;	Inductance & Capacitance Meter with Software calibration
;	First, let us choose our weapon - a 16F628
; LC002	- THIS ONE WORKS FINE WITH A WELL BEHAVED DISPLAY
;	Deleted  CpyBin subroutine and one call to it
;	Modified B2_BCD to take its input directly from <AARGB0,1,2>
;	Modified "oscillator test" so it copies F3   to <AARGB0,1,2>
;	Fixed Get_Lcal so it gets the correct number
;	Minor adjustment to MS100 timing to correct frequency display
;	Check for oscillator too slow when measuring L or C.
; LC003	- Optimised / Modified to handle "bad" displays
;	Removed duplicated code in DATS subroutine
;	Added code to fix crook display (select by jumper on B4 - 10)
;	Optimised L & C formatting code
;	Optimised "Display" subroutine
;	Cleaned up LCDINIT
; LC004 - Deleted timer Interrupt Service Routine
;	Modified way oscillator "out of range" condition is detected
; LC628 - LC004 code ported to 16F628 by Egbert Jarings PA0EJH.
;	Mem starts now at 0x20
;	InitIO modified , 628 PortA start's up in Analog Mode 
;	So changed to Digital Mode (CMCON)
;	Display's "Calibrating" to fill up dead Display time
;	when first Powerd Up.
;	Changed pmsg Routine, EEADR  trick  wont work with 628,
;	PCL was always 0x00 so restart occurs. EEADR is now Etemp.
;	Also changed EEADR in FP routine to Etemp 
;	Bad Display isn't bad at all, its a Hitachi HD44780, as
;	80% of all Display's are. Adress as 2 Lines x 8 Char.
;	So LCDINIT modified for 2 x 8 Display's. (0x28 added)
; LC005 - Cosmetic rewrite of RAM allocation from LC004
;	No change to address of anything - I hope
;	Identified unused RAM & marked for later removal.
; LC006 - Merge LC005 and LC628
;	All "#ifdef" F628 parts by Egbert Jarings PA0EJH.
;	(or derived from his good work)
;	Cleaned up RAM allocation.
;	Added message re: processor type, just to verify selection
;	Included extra initialisation (2 line) command by PA0EJH
; lc007	Changed strings to EEPROM (it's not used for anything else)
;	Added "error collector" code to catch "all" FP errors
;       Addded macros
; LC_swcal.000
;	Changed to use only F628 processor
;	Used internal comparator of F628 in place of LM311
;	Switched relay directly by digital I/O
;	Implemented software calibration via constant in EEPROM
;	Re-allocated most I/O pins
;	Added output munger for LCD connections (easy to re-allocate)
;o-----o-----o-----o-----o-----o-----o-----o-----o-----o-----o-----o
;	Some frequently used code fragments
;	Use macros to make mistreaks consistently.
;	Select Register Bank 0
bank0	macro
	errorlevel	+302		; Re-enable bank warning
	bcf		STATUS,RP0	; Select Bank 0
	endm
;	Select Register Bank 1
bank1	macro
	bsf		STATUS,RP0	; Select Bank 1
	errorlevel	-302		; disable warning
	endm
;	Swap bytes in register file via W
swap	macro	this,that
	movf	this,w		; get this
	xorwf	that,f		; Swap using Microchip
	xorwf	that,w		; Tips'n Tricks
	xorwf	that,f		; #18
	movwf	this
	endm
;	Copy bytes in register file via W
copy	macro	from,to
	MOVF	from,W
	MOVWF	to
	endm
;	CPU configuration
	MESSG		"Processor = 16F628"
	processor	16f628
	include		<p16f628.inc>
	__CONFIG        _CP_OFF & _WDT_OFF & _PWRTE_ON & _HS_OSC & _BODEN_ON & _LVP_OFF
;	I/O Assignments.
