;    "Digital" Frequency display with /64 prescaler & no offsets
;    Crystal freq. = 4.000MHz +/- a bit
;    First, let us choose our weapon - 16F84 or 16F628
;    Comment out the next line [;#define F84] if using a 16F628
#define    F84
#ifndef    F84
    #define    F628
#endif
;    Some Testing Stuff(tm)
;#define    testing        1    ; Comment out when testing finished
;#define    Two_Line    1    ; Un-comment for two line displays
;************************ REVISION HISTORY *************************
;    FM1.000    Originally from FM3/4 9:39pm 14 May 2002
;        As implemented in experimental 3.5MHz receiver
;    FM1.003    Fixed? major silliness in LO-IF code
;        Re-wrote USB/LSB suffix code
;        Added #defines for crook displays
;        Added #defines for two line displays
;        Wrapped #ifdef ... endif around debugging code
;    FM1.004    Added code to allow user to fix crook display
;        Deleted #defines for crook displays
;        Pin 18 is now input. 1 = good display, 0 = crook
;    FM2.000    New Hardware! Deleted external counter & gating
;        Now uses the same scheme as the LC Meter, with the
;        third byte of the count implemented in the PIC.
;        Basically, the "output" of the timer register is
;        counted within the gate timing loop.
;    FM2.001    Discovered that I don't need to use RA0 as a gate
;        cos RA4 can be used as a timer input, even when
;        defined as an output - all that is required is to
;        set it high to count or low to inhibit.
;        Jeez, Microchip are smart arses.
;        I dunno why I didn't spot this long ago.
;        (Can't be used on the LC Meter, cos its oscillator
;        needs to be clamped HIGH, not low as in this case).
;    FM2.002    Added 9600 baud serial output via RA0
;    FM2.003    Rewrote RollOver subroutine to use INTCON,T0IF bit.
;        Incorporated two bits from OvrFlow counter
;        to extend range to over 80MHz.
;    FM2.004    Changed to 32 bit counting.
;    FM2.005    Added "Calibrate" mode.
;    FM2.006    Moved "divide by 4" to increase resolution of
;        the stored IF offsets
;    FM2.007    Moved "check for rollover" out of the inner MS400
;        timing loop and adjusted loop count appropriately
;        The aim - to improve the resolution of the software
;        calibration by a factor of around 13 to 15 times.
;    fm2b.007    Ported to 16F628
;    FM2c.007    Introduced macros
;    fm2.008        Renumbered
;    fm2.009        Cleaned up AM IF Offset calculation
;            Converted some inline code to subroutines
;            Created new 32 bit "copy" macro
;            Adjusted calibration slightly
;            Added a "Processor =" message
;            Removed advertising.
;    ghzfm.000    Added multiply by 64
;            Rendered offsets ineffective
;            changed display format to
;            xxxx.xxxxxx MHz
;            Gate time now 1.000 Second
;o-----o-----o-----o-----o-----o-----o-----o-----o-----o-----o-----o
;    Some frequently used code fragments
;    Use macros to make mistreaks consistently.
;    Select Register Bank 0
bank0    macro
    errorlevel    +302        ; Re-enable bank warning
    bcf        STATUS,RP0    ; Select Bank 0
    endm
;    Select Register Bank 1
bank1    macro
    bsf        STATUS,RP0    ; Select Bank 1
    errorlevel    -302        ; disable warning
    endm
;    Copy a 32 bit thing from one place to another
copy    macro    from,to
    movf    from+0,W
    movwf    to+0
    movf    from+1,W
    movwf    to+1
    movf    from+2,W
    movwf    to+2
    movf    from+3,W
    movwf    to+3
    endm
;    CPU configuration
#ifdef    F84
    MESSG        "Processor = 16F84"
    #define     RAMStart    0x0C    ; by VK3BHR
    processor    16f84
    include        <p16f84.inc>
    __config    _HS_OSC & _PWRTE_ON & _WDT_OFF
#endif
#ifdef    F628
    MESSG        "Processor = 16F628"
    #define     RAMStart    0x20
    processor    16f628
    include        <p16f628.inc>
    __config    _HS_OSC & _PWRTE_ON & _WDT_OFF & _CP_OFF & _BODEN_ON & _LVP_OFF
#endif
;    I/O configuration
#define S_out    PORTA,0x00    ; 9600 baud serial out
#define PUFF    PORTA,0x00    ; Testing counter out
;#define    FIXIT    PORTA,0x01    ; 1 = "good display"
                ; 0 = do CRLF at "chr 8"
#define    PSC    PORTA,0x01    ; 1 = multiply by 64
#define    ENA    PORTA,0x02    ; Display "E"
#define    RS    PORTA,0x03    ; Display "RS"
#define    CLAMP    PORTA,0x04    ; Pull-down the timer input
#define    Store    PORTB,0x04    ; Pin 10, 0 = Measure BFO
#define    Add_LO    PORTB,0x05    ; Pin 11, 0 = RF := LO + IF
                ;         1 = RF := | LO + (-IF) |
#define    BFO_Lo    PORTB,0x06    ; Pin 12, 0 = BFO on lower freq.
