-1.404" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-1.1359" x2="-2.095" y2="-1.651" width="0.127" layer="21" curve="13.038528"/>
<wire x1="-1.136" y1="-0.127" x2="-1.404" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="50.416655"/>
<wire x1="2.664" y1="-0.127" x2="1.404" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.404" y1="-0.127" x2="1.136" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.095" y1="-1.651" x2="2.4247" y2="-1.1118" width="0.127" layer="21" curve="13.609443"/>
<pad name="C" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO92">
<description>&lt;b&gt;TO-92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-0.7863" y2="2.5485" width="0.1524" layer="21" curve="-111.098957"/>
<wire x1="0.7868" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.09954"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.254" y1="-0.254" x2="-0.286" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.286" y1="-0.254" x2="0.286" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.286" y1="-0.254" x2="2.254" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.1524" layer="51" curve="-34.293591"/>
<pad name="1" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="1.143" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-2.159" y="0" size="1.27" layer="51" ratio="10">3</text>
</package>
</packages>
</library>
<library name="transistor">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-2.6549" y2="-0.254" width="0.127" layer="21" curve="-32.78104"/>
<wire x1="-2.6549" y1="-0.254" x2="-0.7863" y2="2.5485" width="0.127" layer="21" curve="-78.318477"/>
<wire x1="0.7863" y1="2.5484" x2="2.0945" y2="-1.651" width="0.127" layer="21" curve="-111.09954"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.2537" y1="-0.254" x2="-0.2863" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.2863" y1="-0.254" x2="2.2537" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.127" layer="51" curve="-34.293591"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="10mil"/>
<param name="mdDrill" value="2mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="5mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="15mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="15mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="15mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
</autorouter>
<elements>
<element name="U1" library="microchip-pic18fxx5x" package="DIL28-3" value="PIC18F2550-I/SP" x="59.69" y="31.75"/>
<element name="R1" library="rcl" package="0204/5" value="12k" x="37.7825" y="40.3225"/>
<element name="C1" library="rcl" package="C050-025X075" value="100n" x="65.0875" y="14.605" rot="R180"/>
<element name="C2" library="rcl" package="C025-024X044" value="22p" x="61.2775" y="18.415" rot="R180"/>
<element name="C3" library="rcl" package="C025-024X044" value="22p" x="68.2625" y="18.415"/>
<element name="C4" library="rcl" package="E2,5-5" value="47u" x="73.18375" y="15.5575" rot="R90"/>
<element name="X1" library="special" package="QS" value="20MHz" x="64.77" y="22.5425" rot="R180"/>
<element name="L1" library="inductor-neosid" package="BS11" value="680uH" x="84.1375" y="18.0975"/>
<element name="ICSP" library="con-molex" package="7395-06" value="6-pin female/90 deg" x="17.78" y="29.21" rot="R270"/>
<element name="D1" library="diode" package="DO34-7" value="BAT85" x="77.62875" y="17.145" rot="R90"/>
<element name="R2" library="rcl" package="0204/5" value="4k7" x="52.3875" y="15.5575"/>
<element name="R3" library="rcl" package="0204V" value="2k7" x="57.15" y="16.8275" rot="R90"/>
<element name="R4" library="rcl" package="0204/5" value="75" x="24.13" y="17.78"/>
<element name="R5" library="rcl" package="0204/5" value="12k" x="37.62375" y="15.24" rot="R90"/>
<element name="R6" library="rcl" package="0204/5" value="4k7" x="24.13" y="20.32" rot="R180"/>
<element name="R7" library="rcl" package="0204/5" value="33" x="24.13" y="29.21"/>
<element name="R8" library="rcl" package="0204/5" value="33" x="24.13" y="33.02"/>
<element name="R9" library="rcl" package="0204/5" value="33" x="24.13" y="35.56"/>