#define	LCD0	PORTB,3
#define	LCD1	PORTB,2
#define	LCD2	PORTB,1
#define	LCD3	PORTB,0
#define	ENA	PORTB,4		; Display "E"
#define	RS	PORTB,5		; Display "RS"
#define	functn	PORTB,6		; 0 = "Inductor"
#define relay	PORTB,7		; Switches Ccal
;	file register declarations: uses only registers in bank0
;	bank 0 file registers begin at 0x0c in the 16F84
;	and at 0x20 in the 16F628
	cblock	0x20
;       Floating Point Stack and other locations used by FP.TXT
;	FP Stack: TOS	A = 	AEXP:AARGB0:AARGB1:AARGB3:AARGB4
;			B = 	BEXP:BARGB0:BARGB1:BARGB2
;			C = 	CEXP:CARGB0:CARGB1
	AARGB4
	AARGB3
	AARGB2
	AARGB1
	AARGB0
	AEXP			; 8 bit biased exponent for argument A
	SIGN			; save location for sign in MSB
	FPFLAGS			; floating point library exception flags
	BARGB2
	BARGB1
	BARGB0
	BEXP			; 8 bit biased exponent for argument B
	TEMPB3			; 1 Unused byte
	TEMPB2			; 1 Unused byte
	TEMPB1			; Used
	TEMPB0			; 1 Unused byte
	CARGB1
	CARGB0			; most significant byte of argument C
	CEXP			; 8 bit biased exponent for argument C
;	"Main" Program Storage
	COUNT			; Bin to BCD convert (bit count)
	cnt			;                    (BCD BYTES)
	CHR 
	F1:2
	F2:2
	F3:2
	bcd:4			; BCD, MSD first 
	TabStop			; Used to fix bad displays.
	TabTemp
	FPE			; Collect FP errors in here
	R_sign			; Holds "+" or " " (sign)
	EEflag:1		; Cal adjust flag
	endc
	cblock	0x70		; Common RAM
	cal_t:2			; Ccal temporary value
	PB_data:1		; LCD output munger temp
	links:1			; User test links copy
	COUNT1			; Used by delay routines
				; and "prescaler flush"
	COUNT2			; Timing (100ms)
	endc
EXP	equ	AEXP		; Used by FP.TXT
TEMP	equ	TEMPB0
;AARG	equ	AARGB0		; Unused
;BARG	equ	BARGB0		; Unused
;CARG	equ	CARGB0		; Unused
;       GENERAL MATH LIBRARY DEFINITIONS
;	define assembler constants
B0		equ	0
B1		equ	1
B2		equ	2
B3		equ	3
B4		equ	4
B5		equ	5
B6		equ	6
B7		equ	7
MSB		equ	7
LSB		equ	0
;     STATUS bit definitions
#define	_C	STATUS,0
#define	_Z	STATUS,2
;       FLOATING POINT literal constants
EXPBIAS         equ     D'127'
IOV             equ     0       ; bit0 = integer overflow flag
FOV             equ     1       ; bit1 = floating point overflow flag
FUN             equ     2       ; bit2 = floating point underflow flag
FDZ             equ     3       ; bit3 = floating point divide by zero flag
NAN		equ	4	; bit4 = not-a-number exception flag
DOM		equ	5	; bit5 = domain error exception flag
RND             equ     6       ; bit6 = floating point rounding flag, 0 = truncation
                                ; 1 = unbiased rounding to nearest LSB
SAT             equ     7       ; bit7 = floating point saturate flag, 0 = terminate on
                                ; exception without saturation, 1 = terminate on
                                ; exception with saturation to appropriate value
;	Motorola syntax branches
#define	beq	bz 
#define	BEQ	bz
#define	BNE	bnz
#define	bne	bnz
#define	BCC	bnc
#define	bcc	bnc
#define	BCS	bc
#define	bcs	bc
#define	BRA	goto
#define	bra	goto
;	Begin Executable Stuff(tm)
	org	0
GO	clrwdt			; 0 << Reset
	call	InitIO
	bcf	relay		; Remove Ccal
;	Main Program
START	CALL	LCDINIT	 	; INITIALIZE LCD MODULE	
	call	EE_RD		; Retrieve CCal integer value
cmdloop	call	HOME
;	"Zero" the meter.