#define    BFO_Hi    PORTB,0x07    ; Pin 13, 0 = BFO on higher freq.
#define    Prg_FLG    FLAGS,0x05
#define    AMflag    FLAGS,0x03    ; 0 = Don't print USB/LSB suffix
#define    beq    bz        ; Motorola syntax branches
#define    BEQ    bz
#define    BNE    bnz
#define    bne    bnz
#define    BCC    bnc
#define    bcc    bnc
#define    BCS    bc
#define    bcs    bc
#define    BRA    goto
#define    bra    goto
;    file register declarations: uses only registers in bank0
;    bank 0 file registers begin at 0x20 in the 16F628
    cblock    RAMStart
    dbg0:4            ; Debugging stuff
    dbg1:4
    dbg2:4
    dbg3:4
    dbg4:4
    dbg5:4
    bcd:5            ; BCD, MSD first 
    SBflag            ; 0 = Lower BFO frequency
                ; 1 = Higher
    COUNT            ; Bin to BCD convert (bit count)
    cnt            ;                    (BCD BYTES)
    CHR
    TEMP            ; DATS/Putchr temporary
    pmsg_t            ; Used by PMSG
    FLAGS
    S_Wtemp            ; "debug" Variables
    S_count
    D_Wtemp
    D_Stemp
    D_FSR
    D_hex
    endc
#ifdef    F84
Part2    equ    D_hex+1        ; Just tack on end
#endif
#ifdef    F628
Part2    equ    0x70        ; $70-7F Visible from all banks
#endif
    cblock    Part2
    COUNT1            ; Used by delay routines
    COUNT2            ; Timing (100ms)
    COUNT3            ; Timing (100ms)
    COUNT4            ; Timing (400ms)
    AccA:4            ; Binary, MSByte first
    AccB:4            ; Intermediate frequency
    Hold:4            ; Used in "cal" mode
    endc
;    Begin Executable Stuff(tm)
    org    0
GO    clrwdt            ; 0 << Reset
    clrf    INTCON        ; 1 No interrupts
#ifdef    F628
    movlw    0x07        ; 2 Comparator off
    movwf    CMCON        ; 3
#endif
    goto    START        ; 4 << Interrupt.
;    Part of string printer
pmsub    movwf    PCL        ; Goto W
    nop            ; Just in case
pm_end    return
;    Text Strings (stored in RETLWs)
mhz    dt    " MHz",0
Spaces    dt    " ",0
USB    dt    "U",0
LSB    dt    "L",0
Prog    dt    "P",0
Cal    dt    "C",0
#ifdef    Two_Line
adv3    dt    "1234567890ABCDEF",0
 endif
;    Main Program
START    call    InitIO        ; INITIALISE PORTS
    CLRF    PORTA
    CLRF    PORTB
    bsf    S_out        ; Serial output to idle
    CALL    LCDINIT         ; INITIALIZE LCD MODULE    
;    MOVLW    adv1        ; Sign on
;    call    pmsg
;    btfss    FIXIT        ; Test input 1 = just return
;    CALL    LINE2        ; 0 = fix bad display
;    movlw    adv2
;    call    pmsg
;    CALL    MS512        ; Delay for about 1 sec.