<element name="C5" library="rcl" package="C050-025X075" value="100n" x="73.66" y="42.545" rot="R270"/>
<element name="C6" library="rcl" package="E2,5-5" value="10u" x="79.375" y="42.545"/>
<element name="C7" library="rcl" package="C050-025X075" value="330n" x="80.01" y="30.7975" rot="R90"/>
<element name="LED1" library="led" package="LED3MM" value="" x="55.245" y="45.72" rot="R180"/>
<element name="LED2" library="led" package="LED3MM" value="" x="61.595" y="45.72" rot="R180"/>
<element name="LED3" library="led" package="LED3MM" value="" x="67.945" y="45.72" rot="R180"/>
<element name="S1" library="switch-omron" package="B3F-10XX" value="" x="44.45" y="45.72" rot="R180"/>
<element name="R10" library="rcl" package="0204/5" value="680" x="79.6925" y="46.6725" rot="R180"/>
<element name="R11" library="rcl" package="0204/5" value="680" x="52.3875" y="40.3225"/>
<element name="R12" library="rcl" package="0204/5" value="680" x="60.0075" y="40.3225" rot="R180"/>
<element name="R13" library="rcl" package="0204/5" value="2k7" x="67.6275" y="40.3225"/>
<element name="R14" library="rcl" package="0204/5" value="4k7" x="24.13" y="38.1"/>
<element name="R15" library="rcl" package="0204/5" value="4k7" x="24.13" y="40.64"/>
<element name="R16" library="rcl" package="0204/5" value="220" x="45.085" y="40.3225" rot="R180"/>
<element name="CN1" library="con-cypressindustries" package="85-32004-00X" value="USB-B female" x="92.71" y="29.21" rot="R180"/>
<element name="R17" library="rcl" package="0204/5" value="1k" x="24.13" y="25.4" rot="R180"/>
<element name="Q7" library="transistor-pnp" package="TO92-BCE" value="BC640" x="34.29" y="31.75" rot="R90"/>
<element name="Q3" library="transistor" package="TO92" value="BC547" x="54.61" y="20.955"/>
<element name="Q8" library="transistor" package="TO92" value="BC547" x="43.815" y="15.24"/>
<element name="Q9" library="transistor" package="TO92" value="BC547" x="74.295" y="23.495" rot="R180"/>
<element name="Q10" library="transistor" package="TO92" value="BC547" x="31.4325" y="41.5925"/>
<element name="R18" library="rcl" package="0204/7" value="1k" x="40.64" y="21.59" rot="R90"/>
<element name="R19" library="rcl" package="0204V" value="1k" x="57.15" y="24.765"/>
<element name="R20" library="rcl" package="0204/7" value="1k" x="34.29" y="45.72"/>
<element name="R21" library="rcl" package="0204V" value="1k" x="73.025" y="19.05" rot="R180"/>
<element name="Q1" library="transistor-pnp" package="TO92" value="BC557" x="26.67" y="12.7"/>
<element name="R22" library="rcl" package="0204/5" value="1k" x="33.02" y="15.24"/>
</elements>
<signals>
<signal name="N$1">
<contactref element="U1" pad="10"/>
<contactref element="X1" pad="1"/>
<contactref element="C3" pad="1"/>
<wire x1="66.04" y1="27.305" x2="66.04" y2="27.94" width="1.27" layer="16"/>
<wire x1="66.9925" y1="18.415" x2="67.31" y2="18.7325" width="1.27" layer="16"/>
<wire x1="67.31" y1="18.7325" x2="67.31" y2="22.5425" width="0.8128" layer="16"/>
<wire x1="66.04" y1="27.305" x2="66.04" y2="26.67" width="0.8128" layer="16"/>
<wire x1="66.04" y1="26.67" x2="67.31" y2="25.4" width="0.8128" layer="16"/>
<wire x1="67.31" y1="25.4" x2="67.31" y2="22.5425" width="0.8128" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="U1" pad="9"/>
<contactref element="X1" pad="2"/>
<contactref element="C2" pad="1"/>
<wire x1="63.5" y1="27.305" x2="63.5" y2="27.94" width="1.27" layer="16"/>
<wire x1="62.5475" y1="18.415" x2="62.23" y2="18.7325" width="1.27" layer="16"/>
<wire x1="62.23" y1="18.7325" x2="62.23" y2="22.5425" width="0.8128" layer="16"/>
<wire x1="63.5" y1="27.305" x2="63.5" y2="26.67" width="0.8128" layer="16"/>
<wire x1="63.5" y1="26.67" x2="62.23" y2="25.4" width="0.8128" layer="16"/>
<wire x1="62.23" y1="25.4" x2="62.23" y2="22.5425" width="0.8128" layer="16"/>
</signal>
<signal name="GND">
<contactref element="C2" pad="2"/>
<contactref element="C3" pad="2"/>
<contactref element="C4" pad="-"/>
<contactref element="C1" pad="2"/>
<contactref element="R3" pad="2"/>
<contactref element="ICSP" pad="3"/>