Chk4Z	MOVLW   Calibr-0x2100	; Display's " Calibrating "
	call	pmsg		; to entertain the punters
	call	Measure		; Dummy Run to stabilise oscillator.
	call	MS200
	call	Measure		; Get freq in F3
	copy	F3+0,F1+0	; Copy F3 to F1
	copy	F3+1,F1+1
	bsf	relay		; Add standard capacitor
	call	MS200
	copy	F3+0,F2+0	; Copy F3 to F2
	copy	F3+1,F2+1
	bcf	relay		; Remove standard capacitor
	call	MS200
;	Now we resume our regular pogrom
;	Read state of user test links on LCD bus
M_F3	bank1			; PORTB:-
	movlw	b'01001111'	; LCD data bits to read
	movwf	TRISB		; 1 = input
	bank0			; 0 = output
	call	MS2		; Settling time
	copy	PORTB,links
	bank1
	movlw	b'01000000'	; restore data direction
	bank0			; 0 = output
;	Take a break from regular duties to do something interesting
	btfss	links,0		; Raise Ccal value
	goto	cal_up
	btfss	links,1		; Lower Ccal value
	goto	cal_dn
	btfss	links,2		; Test osc without Ccal
	goto	osc1
	btfss	links,3		; Test osc with Ccal
	goto	osc2
;	None of the above
	bcf	relay		; In case of osc test
	btfss	EEflag,0	; Time to save Ccal value?
	goto	cont		; No. Back to work
	bcf	EEflag,0	; To say we have done it
	call	EE_WR		; So, we better save it
	goto	cont		; Hi Ho, its off to work I go
;	Add +10 to cal_t:2
cal_up	bsf	EEflag,0	; Say "we're adjusting"
	movlw	0x0a		; +10
	addwf	cal_t+1,f
	bcc	cont
	incf	cal_t+0,f
	goto cont
;	Add -10 to cal_t:2
cal_dn	bsf	EEflag,0	; Say "we're adjusting"
	movlw	0xf6		; -10
	addwf	cal_t+1,f
	bcc	hi_byte
	incf	cal_t+0,f
hi_byte	movlw	0xff
	addwf	cal_t+0,f
	goto	cont		
;	Measure & display osc freq for initial setup
osc2	bsf	relay		; Add Ccal
osc1	call	HOME
	call	Measure		; Measure Local Osc Freq.
	call	CLEAR
	btfss	INTCON,T0IF	; Set = Counter overflow?
	goto	Do_Disp
	MOVLW	ovr-0x2100	; Over-range message
	call	pmsg
	goto	M_F3
Do_Disp	clrf	AARGB0		; Copy to 24 bit number
	movf	F3,W		; in AARGB0, 1, 2
	movwf	AARGB1		; for display
	movf	F3+1,W
	movwf	AARGB2
	call	Display
	goto	M_F3
cont	call	HOME
	call	MS200
	call	Measure		; Measure F3 & leave it there
	movf	F3,w		; test for "too low" frequency
	beq	OORange		; F < 2560Hz ?
	btfss	INTCON,T0IF	; test for "too high" frequency
	goto	OK2GO		; F > 655359Hz ?
OORange	MOVLW	ovr-0x2100	; Over/Under range message
	call	pmsg
	goto	M_F3
;	Precompute major bracketed terms cos
;	we need 'em both for all calculations
OK2GO	clrf	FPE		; Declare "error free"
	call	F1_F2
	call	F1_F3
;	See what mode we are in
	btfss	functn		; 0=Inductor
	goto	Do_Ind
;	OK, we've been told it's a capacitor
Do_Cap	call	C_calc
	movf	FPE,f		; Any FP errors?