;    CALL    MS512        ; 0.512 sec x 2
    CALL    CLEAR
;    Check if in "Calibrate" mode
    btfsc    Store        ; If grounded initially
    goto    newbit        ; then were in "cal"
    MOVLW    0xfa        ; Set initial counter        
    MOVWF    Hold+0        ; value
    MOVLW    0xff        ; 
    MOVWF    Hold+1        ; for a 4 MHZ XTAL
    MOVLW    0x5f
    MOVWF    Hold+2            
    MOVLW    0x00        ; Unused
    MOVWF    Hold+3            
GetCal    call    Measure    
    call    Display
    movlw    Cal        ; Say "we're calibrating"
    call    pmsg
    CALL    HOME
;    Adjust Cal value
cal_dn    btfsc    BFO_Lo
    goto    cal_up
    incf    Hold+2,f    ; Add 1
    bne    inc_xit
    incf    Hold+1,f
    bne    inc_xit
    incf    Hold+0,f
inc_xit    goto    StorCal
cal_up    btfsc    BFO_Hi
    goto    StorCal
;    Hold := Hold + (1-)    ; Subtract 1
Hadd_2    movlw    0xff        ; Process LS byte
    addwf    Hold+2,F
    bcc    Hadd_1        ; If no carry,do next
    incf    Hold+1,f    ; Else roll over higher
    bne    Hadd_1        ; bytes as appropriate
    incf    Hold+0,f    ; may roll over MSByte
Hadd_1    movlw    0xff        ; Process next byte
    addwf    Hold+1,F
    bcc    Hadd_0        ; If no carry,do next
Hadd_0    movlw    0xff        ; Process next byte
    addwf    Hold+0,F
;    Time to save "Cal" value?
StorCal    btfss    Store        ; Ready to store it?
    goto    GetCal
    call    MS512        ; Delay 0.5 sec
    btfss    Store        ; De-bounce
    goto    GetCal
    copy    Hold,AccB    ; Write EEPROM from AccB
    movlw    0x10        ; EEADR of Cal value
    call    EE_WR
;    Begin a new measurement cycle
newbit    movlw    0x10        ; EEADR of Cal value
    call    EE_RD        ; in AccB
    copy    AccB,Hold    ; Get timing "constant"
    call    HOME        ; Display ready
    clrf    SBflag        ; 0 = Lower BFO frequency
                ; 1 = Higher
    bcf    AMflag        ; 0 = No USB/LSB suffix
    bcf    Prg_FLG
    btfsc    Store        ; Doing "BFO STORE"?
    goto    GetOffs
    btfsc    Store        ; De-bounce
    goto    GetOffs
GetIf    call    Measure        ; Get freq in AccA:4
    copy    AccA,AccB    ; For EEPROM Writing
    call    Display        ; Display freq in AccA
    movlw    Prog        ; Say "we're programming"
    call    pmsg
    CALL    HOME
    goto    GetIf
    goto    GetIf
    bsf    Prg_FLG        ; Flag "to be stored"
GetOffs    btfss    BFO_Hi        ; Which Offset??
    goto    Get2        ; Point @ EEPROM
    btfss    BFO_Lo        ; 4 bytes each
    goto    Ch2        ; BFO low link only
    goto    Ch3        ; No links
Get2    btfss    BFO_Lo
    goto    Ch0        ; Both links
    goto    Ch1        ; BFO high link only
Ch0    movlw    0x00        ; Offset channel 0 (both links fitted)
    goto    EndOff
Ch1    bsf    AMflag        ; We're gunna print
    comf    SBflag,f    ; that BFO is on higher frequency
    movlw    0x04        ; Offset channel 1 (BFO_Hi link fitted)
    goto    EndOff
Ch2    bsf    AMflag        ; We're gunna print
                ; that BFO is on lower frequency
    movlw    0x08        ; Offset channel 2 (BFO_Lo link fitted)
    goto    EndOff
Ch3    movlw    0x0C        ; Offset channel 3 (no links fitted)
;    goto    EndOff
EndOff    btfsc    Prg_FLG        ; Storing Offset?
    goto    Do_St        ; If not, then
    call    EE_RD        ; must be reading.
    goto    Do_Meas
Do_St    call    EE_WR
;    Now have IF in AccB
Do_Meas    call    Measure        ; Measure Local Osc Freq.
;    Now have LO in "AccA"
;        and  IF in "AccB"
Add_Sub    btfss    Add_LO        ; Add or Sub LO freq?
    goto    AddLSB        ; Clear = just add
    call    MinusA        ; RF := |IF - LO|
                ; SBflag is OK
AddLSB    call    AplusB
;    Fix overflow. If negative then make positive
    btfss    AccA+0,7    ; Set? (=Overflow)
    goto    OK2go        ; Clear = OK 2 print
    call    MinusA        ; Make positive and
    comf    SBflag,f    ; Swap USB/LSB
;    Display resulting number in AccA
OK2go    call    Display        ; display result at last
;    Print suffix - USB, LSB or nuffin
;    Now disabled
    btfsc    AMflag        ; Do we print at all?
    goto    trySBf
    movlw    Spaces        ; nuffin = spaces
    goto    EndMsg
trySBf    btfsc    SBflag,0    ; Which sideband?
