PC/AT PARALLEL INTERFACE SECRET 1-3
        *    PARALLEL INTERFACE  FOR PRINTER OR NOT *
1. HOW TO FIND PARALLEL ADDRESS FIELD
1.1. BIOS DATA FIELD   - PARALLEL INTERFACES
000408H to 00040FH = input-output addresses (2 bytes) for parallel
interfaces LPT1, LPT2, LPT3, LPT4 respectively.
  - 000408H = No.0 logical channel input-output address = LPT1
  - 00040AH = No.1 logical channel input-output address = LPT2
  - 00040CH = No.2 logical channel input-output address = LPT3
  - 00040EH = No.3 logical channel input-output address = LPT4
Attention!: the channel number (LPTx) is assigned by the BIOS in the order
of channels actually present at addresses 03BCH, 0378H, 0278H. For example,
if there is only one interface at address 0278H, it is assigned to LPT1.
000478H to 00047BH = Time-out (1 byte) for printers No.0, No.1, No.2 and
No.3,  respectively.
1.2. USE DEBUG PROGRAM
*********** HOW TO FIND PARALLEL ADRESS FIELD :  *****************
                 debug <RETURN>
                 d 0:408 <RETURN>
                 The screen is :
C:\> debug               command
-d 0:408                 commande
0000:0400                         -78 03 00 00 00 00 00 00
0000:0410  33 02 C1 80 02 00 41 80-00 00 26 00 26 00 34 05
0000:0420  30 0B 30 0B 0D 1C 73 1F-0D 1C 64 20 65 12 62 30
0000:0430  75 16 67 22 0D 1C 64 20-20 39 30 0B 3A 34 01 00
0000:0440  8C 00 4B 01 07 35 00 B1-20 07 50 00 00 40 00 00
0000:0450  00 08 00 00 00 00 00 00-00 00 00 00 00 00 00 00
0000:0460  0C 0B 00 B4 03 29 00 03-00 00 E0 FF 17 40 16 00
0000:0470  00 00 00 00 00 02 B1 00-14 14 14 14 01 01 01 01
-q                       command to quit
C:\>
The 8 first byte are start address field of parallel ports :
                                  -78 03 00 00 00 00 00 00  (0378 Hexa)
                                    LPT1  LPT2  LPT3  LPT4
                       only one parallel port use in this example
2. General
The parallel interface consists of a circuit specially designed for this
purpose; it includes:
  - 1 data register,
  - 1 command register,
  - 1 control port.
It occupies three addresses. The address field is determined by straps or
switchs (address decoder).
|         I/O address         |       PARALLEL INTERFACE         |
|             or         or   |      Description     |Access mode|
|  0378H  |  03BCH  |  0278H  |8-bit data register   |    Write  |
|  0379H  |  03BDH  |  0279H  |5-bit control port    |    Read   |
|  037AH  |  03BEH  |  027AH  |5-bit command register|    Write  |
The signals exchanged with the printer are sequenced by the registers and
control port; no controller is used: the time-out required to match the
different transmission speeds is done by software (time-out parameter). In
effect, except for certain applications, the software does not use the
parallel interface in interrupt mode.
You can use parallel port as an external PC/AT input or output, reading or
writing registers bits. You can command many external systems, not
especially a printer.
3. Description of the registers
Data register: 0378H (Read/Write)
Writing to this address causes the data to be stored at printer data port.
Reading from this address causes the transfer of printer port data to the
CPU data bus.
Titel       : PC/AT PARALLEL INTERFACE SECRET 2-3
Command register: 037AH (Write)
|                 PARALLEL INTERFACE COMMAND REGISTER                 |
|   b7  |   b6  |   b5  |   b4   |   b3    |   b2   |   b1   |   b0   |
|   x   |   x   |   x   | IRQEN  |SELECTIN*| INIT*  | AUTOFD*| STROBE*|
                            |               Command signals
                            |               sent to
                            |               parallel interface
                       IRQEN : (IRQ Enable)
                              _1 = interrupt valid
                              _0 = interrupt masked
                              generated on the rising edge of the
                              ACK* signal)
Control port: 0379H (Read)
|                   PARALLEL INTERFACE CONTROL PORT                     |
|  BUSY  |  ACK*  |   PE   | SELECT |ERROR*  |    x   |    x   |    x   |
               Parallel interface status
               signals are read;
               these bits are not stored
A rising edge of the ACK signal generates an interrupt request, if this
interrupt request is not masked (IRQEN* command register bit).
4. Electrical interface
The levels of all the signals are TTL compatible.