	bne	complain
	movlw	Cintro-0x2100	; C =
	call	pmsg
	call	C_disp
	goto	M_F3
;	Now, they reckon it's a @#$*! inductor
Do_Ind	call	L_calc
	bne	complain
	movlw	Lintro-0x2100	; L =
	call	pmsg
	call	L_disp
	goto	M_F3
;	Got a Floating Point Error of some sort
complain	movlw	ovr-0x2100	; Over Range
		call	pmsg
		goto	M_F3
;	Print String addressed by W
;	Note: Strings are in EEPROM
;	We do a lotta bank switching here.
pmsg	bank1
	movwf	EEADR		; pointer
pm1	BSF     EECON1,RD       ; EE Read
        MOVF    EEDATA,W        ; W = EEDATA, affects Z bit
        bank0			; Does not change Z bit
	btfsc	STATUS,Z	; ZERO = All done
	return			; so quit
	call	DATS		; Byte -> display
	bank1
	INCF    EEADR,F         ; bump address
	goto	pm1
;	Delay for 2ms (untrimmed)
MS2	MOVLW	0xFD		; DELAY 2ms
	MOVWF	COUNT1
	MOVLW	0x66
	MOVWF	COUNT2
	goto	L3		
;	Delay for about 200ms or 300ms (untrimmed)
MS300	call	MS100
MS200	call	MS100
;	Delay for about 100ms
MS100	MOVLW	0x7e		; Count up
	MOVWF	COUNT1		; to roll-over
	MOVLW	0x20		; was 0x19, then 0x25, then 1f
	MOVWF	COUNT2			
L3	INCFSZ	COUNT2,F
	GOTO	L3
	INCFSZ	COUNT1,F
	GOTO	L3
	RETLW	0
;	Put a BCD nybble to display
PutNyb	ANDLW	0x0F		; MASK OFF OTHER PACKED BCD DIGIT
	ADDLW	0x30		; Convert BIN to ASCII
;	Put a byte to display
DATS	decf	TabStop,F	; Time to tickle bad display?
	bne	DAT1		; Not yet
	movwf	TabTemp		; Save character
;	btfss	FIXIT		; Check if we got a crook one.
;	CALL	LINE2		; Skip this if good
	movf	TabTemp,W	; Restore character
DAT1	BSF	RS		; SELECT DATA REGISTER
CM	MOVWF	CHR		; STORE CHAR TO DISPLAY
	SWAPF	CHR,W		; SWAP UPPER AND LOWER NIBBLES (4 BIT MODE)
	call	PB_dly
	MOVF	CHR,W		; GET CHAR AGAIN 
;	Put 4 bits to LCD & wait (untrimmed)
PB_dly	movwf	PB_data		; Save nybble
	btfss	PB_data,0	; copy LSbit
	bcf	LCD0
	btfsc	PB_data,0
	bsf	LCD0
	btfss	PB_data,1
	bcf	LCD1
	btfsc	PB_data,1
	bsf	LCD1
	btfss	PB_data,2
	bcf	LCD2
	btfsc	PB_data,2
	bsf	LCD2
	btfss	PB_data,3	; copy MSbit
	bcf	LCD3
	btfsc	PB_data,3
	bsf	LCD3
	BSF	ENA		; ENA HIGH
	NOP			
	BCF	ENA		; ENA LOW 
;	goto	D200us		; Fall into DELAY subroutine
;	Delay for 200us (untrimmed)
D200us	MOVLW	0x42		; DELAY  200us
	MOVWF	COUNT1	
NXT5	DECFSZ	COUNT1,F
	GOTO	NXT5	
	RETLW	0
;	Convert 24-bit binary number at <AARGB0,1,2> into a bcd number
;	at <bcd>. Uses Mike Keitz's procedure for handling bcd 
;	adjust; Modified Microchip AN526 for 24-bits.