    goto    pLSB
    movlw    USB        ; USB obviously
    goto    EndMsg
pLSB    movlw    LSB        ; LSB
;    goto    EndMsg
EndMsg    call    pmsg        ; Print selected trailer
#ifdef    Two_Line
    CALL    LINE2        ; WRITE second LINE
    movlw    adv3
    call    pmsg
 endif
    goto    newbit        ; Start next measurement
;    AccA := AccA + AccB
AplusB    movf    AccB+3,W    ; Process LSB
    addwf    AccA+3,F
    bcc    Add_2        ; If no carry,do next
    incf    AccA+2,f    ; Else roll over higher
    bne    Add_2        ; bytes as appropriate
    incf    AccA+1,f
    bne    Add_2
    incf    AccA+0,f    ; may roll over MSByte
Add_2    movf    AccB+2,W    ; Process next byte
    addwf    AccA+2,F
    bcc    Add_1        ; If no carry,do next
    incf    AccA+1,f    ; Else roll over higher
    bne    Add_1        ; bytes as appropriate
Add_1    movf    AccB+1,W    ; Process next byte
    addwf    AccA+1,F
    bcc    Add_0        ; If no carry,do next
Add_0    movf    AccB+0,W    ; Process next byte
    addwf    AccA+0,F
    return
;    Negate number in AccA (2's complement form)
MinusA    comf    AccA+0,f    ; Complement all bits
    comf    AccA+1,f    ; of number
    comf    AccA+2,f
    comf    AccA+3,f
    incf    AccA+3,f    ; Add 1
    bne    N_xit
    incf    AccA+2,f
    bne    N_xit
    incf    AccA+1,f
    bne    N_xit
    incf    AccA+0,f
N_xit    return
;    Divide AccA:4 by 4
Div4    call    Div2        ; Divide AccA:4 by 4
;    Divide AccA:4 by 2
Div2    rrf    AccA+0,f
    rrf    AccA+1,f    
    rrf    AccA+2,f
    rrf    AccA+3,f
    bcf    AccA+0,7    ; Possible bad carry in.
    return
;    Multiply AccA:4 by 64
Mul64    call    Mul2
    call    Mul2
    call    Mul2
    call    Mul2
    call    Mul2        ; then fall through
;    Multiply AccA:4 by 2
Mul2    rlf    AccA+3,f
    rlf    AccA+2,f    
    rlf    AccA+1,f
    rlf    AccA+0,f
    bcf    AccA+3,0    ; Possible bad carry in.
    return
;    Print String addressed by W
;    Note: Strings are in program space
pmsg    movwf    pmsg_t        ; Temp for pointer
pm1    movf    pmsg_t,W    ; Get current pointer
    call    pmsub
    andlw    0xff        ; Test returned value
    beq    pm_end        ; NULL = All done
    call    DATS
    incf    pmsg_t,F
    goto    pm1
;    Delay for 1000ms (trimmed for actual clock freq)
;    Check for Timer register roll over and count 'em
;    Uses: W, COUUNT1, COUNT2, COUNT3 & others
MS1000    MOVF    Hold+0,w    ; 100 MS DELAY LOOP        
    MOVWF    COUNT1        ; 4 MHZ XTAL
    MOVF    Hold+1,w    ; Count up
    MOVWF    COUNT2        ; to 24 bit overflow
    MOVF    Hold+2,w
    MOVWF    COUNT3
L3    INCFSZ    COUNT3,F
    GOTO    L3
    call    RollOver    ; Check for Timer0 RollOver
    INCFSZ    COUNT2,F
    GOTO    L3
    INCFSZ    COUNT1,F
    GOTO    L3
    RETLW    0
;    SEND A COMMAND BYTE TO LCD DISPLAY MODULE    
STROBE    BCF    RS        ; SELECT COMMAND REGISTER
    GOTO    CM
;    Put a BCD nybble to display
PutNyb    ANDLW    0x0F        ; MASK OFF OTHER PACKED BCD DIGIT
    ADDLW    0x30        ; Convert BIN to ASCII
;    Put a data byte to display
DATS    movwf    TEMP        ; Save character for LCD
    call    putchr
    movf    TEMP,w
    BSF    RS        ; SELECT DATA REGISTER
CM    MOVWF    CHR        ; STORE CHAR TO DISPLAY
    SWAPF    CHR,W        ; SWAP UPPER AND LOWER NIBBLES (4 BIT MODE)
    call    PB_dly
    MOVF    CHR,W        ; GET CHAR AGAIN 
;    Put 4 bits to LCD & wait (untrimmed)
PB_dly    ANDLW    0x0F        ; MASK OFF UPPER 4 BITS
    MOVWF    PORTB        ; SEND DATA TO DISPLAY        
    BSF    ENA        ; ENA HIGH
    NOP            
    BCF    ENA        ; ENA LOW 
                ; Fall into 200us DELAY subroutine
;    Delay for 200us (untrimmed)
;    Uses: W, COUNT1
D200us
DELAY    MOVLW    0x42        ; DELAY 200us
    MOVWF    COUNT1    
NXT5    DECFSZ    COUNT1,F
    GOTO    NXT5    
    RETLW    0
;    Delay for 2ms (untrimmed)
;    Uses: W, COUNT2, COUNT1
MS2    MOVLW    0x0A        ; DELAY 2ms