<contactref element="R14" pad="2"/>
<contactref element="R15" pad="2"/>
<contactref element="U1" pad="8"/>
<contactref element="U1" pad="19"/>
<contactref element="C5" pad="2"/>
<contactref element="C6" pad="-"/>
<contactref element="C7" pad="2"/>
<contactref element="R13" pad="2"/>
<contactref element="S1" pad="3"/>
<contactref element="S1" pad="4"/>
<contactref element="LED3" pad="K"/>
<contactref element="LED1" pad="K"/>
<contactref element="CN1" pad="4"/>
<contactref element="CN1" pad="M1"/>
<contactref element="CN1" pad="M2"/>
<contactref element="R1" pad="1"/>
<wire x1="41.1988" y1="47.9806" x2="41.91" y2="48.26" width="0.8128" layer="16"/>
<wire x1="47.7012" y1="47.9806" x2="46.99" y2="48.26" width="1.27" layer="16"/>
<wire x1="19.05" y1="27.305" x2="17.78" y2="27.94" width="0.8128" layer="16"/>
<wire x1="67.31" y1="33.3375" x2="80.01" y2="33.3375" width="0.8128" layer="16"/>
<wire x1="47.7012" y1="47.9806" x2="48.26" y2="48.26" width="1.27" layer="16"/>
<wire x1="66.04" y1="34.925" x2="66.04" y2="35.56" width="1.27" layer="16"/>
<wire x1="67.31" y1="33.3375" x2="66.04" y2="34.925" width="0.8128" layer="16"/>
<wire x1="67.31" y1="30.1625" x2="67.31" y2="33.3375" width="0.6096" layer="1"/>
<wire x1="26.67" y1="38.1" x2="26.3525" y2="38.1" width="0.8128" layer="16"/>
<wire x1="62.5475" y1="30.1625" x2="67.31" y2="30.1625" width="0.8128" layer="16"/>
<wire x1="60.96" y1="28.575" x2="62.5475" y2="30.1625" width="0.8128" layer="16"/>
<wire x1="60.96" y1="27.94" x2="60.96" y2="28.575" width="1.27" layer="16"/>
<wire x1="41.1988" y1="47.9806" x2="40.64" y2="48.26" width="1.27" layer="16"/>
<wire x1="66.04" y1="35.56" x2="66.04" y2="36.195" width="1.27" layer="16"/>
<wire x1="35.2425" y1="40.3225" x2="35.2425" y2="40.64" width="0.4064" layer="16"/>
<via x="67.31" y="30.1625" extent="1-16" drill="0.8" diameter="1.27"/>
<via x="67.31" y="33.3375" extent="1-16" drill="0.8" diameter="1.27"/>
<polygon width="0.4064" layer="16" spacing="0.8128" pour="hatch" isolate="0.8128">
<vertex x="99.06" y="49.53"/>
<vertex x="13.97" y="49.53"/>
<vertex x="13.97" y="10.16"/>
<vertex x="99.06" y="10.16"/>
</polygon>
<contactref element="Q8" pad="1"/>
<wire x1="45.085" y1="15.24" x2="46.355" y2="15.24" width="0.6096" layer="16"/>
<wire x1="46.355" y1="15.24" x2="48.26" y2="17.145" width="0.6096" layer="16"/>
<wire x1="48.26" y1="17.145" x2="51.435" y2="17.145" width="0.6096" layer="16"/>
<wire x1="51.435" y1="17.145" x2="52.07" y2="16.51" width="0.6096" layer="16"/>
<wire x1="52.07" y1="16.51" x2="52.07" y2="14.605" width="0.6096" layer="16"/>
<wire x1="52.07" y1="14.605" x2="52.705" y2="13.97" width="0.6096" layer="16"/>
<wire x1="52.705" y1="13.97" x2="62.5475" y2="13.97" width="0.6096" layer="16"/>
<wire x1="62.5475" y1="13.97" x2="62.5475" y2="14.605" width="0.6096" layer="16"/>
<contactref element="Q3" pad="1"/>
<contactref element="Q10" pad="1"/>
<contactref element="Q9" pad="1"/>
</signal>
<signal name="N$3">
<contactref element="L1" pad="1"/>
<contactref element="D1" pad="A"/>
<contactref element="Q9" pad="3"/>
<wire x1="81.6375" y1="18.0975" x2="78.4225" y2="18.0975" width="0.8128" layer="16"/>
<wire x1="78.4225" y1="18.0975" x2="77.47" y2="19.05" width="0.8128" layer="16"/>
<wire x1="77.47" y1="19.05" x2="77.47" y2="20.79625" width="0.8128" layer="16"/>
<wire x1="77.47" y1="20.79625" x2="77.62875" y2="20.955" width="0.8128" layer="16"/>
<wire x1="77.62875" y1="20.955" x2="77.62875" y2="22.70125" width="0.8128" layer="16"/>
<wire x1="77.62875" y1="22.70125" x2="76.835" y2="23.495" width="0.8128" layer="16"/>
<wire x1="76.835" y1="23.495" x2="75.565" y2="23.495" width="0.8128" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="U1" pad="12"/>
<contactref element="R21" pad="2"/>
<wire x1="71.12" y1="27.94" x2="71.12" y2="20.32" width="0.8128" layer="16"/>
<wire x1="71.12" y1="20.32" x2="71.755" y2="19.685" width="0.8128" layer="16"/>
<wire x1="71.755" y1="19.685" x2="71.755" y2="19.05" width="0.8128" layer="16"/>
</signal>
<signal name="VDD">
<contactref element="C6" pad="+"/>
<contactref element="C5" pad="1"/>