B2_BCD
b2bcd   movlw   .24		; 24-bits
        movwf   COUNT		; make cycle counter
        clrf    bcd+0		; clear result area
        clrf    bcd+1
        clrf    bcd+2
        clrf    bcd+3
b2bcd2  movlw   bcd 		; make pointer
        movwf   FSR
        movlw   .4
        movwf   cnt
; Mike's routine:
b2bcd3  movlw   0x33            
        addwf   INDF,f          ; add to both nybbles
        btfsc   INDF,3          ; test if low result > 7
        andlw   0xf0            ; low result >7 so take the 3 out
        btfsc   INDF,7          ; test if high result > 7
        andlw   0x0f            ; high result > 7 so ok
        subwf   INDF,f          ; any results <= 7, subtract back
        incf    FSR,f           ; point to next
        decfsz  cnt,f
        goto    b2bcd3
        rlf     AARGB2,f	; get another bit
        rlf     AARGB1,f
        rlf     AARGB0,f
        rlf     bcd+3,f         ; put it into bcd
        rlf     bcd+2,f
        rlf     bcd+1,f
        rlf     bcd+0,f
        decfsz  COUNT,f         ; all done?
        goto    b2bcd2          ; no, loop
        return                  ; yes
;*********** INITIALISE LCD MODULE 4 BIT MODE ***********************
LCDINIT CALL	MS100		; WAIT FOR LCD MODULE HARDWARE RESET
	BCF	RS		; REGISTER SELECT LOW
	BCF	ENA		; ENABLE LINE LOW
	MOVLW	0x03		; 1
	call	PB_dly
	CALL	MS100		; WAIT FOR DISPLAY TO CATCH UP
	MOVLW	0x03		; 2
	call	PB_dly
	MOVLW	0x03		; 3
	call	PB_dly
	MOVLW	0x02		; Fn set 4 bits
	call	PB_dly
	MOVLW	0x0C		; 0x0C DISPLAY ON
	CALL	ST200us
	MOVLW	0x28		; DISPLAY 2 Line , 5x7 Dot's
	CALL	ST200us		; New in LC628/LC006 version
	MOVLW	0x06		; 0x06 ENTRY MODE SET
	CALL	ST200us		; Fall into CLEAR
;************ CLEAR DISPLAY ***************************
CLEAR	MOVLW	0x01		; CLEAR DISPLAY
	goto	Home2		; LONGER DELAY NEEDED WHEN CLEARING DISPLAY
;*********** MOVE TO HOME *****************************
HOME	movlw	0x09		; Count characters
	movwf	TabStop		; before tickling display.
	MOVLW	0x02		; HOME DISPLAY
Home2	CALL	STROBE
	goto	MS2
;	SENDS DATA TO LCD DISPLAY MODULE (4 BIT MODE)	
STROBE	BCF	RS		; SELECT COMMAND REGISTER
	GOTO	CM
;************ MOVE TO START OF LINE 2 *****************
LINE2	MOVLW	0xC0		; ADDRESS FOR SECOND LINE OF DISPLAY
ST200us	CALL	STROBE
	goto	D200us
;       Initialise Input & Output devices
InitIO	movlw	b'00000110'
	movwf	CMCON 	   	; Select Comp mode
	bank1
	movlw	b'00000000'
	movwf	VRCON 	   	; Set Volt ref mode to OFF
	movlw	0x37		; Option register
	movwf	OPTION_REG	; Port B weak pull-up enabled
				; INTDEG Don't care
				; Count RA4/T0CKI