    MOVWF    COUNT2
LP15    call    D200us
    DECFSZ    COUNT2,F
    GOTO    LP15
    RETLW    0        
;    Delay for 512ms (untrimmed)
;    Uses: W, COUNT3, COUNT2, COUNT1
MS512    clrw            ; 0 -> 256 loops
;    Delay for multiples of 2ms (untrimmed)
MS2xW    MOVWF    COUNT3    
LPx15    call    MS2
    DECFSZ    COUNT3,F
    GOTO    LPx15
    RETLW    0        
;    Convert 32-bit binary number at <AccA:4> into a bcd number
;    at <bcd:5>. Uses Mike Keitz's procedure for handling bcd 
;    adjust. Microchip AN526
B2_BCD
b2bcd    movlw    .32        ; 32-bits
    movwf    COUNT        ; make cycle counter
    clrf    bcd+0        ; clear result area
    clrf    bcd+1
    clrf    bcd+2
    clrf    bcd+3
    clrf    bcd+4
b2bcd2  movlw    bcd        ; make pointer
    movwf    FSR
    movlw    .5        ; Number of BCD bytes?
    movwf    cnt        ; 2 BCD digits per byte
; Mike's routine:
b2bcd3    movlw    0x33    
        addwf    INDF,f        ; add to both nybbles
        btfsc    INDF,3        ; test if low result > 7
        andlw    0xf0        ; low result >7 so take the 3 out
        btfsc    INDF,7        ; test if high result > 7
        andlw    0x0f        ; high result > 7 so ok
        subwf    INDF,f        ; any results <= 7, subtract back
        incf    FSR,f        ; point to next
        decfsz    cnt,f
        goto    b2bcd3
        rlf    AccA+3,f    ; get another bit
        rlf    AccA+2,f
        rlf    AccA+1,f
        rlf    AccA+0,f
        rlf    bcd+4,f        ; put it into bcd
        rlf    bcd+3,f
        rlf    bcd+2,f
        rlf    bcd+1,f
        rlf    bcd+0,f
        decfsz    COUNT,f        ; all done?
        goto    b2bcd2        ; no, loop
        return            ; yes
;*********** INITIALISE LCD MODULE 4 BIT MODE ***********************
LCDINIT    CALL    MS512        ; Wait 0.512 sec for LCD  RESET
    BCF    RS        ; REGISTER SELECT LOW
    BCF    ENA        ; ENABLE LINE LOW
    MOVLW    0x03        ; 1
    call    PB_dly
    CALL    MS512        ; WAIT FOR DISPLAY TO CATCH UP
    MOVLW    0x03        ; 2
    call    PB_dly
    MOVLW    0x03        ; 3
    call    PB_dly
    MOVLW    0x02        ; Fn set 4 bits
    call    PB_dly
    MOVLW    0x28        ; DISPLAY 2 Line , 5x7 Dot's
    CALL    STROBE        ; Suggested by PA0EJH
    CALL    DELAY        
    MOVLW    0x0C        ; 0x0C DISPLAY ON
    CALL    STROBE
    CALL    DELAY        
    MOVLW    0x06        ; 0x06 ENTRY MODE SET
    CALL    STROBE
    CALL    DELAY
    MOVLW    0x01        ; 0x01 CLEAR DISPLAY
    CALL    STROBE
    CALL    MS2
    RETLW    0
;************ MOVE TO START OF LINE 2 *****************
LINE2    MOVLW    0xC0        ; ADDRESS FOR SECOND LINE OF DISPLAY
    CALL    STROBE
    goto    DELAY
;************ CLEAR DISPLAY ***************************
CLEAR    MOVLW    0x01        ; COMMAND TO CLEAR DISPLAY
    CALL    STROBE
    goto    MS2        ; LONGER DELAY NEEDED WHEN CLEARING DISPLAY
;*********** MOVE TO HOME *****************************
HOME    call    crlf        ; Serial
    MOVLW    0x02        ; COMMAND TO HOME LCD DISPLAY
    CALL    STROBE
    goto    MS2
;       Initialise Input & Output devices
InitIO    bank1
    movlw    0x37        ; Option register
    movwf    OPTION_REG    ; Port B weak pull-up enabled
                ; INTDEG Don't care
                ; Count RA4/T0CKI
                ; Count on falling edge
                ; Prescale Timer/counter
                ; divide Timer/counter by 256
                ; PORTA:-
    movlw    0x02        ; initialise data direction
                ; 1 = input, 0 = output
                ; PORTA has 5 pins     4 3 2 1 0
                ; 0x02       =   0 0 0 0 0 0 1 0
    movwf    TRISA        ; PORTA<0>   = Serial + Debugging Out
                ; PORTA<1>   = FIXIT (input)
                ; PORTA<2>   = LCD "E" Out
                ; PORTA<3>   = LCD "RS" Out
                ; PORTA<4>   = "Input" with pull-down
                ;              Actually an output.