<contactref element="U1" pad="20"/>
<contactref element="L1" pad="2"/>
<contactref element="R12" pad="1"/>
<contactref element="LED2" pad="A"/>
<contactref element="R13" pad="1"/>
<contactref element="CN1" pad="1"/>
<wire x1="63.5" y1="31.75" x2="63.5" y2="35.56" width="0.8128" layer="16"/>
<wire x1="63.5" y1="31.75" x2="83.82" y2="31.75" width="0.8128" layer="16"/>
<wire x1="63.5" y1="35.56" x2="63.5" y2="40.3225" width="0.8128" layer="16"/>
<wire x1="63.5" y1="40.3225" x2="62.5475" y2="40.3225" width="0.8128" layer="16"/>
<wire x1="63.5" y1="40.3225" x2="65.0875" y2="40.3225" width="0.8128" layer="16"/>
<wire x1="62.5475" y1="40.3225" x2="62.5475" y2="45.4025" width="0.8128" layer="16"/>
<wire x1="62.5475" y1="45.4025" x2="62.865" y2="45.72" width="1.27" layer="16"/>
<wire x1="34.29" y1="31.75" x2="63.5" y2="31.75" width="0.8128" layer="16"/>
<wire x1="83.82" y1="31.75" x2="83.998928125" y2="31.69478125" width="0.8128" layer="16"/>
<contactref element="Q7" pad="C"/>
<wire x1="86.6375" y1="18.0975" x2="86.6375" y2="22.5825" width="0.8128" layer="16"/>
<wire x1="86.6375" y1="22.5825" x2="83.82" y2="25.4" width="0.8128" layer="16"/>
<wire x1="83.82" y1="25.4" x2="83.82" y2="31.515853125" width="0.8128" layer="16"/>
<wire x1="83.82" y1="31.515853125" x2="83.998928125" y2="31.69478125" width="0.8128" layer="16"/>
<wire x1="88" y1="30.46" x2="88" y2="30.745" width="0.8128" layer="16"/>
<wire x1="88" y1="30.745" x2="87.15375" y2="31.59125" width="0.8128" layer="16"/>
<wire x1="87.15375" y1="31.59125" x2="84.102459375" y2="31.59125" width="0.8128" layer="16"/>
<wire x1="84.102459375" y1="31.59125" x2="83.998928125" y2="31.69478125" width="0.8128" layer="16"/>
<wire x1="78.105" y1="42.545" x2="76.2" y2="42.545" width="0.8128" layer="16"/>
<wire x1="76.2" y1="42.545" x2="75.565" y2="43.18" width="0.8128" layer="16"/>
<wire x1="75.565" y1="43.18" x2="75.565" y2="44.45" width="0.8128" layer="16"/>
<wire x1="75.565" y1="44.45" x2="74.93" y2="45.085" width="0.8128" layer="16"/>
<wire x1="74.93" y1="45.085" x2="73.66" y2="45.085" width="0.8128" layer="16"/>
<wire x1="73.66" y1="45.085" x2="71.755" y2="45.085" width="0.8128" layer="16"/>
<wire x1="71.755" y1="45.085" x2="71.12" y2="44.45" width="0.8128" layer="16"/>
<wire x1="71.12" y1="44.45" x2="71.12" y2="43.18" width="0.8128" layer="16"/>
<wire x1="71.12" y1="43.18" x2="70.485" y2="42.545" width="0.8128" layer="16"/>
<wire x1="70.485" y1="42.545" x2="66.04" y2="42.545" width="0.8128" layer="16"/>
<wire x1="66.04" y1="42.545" x2="65.0875" y2="41.5925" width="0.8128" layer="16"/>
<wire x1="65.0875" y1="41.5925" x2="65.0875" y2="40.3225" width="0.8128" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="U1" pad="25"/>
<contactref element="R11" pad="1"/>
<contactref element="R16" pad="1"/>
<wire x1="47.625" y1="40.3225" x2="49.8475" y2="40.3225" width="0.8128" layer="16"/>
<wire x1="50.8" y1="35.56" x2="50.8" y2="37.465" width="0.8128" layer="16"/>
<wire x1="50.8" y1="37.465" x2="49.8475" y2="38.4175" width="0.8128" layer="16"/>
<wire x1="49.8475" y1="38.4175" x2="49.8475" y2="40.3225" width="0.8128" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="C4" pad="+"/>
<contactref element="D1" pad="C"/>
<contactref element="C1" pad="1"/>
<contactref element="R2" pad="1"/>
<contactref element="R5" pad="1"/>
<wire x1="37.62375" y1="12.7" x2="49.53" y2="12.7" width="0.8128" layer="16"/>
<wire x1="49.53" y1="12.7" x2="49.8475" y2="13.0175" width="0.4064" layer="16"/>
<wire x1="49.53" y1="15.24" x2="49.8475" y2="15.5575" width="0.4064" layer="16"/>
<wire x1="49.53" y1="12.7" x2="67.31" y2="12.7" width="0.8128" layer="16"/>
<wire x1="67.31" y1="12.7" x2="73.025" y2="12.7" width="0.8128" layer="16"/>
<wire x1="49.8475" y1="15.5575" x2="49.8475" y2="13.0175" width="0.8128" layer="16"/>
<wire x1="73.025" y1="12.7" x2="75.565" y2="12.7" width="0.8128" layer="16"/>
<wire x1="75.565" y1="12.7" x2="76.2" y2="13.335" width="0.8128" layer="16"/>
<wire x1="76.2" y1="13.335" x2="77.62875" y2="13.335" width="0.8128" layer="16"/>