				; Count on falling edge
				; Prescale Timer/counter
				; divide Timer/counter by 256
				; PORTA:-
	movlw	b'11110111'	; initialise data direction
				; 1 = input
				; 0 = output
	movwf	TRISA		; PORTA<0>   = comp1 "-" in
				; PORTA<1>   = comp2 "-" in
				; PORTA<2>   = comp1&2 "+" in
				; PORTA<3>   = comp1 out
				; PORTA<4>   = comp2 out, T0CKI in
				; PORTA<5:7> = unused
				; PORTB:-
	movlw	b'01000000'	; initialise data direction
				; 1 = input
				; 0 = output
	movwf	TRISB		; PORTB<0>   = LCD out "DB4"
				; PORTB<1>   =         "DB5"
				; PORTB<2>   =         "DB6"
				; PORTB<3>   =         "DB7"
				; PORTB<4>   = E  out to LCD
				; PORTB<5>   = RS out to LCD
				; PORTB<6>   = function in
				; PORTB<7>   = Ccal switch out
	bank0
	return	
;	Measure Frequency. Stash in "F3 and F3+1"
Measure	bcf	INTCON,T0IF	; Declare "Not yet Over-range"
	CLRF	TMR0		; RESET INTERNAL COUNT (INCLUDING PRESCALER)
				; See page 27 Section 6.0
	CLRF	F3		; Ready to receive 16 bit number
	CLRF	F3+1
	bank1
				; OPEN GATE
	movlw	b'11100111'	; Enable RA4 output to T0CKI
	movwf	TRISA		; 1 = input
				; 0 = output
	CALL	MS100		; 100MS DELAY
				; CLOSE GATE (COUNT COMPLETE)
	movlw	b'11110111'	; Disable RA4 output to T0CKI
				; 0 = output
	bank0
	MOVF	TMR0,W		; GET HIGH BYTE		
	MOVWF	F3		; Copy to Big end of 16 bit result
; The comparator is "outputting" a 1 'cos we've forced it high
; so T0CKI=1.
PSC1	bank1
	bsf	OPTION_REG,T0SE	; Clock the prescaler
	nop
	bcf	OPTION_REG,T0SE
	bank0
	DECF	F3+1,F		; Decrement the counter
	movf	TMR0,W		; Has TMR0 changed?
	xorwf	F3,W		; if unchanged, XOR -> 0
	beq	PSC1
	return			; F3 : F3+1 now holds 16 bit result
;	Display contents of AARGB0,1,2 on LCD
;	First convert to BCD, Then ASCII (nybble at a time)
Display	CALL	B2_BCD		; CONVERT COUNT TO BCD		
	call	Swap0		; GET NEXT DIGIT
	call	Move0		; GET OTHER BCD DIGIT
	call	Swap1
	call	Move1
	call	Swap2
	call	Move2
	call	Swap3
	goto	Move3		; includes return
;	Formatted display of BCD work area for Capacitor
C_disp	movf	R_sign,w	; Sign
	call	DATS
F_C1	MOVF	bcd+0,W
	ANDLW	0x0F
	beq	F_C2
	CALL	PutNyb
	call	Swap1
	call	Move1
	CALL	DoDP		; Print DP
	call	Swap2
	goto	F_C3U
F_C2	swapf	bcd+1,W
	ANDLW	0x0F
	beq	F_C3
	CALL	PutNyb
	call	Move1
	call	Swap2
	call	Move2
	goto	F_C3U		; print nF. includes RETURN
F_C3	MOVF	bcd+1,W
	ANDLW	0x0F
	beq	F_C4
	CALL	PutNyb
	call	Swap2
	call	Move2
	call	Swap3
F_C3U	movlw	Unit1-0x2100	; nF
	goto	pmsg		; includes RETURN
F_C4	SWAPF	bcd+2,W		; Digit1 == 0 ?
	ANDLW	0x0F
	bne	NoB1_C
	MOVLW	0x20		; YES PRINT A SPACE
	call	DATS
	MOVF	bcd+2,W		; Digit2 == 0 ?