                ; PORTA<5:7> = not implemented in 16F84
                ; PORTB:-
    movlw    0xf0        ; initialise data direction
                ; PORTB has 8 pins
                ; port pin       7 6 5 4 3 2 1 0
                ; 0xf0       =   1 1 1 1 0 0 0 0
    movwf    TRISB        ; PORTB<0>   = LCD "DB4"
                ; PORTB<1>   =     "DB5"
                ; PORTB<2>   =     "DB6"
                ; PORTB<3>   =     "DB7"
                ; PORTB<4>   = Input
                ; PORTB<5>   = Input
                ; PORTB<6>   = Input
                ; PORTB<7>   = Input
    bank0
    return    
;    Measure Frequency. Stash in "AccA:4"
Measure    bcf    CLAMP        ; CLOSE GATE for safety
    bsf    PORTB,2        ; For compatibility with
    bsf    PORTB,3        ; Version 1 hardware
    bcf    INTCON,T0IF    ; Clear any previous overflow
    CLRF    TMR0        ; RESET INTERNAL COUNT (INCLUDING PRESCALER)
                ; See page 27 Section 6.0
    CLRF    AccA+0        ; Ready to receive 32 bit number
    CLRF    AccA+1
    CLRF    AccA+2
    CLRF    AccA+3
    bsf    CLAMP        ; OPEN GATE
    CALL    MS1000        ; 1.0 sec DELAY
    bcf    CLAMP        ; CLOSE GATE (COUNT COMPLETE)
    nop            ; and allow time for
    nop            ; the registers to catch up
    nop
    nop
    nop
    call    RollOver    ; Final check, just in case
    MOVF    TMR0,W        
    MOVWF    AccA+2
;    Now empty the prescaler
PSC1    bank1
    bcf    OPTION_REG,T0SE    ; Clock the prescaler
    nop
    bsf    OPTION_REG,T0SE
    bank0
    DECF    AccA+3,F    ; Decrement the counter
    movf    TMR0,W        ; Has TMR0 changed?
    xorwf    AccA+2,W    ; if unchanged, XOR -> 0
    beq    PSC1
; AccA : AccA+1 : AccA+2 : AccA+3 now holds 32 bit result
; Rollover subroutine has set AccA+0 and AccA+1 suitably.
    return
;    Account for TMR0 overflows when counting
;    Check at regular intervals and handle as
;    necessary.
;    Needs to be done at less than 936us (@ 70MHz in)
;    intervals, or else it can lose counts.
RollOver
    btfss    INTCON,T0IF    ; Rolled over?
    goto    RO3        ; No
RO1    bcf    INTCON,T0IF    ; Yes. ACK!
    INCF    AccA+1,f    ; Count it
    bne    RO2        ; Overflowed?