<wire x1="73.18375" y1="14.2875" x2="73.18375" y2="12.85875" width="0.8128" layer="16"/>
<wire x1="73.18375" y1="12.85875" x2="73.025" y2="12.7" width="0.8128" layer="16"/>
<wire x1="67.6275" y1="14.605" x2="67.6275" y2="13.0175" width="0.8128" layer="16"/>
<wire x1="67.6275" y1="13.0175" x2="67.31" y2="12.7" width="0.8128" layer="16"/>
<contactref element="Q1" pad="1"/>
<wire x1="37.62375" y1="12.7" x2="27.94" y2="12.7" width="0.8128" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="R2" pad="2"/>
<contactref element="R3" pad="1"/>
<contactref element="U1" pad="2"/>
<wire x1="45.72" y1="18.415" x2="45.72" y2="25.4" width="0.6096" layer="1"/>
<wire x1="45.72" y1="25.4" x2="45.72" y2="27.94" width="1.27" layer="16"/>
<via x="45.72" y="18.415" extent="1-16" drill="0.8" diameter="1.27"/>
<via x="45.72" y="25.4" extent="1-16" drill="0.8" diameter="1.27"/>
<wire x1="54.9275" y1="15.5575" x2="57.15" y2="15.5575" width="0.8128" layer="16"/>
<wire x1="54.9275" y1="18.415" x2="54.9275" y2="15.5575" width="0.8128" layer="16"/>
<wire x1="54.9275" y1="18.415" x2="45.72" y2="18.415" width="0.8128" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="R5" pad="2"/>
<contactref element="Q8" pad="3"/>
<contactref element="R22" pad="2"/>
<wire x1="35.56" y1="15.24" x2="37.465" y2="15.24" width="0.8128" layer="16"/>
<wire x1="37.465" y1="15.24" x2="42.545" y2="15.24" width="0.8128" layer="16"/>
<wire x1="37.62375" y1="17.78" x2="37.62375" y2="15.39875" width="0.8128" layer="16"/>
<wire x1="37.62375" y1="15.39875" x2="37.465" y2="15.24" width="0.8128" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="R4" pad="2"/>
<contactref element="Q3" pad="3"/>
<wire x1="26.67" y1="17.78" x2="34.29" y2="17.78" width="0.8128" layer="16"/>
<wire x1="34.29" y1="17.78" x2="36.195" y2="19.685" width="0.8128" layer="16"/>
<wire x1="36.195" y1="19.685" x2="52.07" y2="19.685" width="0.8128" layer="16"/>
<wire x1="52.07" y1="19.685" x2="53.34" y2="20.955" width="0.8128" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="R4" pad="1"/>
<contactref element="ICSP" pad="1"/>
<wire x1="23.495" y1="12.7" x2="21.59" y2="14.605" width="0.8128" layer="16"/>
<wire x1="21.59" y1="14.605" x2="21.59" y2="17.78" width="0.8128" layer="16"/>
<wire x1="21.59" y1="17.78" x2="20.32" y2="17.78" width="0.8128" layer="16"/>
<wire x1="20.32" y1="17.78" x2="17.78" y2="20.32" width="0.8128" layer="16"/>
<wire x1="17.78" y1="20.32" x2="17.78" y2="22.86" width="0.8128" layer="16"/>
<contactref element="Q1" pad="3"/>
<wire x1="25.4" y1="12.7" x2="23.495" y2="12.7" width="0.8128" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="U1" pad="7"/>
<wire x1="58.42" y1="27.305" x2="58.42" y2="27.94" width="1.27" layer="16"/>
<contactref element="R19" pad="2"/>
<wire x1="58.42" y1="27.305" x2="58.42" y2="24.765" width="0.8128" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="U1" pad="23"/>
<wire x1="40.64" y1="28.2575" x2="40.64" y2="33.3375" width="0.6096" layer="1"/>
<wire x1="40.64" y1="33.3375" x2="54.61" y2="33.3375" width="0.8128" layer="16"/>
<wire x1="54.61" y1="33.3375" x2="55.88" y2="34.925" width="0.8128" layer="16"/>
<wire x1="55.88" y1="34.925" x2="55.88" y2="35.56" width="1.27" layer="16"/>
<via x="40.64" y="33.3375" extent="1-16" drill="0.8" diameter="1.27"/>
<via x="40.64" y="28.2575" extent="1-16" drill="0.8" diameter="1.27"/>
<contactref element="R18" pad="2"/>
<wire x1="40.64" y1="25.4" x2="40.64" y2="28.2575" width="0.8128" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="U1" pad="3"/>
<contactref element="R6" pad="1"/>
<wire x1="48.26" y1="25.0825" x2="48.26" y2="27.94" width="0.8128" layer="16"/>
<wire x1="38.735" y1="23.8125" x2="46.99" y2="23.8125" width="0.8128" layer="16"/>
<wire x1="46.99" y1="23.8125" x2="48.26" y2="25.0825" width="0.8128" layer="16"/>
<wire x1="38.735" y1="23.8125" x2="38.735" y2="26.67" width="0.8128" layer="16"/>
<wire x1="38.735" y1="26.67" x2="38.1" y2="27.305" width="0.8128" layer="16"/>
<wire x1="38.1" y1="27.305" x2="35.56" y2="27.305" width="0.8128" layer="16"/>
<wire x1="35.56" y1="27.305" x2="34.925" y2="26.67" width="0.8128" layer="16"/>