	ANDLW	0x0F
	bne	NoB2_C
	call	DATS
	bra	NoB3_C
NoB1_C	call	Swap2		; 1
NoB2_C	call	Move2		; 2
NoB3_C	call	Swap3		; 3
	call	Move3		; 4
	movlw	Unit2-0x2100	; pF
;	Formatted display of BCD work area for Inductor
L_disp	movf	R_sign,w	; Sign
	call	DATS
F_L1	MOVF	bcd+0,W
	ANDLW	0x0F
	beq	F_L2
	CALL	PutNyb
	call	Swap1
	call	Move1
	call	Swap2
	goto	F_L2U		; Print mH. includes RETURN
F_L2	swapf	bcd+1,W
	ANDLW	0x0F
	beq	F_L3
	CALL	PutNyb
	call	Move1
	call	Swap2
	call	Move2
F_L2U	movlw	Unit3-0x2100	; mH
F_L3	MOVF	bcd+1,W
	ANDLW	0x0F
	beq	F_L4
	CALL	PutNyb
	call	Swap2
	call	Move2
	call	Swap3
	goto	F_L4U		; Print uH. includes RETURN
F_L4	SWAPF	bcd+2,W		; Digit1 == 0 ?
	ANDLW	0x0F
	bne	NoB1_L
	call	DATS
	goto	NoB2_L
NoB1_L	call	Swap2		; 1
NoB2_L	call	Move2		; 2
	call	Swap3		; 3
	call	Move3		; 4
F_L4U	movlw	Unit4-0x2100	; uH
;	Common subroutine for formatted output
DoDP	MOVLW	'.'		; Print DP
	goto	DATS		; Return from DATS
Swap0	SWAPF	bcd+0,W		; GET NEXT DIGIT
	goto	PutNyb		; DISPLAY IT
Move0	MOVF	bcd+0,W		; GET OTHER BCD DIGIT
	goto	PutNyb
Swap1	SWAPF	bcd+1,W
	goto	PutNyb
Move1	MOVF	bcd+1,W
	goto	PutNyb
Swap2	SWAPF	bcd+2,W
	goto	PutNyb
Move2	MOVF	bcd+2,W
	goto	PutNyb
Swap3	SWAPF	bcd+3,W
	goto	PutNyb
Move3	MOVF	bcd+3,W
	goto	PutNyb
;	Stack operations
;add		call	FPA24
;		goto	S_fix
subtract	call	FPS24
		goto	S_fix
divide		call	FPD24
		goto	S_fix
multiply	call	FPM24
;		goto	S_fix
;	Fix stack after add, subtract, divide & multiply
;	AND Collect ALL Floating Point Errors in FPE
S_fix	iorwf	FPE,f			; W may hold Error (0xff)
	copy	CARGB1,BARGB1		; C -> B
	copy	CARGB0,BARGB0
	copy	CEXP,BEXP
	return
;	Push stack (duplicates TOS)
S_push	copy	BARGB1,CARGB1		; B -> C
	copy	BARGB0,CARGB0
	copy	BEXP,CEXP
	copy	AARGB1,BARGB1		; A -> B
	copy	AARGB0,BARGB0
	copy	AEXP,BEXP
	return
;	Swap A and B
S_swap	swap	AARGB1,BARGB1		; A <-> B
	swap	AARGB0,BARGB0
	swap	AEXP,BEXP
	return
;	Calculate Unknown Capacitance OR inductance
;       Output: 24 bit positive integer (scaled)
;	right justified in AARGB0, AARGB1, AARGB2
;	also as BCD in bcd:bcd+1:bcd+2:bcd+3
C_calc	call	divide
	call	Get_Ccal	; Times 10,000 ( = 1000.0pF)
	call	multiply
	goto	PorM		; includes return
L_calc	call	multiply
	call	Get_Lscale	; Precomputed Scale_factor/(4*PI*PI)
	call	multiply
	call	Get_Ccal
	call	S_swap
	call	divide
L_divF1	call	Get_F1		; Divide by F1^2
	call	S_push
	call	multiply
	call	S_swap
	call	divide
;	Handle Space or Minus in front of FP number
PorM	btfss	AARGB0,7	; test sign
	goto	Pplus
Pminus	movlw	0x2d		; minus
	goto	PMdisp
Pplus	movlw	0x20		; plus
PMdisp	movwf	R_sign		; save for later display
	bcf	AARGB0,7	; make plus anyway
;	Format as raw BCD string in bcd:bcd+1:bcd+2:bcd+3
	call	INT2424		; To INT in AARGB0 etc.