    incf    AccA+0,f    ; No need to check
RO2    return
;    Balance path lengths
RO3    nop
    nop
    goto    RO2
;    Display frequency
;    Display contents of AccA+0...AccA+3 on LCD
;    First convert to BCD, Then ASCII (nybble at a time)
;    In this version, multiply ACCA:4 by 64 since gate
;    time = 1.0 second and ext prescale=64
Display    btfsc    PSC        ; 1 = prescaler active = *64        
    call    Mul64        ; Account for prescaler
    CALL    B2_BCD        ; CONVERT all AccA TO BCD
;    Perform Leading Zero Blanking on first 3 digits
    swapf    bcd+0,W        ; 1000's of MHz
    andlw    0x0F        ; MASK OFF OTHER PACKED BCD DIGIT
    bne    NoB1K
    MOVLW    0x20        ; YES PRINT A BLANK SPACE
    CALL    DATS
    movf    bcd+0,W        ; 100's of MHz
    bne    NoB100
    CALL    DATS
    swapf    bcd+1,W        ; 10's of MHz
    bne    NoB10
    CALL    DATS
    goto    NoB1
;    Handle rest of number non blanked
NoB1K    SWAPF    bcd+0,W        ; 1000's of MHz
    CALL    PutNyb
NoB100    MOVF    bcd+0,W        ; 100's of MHz
    CALL    PutNyb
NoB10    SWAPF    bcd+1,W        ; 10's of MHz
    CALL    PutNyb
NoB1    MOVF    bcd+1,W        ; 1's of MHz
    CALL    PutNyb
    MOVLW    '.'        ; Decimal Point
    CALL    DATS
    SWAPF    bcd+2,W        ; 100's of KHz
    CALL    PutNyb
    MOVF    bcd+2,W        ; 10's of KHz
    CALL    PutNyb
    SWAPF    bcd+3,W        ; 1's of KHz
    CALL    PutNyb
    CALL    LINE2
    MOVF    bcd+3,W        ; 100's of Hz
    CALL    PutNyb
    SWAPF    bcd+4,W        ; 10's of Hz
    CALL    PutNyb
    MOVF    bcd+4,W        ; 1's of Hz
    CALL    PutNyb
    movlw    mhz        ; WRITE " Mhz" AT end OF LINE
    goto    pmsg        ; includes RETURN
;    Read EEPROM into "AccB"  (AccB must be visible in both
;    W -> memory to read          memory banks 0 & 1)
EE_RD
#ifdef    F628
    bank1
#endif
    MOVWF    EEADR        ; Address to read
#ifdef    F628
    bank0
#endif
    XORLW    0x0C        ; Special case (no links)
    BEQ    AVERAGE
    CALL    EE_R
    MOVWF    AccB+0
    CALL    EE_Rinc
    MOVWF    AccB+1
    CALL    EE_Rinc
    MOVWF    AccB+2
    CALL    EE_Rinc
    MOVWF    AccB+3
    RETURN
#ifdef F84
EE_Rinc    INCF    EEADR,F        ; bump address
EE_R    bank1
    BSF    EECON1,RD    ; EE Read
    bank0
    MOVF    EEDATA,W    ; W = EEDATA
    RETURN
#endif
#ifdef    F628
EE_Rinc    bank1
EE_R    bank1
    bank0
    RETURN
#endif
AVERAGE    movlw    0x04        ; AM - use avg BFO freq.
    call    EE_RD        ; Read in one BFO freq
    copy    AccB,AccA    ; Into AccA
    movlw    0x08        ; Then second
    call    EE_RD        ; into AccB
    call    AplusB        ; Add 'em
    call    Div2        ; get average in AccA
    copy    AccA,AccB    ; and in AccB
    return
;    Write EEPROM from "AccB"  (AccB must be visible in both
;    W -> memory to write          memory banks 0 & 1)
#ifdef    F84
EE_WR    MOVWF    EEADR        ; Address to write
    MOVF    AccB+0,W    ; Data byte #0
    CALL    EE_W
    MOVF    AccB+1,W    ; Data byte #1
    CALL    EE_Winc
    MOVF    AccB+2,W    ; Data byte #2
    CALL    EE_Winc
    MOVF    AccB+3,W    ; Data byte #3
    CALL    EE_Winc
    RETURN
EE_Winc    INCF    EEADR,F        ; bump address
EE_W    MOVWF    EEDATA
    bank1
    BSF    EECON1,WREN    ; Enable Write
    MOVLW    0x55        ;
    MOVWF    EECON2        ; Write 0x55
    MOVLW    0xAA        ;
    MOVWF    EECON2        ; Write 0xAA
    BSF    EECON1,WR    ; Set WR bit (begin write)
EE_W2    BTFSC    EECON1,WR    ; Wait for write to finish
    GOTO    EE_W2
    BCF    EECON1,EEIF    ; clear interrupts
    bank0
    RETURN    
#endif
#ifdef    F628
EE_WR    bank1
    CALL    EE_W
    CALL    EE_Winc
    CALL    EE_Winc
    CALL    EE_Winc
    bank0
    RETURN
    errorlevel    -302    ; In Bank 2
EE_W    MOVWF    EEDATA
    MOVLW    0x55        ;
    MOVLW    0xAA        ;