<wire x1="34.925" y1="26.67" x2="34.925" y2="21.59" width="0.8128" layer="16"/>
<wire x1="34.925" y1="21.59" x2="33.655" y2="20.32" width="0.8128" layer="16"/>
<wire x1="33.655" y1="20.32" x2="26.67" y2="20.32" width="0.8128" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="ICSP" pad="6"/>
<contactref element="R9" pad="1"/>
<wire x1="17.78" y1="35.56" x2="21.59" y2="35.56" width="0.8128" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="R8" pad="1"/>
<contactref element="ICSP" pad="5"/>
<contactref element="R14" pad="1"/>
<wire x1="17.78" y1="33.02" x2="21.59" y2="33.02" width="0.8128" layer="16"/>
<wire x1="15.24" y1="33.02" x2="17.78" y2="33.02" width="0.8128" layer="16"/>
<wire x1="15.24" y1="33.02" x2="15.24" y2="37.465" width="0.8128" layer="16"/>
<wire x1="15.24" y1="37.465" x2="15.875" y2="38.1" width="0.8128" layer="16"/>
<wire x1="15.875" y1="38.1" x2="21.59" y2="38.1" width="0.8128" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="ICSP" pad="4"/>
<contactref element="R7" pad="1"/>
<contactref element="R15" pad="1"/>
<wire x1="21.59" y1="30.48" x2="17.78" y2="30.48" width="0.8128" layer="16"/>
<wire x1="23.1775" y1="40.64" x2="21.59" y2="40.64" width="0.8128" layer="16"/>
<wire x1="21.59" y1="29.21" x2="21.59" y2="30.48" width="0.8128" layer="16"/>
<wire x1="23.1775" y1="40.64" x2="23.1775" y2="31.4325" width="0.8128" layer="16"/>
<wire x1="23.1775" y1="31.4325" x2="22.225" y2="30.48" width="0.8128" layer="16"/>
<wire x1="22.225" y1="30.48" x2="21.59" y2="30.48" width="0.8128" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="U1" pad="4"/>
<contactref element="R7" pad="2"/>
<wire x1="31.115" y1="24.765" x2="36.83" y2="24.765" width="0.6096" layer="1"/>
<wire x1="36.83" y1="24.765" x2="36.83" y2="22.5425" width="0.8128" layer="16"/>
<via x="31.115" y="24.765" extent="1-16" drill="0.8" diameter="1.27"/>
<via x="36.83" y="24.765" extent="1-16" drill="0.8" diameter="1.27"/>
<wire x1="36.83" y1="22.5425" x2="47.9425" y2="22.5425" width="0.8128" layer="16"/>
<wire x1="47.9425" y1="22.5425" x2="50.8" y2="25.4" width="0.8128" layer="16"/>
<wire x1="50.8" y1="25.4" x2="50.8" y2="27.94" width="0.8128" layer="16"/>
<wire x1="26.67" y1="29.21" x2="30.48" y2="29.21" width="0.8128" layer="16"/>
<wire x1="30.48" y1="29.21" x2="31.115" y2="28.575" width="0.8128" layer="16"/>
<wire x1="31.115" y1="28.575" x2="31.115" y2="24.765" width="0.8128" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="U1" pad="5"/>
<contactref element="R8" pad="2"/>
<wire x1="38.1" y1="36.195" x2="38.1" y2="21.2725" width="0.6096" layer="1"/>
<wire x1="53.34" y1="25.0825" x2="53.34" y2="27.94" width="0.8128" layer="16"/>
<via x="38.1" y="36.195" extent="1-16" drill="0.8" diameter="1.27"/>
<via x="38.1" y="21.2725" extent="1-16" drill="0.8" diameter="1.27"/>
<wire x1="38.1" y1="21.2725" x2="49.53" y2="21.2725" width="0.8128" layer="16"/>
<wire x1="49.53" y1="21.2725" x2="53.34" y2="25.0825" width="0.8128" layer="16"/>
<wire x1="32.385" y1="36.195" x2="38.1" y2="36.195" width="0.8128" layer="16"/>
<wire x1="32.385" y1="36.195" x2="29.21" y2="33.02" width="0.8128" layer="16"/>
<wire x1="29.21" y1="33.02" x2="26.67" y2="33.02" width="0.8128" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="U1" pad="6"/>
<contactref element="R9" pad="2"/>
<wire x1="39.37" y1="37.7825" x2="39.37" y2="30.1625" width="0.6096" layer="1"/>
<wire x1="53.975" y1="30.1625" x2="55.88" y2="28.575" width="0.8128" layer="16"/>
<wire x1="55.88" y1="28.575" x2="55.88" y2="27.94" width="1.27" layer="16"/>
<wire x1="39.37" y1="30.1625" x2="53.975" y2="30.1625" width="0.8128" layer="16"/>
<via x="39.37" y="30.1625" extent="1-16" drill="0.8" diameter="1.27"/>
<via x="39.37" y="37.7825" extent="1-16" drill="0.8" diameter="1.27"/>
<wire x1="39.37" y1="37.7825" x2="31.4325" y2="37.7825" width="0.8128" layer="16"/>
<wire x1="31.4325" y1="37.7825" x2="29.21" y2="35.56" width="0.8128" layer="16"/>
<wire x1="29.21" y1="35.56" x2="26.67" y2="35.56" width="0.8128" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="U1" pad="15"/>