	goto	B2_BCD		; includes return
;	Calculate (F1/F3)^2-1, leave result on stack
F1_F3	call	Get_F3
	goto	F1_F1
;	Calculate (F1/F2)^2-1, leave result on stack
F1_F2	call	Get_F2
F1_F1	call	Get_F1
	call	divide		; F1/Fx
	call	S_push
	call	multiply	; (F1/Fx)^2
	call	Get_One
	call	S_swap
	goto	subtract	; (F1/Fx)^2-1
				; includes return
;	Fetch assorted things used for the calculation
;	of Unknown L and C
Get_Lscale	call	S_push		; make room first
		movlw	0xB8		; 2.53303e+17
		movwf	AEXP		; Create FP version of
		movlw	0x60		; Precomputed 1/(4*PI*PI)
		movwf	AARGB0		; times any needed
		movlw	0xFA		; fiddle factor (1/100)
		movwf	AARGB1
		return
Get_One		call	S_push		; make room first
		clrf	AEXP		; Create a binary 1
		clrf	AARGB0
		clrf	AARGB1
		movlw	0x01
		goto	LSB2stak
Get_Ccal	movlw	cal_t		; Get integer value
		goto	W2stak		; Includes stack push
Get_F1		movlw	F1		; Includes stack push
		goto	W2stak
Get_F2		movlw	F2		; Includes stack push
		goto	W2stak
Get_F3		movlw	F3		; Includes stack push
;		goto	W2stak
;	Copy 16 bit number, pointed to by W, to stack
;	and convert to FP (positive value only)
;	via a 24 bit number in AARGB0,1,2
W2stak		movwf	FSR
		clrf	AEXP
		clrf	AARGB0
		movf	INDF,W		; Big Byte first
		movwf	AARGB1
		incf	FSR,F		; then little byte
		movf	INDF,W
LSB2stak	movwf	AARGB2
		CALL	FLO2424		; 24 bit int -> 24 bit FP
		RETURN
;	Read EEPROM into "cal_t"
EE_RD	bank1
	movlw	cal_p-0x2100	; Address to read
	MOVWF	EEADR
	bank0
	CALL	EE_R
	MOVWF	cal_t+0
	CALL	EE_Rinc
	MOVWF	cal_t+1
	RETURN
EE_Rinc	bank1
EE_R	bank1
	bank0
	RETURN
;	Write EEPROM from "cal_t"
EE_WR	bank1
	movlw	cal_p-0x2100
	MOVWF	EEADR		; Address to write
	MOVF	cal_t+0,W	; Data byte #0
	CALL	EE_W
	MOVF	cal_t+1,W	; Data byte #1
	CALL	EE_Winc
	bank0
	RETURN
	errorlevel	-302	; In Bank 2
EE_Winc	INCF	EEADR,F		; bump address
EE_W	MOVWF	EEDATA
	BSF	EECON1,WREN	; Enable Write
	MOVLW	0x55		;
	MOVWF	EECON2		; Write 0x55
	MOVLW	0xAA		;
	MOVWF	EECON2		; Write 0xAA
	BSF	EECON1,WR	; Set WR bit (begin write)
EE_W2	BTFSC	EECON1,WR	; Wait for write to finish
	GOTO	EE_W2
	bank0
	BCF	PIR1,EEIF	; clear interrupts
	bank1
	RETURN	
	errorlevel	+302
	INCLUDE <FP.TXT>
;	Text Strings (stored in data EEPROM)
        ORG 0x2100
ovr	de	"   Over Range   ",0
Unit1	de	" nF",0
Unit2	de	" pF",0
Unit3	de	" mH",0
Unit4	de	" uH",0
Cintro	de	" C = ",0
Lintro	de	" L = ",0
Calibr  de	"   Calibrating  ",0
cal_p	de	0x27,0x10		; Initial value = 10000
 	END