    GOTO    EE_W2
    bank0
    BCF    PIR1,EEIF    ; clear interrupts
    bank1
    RETURN    
    errorlevel    +302
#endif
;    Testing counter 
ctest    movlw    0xfe        ; MS byte of loop count
    movwf    COUNT3        ; Counted upward till it overflows
    movlw    0x1d
    movwf    COUNT2
    movlw    0xc0
    movwf    COUNT1
cloop    bcf    PUFF        ; Toggle counter input once
    bsf    PUFF
    incfsz    COUNT1,f
    goto    cloop
    incfsz    COUNT2,f
    goto    cloop
    incfsz    COUNT3,f
    goto    cloop
    return
;    Debugging Memory & Register dump
debug
    MOVWF    D_Wtemp        ; Copy W to temp register,
    SWAPF    STATUS,W    ; Swap status to be saved into W
    MOVWF    D_Stemp        ; Save status to D_Stemp register
    movf    FSR,W        ; Save FSR
    movwf    D_FSR
    movlw    0x57        ; W=
    call    putchr
    movlw    0x3d
    call    putchr
    movf    D_Wtemp,w
    call    hex_2
    movlw    0x20        ; 2 spaces, just to be neat
    call    putchr
    movlw    0x20
    call    putchr
    movlw    0x53        ; SR=
    call    putchr
    movlw    0x52
    call    putchr
    movlw    0x3d
    call    putchr
    movf    D_Stemp,w
    call    hex_2
    call    crlf        ; Serial
    clrf    FSR        ; Ready for memory dump
D_loop    movf    0,W        ; Read indirect
    call    hex_2
    movlw    0x20
    call    putchr
    incf    FSR,f        ; to next byte
    movf    FSR,w        ; end of line?
    andlw    0x0F
    bne    next_ln
    call    crlf
    bra    chk4end
next_ln    andlw    0x03        ; Groups of 4
    bne    chk4end
    movlw    0x20
    call    putchr
chk4end    movf    FSR,w        ; All done?
    xorlw    0x80
    bne    D_loop
    call    crlf
    call    crlf
    movf    D_FSR,W        ; Restore FSR
    movwf    FSR
    SWAPF    D_Stemp,W    ; Swap nibbles in D_Stemp register
                ; and place result into W
    MOVWF    STATUS        ; Move W into STATUS register
                ; (sets bank to original state)
    SWAPF    D_Wtemp,F    ; Swap nibbles in D_Wtemp and place result in D_Wtemp
    SWAPF    D_Wtemp,W    ; Swap nibbles in D_Wtemp and place result into W
    return
;    Print CRLF to serial
crlf    movlw    0x0d        ; CRLF
    call    putchr
    movlw    0x0a
    goto    putchr
;    Print W as 2 Hex digits
hex_2    movwf    D_hex
    swapf    D_hex,w        ; Get big bit
    call    hex_3
    movf    D_hex,w        ; Get little bit
hex_3    andlw    0x0f        ; keep bottom 4 bits
    addlw    0xF6
    bcc    hex_4
    addlw    0x07        ; binary A -> ASCII A
hex_4    addlw    0x3A        ; binary 0 -> ASCII 0
;    goto    putchr
;    Output Routines for PIC16F84
;    Clock is 4.0 MHz.
;    ie. 1.0 us per cycle = 4/Fosc.
;    9600 Baud  = 104.17 us
;               = 104.17   CPU cycles
;    Output the character in W. Assumes Mac is ready.
;    Uses W
putchr    movwf    S_Wtemp        ; Character being output
    movlw    0x08        ; Bit count
    movwf    S_count
    bcf    S_out        ; Send a 0 - Start bit
put_clp    movlw    0xE7        ; Delay "104" cycles
txd_0    addlw    0x01
    bne    txd_0
    rrf    S_Wtemp,f    ; Transmit a bit
    bcs    t_0
    bra    tx_1
t_0    bsf    S_out        ; Send a 1
tx_1    decfsz    S_count,f    ; Done all bits?
    goto    put_clp
    movlw    0xE7        ; Delay for last data
txd_1    addlw    0x01
    bne    txd_1
    bsf    S_out        ; Transmit two stop bit
    movlw    0xCD
txd_9    addlw    0x01
    bne    txd_9
    return
;    Tail End Charlie
; initialize eeprom locations
        ORG 0x2100
        DE  0x00, 0x00, 0x00, 0x00    ; Unused (reserved for later)
        DE  0x00, 0x00, 0x00, 0x00    ; IF Offset 1 Low  BFO ????
        DE  0x00, 0x00, 0x00, 0x00    ; IF Offset 2 High BFO ????
        DE  0x00, 0x00, 0x00, 0x00    ; IF Offset 3 No   BFO -AM-
        DE  0xfa, 0xff, 0x5f, 0x00    ; 4.000 MHz initial calibration
     END