<contactref element="CN1" pad="2"/>
<wire x1="85.4075" y1="35.56" x2="85.4075" y2="27.94" width="0.6096" layer="1"/>
<wire x1="76.2" y1="35.56" x2="85.4075" y2="35.56" width="0.8128" layer="16"/>
<wire x1="87.9475" y1="27.94" x2="88" y2="27.96" width="1.27" layer="16"/>
<wire x1="85.4075" y1="27.94" x2="87.9475" y2="27.94" width="0.8128" layer="16"/>
<via x="85.4075" y="35.56" extent="1-16" drill="0.8" diameter="1.27"/>
<via x="85.4075" y="27.94" extent="1-16" drill="0.8" diameter="1.27"/>
</signal>
<signal name="N$26">
<contactref element="U1" pad="16"/>
<contactref element="CN1" pad="3"/>
<wire x1="73.66" y1="35.56" x2="73.66" y2="36.195" width="1.27" layer="16"/>
<wire x1="90" y1="27.96" x2="90.825" y2="27.96" width="0.8128" layer="16"/>
<wire x1="90.825" y1="27.96" x2="92.075" y2="29.21" width="0.8128" layer="16"/>
<wire x1="92.075" y1="29.21" x2="92.075" y2="31.75" width="0.8128" layer="16"/>
<wire x1="92.075" y1="31.75" x2="85.725" y2="38.1" width="0.8128" layer="16"/>
<wire x1="85.725" y1="38.1" x2="74.93" y2="38.1" width="0.8128" layer="16"/>
<wire x1="74.93" y1="38.1" x2="73.66" y2="36.83" width="0.8128" layer="16"/>
<wire x1="73.66" y1="36.83" x2="73.66" y2="36.195" width="0.8128" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="C7" pad="1"/>
<contactref element="U1" pad="14"/>
<wire x1="76.2" y1="27.94" x2="79.6925" y2="27.94" width="0.8128" layer="16"/>
<wire x1="79.6925" y1="27.94" x2="80.01" y2="28.2575" width="0.8128" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="R12" pad="2"/>
<contactref element="LED1" pad="A"/>
<wire x1="57.4675" y1="40.3225" x2="57.4675" y2="44.7675" width="0.8128" layer="16"/>
<wire x1="57.4675" y1="44.7675" x2="56.515" y2="45.72" width="0.8128" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="R10" pad="2"/>
<contactref element="LED3" pad="A"/>
<wire x1="69.215" y1="45.72" x2="70.1675" y2="46.6725" width="0.8128" layer="16"/>
<wire x1="70.1675" y1="46.6725" x2="77.1525" y2="46.6725" width="0.8128" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="U1" pad="11"/>
<contactref element="R10" pad="1"/>
<wire x1="69.5325" y1="30.1625" x2="81.5975" y2="30.1625" width="0.8128" layer="16"/>
<wire x1="81.5975" y1="30.1625" x2="82.2325" y2="28.8925" width="0.8128" layer="16"/>
<wire x1="82.2325" y1="28.8925" x2="82.2325" y2="40.005" width="0.6096" layer="1"/>
<wire x1="68.58" y1="27.94" x2="68.58" y2="28.575" width="1.27" layer="16"/>
<wire x1="68.58" y1="28.575" x2="69.5325" y2="30.1625" width="0.8128" layer="16"/>
<via x="82.2325" y="28.8925" extent="1-16" drill="0.8" diameter="1.27"/>
<via x="82.2325" y="40.005" extent="1-16" drill="0.8" diameter="1.27"/>
<wire x1="82.2325" y1="40.005" x2="82.2325" y2="46.6725" width="0.8128" layer="16"/>
</signal>
<signal name="N$32">
<contactref element="S1" pad="1"/>
<contactref element="S1" pad="2"/>
<contactref element="U1" pad="26"/>
<wire x1="46.99" y1="43.18" x2="45.085" y2="43.18" width="0.8128" layer="16"/>
<wire x1="45.085" y1="43.18" x2="41.91" y2="43.18" width="0.8128" layer="16"/>
<wire x1="41.91" y1="43.18" x2="41.1988" y2="43.4594" width="1.27" layer="16"/>
<wire x1="46.99" y1="43.18" x2="47.7012" y2="43.4594" width="1.27" layer="16"/>
<wire x1="48.26" y1="35.56" x2="48.26" y2="37.465" width="0.8128" layer="16"/>
<wire x1="48.26" y1="37.465" x2="47.625" y2="38.1" width="0.8128" layer="16"/>
<wire x1="47.625" y1="38.1" x2="45.72" y2="38.1" width="0.8128" layer="16"/>
<wire x1="45.72" y1="38.1" x2="45.085" y2="38.735" width="0.8128" layer="16"/>
<wire x1="45.085" y1="38.735" x2="45.085" y2="43.18" width="0.8128" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R11" pad="2"/>
<contactref element="LED2" pad="K"/>
<wire x1="56.03875" y1="38.1" x2="59.69" y2="38.1" width="0.8128" layer="16"/>
<wire x1="60.325" y1="38.735" x2="60.325" y2="45.72" width="0.8128" layer="16"/>
<wire x1="59.69" y1="38.1" x2="60.325" y2="38.735" width="0.8128" layer="16"/>
<wire x1="56.03875" y1="38.1" x2="54.9275" y2="39.21125" width="0.8128" layer="16"/>