                             HE5 type connector 25-pin female
|  PRINTER INTERFACE PINS        Connector       |  |     O     |
| Pin  |Signal |I/O mode|| Pin  |Signal |I/O mode| 1| |o     o| |14
-------------------------------------------------- 2| |o     o| |15
|   1  |STROBE*|  O     ||  14  |AUTOFD*|   O    | 3| |o     o| |16
|   2  | DATA0 |  O     ||  15  |ERROR* |   I    | 4| |o     o| |17
|   3  | DATA1 |  O     ||  16  | INIT* |   O    | 5| |o     o| |18
|   4  | DATA2 |  O     ||  17  |SLCTIN*|   O    | 6| |o     o| |19
|   5  | DATA3 |  O     ||  18  |  GND  |        | 7| |o      | |
|   6  | DATA4 |  O     ||  19  |  GND  |        | 8| |o     o| |20
|   7  | DATA5 |  O     ||  20  |  GND  |        | 9| |o     o| |21
|   8  | DATA6 |  O     ||  21  |  GND  |        |10| |o     o| |22
|   9  | DATA7 |  O     ||  22  |  GND  |        |11| |o     o| |23
|  10  |  ACK* |  I     ||  23  |  GND  |        |12| |o     o| |24
|  11  |  BUSY |  I     ||  24  |  GND  |        |13| |o     o| |25
|  12  |  PE   |  I     ||  25  |  GND  |        |  | |-------/ |
|  13  |  SLCT |  I     -|------|-------|--------|  |     O     |
                          - Connector  pin arrangement
ACK*: When active, (pulse of several micro.s) this signal indicates that
  the data has been handled by the printer.
AUTOFD*: (automatic feed) when low, this signal control the paper feed
  motor. Writing a 1 in the interface control AUTOFD* bit causes an
  automatic line feed after each carriage return. This bit must be reset
  if the printer controls the automatic line feed or if the file to be
  printed already has a line feed stored after each carriage return.
BUSY: When active (high), this signal indicates that the printer is busy
  and that data cannot be handled.
DATA0 to DATA7: Data lines. Data is transmitted in 8-bits format (extended
  ASCII code).
ERROR*: Active low, this signal indicates that the printer is in standby
  subsequent to error detection (such as paper end).
INIT*: Active low, this signal initializes the printer's electronics.
PE: (Paper End) when high, this signal indicates that a sensor has detected
  a paper end condition.
SLCTIN*: When low, this signal enables printer operation.
SLCT: When high, this signal indicates that the printer is ready to receive
  data (response to SELECTIN)
STROBE*: Active low, this signal samples the data present on the data
  lines.
Titel       : PC/AT PARALLEL INTERFACE SECRET 3-3
5. Parallel printer connection
COMPUTER                                                 PRINTER
(connector HE5, 25-pin)                          (Centronics type
                                                  36-pin connector)
STROBE*          1 -----------------------------> 1       STROBE*
D0 to D7    2 to 9 -----------------------------> 2 to 9  D0 to D7
ACK*            10 <----------------------------- 10      ACK*
BUSY            11 <----------------------------- 11      BUSY
PE              12 <----------------------------- 12      PE
SELECT          13 <----------------------------- 13      SELECT
AUTO FEED       14 -----------------------------> 14      AUTO FEED
ERROR           15 <----------------------------- 32      ERROR
INIT            16 -----------------------------> 31      INIT
SELECT IN       17 -----------------------------> 36      SELECT IN
ground    18 to 25 ------------------------------ 19 to 30 ground
               |     O     |
     STROBE*  1| ||     || |19 ground
       DATA0  2| ||     || |20 ground
       DATA1  3| ||     || |21 ground
       DATA2  4| ||     || |22 ground
       DATA3  5| ||     || |23 ground
       DATA4  6| ||     || |24 ground
       DATA5  7| ||     || |25 ground
       DATA6  8| ||     || |26 ground
       DATA7  9| ||     || |27 ground
        ACK* 10| ||     || |28 ground
        BUSY 11| ||     || |29 ground
          PE 12| ||     || |30 ground
        SLCT 13| ||     || |31 INIT*
  AUTO FEED* 14| ||     || |32 ERROR*
             15| ||     || |33 ground
      ground 16| ||     || |34
     chassis 17| ||     || |35
         +5V 18| ||     || |36 SLCTIN*
               |     O     |
 - Centronics type 36-pin connector pin arrangement
6. Printer control procedure
The Centronics interface is a parallel interface between the microcomputer
and a printer.
The characters are sent to the printer in ASCII code..
Synchronization and dialogue are provided by three signals: STROBE*, ACK*
and BUSY.
CONTROL PROCEDURE
DATA    --            ----------------            ----------------
          <T1><T2>                    <T1><T2>
STROBE*       ----<T3>                    ----<T3>
BUSY    -----------------       ------------------            ----
ACK*                            --                            --
                               >--<2,5 a 30 mic.s
IRQ     ---------------------------     -------------------------
SENDING A CHARACTER TO THE PRINTER: When the BUSY line is at 1, the printer
accepts a character. The ASCII code of the character is presented in
parallel on the printer's data bus.
After time-out T1 (Set Up Time = 1micro.s at least), the system switchs the
STROBE* signal to 0. On the falling edge of this signal, the character code
is handled by the printer. The data bus must keep the character code for at
least T2+T3 (Strobe + Hold Time).
PRINTER RESPONSE: The printer responds by switching the BUSY line to 1 to
signal that it will not accept another character. This signal indicates the
printer's status.
By sending an ACK* signal (5 micro.s to 30 micro.s pulse), it signals that
the data has been handled and more data can be accepted.
END
*         73 QRO               *
*   F6FLV@FF6KRK.FRPA.FRA.EU   *
*        Jean-Pierre           *
*      BOIS D'ARCY (78)        *
*          JN18AT              *
