Freq range: Downlink (direction is the BTS): 2110-2170 MHz Uplink the empowerer is the BTS): 1920-1980 MHz Profit Downlink: 70dB Uplink: 65 dB Outer performance (kimenő teljesítmény): Downlink 27 dBm Uplink: 27 dBm Impedance: -40 DBc max (Dual Band Spacing 5 MHz) Inter-modulation attenuation: -40 DBc max (Dual Band Spacing 5 MHz) In-band fluctiation: max 5 db Empowering setting – Setting range: 31 dB / 1 db léptető (error + - 1,5 dB) Noise range-illustration: max 5 db Port VSWR: max 2.0 Operating power (DC): 1.6 A Power supply: 110-230 V Operating temperature: -25 ° C és +55 ° C Operating moisture: 5%-tól 95% Size: 28 cm x 18 cm x 6 cm