<wire x1="54.9275" y1="39.21125" x2="54.9275" y2="40.3225" width="0.8128" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="R16" pad="2"/>
<wire x1="39.0525" y1="34.29" x2="41.275" y2="36.5125" width="0.8128" layer="16"/>
<contactref element="Q7" pad="B"/>
<wire x1="34.29" y1="34.29" x2="39.0525" y2="34.29" width="0.8128" layer="16"/>
<wire x1="41.275" y1="36.5125" x2="41.275" y2="38.1" width="0.8128" layer="16"/>
<wire x1="41.275" y1="38.1" x2="42.545" y2="39.37" width="0.8128" layer="16"/>
<wire x1="42.545" y1="39.37" x2="42.545" y2="40.3225" width="0.8128" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="Q7" pad="E"/>
<contactref element="ICSP" pad="2"/>
<contactref element="R6" pad="2"/>
<contactref element="R17" pad="2"/>
<wire x1="21.59" y1="25.4" x2="19.05" y2="25.4" width="0.8128" layer="16"/>
<wire x1="19.05" y1="25.4" x2="17.78" y2="25.4" width="1.27" layer="16"/>
<wire x1="21.59" y1="25.4" x2="17.78" y2="25.4" width="0.8128" layer="16"/>
<wire x1="21.59" y1="25.4" x2="21.59" y2="22.86" width="0.8128" layer="16"/>
<wire x1="21.59" y1="22.86" x2="31.75" y2="22.86" width="0.8128" layer="16"/>
<wire x1="31.75" y1="22.86" x2="33.02" y2="24.13" width="0.8128" layer="16"/>
<wire x1="33.02" y1="24.13" x2="33.02" y2="27.94" width="0.8128" layer="16"/>
<wire x1="33.02" y1="27.94" x2="34.29" y2="29.21" width="0.8128" layer="16"/>
<wire x1="21.59" y1="20.32" x2="21.59" y2="22.86" width="0.8128" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="R1" pad="2"/>
<contactref element="U1" pad="24"/>
<wire x1="37.7825" y1="40.3225" x2="37.7825" y2="45.72" width="0.8128" layer="16"/>
<wire x1="37.7825" y1="40.3225" x2="40.3225" y2="40.3225" width="0.8128" layer="16"/>
<wire x1="38.1" y1="45.72" x2="49.8475" y2="45.72" width="0.8128" layer="16"/>
<contactref element="R20" pad="2"/>
<wire x1="38.1" y1="45.72" x2="37.7825" y2="45.72" width="0.8128" layer="16"/>
<wire x1="53.34" y1="35.56" x2="53.34" y2="37.465" width="0.8128" layer="16"/>
<wire x1="53.34" y1="37.465" x2="51.59375" y2="39.21125" width="0.8128" layer="16"/>
<wire x1="51.59375" y1="39.21125" x2="51.59375" y2="43.97375" width="0.8128" layer="16"/>
<wire x1="51.59375" y1="43.97375" x2="49.8475" y2="45.72" width="0.8128" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="R17" pad="1"/>
<wire x1="26.67" y1="25.4" x2="28.575" y2="25.4" width="0.8128" layer="16"/>
<wire x1="28.575" y1="25.4" x2="28.575" y2="43.4975" width="0.6096" layer="1"/>
<via x="28.575" y="25.4" extent="1-16" drill="0.8" diameter="1.27"/>
<via x="28.575" y="43.4975" extent="1-16" drill="0.8" diameter="1.27"/>
<contactref element="Q10" pad="3"/>
<wire x1="28.575" y1="43.4975" x2="28.575" y2="42.2275" width="0.8128" layer="16"/>
<wire x1="28.575" y1="42.2275" x2="29.21" y2="41.5925" width="0.8128" layer="16"/>
<wire x1="29.21" y1="41.5925" x2="30.1625" y2="41.5925" width="0.8128" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="Q8" pad="2"/>
<contactref element="R18" pad="1"/>
<wire x1="40.64" y1="17.78" x2="43.18" y2="17.78" width="0.8128" layer="16"/>
<wire x1="43.18" y1="17.78" x2="43.815" y2="17.145" width="0.8128" layer="16"/>
</signal>
<signal name="N$33">
<contactref element="Q3" pad="2"/>
<contactref element="R19" pad="1"/>
<wire x1="55.88" y1="24.765" x2="54.61" y2="22.86" width="0.8128" layer="16"/>
</signal>
<signal name="N$34">
<contactref element="Q10" pad="2"/>
<contactref element="R20" pad="1"/>
<wire x1="30.48" y1="45.72" x2="31.115" y2="45.72" width="0.8128" layer="16"/>
<wire x1="31.115" y1="45.72" x2="31.4325" y2="45.4025" width="0.8128" layer="16"/>
<wire x1="31.4325" y1="45.4025" x2="31.4325" y2="43.4975" width="0.8128" layer="16"/>
</signal>
<signal name="N$35">
<contactref element="R21" pad="1"/>
<contactref element="Q9" pad="2"/>
<wire x1="74.295" y1="21.59" x2="74.295" y2="19.05" width="0.8128" layer="16"/>
</signal>
<signal name="N$36">
<contactref element="Q1" pad="2"/>
<contactref element="R22" pad="1"/>
<wire x1="30.48" y1="15.24" x2="27.305" y2="15.24" width="0.8128" layer="16"/>
<wire x1="27.305" y1="15.24" x2="26.67" y2="14.605" width="0.8128" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
